Pretty sure it’s the right way round… tried in both orientations anyway, still no luck.
Settled on contacts towards the inside of the board… that is correct, right?
DMESG output:
[code][ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3531) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb6000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc0fefd2000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb6000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29384(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3567872K/4159488K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 116480K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] boot misc1 0x90000000: expected 0x10000000
[ 0.000000] (comparison mask = 0xf8000000)
[ 0.000000] boot misc2 0x0: expected 0xf6e0f620
[ 0.000000] (comparison mask = 0xffffffff)
[ 0.000000] boot misc3 0xf5c1: expected 0x10000
[ 0.000000] PLL_D2 already enabled. Postponing set full defaults
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001493] Console: colour dummy device 80x25
[ 0.002432] console [tty0] enabled
[ 0.002459] kmemleak: Kernel memory leak detector disabled
[ 0.002487] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.002517] pid_max: default: 32768 minimum: 301
[ 0.002983] Security Framework initialized
[ 0.003221] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003242] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004512] ftrace: allocating 46802 entries in 183 pages
[ 0.175993] sched-energy: CPU device node has no sched-energy-costs
[ 0.176029] ASID allocator initialised with 65536 entries
[ 0.211807] tegra-id: chipid=22117.
[ 0.211851] tegra-id: opt_subrevision=0.
[ 0.211881] Tegra Speedo/IDDQ fuse revision 4
[ 0.211897] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211914] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.211931] Tegra: CPU Speedo Value 2014, SoC Speedo Value 1918, GPU Speedo Value 2019
[ 0.211952] Tegra: CPU IDDQ Value 1588, SoC IDDQ Value 1796, GPU IDDQ Value 2145
[ 0.211989] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.212015] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.212050] DTB Build time: Mar 15 2019 09:52:07
[ 0.261077] CPU1: Booted secondary processor [411fd071]
[ 0.293000] CPU2: Booted secondary processor [411fd071]
[ 0.324995] CPU3: Booted secondary processor [411fd071]
[ 0.325085] Brought up 4 CPUs
[ 0.325150] SMP: Total of 4 processors activated.
[ 0.325166] CPU features: detected feature: 32-bit EL0 Support
[ 0.325446] CPU: All CPU(s) started at EL2
[ 0.325476] alternatives: patching kernel code
[ 0.333797] devtmpfs: initialized
[ 0.368886] Initilizing CustomIPI irq domain
[ 0.369362] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369409] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.380813] pinctrl core: initialized pinctrl subsystem
[ 0.381529] OS set in device tree is not L4T.
[ 0.381969] regulator-dummy: no parameters
[ 0.382259] Initializing plugin-manager
[ 0.382415] Plugin module not found
[ 0.382631] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.383190] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.383955] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.387270] NET: Registered protocol family 16
[ 0.388719] pstore: using zlib compression
[ 0.389437] console [pstore-1] enabled
[ 0.389455] pstore: Registered ramoops as persistent store backend
[ 0.389474] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.405096] cpuidle: using governor menu
[ 0.409053] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.410629] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.410671] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413660] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.415199] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.416179] tegra_powergate_init: DONE
[ 0.416220] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.416258] DTB Build time: Mar 15 2019 09:52:07
[ 0.417950] Tegra reboot handler registered.
[ 0.422363] iommu: Adding device tegra-carveouts to group 0
[ 0.422543] platform tegra-carveouts: domain=ffffffc0f9bf03d8 allocates as[0]=ffffffc0f9b980a8
[ 0.422937] iommu: Adding device smmu_test to group 1
[ 0.423002] platform smmu_test: domain=ffffffc0f9bf0618 allocates as[0]=ffffffc0f9b98110
[ 0.423840] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.423918] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.423992] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.424014] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.424049] mc-err: mcerr ops are set to t21x
[ 0.433931] iommu: Adding device 70090000.xusb to group 2
[ 0.434249] iommu: Adding device 70006000.serial to group 3
[ 0.434354] platform 70006000.serial: domain=ffffffc0f9470618 allocates as[0]=ffffffc0f9b98178
[ 0.434802] iommu: Adding device 70006040.serial to group 4
[ 0.435102] iommu: Adding device 70006200.serial to group 5
[ 0.435344] iommu: Adding device sound to group 6
[ 0.435407] platform sound: domain=ffffffc0f9470b58 allocates as[0]=ffffffc0f9b981e0
[ 0.435992] iommu: Adding device 7000d400.spi to group 7
[ 0.436270] iommu: Adding device 7000d600.spi to group 8
