The kenel message is as following:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (wujz@thinkstation-p328) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #7 SMP PREEMPT Mon Apr 19 15:42:53 HKT 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92cb5000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu @ffffffc0fefa6000 s59608 r8192 d30504 u98304
[ 0.000000] pcpu-alloc: s59608 r8192 d30504 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb5000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29248(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3572760K/4159488K available (14590K kernel code, 2622K rwdata, 6248K rodata, 6208K init, 608K bss, 111592K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ec0000 ( 14592 KB)
[ 0.000000] .rodata : 0xffffff8008ec0000 - 0xffffff80094e0000 ( 6272 KB)
[ 0.000000] .init : 0xffffff80094e0000 - 0xffffff8009af0000 ( 6208 KB)
[ 0.000000] .data : 0xffffff8009af0000 - 0xffffff8009d7f808 ( 2623 KB)
[ 0.000000] .bss : 0xffffff8009d7f808 - 0xffffff8009e17aa4 ( 609 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001573] Console: colour dummy device 80x25
[ 0.001582] console [tty0] enabled
[ 0.001589] bootconsole [uart8250] disabled
[ 0.001621] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001634] pid_max: default: 32768 minimum: 301
[ 0.001748] Security Framework initialized
[ 0.001794] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.001800] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002673] ftrace: allocating 45815 entries in 179 pages
[ 0.167949] knl–>in start_kernel
[ 0.168024] knl–>val1 = 0x4AC11902
[ 0.168035] knl–>val2 = 0x190101
[ 0.168607] sched-energy: CPU device node has no sched-energy-costs
[ 0.168630] ASID allocator initialised with 65536 entries
[ 0.207658] tegra-id: chipid=22117.
[ 0.207670] tegra-id: opt_subrevision=0.
[ 0.207687] Tegra Speedo/IDDQ fuse revision 4
[ 0.207691] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.207695] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.207701] Tegra: CPU Speedo Value 2062, SoC Speedo Value 1953, GPU Speedo Value 2051
[ 0.207705] Tegra: CPU IDDQ Value 1804, SoC IDDQ Value 1884, GPU IDDQ Value 2260
[ 0.207725] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.207743] DTS File Name: /home/jiang/nvidia/cinderella_nano_source/kernel_src_32.4.4/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.207750] DTB Build time: Feb 5 2021 17:47:29
[ 0.244808] CPU1: Booted secondary processor [411fd071]
[ 0.272708] CPU2: Booted secondary processor [411fd071]
[ 0.300685] CPU3: Booted secondary processor [411fd071]
[ 0.300769] Brought up 4 CPUs
[ 0.300775] SMP: Total of 4 processors activated.
[ 0.300782] CPU features: detected feature: 32-bit EL0 Support
[ 0.301038] CPU: All CPU(s) started at EL2
[ 0.301053] alternatives: patching kernel code
[ 0.309155] devtmpfs: initialized
[ 0.346735] Initilizing CustomIPI irq domain
[ 0.347109] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.347130] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.357540] pinctrl core: initialized pinctrl subsystem
[ 0.358130] OS set in device tree is not L4T.
[ 0.358522] regulator-dummy: no parameters
[ 0.358789] Initializing plugin-manager
[ 0.358944] Plugin module not found
[ 0.359135] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.359645] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.360079] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.360664] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.361076] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.361659] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[ 0.363560] node /plugin-manager/fragement@13 match with board >=3448-0002-300
[ 0.367079] NET: Registered protocol family 16
[ 0.368379] pstore: using zlib compression
[ 0.368457] console [pstore-1] enabled
[ 0.368462] pstore: Registered ramoops as persistent store backend
[ 0.368467] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.384823] cpuidle: using governor menu
[ 0.389356] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.391046] vdso: 2 pages (1 code @ ffffff8008ec6000, 1 data @ ffffff8009af4000)
[ 0.393304] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.396161] tegra_powergate_init: DONE
[ 0.396179] DTS File Name: /home/jiang/nvidia/cinderella_nano_source/kernel_src_32.4.4/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.396185] DTB Build time: Feb 5 2021 17:47:29
[ 0.398102] Tegra reboot handler registered.
