[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140nir-or (nvidia@nvidia-desktop) (gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1) ) #2 SMP PREEMPT Wed Sep 4 14:47:24 IDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] Found tegra_fbmem2: 00140000@9607b000
[ 0.000000] Found lut_mem2: 00002008@96078000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2054845
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523453 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f676a000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022645
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x140000@0x9607b000 lut_mem2=0x2008@0x96078000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29584(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7967712K/8219380K available (15166K kernel code, 2908K rwdata, 6836K rodata, 8512K init, 611K bss, 186132K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff8009610000 ( 6912 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e60000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a137008 ( 2909 KB)
[ 0.000000] .bss : 0xffffff800a137008 - 0xffffff800a1cfdbc ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001595] Console: colour dummy device 80x25
[ 0.001600] console [tty0] enabled
[ 0.001604] bootconsole [uart8250] disabled
[ 0.001611] kmemleak: Kernel memory leak detector disabled
[ 0.001620] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.001627] pid_max: default: 32768 minimum: 301
[ 0.001938] Security Framework initialized
[ 0.002096] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002100] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002690] ftrace: allocating 46783 entries in 183 pages
[ 0.127133] sched-energy: Sched-energy-costs installed from DT
[ 0.127144] ASID allocator initialised with 65536 entries
[ 0.163607] tegra-id: chipid=21817.
[ 0.163614] tegra-id: opt_subrevision=1.
[ 0.163631] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.163639] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.163645] DTB Build time: Aug 12 2019 21:34:58
[ 0.209656] CPU1: Booted secondary processor [4e0f0030]
[ 0.241290] CPU2: Booted secondary processor [4e0f0030]
[ 0.273081] CPU3: Booted secondary processor [411fd073]
[ 0.305069] CPU4: Booted secondary processor [411fd073]
[ 0.337059] CPU5: Booted secondary processor [411fd073]
[ 0.337112] Brought up 6 CPUs
[ 0.337116] SMP: Total of 6 processors activated.
[ 0.337121] CPU features: detected feature: 32-bit EL0 Support
[ 0.337938] CPU: All CPU(s) started at EL2
[ 0.337988] alternatives: patching kernel code
[ 0.347471] devtmpfs: initialized
[ 0.383826] Initilizing CustomIPI irq domain
[ 0.384007] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.384019] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.384837] pinctrl core: initialized pinctrl subsystem
[ 0.385025] OS set in device tree is not L4T.
[ 0.385165] regulator-dummy: no parameters
[ 0.385300] Initializing plugin-manager
[ 0.385363] Plugin module not found
[ 0.385402] Plugin-manager status disabled
[ 0.387135] NET: Registered protocol family 16
[ 0.387812] persistent_ram: found existing invalid buffer, size 2320, start 2456
[ 0.387818] pstore: using zlib compression
[ 0.387830] console [pstore-1] enabled
[ 0.387833] pstore: Registered ramoops as persistent store backend
[ 0.387837] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.404680] cpuidle: using governor menu
[ 0.406066] bpmp: waiting for handshake
[ 0.406070] bpmp: handshake completed
[ 0.406083] bpmp: synchronizing channels
[ 0.406099] bpmp: channels synchronized
[ 0.406103] bpmp: mail init ok
[ 0.408065] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.408070] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.408074] arm-smmu 12000000.iommu: stage 1 translation
[ 0.408078] arm-smmu 12000000.iommu: stage 2 translation
[ 0.408080] arm-smmu 12000000.iommu: nested translation
[ 0.408087] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.408092] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.408096] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.408101] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.408104] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.410185] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e64000)
[ 0.410197] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.412827] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.414580] Registering BPMP clocks…
[ 0.414672] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.416859] tegra_powergate_init: DONE
[ 0.416867] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.416873] DTB Build time: Aug 12 2019 21:34:58
[ 0.418815] Tegra reboot handler registered.
