Hi all,
We are using TX2 r28.1. We use the usb lane mapping #3. Three INTEL® 82574L GIGABIT ETHERNET CONTROLLERLs are connected to each of the three PCIE x1.
PCI#1_0, PCI#2_0 works.
00:02.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:10e6] (rev a1)
00:03.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:10e6] (rev a1)
01:00.0 Ethernet controller [0200]: Intel Corporation 82574L Gigabit Network Connection [8086:10d3]
02:00.0 Ethernet controller [0200]: Intel Corporation 82574L Gigabit Network Connection [8086:10d3]
But the PCI#0_0 never show. Can anyone help me ?
nvidia@tegra-ubuntu:~$ sudo devmem2 0x02520284 b
[sudo] password for nvidia:
/dev/mem opened.
Memory mapped at address 0x7f7d88b000.
Value at address 0x2520284 (0x7f7d88b284): 0x1
nvidia@tegra-ubuntu:~$ sudo devmem2 0x02530284 b
/dev/mem opened.
Memory mapped at address 0x7f98fbb000.
Value at address 0x2530284 (0x7f98fbb284): 0x0
nvidia@tegra-ubuntu:~$ sudo devmem2 0x02540284 b
/dev/mem opened.
Memory mapped at address 0x7fa79c5000.
Value at address 0x2540284 (0x7fa79c5284): 0x0
nvidia@tegra-ubuntu:~$ sudo devmem2 0x02550284 b
/dev/mem opened.
Memory mapped at address 0x7fa5dd2000.
Value at address 0x2550284 (0x7fa5dd2284): 0x1
nvidia@tegra-ubuntu:~$ sudo devmem2 0x02560284 b
/dev/mem opened.
Memory mapped at address 0x7f78d4c000.
Value at address 0x2560284 (0x7f78d4c284): 0x1
nvidia@tegra-ubuntu:~$ sudo devmem2 0x02570284 b
/dev/mem opened.
Memory mapped at address 0x7f91690000.
Value at address 0x2570284 (0x7f91690284): 0x2
The USB 3.0s works.
pcie-controller@10003000 {
status = "okay";
pci@1,0 {
nvidia,num-lanes = <1>;
status = "okay";
pci@2,0 {
status = "okay";
pci@3,0 {
status = "okay";
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (as@as-XS) (gcc version 4.8.5 (GCC) ) #52 SMP PREEMPT Sun Feb 25 13:34:35 CST 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2051072
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519408 pages, LIFO batch:31
[ 0.000000] Normal zone: 23933 pages used for memmap
[ 0.000000] Normal zone: 1531664 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5cea000 s31232 r8192 d30208 u69632
[ 0.000000] pcpu-alloc: s31232 r8192 d30208 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2018947
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0323917023426 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 pcie_aspm=off
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] log_buf_len individual max cpu contribution: 1048576 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 5242880 bytes
[ 0.000000] log_buf_len min size: 1048576 bytes
[ 0.000000] log_buf_len: 8388608 bytes
[ 0.000000] early log buf free: 1046336(99%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7954248K/8204288K available (12552K kernel code, 1868K rwdata, 6408K rodata, 1188K init, 8168K bss, 184504K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 MB)
.init : 0xffffffc001305000 - 0xffffffc00142e000 ( 1188 KB)
.text : 0xffffffc000080000 - 0xffffffc001305000 ( 18964 KB)
.data : 0xffffffc001451000 - 0xffffffc001624070 ( 1869 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009892] Console: colour dummy device 80x25
[ 0.014552] console [tty0] enabled
[ 0.018106] bootconsole [uart0] disabled
[ 0.022208] kmemleak: Kernel memory leak detector disabled
[ 0.022219] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022231] pid_max: default: 32768 minimum: 301
[ 0.022271] Security Framework initialized
[ 0.022299] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022307] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022659] Initializing cgroup subsys freezer
[ 0.022669] Initializing cgroup subsys debug
[ 0.022807] CPU0 ipc=752
[ 0.022816] CPU1 ipc=1024
[ 0.022822] CPU2 ipc=1024
[ 0.022830] CPU3 ipc=752
[ 0.022838] CPU4 ipc=752
[ 0.022847] CPU5 ipc=752
[ 0.022879] ASID allocator initialised with 65536 entries
[ 0.046376] tegra-id: chipid=21817.
[ 0.046387] tegra-id: opt_subrevision=1.
[ 0.046395] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.047034] DTS File Name: /ext/jet31.old/64_TX2/source_release/kernel_src-tx2/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.047053] DTB Build time: Feb 25 2018 13:05:43
[ 0.062615] CPU1: Booted secondary processor [4e0f0030]
[ 0.074115] CPU2: Booted secondary processor [4e0f0030]
[ 0.085833] CPU3: Booted secondary processor [411fd073]
[ 0.097851] CPU4: Booted secondary processor [411fd073]
[ 0.109829] CPU5: Booted secondary processor [411fd073]
[ 0.109890] Brought up 6 CPUs
[ 0.109939] SMP: Total of 6 processors activated.
