The power on log message is as follow, it may be help.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-jeremy (jeremy@jeremy-VirtualBox) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Aug 6 14:57:56 CST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29476(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3573016K/4159488K available (14078K kernel code, 2460K rwdata, 5456K rodata, 7040K init, 601K bss, 111336K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008e40000 ( 14080 KB)
[ 0.000000] .rodata : 0xffffff8008e40000 - 0xffffff80093a0000 ( 5504 KB)
[ 0.000000] .init : 0xffffff80093a0000 - 0xffffff8009a80000 ( 7040 KB)
[ 0.000000] .data : 0xffffff8009a80000 - 0xffffff8009ce7008 ( 2461 KB)
[ 0.000000] .bss : 0xffffff8009ce7008 - 0xffffff8009d7d534 ( 602 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.009985] Console: colour dummy device 80x25
[ 0.014628] console [tty0] enabled
[ 0.018142] bootconsole [uart8250] disabled
[ 0.022466] kmemleak: Kernel memory leak detector disabled
[ 0.022492] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.022515] pid_max: default: 32768 minimum: 301
[ 0.022973] Security Framework initialized
[ 0.023200] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023215] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.024344] ftrace: allocating 42986 entries in 168 pages
[ 0.179227] sched-energy: CPU device node has no sched-energy-costs
[ 0.179262] ASID allocator initialised with 65536 entries
[ 0.215520] tegra-id: chipid=22117.
[ 0.215548] tegra-id: opt_subrevision=0.
[ 0.215571] Tegra Speedo/IDDQ fuse revision 4
[ 0.215580] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.215592] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.215603] Tegra: CPU Speedo Value 2069, SoC Speedo Value 1960, GPU Speedo Value 2074
[ 0.215615] Tegra: CPU IDDQ Value 2140, SoC IDDQ Value 2408, GPU IDDQ Value 2920
[ 0.215640] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.215660] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.215679] DTB Build time: Aug 10 2021 18:49:11
[ 0.265293] CPU1: Booted secondary processor [411fd071]
[ 0.297178] CPU2: Booted secondary processor [411fd071]
[ 0.329193] CPU3: Booted secondary processor [411fd071]
[ 0.329295] Brought up 4 CPUs
[ 0.329353] SMP: Total of 4 processors activated.
[ 0.329369] CPU features: detected feature: 32-bit EL0 Support
[ 0.329640] CPU: All CPU(s) started at EL2
[ 0.329669] alternatives: patching kernel code
[ 0.337661] devtmpfs: initialized
[ 0.376544] Initilizing CustomIPI irq domain
[ 0.376945] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.376985] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.387504] pinctrl core: initialized pinctrl subsystem
[ 0.388116] OS set in device tree is not L4T.
[ 0.388636] regulator-dummy: no parameters
[ 0.388932] Initializing plugin-manager
[ 0.389103] Plugin module not found
[ 0.389330] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.389837] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.390826] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.391047] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.391652] node /plugin-manager/fragement@10 match with board >=3448-0000-300
[ 0.393573] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[ 0.397155] NET: Registered protocol family 16
[ 0.403508] pstore: using zlib compression
[ 0.404009] console [pstore-1] enabled
[ 0.404025] pstore: Registered ramoops as persistent store backend
[ 0.404042] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.417306] cpuidle: using governor menu
[ 0.420662] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.422511] vdso: 2 pages (1 code @ ffffff8008e47000, 1 data @ ffffff8009a84000)
[ 0.422557] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.425709] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.428325] Serial: AMBA PL011 UART driver
[ 0.428847] tegra_powergate_init: DONE
[ 0.428878] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.428907] DTB Build time: Aug 10 2021 18:49:11
[ 0.431033] Tegra reboot handler registered.
