For reference here is full dmesg from boot, including insmod of modules, and finally crashing on starting hostapd or wpa_supplicant
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-matterport-000 (phahn@phahn-pvm) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #30 SMP PREEMPT Tue Dec 3 15:15:24 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefba000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 pcie_aspm=off pci=noaer quiet
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29436(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3570324K/4159488K available (15230K kernel code, 2916K rwdata, 6672K rodata, 8576K init, 611K bss, 114028K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095f0000 ( 6720 KB)
[ 0.000000] .init : 0xffffff80095f0000 - 0xffffff8009e50000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e50000 - 0xffffff800a129008 ( 2917 KB)
[ 0.000000] .bss : 0xffffff800a129008 - 0xffffff800a1c1dbc ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001629] Console: colour dummy device 80x25
[ 0.001648] console [tty0] enabled
[ 0.001664] kmemleak: Kernel memory leak detector disabled
[ 0.001684] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001696] pid_max: default: 32768 minimum: 301
[ 0.002147] Security Framework initialized
[ 0.002367] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002376] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003475] ftrace: allocating 46955 entries in 184 pages
[ 0.173603] sched-energy: CPU device node has no sched-energy-costs
[ 0.173637] ASID allocator initialised with 65536 entries
[ 0.211636] tegra-id: chipid=22117.
[ 0.211648] tegra-id: opt_subrevision=0.
[ 0.211667] Tegra Speedo/IDDQ fuse revision 4
[ 0.211672] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211676] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.211681] Tegra: CPU Speedo Value 2052, SoC Speedo Value 1948, GPU Speedo Value 2072
[ 0.211685] Tegra: CPU IDDQ Value 2048, SoC IDDQ Value 2252, GPU IDDQ Value 2935
[ 0.211705] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.211719] DTS File Name: /home/phahn/JetPack_4.2.2_Nano/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.211727] DTB Build time: Dec 18 2019 16:53:22
[ 0.261030] CPU1: Booted secondary processor [411fd071]
[ 0.292954] CPU2: Booted secondary processor [411fd071]
[ 0.324939] CPU3: Booted secondary processor [411fd071]
[ 0.325029] Brought up 4 CPUs
[ 0.325035] SMP: Total of 4 processors activated.
[ 0.325042] CPU features: detected feature: 32-bit EL0 Support
[ 0.325306] CPU: All CPU(s) started at EL2
[ 0.325324] alternatives: patching kernel code
[ 0.333422] devtmpfs: initialized
[ 0.370668] Initilizing CustomIPI irq domain
[ 0.371040] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.371059] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.381569] pinctrl core: initialized pinctrl subsystem
[ 0.382178] OS set in device tree is not L4T.
[ 0.382574] regulator-dummy: no parameters
[ 0.382856] Initializing plugin-manager
[ 0.382964] Plugin module not found
[ 0.383190] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.383744] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.384238] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.384921] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.385397] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.385950] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[ 0.386512] node /plugin-manager/fragment@12 match with board *
[ 0.390589] NET: Registered protocol family 16
[ 0.398596] pstore: using zlib compression
[ 0.398630] console [pstore-1] enabled
[ 0.398635] pstore: Registered ramoops as persistent store backend
[ 0.398640] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.413049] cpuidle: using governor menu
[ 0.417311] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.418921] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e54000)
[ 0.418941] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421507] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.424087] tegra_powergate_init: DONE
[ 0.424103] DTS File Name: /home/phahn/JetPack_4.2.2_Nano/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.424110] DTB Build time: Dec 18 2019 16:53:22
[ 0.425897] Tegra reboot handler registered.