[ 0.109950] CPU: All CPU(s) started at EL2
[ 0.110373] devtmpfs: initialized
[ 0.138806] Initilizing CustomIPI irq domain
[ 0.138999] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.139842] pinctrl core: initialized pinctrl subsystem
[ 0.140010] OS set in device tree is L4T.
[ 0.140206] regulator-dummy: no parameters
[ 0.140311] Initializing plugin-manager
[ 0.140364] Plugin module not found
[ 0.140771] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.141114] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.141746] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.142724] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.143073] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.143324] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.143542] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.143962] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.144400] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.144415] node /plugin-manager/fragment-500-e3325-pcie match with odm-data enable-pcie-on-uphy-lane0
[ 0.144830] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.145074] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.145294] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.145563] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.147132] node /plugin-manager/fragment-e3326@0 match with board 3310-*
[ 0.149119] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.150959] Adding domain adsp-pd to PM domain ape-pd
[ 0.153287] NET: Registered protocol family 16
[ 0.155545] console [pstore-1] enabled
[ 0.155556] pstore: Registered ramoops as persistent store backend
[ 0.155569] ramoops: attached 0x200000@0x96080000, ecc: 0/0
[ 0.165372] cpuidle: using governor ladder
[ 0.169831] cpuidle: using governor menu
[ 0.171005] bpmp: waiting for handshake
[ 0.171017] bpmp: handshake completed
[ 0.171057] bpmp: synchronizing channels
[ 0.171084] bpmp: channels synchronized
[ 0.171094] bpmp: mail init ok
[ 0.171490] vdso: 2 pages (1 code @ ffffffc001459000, 1 data @ ffffffc001458000)
[ 0.171521] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.172445] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.173797] tegra_powergate_init: DONE
[ 0.173816] DTS File Name: /ext/jet31.old/64_TX2/source_release/kernel_src-tx2/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.173852] DTB Build time: Feb 25 2018 13:05:43
[ 0.174759] Tegra reboot handler registered.
[ 0.175828] Registering Tegra186 clocks (this may take a while)...done
[ 0.177446] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.177461] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.177473] arm-smmu 12000000.iommu: stage 1 translation
[ 0.177484] arm-smmu 12000000.iommu: stage 2 translation
[ 0.177494] arm-smmu 12000000.iommu: nested translation
[ 0.177508] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.177525] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.177542] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.177555] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.177567] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.226386] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.231680] iommu: Adding device 3460000.sdhci to group 0
[ 0.232580] iommu: Adding device 3400000.sdhci to group 1
[ 0.236326] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.236752] iommu: Adding device 3160000.i2c to group 3
[ 0.237140] iommu: Adding device c240000.i2c to group 4
[ 0.237458] iommu: Adding device 3180000.i2c to group 5
[ 0.237797] iommu: Adding device 3190000.i2c to group 6
[ 0.238243] iommu: Adding device 31b0000.i2c to group 7
[ 0.238538] iommu: Adding device 31c0000.i2c to group 8
[ 0.238873] iommu: Adding device c250000.i2c to group 9
[ 0.239220] iommu: Adding device 31e0000.i2c to group 10
[ 0.241198] iommu: Adding device 3210000.spi to group 11
[ 0.241547] iommu: Adding device c260000.spi to group 12
[ 0.241837] iommu: Adding device 3240000.spi to group 13
[ 0.242637] iommu: Adding device 3100000.serial to group 14
[ 0.242934] iommu: Adding device 3110000.serial to group 15
[ 0.243267] iommu: Adding device c280000.serial to group 16
[ 0.243576] iommu: Adding device 3130000.serial to group 17
[ 0.244781] iommu: Adding device 2490000.ether_qos to group 18
[ 0.245375] iommu: Adding device b000000.rtcpu to group 19
[ 0.245826] iommu: Adding device c1a0000.aon to group 20
[ 0.246693] Wake73 for irq=42
[ 0.247016] iommu: Adding device smmu_test to group 21
[ 0.247533] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.247570] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.247603] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.247655] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.247688] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.247719] mc-err: Set intmask: 0xf3140
[ 0.247959] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.248746] Wake76 for irq=199
[ 0.248766] Wake77 for irq=199
[ 0.248783] Wake78 for irq=199
[ 0.248800] Wake79 for irq=199
[ 0.248817] Wake80 for irq=199
[ 0.248833] Wake81 for irq=199
[ 0.248851] Wake82 for irq=199
[ 0.248983] iommu: Adding device 3530000.xhci to group 22
[ 0.249316] iommu: Adding device 3550000.xudc to group 23
[ 0.250075] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.250102] tegra-pmc: ### PMC reset source: Software reset
[ 0.250123] tegra-pmc: ### PMC reset level: L1
[ 0.250141] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.250390] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.250424] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.250629] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.250656] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.251108] iommu: Adding device 13e10000.host1x to group 24
[ 0.251438] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.251781] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.252130] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.252385] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.252649] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.252863] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.253136] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.253350] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.253790] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.254318] iommu: Adding device 15700000.vi to group 34
[ 0.254650] iommu: Adding device 15600000.isp to group 35
[ 0.254982] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.255174] iommu: Adding device 15340000.vic to group 37
[ 0.255386] iommu: Adding device 154c0000.nvenc to group 38
[ 0.255575] iommu: Adding device 15480000.nvdec to group 39
[ 0.255871] iommu: Adding device 15380000.nvjpg to group 40
[ 0.256106] iommu: Adding device 15500000.tsec to group 41
[ 0.256322] iommu: Adding device 15100000.tsecb to group 42
[ 0.256963] iommu: Adding device 15810000.se to group 43
[ 0.257153] iommu: Adding device 15820000.se to group 44
[ 0.257385] iommu: Adding device 15830000.se to group 45
[ 0.257626] iommu: Adding device 15840000.se to group 46
[ 0.258274] iommu: Adding device 17000000.gp10b to group 47
[ 0.259844] tegra-reset 5000000.clock: registered 193 resets.