[ 0.435643] iommu: Adding device tegra-carveouts to group 0
[ 0.435814] platform tegra-carveouts: domain=ffffffc0f945c3d8 allocates as[0]=ffffffc0f9be40a8
[ 0.436195] iommu: Adding device smmu_test to group 1
[ 0.436260] platform smmu_test: domain=ffffffc0f945c618 allocates as[0]=ffffffc0f9be4110
[ 0.437088] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.437164] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.437231] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.437252] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.437316] mc-err: mcerr ops are set to t21x
[ 0.447545] iommu: Adding device 70090000.xusb to group 2
[ 0.447875] iommu: Adding device 70006000.serial to group 3
[ 0.447954] platform 70006000.serial: domain=ffffffc0f9465cd8 allocates as[0]=ffffffc0f9be4178
[ 0.448391] iommu: Adding device 70006040.serial to group 4
[ 0.448673] iommu: Adding device 70006200.serial to group 5
[ 0.448877] iommu: Adding device sound to group 6
[ 0.448937] platform sound: domain=ffffffc0f94de258 allocates as[0]=ffffffc0f9be41e0
[ 0.449543] iommu: Adding device 7000d400.spi to group 7
[ 0.449822] iommu: Adding device 7000d600.spi to group 8
[ 0.450136] iommu: Adding device 70410000.spi to group 9
[ 0.450445] iommu: Adding device 50000000.host1x to group 10
[ 0.450726] iommu: Adding device 54080000.vi to group 11
[ 0.451121] iommu: Adding device 54600000.isp to group 12
[ 0.451386] iommu: Adding device 54680000.isp to group 13
[ 0.451677] iommu: Adding device tegradc.0 to group 14
[ 0.451740] platform tegradc.0: domain=ffffffc0f94eb198 allocates as[0]=ffffffc0f9be4248
[ 0.452276] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.452610] iommu: Adding device tegradc.1 to group 15
[ 0.452676] platform tegradc.1: domain=ffffffc0f94eb3d8 allocates as[0]=ffffffc0f9be42b0
[ 0.453200] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.453506] iommu: Adding device 54340000.vic to group 16
[ 0.453724] iommu: Adding device 544c0000.nvenc to group 17
[ 0.453947] iommu: Adding device 54500000.tsec to group 18
[ 0.454147] iommu: Adding device 54100000.tsecb to group 19
[ 0.454349] iommu: Adding device 54480000.nvdec to group 20
[ 0.454547] iommu: Adding device 54380000.nvjpg to group 21
[ 0.455589] iommu: Adding device 546c0000.i2c to group 22
[ 0.455934] iommu: Adding device 57000000.gpu to group 23
[ 0.456002] platform 57000000.gpu: domain=ffffffc0f954b3d8 allocates as[0]=ffffffc0f9be4318
[ 0.456076] platform 57000000.gpu: domain=ffffffc0f954b3d8 allocates as[1]=ffffffc0f9be4380
[ 0.456134] platform 57000000.gpu: domain=ffffffc0f954b3d8 allocates as[2]=ffffffc0f9be43e8
[ 0.456185] platform 57000000.gpu: domain=ffffffc0f954b3d8 allocates as[3]=ffffffc0f9be4450
[ 0.457057] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.457093] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.457119] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.457137] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.457154] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.509490] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509519] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509553] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509628] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509948] iommu: Adding device 70012000.se to group 24
[ 0.510709] iommu: Adding device 7000c000.i2c to group 25
[ 0.510970] iommu: Adding device 7000c400.i2c to group 26
[ 0.511239] iommu: Adding device 7000c500.i2c to group 27
[ 0.511494] iommu: Adding device 7000c700.i2c to group 28
[ 0.511755] iommu: Adding device 7000d000.i2c to group 29
[ 0.512007] iommu: Adding device 7000d100.i2c to group 30
[ 0.512301] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.512373] platform sdhci-tegra.0: domain=ffffffc0f958f558 allocates as[0]=ffffffc0f9be44b8
[ 0.513215] iommu: Adding device 700d0000.xudc to group 32
[ 0.516349] vdd-ac-bat: 5000 mV
[ 0.516710] vdd-5v0-sys: 5000 mV
[ 0.517695] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.517755] vdd-5v0-hdmi: 5000 mV
[ 0.518160] vdd-1v8-sys: 1800 mV
[ 0.518603] vdd-fan: supplied by vdd-5v0-sys
[ 0.518656] vdd-fan: 5000 mV
[ 0.519041] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.519086] vdd-usb-vbus: 5000 mV
[ 0.519610] vdd-usb-vbus2: 5000 mV
[ 0.550308] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.553229] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.554355] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.554392] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.554441] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.554842] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.562586] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.562972] SCSI subsystem initialized
[ 0.563216] libata version 3.00 loaded.
