[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-770) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Aug 12 21:29:52 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@9607b000
[ 0.000000] Found lut_mem2: 00002008@96078000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2053117
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 521725 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f676a000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2020917
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607b000 lut_mem2=0x2008@0x96078000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29512(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7960920K/8212468K available (15230K kernel code, 2914K rwdata, 6628K rodata, 8576K init, 609K bss, 186012K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a118808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a118808 - 0xffffff800a1b0dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001602] Console: colour dummy device 80x25
[ 0.001608] console [tty0] enabled
[ 0.001611] bootconsole [uart8250] disabled
[ 0.001618] kmemleak: Kernel memory leak detector disabled
[ 0.001628] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001636] pid_max: default: 32768 minimum: 301
[ 0.001942] Security Framework initialized
[ 0.002097] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002102] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002691] ftrace: allocating 46938 entries in 184 pages
[ 0.125720] sched-energy: Sched-energy-costs installed from DT
[ 0.125730] ASID allocator initialised with 65536 entries
[ 0.163844] tegra-id: chipid=21817.
[ 0.163850] tegra-id: opt_subrevision=1.
[ 0.163867] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.163874] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.163880] DTB Build time: Aug 12 2019 21:34:58
[ 0.209661] CPU1: Booted secondary processor [4e0f0030]
[ 0.241296] CPU2: Booted secondary processor [4e0f0030]
[ 0.273084] CPU3: Booted secondary processor [411fd073]
[ 0.305072] CPU4: Booted secondary processor [411fd073]
[ 0.337075] CPU5: Booted secondary processor [411fd073]
[ 0.337129] Brought up 6 CPUs
[ 0.337133] SMP: Total of 6 processors activated.
[ 0.337137] CPU features: detected feature: 32-bit EL0 Support
[ 0.337858] CPU: All CPU(s) started at EL2
[ 0.337907] alternatives: patching kernel code
[ 0.347269] devtmpfs: initialized
[ 0.384249] Initilizing CustomIPI irq domain
[ 0.384440] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.384449] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.385278] pinctrl core: initialized pinctrl subsystem
[ 0.385483] OS set in device tree is not L4T.
[ 0.385640] regulator-dummy: no parameters
[ 0.385779] Initializing plugin-manager
[ 0.385832] Plugin module not found
[ 0.385869] Plugin-manager status disabled
[ 0.387707] NET: Registered protocol family 16
[ 0.388406] pstore: using zlib compression
[ 0.388420] console [pstore-1] enabled
[ 0.388422] pstore: Registered ramoops as persistent store backend
[ 0.388426] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.404681] cpuidle: using governor menu
[ 0.406127] bpmp: waiting for handshake
[ 0.406131] bpmp: handshake completed
[ 0.406144] bpmp: synchronizing channels
[ 0.406161] bpmp: channels synchronized
[ 0.406164] bpmp: mail init ok
[ 0.408189] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.408193] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.408197] arm-smmu 12000000.iommu: stage 1 translation
[ 0.408200] arm-smmu 12000000.iommu: stage 2 translation
[ 0.408203] arm-smmu 12000000.iommu: nested translation
[ 0.408209] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.408215] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.408218] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.408223] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.408226] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.410381] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.410393] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.412853] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.414705] Registering BPMP clocks...
[ 0.414802] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.417086] tegra_powergate_init: DONE
[ 0.417095] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.417100] DTB Build time: Aug 12 2019 21:34:58
[ 0.419104] Tegra reboot handler registered.
