Ir read from thread about problems with Intel 9260 and that there was a fix already scheduled, but I’m not skilled enough to test this kernel fix out myself.
Here is what problems I’m having with Intel 7265
lspci -vnn
00:01.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:0fae] (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 84
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: 13000000-130fffff
Capabilities: <access denied>
Kernel driver in use: pcieport
00:02.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:0faf] (rev a1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 13100000-131fffff
01:00.0 Network controller [0280]: Intel Corporation Wireless 7265 [8086:095a] (rev ff) (prog-if ff)
!!! Unknown header type 7f
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller [10ec:8168]
Flags: bus master, fast devsel, latency 0, IRQ 404
I/O ports at 1000
Memory at 13104000 (64-bit, non-prefetchable)
Memory at 13100000 (64-bit, non-prefetchable)
Kernel driver in use: r8168
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3531) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb6000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc0fefd2000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb6000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29384(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3567872K/4159488K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 116480K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] boot misc1 0x90000000: expected 0x10000000
[ 0.000000] (comparison mask = 0xf8000000)
[ 0.000000] boot misc2 0x0: expected 0xf6e0f620
[ 0.000000] (comparison mask = 0xffffffff)
[ 0.000000] boot misc3 0xf5c1: expected 0x10000
[ 0.000000] PLL_D2 already enabled. Postponing set full defaults
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001505] Console: colour dummy device 80x25
[ 0.002447] console [tty0] enabled
[ 0.002471] kmemleak: Kernel memory leak detector disabled
[ 0.002499] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002528] pid_max: default: 32768 minimum: 301
[ 0.002989] Security Framework initialized
[ 0.003221] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003242] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004501] ftrace: allocating 46802 entries in 183 pages
[ 0.175413] sched-energy: CPU device node has no sched-energy-costs
[ 0.175446] ASID allocator initialised with 65536 entries
[ 0.211658] tegra-id: chipid=22117.
[ 0.211702] tegra-id: opt_subrevision=0.
[ 0.211731] Tegra Speedo/IDDQ fuse revision 4
[ 0.211746] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211762] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.211778] Tegra: CPU Speedo Value 2033, SoC Speedo Value 1933, GPU Speedo Value 2045
[ 0.211799] Tegra: CPU IDDQ Value 1792, SoC IDDQ Value 2152, GPU IDDQ Value 2625
[ 0.211836] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.211862] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.211897] DTB Build time: Mar 15 2019 09:52:07
[ 0.261101] CPU1: Booted secondary processor [411fd071]
[ 0.292989] CPU2: Booted secondary processor [411fd071]
[ 0.324983] CPU3: Booted secondary processor [411fd071]
[ 0.325081] Brought up 4 CPUs
[ 0.325145] SMP: Total of 4 processors activated.
[ 0.325162] CPU features: detected feature: 32-bit EL0 Support
[ 0.325439] CPU: All CPU(s) started at EL2
[ 0.325469] alternatives: patching kernel code
[ 0.333775] devtmpfs: initialized
[ 0.368775] Initilizing CustomIPI irq domain
[ 0.369215] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.369266] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.380674] pinctrl core: initialized pinctrl subsystem
[ 0.381415] OS set in device tree is not L4T.
[ 0.381858] regulator-dummy: no parameters
[ 0.382154] Initializing plugin-manager
[ 0.382324] Plugin module not found
[ 0.382542] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.383083] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.383850] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.387231] NET: Registered protocol family 16
[ 0.392762] pstore: using zlib compression
[ 0.393476] console [pstore-1] enabled
[ 0.393493] pstore: Registered ramoops as persistent store backend
[ 0.393511] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.413119] cpuidle: using governor menu
[ 0.417201] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.418755] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.418798] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421690] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.423284] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.424249] tegra_powergate_init: DONE
[ 0.424289] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.424328] DTB Build time: Mar 15 2019 09:52:07
[ 0.426017] Tegra reboot handler registered.