[ 0.563512] usbcore: registered new interface driver usbfs
[ 0.563582] usbcore: registered new interface driver hub
[ 0.563672] usbcore: registered new device driver usb
[ 0.567602] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.573493] random: fast init done
[ 0.573531] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.574530] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.576487] vdd-ddr-1v1: 1150 mV
[ 0.581302] vdd-pre-reg-1v35: 1350 mV
[ 0.584478] vdd-1v8: 1800 mV
[ 0.588470] avdd-sys-1v2: 1200 mV
[ 0.592477] vdd-pex-1v0: 1050 mV
[ 0.593127] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.593673] max77620-ldo3: at 3100 mV
[ 0.596475] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.597029] max77620-ldo5: at 3100 mV
[ 0.600475] vddio-sdmmc3-ap: 1800 <–> 3300 mV at 2800 mV
[ 0.604472] avdd-1v05-pll: 1050 mV
[ 0.608473] avdd-io-hdmi-dp: 1050 mV
[ 0.610955] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.611276] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.611583] max77620 4-003c: max77620 probe successful
[ 0.614247] media: Linux media interface: v0.10
[ 0.614326] Linux video capture interface: v2.00
[ 0.615192] pps_core: LinuxPPS API ver. 1 registered
[ 0.615217] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.615257] PTP clock support registered
[ 0.618534] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.621690] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.621735] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.621796] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.621824] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.625372] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.626704] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.626821] vdd-3v3-sys: 3300 mV
[ 0.627113] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.628562] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629067] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.629123] vdd-3v3-sd: 3300 mV
[ 0.630051] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.630107] avdd-io-edp-1v05: 1050 mV
[ 0.630540] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.630593] vdd-usb-hub-en: 5000 mV
[ 0.631948] camchar: rtcpu character device driver loaded
[ 0.632803] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.634054] clocksource: Switched to clocksource arch_sys_counter
[ 0.669050] VFS: Disk quotas dquot_6.6.0
[ 0.669212] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.669739] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.670187] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.670232] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.670511] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.670538] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.670570] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.670629] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.670656] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.670687] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.670708] nvmap_page_pool_init: Total RAM pages: 1012038
[ 0.670725] nvmap_page_pool_init: nvmap page pool size: 126504 pages (494 MB)
[ 0.670915] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.671254] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.672152] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.680439] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.680934] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.681324] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.681629] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.681829] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.682150] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.682172] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.682624] NET: Registered protocol family 2
[ 0.683669] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.683905] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.684414] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.684577] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.684672] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.685098] NET: Registered protocol family 1
[ 0.685752] RPC: Registered named UNIX socket transport module.
[ 0.685776] RPC: Registered udp transport module.
[ 0.685791] RPC: Registered tcp transport module.
