I have never connected TW6816 to Jetson TX2. I do not have TW6816. I have already connected DVP-7041E video capture card to mini pci-e. Then i have connected mini pci-e card to M.2 KEY e input on Jetson TX2.
nvidia@tegra-ubuntu:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@969ee000
[ 0.000000] Found lut_mem2: 00002008@969eb000
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x969ee000 lut_mem2=0x2008@0x969eb000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0321217203498 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7967772K/8208384K available (11296K kernel code, 1841K rwdata, 5796K rodata, 1168K init, 691K bss, 175076K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168 KB)
.text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096 KB)
.data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009842] Console: colour dummy device 80x25
[ 0.014501] console [tty0] enabled
[ 0.018058] bootconsole [uart0] disabled
[ 0.022162] kmemleak: Kernel memory leak detector disabled
[ 0.022173] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022185] pid_max: default: 32768 minimum: 301
[ 0.022233] Security Framework initialized
[ 0.022270] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022281] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022660] Initializing cgroup subsys io
[ 0.022673] Initializing cgroup subsys memory
[ 0.022689] Initializing cgroup subsys devices
[ 0.022699] Initializing cgroup subsys freezer
[ 0.022708] Initializing cgroup subsys net_cls
[ 0.022718] Initializing cgroup subsys perf_event
[ 0.022727] Initializing cgroup subsys net_prio
[ 0.022737] Initializing cgroup subsys pids
[ 0.022745] Initializing cgroup subsys debug
[ 0.022885] CPU0 ipc=752
[ 0.022895] CPU1 ipc=1024
[ 0.022902] CPU2 ipc=1024
[ 0.022911] CPU3 ipc=752
[ 0.022921] CPU4 ipc=752
[ 0.022931] CPU5 ipc=752
[ 0.022967] ASID allocator initialised with 65536 entries
[ 0.046163] tegra-id: chipid=21817.
[ 0.046181] tegra-id: opt_subrevision=1.
[ 0.046194] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046863] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046889] DTB Build time: May 17 2018 00:17:47
[ 0.062562] CPU1: Booted secondary processor [4e0f0030]
[ 0.074114] CPU2: Booted secondary processor [4e0f0030]
[ 0.085808] CPU3: Booted secondary processor [411fd073]
[ 0.097802] CPU4: Booted secondary processor [411fd073]
[ 0.109802] CPU5: Booted secondary processor [411fd073]
[ 0.109865] Brought up 6 CPUs
[ 0.109921] SMP: Total of 6 processors activated.
[ 0.109933] CPU: All CPU(s) started at EL2
[ 0.110353] devtmpfs: initialized
[ 0.137148] Initilizing CustomIPI irq domain
[ 0.137364] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138124] pinctrl core: initialized pinctrl subsystem
[ 0.138297] OS set in device tree is not L4T.
[ 0.138493] regulator-dummy: no parameters
[ 0.138598] Initializing plugin-manager
[ 0.138650] Plugin module not found
[ 0.139056] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139391] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.139995] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141145] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141523] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.141778] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.141999] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142421] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.142859] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143131] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143148] node /plugin-manager/fragment-500-e3325-pcie match with odm-data enable-pcie-on-uphy-lane0
[ 0.143628] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143872] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144093] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144349] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.145911] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[ 0.146982] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148762] Adding domain adsp-pd to PM domain ape-pd
[ 0.151136] NET: Registered protocol family 16
[ 0.151997] console [pstore-1] enabled
[ 0.152010] pstore: Registered ramoops as persistent store backend
[ 0.152022] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161343] cpuidle: using governor ladder
[ 0.165808] cpuidle: using governor menu
[ 0.166943] bpmp: waiting for handshake
[ 0.166958] bpmp: handshake completed
[ 0.166999] bpmp: synchronizing channels
[ 0.167025] bpmp: channels synchronized
[ 0.167036] bpmp: mail init ok
[ 0.167396] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)
[ 0.167430] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168361] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169757] tegra_powergate_init: DONE
[ 0.169777] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169813] DTB Build time: May 17 2018 00:17:47
[ 0.170748] Tegra reboot handler registered.