[ 0.430485] iommu: Adding device tegra-carveouts to group 0
[ 0.430664] platform tegra-carveouts: domain=ffffffc0f940c318 allocates as[0]=ffffffc0f94040a8
[ 0.431047] iommu: Adding device smmu_test to group 1
[ 0.431119] platform smmu_test: domain=ffffffc0f940c558 allocates as[0]=ffffffc0f9404110
[ 0.431967] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.432046] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.432124] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.432147] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.432183] mc-err: mcerr ops are set to t21x
[ 0.441774] iommu: Adding device 70090000.xusb to group 2
[ 0.442117] iommu: Adding device 70006000.serial to group 3
[ 0.442201] platform 70006000.serial: domain=ffffffc0f9b9dc18 allocates as[0]=ffffffc0f9404178
[ 0.442636] iommu: Adding device 70006040.serial to group 4
[ 0.442905] iommu: Adding device 70006200.serial to group 5
[ 0.443107] iommu: Adding device sound to group 6
[ 0.443210] platform sound: domain=ffffffc0f94b1198 allocates as[0]=ffffffc0f94041e0
[ 0.443787] iommu: Adding device 7000d400.spi to group 7
[ 0.444076] iommu: Adding device 7000d600.spi to group 8
[ 0.444390] iommu: Adding device 70410000.spi to group 9
[ 0.444710] iommu: Adding device 50000000.host1x to group 10
[ 0.445030] iommu: Adding device 54080000.vi to group 11
[ 0.445480] iommu: Adding device 54600000.isp to group 12
[ 0.445760] iommu: Adding device 54680000.isp to group 13
[ 0.446052] iommu: Adding device tegradc.0 to group 14
[ 0.446121] platform tegradc.0: domain=ffffffc0f94bf0d8 allocates as[0]=ffffffc0f9404248
[ 0.450337] platform tegradc.0: IOVA linear map 0x0000000092cb6000(800000)
[ 0.450750] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.451122] iommu: Adding device tegradc.1 to group 15
[ 0.451190] platform tegradc.1: domain=ffffffc0f94bf318 allocates as[0]=ffffffc0f94042b0
[ 0.455359] platform tegradc.1: IOVA linear map 0x0000000092cb6000(800000)
[ 0.455770] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.456066] iommu: Adding device 54340000.vic to group 16
[ 0.456283] iommu: Adding device 544c0000.nvenc to group 17
[ 0.456497] iommu: Adding device 54500000.tsec to group 18
[ 0.456709] iommu: Adding device 54100000.tsecb to group 19
[ 0.456927] iommu: Adding device 54480000.nvdec to group 20
[ 0.457167] iommu: Adding device 54380000.nvjpg to group 21
[ 0.458241] iommu: Adding device 546c0000.i2c to group 22
[ 0.458599] iommu: Adding device 57000000.gpu to group 23
[ 0.458672] platform 57000000.gpu: domain=ffffffc0f955a318 allocates as[0]=ffffffc0f9404318
[ 0.458754] platform 57000000.gpu: domain=ffffffc0f955a318 allocates as[1]=ffffffc0f9404380
[ 0.458816] platform 57000000.gpu: domain=ffffffc0f955a318 allocates as[2]=ffffffc0f94043e8
[ 0.458870] platform 57000000.gpu: domain=ffffffc0f955a318 allocates as[3]=ffffffc0f9404450
[ 0.459747] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.459791] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.459823] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.459849] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.459870] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.509289] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509323] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509355] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509433] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509758] iommu: Adding device 70012000.se to group 24
[ 0.510575] iommu: Adding device 7000c000.i2c to group 25
[ 0.510842] iommu: Adding device 7000c400.i2c to group 26
[ 0.511099] iommu: Adding device 7000c500.i2c to group 27
[ 0.511362] iommu: Adding device 7000c700.i2c to group 28
[ 0.511637] iommu: Adding device 7000d000.i2c to group 29
[ 0.511908] iommu: Adding device 7000d100.i2c to group 30
[ 0.512218] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.512290] platform sdhci-tegra.0: domain=ffffffc0f9569498 allocates as[0]=ffffffc0f94044b8
[ 0.513239] iommu: Adding device 700d0000.xudc to group 32
[ 0.517885] vdd-ac-bat: 5000 mV
[ 0.518278] vdd-5v0-sys: 5000 mV
[ 0.519282] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.519345] vdd-5v0-hdmi: 5000 mV
[ 0.519758] vdd-1v8: 1800 mV
[ 0.520256] vdd-fan: supplied by vdd-5v0-sys
[ 0.520311] vdd-fan: 5000 mV
[ 0.520739] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.520795] vdd-usb-vbus: 5000 mV
[ 0.521368] vdd-usb-vbus2: 5000 mV
[ 0.550275] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.552855] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.553548] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.561593] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.561994] SCSI subsystem initialized
[ 0.562255] libata version 3.00 loaded.