[ 0.261929] iommu: Adding device d000000.bpmp to group 48
[ 0.262165] bpmp: ping status is 0
[ 0.262342] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
[ 0.262725] bpmp d000000.bpmp: probe ok
[ 0.265186] iommu: Adding device 2600000.dma to group 49
[ 0.266039] GPIO line 459 (pcie-lane2-mux) hogged as output/low
[ 0.266101] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.266174] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.266223] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.266267] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.266318] GPIO line 457 (cam2-rst) hogged as output/high
[ 0.266360] GPIO line 426 (cam2-pwdn) hogged as output/high
[ 0.266409] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.266486] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.266535] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.266665] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.268518] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.268668] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.269548] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.269834] iommu: Adding device sound to group 51
[ 0.271673] iommu: Adding device 3510000.hda to group 52
[ 0.273181] iommu: Adding device adsp_audio to group 53
[ 0.274781] iommu: Adding device 2993000.adsp to group 54
[ 0.284281] vdd-ac-bat: 5000 mV
[ 0.286409] vdd-1v8-ap: 1800 mV
[ 0.287592] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.287944] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.304730] SCSI subsystem initialized
[ 0.304939] libata version 3.00 loaded.
[ 0.305130] usbcore: registered new interface driver usbfs
[ 0.305190] usbcore: registered new interface driver hub
[ 0.305295] usbcore: registered new device driver usb
[ 0.309449] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.309896] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.310002] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.310348] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.310803] pca953x 0-0077: failed reading register
[ 0.310876] pca953x: probe of 0-0077 failed with error -121
[ 0.323296] media: Linux media interface: v0.10
[ 0.323366] Linux video capture interface: v2.00
[ 0.327304] pps_core: LinuxPPS API ver. 1 registered
[ 0.327337] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.327399] PTP clock support registered
[ 0.328322] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.328365] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.329814] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.331779] GPIO line 237 (spmic_gpio_input_5) hogged as input
[ 0.331974] GPIO line 238 (spmic_gpio_input_6) hogged as input
[ 0.332069] gpiochip_add_data: registered GPIOs 232 to 239 on device: max77620-gpio
[ 0.338792] vddio-ddr: at 1125 mV
[ 0.342628] avdd_dsi_csi: 1200 mV
[ 0.346631] vdd-1v8: 1800 mV
[ 0.350628] vdd-3v3-sys: 3300 mV
[ 0.351403] spmic-ldo0: at 1800 mV
[ 0.352202] spmic-ldo1: at 800 mV
[ 0.354629] vddio-3v3: 3300 mV
[ 0.355283] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.358632] vdd-rtc: at 800 mV
[ 0.359321] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.362624] spmic-ldo6: at 1500 mV
[ 0.365837] vdd-pex-1v05: 1000 mV
[ 0.366378] dvdd-pex: 1000 mV
[ 0.366661] max77620 4-003c: max77620 probe successful
[ 0.366912] Advanced Linux Sound Architecture Driver Initialized.
[ 0.367915] en-vdd-sd: 3300 mV
[ 0.369863] vdd-hdmi: 5000 mV
[ 0.370044] vdd-usb0-5v: 5000 mV
[ 0.370216] vdd-usb1-5v: 5000 mV
[ 0.373836] en-vdd-ts-1v8: 1800 mV
[ 0.377834] en-vdd-ts-hv-3v3: 3300 mV
[ 0.378370] en-vdd-disp-3v3: 3300 mV
[ 0.378882] en-mdm-pwr-3v7: 3700 mV
[ 0.379398] en-vdd-disp-1v8: 1800 mV
[ 0.379915] en-vdd-cam-hv-2v8: 2800 mV
[ 0.380461] vdd-fan: 5000 mV
[ 0.380579] vdd-3v3: 3300 mV
[ 0.381291] dis-vdd-1v2: 1200 mV
[ 0.381402] en-vdd-vcm-2v8: 2800 mV
[ 0.381916] vdd-usb2-5v: 5000 mV
[ 0.382033] vdd-sys-bl: 3300 mV
[ 0.383810] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.385497] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.385980] clocksource: Switched to clocksource arch_sys_counter
[ 0.407071] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.407368] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.407843] nvmap_page_pool_init: Total RAM pages: 2004946
[ 0.407858] nvmap_page_pool_init: nvmap page pool size: 250618 pages (978 MB)
[ 0.408015] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.412701] Wake76 for irq=199
[ 0.412713] Wake77 for irq=199
[ 0.412723] Wake78 for irq=199
[ 0.412732] Wake79 for irq=199
[ 0.412740] Wake80 for irq=199
[ 0.412749] Wake81 for irq=199
[ 0.412757] Wake82 for irq=199
[ 0.413216] vcc_lp = (null), pca954x
[ 0.413234] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[ 0.413251] pca954x 2-0070: device detect skipped.