[ 0.436567] iommu: Adding device 70410000.spi to group 9
[ 0.436882] iommu: Adding device 50000000.host1x to group 10
[ 0.437209] iommu: Adding device 54080000.vi to group 11
[ 0.437627] iommu: Adding device 54600000.isp to group 12
[ 0.437903] iommu: Adding device 54680000.isp to group 13
[ 0.438224] iommu: Adding device tegradc.0 to group 14
[ 0.438308] platform tegradc.0: domain=ffffffc0f947da98 allocates as[0]=ffffffc0f9b98248
[ 0.442565] platform tegradc.0: IOVA linear map 0x0000000092cb6000(800000)
[ 0.442982] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.443344] iommu: Adding device tegradc.1 to group 15
[ 0.443412] platform tegradc.1: domain=ffffffc0f947dcd8 allocates as[0]=ffffffc0f9b982b0
[ 0.447617] platform tegradc.1: IOVA linear map 0x0000000092cb6000(800000)
[ 0.448032] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.448296] iommu: Adding device 54340000.vic to group 16
[ 0.448526] iommu: Adding device 544c0000.nvenc to group 17
[ 0.448740] iommu: Adding device 54500000.tsec to group 18
[ 0.448973] iommu: Adding device 54100000.tsecb to group 19
[ 0.449208] iommu: Adding device 54480000.nvdec to group 20
[ 0.449450] iommu: Adding device 54380000.nvjpg to group 21
[ 0.450516] iommu: Adding device 546c0000.i2c to group 22
[ 0.450866] iommu: Adding device 57000000.gpu to group 23
[ 0.450937] platform 57000000.gpu: domain=ffffffc0f948ccd8 allocates as[0]=ffffffc0f9b98318
[ 0.450995] platform 57000000.gpu: domain=ffffffc0f948ccd8 allocates as[1]=ffffffc0f9b98380
[ 0.451056] platform 57000000.gpu: domain=ffffffc0f948ccd8 allocates as[2]=ffffffc0f9b983e8
[ 0.451115] platform 57000000.gpu: domain=ffffffc0f948ccd8 allocates as[3]=ffffffc0f9b98450
[ 0.452033] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.452079] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.452106] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.452128] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.452144] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.505184] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.505220] tegra-pmc: Clear bootloader IO dpd settings
[ 0.505254] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.505333] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.505657] iommu: Adding device 70012000.se to group 24
[ 0.506457] iommu: Adding device 7000c000.i2c to group 25
[ 0.506732] iommu: Adding device 7000c400.i2c to group 26
[ 0.507014] iommu: Adding device 7000c500.i2c to group 27
[ 0.507292] iommu: Adding device 7000c700.i2c to group 28
[ 0.507617] iommu: Adding device 7000d000.i2c to group 29
[ 0.507888] iommu: Adding device 7000d100.i2c to group 30
[ 0.508208] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.508279] platform sdhci-tegra.0: domain=ffffffc0f954be58 allocates as[0]=ffffffc0f9b984b8
[ 0.509177] iommu: Adding device 700d0000.xudc to group 32
[ 0.513845] vdd-ac-bat: 5000 mV
[ 0.514230] vdd-5v0-sys: 5000 mV
[ 0.515219] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.515307] vdd-5v0-hdmi: 5000 mV
[ 0.515752] vdd-1v8: 1800 mV
[ 0.516164] vdd-fan: supplied by vdd-5v0-sys
[ 0.516217] vdd-fan: 5000 mV
[ 0.516631] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.516709] vdd-usb-vbus: 5000 mV
[ 0.517294] vdd-usb-vbus2: 5000 mV
[ 0.546259] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548871] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.549496] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.557784] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.558184] SCSI subsystem initialized
[ 0.558431] libata version 3.00 loaded.
[ 0.558729] usbcore: registered new interface driver usbfs
[ 0.558804] usbcore: registered new interface driver hub
[ 0.558898] usbcore: registered new device driver usb
[ 0.563043] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.564732] random: fast init done
[ 0.568395] vdd-core: 600 <–> 1162 mV at 1125 mV
[ 0.569704] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.572378] vdd-ddr-1v1: 1150 mV
[ 0.576240] vdd-pre-reg-1v35: 1350 mV
[ 0.580285] vdd-1v8: 1800 mV
[ 0.580561] vdd-1v8: Failed to create debugfs directory
[ 0.584240] avdd-sys-1v2: 1200 mV
[ 0.588242] vdd-pex-1v0: 1050 mV
[ 0.589027] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.589701] max77620-ldo3: at 3100 mV
[ 0.592244] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.592879] max77620-ldo5: at 3100 mV
[ 0.593528] max77620-ldo6: at 2800 mV
[ 0.596261] avdd-1v05-pll: 1050 mV
[ 0.600240] avdd-io-hdmi-dp: 1050 mV
[ 0.601788] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.602124] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.604271] max77620 4-003c: max77620 probe successful
[ 0.606646] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.607201] media: Linux media interface: v0.10
[ 0.607267] Linux video capture interface: v2.00
[ 0.608270] pps_core: LinuxPPS API ver. 1 registered
[ 0.608295] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.608340] PTP clock support registered
[ 0.611766] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.618252] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.619191] Advanced Linux Sound Architecture Driver Initialized.