[ 0.402679] iommu: Adding device tegra-carveouts to group 0
[ 0.402808] platform tegra-carveouts: domain=ffffffc0f942d318 allocates as[0]=ffffffc0f94280a8
[ 0.403149] iommu: Adding device smmu_test to group 1
[ 0.403193] platform smmu_test: domain=ffffffc0f942d558 allocates as[0]=ffffffc0f9428110
[ 0.403961] mc: mapped MMIO address: 0xffffff8008043000 → 0x70019000
[ 0.404016] mc: mapped MMIO address: 0xffffff8008069000 → 0x7001c000
[ 0.404075] mc: mapped MMIO address: 0xffffff800807d000 → 0x7001d000
[ 0.404083] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.404106] mc-err: mcerr ops are set to t21x
[ 0.413809] iommu: Adding device 70090000.xusb to group 2
[ 0.414085] iommu: Adding device 70006000.serial to group 3
[ 0.414153] platform 70006000.serial: domain=ffffffc0f9455618 allocates as[0]=ffffffc0f9428178
[ 0.414546] iommu: Adding device 70006040.serial to group 4
[ 0.414810] iommu: Adding device 70006200.serial to group 5
[ 0.415029] iommu: Adding device sound to group 6
[ 0.415076] platform sound: domain=ffffffc0f9455b58 allocates as[0]=ffffffc0f94281e0
[ 0.415597] iommu: Adding device 7000d400.spi to group 7
[ 0.415855] iommu: Adding device 7000d600.spi to group 8
[ 0.416182] iommu: Adding device 50000000.host1x to group 9
[ 0.416454] iommu: Adding device 54080000.vi to group 10
[ 0.416935] iommu: Adding device 54600000.isp to group 11
[ 0.417194] iommu: Adding device 54680000.isp to group 12
[ 0.417461] iommu: Adding device tegradc.0 to group 13
[ 0.417536] platform tegradc.0: domain=ffffffc0f94c6918 allocates as[0]=ffffffc0f9428248
[ 0.418913] platform tegradc.0: IOVA linear map 0x0000000092cb5000(140000)
[ 0.419304] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.419624] iommu: Adding device tegradc.1 to group 14
[ 0.419672] platform tegradc.1: domain=ffffffc0f94c6b58 allocates as[0]=ffffffc0f94282b0
[ 0.421062] platform tegradc.1: IOVA linear map 0x0000000092cb5000(140000)
[ 0.421450] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.421678] iommu: Adding device 54340000.vic to group 15
[ 0.421872] iommu: Adding device 544c0000.nvenc to group 16
[ 0.422069] iommu: Adding device 54500000.tsec to group 17
[ 0.422265] iommu: Adding device 54100000.tsecb to group 18
[ 0.422458] iommu: Adding device 54480000.nvdec to group 19
[ 0.422642] iommu: Adding device 54380000.nvjpg to group 20
[ 0.423693] iommu: Adding device 546c0000.i2c to group 21
[ 0.424028] iommu: Adding device 57000000.gpu to group 22
[ 0.424074] platform 57000000.gpu: domain=ffffffc0f94d2b58 allocates as[0]=ffffffc0f9428318
[ 0.424109] platform 57000000.gpu: domain=ffffffc0f94d2b58 allocates as[1]=ffffffc0f9428380
[ 0.424148] platform 57000000.gpu: domain=ffffffc0f94d2b58 allocates as[2]=ffffffc0f94283e8
[ 0.424186] platform 57000000.gpu: domain=ffffffc0f94d2b58 allocates as[3]=ffffffc0f9428450
[ 0.425064] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.425073] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.425085] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.425089] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.425093] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.425096] rock.pmc–>PMC reset source: TEGRA_POWER_ON_RESET
[ 0.425099] rock.pmc–>PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.425102] rock.pmc–>PMC reset status reg: 0x0
[ 0.476863] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.476870] tegra-pmc: Clear bootloader IO dpd settings
[ 0.476890] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.476948] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.477244] iommu: Adding device 70012000.se to group 23
[ 0.478006] iommu: Adding device 7000c000.i2c to group 24
[ 0.478267] iommu: Adding device 7000c400.i2c to group 25
[ 0.478507] iommu: Adding device 7000c500.i2c to group 26
[ 0.478754] iommu: Adding device 7000c700.i2c to group 27
[ 0.478998] iommu: Adding device 7000d000.i2c to group 28
[ 0.479271] iommu: Adding device 7000d100.i2c to group 29
[ 0.479529] iommu: Adding device sdhci-tegra.3 to group 30
[ 0.479584] platform sdhci-tegra.3: domain=ffffffc0f9582cd8 allocates as[0]=ffffffc0f94284b8
[ 0.479990] iommu: Adding device sdhci-tegra.2 to group 31
[ 0.480037] platform sdhci-tegra.2: domain=ffffffc0f9582f18 allocates as[0]=ffffffc0f9428520
[ 0.480873] iommu: Adding device 700d0000.xudc to group 32
[ 0.484201] vdd-ac-bat: 5000 mV
[ 0.484553] vdd-5v0-sys: 5000 mV
[ 0.485574] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.485616] vdd-5v0-hdmi: 5000 mV
[ 0.486009] vdd-1v8-sys: 1800 mV
[ 0.486400] vdd-fan: supplied by vdd-5v0-sys
[ 0.486436] vdd-fan: 5000 mV
[ 0.486867] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.486902] vdd-usb-vbus: 5000 mV
[ 0.487428] vdd-usb-vbus2: 5000 mV
[ 0.504438] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.506619] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.507743] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.507763] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.507794] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.508141] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.516655] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.516960] SCSI subsystem initialized
[ 0.517204] libata version 3.00 loaded.
[ 0.517491] usbcore: registered new interface driver usbfs
[ 0.517612] usbcore: registered new interface driver hub
[ 0.517695] usbcore: registered new device driver usb
[ 0.522447] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.529050] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.530150] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.530601] random: fast init done
[ 0.532831] vdd-ddr-1v1: 1150 mV
[ 0.536941] vdd-pre-reg-1v35: 1350 mV
[ 0.540823] vdd-1v8: 1800 mV
[ 0.544869] avdd-sys-1v2: 1200 mV
[ 0.548186] vdd-pex-1v0: 1050 mV
[ 0.548853] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.549409] max77620-ldo3: at 3100 mV
[ 0.552192] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.552744] max77620-ldo5: at 3100 mV
[ 0.556187] vddio-sdmmc3-ap: 1800 <–> 3300 mV at 2800 mV
[ 0.560186] avdd-1v05-pll: 1050 mV
[ 0.564182] avdd-io-hdmi-dp: 1050 mV
[ 0.566834] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.567110] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.567392] max77620 4-003c: max77620 probe successful
[ 0.570161] media: Linux media interface: v0.10
[ 0.570222] Linux video capture interface: v2.00
[ 0.571144] pps_core: LinuxPPS API ver. 1 registered
[ 0.571151] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.571173] PTP clock support registered
[ 0.575265] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.581681] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.582513] Advanced Linux Sound Architecture Driver Initialized.
