Hello, I refer to TX2 jetpack4.4 and TX1 jetpack 3.3 how to modify usb3.0. It is found that usb3 0 port 2 cannot be found in TX1. It has been tested for two days and no solution can be found. Please help me, thank you. Use config#4
tegra210-jetson-cv-base-p2597-2180-a00.dts (29.0 KB)
The log:
tx1@localhost:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3456) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:25:44 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem2: 00140000@92cb1000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fef08000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem2=0x140000@0x92cb1000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29300(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568056K/4159488K available (15294K kernel code, 2934K rwdata, 6640K rodata, 8576K init, 609K bss, 116296K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a13d808 - 0xffffff800a1d5f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000004] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.002034] Console: colour dummy device 80x25
[ 0.002045] console [tty0] enabled
[ 0.002053] kmemleak: Kernel memory leak detector disabled
[ 0.002065] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002075] pid_max: default: 32768 minimum: 301
[ 0.002478] Security Framework initialized
[ 0.002683] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002690] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003464] ftrace: allocating 47104 entries in 185 pages
[ 0.160330] sched-energy: CPU device node has no sched-energy-costs
[ 0.160344] ASID allocator initialised with 65536 entries
[ 0.198322] tegra-id: chipid=22117.
[ 0.198329] tegra-id: opt_subrevision=0.
[ 0.198343] Tegra Speedo/IDDQ fuse revision 4
[ 0.198348] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.198352] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.198357] Tegra: CPU Speedo Value 2014, SoC Speedo Value 1913, GPU Speedo Value 2011
[ 0.198360] Tegra: CPU IDDQ Value 1548, SoC IDDQ Value 1772, GPU IDDQ Value 2095
[ 0.198375] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 0
[ 0.198385] DTS File Name: /home/greetrix/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX1/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.198391] DTB Build time: Jan 16 2022 18:35:36
[ 0.248622] CPU1: Booted secondary processor [411fd071]
[ 0.280595] CPU2: Booted secondary processor [411fd071]
[ 0.312585] CPU3: Booted secondary processor [411fd071]
[ 0.312655] Brought up 4 CPUs
[ 0.312660] SMP: Total of 4 processors activated.
[ 0.312666] CPU features: detected feature: 32-bit EL0 Support
[ 0.312892] CPU: All CPU(s) started at EL2
[ 0.312906] alternatives: patching kernel code
[ 0.318003] devtmpfs: initialized
[ 0.369100] Initilizing CustomIPI irq domain
[ 0.369342] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369354] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.375239] pinctrl core: initialized pinctrl subsystem
[ 0.375495] OS set in device tree is not L4T.
[ 0.375714] regulator-dummy: no parameters
[ 0.375896] Initializing plugin-manager
[ 0.375967] Plugin module not found
[ 0.377251] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[ 0.378402] node /plugin-manager/fragement@5 match with odm-data enable-tegra-wdt
[ 0.378862] node /plugin-manager/fragement@7 match with odm-data enable-tegra-wdt
[ 0.381105] NET: Registered protocol family 16
[ 0.382176] pstore: using zlib compression
[ 0.382193] console [pstore-1] enabled
[ 0.382197] pstore: Registered ramoops as persistent store backend
[ 0.382202] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.400184] cpuidle: using governor menu
[ 0.403818] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.405699] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.405712] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.407824] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.410527] Serial: AMBA PL011 UART driver
[ 0.410947] tegra_powergate_init: DONE
[ 0.410957] DTS File Name: /home/greetrix/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX1/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.410963] DTB Build time: Jan 16 2022 18:35:36
[ 0.412886] Tegra reboot handler registered.
[ 0.416634] iommu: Adding device tegra-carveouts to group 0
[ 0.416697] platform tegra-carveouts: domain=ffffffc0f91ac018 allocates as[0]=ffffffc0f913c0a8
[ 0.416945] iommu: Adding device smmu_test to group 1
[ 0.416985] platform smmu_test: domain=ffffffc0f91ac258 allocates as[0]=ffffffc0f913c110
[ 0.417626] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.417675] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.417726] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.417734] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.417744] mc-err: mcerr ops are set to t21x
[ 0.426836] iommu: Adding device 70090000.xusb to group 2
[ 0.427084] iommu: Adding device 70006000.serial to group 3
[ 0.427131] platform 70006000.serial: domain=ffffffc0f921b798 allocates as[0]=ffffffc0f913c178
[ 0.427462] iommu: Adding device 70006040.serial to group 4
[ 0.427695] iommu: Adding device 70006200.serial to group 5
[ 0.427939] iommu: Adding device 70006300.serial to group 6
[ 0.428103] iommu: Adding device sound to group 7
[ 0.428137] platform sound: domain=ffffffc0f921be58 allocates as[0]=ffffffc0f913c1e0
[ 0.428587] iommu: Adding device 7000d400.spi to group 8
[ 0.428878] iommu: Adding device 7000da00.spi to group 9
[ 0.429167] iommu: Adding device 50000000.host1x to group 10
[ 0.429422] iommu: Adding device 54080000.vi to group 11