[ 0.420261] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.420323] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.420336] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.420338] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.420341] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.420489] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.420499] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.420855] iommu: Adding device 3460000.sdhci to group 0
[ 0.421543] iommu: Adding device 3400000.sdhci to group 1
[ 0.422617] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.422630] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.423064] iommu: Adding device 3160000.i2c to group 3
[ 0.423489] iommu: Adding device c240000.i2c to group 4
[ 0.423827] iommu: Adding device 3180000.i2c to group 5
[ 0.424157] iommu: Adding device 3190000.i2c to group 6
[ 0.424578] iommu: Adding device 31b0000.i2c to group 7
[ 0.424949] iommu: Adding device 31c0000.i2c to group 8
[ 0.425284] iommu: Adding device c250000.i2c to group 9
[ 0.425619] iommu: Adding device 31e0000.i2c to group 10
[ 0.427099] iommu: Adding device 3210000.spi to group 11
[ 0.427428] iommu: Adding device c260000.spi to group 12
[ 0.427756] iommu: Adding device 3240000.spi to group 13
[ 0.428432] iommu: Adding device 3100000.serial to group 14
[ 0.428804] iommu: Adding device 3110000.serial to group 15
[ 0.429140] iommu: Adding device c280000.serial to group 16
[ 0.429480] iommu: Adding device 3130000.serial to group 17
[ 0.430813] iommu: Adding device 2490000.ether_qos to group 18
[ 0.430825] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.431487] iommu: Adding device b000000.rtcpu to group 19
[ 0.433719] iommu: Adding device 13e10000.host1x to group 20
[ 0.434023] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.434324] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.434634] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.434930] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.435227] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.435529] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.435837] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.436135] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.436601] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.437287] iommu: Adding device 15700000.vi to group 30
[ 0.437642] iommu: Adding device 15600000.isp to group 31
[ 0.438092] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.438201] platform 15210000.nvdisplay: OF IOVA linear map 0x9607b000 size (0x140000)
[ 0.438217] platform 15210000.nvdisplay: OF IOVA linear map 0x96078000 size (0x2008)
[ 0.438724] iommu: Adding device 15340000.vic to group 33
[ 0.438944] iommu: Adding device 154c0000.nvenc to group 34
[ 0.439160] iommu: Adding device 15480000.nvdec to group 35
[ 0.439497] iommu: Adding device 15380000.nvjpg to group 36
[ 0.439720] iommu: Adding device 15500000.tsec to group 37
[ 0.439932] iommu: Adding device 15100000.tsecb to group 38
[ 0.440596] iommu: Adding device 15810000.se to group 39
[ 0.440831] iommu: Adding device 15820000.se to group 40
[ 0.441039] iommu: Adding device 15830000.se to group 41
[ 0.441251] iommu: Adding device 15840000.se to group 42
[ 0.442109] iommu: Adding device smmu_test to group 43
[ 0.442693] mc: mapped MMIO address: 0xffffff800a6c0000 → 0x2c10000
[ 0.442704] mc: mapped MMIO address: 0xffffff800a6e0000 → 0x2c20000
[ 0.442714] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c30000
[ 0.442724] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c40000
[ 0.442734] mc: mapped MMIO address: 0xffffff800b110000 → 0x2c50000
[ 0.442741] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.442752] mc-err: mcerr ops are set to t18x
[ 0.442897] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.443995] iommu: Adding device 3530000.xhci to group 44
[ 0.444006] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.444449] iommu: Adding device 3550000.xudc to group 45
[ 0.444460] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.445204] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.445210] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.445780] iommu: Adding device 17000000.gp10b to group 46
[ 0.446802] tegra-reset 5000000.clock: registered 193 resets.
[ 0.449004] iommu: Adding device d000000.bpmp to group 47
[ 0.449208] bpmp: ping status is 0
[ 0.449305] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.451671] bpmp d000000.bpmp: probe ok
[ 0.454839] iommu: Adding device 2600000.dma to group 48
[ 0.456066] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.456091] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.456113] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.456135] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.456159] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.456182] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.456204] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.456417] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.460134] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.460304] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.461933] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.461947] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.462263] iommu: Adding device sound to group 50
[ 0.462617] iommu: Adding device 3510000.hda to group 51
[ 0.471360] iommu: Adding device c1a0000.aon to group 52
[ 0.472158] vdd-ac-bat: 5000 mV
[ 0.476405] vdd-1v8-ap: 1800 mV
[ 0.497326] random: fast init done
[ 0.510377] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.516214] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.516746] SCSI subsystem initialized
[ 0.516987] libata version 3.00 loaded.
[ 0.517200] usbcore: registered new interface driver usbfs
[ 0.517246] usbcore: registered new interface driver hub
[ 0.517398] usbcore: registered new device driver usb
[ 0.520988] GPIO line 241 (touch-rails) hogged as output/high
[ 0.521236] GPIO line 242 (touch-rails) hogged as output/high
[ 0.521522] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.522510] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.522804] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.535005] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.541896] vddio-ddr: at 1125 mV
[ 0.545681] avdd_dsi_csi: 1200 mV
[ 0.549724] vdd-1v8: 1800 mV
[ 0.553696] vdd-3v3-sys: 3300 mV
[ 0.554977] spmic-ldo0: at 1800 mV
[ 0.555856] spmic-ldo1: at 800 mV
[ 0.561681] vddio-3v3: 3300 mV
[ 0.562396] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.565688] vdd-rtc: at 800 mV
[ 0.566600] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.569684] spmic-ldo6: at 1500 mV
[ 0.573687] vdd-pex-1v00: 1000 mV
[ 0.574468] dvdd-pex: 1000 mV
[ 0.575052] GPIO line 221 (spmic_gpio_input) hogged as input
[ 0.575226] GPIO line 222 (spmic_gpio_input) hogged as input
[ 0.575563] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 0.577880] max77620 4-003c: max77620 probe successful
[ 0.578451] media: Linux media interface: v0.10
[ 0.578515] Linux video capture interface: v2.00
[ 0.581896] pps_core: LinuxPPS API ver. 1 registered
[ 0.581903] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.581926] PTP clock support registered
[ 0.582563] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.582596] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.586446] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.591934] trusty trusty: trusty version: Built: 21:17:07 Aug 12 2019
[ 0.591975] trusty trusty: selected api version: 3 (requested 3)
[ 0.593149] Advanced Linux Sound Architecture Driver Initialized.