[ 0.584901] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.584917] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.584960] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.584973] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.588254] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.589416] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.589477] vdd-3v3-sys: 3300 mV
[ 0.589746] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.592257] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.592716] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.592753] vdd-3v3-sd: 3300 mV
[ 0.593833] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.593874] avdd-io-edp-1v05: 1050 mV
[ 0.594327] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.594362] vdd-usb-hub-en: 5000 mV
[ 0.595795] camchar: rtcpu character device driver loaded
[ 0.596476] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.597913] clocksource: Switched to clocksource arch_sys_counter
[ 0.631838] VFS: Disk quotas dquot_6.6.0
[ 0.631915] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.632288] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.632695] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.632712] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.632922] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.632927] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.632940] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.632964] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.632970] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.632982] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.632991] nvmap_page_pool_init: Total RAM pages: 1011974
[ 0.632997] nvmap_page_pool_init: nvmap page pool size: 126496 pages (494 MB)
[ 0.633080] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.633564] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.634499] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.642718] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.643159] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.643517] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.643791] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.643973] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.644245] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.644249] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.644393] NET: Registered protocol family 2
[ 0.645005] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.645215] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.645714] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.645857] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.646008] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.646267] NET: Registered protocol family 1
[ 0.646798] RPC: Registered named UNIX socket transport module.
[ 0.646803] RPC: Registered udp transport module.
[ 0.646807] RPC: Registered tcp transport module.
[ 0.646810] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.646823] PCI: CLS 0 bytes, default 64
[ 0.647085] Trying to unpack rootfs image as initramfs…
[ 0.877155] Freeing initrd memory: 5356K
[ 0.887117] host1x 50000000.host1x: initialized
[ 0.891427] audit: initializing netlink subsys (disabled)
[ 0.891499] audit: type=2000 audit(0.747:1): initialized
[ 0.891838] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.900269] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.901127] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.901537] 9p: Installing v9fs 9p2000 file system support
[ 0.904556] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.904701] io scheduler noop registered
[ 0.904844] io scheduler cfq registered (default)
[ 0.907177] gic 702f9000.agic: GIC IRQ controller registered
[ 0.910158] iommu: Adding device 702ef000.adsp to group 33
[ 0.919040] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.919185] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.919780] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7227c10
[ 0.919789] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.921408] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.921508] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.921608] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.921791] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.921883] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.922389] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.922481] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.922567] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.922672] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.922769] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.928935] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.930706] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.931563] knl–>in tegra_pcie_probe
[ 0.932579] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.933780] knl–>in pcie_delayed_detect
[ 0.933784] knl–>in tegra_pcie_probe_complete
[ 0.933788] knl–>in tegra_pcie_init
[ 0.933854] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.934255] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.935476] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.935692] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.935938] Adding domain tsec-pd to PM domain host1x-pd
[ 0.938392] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.939279] tsec 54500000.tsec: initialized
[ 0.940852] tsec 54100000.tsecb: initialized
[ 0.941562] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.945074] nvdec 54480000.nvdec: initialized
[ 0.946220] Adding domain vic03-pd to PM domain host1x-pd
[ 0.946403] Adding domain msenc-pd to PM domain host1x-pd
[ 0.946559] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.950883] falcon 54340000.vic: initialized
[ 0.952111] falcon 544c0000.nvenc: initialized
[ 0.953383] falcon 54380000.nvjpg: initialized
[ 0.958171] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.958265] display board info: id 0x0, fab 0x0
[ 0.958330] generic_infoframe_type: 0x87
[ 0.958468] tegradc tegradc.0: DT parsed successfully
[ 0.958516] tegradc tegradc.0: Display dc.ffffff800a7c0000 registered with id=0
[ 0.959237] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[ 0.962346] tegradc tegradc.0: probed
[ 0.966101] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.972965] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 0.973872] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 0.973881] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.974307] kfuse 7000fc00.kfuse: initialized
[ 0.975772] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.976798] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.978291] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.978306] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.978794] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.980388] vdd-gpu: applied init 1000000uV constraint
[ 0.980395] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 0.980791] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.984829] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.984937] No Device Node present for smmu client: serial8250 !!
