Hello!
I’m developing driver for custom mipi-csi2 2-lane camera for tx2. Camera streams in YCbCr 4:2:2 768x576@50. It seems that hardware can’t handle stream when I try to capture frame.
- Is Tx2 supports this format?
- Is mclk mandatory for tx2? (camera doesn’t need input clock)
- Can it be caused by too big pix_clk_hz? (I set it to 100MHz, like on other our device)
- Is tegra video drivers support csi_pixel_depth=8?
- Camera stream is always on. Can tx2 sync with running stream?
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra-tegra (kuklin_m@infratest) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #12 SMP PREEMPT Mon Nov 25 17:40:30 +05 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 145600000
[ 0.000000] OF: fdt: - 235e00000 , 200000
[ 0.000000] OF: fdt: - 236600000 , 200000
[ 0.000000] OF: fdt: - 237000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 1793024
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 19912 pages used for memmap
[ 0.000000] Normal zone: 1269248 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1b7048000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1764920
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2372e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x235840000 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29416(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6937844K/7172096K available (15230K kernel code, 2918K rwdata, 6628K rodata, 8576K init, 609K bss, 168716K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a119808 ( 2919 KB)
[ 0.000000] .bss : 0xffffff800a119808 - 0xffffff800a1b1dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf06dc8000 ( 109 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1b7200000 ( 7026 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000964] Console: colour dummy device 80x25
[ 0.000969] console [tty0] enabled
[ 0.000972] bootconsole [uart8250] disabled
[ 0.000979] kmemleak: Kernel memory leak detector disabled
[ 0.000990] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000997] pid_max: default: 32768 minimum: 301
[ 0.001309] Security Framework initialized
[ 0.001467] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.001472] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002080] ftrace: allocating 46972 entries in 184 pages
[ 0.127992] sched-energy: Sched-energy-costs installed from DT
[ 0.128003] ASID allocator initialised with 65536 entries
[ 0.161059] tegra-id: chipid=21817.
[ 0.161065] tegra-id: opt_subrevision=1.
[ 0.161081] Tegra Revision: A02p SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.161089] DTS File Name: tegra186-tx2i-cti-ASG002-revF+.dts
[ 0.161094] DTB Build time: Nov 25 2019 13:46:21
[ 0.209630] CPU1: Booted secondary processor [4e0f0030]
[ 0.241257] CPU2: Booted secondary processor [4e0f0030]
[ 0.273032] CPU3: Booted secondary processor [411fd073]
[ 0.305000] CPU4: Booted secondary processor [411fd073]
[ 0.336991] CPU5: Booted secondary processor [411fd073]
[ 0.337046] Brought up 6 CPUs
[ 0.337050] SMP: Total of 6 processors activated.
[ 0.337055] CPU features: detected feature: 32-bit EL0 Support
[ 0.337867] CPU: All CPU(s) started at EL2
[ 0.337918] alternatives: patching kernel code
[ 0.347429] devtmpfs: initialized
[ 0.371029] Initilizing CustomIPI irq domain
[ 0.371228] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.371239] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.372122] pinctrl core: initialized pinctrl subsystem
[ 0.372320] OS set in device tree is not L4T.
[ 0.372482] regulator-dummy: no parameters
[ 0.372666] Initializing plugin-manager
[ 0.372725] Plugin module not found
[ 0.372760] Plugin-manager status disabled
[ 0.373866] NET: Registered protocol family 16
[ 0.374555] pstore: using zlib compression
[ 0.374569] console [pstore-1] enabled
[ 0.374572] pstore: Registered ramoops as persistent store backend
[ 0.374576] ramoops: attached 0x200000@0x235880000, ecc: 0/0
[ 0.392575] cpuidle: using governor menu
[ 0.393557] bpmp: waiting for handshake
[ 0.393560] bpmp: handshake completed
[ 0.393571] bpmp: synchronizing channels
[ 0.393591] bpmp: channels synchronized
[ 0.393594] bpmp: mail init ok
[ 0.395221] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.395226] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.395230] arm-smmu 12000000.iommu: stage 1 translation
[ 0.395233] arm-smmu 12000000.iommu: stage 2 translation
[ 0.395236] arm-smmu 12000000.iommu: nested translation
[ 0.395242] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.395247] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.395251] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.395256] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.395259] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.396910] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.396923] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.399974] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.400883] Registering BPMP clocks...
[ 0.400975] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.402696] tegra_powergate_init: DONE
[ 0.402703] DTS File Name: tegra186-tx2i-cti-ASG002-revF+.dts
[ 0.402709] DTB Build time: Nov 25 2019 13:46:21
[ 0.403992] Tegra reboot handler registered.