[ 0.413342] regulator_get() failed for (2-0070,vcc-pullup), -19
[ 0.413355] pca954x 2-0070: vcc-pullup regulator not found
[ 0.413557] i2c i2c-2: Added multiplexed i2c bus 30
[ 0.413680] i2c i2c-2: Added multiplexed i2c bus 31
[ 0.413800] i2c i2c-2: Added multiplexed i2c bus 32
[ 0.413867] i2c i2c-2: Added multiplexed i2c bus 33
[ 0.413880] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
[ 0.414229] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.414431] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.414553] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.414631] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.415032] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.415170] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.415312] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.415462] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.415754] isomgr_init(): iso emc max clk=1866000KHz
[ 0.415765] isomgr_init(): max_iso_bw=26870400KB
[ 0.415838] NET: Registered protocol family 2
[ 0.416135] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.416344] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.416639] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.416691] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.416742] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.416895] NET: Registered protocol family 1
[ 0.417107] RPC: Registered named UNIX socket transport module.
[ 0.417120] RPC: Registered udp transport module.
[ 0.417131] RPC: Registered tcp transport module.
[ 0.417141] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.417161] PCI: CLS 0 bytes, default 128
[ 0.417255] Trying to unpack rootfs image as initramfs...
[ 0.431298] host1x 13e10000.host1x: initialized
[ 0.432156] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.433828] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.433918] audit: initializing netlink subsys (disabled)
[ 0.433982] audit: type=2000 audit(0.424:1): initialized
[ 0.441139] io scheduler noop registered (default)
[ 0.443664] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.444827] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.445868] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.446902] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.449348] tegra-pcie 10003000.pcie-controller: 1x1, 1x1, 1x1 configuration
[ 0.451446] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.451949] tegra-pcie 10003000.pcie-controller: probing port 0, using 1 lanes
[ 0.452768] tsec 15500000.tsec: initialized
[ 0.453841] tsec 15100000.tsecb: initialized
[ 0.455781] nvdec 15480000.nvdec: initialized
[ 0.459073] falcon 15340000.vic: initialized
[ 0.460054] falcon 154c0000.nvenc: initialized
[ 0.461008] falcon 15380000.nvjpg: initialized
[ 0.461699] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.462217] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.462715] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.463209] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.463724] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.464217] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.464716] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.465209] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.466472] DC OR NODE connected to /host1x/sor1
[ 0.466638] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.466687] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.466727] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.466737] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.466740] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=4500000, max_bw=4687500
[ 0.474123] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.474141] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.474157] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.474200] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.474214] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.474430] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.476479] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.476786] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.476795] kfuse 3830000.kfuse: initialized
[ 0.476813] PD DISP0 index2 UP
[ 0.477634] PD DISP1 index3 UP
[ 0.477796] PD DISP2 index4 UP
[ 0.477973] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.478358] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.480189] console [ttyS0] disabled
[ 0.480233] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.504094] Unsupported HDMI VIC 5, ignoring
[ 0.504097] Unsupported HDMI VIC 58, ignoring
[ 0.504098] Unsupported HDMI VIC 128, ignoring
[ 0.504099] Unsupported HDMI VIC 24, ignoring
[ 0.504108] PD DISP2 index4 DOWN
[ 0.504260] PD DISP1 index3 DOWN
[ 0.504419] PD DISP0 index2 DOWN
[ 0.506340] tegradc 15210000.nvdisplay: probed
[ 1.454269] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[ 2.456503] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 2.717383] console [ttyS0] enabled
[ 2.719382] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.720499] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.720725] serial-tegra 3130000.serial: RX in PIO mode
[ 2.721662] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.731351] Console: switching to colour frame buffer device 240x67
[ 2.731795] brd: module loaded
[ 2.736407] loop: module loaded
[ 2.736622] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.736640] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.736644] nct1008_nct72 7-004c: starting parse dt
[ 2.736730] nct1008_nct72 7-004c: success parsing dt
[ 2.736848] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.820741] tegradc 15210000.nvdisplay: fb registered
[ 2.820798] tmp451: Enabled overheat logging at 104.00C
[ 2.820885] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.820913] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.843100] THERMAL EST: found 3 subdevs
[ 2.845909] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.845996] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 2.846069] PD DISP0 index2 UP
[ 2.847029] PD DISP1 index3 UP
[ 2.847215] PD DISP2 index4 UP
[ 2.856048] Parent Clock set for DC plld2
[ 2.860080] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 2.880119] THERMAL EST num_resources: 0
[ 2.884087] [THERMAL EST subdev 0]
[ 2.887525] [THERMAL EST subdev 1]
[ 2.890962] [THERMAL EST subdev 2]
[ 2.894607] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.903649] THERMAL EST: thz register success.