[ 0.429785] iommu: Adding device 54600000.isp to group 12
[ 0.430033] iommu: Adding device 54680000.isp to group 13
[ 0.430297] iommu: Adding device tegradc.1 to group 14
[ 0.430333] platform tegradc.1: domain=ffffffc0f9234c18 allocates as[0]=ffffffc0f913c248
[ 0.431444] platform tegradc.1: IOVA linear map 0x0000000092cb1000(140000)
[ 0.431770] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.431967] iommu: Adding device 54340000.vic to group 15
[ 0.432148] iommu: Adding device 544c0000.nvenc to group 16
[ 0.432334] iommu: Adding device 54500000.tsec to group 17
[ 0.432515] iommu: Adding device 54100000.tsecb to group 18
[ 0.432721] iommu: Adding device 54480000.nvdec to group 19
[ 0.432898] iommu: Adding device 54380000.nvjpg to group 20
[ 0.433546] iommu: Adding device 546c0000.i2c to group 21
[ 0.433871] iommu: Adding device 57000000.gpu to group 22
[ 0.433907] platform 57000000.gpu: domain=ffffffc0f9241a98 allocates as[0]=ffffffc0f913c2b0
[ 0.433934] platform 57000000.gpu: domain=ffffffc0f9241a98 allocates as[1]=ffffffc0f913c318
[ 0.433961] platform 57000000.gpu: domain=ffffffc0f9241a98 allocates as[2]=ffffffc0f913c380
[ 0.433988] platform 57000000.gpu: domain=ffffffc0f9241a98 allocates as[3]=ffffffc0f913c3e8
[ 0.434563] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.434572] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.434582] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.434586] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.434589] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.488759] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.488765] tegra-pmc: Clear bootloader IO dpd settings
[ 0.488782] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.488827] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.489070] iommu: Adding device 70012000.se to group 23
[ 0.489575] iommu: Adding device 1003000.pcie to group 24
[ 0.489616] platform 1003000.pcie: domain=ffffffc0f92c1258 allocates as[0]=ffffffc0f913c450
[ 0.489936] iommu: Adding device 7000c000.i2c to group 25
[ 0.490168] iommu: Adding device 7000c400.i2c to group 26
[ 0.490404] iommu: Adding device 7000c500.i2c to group 27
[ 0.490636] iommu: Adding device 7000c700.i2c to group 28
[ 0.490881] iommu: Adding device 7000d000.i2c to group 29
[ 0.491112] iommu: Adding device 7000d100.i2c to group 30
[ 0.491353] iommu: Adding device sdhci-tegra.3 to group 31
[ 0.491388] platform sdhci-tegra.3: domain=ffffffc0f92c1d98 allocates as[0]=ffffffc0f913c4b8
[ 0.491896] iommu: Adding device sdhci-tegra.0 to group 32
[ 0.491932] platform sdhci-tegra.0: domain=ffffffc0f92cd0d8 allocates as[0]=ffffffc0f913c520
[ 0.492576] iommu: Adding device 700d0000.xudc to group 33
[ 0.495044] iommu: Adding device 70027000.sata to group 34
[ 0.497392] vdd-ac-bat: 5000 mV
[ 0.498386] vdd-cpu-fixed: 1000 mV
[ 0.529190] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.530982] GPIO line 58 (wlan-default-input) hogged as input
[ 0.531002] GPIO line 65 (wlan-default-input) hogged as input
[ 0.531026] GPIO line 56 (wlan-default-output-high) hogged as output/high
[ 0.531045] GPIO line 64 (wlan-default-output-high) hogged as output/high
[ 0.531065] GPIO line 66 (wlan-default-output-high) hogged as output/high
[ 0.531086] GPIO line 148 (camera-control-output-low) hogged as output/low
[ 0.531105] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.531123] GPIO line 149 (camera-control-output-low) hogged as output/low
[ 0.531141] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.531376] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.537919] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.538169] SCSI subsystem initialized
[ 0.538313] libata version 3.00 loaded.
[ 0.538504] usbcore: registered new interface driver usbfs
[ 0.538547] usbcore: registered new interface driver hub
[ 0.538612] usbcore: registered new device driver usb
[ 0.542212] gpiochip_setup_dev: registered GPIOs 496 to 511 on device: gpiochip1 (tca9539)
[ 0.543726] tegra-i2c 7000c400.i2c: no acknowledge from address 0x77
[ 0.543763] pca953x 1-0077: failed reading register
[ 0.543833] pca953x: probe of 1-0077 failed with error -121
[ 0.545775] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[ 0.547534] random: fast init done
[ 0.548727] vdd-core: 600 <--> 1400 mV at 1125 mV
[ 0.552764] vddio-ddr: at 1125 mV
[ 0.553478] vdd-pre-reg: 1350 mV
[ 0.556633] vdd-1v8: 1800 mV
[ 0.560623] avdd-sys: 1200 mV
[ 0.564611] vdd-pex: 1050 mV
[ 0.565116] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.565715] vdd-cam-hv: Bringing 3100000uV into 2800000-2800000uV
[ 0.565819] vdd-cam-hv: 2800 mV
[ 0.566432] vdd-rtc: Bringing 1000000uV into 850000-850000uV
[ 0.568612] vdd-rtc: 850 mV
[ 0.569242] avdd-ts-hv: Bringing 3100000uV into 3300000-3300000uV
[ 0.569342] avdd-ts-hv: 3300 mV
[ 0.569994] vdd-ts: Bringing 2800000uV into 1800000-1800000uV
[ 0.570103] vdd-ts: 1800 mV
[ 0.572616] vdd-gen-pll-edp: 1050 mV
[ 0.576611] vdd-hdmi-dp: 1050 mV
[ 0.578981] GPIO line 490 (spmic-default-output-high) hogged as output/high
[ 0.579168] gpiochip_setup_dev: registered GPIOs 488 to 495 on device: gpiochip2 (max77620-gpio)
[ 0.579404] max77620 4-003c: max77620 probe successful
[ 0.581319] media: Linux media interface: v0.10
[ 0.581356] Linux video capture interface: v2.00
[ 0.582105] pps_core: LinuxPPS API ver. 1 registered
[ 0.582108] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.582126] PTP clock support registered
[ 0.587035] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.587601] Advanced Linux Sound Architecture Driver Initialized.