[ 0.562615] usbcore: registered new interface driver usbfs
[ 0.562690] usbcore: registered new interface driver hub
[ 0.562782] usbcore: registered new device driver usb
[ 0.566941] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.568372] random: fast init done
[ 0.573152] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.574365] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.576250] vdd-ddr-1v1: 1150 mV
[ 0.580305] vdd-pre-reg-1v35: 1350 mV
[ 0.584239] vdd-1v8: 1800 mV
[ 0.584518] vdd-1v8: Failed to create debugfs directory
[ 0.588237] avdd-sys-1v2: 1200 mV
[ 0.592241] vdd-pex-1v0: 1050 mV
[ 0.593042] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.593747] max77620-ldo3: at 3100 mV
[ 0.596246] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.596892] max77620-ldo5: at 3100 mV
[ 0.597545] max77620-ldo6: at 2800 mV
[ 0.600244] avdd-1v05-pll: 1050 mV
[ 0.604239] avdd-io-hdmi-dp: 1050 mV
[ 0.605608] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.605935] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.608056] max77620 4-003c: max77620 probe successful
[ 0.610442] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.611000] media: Linux media interface: v0.10
[ 0.611066] Linux video capture interface: v2.00
[ 0.612030] pps_core: LinuxPPS API ver. 1 registered
[ 0.612057] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.612099] PTP clock support registered
[ 0.615619] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.621951] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.622911] Advanced Linux Sound Architecture Driver Initialized.
[ 0.623590] Bluetooth: Core ver 2.22
[ 0.623659] NET: Registered protocol family 31
[ 0.623677] Bluetooth: HCI device and connection manager initialized
[ 0.623707] Bluetooth: HCI socket layer initialized
[ 0.623728] Bluetooth: L2CAP socket layer initialized
[ 0.623767] Bluetooth: SCO socket layer initialized
[ 0.625460] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.625499] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.625566] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.625593] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.628336] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.629835] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.629917] vdd-3v3-sys: 3300 mV
[ 0.630221] vdd-1v8: supplied by vdd-3v3-sys
[ 0.632311] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.632787] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.632843] vdd-3v3-sd: 3300 mV
[ 0.633826] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.633907] avdd-io-edp-1v05: 1050 mV
[ 0.634408] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.634460] vdd-usb-hub-en: 5000 mV
[ 0.635831] camchar: rtcpu character device driver loaded
[ 0.636600] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.637998] clocksource: Switched to clocksource arch_sys_counter
[ 0.679195] VFS: Disk quotas dquot_6.6.0
[ 0.679368] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.679872] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.680327] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.680378] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.680604] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.680628] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.680655] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.680707] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.680733] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.680767] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.680789] nvmap_page_pool_init: Total RAM pages: 1010752
[ 0.680808] nvmap_page_pool_init: nvmap page pool size: 126344 pages (493 MB)
[ 0.680916] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.681417] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.682533] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.690600] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.691016] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.691311] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.691538] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.691730] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.692027] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.692049] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.692509] NET: Registered protocol family 2
[ 0.693611] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.693848] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.694447] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.694628] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.694730] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.695159] NET: Registered protocol family 1
[ 0.695933] RPC: Registered named UNIX socket transport module.