[ 2.908246] THERMAL EST: end of probe, return err: 0
[ 2.913453] tegra_profiler: Branch: Dev
[ 2.917330] tegra_profiler: Version: 1.109
[ 2.921465] tegra_profiler: Samples version: 37
[ 2.926039] tegra_profiler: IO version: 21
[ 2.930177] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.934578] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.944368] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.951481] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 2.961293] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.968378] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 2.978154] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.985253] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.994958] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.999977] Unsupported HDMI VIC 5, ignoring
[ 2.999986] Unsupported HDMI VIC 58, ignoring
[ 2.999989] Unsupported HDMI VIC 128, ignoring
[ 2.999991] Unsupported HDMI VIC 24, ignoring
[ 3.029886] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.029888] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.029890] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.030075] tegra_profiler: auth: init
[ 3.033654] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.033664] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.034745] scsi host0: tegra_ahci
[ 3.035125] scsi host1: tegra_ahci
[ 3.035264] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 3.035267] ata2: DUMMY
[ 3.036244] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.036731] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.037145] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.037985] tun: Universal TUN/TAP device driver, 1.6
[ 3.037987] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.038164] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 3.038166] e100: Copyright(c) 1999-2006 Intel Corporation
[ 3.038204] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 3.038206] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 3.038275] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 3.038277] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.038317] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.0.2-k
[ 3.038319] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.038354] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.4.6
[ 3.038356] Copyright(c) 1999 - 2016 Intel Corporation.
[ 3.038510] ixgbevf: Intel(R) 10 Gigabit PCI Express Virtual Function Network Driver - version 2.12.1-k
[ 3.038512] ixgbevf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.038549] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.3.46-k
[ 3.038551] i40e: Copyright (c) 2013 - 2014 Intel Corporation.
[ 3.038590] ixgb: Intel(R) PRO/10GbE Network Driver - version 1.0.135-k2-NAPI
[ 3.038592] ixgb: Copyright (c) 1999-2008 Intel Corporation.
[ 3.038628] i40evf: Intel(R) XL710/X710 Virtual Function Network Driver - version 1.3.33
[ 3.038629] Copyright (c) 2013 - 2015 Intel Corporation.
[ 3.038666] Intel(R) Ethernet Switch Host Interface Driver - version 0.15.2-k
[ 3.038667] Copyright (c) 2013 Intel Corporation.
[ 3.039964] PPP generic driver version 2.4.2
[ 3.040091] PPP BSD Compression module registered
[ 3.040099] PPP Deflate Compression module registered
[ 3.040125] PPP MPPE Compression module registered
[ 3.040137] NET: Registered protocol family 24
[ 3.040393] usbcore: registered new interface driver ath9k_htc
[ 3.040430] usbcore: registered new interface driver carl9170
[ 3.040498] usbcore: registered new interface driver r8152
[ 3.040537] usbcore: registered new interface driver asix
[ 3.040593] usbcore: registered new interface driver ax88179_178a
[ 3.040623] usbcore: registered new interface driver cdc_ether
[ 3.040661] usbcore: registered new interface driver smsc95xx
[ 3.040688] usbcore: registered new interface driver net1080
[ 3.040717] usbcore: registered new interface driver cdc_subset
[ 3.040745] usbcore: registered new interface driver zaurus
[ 3.040792] usbcore: registered new interface driver cdc_ncm
[ 3.041028] Wake76 for irq=199
[ 3.041031] Wake77 for irq=199
[ 3.041033] Wake78 for irq=199
[ 3.041035] Wake79 for irq=199
[ 3.041036] Wake80 for irq=199
[ 3.041038] Wake81 for irq=199
[ 3.041040] Wake82 for irq=199
[ 3.041131] tegra-xotg xotg: usb2 phy is not available yet
[ 3.041780] usbcore: registered new interface driver usb-storage
[ 3.041839] usbcore: registered new interface driver usbserial
[ 3.041868] usbcore: registered new interface driver ftdi_sio
[ 3.041889] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.041916] usbcore: registered new interface driver option
[ 3.041935] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.041982] usbcore: registered new interface driver pl2303
[ 3.042000] usbserial: USB Serial support registered for pl2303
[ 3.042174] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.043235] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 6a 9c
[ 3.043808] libphy: dwc_phy: probed
[ 3.044434] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.107012] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 3.107157] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.177087] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.179277] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.179293] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.179434] i2c /dev entries driver
[ 3.180490] [OV5693]: probing v4l2 sensor.
[ 3.180606] pdata->mclk_name = extperiph1
[ 3.180607] mclk_name = extperiph1
[ 3.181596] [OV5693]: probing v4l2 sensor.
[ 3.181702] pdata->mclk_name = extperiph1
[ 3.181704] mclk_name = extperiph1
[ 3.182155] [OV5693]: probing v4l2 sensor.