[ 0.430288] iommu: Adding device tegra-carveouts to group 0
[ 0.430420] platform tegra-carveouts: domain=ffffffc0f9428318 allocates as[0]=ffffffc0f943c0a8
[ 0.430758] iommu: Adding device smmu_test to group 1
[ 0.430801] platform smmu_test: domain=ffffffc0f9428558 allocates as[0]=ffffffc0f943c110
[ 0.431610] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.431666] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.431726] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.431735] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.431759] mc-err: mcerr ops are set to t21x
[ 0.441063] iommu: Adding device 70090000.xusb to group 2
[ 0.441378] iommu: Adding device 70006000.serial to group 3
[ 0.441443] platform 70006000.serial: domain=ffffffc0f9431c18 allocates as[0]=ffffffc0f943c178
[ 0.441859] iommu: Adding device 70006040.serial to group 4
[ 0.442120] iommu: Adding device 70006200.serial to group 5
[ 0.442309] iommu: Adding device sound to group 6
[ 0.442360] platform sound: domain=ffffffc0f94a0198 allocates as[0]=ffffffc0f943c1e0
[ 0.442906] iommu: Adding device 7000d400.spi to group 7
[ 0.443160] iommu: Adding device 7000d600.spi to group 8
[ 0.443527] iommu: Adding device 50000000.host1x to group 9
[ 0.443804] iommu: Adding device 54080000.vi to group 10
[ 0.444224] iommu: Adding device 54600000.isp to group 11
[ 0.444487] iommu: Adding device 54680000.isp to group 12
[ 0.444760] iommu: Adding device tegradc.0 to group 13
[ 0.444811] platform tegradc.0: domain=ffffffc0f94a0f18 allocates as[0]=ffffffc0f943c248
[ 0.445350] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.445671] iommu: Adding device tegradc.1 to group 14
[ 0.445722] platform tegradc.1: domain=ffffffc0f9514198 allocates as[0]=ffffffc0f943c2b0
[ 0.446231] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.446468] iommu: Adding device 54340000.vic to group 15
[ 0.446699] iommu: Adding device 544c0000.nvenc to group 16
[ 0.446885] iommu: Adding device 54500000.tsec to group 17
[ 0.447079] iommu: Adding device 54100000.tsecb to group 18
[ 0.447285] iommu: Adding device 54480000.nvdec to group 19
[ 0.447477] iommu: Adding device 54380000.nvjpg to group 20
[ 0.448307] iommu: Adding device 546c0000.i2c to group 21
[ 0.448634] iommu: Adding device 57000000.gpu to group 22
[ 0.448687] platform 57000000.gpu: domain=ffffffc0f95200d8 allocates as[0]=ffffffc0f943c318
[ 0.448726] platform 57000000.gpu: domain=ffffffc0f95200d8 allocates as[1]=ffffffc0f943c380
[ 0.448782] platform 57000000.gpu: domain=ffffffc0f95200d8 allocates as[2]=ffffffc0f943c3e8
[ 0.448822] platform 57000000.gpu: domain=ffffffc0f95200d8 allocates as[3]=ffffffc0f943c450
[ 0.449746] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.449757] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.449769] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.449774] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.449778] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.501199] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.501207] tegra-pmc: Clear bootloader IO dpd settings
[ 0.501226] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.501288] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.501567] iommu: Adding device 70012000.se to group 23
[ 0.502384] iommu: Adding device 7000c000.i2c to group 24
[ 0.502641] iommu: Adding device 7000c400.i2c to group 25
[ 0.502878] iommu: Adding device 7000c500.i2c to group 26
[ 0.503124] iommu: Adding device 7000c700.i2c to group 27
[ 0.503378] iommu: Adding device 7000d000.i2c to group 28
[ 0.503626] iommu: Adding device 7000d100.i2c to group 29
[ 0.503915] iommu: Adding device sdhci-tegra.3 to group 30
[ 0.503967] platform sdhci-tegra.3: domain=ffffffc0f952e258 allocates as[0]=ffffffc0f943c4b8
[ 0.504810] iommu: Adding device 700d0000.xudc to group 31
[ 0.508216] vdd-ac-bat: 5000 mV
[ 0.508561] vdd-5v0-sys: 5000 mV
[ 0.509537] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.509587] vdd-5v0-hdmi: 5000 mV
[ 0.509997] vdd-1v8-sys: 1800 mV
[ 0.510387] vdd-fan: supplied by vdd-5v0-sys
[ 0.510440] vdd-fan: 5000 mV
[ 0.510833] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.510863] vdd-usb-vbus: 5000 mV
[ 0.511367] vdd-usb-vbus2: 5000 mV
[ 0.542212] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.544626] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.545883] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.546206] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.554040] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.554367] SCSI subsystem initialized
[ 0.554587] libata version 3.00 loaded.
[ 0.554851] usbcore: registered new interface driver usbfs
[ 0.554906] usbcore: registered new interface driver hub
[ 0.554983] usbcore: registered new device driver usb
[ 0.558816] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.564305] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.565136] random: fast init done
[ 0.565153] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.568230] vdd-ddr-1v1: 1150 mV
[ 0.572271] vdd-pre-reg-1v35: 1350 mV
[ 0.576226] vdd-1v8: 1800 mV
[ 0.580237] avdd-sys-1v2: 1200 mV
[ 0.584225] vdd-pex-1v0: 1050 mV
[ 0.584816] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.585314] max77620-ldo3: at 3100 mV
[ 0.588236] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.588730] max77620-ldo5: at 3100 mV
[ 0.592232] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.596232] avdd-1v05-pll: 1050 mV
[ 0.600230] avdd-io-hdmi-dp: 1050 mV
[ 0.601278] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.601579] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.602918] max77620 4-003c: max77620 probe successful
[ 0.605638] media: Linux media interface: v0.10
[ 0.605693] Linux video capture interface: v2.00
[ 0.606614] pps_core: LinuxPPS API ver. 1 registered
[ 0.606621] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.606648] PTP clock support registered
[ 0.610475] tegra_fiq_debugger_init: found FIQ source (IRQ 96)
[ 0.616775] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.617772] Advanced Linux Sound Architecture Driver Initialized.
