dmesg as follows:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-rt93-tegra (will@ubuntu) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT RT Tue Sep 22 08:13:27 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2055168
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f676a000 s64704 r8192 d29504 u102400
[ 0.000000] pcpu-alloc: s64704 r8192 d29504 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022968
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29212(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7960716K/8220672K available (15294K kernel code, 2964K rwdata, 6688K rodata, 8512K init, 621K bss, 194420K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e50000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e50000 - 0xffffff800a135008 ( 2965 KB)
[ 0.000000] .bss : 0xffffff800a135008 - 0xffffff800a1d07f8 ( 622 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001655] Console: colour dummy device 80x25
[ 0.001663] console [tty0] enabled
[ 0.001665] bootconsole [uart8250] disabled
[ 0.001671] kmemleak: Kernel memory leak detector disabled
[ 0.001701] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=31250)
[ 0.001703] pid_max: default: 32768 minimum: 301
[ 0.002019] Security Framework initialized
[ 0.002178] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002181] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002831] ftrace: allocating 46900 entries in 184 pages
[ 0.128589] sched-energy: Sched-energy-costs installed from DT
[ 0.128600] ASID allocator initialised with 65536 entries
[ 0.147422] tegra-id: chipid=21817.
[ 0.147428] tegra-id: opt_subrevision=1.
[ 0.147445] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.147453] DTS File Name: /home/will/workspace/tx2_rt_patch/sources/kernel/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.147458] DTB Build time: Oct 10 2020 01:05:19
[ 0.163707] CPU1: Booted secondary processor [4e0f0030]
[ 0.175406] CPU2: Booted secondary processor [4e0f0030]
[ 0.187155] CPU3: Booted secondary processor [411fd073]
[ 0.198139] CPU4: Booted secondary processor [411fd073]
[ 0.209116] CPU5: Booted secondary processor [411fd073]
[ 0.209199] Brought up 6 CPUs
[ 0.209204] SMP: Total of 6 processors activated.
[ 0.209208] CPU features: detected feature: 32-bit EL0 Support
[ 0.209942] CPU: All CPU(s) started at EL2
[ 0.209994] alternatives: patching kernel code
[ 0.212959] devtmpfs: initialized
[ 0.255770] Initilizing CustomIPI irq domain
[ 0.255956] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.255967] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.256945] pinctrl core: initialized pinctrl subsystem
[ 0.257161] OS set in device tree is not L4T.
[ 0.257383] regulator-dummy: no parameters
[ 0.257533] Initializing plugin-manager
[ 0.257591] Plugin module not found
[ 0.257628] Plugin-manager status disabled
[ 0.259597] NET: Registered protocol family 16
[ 0.260472] pstore: using zlib compression
[ 0.260486] console [pstore-1] enabled
[ 0.260489] pstore: Registered ramoops as persistent store backend
[ 0.260493] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.261080] cpuidle: using governor menu
[ 0.262771] bpmp: waiting for handshake
[ 0.262775] bpmp: handshake completed
[ 0.262789] bpmp: synchronizing channels
[ 0.262805] bpmp: channels synchronized
[ 0.262808] bpmp: mail init ok
[ 0.265013] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.265019] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.265023] arm-smmu 12000000.iommu: stage 1 translation
[ 0.265026] arm-smmu 12000000.iommu: stage 2 translation
[ 0.265029] arm-smmu 12000000.iommu: nested translation
[ 0.265035] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.265040] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.265044] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.265049] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.265052] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.267827] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e54000)
[ 0.267840] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.269430] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.271634] Registering BPMP clocks…
[ 0.271725] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.272799] Serial: AMBA PL011 UART driver
[ 0.274040] tegra_powergate_init: DONE
[ 0.274048] DTS File Name: /home/will/workspace/tx2_rt_patch/sources/kernel/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.274054] DTB Build time: Oct 10 2020 01:05:19
[ 0.276658] Tegra reboot handler registered.