[ 0.405196] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.405259] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.405271] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.405274] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.405276] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.405428] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.405438] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.405719] iommu: Adding device 3460000.sdhci to group 0
[ 0.406132] iommu: Adding device 3440000.sdhci to group 1
[ 0.406536] iommu: Adding device 3400000.sdhci to group 2
[ 0.407604] iommu: Adding device 3507000.ahci-sata to group 3
[ 0.407618] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.408015] iommu: Adding device 3160000.i2c to group 4
[ 0.408413] iommu: Adding device c240000.i2c to group 5
[ 0.408759] iommu: Adding device 3180000.i2c to group 6
[ 0.409072] iommu: Adding device 3190000.i2c to group 7
[ 0.409463] iommu: Adding device 31b0000.i2c to group 8
[ 0.409755] iommu: Adding device 31c0000.i2c to group 9
[ 0.410044] iommu: Adding device c250000.i2c to group 10
[ 0.410330] iommu: Adding device 31e0000.i2c to group 11
[ 0.412254] iommu: Adding device 3210000.spi to group 12
[ 0.412636] iommu: Adding device c260000.spi to group 13
[ 0.412975] iommu: Adding device 3240000.spi to group 14
[ 0.413675] iommu: Adding device 3100000.serial to group 15
[ 0.413979] iommu: Adding device 3110000.serial to group 16
[ 0.414322] iommu: Adding device c280000.serial to group 17
[ 0.414614] iommu: Adding device 3130000.serial to group 18
[ 0.415853] iommu: Adding device 2490000.ether_qos to group 19
[ 0.415865] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.416632] iommu: Adding device b000000.rtcpu to group 20
[ 0.418467] iommu: Adding device 13e10000.host1x to group 21
[ 0.418777] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.419081] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.419371] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.419662] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.419959] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.420258] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.420588] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.420888] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.421348] iommu: Adding device 150c0000.nvcsi to group 30
[ 0.421925] iommu: Adding device 15700000.vi to group 31
[ 0.422249] iommu: Adding device 15600000.isp to group 32
[ 0.422676] iommu: Adding device 15210000.nvdisplay to group 33
[ 0.423182] iommu: Adding device 15340000.vic to group 34
[ 0.423380] iommu: Adding device 154c0000.nvenc to group 35
[ 0.423585] iommu: Adding device 15480000.nvdec to group 36
[ 0.423893] iommu: Adding device 15380000.nvjpg to group 37
[ 0.424087] iommu: Adding device 15500000.tsec to group 38
[ 0.424283] iommu: Adding device 15100000.tsecb to group 39
[ 0.424933] iommu: Adding device 15810000.se to group 40
[ 0.425135] iommu: Adding device 15820000.se to group 41
[ 0.425329] iommu: Adding device 15830000.se to group 42
[ 0.425534] iommu: Adding device 15840000.se to group 43
[ 0.426304] iommu: Adding device smmu_test to group 44
[ 0.426879] mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c10000
[ 0.426890] mc: mapped MMIO address: 0xffffff800a6b0000 -> 0x2c20000
[ 0.426903] mc: mapped MMIO address: 0xffffff800a6d0000 -> 0x2c30000
[ 0.426915] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 0.426924] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 0.426932] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.426942] mc-err: mcerr ops are set to t18x
[ 0.427076] dram-ecc: DRAM ECC enabled-MC_ECC_CONTROL:0x0000000d
[ 0.427097] dram-ecc: SCE-R5 is booted with Camera FW
[ 0.427100] dram-ecc: DRAM ECC interrupts handled in Camera FW
[ 0.428087] iommu: Adding device 3530000.xhci to group 45
[ 0.428099] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.428506] iommu: Adding device 3550000.xudc to group 46
[ 0.428518] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.429241] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.429246] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.429765] iommu: Adding device 17000000.gp10b to group 47
[ 0.430699] tegra-reset 5000000.clock: registered 193 resets.
[ 0.432648] iommu: Adding device d000000.bpmp to group 48
[ 0.432860] bpmp: ping status is 0
[ 0.432964] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.434939] bpmp d000000.bpmp: probe ok
[ 0.437633] iommu: Adding device 2600000.dma to group 49
[ 0.438718] GPIO line 459 (pcie0_lane2_mux) hogged as output/low
[ 0.438739] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.438758] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.438951] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.442700] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.444209] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.444225] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.444530] iommu: Adding device sound to group 51
[ 0.444848] iommu: Adding device 3510000.hda to group 52
[ 0.451780] iommu: Adding device c1a0000.aon to group 53
[ 0.452231] vdd-ac-bat: 5000 mV
[ 0.453958] vdd-1v8-ap: 1800 mV
[ 0.486661] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.492527] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.493042] SCSI subsystem initialized
[ 0.493312] libata version 3.00 loaded.
[ 0.493584] usbcore: registered new interface driver usbfs
[ 0.493722] usbcore: registered new interface driver hub
[ 0.493854] usbcore: registered new device driver usb
[ 0.497288] random: fast init done
[ 0.510209] max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
[ 0.517158] vddio-ddr: at 1125 mV
[ 0.521659] avdd_dsi_csi: 1200 mV
[ 0.525014] vdd-1v8: 1800 mV
[ 0.529014] vdd-3v3-sys: 3300 mV
[ 0.529570] max77620-sd4: at 600 mV
[ 0.530390] spmic-ldo0: at 1800 mV
[ 0.531074] spmic-ldo1: at 800 mV
[ 0.533013] vddio-3v3: 3300 mV
[ 0.533599] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.537015] vdd-rtc: at 800 mV
[ 0.537615] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.541015] spmic-ldo6: at 1500 mV
[ 0.545013] vdd-pex-1v00: 1000 mV
[ 0.545638] dvdd-pex: 1000 mV
[ 0.546129] GPIO line 253 (spmic_gpio_input) hogged as input
[ 0.546273] GPIO line 254 (spmic_gpio_input) hogged as input
[ 0.546461] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 0.548400] max77620 4-003c: max77620 probe successful
[ 0.548870] media: Linux media interface: v0.10
[ 0.548901] Linux video capture interface: v2.00
[ 0.552447] pps_core: LinuxPPS API ver. 1 registered
[ 0.552450] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.552465] PTP clock support registered
[ 0.552841] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.552870] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.554589] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.558751] trusty trusty: trusty version: Built: 16:57:40 Jul 16 2019
[ 0.558764] trusty trusty: selected api version: 3 (requested 3)
[ 0.560041] Advanced Linux Sound Architecture Driver Initialized.