[ 0.685805] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.685829] PCI: CLS 0 bytes, default 64
[ 0.686098] Trying to unpack rootfs image as initramfs…
[ 0.994275] Freeing initrd memory: 6992K
[ 1.004120] host1x 50000000.host1x: initialized
[ 1.005814] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.009051] audit: initializing netlink subsys (disabled)
[ 1.009167] audit: type=2000 audit(0.863:1): initialized
[ 1.009924] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.019806] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.021288] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.025133] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.025301] io scheduler noop registered
[ 1.025602] io scheduler cfq registered (default)
[ 1.028306] gic 702f9000.agic: GIC IRQ controller registered
[ 1.031294] iommu: Adding device 702ef000.adsp to group 33
[ 1.040203] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.040368] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.040949] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9acac15
[ 1.040980] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.043240] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.043375] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.043498] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.043707] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.043823] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.043932] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.044037] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.044138] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.044243] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.044342] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.050440] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.052201] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.054182] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.055483] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.055835] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.057037] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.057281] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.057576] Adding domain tsec-pd to PM domain host1x-pd
[ 1.059772] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.060731] tsec 54500000.tsec: initialized
[ 1.062313] tsec 54100000.tsecb: initialized
[ 1.063049] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.066684] nvdec 54480000.nvdec: initialized
[ 1.067782] Adding domain vic03-pd to PM domain host1x-pd
[ 1.067988] Adding domain msenc-pd to PM domain host1x-pd
[ 1.068165] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.072479] falcon 54340000.vic: initialized
[ 1.073781] falcon 544c0000.nvenc: initialized
[ 1.075166] falcon 54380000.nvjpg: initialized
[ 1.079547] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.079625] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.079669] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.079676] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.079773] display board info: id 0x0, fab 0x0
[ 1.079845] generic_infoframe_type: 0x87
[ 1.079974] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.079994] tegra_cec 70015000.tegra_cec: probed
[ 1.080001] tegradc tegradc.0: DT parsed successfully
[ 1.080046] tegradc tegradc.0: Display dc.ffffff800a740000 registered with id=0
[ 1.083770] tegradc tegradc.0: probed
[ 1.084509] Console: switching to colour frame buffer device 80x30
[ 1.084559] tegradc tegradc.0: fb registered
[ 1.085765] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.085872] tegradc tegradc.1: No lt-data, using default setting
[ 1.085913] tegradc tegradc.1: No hpd-gpio in DT
[ 1.085955] tegradc tegradc.1: DT parsed successfully
[ 1.086014] tegradc tegradc.1: Display dc.ffffff800a8c0000 registered with id=1
[ 1.087648] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.088090] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.593361] Host read timeout at address 545c00c4
[ 1.594722] tegradc tegradc.1: probed
[ 1.595131] tegradc tegradc.1: fb registered
[ 1.596108] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.596878] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.596901] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.597208] kfuse 7000fc00.kfuse: initialized
[ 1.598126] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.598480] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.598500] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.598538] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.598562] tegradc tegradc.1: blank - powerdown
[ 1.598593] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.598608] Extcon DP: HPD disabled
[ 1.598619] hpd: hpd_switch 0
[ 1.598630] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.598650] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.598666] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.599018] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.599936] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.599960] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.600342] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.601564] vdd-gpu: applied init 1000000uV constraint
[ 1.601583] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.601936] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.605372] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.605482] No Device Node present for smmu client: serial8250 !!
[ 1.605502] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.605558] iommu: Adding device serial8250 to group 35
[ 1.607799] console [ttyS0] disabled
[ 1.607893] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.985632] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.098086] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.098091] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.388994] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.793361] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.795380] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.901599] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.901608] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.901614] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.901619] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.901624] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.901668] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.901776] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.902019] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.902218] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.902246] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.902279] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.902302] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.902458] pci 0000:01:00.0: supports D1 D2
[ 2.902461] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.910156] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.910204] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.910209] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.910219] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.910240] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.910258] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.910269] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.910274] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.910281] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.910687] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.910693] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.910700] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.910837] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 4.103364] console [ttyS0] enabled
[ 4.108091] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 4.117276] serial-tegra 70006200.serial: RX in PIO mode
[ 4.122714] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 4.132611] [drm] Initialized
[ 4.146125] brd: module loaded
[ 4.154515] loop: module loaded
[ 4.157779] tegra_profiler: version: 1.143, samples/io: 48/28
[ 4.163703] tegra_profiler: auth: init
[ 4.168943] THERMAL EST: found 2 subdevs
[ 4.172911] THERMAL EST num_resources: 0
[ 4.176956] [THERMAL EST subdev 0]
[ 4.180372] [THERMAL EST subdev 1]
[ 4.184224] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 4.193193] THERMAL EST: thz register success.