[ 0.171793] Registering Tegra186 clocks (this may take a while)...done
[ 0.173905] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.173923] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173936] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173949] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173961] arm-smmu 12000000.iommu: nested translation
[ 0.173975] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.173994] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174012] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174026] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.174039] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.220263] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.226622] iommu: Adding device 3460000.sdhci to group 0
[ 0.227637] iommu: Adding device 3400000.sdhci to group 1
[ 0.231558] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.232034] iommu: Adding device 3160000.i2c to group 3
[ 0.232487] iommu: Adding device c240000.i2c to group 4
[ 0.232849] iommu: Adding device 3180000.i2c to group 5
[ 0.233254] iommu: Adding device 3190000.i2c to group 6
[ 0.233748] iommu: Adding device 31b0000.i2c to group 7
[ 0.234110] iommu: Adding device 31c0000.i2c to group 8
[ 0.234453] iommu: Adding device c250000.i2c to group 9
[ 0.234826] iommu: Adding device 31e0000.i2c to group 10
[ 0.236859] iommu: Adding device 3210000.spi to group 11
[ 0.237181] iommu: Adding device c260000.spi to group 12
[ 0.237533] iommu: Adding device 3240000.spi to group 13
[ 0.238339] iommu: Adding device 3100000.serial to group 14
[ 0.238710] iommu: Adding device 3110000.serial to group 15
[ 0.239082] iommu: Adding device c280000.serial to group 16
[ 0.239443] iommu: Adding device 3130000.serial to group 17
[ 0.240694] iommu: Adding device 2490000.ether_qos to group 18
[ 0.241317] iommu: Adding device b000000.rtcpu to group 19
[ 0.241805] iommu: Adding device c1a0000.aon to group 20
[ 0.242736] Wake73 for irq=42
[ 0.243091] iommu: Adding device smmu_test to group 21
[ 0.243611] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.243652] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.243688] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.243725] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.243760] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.243819] mc-err: Set intmask: 0xf3140
[ 0.244057] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.244893] Wake76 for irq=199
[ 0.244922] Wake77 for irq=199
[ 0.244943] Wake78 for irq=199
[ 0.244963] Wake79 for irq=199
[ 0.244982] Wake80 for irq=199
[ 0.245001] Wake81 for irq=199
[ 0.245020] Wake82 for irq=199
[ 0.245164] iommu: Adding device 3530000.xhci to group 22
[ 0.245508] iommu: Adding device 3550000.xudc to group 23
[ 0.246307] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.246338] tegra-pmc: ### PMC reset source: Power on reset
[ 0.246361] tegra-pmc: ### PMC reset level: L0
[ 0.246382] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.246685] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.246724] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.246887] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.246916] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.247441] iommu: Adding device 13e10000.host1x to group 24
[ 0.247692] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.247964] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.248251] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.248495] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.248713] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.248985] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.249205] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.249473] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.249905] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.250442] iommu: Adding device 15700000.vi to group 34
[ 0.250812] iommu: Adding device 15600000.isp to group 35
[ 0.251170] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.251378] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ee000(800000)
[ 0.251422] platform 15210000.nvdisplay: IOVA linear map 0x00000000969eb000(3000)
[ 0.251606] iommu: Adding device 15340000.vic to group 37
[ 0.251815] iommu: Adding device 154c0000.nvenc to group 38
[ 0.252030] iommu: Adding device 15480000.nvdec to group 39
[ 0.252354] iommu: Adding device 15380000.nvjpg to group 40
[ 0.252575] iommu: Adding device 15500000.tsec to group 41
[ 0.252776] iommu: Adding device 15100000.tsecb to group 42
[ 0.253499] iommu: Adding device 15810000.se to group 43
[ 0.253696] iommu: Adding device 15820000.se to group 44
[ 0.253891] iommu: Adding device 15830000.se to group 45
[ 0.254102] iommu: Adding device 15840000.se to group 46
[ 0.254644] iommu: Adding device 17000000.gp10b to group 47
[ 0.256035] tegra-reset 5000000.clock: registered 193 resets.
[ 0.258097] iommu: Adding device d000000.bpmp to group 48
[ 0.258358] bpmp: ping status is 0
[ 0.258538] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.258934] bpmp d000000.bpmp: probe ok
[ 0.261830] iommu: Adding device 2600000.dma to group 49
[ 0.262758] GPIO line 459 (pcie-lane2-mux) hogged as output/low
[ 0.262828] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.262904] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.262962] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.263015] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.263073] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.263128] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.263185] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.263315] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.265170] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.265308] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.266323] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.266660] iommu: Adding device sound to group 51
[ 0.268481] iommu: Adding device 3510000.hda to group 52
[ 0.269683] iommu: Adding device adsp_audio to group 53
[ 0.271161] iommu: Adding device 2993000.adsp to group 54
[ 0.280426] vdd-ac-bat: 5000 mV
[ 0.282626] vdd-1v8-ap: 1800 mV
[ 0.300819] SCSI subsystem initialized
[ 0.301011] libata version 3.00 loaded.
[ 0.301181] usbcore: registered new interface driver usbfs
[ 0.301239] usbcore: registered new interface driver hub
[ 0.301360] usbcore: registered new device driver usb
[ 0.305173] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.305628] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.305751] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.307164] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.307258] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.317892] media: Linux media interface: v0.10
[ 0.317960] Linux video capture interface: v2.00
[ 0.321102] pps_core: LinuxPPS API ver. 1 registered
[ 0.321138] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.321219] PTP clock support registered
[ 0.322187] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.322235] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.323771] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.325850] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.326030] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.326140] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.330292] vddio-ddr: at 1125 mV
[ 0.334125] avdd_dsi_csi: 1200 mV
[ 0.338121] vdd-1v8: 1800 mV
[ 0.342121] vdd-3v3-sys: 3300 mV
[ 0.343215] spmic-ldo0: at 1800 mV
[ 0.344000] spmic-ldo1: at 800 mV
[ 0.346151] vddio-3v3: 3300 mV
[ 0.346842] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.350126] vdd-rtc: at 800 mV
[ 0.350957] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.354126] spmic-ldo6: at 1500 mV
[ 0.358127] vdd-pex-1v05: 1000 mV
[ 0.358738] dvdd-pex: 1000 mV
[ 0.359014] max77620 4-003c: max77620 probe successful
[ 0.359272] Advanced Linux Sound Architecture Driver Initialized.
