It looks like /dev/video0 is present, and if I use v4l2-ctl --all it returns:
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, imx185 2-001a
Bus info : platform:15700000.vi:0
Driver version: 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: no power)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'RG12'
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
hdr_enable 0x009a2004 (intmenu): min=0 max=1 default=0 value=0
fuse_id 0x009a2007 (str) : min=0 max=12 step=2 value='000085010101' flags=read-only, has-payload
sensor_mode 0x009a2008 (int64) : min=0 max=0 step=0 default=0 value=0 flags=slider
gain 0x009a2009 (int64) : min=0 max=0 step=0 default=0 value=0 flags=slider
exposure 0x009a200a (int64) : min=0 max=0 step=0 default=0 value=30 flags=slider
frame_rate 0x009a200b (int64) : min=0 max=0 step=0 default=0 value=1500000 flags=slider
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=5 flags=read-only
This command just hangs (freezes) when run:
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100
As for the kernel init messages, are those found with ‘dmesg’? This is the output of dmesg after boot:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (root@supportDEV1) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #1 SMP PREEMPT Tue Nov 5 15:53:32 EST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2055168
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f702d000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022968
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29500(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7970036K/8220672K available (15038K kernel code, 2912K rwdata, 6656K rodata, 8576K init, 611K bss, 185100K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f30000 ( 15040 KB)
[ 0.000000] .rodata : 0xffffff8008f30000 - 0xffffff80095c0000 ( 6720 KB)
[ 0.000000] .init : 0xffffff80095c0000 - 0xffffff8009e20000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8008 ( 2913 KB)
[ 0.000000] .bss : 0xffffff800a0f8008 - 0xffffff800a190d3c ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001078] Console: colour dummy device 80x25
[ 0.001084] console [tty0] enabled
[ 0.001087] bootconsole [uart8250] disabled
[ 0.001094] kmemleak: Kernel memory leak detector disabled
[ 0.001103] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001111] pid_max: default: 32768 minimum: 301
[ 0.001421] Security Framework initialized
[ 0.001577] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.001581] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002175] ftrace: allocating 46905 entries in 184 pages
[ 0.126817] sched-energy: Sched-energy-costs installed from DT
[ 0.126827] ASID allocator initialised with 65536 entries
[ 0.161440] tegra-id: chipid=21817.
[ 0.161446] tegra-id: opt_subrevision=1.
[ 0.161463] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.161470] DTS File Name: tegra186-tx2-cti-ASG008-IMX185.dts
[ 0.161476] DTB Build time: Nov 12 2019 11:26:39
[ 0.209588] CPU1: Booted secondary processor [4e0f0030]
[ 0.241218] CPU2: Booted secondary processor [4e0f0030]
[ 0.273007] CPU3: Booted secondary processor [411fd073]
[ 0.305001] CPU4: Booted secondary processor [411fd073]
[ 0.336990] CPU5: Booted secondary processor [411fd073]
[ 0.337048] Brought up 6 CPUs
[ 0.337052] SMP: Total of 6 processors activated.
[ 0.337057] CPU features: detected feature: 32-bit EL0 Support
[ 0.337884] CPU: All CPU(s) started at EL2
[ 0.337915] alternatives: patching kernel code
[ 0.347051] devtmpfs: initialized
[ 0.371651] Initilizing CustomIPI irq domain
[ 0.371845] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.371855] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.372764] pinctrl core: initialized pinctrl subsystem
[ 0.372957] OS set in device tree is not L4T.
[ 0.373112] regulator-dummy: no parameters
[ 0.373255] Initializing plugin-manager
[ 0.373306] Plugin module not found
[ 0.373341] Plugin-manager status disabled
[ 0.374536] NET: Registered protocol family 16
[ 0.375639] pstore: using zlib compression
[ 0.375652] console [pstore-1] enabled
[ 0.375655] pstore: Registered ramoops as persistent store backend
[ 0.375659] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.392604] cpuidle: using governor menu
[ 0.393648] bpmp: waiting for handshake
[ 0.393652] bpmp: handshake completed
[ 0.393666] bpmp: synchronizing channels
[ 0.393680] bpmp: channels synchronized
[ 0.393683] bpmp: mail init ok
[ 0.395387] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.395392] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.395397] arm-smmu 12000000.iommu: stage 1 translation
[ 0.395400] arm-smmu 12000000.iommu: stage 2 translation
[ 0.395403] arm-smmu 12000000.iommu: nested translation
[ 0.395409] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.395415] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.395418] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.395422] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.395426] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.397160] vdso: 2 pages (1 code @ ffffff8008f37000, 1 data @ ffffff8009e24000)
[ 0.397173] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.399854] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.400908] Registering BPMP clocks...