[ 4.197837] THERMAL EST: end of probe, return err: 0
[ 4.203977] sd: No Scsi addr parsed to reserve index
[ 4.209002] hisi_sas: driver version v1.6
[ 4.217684] tegra-qspi 70410000.spi: Prod settings list not found
[ 4.224906] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 4.230332] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 4.245203] libphy: Fixed MDIO Bus: probed
[ 4.250144] tun: Universal TUN/TAP device driver, 1.6
[ 4.255221] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.262450] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.268304] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.274299] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.281267] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.286898] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.294731] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.300741] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.307709] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.313944] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 4.319833] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 4.339871] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 4.352256] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:3c:b4:61 from device tree
[ 4.364735] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 4.376178] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 4.407518] PPP generic driver version 2.4.2
[ 4.411996] PPP BSD Compression module registered
[ 4.416717] PPP Deflate Compression module registered
[ 4.421806] PPP MPPE Compression module registered
[ 4.426612] NET: Registered protocol family 24
[ 4.431135] usbcore: registered new interface driver r8152
[ 4.436680] usbcore: registered new interface driver asix
[ 4.442135] usbcore: registered new interface driver ax88179_178a
[ 4.448272] usbcore: registered new interface driver cdc_ether
[ 4.454147] usbcore: registered new interface driver net1080
[ 4.459854] usbcore: registered new interface driver cdc_subset
[ 4.465813] usbcore: registered new interface driver zaurus
[ 4.471452] usbcore: registered new interface driver cdc_ncm
[ 4.477286] VFIO - User Level meta-driver version: 0.3
[ 4.483651] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.490212] ehci-pci: EHCI PCI platform driver
[ 4.494711] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.500904] ohci-pci: OHCI PCI platform driver
[ 4.505401] ohci-platform: OHCI generic platform driver
[ 4.513209] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 4.519597] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 4.527998] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f90da400 id
[ 4.536465] usbcore: registered new interface driver uas
[ 4.541841] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 4.541892] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 4.541922] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 4.542704] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 4.542769] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 4.543039] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.543045] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.543049] usb usb1: Product: xHCI Host Controller
[ 4.543053] usb usb1: Manufacturer: Linux 4.9.201-wtoe xhci-hcd
[ 4.543057] usb usb1: SerialNumber: 70090000.xusb
[ 4.543682] hub 1-0:1.0: USB hub found
[ 4.543723] hub 1-0:1.0: 5 ports detected
[ 4.544248] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 4.544260] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 4.544332] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.544425] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.544431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.544435] usb usb2: Product: xHCI Host Controller
[ 4.544438] usb usb2: Manufacturer: Linux 4.9.201-wtoe xhci-hcd
[ 4.544442] usb usb2: SerialNumber: 70090000.xusb
[ 4.544862] hub 2-0:1.0: USB hub found
[ 4.544893] hub 2-0:1.0: 4 ports detected
[ 4.545607] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 4.545612] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 4.646318] usb usb1: usb_suspend_both: status 0
[ 4.646468] usb usb2: usb_suspend_both: status 0
[ 4.697144] usbcore: registered new interface driver usb-storage
[ 4.703287] usbcore: registered new interface driver usbserial
[ 4.711250] mousedev: PS/2 mouse device common for all mice
[ 4.716928] usbcore: registered new interface driver xpad
[ 4.853439] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.863321] rtc rtc1: alarm rtc device
[ 4.867112] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 4.874285] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 4.881070] i2c /dev entries driver
[ 4.886403] i2c i2c-6: Added multiplexed i2c bus 7
[ 4.891578] i2c i2c-6: Added multiplexed i2c bus 8
[ 4.896392] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 4.904268] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.933547] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 4.940178] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.947782] imx219 7-0010: board setup failed
[ 4.952220] imx219: probe of 7-0010 failed with error -121
[ 4.958295] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.987498] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 4.994169] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 5.001717] imx219 8-0010: board setup failed
[ 5.006151] imx219: probe of 8-0010 failed with error -121
[ 5.012871] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 5.022209] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 5.029278] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 5.036668] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.046013] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 5.054989] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 5.064015] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.073340] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 5.082305] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 5.091330] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.100646] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 5.109611] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 5.117653] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 5.125485] tegra_aotag tegra-aotag: Registering sensor 0
[ 5.130999] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 5.136248] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 5.142769] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.152099] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 5.160334] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 5.169113] parse_throttle_dt_data: Num cap clks = 6
[ 5.174098] parse_throttle_dt_data: clk=cclk_g type=2
[ 5.179165] parse_throttle_dt_data: clk=gpu type=4
[ 5.183989] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 5.190105] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 5.196227] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 5.202236] parse_throttle_dt_data: clk=emc type=3
[ 5.207414] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.216832] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.226288] tegra_throttle_probe: probe successful. #cdevs=4
[ 5.232699] FAN dev name: pwm-fan
[ 5.236111] FAN:gpio request success.