[ 0.619887] Bluetooth: Core ver 2.22
[ 0.619955] NET: Registered protocol family 31
[ 0.619974] Bluetooth: HCI device and connection manager initialized
[ 0.620004] Bluetooth: HCI socket layer initialized
[ 0.620030] Bluetooth: L2CAP socket layer initialized
[ 0.620068] Bluetooth: SCO socket layer initialized
[ 0.621925] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.621966] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.622026] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.622054] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.624897] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.626293] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.626383] vdd-3v3-sys: 3300 mV
[ 0.626668] vdd-1v8: supplied by vdd-3v3-sys
[ 0.629101] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629606] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.629668] vdd-3v3-sd: 3300 mV
[ 0.630951] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.631012] avdd-io-edp-1v05: 1050 mV
[ 0.631548] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.631601] vdd-usb-hub-en: 5000 mV
[ 0.632971] camchar: rtcpu character device driver loaded
[ 0.633782] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.635214] clocksource: Switched to clocksource arch_sys_counter
[ 0.675863] VFS: Disk quotas dquot_6.6.0
[ 0.676038] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.676563] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.677005] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.677055] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.677344] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.677371] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.677398] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.677446] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.677471] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.677502] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.677524] nvmap_page_pool_init: Total RAM pages: 1010752
[ 0.677542] nvmap_page_pool_init: nvmap page pool size: 126344 pages (493 MB)
[ 0.677675] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.678058] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.678975] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.687163] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.687604] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.687870] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.688110] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.688307] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.688614] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.688634] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.689088] NET: Registered protocol family 2
[ 0.690073] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.690307] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.690865] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.691049] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691151] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691645] NET: Registered protocol family 1
[ 0.692453] RPC: Registered named UNIX socket transport module.
[ 0.692479] RPC: Registered udp transport module.
[ 0.692497] RPC: Registered tcp transport module.
[ 0.692514] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.692540] PCI: CLS 0 bytes, default 64
[ 0.692779] Trying to unpack rootfs image as initramfs…
[ 0.702512] host1x 50000000.host1x: initialized
[ 0.704449] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.707757] audit: initializing netlink subsys (disabled)
[ 0.707852] audit: type=2000 audit(0.559:1): initialized
[ 0.708597] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.718656] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.720354] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.721197] 9p: Installing v9fs 9p2000 file system support
[ 0.724858] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.725041] io scheduler noop registered
[ 0.725352] io scheduler cfq registered (default)
[ 0.728148] gic 702f9000.agic: GIC IRQ controller registered
[ 0.731112] iommu: Adding device 702ef000.adsp to group 33
[ 0.738077] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.738257] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.738906] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8a09411
[ 0.738939] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.740798] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.740936] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.741048] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.741264] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.741380] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.741488] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.741602] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.741709] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.741819] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.741930] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.748302] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.749649] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.751687] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.752976] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.753342] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.754647] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.754899] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.755193] Adding domain tsec-pd to PM domain host1x-pd
[ 0.755371] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.758617] tsec 54500000.tsec: initialized
[ 0.760130] tsec 54100000.tsecb: initialized
[ 0.760880] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.764017] nvdec 54480000.nvdec: initialized
[ 0.765125] Adding domain vic03-pd to PM domain host1x-pd
[ 0.765328] Adding domain msenc-pd to PM domain host1x-pd
[ 0.765511] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.769139] falcon 54340000.vic: initialized
[ 0.770409] falcon 544c0000.nvenc: initialized
[ 0.771801] falcon 54380000.nvjpg: initialized
[ 0.776541] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.776679] display board info: id 0x0, fab 0x0
[ 0.776750] generic_infoframe_type: 0x87
[ 0.776892] tegradc tegradc.0: DT parsed successfully
[ 0.776952] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 0.777670] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 0.781098] tegradc tegradc.0: probed
[ 0.784655] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.790068] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.791051] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.791532] kfuse 7000fc00.kfuse: initialized
[ 0.793273] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.794250] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.795716] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.795768] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.796332] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.798171] vdd-gpu: applied init 1000000uV constraint
[ 0.798206] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 0.798633] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.803703] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.803949] No Device Node present for smmu client: serial8250 !!
[ 0.803981] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.804066] iommu: Adding device serial8250 to group 35
[ 0.807916] console [ttyS0] disabled
[ 0.808087] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.280095] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 1.684421] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.088744] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.090762] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 2.091180] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.091189] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.091193] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.091225] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.091230] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.091275] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.091404] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.091650] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.091822] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.091857] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.091901] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.091930] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.092126] pci 0000:01:00.0: supports D1 D2
[ 2.092129] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.103348] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.103401] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.103406] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.103416] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.103441] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.103465] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.103477] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.103483] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.103490] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.104281] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.104286] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.104294] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.104416] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.221962] console [ttyS0] enabled
[ 3.222572] Console: switching to colour frame buffer device 240x67
[ 3.224567] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.224917] serial-tegra 70006200.serial: RX in PIO mode
[ 3.225004] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.225936] [drm] Initialized
[ 3.248457] brd: module loaded
[ 3.262224] tegradc tegradc.0: fb registered
[ 3.263085] loop: module loaded
[ 3.263250] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.263376] tegra_profiler: auth: init
[ 3.267935] THERMAL EST: found 2 subdevs
[ 3.267942] THERMAL EST num_resources: 0
[ 3.267948] [THERMAL EST subdev 0]
[ 3.267953] [THERMAL EST subdev 1]
[ 3.268439] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.268441] THERMAL EST: thz register success.