[ 3.182242] pdata->mclk_name = extperiph3
[ 3.182243] mclk_name = extperiph3
[ 3.183351] pca9570 30-0024: pca9570_icr_move, forward val=5
[ 3.293741] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.294348] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 3.294682] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.295246] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 3.354005] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.405608] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.406201] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 3.406542] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.407119] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 3.517468] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.518076] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 3.518405] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.518961] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 3.629308] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.629891] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 3.630231] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.630801] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 3.741146] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.741732] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 3.742071] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.742643] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 3.853002] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.853583] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 3.853924] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.854493] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 3.882180] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 3.964838] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.965421] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 3.965749] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 3.966320] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 4.076670] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 4.077244] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 4.077572] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 4.078152] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 4.188502] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 4.189083] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 4.189411] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 4.189982] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[ 4.286411] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 4.300325] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 4.300894] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[ 4.301222] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[ 4.301781] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[ 4.301783] pca9570 30-0024: pca9570_icr_move:i2c write failed
[ 4.301830] pca9570: probe of 30-0024 failed with error -121
[ 4.301858] gspca_main: v2.14.0 registered
[ 4.301918] usbcore: registered new interface driver gspca_zc3xx
[ 4.302244] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 4.304036] FAN dev name: pwm-fan
[ 4.304083] FAN:gpio request success.
[ 4.304089] FAN: can't find tach_gpio
[ 4.304111] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.304262] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 4.304267] pwm_fan_driver pwm-fan: got pwm for fan
[ 4.304270] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.304570] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.304574] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 4.304577] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.304580] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.304583] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.304586] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.304589] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.304592] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.304595] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.304598] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.305344] device-mapper: uevent: version 1.0.3
[ 4.305542] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 4.305942] sdhci: Secure Digital Host Controller Interface driver
[ 4.305943] sdhci: Copyright(c) Pierre Ossman
[ 4.305948] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.306279] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 4.306588] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 4.306828] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.307982] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.308104] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.309723] usbcore: registered new interface driver usbhid
[ 4.309724] usbhid: USB HID core driver
[ 4.311513] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 4.311890] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 4.311995] ina3221x: probe of 0-0042 failed with error -121
[ 4.312333] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 4.312698] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 4.312786] ina3221x: probe of 0-0043 failed with error -121
[ 4.313092] nvadsp 2993000.adsp: in probe()...
[ 4.314969] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 4.314997] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 4.315183] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 4.315887] Denver: backdoor interface is NOT available.
[ 4.317567] coresight-tmc 8030000.etf: TMC initialized
[ 4.318611] coresight-tmc 8050000.etr: TMC initialized
[ 4.318957] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 4.319419] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 4.319820] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 4.320210] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 4.320625] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 4.321210] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 4.321731] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 4.322278] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 4.322797] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 4.322822] Module initialized successfully
[ 4.326050] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 4.327308] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 4.327574] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 4.327954] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.327998] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 4.328035] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 4.328073] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 4.328110] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 4.328146] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 4.328182] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 4.328321] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 4.328324] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.329212] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 4.329215] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 4.329217] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 4.329220] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 4.329222] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 4.329224] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 4.329226] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 4.329251] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 4.333151] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 4.333906] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 4.334008] camchar: rtcpu character device driver loaded
[ 4.337470] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.337704] register_ari_mca_banks: Registered MCA ROC:IOB
[ 4.337791] register_ari_mca_banks: Registered MCA ROC:CCE