[ 0.278307] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.278376] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.278388] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.278390] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.278393] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.278568] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.278578] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.278919] iommu: Adding device 3460000.sdhci to group 0
[ 0.279664] iommu: Adding device 3400000.sdhci to group 1
[ 0.280793] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.280809] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.281299] iommu: Adding device 3160000.i2c to group 3
[ 0.281772] iommu: Adding device c240000.i2c to group 4
[ 0.282163] iommu: Adding device 3180000.i2c to group 5
[ 0.282519] iommu: Adding device 3190000.i2c to group 6
[ 0.282955] iommu: Adding device 31b0000.i2c to group 7
[ 0.283342] iommu: Adding device 31c0000.i2c to group 8
[ 0.283696] iommu: Adding device c250000.i2c to group 9
[ 0.284050] iommu: Adding device 31e0000.i2c to group 10
[ 0.285667] iommu: Adding device 3210000.spi to group 11
[ 0.286023] iommu: Adding device c260000.spi to group 12
[ 0.286400] iommu: Adding device 3240000.spi to group 13
[ 0.287157] iommu: Adding device 3100000.serial to group 14
[ 0.287514] iommu: Adding device 3110000.serial to group 15
[ 0.287857] iommu: Adding device c280000.serial to group 16
[ 0.288231] iommu: Adding device 3130000.serial to group 17
[ 0.289652] iommu: Adding device 2490000.ether_qos to group 18
[ 0.289665] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.290419] iommu: Adding device b000000.rtcpu to group 19
[ 0.292699] iommu: Adding device 13e10000.host1x to group 20
[ 0.293016] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.293366] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.293685] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.294010] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.294356] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.294669] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.295012] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.295375] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.295852] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.296536] iommu: Adding device 15700000.vi to group 30
[ 0.296910] iommu: Adding device 15600000.isp to group 31
[ 0.297409] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.298029] iommu: Adding device 15340000.vic to group 33
[ 0.298288] iommu: Adding device 154c0000.nvenc to group 34
[ 0.298527] iommu: Adding device 15480000.nvdec to group 35
[ 0.298888] iommu: Adding device 15380000.nvjpg to group 36
[ 0.299145] iommu: Adding device 15500000.tsec to group 37
[ 0.299375] iommu: Adding device 15100000.tsecb to group 38
[ 0.300069] iommu: Adding device 15810000.se to group 39
[ 0.300341] iommu: Adding device 15820000.se to group 40
[ 0.300567] iommu: Adding device 15830000.se to group 41
[ 0.300792] iommu: Adding device 15840000.se to group 42
[ 0.301734] iommu: Adding device smmu_test to group 43
[ 0.302366] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c10000
[ 0.302377] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c20000
[ 0.302386] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c30000
[ 0.302397] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c40000
[ 0.302406] mc: mapped MMIO address: 0xffffff800b110000 -> 0x2c50000
[ 0.302415] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.302427] mc-err: mcerr ops are set to t18x
[ 0.302617] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.303892] iommu: Adding device 3530000.xhci to group 44
[ 0.303905] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.304373] iommu: Adding device 3550000.xudc to group 45
[ 0.304384] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.305162] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.305168] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.305798] iommu: Adding device 17000000.gp10b to group 46
[ 0.306927] tegra-reset 5000000.clock: registered 193 resets.
[ 0.309300] iommu: Adding device d000000.bpmp to group 47
[ 0.309528] bpmp: ping status is 0
[ 0.309635] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.312268] bpmp d000000.bpmp: probe ok
[ 0.315563] iommu: Adding device 2600000.dma to group 48
[ 0.316890] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.316921] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.316950] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.316977] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.317007] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.317036] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.317065] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.317252] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.321214] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.321361] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.323041] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.323056] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.323422] iommu: Adding device sound to group 50
[ 0.323798] iommu: Adding device 3510000.hda to group 51
[ 0.331913] iommu: Adding device c1a0000.aon to group 52
[ 0.332428] vdd-ac-bat: 5000 mV
[ 0.334282] vdd-1v8-ap: 1800 mV
[ 0.345511] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.349202] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.349540] SCSI subsystem initialized
[ 0.349782] libata version 3.00 loaded.