[ 0.560553] Bluetooth: Core ver 2.22
[ 0.560599] NET: Registered protocol family 31
[ 0.560604] Bluetooth: HCI device and connection manager initialized
[ 0.560616] Bluetooth: HCI socket layer initialized
[ 0.560625] Bluetooth: L2CAP socket layer initialized
[ 0.560650] Bluetooth: SCO socket layer initialized
[ 0.561909] en-vdd-sd: 3300 mV
[ 0.562316] en-vdd-cam: 1800 mV
[ 0.562585] vdd-hdmi: 5000 mV
[ 0.562948] vdd-usb0-5v: 5000 mV
[ 0.563311] vdd-usb1-5v: 5000 mV
[ 0.563592] en-vdd-ts-1v8: 1800 mV
[ 0.563895] en-vdd-ts-hv-3v3: 3300 mV
[ 0.564194] en-vdd-disp-3v3: 3300 mV
[ 0.564499] en-mdm-pwr-3v7: 3700 mV
[ 0.564816] en-vdd-disp-1v8: 1800 mV
[ 0.565127] en-vdd-cam-hv-2v8: 2800 mV
[ 0.565437] en-vdd-cam-1v2: 1200 mV
[ 0.565855] vdd-fan: 5000 mV
[ 0.566160] vdd-3v3: 3300 mV
[ 0.566601] dis-vdd-1v2: 1200 mV
[ 0.566932] en-vdd-vcm-2v8: 2800 mV
[ 0.567242] vdd-usb2-5v: 5000 mV
[ 0.567635] vdd-sys-bl: 3300 mV
[ 0.568003] en-vdd-sys: 1200 mV
[ 0.570744] camchar: rtcpu character device driver loaded
[ 0.571314] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.573332] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 0.574815] clocksource: Switched to clocksource arch_sys_counter
[ 0.619298] VFS: Disk quotas dquot_6.6.0
[ 0.619528] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.620669] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
[ 0.621663] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.622048] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.622053] nvmap_page_pool_init: Total RAM pages: 1750845
[ 0.622057] nvmap_page_pool_init: nvmap page pool size: 218855 pages (854 MB)
[ 0.622111] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.622625] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.623169] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[ 0.625348] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[ 0.626982] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.627882] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.639000] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.639209] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.639587] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.639689] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.639840] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.639993] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.640164] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.640375] la/ptsa driver initialized.
[ 0.640388] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.640394] pre_t19x_iso_plat_init(): max_iso_bw=7680000KB
[ 0.641615] NET: Registered protocol family 2
[ 0.643759] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.644342] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.645152] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.645212] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.645340] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.646292] NET: Registered protocol family 1
[ 0.647321] RPC: Registered named UNIX socket transport module.
[ 0.647328] RPC: Registered udp transport module.
[ 0.647333] RPC: Registered tcp transport module.
[ 0.647338] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.647504] PCI: CLS 0 bytes, default 64
[ 0.647785] Trying to unpack rootfs image as initramfs...