[ 0.400998] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.402829] tegra_powergate_init: DONE
[ 0.402836] DTS File Name: tegra186-tx2-cti-ASG008-IMX185.dts
[ 0.402842] DTB Build time: Nov 12 2019 11:26:39
[ 0.404199] Tegra reboot handler registered.
[ 0.405437] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.405501] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.405513] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.405516] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.405518] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.405678] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.405689] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.405982] iommu: Adding device 3460000.sdhci to group 0
[ 0.406617] iommu: Adding device 3400000.sdhci to group 1
[ 0.407655] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.407668] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.408089] iommu: Adding device 3160000.i2c to group 3
[ 0.408493] iommu: Adding device c240000.i2c to group 4
[ 0.408814] iommu: Adding device 3180000.i2c to group 5
[ 0.409176] iommu: Adding device 3190000.i2c to group 6
[ 0.409595] iommu: Adding device 31b0000.i2c to group 7
[ 0.409904] iommu: Adding device 31c0000.i2c to group 8
[ 0.410213] iommu: Adding device c250000.i2c to group 9
[ 0.410528] iommu: Adding device 31e0000.i2c to group 10
[ 0.412039] iommu: Adding device 3210000.spi to group 11
[ 0.412354] iommu: Adding device c260000.spi to group 12
[ 0.412661] iommu: Adding device 3240000.spi to group 13
[ 0.413356] iommu: Adding device 3100000.serial to group 14
[ 0.413670] iommu: Adding device 3110000.serial to group 15
[ 0.413960] iommu: Adding device c280000.serial to group 16
[ 0.414256] iommu: Adding device 3130000.serial to group 17
[ 0.415467] iommu: Adding device 2490000.ether_qos to group 18
[ 0.415485] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.416116] iommu: Adding device b000000.rtcpu to group 19
[ 0.418008] iommu: Adding device 13e10000.host1x to group 20
[ 0.418293] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.418577] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.418865] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.419143] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.419426] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.419706] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.420002] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.420287] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.420714] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.421339] iommu: Adding device 15700000.vi to group 30
[ 0.421664] iommu: Adding device 15600000.isp to group 31
[ 0.422094] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.422619] iommu: Adding device 15340000.vic to group 33
[ 0.422824] iommu: Adding device 154c0000.nvenc to group 34
[ 0.423022] iommu: Adding device 15480000.nvdec to group 35
[ 0.423337] iommu: Adding device 15380000.nvjpg to group 36
[ 0.423547] iommu: Adding device 15500000.tsec to group 37
[ 0.423740] iommu: Adding device 15100000.tsecb to group 38
[ 0.424358] iommu: Adding device 15810000.se to group 39
[ 0.424557] iommu: Adding device 15820000.se to group 40
[ 0.424759] iommu: Adding device 15830000.se to group 41
[ 0.424950] iommu: Adding device 15840000.se to group 42
[ 0.425758] iommu: Adding device smmu_test to group 43
[ 0.426320] mc: mapped MMIO address: 0xffffff800a680000 -> 0x2c10000
[ 0.426331] mc: mapped MMIO address: 0xffffff800a6a0000 -> 0x2c20000
[ 0.426341] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c30000
[ 0.426351] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c40000
[ 0.426360] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c50000
[ 0.426369] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.426378] mc-err: mcerr ops are set to t18x
[ 0.426514] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.427515] iommu: Adding device 3530000.xhci to group 44
[ 0.427526] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.427936] iommu: Adding device 3550000.xudc to group 45
[ 0.427947] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.428630] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.428636] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.429184] iommu: Adding device 17000000.gp10b to group 46
[ 0.430148] tegra-reset 5000000.clock: registered 193 resets.
[ 0.432108] iommu: Adding device d000000.bpmp to group 47
[ 0.432304] bpmp: ping status is 0
[ 0.432405] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.434371] bpmp d000000.bpmp: probe ok
[ 0.437114] iommu: Adding device 2600000.dma to group 48
[ 0.438277] GPIO line 459 (pcie0_lane2_mux) hogged as output/low
[ 0.438303] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.438325] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.438349] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.438374] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.438396] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.438584] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.442298] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.442461] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.444000] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.444014] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.444314] iommu: Adding device sound to group 50
[ 0.444640] iommu: Adding device 3510000.hda to group 51
[ 0.451457] iommu: Adding device c1a0000.aon to group 52
[ 0.451899] vdd-ac-bat: 5000 mV
[ 0.454197] vdd-1v8-ap: 1800 mV
[ 0.494465] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.497234] random: fast init done
[ 0.500402] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.500900] SCSI subsystem initialized
[ 0.501128] libata version 3.00 loaded.