[ 0.350126] usbcore: registered new interface driver usbfs
[ 0.350204] usbcore: registered new interface driver hub
[ 0.350307] usbcore: registered new device driver usb
[ 0.353419] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.353451] pca953x 0-0074: failed reading register
[ 0.353515] pca953x: probe of 0-0074 failed with error -121
[ 0.353948] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.353977] pca953x 0-0077: failed reading register
[ 0.354029] pca953x: probe of 0-0077 failed with error -121
[ 0.364816] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.368310] vddio-ddr: at 1125 mV
[ 0.370156] avdd_dsi_csi: 1200 mV
[ 0.375154] vdd-1v8: 1800 mV
[ 0.377154] vdd-3v3-sys: 3300 mV
[ 0.378312] spmic-ldo0: at 1800 mV
[ 0.379058] spmic-ldo1: at 800 mV
[ 0.381132] vddio-3v3: 3300 mV
[ 0.381882] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.383136] vdd-rtc: at 800 mV
[ 0.383891] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.385135] spmic-ldo6: at 1500 mV
[ 0.387132] vdd-pex-1v00: 1000 mV
[ 0.387776] dvdd-pex: 1000 mV
[ 0.390095] GPIO line 253 (spmic_gpio_input) hogged as input
[ 0.390253] GPIO line 254 (spmic_gpio_input) hogged as input
[ 0.390418] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 0.390612] max77620 4-003c: max77620 probe successful
[ 0.391017] media: Linux media interface: v0.10
[ 0.391049] Linux video capture interface: v2.00
[ 0.394753] pps_core: LinuxPPS API ver. 1 registered
[ 0.394756] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.394768] PTP clock support registered
[ 0.394962] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.395185] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.395207] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.396643] trusty trusty: trusty version: Built: 21:16:26 Jun 25 2020
[ 0.396658] trusty trusty: selected api version: 3 (requested 3)
[ 0.397543] Advanced Linux Sound Architecture Driver Initialized.
[ 0.397879] Bluetooth: Core ver 2.22
[ 0.397909] NET: Registered protocol family 31
[ 0.397911] Bluetooth: HCI device and connection manager initialized
[ 0.397918] Bluetooth: HCI socket layer initialized
[ 0.397923] Bluetooth: L2CAP socket layer initialized
[ 0.397939] Bluetooth: SCO socket layer initialized
[ 0.398746] en-vdd-sd: 3300 mV
[ 0.399178] vdd-usb0-5v: 5000 mV
[ 0.399469] vdd-usb1-5v: 5000 mV
[ 0.399962] vdd-3v3: 3300 mV
[ 0.400246] en-vdd-vcm-2v8: 2800 mV
[ 0.400492] vdd-sys-bl: 3300 mV
[ 0.402614] camchar: rtcpu character device driver loaded
[ 0.403224] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.405005] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.405838] clocksource: Switched to clocksource arch_sys_counter
[ 0.433979] VFS: Disk quotas dquot_6.6.0
[ 0.434055] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.434310] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.434901] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.434908] nvmap_page_pool_init: Total RAM pages: 2006563
[ 0.434911] nvmap_page_pool_init: nvmap page pool size: 250820 pages (979 MB)
[ 0.434977] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.439201] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.445500] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.445674] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.446111] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.446188] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.446299] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.446406] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.446570] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.446786] la/ptsa driver initialized.
[ 0.446795] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.446797] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.447157] NET: Registered protocol family 2
[ 0.447865] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.448223] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 0.449528] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.449594] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[ 0.449807] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[ 0.450325] NET: Registered protocol family 1
[ 0.450752] RPC: Registered named UNIX socket transport module.
[ 0.450756] RPC: Registered udp transport module.
[ 0.450758] RPC: Registered tcp transport module.