[ 0.618406] Bluetooth: Core ver 2.22
[ 0.618454] NET: Registered protocol family 31
[ 0.618458] Bluetooth: HCI device and connection manager initialized
[ 0.618471] Bluetooth: HCI socket layer initialized
[ 0.618480] Bluetooth: L2CAP socket layer initialized
[ 0.618503] Bluetooth: SCO socket layer initialized
[ 0.620180] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.620196] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.620241] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.620255] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.623239] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.624442] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.624529] vdd-3v3-sys: 3300 mV
[ 0.624801] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.629137] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629632] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.629675] vdd-3v3-sd: 3300 mV
[ 0.630504] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.630542] avdd-io-edp-1v05: 1050 mV
[ 0.630968] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.631005] vdd-usb-hub-en: 5000 mV
[ 0.632457] camchar: rtcpu character device driver loaded
[ 0.633128] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.634440] clocksource: Switched to clocksource arch_sys_counter
[ 0.674640] VFS: Disk quotas dquot_6.6.0
[ 0.674790] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.675258] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.675661] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.675676] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.675891] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.675898] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.675913] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.675944] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.675950] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.675963] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.675973] nvmap_page_pool_init: Total RAM pages: 1011365
[ 0.675978] nvmap_page_pool_init: nvmap page pool size: 126420 pages (493 MB)
[ 0.676077] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.676491] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.677198] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.687016] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.687411] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.687665] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.687870] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.688046] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.688336] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.688340] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.688792] NET: Registered protocol family 2
[ 0.689770] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.689979] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.690561] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.690716] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.690796] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691217] NET: Registered protocol family 1
[ 0.691957] RPC: Registered named UNIX socket transport module.
[ 0.691963] RPC: Registered udp transport module.
[ 0.691967] RPC: Registered tcp transport module.
[ 0.691971] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.691986] PCI: CLS 0 bytes, default 64
[ 0.692216] Trying to unpack rootfs image as initramfs...
[ 0.937710] Freeing initrd memory: 5432K
[ 0.947410] host1x 50000000.host1x: initialized
[ 0.949238] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.952510] audit: initializing netlink subsys (disabled)
[ 0.952606] audit: type=2000 audit(0.799:1): initialized
[ 0.953380] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.963544] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.965009] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.965803] 9p: Installing v9fs 9p2000 file system support
[ 0.969192] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.969326] io scheduler noop registered
[ 0.969624] io scheduler cfq registered (default)
[ 0.972304] gic 702f9000.agic: GIC IRQ controller registered
[ 0.975566] iommu: Adding device 702ef000.adsp to group 32
[ 0.982220] iommu: Adding device aconnect@702c0000:adsp_audio to group 33
[ 0.982378] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.983120] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7247410
[ 0.983128] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.984765] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.984872] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.984962] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.985151] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.985240] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.985328] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.985411] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.985504] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.985586] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.985674] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.991051] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.992694] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.994521] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.995822] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.996177] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.997361] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.997587] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.997823] Adding domain tsec-pd to PM domain host1x-pd
[ 1.000040] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.001011] tsec 54500000.tsec: initialized
[ 1.002612] tsec 54100000.tsecb: initialized
[ 1.003319] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.006737] nvdec 54480000.nvdec: initialized
[ 1.007824] Adding domain vic03-pd to PM domain host1x-pd
[ 1.008001] Adding domain msenc-pd to PM domain host1x-pd
[ 1.008160] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.012062] falcon 54340000.vic: initialized
[ 1.013257] falcon 544c0000.nvenc: initialized
[ 1.014602] falcon 54380000.nvjpg: initialized
[ 1.019154] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.019268] display board info: id 0x0, fab 0x0
[ 1.019316] tegradc tegradc.0: tegra_dc_parse_panel_ops: panel: /host1x/sor1/hdmi-display is not active
[ 1.019357] tegradc tegradc.0: err:-19 parsing panel_ops
[ 1.019867] tegradc tegradc.1: disp0 connected to head1->/host1x/sor
[ 1.019871] display board info: id 0x0, fab 0x0
[ 1.019963] tegradc tegradc.1: No lt-data, using default setting
[ 1.019999] tegradc tegradc.1: No hpd-gpio in DT
[ 1.020036] tegradc tegradc.1: DT parsed successfully
[ 1.020079] tegradc tegradc.1: Display dc.ffffff800ab80000 registered with id=0
[ 1.022071] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.026168] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.527803] Host read timeout at address 545c00c4
[ 1.529003] tegradc tegradc.1: probed
[ 1.531354] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.532694] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.533168] kfuse 7000fc00.kfuse: initialized
[ 1.534720] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.534737] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.534744] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.534753] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.534759] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.534830] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.534981] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.535289] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.535377] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.535589] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.535603] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.535793] pci 0000:01:00.0: [1b4b:2b42] type 00 class 0x020000
[ 1.535835] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 1.535861] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x000fffff 64bit pref]