[ 0.501383] usbcore: registered new interface driver usbfs
[ 0.501699] usbcore: registered new interface driver hub
[ 0.501832] usbcore: registered new device driver usb
[ 0.516629] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.521454] vddio-ddr: at 1125 mV
[ 0.525328] avdd_dsi_csi: 1200 mV
[ 0.529251] vdd-1v8: 1800 mV
[ 0.533254] vdd-3v3-sys: 3300 mV
[ 0.534400] spmic-ldo0: at 1800 mV
[ 0.535298] spmic-ldo1: at 800 mV
[ 0.537616] vddio-3v3: 3300 mV
[ 0.538397] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.541667] vdd-rtc: at 800 mV
[ 0.542421] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.545615] spmic-ldo6: at 1500 mV
[ 0.549616] vdd-pex-1v00: 1000 mV
[ 0.550438] dvdd-pex: 1000 mV
[ 0.551112] GPIO line 253 (spmic_gpio_input) hogged as input
[ 0.551286] GPIO line 254 (spmic_gpio_input) hogged as input
[ 0.551627] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 0.554205] max77620 4-003c: max77620 probe successful
[ 0.554711] media: Linux media interface: v0.10
[ 0.554756] Linux video capture interface: v2.00
[ 0.559023] pps_core: LinuxPPS API ver. 1 registered
[ 0.559029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.559059] PTP clock support registered
[ 0.559840] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.559876] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.562780] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.568044] trusty trusty: trusty version: Built: 16:57:40 Jul 16 2019
[ 0.568085] trusty trusty: selected api version: 3 (requested 3)
[ 0.569395] Advanced Linux Sound Architecture Driver Initialized.
[ 0.569985] Bluetooth: Core ver 2.22
[ 0.570085] NET: Registered protocol family 31
[ 0.570091] Bluetooth: HCI device and connection manager initialized
[ 0.570103] Bluetooth: HCI socket layer initialized
[ 0.570114] Bluetooth: L2CAP socket layer initialized
[ 0.570164] Bluetooth: SCO socket layer initialized
[ 0.571084] en-vdd-sd: 3300 mV
[ 0.571405] en-vdd-cam: 1800 mV
[ 0.571703] vdd-hdmi: 5000 mV
[ 0.572031] vdd-usb0-5v: 5000 mV
[ 0.572377] vdd-usb1-5v: 5000 mV
[ 0.572671] en-vdd-ts-1v8: 1800 mV
[ 0.572936] en-vdd-ts-hv-3v3: 3300 mV
[ 0.573273] en-vdd-disp-3v3: 3300 mV
[ 0.573574] en-mdm-pwr-3v7: 3700 mV
[ 0.573875] en-vdd-disp-1v8: 1800 mV
[ 0.574178] en-vdd-cam-hv-2v8: 2800 mV
[ 0.574494] en-vdd-cam-1v2: 1200 mV
[ 0.574779] vdd-fan: 5000 mV
[ 0.575067] vdd-3v3: 3300 mV
[ 0.575395] dis-vdd-1v2: 1200 mV
[ 0.575684] en-vdd-vcm-2v8: 2800 mV
[ 0.576004] vdd-usb2-5v: 5000 mV
[ 0.576308] vdd-sys-bl: 3300 mV
[ 0.576684] en-vdd-sys: 1200 mV
[ 0.579578] camchar: rtcpu character device driver loaded
[ 0.580247] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.582306] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 0.583355] clocksource: Switched to clocksource arch_sys_counter
[ 0.625525] VFS: Disk quotas dquot_6.6.0
[ 0.625764] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.626951] tegra-pcie 10003000.pcie-controller: wrong configuration updated in DT, switching to default 2x1, 1x1, 1x1 configuration
[ 0.627999] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.628644] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.628654] nvmap_page_pool_init: Total RAM pages: 2008893
[ 0.628661] nvmap_page_pool_init: nvmap page pool size: 251111 pages (980 MB)
[ 0.628789] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.628861] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.633491] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.645962] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.646151] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.646543] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.646654] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.646803] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.646941] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.647117] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.647442] la/ptsa driver initialized.
[ 0.647456] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.647461] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.648646] NET: Registered protocol family 2
[ 0.650846] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.650999] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 0.651660] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.652419] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.652472] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.652605] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.653573] NET: Registered protocol family 1
[ 0.654747] RPC: Registered named UNIX socket transport module.