[ 5.239851] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 5.245842] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 5.252638] pwm_fan_driver pwm-fan: fan tach request irq success
[ 5.258667] pwm_fan_driver pwm-fan: tach period: 1000
[ 5.263816] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 5.271400] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 5.279147] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 5.286982] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 5.294814] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 5.302649] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 5.310481] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 5.318315] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 5.326147] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 5.334067] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 5.344564] device-mapper: uevent: version 1.0.3
[ 5.349684] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 5.363638] tegra210-cpufreq cpufreq: probe()…completed
[ 5.369811] sdhci: Secure Digital Host Controller Interface driver
[ 5.375998] sdhci: Copyright(c) Pierre Ossman
[ 5.380356] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.386508] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 5.391656] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 5.398914] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 5.409702] tegra-se 70012000.se: tegra_se_probe: complete
[ 5.415687] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.422185] usbcore: registered new interface driver usbhid
[ 5.427764] usbhid: USB HID core driver
[ 5.433666] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 5.440246] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 5.450160] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 5.450441] nvpmodel: initialized successfully
[ 5.450916] u32 classifier
[ 5.450917] Actions configured
[ 5.450990] Initializing XFRM netlink socket
[ 5.451686] NET: Registered protocol family 10
[ 5.452404] NET: Registered protocol family 17
[ 5.452414] NET: Registered protocol family 15
[ 5.452486] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.452494] Key type dns_resolver registered
[ 5.459455] Registered cp15_barrier emulation handler
[ 5.459512] Registered setend emulation handler
[ 5.460559] registered taskstats version 1
[ 5.461103] Adding domain ve2-pd to PM domain host1x-pd
[ 5.461338] Adding domain ve-pd to PM domain host1x-pd
[ 5.463402] isp 54600000.isp: initialized
[ 5.464311] isp 54680000.isp: initialized
[ 5.474286] last reset is due to software reset
[ 5.474289] KERNEL: PMC reset status reg: 0x3
[ 5.474348] BL: PMC reset status reg: 0x3
[ 5.474350] BL: PMIC poweroff Event Recorder: 0x0
[ 5.475760] clk_cbus_recalc_rate: no gbus parent
[ 5.475764] clk_cbus_round_rate: no gbus parent
[ 5.475766] clk_cbus_round_rate: no gbus parent
[ 5.475773] clk_cbus_recalc_rate: no gbus parent
[ 5.475875] clk_cbus_recalc_rate: no gbus parent
[ 5.475877] clk_cbus_round_rate: no gbus parent
[ 5.475879] clk_cbus_round_rate: no gbus parent
[ 5.475882] clk_cbus_recalc_rate: no gbus parent
[ 5.475895] tegra_dvfs: GPU-cap: registered
[ 5.475952] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 5.475954] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 5.475956] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 5.477336] tegra_dvfs: vdd-gpu-vts: registered
[ 5.478022] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 5.478653] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 5.479121] input: gpio-keys as /devices/gpio-keys/input/input0
[ 5.514772] tegra_rtc 7000e000.rtc: setting system clock to 2021-08-20 06:08:57 UTC (1629439737)
[ 5.515757] vi 54080000.vi: vi_probe: ++
[ 5.518388] vi 54080000.vi: initialized
[ 5.520417] vi 54080000.vi: subdev nvcsi–2 bound
[ 5.520518] vi 54080000.vi: subdev nvcsi–1 bound
[ 5.521248] Disable partitions left on by BL
[ 5.521250] disb
[ 5.521390] bwmgr: missing cdev-type property
[ 5.521489] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.521494] DRAM derating cdev registered.