[ 0.450760] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.450767] PCI: CLS 0 bytes, default 64
[ 0.450930] Trying to unpack rootfs image as initramfs…
[ 0.625552] Freeing initrd memory: 5432K
[ 0.636521] random: fast init done
[ 0.642378] host1x 13e10000.host1x: initialized
[ 0.643654] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.645970] audit: initializing netlink subsys (disabled)
[ 0.645996] audit: type=2000 audit(0.533:1): initialized
[ 0.646445] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.653941] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.654967] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.655531] 9p: Installing v9fs 9p2000 file system support
[ 0.657971] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.658060] io scheduler noop registered
[ 0.658356] io scheduler cfq registered (default)
[ 0.661960] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.774061] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 0.810559] iommu: Adding device 2993000.adsp to group 54
[ 0.811707] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.814050] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 0.818253] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.819473] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.820625] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.821763] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.824170] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.825203] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.825592] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.825613] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.825728] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.825733] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 0.828020] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.829335] tsec 15500000.tsec: initialized
[ 0.830526] tsec 15100000.tsecb: initialized
[ 0.834190] nvdec 15480000.nvdec: initialized
[ 0.840693] falcon 15340000.vic: initialized
[ 0.842159] falcon 154c0000.nvenc: initialized
[ 0.843419] falcon 15380000.nvjpg: initialized
[ 0.845319] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.846728] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.848154] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.849516] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.850926] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.852306] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.853704] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.855114] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.858553] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.858562] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.858602] tegradccommon 15200000.dc_common: dma mapping done
[ 0.858913] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=390
[ 0.859217] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.859260] generic_infoframe_type: 0x87
[ 0.859339] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.859359] tegradc 15210000.nvdisplay: Display dc.ffffff800b650000 registered with id=0
[ 0.859572] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 0.860472] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 0.860485] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 0.860711] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 0.860715] tegra_cec 3960000.tegra_cec: probed
[ 0.865038] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.865042] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.865045] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.865226] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.865232] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.866050] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn’t get regulator vdd_hdmi_5v0, -517
[ 0.872072] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 0.872076] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 0.875091] tegradc 15210000.nvdisplay: probed
[ 0.875435] Console: switching to colour frame buffer device 80x30
[ 0.875456] tegradc 15210000.nvdisplay: fb registered
[ 0.875641] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 0.878412] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 0.879198] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 0.879226] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.879660] kfuse 3830000.kfuse: initialized
[ 0.881209] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.884339] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.886932] console [ttyS0] disabled
[ 0.886979] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 0.913784] console [ttyS0] enabled
[ 0.915305] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 0.916230] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 0.916412] serial-tegra 3130000.serial: RX in PIO mode
[ 0.917217] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 0.918298] [drm] Initialized
[ 0.926960] brd: module loaded
[ 0.930664] loop: module loaded
[ 0.930728] tegra_profiler: version: 1.141, samples/io: 48/28
[ 0.930803] tegra_profiler: auth: init
[ 0.931207] nct1008_nct72 7-004c: starting parse dt
[ 0.931302] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 0.931306] nct1008_nct72 7-004c: success parsing dt
[ 0.931418] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 0.931756] THERMAL EST: found 3 subdevs
[ 0.931760] THERMAL EST num_resources: 0
[ 0.931764] [THERMAL EST subdev 0]
[ 0.931768] [THERMAL EST subdev 1]
[ 0.931771] [THERMAL EST subdev 2]
[ 0.932098] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 0.932101] THERMAL EST: thz register success.
[ 0.932187] THERMAL EST: end of probe, return err: 0
[ 0.932824] sd: No Scsi addr parsed to reserve index
[ 0.932888] hisi_sas: driver version v1.6
[ 0.936551] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 0.936558] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 0.937373] scsi host0: tegra_ahci
[ 0.937776] scsi host1: tegra_ahci
[ 0.937945] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 0.937948] ata2: DUMMY
[ 0.944314] libphy: Fixed MDIO Bus: probed
[ 0.945962] tun: Universal TUN/TAP device driver, 1.6
[ 0.945965] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 0.946776] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 0.946778] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 0.946880] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 0.946883] igb: Copyright © 2007-2014 Intel Corporation.