[ 0.695963] RPC: Registered udp transport module.
[ 0.695979] RPC: Registered tcp transport module.
[ 0.695996] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.696023] PCI: CLS 0 bytes, default 64
[ 0.696288] Trying to unpack rootfs image as initramfs...
[ 0.706191] host1x 50000000.host1x: initialized
[ 0.708084] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.711364] audit: initializing netlink subsys (disabled)
[ 0.711461] audit: type=2000 audit(0.563:1): initialized
[ 0.712208] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.722449] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.723982] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.724812] 9p: Installing v9fs 9p2000 file system support
[ 0.728218] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.728402] io scheduler noop registered
[ 0.728713] io scheduler cfq registered (default)
[ 0.731512] gic 702f9000.agic: GIC IRQ controller registered
[ 0.734732] iommu: Adding device 702ef000.adsp to group 33
[ 0.741459] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.741629] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.742635] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8a4840f
[ 0.742671] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.744370] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.744507] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.744630] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.744827] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.744941] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.745050] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.745162] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.745270] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.745384] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.745502] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.751844] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.753194] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.755202] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.756509] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.756900] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.758173] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.758530] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.758784] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.759070] Adding domain tsec-pd to PM domain host1x-pd
[ 0.761974] tsec 54500000.tsec: initialized
[ 0.763505] tsec 54100000.tsecb: initialized
[ 0.764234] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.767341] nvdec 54480000.nvdec: initialized
[ 0.768425] Adding domain vic03-pd to PM domain host1x-pd
[ 0.768622] Adding domain msenc-pd to PM domain host1x-pd
[ 0.768800] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.772438] falcon 54340000.vic: initialized
[ 0.773667] falcon 544c0000.nvenc: initialized
[ 0.775019] falcon 54380000.nvjpg: initialized
[ 0.779626] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.779756] display board info: id 0x0, fab 0x0
[ 0.779834] generic_infoframe_type: 0x87
[ 0.779969] tegradc tegradc.0: DT parsed successfully
[ 0.780028] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 0.780649] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 0.783579] tegradc tegradc.0: probed
[ 0.788180] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.792696] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 0.792771] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.792795] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 0.792819] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 0.792849] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.792936] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 0.793121] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.793463] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 0.793578] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.793806] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.793854] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.794141] pci 0000:01:00.0: [8086:095a] type 00 class 0x028000
[ 0.794212] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 0.794542] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.795751] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.797053] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.797460] kfuse 7000fc00.kfuse: initialized
[ 0.799143] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.800160] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.801615] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.801664] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 0.802258] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.804059] vdd-gpu: applied init 1000000uV constraint
[ 0.804096] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 0.804534] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.806222] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.806503] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.806552] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 0.806609] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 0.806641] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 0.806896] pci 0000:02:00.0: supports D1 D2
[ 0.806900] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.810749] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.810935] No Device Node present for smmu client: serial8250 !!
[ 0.810967] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.811111] iommu: Adding device serial8250 to group 35
[ 0.815247] console [ttyS0] disabled
[ 0.815427] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 0.818262] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 0.818410] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 0.818416] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 0.818421] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.818434] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[ 0.818469] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.818482] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 0.818498] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 0.818526] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 0.818552] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 0.818562] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.818566] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 0.818573] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 0.820374] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 0.820380] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.820393] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 0.820578] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 0.820881] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 0.820887] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.820895] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 0.821049] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.250484] console [ttyS0] enabled
[ 3.251072] Console: switching to colour frame buffer device 240x67
[ 3.252003] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.252361] serial-tegra 70006200.serial: RX in PIO mode
[ 3.252465] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.253435] [drm] Initialized
[ 3.276629] brd: module loaded
[ 3.290693] tegradc tegradc.0: fb registered
[ 3.291570] loop: module loaded
[ 3.291677] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.291810] tegra_profiler: auth: init
[ 3.293258] THERMAL EST: found 2 subdevs
[ 3.293265] THERMAL EST num_resources: 0
[ 3.293270] [THERMAL EST subdev 0]
[ 3.293277] [THERMAL EST subdev 1]
[ 3.293743] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.293745] THERMAL EST: thz register success.