[ 4.338133] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 4.338158] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 4.338182] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 4.338206] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 4.338233] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 4.338256] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 4.338280] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 4.338304] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 4.338329] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 4.338351] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 4.338375] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 4.338399] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 4.338427] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 4.338452] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 4.338475] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 4.338523] **** A57 ECC: Enabled
[ 4.338525] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 4.338657] parse_throttle_dt_data: Num cap clks = 4
[ 4.338660] parse_throttle_dt_data: clk=mcpu type=1
[ 4.338662] parse_throttle_dt_data: clk=bcpu type=2
[ 4.338667] parse_throttle_dt_data: clk=gpu type=4
[ 4.338669] parse_throttle_dt_data: clk=emc type=3
[ 4.339116] tegra_throttle_probe: probe successful. #cdevs=4
[ 4.339199] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 4.341643] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.341949] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 4.341990] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.342219] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 4.342492] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 4.344866] tegra-se-nvhost 15810000.se: initialized
[ 4.345263] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.345581] tegra-se-nvhost 15820000.se: initialized
[ 4.346443] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.346766] tegra-se-nvhost 15830000.se: initialized
[ 4.346909] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.347197] tegra-se-nvhost 15840000.se: initialized
[ 4.347627] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.351752] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.355045] cpufreq: platform driver Initialization: pass
[ 4.355196] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[ 4.355247] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.355420] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.355425] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.355463] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2aa894
[ 4.355466] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 4.357696] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.359687] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.359796] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.360690] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.360693] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.363327] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.363852] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.364069] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.364367] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.364611] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.364906] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.364909] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.364910] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.375498] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.375498] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.375638] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.376143] OPE platform probe
[ 4.376216] OPE platform probe successful
[ 4.381670] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 4.381980] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.382173] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.382212] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 4.382505] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 4.382533] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 4.382752] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.422039] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 4.422072] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.428029] mmc0: MAN_BKOPS_EN bit is not set
[ 4.435308] mmc0: Skipping tuning since strobe enabled
[ 4.437906] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.438089] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.438272] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.438439] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.438534] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.438651] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.438744] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.438836] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.438933] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.439025] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.439121] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.439250] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.439347] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.439441] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.439535] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.439653] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.439750] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.439842] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.439937] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.440064] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.442799] mmc0: periodic cache flush enabled
[ 4.442806] mmc0: new HS400 MMC card at address 0001
[ 4.443105] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 4.443202] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 4.443292] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 4.443375] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 4.444345] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.444461] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.444491] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.444516] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.444533] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 4.482657] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 4.484050] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.484785] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 4.484788] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.485487] GACT probability NOT on
[ 4.485497] Mirror/redirect action on
[ 4.485508] u32 classifier
[ 4.485509] Actions configured
[ 4.485530] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.486226] ipip: IPv4 over IPv4 tunneling driver
[ 4.486535] Initializing XFRM netlink socket
[ 4.486872] NET: Registered protocol family 10
[ 4.487587] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.487646] NET: Registered protocol family 17
[ 4.487658] NET: Registered protocol family 15
[ 4.487680] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.487685] 8021q: 802.1Q VLAN Support v1.8
[ 4.488451] Registered cp15_barrier emulation handler
[ 4.488467] Registered setend emulation handler
[ 4.489936] registered taskstats version 1
[ 4.493883] isp 15600000.isp: initialized
[ 4.498234] nvcsi 150c0000.nvcsi: initialized
[ 4.499631] Wake76 for irq=199
[ 4.499632] Wake77 for irq=199
[ 4.499633] Wake78 for irq=199
[ 4.499634] Wake79 for irq=199
[ 4.499634] Wake80 for irq=199
[ 4.499635] Wake81 for irq=199
[ 4.499636] Wake82 for irq=199
[ 4.500037] xhci-tegra 3530000.xhci: No UTMI port has OTG_CAP
[ 4.500039] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.501576] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.501721] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.501723] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.502251] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.502892] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.503377] tegra-xotg xotg: usb2 phy doesn't have OTG capability
[ 4.503397] tegra-xotg: probe of xotg failed with error -22