[ 0.984946] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.984983] iommu: Adding device serial8250 to group 35
[ 0.987394] console [ttyS0] disabled
[ 0.987489] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 0.997813] console [ttyS0] enabled
[ 0.998211] Console: switching to colour frame buffer device 80x30
[ 0.998253] tegradc tegradc.0: fb registered
[ 0.999424] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 0.999973] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.001428] knl–>request ok, gpio = 66
[ 1.001451] knl–>request ok, gpio = 62
[ 1.001464] knl–>request ok, gpio = 16
[ 1.001474] knl–>request ok, gpio = 17
[ 1.001485] knl–>request ok, gpio = 18
[ 1.001495] knl–>request ok, gpio = 19
[ 1.001739] knl–>name = gpio_lcd, index = 66, val = 1
[ 1.001747] knl–>name = gpio_usb, index = 62, val = 1
[ 1.001754] knl–>name = gpio_wifi, index = 19, val = 0
[ 1.001761] knl–>name = gpio_4g_power_ctl, index = 16, val = 1
[ 1.001794] knl–>name = gpio_4g_reset, index = 18, val = 0
[ 1.001800] knl–>name = gpio_4g_power_on, index = 17, val = 0
[ 1.006054] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.006100] tegradc tegradc.0: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[ 1.006584] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.006596] tegradc tegradc.0: hdmi: BL set VIC 0
[ 1.006602] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.007066] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.007072] Extcon AUX1(HDMI) enable
[ 1.007936] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.008011] tegradc tegradc.1: No lt-data, using default setting
[ 1.008038] tegradc tegradc.1: No hpd-gpio in DT
[ 1.008070] tegradc tegradc.1: DT parsed successfully
[ 1.008116] tegradc tegradc.1: Display dc.ffffff800d140000 registered with id=1
[ 1.009464] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.019201] tegradc tegradc.1: probed
[ 1.019525] tegradc tegradc.1: fb registered
[ 1.021951] knl–>name = gpio_4g_power_on, index = 17, val = 1
[ 1.021958] knl–>queue_delayed_work for module_4g
[ 1.022064] knl–>in roborock_version_init
[ 1.022719] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.022727] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.022737] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.022750] tegradc tegradc.1: blank - powerdown
[ 1.022769] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.022775] Extcon DP: HPD disabled
[ 1.022778] hpd: hpd_switch 0
[ 1.022782] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.022790] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.022797] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.022899] knl–>in roborock_version_probe
[ 1.022978] [drm] Initialized
[ 1.042550] brd: module loaded
[ 1.046349] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 1.051519] loop: module loaded
[ 1.051589] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.051678] tegra_profiler: auth: init
[ 1.052274] THERMAL EST: found 2 subdevs
[ 1.052280] THERMAL EST num_resources: 0
[ 1.052285] [THERMAL EST subdev 0]
[ 1.052292] [THERMAL EST subdev 1]
[ 1.052613] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.052616] THERMAL EST: thz register success.
[ 1.052712] THERMAL EST: end of probe, return err: 0
[ 1.053254] sd: No Scsi addr parsed to reserve index
[ 1.053279] hisi_sas: driver version v1.6
[ 1.061865] libphy: Fixed MDIO Bus: probed
[ 1.062418] tun: Universal TUN/TAP device driver, 1.6
[ 1.062422] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.063097] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.063101] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.063146] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.063149] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.063187] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.063191] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.063230] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.063233] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.063977] PPP generic driver version 2.4.2
[ 1.064099] PPP BSD Compression module registered
[ 1.064103] PPP Deflate Compression module registered
[ 1.064118] PPP MPPE Compression module registered
[ 1.064122] NET: Registered protocol family 24
[ 1.064170] usbcore: registered new interface driver r8152
[ 1.064211] usbcore: registered new interface driver asix
[ 1.064244] usbcore: registered new interface driver ax88179_178a
[ 1.064275] usbcore: registered new interface driver cdc_ether
[ 1.064307] usbcore: registered new interface driver net1080
[ 1.064339] usbcore: registered new interface driver cdc_subset
[ 1.064372] usbcore: registered new interface driver zaurus
[ 1.064408] usbcore: registered new interface driver simcom_wwan
[ 1.064446] usbcore: registered new interface driver cdc_ncm
[ 1.064563] VFIO - User Level meta-driver version: 0.3
[ 1.065233] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.065243] ehci-pci: EHCI PCI platform driver
[ 1.065280] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.065288] ohci-pci: OHCI PCI platform driver
[ 1.065322] ohci-platform: OHCI generic platform driver
[ 1.067269] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.067807] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.068850] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f943b400 id
[ 1.069861] usbcore: registered new interface driver uas
[ 1.069936] usbcore: registered new interface driver usb-storage
[ 1.070012] usbcore: registered new interface driver usbserial
[ 1.070045] usbcore: registered new interface driver option
[ 1.070075] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.073004] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.073931] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.073961] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.073979] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.074684] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.074717] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.074900] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.074906] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.074912] usb usb1: Product: xHCI Host Controller
[ 1.074916] usb usb1: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.074920] usb usb1: SerialNumber: 70090000.xusb
[ 1.075316] hub 1-0:1.0: USB hub found
[ 1.075352] hub 1-0:1.0: 5 ports detected
[ 1.075830] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.075842] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.075913] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.076002] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.076008] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.076012] usb usb2: Product: xHCI Host Controller
