I’m trying to use a raspberry Pi v2.1 camera with my Jetson Nano, however it doesn’t show up at all. I made sure the camera is connected correctly. I was able to use the same camera on a raspberry pi without any problem.
After I plugin the camera it’s not listed in /dev/
ecto2@ecto2:~$ ls /dev/video0
ls: cannot access '/dev/video0': No such file or directory
ecto2@ecto2:~$ v4l2-ctl -d /dev/video0 --list-formats
Failed to open /dev/video0: No such file or directory
I tried to reinstall with a fresh image but that didn’t solve the problem.
I found some error from the dmesg:
[ 1.730430] i2c /dev entries driver
[ 1.732328] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.755664] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.755743] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.763305] imx219 6-0010: board setup failed
[ 1.767772] imx219: probe of 6-0010 failed with error -121
How can I fix this?
Here is the dump from dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2713) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:47:42 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29496(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3570416K/4159488K available (15230K kernel code, 2926K rwdata, 6620K rodata, 8576K init, 609K bss, 113936K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a11b808 ( 2927 KB)
[ 0.000000] .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001757] Console: colour dummy device 80x25
[ 0.001776] console [tty0] enabled
[ 0.001794] kmemleak: Kernel memory leak detector disabled
[ 0.001815] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001828] pid_max: default: 32768 minimum: 301
[ 0.002277] Security Framework initialized
[ 0.002501] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002511] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003617] ftrace: allocating 47001 entries in 184 pages
[ 0.175657] sched-energy: CPU device node has no sched-energy-costs
[ 0.175689] ASID allocator initialised with 65536 entries
[ 0.211666] tegra-id: chipid=22117.
[ 0.211680] tegra-id: opt_subrevision=0.
[ 0.211697] Tegra Speedo/IDDQ fuse revision 4
[ 0.211702] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211705] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211711] Tegra: CPU Speedo Value 2072, SoC Speedo Value 1966, GPU Speedo Value 2068
[ 0.211715] Tegra: CPU IDDQ Value 2276, SoC IDDQ Value 2276, GPU IDDQ Value 2805
[ 0.211736] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211749] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.211756] DTB Build time: Dec 9 2019 22:51:55
[ 0.261028] CPU1: Booted secondary processor [411fd071]
[ 0.292971] CPU2: Booted secondary processor [411fd071]
[ 0.324938] CPU3: Booted secondary processor [411fd071]
[ 0.325028] Brought up 4 CPUs
[ 0.325035] SMP: Total of 4 processors activated.
[ 0.325042] CPU features: detected feature: 32-bit EL0 Support
[ 0.325302] CPU: All CPU(s) started at EL2
[ 0.325321] alternatives: patching kernel code
[ 0.333364] devtmpfs: initialized
[ 0.370583] Initilizing CustomIPI irq domain
[ 0.370971] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.370994] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.381455] pinctrl core: initialized pinctrl subsystem
[ 0.382098] OS set in device tree is not L4T.
[ 0.382485] regulator-dummy: no parameters
[ 0.382770] Initializing plugin-manager
[ 0.382869] Plugin module not found
[ 0.383099] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.383640] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.384491] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.385526] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.390284] NET: Registered protocol family 16
[ 0.391614] pstore: using zlib compression
[ 0.391659] console [pstore-1] enabled
[ 0.391663] pstore: Registered ramoops as persistent store backend
[ 0.391668] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.401052] cpuidle: using governor menu
[ 0.405310] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.406983] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.407005] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.409500] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.412109] tegra_powergate_init: DONE
[ 0.412124] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.412132] DTB Build time: Dec 9 2019 22:51:55
[ 0.413925] Tegra reboot handler registered.