[ 1.536042] pci 0000:01:00.0: supports D1 D2
[ 1.536047] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 1.536281] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.536455] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 1.536485] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.536522] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 1.536548] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 1.536697] pci 0000:02:00.0: supports D1 D2
[ 1.536701] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.536928] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 1.537026] pci 0000:00:01.0: BAR 15: assigned [mem 0x20000000-0x201fffff 64bit pref]
[ 1.537034] pci 0000:00:02.0: BAR 15: assigned [mem 0x20200000-0x202fffff 64bit pref]
[ 1.537040] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.537054] pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 1.537078] pci 0000:01:00.0: BAR 2: assigned [mem 0x20100000-0x201fffff 64bit pref]
[ 1.537102] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.537115] pci 0000:00:01.0: bridge window [mem 0x20000000-0x201fffff 64bit pref]
[ 1.537126] pci 0000:02:00.0: BAR 4: assigned [mem 0x20200000-0x20203fff 64bit pref]
[ 1.537146] pci 0000:02:00.0: BAR 2: assigned [mem 0x20204000-0x20204fff 64bit pref]
[ 1.537167] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.537178] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 1.537184] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.537193] pci 0000:00:02.0: bridge window [mem 0x20200000-0x202fffff 64bit pref]
[ 1.537210] PCIE: ASPM not enabled
[ 1.537624] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.537632] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.537643] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.537891] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.537895] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.537904] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.539372] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.540310] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.542074] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.542092] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.542662] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.543929] vdd-gpu: applied init 1000000uV constraint
[ 1.543936] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.544330] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.548661] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.548775] No Device Node present for smmu client: serial8250 !!
[ 1.548783] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.548821] iommu: Adding device serial8250 to group 34
[ 1.551158] console [ttyS0] disabled
[ 1.551226] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.576153] console [ttyS0] enabled
[ 1.576495] Console: switching to colour frame buffer device 80x30
[ 1.576535] tegradc tegradc.1: fb registered
[ 1.577375] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.577703] serial-tegra 70006200.serial: RX in PIO mode
[ 1.577804] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.579138] [drm] Initialized
[ 1.579792] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.579799] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.579809] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.579828] tegradc tegradc.1: blank - powerdown
[ 1.579904] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.579909] Extcon DP: HPD disabled
[ 1.579913] hpd: hpd_switch 0
[ 1.579918] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.579927] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.579934] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.625181] brd: module loaded
[ 1.654506] loop: module loaded
[ 1.654609] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.654727] tegra_profiler: auth: init
[ 1.656047] THERMAL EST: found 2 subdevs
[ 1.656055] THERMAL EST num_resources: 0
[ 1.656061] [THERMAL EST subdev 0]
[ 1.656070] [THERMAL EST subdev 1]
[ 1.656508] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.656512] THERMAL EST: thz register success.
[ 1.660692] THERMAL EST: end of probe, return err: 0
[ 1.661916] hisi_sas: driver version v1.6
[ 1.667790] libphy: Fixed MDIO Bus: probed
[ 1.668422] tun: Universal TUN/TAP device driver, 1.6
[ 1.668427] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.669479] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.669484] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.669547] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.669552] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.669608] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.669612] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.669660] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.669664] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.670518] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 1.670548] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.691826] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.691995] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e5:dd:ed from device tree
[ 1.692581] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.692619] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.693167] PPP generic driver version 2.4.2
[ 1.693376] PPP BSD Compression module registered
[ 1.693381] PPP Deflate Compression module registered
[ 1.693425] PPP MPPE Compression module registered
[ 1.693431] NET: Registered protocol family 24
[ 1.693501] usbcore: registered new interface driver r8152
[ 1.693552] usbcore: registered new interface driver asix
[ 1.693611] usbcore: registered new interface driver ax88179_178a
[ 1.693650] usbcore: registered new interface driver cdc_ether
[ 1.693688] usbcore: registered new interface driver net1080
[ 1.693723] usbcore: registered new interface driver cdc_subset
[ 1.693762] usbcore: registered new interface driver zaurus
[ 1.693822] usbcore: registered new interface driver cdc_ncm
[ 1.694037] VFIO - User Level meta-driver version: 0.3
[ 1.695570] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.695598] ehci-pci: EHCI PCI platform driver
[ 1.695651] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.695662] ohci-pci: OHCI PCI platform driver
[ 1.695714] ohci-platform: OHCI generic platform driver
[ 1.698376] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.699037] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.700220] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f914e400 id
[ 1.702486] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 1.702533] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.702561] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.703468] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.703533] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.703737] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.703743] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.703749] usb usb1: Product: xHCI Host Controller
[ 1.703754] usb usb1: Manufacturer: Linux 4.9.140-matterport-000 xhci-hcd
[ 1.703758] usb usb1: SerialNumber: 70090000.xusb
[ 1.704438] hub 1-0:1.0: USB hub found
[ 1.704481] hub 1-0:1.0: 5 ports detected
[ 1.705110] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.705124] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.705207] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.705291] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.705297] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.705302] usb usb2: Product: xHCI Host Controller
[ 1.705306] usb usb2: Manufacturer: Linux 4.9.140-matterport-000 xhci-hcd
[ 1.705310] usb usb2: SerialNumber: 70090000.xusb
[ 1.705489] usbcore: registered new interface driver uas
[ 1.705585] usbcore: registered new interface driver usb-storage
[ 1.705707] usbcore: registered new interface driver usbserial
[ 1.709012] hub 2-0:1.0: USB hub found
[ 1.709049] hub 2-0:1.0: 4 ports detected