[ 0.654753] RPC: Registered udp transport module.
[ 0.654758] RPC: Registered tcp transport module.
[ 0.654763] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.654929] PCI: CLS 0 bytes, default 64
[ 0.655193] Trying to unpack rootfs image as initramfs...
[ 0.841660] Freeing initrd memory: 5432K
[ 0.862650] host1x 13e10000.host1x: initialized
[ 0.864158] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.869108] audit: initializing netlink subsys (disabled)
[ 0.869149] audit: type=2000 audit(0.756:1): initialized
[ 0.869895] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.884312] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.886940] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.888568] 9p: Installing v9fs 9p2000 file system support
[ 0.894576] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.894737] io scheduler noop registered
[ 0.895399] io scheduler cfq registered (default)
[ 0.900557] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.962867] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 1.003172] iommu: Adding device 2993000.adsp to group 54
[ 1.004469] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.007161] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 1.011104] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.012673] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.014016] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.015394] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.018776] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.019005] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.019014] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 1.022293] tsec 15500000.tsec: initialized
[ 1.023571] tsec 15100000.tsecb: initialized
[ 1.026425] nvdec 15480000.nvdec: initialized
[ 1.032305] falcon 15340000.vic: initialized
[ 1.033883] falcon 154c0000.nvenc: initialized
[ 1.035335] falcon 15380000.nvjpg: initialized
[ 1.039753] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.041391] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.042948] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.044522] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.046079] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.047620] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.049182] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.050685] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.054051] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.054065] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.054103] tegradccommon 15200000.dc_common: dma mapping done
[ 1.055180] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.055222] tegradc 15210000.nvdisplay: tegra_dc_parse_panel_ops: panel: /host1x/sor1/hdmi-display is not active
[ 1.055244] tegradc 15210000.nvdisplay: err:-19 parsing panel_ops
[ 1.055675] of_fixed_clk: probe of can_clock failed with error -17
[ 1.063313] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.063901] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.064393] kfuse 3830000.kfuse: initialized
[ 1.065859] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.071386] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.074517] console [ttyS0] disabled
[ 1.074583] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.091019] console [ttyS0] enabled
[ 1.093011] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.094277] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.094604] serial-tegra 3130000.serial: RX in PIO mode
[ 1.095544] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.096606] [drm] Initialized
[ 1.107292] brd: module loaded
[ 1.112199] loop: module loaded
[ 1.112289] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.112420] tegra_profiler: auth: init
[ 1.112975] nct1008_nct72 7-004c: starting parse dt
[ 1.113138] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.113151] nct1008_nct72 7-004c: success parsing dt
[ 1.113271] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.113358] THERMAL EST: found 3 subdevs
[ 1.113365] THERMAL EST num_resources: 0
[ 1.113371] [THERMAL EST subdev 0]
[ 1.113378] [THERMAL EST subdev 1]
[ 1.113384] [THERMAL EST subdev 2]
[ 1.113731] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.113736] THERMAL EST: thz register success.
[ 1.113918] THERMAL EST: end of probe, return err: 0
[ 1.114971] hisi_sas: driver version v1.6
[ 1.119178] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.119192] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.120258] scsi host0: tegra_ahci
[ 1.121188] scsi host1: tegra_ahci
[ 1.121374] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.121380] ata2: DUMMY
[ 1.127007] libphy: Fixed MDIO Bus: probed
[ 1.127687] tun: Universal TUN/TAP device driver, 1.6
[ 1.127692] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.128424] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.128430] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.128470] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.128475] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.128515] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.128519] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.128558] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.128562] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.130039] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 1.133768] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c6 8b d2
[ 1.133889] libphy: dwc_phy: probed
[ 1.134281] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.136627] PPP generic driver version 2.4.2
[ 1.136795] PPP BSD Compression module registered
[ 1.136801] PPP Deflate Compression module registered
[ 1.136819] PPP MPPE Compression module registered
[ 1.136825] NET: Registered protocol family 24
[ 1.136872] usbcore: registered new interface driver r8152
[ 1.136908] usbcore: registered new interface driver asix
[ 1.136943] usbcore: registered new interface driver ax88179_178a
[ 1.136972] usbcore: registered new interface driver cdc_ether
[ 1.137002] usbcore: registered new interface driver net1080
[ 1.137030] usbcore: registered new interface driver cdc_subset
[ 1.137060] usbcore: registered new interface driver zaurus
[ 1.137103] usbcore: registered new interface driver cdc_ncm