[ 3.268610] THERMAL EST: end of probe, return err: 0
[ 3.269943] hisi_sas: driver version v1.6
[ 3.274202] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.279338] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.279345] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.286498] libphy: Fixed MDIO Bus: probed
[ 3.287702] tun: Universal TUN/TAP device driver, 1.6
[ 3.287704] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.288712] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.288714] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.288777] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.288779] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.288828] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.288831] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.288880] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.288883] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.289771] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 3.289801] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.304020] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.304173] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e3:fb:1d from device tree
[ 3.304783] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.304828] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.305449] PPP generic driver version 2.4.2
[ 3.305653] PPP BSD Compression module registered
[ 3.305659] PPP Deflate Compression module registered
[ 3.305703] PPP MPPE Compression module registered
[ 3.305710] NET: Registered protocol family 24
[ 3.305782] usbcore: registered new interface driver r8152
[ 3.305834] usbcore: registered new interface driver asix
[ 3.305900] usbcore: registered new interface driver ax88179_178a
[ 3.305939] usbcore: registered new interface driver cdc_ether
[ 3.306036] usbcore: registered new interface driver net1080
[ 3.306076] usbcore: registered new interface driver cdc_subset
[ 3.306115] usbcore: registered new interface driver zaurus
[ 3.306221] usbcore: registered new interface driver cdc_ncm
[ 3.306392] VFIO - User Level meta-driver version: 0.3
[ 3.307805] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.307831] ehci-pci: EHCI PCI platform driver
[ 3.307884] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.307895] ohci-pci: OHCI PCI platform driver
[ 3.307939] ohci-platform: OHCI generic platform driver
[ 3.310718] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.311692] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.312927] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f908c000 id
[ 3.313041] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.313044] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.314437] usbcore: registered new interface driver uas
[ 3.314498] usbcore: registered new interface driver usb-storage
[ 3.314602] usbcore: registered new interface driver usbserial
[ 3.317877] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.319312] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.319325] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 3.319340] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 3.319372] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 3.319393] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 3.320114] mousedev: PS/2 mouse device common for all mice
[ 3.320207] usbcore: registered new interface driver xpad
[ 3.564516] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.577200] rtc rtc1: alarm rtc device
[ 3.577219] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.577245] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.577889] i2c /dev entries driver
[ 3.579782] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.603744] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.603818] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.603845] imx219 6-0010: board setup failed
[ 3.603949] imx219: probe of 6-0010 failed with error -121
[ 3.613431] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.654882] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.654888] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.655356] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.655373] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.655382] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.655514] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.655523] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.655529] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.655705] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.655715] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.655719] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.655896] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.656787] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.656842] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.656870] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.656886] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.656896] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.657755] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.657776] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.657945] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.657973] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 3.658386] parse_throttle_dt_data: Num cap clks = 6
[ 3.658392] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.658407] parse_throttle_dt_data: clk=gpu type=4
[ 3.658435] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.658454] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.658475] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.658478] parse_throttle_dt_data: clk=emc type=3
[ 3.659826] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.659924] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.660068] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.660963] FAN dev name: pwm-fan
[ 3.661019] FAN:gpio request success.
[ 3.661094] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.661419] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.661616] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.661626] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.661711] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.661715] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.661719] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.661723] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.661726] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.661730] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.661734] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.661737] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.661740] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.661744] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.662367] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.662744] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.663723] device-mapper: uevent: version 1.0.3
[ 3.664208] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.669564] tegra210-cpufreq cpufreq: probe()…completed
[ 3.670286] sdhci: Secure Digital Host Controller Interface driver
[ 3.670287] sdhci: Copyright(c) Pierre Ossman
[ 3.670288] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.670782] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.671132] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.671271] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.674836] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.675480] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.676931] usbcore: registered new interface driver usbhid