[ 1.709735] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.711012] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.711025] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.711483] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.711750] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.711902] mousedev: PS/2 mouse device common for all mice
[ 1.712010] usbcore: registered new interface driver xpad
[ 1.806648] usb usb1: usb_suspend_both: status 0
[ 1.839349] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.841865] rtc rtc1: alarm rtc device
[ 1.841887] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.841919] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.842525] i2c /dev entries driver
[ 1.894050] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.896737] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.896744] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.897234] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.897251] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.897261] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.897394] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.897405] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.897412] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.897566] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.897576] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.897582] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.897762] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.898569] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.898625] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.898651] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.898669] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.898680] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.899621] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.899642] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.899831] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.899866] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.900274] parse_throttle_dt_data: Num cap clks = 6
[ 1.900281] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.900295] parse_throttle_dt_data: clk=gpu type=4
[ 1.900325] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.900345] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.900367] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.900372] parse_throttle_dt_data: clk=emc type=3
[ 1.900834] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.900984] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.901161] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.902000] FAN dev name: pwm-fan
[ 1.902057] FAN:gpio request success.
[ 1.902132] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.902524] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.902730] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.902740] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.902843] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.902849] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.902854] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.902859] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.902864] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.902869] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.902874] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.902879] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.902883] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.902889] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.903529] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.904015] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.905076] device-mapper: uevent: version 1.0.3
[ 1.905616] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.910981] tegra210-cpufreq cpufreq: probe()...completed
[ 1.911690] sdhci: Secure Digital Host Controller Interface driver
[ 1.911692] sdhci: Copyright(c) Pierre Ossman
[ 1.911695] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.912070] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.918576] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.919098] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.921751] usbcore: registered new interface driver usbhid
[ 1.921754] usbhid: USB HID core driver
[ 1.924268] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.924436] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.926487] nvpmodel: initialized successfully
[ 1.927800] usbcore: registered new interface driver snd-usb-audio
[ 1.927855] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.927860] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.927879] iommu: Adding device snd-soc-dummy to group 35
[ 1.933615] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.954471] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 1.955691] OPE platform probe
[ 1.955778] OPE platform probe successful
[ 1.956149] OPE platform probe
[ 1.956233] OPE platform probe successful
[ 1.980839] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.980968] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.981093] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.981238] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.981358] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.981482] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.981601] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.981724] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.981851] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.981969] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.993666] u32 classifier
[ 1.993669] Actions configured
[ 1.993739] Initializing XFRM netlink socket
[ 1.994489] NET: Registered protocol family 10
[ 1.995201] NET: Registered protocol family 17
[ 1.995213] NET: Registered protocol family 15
[ 1.995291] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.995338] Bluetooth: RFCOMM socket layer initialized
[ 1.995348] Bluetooth: RFCOMM ver 1.11
[ 1.995353] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.995360] Bluetooth: HIDP socket layer initialized
[ 1.995379] 9pnet: Installing 9P2000 support
[ 1.995418] Key type dns_resolver registered
[ 1.995903] Registered cp15_barrier emulation handler
[ 1.995916] Registered setend emulation handler
[ 1.996953] registered taskstats version 1
[ 1.997570] Adding domain ve2-pd to PM domain host1x-pd
[ 1.997810] Adding domain ve-pd to PM domain host1x-pd
[ 1.999869] isp 54600000.isp: initialized
[ 2.000791] isp 54680000.isp: initialized
[ 2.006116] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.010664] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 2.010921] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 2.011024] last reset is due to software reset
[ 2.011027] KERNEL: PMC reset status reg: 0x3
[ 2.011109] BL: PMC reset status reg: 0x3
[ 2.011111] BL: PMIC poweroff Event Recorder: 0x0
[ 2.011754] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.012646] clk_cbus_recalc_rate: no gbus parent
[ 2.012652] clk_cbus_round_rate: no gbus parent
[ 2.012654] clk_cbus_round_rate: no gbus parent
[ 2.012662] clk_cbus_recalc_rate: no gbus parent
[ 2.012768] clk_cbus_recalc_rate: no gbus parent
[ 2.012772] clk_cbus_round_rate: no gbus parent
[ 2.012775] clk_cbus_round_rate: no gbus parent
[ 2.012779] clk_cbus_recalc_rate: no gbus parent
[ 2.013453] tegra_dvfs: GPU-cap: registered
[ 2.013508] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 2.013510] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 2.013513] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 2.014886] tegra_dvfs: vdd-gpu-vts: registered
[ 2.015587] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 2.016245] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 2.016725] input: gpio-keys as /devices/gpio-keys/input/input1
[ 2.047175] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:10:56 UTC (946689056)
[ 2.048141] vi 54080000.vi: vi_probe: ++
[ 2.051454] vi 54080000.vi: initialized
[ 2.053338] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@0/endpoint.