[ 0.593667] Bluetooth: Core ver 2.22
[ 0.593785] NET: Registered protocol family 31
[ 0.593791] Bluetooth: HCI device and connection manager initialized
[ 0.593803] Bluetooth: HCI socket layer initialized
[ 0.593811] Bluetooth: L2CAP socket layer initialized
[ 0.593835] Bluetooth: SCO socket layer initialized
[ 0.594919] en-vdd-sd: 3300 mV
[ 0.595558] en-vdd-cam: 1800 mV
[ 0.597453] vdd-hdmi: 5000 mV
[ 0.598005] vdd-usb0-5v: 5000 mV
[ 0.598444] vdd-usb1-5v: 5000 mV
[ 0.601335] en-vdd-ts-1v8: 1800 mV
[ 0.605342] en-vdd-ts-hv-3v3: 3300 mV
[ 0.605955] en-vdd-disp-3v3: 3300 mV
[ 0.606537] en-mdm-pwr-3v7: 3700 mV
[ 0.607146] en-vdd-disp-1v8: 1800 mV
[ 0.607697] en-vdd-cam-hv-2v8: 2800 mV
[ 0.608294] en-vdd-cam-1v2: 1200 mV
[ 0.608889] vdd-fan: 5000 mV
[ 0.609178] vdd-3v3: 3300 mV
[ 0.609959] dis-vdd-1v2: 1200 mV
[ 0.610256] en-vdd-vcm-2v8: 2800 mV
[ 0.610865] vdd-usb2-5v: 5000 mV
[ 0.611161] vdd-sys-bl: 3300 mV
[ 0.611727] en-vdd-sys: 1200 mV
[ 0.614882] camchar: rtcpu character device driver loaded
[ 0.615508] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.617513] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.618983] clocksource: Switched to clocksource arch_sys_counter
[ 0.660176] VFS: Disk quotas dquot_6.6.0
[ 0.660419] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.660989] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.661917] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.661926] nvmap_page_pool_init: Total RAM pages: 2008312
[ 0.661933] nvmap_page_pool_init: nvmap page pool size: 251039 pages (980 MB)
[ 0.662044] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.665860] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.677588] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.677783] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.678216] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.678308] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.678453] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.678581] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.678756] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.679114] la/ptsa driver initialized.
[ 0.679127] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.679132] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.680270] NET: Registered protocol family 2
[ 0.682240] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.682838] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.683689] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.683747] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.683872] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.684746] NET: Registered protocol family 1
[ 0.685831] RPC: Registered named UNIX socket transport module.
[ 0.685837] RPC: Registered udp transport module.
[ 0.685842] RPC: Registered tcp transport module.
[ 0.685846] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.685857] PCI: CLS 0 bytes, default 64
[ 0.686141] Trying to unpack rootfs image as initramfs…
[ 0.877713] Freeing initrd memory: 5432K
[ 0.898923] host1x 13e10000.host1x: initialized
[ 0.900419] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.904647] audit: initializing netlink subsys (disabled)
[ 0.904694] audit: type=2000 audit(0.796:1): initialized
[ 0.905401] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.917711] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.920362] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.921940] 9p: Installing v9fs 9p2000 file system support
[ 0.927958] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.928105] io scheduler noop registered
[ 0.928752] io scheduler cfq registered (default)
[ 0.933750] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.996889] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 1.037783] iommu: Adding device 2993000.adsp to group 54
[ 1.038936] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.042657] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 1.047037] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.048528] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.049852] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.051199] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.053920] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 1.055051] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 1.055457] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 1.055838] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.056031] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.056041] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 1.059300] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 1.060732] tsec 15500000.tsec: initialized
[ 1.061867] tsec 15100000.tsecb: initialized
[ 1.065317] nvdec 15480000.nvdec: initialized
[ 1.071462] falcon 15340000.vic: initialized
[ 1.072944] falcon 154c0000.nvenc: initialized
[ 1.074235] falcon 15380000.nvjpg: initialized
[ 1.076174] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.077589] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.079031] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.080455] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.081861] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.083286] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.084685] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.086109] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.089247] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.089254] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.089289] tegradccommon 15200000.dc_common: dma mapping done
[ 1.090351] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.090474] generic_infoframe_type: 0x87
[ 1.090693] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.090747] tegradc 15210000.nvdisplay: Display dc.ffffff800b650000 registered with id=0
[ 1.100095] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.100103] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.100108] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.100402] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.100413] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.102130] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.102564] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=50347983
[ 1.103105] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.104696] kfuse 3830000.kfuse: initialized
[ 1.106513] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.106522] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.106843] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.111971] tegradc 15210000.nvdisplay: probed