[ 0.418405] iommu: Adding device tegra-carveouts to group 0
[ 0.418543] platform tegra-carveouts: domain=ffffffc0f9bbe318 allocates as[0]=ffffffc0f9bcc0a8
[ 0.418888] iommu: Adding device smmu_test to group 1
[ 0.418937] platform smmu_test: domain=ffffffc0f9bbe558 allocates as[0]=ffffffc0f9bcc110
[ 0.419730] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.419786] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.419842] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.419852] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.419873] mc-err: mcerr ops are set to t21x
[ 0.429463] iommu: Adding device 70090000.xusb to group 2
[ 0.429765] iommu: Adding device 70006000.serial to group 3
[ 0.429826] platform 70006000.serial: domain=ffffffc0f9442c18 allocates as[0]=ffffffc0f9bcc178
[ 0.430243] iommu: Adding device 70006040.serial to group 4
[ 0.430498] iommu: Adding device 70006200.serial to group 5
[ 0.430688] iommu: Adding device sound to group 6
[ 0.430734] platform sound: domain=ffffffc0f94b6198 allocates as[0]=ffffffc0f9bcc1e0
[ 0.431259] iommu: Adding device 7000d400.spi to group 7
[ 0.431506] iommu: Adding device 7000d600.spi to group 8
[ 0.431809] iommu: Adding device 70410000.spi to group 9
[ 0.432109] iommu: Adding device 50000000.host1x to group 10
[ 0.432383] iommu: Adding device 54080000.vi to group 11
[ 0.432781] iommu: Adding device 54600000.isp to group 12
[ 0.433074] iommu: Adding device 54680000.isp to group 13
[ 0.433357] iommu: Adding device tegradc.0 to group 14
[ 0.433408] platform tegradc.0: domain=ffffffc0f94c20d8 allocates as[0]=ffffffc0f9bcc248
[ 0.433927] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.434241] iommu: Adding device tegradc.1 to group 15
[ 0.434286] platform tegradc.1: domain=ffffffc0f94c2318 allocates as[0]=ffffffc0f9bcc2b0
[ 0.434790] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.435060] iommu: Adding device 54340000.vic to group 16
[ 0.435261] iommu: Adding device 544c0000.nvenc to group 17
[ 0.435455] iommu: Adding device 54500000.tsec to group 18
[ 0.435645] iommu: Adding device 54100000.tsecb to group 19
[ 0.435835] iommu: Adding device 54480000.nvdec to group 20
[ 0.436024] iommu: Adding device 54380000.nvjpg to group 21
[ 0.437122] iommu: Adding device 546c0000.i2c to group 22
[ 0.437470] iommu: Adding device 57000000.gpu to group 23
[ 0.437525] platform 57000000.gpu: domain=ffffffc0f94cd318 allocates as[0]=ffffffc0f9bcc318
[ 0.437580] platform 57000000.gpu: domain=ffffffc0f94cd318 allocates as[1]=ffffffc0f9bcc380
[ 0.437618] platform 57000000.gpu: domain=ffffffc0f94cd318 allocates as[2]=ffffffc0f9bcc3e8
[ 0.437649] platform 57000000.gpu: domain=ffffffc0f94cd318 allocates as[3]=ffffffc0f9bcc450
[ 0.438497] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.438507] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.438518] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.438523] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.438528] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.489232] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.489241] tegra-pmc: Clear bootloader IO dpd settings
[ 0.489261] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.489326] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.489615] iommu: Adding device 70012000.se to group 24
[ 0.490461] iommu: Adding device 7000c000.i2c to group 25
[ 0.490775] iommu: Adding device 7000c400.i2c to group 26
[ 0.491083] iommu: Adding device 7000c500.i2c to group 27
[ 0.491378] iommu: Adding device 7000c700.i2c to group 28
[ 0.491674] iommu: Adding device 7000d000.i2c to group 29
[ 0.491979] iommu: Adding device 7000d100.i2c to group 30
[ 0.492332] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.492393] platform sdhci-tegra.0: domain=ffffffc0f955f498 allocates as[0]=ffffffc0f9bcc4b8
[ 0.493440] iommu: Adding device 700d0000.xudc to group 32
[ 0.497617] vdd-ac-bat: 5000 mV
[ 0.498076] vdd-5v0-sys: 5000 mV
[ 0.499267] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.499306] vdd-5v0-hdmi: 5000 mV
[ 0.499812] vdd-1v8-sys: 1800 mV
[ 0.500363] vdd-fan: supplied by vdd-5v0-sys
[ 0.500401] vdd-fan: 5000 mV
[ 0.500901] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.500933] vdd-usb-vbus: 5000 mV
[ 0.501573] vdd-usb-vbus2: 5000 mV
[ 0.538158] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540485] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.541990] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.542010] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.542353] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.550156] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.550489] SCSI subsystem initialized
[ 0.550715] libata version 3.00 loaded.
[ 0.551001] usbcore: registered new interface driver usbfs
[ 0.551050] usbcore: registered new interface driver hub
[ 0.551121] usbcore: registered new device driver usb
[ 0.555058] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.560348] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.561133] random: fast init done
[ 0.561363] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.564295] vdd-ddr-1v1: 1150 mV
[ 0.568231] vdd-pre-reg-1v35: 1350 mV
[ 0.572232] vdd-1v8: 1800 mV
[ 0.576232] avdd-sys-1v2: 1200 mV
[ 0.580230] vdd-pex-1v0: 1050 mV
[ 0.580896] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.581432] max77620-ldo3: at 3100 mV
[ 0.584237] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.584777] max77620-ldo5: at 3100 mV
[ 0.585319] max77620-ldo6: at 2800 mV
[ 0.588232] avdd-1v05-pll: 1050 mV
[ 0.592230] avdd-io-hdmi-dp: 1050 mV
[ 0.594857] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.595155] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.595433] max77620 4-003c: max77620 probe successful
[ 0.598055] media: Linux media interface: v0.10
[ 0.598106] Linux video capture interface: v2.00
[ 0.598958] pps_core: LinuxPPS API ver. 1 registered
[ 0.598965] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.598985] PTP clock support registered
[ 0.602518] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.608817] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.609651] Advanced Linux Sound Architecture Driver Initialized.