[ 1.137320] VFIO - User Level meta-driver version: 0.3
[ 1.139020] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.139038] ehci-pci: EHCI PCI platform driver
[ 1.139072] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.139081] ohci-pci: OHCI PCI platform driver
[ 1.139115] ohci-platform: OHCI generic platform driver
[ 1.143684] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.144910] tegra-xusb 3530000.xhci: extcon 0: ffffffc1eac49000 id
[ 1.145595] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 1.145599] usbcore: registered new interface driver uas
[ 1.145640] usbcore: registered new interface driver usb-storage
[ 1.145735] usbcore: registered new interface driver usbserial
[ 1.146124] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 1.147317] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[ 1.149579] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.150715] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.150745] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.151656] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.152139] mousedev: PS/2 mouse device common for all mice
[ 1.152202] usbcore: registered new interface driver xpad
[ 1.175453] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.175473] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.176363] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.176402] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 1.176640] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.176648] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.176654] usb usb1: Product: xHCI Host Controller
[ 1.176660] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.176665] usb usb1: SerialNumber: 3530000.xhci
[ 1.177122] hub 1-0:1.0: USB hub found
[ 1.177168] hub 1-0:1.0: 4 ports detected
[ 1.177590] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.177605] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.177831] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.177838] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.177844] usb usb2: Product: xHCI Host Controller
[ 1.177849] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.177855] usb usb2: SerialNumber: 3530000.xhci
[ 1.178272] hub 2-0:1.0: USB hub found
[ 1.178312] hub 2-0:1.0: 3 ports detected
[ 1.178858] nct1008_nct72 7-004c: initial LOC temp: 34000
[ 1.179162] nct1008_nct72 7-004c: initial EXT temp: 36000
[ 1.179767] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.180055] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.180241] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.279591] usb usb1: usb_suspend_both: status 0
[ 1.280047] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.281291] Wake73 for irq=42
[ 1.282558] rtc rtc1: alarm rtc device
[ 1.282574] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.282597] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.282773] i2c /dev entries driver
[ 1.284143] imx185 2-001a: probing v4l2 sensor
[ 1.284755] imx185 2-001a: tegracam sensor driver:imx185_v2.0.6
[ 1.286370] imx185 2-001a: Detected IMX185 sensor
[ 1.287049] pca9570 2-0024: pca9570_icr_move, forward val=5
[ 1.388276] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.388320] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 1.395271] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.395332] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 1.433778] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.512205] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.512266] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 1.519187] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.519242] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 1.636126] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.636203] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 1.643151] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.643207] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 1.760104] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.760140] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 1.767057] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.767116] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 1.883972] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.884007] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 1.890917] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 1.890950] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 2.007572] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.007610] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 2.014555] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.014590] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 2.131451] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.131486] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 2.138402] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.138458] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 2.255328] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.255420] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 2.262335] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.262370] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 2.379254] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.379289] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 2.386205] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.386262] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 2.503156] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.503192] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 2.510113] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 2.510147] pca9570 2-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 2.516908] pca9570 2-0024: pca9570_icr_move:i2c write failed
[ 2.522819] pca9570: probe of 2-0024 failed with error -121
[ 2.523500] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.529444] parse_throttle_dt_data: Num cap clks = 4
[ 2.529451] parse_throttle_dt_data: clk=mcpu type=1
[ 2.529457] parse_throttle_dt_data: clk=bcpu type=2
[ 2.529466] parse_throttle_dt_data: clk=gpu type=4
[ 2.529471] parse_throttle_dt_data: clk=emc type=3
[ 2.530354] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.530857] FAN dev name: pwm-fan
[ 2.530915] FAN:gpio request success.