[ 0.946956] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 0.946959] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 0.947024] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 0.947026] Copyright© 1999 - 2017 Intel Corporation.
[ 0.949917] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 0.952932] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d e 31 de
[ 0.953038] libphy: dwc_phy: probed
[ 0.953323] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 0.955322] PPP generic driver version 2.4.2
[ 0.955452] PPP BSD Compression module registered
[ 0.955455] PPP Deflate Compression module registered
[ 0.955468] PPP MPPE Compression module registered
[ 0.955472] NET: Registered protocol family 24
[ 0.955518] usbcore: registered new interface driver r8152
[ 0.955552] usbcore: registered new interface driver asix
[ 0.955581] usbcore: registered new interface driver ax88179_178a
[ 0.955609] usbcore: registered new interface driver cdc_ether
[ 0.955636] usbcore: registered new interface driver net1080
[ 0.955668] usbcore: registered new interface driver cdc_subset
[ 0.955695] usbcore: registered new interface driver zaurus
[ 0.955733] usbcore: registered new interface driver cdc_ncm
[ 0.955879] VFIO - User Level meta-driver version: 0.3
[ 0.956804] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.956818] ehci-pci: EHCI PCI platform driver
[ 0.956887] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.956895] ohci-pci: OHCI PCI platform driver
[ 0.956925] ohci-platform: OHCI generic platform driver
[ 0.959372] usbcore: registered new interface driver uas
[ 0.959411] usbcore: registered new interface driver usb-storage
[ 0.959489] usbcore: registered new interface driver usbserial
[ 0.961335] tegra-usb-cd usb_cd: otg phy is not available yet
[ 0.962988] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 0.963508] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 0.964311] mousedev: PS/2 mouse device common for all mice
[ 0.964361] usbcore: registered new interface driver xpad
[ 0.996016] nct1008_nct72 7-004c: initial LOC temp: 30000
[ 0.996326] nct1008_nct72 7-004c: initial EXT temp: 44250
[ 0.996936] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 0.997295] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 0.997491] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.096158] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.097341] Wake73 for irq=42
[ 1.098590] rtc rtc1: alarm rtc device
[ 1.098601] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.098618] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.098868] i2c /dev entries driver
[ 1.101271] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.106713] parse_throttle_dt_data: Num cap clks = 4
[ 1.106718] parse_throttle_dt_data: clk=mcpu type=1
[ 1.106722] parse_throttle_dt_data: clk=bcpu type=2
[ 1.106728] parse_throttle_dt_data: clk=gpu type=4
[ 1.106731] parse_throttle_dt_data: clk=emc type=3
[ 1.107506] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.108136] FAN: coudln’t get the regulator
[ 1.113264] device-mapper: uevent: version 1.0.3
[ 1.113689] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.113922] CPU EMC frequency mapping table: from device tree
[ 1.120680] cpufreq: platform driver Initialization: pass
[ 1.121457] sdhci: Secure Digital Host Controller Interface driver
[ 1.121459] sdhci: Copyright© Pierre Ossman
[ 1.121460] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.122671] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.124461] CMDQ: cmdq_platfm_init successful
[ 1.125535] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.125699] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.128546] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.128598] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.129588] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.131306] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 1.135865] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.136763] tegra-se-nvhost 15810000.se: initialized
[ 1.137978] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.138586] tegra-se-nvhost 15820000.se: initialized
[ 1.139618] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.140225] tegra-se-nvhost 15830000.se: initialized
[ 1.141073] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.141628] tegra-se-nvhost 15840000.se: initialized
[ 1.142570] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.142804] hidraw: raw HID events driver © Jiri Kosina
[ 1.144266] usbcore: registered new interface driver usbhid
[ 1.144269] usbhid: USB HID core driver
[ 1.146359] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 1.146388] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 1.152851] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.152990] ina3221x: probe of 0-0042 failed with error -121
[ 1.153294] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 1.153329] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 1.156850] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.159876] ina3221x: probe of 0-0043 failed with error -121
[ 1.162542] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.164911] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.165139] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.165329] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.165530] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.165917] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.165959] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.166602] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.166681] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.166765] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.166817] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.167004] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.167392] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 1.167395] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.167923] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.169737] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.170258] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.170424] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.170491] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.170819] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.170822] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 1.170825] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.170911] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.170914] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 1.170916] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.170968] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.170970] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 