[ 1.116264] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.120091] console [ttyS0] disabled
[ 1.120140] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.120195] console [ttyS0] enabled
[ 1.121729] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.122870] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.123171] serial-tegra 3130000.serial: RX in PIO mode
[ 1.123667] Console: switching to colour frame buffer device 80x30
[ 1.123713] tegradc 15210000.nvdisplay: fb registered
[ 1.123911] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.124234] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.124637] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.124700] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.124760] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.125449] [drm] Initialized
[ 1.132247] Parent Clock set for DC plld2
[ 1.140539] brd: module loaded
[ 1.149494] loop: module loaded
[ 1.149578] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.149734] tegra_profiler: auth: init
[ 1.150289] nct1008_nct72 7-004c: starting parse dt
[ 1.150425] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.150433] nct1008_nct72 7-004c: success parsing dt
[ 1.150578] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.150689] THERMAL EST: found 3 subdevs
[ 1.150696] THERMAL EST num_resources: 0
[ 1.150702] [THERMAL EST subdev 0]
[ 1.150709] [THERMAL EST subdev 1]
[ 1.150715] [THERMAL EST subdev 2]
[ 1.151156] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.151162] THERMAL EST: thz register success.
[ 1.151280] THERMAL EST: end of probe, return err: 0
[ 1.152869] hisi_sas: driver version v1.6
[ 1.157928] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.157944] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.159287] scsi host0: tegra_ahci
[ 1.160302] scsi host1: tegra_ahci
[ 1.160598] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.160605] ata2: DUMMY
[ 1.166912] libphy: Fixed MDIO Bus: probed
[ 1.169270] tun: Universal TUN/TAP device driver, 1.6
[ 1.169276] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.170145] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.170151] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.170240] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.170245] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.170332] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.170338] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.170433] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.170438] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.172112] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 1.176184] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c5 38 b1
[ 1.176321] libphy: dwc_phy: probed
[ 1.176736] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.179211] PPP generic driver version 2.4.2
[ 1.179400] PPP BSD Compression module registered
[ 1.179406] PPP Deflate Compression module registered
[ 1.179451] PPP MPPE Compression module registered
[ 1.179457] NET: Registered protocol family 24
[ 1.179509] usbcore: registered new interface driver r8152
[ 1.179554] usbcore: registered new interface driver asix
[ 1.179582] usbcore: registered new interface driver ax88179_178a
[ 1.179624] usbcore: registered new interface driver cdc_ether
[ 1.179657] usbcore: registered new interface driver net1080
[ 1.179699] usbcore: registered new interface driver cdc_subset
[ 1.179743] usbcore: registered new interface driver zaurus
[ 1.179801] usbcore: registered new interface driver cdc_ncm
[ 1.179987] VFIO - User Level meta-driver version: 0.3
[ 1.181595] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.181613] ehci-pci: EHCI PCI platform driver
[ 1.181655] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.181665] ohci-pci: OHCI PCI platform driver
[ 1.181701] ohci-platform: OHCI generic platform driver
[ 1.182857] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 1.183369] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 1.184458] tegradc 15210000.nvdisplay: hdmi: tmds rate:50349K prod-setting:prod_c_hdmi_0m_54m
[ 1.184993] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.185003] tegradc 15210000.nvdisplay: hdmi: BL set VIC 0
[ 1.185006] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.187412] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.189416] tegra-xusb 3530000.xhci: extcon 0: ffffffc1ead93400 id
[ 1.190235] usbcore: registered new interface driver uas
[ 1.190295] usbcore: registered new interface driver usb-storage
[ 1.190410] usbcore: registered new interface driver usbserial
[ 1.191032] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[ 1.195372] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.196592] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 1.198648] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.198654] Extcon AUX1(HDMI) enable
[ 1.215141] nct1008_nct72 7-004c: initial LOC temp: 35000
[ 1.215447] nct1008_nct72 7-004c: initial EXT temp: 47750
[ 1.216054] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.216421] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.216644] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.219202] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.219223] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.220098] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.220144] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 1.220567] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.220575] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.220581] usb usb1: Product: xHCI Host Controller
[ 1.220586] usb usb1: Manufacturer: Linux 4.9.140nir-or xhci-hcd
[ 1.220591] usb usb1: SerialNumber: 3530000.xhci
[ 1.220985] hub 1-0:1.0: USB hub found
[ 1.221030] hub 1-0:1.0: 4 ports detected
[ 1.221463] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.221477] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.221732] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.221739] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.221745] usb usb2: Product: xHCI Host Controller
[ 1.221750] usb usb2: Manufacturer: Linux 4.9.140nir-or xhci-hcd
[ 1.221755] usb usb2: SerialNumber: 3530000.xhci
[ 1.222126] hub 2-0:1.0: USB hub found
[ 1.222172] hub 2-0:1.0: 3 ports detected
[ 1.315212] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.351715] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.351719] Extcon AUX1(HDMI) disable