[ 0.360222] en-vdd-sd: 3300 mV
[ 0.360823] en-vdd-cam: 1800 mV
[ 0.365810] vdd-hdmi: 5000 mV
[ 0.365987] vdd-usb0-5v: 5000 mV
[ 0.366154] vdd-usb1-5v: 5000 mV
[ 0.369812] en-vdd-ts-1v8: 1800 mV
[ 0.373810] en-vdd-ts-hv-3v3: 3300 mV
[ 0.374329] en-vdd-disp-3v3: 3300 mV
[ 0.374828] en-mdm-pwr-3v7: 3700 mV
[ 0.375337] en-vdd-disp-1v8: 1800 mV
[ 0.375845] en-vdd-cam-hv-2v8: 2800 mV
[ 0.376355] en-vdd-cam-1v2: 1200 mV
[ 0.376870] vdd-fan: 5000 mV
[ 0.376989] vdd-3v3: 3300 mV
[ 0.377703] dis-vdd-1v2: 1200 mV
[ 0.377824] en-vdd-vcm-2v8: 2800 mV
[ 0.378333] vdd-usb2-5v: 5000 mV
[ 0.378439] vdd-sys-bl: 3300 mV
[ 0.378971] en-vdd-sys: 1200 mV
[ 0.382309] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.382694] clocksource: Switched to clocksource arch_sys_counter
[ 0.400952] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.401238] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.401714] nvmap_page_pool_init: Total RAM pages: 2008327
[ 0.401732] nvmap_page_pool_init: nvmap page pool size: 251040 pages (980 MB)
[ 0.401923] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.406329] Wake76 for irq=199
[ 0.406342] Wake77 for irq=199
[ 0.406353] Wake78 for irq=199
[ 0.406363] Wake79 for irq=199
[ 0.406373] Wake80 for irq=199
[ 0.406383] Wake81 for irq=199
[ 0.406392] Wake82 for irq=199
[ 0.407132] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.407327] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.407698] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.407775] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.407916] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.408054] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.408199] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.408491] isomgr_init(): iso emc max clk=1866000KHz
[ 0.408503] isomgr_init(): max_iso_bw=26870400KB
[ 0.408587] NET: Registered protocol family 2
[ 0.408888] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.409112] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.409407] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.409466] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.409521] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.409682] NET: Registered protocol family 1
[ 0.409891] RPC: Registered named UNIX socket transport module.
[ 0.409906] RPC: Registered udp transport module.
[ 0.409917] RPC: Registered tcp transport module.
[ 0.409928] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.409948] PCI: CLS 0 bytes, default 128
[ 0.410041] Trying to unpack rootfs image as initramfs...
[ 0.423670] host1x 13e10000.host1x: initialized
[ 0.424536] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.426221] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.426316] audit: initializing netlink subsys (disabled)
[ 0.426349] audit: type=2000 audit(0.412:1): initialized
[ 0.432785] io scheduler noop registered
[ 0.432889] io scheduler cfq registered (default)
[ 0.435841] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.437030] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.438098] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.439162] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.442563] tsec 15500000.tsec: initialized
[ 0.443700] tsec 15100000.tsecb: initialized
[ 0.446048] nvdec 15480000.nvdec: initialized
[ 0.449687] falcon 15340000.vic: initialized
[ 0.450680] falcon 154c0000.nvenc: initialized
[ 0.451669] falcon 15380000.nvjpg: initialized
[ 0.452429] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.452926] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.453425] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.453925] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.454419] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.454932] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.455427] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.455930] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.458512] DC OR NODE connected to /host1x/sor1
[ 0.458629] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.458635] generic_infoframe_type: 0x87
[ 0.458740] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.458760] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.458781] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.458787] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.466403] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.466424] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.466430] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.466451] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.466495] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.466510] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.467421] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.468321] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.468803] kfuse 3830000.kfuse: initialized
[ 0.469650] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.470535] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.470991] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.471222] tegradc 15210000.nvdisplay: probed
[ 0.472922] console [ttyS0] disabled
[ 0.472971] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.615736] console [ttyS0] enabled
[ 2.617767] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.618856] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.619071] serial-tegra 3130000.serial: RX in PIO mode
[ 2.619947] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.630275] Console: switching to colour frame buffer device 240x67
[ 2.630315] brd: module loaded
[ 2.634856] loop: module loaded
[ 2.635109] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.635113] nct1008_nct72 7-004c: starting parse dt
[ 2.635201] nct1008_nct72 7-004c: success parsing dt
[ 2.635318] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.714927] tegradc 15210000.nvdisplay: fb registered
[ 2.714942] tmp451: Enabled overheat logging at 104.00C
[ 2.715039] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.717075] THERMAL EST: found 3 subdevs
[ 2.717077] THERMAL EST num_resources: 0
[ 2.717081] [THERMAL EST subdev 0]
[ 2.717084] [THERMAL EST subdev 1]
[ 2.717086] [THERMAL EST subdev 2]
[ 2.717295] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.717296] THERMAL EST: thz register success.