[ 2.530927] FAN: can't find tach_gpio
[ 2.530960] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.531166] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 2.531173] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.531516] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.531524] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.531530] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.531535] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.531541] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.531546] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.531551] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.531557] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.531563] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.531570] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.533199] device-mapper: uevent: version 1.0.3
[ 2.533995] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.541213] cpufreq: platform driver Initialization: pass
[ 2.541783] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 2.541898] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 2.542650] sdhci: Secure Digital Host Controller Interface driver
[ 2.542654] sdhci: Copyright(c) Pierre Ossman
[ 2.542657] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.544277] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.546232] CMDQ: cmdq_platfm_init successful
[ 2.547430] CQE: CMD_TIMING bit set for R1B DCMD
[ 2.549801] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.556012] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.556060] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.557916] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.559841] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 2.565121] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.566203] tegra-se-nvhost 15810000.se: initialized
[ 2.567477] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.568299] tegra-se-nvhost 15820000.se: initialized
[ 2.569374] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.570097] tegra-se-nvhost 15830000.se: initialized
[ 2.571019] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.571796] tegra-se-nvhost 15840000.se: initialized
[ 2.572683] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.572963] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.574044] usbcore: registered new interface driver usbhid
[ 2.574048] usbhid: USB HID core driver
[ 2.576059] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 2.576088] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 2.582695] ina3221x: probe of 0-0042 failed with error -121
[ 2.582944] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 2.582971] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 2.589550] ina3221x: probe of 0-0043 failed with error -121
[ 2.591962] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 2.595035] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 2.595402] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.595445] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.595684] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.595861] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 2.596255] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 2.597093] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 2.597166] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 2.597219] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 2.597271] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 2.597379] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 2.597784] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 2.597789] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.598718] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 2.600232] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.600727] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.600888] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.600970] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.601874] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.601880] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 2.601884] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.601965] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.601970] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 2.601973] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.602027] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602032] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 2.602035] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.602098] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602102] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 2.602105] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.602162] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602166] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 2.602169] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.602226] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602235] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 2.602238] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.602298] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602305] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 2.602308] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.602362] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602368] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 2.602371] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.602425] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602432] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 2.602435] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.602485] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602490] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 2.602493] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.602546] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602554] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 2.602557] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.602609] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602629] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 2.602633] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.602683] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602690] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 2.602693] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.602747] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602754] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 2.602757] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.602838] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 2.602844] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 2.602847] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.602917] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 2.602991] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 2.603618] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.604068] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.604159] denver_knobs_init:MTS_VERSION:43068234
[ 2.605593] nvpmodel: initialized successfully
[ 2.606569] trusty-virtio trusty:virtio: initializing
[ 2.606772] trusty_ipc virtio0: vring0: va(pa) ffffffc1eadba000(0) qsz 32 notifyid 1
[ 2.606781] trusty_ipc virtio0: vring1: va(pa) ffffffc1e91e8000(0) qsz 32 notifyid 2
[ 2.606982] trusty-virtio trusty:virtio: initializing done
[ 2.607308] trusty_ipc virtio0: is online
[ 2.607467] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 2.607519] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.611664] usbcore: registered new interface driver snd-usb-audio
[ 2.620028] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.620315] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.649009] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 2.664272] mmc0: periodic cache flush enabled
[ 2.664291] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.664790] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.669074] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.669261] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.672051] OPE platform probe
[ 2.672112] OPE platform probe successful
[ 2.673529] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.674038] tegra-asoc: sound: This is a dummy codec
[ 2.676693] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 2.723092] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.723165] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.723229] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.723300] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.723413] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.723482] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.723545] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.723610] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.723676] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.723766] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.723832] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.723900] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.723967] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.724031] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.724096] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.724160] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.724223] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.724287] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.724352] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.724420] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.745082] u32 classifier
[ 2.745088] Actions configured
[ 2.745184] Initializing XFRM netlink socket
[ 2.746823] NET: Registered protocol family 10
[ 2.748150] NET: Registered protocol family 17
[ 2.748163] NET: Registered protocol family 15
[ 2.748373] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.748443] Bluetooth: RFCOMM socket layer initialized
[ 2.748455] Bluetooth: RFCOMM ver 1.11
[ 2.748461] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.748468] Bluetooth: HIDP socket layer initialized
[ 2.748488] 9pnet: Installing 9P2000 support
[ 2.748532] Key type dns_resolver registered
[ 2.749237] Registered cp15_barrier emulation handler
[ 2.749252] Registered setend emulation handler
[ 2.750406] registered taskstats version 1
[ 2.753829] isp 15600000.isp: initialized
[ 2.758139] nvcsi 150c0000.nvcsi: initialized
[ 2.762882] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 2.762962] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 2.763031] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 2.763208] input: gpio-keys as /devices/gpio-keys/input/input2
[ 2.764398] tegra-vi4 15700000.vi: initialized
[ 2.765507] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 2.765518] tegra-vi4 15700000.vi: subdev imx185 2-001a bound
[ 2.796724] tegra_rtc c2a0000.rtc: setting system clock to 2019-12-09 15:31:56 UTC (1575905516)
[ 2.797845] mmcblk mmc0:0001: Card claimed for testing.