[ 0.841961] Freeing initrd memory: 5432K
[ 0.860688] host1x 13e10000.host1x: initialized
[ 0.862018] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.866758] audit: initializing netlink subsys (disabled)
[ 0.866798] audit: type=2000 audit(0.752:1): initialized
[ 0.867622] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.879754] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.882424] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.884015] 9p: Installing v9fs 9p2000 file system support
[ 0.889967] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.890205] io scheduler noop registered
[ 0.890905] io scheduler cfq registered (default)
[ 0.895757] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.954906] iommu: Adding device aconnect@2a41000:adsp_audio to group 54
[ 0.992541] iommu: Adding device 2993000.adsp to group 55
[ 0.993725] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.997378] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 1.001038] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.002479] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.003865] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.005130] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.008373] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.008553] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[ 1.008564] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=750000, max_bw=750000
[ 1.011719] tsec 15500000.tsec: initialized
[ 1.012932] tsec 15100000.tsecb: initialized
[ 1.016126] nvdec 15480000.nvdec: initialized
[ 1.021409] falcon 15340000.vic: initialized
[ 1.023002] falcon 154c0000.nvenc: initialized
[ 1.024397] falcon 15380000.nvjpg: initialized
[ 1.028919] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.030865] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.032444] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.034002] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.035629] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.037190] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.038701] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.040279] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.043259] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.043274] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.043315] tegradccommon 15200000.dc_common: dma mapping done
[ 1.044326] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.044409] generic_infoframe_type: 0x87
[ 1.044543] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.044591] tegradc 15210000.nvdisplay: Display dc.ffffff800b690000 registered with id=0
[ 1.044912] of_fixed_clk: probe of can_clock failed with error -17
[ 1.050848] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.053288] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 5924200 KB/s
[ 1.053296] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 204000000 Hz
[ 1.053301] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 207380000 Hz
[ 1.053611] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.053622] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.055023] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.056481] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.057200] kfuse 3830000.kfuse: initialized
[ 1.058037] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.058045] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.059175] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.063929] tegradc 15210000.nvdisplay: probed
[ 1.067644] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.070944] console [ttyS0] disabled
[ 1.071014] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.071115] console [ttyS0] enabled
[ 1.072835] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.073938] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.074163] serial-tegra 3130000.serial: RX in PIO mode
[ 1.074866] Console: switching to colour frame buffer device 80x30
[ 1.074889] tegradc 15210000.nvdisplay: fb registered
[ 1.075077] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.075088] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.076432] [drm] Initialized
[ 1.086950] brd: module loaded
[ 1.092023] loop: module loaded
[ 1.092121] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.092252] tegra_profiler: auth: init
[ 1.092821] nct1008_nct72 7-004c: starting parse dt
[ 1.092964] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.092976] nct1008_nct72 7-004c: success parsing dt
[ 1.093144] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.093177] THERMAL EST: found 3 subdevs
[ 1.093185] THERMAL EST num_resources: 0
[ 1.093191] [THERMAL EST subdev 0]
[ 1.093198] [THERMAL EST subdev 1]
[ 1.093204] [THERMAL EST subdev 2]
[ 1.093502] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.093507] THERMAL EST: thz register success.
[ 1.093646] THERMAL EST: end of probe, return err: 0
[ 1.094712] hisi_sas: driver version v1.6
[ 1.098713] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.098728] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.099703] scsi host0: tegra_ahci
[ 1.100689] scsi host1: tegra_ahci
[ 1.100881] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.100923] ata2: DUMMY
[ 1.106956] libphy: Fixed MDIO Bus: probed
[ 1.107433] tun: Universal TUN/TAP device driver, 1.6
[ 1.107439] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.108742] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.108748] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.108801] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.108806] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.108839] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.108843] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.108882] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.108887] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.110262] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 1.113972] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a9 2c bb
[ 1.114102] libphy: dwc_phy: probed
[ 1.114534] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.116905] PPP generic driver version 2.4.2
[ 1.117105] PPP BSD Compression module registered
[ 1.117111] PPP Deflate Compression module registered
[ 1.117159] PPP MPPE Compression module registered
[ 1.117165] NET: Registered protocol family 24
[ 1.117224] usbcore: registered new interface driver r8152
[ 1.117265] usbcore: registered new interface driver asix
[ 1.117293] usbcore: registered new interface driver ax88179_178a
[ 1.117318] usbcore: registered new interface driver cdc_ether
[ 1.117346] usbcore: registered new interface driver net1080
[ 1.117371] usbcore: registered new interface driver cdc_subset
[ 1.117395] usbcore: registered new interface driver zaurus
[ 1.117429] usbcore: registered new interface driver cdc_ncm
[ 1.117626] VFIO - User Level meta-driver version: 0.3
[ 1.119325] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.119344] ehci-pci: EHCI PCI platform driver
[ 1.119389] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.119399] ohci-pci: OHCI PCI platform driver
[ 1.119431] ohci-platform: OHCI generic platform driver
[ 1.123878] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.124558] nct1008_nct72 7-004c: LOC shutdown limit 110
[ 1.125108] nct1008_nct72 7-004c: EXT shutdown limit 110
[ 1.125697] tegra-xusb 3530000.xhci: extcon 0: ffffffc1ac77bc00 id
[ 1.126491] usbcore: registered new interface driver uas
[ 1.126535] usbcore: registered new interface driver usb-storage
[ 1.126608] usbcore: registered new interface driver usbserial
[ 1.128164] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[ 1.130211] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.131384] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.131707] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.132022] mousedev: PS/2 mouse device common for all mice
[ 1.132123] usbcore: registered new interface driver xpad
[ 1.132858] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.154911] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.154934] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.155776] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.155820] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 1.156065] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.156073] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.156080] usb usb1: Product: xHCI Host Controller
[ 1.156085] usb usb1: Manufacturer: Linux 4.9.140-tegra-tegra xhci-hcd
[ 1.156091] usb usb1: SerialNumber: 3530000.xhci
[ 1.156574] hub 1-0:1.0: USB hub found
[ 1.156619] hub 1-0:1.0: 4 ports detected
[ 1.157016] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.157028] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.157047] nct1008_nct72 7-004c: initial LOC temp: 41000
[ 1.157256] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.157264] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.157269] usb usb2: Product: xHCI Host Controller
[ 1.157274] usb usb2: Manufacturer: Linux 4.9.140-tegra-tegra xhci-hcd
[ 1.157279] usb usb2: SerialNumber: 3530000.xhci
[ 1.157381] nct1008_nct72 7-004c: initial EXT temp: 43250
[ 1.157632] hub 2-0:1.0: USB hub found
[ 1.157674] hub 2-0:1.0: 3 ports detected
[ 1.158039] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.158447] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.158647] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.251908] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.253212] Wake73 for irq=42
[ 1.254533] rtc rtc1: alarm rtc device
[ 1.254551] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.254577] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.254791] i2c /dev entries driver
[ 1.257989] thermoframe 2-0010: probing v4l2 sensor
[ 1.258140] thermoframe 2-0010: tegracam sensor driver:thermoframe_v2.0.6
[ 1.258176] thermoframe 2-0010: Detected Thermoframe sensor
[ 1.258623] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 1.259071] usb usb1: usb_suspend_both: status 0
[ 1.264316] parse_throttle_dt_data: Num cap clks = 4
[ 1.264325] parse_throttle_dt_data: clk=mcpu type=1
[ 1.264330] parse_throttle_dt_data: clk=bcpu type=2
[ 1.264340] parse_throttle_dt_data: clk=gpu type=4
[ 1.264345] parse_throttle_dt_data: clk=emc type=3
[ 1.265419] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.266005] FAN dev name: pwm-fan
[ 1.266060] FAN:gpio request success.