[ 2.053438] vi 54080000.vi: subdev nvcsi--2 bound
[ 2.053455] vi 54080000.vi: ep of_device is not enabled /host1x/vi/ports/port@2/endpoint.
[ 2.053692] mmcblk mmc0:0001: Card claimed for testing.
[ 2.054969] Disable partitions left on by BL
[ 2.054972] disb
[ 2.055020] bwmgr: missing cdev-type property
[ 2.055146] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.055152] DRAM derating cdev registered.
[ 2.056199] vdd-fan: disabling
[ 2.056203] vdd-usb-vbus: disabling
[ 2.056206] vdd-usb-vbus2: disabling
[ 2.056214] vddio-sdmmc-ap: disabling
[ 2.056299] vddio-sdmmc3-ap: disabling
[ 2.056364] vdd-3v3-sd: disabling
[ 2.056369] avdd-io-edp-1v05: disabling
[ 2.056372] vdd-usb-hub-en: disabling
[ 2.056453] ALSA device list:
[ 2.056456] #0: tegra-hda at 0x70038000 irq 81
[ 2.056459] #1: tegra-snd-t210ref-mobile-rt565x
[ 2.059474] Freeing unused kernel memory: 8576K
[ 2.077767] L4T-INITRD Build DATE: Sat Jan 1 01:10:56 UTC 2000
[ 2.082098] Root device found: mmcblk0p1
[ 2.083246] Found dev node: /dev/mmcblk0p1
[ 2.203305] EXT4-fs (mmcblk0p1): 12 orphan inodes deleted
[ 2.203310] EXT4-fs (mmcblk0p1): recovery complete
[ 2.211182] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.211955] Rootfs mounted over mmcblk0p1
[ 2.225414] Switching from initrd to actual rootfs
[ 2.295323] systemd[1]: System time before build time, advancing clock.
[ 2.318583] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.330058] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.346017] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.346819] systemd[1]: Detected architecture arm64.
[ 2.370009] systemd[1]: Set hostname to <nano-jp422-b01>.
[ 2.423857] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.423868] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.511100] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.511133] systemd[1]: Reached target User and Group Name Lookups.
[ 2.511331] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.513211] systemd[1]: Created slice System Slice.
[ 2.513404] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.515284] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.515562] systemd[1]: Listening on Journal Socket.
[ 2.517902] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 2.565327] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.863594] systemd-journald[1917]: Received request to flush runtime journal from PID 1
[ 3.136847] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.564720] using random self ethernet address
[ 3.646469] using random host ethernet address
[ 3.692779] Mass Storage Function, version: 2009/09/11
[ 3.692786] LUN: removable file: (no medium)
[ 3.710836] using random self ethernet address
[ 3.733799] using random host ethernet address
[ 3.775676] rndis0: HOST MAC 92:21:b3:5c:4e:d4
[ 3.775923] rndis0: MAC 92:21:b3:5c:4e:d5
[ 3.777892] usb0: HOST MAC 92:21:b3:5c:4e:d6
[ 3.778105] usb0: MAC 92:21:b3:5c:4e:d7
[ 3.778132] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 3.779794] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 3.779814] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 3.779847] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.780087] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.780102] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 3.785552] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 3.785580] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.785843] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.794495] l4tbr0: port 1(rndis0) entered blocking state
[ 3.794500] l4tbr0: port 1(rndis0) entered disabled state
[ 3.795056] device rndis0 entered promiscuous mode
[ 3.811669] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 3.823253] l4tbr0: port 2(usb0) entered blocking state
[ 3.823258] l4tbr0: port 2(usb0) entered disabled state