[ 0.588033] Bluetooth: Core ver 2.22
[ 0.588067] NET: Registered protocol family 31
[ 0.588071] Bluetooth: HCI device and connection manager initialized
[ 0.588079] Bluetooth: HCI socket layer initialized
[ 0.588086] Bluetooth: L2CAP socket layer initialized
[ 0.588104] Bluetooth: SCO socket layer initialized
[ 0.589431] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.589446] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.589489] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.589503] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.592125] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.596620] vdd-3v3: 3300 mV
[ 0.597765] max77620-gpio7: supplied by vdd-gen-pll-edp
[ 0.600612] max77620-gpio7: 1050 mV
[ 0.600957] lcd-bl-en: 1800 mV
[ 0.601373] en-vdd-sd: supplied by vdd-3v3
[ 0.601398] en-vdd-sd: 3300 mV
[ 0.604617] vdd-sys-boost: 5000 mV
[ 0.605734] vdd-hdmi: 5000 mV
[ 0.606027] aux-3v3: 3300 mV
[ 0.606318] snsr_pm: 3300 mV
[ 0.608613] vdd-disp-3v0: 3000 mV
[ 0.609751] vdd-fan: 5000 mV
[ 0.610169] usb-vbus1: supplied by vdd-3v3
[ 0.610193] usb-vbus1: 5000 mV
[ 0.611327] en-vdd-ts-1v8: 1800 mV
[ 0.612481] en-vdd-ts-hv-3v3: 3300 mV
[ 0.614036] en-vdd-disp-3v3: 3300 mV
[ 0.615182] en-mdm-pwr-3v7: 3700 mV
[ 0.616723] en-vdd-disp-1v8: 1800 mV
[ 0.617886] en-vdd-cam-hv-2v8: 2800 mV
[ 0.618298] rtl-5v0: 5000 mV
[ 0.618709] en-usb-vbus2: 5000 mV
[ 0.619249] en-vdd-vcm-2v8: supplied by vdd-3v3
[ 0.619272] en-vdd-vcm-2v8: 2800 mV
[ 0.620433] camchar: rtcpu character device driver loaded
[ 0.622438] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.623653] clocksource: Switched to clocksource arch_sys_counter
[ 0.653962] VFS: Disk quotas dquot_6.6.0
[ 0.654054] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.654374] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.654586] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.654596] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.654710] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.654715] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.654723] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.654749] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.654754] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.654763] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.654769] nvmap_page_pool_init: Total RAM pages: 1010798
[ 0.654773] nvmap_page_pool_init: nvmap page pool size: 126349 pages (493 MB)
[ 0.654828] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.655086] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.655768] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.661960] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.663455] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.663768] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.663896] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.665054] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 0.665229] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 0.665425] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.665574] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.665578] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.665952] NET: Registered protocol family 2
[ 0.666734] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.666940] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.667332] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.667395] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.667473] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.667825] NET: Registered protocol family 1
[ 0.668327] RPC: Registered named UNIX socket transport module.
[ 0.668331] RPC: Registered udp transport module.
[ 0.668334] RPC: Registered tcp transport module.
[ 0.668337] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.668345] PCI: CLS 0 bytes, default 64
[ 0.668490] Trying to unpack rootfs image as initramfs...