[ 1.266071] FAN: can't find tach_gpio
[ 1.266138] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.266433] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.266440] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.266791] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.266870] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.266877] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.266883] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.266888] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.266894] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.266899] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.266905] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.266912] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.266918] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.268861] device-mapper: uevent: version 1.0.3
[ 1.269785] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.272616] cpufreq: platform driver Initialization: pass
[ 1.273269] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.273383] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.274275] sdhci: Secure Digital Host Controller Interface driver
[ 1.274279] sdhci: Copyright(c) Pierre Ossman
[ 1.274282] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.275729] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.277688] CMDQ: cmdq_platfm_init successful
[ 1.278775] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.279079] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.284305] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.284352] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.285646] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.288474] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 1.292377] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.293557] tegra-se-nvhost 15810000.se: initialized
[ 1.294697] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.295756] tegra-se-nvhost 15820000.se: initialized
[ 1.296773] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.297568] tegra-se-nvhost 15830000.se: initialized
[ 1.298133] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.299003] tegra-se-nvhost 15840000.se: initialized
[ 1.299804] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.300178] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.303604] usbcore: registered new interface driver usbhid
[ 1.303609] usbhid: USB HID core driver
[ 1.307763] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 1.307793] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 1.314468] ina3221x: probe of 0-0042 failed with error -121
[ 1.314824] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 1.314872] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 1.321564] ina3221x: probe of 0-0043 failed with error -121
[ 1.322872] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.324214] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.327016] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.327186] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.327335] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.327544] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.327932] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.332569] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.332680] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.332744] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.332799] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.332972] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.333591] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 1.333597] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.334577] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.334870] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.334916] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.336363] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.336815] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.336978] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.337054] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.337378] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337382] tegra18-bridge 2390000.axi2apb: enabled timeout = 16684000
[ 1.337384] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.337437] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337440] tegra18-bridge 23a0000.axi2apb: enabled timeout = 16684000
[ 1.337442] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.337492] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337494] tegra18-bridge 23b0000.axi2apb: enabled timeout = 16684000
[ 1.337496] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.337542] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337545] tegra18-bridge 23c0000.axi2apb: enabled timeout = 16684000
[ 1.337547] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.337592] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337594] tegra18-bridge 23d0000.axi2apb: enabled timeout = 16684000
[ 1.337596] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.337655] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337659] tegra18-bridge 2100000.axip2p: enabled timeout = 16684000
[ 1.337661] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.337708] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337717] tegra18-bridge 2110000.axip2p: enabled timeout = 16684000
[ 1.337719] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.337785] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337790] tegra18-bridge 2120000.axip2p: enabled timeout = 16684000
[ 1.337792] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.337836] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337840] tegra18-bridge 2130000.axip2p: enabled timeout = 16684000
[ 1.337842] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.337885] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337887] tegra18-bridge 2140000.axip2p: enabled timeout = 16684000
[ 1.337889] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.337935] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337939] tegra18-bridge 2150000.axip2p: enabled timeout = 16684000
[ 1.337941] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.337987] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.337992] tegra18-bridge 2160000.axip2p: enabled timeout = 16684000
[ 1.337993] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.338036] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.338041] tegra18-bridge 2170000.axip2p: enabled timeout = 16684000
[ 1.338043] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.338088] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.338093] tegra18-bridge 2180000.axip2p: enabled timeout = 16684000
[ 1.338095] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.338153] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.338156] tegra18-bridge 2190000.axip2p: enabled timeout = 16684000
[ 1.338158] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.338213] **** A57 ECC: Enabled