[ 0.420597] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.420694] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.420708] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.420710] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.420712] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.420868] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.420879] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.421205] iommu: Adding device 3460000.sdhci to group 0
[ 0.421887] iommu: Adding device 3400000.sdhci to group 1
[ 0.422943] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.422955] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.423389] iommu: Adding device 3160000.i2c to group 3
[ 0.423818] iommu: Adding device c240000.i2c to group 4
[ 0.424157] iommu: Adding device 3180000.i2c to group 5
[ 0.424484] iommu: Adding device 3190000.i2c to group 6
[ 0.424940] iommu: Adding device 31b0000.i2c to group 7
[ 0.425276] iommu: Adding device 31c0000.i2c to group 8
[ 0.425602] iommu: Adding device c250000.i2c to group 9
[ 0.425927] iommu: Adding device 31e0000.i2c to group 10
[ 0.427417] iommu: Adding device 3210000.spi to group 11
[ 0.427750] iommu: Adding device c260000.spi to group 12
[ 0.428080] iommu: Adding device 3240000.spi to group 13
[ 0.428790] iommu: Adding device 3100000.serial to group 14
[ 0.429127] iommu: Adding device 3110000.serial to group 15
[ 0.429460] iommu: Adding device c280000.serial to group 16
[ 0.429797] iommu: Adding device 3130000.serial to group 17
[ 0.431123] iommu: Adding device 2490000.ether_qos to group 18
[ 0.431133] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.431800] iommu: Adding device b000000.rtcpu to group 19
[ 0.434019] iommu: Adding device 13e10000.host1x to group 20
[ 0.434327] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.434625] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.434931] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.435230] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.435527] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.435830] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.436137] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.436437] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.436933] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.437577] iommu: Adding device 15700000.vi to group 30
[ 0.437927] iommu: Adding device 15600000.isp to group 31
[ 0.438387] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.438495] platform 15210000.nvdisplay: OF IOVA linear map 0x9607b000 size (0x800000)
[ 0.438530] platform 15210000.nvdisplay: OF IOVA linear map 0x96078000 size (0x2008)
[ 0.439031] iommu: Adding device 15340000.vic to group 33
[ 0.439246] iommu: Adding device 154c0000.nvenc to group 34
[ 0.439460] iommu: Adding device 15480000.nvdec to group 35
[ 0.439796] iommu: Adding device 15380000.nvjpg to group 36
[ 0.440019] iommu: Adding device 15500000.tsec to group 37
[ 0.440228] iommu: Adding device 15100000.tsecb to group 38
[ 0.440917] iommu: Adding device 15810000.se to group 39
[ 0.441136] iommu: Adding device 15820000.se to group 40
[ 0.441347] iommu: Adding device 15830000.se to group 41
[ 0.441555] iommu: Adding device 15840000.se to group 42
[ 0.442415] iommu: Adding device smmu_test to group 43
[ 0.443010] mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c10000
[ 0.443030] mc: mapped MMIO address: 0xffffff800a6b0000 -> 0x2c20000
[ 0.443039] mc: mapped MMIO address: 0xffffff800a6d0000 -> 0x2c30000
[ 0.443049] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 0.443058] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 0.443066] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.443077] mc-err: mcerr ops are set to t18x
[ 0.443222] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.444297] iommu: Adding device 3530000.xhci to group 44
[ 0.444308] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.444770] iommu: Adding device 3550000.xudc to group 45
[ 0.444781] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.445489] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.445495] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.446056] iommu: Adding device 17000000.gp10b to group 46
[ 0.447083] tegra-reset 5000000.clock: registered 193 resets.
[ 0.449294] iommu: Adding device d000000.bpmp to group 47
[ 0.449503] bpmp: ping status is 0
[ 0.449605] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.452014] bpmp d000000.bpmp: probe ok
[ 0.455186] iommu: Adding device 2600000.dma to group 48
[ 0.456440] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.456463] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.456485] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.456506] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.456530] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.456551] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.456573] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.456765] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.460493] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.460658] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.462294] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.462309] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.462633] iommu: Adding device sound to group 50
[ 0.462994] iommu: Adding device 3510000.hda to group 51
[ 0.470598] iommu: Adding device c1a0000.aon to group 52
[ 0.471042] vdd-ac-bat: 5000 mV
[ 0.472771] vdd-1v8-ap: 1800 mV
[ 0.497319] random: fast init done
[ 0.514839] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.520937] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.521444] SCSI subsystem initialized
[ 0.521707] libata version 3.00 loaded.
[ 0.521960] usbcore: registered new interface driver usbfs
[ 0.522016] usbcore: registered new interface driver hub
[ 0.522129] usbcore: registered new device driver usb
[ 0.526044] GPIO line 241 (touch-rails) hogged as output/high
[ 0.526311] GPIO line 242 (touch-rails) hogged as output/high
[ 0.526732] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.527894] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.528236] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.541691] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.544831] vddio-ddr: at 1125 mV
[ 0.548682] avdd_dsi_csi: 1200 mV
[ 0.552680] vdd-1v8: 1800 mV
[ 0.556693] vdd-3v3-sys: 3300 mV
[ 0.557796] spmic-ldo0: at 1800 mV
[ 0.558492] spmic-ldo1: at 800 mV
[ 0.560679] vddio-3v3: 3300 mV
[ 0.561266] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.564680] vdd-rtc: at 800 mV
[ 0.565535] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.569334] spmic-ldo6: at 1500 mV
[ 0.573335] vdd-pex-1v00: 1000 mV
[ 0.574268] dvdd-pex: 1000 mV
[ 0.574952] GPIO line 221 (spmic_gpio_input) hogged as input
[ 0.575137] GPIO line 222 (spmic_gpio_input) hogged as input
[ 0.575485] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 0.578032] max77620 4-003c: max77620 probe successful
[ 0.578617] media: Linux media interface: v0.10
[ 0.578665] Linux video capture interface: v2.00
[ 0.581984] pps_core: LinuxPPS API ver. 1 registered
[ 0.581991] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.582008] PTP clock support registered
[ 0.582750] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.582782] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.586823] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.592350] trusty trusty: trusty version: Built: 21:17:07 Aug 12 2019
[ 0.592389] trusty trusty: selected api version: 3 (requested 3)
[ 0.593561] Advanced Linux Sound Architecture Driver Initialized.