[ 3.676932] usbhid: USB HID core driver
[ 3.702156] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.702327] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.704182] nvpmodel: initialized successfully
[ 3.705385] usbcore: registered new interface driver snd-usb-audio
[ 3.705441] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.705445] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.705462] iommu: Adding device snd-soc-dummy to group 36
[ 3.727411] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.728006] OPE platform probe
[ 3.728097] OPE platform probe successful
[ 3.728122] OPE platform probe
[ 3.728203] OPE platform probe successful
[ 3.758007] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.758139] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.758263] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.758387] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.758514] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.758638] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.758761] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.758883] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.759004] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.759127] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.771361] u32 classifier
[ 3.771362] Actions configured
[ 3.771431] Initializing XFRM netlink socket
[ 3.772160] NET: Registered protocol family 10
[ 3.772920] NET: Registered protocol family 17
[ 3.772932] NET: Registered protocol family 15
[ 3.773006] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.773052] Bluetooth: RFCOMM socket layer initialized
[ 3.773060] Bluetooth: RFCOMM ver 1.11
[ 3.773065] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.773071] Bluetooth: HIDP socket layer initialized
[ 3.773090] 9pnet: Installing 9P2000 support
[ 3.773127] Key type dns_resolver registered
[ 3.779969] Registered cp15_barrier emulation handler
[ 3.780042] Registered setend emulation handler
[ 3.781124] registered taskstats version 1
[ 3.781708] Adding domain ve2-pd to PM domain host1x-pd
[ 3.781948] Adding domain ve-pd to PM domain host1x-pd
[ 3.894326] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.398988] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 4.406250] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 4.414697] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 4.421847] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 4.429160] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.435295] Extcon AUX1(HDMI) enable
[ 4.439319] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.445732] tegradc tegradc.1: No lt-data, using default setting
[ 4.451801] edid invalid
[ 4.455376] tegradc tegradc.1: No hpd-gpio in DT
[ 4.460012] tegradc tegradc.1: DT parsed successfully
[ 4.465142] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 4.473268] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.478283] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 4.493134] tegradc tegradc.1: probed
[ 4.511264] tegradc tegradc.1: fb registered
[ 4.518670] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.522781] mmc0: hw tuning done …
[ 4.522814] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 4.523078] isp 54600000.isp: initialized
[ 4.523905] isp 54680000.isp: initialized
[ 4.529650] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 4.535543] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 4.535781] clk_cbus_recalc_rate: no gbus parent
[ 4.535785] clk_cbus_round_rate: no gbus parent
[ 4.535787] clk_cbus_round_rate: no gbus parent
[ 4.535794] clk_cbus_recalc_rate: no gbus parent
[ 4.535905] clk_cbus_recalc_rate: no gbus parent
[ 4.535908] clk_cbus_round_rate: no gbus parent
[ 4.535909] clk_cbus_round_rate: no gbus parent
[ 4.535912] clk_cbus_recalc_rate: no gbus parent
[ 4.536604] tegra_dvfs: GPU-cap: registered
[ 4.536658] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.536659] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.536661] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.538703] tegra_dvfs: vdd-gpu-vts: registered
[ 4.539739] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 4.540398] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 4.540908] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.577064] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:26 UTC (946688426)
[ 4.578039] vi 54080000.vi: vi_probe: ++
[ 4.582330] vi 54080000.vi: initialized
[ 4.584673] vi 54080000.vi: subdev nvcsi–1 bound
[ 4.584934] mmcblk mmc0:aaaa: Card claimed for testing.
[ 4.586102] Disable partitions left on by BL
[ 4.586105] disb
[ 4.586151] bwmgr: missing cdev-type property
[ 4.586278] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.586283] DRAM derating cdev registered.
[ 4.587291] vdd-1v8: disabling
[ 4.587293] vdd-fan: disabling
[ 4.587294] vdd-usb-vbus: disabling
[ 4.587296] vdd-usb-vbus2: disabling
[ 4.587305] avdd-io-edp-1v05: disabling
[ 4.587306] vdd-usb-hub-en: disabling
[ 4.587519] ALSA device list:
[ 4.587522] #0: tegra-hda at 0x70038000 irq 83
[ 4.587523] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.732865] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.732874] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.732889] tegradc tegradc.0: blank - powerdown
[ 4.781460] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 4.781462] Extcon AUX1(HDMI) disable
[ 4.809640] tegradc tegradc.0: unblank
[ 4.846976] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 4.847024] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 4.848042] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 4.848048] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 4.851287] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.851288] Extcon AUX1(HDMI) enable
[ 4.851597] tegradc tegradc.0: sync windows ret = 250
[ 4.964990] tegradc tegradc.1: blank - powerdown
[ 4.971803] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 4.971805] Extcon DP: HPD disabled
[ 4.971806] hpd: hpd_switch 0
[ 4.971813] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.971827] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 4.971831] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.018029] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 5.018030] Extcon HDMI: HPD enabled
[ 5.018041] tegradc tegradc.0: hdmi: plugged
[ 5.402868] EXT4-fs (mmcblk0p1): 13 orphan inodes deleted
[ 5.410531] EXT4-fs (mmcblk0p1): recovery complete
[ 5.440054] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.450317] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.463397] devtmpfs: mounted
[ 5.471627] Freeing unused kernel memory: 8512K
[ 5.694214] systemd[1]: System time before build time, advancing clock.
[ 5.738882] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.757523] cgroup: cgroup2: unknown option “nsdelegate”
[ 5.787774] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.814459] systemd[1]: Detected architecture arm64.
[ 5.858379] systemd[1]: Set hostname to .
[ 5.974617] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 5.994029] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.168370] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.179733] systemd[1]: Created slice System Slice.
[ 6.189855] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.199116] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.211326] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.222085] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.237556] systemd[1]: Created slice User and Session Slice.
[ 6.248502] systemd[1]: Reached target Swap.