[ 1.338215] tegra18_a57_serr_init: on CPU 3 a A57 Core
[ 1.338278] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 1.338744] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.339659] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.339770] denver_knobs_init:MTS_VERSION:43068234
[ 1.341497] nvpmodel: initialized successfully
[ 1.343781] trusty-virtio trusty:virtio: initializing
[ 1.343974] trusty_ipc virtio0: vring0: va(pa) ffffffc1a7a92000(0) qsz 32 notifyid 1
[ 1.343986] trusty_ipc virtio0: vring1: va(pa) ffffffc1a7ab4000(0) qsz 32 notifyid 2
[ 1.344144] trusty-virtio trusty:virtio: initializing done
[ 1.344302] trusty_ipc virtio0: is online
[ 1.346398] usbcore: registered new interface driver snd-usb-audio
[ 1.354131] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.354513] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.388419] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.406566] mmc0: periodic cache flush enabled
[ 1.406582] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.407186] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 1.407433] mmcblk0boot0: mmc0:0001 032G34 partition 1 8.00 MiB
[ 1.411692] mmcblk0boot1: mmc0:0001 032G34 partition 2 8.00 MiB
[ 1.411922] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 1.415511] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 1.415692] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.421465] OPE platform probe
[ 1.421568] OPE platform probe successful
[ 1.424089] tegra-asoc: sound: This is a dummy codec
[ 1.462003] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.477212] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.477308] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.477400] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.477515] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.477600] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.477689] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.477774] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.477868] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.477951] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.478034] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.478127] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.478210] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.478294] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.478382] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.478465] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.478579] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.478667] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.478752] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.478877] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.478983] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.511754] u32 classifier
[ 1.511760] Actions configured
[ 1.511851] Initializing XFRM netlink socket
[ 1.513507] NET: Registered protocol family 10
[ 1.514997] NET: Registered protocol family 17
[ 1.515015] NET: Registered protocol family 15
[ 1.515238] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.515338] Bluetooth: RFCOMM socket layer initialized
[ 1.515355] Bluetooth: RFCOMM ver 1.11
[ 1.515363] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.515370] Bluetooth: HIDP socket layer initialized
[ 1.515407] 9pnet: Installing 9P2000 support
[ 1.515454] Key type dns_resolver registered
[ 1.515707] Registered cp15_barrier emulation handler
[ 1.515725] Registered setend emulation handler
[ 1.518474] registered taskstats version 1
[ 1.521950] isp 15600000.isp: initialized
[ 1.526234] nvcsi 150c0000.nvcsi: initialized
[ 1.531244] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.531341] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 1.531403] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 1.531574] input: gpio-keys as /devices/gpio-keys/input/input2
[ 1.533149] tegra-vi4 15700000.vi: initialized
[ 1.534279] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 1.534294] tegra-vi4 15700000.vi: subdev thermoframe 2-0010 bound
[ 1.563595] tegra_rtc c2a0000.rtc: setting system clock to 2019-11-25 12:59:30 UTC (1574686770)
[ 1.564664] mmcblk mmc0:0001: Card claimed for testing.
[ 1.591298] bpmp: mounted debugfs mirror
[ 1.592775] bwmgr: missing cdev-type property
[ 1.598790] spmic-ldo0: disabling
[ 1.598999] spmic-ldo1: disabling
[ 1.599196] en-vdd-sd: disabling
[ 1.599201] vdd-usb0-5v: disabling
[ 1.599204] vdd-usb1-5v: disabling
[ 1.599210] vdd-3v3: disabling
[ 1.599213] en-vdd-vcm-2v8: disabling
[ 1.599217] vdd-sys-bl: disabling
[ 1.599221] ALSA device list:
[ 1.599225] #0: tegra-hda at 0x3518000 irq 383
[ 1.599228] #1: tegra-snd-t186ref-mobile-rt565x
[ 1.601260] Freeing unused kernel memory: 8576K
[ 1.636842] L4T-INITRD Build DATE: Mon Nov 25 12:59:30 UTC 2019
[ 1.646072] Root device found: mmcblk0p1
[ 1.648481] Found dev node: /dev/mmcblk0p1
[ 1.672675] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.673925] Rootfs mounted over mmcblk0p1
[ 1.713382] Switching from initrd to actual rootfs
[ 1.865203] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.867240] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 1.910631] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.957815] cgroup: cgroup2: unknown option "nsdelegate"
[ 1.992202] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.995612] systemd[1]: Detected architecture arm64.
[ 2.088739] systemd[1]: Set hostname to <nvidia-desktop>.
[ 2.184784] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.184812] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.266843] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 2.397539] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.405494] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.405738] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.409329] systemd[1]: Created slice User and Session Slice.
[ 2.409512] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.409863] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.409958] systemd[1]: Reached target User and Group Name Lookups.
[ 2.410034] systemd[1]: Reached target Swap.
[ 2.461710] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.685512] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 2.783536] systemd-journald[2237]: Received request to flush runtime journal from PID 1
[ 3.102851] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 3.104883] tegra-pcie 10003000.pcie-controller: link 1 down, ignoring
[ 3.506861] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.521515] thermoframe 2-0010: tfm_open:
[ 3.554895] thermoframe 2-0010: tfm_power_on: power on
[ 3.557571] thermoframe 2-0010: tfm_power_off: power off
[ 3.569500] using random self ethernet address
[ 3.574042] using random host ethernet address
[ 3.579197] random: crng init done
[ 3.582604] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.942861] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.951650] nvgpu: 17000000.gp10b railgate_enable_store:283 [INFO] railgate is disabled.