1.170972] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.171024] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171026] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 1.171028] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.171079] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171081] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 1.171083] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.171132] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171137] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 1.171139] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.171189] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171194] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 1.171196] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.171244] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171249] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 1.171251] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.171302] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171306] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 1.171308] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.171362] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171365] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 1.171366] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.171417] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171423] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 1.171424] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.171483] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171488] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 1.171490] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.171540] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171545] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 1.171547] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.171596] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171602] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 1.171604] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.171653] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.171657] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 1.171659] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.171721] **** A57 ECC: Enabled
[ 1.171723] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 1.171788] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 1.172309] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.172751] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.172994] denver_knobs_init:MTS_VERSION:47926945
[ 1.174967] nvpmodel: initialized successfully
[ 1.175895] trusty-virtio trusty:virtio: initializing
[ 1.176011] trusty_ipc virtio0: vring0: va(pa) ffffffc1e87d4000(0) qsz 32 notifyid 1
[ 1.176017] trusty_ipc virtio0: vring1: va(pa) ffffffc1e87d6000(0) qsz 32 notifyid 2
[ 1.176088] trusty-virtio trusty:virtio: initializing done
[ 1.176195] trusty_ipc virtio0: is online
[ 1.177935] usbcore: registered new interface driver snd-usb-audio
[ 1.186068] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.186209] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.204163] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.220305] mmc0: periodic cache flush enabled
[ 1.220318] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.221793] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[ 1.221922] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[ 1.222033] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[ 1.223147] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[ 1.226556] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 1.232772] OPE platform probe
[ 1.232895] OPE platform probe successful
[ 1.245151] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.250852] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.283368] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.283443] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.283515] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.283586] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.283656] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.283729] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.283800] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.283906] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.283976] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.284046] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.284115] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.284188] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.284258] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.284326] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.284398] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.284468] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.284538] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.284608] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.284677] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.284751] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.305191] u32 classifier
[ 1.305194] Actions configured
[ 1.305254] Initializing XFRM netlink socket
[ 1.305873] NET: Registered protocol family 10
[ 1.306522] NET: Registered protocol family 17
[ 1.306532] NET: Registered protocol family 15
[ 1.306599] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.306645] Bluetooth: RFCOMM socket layer initialized
[ 1.306655] Bluetooth: RFCOMM ver 1.11
[ 1.306659] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.306663] Bluetooth: HIDP socket layer initialized
[ 1.306676] 9pnet: Installing 9P2000 support
[ 1.306710] Key type dns_resolver registered
[ 1.306997] Registered cp15_barrier emulation handler
[ 1.307009] Registered setend emulation handler
[ 1.307924] registered taskstats version 1
[ 1.311606] isp 15600000.isp: initialized
[ 1.316475] nvcsi 150c0000.nvcsi: initialized
[ 1.318327] tegra-vi4 15700000.vi: using default number of vi channels,15
[ 1.324480] tegra-vi4 15700000.vi: initialized
[ 1.325528] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.326377] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 1.326380] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
[ 1.335297] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.338962] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.347704] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.347814] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 1.347944] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 1.348067] input: gpio-keys as /devices/gpio-keys/input/input2
[ 1.349696] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.353289] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.380512] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:28 UTC (946688428)
[ 1.382199] mmcblk mmc0:0001: Card claimed for testing.