[ 0.610293] Bluetooth: Core ver 2.22
[ 0.610345] NET: Registered protocol family 31
[ 0.610349] Bluetooth: HCI device and connection manager initialized
[ 0.610363] Bluetooth: HCI socket layer initialized
[ 0.610371] Bluetooth: L2CAP socket layer initialized
[ 0.610397] Bluetooth: SCO socket layer initialized
[ 0.612091] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.612106] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.612160] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.612175] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.615333] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.616460] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.616521] vdd-3v3-sys: 3300 mV
[ 0.616797] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.621072] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.621550] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.621593] vdd-3v3-sd: 3300 mV
[ 0.622628] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.622668] avdd-io-edp-1v05: 1050 mV
[ 0.623171] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.623204] vdd-usb-hub-en: 5000 mV
[ 0.624651] camchar: rtcpu character device driver loaded
[ 0.625482] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.626824] clocksource: Switched to clocksource arch_sys_counter
[ 0.666992] VFS: Disk quotas dquot_6.6.0
[ 0.667112] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.667606] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.668006] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.668025] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.668220] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.668226] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.668236] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.668260] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.668266] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.668279] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.668287] nvmap_page_pool_init: Total RAM pages: 1011388
[ 0.668292] nvmap_page_pool_init: nvmap page pool size: 126423 pages (493 MB)
[ 0.668390] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.668838] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.669750] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.677882] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.678282] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.678520] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.678720] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.678945] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.679214] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.679219] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.679657] NET: Registered protocol family 2
[ 0.680611] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.680822] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.681315] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.681453] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.681534] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.681945] NET: Registered protocol family 1
[ 0.682707] RPC: Registered named UNIX socket transport module.
[ 0.682712] RPC: Registered udp transport module.
[ 0.682716] RPC: Registered tcp transport module.
[ 0.682719] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.682733] PCI: CLS 0 bytes, default 64
[ 0.683006] Trying to unpack rootfs image as initramfs...
[ 0.915345] Freeing initrd memory: 5356K
[ 0.925149] host1x 50000000.host1x: initialized
[ 0.926969] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.930108] audit: initializing netlink subsys (disabled)
[ 0.930201] audit: type=2000 audit(0.779:1): initialized
[ 0.931035] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.941042] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.942525] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.943380] 9p: Installing v9fs 9p2000 file system support
[ 0.946598] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.946750] io scheduler noop registered
[ 0.947079] io scheduler cfq registered (default)
[ 0.949687] gic 702f9000.agic: GIC IRQ controller registered
[ 0.953134] iommu: Adding device 702ef000.adsp to group 33
[ 0.961940] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.962084] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.962664] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0xa249414
[ 0.962673] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.964339] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.964441] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.964533] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.964723] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.964813] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.964901] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.964989] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.965074] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.965172] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.965258] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.971283] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.972958] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.974955] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.976241] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.976595] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.977788] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.977998] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.978246] Adding domain tsec-pd to PM domain host1x-pd
[ 0.980494] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.981389] tsec 54500000.tsec: initialized
[ 0.982927] tsec 54100000.tsecb: initialized
[ 0.983622] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.987049] nvdec 54480000.nvdec: initialized
[ 0.988093] Adding domain vic03-pd to PM domain host1x-pd
[ 0.988270] Adding domain msenc-pd to PM domain host1x-pd
[ 0.988427] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.992518] falcon 54340000.vic: initialized
[ 0.993769] falcon 544c0000.nvenc: initialized
[ 0.995106] falcon 54380000.nvjpg: initialized
[ 0.999326] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 0.999368] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 0.999395] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 0.999494] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.999618] display board info: id 0x0, fab 0x0
[ 0.999681] generic_infoframe_type: 0x87
[ 0.999709] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 0.999714] tegra_cec 70015000.tegra_cec: probed
[ 0.999830] tegradc tegradc.0: DT parsed successfully
[ 0.999887] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.003516] tegradc tegradc.0: probed
[ 1.004223] Console: switching to colour frame buffer device 80x30
[ 1.004261] tegradc tegradc.0: fb registered
[ 1.005436] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.005511] tegradc tegradc.1: No lt-data, using default setting
[ 1.005539] tegradc tegradc.1: No hpd-gpio in DT
[ 1.005571] tegradc tegradc.1: DT parsed successfully
[ 1.005616] tegradc tegradc.1: Display dc.ffffff800acc0000 registered with id=1
[ 1.007733] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.008099] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.514292] Host read timeout at address 545c00c4
[ 1.515981] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.515999] tegradc tegradc.1: probed
[ 1.516380] tegradc tegradc.1: fb registered
[ 1.516811] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.517112] kfuse 7000fc00.kfuse: initialized
[ 1.517967] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.518842] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.519609] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.519616] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.519702] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.519719] tegradc tegradc.1: blank - powerdown
[ 1.519744] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.519750] Extcon DP: HPD disabled
[ 1.519755] hpd: hpd_switch 0
[ 1.519760] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.519768] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.519775] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.519782] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.519794] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.520179] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.521494] vdd-gpu: applied init 1000000uV constraint
[ 1.521503] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.521880] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.526312] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.526415] No Device Node present for smmu client: serial8250 !!