[ 1.371107] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 1.371113] tegra-usb-cd usb_cd: connected to SDP
[ 1.371127] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 1.371142] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 1.371981] mousedev: PS/2 mouse device common for all mice
[ 1.372058] usbcore: registered new interface driver xpad
[ 1.379866] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1.380499] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.386183] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.422428] tegradc 15210000.nvdisplay: unblank
[ 1.429276] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.430006] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.430520] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.444695] Parent Clock set for DC plld2
[ 1.448771] tegradc 15210000.nvdisplay: hdmi: tmds rate:108000K prod-setting:prod_c_hdmi_54m_111m
[ 1.473647] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.487013] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.489558] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.490962] Wake73 for irq=42
[ 1.492327] rtc rtc1: alarm rtc device
[ 1.492342] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.492370] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.492621] i2c /dev entries driver
[ 1.494891] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.500896] parse_throttle_dt_data: Num cap clks = 4
[ 1.500901] parse_throttle_dt_data: clk=mcpu type=1
[ 1.500906] parse_throttle_dt_data: clk=bcpu type=2
[ 1.500914] parse_throttle_dt_data: clk=gpu type=4
[ 1.500918] parse_throttle_dt_data: clk=emc type=3
[ 1.502083] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.502681] FAN dev name: pwm-fan
[ 1.502736] FAN:gpio request success.
[ 1.502744] FAN: can’t find tach_gpio
[ 1.502772] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.502987] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.502992] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.503290] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.503294] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.503297] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.503301] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.503303] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.503306] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.503309] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.503312] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.503315] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.503318] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.504234] device-mapper: uevent: version 1.0.3
[ 1.504618] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.508839] cpufreq: platform driver Initialization: pass
[ 1.509431] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.509544] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.510305] sdhci: Secure Digital Host Controller Interface driver
[ 1.510306] sdhci: Copyright(c) Pierre Ossman
[ 1.510307] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.512008] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.513976] CMDQ: cmdq_platfm_init successful
[ 1.515255] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.517365] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.521194] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.521240] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.521932] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.524348] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 1.528882] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.529842] tegra-se-nvhost 15810000.se: initialized
[ 1.530937] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.531628] tegra-se-nvhost 15820000.se: initialized
[ 1.532627] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.533443] tegra-se-nvhost 15830000.se: initialized
[ 1.534238] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.535246] tegra-se-nvhost 15840000.se: initialized
[ 1.536302] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.536599] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.537716] usbcore: registered new interface driver usbhid
[ 1.537718] usbhid: USB HID core driver
[ 1.544299] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.547122] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.547382] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.547496] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.547658] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.547871] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.549132] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.549238] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.549305] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.549360] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.549527] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.550002] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 1.550006] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.550998] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.552475] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.553003] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.553228] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.553305] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.553676] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.553679] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 1.553682] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.553741] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.553744] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 1.553746] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.553803] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.553805] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 1.553808] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.553864] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.553867] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 1.553869] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.553925] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.553927] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 1.553929] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.553991] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.553997] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 1.553999] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.554063] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554068] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 