[ 1.076017] usb usb2: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.076021] usb usb2: SerialNumber: 70090000.xusb
[ 1.076366] hub 2-0:1.0: USB hub found
[ 1.076397] hub 2-0:1.0: 4 ports detected
[ 1.076645] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.076656] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.076677] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.076925] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.077391] mousedev: PS/2 mouse device common for all mice
[ 1.077451] usbcore: registered new interface driver xpad
[ 1.077514] cyttsp5_i2c_probe, 137
[ 1.081040] cyttsp5_i2c_adapter 0-0024: cyttsp5_init: INIT CYTTSP RST gpio=194 and IRQ gpio=224 r=0
[ 1.081372] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 1.081479] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 1.081514] cyttsp5_i2c_adapter 0-0024: cyttsp5_get_hid_descriptor_: failed to get HID descriptor length and version, rc=-121
[ 1.092836] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Error on getting HID descriptor r=-121
[ 1.101745] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 1.110062] tegradc tegradc.0: blank - powerdown
[ 1.150100] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.150103] Extcon AUX1(HDMI) disable
[ 1.178032] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.181790] tegradc tegradc.0: unblank
[ 1.201926] cyttsp5_i2c_adapter 0-0024: cyttsp5_xres: RESET CYTTSP gpio=194 r=0
[ 1.224501] tegradc tegradc.0: nominal-pclk:69300000 parent:69300000 div:1.0 pclk:69300000 68607000~75537000
[ 1.224584] tegradc tegradc.0: hdmi: tmds rate:69300K prod-setting:prod_c_hdmi_54m_75m
[ 1.242512] tegradc tegradc.0: sync windows ret = 246
[ 1.264570] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.264574] Extcon HDMI: HPD enabled
[ 1.264594] tegradc tegradc.0: hdmi: plugged
[ 1.370869] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.401916] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.430528] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.430534] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.430539] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.430544] usb 1-2: Manufacturer: Generic
[ 1.431856] hub 1-2:1.0: USB hub found
[ 1.432439] hub 1-2:1.0: 4 ports detected
[ 1.721917] usb 1-2.4: new high-speed USB device number 3 using tegra-xusb
[ 1.742487] usb 1-2.4: New USB device found, idVendor=0bda, idProduct=c811
[ 1.742494] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.742498] usb 1-2.4: Product: 802.11ac NIC
[ 1.742503] usb 1-2.4: Manufacturer: Realtek
[ 1.742507] usb 1-2.4: SerialNumber: 123456
[ 1.775061] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.837913] knl–>in module_4g_delayed_work_func
[ 1.837919] knl–>name = gpio_4g_power_on, index = 17, val = 0
[ 2.179294] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.181312] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.287029] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.287037] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.287042] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.287047] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.287053] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.287080] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.287157] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.287353] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.287488] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.287515] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.287548] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 2.287571] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 2.287712] pci 0000:01:00.0: supports D1 D2
[ 2.287717] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.297964] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.297998] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 2.298005] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.298014] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[ 2.298035] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[ 2.298054] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.298064] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.298070] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.298078] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[ 2.298300] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.298305] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.298311] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.298413] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.298565] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.298585] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.319739] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.319806] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e9:c5:3f from device tree
[ 2.320245] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.320262] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 5.234275] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.234281] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.562306] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.590358] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.590364] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.590369] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.590373] usb 2-1: Manufacturer: Generic
[ 5.594118] hub 2-1:1.0: USB hub found
[ 5.594897] hub 2-1:1.0: 4 ports detected
[ 5.745918] usb 2-1: usb_suspend_both: status 0
[ 5.746053] usb usb2: usb_suspend_both: status 0
[ 6.253924] cyttsp5_i2c_adapter 0-0024: cyttsp5_reset_and_wait: reset timed out
[ 6.261311] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Error on h/w reset r=-62
[ 6.269037] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 6.369922] cyttsp5_i2c_adapter 0-0024: cyttsp5_xres: RESET CYTTSP gpio=194 r=0
[ 6.391495] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 6.653922] usb 1-3: new high-speed USB device number 4 using tegra-xusb
[ 6.687960] usb 1-3: New USB device found, idVendor=1e0e, idProduct=9001
[ 6.687967] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.687972] usb 1-3: Product: SimTech, Incorporated
[ 6.687977] usb 1-3: Manufacturer: SimTech, Incorporated
[ 6.687982] usb 1-3: SerialNumber: 0123456789ABCDEF
[ 6.691083] simcom_wwan: probe of 1-3:1.0 failed with error -22
[ 6.691239] option 1-3:1.0: GSM modem (1-port) converter detected
[ 6.691442] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB0
[ 6.691567] simcom_wwan: probe of 1-3:1.1 failed with error -22
[ 6.691716] option 1-3:1.1: GSM modem (1-port) converter detected
[ 6.691898] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB1
[ 6.692163] simcom_wwan: probe of 1-3:1.2 failed with error -22
[ 6.692310] option 1-3:1.2: GSM modem (1-port) converter detected