[ 3.293906] THERMAL EST: end of probe, return err: 0
[ 3.295061] hisi_sas: driver version v1.6
[ 3.299782] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.304525] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.304533] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.311335] libphy: Fixed MDIO Bus: probed
[ 3.312075] tun: Universal TUN/TAP device driver, 1.6
[ 3.312077] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.313253] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.313257] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.313326] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.313328] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.313381] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.313383] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.313434] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.313437] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.314541] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 3.314572] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.328758] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.328914] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e4:26:c2 from device tree
[ 3.329553] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.329592] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.330457] PPP generic driver version 2.4.2
[ 3.330675] PPP BSD Compression module registered
[ 3.330684] PPP Deflate Compression module registered
[ 3.330735] PPP MPPE Compression module registered
[ 3.330741] NET: Registered protocol family 24
[ 3.330812] usbcore: registered new interface driver r8152
[ 3.330863] usbcore: registered new interface driver asix
[ 3.330933] usbcore: registered new interface driver ax88179_178a
[ 3.330971] usbcore: registered new interface driver cdc_ether
[ 3.331015] usbcore: registered new interface driver net1080
[ 3.331052] usbcore: registered new interface driver cdc_subset
[ 3.331105] usbcore: registered new interface driver zaurus
[ 3.331158] usbcore: registered new interface driver cdc_ncm
[ 3.331329] VFIO - User Level meta-driver version: 0.3
[ 3.332641] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.332664] ehci-pci: EHCI PCI platform driver
[ 3.332712] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.332723] ohci-pci: OHCI PCI platform driver
[ 3.332766] ohci-platform: OHCI generic platform driver
[ 3.335540] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.336146] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.337320] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9151800 id
[ 3.337431] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.337435] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.338803] usbcore: registered new interface driver uas
[ 3.338861] usbcore: registered new interface driver usb-storage
[ 3.338981] usbcore: registered new interface driver usbserial
[ 3.342220] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.343595] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.343609] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.343646] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.343903] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.344581] mousedev: PS/2 mouse device common for all mice
[ 3.344675] usbcore: registered new interface driver xpad
[ 3.593795] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.606489] rtc rtc1: alarm rtc device
[ 3.606506] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.606535] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.607163] i2c /dev entries driver
[ 3.609101] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.683397] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.724381] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.724387] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.724830] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.724846] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.724855] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.725010] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.725021] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.725027] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.725180] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.725190] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.725194] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.725368] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.726247] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.726306] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.726331] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.726347] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.726357] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.727253] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.727274] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 3.727463] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.727494] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 3.727926] parse_throttle_dt_data: Num cap clks = 6
[ 3.727932] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.727947] parse_throttle_dt_data: clk=gpu type=4
[ 3.727975] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.727995] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.728016] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.728019] parse_throttle_dt_data: clk=emc type=3
[ 3.729945] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.730074] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.730215] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.731042] FAN dev name: pwm-fan
[ 3.731095] FAN:gpio request success.