[ 4.582005] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 4.582007] tegra-usb-cd usb_cd: set current 0ma
[ 4.582012] tegra-xudc-new 3550000.xudc: device mode on
[ 4.582601] dhd_module_init in
[ 4.582631] tegra_net_perf_init: cannot get wifi sclk
[ 4.582691] found wifi platform device bcmdhd_wlan
[ 4.584003] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 4.584012] wifi_platform_get_country_code_map: could not get country_code_map
[ 4.584014] wifi_plat_dev_drv_probe:platform country code map is not available
[ 4.584030] Power-up adapter 'DHD generic adapter'
[ 4.584042] wifi_platform_set_power = 1
[ 4.681433] mmc1 tuning done saved tap delay=67
[ 4.681435] mmc1: hw tuning done ...
[ 4.681443] mmc1: tuning_window[0]: 0xffffffff
[ 4.681447] mmc1: tuning_window[1]: 0xffffc7ff
[ 4.681452] mmc1: tuning_window[2]: 0xe3ffffff
[ 4.681456] mmc1: tuning_window[3]: 0x7fffffff
[ 4.681460] mmc1: tuning_window[4]: 0x0
[ 4.681464] mmc1: tuning_window[5]: 0x0
[ 4.681469] mmc1: tuning_window[6]: 0x0
[ 4.681493] mmc1: tuning_window[7]: 0x0
[ 4.681496] sdhci: Tap value: 67 | Trim value: 5
[ 4.681499] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.688704] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.688758] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.694794] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 4.696812] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 4.697008] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 4.697011] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[ 4.697014] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[ 4.697016] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.697018] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 4.697042] pci 0000:00:02.0: [10de:10e6] type 01 class 0x060400
[ 4.697134] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 4.697272] iommu: Adding device 0000:00:02.0 to group 55
[ 4.697338] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[ 4.697426] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 4.697537] iommu: Adding device 0000:00:03.0 to group 56
[ 4.697571] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.697581] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.697708] pci 0000:01:00.0: [8086:10d3] type 00 class 0x020000
[ 4.697772] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 4.697786] pci 0000:01:00.0: reg 0x14: [mem 0x00000000-0x000fffff]
[ 4.697801] pci 0000:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 4.697815] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 4.697931] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 4.698067] iommu: Adding device 0000:01:00.0 to group 57
[ 4.698096] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.698206] pci 0000:02:00.0: [8086:10d3] type 00 class 0x020000
[ 4.698269] pci 0000:02:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 4.698284] pci 0000:02:00.0: reg 0x14: [mem 0x00000000-0x000fffff]
[ 4.698298] pci 0000:02:00.0: reg 0x18: [io 0x0000-0x001f]
[ 4.698312] pci 0000:02:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 4.698428] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 4.698553] iommu: Adding device 0000:02:00.0 to group 58
[ 4.698581] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 4.698588] PCIE: ASPM not enabled
[ 4.698629] pci 0000:00:02.0: BAR 8: assigned [mem 0x50100000-0x502fffff]
[ 4.698632] pci 0000:00:03.0: BAR 8: assigned [mem 0x50300000-0x504fffff]
[ 4.698634] pci 0000:00:02.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 4.698636] pci 0000:00:03.0: BAR 7: assigned [io 0x2000-0x2fff]
[ 4.698640] pci 0000:01:00.0: BAR 1: assigned [mem 0x50100000-0x501fffff]
[ 4.698647] pci 0000:01:00.0: BAR 0: assigned [mem 0x50200000-0x5021ffff]
[ 4.698654] pci 0000:01:00.0: BAR 3: assigned [mem 0x50220000-0x50223fff]
[ 4.698661] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 4.698669] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 4.698672] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 4.698678] pci 0000:00:02.0: bridge window [mem 0x50100000-0x502fffff]
[ 4.698688] pci 0000:02:00.0: BAR 1: assigned [mem 0x50300000-0x503fffff]
[ 4.698695] pci 0000:02:00.0: BAR 0: assigned [mem 0x50400000-0x5041ffff]
[ 4.698702] pci 0000:02:00.0: BAR 3: assigned [mem 0x50420000-0x50423fff]
[ 4.698709] pci 0000:02:00.0: BAR 2: assigned [io 0x2000-0x201f]
[ 4.698716] pci 0000:00:03.0: PCI bridge to [bus 02]
[ 4.698718] pci 0000:00:03.0: bridge window [io 0x2000-0x2fff]
[ 4.698724] pci 0000:00:03.0: bridge window [mem 0x50300000-0x504fffff]
[ 4.698847] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 4.698849] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 4.698854] pcie_pme 0000:00:02.0:pcie01: service driver pcie_pme loaded
[ 4.698919] aer 0000:00:02.0:pcie02: service driver aer loaded
[ 4.699057] pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
[ 4.699059] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 4.699063] pcie_pme 0000:00:03.0:pcie01: service driver pcie_pme loaded
[ 4.699135] aer 0000:00:03.0:pcie02: service driver aer loaded
[ 4.785992] wifi_platform_bus_enumerate device present 1
[ 4.803841] wifi_platform_bus_enumerate device present 0
[ 4.804298] F1 signature read @0x18000000=0x17214354
[ 4.808540] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 4.809153] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 4.809217] wifi_platform_prealloc: failed to alloc static mem section 7
[ 4.809222] wifi_platform_get_mac_addr
[ 4.809328] firmware path not found
[ 4.809368] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 4.809550] wl_create_event_handler(): thread:wl_event_handler:102 started
[ 4.809554] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc07b121a70
[ 4.809640] dhd_attach(): thread:dhd_watchdog_thread:103 started
[ 4.809672] dhd_attach(): thread:dhd_dpc:104 started
[ 4.809704] dhd_attach(): thread:dhd_rxf:105 started
[ 4.809708] dhd_deferred_work_init: work queue initialized
[ 4.809920] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Jan 27 2018 at 12:51:05
[ 4.810174] tegra_sysfs_register
[ 4.810196] Register interface [wlan0] MAC: 00:04:4b:8d:6a:9a
[ 4.810198] dhd_prot_ioctl : bus is down. we have nothing to do
[ 4.810296] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 67
[ 4.811335] wifi_platform_set_power = 0
[ 5.014556] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 5.014611] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 5.014658] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 5.014751] input: gpio-keys as /devices/gpio-keys/input/input3
[ 5.048188] tegra_rtc c2a0000.rtc: setting system clock to 2018-02-25 06:00:38 UTC (1519538438)
[ 5.078238] bpmp: mounted debugfs mirror
[ 5.078716] [dram-timers] DRAM derating cdev registered.
[ 5.082640] spmic-ldo0: disabling
[ 5.082833] spmic-ldo1: disabling
[ 5.083006] en-vdd-sd: disabling
[ 5.083009] vdd-usb0-5v: disabling
[ 5.083010] vdd-usb1-5v: disabling
[ 5.083013] en-vdd-disp-3v3: disabling
[ 5.083014] en-mdm-pwr-3v7: disabling
[ 5.083016] en-vdd-disp-1v8: disabling
[ 5.083017] en-vdd-cam-hv-2v8: disabling
[ 5.083018] vdd-fan: disabling
[ 5.083019] vdd-3v3: disabling
[ 5.083021] en-vdd-vcm-2v8: disabling
[ 5.083022] vdd-usb2-5v: disabling
[ 5.083024] vdd-sys-bl: disabling
[ 5.089051] ALSA device list:
[ 5.089054] #0: tegra-hda at 0x3518000 irq 400
[ 5.089055] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.090330] tegra-vi4 15700000.vi: initialized
[ 7.917990] random: nonblocking pool is initialized
[ 13.341217] tegradc 15210000.nvdisplay: hdmi: plugged
[ 13.346045] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.346056] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 13.347664] devtmpfs: mounted
[ 13.347979] Freeing unused kernel memory: 1188K (ffffffc001305000 - ffffffc00142e000)
[ 13.348001] Freeing alternatives memory: 100K (ffffffc00142e000 - ffffffc001447000)
[ 13.409512] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 13.429860] systemd[1]: Detected architecture arm64.
[ 13.447353] systemd[1]: Set hostname t