[ 6.692489] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB2
[ 6.692743] simcom_wwan: probe of 1-3:1.3 failed with error -22
[ 6.692888] option 1-3:1.3: GSM modem (1-port) converter detected
[ 6.693066] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB3
[ 6.693320] simcom_wwan: probe of 1-3:1.4 failed with error -22
[ 6.693459] option 1-3:1.4: GSM modem (1-port) converter detected
[ 6.693643] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB4
[ 6.694863] simcom usbnet bind here
[ 6.695980] simcom_wwan 1-3:1.5 wwan0: register ‘simcom_wwan’ at usb-70090000.xusb-3, SIMCOM wwan/QMI device, 2a:d9:9b:99:4e:de
[ 11.373922] cyttsp5_i2c_adapter 0-0024: cyttsp5_reset_and_wait: reset timed out
[ 11.381404] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Error on h/w reset r=-62
[ 11.389129] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 11.489921] cyttsp5_i2c_adapter 0-0024: cyttsp5_xres: RESET CYTTSP gpio=194 r=0
[ 14.618384] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 2
[ 14.618408] usb 1-3: USB disconnect, device number 4
[ 14.618739] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 14.618769] option 1-3:1.0: device disconnected
[ 14.619097] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 14.619134] option 1-3:1.1: device disconnected
[ 14.619448] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 14.619474] option 1-3:1.2: device disconnected
[ 14.619788] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 14.619816] option 1-3:1.3: device disconnected
[ 14.620127] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
[ 14.620155] option 1-3:1.4: device disconnected
[ 14.620315] simcom_wwan 1-3:1.5 wwan0: unregister ‘simcom_wwan’ usb-70090000.xusb-3, SIMCOM wwan/QMI device
[ 14.638705] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 14.901919] usb 1-3: new high-speed USB device number 5 using tegra-xusb
[ 14.935975] usb 1-3: New USB device found, idVendor=1e0e, idProduct=9001
[ 14.935982] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 14.935987] usb 1-3: Product: SimTech, Incorporated
[ 14.935992] usb 1-3: Manufacturer: SimTech, Incorporated
[ 14.935996] usb 1-3: SerialNumber: 0123456789ABCDEF
[ 14.939069] simcom_wwan: probe of 1-3:1.0 failed with error -22
[ 14.939224] option 1-3:1.0: GSM modem (1-port) converter detected
[ 14.939407] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB0
[ 14.939527] simcom_wwan: probe of 1-3:1.1 failed with error -22
[ 14.939674] option 1-3:1.1: GSM modem (1-port) converter detected
[ 14.939847] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB1
[ 14.940094] simcom_wwan: probe of 1-3:1.2 failed with error -22
[ 14.940247] option 1-3:1.2: GSM modem (1-port) converter detected
[ 14.940414] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB2
[ 14.940665] simcom_wwan: probe of 1-3:1.3 failed with error -22
[ 14.940812] option 1-3:1.3: GSM modem (1-port) converter detected
[ 14.940977] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB3
[ 14.941222] simcom_wwan: probe of 1-3:1.4 failed with error -22
[ 14.941375] option 1-3:1.4: GSM modem (1-port) converter detected
[ 14.941549] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB4
[ 14.942640] simcom usbnet bind here
[ 14.943790] simcom_wwan 1-3:1.5 wwan0: register ‘simcom_wwan’ at usb-70090000.xusb-3, SIMCOM wwan/QMI device, 2a:d9:9b:99:4e:de
[ 16.493923] cyttsp5_i2c_adapter 0-0024: cyttsp5_reset_and_wait: reset timed out
[ 16.501439] cyttsp5_i2c_adapter 0-0024: cyttsp5_startup_: Error on h/w reset r=-62
[ 16.509164] tegra-i2c 7000c000.i2c: no acknowledge from address 0x24
[ 16.509194] cyttsp5_i2c_adapter 0-0024: cyttsp5_hid_exec_cmd_: Fail cyttsp5_adap_transfer
[ 16.517578] cyttsp5_i2c_adapter 0-0024: cyttsp5_hid_cmd_set_power_: Failed to set power to state:1
[ 16.526619] cyttsp5_i2c_adapter 0-0024: cyttsp5_core_rt_suspend: Error on sleep
[ 16.534124] cyttsp5_i2c_adapter 0-0024: cyttsp5_probe: Fail initial startup r=-19
[ 16.541781] cyttsp5_i2c_adapter 0-0024: cyttsp5_init: INIT CYTTSP RST gpio=194 and IRQ gpio=224 r=0
[ 16.541787] cyttsp5_i2c_adapter 0-0024: cyttsp5_probe failed.
[ 16.547705] cyttsp5_debug_init: Parade TTSP Debug Driver (Built TTDA.03.08.874312) rc=0
[ 16.547710] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 16.547715] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 16.675129] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 16.677322] rtc rtc1: alarm rtc device
[ 16.677335] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 16.677353] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 16.677790] i2c /dev entries driver
[ 16.679297] i2c i2c-6: Added multiplexed i2c bus 7
[ 16.679613] i2c i2c-6: Added multiplexed i2c bus 8
[ 16.679619] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 16.680295] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 16.682258] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 16.682265] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 16.682561] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.682574] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 16.682581] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 16.682705] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.682715] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 16.682722] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 16.682867] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.682876] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 16.682881] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 16.683074] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 16.683614] tegra_aotag tegra-aotag: Registering sensor 0
[ 16.683660] tegra_aotag tegra-aotag: Invalid temp readout
[ 16.683681] tegra_aotag tegra-aotag: Invalid temp readout
[ 16.683698] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 16.683707] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 16.684618] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.684634] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 16.684820] tegra_aotag tegra-aotag: Invalid temp readout
[ 16.684843] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 16.685285] parse_throttle_dt_data: Num cap clks = 6
[ 16.685291] parse_throttle_dt_data: clk=cclk_g type=2
[ 16.685299] parse_throttle_dt_data: clk=gpu type=4
[ 16.685319] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 16.685336] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 16.685356] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 16.685360] parse_throttle_dt_data: clk=emc type=3
[ 16.685718] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.685842] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.685973] tegra_throttle_probe: probe successful. #cdevs=4
[ 16.686565] FAN dev name: pwm-fan
[ 16.686604] FAN:gpio request success.