[ 6.342177] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.516562] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 6.614480] systemd-journald[1923]: Received request to flush runtime journal from PID 1
[ 7.313053] using random self ethernet address
[ 7.319847] using random host ethernet address
[ 7.353984] Mass Storage Function, version: 2009/09/11
[ 7.353990] LUN: removable file: (no medium)
[ 7.359498] using random self ethernet address
[ 7.365566] using random host ethernet address
[ 7.382628] rndis0: HOST MAC d6:60:98:be:49:24
[ 7.382718] rndis0: MAC d6:60:98:be:49:25
[ 7.386415] usb0: HOST MAC d6:60:98:be:49:26
[ 7.386553] usb0: MAC d6:60:98:be:49:27
[ 7.386584] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 7.444362] l4tbr0: port 1(rndis0) entered blocking state
[ 7.444367] l4tbr0: port 1(rndis0) entered disabled state
[ 7.444517] device rndis0 entered promiscuous mode
[ 7.453244] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 7.458227] l4tbr0: port 2(usb0) entered blocking state
[ 7.458232] l4tbr0: port 2(usb0) entered disabled state
[ 7.458532] device usb0 entered promiscuous mode
[ 7.464167] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.464175] l4tbr0: port 2(usb0) entered blocking state
[ 7.464178] l4tbr0: port 2(usb0) entered forwarding state
[ 7.713938] random: crng init done
[ 7.718815] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.994456] tegra-xusb 70090000.xusb: cannot find firmware…retry after 1 second
[ 8.134358] nvs_dsm nvs_dsm: dsm_probe
[ 8.134382] nvs_dsm nvs_dsm: dsm_remove
[ 8.134385] nvs_dsm nvs_dsm: dsm_probe done
[ 8.433999] l4tbr0: port 2(usb0) entered disabled state
[ 9.023345] tegra-xusb 70090000.xusb: Firmware timestamp: 2017-11-03 13:36:19 UTC, Version: 50.20 release
[ 9.023388] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 9.023408] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 9.024265] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 9.024303] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 9.030970] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.030974] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.030977] usb usb1: Product: xHCI Host Controller
[ 9.030980] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 9.030982] usb usb1: SerialNumber: 70090000.xusb
[ 9.031427] hub 1-0:1.0: USB hub found
[ 9.031457] hub 1-0:1.0: 5 ports detected
[ 9.031855] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 9.031864] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 9.031991] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 9.032064] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.032068] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.032071] usb usb2: Product: xHCI Host Controller
[ 9.032073] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 9.032075] usb usb2: SerialNumber: 70090000.xusb
[ 9.032512] hub 2-0:1.0: USB hub found
[ 9.032580] hub 2-0:1.0: 4 ports detected
[ 9.069768] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.082508] eth0: 0xffffff800a2fe000, 00:04:4b:e3:fb:1d, IRQ 404
[ 9.135412] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 9.135731] usb usb2: usb_suspend_both: status 0
[ 9.162582] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.359251] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 9.396881] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 9.396888] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.396892] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 9.396895] usb 1-2: Manufacturer: Generic
[ 9.398192] hub 1-2:1.0: USB hub found
[ 9.399291] hub 1-2:1.0: 4 ports detected
[ 9.508345] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 9.527249] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 9.543297] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 9.543302] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.543306] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 9.543309] usb 2-1: Manufacturer: Generic
[ 9.547282] usb 1-2: usb_suspend_both: status 0
[ 9.547588] usb usb1: usb_suspend_both: status 0
[ 9.547704] hub 2-1:1.0: USB hub found
[ 9.549146] hub 2-1:1.0: 4 ports detected
[ 9.574015] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 9.574195] usb usb1: usb_suspend_both: status -16
[ 9.574279] usb usb1: usb_suspend_both: status -16
[ 9.574360] usb usb1: usb_suspend_both: status -16
[ 9.574442] usb usb1: usb_suspend_both: status -16
[ 9.574522] usb usb1: usb_suspend_both: status -16
[ 9.574606] usb usb1: usb_suspend_both: status -16
[ 9.574687] usb usb1: usb_suspend_both: status -16
[ 9.574767] usb usb1: usb_suspend_both: status -16
[ 9.574846] usb usb1: usb_suspend_both: status -16
[ 9.574925] usb usb1: usb_suspend_both: status -16
[ 9.575005] usb usb1: usb_suspend_both: status -16