1.554071] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.554128] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554133] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 1.554136] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.554200] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554205] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 1.554208] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.554266] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554269] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 1.554271] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.554355] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554360] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 1.554363] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.554430] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554436] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 1.554438] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.554496] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554502] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 1.554504] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.554564] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554570] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 1.554572] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.554630] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.554635] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 1.554637] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.554706] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 1.554796] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 1.555403] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.555904] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.556028] denver_knobs_init:MTS_VERSION:43068234
[ 1.558109] nvpmodel: initialized successfully
[ 1.559038] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.559229] trusty-virtio trusty:virtio: initializing
[ 1.559399] trusty_ipc virtio0: vring0: va¶ ffffffc1e6bd6000(0) qsz 32 notifyid 1
[ 1.559406] trusty_ipc virtio0: vring1: va¶ ffffffc1e5504000(0) qsz 32 notifyid 2
[ 1.559538] trusty-virtio trusty:virtio: initializing done
[ 1.559877] trusty_ipc virtio0: is online
[ 1.561143] usbcore: registered new interface driver snd-usb-audio
[ 1.567009] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.570771] usb 1-2: New USB device found, idVendor=0409, idProduct=005a
[ 1.570777] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.571047] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.571094] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.571320] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.571543] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.571837] hub 1-2:1.0: USB hub found
[ 1.571910] hub 1-2:1.0: 4 ports detected
[ 1.625265] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.640136] mmc0: periodic cache flush enabled
[ 1.640149] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.640696] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 1.644991] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 1.645215] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 1.645406] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 1.647211] OPE platform probe
[ 1.647279] OPE platform probe successful
[ 1.648432] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 1.649475] tegra-asoc: sound: This is a dummy codec
[ 1.694301] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.694375] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.694439] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.694505] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.694570] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.694634] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.694699] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.694763] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.694826] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.694891] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.694956] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.695047] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.695115] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.695181] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.695245] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.695312] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.695378] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.695444] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.695508] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.695575] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.732929] u32 classifier
[ 1.732932] Actions configured
[ 1.733010] Initializing XFRM netlink socket
[ 1.734858] NET: Registered protocol family 10
[ 1.736178] NET: Registered protocol family 17
[ 1.736189] NET: Registered protocol family 15
[ 1.736394] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.736482] Bluetooth: RFCOMM socket layer initialized
[ 1.736496] Bluetooth: RFCOMM ver 1.11
[ 1.736502] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.736507] Bluetooth: HIDP socket layer initialized
[ 1.736526] 9pnet: Installing 9P2000 support
[ 1.736568] Key type dns_resolver registered
[ 1.736986] Registered cp15_barrier emulation handler
[ 1.736999] Registered setend emulation handler
[ 1.738489] registered taskstats version 1
[ 1.751637] isp 15600000.isp: initialized
[ 1.788817] nvcsi 150c0000.nvcsi: initialized
[ 1.793761] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.793843] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 1.793925] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 1.794090] input: gpio-keys as /devices/gpio-keys/input/input2
[ 1.819605] mmc1: hw tuning done …
[ 1.819856] tegra-vi4 15700000.vi: initialized
[ 1.821052] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–1 bound
[ 1.823515] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 1.827721] tegra_rtc c2a0000.rtc: setting system clock to 2019-09-04 12:07:16 UTC (1567598836)
[ 1.829067] mmcblk mmc0:0001: Card claimed for testing.
[ 1.864813] bpmp: mounted debugfs mirror
[ 1.866584] bwmgr: missing cdev-type property
[ 1.867048] usb 1-2.2: new low-speed USB device number 3 using tegra-xusb
[ 1.872573] spmic-ldo0: disabling
[ 1.872764] spmic-ldo1: disabling
[ 1.872924] en-vdd-cam: disabling
[ 1.872927] vdd-usb0-5v: disabling
[ 1.872929] vdd-usb1-5v: disabling
[ 1.872954] en-vdd-disp-3v3: disabling