[ 1.405192] mmc1: hw tuning done …
[ 1.409919] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 1.415790] bpmp: mounted debugfs mirror
[ 1.417110] bwmgr: missing cdev-type property
[ 1.422997] spmic-ldo0: disabling
[ 1.423157] spmic-ldo1: disabling
[ 1.423316] en-vdd-sd: disabling
[ 1.423318] vdd-usb0-5v: disabling
[ 1.423320] vdd-usb1-5v: disabling
[ 1.423322] vdd-3v3: disabling
[ 1.423324] en-vdd-vcm-2v8: disabling
[ 1.423326] vdd-sys-bl: disabling
[ 1.423328] ALSA device list:
[ 1.423331] #0: tegra-hda at 0x3518000 irq 383
[ 1.423332] #1: tegra-snd-t186ref-mobile-rt565x
[ 1.425873] Freeing unused kernel memory: 8512K
[ 1.448690] Root device found: mmcblk0p1
[ 1.449557] Found dev node: /dev/mmcblk0p1
[ 1.469579] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.470260] Rootfs mounted over mmcblk0p1
[ 1.496074] Switching from initrd to actual rootfs
[ 1.600408] systemd[1]: System time before build time, advancing clock.
[ 1.623982] ip_tables: © 2000-2006 Netfilter Core Team
[ 1.633033] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.646069] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.646819] systemd[1]: Detected architecture arm64.
[ 1.653925] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.664762] systemd[1]: Set hostname to .
[ 1.750469] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 1.750477] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 1.859712] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.861388] systemd[1]: Created slice User and Session Slice.
[ 1.861651] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.863102] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.863139] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.863156] systemd[1]: Reached target User and Group Name Lookups.
[ 1.863191] systemd[1]: Reached target Swap.
[ 1.864024] systemd[1]: Created slice System Slice.
[ 1.871878] tegra_cec 3960000.tegra_cec: Can’t find physical addresse.
[ 1.871884] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 1.887680] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 1.889530] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.901519] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.965546] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.055874] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.057862] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.244647] systemd-journald[2393]: Received request to flush runtime journal from PID 1
[ 2.457850] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.465014] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.582611] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 2.859854] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.261859] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.263860] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.468347] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.468644] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 4.272307] random: crng init done
[ 4.275718] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.896249] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.036068] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 5.116325] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.285071] dhd_module_init in
[ 5.285174] found wifi platform device bcmdhd_wlan
[ 5.293617] wifi_platform_get_country_code_map: could not get country_code_map
[ 5.293623] wifi_plat_dev_drv_probe:platform country code map is not available
[ 5.293640] Power-up adapter ‘DHD generic adapter’
[ 5.293650] wifi_platform_set_power = 1
[ 5.497336] wifi_platform_bus_enumerate device present 1
[ 5.526687] wifi_platform_bus_enumerate device present 0
[ 5.535139] F1 signature read @0x18000000=0x17214354
[ 5.546933] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 5.547880] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 5.547985] wifi_platform_get_mac_addr
[ 5.549921] ids dhd_log_netlink_init
[ 5.589909] wl_create_event_handler(): thread:wl_event_handler:1273 started
[ 5.590874] wl_event_handler :
[ 5.590879] tsk Enter, tsk = 0xffffffc1df501c48
[ 5.624277] dhd_attach(): thread:dhd_watchdog_thread:1282 started
[ 5.624887] dhd_attach(): thread:dhd_dpc:1284 started
[ 5.627089] dhd_attach(): thread:dhd_rxf:1285 started
[ 5.627098] dhd_deferred_work_init: work queue initialized
[ 5.628800]
Dongle Host Driver, version 1.201.82 ®
Compiled from
[ 5.681520] Register interface [wlan0] MAC: 48:b0:2d:0e:31:dc
[ 5.681528] dhd_prot_ioctl : bus is down. we have nothing to do
[ 5.682464] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 65
[ 5.684877] wifi_platform_set_power = 0
[ 5.709266] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 5.791036] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.922549] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 6.022103] tegra-usb-cd usb_cd: otg phy is not available yet