[ 0.882549] Freeing initrd memory: 5356K
[ 0.890477] host1x 50000000.host1x: initialized
[ 0.891902] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.894461] audit: initializing netlink subsys (disabled)
[ 0.894504] audit: type=2000 audit(0.755:1): initialized
[ 0.895056] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.903768] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.905018] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.905680] 9p: Installing v9fs 9p2000 file system support
[ 0.908511] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.908597] io scheduler noop registered
[ 0.908861] io scheduler cfq registered (default)
[ 0.910756] gic 702f9000.agic: GIC IRQ controller registered
[ 0.913477] iommu: Adding device 702ef000.adsp to group 35
[ 0.921668] iommu: Adding device aconnect@702c0000:adsp_audio to group 36
[ 0.921805] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.922236] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7208c10
[ 0.922243] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.923485] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.923573] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.923680] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.923764] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.3, lane = usb2-3, function = xusb
[ 0.923926] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-hsic.4, lane = hsic-0, function = xusb
[ 0.924075] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-0, function = pcie-x4
[ 0.924161] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = xusb
[ 0.924245] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x1
[ 0.924327] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.924413] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.924549] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-sata.10, lane = sata-0, function = sata
[ 0.930596] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.931915] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.933476] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.933488] tegra-pcie 1003000.pcie: failed to get PHY: -19
[ 0.933513] tegra-pcie 1003000.pcie: failed to get PHYs: -19
[ 0.934621] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.934760] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1020000, vi_iso_bw=750000, max_bw=1020000
[ 0.934957] Adding domain tsec-pd to PM domain host1x-pd
[ 0.937318] tsec 54500000.tsec: initialized
[ 0.938374] tsec 54100000.tsecb: initialized
[ 0.938992] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.941881] nvdec 54480000.nvdec: initialized
[ 0.942915] Adding domain vic03-pd to PM domain host1x-pd
[ 0.943089] Adding domain msenc-pd to PM domain host1x-pd
[ 0.943245] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.947448] falcon 54340000.vic: initialized
[ 0.948575] falcon 544c0000.nvenc: initialized
[ 0.949783] falcon 54380000.nvjpg: initialized
[ 0.954132] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 0.954178] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 0.954199] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 0.954298] tegradc tegradc.1: disp0 connected to head1->/host1x/sor1
[ 0.954369] display board info: id 0xffff, fab 0x0
[ 0.954419] generic_infoframe_type: 0x87
[ 0.954523] tegradc tegradc.1: DT parsed successfully
[ 0.954553] tegradc tegradc.1: Display dc.ffffff800ab80000 registered with id=0
[ 0.955031] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 0.955036] tegra_cec 70015000.tegra_cec: probed
[ 0.955934] tegradc tegradc.1: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[ 0.961035] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.962805] tegradc tegradc.1: probed
[ 0.966039] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 0.966693] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 0.966698] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.966974] kfuse 7000fc00.kfuse: initialized
[ 0.968697] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.969516] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.969524] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 0.969912] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.971094] vdd-gpu: applied init 1000000uV constraint
[ 0.971100] vdd-gpu: 710 <--> 1320 mV at 1002 mV
[ 0.971483] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.974501] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.974570] No Device Node present for smmu client: serial8250 !!
[ 0.974577] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.974603] iommu: Adding device serial8250 to group 37
[ 0.975321] Console: switching to colour frame buffer device 80x30
[ 0.975349] tegradc tegradc.1: fb registered
[ 0.976485] console [ttyS0] disabled
[ 0.976537] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 0.981630] tegradc tegradc.1: DC initialized, skipping tegra_dc_program_mode.
[ 0.981656] tegradc tegradc.1: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[ 0.982036] tegradc tegradc.1: hdmi: get RGB quant from REG programmed by BL.
[ 0.982046] tegradc tegradc.1: hdmi: BL set VIC 0
[ 0.982049] tegradc tegradc.1: hdmi: get YCC quant from REG programmed by BL.
[ 0.992708] console [ttyS0] enabled
[ 0.993602] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 0.993916] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 0.994123] serial-tegra 70006300.serial: RX in PIO mode
[ 0.994208] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 66, base_baud = 0) is a TEGRA_UART
[ 0.995096] [drm] Initialized
[ 1.003067] brd: module loaded
[ 1.007281] loop: module loaded
[ 1.007356] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.007448] tegra_profiler: auth: init
[ 1.007785] nct1008_nct72 0-004c: starting parse dt
[ 1.007869] nct1008_nct72 0-004c: !!!Found deprecated property!!!
[ 1.007876] nct1008_nct72 0-004c: success parsing dt
[ 1.008098] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[ 1.008390] THERMAL EST: found 2 subdevs
[ 1.008395] THERMAL EST num_resources: 0
[ 1.008400] [THERMAL EST subdev 0]
[ 1.008406] [THERMAL EST subdev 1]
[ 1.008735] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.008738] THERMAL EST: thz register success.