[ 1.526425] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.526465] iommu: Adding device serial8250 to group 35
[ 1.528877] console [ttyS0] disabled
[ 1.528979] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.539229] console [ttyS0] enabled
[ 1.540139] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.540421] serial-tegra 70006200.serial: RX in PIO mode
[ 1.540501] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.541409] [drm] Initialized
[ 1.551541] brd: module loaded
[ 1.556898] loop: module loaded
[ 1.557004] tegra_profiler: version: 1.139, samples/io: 47/27
[ 1.557118] tegra_profiler: auth: init
[ 1.558510] THERMAL EST: found 2 subdevs
[ 1.558518] THERMAL EST num_resources: 0
[ 1.558524] [THERMAL EST subdev 0]
[ 1.558532] [THERMAL EST subdev 1]
[ 1.559246] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.559251] THERMAL EST: thz register success.
[ 1.559396] THERMAL EST: end of probe, return err: 0
[ 1.561112] hisi_sas: driver version v1.6
[ 1.566100] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.567457] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.567466] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.571662] libphy: Fixed MDIO Bus: probed
[ 1.573430] tun: Universal TUN/TAP device driver, 1.6
[ 1.573435] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.574492] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.574496] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.574590] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.574594] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.574682] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.574686] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.574772] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.574776] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.575835] PPP generic driver version 2.4.2
[ 1.576067] PPP BSD Compression module registered
[ 1.576071] PPP Deflate Compression module registered
[ 1.576111] PPP MPPE Compression module registered
[ 1.576120] NET: Registered protocol family 24
[ 1.576244] usbcore: registered new interface driver r8152
[ 1.576331] usbcore: registered new interface driver asix
[ 1.576417] usbcore: registered new interface driver ax88179_178a
[ 1.576490] usbcore: registered new interface driver cdc_ether
[ 1.576569] usbcore: registered new interface driver net1080
[ 1.576659] usbcore: registered new interface driver cdc_subset
[ 1.576739] usbcore: registered new interface driver zaurus
[ 1.576831] usbcore: registered new interface driver cdc_ncm
[ 1.577090] VFIO - User Level meta-driver version: 0.3
[ 1.578320] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.578343] ehci-pci: EHCI PCI platform driver
[ 1.578388] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.578401] ohci-pci: OHCI PCI platform driver
[ 1.578442] ohci-platform: OHCI generic platform driver
[ 1.581284] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.581883] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.583100] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f913c000 id
[ 1.585405] usbcore: registered new interface driver uas
[ 1.585479] usbcore: registered new interface driver usb-storage
[ 1.585591] usbcore: registered new interface driver usbserial
[ 1.586153] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.586229] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.586256] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.587252] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.587313] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.588198] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.588205] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.588210] usb usb1: Product: xHCI Host Controller
[ 1.588215] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.588220] usb usb1: SerialNumber: 70090000.xusb
[ 1.588875] hub 1-0:1.0: USB hub found
[ 1.588916] hub 1-0:1.0: 5 ports detected
[ 1.589457] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.589469] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.589575] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.589663] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.589670] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.589675] usb usb2: Product: xHCI Host Controller
[ 1.589680] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.589684] usb usb2: SerialNumber: 70090000.xusb
[ 1.590103] hub 2-0:1.0: USB hub found
[ 1.590136] hub 2-0:1.0: 4 ports detected
[ 1.593285] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.594541] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.594557] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.594573] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.594585] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.594610] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.595585] mousedev: PS/2 mouse device common for all mice
[ 1.595755] usbcore: registered new interface driver xpad
[ 1.690907] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.727213] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.729768] rtc rtc1: alarm rtc device
[ 1.729787] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.729816] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.768759] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.771321] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.771328] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.771788] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.771807] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.771817] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.771973] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.771985] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.771992] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.772134] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.772146] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.772152] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.772325] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.773081] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.773134] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.773162] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.773179] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.773189] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.774099] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.774119] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.774307] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.774340] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.774747] parse_throttle_dt_data: Num cap clks = 6
[ 1.774753] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.774766] parse_throttle_dt_data: clk=gpu type=4
[ 1.774792] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.774851] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.774871] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.774875] parse_throttle_dt_data: clk=emc type=3
[ 1.775263] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.775362] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.775496] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.776219] FAN dev name: pwm-fan
[ 1.776310] FAN:gpio request success.