[ 2.836054] bpmp: mounted debugfs mirror
[ 2.837919] bwmgr: missing cdev-type property
[ 2.842907] spmic-ldo0: disabling
[ 2.843109] spmic-ldo1: disabling
[ 2.843280] en-vdd-sd: disabling
[ 2.843285] vdd-usb0-5v: disabling
[ 2.843289] vdd-usb1-5v: disabling
[ 2.843311] vdd-3v3: disabling
[ 2.843314] en-vdd-vcm-2v8: disabling
[ 2.843318] vdd-sys-bl: disabling
[ 2.843322] ALSA device list:
[ 2.843326] #0: tegra-hda at 0x3518000 irq 383
[ 2.843328] #1: tegra-snd-t186ref-mobile-rt565x
[ 2.845013] Freeing unused kernel memory: 8576K
[ 2.861590] mmc1: Applying tuning correction
[ 2.861621] mmc1: Tap value after applying correction 58
[ 2.861630] mmc1: hw tuning done ...
[ 2.868475] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 2.871939] L4T-INITRD Build DATE: Mon Dec 9 15:31:56 UTC 2019
[ 2.877090] Root device found: mmcblk0p1
[ 2.879457] Found dev node: /dev/mmcblk0p1
[ 2.901976] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.903016] Rootfs mounted over mmcblk0p1
[ 2.933199] Switching from initrd to actual rootfs
[ 3.096735] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.139669] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.168887] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.172002] systemd[1]: Detected architecture arm64.
[ 3.259426] systemd[1]: Set hostname to <CAR2>.
[ 3.342982] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.343006] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.535113] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.538866] systemd[1]: Created slice User and Session Slice.
[ 3.539231] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.540788] systemd[1]: Created slice System Slice.
[ 3.541254] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.541449] systemd[1]: Listening on Journal Audit Socket.
[ 3.541680] systemd[1]: Listening on udev Kernel Socket.
[ 3.542074] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.576328] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.622021] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 3.904476] systemd-journald[2288]: Received request to flush runtime journal from PID 1
[ 4.300160] Wake76 for irq=199
[ 4.300166] Wake77 for irq=199
[ 4.300169] Wake78 for irq=199
[ 4.300171] Wake79 for irq=199
[ 4.300174] Wake80 for irq=199
[ 4.300176] Wake81 for irq=199
[ 4.300178] Wake82 for irq=199
[ 4.300210] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.300215] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.403675] usb usb2: usb_suspend_both: status 0
[ 4.553664] using random self ethernet address
[ 4.558255] using random host ethernet address
[ 4.585258] Mass Storage Function, version: 2009/09/11
[ 4.585267] LUN: removable file: (no medium)
[ 4.594399] using random self ethernet address
[ 4.600196] using random host ethernet address
[ 4.703417] rndis0: HOST MAC 5a:62:17:d7:1f:cc
[ 4.703789] rndis0: MAC 5a:62:17:d7:1f:cd
[ 4.709212] usb0: HOST MAC 5a:62:17:d7:1f:ce
[ 4.709789] usb0: MAC 5a:62:17:d7:1f:cf
[ 4.709817] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 4.720115] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 4.720136] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.720172] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.721019] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.721041] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 4.722995] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 4.723019] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.723994] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.731139] l4tbr0: port 1(rndis0) entered blocking state
[ 4.731147] l4tbr0: port 1(rndis0) entered disabled state
[ 4.735995] device rndis0 entered promiscuous mode
[ 4.753838] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.758544] l4tbr0: port 2(usb0) entered blocking state
[ 4.758549] l4tbr0: port 2(usb0) entered disabled state
[ 4.758681] device usb0 entered promiscuous mode
[ 4.763385] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.792834] random: crng init done
[ 4.796245] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.366533] nvgpu: 17000000.gp10b railgate_enable_store:283 [INFO] railgate is disabled.
[ 5.378480] dhd_module_init in
[ 5.378555] found wifi platform device bcmdhd_wlan
[ 5.380208] wifi_platform_get_country_code_map: could not get country_code_map
[ 5.380213] wifi_plat_dev_drv_probe:platform country code map is not available
[ 5.380297] Power-up adapter 'DHD generic adapter'
[ 5.380306] wifi_platform_set_power = 1
[ 5.591411] wifi_platform_bus_enumerate device present 1
[ 5.627088] wifi_platform_bus_enumerate device present 0
[ 5.652635] F1 signature read @0x18000000=0x17214354
[ 5.711602] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.724983] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 5.725747] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 5.725835] wifi_platform_get_mac_addr
[ 5.731440] ids dhd_log_netlink_init
[ 5.800310] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 5.803483] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.861533] wl_create_event_handler(): thread:wl_event_handler:14dc started
[ 5.861540] wl_event_handler :
[ 5.861546] tsk Enter, tsk = 0xffffffc1e3801a90
[ 5.863625] dhd_attach(): thread:dhd_watchdog_thread:14e3 started
[ 5.867521] dhd_attach(): thread:dhd_dpc:14e4 started
[ 5.868175] dhd_attach(): thread:dhd_rxf:14e5 started
[ 5.868183] dhd_deferred_work_init: work queue initialized
[ 5.872017]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 5.873585] Register interface [wlan0] MAC: 00:04:4b:c6:8b:d0
[ 5.873590] dhd_prot_ioctl : bus is down. we have nothing to do
[ 5.880481] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 58
[ 5.881525] wifi_platform_set_power = 0
[ 6.324750] CPU1: shutdown
[ 6.327583] psci: CPU1 killed.