[ 2.717368] THERMAL EST: end of probe, return err: 0
[ 2.717412] tegra_profiler: Branch: Dev
[ 2.717413] tegra_profiler: Version: 1.117
[ 2.717415] tegra_profiler: Samples version: 41
[ 2.717416] tegra_profiler: IO version: 22
[ 2.717419] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.717422] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.717424] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.717426] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0, pmu ver: 0x1
[ 2.717428] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.717430] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0, pmu ver: 0x1
[ 2.717432] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.717433] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.717435] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.717437] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.717439] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.717440] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.717513] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.717542] tegra_profiler: auth: init
[ 2.720210] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.720216] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.720838] scsi host0: tegra_ahci
[ 2.721065] scsi host1: tegra_ahci
[ 2.721178] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.721180] ata2: DUMMY
[ 2.721904] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.722246] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.722554] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.723184] tun: Universal TUN/TAP device driver, 1.6
[ 2.723185] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.723323] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.723324] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.723351] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.723353] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.724119] PPP generic driver version 2.4.2
[ 2.724222] PPP BSD Compression module registered
[ 2.724227] PPP Deflate Compression module registered
[ 2.724240] PPP MPPE Compression module registered
[ 2.724250] NET: Registered protocol family 24
[ 2.724292] usbcore: registered new interface driver r8152
[ 2.724319] usbcore: registered new interface driver asix
[ 2.724343] usbcore: registered new interface driver ax88179_178a
[ 2.724365] usbcore: registered new interface driver cdc_ether
[ 2.724392] usbcore: registered new interface driver smsc75xx
[ 2.724416] usbcore: registered new interface driver net1080
[ 2.724437] usbcore: registered new interface driver cdc_subset
[ 2.724459] usbcore: registered new interface driver zaurus
[ 2.724495] usbcore: registered new interface driver cdc_ncm
[ 2.724681] Wake76 for irq=199
[ 2.724683] Wake77 for irq=199
[ 2.724684] Wake78 for irq=199
[ 2.724685] Wake79 for irq=199
[ 2.724686] Wake80 for irq=199
[ 2.724687] Wake81 for irq=199
[ 2.724688] Wake82 for irq=199
[ 2.724731] tegra-xotg xotg: usb2 phy is not available yet
[ 2.725164] usbcore: registered new interface driver cdc_acm
[ 2.725165] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.725193] usbcore: registered new interface driver usb-storage
[ 2.725234] usbcore: registered new interface driver usbserial
[ 2.725254] usbcore: registered new interface driver cp210x
[ 2.725269] usbserial: USB Serial support registered for cp210x
[ 2.725287] usbcore: registered new interface driver ftdi_sio
[ 2.725300] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.725319] usbcore: registered new interface driver option
[ 2.725333] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.725350] usbcore: registered new interface driver pl2303
[ 2.725363] usbserial: USB Serial support registered for pl2303
[ 2.725499] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.727273] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c 8f 2c
[ 2.727691] libphy: dwc_phy: probed
[ 2.728108] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.791875] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.860510] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.862711] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.862723] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.862861] i2c /dev entries driver
[ 2.863587] [OV5693]: probing v4l2 sensor.
[ 3.038731] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.320871] PD DISP0 index2 UP
[ 3.344604] PD DISP1 index3 UP
[ 3.349217] PD DISP2 index4 UP
[ 3.362914] Parent Clock set for DC plld2
[ 3.369391] edid invalid
[ 3.411455] edid invalid
[ 3.415355] edid invalid
[ 3.419245] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting:prod_c_150M
[ 3.574965] tegradc 15210000.nvdisplay: blank - normal
[ 3.578274] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.636984] PD DISP2 index4 DOWN
[ 3.638190] PD DISP1 index3 DOWN
[ 3.638905] PD DISP0 index2 DOWN
[ 3.668278] tegradc 15210000.nvdisplay: unblank
[ 3.668349] PD DISP0 index2 UP
[ 3.674645] PD DISP1 index3 UP
[ 3.675178] PD DISP2 index4 UP
[ 3.691376] Parent Clock set for DC plld2
[ 3.694324] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 3.761565] gspca_main: v2.14.0 registered
[ 3.761608] usbcore: registered new interface driver gspca_zc3xx
[ 3.761939] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.763851] FAN dev name: pwm-fan
[ 3.763899] FAN:gpio request success.