[ 1.776389] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.776713] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.776890] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.776901] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.777012] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.777018] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.777023] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.777028] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.777033] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.777038] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.777043] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.777048] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.777053] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.777059] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.778305] device-mapper: uevent: version 1.0.3
[ 1.778857] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.784649] tegra210-cpufreq cpufreq: probe()...completed
[ 1.785448] sdhci: Secure Digital Host Controller Interface driver
[ 1.785450] sdhci: Copyright(c) Pierre Ossman
[ 1.785452] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.785920] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.786254] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.786383] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.790868] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.791346] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.793292] usbcore: registered new interface driver usbhid
[ 1.793295] usbhid: USB HID core driver
[ 1.795581] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.795745] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.797449] nvpmodel: initialized successfully
[ 1.798510] usbcore: registered new interface driver snd-usb-audio
[ 1.798569] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.798574] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.798594] iommu: Adding device snd-soc-dummy to group 36
[ 1.804185] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.823534] OPE platform probe
[ 1.823621] OPE platform probe successful
[ 1.823923] OPE platform probe
[ 1.824003] OPE platform probe successful
[ 1.835107] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.850615] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.850749] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.850917] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.851041] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.851170] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.851299] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.851427] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.851553] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.851685] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.851814] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.863328] u32 classifier
[ 1.863331] Actions configured
[ 1.863405] Initializing XFRM netlink socket
[ 1.864120] NET: Registered protocol family 10
[ 1.864793] NET: Registered protocol family 17
[ 1.864804] NET: Registered protocol family 15
[ 1.864903] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.864962] Bluetooth: RFCOMM socket layer initialized
[ 1.864973] Bluetooth: RFCOMM ver 1.11
[ 1.864978] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.864984] Bluetooth: HIDP socket layer initialized
[ 1.865002] 9pnet: Installing 9P2000 support
[ 1.865043] Key type dns_resolver registered
[ 1.865401] Registered cp15_barrier emulation handler
[ 1.865408] Registered setend emulation handler
[ 1.866373] registered taskstats version 1
[ 1.866926] Adding domain ve2-pd to PM domain host1x-pd
[ 1.867181] Adding domain ve-pd to PM domain host1x-pd
[ 1.869221] isp 54600000.isp: initialized
[ 1.870193] isp 54680000.isp: initialized
[ 1.880284] last reset is due to power on reset
[ 1.880289] KERNEL: PMC reset status reg: 0x0
[ 1.880364] BL: PMC reset status reg: 0x0
[ 1.880366] BL: PMIC poweroff Event Recorder: 0x40
[ 1.881776] clk_cbus_recalc_rate: no gbus parent
[ 1.881781] clk_cbus_round_rate: no gbus parent
[ 1.881783] clk_cbus_round_rate: no gbus parent
[ 1.881791] clk_cbus_recalc_rate: no gbus parent
[ 1.881893] clk_cbus_recalc_rate: no gbus parent
[ 1.881897] clk_cbus_round_rate: no gbus parent
[ 1.881899] clk_cbus_round_rate: no gbus parent
[ 1.881903] clk_cbus_recalc_rate: no gbus parent
[ 1.882589] tegra_dvfs: GPU-cap: registered
[ 1.882651] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.882654] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.882656] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.884090] tegra_dvfs: vdd-gpu-vts: registered
[ 1.884809] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.885390] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.885884] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.912927] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.914883] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.917197] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:19 UTC (946688419)
[ 1.918245] vi 54080000.vi: vi_probe: ++
[ 1.934756] vi 54080000.vi: initialized
[ 1.941114] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.942653] Disable partitions left on by BL
[ 1.942657] disb
[ 1.942700] bwmgr: missing cdev-type property
[ 1.942859] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.942866] DRAM derating cdev registered.
