I am using the Jetson Nano dev kit with a 16GB SD card and I successfully flashed the SD card using the SDK Manager under Ubuntu 18.04 using latest Jetpack.
Everything works fine but I am a bit concerned about the booting time. It takes me about 2-3 minutes before doing the Ubuntu desktop on my Nano. Is that normal?
First, I am seeing the Nvidia logo and then I see log on screen that says the board setup failed, like shown in this thread.
[ 1.071534] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.259841] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.259871] imx219 6-0010: board setup failed
https://devtalk.nvidia.com/default/topic/1070332/jetson-nano/problem-booting-jetson-nano/post/5422484/#5422484
After, I can see the nVidia logo and then black screen for a couple of seconds until I see the desktop.
Is there any way to decrease the booting time?
Here is the kernel dump:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2713) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:47:42 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb0000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb0000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29392(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562224K/4159488K available (15230K kernel code, 2926K rwdata, 6620K rodata, 8576K init, 609K bss, 122128K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a11b808 ( 2927 KB)
[ 0.000000] .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001775] Console: colour dummy device 80x25
[ 0.001797] console [tty0] enabled
[ 0.001815] kmemleak: Kernel memory leak detector disabled
[ 0.001836] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001850] pid_max: default: 32768 minimum: 301
[ 0.002301] Security Framework initialized
[ 0.002525] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002534] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003702] ftrace: allocating 47001 entries in 184 pages
[ 0.177249] sched-energy: CPU device node has no sched-energy-costs
[ 0.177283] ASID allocator initialised with 65536 entries
[ 0.216162] tegra-id: chipid=22117.
[ 0.216177] tegra-id: opt_subrevision=0.
[ 0.216196] Tegra Speedo/IDDQ fuse revision 4
[ 0.216201] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.216205] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.216211] Tegra: CPU Speedo Value 2072, SoC Speedo Value 1980, GPU Speedo Value 2069
[ 0.216214] Tegra: CPU IDDQ Value 1988, SoC IDDQ Value 2184, GPU IDDQ Value 2615
[ 0.216273] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.216288] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.216297] DTB Build time: Dec 9 2019 22:51:54
[ 0.265062] CPU1: Booted secondary processor [411fd071]
[ 0.297006] CPU2: Booted secondary processor [411fd071]
[ 0.328990] CPU3: Booted secondary processor [411fd071]
[ 0.329082] Brought up 4 CPUs
[ 0.329090] SMP: Total of 4 processors activated.
[ 0.329098] CPU features: detected feature: 32-bit EL0 Support
[ 0.329366] CPU: All CPU(s) started at EL2
[ 0.329384] alternatives: patching kernel code
[ 0.337765] devtmpfs: initialized
[ 0.375005] Initilizing CustomIPI irq domain
[ 0.375402] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.375423] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.386920] pinctrl core: initialized pinctrl subsystem
[ 0.387620] OS set in device tree is not L4T.
[ 0.388045] regulator-dummy: no parameters
[ 0.388357] Initializing plugin-manager
[ 0.388468] Plugin module not found
[ 0.388701] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.389336] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.390207] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.390641] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.391061] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.391463] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.396369] NET: Registered protocol family 16
[ 0.397722] pstore: using zlib compression
[ 0.397762] console [pstore-1] enabled
[ 0.397766] pstore: Registered ramoops as persistent store backend
[ 0.397772] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.413079] cpuidle: using governor menu
[ 0.417377] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.419078] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.419100] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421672] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.424227] tegra_powergate_init: DONE
[ 0.424243] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.424250] DTB Build time: Dec 9 2019 22:51:54
[ 0.426038] Tegra reboot handler registered.