[ 1.008846] THERMAL EST: end of probe, return err: 0
[ 1.009570] sd: No Scsi addr parsed to reserve index
[ 1.009597] hisi_sas: driver version v1.6
[ 1.010631] tegra-ahci 70027000.sata: Missing devslp-active state
[ 1.012587] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.012596] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.013572] scsi host0: tegra_ahci
[ 1.014071] scsi host1: tegra_ahci
[ 1.014263] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 99
[ 1.014267] ata2: DUMMY
[ 1.018000] libphy: Fixed MDIO Bus: probed
[ 1.018704] tun: Universal TUN/TAP device driver, 1.6
[ 1.018707] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.019446] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.019449] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.019489] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.019492] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.019530] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.019533] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.019574] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.019577] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.020647] PPP generic driver version 2.4.2
[ 1.020788] PPP BSD Compression module registered
[ 1.020792] PPP Deflate Compression module registered
[ 1.020810] PPP MPPE Compression module registered
[ 1.020814] NET: Registered protocol family 24
[ 1.020862] usbcore: registered new interface driver r8152
[ 1.020902] usbcore: registered new interface driver asix
[ 1.020937] usbcore: registered new interface driver ax88179_178a
[ 1.020972] usbcore: registered new interface driver cdc_ether
[ 1.021006] usbcore: registered new interface driver net1080
[ 1.021038] usbcore: registered new interface driver cdc_subset
[ 1.021073] usbcore: registered new interface driver zaurus
[ 1.021118] usbcore: registered new interface driver cdc_ncm
[ 1.021248] VFIO - User Level meta-driver version: 0.3
[ 1.022250] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.022263] ehci-pci: EHCI PCI platform driver
[ 1.022304] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.022312] ohci-pci: OHCI PCI platform driver
[ 1.022347] ohci-platform: OHCI generic platform driver
[ 1.024821] tegra-xusb-padctl 7009f000.xusb_padctl: no port found for USB3 lane 2
[ 1.032493] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.033484] tegra-xusb-padctl 7009f000.xusb_padctl: no port found for USB3 lane 2
[ 1.039803] nct1008_nct72 0-004c: LOC shutdown limit 120
[ 1.040270] nct1008_nct72 0-004c: EXT shutdown limit 105
[ 1.041299] phy phy-pcie.6: phy init failed --> -19
[ 1.047370] tegra-xusb 70090000.xusb: failed to enable PHYs: -19
[ 1.054153] usbcore: registered new interface driver uas
[ 1.054202] usbcore: registered new interface driver usb-storage
[ 1.054278] usbcore: registered new interface driver usbserial
[ 1.057595] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.057884] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.058725] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.058735] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.072963] nct1008_nct72 0-004c: initial LOC temp: 26000
[ 1.073256] nct1008_nct72 0-004c: initial EXT temp: 28500
[ 1.073830] nct1008_nct72 0-004c: hi_b:0, lo_b:0
[ 1.074300] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 1.223675] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 0
[ 1.223728] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 1.223733] tegra-usb-cd usb_cd: connected to SDP
[ 1.224202] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.224215] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.224237] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.224855] mousedev: PS/2 mouse device common for all mice
[ 1.224920] usbcore: registered new interface driver xpad
[ 1.326048] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.340784] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.342901] rtc rtc1: alarm rtc device
[ 1.342915] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.342933] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.343360] i2c /dev entries driver
[ 1.345248] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.347352] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.347358] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.347725] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.347753] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.347761] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.347916] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.347926] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.347934] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.348112] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.348117] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[ 1.348125] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.348130] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.348414] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.349027] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.349083] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.349091] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.349100] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.349957] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.350448] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.350871] parse_throttle_dt_data: Num cap clks = 6
[ 1.350877] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.350885] parse_throttle_dt_data: clk=gpu type=4
[ 1.350913] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.350939] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.350968] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.350972] parse_throttle_dt_data: clk=emc type=3
[ 1.351364] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.351472] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.352213] FAN dev name: pwm-fan
[ 1.352268] FAN:gpio request success.
[ 1.352323] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.352560] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.352676] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.352683] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.352755] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.352761] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.352766] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.352771] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.352777] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.352781] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.352786] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.352791] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.352796] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.352801] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.353361] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.353594] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.354356] device-mapper: uevent: version 1.0.3
[ 1.354744] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.360538] tegra210-cpufreq cpufreq: probe()...completed
[ 1.361298] sdhci: Secure Digital Host Controller Interface driver
[ 1.361301] sdhci: Copyright(c) Pierre Ossman
[ 1.361303] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.361623] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.365843] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[ 1.371437] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.371466] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[ 1.371855] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.374386] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.374880] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.376150] usbcore: registered new interface driver usbhid
[ 1.376153] usbhid: USB HID core driver
[ 1.381800] tegra-i2c 7000c400.i2c: no acknowledge from address 0x42
[ 1.381833] ina3221x 1-0042: ina3221 reset failure status: 0xffffff87
[ 1.388537] ina3221x: probe of 1-0042 failed with error -121
[ 1.388957] tegra-i2c 7000c400.i2c: no acknowledge from address 0x43
[ 1.388987] ina3221x 1-0043: ina3221 reset failure status: 0xffffff87
[ 1.395570] ina3221x: probe of 1-0043 failed with error -121
[ 1.396534] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.396740] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.398584] nvpmodel: initialized successfully
[ 1.399722] usbcore: registered new interface driver snd-usb-audio
[ 1.399777] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.399781] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.399799] iommu: Adding device snd-soc-dummy to group 38
[ 1.403687] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 1.405036] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.407672] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[ 1.413768] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 1.414772] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 1.415103] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 1.415477] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 1.422589] OPE platform probe
[ 1.422660] OPE platform probe successful
[ 1.422908] OPE platform probe
[ 1.422971] OPE platform probe successful
[ 1.423799] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.445362] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.445504] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.445620] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.445732] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.445869] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.445980] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.446092] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.446223] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.446337] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.446448] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.458131] u32 classifier
[ 1.458134] Actions configured
[ 1.458198] Initializing XFRM netlink socket
[ 1.458801] NET: Registered protocol family 10
[ 1.459392] NET: Registered protocol family 17
[ 1.459403] NET: Registered protocol family 15
[ 1.459467] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.459509] Bluetooth: RFCOMM socket layer initialized
[ 1.459517] Bluetooth: RFCOMM ver 1.11
[ 1.459521] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.459525] Bluetooth: HIDP socket layer initialized
[ 1.459541] 9pnet: Installing 9P2000 support
[ 1.459573] Key type dns_resolver registered
[ 1.459952] Registered cp15_barrier emulation handler
[ 1.459959] Registered setend emulation handler
[ 1.460893] registered taskstats version 1
[ 1.461526] Adding domain ve2-pd to PM domain host1x-pd
[ 1.461779] Adding domain ve-pd to PM domain host1x-pd
[ 1.474850] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.479194] mmcblk0: mmc0:0001 016G32 14.7 GiB
[ 1.479301] mmcblk0boot0: mmc0:0001 016G32 partition 1 4.00 MiB
[ 1.483530] mmcblk0boot1: mmc0:0001 016G32 partition 2 4.00 MiB
[ 1.487734] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 1.489406] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[ 1.645681] mmc1: hw tuning done ...