[ 8.685605] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.742709] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 8.748962] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.805180] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.805322]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 8.805330] wl_android_wifi_on in
[ 8.805335] wifi_platform_set_power = 1
[ 9.011918] vdd-1v8: voltage operation not allowed
[ 9.016728] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 9.036244] vdd-1v8: voltage operation not allowed
[ 9.041072] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 9.059896] vdd-1v8: voltage operation not allowed
[ 9.064706] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 9.077119] vdd-1v8: voltage operation not allowed
[ 9.081946] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 9.195822] vdd-1v8: voltage operation not allowed
[ 9.200699] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 9.208245] vdd-1v8: voltage operation not allowed
[ 9.213049] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 9.222001] vdd-1v8: voltage operation not allowed
[ 9.226806] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 9.233443] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 65
[ 9.234223] F1 signature read @0x18000000=0x17214354
[ 9.240743] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.241894] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.330543] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.395438] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.395861] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 9.395921] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 9.395922] Enabling wake69
[ 9.397797] wifi_platform_get_mac_addr
[ 9.399567] Firmware up: op_mode=0x0005, MAC=48:b0:2d:0e:31:dc
[ 9.404330] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 9.404362] Skipping the clm download. len:0 memblk: (null)
[ 9.406739] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.411997] Firmware version = wl0: Nov 6 2019 21:22:23 version 7.35.349.85 (r723239 CY) FWID 01-a59d25b5
[ 9.414527] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.495142] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[ 9.495145] P2P interface registered
[ 9.505395] WLC_E_IF: NO_IF set, event Ignored
[ 9.513782] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.954400] zram: Added device: zram0
[ 9.978693] zram: Added device: zram1
[ 10.008588] zram: Added device: zram2
[ 10.048341] zram: Added device: zram3
[ 10.105107] zram: Added device: zram4
[ 10.150897] zram: Added device: zram5
[ 10.188261] zram0: detected capacity change from 0 to 686096384
[ 10.238565] Adding 670012k swap on /dev/zram0. Priority:5 extents:1 across:670012k SS
[ 10.267779] zram1: detected capacity change from 0 to 686096384
[ 10.285684] Adding 670012k swap on /dev/zram1. Priority:5 extents:1 across:670012k SS
[ 10.302114] zram2: detected capacity change from 0 to 686096384
[ 10.318379] Adding 670012k swap on /dev/zram2. Priority:5 extents:1 across:670012k SS
[ 10.335092] zram3: detected capacity change from 0 to 686096384
[ 10.351600] Adding 670012k swap on /dev/zram3. Priority:5 extents:1 across:670012k SS
[ 10.377825] zram4: detected capacity change from 0 to 686096384
[ 10.407338] Adding 670012k swap on /dev/zram4. Priority:5 extents:1 across:670012k SS
[ 10.423577] zram5: detected capacity change from 0 to 686096384
[ 10.442541] Adding 670012k swap on /dev/zram5. Priority:5 extents:1 across:670012k SS
[ 10.943784] tegradc 15210000.nvdisplay: blank - powerdown
[ 11.214404] [10-10 11:06:17.680] wl_cfg80211_connect: Connectting with d4:5d:64:cc:d5:9c channel (48) ssid “GNSS-5G-RX”, len (10)
[ 11.268172] [10-10 11:06:17.734] wl_notify_connect_status: wl_bss_connect_done succeeded with d4:5d:64:cc:d5:9c
[ 11.279655] [10-10 11:06:17.745] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M1 of 4way
[ 11.285878] wl_bss_connect_done :
[ 11.285881] Report connect result - connection succeeded
[ 11.286586] [10-10 11:06:17.752] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M2 of 4way
[ 11.299318] [10-10 11:06:17.765] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M3 of 4way
[ 11.299487] [10-10 11:06:17.765] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M4 of 4way
[ 11.320427] [10-10 11:06:17.786] wl_notify_connect_status: wl_bss_connect_done succeeded with d4:5d:64:cc:d5:9c
[ 11.323745] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 11.344035] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 11.344045] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 11.377147] ifidx:0 DHCP - REQUEST [TX]
[ 11.382681] ifidx:0 DHCP - ACK [RX]
[ 13.557637] fuse init (API version 7.26)
[ 13.627805] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.627817] Bluetooth: BNEP socket layer initialized