[ 16.686654] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 16.686875] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 16.686983] pwm_fan_driver pwm-fan: fan tach request irq success
[ 16.686991] pwm_fan_driver pwm-fan: tach period: 1000
[ 16.687063] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 16.687069] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 16.687074] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 16.687079] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 16.687084] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 16.687089] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 16.687093] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 16.687098] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 16.687103] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 16.687108] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 16.687731] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 16.687980] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 16.687984] rock.watchdog–>initialized ok, timeout = 120 sec, nowayout = 1
[ 16.688478] device-mapper: uevent: version 1.0.3
[ 16.688781] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 16.691474] tegra210-cpufreq cpufreq: probe()…completed
[ 16.692188] sdhci: Secure Digital Host Controller Interface driver
[ 16.692191] sdhci: Copyright(c) Pierre Ossman
[ 16.692193] sdhci-pltfm: SDHCI platform and OF driver helper
[ 16.692542] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 16.697204] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[ 16.701478] tegra-se 70012000.se: tegra_se_probe: complete
[ 16.702027] hidraw: raw HID events driver (C) Jiri Kosina
[ 16.703176] usbcore: registered new interface driver usbhid
[ 16.703180] usbhid: USB HID core driver
[ 16.705285] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 16.705452] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 16.707152] nvpmodel: initialized successfully
[ 16.708149] usbcore: registered new interface driver snd-usb-audio
[ 16.708206] No Device Node present for smmu client: snd-soc-dummy !!
[ 16.708212] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 16.708231] iommu: Adding device snd-soc-dummy to group 36
[ 16.709086] rock.sndcard–>in tas5805m_i2c_probe
[ 16.709375] tegra-i2c 7000c500.i2c: no acknowledge from address 0x2d
[ 16.709405] tas5805m 2-002d: Failed to initialize TAS5805M: -121, tas5805m_init_sequence_1
[ 16.717863] rock.sndcard–>Failed to initialize TAS5805M: -121, tas5805m_init_sequence_1
[ 16.717922] FAN rising trip_level:1 cur_temp:39000 trip_temps[2]:51000
[ 16.717960] tas5805m: probe of 2-002d failed with error -121
[ 16.718957] u32 classifier
[ 16.718959] Actions configured
[ 16.719028] Initializing XFRM netlink socket
[ 16.719335] NET: Registered protocol family 10
[ 16.719889] NET: Registered protocol family 17
[ 16.719901] NET: Registered protocol family 15
[ 16.719916] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 16.719934] 9pnet: Installing 9P2000 support
[ 16.719967] Key type dns_resolver registered
[ 16.721513] Registered cp15_barrier emulation handler
[ 16.721522] Registered setend emulation handler
[ 16.722600] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 16.723188] registered taskstats version 1
[ 16.723757] Adding domain ve2-pd to PM domain host1x-pd
[ 16.723994] Adding domain ve-pd to PM domain host1x-pd
[ 16.726199] isp 54600000.isp: initialized
[ 16.727148] isp 54680000.isp: initialized
[ 16.734000] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 16.736980] last reset is due to power on reset
[ 16.736985] KERNEL: PMC reset status reg: 0x0
[ 16.737047] BL: PMC reset status reg: 0x0
[ 16.737049] BL: PMIC poweroff Event Recorder: 0x40
[ 16.738582] clk_cbus_recalc_rate: no gbus parent
[ 16.738589] clk_cbus_round_rate: no gbus parent
[ 16.738591] clk_cbus_round_rate: no gbus parent
[ 16.738599] clk_cbus_recalc_rate: no gbus parent
[ 16.738690] clk_cbus_recalc_rate: no gbus parent
[ 16.738694] clk_cbus_round_rate: no gbus parent
[ 16.738696] clk_cbus_round_rate: no gbus parent
[ 16.738700] clk_cbus_recalc_rate: no gbus parent
[ 16.739365] tegra_dvfs: GPU-cap: registered
[ 16.739419] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 16.739422] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 16.739424] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 16.740789] tegra_dvfs: vdd-gpu-vts: registered
[ 16.741469] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 16.741934] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 16.742144] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 16.742644] input: gpio-keys as /devices/gpio-keys/input/input1
[ 16.776055] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:03:43 UTC (946688623)
[ 16.777101] vi 54080000.vi: vi_probe: ++
[ 16.779707] vi 54080000.vi: initialized
[ 16.781801] vi 54080000.vi: subdev nvcsi–2 bound
[ 16.782023] vi 54080000.vi: subdev nvcsi–1 bound
[ 16.783647] Disable partitions left on by BL
[ 16.783651] disb
[ 16.783697] bwmgr: missing cdev-type property
[ 16.783789] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.783796] DRAM derating cdev registered.
[ 16.784813] vdd-fan: disabling
[ 16.784816] vdd-usb-vbus: disabling
[ 16.784819] vdd-usb-vbus2: disabling
[ 16.784827] vddio-sdmmc-ap: disabling
[ 16.784915] vdd-3v3-sd: disabling
[ 16.784920] avdd-io-edp-1v05: disabling
[ 16.784923] vdd-usb-hub-en: disabling
[ 16.785003] ALSA device list:
[ 16.785006] #0: tegra-hda at 0x70038000 irq 82
[ 16.785789] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 16.786299] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 16.787189] Freeing unused kernel memory: 6208K
[ 16.790530] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 16.790711] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 16.795184] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 16.799695] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26
[ 16.819488] Root device found: mmcblk0p1
[ 16.820552] Found dev node: /dev/mmcblk0p1
[ 16.943762] EXT4-fs (mmcblk0p1): recovery complete
[ 16.944560] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 16.945314] Rootfs mounted over mmcblk0p1
[ 16.956525] Switching from initrd to actual rootfs
[ 17.034966] systemd[1]: System time before build time, advancing clock.