[ 3.763905] FAN: can't find tach_gpio
[ 3.763925] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.764095] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.764098] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.764384] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.764388] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.764391] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.764394] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.764397] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.764399] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.764402] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.764405] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.764408] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.764411] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.765141] device-mapper: uevent: version 1.0.3
[ 3.765320] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.765684] sdhci: Secure Digital Host Controller Interface driver
[ 3.765685] sdhci: Copyright(c) Pierre Ossman
[ 3.765690] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.765973] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.766266] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.766504] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.767075] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.767203] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.768748] usbcore: registered new interface driver usbhid
[ 3.768749] usbhid: USB HID core driver
[ 3.773554] nvadsp 2993000.adsp: in probe()...
[ 3.789867] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.789893] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.790080] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.790811] Denver: backdoor interface is NOT available.
[ 3.792492] coresight-tmc 8030000.etf: TMC initialized
[ 3.793546] coresight-tmc 8050000.etr: TMC initialized
[ 3.793887] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.794359] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.794754] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.795150] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.795539] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.796111] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.796621] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.797124] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.797632] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.797656] Module initialized successfully
[ 3.800822] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.802020] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.802203] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.802511] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.802555] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.802592] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.802629] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.802667] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.802712] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.802717] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.802759] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.802956] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.802958] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.802961] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.803236] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.803491] random: nonblocking pool is initialized
[ 3.806984] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.806987] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.806989] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.806992] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.806994] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.806996] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.806999] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.807025] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.811170] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.811945] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.812044] camchar: rtcpu character device driver loaded
[ 3.815533] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.815762] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.815850] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.816179] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.816207] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.816230] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.816253] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.816275] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.816300] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.816323] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.816345] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.816368] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.816392] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.816414] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.816437] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.816460] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.816482] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.816503] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.816553] **** A57 ECC: Enabled
[ 3.816555] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.816687] parse_throttle_dt_data: Num cap clks = 4
[ 3.816689] parse_throttle_dt_data: clk=mcpu type=1
[ 3.816691] parse_throttle_dt_data: clk=bcpu type=2
[ 3.816697] parse_throttle_dt_data: clk=gpu type=4
[ 3.816698] parse_throttle_dt_data: clk=emc type=3
[ 3.817157] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.817242] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 3.819664] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.819969] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.821995] tegra-se-nvhost 15810000.se: initialized
[ 3.822415] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.822728] tegra-se-nvhost 15820000.se: initialized
[ 3.823158] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.823439] tegra-se-nvhost 15830000.se: initialized
[ 3.823556] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.823828] tegra-se-nvhost 15840000.se: initialized
[ 3.824280] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.827811] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.831000] cpufreq: platform driver Initialization: pass
[ 3.831126] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[ 3.831176] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.831336] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.831340] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.831374] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x32b917
[ 3.831377] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.832520] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.832997] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 3.833507] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.833843] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.835293] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.835403] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.836302] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.836306] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.838925] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.839461] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.839695] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.839992] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.840252] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.840547] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.840550] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.840552] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.842708] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.842709] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.842934] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.842997] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.843600] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.843624] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.844172] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.851371] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.851496] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.853100] OPE platform probe
[ 3.853168] OPE platform probe successful
[ 3.876717] mmc0: MAN_BKOPS_EN bit is not set
[ 3.883019] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.888988] mmc0: Skipping tuning since strobe enabled
[ 3.896955] mmc0: periodic cache flush enabled
[ 3.896964] mmc0: new HS400 MMC card at address 0001
[ 3.897287] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.897448] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.897599] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.897747] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.899020] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 3.920961] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.921115] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.921260] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.921384] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.921493] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.921602] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.921719] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.921819] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.921917] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.922033] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.922136] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 3.922237] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 3.922353] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 3.922452] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 3.922569] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 3.922681] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 3.922815] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.922928] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.923053] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.923151] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.927746] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 3.927853] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 3.927883] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 3.927910] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 3.935131] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.966231] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.966995] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 3.966998] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.967726] GACT probability NOT on
[ 3.967736] Mirror/redirect action on
[ 3.967747] u32 classifier
[ 3.967748] Actions configured
[ 3.967777] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.968419] IPVS: Registered protocols ()
[ 3.968448] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.968516] IPVS: Creating netns size=1424 id=0
[ 3.968540] IPVS: ipvs loaded.
[ 3.968546] IPVS: [rr] scheduler registered.
[ 3.968618] ipip: IPv4 over IPv4 tunneling driver
[ 3.968931] Initializing XFRM netlink socket
[ 3.969266] NET: Registered protocol family 10
[ 3.969927] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.970003] NET: Registered protocol family 17
[ 3.970016] NET: Registered protocol family 15
[ 3.970043] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.970049] 8021q: 802.1Q VLAN Support v1.8
[ 3.970620] Registered cp15_barrier emulation handler
[ 3.970648] Registered setend emulation handler
[ 3.972683] registered taskstats version 1
[ 3.976177] isp 15600000.isp: initialized
[ 3.980422] nvcsi 150c0000.nvcsi: initialized
[ 3.981525] Wake76 for irq=199
[ 3.981526] Wake77 for irq=199
[ 3.981527] Wake78 for irq=199
[ 3.981528] Wake79 for irq=199
[ 3.981528] Wake80 for irq=199
[ 3.981529] Wake81 for irq=199
[ 3.981529] Wake82 for irq=199
[ 3.981820] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 3.981822] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.002991] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.003143] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.003145] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.003623] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.004316] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.005000] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 4.005036] tegra-xotg xotg: update_id_state: ID floating
[ 4.005040] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 4.005053] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.006757] tegra-xotg xotg: otg: gadget gadget registered
[ 4.006759] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 4.006761] tegra-xotg xotg: otg: host not registered yet
[ 4.006762] tegra-xotg xotg: otg: start OTG finite state machine
[ 4.006806] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.007340] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.007849] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.041959] tegra_rtc c2a0000.rtc: setting system clock to 2018-07-30 09:15:55 UTC (1532942155)
[ 4.071884] bpmp: mounted debugfs mirror
[ 4.072411] [dram-timers] DRAM derating cdev registered.