[ 0.594082] Bluetooth: Core ver 2.22
[ 0.594124] NET: Registered protocol family 31
[ 0.594129] Bluetooth: HCI device and connection manager initialized
[ 0.594140] Bluetooth: HCI socket layer initialized
[ 0.594149] Bluetooth: L2CAP socket layer initialized
[ 0.594172] Bluetooth: SCO socket layer initialized
[ 0.595167] en-vdd-sd: 3300 mV
[ 0.595781] en-vdd-cam: 1800 mV
[ 0.597112] vdd-hdmi: 5000 mV
[ 0.597443] vdd-usb0-5v: 5000 mV
[ 0.597723] vdd-usb1-5v: 5000 mV
[ 0.601687] en-vdd-ts-1v8: 1800 mV
[ 0.605742] en-vdd-ts-hv-3v3: 3300 mV
[ 0.606342] en-vdd-disp-3v3: 3300 mV
[ 0.606959] en-mdm-pwr-3v7: 3700 mV
[ 0.607589] en-vdd-disp-1v8: 1800 mV
[ 0.608248] en-vdd-cam-hv-2v8: 2800 mV
[ 0.608904] en-vdd-cam-1v2: 1200 mV
[ 0.609631] vdd-fan: 5000 mV
[ 0.610046] vdd-3v3: 3300 mV
[ 0.610893] dis-vdd-1v2: 1200 mV
[ 0.611224] en-vdd-vcm-2v8: 2800 mV
[ 0.611848] vdd-usb2-5v: 5000 mV
[ 0.612166] vdd-sys-bl: 3300 mV
[ 0.612761] en-vdd-sys: 1200 mV
[ 0.615786] camchar: rtcpu character device driver loaded
[ 0.616382] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.618412] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.619890] clocksource: Switched to clocksource arch_sys_counter
[ 0.659512] VFS: Disk quotas dquot_6.6.0
[ 0.659726] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.660366] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.661294] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.661303] nvmap_page_pool_init: Total RAM pages: 2006614
[ 0.661309] nvmap_page_pool_init: nvmap page pool size: 250826 pages (979 MB)
[ 0.661496] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.665300] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.677359] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.677566] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.677990] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.678087] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.678220] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.678347] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.678523] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.678771] la/ptsa driver initialized.
[ 0.678784] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.678789] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.679988] NET: Registered protocol family 2
[ 0.681969] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.682639] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.683418] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.683482] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.683613] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.684510] NET: Registered protocol family 1
[ 0.685577] RPC: Registered named UNIX socket transport module.
[ 0.685583] RPC: Registered udp transport module.
[ 0.685587] RPC: Registered tcp transport module.
[ 0.685592] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.685602] PCI: CLS 0 bytes, default 64
[ 0.685842] Trying to unpack rootfs image as initramfs...
[ 0.870624] Freeing initrd memory: 5432K
[ 0.893755] host1x 13e10000.host1x: initialized
[ 0.895724] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.900592] audit: initializing netlink subsys (disabled)
[ 0.900639] audit: type=2000 audit(0.792:1): initialized
[ 0.901421] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.913427] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.916267] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.917810] 9p: Installing v9fs 9p2000 file system support
[ 0.922774] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.922959] io scheduler noop registered
[ 0.923574] io scheduler cfq registered (default)
[ 0.928521] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.990554] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 1.030068] iommu: Adding device 2993000.adsp to group 54
[ 1.031265] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.034996] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 1.039267] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.040742] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.042078] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.043389] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.046509] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 1.047592] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 1.048044] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 1.048275] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.048420] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.048432] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 1.051378] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 1.052770] tsec 15500000.tsec: initialized
[ 1.053861] tsec 15100000.tsecb: initialized
[ 1.057237] nvdec 15480000.nvdec: initialized
[ 1.063337] falcon 15340000.vic: initialized
[ 1.064730] falcon 154c0000.nvenc: initialized
[ 1.065936] falcon 15380000.nvjpg: initialized
[ 1.067991] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.069485] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.070950] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.072400] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.073845] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.075293] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.076795] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.078230] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.081506] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.081513] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.081546] tegradccommon 15200000.dc_common: dma mapping done
[ 1.082045] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.082092] generic_infoframe_type: 0x87
[ 1.082178] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.082199] tegradc 15210000.nvdisplay: Display dc.ffffff800b690000 registered with id=0
[ 1.090773] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.090782] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.090788] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.091125] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.091135] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.092520] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.093399] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.093751] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.094399] kfuse 3830000.kfuse: initialized
[ 1.097124] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.098226] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.098234] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.101992] tegradc 15210000.nvdisplay: probed
[ 1.105015] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.108583] console [ttyS0] disabled
[ 1.108650] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.108725] console [ttyS0] enabled
[ 1.110664] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.112035] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.112419] serial-tegra 3130000.serial: RX in PIO mode
[ 1.112969] Console: switching to colour frame buffer device 240x67
[ 1.113055] tegradc 15210000.nvdisplay: fb registered
[ 1.113312] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.113521] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.113818] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.113878] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.113937] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.114934] [drm] Initialized
[ 1.121468] Parent Clock set for DC plld2
[ 1.137843] brd: module loaded
[ 1.150979] loop: module loaded
[ 1.151107] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.151241] tegra_profiler: auth: init
[ 1.151790] nct1008_nct72 7-004c: starting parse dt
[ 1.151969] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.151977] nct1008_nct72 7-004c: success parsing dt
[ 1.152102] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.152305] THERMAL EST: found 3 subdevs
[ 1.152312] THERMAL EST num_resources: 0
[ 1.152317] [THERMAL EST subdev 0]
[ 1.152325] [THERMAL EST subdev 1]
[ 1.152331] [THERMAL EST subdev 2]
[ 1.152695] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.152701] THERMAL EST: thz register success.