[ 5.703019] Freeing unused kernel memory: 7040K
[ 5.731620] Root device found: mmcblk0p1
[ 5.897019] mmc0: Applying tuning correction
[ 5.901294] mmc0: Tap value after applying correction 58
[ 5.906607] mmc0: hw tuning done …
[ 5.910237] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 5.917266] mmcblk0: mmc0:aaaa SD64G 59.5 GiB
[ 5.927141] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 5.940435] Found dev node: /dev/mmcblk0p1
[ 6.009728] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.019680] Rootfs mounted over mmcblk0p1
[ 6.044390] Switching from initrd to actual rootfs
[ 6.244920] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.262166] cgroup: cgroup2: unknown option “nsdelegate”
[ 6.283182] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.305334] systemd[1]: Detected architecture arm64.
[ 6.333532] systemd[1]: Set hostname to .
[ 6.462882] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.480298] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.577745] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.584472] systemd[1]: Reached target Remote File Systems.
[ 6.590383] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.597139] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.605194] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.612267] systemd[1]: Created slice User and Session Slice.
[ 6.618254] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.625978] systemd[1]: Reached target Local Encrypted Volumes.
[ 6.670800] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.776850] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 6.795154] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 6.804826] cpu-throttle-alert cooling device registered.
[ 6.810730] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 6.820171] gpu-throttle-alert cooling device registered.
[ 6.825859] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 6.835235] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 6.835257] hot-surface-alert cooling device registered.
[ 6.875050] systemd-journald[1779]: Received request to flush runtime journal from PID 1
[ 7.022118] tegra-xusb 70090000.xusb: entering ELPG
[ 7.023200] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 7.023390] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 7.025973] tegra-xusb 70090000.xusb: entering ELPG done
[ 7.515741] eth0: 0xffffff8009f4c000, 48:b0:2d:3c:b4:61, IRQ 406
[ 7.567024] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.967940] zram: Added device: zram0
[ 8.968350] zram: Added device: zram1
[ 8.972977] zram: Added device: zram2
[ 8.973502] zram: Added device: zram3
[ 8.994423] zram0: detected capacity change from 0 to 519962624
[ 9.614121] r8168: eth0: link up
[ 9.614166] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.371890] tegra-xusb 70090000.xusb: exiting ELPG
[ 11.373413] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 11.378052] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 11.378829] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 11.379013] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 11.379191] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 11.379816] tegra-xusb 70090000.xusb: exiting ELPG done
[ 11.606561] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 11.637175] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 11.637181] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.637184] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 11.637187] usb 1-2: Manufacturer: Generic
[ 11.639520] hub 1-2:1.0: USB hub found
[ 11.640110] hub 1-2:1.0: 4 ports detected
[ 11.746991] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 11.762302] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 11.777140] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 11.777166] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.777183] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 11.777198] usb 2-1: Manufacturer: Generic
[ 11.781873] hub 2-1:1.0: USB hub found
[ 11.782125] usb 1-2: usb_suspend_both: status 0
[ 11.782215] usb usb1: usb_suspend_both: status 0
[ 11.782672] hub 2-1:1.0: 4 ports detected
[ 11.942526] usb 2-1: usb_suspend_both: status 0
[ 11.943419] usb usb2: usb_suspend_both: status 0
[ 12.982671] usb 2-1: USB disconnect, device number 2
[ 12.990029] usb usb2: usb_suspend_both: status 0
[ 13.050570] usb 1-2: USB disconnect, device number 2
[ 13.055825] usb usb1: usb_suspend_both: status 0
[ 13.934699] tegra-xusb 70090000.xusb: entering ELPG
[ 13.936105] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 13.936774] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 13.946700] tegra-xusb 70090000.xusb: entering ELPG done
[ 16.164489] tegra-xusb 70090000.xusb: exiting ELPG
[ 16.166042] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 16.170842] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 16.171201] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 16.171273] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 16.171349] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 16.171880] tegra-xusb 70090000.xusb: exiting ELPG done
[ 16.398602] usb 1-2: new high-speed USB device number 3 using tegra-xusb
[ 16.472064] usb 1-2: Device not responding to setup address.