[ 4.077021] spmic-ldo0: disabling
[ 4.077195] spmic-ldo1: disabling
[ 4.077337] en-vdd-cam: disabling
[ 4.077339] vdd-usb0-5v: disabling
[ 4.077340] vdd-usb1-5v: disabling
[ 4.077343] en-vdd-disp-3v3: disabling
[ 4.077345] en-mdm-pwr-3v7: disabling
[ 4.077346] en-vdd-disp-1v8: disabling
[ 4.077348] en-vdd-cam-hv-2v8: disabling
[ 4.077349] en-vdd-cam-1v2: disabling
[ 4.077350] vdd-fan: disabling
[ 4.077352] vdd-3v3: disabling
[ 4.077354] en-vdd-vcm-2v8: disabling
[ 4.077355] vdd-usb2-5v: disabling
[ 4.077357] vdd-sys-bl: disabling
[ 4.077359] en-vdd-sys: disabling
[ 4.082983] ALSA device list:
[ 4.082984] #0: tegra-hda at 0x3518000 irq 400
[ 4.082986] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.084254] tegra-vi4 15700000.vi: initialized
[ 4.085417] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 4.085420] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 4.133388] mmc1 tuning done saved tap delay=63
[ 4.133391] mmc1: hw tuning done ...
[ 4.133396] mmc1: tuning_window[0]: 0xffffffff
[ 4.133401] mmc1: tuning_window[1]: 0xfffff8ff
[ 4.133405] mmc1: tuning_window[2]: 0xff8fffff
[ 4.133410] mmc1: tuning_window[3]: 0x7fffffff
[ 4.133414] mmc1: tuning_window[4]: 0x0
[ 4.133418] mmc1: tuning_window[5]: 0x0
[ 4.133442] mmc1: tuning_window[6]: 0x0
[ 4.133446] mmc1: tuning_window[7]: 0x0
[ 4.133449] sdhci: Tap value: 63 | Trim value: 5
[ 4.133452] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.138940] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.138982] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 6.672040] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.675609] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.675622] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.676610] devtmpfs: mounted
[ 6.676908] Freeing unused kernel memory: 1168K (ffffffc001132000 - ffffffc001256000)
[ 6.676931] Freeing alternatives memory: 96K (ffffffc001256000 - ffffffc00126e000)
[ 6.683856] btb inv war enabled
[ 6.743727] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.763813] systemd[1]: Detected architecture arm64.
[ 6.782062] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 6.912575] systemd[1]: Reached target Swap.
[ 6.921041] systemd[1]: Created slice System Slice.
[ 6.929442] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.939956] systemd[1]: Listening on Journal Socket.
[ 6.949876] systemd[1]: Started Braille Device Support.
[ 6.959325] systemd[1]: Listening on udev Control Socket.
[ 6.968480] systemd[1]: Reached target User and Group Name Lookups.
[ 6.980271] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 6.994910] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.004623] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.015576] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.026517] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.032797] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.045430] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.055269] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 7.066833] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 7.080855] systemd[1]: Reached target Remote File Systems (Pre).
[ 7.092501] systemd[1]: Starting Set console keymap...
[ 7.107452] systemd[1]: Mounting Debug File System...
[ 7.121109] systemd[1]: Starting Load Kernel Modules...
[ 7.130155] systemd[1]: Listening on udev Kernel Socket.
[ 7.139893] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.150801] systemd[1]: Created slice User and Session Slice.
[ 7.160357] systemd[1]: Reached target Slices.
[ 7.168798] systemd[1]: Listening on Journal Audit Socket.
[ 7.178113] systemd[1]: Reached target Encrypted Volumes.
[ 7.189382] systemd[1]: Reached target Remote File Systems.
[ 7.198949] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.208813] systemd[1]: Listening on Syslog Socket.
[ 7.219553] systemd[1]: Starting Journal Service...
[ 7.233061] systemd[1]: Mounted Debug File System.
[ 7.242509] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.256209] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 7.270771] systemd[1]: Started Remount Root and Kernel File Systems.
[ 7.285491] systemd[1]: Started Set console keymap.
[ 7.296080] systemd[1]: Started Load Kernel Modules.