[ 1.157048] THERMAL EST: end of probe, return err: 0
[ 1.158223] hisi_sas: driver version v1.6
[ 1.167039] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.167053] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.168158] scsi host0: tegra_ahci
[ 1.169148] scsi host1: tegra_ahci
[ 1.169449] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.169456] ata2: DUMMY
[ 1.177106] libphy: Fixed MDIO Bus: probed
[ 1.179094] tun: Universal TUN/TAP device driver, 1.6
[ 1.179100] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.180085] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.180090] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.180187] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.180192] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.180286] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.180291] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.180382] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.180387] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.181347] tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.181862] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.181872] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.181955] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 1.184094] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 1.184692] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 1.186250] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b dd ba 3f
[ 1.186400] libphy: dwc_phy: probed
[ 1.186825] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.189451] PPP generic driver version 2.4.2
[ 1.189669] PPP BSD Compression module registered
[ 1.189676] PPP Deflate Compression module registered
[ 1.189705] PPP MPPE Compression module registered
[ 1.189711] NET: Registered protocol family 24
[ 1.189818] usbcore: registered new interface driver r8152
[ 1.189859] usbcore: registered new interface driver asix
[ 1.189896] usbcore: registered new interface driver ax88179_178a
[ 1.189924] usbcore: registered new interface driver cdc_ether
[ 1.189949] usbcore: registered new interface driver net1080
[ 1.189972] usbcore: registered new interface driver cdc_subset
[ 1.190002] usbcore: registered new interface driver zaurus
[ 1.190037] usbcore: registered new interface driver cdc_ncm
[ 1.190223] VFIO - User Level meta-driver version: 0.3
[ 1.191988] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.192011] ehci-pci: EHCI PCI platform driver
[ 1.192043] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.192053] ohci-pci: OHCI PCI platform driver
[ 1.192078] ohci-platform: OHCI generic platform driver
[ 1.198396] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.200301] tegra-xusb 3530000.xhci: extcon 0: ffffffc1eb51f000 id
[ 1.201154] usbcore: registered new interface driver uas
[ 1.201209] usbcore: registered new interface driver usb-storage
[ 1.201283] usbcore: registered new interface driver usbserial
[ 1.202769] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[ 1.206848] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.208041] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.208044] Extcon AUX1(HDMI) enable
[ 1.208226] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 1.217427] nct1008_nct72 7-004c: initial LOC temp: 23000
[ 1.217768] nct1008_nct72 7-004c: initial EXT temp: 33750
[ 1.218469] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.218849] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.219041] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.228121] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.228150] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.229034] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.229081] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 1.229444] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.229453] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.229459] usb usb1: Product: xHCI Host Controller
[ 1.229465] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.229470] usb usb1: SerialNumber: 3530000.xhci
[ 1.230002] hub 1-0:1.0: USB hub found
[ 1.230063] hub 1-0:1.0: 4 ports detected
[ 1.230463] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.230476] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.230674] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.230681] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.230687] usb usb2: Product: xHCI Host Controller
[ 1.230692] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.230697] usb usb2: SerialNumber: 3530000.xhci
[ 1.231190] hub 2-0:1.0: USB hub found
[ 1.231232] hub 2-0:1.0: 3 ports detected
[ 1.332173] usb usb1: usb_suspend_both: status 0
[ 1.343642] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.380209] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 1.380215] tegra-usb-cd usb_cd: connected to SDP
[ 1.380229] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 1.380438] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 1.381284] mousedev: PS/2 mouse device common for all mice
[ 1.381347] usbcore: registered new interface driver xpad
[ 1.381664] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.381666] Extcon AUX1(HDMI) disable
[ 1.408979] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1.409584] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.414653] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.467342] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.477153] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.482988] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.485998] Wake73 for irq=42
[ 1.488866] rtc rtc1: alarm rtc device
[ 1.488957] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.489186] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.490701] i2c /dev entries driver
[ 1.500781] ov5693 2-0036: probing v4l2 sensor.