[ 3.823443] device usb0 entered promiscuous mode
[ 3.830675] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.102559] random: crng init done
[ 4.105965] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.521306] zram: Added device: zram0
[ 4.528320] zram: Added device: zram1
[ 4.534941] zram: Added device: zram2
[ 4.539336] zram: Added device: zram3
[ 4.584894] zram0: detected capacity change from 0 to 519614464
[ 4.603665] Adding 507432k swap on /dev/zram0. Priority:5 extents:1 across:507432k SS
[ 4.617800] zram1: detected capacity change from 0 to 519614464
[ 4.654768] Adding 507432k swap on /dev/zram1. Priority:5 extents:1 across:507432k SS
[ 4.661641] zram2: detected capacity change from 0 to 519614464
[ 4.678558] Adding 507432k swap on /dev/zram2. Priority:5 extents:1 across:507432k SS
[ 4.682385] zram3: detected capacity change from 0 to 519614464
[ 4.695395] Adding 507432k swap on /dev/zram3. Priority:5 extents:1 across:507432k SS
[ 4.921958] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.923509] eth0: 0xffffff800a38c000, 00:04:4b:e5:dd:ed, IRQ 402
[ 4.995652] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.639421] tegradc tegradc.1: blank - powerdown
[ 5.873868] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.873875] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.974877] usb usb2: usb_suspend_both: status 0
[ 6.226814] tegradc tegradc.1: blank - powerdown
[ 6.740177] fuse init (API version 7.26)
[ 7.962453] tegra-xusb 70090000.xusb: entering ELPG
[ 7.963639] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 0
[ 7.963826] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 7.965362] tegra-xusb 70090000.xusb: entering ELPG done
# insmod WiFi kernel modules
[ 38.209161] compat: no symbol version for module_layout
[ 38.214514] compat: loading out-of-tree module taints kernel.
[ 38.221453] Loading modules backported from Laird Linux version LRD-REL-7.0.0.139-0-g37fdd4c
[ 38.221457] Backport generated by backports.git v7.0.0.139
[ 38.497238] <<Laird 60 Series Wireless Network Driver version 7.0.0.139-P39-20190123>>
[ 38.497273] lrdmwl_pcie 0000:01:00.0: enabling device (0000 -> 0002)
[ 38.497372] ieee80211 phy0: card->iobase0 = ffffff800f100000
[ 38.497398] ieee80211 phy0: card->iobase1 = ffffff800fc00000
[ 38.497603] ieee80211 phy0: priv->pcmd_buf = ffffffc07ad10000 priv->pphys_cmd_buf = 00000000fad10000
[ 38.497610] ieee80211 phy0: mwl_tx_init() called: ctype=3
[ 38.503110] ieee80211 phy0: TX ring: allocating 640 bytes
[ 38.508582] ieee80211 phy0: TX ring: - base: ffffff800a582000, pbase: 0x0:fac01000,len: 280
[ 38.520959] ieee80211 phy0: lrdmwl: found firmware image <lrdmwl/88W8997_pcie.bin>
[ 38.526050] ieee80211 phy0: Starting fw download
[ 38.983673] ieee80211 phy0: FwSize = 372416 downloaded Size = 372416
[ 41.202784] ieee80211 phy0: fw download complete
[ 41.212930] ieee80211 phy0: OTP data len = 0
[ 41.218867] ieee80211 phy0: Radio Type ST60 (0x0)
[ 41.218872] ieee80211 phy0: Num mac 2 : OTP Version (1)
[ 41.218875] ieee80211 phy0: Firmware version: 0x5041701
[ 41.218878] ieee80211 phy0: Firmware region code: ff
[ 41.218880] ieee80211 phy0: Deep Sleep is disabled
[ 41.218883] ieee80211 phy0: 2G enabled, 5G enabled
[ 41.218887] ieee80211 phy0: 2 TX antennas, 2 RX antennas. (00000003)/(00000003)
# start access point with hostapd
[ 357.796090] Unable to handle kernel paging request at virtual address fffffffff09e0080
[ 357.796214] mc-err: (0) csw_afiw: EMEM address decode error
[ 357.796221] mc-err: status = 0x20012031; addr = 0x709e0080
[ 357.796229] mc-err: secure: no, access-type: write, SMMU fault: none
[ 357.822482] Mem abort info:
[ 357.825331] ESR = 0x96000145
[ 357.828534] Exception class = DABT (current EL), IL = 32 bits
[ 357.834511] SET = 0, FnV = 0
[ 357.837585] EA = 0, S1PTW = 0