[ 1.943890] vdd-fan: disabling
[ 1.943893] vdd-usb-vbus: disabling
[ 1.943896] vdd-usb-vbus2: disabling
[ 1.943905] avdd-io-edp-1v05: disabling
[ 1.944928] ALSA device list:
[ 1.944931] #0: tegra-hda at 0x70038000 irq 83
[ 1.944933] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.948086] Freeing unused kernel memory: 8576K
[ 1.952513] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.952519] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.952522] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.952525] usb 1-2: Manufacturer: Generic
[ 1.955824] hub 1-2:1.0: USB hub found
[ 1.957860] hub 1-2:1.0: 4 ports detected
[ 1.968556] Root device found: mmcblk0p1
[ 2.006829] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 2.006833] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.165440] mmc0: hw tuning done ...
[ 2.165478] mmc0: new ultra high speed SDR50 SDXC card at address 0001
[ 2.165901] mmcblk0: mmc0:0001 00000 59.6 GiB
[ 2.202974] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 2.202979] GPT:25165823 != 125042687
[ 2.202980] GPT:Alternate GPT header not at the end of the disk.
[ 2.202982] GPT:25165823 != 125042687
[ 2.202984] GPT: Use GNU Parted to correct GPT errors.
[ 2.203005] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.258889] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 2.298691] usb 1-2.1: New USB device found, idVendor=148f, idProduct=5372
[ 2.298696] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.298699] usb 1-2.1: Product: 802.11 n WLAN
[ 2.298702] usb 1-2.1: Manufacturer: Ralink
[ 2.324949] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.376636] Found dev node: /dev/mmcblk0p1
[ 2.382837] usb 1-2.2: new full-speed USB device number 4 using tegra-xusb
[ 2.410639] usb 1-2.2: New USB device found, idVendor=0b05, idProduct=17cb
[ 2.410645] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.410649] usb 1-2.2: Product: BCM20702A0
[ 2.410652] usb 1-2.2: Manufacturer: Broadcom Corp
[ 2.410655] usb 1-2.2: SerialNumber: 5CF37099B663
[ 2.431521] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.432295] Rootfs mounted over mmcblk0p1
[ 2.460429] Switching from initrd to actual rootfs
[ 2.734828] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.736846] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.746334] systemd[1]: System time before build time, advancing clock.
[ 2.786931] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.799701] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.822246] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.823021] systemd[1]: Detected architecture arm64.
[ 2.841147] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.841153] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.841156] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.841160] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.841164] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.841185] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.841247] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.841391] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.841497] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.841521] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.841551] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.841571] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.841701] pci 0000:01:00.0: supports D1 D2
[ 2.841705] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.845459] systemd[1]: No hostname configured.
[ 2.845474] systemd[1]: Set hostname to <localhost>.
[ 2.850969] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.850994] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.850997] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.851003] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.851019] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.851034] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.851041] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.851044] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.851049] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.851279] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.851283] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.851288] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.851365] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.851524] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.851540] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.858756] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.858777] systemd[1]: Initializing machine ID from random generator.
[ 2.865561] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.865641] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e5:5b:c6 from device tree
[ 2.866046] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.866059] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 2.979925] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.979935] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.119273] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.120834] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.120955] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.122656] systemd[1]: Created slice System Slice.
[ 3.122968] systemd[1]: Listening on Journal Socket.