[ 1.509215] ov5693 2-0036: tegracam sensor driver:ov5693_v2.0.6
[ 1.534206] tegra-i2c 3180000.i2c: no acknowledge from address 0x36
[ 1.534405] regmap_util_write_table_8:regmap_util_write_table:-121
[ 1.534412] ov5693 2-0036: could not read otp bank
[ 1.534421] ov5693 2-0036: Error -121 reading otp data
[ 1.538667] ov5693 2-0036: board setup failed
[ 1.540438] ov5693: probe of 2-0036 failed with error -121
[ 1.547149] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.583205] parse_throttle_dt_data: Num cap clks = 4
[ 1.583227] parse_throttle_dt_data: clk=mcpu type=1
[ 1.583242] parse_throttle_dt_data: clk=bcpu type=2
[ 1.583328] parse_throttle_dt_data: clk=gpu type=4
[ 1.583335] parse_throttle_dt_data: clk=emc type=3
[ 1.589831] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.595619] FAN dev name: pwm-fan
[ 1.596128] FAN:gpio request success.
[ 1.596176] FAN: can't find tach_gpio
[ 1.596454] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.597882] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.597895] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.600314] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.600327] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.600337] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.600345] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.600484] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.600517] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.600526] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.600534] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.600563] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.600571] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.606258] device-mapper: uevent: version 1.0.3
[ 1.608648] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.631570] cpufreq: platform driver Initialization: pass
[ 1.632208] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.632319] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.632739] tegradc 15210000.nvdisplay: unblank
[ 1.633131] sdhci: Secure Digital Host Controller Interface driver
[ 1.633134] sdhci: Copyright(c) Pierre Ossman
[ 1.633136] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.634047] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.634152] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.634410] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.636315] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.636319] Parent Clock set for DC plld2
[ 1.638827] CMDQ: cmdq_platfm_init successful
[ 1.640138] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.640326] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.641561] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.641566] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.642559] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.648651] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.648850] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.650493] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.652413] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 1.657206] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.658104] tegra-se-nvhost 15810000.se: initialized
[ 1.659153] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.659818] tegra-se-nvhost 15820000.se: initialized
[ 1.660813] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.661384] tegra-se-nvhost 15830000.se: initialized
[ 1.662138] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.662693] tegra-se-nvhost 15840000.se: initialized
[ 1.663672] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.664006] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.664917] usbcore: registered new interface driver usbhid
[ 1.664918] usbhid: USB HID core driver
[ 1.670543] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.672707] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.672928] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.673048] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.673252] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.674265] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.674353] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.674428] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.674480] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.674635] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.675234] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 1.675237] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.676194] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.676789] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.676791] Extcon AUX1(HDMI) enable
[ 1.677758] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.678301] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.678485] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.678561] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.678869] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.678873] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 1.678875] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.678932] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.678935] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 1.678938] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.678998] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679001] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 1.679003] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.679058] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679061] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 1.679063] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.679119] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679122] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 1.679124] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.679186] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679191] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 1.679194] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.679248] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679275] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 1.679278] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.679335] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679340] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 1.679342] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.679399] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679405] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 1.679407] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.679461] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679465] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 1.679467] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.679533] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679539] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 1.679541] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.679596] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679602] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 1.679605] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.679659] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679665] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 1.679667] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.679721] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679728] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 1.679730] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.679786] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.679791] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 1.679793] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.679856] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 1.679956] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 1.680451] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.681117] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.681271] denver_knobs_init:MTS_VERSION:43068234