[ 3.731170] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.731476] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.731672] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.731683] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.731780] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.731784] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.731788] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.731792] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.731795] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.731799] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.731802] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.731805] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.731809] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.731813] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.732418] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.732785] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.733707] device-mapper: uevent: version 1.0.3
[ 3.734237] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.739704] tegra210-cpufreq cpufreq: probe()...completed
[ 3.740413] sdhci: Secure Digital Host Controller Interface driver
[ 3.740414] sdhci: Copyright(c) Pierre Ossman
[ 3.740416] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.740888] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.741240] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.741361] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.744936] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.745547] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.746649] usbcore: registered new interface driver usbhid
[ 3.746650] usbhid: USB HID core driver
[ 3.779606] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 3.779793] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.781468] nvpmodel: initialized successfully
[ 3.782953] usbcore: registered new interface driver snd-usb-audio
[ 3.783013] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.783017] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.783035] iommu: Adding device snd-soc-dummy to group 36
[ 3.790173] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.815638] OPE platform probe
[ 3.815726] OPE platform probe successful
[ 3.816102] OPE platform probe
[ 3.816183] OPE platform probe successful
[ 3.842239] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.842372] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.842499] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.842620] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.842743] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.842865] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.842995] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.843119] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.843241] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.843365] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.855722] u32 classifier
[ 3.855723] Actions configured
[ 3.855798] Initializing XFRM netlink socket
[ 3.856539] NET: Registered protocol family 10
[ 3.857264] NET: Registered protocol family 17
[ 3.857274] NET: Registered protocol family 15
[ 3.857350] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.857396] Bluetooth: RFCOMM socket layer initialized
[ 3.857405] Bluetooth: RFCOMM ver 1.11
[ 3.857410] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.857414] Bluetooth: HIDP socket layer initialized
[ 3.857432] 9pnet: Installing 9P2000 support
[ 3.857467] Key type dns_resolver registered
[ 3.858906] Registered cp15_barrier emulation handler
[ 3.858916] Registered setend emulation handler
[ 3.860008] registered taskstats version 1
[ 3.860635] Adding domain ve2-pd to PM domain host1x-pd
[ 3.860880] Adding domain ve-pd to PM domain host1x-pd
[ 3.963511] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.397989] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 4.405245] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 4.413662] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 4.420824] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 4.428134] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.434244] Extcon AUX1(HDMI) enable
[ 4.438978] isp 54600000.isp: initialized
[ 4.444069] isp 54680000.isp: initialized
[ 4.448188] edid invalid
[ 4.449752] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.449793] tegradc tegradc.1: No lt-data, using default setting
[ 4.449806] tegradc tegradc.1: No hpd-gpio in DT
[ 4.449824] tegradc tegradc.1: DT parsed successfully
[ 4.449845] tegradc tegradc.1: Display dc.ffffff800f5c0000 registered with id=1
[ 4.450833] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.454854] tegradc tegradc.1: probed
[ 4.460688] clk_cbus_recalc_rate: no gbus parent
[ 4.460694] clk_cbus_round_rate: no gbus parent
[ 4.460695] clk_cbus_round_rate: no gbus parent
[ 4.460699] clk_cbus_recalc_rate: no gbus parent
[ 4.460803] clk_cbus_recalc_rate: no gbus parent
[ 4.460805] clk_cbus_round_rate: no gbus parent
[ 4.460807] clk_cbus_round_rate: no gbus parent
[ 4.460809] clk_cbus_recalc_rate: no gbus parent
[ 4.461523] tegra_dvfs: GPU-cap: registered
[ 4.461592] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.461594] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.461595] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.463762] tegra_dvfs: vdd-gpu-vts: registered
[ 4.464807] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 4.465455] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 4.466002] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.502800] tegra_rtc 7000e000.rtc: setting system clock to 2019-05-18 10:33:13 UTC (1558175593)
[ 4.522284] mmc0: hw tuning done ...
[ 4.522325] mmc0: new ultra high speed SDR104 SDHC card at address 0001
[ 4.522686] mmcblk0: mmc0:0001 FB4HT 29.8 GiB
[ 4.527861] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 4.613674] tegradc tegradc.1: fb registered
[ 4.613742] tegradc tegradc.0: blank - powerdown
[ 4.616807] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.616809] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.616814] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.617235] vi 54080000.vi: vi_probe: ++
[ 4.621640] vi 54080000.vi: initialized
[ 4.624021] vi 54080000.vi: subdev nvcsi--1 bound
[ 4.624037] vi 54080000.vi: subdev imx219 6-0010 bound
[ 4.624858] mmcblk mmc0:0001: Card claimed for testing.