[ 6.371207] CPU2: shutdown
[ 6.374145] psci: CPU2 killed.
[ 6.439298] zram: Added device: zram0
[ 6.440106] zram: Added device: zram1
[ 6.441751] zram: Added device: zram2
[ 6.443958] zram: Added device: zram3
[ 6.489741] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.489856]
Compiled from
[ 6.489864] wl_android_wifi_on in
[ 6.489869] wifi_platform_set_power = 1
[ 6.493691] zram0: detected capacity change from 0 to 1030348800
[ 6.521568] Adding 1006196k swap on /dev/zram0. Priority:5 extents:1 across:1006196k SS
[ 6.529311] zram1: detected capacity change from 0 to 1030348800
[ 6.562429] Adding 1006196k swap on /dev/zram1. Priority:5 extents:1 across:1006196k SS
[ 6.568255] zram2: detected capacity change from 0 to 1030348800
[ 6.585945] Adding 1006196k swap on /dev/zram2. Priority:5 extents:1 across:1006196k SS
[ 6.597541] zram3: detected capacity change from 0 to 1030348800
[ 6.629327] Adding 1006196k swap on /dev/zram3. Priority:5 extents:1 across:1006196k SS
[ 6.700914] vdd-1v8: voltage operation not allowed
[ 6.712432] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 6.739740] vdd-1v8: voltage operation not allowed
[ 6.744612] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 6.773645] vdd-1v8: voltage operation not allowed
[ 6.778630] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 6.788320] vdd-1v8: voltage operation not allowed
[ 6.793202] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 6.903752] vdd-1v8: voltage operation not allowed
[ 6.908621] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 6.916519] vdd-1v8: voltage operation not allowed
[ 6.921463] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 6.927398] tegra-xusb 3530000.xhci: entering ELPG
[ 6.929549] tegra-xusb 3530000.xhci: entering ELPG done
[ 6.930920] vdd-1v8: voltage operation not allowed
[ 6.939388] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 6.946323] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 58
[ 6.946976] F1 signature read @0x18000000=0x17214354
[ 6.952581] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 6.953344] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 7.021545] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 7.083432] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 7.083691] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 7.083751] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 7.083753] Enabling wake69
[ 7.084528] wifi_platform_get_mac_addr
[ 7.086556] Firmware up: op_mode=0x0005, MAC=00:04:4b:c6:8b:d0
[ 7.090913] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 7.090952] Skipping the clm download. len:0 memblk: (null)
[ 7.093143] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 7.098342] Firmware version = wl0: May 17 2019 16:59:40 version 7.35.349.79 (r714996 CY) FWID 01-e527e2ad
[ 7.100736] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 7.180618] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[ 7.180623] P2P interface registered
[ 7.189017] WLC_E_IF: NO_IF set, event Ignored
[ 7.201972] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.851234] fuse init (API version 7.26)
[ 8.931527] [12-09 15:32:02.635] wl_cfg80211_connect: Connectting with fc:ec:da:f8:5f:e2 channel (36) ssid "Nova", len (4)
[ 8.987949] [12-09 15:32:02.691] wl_notify_connect_status: wl_bss_connect_done succeeded with fc:ec:da:f8:5f:e2
[ 8.988400] [12-09 15:32:02.692] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M1 of 4way
[ 9.007145] wl_bss_connect_done :
[ 9.007149] Report connect result - connection succeeded
[ 9.007156] [12-09 15:32:02.711] wl_notify_connect_status: wl_bss_connect_done succeeded with fc:ec:da:f8:5f:e2
[ 9.008016] [12-09 15:32:02.711] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M2 of 4way
[ 9.009804] [12-09 15:32:02.713] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M3 of 4way
[ 9.009955] [12-09 15:32:02.713] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M4 of 4way
[ 9.026654] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 9.074587] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 9.074596] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 9.127804] ifidx:0 DHCP - REQUEST [TX]
[ 9.154993] ifidx:0 DHCP - ACK [RX]