[ 1.682960] nvpmodel: initialized successfully
[ 1.683929] trusty-virtio trusty:virtio: initializing
[ 1.683942] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.684033] trusty_ipc virtio0: vring0: va(pa) ffffffc1e5528000(0) qsz 32 notifyid 1
[ 1.684039] trusty_ipc virtio0: vring1: va(pa) ffffffc1e552a000(0) qsz 32 notifyid 2
[ 1.684104] trusty-virtio trusty:virtio: initializing done
[ 1.684200] trusty_ipc virtio0: is online
[ 1.685570] usbcore: registered new interface driver snd-usb-audio
[ 1.687927] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.699868] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.700014] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.700040] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.700084] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.751085] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.765080] mmc0: periodic cache flush enabled
[ 1.765094] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.765644] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 1.769977] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 1.770231] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 1.774512] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 1.777560] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 1.781180] OPE platform probe
[ 1.781257] OPE platform probe successful
[ 1.795711] tegra-asoc: sound: This is a dummy codec
[ 1.877982] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.878072] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.878160] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.878268] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.878347] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.878427] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.878512] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.878592] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.878672] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.878749] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.878832] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.878910] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.878989] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.879076] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.879155] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.879264] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.879348] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.879431] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.879509] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.879595] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.881929] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.908260] u32 classifier
[ 1.908263] Actions configured
[ 1.908342] Initializing XFRM netlink socket
[ 1.909991] NET: Registered protocol family 10
[ 1.911325] NET: Registered protocol family 17
[ 1.911338] NET: Registered protocol family 15
[ 1.911545] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.911651] Bluetooth: RFCOMM socket layer initialized
[ 1.911667] Bluetooth: RFCOMM ver 1.11
[ 1.911672] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.911678] Bluetooth: HIDP socket layer initialized
[ 1.911697] 9pnet: Installing 9P2000 support
[ 1.911738] Key type dns_resolver registered
[ 1.912036] Registered cp15_barrier emulation handler
[ 1.913045] Registered setend emulation handler
[ 1.914466] registered taskstats version 1
[ 1.918676] isp 15600000.isp: initialized
[ 1.924205] nvcsi 150c0000.nvcsi: initialized
[ 1.930680] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.930759] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 1.930827] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 1.931003] input: gpio-keys as /devices/gpio-keys/input/input2
[ 1.932221] tegra-vi4 15700000.vi: initialized
[ 1.933160] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 1.937420] mmc1: hw tuning done ...
[ 1.944475] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 1.960633] tegra_rtc c2a0000.rtc: setting system clock to 2019-11-11 16:42:59 UTC (1573490579)
[ 1.962184] mmcblk mmc0:0001: Card claimed for testing.
[ 2.003203] bpmp: mounted debugfs mirror
[ 2.005647] bwmgr: missing cdev-type property
[ 2.010973] spmic-ldo0: disabling
[ 2.011168] spmic-ldo1: disabling
[ 2.011334] en-vdd-cam: disabling
[ 2.011338] vdd-usb0-5v: disabling
[ 2.011341] vdd-usb1-5v: disabling
[ 2.011344] en-vdd-disp-3v3: disabling
[ 2.011346] en-mdm-pwr-3v7: disabling
[ 2.011349] en-vdd-disp-1v8: disabling
[ 2.011372] en-vdd-cam-hv-2v8: disabling
[ 2.011375] en-vdd-cam-1v2: disabling
[ 2.011377] vdd-fan: disabling
[ 2.011379] vdd-3v3: disabling
[ 2.011382] en-vdd-vcm-2v8: disabling
[ 2.011386] vdd-sys-bl: disabling
[ 2.011388] en-vdd-sys: disabling
[ 2.011391] ALSA device list:
[ 2.011394] #0: tegra-hda at 0x3518000 irq 383
[ 2.011396] #1: tegra-snd-t186ref-mobile-rt565x
[ 2.103895] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.120394] mmc2: hw tuning done ...
[ 2.120468] mmc2: new ultra high speed SDR104 SDXC card at address 0001
[ 2.121082] mmcblk2: mmc2:0001 GD4QT 119 GiB
[ 2.122241] mmcblk2: p1
[ 2.131409] usb 1-2: New USB device found, idVendor=0bda, idProduct=5401
[ 2.131413] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.131415] usb 1-2: Product: USB3.0 Hub
[ 2.131417] usb 1-2: Manufacturer: Realtek
[ 2.132136] hub 1-2:1.0: USB hub found
[ 2.133203] hub 1-2:1.0: 4 ports detected
[ 2.286416] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.288476] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.419908] usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
[ 2.456632] usb 1-2.1: New USB device found, idVendor=04f2, idProduct=0116
[ 2.456635] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.456637] usb 1-2.1: Product: USB Keyboard
[ 2.456638] usb 1-2.1: Manufacturer: CHICONY
[ 2.465960] input: CHICONY USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:04F2:0116.0001/input/input3
[ 2.524192] hid-generic 0003:04F2:0116.0001: input,hidraw0: USB HID v1.11 Keyboard [CHICONY USB Keyboard] on usb-3530000.xhci-2.1/input0
[ 2.603912] usb 1-2.4: new high-speed USB device number 4 using tegra-xusb
[ 2.691416] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.842398] usb 1-2.4: New USB device found, idVendor=046d, idProduct=0825
[ 2.842403] usb 1-2.4: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[ 2.842406] usb 1-2.4: SerialNumber: F265D4D0
[ 3.097156] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.502064] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.504104] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.714366] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 3.714369] Extcon HDMI: HPD enabled
[ 3.714384] tegradc 15210000.nvdisplay: hdmi: plugged
[ 3.714671] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.715037] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 3.716177] Freeing unused kernel memory: 8576K
[ 3.731894] random: crng init done
[ 3.751165] L4T-INITRD Build DATE: Mon Nov 11 16:43:01 UTC 2019
[ 3.759321] Root device found: mmcblk0p1
[ 3.761733] Found dev node: /dev/mmcblk0p1
[ 3.789293] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.790432] Rootfs mounted over mmcblk0p1
[ 3.823554] Switching from initrd to actual rootfs
[ 3.992579] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.037478] cgroup: cgroup2: unknown option "nsdelegate"
[ 4.066613] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.069752] systemd[1]: Detected architecture arm64.