[ 16.686352] tegra-xusb 70090000.xusb: ERROR: unexpected setup address command completion code 0x11.
[ 16.902300] usb 1-2: device not accepting address 3, error -22
[ 17.653265] usb usb2: usb_suspend_both: status 0
[ 18.662272] usb 1-2: new high-speed USB device number 4 using tegra-xusb
[ 18.695577] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 18.695640] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 18.695684] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 18.695726] usb 1-2: Manufacturer: Generic
[ 18.706507] hub 1-2:1.0: USB hub found
[ 18.707115] hub 1-2:1.0: 4 ports detected
[ 18.807472] usb 2-1: new SuperSpeed USB device number 4 using tegra-xusb
[ 18.830321] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 18.838585] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 18.838653] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 18.838703] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 18.838747] usb 2-1: Manufacturer: Generic
[ 18.845329] hub 2-1:1.0: USB hub found
[ 18.846118] hub 2-1:1.0: 4 ports detected
[ 18.850076] usb 1-2: usb_suspend_both: status 0
[ 18.850172] usb usb1: usb_suspend_both: status 0
[ 19.006241] usb 2-1: usb_suspend_both: status 0
[ 19.007041] usb usb2: usb_suspend_both: status 0
[ 19.007150] tegra-xusb 70090000.xusb: entering ELPG
[ 19.008497] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 19.009086] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 19.012491] tegra-xusb 70090000.xusb: entering ELPG done
[ 19.531280] tegra-xusb 70090000.xusb: exiting ELPG
[ 19.532874] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 19.537566] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 19.538331] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 19.538514] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 19.538692] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 19.5[ 114.324917] usb 2-1: can’t set config #1, error -71
39475] tegra-xusb 70090000.xusb: exiting ELPG done
[ 20.046160] usb 2-1: USB disconnect, device number 4
[ 20.047478] usb usb2: usb_suspend_both: status 0
[ 20.743095] usb 1-2: reset high-speed USB device number 4 using tegra-xusb
[ 20.887467] usb 2-1: new SuperSpeed USB device number 5 using tegra-xusb
[ 20.902599] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 20.922231] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 20.922282] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 20.922320] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 20.922359] usb 2-1: Manufacturer: Generic
[ 20.923674] usb 1-2: usb_suspend_both: status 0
[ 20.924074] usb usb1: usb_suspend_both: status 0
[ 20.932349] hub 2-1:1.0: USB hub found
[ 20.933129] hub 2-1:1.0: 4 ports detected
[ 21.090586] usb 2-1: usb_suspend_both: status 0
[ 21.091394] usb usb2: usb_suspend_both: status 0
[ 22.126756] tegra-xusb 70090000.xusb: entering ELPG
[ 22.128092] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 22.128666] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 22.131877] tegra-xusb 70090000.xusb: entering ELPG done
[ 22.159889] tegra-xusb 70090000.xusb: exiting ELPG
[ 22.161410] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 22.166329] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 22.166890] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 22.167075] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 22.167254] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 22.168027] tegra-xusb 70090000.xusb: exiting ELPG done
[ 23.106929] usb 2-1: USB disconnect, device number 5
[ 23.115734] usb usb2: usb_suspend_both: status 0