[ 7.305202] systemd[1]: Started Journal Service.
[ 7.502607] systemd-journald[306]: Received request to flush runtime journal from PID 1
[ 7.678243] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 7.689494] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 7.699470] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 7.710624] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 7.724247] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[ 7.821640] dhd_module_init in
[ 7.821670] tegra_net_perf_init: cannot get wifi sclk
[ 7.821737] found wifi platform device bcmdhd_wlan
[ 7.824665] wifi_platform_get_country_code_map: could not get country_code_map
[ 7.824666] wifi_plat_dev_drv_probe:platform country code map is not available
[ 7.824677] Power-up adapter 'DHD generic adapter'
[ 7.824683] wifi_platform_set_power = 1
[ 8.026708] wifi_platform_bus_enumerate device present 1
[ 8.052708] wifi_platform_bus_enumerate device present 0
[ 8.053049] F1 signature read @0x18000000=0x17214354
[ 8.056629] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.057158] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.057215] wifi_platform_prealloc: failed to alloc static mem section 7
[ 8.057230] wifi_platform_get_mac_addr
[ 8.064998] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 8.109688] wl_create_event_handler(): thread:wl_event_handler:200 started
[ 8.109815] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e0e81a70
[ 8.109818] dhd_attach(): thread:dhd_watchdog_thread:201 started
[ 8.109847] dhd_attach(): thread:dhd_dpc:202 started
[ 8.109875] dhd_attach(): thread:dhd_rxf:203 started
[ 8.109880] dhd_deferred_work_init: work queue initialized
[ 8.110291] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on May 17 2018 at 00:12:47
[ 8.110575] tegra_sysfs_register
[ 8.110607] Register interface [wlan0] MAC: 00:04:4b:8c:8f:2a
[ 8.110610] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.110704] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 63
[ 8.111770] wifi_platform_set_power = 0
[ 8.142758] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.544785] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.750425] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[ 8.752471] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.752485] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 8.753290] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 8.753313] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 8.753420] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.753423] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.753424] usb usb1: Product: xHCI Host Controller
[ 8.753426] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.753428] usb usb1: SerialNumber: 3530000.xhci
[ 8.753729] hub 1-0:1.0: USB hub found
[ 8.753750] hub 1-0:1.0: 4 ports detected
[ 8.754162] using random self ethernet address
[ 8.754166] using random host ethernet address
[ 8.765448] Mass Storage Function, version: 2009/09/11
[ 8.765452] LUN: removable file: (no medium)
[ 8.769689] using random self ethernet address
[ 8.769693] using random host ethernet address
[ 8.774886] usb0: HOST MAC fe:d0:ab:58:f4:a8
[ 8.774926] usb0: MAC b6:e6:01:63:ef:88
[ 8.775226] usb1: HOST MAC aa:5f:1c:06:68:56
[ 8.775238] usb1: MAC 3a:c2:75:de:70:23
[ 8.775251] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.776277] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.776291] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.776315] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.776810] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.776824] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.777519] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.777532] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.777915] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.782891] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.782899] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 8.783036] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.783039] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.783041] usb usb2: Product: xHCI Host Controller
[ 8.783042] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.783044] usb usb2: SerialNumber: 3530000.xhci
[ 8.783306] hub 2-0:1.0: USB hub found
[ 8.783324] hub 2-0:1.0: 3 ports detected
[ 8.783672] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 8.911917] device usb0 entered promiscuous mode
[ 8.914894] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.918598] device usb1 entered promiscuous mode
[ 8.922239] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 8.922244] l4tbr0: port 2(usb1) entered forwarding state
[ 8.922254] l4tbr0: port 2(usb1) entered forwarding state