[ 4.159560] systemd[1]: Set hostname to <coach-tx2>.
[ 4.183177] usb 1-2.4: set resolution quirk: cval->res = 384
[ 4.251515] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.251540] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.352365] Wake76 for irq=199
[ 4.352371] Wake77 for irq=199
[ 4.352373] Wake78 for irq=199
[ 4.352375] Wake79 for irq=199
[ 4.352378] Wake80 for irq=199
[ 4.352380] Wake81 for irq=199
[ 4.352383] Wake82 for irq=199
[ 4.352415] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.352420] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.411905] usb 1-2.2: new low-speed USB device number 5 using tegra-xusb
[ 4.436219] usb 1-2.2: New USB device found, idVendor=04f2, idProduct=0939
[ 4.436223] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.436226] usb 1-2.2: Product: USB Optical Mouse
[ 4.436228] usb 1-2.2: Manufacturer: PixArt
[ 4.438990] input: PixArt USB Optical Mouse as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:04F2:0939.0002/input/input4
[ 4.439180] hid-generic 0003:04F2:0939.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3530000.xhci-2.2/input0
[ 4.449856] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.453353] systemd[1]: Created slice User and Session Slice.
[ 4.453420] systemd[1]: Reached target Swap.
[ 4.461312] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.461389] systemd[1]: Reached target User and Group Name Lookups.
[ 4.506389] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 4.537205] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.681062] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.713903] usb 2-1: New USB device found, idVendor=0bda, idProduct=0401
[ 4.713912] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.713916] usb 2-1: Product: USB3.0 Hub
[ 4.713920] usb 2-1: Manufacturer: Realtek
[ 4.800649] systemd-journald[2362]: Received request to flush runtime journal from PID 1
[ 5.658014] dhd_module_init in
[ 5.658090] found wifi platform device bcmdhd_wlan
[ 5.659532] wifi_platform_get_country_code_map: could not get country_code_map
[ 5.659537] wifi_plat_dev_drv_probe:platform country code map is not available
[ 5.659553] Power-up adapter 'DHD generic adapter'
[ 5.659559] wifi_platform_set_power = 1
[ 5.728932] hub 2-1:1.0: USB hub found
[ 5.730416] hub 2-1:1.0: 4 ports detected
[ 5.863911] wifi_platform_bus_enumerate device present 1
[ 5.885017] wifi_platform_bus_enumerate device present 0
[ 5.885625] F1 signature read @0x18000000=0x17214354
[ 5.896116] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 5.896946] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 5.897026] wifi_platform_get_mac_addr
[ 5.907939] usb 2-1: usb_suspend_both: status 0
[ 5.908106] usb usb2: usb_suspend_both: status 0
[ 5.930356] ids dhd_log_netlink_init
[ 5.932436] wl_event_handler :
[ 5.932442] tsk Enter, tsk = 0xffffffc1d8d41a90
[ 5.932448] wl_create_event_handler(): thread:wl_event_handler:130f started
[ 5.932654] dhd_attach(): thread:dhd_watchdog_thread:1312 started
[ 5.933623] dhd_attach(): thread:dhd_dpc:1313 started
[ 5.935215] dhd_attach(): thread:dhd_rxf:1314 started
[ 5.935226] dhd_deferred_work_init: work queue initialized
[ 5.935869]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 5.937196] Register interface [wlan0] MAC: 00:04:4b:dd:ba:3d
[ 5.937202] dhd_prot_ioctl : bus is down. we have nothing to do
[ 5.941579] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 62
[ 5.944906] wifi_platform_set_power = 0
[ 5.994109] using random self ethernet address
[ 6.009286] using random host ethernet address
[ 6.058085] Mass Storage Function, version: 2009/09/11
[ 6.058095] LUN: removable file: (no medium)
[ 6.080001] using random self ethernet address
[ 6.090589] using random host ethernet address
[ 6.140613] rndis0: HOST MAC 72:a0:a1:74:c0:c4
[ 6.140801] rndis0: MAC 72:a0:a1:74:c0:c5
[ 6.142723] usb0: HOST MAC 72:a0:a1:74:c0:c6
[ 6.142764] usb0: MAC 72:a0:a1:74:c0:c7
[ 6.142794] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.151206] l4tbr0: port 1(rndis0) entered blocking state
[ 6.151214] l4tbr0: port 1(rndis0) entered disabled state
[ 6.171688] device rndis0 entered promiscuous mode
[ 6.202609] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.233948] l4tbr0: port 2(usb0) entered blocking state
[ 6.233956] l4tbr0: port 2(usb0) entered disabled state
[ 6.238518] device usb0 entered promiscuous mode
[ 6.249810] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 6.255296] nvgpu: 17000000.gp10b railgate_enable_store:283 [INFO] railgate is disabled.