[ 3.180358] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.389146] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.427546] systemd-journald[1990]: Received request to flush runtime journal from PID 1
[ 4.101830] using random self ethernet address
[ 4.106495] using random host ethernet address
[ 4.370266] random: crng init done
[ 4.373673] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.133270] Mass Storage Function, version: 2009/09/11
[ 5.133275] LUN: removable file: (no medium)
[ 5.138449] using random self ethernet address
[ 5.138452] using random host ethernet address
[ 5.196516] rndis0: HOST MAC 62:73:cc:48:15:a0
[ 5.196578] rndis0: MAC 62:73:cc:48:15:a1
[ 5.197029] usb0: HOST MAC 62:73:cc:48:15:a2
[ 5.197053] usb0: MAC 62:73:cc:48:15:a3
[ 5.197082] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.201290] l4tbr0: port 1(rndis0) entered blocking state
[ 5.201296] l4tbr0: port 1(rndis0) entered disabled state
[ 5.201419] device rndis0 entered promiscuous mode
[ 5.205868] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.210100] l4tbr0: port 2(usb0) entered blocking state
[ 5.210106] l4tbr0: port 2(usb0) entered disabled state
[ 5.210231] device usb0 entered promiscuous mode
[ 5.216901] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.450305] android_work: did not send uevent (0 0 (null))
[ 5.463795] android_work: sent uevent USB_STATE=CONNECTED
[ 5.470218] configfs-gadget gadget: high-speed config #1: c
[ 5.470250] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 5.470268] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 5.470283] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 5.470359] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 5.470375] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 5.470389] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 5.470416] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 5.470445] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 5.470473] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 5.470488] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 5.470543] android_work: sent uevent USB_STATE=CONFIGURED
[ 5.759580] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.759586] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.988472] usbcore: registered new interface driver btusb
[ 5.997852] Bluetooth: hci0: BCM: chip id 63
[ 6.013923] Bluetooth: hci0: BCM20702A
[ 6.014897] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[ 6.025872] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0b05-17cb.hcd failed with error -2
[ 6.035332] bluetooth hci0: Falling back to user helper
[ 6.041387] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0b05-17cb.hcd not found
[ 6.087812] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.122443] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 6.122449] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.122452] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 6.122454] usb 2-1: Manufacturer: Generic
[ 6.128082] hub 2-1:1.0: USB hub found
[ 6.129492] hub 2-1:1.0: 4 ports detected
[ 6.219134] usb 1-2.1: reset high-speed USB device number 3 using tegra-xusb
[ 6.249759] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5392, rev 0223 detected
[ 6.267696] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5372 detected
[ 6.268227] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 6.269161] usbcore: registered new interface driver rt2800usb
[ 6.290853] usb 2-1: usb_suspend_both: status 0
[ 6.291109] usb usb2: usb_suspend_both: status 0
[ 8.491483] tegra-xudc-new 700d0000.xudc: ep 13 (type: 2, dir: in) enabled
[ 8.491501] tegra-xudc-new 700d0000.xudc: ep 8 (type: 2, dir: out) enabled
[ 8.491732] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 10.101184] Please complete system configuration setup on the serial port provided by Jetson's USB device mode connection. e.g. /dev/ttyACMx where x can 0, 1, 2 etc.
[ 13.247228] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.247238] Bluetooth: BNEP socket layer initialized
[ 13.454642] l4tbr0: port 2(usb0) entered blocking state
[ 13.454648] l4tbr0: port 2(usb0) entered forwarding state
[ 13.454691] l4tbr0: port 1(rndis0) entered blocking state
[ 13.454694] l4tbr0: port 1(rndis0) entered forwarding state
[ 13.454875] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 13.454893] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 14.566632] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.567686] eth0: 0xffffff800ab81000, 00:04:4b:e5:5b:c6, IRQ 407
[ 14.617561] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.645360] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 14.645503] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 14.684519] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[ 14.891952] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 17.051166] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 122.745658] EXT4-fs (mmcblk0p1): resizing filesystem from 3142139 to 15626496 blocks
[ 144.908787] EXT4-fs (mmcblk0p1): resized to 7864320 blocks
[ 156.085070] EXT4-fs (mmcblk0p1): resized to 8388608 blocks
[ 166.258745] EXT4-fs (mmcblk0p1): resized to 11534336 blocks
[ 176.485980] EXT4-fs (mmcblk0p1): resized to 14155776 blocks
[ 177.101416] EXT4-fs (mmcblk0p1): resized filesystem to 15626496
[ 178.473843] l4tbr0: port 2(usb0) entered disabled state
[ 178.473890] l4tbr0: port 1(rndis0) entered disabled state
[ 178.477149] tegra-xudc-new 700d0000.xudc: ep 3 disabled
[ 178.477224] tegra-xudc-new 700d0000.xudc: ep 2 disabled