[ 4.626067] Disable partitions left on by BL
[ 4.626069] disb
[ 4.626121] bwmgr: missing cdev-type property
[ 4.626211] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.626216] DRAM derating cdev registered.
[ 4.627251] vdd-1v8: disabling
[ 4.627253] vdd-fan: disabling
[ 4.627254] vdd-usb-vbus: disabling
[ 4.627256] vdd-usb-vbus2: disabling
[ 4.627266] avdd-io-edp-1v05: disabling
[ 4.627267] vdd-usb-hub-en: disabling
[ 4.627421] ALSA device list:
[ 4.627423] #0: tegra-hda at 0x70038000 irq 83
[ 4.627424] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.639438] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 4.647519] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 4.647521] Extcon AUX1(HDMI) disable
[ 4.675743] tegradc tegradc.0: unblank
[ 4.713280] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 4.713327] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 4.714320] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 4.714325] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 4.717534] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.717548] Extcon AUX1(HDMI) enable
[ 4.717807] tegradc tegradc.0: sync windows ret = 250
[ 4.976954] tegradc tegradc.1: blank - powerdown
[ 4.983579] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 4.983581] Extcon DP: HPD disabled
[ 4.983587] hpd: hpd_switch 0
[ 4.983589] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.983604] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 4.983608] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.028665] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 5.036829] Extcon HDMI: HPD enabled
[ 5.042494] tegradc tegradc.0: hdmi: plugged
[ 5.054787] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.064975] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.075609] devtmpfs: mounted
[ 5.083661] Freeing unused kernel memory: 8512K
[ 5.332323] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.352239] cgroup: cgroup2: unknown option "nsdelegate"
[ 5.375151] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.401552] systemd[1]: Detected architecture arm64.
[ 5.438075] systemd[1]: Set hostname to <jetson-nano>.
[ 5.528235] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 5.547881] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 5.686041] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.697055] systemd[1]: Created slice System Slice.
[ 5.707031] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.716205] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.727880] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.737652] systemd[1]: Created slice User and Session Slice.
[ 5.748234] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.759638] systemd[1]: Reached target Swap.
[ 5.898180] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 5.939054] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 6.179687] systemd-journald[1972]: Received request to flush runtime journal from PID 1
[ 6.762323] using random self ethernet address
[ 6.768645] using random host ethernet address
[ 6.902770] Mass Storage Function, version: 2009/09/11
[ 6.902775] LUN: removable file: (no medium)
[ 6.908999] using random self ethernet address
[ 6.920235] using random host ethernet address
[ 6.937330] rndis0: HOST MAC 56:f1:f9:b7:3a:68
[ 6.937402] rndis0: MAC 56:f1:f9:b7:3a:69
[ 6.942452] usb0: HOST MAC 56:f1:f9:b7:3a:6a
[ 6.942481] usb0: MAC 56:f1:f9:b7:3a:6b
[ 6.942499] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 6.943681] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 6.943698] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.943727] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 6.943957] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 6.943969] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 6.944464] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 6.944479] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 6.944692] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 6.998885] l4tbr0: port 1(rndis0) entered blocking state
[ 6.998890] l4tbr0: port 1(rndis0) entered disabled state
[ 7.004480] device rndis0 entered promiscuous mode
[ 7.009909] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 7.022412] l4tbr0: port 2(usb0) entered blocking state
[ 7.022417] l4tbr0: port 2(usb0) entered disabled state
[ 7.022574] device usb0 entered promiscuous mode
[ 7.033190] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.033197] l4tbr0: port 2(usb0) entered blocking state
[ 7.033201] l4tbr0: port 2(usb0) entered forwarding state
[ 7.116936] random: crng init done
[ 7.121888] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.249742] tegra-xusb 70090000.xusb: cannot find firmware....retry after 1 second
[ 7.345880] nvs_dsm nvs_dsm: dsm_probe
[ 7.345904] nvs_dsm nvs_dsm: dsm_remove
[ 7.345907] nvs_dsm nvs_dsm: dsm_probe done
[ 7.383740] Intel(R) Wireless WiFi driver for Linux
[ 7.383743] Copyright(c) 2003- 2015 Intel Corporation
[ 7.383976] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.409878] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.409888] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.424297] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.434550] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.443152] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.443157] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.443162] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.443170] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.456770] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.468856] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.477642] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.477647] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.477653] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.477661] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.491319] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.501620] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.510315] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.510320] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.510325] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.510333] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.524063] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.534370] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.543221] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.543225] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.543231] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.543239] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.