[ 3.984330] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 3.987320] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.278901] Wake76 for irq=199
[ 4.278907] Wake77 for irq=199
[ 4.278910] Wake78 for irq=199
[ 4.278912] Wake79 for irq=199
[ 4.278915] Wake80 for irq=199
[ 4.278917] Wake81 for irq=199
[ 4.278920] Wake82 for irq=199
[ 4.278972] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.278978] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.341454] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 4.342905] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 4.379190] usb usb2: usb_suspend_both: status 0
[ 4.571253] zram: Added device: zram0
[ 4.575124] zram: Added device: zram1
[ 4.577269] zram: Added device: zram2
[ 4.579434] zram: Added device: zram3
[ 4.581870] zram: Added device: zram4
[ 4.583477] zram: Added device: zram5
[ 4.596103] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control off
[ 4.596672] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 4.603437] CPU1: shutdown
[ 4.606218] psci: CPU1 killed.
[ 4.647342] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 4.683808] CPU2: shutdown
[ 4.686547] psci: CPU2 killed.
[ 4.688675] zram0: detected capacity change from 0 to 598818816
[ 4.707918] Adding 584780k swap on /dev/zram0. Priority:5 extents:1 across:584780k SS
[ 4.710701] zram1: detected capacity change from 0 to 598818816
[ 4.727517] Adding 584780k swap on /dev/zram1. Priority:5 extents:1 across:584780k SS
[ 4.730347] zram2: detected capacity change from 0 to 598818816
[ 4.756506] Adding 584780k swap on /dev/zram2. Priority:5 extents:1 across:584780k SS
[ 4.759637] zram3: detected capacity change from 0 to 598818816
[ 4.773189] Adding 584780k swap on /dev/zram3. Priority:5 extents:1 across:584780k SS
[ 4.776314] zram4: detected capacity change from 0 to 598818816
[ 4.800102] Adding 584780k swap on /dev/zram4. Priority:5 extents:1 across:584780k SS
[ 4.803320] zram5: detected capacity change from 0 to 598818816
[ 4.820492] Adding 584780k swap on /dev/zram5. Priority:5 extents:1 across:584780k SS
[ 6.895104] tegradc 15210000.nvdisplay: blank - powerdown
[ 6.990868] tegra-xusb 3530000.xhci: entering ELPG
[ 6.994038] tegra-xusb 3530000.xhci: entering ELPG done
[ 9.390256] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.390268] Bluetooth: BNEP socket layer initialized
[ 9.849501] fuse init (API version 7.26)
[ 66.313222] thermoframe 2-0010: tfm_open:
[ 66.314341] thermoframe 2-0010: tfm_power_on: power on
[ 66.315724] thermoframe 2-0010: tfm_power_off: power off
[ 66.506672] thermoframe 2-0010: tfm_open:
[ 66.506910] thermoframe 2-0010: tfm_power_on: power on
[ 66.506955] thermoframe 2-0010: tfm_power_off: power off
[ 66.513419] thermoframe 2-0010: tfm_power_on: power on
[ 66.518107] thermoframe 2-0010: tfm_set_mode:
[ 66.518116] thermoframe 2-0010: tfm_start_streaming:
[ 71.759021] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 71.765659] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 76.878887] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 76.885293] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 81.999310] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 82.005675] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 87.119660] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 87.126046] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 92.240109] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 92.246657] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 92.260047] thermoframe 2-0010: tfm_power_off: power off
trace:
[code]
tracer: nop
entries-in-buffer/entries-written: 1028/1028 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/3:3-4089 [003] .... 34.774966: rtos_queue_peek_from_isr_failed: tstamp:1459225229 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 34.942911: rtos_queue_peek_from_isr_failed: tstamp:1464225223 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 35.110929: rtos_queue_peek_from_isr_failed: tstamp:1469225214 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 35.278898: rtos_queue_peek_from_isr_failed: tstamp:1474225234 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 35.446943: rtos_queue_peek_from_isr_failed: tstamp:1479225202 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 35.614986: rtos_queue_peek_from_isr_failed: tstamp:1484225098 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 35.726908: rtos_queue_peek_from_isr_failed: tstamp:1489225215 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 35.894932: rtos_queue_peek_from_isr_failed: tstamp:1494225169 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 36.062917: rtos_queue_peek_from_isr_failed: tstamp:1499225175 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 36.230957: rtos_queue_peek_from_isr_failed: tstamp:1504225169 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 36.399038: rtos_queue_peek_from_isr_failed: tstamp:1509225074 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 36.570894: rtos_queue_peek_from_isr_failed: tstamp:1514225168 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 36.738910: rtos_queue_peek_from_isr_failed: tstamp:1519225148 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 36.850948: rtos_queue_peek_from_isr_failed: tstamp:1524225152 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 37.018907: rtos_queue_peek_from_isr_failed: tstamp:1529225135 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 37.186922: rtos_queue_peek_from_isr_failed: tstamp:1534225129 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 37.354920: rtos_queue_peek_from_isr_failed: tstamp:1539225121 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 37.522937: rtos_queue_peek_from_isr_failed: tstamp:1544225114 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 37.690981: rtos_queue_peek_from_isr_failed: tstamp:1549225120 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 37.858917: rtos_queue_peek_from_isr_failed: tstamp:1554225098 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 37.970853: rtos_queue_peek_from_isr_failed: tstamp:1559224994 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 38.138963: rtos_queue_peek_from_isr_failed: tstamp:1564225101 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 38.306959: rtos_queue_peek_from_isr_failed: tstamp:1569225079 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 38.474901: rtos_queue_peek_from_isr_failed: tstamp:1574225072 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 38.642938: rtos_queue_peek_from_isr_failed: tstamp:1579225066 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 38.811067: rtos_queue_peek_from_isr_failed: tstamp:1584224957 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 38.978921: rtos_queue_peek_from_isr_failed: tstamp:1589225079 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 39.090961: rtos_queue_peek_from_isr_failed: tstamp:1594225044 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 39.258894: rtos_queue_peek_from_isr_failed: tstamp:1599225065 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 39.426916: rtos_queue_peek_from_isr_failed: tstamp:1604225028 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 39.594921: rtos_queue_peek_from_isr_failed: tstamp:1609225025 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 39.762997: rtos_queue_peek_from_isr_failed: tstamp:1614225016 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 39.930932: rtos_queue_peek_from_isr_failed: tstamp:1619225010 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 40.098953: rtos_queue_peek_from_isr_failed: tstamp:1624225030 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 40.210918: rtos_queue_peek_from_isr_failed: tstamp:1629224997 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 40.379008: rtos_queue_peek_from_isr_failed: tstamp:1634224974 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 40.546967: rtos_queue_peek_from_isr_failed: tstamp:1639225008 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 40.714920: rtos_queue_peek_from_isr_failed: tstamp:1644224976 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 40.882918: rtos_queue_peek_from_isr_failed: tstamp:1649224969 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 41.050939: rtos_queue_peek_from_isr_failed: tstamp:1654224963 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 41.219013: rtos_queue_peek_from_isr_failed: tstamp:1659224949 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 41.330936: rtos_queue_peek_from_isr_failed: tstamp:1664224973 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 41.498919: rtos_queue_peek_from_isr_failed: tstamp:1669225019 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 41.666945: rtos_queue_peek_from_isr_failed: tstamp:1674224961 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 41.834914: rtos_queue_peek_from_isr_failed: tstamp:1679224929 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 42.002966: rtos_queue_peek_from_isr_failed: tstamp:1684224922 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 42.170925: rtos_queue_peek_from_isr_failed: tstamp:1689224915 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 42.338912: rtos_queue_peek_from_isr_failed: tstamp:1694224909 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 42.450985: rtos_queue_peek_from_isr_failed: tstamp:1699224928 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 42.618960: rtos_queue_peek_from_isr_failed: tstamp:1704224894 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 42.786987: rtos_queue_peek_from_isr_failed: tstamp:1709224873 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 42.954945: rtos_queue_peek_from_isr_failed: tstamp:1714224908 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 43.122941: rtos_queue_peek_from_isr_failed: tstamp:1719224872 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 43.290863: rtos_queue_peek_from_isr_failed: tstamp:1724224767 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 43.458942: rtos_queue_peek_from_isr_failed: tstamp:1729224859 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 43.571111: rtos_queue_peek_from_isr_failed: tstamp:1734224853 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 43.738974: rtos_queue_peek_from_isr_failed: tstamp:1739224873 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 43.906911: rtos_queue_peek_from_isr_failed: tstamp:1744224840 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 44.074977: rtos_queue_peek_from_isr_failed: tstamp:1749224860 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 44.242957: rtos_queue_peek_from_isr_failed: tstamp:1754224825 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 44.410974: rtos_queue_peek_from_isr_failed: tstamp:1759224819 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 44.578918: rtos_queue_peek_from_isr_failed: tstamp:1764224815 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 44.694918: rtos_queue_peek_from_isr_failed: tstamp:1769224808 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 44.862895: rtos_queue_peek_from_isr_failed: tstamp:1774224703 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 45.031005: rtos_queue_peek_from_isr_failed: tstamp:1779224793 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 45.198913: rtos_queue_peek_from_isr_failed: tstamp:1784224784 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 45.366929: rtos_queue_peek_from_isr_failed: tstamp:1789224807 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 45.534911: rtos_queue_peek_from_isr_failed: tstamp:1794224772 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 45.646934: rtos_queue_peek_from_isr_failed: tstamp:1799224765 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 45.814980: rtos_queue_peek_from_isr_failed: tstamp:1804224758 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 45.983154: rtos_queue_peek_from_isr_failed: tstamp:1809224752 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 46.150958: rtos_queue_peek_from_isr_failed: tstamp:1814224772 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 46.318918: rtos_queue_peek_from_isr_failed: tstamp:1819224737 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 46.486920: rtos_queue_peek_from_isr_failed: tstamp:1824224760 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 46.654973: rtos_queue_peek_from_isr_failed: tstamp:1829224738 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 46.766948: rtos_queue_peek_from_isr_failed: tstamp:1834224717 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 46.934914: rtos_queue_peek_from_isr_failed: tstamp:1839224711 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 47.102897: rtos_queue_peek_from_isr_failed: tstamp:1844224702 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 47.270960: rtos_queue_peek_from_isr_failed: tstamp:1849224725 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 47.438952: rtos_queue_peek_from_isr_failed: tstamp:1854224690 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 47.607081: rtos_queue_peek_from_isr_failed: tstamp:1859224683 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 47.774957: rtos_queue_peek_from_isr_failed: tstamp:1864224700 queue:0x0b4b5f58
kworker/3:3-4089 [003] .... 47.886911: rtos_queue_peek_from_isr_failed: tstamp:1869224667 queue:0x0b4b5f58
kwor