[ 178.477240] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 178.477256] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 178.481859] tegra-xudc-new 700d0000.xudc: ep 13 disabled
[ 178.481949] tegra-xudc-new 700d0000.xudc: ep 8 disabled
[ 178.481965] tegra-xudc-new 700d0000.xudc: ep 13 (type: 2, dir: in) enabled
[ 178.481980] tegra-xudc-new 700d0000.xudc: ep 8 (type: 2, dir: out) enabled
[ 189.472161] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 216.844847] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 796.860169] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 827.491248] wlan0: authenticate with 80:ea:96:f0:71:18
[ 827.524282] wlan0: send auth to 80:ea:96:f0:71:18 (try 1/3)
[ 827.526310] wlan0: authenticated
[ 827.530850] wlan0: associate with 80:ea:96:f0:71:18 (try 1/3)
[ 827.534288] wlan0: RX AssocResp from 80:ea:96:f0:71:18 (capab=0x1411 status=0 aid=11)
[ 827.540180] wlan0: associated
[ 827.540254] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 827.556196] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 80:ea:96:f0:71:18
[ 922.931678] zram: Added device: zram0
[ 922.932148] zram: Added device: zram1
[ 922.932623] zram: Added device: zram2
[ 922.934379] zram: Added device: zram3
[ 922.952403] zram0: detected capacity change from 0 to 519614464
[ 923.013838] Adding 507432k swap on /dev/zram0. Priority:5 extents:1 across:507432k SS
[ 923.028551] zram1: detected capacity change from 0 to 519614464
[ 923.039577] Adding 507432k swap on /dev/zram1. Priority:5 extents:1 across:507432k SS
[ 923.049205] zram2: detected capacity change from 0 to 519614464
[ 923.063998] Adding 507432k swap on /dev/zram2. Priority:5 extents:1 across:507432k SS
[ 923.070732] zram3: detected capacity change from 0 to 519614464
[ 923.082567] Adding 507432k swap on /dev/zram3. Priority:5 extents:1 across:507432k SS
[ 923.371462] tegra-xudc-new 700d0000.xudc: ep 3 disabled
[ 923.371483] tegra-xudc-new 700d0000.xudc: ep 2 disabled
[ 923.371502] tegra-xudc-new 700d0000.xudc: ep 5 disabled
[ 923.371599] tegra-xudc-new 700d0000.xudc: ep 4 disabled
[ 923.371612] tegra-xudc-new 700d0000.xudc: ep 7 disabled
[ 923.371646] tegra-xudc-new 700d0000.xudc: ep 9 disabled
[ 923.371669] tegra-xudc-new 700d0000.xudc: ep 13 disabled
[ 923.371687] tegra-xudc-new 700d0000.xudc: ep 8 disabled
[ 923.371706] tegra-xudc-new 700d0000.xudc: ep 15 disabled
[ 923.371754] tegra-xudc-new 700d0000.xudc: ep 11 disabled
[ 923.371756] android_work: sent uevent USB_STATE=DISCONNECTED
[ 923.371778] tegra-xudc-new 700d0000.xudc: ep 6 disabled
[ 923.371842] tegra-xudc-new 700d0000.xudc: ep 0 disabled
[ 923.433551] device usb0 left promiscuous mode
[ 923.433559] l4tbr0: port 2(usb0) entered disabled state
[ 923.489644] device rndis0 left promiscuous mode
[ 923.489650] l4tbr0: port 1(rndis0) entered disabled state
[ 928.431332] using random self ethernet address
[ 928.435949] using random host ethernet address
[ 928.958355] Mass Storage Function, version: 2009/09/11
[ 928.958365] LUN: removable file: (no medium)
[ 928.969359] using random self ethernet address
[ 928.973926] using random host ethernet address
[ 929.003446] rndis0: HOST MAC 62:73:cc:48:15:a0
[ 929.003515] rndis0: MAC 62:73:cc:48:15:a1
[ 929.003971] usb0: HOST MAC 62:73:cc:48:15:a2
[ 929.004004] usb0: MAC 62:73:cc:48:15:a3
[ 929.004035] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 929.004423] android_work: did not send uevent (0 0 (null))
[ 929.010191] l4tbr0: port 1(rndis0) entered blocking state
[ 929.010195] l4tbr0: port 1(rndis0) entered disabled state
[ 929.010530] device rndis0 entered promiscuous mode
[ 929.016965] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 929.021520] l4tbr0: port 2(usb0) entered blocking state
[ 929.021525] l4tbr0: port 2(usb0) entered disabled state
[ 929.021854] device usb0 entered promiscuous mode
[ 929.027366] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 929.175335] android_work: did not send uevent (0 0 (null))
[ 929.189752] android_work: sent uevent USB_STATE=CONNECTED
[ 929.196980] configfs-gadget gadget: high-speed config #1: c
[ 929.197034] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 929.197060] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 929.197083] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 929.197249] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 929.197274] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 929.197295] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 929.197353] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 929.197384] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 929.197418] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 929.197544] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 929.197878] android_work: sent uevent USB_STATE=CONFIGURED
[ 929.436209] tegra-xudc-new 700d0000.xudc: ep 13 (type: 2, dir: in) enabled
[ 929.436240] tegra-xudc-new 700d0000.xudc: ep 8 (type: 2, dir: out) enabled
[ 929.436859] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 932.294323] tegradc tegradc.0: blank - powerdown
[ 932.294333] tegradc tegradc.1: blank - powerdown
[ 932.845846] fuse init (API version 7.26)
[ 934.961619] l4tbr0: port 2(usb0) entered blocking state
[ 934.961625] l4tbr0: port 2(usb0) entered forwarding state
[ 934.961701] l4tbr0: port 1(rndis0) entered blocking state
[ 934.961706] l4tbr0: port 1(rndis0) entered forwarding state
[ 934.971553] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 934.971581] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