[ 1.649070] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 1.959717] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 1.959720] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 11.111716] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 11.118166] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 11.124874] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 11.130012] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.136708] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 11.142277] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.148106] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 11.153327] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 11.158663] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 11.165212] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 11.165215] Extcon AUX1(HDMI) enable
[ 11.166512] isp 54600000.isp: initialized
[ 11.167276] isp 54680000.isp: initialized
[ 11.176830] last reset is due to power on reset
[ 11.176834] KERNEL: PMC reset status reg: 0x0
[ 11.176910] BL: PMC reset status reg: 0x0
[ 11.176912] BL: PMIC poweroff Event Recorder: 0x4
[ 11.176992] edid invalid
[ 11.178504] clk_cbus_recalc_rate: no gbus parent
[ 11.178509] clk_cbus_round_rate: no gbus parent
[ 11.178511] clk_cbus_round_rate: no gbus parent
[ 11.178518] clk_cbus_recalc_rate: no gbus parent
[ 11.178883] clk_cbus_recalc_rate: no gbus parent
[ 11.178886] clk_cbus_round_rate: no gbus parent
[ 11.178888] clk_cbus_round_rate: no gbus parent
[ 11.178891] clk_cbus_recalc_rate: no gbus parent
[ 11.178906] tegra_dvfs: GPU-cap: registered
[ 11.178958] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 11.178961] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 11.178963] tegra dvfs: vdd-gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
[ 11.180756] tegra_dvfs: vdd-gpu-vts: registered
[ 11.182309] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 11.183161] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 11.188253] input: gpio-keys as /devices/gpio-keys/input/input1
[ 11.202624] tegradc tegradc.1: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 11.220649] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:25:59 UTC (946689959)
[ 11.221861] vi 54080000.vi: vi_probe: ++
[ 11.225402] vi 54080000.vi: initialized
[ 11.227368] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@0/endpoint.
[ 11.227372] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@1/endpoint.
[ 11.228315] mmcblk mmc0:0001: Card claimed for testing.
[ 11.230175] Disable partitions left on by BL
[ 11.230179] disb
[ 11.230260] bwmgr: missing cdev-type property
[ 11.230574] DRAM derating cdev registered.
[ 11.231924] vdd-cpu-fixed: disabling
[ 11.231934] vdd-cam-hv: disabling
[ 11.232064] avdd-ts-hv: disabling
[ 11.232178] vdd-ts: disabling
[ 11.232293] max77620-gpio7: disabling
[ 11.232432] lcd-bl-en: disabling
[ 11.232436] en-vdd-sd: disabling
[ 11.232439] aux-3v3: disabling
[ 11.232441] snsr_pm: disabling
[ 11.232443] vdd-disp-3v0: disabling
[ 11.232446] vdd-fan: disabling
[ 11.232448] usb-vbus1: disabling
[ 11.232450] en-vdd-ts-1v8: disabling
[ 11.232452] en-vdd-ts-hv-3v3: disabling
[ 11.232453] en-vdd-disp-3v3: disabling
[ 11.232808] en-mdm-pwr-3v7: disabling
[ 11.232811] en-vdd-disp-1v8: disabling
[ 11.233162] en-vdd-cam-hv-2v8: disabling
[ 11.233165] rtl-5v0: disabling
[ 11.233168] en-usb-vbus2: disabling
[ 11.233171] en-vdd-vcm-2v8: disabling
[ 11.233251] ALSA device list:
[ 11.233254] #0: tegra-hda at 0x70038000 irq 81
[ 11.233256] #1: tegra-snd-t210ref-mobile-rt565x
[ 11.235939] Freeing unused kernel memory: 8576K
[ 11.256868] Root device found: mmcblk0p1
[ 11.257770] Found dev node: /dev/mmcblk0p1
[ 11.493051] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 11.493055] EXT4-fs (mmcblk0p1): recovery complete
[ 11.497876] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.498535] Rootfs mounted over mmcblk0p1
[ 11.510056] Switching from initrd to actual rootfs
[ 11.579674] systemd[1]: System time before build time, advancing clock.
[ 11.591090] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 11.600759] cgroup: cgroup2: unknown option "nsdelegate"
[ 11.612774] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 11.613469] systemd[1]: Detected architecture arm64.
[ 11.631584] systemd[1]: No hostname configured.
[ 11.631596] systemd[1]: Set hostname to <localhost>.
[ 11.706795] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 11.706803] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 11.789139] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.790444] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.790530] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.790629] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.790655] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.790672] systemd[1]: Reached target User and Group Name Lookups.
[ 11.790711] systemd[1]: Reached target Swap.