[ 9.575087] usb usb1: usb_suspend_both: status -16
[ 9.575166] usb usb1: usb_suspend_both: status -16
[ 9.575300] usb usb1: usb_suspend_both: status -16
[ 9.575385] usb usb1: usb_suspend_both: status -16
[ 9.575468] usb usb1: usb_suspend_both: status -16
[ 9.575558] usb usb1: usb_suspend_both: status -16
[ 9.575641] usb usb1: usb_suspend_both: status -16
[ 9.575724] usb usb1: usb_suspend_both: status -16
[ 9.575805] usb usb1: usb_suspend_both: status -16
[ 9.575884] usb usb1: usb_suspend_both: status -16
[ 9.575964] usb usb1: usb_suspend_both: status -16
[ 9.576044] usb usb1: usb_suspend_both: status -16
[ 9.576125] usb usb1: usb_suspend_both: status -16
[ 9.576206] usb usb1: usb_suspend_both: status -16
[ 9.576290] usb usb1: usb_suspend_both: status -16
[ 9.576368] usb usb1: usb_suspend_both: status -16
[ 9.576448] usb usb1: usb_suspend_both: status -16
[ 9.576527] usb usb1: usb_suspend_both: status -16
[ 9.576607] usb usb1: usb_suspend_both: status -16
[ 9.576711] usb usb1: usb_suspend_both: status -16
[ 9.576801] usb usb1: usb_suspend_both: status -16
[ 9.576882] usb usb1: usb_suspend_both: status -16
[ 9.576962] usb usb1: usb_suspend_both: status -16
[ 9.577041] usb usb1: usb_suspend_both: status -16
[ 9.577119] usb usb1: usb_suspend_both: status -16
[ 9.577198] usb usb1: usb_suspend_both: status -16
[ 9.577278] usb usb1: usb_suspend_both: status -16
[ 9.577358] usb usb1: usb_suspend_both: status -16
[ 9.577438] usb usb1: usb_suspend_both: status -16
[ 9.577519] usb usb1: usb_suspend_both: status -16
[ 9.577599] usb usb1: usb_suspend_both: status -16
[ 9.577678] usb usb1: usb_suspend_both: status -16
[ 9.577760] usb usb1: usb_suspend_both: status -16
[ 9.577840] usb usb1: usb_suspend_both: status -16
[ 9.577918] usb usb1: usb_suspend_both: status -16
[ 9.577998] usb usb1: usb_suspend_both: status -16
[ 9.578077] usb usb1: usb_suspend_both: status -16
[ 9.578156] usb usb1: usb_suspend_both: status -16
[ 9.578235] usb usb1: usb_suspend_both: status -16
[ 9.578315] usb usb1: usb_suspend_both: status -16
[ 9.578395] usb usb1: usb_suspend_both: status -16
[ 9.578475] usb usb1: usb_suspend_both: status -16
[ 9.578555] usb usb1: usb_suspend_both: status -16
[ 9.578633] usb usb1: usb_suspend_both: status -16
[ 9.578713] usb usb1: usb_suspend_both: status -16
[ 9.578792] usb usb1: usb_suspend_both: status -16
[ 9.578871] usb usb1: usb_suspend_both: status -16
[ 9.578949] usb usb1: usb_suspend_both: status -16
[ 9.579028] usb usb1: usb_suspend_both: status -16
[ 9.579107] usb usb1: usb_suspend_both: status -16
[ 9.579186] usb usb1: usb_suspend_both: status -16
[ 9.579308] usb usb1: usb_suspend_both: status -16
[ 9.579397] usb usb1: usb_suspend_both: status -16
[ 9.579481] usb usb1: usb_suspend_both: status -16
[ 9.579567] usb usb1: usb_suspend_both: status -16
[ 9.579648] usb usb1: usb_suspend_both: status -16
[ 9.579729] usb usb1: usb_suspend_both: status -16
[ 9.579811] usb usb1: usb_suspend_both: status -16
[ 9.579892] usb usb1: usb_suspend_both: status -16
[ 9.579974] usb usb1: usb_suspend_both: status -16
[ 9.580055] usb usb1: usb_suspend_both: status -16
[ 9.580134] usb usb1: usb_suspend_both: status -16
[ 9.580216] usb usb1: usb_suspend_both: status -16
[ 9.580296] usb usb1: usb_suspend_both: status -16
[ 9.580377] usb usb1: usb_suspend_both: status -16
[ 9.580458] usb usb1: usb_suspend_both: status -16
[ 9.580539] usb usb1: usb_suspend_both: status -16
[ 9.580619] usb usb1: usb_suspend_both: status -16
[ 9.580699] usb usb1: usb_suspend_both: status -16
[ 9.580778] usb usb1: usb_suspend_both: status -16
[ 9.580858] usb usb1: usb_suspend_both: status -16
[ 9.580943] usb usb1: usb_suspend_both: status -16
[ 9.581023] usb usb1: usb_suspend_both: status -16
[ 9.581102] usb usb1: usb_suspend_both: status -16
[ 9.581184] usb usb1: usb_suspend_both: status -16
[ 9.581264] usb usb1: usb_suspend_both: status -16
[ 9.581343] usb usb1: usb_suspend_both: status -16
[ 9.581422] usb usb1: usb_suspend_both: status -16
[ 9.581501] usb usb1: usb_suspend_both: status -16
[ 9.581571] usb usb1: usb_suspend_both: status -16
[ 9.581641] usb usb1: usb_suspend_both: status -16
[ 9.581708] usb usb1: usb_suspend_both: status -16
[ 9.581774] usb usb1: usb_suspend_both: status -16
[ 9.581840] usb usb1: usb_suspend_both: status -16
[ 9.581907] usb usb1: usb_suspend_both: status -16
[ 9.581972] usb usb1: usb_suspend_both: status -16
[ 9.582037] usb usb1: usb_suspend_both: status -16
[ 9.582104] usb usb1: usb_suspend_both: status -16
[ 9.582170] usb usb1: usb_suspend_both: status -16
[ 9.582236] usb usb1: usb_suspend_both: status -16
[ 9.582302] usb usb1: usb_suspend_both: status -16
[ 9.582369] usb usb1: usb_suspend_both: status -16
[ 9.582434] usb usb1: usb_suspend_both: status -16