557154] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.567540] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.576378] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.576383] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.576388] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.576397] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.590312] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.600741] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.609803] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.609808] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.609813] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.609821] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.623775] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.634288] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.643642] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.643647] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.643652] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.643660] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.657666] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.668423] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.677467] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.677472] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.677476] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.677485] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.691509] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.702311] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.711412] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.711417] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.711422] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.711429] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.725538] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.736392] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.745524] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.745528] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.745533] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.745541] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.759666] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.770590] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.779801] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.779806] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.779811] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[ 7.779824] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 10010049
[ 7.791245] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 11010005
[ 7.802797] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 11010009
[ 7.814182] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.828386] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.839382] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.848691] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.848695] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.848700] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[ 7.848713] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 10010049
[ 7.860225] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 11010005
[ 7.871914] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 11010009
[ 7.883388] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.897684] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.908601] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.917933] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.917937] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.917942] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.917950] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.932242] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.943152] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.952511] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.952515] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.952520] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.952528] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 7.966862] l4tbr0: port 2(usb0) entered disabled state
[ 7.966904] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 7.977914] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 7.987371] pcieport 0000:00:01.0: broadcast error_detected message
[ 7.987375] pcieport 0000:00:01.0: AER: Device recovery failed
[ 7.987379] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 7.987387] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 8.001851] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 8.013034] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 8.022575] pcieport 0000:00:01.0: broadcast error_detected message
[ 8.022579] pcieport 0000:00:01.0: AER: Device recovery failed
[ 8.022584] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[ 8.022592] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 8.037133] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00004000/00000000
[ 8.048317] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 8.057915] pcieport 0000:00:01.0: broadcast error_detected message
[ 8.057920] pcieport 0000:00:01.0: AER: Device recovery failed
[ 8.149486] iwlwifi 0000:01:00.0: loaded firmware version 17.948900127.0 op_mode iwlmvm
[ 8.280427] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 7265, REV=0xFFFFFFFF
[ 8.280445] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000001
[ 8.282122] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 8.292209] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000000
[ 8.297726] Timeout waiting for hardware access (CSR_GP_CNTRL 0xffffffff)
[ 8.297780] ------------[ cut here ]------------
[ 8.297808] WARNING: CPU: 1 PID: 4152 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/drivers/net/wireless/intel/iwlwifi/pcie/trans.c:1860 iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 8.297818] Modules linked in: iwlmvm(+) mac80211 iwlwifi nvs cfg80211 nvgpu bluedroid_pm ip_tables x_tables
[ 8.297823] CPU: 1 PID: 4152 Comm: modprobe Not tainted 4.9.140-tegra #1
[ 8.297824] Hardware name: jetson-nano (DT)
[ 8.297826] task: ffffffc0f9ace200 task.stack: ffffffc0e38f4000
[ 8.297846] PC is at iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 8.297864] LR is at iwl_trans_pcie_reclaim+0x236c/0x3bb0 [iwlwifi]
[ 8.297867] pc : [<ffffff8001220bc4>] lr : [<ffffff8001220bc4>] pstate: 804000c5
[ 8.297868] sp : ffffffc0e38f79e0
[ 8.297871] x29: ffffffc0e38f79e0 x28: ffffffc0e300d5e0
[ 8.297874] x27: ffffffc0e93f7010 x26: 00000000000023e8
[ 8.297877] x25: ffffff8001232888 x24: ffffff80022af80