[ 11.841160] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 11.890930] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 12.135615] systemd-journald[2089]: Received request to flush runtime journal from PID 1
[ 12.700337] using random self ethernet address
[ 12.705204] using random host ethernet address
[ 13.075096] random: crng init done
[ 13.078503] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.232976] Mass Storage Function, version: 2009/09/11
[ 13.232982] LUN: removable file: (no medium)
[ 13.240452] using random self ethernet address
[ 13.245126] using random host ethernet address
[ 13.276189] rndis0: HOST MAC da:44:5a:96:43:f8
[ 13.276431] rndis0: MAC da:44:5a:96:43:f9
[ 13.278858] usb0: HOST MAC da:44:5a:96:43:fa
[ 13.278885] usb0: MAC da:44:5a:96:43:fb
[ 13.278913] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 13.283049] l4tbr0: port 1(rndis0) entered blocking state
[ 13.283054] l4tbr0: port 1(rndis0) entered disabled state
[ 13.283219] device rndis0 entered promiscuous mode
[ 13.301289] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 13.318378] l4tbr0: port 2(usb0) entered blocking state
[ 13.318383] l4tbr0: port 2(usb0) entered disabled state
[ 13.318666] device usb0 entered promiscuous mode
[ 13.326595] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 13.535986] android_work: did not send uevent (0 0 (null))
[ 13.568991] android_work: sent uevent USB_STATE=CONNECTED
[ 13.649898] zram: Added device: zram0
[ 13.652679] zram: Added device: zram1
[ 13.656110] zram: Added device: zram2
[ 13.659448] zram: Added device: zram3
[ 13.683054] configfs-gadget gadget: high-speed config #1: c
[ 13.683088] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 13.683105] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 13.683120] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 13.683222] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 13.683238] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 13.683252] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 13.683288] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 13.683307] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 13.683329] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 13.683386] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 13.683568] android_work: sent uevent USB_STATE=CONFIGURED
[ 13.692534] zram0: detected capacity change from 0 to 519311360
[ 13.749335] Adding 507136k swap on /dev/zram0. Priority:5 extents:1 across:507136k SS
[ 13.752885] zram1: detected capacity change from 0 to 519311360
[ 13.776751] Adding 507136k swap on /dev/zram1. Priority:5 extents:1 across:507136k SS
[ 13.783925] zram2: detected capacity change from 0 to 519311360
[ 13.800431] Adding 507136k swap on /dev/zram2. Priority:5 extents:1 across:507136k SS
[ 13.803900] zram3: detected capacity change from 0 to 519311360
[ 13.816168] Adding 507136k swap on /dev/zram3. Priority:5 extents:1 across:507136k SS
[ 14.378176] dhd_module_init in
[ 14.378242] found wifi platform device bcmdhd_wlan
[ 14.379306] Power-up adapter 'DHD generic adapter'
[ 14.379330] wifi_platform_set_power = 1
[ 14.587689] wifi_platform_bus_enumerate device present 1
[ 14.605808] tegradc tegradc.1: blank - powerdown
[ 14.608902] wifi_platform_bus_enumerate device present 0
[ 14.609594] F1 signature read @0x18000000=0x17214354
[ 14.614009] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 14.614610] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 14.614681] wifi_platform_get_mac_addr
[ 14.616875] ids dhd_log_netlink_init
[ 14.663960] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 14.663962] Extcon AUX1(HDMI) disable
[ 14.684527] tegradc tegradc.1: unblank
[ 14.714431] edid invalid
[ 14.714498] tegradc tegradc.1: nominal-pclk:25174825 parent:25174375 div:1.0 pclk:25174375 24923052~27440532
[ 14.714560] tegradc tegradc.1: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[ 14.716430] tegradc tegradc.1: hdmi: get RGB quant from EDID.
[ 14.716435] tegradc tegradc.1: hdmi: get YCC quant from EDID.
[ 14.781365] wl_create_event_handler(): thread:wl_event_handler:1543 started
[ 14.781539] wl_event_handler :
[ 14.781540] tsk Enter, tsk = 0xffffffc0d7801a90
[ 14.781604] dhd_attach(): thread:dhd_watchdog_thread:1546 started
[ 14.782744] dhd_attach(): thread:dhd_dpc:1547 started
[ 14.784906] dhd_attach(): thread:dhd_rxf:1548 started
[ 14.784912] dhd_deferred_work_init: work queue initialized
[ 14.785234]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 14.789736] Register interface [wlan0] MAC: 00:04:4b:a3:e5:ef
[ 14.789741] dhd_prot_ioctl : bus is down. we have nothing to do
[ 14.789892] sdhci-tegra sdhci-tegra.1: Tuning done, restoring the best tap value : 84
[ 14.790940] wifi_platform_set_power = 0
[ 15.175420] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 15.175551]
Compiled from
[ 15.175559] wl_android_wifi_on in
[ 15.175564] wifi_platform_set_power = 1
[ 15.544077] sdhci-tegra sdhci-tegra.1: Tuning done, restoring the best tap value : 84
[ 15.545692] F1 signature read @0x18000000=0x17214354
[ 15.554582] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 15.555648] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 15.619761] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 15.684351] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 15.685432] wifi_platform_get_mac_addr
[ 15.687481] Firmware up: op_mode=0x0005, MAC=00:04:4b:a3:e5:ef
[ 15.692084] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 15.692130] Skipping the clm download. len:0 memblk: (null)
[ 15.694355] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 15.699230] Firmware version = wl0: Nov 6 2019 21:22:16 version 7.35.349.85 (r723239 CY) FWID 01-ea638cff
[ 15.701543] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 15.798126] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[ 15.798126] P2P interface registered
[ 15.806861] WLC_E_IF: NO_IF set, event Ignored
[ 15.821164] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 21.352649] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 21.352694] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 21.352745] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 21.352782] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.352817] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 21.352852] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.352890] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 21.352925] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 21.353027] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 31.592611] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 31.592658] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 31.592703] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 31.592736] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 31.592771] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 31.592802] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 31.592839] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 31.592872] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 31.592975] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 31.597146] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 31.597178] Extcon AUX1(HDMI) enable
[ 31.715723] tegradc tegradc.1: unblank
[ 32.202664] fuse init (API version 7.26)
[ 34.907264] l4tbr0: port 1(rndis0) entered blocking state
[ 34.907269] l4tbr0: port 1(rndis0) entered forwarding state
[ 34.907524] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 34.907540] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 41.831940] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 41.838607] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 41.846025] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 41.851328] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 41.858127] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 41.863826] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 41.869750] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 41.875009] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 41.880364] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 52.072502] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 52.079322] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 52.086326] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 52.091574] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 52.098350] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 52.104310] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 52.111313] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 52.116946] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 52.122513] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 62.312372] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 62.319202] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 62.326534] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 62.331775] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 62.338562] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 62.344419] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 62.350415] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 62.355711] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 62.361211] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 72.552421] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 72.559230] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 72.566487] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 72.571801] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 72.578592] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 72.584214] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 72.590076] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 72.595307] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 72.600999] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 82.791892] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 82.798861] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 82.805980] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 82.811329] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 82.818142] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 82.823766] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 82.829619] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 82.834854] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 82.840416] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 93.032496] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 93.041008] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 93.055893] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 93.061475] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 93.068387] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 93.074063] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 93.080523] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 93.085917] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 93.091330] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 103.272310] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 103.279094] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 103.286089] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 103.291285] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 103.298082] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 103.304622] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 103.310718] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 103.316338] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 103.321749] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 113.512302] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 113.519092] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 113.529774] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 113.537668] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 113.544795] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 113.550518] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 113.556650] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 113.561983] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 113.567938] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 123.752303] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 123.759100] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 123.766121] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 123.772357] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 123.779317] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 123.785308] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 123.791245] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 123.796889] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 123.802334] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 123.810362] tegradc tegradc.1: hdmi: edid read failed
[ 123.815932] tegradc tegradc.1: hdmi: using fallback edid
[ 123.816112] tegradc tegradc.1: blank - powerdown
[ 123.878415] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 123.878420] Extcon AUX1(HDMI) disable
[ 123.898747] tegradc tegradc.1: unblank
[ 123.908711] tegradc tegradc.1: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 123.908787] tegradc tegradc.1: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[ 123.909791] tegradc tegradc.1: hdmi: get RGB quant from EDID.
[ 123.909796] tegradc tegradc.1: hdmi: get YCC quant from EDID.
[ 133.992711] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 133.992762] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 133.992816] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 133.992851] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 133.992886] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 133.992920] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 133.992956] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 133.992992] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 133.993093] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 133.998598] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 133.998622] Extcon AUX1(HDMI) enable
[ 134.053028] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 134.053031] Extcon HDMI: HPD enabled
[ 134.053058] tegradc tegradc.1: hdmi: plugged
[ 134.083219] tegradc tegradc.1: blank - powerdown
[ 134.144881] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 134.144890] Extcon AUX1(HDMI) disable
[ 134.164628] tegradc tegradc.1: unblank
[ 134.195936] tegradc tegradc.1: nominal-pclk:25174825 parent:25174375 div:1.0 pclk:25174375 24923052~27440532
[ 134.196009] tegradc tegradc.1: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[ 134.197019] tegradc tegradc.1: hdmi: get RGB quant from EDID.
[ 134.197025] tegradc tegradc.1: hdmi: get YCC quant from EDID.
[ 144.232666] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 144.232717] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 144.232765] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 144.232798] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 144.232831] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 144.232864] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 144.232899] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 144.232931] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 144.233032] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 144.239652] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 144.240083] Extcon AUX1(HDMI) enable
[ 144.298740] tegradc tegradc.1: unblank
[ 144.412733] tegradc tegradc.1: blank - powerdown
[ 144.475314] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 144.475322] Extcon AUX1(HDMI) disable
[ 144.495485] tegradc tegradc.1: unblank
[ 144.503497] tegradc tegradc.1: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 144.505177] tegradc tegradc.1: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[ 144.506234] tegradc tegradc.1: hdmi: get RGB quant from EDID.
[ 144.506240] tegradc tegradc.1: hdmi: get YCC quant from EDID.
[ 154.728771] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[ 154.728819] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[ 154.728863] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 154.728895] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 154.728931] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[ 154.728964] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 154.728999] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[ 154.729028] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[ 154.729128] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 154.735127] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 154.735142] Extcon AUX1(HDMI) enable
[ 154.792055] tegradc tegradc.1: unblank
tx1@localhost:~$ dmesg | grep xusb