[ 357.840834] Data abort info:
[ 357.843807] ISV = 0, ISS = 0x00000145
[ 357.847773] CM = 1, WnR = 1
[ 357.847961] mc-err: (0) csw_afiw: EMEM address decode error
[ 357.847976] mc-err: status = 0x20012031; addr = 0x43664080
[ 357.847989] mc-err: secure: no, access-type: write, SMMU fault: none
[ 357.868805] swapper pgtable: 4k pages, 39-bit VAs, pgd = ffffff800a1c5000
[ 357.869145] mc-err: (0) csw_afiw: EMEM address decode error
[ 357.869175] mc-err: status = 0x20012031; addr = 0x43630080
[ 357.869200] mc-err: secure: no, access-type: write, SMMU fault: none
[ 357.887670] mc-err: (0) csw_afiw: EMEM address decode error
[ 357.887700] mc-err: status = 0x20012031; addr = 0x436bc080
[ 357.887724] mc-err: secure: no, access-type: write, SMMU fault: none
[ 357.899926] mc-err: Too many MC errors; throttling prints
[ 357.917674] [fffffffff09e0080] *pgd=0000000000000000, *pud=0000000000000000
[ 357.925146] Internal error: Oops: 96000145 [#1] PREEMPT SMP
[ 357.930795] Modules linked in: lrdmwl_pcie(O) lrdmwl(O) mac80211(O) cfg80211(O) compat(O) fuse spidev zram overlay nvgpu bluedroid_pm ip_tables x_tables
[ 357.945194] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 4.9.140-matterport-000 #30
[ 357.953880] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 357.959958] task: ffffff8009e613c0 task.stack: ffffff8009e50000
[ 357.965987] PC is at __inval_cache_range+0x3c/0x54
[ 357.970861] LR is at __dma_page_dev_to_cpu+0x40/0x80
[ 357.975902] pc : [<ffffff80080a417c>] lr : [<ffffff80080a0728>] pstate: 40400045
[ 357.983357] sp : ffffffc0fefbddd0
[ 357.986736] x29: ffffffc0fefbddd0 x28: ffffffc0ed518000
[ 357.992206] x27: ffffff800a12e1b8 x26: ffffff8009e550c0
[ 357.997663] x25: ffffff800a12e1b8 x24: ffffffc0bce78fa0
[ 358.003113] x23: ffffffc0c667b800 x22: ffffffbeffc27800
[ 358.008560] x21: 0000000000002000 x20: 0000000000000002
[ 358.014008] x19: 0000000000000080 x18: 0000000000000400
[ 358.019454] x17: 000000000002eb01 x16: 0000000000000000
[ 358.024896] x15: 0000000000000278 x14: 0000000000000000
[ 358.030344] x13: 000000000000027c x12: 071c71c71c71c71c
[ 358.035786] x11: 0000000000000f50 x10: 0000000000000040
[ 358.041230] x9 : ffffff8009e74440 x8 : ffffffc0f8d98000
[ 358.046672] x7 : 00000000709e0080 x6 : 000000000d066a1b
[ 358.052114] x5 : ffffffbf00000000 x4 : 0000000080000000
[ 358.057551] x3 : 000000000000003f x2 : 0000000000000040
[ 358.062992] x1 : fffffffff09e2080 x0 : fffffffff09e0080
[ 358.068433]
[ 358.070005] Process swapper/0 (pid: 0, stack limit = 0xffffff8009e50000)
[ 358.076771] Call trace:
[ 358.079324] [<ffffff80080a417c>] __inval_cache_range+0x3c/0x54
[ 358.085244] [<ffffff80080a260c>] arm_dma_unmap_page+0x6c/0x80
[ 358.091178] [<ffffff800130c8a8>] mwl_pcie_rx_recv+0xb8/0x4c8 [lrdmwl_pcie]
[ 358.098148] [<ffffff80080bb900>] tasklet_action+0x70/0x108
[ 358.103715] [<ffffff8008081054>] __do_softirq+0x13c/0x3b0
[ 358.109196] [<ffffff80080bb298>] irq_exit+0xd0/0x118
[ 358.114247] [<ffffff8008122934>] __handle_domain_irq+0x6c/0xc0
[ 358.120154] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 358.125627] [<ffffff8008082be8>] el1_irq+0xe8/0x18c
[ 358.130604] [<ffffff8008b91400>] cpuidle_enter_state+0xb8/0x380
[ 358.136601] [<ffffff8008b9173c>] cpuidle_enter+0x34/0x48
[ 358.141993] [<ffffff8008112a1c>] call_cpuidle+0x44/0x70
[ 358.147297] [<ffffff8008112d98>] cpu_startup_entry+0x1b0/0x200
[ 358.153219] [<ffffff8008f4756c>] rest_init+0x84/0x90
[ 358.158272] [<ffffff80095f0b64>] start_kernel+0x370/0x384
[ 358.163749] [<ffffff80095f0204>] __primary_switched+0x80/0x94
[ 358.169603] ---[ end trace 07d68c7cf08992d9 ]---
[ 358.267748] Kernel panic - not syncing: Fatal exception in interrupt
[ 358.274207] SMP: stopping secondary CPUs
[ 358.278640] Kernel Offset: disabled
[ 358.282237] Memory Limit: none
[ 358.377296] Rebooting in 5 seconds..