[ 1.872956] en-mdm-pwr-3v7: disabling
[ 1.872959] en-vdd-disp-1v8: disabling
[ 1.872961] en-vdd-cam-hv-2v8: disabling
[ 1.872963] en-vdd-cam-1v2: disabling
[ 1.872965] vdd-fan: disabling
[ 1.872967] vdd-3v3: disabling
[ 1.872969] en-vdd-vcm-2v8: disabling
[ 1.872972] vdd-sys-bl: disabling
[ 1.872974] en-vdd-sys: disabling
[ 1.872977] ALSA device list:
[ 1.872979] #0: tegra-hda at 0x3518000 irq 383
[ 1.872981] #1: tegra-snd-t186ref-mobile-rt565x
[ 1.890723] usb 1-2.2: New USB device found, idVendor=045e, idProduct=0797
[ 1.890728] usb 1-2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.890731] usb 1-2.2: Product: USB Optical Mouse
[ 1.893853] input: USB Optical Mouse as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:045E:0797.0001/input/input3
[ 1.894149] hid-generic 0003:045E:0797.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3530000.xhci-2.2/input0
[ 1.897016] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.991004] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 2.016896] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c31c
[ 2.016901] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.016904] usb 1-2.3: Product: USB Keyboard
[ 2.016906] usb 1-2.3: Manufacturer: Logitech
[ 2.022690] input: Logitech USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:046D:C31C.0002/input/input4
[ 2.079430] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3530000.xhci-2.3/input0
[ 2.086370] input: Logitech USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:046D:C31C.0003/input/input5
[ 2.086384] mmc2: hw tuning done …
[ 2.086416] mmc2: new ultra high speed SDR50 SDHC card at address aaaa
[ 2.086781] mmcblk2: mmc2:aaaa SS08G 7.40 GiB
[ 2.089809] mmcblk2: p1
[ 2.143261] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3530000.xhci-2.3/input1
[ 2.299228] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.301263] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.674995] usb 1-2.4: new high-speed USB device number 5 using tegra-xusb
[ 2.695620] usb 1-2.4: New USB device found, idVendor=0781, idProduct=5567
[ 2.695625] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.695628] usb 1-2.4: Product: Cruzer Blade
[ 2.695630] usb 1-2.4: Manufacturer: SanDisk
[ 2.695633] usb 1-2.4: SerialNumber: 4C530001071013106313
[ 2.696451] usb-storage 1-2.4:1.0: USB Mass Storage device detected
[ 2.696622] scsi host2: usb-storage 1-2.4:1.0
[ 2.701038] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.103161] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.500712] Freeing unused kernel memory: 8512K
[ 3.505099] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.507020] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.509377] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 3.509380] Extcon HDMI: HPD enabled
[ 3.509403] tegradc 15210000.nvdisplay: hdmi: plugged
[ 3.535882] L4T-INITRD Build DATE: Wed Sep 4 12:07:18 UTC 2019
[ 3.543883] Root device found: mmcblk0p1
[ 3.545522] Found dev node: /dev/mmcblk0p1
[ 3.693409] EXT4-fs (mmcblk0p1): 23 orphan inodes deleted
[ 3.693412] EXT4-fs (mmcblk0p1): recovery complete
[ 3.700896] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.702462] Rootfs mounted over mmcblk0p1
[ 3.710059] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.710417] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 3.723964] scsi 2:0:0:0: Direct-Access SanDisk Cruzer Blade 1.00 PQ: 0 ANSI: 6
[ 3.725024] sd 2:0:0:0: [sda] 61341696 512-byte logical blocks: (31.4 GB/29.3 GiB)
[ 3.726629] sd 2:0:0:0: [sda] Write Protect is off
[ 3.726636] sd 2:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 3.727390] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.730090] Switching from initrd to actual rootfs
[ 3.749747] sda: sda1
[ 3.751787] sd 2:0:0:0: [sda] Attached SCSI removable disk
[ 3.915459] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.960527] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.989065] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.992250] systemd[1]: Detected architecture arm64.
[ 4.087494] systemd[1]: Set hostname to .
[ 4.177023] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.177049] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.339500] Wake76 for irq=199
[ 4.339506] Wake77 for irq=199
[ 4.339508] Wake78 for irq=199
[ 4.339511] Wake79 for irq=199
[ 4.339513] Wake80 for irq=199
[ 4.339515] Wake81 for irq=199
[ 4.339517] Wake82 for irq=199
[ 4.339550] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.339555] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.362763] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.362821] systemd[1]: Reached target Swap.
[ 4.363348] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.366788] systemd[1]: Created slice User and Session Slice.
[ 4.367224] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.374780] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.376992] systemd[1]: Created slice System Slice.
[ 4.377488] systemd[1]: Listening on udev Control Socket.
[ 4.411325] random: crng init done
[ 4.411329] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.418344] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 4.443286] usb usb2: usb_suspend_both: status 0
[ 4.456415] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.738334] systemd-journald[2275]: Received request to flush runtime journal from PID 1
[ 5.529042] using random self ethernet address
[ 5.534256] using random host ethernet address
[ 5.569638] Mass Storage Function, version: 2009/09/11
[ 5.569647] LUN: removable file: (no medium)
[ 5.582352] using random self ethernet address
[ 5.586962] using random host ethernet address
[ 5.638691] rndis0: HOST MAC 3a:99:a7:61:ff:64
[ 5.638850] rndis0: MAC 3a:99:a7:61:ff:65
[ 5.640077] usb0: HOST MAC 3a:99:a7:61:ff:66
[ 5.640112] usb0: MAC 3a:99:a7:61:ff:67
[ 5.640136] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.644609] l4tbr0: port 1(rndis0) entered blocking state
[ 5.644613] l4tbr0: port 1(rndis0) entered disabled state
[ 5.645109] device rndis0 entered promiscuous mode
[ 5.654195] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.676299] l4tbr0: port 2(usb0) entered blocking state
[ 5.676304] l4tbr0: port 2(usb0) entered disabled state
[ 5.676797] device usb0 entered promiscuous mode
[ 5.695850] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.803516] android_work: did not send uevent (0 0 (null))
[ 5.876569] android_work: sent uevent USB_STATE=CONNECTED
[ 5.917841] nvgpu: 17000000.gp10b railgate_enable_store:283 [INFO] railgate is disabled.