[ 6.474769] android_work: did not send uevent (0 0 (null))
[ 6.543522] android_work: sent uevent USB_STATE=CONNECTED
[ 6.554744] android_work: sent uevent USB_STATE=DISCONNECTED
[ 6.651456] android_work: sent uevent USB_STATE=CONNECTED
[ 6.652820] configfs-gadget gadget: high-speed config #1: c
[ 6.652852] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 6.652868] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 6.652883] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 6.652960] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 6.652976] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 6.652990] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 6.653021] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 6.653059] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 6.653188] android_work: sent uevent USB_STATE=CONFIGURED
[ 6.653223] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 6.653238] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 6.662078] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 6.662095] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 6.662192] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 6.730782] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
[ 6.744620] uvcvideo 1-2.4:1.0: Entity type for entity Extension 4 was not initialized!
[ 6.760223] uvcvideo 1-2.4:1.0: Entity type for entity Extension 6 was not initialized!
[ 6.768713] uvcvideo 1-2.4:1.0: Entity type for entity Extension 7 was not initialized!
[ 6.777075] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
[ 6.790128] uvcvideo 1-2.4:1.0: Entity type for entity Extension 3 was not initialized!
[ 6.801235] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
[ 6.810388] input: UVC Camera (046d:0825) as /devices/3530000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/input/input5
[ 6.811431] usbcore: registered new interface driver uvcvideo
[ 6.812402] USB Video Class driver (1.1.1)
[ 7.095117] zram: Added device: zram0
[ 7.096310] zram: Added device: zram1
[ 7.096659] zram: Added device: zram2
[ 7.097021] zram: Added device: zram3
[ 7.097340] zram: Added device: zram4
[ 7.100483] zram: Added device: zram5
[ 7.124486] CPU1: shutdown
[ 7.143932] psci: Retrying again to check for CPU kill
[ 7.143937] psci: CPU1 killed.
[ 7.146515] zram0: detected capacity change from 0 to 686120960
[ 7.159736] Adding 670036k swap on /dev/zram0. Priority:5 extents:1 across:670036k SS
[ 7.238823] CPU2: shutdown
[ 7.255900] psci: Retrying again to check for CPU kill
[ 7.255907] psci: CPU2 killed.
[ 7.258563] zram1: detected capacity change from 0 to 686120960
[ 7.270145] Adding 670036k swap on /dev/zram1. Priority:5 extents:1 across:670036k SS
[ 7.276951] zram2: detected capacity change from 0 to 686120960
[ 7.297014] Adding 670036k swap on /dev/zram2. Priority:5 extents:1 across:670036k SS
[ 7.307608] zram3: detected capacity change from 0 to 686120960
[ 7.351647] Adding 670036k swap on /dev/zram3. Priority:5 extents:1 across:670036k SS
[ 7.358704] zram4: detected capacity change from 0 to 686120960
[ 7.368927] Adding 670036k swap on /dev/zram4. Priority:5 extents:1 across:670036k SS
[ 7.372043] zram5: detected capacity change from 0 to 686120960
[ 7.413884] Adding 670036k swap on /dev/zram5. Priority:5 extents:1 across:670036k SS
[ 7.571348] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.644890] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 7.647203] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.699764] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.699911]
Compiled from
[ 7.699921] wl_android_wifi_on in
[ 7.699924] wifi_platform_set_power = 1
[ 7.913685] vdd-1v8: voltage operation not allowed
[ 7.913697] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 7.932103] vdd-1v8: voltage operation not allowed
[ 7.932113] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 7.952934] vdd-1v8: voltage operation not allowed
[ 7.952944] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 7.955369] vdd-1v8: voltage operation not allowed
[ 7.955377] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.061658] vdd-1v8: voltage operation not allowed
[ 8.061672] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.062599] vdd-1v8: voltage operation not allowed
[ 8.062610] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.064231] vdd-1v8: voltage operation not allowed
[ 8.064248] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.064284] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 62
[ 8.065374] F1 signature read @0x18000000=0x17214354
[ 8.070979] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.071729] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.172430] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 8.234960] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 8.235302] gpio tegra-gpio-aon wake69 for gpio=5