[ 9.582531] usb usb1: usb_suspend_both: status -16
[ 9.582600] usb usb1: usb_suspend_both: status -16
[ 9.582668] usb usb1: usb_suspend_both: status -16
[ 9.582736] usb usb1: usb_suspend_both: status -16
[ 9.582802] usb usb1: usb_suspend_both: status -16
[ 9.582868] usb usb1: usb_suspend_both: status -16
[ 9.582936] usb usb1: usb_suspend_both: status -16
[ 9.583002] usb usb1: usb_suspend_both: status -16
[ 9.583068] usb usb1: usb_suspend_both: status -16
[ 9.583133] usb usb1: usb_suspend_both: status -16
[ 9.583291] usb usb1: usb_suspend_both: status -16
[ 9.583366] usb usb1: usb_suspend_both: status -16
[ 9.583435] usb usb1: usb_suspend_both: status -16
[ 9.583503] usb usb1: usb_suspend_both: status -16
[ 9.583572] usb usb1: usb_suspend_both: status -16
[ 9.583638] usb usb1: usb_suspend_both: status -16
[ 9.583704] usb usb1: usb_suspend_both: status -16
[ 9.583772] usb usb1: usb_suspend_both: status -16
[ 9.583838] usb usb1: usb_suspend_both: status -16
[ 9.583905] usb usb1: usb_suspend_both: status -16
[ 9.583970] usb usb1: usb_suspend_both: status -16
[ 9.584036] usb usb1: usb_suspend_both: status -16
[ 9.584102] usb usb1: usb_suspend_both: status -16
[ 9.584169] usb usb1: usb_suspend_both: status -16
[ 9.584235] usb usb1: usb_suspend_both: status -16
[ 9.584300] usb usb1: usb_suspend_both: status -16
[ 9.584366] usb usb1: usb_suspend_both: status -16
[ 9.584433] usb usb1: usb_suspend_both: status -16
[ 9.584500] usb usb1: usb_suspend_both: status -16
[ 9.584567] usb usb1: usb_suspend_both: status -16
[ 9.584634] usb usb1: usb_suspend_both: status -16
[ 9.584707] usb usb1: usb_suspend_both: status -16
[ 9.584776] usb usb1: usb_suspend_both: status -16
[ 9.584842] usb usb1: usb_suspend_both: status -16
[ 9.584908] usb usb1: usb_suspend_both: status -16
[ 9.584974] usb usb1: usb_suspend_both: status -16
[ 9.585041] usb usb1: usb_suspend_both: status -16
[ 9.585107] usb usb1: usb_suspend_both: status -16
[ 9.585175] usb usb1: usb_suspend_both: status -16
[ 9.585242] usb usb1: usb_suspend_both: status -16
[ 9.585311] usb usb1: usb_suspend_both: status -16
[ 9.585381] usb usb1: usb_suspend_both: status -16
[ 9.585448] usb usb1: usb_suspend_both: status -16
[ 9.585517] usb usb1: usb_suspend_both: status -16
[ 9.585584] usb usb1: usb_suspend_both: status -16
[ 9.585652] usb usb1: usb_suspend_both: status -16
[ 9.585719] usb usb1: usb_suspend_both: status -16
[ 9.585785] usb usb1: usb_suspend_both: status -16
[ 9.585853] usb usb1: usb_suspend_both: status -16
[ 9.585921] usb usb1: usb_suspend_both: status -16
[ 9.585987] usb usb1: usb_suspend_both: status -16
[ 9.586054] usb usb1: usb_suspend_both: status -16
[ 9.586120] usb usb1: usb_suspend_both: status -16
[ 9.586187] usb usb1: usb_suspend_both: status -16
[ 9.586254] usb usb1: usb_suspend_both: status -16
[ 9.586321] usb usb1: usb_suspend_both: status -16
[ 9.586387] usb usb1: usb_suspend_both: status -16
[ 9.586457] usb usb1: usb_suspend_both: status -16
[ 9.586523] usb usb1: usb_suspend_both: status -16
[ 9.586589] usb usb1: usb_suspend_both: status -16
[ 9.586656] usb usb1: usb_suspend_both: status -16
[ 9.586725] usb usb1: usb_suspend_both: status -16
[ 9.586791] usb usb1: usb_suspend_both: status -16
[ 9.586860] usb usb1: usb_suspend_both: status -16
[ 9.586927] usb usb1: usb_suspend_both: status -16
[ 9.586995] usb usb1: usb_suspend_both: status -16
[ 9.587063] usb usb1: usb_suspend_both: status -16
[ 9.587129] usb usb1: usb_suspend_both: status -16
[ 9.587229] usb usb1: usb_suspend_both: status -16
[ 9.587304] usb usb1: usb_suspend_both: status -16
[ 9.587630] usb usb1: usb_suspend_both: status -16
[ 9.587707] usb usb1: usb_suspend_both: status -16
[ 9.587775] usb usb1: usb_suspend_both: status -16
[ 9.587841] usb usb1: usb_suspend_both: status -16
[ 9.587906] usb usb1: usb_suspend_both: status -16
[ 9.587972] usb usb1: usb_suspend_both: status -16
[ 9.588037] usb usb1: usb_suspend_both: status -16
[ 9.588103] usb usb1: usb_suspend_both: status -16
[ 9.588292] usb usb1: usb_suspend_both: status -16
[ 9.588394] usb usb1: usb_suspend_both: status -16
[ 9.588462] usb usb1: usb_suspend_both: status -16
[ 9.588529] usb usb1: usb_suspend_both: status -16
[ 9.588594] usb usb1: usb_suspend_both: status -16
[ 9.588659] usb usb1: usb_suspend_both: status -16
[ 9.588726] usb usb1: usb_suspend_both: status -16
[ 9.588793] usb usb1: usb_suspend_both: status -16
[ 9.588859] usb usb1: usb_suspend_both: status -16
[ 9.589015] usb usb1: usb_suspend_both: status -16
[ 9.589423] usb usb1: usb_suspend_both: status -16
[ 9.589500] usb usb1: usb_suspend_both: status -16
[ 9.589568] usb usb1: usb_suspend_both: status -16
[ 9.589636] usb usb1: usb_suspend_both: status -16
[ 9.589703] usb usb1: usb_suspend_both: status -16
[ 9.589769] usb usb1: usb_suspend_both: status -