[ 5.931450] android_work: sent uevent USB_STATE=DISCONNECTED
[ 6.024350] android_work: sent uevent USB_STATE=CONNECTED
[ 6.027035] configfs-gadget gadget: high-speed config #1: c
[ 6.027063] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 6.027079] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 6.027094] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 6.027172] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 6.027188] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 6.027202] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 6.027235] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 6.027253] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 6.027273] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 6.031077] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 6.031246] android_work: sent uevent USB_STATE=CONFIGURED
[ 6.035552] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 6.035570] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 6.035698] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 6.138696] dhd_module_init in
[ 6.138772] found wifi platform device bcmdhd_wlan
[ 6.141170] wifi_platform_get_country_code_map: could not get country_code_map
[ 6.141178] wifi_plat_dev_drv_probe:platform country code map is not available
[ 6.141211] Power-up adapter ‘DHD generic adapter’
[ 6.141220] wifi_platform_set_power = 1
[ 6.350633] wifi_platform_bus_enumerate device present 1
[ 6.446691] wifi_platform_bus_enumerate device present 0
[ 6.483463] F1 signature read @0x18000000=0x17214354
[ 6.498150] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 6.502071] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 6.502153] wifi_platform_get_mac_addr
[ 6.514548] ids dhd_log_netlink_init
[ 6.522421] wl_create_event_handler(): thread:wl_event_handler:152f started
[ 6.522434] wl_event_handler :
[ 6.522442] tsk Enter, tsk = 0xffffffc1e03c1a90
[ 6.527426] dhd_attach(): thread:dhd_watchdog_thread:1539 started
[ 6.529607] dhd_attach(): thread:dhd_dpc:153d started
[ 6.536540] dhd_attach(): thread:dhd_rxf:1541 started
[ 6.536548] dhd_deferred_work_init: work queue initialized
[ 6.571826]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 6.572611] Register interface [wlan0] MAC: 00:04:4b:c5:38:af
[ 6.572618] dhd_prot_ioctl : bus is down. we have nothing to do
[ 6.572991] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 64
[ 6.574040] wifi_platform_set_power = 0
[ 6.689655] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.691796] CPU1: shutdown
[ 6.701517] psci: CPU1 killed.
[ 6.710813] zram: Added device: zram0
[ 6.713155] zram: Added device: zram1
[ 6.715327] zram: Added device: zram2
[ 6.717037] zram: Added device: zram3
[ 6.740125] zram: Added device: zram4
[ 6.742733] zram: Added device: zram5
[ 6.784769] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 6.789133] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.799897] CPU2: shutdown
[ 6.802632] psci: CPU2 killed.
[ 6.812158] zram0: detected capacity change from 0 to 686694400
[ 6.846307] Adding 670596k swap on /dev/zram0. Priority:5 extents:1 across:670596k SS
[ 6.850862] zram1: detected capacity change from 0 to 686694400
[ 6.877078] Adding 670596k swap on /dev/zram1. Priority:5 extents:1 across:670596k SS
[ 6.894269] zram2: detected capacity change from 0 to 686694400
[ 6.909192] Adding 670596k swap on /dev/zram2. Priority:5 extents:1 across:670596k SS
[ 6.912439] zram3: detected capacity change from 0 to 686694400
[ 6.941800] Adding 670596k swap on /dev/zram3. Priority:5 extents:1 across:670596k SS
[ 6.945796] zram4: detected capacity change from 0 to 686694400
[ 6.976872] Adding 670596k swap on /dev/zram4. Priority:5 extents:1 across:670596k SS
[ 6.979912] zram5: detected capacity change from 0 to 686694400
[ 7.007768] Adding 670596k swap on /dev/zram5. Priority:5 extents:1 across:670596k SS
[ 7.666307] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.666434]
Compiled from
[ 7.666441] wl_android_wifi_on in
[ 7.666445] wifi_platform_set_power = 1
[ 7.875590] vdd-1v8: voltage operation not allowed
[ 7.875602] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 7.895218] vdd-1v8: voltage operation not allowed
[ 7.895227] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 7.916025] vdd-1v8: voltage operation not allowed
[ 7.916035] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 7.918447] vdd-1v8: voltage operation not allowed
[ 7.918455] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.023661] vdd-1v8: voltage operation not allowed
[ 8.023674] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.024594] vdd-1v8: voltage operation not allowed
[ 8.024603] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.026147] vdd-1v8: voltage operation not allowed
[ 8.026154] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.026178] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 64
[ 8.026738] F1 signature read @0x18000000=0x17214354
[ 8.031449] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.032084] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.116117] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 8.178402] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 8.178805] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 8.178891] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 8.178894] Enabling wake69
[ 8.179931] wifi_platform_get_mac_addr
[ 8.182372] Firmware up: op_mode=0x0005, MAC=00:04:4b:c5:38:af
[ 8.187600] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 8.187652] Skipping the clm download. len:0 memblk: (null)
[ 8.190238] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 8.195938] Firmware version = wl0: May 17 2019 16:59:40 version 7.35.349.79 (r714996 CY) FWID 01-e527e2ad
[ 8.198668] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 8.321309] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[ 8.321313] P2P interface registered
[ 8.335770] WLC_E_IF: NO_IF set, event Ignored
[ 8.355773] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.582673] tegradc 15210000.nvdisplay: blank - powerdown
[ 8.647964] extcon-disp-state external-connection:disp-state: cable 47 state 0 already set.
[ 8.647965] Extcon AUX1(HDMI) disable