[ 17.049361] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 17.060482] cgroup: cgroup2: unknown option “nsdelegate”
[ 17.074527] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 17.075290] systemd[1]: Detected architecture arm64.
[ 17.095871] systemd[1]: Set hostname to .
[ 17.187435] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 17.187445] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 17.272547] random: systemd: uninitialized urandom read (16 bytes read)
[ 17.272762] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 17.272862] random: systemd: uninitialized urandom read (16 bytes read)
[ 17.273297] systemd[1]: Created slice System Slice.
[ 17.273354] random: systemd: uninitialized urandom read (16 bytes read)
[ 17.273472] systemd[1]: Listening on udev Kernel Socket.
[ 17.273626] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 17.273762] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 17.311118] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 17.365038] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 17.522095] systemd-journald[1923]: Received request to flush runtime journal from PID 1
[ 18.231232] random: crng init done
[ 18.234670] random: 7 urandom warning(s) missed due to ratelimiting
[ 18.346040] usbcore: registered new interface driver rtl8821cu
[ 18.755093] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[ 18.766399] EXT4-fs (mmcblk0p6): mounted filesystem without journal. Opts: (null)
[ 18.767030] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 18.776672] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 18.781781] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 18.802424] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
[ 18.853743] eth0: 0xffffff800a4b5000, 00:04:4b:e9:c5:3f, IRQ 406
[ 18.961114] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 19.325996] using random self ethernet address
[ 19.331792] using random host ethernet address
[ 19.707775] Mass Storage Function, version: 2009/09/11
[ 19.707781] LUN: removable file: (no medium)
[ 19.722332] using random self ethernet address
[ 19.722334] using random host ethernet address
[ 19.895983] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.200097] tegradc tegradc.0: nominal-pclk:69300000 parent:69300000 div:1.0 pclk:69300000 68607000~75537000
[ 20.200147] tegradc tegradc.0: blank - normal
[ 20.708747] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 20.713599] tegradc tegradc.0: unblank
[ 20.716933] tegradc tegradc.0: sync windows ret = 249
[ 20.726964] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.804920] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 21.643323] rock.uart–>in tegra_set_baudrate
[ 21.643329] rock.uart–>baudrate_set = 115200
[ 21.643331] rock.uart–>clkrate_set = 1861632
[ 21.643341] rock.uart–>clkrate_cfg = 1858770
[ 21.643343] rock.uart–>baudrate_cfg = 116173
[ 21.643347] rock.uart–>out tegra_set_baudrate
[ 21.643383] rock.uart–>in tegra_uart_set_termios
[ 21.643386] rock.uart–>uart: 1
[ 21.643416] rock.uart–>in tegra_set_baudrate
[ 21.643417] rock.uart–>baudrate_set = 9600
[ 21.643419] rock.uart–>clkrate_set = 153600
[ 21.643426] rock.uart–>clkrate_cfg = 153586
[ 21.643428] rock.uart–>baudrate_cfg = 9599
[ 21.645103] zram: Added device: zram0
[ 21.645519] rock.uart–>out tegra_set_baudrate
[ 21.647280] rock.uart–>in tegra_set_baudrate
[ 21.647285] rock.uart–>baudrate_set = 115200
[ 21.647287] rock.uart–>clkrate_set = 1861632
[ 21.647297] rock.uart–>clkrate_cfg = 1858770
[ 21.647299] rock.uart–>baudrate_cfg = 116173
[ 21.647476] rock.uart–>out tegra_set_baudrate
[ 21.647499] rock.uart–>in tegra_uart_set_termios
[ 21.647502] rock.uart–>uart: 1
[ 21.647506] rock.uart–>in tegra_set_baudrate
[ 21.647508] rock.uart–>baudrate_set = 9600
[ 21.647510] rock.uart–>clkrate_set = 153600
[ 21.647516] rock.uart–>clkrate_cfg = 153586
[ 21.647518] rock.uart–>baudrate_cfg = 9599
[ 21.649606] rock.uart–>out tegra_set_baudrate
[ 21.649732] rock.uart–>in tegra_uart_set_termios
[ 21.649735] rock.uart–>uart: 1
[ 21.649740] rock.uart–>in tegra_set_baudrate
[ 21.649742] rock.uart–>baudrate_set = 115200
[ 21.649744] rock.uart–>clkrate_set = 1861632
[ 21.649752] rock.uart–>clkrate_cfg = 1858770
[ 21.649753] rock.uart–>baudrate_cfg = 116173
[ 21.650009] rock.uart–>out tegra_set_baudrate
[ 21.652656] zram: Added device: zram1
[ 21.658560] zram: Added device: zram2
[ 21.664059] zram: Added device: zram3
[ 21.681254] zram0: detected capacity change from 0 to 519610368
[ 21.725412] Adding 507428k swap on /dev/zram0. Priority:5 extents:1 across:507428k SS
[ 21.730746] zram1: detected capacity change from 0 to 519610368
[ 21.756767] Adding 507428k swap on /dev/zram1. Priority:5 extents:1 across:507428k SS
[ 21.766640] zram2: detected capacity change from 0 to 519610368
[ 21.789494] Adding 507428k swap on /dev/zram2. Priority:5 extents:1 across:507428k SS
[ 21.794641] zram3: detected capacity change from 0 to 519610368
[ 21.808519] Adding 507428k swap on /dev/zram3. Priority:5 extents:1 across:507428k SS
[ 22.034429] r8168: eth0: link up
[ 22.034574] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 48.954254] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