[ 8.954904] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.956931] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 8.957323] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 8.957329] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[ 8.957333] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[ 8.957337] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 8.957340] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 8.957371] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[ 8.957474] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 8.957630] iommu: Adding device 0000:00:03.0 to group 55
[ 8.957716] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 8.957902] pci 0000:01:00.0: [12d8:e111] type 01 class 0x060400
[ 8.958185] iommu: Adding device 0000:01:00.0 to group 56
[ 8.958239] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 8.958400] pci 0000:02:04.0: [1797:6810] type 00 class 0x040000
[ 8.958436] pci 0000:02:04.0: reg 0x10: [mem 0x00000000-0x000003ff]
[ 8.958619] iommu: Adding device 0000:02:04.0 to group 57
[ 8.958714] pci 0000:02:04.1: [1797:6811] type 00 class 0x040000
[ 8.958750] pci 0000:02:04.1: reg 0x10: [mem 0x00000000-0x000003ff]
[ 8.958949] iommu: Adding device 0000:02:04.1 to group 58
[ 8.959314] pci 0000:02:04.2: [1797:6812] type 00 class 0x040000
[ 8.959362] pci 0000:02:04.2: reg 0x10: [mem 0x00000000-0x000003ff]
[ 8.959546] iommu: Adding device 0000:02:04.2 to group 59
[ 8.959616] pci 0000:02:04.3: [1797:6813] type 00 class 0x040000
[ 8.959651] pci 0000:02:04.3: reg 0x10: [mem 0x00000000-0x000003ff]
[ 8.959829] iommu: Adding device 0000:02:04.3 to group 60
[ 8.959900] pci 0000:02:04.4: [1797:6814] type 00 class 0x048000
[ 8.959936] pci 0000:02:04.4: reg 0x10: [mem 0x00000000-0x0000007f]
[ 8.960129] iommu: Adding device 0000:02:04.4 to group 61
[ 8.960195] pci 0000:02:04.5: [1797:6815] type 00 class 0x048000
[ 8.960230] pci 0000:02:04.5: reg 0x10: [mem 0x00000000-0x0000007f]
[ 8.960434] iommu: Adding device 0000:02:04.5 to group 62
[ 8.960501] pci 0000:02:04.6: [1797:6816] type 00 class 0x048000
[ 8.960536] pci 0000:02:04.6: reg 0x10: [mem 0x00000000-0x0000007f]
[ 8.960715] iommu: Adding device 0000:02:04.6 to group 63
[ 8.960782] pci 0000:02:04.7: [1797:6817] type 00 class 0x048000
[ 8.960816] pci 0000:02:04.7: reg 0x10: [mem 0x00000000-0x0000007f]
[ 8.960995] iommu: Adding device 0000:02:04.7 to group 64
[ 8.961076] pci 0000:02:05.0: [1797:6810] type 00 class 0x040000
[ 8.961111] pci 0000:02:05.0: reg 0x10: [mem 0x00000000-0x000003ff]
[ 8.961290] iommu: Adding device 0000:02:05.0 to group 65
[ 8.961352] pci 0000:02:05.1: [1797:6811] type 00 class 0x040000
[ 8.961547] pci 0000:02:05.1: reg 0x10: [mem 0x00000000-0x000003ff]
[ 8.961748] iommu: Adding device 0000:02:05.1 to group 66
[ 8.961811] pci 0000:02:05.2: [1797:6812] type 00 class 0x040000
[ 8.961845] pci 0000:02:05.2: reg 0x10: [mem 0x00000000-0x000003ff]
[ 8.962080] iommu: Adding device 0000:02:05.2 to group 67
[ 8.962145] pci 0000:02:05.3: [1797:6813] type 00 class 0x040000
[ 8.962179] pci 0000:02:05.3: reg 0x10: [mem 0x00000000-0x000003ff]
[ 8.962382] iommu: Adding device 0000:02:05.3 to group 68
[ 8.962444] pci 0000:02:05.4: [1797:6814] type 00 class 0x048000
[ 8.962479] pci 0000:02:05.4: reg 0x10: [mem 0x00000000-0x0000007f]
[ 8.962674] iommu: Adding device 0000:02:05.4 to group 69
[ 8.962764] pci 0000:02:05.5: [1797:6815] type 00 class 0x048000
[ 8.962799] pci 0000:02:05.5: reg 0x10: [mem 0x00000000-0x0000007f]
[ 8.962980] iommu: Adding device 0000:02:05.5 to group 70
[ 8.963062] pci 0000:02:05.6: [1797:6816] type 00 class 0x048000
[ 8.963097] pci 0000:02:05.6: reg 0x10: [mem 0x00000000-0x0000007f]
[ 8.963289] iommu: Adding device 0000:02:05.6 to group 71
[ 8.963356] pci 0000:02:05.7: [1797:6817] type 00 class 0x048000
[ 8.963391] pci 0000:02:05.7: reg 0x10: [mem 0x00000000-0x0000007f]
[ 8.964103] iommu: Adding device 0000:02:05.7 to group 72
[ 8.964229] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 8.964238] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 02
[ 8.964359] pci 0000:00:03.0: BAR 8: assigned [mem 0x50100000-0x501fffff]
[ 8.964364] pci 0000:01:00.0: BAR 8: assigned [mem 0x50100000-0x501fffff]
[ 8.964378] pci 0000:02:04.0: BAR 0: assigned [mem 0x50100000-0x501003ff]
[ 8.964386] pci 0000:02:04.1: BAR 0: assigned [mem 0x50100400-0x501007ff]
[ 8.964394] pci 0000:02:04.2: BAR 0: assigned [mem 0x50100800-0x50100bff]
[ 8.964402] pci 0000:02:04.3: BAR 0: assigned [mem 0x50100c00-0x50100fff]
[ 8.964425] pci 0000:02:05.0: BAR 0: assigned [mem 0x50101000-0x501013ff]
[ 8.964432] pci 0000:02:05.1: BAR 0: assigned [mem 0x50101400-0x501017ff]
[ 8.964439] pci 0000:02:05.2: BAR 0: assigned [mem 0x50101800-0x50101bff]
[ 8.964447] pci 0000:02:05.3: BAR 0: assigned [mem 0x50101c00-0x50101fff]
[ 8.964455] pci 0000:02:04.4: BAR 0: assigned [mem 0x50102000-0x5010207f]
[ 8.964462] pci 0000:02:04.5:
