USB3.0 HUB on customer carrier board
hello everyone:
I used RTSP-5411S as a usb3.0 hub on my jetson nano carrier board ,also i add a usb ethernet(rtl8153b).
nano@ubuntu:~$ lsusb
Bus 002 Device 003: ID 0bda:8153 Realtek Semiconductor Corp.
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0bda:881a Realtek Semiconductor Corp.
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
problems:
  1. the DSP1_PWR of the RTS-5411S is active Low but the Power Switch’s Enable Pin is Active High(TPS259530DSG ) how to config the RTS-5411S to change the active status?
2.the device list shows the RTL8153 has been detected,but i can’t find it .
nano@ubuntu:~$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.0.11  netmask 255.255.255.0  broadcast 10.0.0.255
        inet6 fe80::204:4bff:fee5:db78  prefixlen 64  scopeid 0x20<link>
        ether 00:04:4b:e5:db:78  txqueuelen 1000  (Ethernet)
        RX packets 35129  bytes 3837957 (3.8 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 34420  bytes 3855213 (3.8 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 151  base 0xa000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 196  bytes 14625 (14.6 KB)
        TX packets 196  bytes 14625 (14.6 KB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 60:23:a4:9a:c7:2b  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
here is the dmesg info:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2713) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:47:42 PST 2019
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] On node 0 totalpages: 1039872
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519168 pages, LIFO batch:31
[    0.000000]   Normal zone: 8136 pages used for memmap
[    0.000000]   Normal zone: 520704 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefc2000 s61592 r8192 d32616 u102400
[    0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0    root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29496(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3570412K/4159488K available (15230K kernel code, 2926K rwdata, 6620K rodata, 8576K init, 609K bss, 113940K reserved, 475136K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f60000   ( 15232 KB)
[    0.000000]     .rodata : 0xffffff8008f60000 - 0xffffff80095e0000   (  6656 KB)
[    0.000000]       .init : 0xffffff80095e0000 - 0xffffff8009e40000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e40000 - 0xffffff800a11b808   (  2927 KB)
[    0.000000]        .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc   (   610 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03fc8000   (    63 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ff200000   (  4082 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001515] Console: colour dummy device 80x25
[    0.001537] console [tty0] enabled
[    0.001554] kmemleak: Kernel memory leak detector disabled
[    0.001574] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001586] pid_max: default: 32768 minimum: 301
[    0.002037] Security Framework initialized
[    0.002260] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002268] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003365] ftrace: allocating 47001 entries in 184 pages
[    0.174919] sched-energy: CPU device node has no sched-energy-costs
[    0.174954] ASID allocator initialised with 65536 entries
[    0.211549] tegra-id: chipid=22117.
[    0.211563] tegra-id: opt_subrevision=0.
[    0.211582] Tegra Speedo/IDDQ fuse revision 4
[    0.211587] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.211591] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[    0.211597] Tegra: CPU Speedo Value 2106, SoC Speedo Value 1983, GPU Speedo Value 2099
[    0.211601] Tegra: CPU IDDQ Value 2164, SoC IDDQ Value 2432, GPU IDDQ Value 2915
[    0.211620] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[    0.211635] DTS File Name: /home/auvidea/Downloads/l4t_rev_32_3_1/Nano/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[    0.211642] DTB Build time: Feb 26 2020 14:09:32
[    0.261037] CPU1: Booted secondary processor [411fd071]
[    0.292966] CPU2: Booted secondary processor [411fd071]
[    0.324933] CPU3: Booted secondary processor [411fd071]
[    0.325018] Brought up 4 CPUs
[    0.325025] SMP: Total of 4 processors activated.
[    0.325033] CPU features: detected feature: 32-bit EL0 Support
[    0.325295] CPU: All CPU(s) started at EL2
[    0.325315] alternatives: patching kernel code
[    0.333356] devtmpfs: initialized
[    0.368838] Initilizing CustomIPI irq domain
[    0.369240] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.369265] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.379669] pinctrl core: initialized pinctrl subsystem
[    0.380340] OS set in device tree is not L4T.
[    0.380730] regulator-dummy: no parameters
[    0.381065] Initializing plugin-manager
[    0.381175] Plugin module not found
[    0.381405] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[    0.381946] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[    0.382452] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[    0.383138] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[    0.383565] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[    0.384095] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[    0.384679] node /plugin-manager/fragement@11 match with board >=3448-0002-300
[    0.388027] NET: Registered protocol family 16
[    0.389389] pstore: using zlib compression
[    0.389425] console [pstore-1] enabled
[    0.389430] pstore: Registered ramoops as persistent store backend
[    0.389435] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.405052] cpuidle: using governor menu
[    0.408861] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.410420] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[    0.410441] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.413465] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.415898] tegra_powergate_init: DONE
[    0.415914] DTS File Name: /home/auvidea/Downloads/l4t_rev_32_3_1/Nano/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[    0.415921] DTB Build time: Feb 26 2020 14:09:32
[    0.417472] Tegra reboot handler registered.
[    0.421841] iommu: Adding device tegra-carveouts to group 0
[    0.421979] platform tegra-carveouts: domain=ffffffc0f9b88318 allocates as[0]=ffffffc0f94000a8
[    0.422337] iommu: Adding device smmu_test to group 1
[    0.422381] platform smmu_test: domain=ffffffc0f9b88558 allocates as[0]=ffffffc0f9400110
[    0.423187] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[    0.423241] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[    0.423299] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[    0.423308] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.423330] mc-err: mcerr ops are set to t21x
[    0.432865] iommu: Adding device 70090000.xusb to group 2
[    0.433197] iommu: Adding device 70006000.serial to group 3
[    0.433261] platform 70006000.serial: domain=ffffffc0f9beec18 allocates as[0]=ffffffc0f9400178
[    0.433673] iommu: Adding device 70006040.serial to group 4
[    0.433921] iommu: Adding device 70006200.serial to group 5
[    0.434101] iommu: Adding device sound to group 6
[    0.434144] platform sound: domain=ffffffc0f9499198 allocates as[0]=ffffffc0f94001e0
[    0.434687] iommu: Adding device 7000d400.spi to group 7
[    0.434939] iommu: Adding device 7000d600.spi to group 8
[    0.435297] iommu: Adding device 50000000.host1x to group 9
[    0.435565] iommu: Adding device 54080000.vi to group 10
[    0.435964] iommu: Adding device 54600000.isp to group 11
[    0.436213] iommu: Adding device 54680000.isp to group 12
[    0.436488] iommu: Adding device tegradc.0 to group 13
[    0.436535] platform tegradc.0: domain=ffffffc0f9499f18 allocates as[0]=ffffffc0f9400248
[    0.437085] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[    0.437410] iommu: Adding device tegradc.1 to group 14
[    0.437459] platform tegradc.1: domain=ffffffc0f94a4198 allocates as[0]=ffffffc0f94002b0
[    0.437962] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[    0.438206] iommu: Adding device 54340000.vic to group 15
[    0.438424] iommu: Adding device 544c0000.nvenc to group 16
[    0.438617] iommu: Adding device 54500000.tsec to group 17
[    0.438813] iommu: Adding device 54100000.tsecb to group 18
[    0.439002] iommu: Adding device 54480000.nvdec to group 19
[    0.439192] iommu: Adding device 54380000.nvjpg to group 20
[    0.440223] iommu: Adding device 546c0000.i2c to group 21
[    0.440513] iommu: Adding device 7000c000.i2c to group 22
[    0.440851] iommu: Adding device 57000000.gpu to group 23
[    0.440909] platform 57000000.gpu: domain=ffffffc0f94b0318 allocates as[0]=ffffffc0f9400318
[    0.440966] platform 57000000.gpu: domain=ffffffc0f94b0318 allocates as[1]=ffffffc0f9400380
[    0.441005] platform 57000000.gpu: domain=ffffffc0f94b0318 allocates as[2]=ffffffc0f94003e8
[    0.441064] platform 57000000.gpu: domain=ffffffc0f94b0318 allocates as[3]=ffffffc0f9400450
[    0.441927] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.441938] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.441950] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.441954] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.441959] tegra-pmc: ### PMC reset status reg: 0x3
[    0.493231] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.493241] tegra-pmc: Clear bootloader IO dpd settings
[    0.493260] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.493326] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.493617] iommu: Adding device 70012000.se to group 24
[    0.494372] iommu: Adding device 7000c400.i2c to group 25
[    0.494628] iommu: Adding device 7000c500.i2c to group 26
[    0.494874] iommu: Adding device 7000c700.i2c to group 27
[    0.495113] iommu: Adding device 7000d000.i2c to group 28
[    0.495358] iommu: Adding device 7000d100.i2c to group 29
[    0.495614] iommu: Adding device sdhci-tegra.3 to group 30
[    0.495671] platform sdhci-tegra.3: domain=ffffffc0f954f318 allocates as[0]=ffffffc0f94004b8
[    0.496089] iommu: Adding device sdhci-tegra.2 to group 31
[    0.496157] platform sdhci-tegra.2: domain=ffffffc0f954f558 allocates as[0]=ffffffc0f9400520
[    0.497003] iommu: Adding device 700d0000.xudc to group 32
[    0.500354] vdd-ac-bat: 5000 mV
[    0.500709] vdd-5v0-sys: 5000 mV
[    0.501689] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.501731] vdd-5v0-hdmi: 5000 mV
[    0.502155] vdd-1v8-sys: 1800 mV
[    0.502526] vdd-fan: supplied by vdd-5v0-sys
[    0.502557] vdd-fan: 5000 mV
[    0.502932] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.502967] vdd-usb-vbus: 5000 mV
[    0.503477] vdd-usb-vbus2: 5000 mV
[    0.534095] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.536442] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.537961] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.537983] GPIO line 152 (camera-control-output-low) hogged as output/low
[    0.538016] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.538394] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.546156] eventlib_kernel: keventlib is initialized, test id: 0
[    0.546509] SCSI subsystem initialized
[    0.546742] libata version 3.00 loaded.
[    0.547084] usbcore: registered new interface driver usbfs
[    0.547134] usbcore: registered new interface driver hub
[    0.547203] usbcore: registered new device driver usb
[    0.551336] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.556360] vdd-core: 600 <--> 1162 mV at 1075 mV
[    0.557335] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.557430] random: fast init done
[    0.560985] vdd-ddr-1v1: 1150 mV
[    0.564982] vdd-pre-reg-1v35: 1350 mV
[    0.568982] vdd-1v8: 1800 mV
[    0.572987] avdd-sys-1v2: 1200 mV
[    0.576983] vdd-pex-1v0: 1050 mV
[    0.577596] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.578131] max77620-ldo3: at 3100 mV
[    0.580986] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.581559] max77620-ldo5: at 3100 mV
[    0.584986] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 3300 mV
[    0.588980] avdd-1v05-pll: 1050 mV
[    0.592984] avdd-io-hdmi-dp: 1050 mV
[    0.595440] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.595709] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.595986] max77620 4-003c: max77620 probe successful
[    0.598648] media: Linux media interface: v0.10
[    0.598706] Linux video capture interface: v2.00
[    0.599636] pps_core: LinuxPPS API ver. 1 registered
[    0.599642] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.599666] PTP clock support registered
[    0.603171] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[    0.609400] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.610188] Advanced Linux Sound Architecture Driver Initialized.
[    0.610808] Bluetooth: Core ver 2.22
[    0.610864] NET: Registered protocol family 31
[    0.610867] Bluetooth: HCI device and connection manager initialized
[    0.610881] Bluetooth: HCI socket layer initialized
[    0.610889] Bluetooth: L2CAP socket layer initialized
[    0.610912] Bluetooth: SCO socket layer initialized
[    0.612545] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.612560] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.612603] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.612617] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.615476] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.616691] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.616757] vdd-3v3-sys: 3300 mV
[    0.617097] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.621039] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.621522] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.621562] vdd-3v3-sd: 3300 mV
[    0.622399] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.622440] avdd-io-edp-1v05: 1050 mV
[    0.622840] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.622901] vdd-usb-hub-en: 5000 mV
[    0.624206] camchar: rtcpu character device driver loaded
[    0.624862] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[    0.626206] clocksource: Switched to clocksource arch_sys_counter
[    0.665021] VFS: Disk quotas dquot_6.6.0
[    0.665146] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.665619] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.666030] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.666048]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.666274] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.666280] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.666299] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.666343] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.666349] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.666362] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.666370] nvmap_page_pool_init: Total RAM pages: 1011387
[    0.666375] nvmap_page_pool_init: nvmap page pool size: 126423 pages (493 MB)
[    0.666472] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.666893] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[    0.667600] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[    0.677233] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.677614] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.677865] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.678084] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.678305] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.678585] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.678589] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.679030] NET: Registered protocol family 2
[    0.679992] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.680203] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.680699] TCP: Hash tables configured (established 32768 bind 32768)
[    0.680840] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.680924] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.681333] NET: Registered protocol family 1
[    0.682122] RPC: Registered named UNIX socket transport module.
[    0.682126] RPC: Registered udp transport module.
[    0.682130] RPC: Registered tcp transport module.
[    0.682134] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.682149] PCI: CLS 0 bytes, default 64
[    0.682437] Trying to unpack rootfs image as initramfs...
[    0.917541] Freeing initrd memory: 5432K
[    0.927055] host1x 50000000.host1x: initialized
[    0.928828] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.931964] audit: initializing netlink subsys (disabled)
[    0.932049] audit: type=2000 audit(0.783:1): initialized
[    0.932784] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.942920] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.944405] ntfs: driver 2.1.32 [Flags: R/W].
[    0.945195] 9p: Installing v9fs 9p2000 file system support
[    0.948442] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.948585] io scheduler noop registered
[    0.948880] io scheduler cfq registered (default)
[    0.951595] gic 702f9000.agic: GIC IRQ controller registered
[    0.954600] iommu: Adding device 702ef000.adsp to group 33
[    0.963727] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[    0.963888] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    0.964472] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x6209411
[    0.964481] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    0.966084] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    0.966181] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    0.966316] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    0.966497] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    0.966591] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    0.966682] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    0.966775] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    0.966858] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    0.966941] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    0.967021] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    0.973012] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    0.974687] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    0.976556] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    0.977844] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    0.978257] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    0.979393] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.979625] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    0.979874] Adding domain tsec-pd to PM domain host1x-pd
[    0.981952] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    0.982817] tsec 54500000.tsec: initialized
[    0.984335] tsec 54100000.tsecb: initialized
[    0.984990] Adding domain nvdec-pd to PM domain host1x-pd
[    0.988109] nvdec 54480000.nvdec: initialized
[    0.989124] Adding domain vic03-pd to PM domain host1x-pd
[    0.989304] Adding domain msenc-pd to PM domain host1x-pd
[    0.989467] Adding domain nvjpg-pd to PM domain host1x-pd
[    0.993303] falcon 54340000.vic: initialized
[    0.994498] falcon 544c0000.nvenc: initialized
[    0.995839] falcon 54380000.nvjpg: initialized
[    0.999988] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[    1.000039] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    1.000067] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    1.000234] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    1.000339] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    1.000343] tegra_cec 70015000.tegra_cec: probed
[    1.000362] display board info: id 0x0, fab 0x0
[    1.000434] generic_infoframe_type: 0x87
[    1.000583] tegradc tegradc.0: DT parsed successfully
[    1.000624] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[    1.007961] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.009225] tegradc tegradc.0: probed
[    1.009959] Console: switching to colour frame buffer device 80x30
[    1.009992] tegradc tegradc.0: fb registered
[    1.011493] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[    1.011574] tegradc tegradc.1: No lt-data, using default setting
[    1.011600] tegradc tegradc.1: No hpd-gpio in DT
[    1.011632] tegradc tegradc.1: DT parsed successfully
[    1.011684] tegradc tegradc.1: Display dc.ffffff800acc0000 registered with id=1
[    1.012801] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    1.012809] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    1.012814] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    1.012819] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    1.012824] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.012858] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[    1.012988] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.013217] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    1.013292] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.013477] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.013496] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.013499] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.013658] pci 0000:01:00.0: [126f:2263] type 00 class 0x010802
[    1.013688] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    1.015134] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.015597] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.015831] kfuse 7000fc00.kfuse: initialized
[    1.016399] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.017045] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.017661] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.017668] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.017998] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.018985] vdd-gpu: applied init 1000000uV constraint
[    1.018991] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.019308] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.523392] Host read timeout at address 545c00c4
[    1.523495] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.523639] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    1.523663] pci 0000:02:00.0: reg 0x10: [io  0x0000-0x00ff]
[    1.523690] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[    1.523709] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[    1.523825] pci 0000:02:00.0: supports D1 D2
[    1.523829] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.524136] tegradc tegradc.1: probed
[    1.524409] tegradc tegradc.1: fb registered
[    1.526029] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.526094] No Device Node present for smmu client: serial8250 !!
[    1.526100] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.526127] iommu: Adding device serial8250 to group 35
[    1.527550] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    1.527555] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    1.527563] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    1.527573] tegradc tegradc.1: blank - powerdown
[    1.527585] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[    1.527588] Extcon DP: HPD disabled
[    1.527592] hpd: hpd_switch 0
[    1.527595] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.527601] console [ttyS0] disabled
[    1.527603] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    1.527609] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    1.527641] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.537804] console [ttyS0] enabled
[    1.537950] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[    1.537994] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[    1.538003] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[    1.538009] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    1.538018] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13003fff 64bit]
[    1.538035] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.538042] pci 0000:00:01.0:   bridge window [mem 0x13000000-0x130fffff]
[    1.538053] pci 0000:02:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[    1.538070] pci 0000:02:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[    1.538086] pci 0000:02:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    1.538094] pci 0000:00:02.0: PCI bridge to [bus 02]
[    1.538099] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    1.538106] pci 0000:00:02.0:   bridge window [mem 0x20000000-0x200fffff 64bit pref]
[    1.538505] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[    1.538511] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    1.538517] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[    1.538620] aer 0000:00:01.0:pcie002: service driver aer loaded
[    1.538806] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    1.538810] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[    1.538816] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    1.538909] aer 0000:00:02.0:pcie002: service driver aer loaded
[    1.539733] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    1.539977] serial-tegra 70006200.serial: RX in PIO mode
[    1.540063] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    1.540818] [drm] Initialized
[    1.548600] brd: module loaded
[    1.552517] loop: module loaded
[    1.552582] tegra_profiler: version: 1.139, samples/io: 47/27
[    1.552668] tegra_profiler: auth: init
[    1.553222] THERMAL EST: found 2 subdevs
[    1.553227] THERMAL EST num_resources: 0
[    1.553232] [THERMAL EST subdev 0]
[    1.553237] [THERMAL EST subdev 1]
[    1.553550] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.553554] THERMAL EST: thz register success.
[    1.553647] THERMAL EST: end of probe, return err: 0
[    1.554519] hisi_sas: driver version v1.6
[    1.555143] nvme nvme0: pci function 0000:01:00.0
[    1.555170] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    1.559309] libphy: Fixed MDIO Bus: probed
[    1.560024] tun: Universal TUN/TAP device driver, 1.6
[    1.560027] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.560600] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.560603] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.560651] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    1.560654] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.560695] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.560697] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.560738] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    1.560741] Copyright(c) 1999 - 2017 Intel Corporation.
[    1.561261] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[    1.561279] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    1.582726] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    1.582805] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e5:db:78 from device tree
[    1.583201] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    1.583230] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    1.583619] PPP generic driver version 2.4.2
[    1.583752] PPP BSD Compression module registered
[    1.583756] PPP Deflate Compression module registered
[    1.583771] PPP MPPE Compression module registered
[    1.583775] NET: Registered protocol family 24
[    1.583828] usbcore: registered new interface driver r8152
[    1.583868] usbcore: registered new interface driver asix
[    1.583906] usbcore: registered new interface driver ax88179_178a
[    1.583940] usbcore: registered new interface driver cdc_ether
[    1.583976] usbcore: registered new interface driver net1080
[    1.584011] usbcore: registered new interface driver cdc_subset
[    1.584045] usbcore: registered new interface driver zaurus
[    1.584090] usbcore: registered new interface driver cdc_ncm
[    1.584209] VFIO - User Level meta-driver version: 0.3
[    1.585124] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.585135] ehci-pci: EHCI PCI platform driver
[    1.585171] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.585177] ohci-pci: OHCI PCI platform driver
[    1.585210] ohci-platform: OHCI generic platform driver
[    1.587104] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    1.587765] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    1.588819] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f969cc00 id
[    1.589786] usbcore: registered new interface driver uas
[    1.589832] usbcore: registered new interface driver usb-storage
[    1.589908] usbcore: registered new interface driver usbserial
[    1.592763] tegra-xudc-new 700d0000.xudc: device count: 1
[    1.593134] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[    1.593164] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.593184] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[    1.593881] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[    1.593914] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[    1.594062] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.594068] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.594073] usb usb1: Product: xHCI Host Controller
[    1.594078] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    1.594082] usb usb1: SerialNumber: 70090000.xusb
[    1.594933] hub 1-0:1.0: USB hub found
[    1.594967] hub 1-0:1.0: 5 ports detected
[    1.595379] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    1.595390] tegra-xudc-new 700d0000.xudc: vbus state: 0
[    1.595411] tegra-xudc-new 700d0000.xudc: entering ELPG
[    1.595499] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.595509] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[    1.595586] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.595642] tegra-xudc-new 700d0000.xudc: entering ELPG done
[    1.595679] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.595684] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.595689] usb usb2: Product: xHCI Host Controller
[    1.595694] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[    1.595698] usb usb2: SerialNumber: 70090000.xusb
[    1.596108] hub 2-0:1.0: USB hub found
[    1.596203] hub 2-0:1.0: 4 ports detected
[    1.596230] mousedev: PS/2 mouse device common for all mice
[    1.596302] usbcore: registered new interface driver xpad
[    1.677463]  nvme0n1: p1
[    1.698260] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[    1.722767] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.724880] rtc rtc1: alarm rtc device
[    1.724893] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    1.724911] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    1.725295] i2c /dev entries driver
[    1.726817] imx219 0-0010: tegracam sensor driver:imx219_v2.0.6
[    1.750114] tegra-i2c 7000c000.i2c: no acknowledge from address 0x10
[    1.750145] imx219 0-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.757678] imx219 0-0010: board setup failed
[    1.762102] imx219: probe of 0-0010 failed with error -121
[    1.762502] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[    1.785763] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.785821] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.793344] imx219 6-0010: board setup failed
[    1.797759] imx219: probe of 6-0010 failed with error -121
[    1.798905] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.801091] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    1.801096] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    1.801373] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.801386] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    1.801394] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    1.801526] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.801535] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    1.801542] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    1.801684] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.801692] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    1.801697] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    1.801869] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    1.802446] tegra_aotag tegra-aotag: Registering sensor 0
[    1.802495] tegra_aotag tegra-aotag: Invalid temp readout
[    1.802516] tegra_aotag tegra-aotag: Invalid temp readout
[    1.802533] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    1.802542] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    1.803309] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.803324] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    1.803473] tegra_aotag tegra-aotag: Invalid temp readout
[    1.803497] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    1.803843] parse_throttle_dt_data: Num cap clks = 6
[    1.803848] parse_throttle_dt_data: clk=cclk_g type=2
[    1.803856] parse_throttle_dt_data: clk=gpu type=4
[    1.803876] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    1.803894] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    1.803914] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    1.803918] parse_throttle_dt_data: clk=emc type=3
[    1.804292] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.804415] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.804554] tegra_throttle_probe: probe successful. #cdevs=4
[    1.805180] FAN dev name: pwm-fan
[    1.805223] FAN:gpio request success.
[    1.805234] FAN: can't find tach_gpio
[    1.805263] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    1.805531] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.805537] pwm_fan_driver pwm-fan: tach period: 1000
[    1.805617] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.805623] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    1.805628] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    1.805633] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    1.805638] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.805642] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.805647] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.805651] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.805656] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.805661] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.806182] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[    1.806516] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[    1.807328] device-mapper: uevent: version 1.0.3
[    1.807776] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.810432] tegra210-cpufreq cpufreq: probe()...completed
[    1.811277] sdhci: Secure Digital Host Controller Interface driver
[    1.811279] sdhci: Copyright(c) Pierre Ossman
[    1.811281] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.811623] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[    1.814466] sdhci-tegra sdhci-tegra.2: Got CD GPIO
[    1.814820] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[    1.819746] tegra-se 70012000.se: tegra_se_probe: complete
[    1.820241] hidraw: raw HID events driver (C) Jiri Kosina
[    1.821385] usbcore: registered new interface driver usbhid
[    1.821388] usbhid: USB HID core driver
[    1.823448] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    1.823728] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    1.825471] nvpmodel: initialized successfully
[    1.826438] usbcore: registered new interface driver snd-usb-audio
[    1.826496] No Device Node present for smmu client: snd-soc-dummy !!
[    1.826501] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.826519] iommu: Adding device snd-soc-dummy to group 36
[    1.837087] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    1.848922] OPE platform probe
[    1.849006] OPE platform probe successful
[    1.849314] OPE platform probe
[    1.849398] OPE platform probe successful
[    1.854463] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[    1.862408] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[    1.883555] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.883673] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.883793] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.883908] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.884020] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.884134] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.884245] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.884362] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.884474] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.884584] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.897411] u32 classifier
[    1.897414]     Actions configured
[    1.897485] Initializing XFRM netlink socket
[    1.898228] NET: Registered protocol family 10
[    1.898971] NET: Registered protocol family 17
[    1.898981] NET: Registered protocol family 15
[    1.899058] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.899100] Bluetooth: RFCOMM socket layer initialized
[    1.899110] Bluetooth: RFCOMM ver 1.11
[    1.899115] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.899120] Bluetooth: HIDP socket layer initialized
[    1.899138] 9pnet: Installing 9P2000 support
[    1.899174] Key type dns_resolver registered
[    1.899330] mmc1: host does not support reading read-only switch, assuming write-enable
[    1.900108] Registered cp15_barrier emulation handler
[    1.900115] Registered setend emulation handler
[    1.902935] mmc1: new high speed SD card at address b368
[    1.903198] mmcblk1: mmc1:b368 SMI   244 MiB
[    1.905366] registered taskstats version 1
[    1.905461] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    1.905799] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.905917] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    1.906553]  mmcblk1: p1
[    1.906687] Adding domain ve2-pd to PM domain host1x-pd
[    1.906807]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    1.908073] Adding domain ve-pd to PM domain host1x-pd
[    1.910117] isp 54600000.isp: initialized
[    1.911031] isp 54680000.isp: initialized
[    1.921026] last reset is due to software reset
[    1.921030] KERNEL: PMC reset status reg: 0x3
[    1.921104] BL: PMC reset status reg: 0x3
[    1.921107] BL: PMIC poweroff Event Recorder: 0x0
[    1.922603] clk_cbus_recalc_rate: no gbus parent
[    1.922609] clk_cbus_round_rate: no gbus parent
[    1.922611] clk_cbus_round_rate: no gbus parent
[    1.922618] clk_cbus_recalc_rate: no gbus parent
[    1.922720] clk_cbus_recalc_rate: no gbus parent
[    1.922723] clk_cbus_round_rate: no gbus parent
[    1.922726] clk_cbus_round_rate: no gbus parent
[    1.922729] clk_cbus_recalc_rate: no gbus parent
[    1.923420] tegra_dvfs: GPU-cap: registered
[    1.923474] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    1.923477] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[    1.923479] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[    1.923646] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    1.924775] tegra_dvfs: vdd-gpu-vts: registered
[    1.925425] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    1.926019] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    1.926518] input: gpio-keys as /devices/gpio-keys/input/input1
[    1.951559] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[    1.951563] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.951566] usb 1-2: Product: 4-Port USB 2.1 Hub
[    1.951569] usb 1-2: Manufacturer: Generic
[    1.952388] hub 1-2:1.0: USB hub found
[    1.952997] hub 1-2:1.0: 4 ports detected
[    1.958830] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:02:21 UTC (946688541)
[    1.959800] vi 54080000.vi: vi_probe: ++
[    1.962268] vi 54080000.vi: initialized
[    1.964169] vi 54080000.vi: subdev nvcsi--2 bound
[    1.964255] vi 54080000.vi: subdev nvcsi--1 bound
[    1.964484] mmcblk mmc1:b368: Card claimed for testing.
[    1.964494] mmcblk mmc0:0001: Card claimed for testing.
[    1.965665] Disable partitions left on by BL
[    1.965668]   disb
[    1.965712] bwmgr: missing cdev-type property
[    1.965843] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.965849] DRAM derating cdev registered.
[    1.966807] vdd-fan: disabling
[    1.966810] vdd-usb-vbus: disabling
[    1.966813] vdd-usb-vbus2: disabling
[    1.966821] vddio-sdmmc-ap: disabling
[    1.966899] vdd-3v3-sd: disabling
[    1.966903] avdd-io-edp-1v05: disabling
[    1.966906] vdd-usb-hub-en: disabling
[    1.966984] ALSA device list:
[    1.966987]   #0: tegra-hda at 0x70038000 irq 83
[    1.966990]   #1: tegra-snd-t210ref-mobile-rt565x
[    1.970011] Freeing unused kernel memory: 8576K
[    1.987436] L4T-INITRD Build DATE: Sat Jan  1 01:02:21 UTC 2000
[    1.991757] Root device found: mmcblk0p1
[    1.992774] Found dev node: /dev/mmcblk0p1
[    2.002220] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    2.002225] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    2.011573] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    2.012292] Rootfs mounted over mmcblk0p1
[    2.026871] Switching from initrd to actual rootfs
[    2.107788] systemd[1]: System time before build time, advancing clock.
[    2.123510] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.134485] cgroup: cgroup2: unknown option "nsdelegate"
[    2.149038] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.149757] systemd[1]: Detected architecture arm64.
[    2.172056] systemd[1]: Set hostname to <ubuntu>.
[    2.234614] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    2.234624] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.242224] usb 1-2.2: new high-speed USB device number 3 using tegra-xusb
[    2.262687] usb 1-2.2: New USB device found, idVendor=0bda, idProduct=881a
[    2.262693] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.262697] usb 1-2.2: Product: 802.11n NIC
[    2.262700] usb 1-2.2: Manufacturer: Realtek
[    2.262703] usb 1-2.2: SerialNumber: 123456
[    2.324477] random: systemd: uninitialized urandom read (16 bytes read)
[    2.326347] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.326455] random: systemd: uninitialized urandom read (16 bytes read)
[    2.326475] systemd[1]: Reached target User and Group Name Lookups.
[    2.326503] random: systemd: uninitialized urandom read (16 bytes read)
[    2.326617] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.328411] systemd[1]: Created slice User and Session Slice.
[    2.328464] systemd[1]: Reached target Swap.
[    2.390607] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    2.442313] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[    2.618552] systemd-journald[1999]: Received request to flush runtime journal from PID 1
[    3.351474] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[    4.160252] using random self ethernet address
[    4.170246] using random host ethernet address
[    4.787308] random: crng init done
[    4.790715] random: 7 urandom warning(s) missed due to ratelimiting
[    4.959660] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    4.960797] eth0: 0xffffff800a3fa000, 00:04:4b:e5:db:78, IRQ 407
[    5.042765] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.188839] zram: Added device: zram0
[    5.189255] zram: Added device: zram1
[    5.191929] zram: Added device: zram2
[    5.194814] zram: Added device: zram3
[    5.223308] zram0: detected capacity change from 0 to 519622656
[    5.267642] Adding 507440k swap on /dev/zram0.  Priority:5 extents:1 across:507440k SS
[    5.272298] zram1: detected capacity change from 0 to 519622656
[    5.288889] Adding 507440k swap on /dev/zram1.  Priority:5 extents:1 across:507440k SS
[    5.296251] zram2: detected capacity change from 0 to 519622656
[    5.324894] Adding 507440k swap on /dev/zram2.  Priority:5 extents:1 across:507440k SS
[    5.334431] zram3: detected capacity change from 0 to 519622656
[    5.351189] Adding 507440k swap on /dev/zram3.  Priority:5 extents:1 across:507440k SS
[    5.760400] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[    5.760406] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[    5.954220] RTW: module init start
[    5.954225] RTW: rtl8812au v5.6.4.1_33916.20190619
[    5.954228] RTW: build time: Dec  9 2019 22:44:53
[    5.954257] RTW: rtw_inetaddr_notifier_register
[    5.954324] RTW:
               usb_endpoint_descriptor(0):
[    5.954326] RTW: bLength=7
[    5.954329] RTW: bDescriptorType=5
[    5.954331] RTW: bEndpointAddress=81
[    5.954333] RTW: wMaxPacketSize=512
[    5.954335] RTW: bInterval=0
[    5.954337] RTW: RT_usb_endpoint_is_bulk_in = 1
[    5.954339] RTW:
               usb_endpoint_descriptor(1):
[    5.954341] RTW: bLength=7
[    5.954343] RTW: bDescriptorType=5
[    5.954344] RTW: bEndpointAddress=2
[    5.954346] RTW: wMaxPacketSize=512
[    5.954348] RTW: bInterval=0
[    5.954350] RTW: RT_usb_endpoint_is_bulk_out = 2
[    5.954351] RTW:
               usb_endpoint_descriptor(2):
[    5.954353] RTW: bLength=7
[    5.954355] RTW: bDescriptorType=5
[    5.954356] RTW: bEndpointAddress=3
[    5.954358] RTW: wMaxPacketSize=512
[    5.954360] RTW: bInterval=0
[    5.954361] RTW: RT_usb_endpoint_is_bulk_out = 3
[    5.954363] RTW:
               usb_endpoint_descriptor(3):
[    5.954365] RTW: bLength=7
[    5.954367] RTW: bDescriptorType=5
[    5.954368] RTW: bEndpointAddress=4
[    5.954370] RTW: wMaxPacketSize=512
[    5.954372] RTW: bInterval=0
[    5.954373] RTW: RT_usb_endpoint_is_bulk_out = 4
[    5.954375] RTW:
               usb_endpoint_descriptor(4):
[    5.954377] RTW: bLength=7
[    5.954378] RTW: bDescriptorType=5
[    5.954380] RTW: bEndpointAddress=85
[    5.954382] RTW: wMaxPacketSize=64
[    5.954383] RTW: bInterval=1
[    5.954385] RTW: RT_usb_endpoint_is_int_in = 5, Interval = 1
[    5.954387] RTW: nr_endpoint=5, in_num=2, out_num=3
[    5.954389] RTW: USB_SPEED_HIGH
[    5.954392] RTW: CHIP TYPE: RTL8812
[    5.954627] RTW: read_chip_version_8812a SYS_CFG(0xF0)=0x04411135
[    5.954741] RTW: rtw_hal_config_rftype RF_Type is 2 TotalTxPath is 2
[    5.954746] RTW: Chip Version Info: CHIP_8812_Normal_Chip_TSMC_C_CUT_2T2R_RomVer(0)
[    5.954750] RTW: _ConfigChipOutEP_8812 OutEpQueueSel(0x07), OutEpNumber(3)
[    5.954864] RTW: Boot from EFUSE, Autoload OK !
[    5.978424] tegradc tegradc.0: blank - powerdown
[    5.978434] tegradc tegradc.1: blank - powerdown
[    6.060995] RTW: Hal_EfuseReadEFuse8812A: eFuse_Addr offset(0xe0) !!
[    6.061074] RTW: HW EFUSE
[    6.061081] RTW: 0x000: 29 81 0B 86  0C 00 08 00  00 00 00 00  00 00 00 00
[    6.061112] RTW: 0x010: 20 20 20 20  20 20 29 29  29 29 29 02  EE EE FF FF
[    6.061140] RTW: 0x020: FF FF 26 24  23 23 27 26  25 24 23 23  24 24 24 24
[    6.061174] RTW: 0x030: 02 EE FF FF  EE FF 10 EE  FF FF 26 27  27 27 27 27
[    6.061201] RTW: 0x040: 2E 2E 2E 2E  2E 02 EE EE  FF FF FF FF  22 20 1F 1F
[    6.061228] RTW: 0x050: 21 20 1F 1D  1B 1B 1C 1C  1C 1C 02 EE  FF FF EE FF
[    6.061256] RTW: 0x060: 10 EE FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061284] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061322] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061351] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061380] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061409] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 36 16 00  03 00 00 88
[    6.061437] RTW: 0x0C0: 00 01 00 10  00 00 00 55  00 FF 01 FF  FF FF FF FF
[    6.061465] RTW: 0x0D0: DA 0B 1A 88  41 66 C2 60  23 A4 9A C7  2B 09 03 52
[    6.061493] RTW: 0x0E0: 65 61 6C 74  65 6B 0D 03  38 30 32 2E  31 31 6E 20
[    6.061520] RTW: 0x0F0: 4E 49 43 08  03 31 32 33  34 35 36 FF  FF FF FF FF
[    6.061547] RTW: 0x100: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061579] RTW: 0x110: FF FF FF FF  FF FF FF 01  FF FF FF FF  FF FF FF FF
[    6.061606] RTW: 0x120: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061634] RTW: 0x130: 81 AE 98 2D  03 93 96 11  FC 8C 00 11  9B FF FF FF
[    6.061661] RTW: 0x140: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061689] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061727] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061756] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061784] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061812] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061840] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061868] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061896] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061924] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061956] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.061984] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    6.062014] RTW: EEPROM ID=0x8129
[    6.062017] RTW: VID = 0x0BDA, PID = 0x881A
[    6.062020] RTW: Customer ID: 0x00, SubCustomer ID: 0xCD
[    6.062036] RTW: EEPROMRegulatory = 0x1
[    6.062039] RTW: Board Type: 0x 0
[    6.062043] RTW: hal_com_config_channel_plan chplan:0x7F
[    6.062045] RTW: crystal_cap: 0x36
[    6.062047] RTW: ThermalMeter = 0x16
[    6.062049] RTW: Hal_ReadRemoteWakeup_8812A...bSupportRemoteWakeup(0)
[    6.062062] RTW: pHalData->PAType_2G is 0x3, pHalData->ExternalPA_2G = 0
[    6.062064] RTW: pHalData->PAType_5G is 0x3, pHalData->external_pa_5g = 1
[    6.062066] RTW: pHalData->LNAType_2G is 0x0, pHalData->ExternalLNA_2G = 0
[    6.062069] RTW: pHalData->LNAType_5G is 0x88, pHalData->external_lna_5g = 1
[    6.062071] RTW: pHalData->TypeGPA = 0x0
[    6.062073] RTW: pHalData->TypeAPA = 0x0
[    6.062074] RTW: pHalData->TypeGLNA = 0x0
[    6.062076] RTW: pHalData->TypeALNA = 0x0
[    6.062079] RTW: RFE Type: 0x 1
[    6.062081] RTW: Usb Switch: 0
[    6.062084] RTW: PID= 0x881a, VID=  bda
[    6.062086] RTW: PID= 0x881a, VID=  bda
[    6.062088] RTW: Customer ID: 0x 0
[    6.063361] RTW: hal_ReadUsbType_8812AU: antenna=2, wmode=3
[    6.063365] RTW: hal_ReadUsbType_8812AU(): EFUSE_HIDDEN_8812AU_VS
[    6.063370] RTW: rtw_hal_read_chip_info in 108 ms
[    6.063386] RTW: init_channel_set((null)) ChannelPlan ID:0x7f, ch num:37
[    6.063481] RTW: init_mlme_default_rate_set: support CCK
[    6.063483] RTW: init_mlme_default_rate_set: support OFDM
[    6.063664] RTW: NR_RECVBUFF: 8
[    6.063667] RTW: MAX_RECVBUF_SZ: 32768
[    6.063670] RTW: NR_PREALLOC_RECV_SKB: 8
[    6.063770] RTW: rtw_alloc_macid((null)) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:1
[    6.063780] RTW: IQK FW offload:disable
[    6.063787] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[    6.063793] RTW: can't get autopm:
[    6.063797] RTW: rtw_macaddr_cfg mac addr:60:23:a4:9a:c7:2b
[    6.063800] RTW: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
[    6.063893] RTW: init_mlme_default_rate_set: support CCK
[    6.063895] RTW: init_mlme_default_rate_set: support OFDM
[    6.064058] RTW: NR_RECVBUFF: 8
[    6.064061] RTW: MAX_RECVBUF_SZ: 32768
[    6.064064] RTW: NR_PREALLOC_RECV_SKB: 8
[    6.064164] RTW: rtw_alloc_macid((null)) if2, mac_addr:ff:ff:ff:ff:ff:ff macid:1
[    6.064185] RTW: rtw_drv_add_vir_if if2 mac_addr : 62:23:a4:9a:c7:2b
[    6.064203] RTW: rtw_wiphy_alloc(phy0)
[    6.064218] RTW: rtw_wdev_alloc(padapter=ffffff800aeb7000)
[    6.064223] RTW: rtw_wiphy_register(phy0)
[    6.064225] RTW: Register RTW cfg80211 vendor cmd(0x67) interface
[    6.064347] RTW: rtw_reg_notifier: NL80211_REGDOM_SET_BY_CORE
[    6.072145] RTW: rtw_ndev_init(wlan0) if1 mac_addr=60:23:a4:9a:c7:2b
[    6.072324] RTW: rtw_ndev_notifier_call(wlan0) state:16
[    6.073594] RTW: cfg80211_rtw_get_txpower
[    6.073603] RTW: rtw_ndev_notifier_call(wlan0) state:5
[    6.073837] usbcore: registered new interface driver rtl8812au
[    6.073841] RTW: module init ret=0
[    6.075231] RTW: cfg80211_rtw_get_txpower
[    6.091004] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[    6.119215] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[    6.119222] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.119226] usb 2-1: Product: 4-Port USB 3.1 Hub
[    6.119229] usb 2-1: Manufacturer: Generic
[    6.123207] hub 2-1:1.0: USB hub found
[    6.124008] hub 2-1:1.0: 4 ports detected
[    6.140072] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.140215] RTW: rtw_ndev_notifier_call(wlan0) state:13
[    6.140221] RTW: _netdev_open(wlan0) , bup=0
[    6.140381] RTW:  power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea.
[    6.140383] RTW:  MAC has not been powered on yet.
[    6.143385] RTW: SetHwReg: bMacPwrCtrlOn=1
[    6.182027] RTW: FirmwareDownload8812 fw source from Header
[    6.182032] RTW: FirmwareDownload8812 fw:NIC, size: 27030
[    6.182036] RTW: FirmwareDownload8812: fw_ver=52 fw_subver=14 sig=0x9501
[    6.207454] RTW: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00060705
[    6.208340] RTW: =====> _8051Reset8812(): 8051 reset success .
[    6.236933] RTW: _FWFreeToGo8812: Polling FW ready OK! (493, 28ms), REG_MCUFWDL:0x000607c6
[    6.236938] RTW: FWDL success. write_fw:1, 52ms
[    6.237001] RTW: rtl8812au_hal_init: Download Firmware Success!!
[    6.410583] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[    6.431335] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=8153
[    6.431344] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    6.431350] usb 2-1.1: Product: USB 10/100/1000 LAN
[    6.431354] usb 2-1.1: Manufacturer: Realtek
[    6.431359] usb 2-1.1: SerialNumber: 000000000000
[    6.453432] fuse init (API version 7.26)
[    6.526907] usb 2-1.1: reset SuperSpeed USB device number 3 using tegra-xusb
[    6.535888] RTW: HW_VAR_BASIC_RATE: 0x15f->0x15f->0x15f
[    6.598742] RTW: rtl8812au_hal_init in 460ms
[    6.598752] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =60:23:a4:9a:c7:2b
[    6.599113] RTW: rtw_hal_set_macaddr_port (null)- hw port(1) mac_addr =62:23:a4:9a:c7:2b
[    6.599817] RTW: rtw_hal_get_macaddr_port wlan0- hw port(0) mac_addr =60:23:a4:9a:c7:2b
[    6.599821] RTW: wlan0- hw port(0) mac_addr =60:23:a4:9a:c7:2b
[    6.600174] RTW: rtw_hal_get_macaddr_port (null)- hw port(1) mac_addr =62:23:a4:9a:c7:2b
[    6.600178] RTW: (null)- hw port(1) mac_addr =62:23:a4:9a:c7:2b
[    6.600370] RTW: [HW_VAR_ENABLE_RX_BAR] 0x6A2=0x520
[    6.615308] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =60:23:a4:9a:c7:2b
[    6.615814] RTW: hw_var_set_opmode()-4318 mode = 2
[    6.616158] RTW: MAC Address = 60:23:a4:9a:c7:2b
[    6.616161] RTW: rtw_start_drv_threads(wlan0) enter
[    6.616163] RTW: rtw_start_drv_threads(wlan0) start RTW_CMD_THREAD
[    6.616451] RTW: rtw_cfg80211_init_wiphy:rf_type=2
[    6.616456] RTW: [HT] HAL Support STBC = 0x01
[    6.616459] RTW: [HT] HAL Support STBC = 0x01
[    6.616462] RTW: [VHT] Support STBC = 0x03
[    6.616465] RTW: [VHT] Support Beamformee
[    6.616469] RTW: rtw_build_vht_cap_ie, line818, Set MAX MPDU len = 11454 bytes
[    6.616471] RTW: [VHT] Declare supporting SGI 80MHz
[    6.616473] RTW: [VHT] Declare supporting TX STBC
[    6.616475] RTW: [VHT] Declare supporting RX STBC = 1
[    6.616477] RTW: [VHT] Declare supporting SU Bfee
[    6.616486] RTW: -871x_drv - drv_open, bup=1
[    6.616557] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.616564] RTW: cfg80211_rtw_set_power_mgmt(wlan0) enabled:1, timeout:-1
[    6.616568] RTW: rtw_ndev_notifier_call(wlan0) state:1
[    6.617285] r8152 2-1.1:1.0 eth1: v2.09.00 (2017/08/21)
[    6.617291] r8152 2-1.1:1.0 eth1: This product is covered by one or more of the following patents:
[    6.617668] RTW: cfg80211_rtw_get_txpower
[    6.625922] RTW: cfg80211_rtw_get_txpower
[    6.625982] RTW: cfg80211_rtw_get_txpower
[    6.626774] RTW: cfg80211_rtw_get_txpower
[    6.626828] RTW: cfg80211_rtw_get_txpower
[    6.627893] RTW: cfg80211_rtw_get_txpower
[    6.627969] RTW: rtw_ndev_notifier_call(wlan0) state:4
[    6.646795] RTW: cfg80211_rtw_flush_pmksa(wlan0)
[    6.675182] RTW: cfg80211_rtw_add_virtual_intf(phy0) name:p2p-dev-wlan0, type:10
[    6.675192] RTW: rtw_pd_iface_alloc(phy0) pd_wdev:ffffffc0e8326000, addr=60:23:a4:9a:c7:2b added
[    6.675195] RTW: cfg80211_rtw_add_virtual_intf(phy0) wdev:ffffffc0e8326000, ret:0
[    6.675200] RTW: cfg80211_rtw_get_txpower
[    6.675206] RTW: cfg80211_rtw_get_txpower
[    6.680538] RTW: cfg80211_rtw_get_txpower
[    6.680841] RTW: cfg80211_rtw_get_txpower
[    6.680894] RTW: cfg80211_rtw_get_txpower
[    6.680984] RTW: cfg80211_rtw_get_txpower
[    6.681641] RTW: cfg80211_rtw_get_txpower
[    6.682001] RTW: cfg80211_rtw_get_txpower
[    6.682058] RTW: cfg80211_rtw_start_p2p_device(phy0) wdev=ffffffc0e8326000
[    6.684058] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[    6.694453] RTW: rtw_ndev_notifier_call(wlan0) state:4
[    6.694817] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.696487] RTW: cfg80211_rtw_scan(wlan0)
[    6.696754] RTW: SetHwReg8812A:(HW_VAR_CHECK_TXBUF)TXBUF Empty(1) in 0 ms
[    6.696880] RTW: wlan0 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
[    8.115039] r8168: eth0: link up
[    8.115104] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   10.732687] RTW: wlan0 wakeup m0=0x00000002, ori reg_0x4d4=0x00000002
[   10.732755] RTW: survey done event(17) band:0 for wlan0
[   10.732804] RTW: rtw_indicate_scan_done(wlan0)
[   10.741061] RTW: ==>rtw_ps_processor .fw_state(8)
[   10.741065] RTW: ==>ips_enter cnts:1
[   10.741067] RTW: nolinked power save enter
[   10.741069] RTW: ===> rtw_ips_pwr_down...................
[   10.741072] RTW: ====> rtw_ips_dev_unload...
[   10.751503] RTW: usb_read_port_cancel
[   10.751756] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[   10.752007] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[   10.752881] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[   10.753127] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[   10.753379] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[   10.753609] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[   10.753857] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[   10.754093] RTW: usb_read_port_complete() RX Warning! bDriverStopped(False) OR bSurpriseRemoved(False)
[   10.754105] RTW: usb_write_port_cancel
[   10.754131] RTW: ==> rtl8812au_hal_deinit
[   10.755756] RTW:  hal_poweroff_8812au
[   10.757674] RTW: =====> _8051Reset8812(): 8051 reset success .
[   10.760599] RTW: SetHwReg: bMacPwrCtrlOn=0
[   10.760828] RTW: <=== rtw_ips_pwr_down..................... in 20ms
[   11.634236] FAN rising trip_level:1 cur_temp:51750 trip_temps[2]:61000
[   34.161257] RTW: cfg80211_rtw_scan(wlan0)
[   34.161340] RTW: _rtw_pwr_wakeup call ips_leave....
[   34.161380] RTW: ==>ips_leave cnts:1
[   34.161407] RTW: ===>  rtw_ips_pwr_up..............
[   34.161487] RTW: ===> ips_netdrv_open.........
[   34.163626] RTW:  power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea.
[   34.163643] RTW:  MAC has not been powered on yet.
[   34.173568] RTW: SetHwReg: bMacPwrCtrlOn=1
[   34.340375] RTW: FirmwareDownload8812 fw source from Header
[   34.340426] RTW: FirmwareDownload8812 fw:NIC, size: 27030
[   34.340473] RTW: FirmwareDownload8812: fw_ver=52 fw_subver=14 sig=0x9501
[   34.410792] RTW: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00060705
[   34.411843] RTW: =====> _8051Reset8812(): 8051 reset success .
[   34.442167] RTW: _FWFreeToGo8812: Polling FW ready OK! (361, 28ms), REG_MCUFWDL:0x000607c6
[   34.442172] RTW: FWDL success. write_fw:1, 100ms
[   34.442740] RTW: rtl8812au_hal_init: Download Firmware Success!!
[   34.835496] RTW: rtl8812au_hal_init in 676ms
[   34.835504] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =60:23:a4:9a:c7:2b
[   34.835822] RTW: rtw_hal_set_macaddr_port (null)- hw port(1) mac_addr =62:23:a4:9a:c7:2b
[   34.836499] RTW: rtw_hal_get_macaddr_port wlan0- hw port(0) mac_addr =60:23:a4:9a:c7:2b
[   34.836503] RTW: wlan0- hw port(0) mac_addr =60:23:a4:9a:c7:2b
[   34.836821] RTW: rtw_hal_get_macaddr_port (null)- hw port(1) mac_addr =62:23:a4:9a:c7:2b
[   34.836824] RTW: (null)- hw port(1) mac_addr =62:23:a4:9a:c7:2b
[   34.836994] RTW: [HW_VAR_ENABLE_RX_BAR] 0x6A2=0x520
[   34.852627] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =60:23:a4:9a:c7:2b
[   34.853145] RTW: hw_var_set_opmode()-4318 mode = 2
[   34.853742] RTW: <===  rtw_ips_pwr_up.............. in 692ms
[   34.853745] RTW: nolinked power save leave
[   34.853868] RTW: ==> ips_leave.....LED(0x00022828)...
[   34.854133] RTW: SetHwReg8812A:(HW_VAR_CHECK_TXBUF)TXBUF Empty(1) in 0 ms
[   34.854327] RTW: wlan0 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
Please check product design guide:
https://developer.nvidia.com/embedded/dlc/jetson-nano-product-design-guide
And share which pins are user in your design.
For different USB lane mapping, you also need to check adaptation guide and modify device tree accordingly.
https://developer.nvidia.com/embedded/dlc/Tegra_Linux_Driver_Package_Nano_Adaptation_Guide
thank you