[ 0.430613] iommu: Adding device tegra-carveouts to group 0
[ 0.430806] platform tegra-carveouts: domain=ffffffc0f9bc6318 allocates as[0]=ffffffc0f94340a8
[ 0.431150] iommu: Adding device smmu_test to group 1
[ 0.431195] platform smmu_test: domain=ffffffc0f9bc6558 allocates as[0]=ffffffc0f9434110
[ 0.432008] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.432072] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.432124] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.432132] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.432155] mc-err: mcerr ops are set to t21x
[ 0.442166] iommu: Adding device 70090000.xusb to group 2
[ 0.442446] iommu: Adding device 70006000.serial to group 3
[ 0.442526] platform 70006000.serial: domain=ffffffc0f94c9558 allocates as[0]=ffffffc0f9434178
[ 0.442949] iommu: Adding device 70006040.serial to group 4
[ 0.443213] iommu: Adding device 70006200.serial to group 5
[ 0.443435] iommu: Adding device sound to group 6
[ 0.443483] platform sound: domain=ffffffc0f94c9a98 allocates as[0]=ffffffc0f94341e0
[ 0.444047] iommu: Adding device 7000d400.spi to group 7
[ 0.444312] iommu: Adding device 7000d600.spi to group 8
[ 0.444593] iommu: Adding device 70410000.spi to group 9
[ 0.444899] iommu: Adding device 50000000.host1x to group 10
[ 0.445208] iommu: Adding device 54080000.vi to group 11
[ 0.445600] iommu: Adding device 54600000.isp to group 12
[ 0.445860] iommu: Adding device 54680000.isp to group 13
[ 0.446180] iommu: Adding device tegradc.0 to group 14
[ 0.446236] platform tegradc.0: domain=ffffffc0f94d49d8 allocates as[0]=ffffffc0f9434248
[ 0.450462] platform tegradc.0: IOVA linear map 0x0000000092cb0000(800000)
[ 0.450850] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.451195] iommu: Adding device tegradc.1 to group 15
[ 0.451244] platform tegradc.1: domain=ffffffc0f94d4c18 allocates as[0]=ffffffc0f94342b0
[ 0.455422] platform tegradc.1: IOVA linear map 0x0000000092cb0000(800000)
[ 0.455814] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.456077] iommu: Adding device 54340000.vic to group 16
[ 0.456280] iommu: Adding device 544c0000.nvenc to group 17
[ 0.456497] iommu: Adding device 54500000.tsec to group 18
[ 0.456698] iommu: Adding device 54100000.tsecb to group 19
[ 0.456889] iommu: Adding device 54480000.nvdec to group 20
[ 0.457130] iommu: Adding device 54380000.nvjpg to group 21
[ 0.458178] iommu: Adding device 546c0000.i2c to group 22
[ 0.458513] iommu: Adding device 57000000.gpu to group 23
[ 0.458565] platform 57000000.gpu: domain=ffffffc0f94e2c18 allocates as[0]=ffffffc0f9434318
[ 0.458606] platform 57000000.gpu: domain=ffffffc0f94e2c18 allocates as[1]=ffffffc0f9434380
[ 0.458646] platform 57000000.gpu: domain=ffffffc0f94e2c18 allocates as[2]=ffffffc0f94343e8
[ 0.458685] platform 57000000.gpu: domain=ffffffc0f94e2c18 allocates as[3]=ffffffc0f9434450
[ 0.459592] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.459602] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.459613] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.459617] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.459621] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.509198] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509207] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509228] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509292] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509596] iommu: Adding device 70012000.se to group 24
[ 0.510388] iommu: Adding device 7000c000.i2c to group 25
[ 0.510631] iommu: Adding device 7000c400.i2c to group 26
[ 0.510883] iommu: Adding device 7000c500.i2c to group 27
[ 0.511134] iommu: Adding device 7000c700.i2c to group 28
[ 0.511421] iommu: Adding device 7000d000.i2c to group 29
[ 0.511673] iommu: Adding device 7000d100.i2c to group 30
[ 0.511969] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.512027] platform sdhci-tegra.0: domain=ffffffc0f9575e58 allocates as[0]=ffffffc0f94344b8
[ 0.512867] iommu: Adding device 700d0000.xudc to group 32
[ 0.516312] vdd-ac-bat: 5000 mV
[ 0.516682] vdd-5v0-sys: 5000 mV
[ 0.517643] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.517710] vdd-5v0-hdmi: 5000 mV
[ 0.518106] vdd-1v8-sys: 1800 mV
[ 0.518505] vdd-fan: supplied by vdd-5v0-sys
[ 0.518542] vdd-fan: 5000 mV
[ 0.518927] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.518986] vdd-usb-vbus: 5000 mV
[ 0.519517] vdd-usb-vbus2: 5000 mV
[ 0.549980] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.552420] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.553504] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.553525] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.553905] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.561761] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.562120] SCSI subsystem initialized
[ 0.562366] libata version 3.00 loaded.
[ 0.562660] usbcore: registered new interface driver usbfs
[ 0.562716] usbcore: registered new interface driver hub
[ 0.562792] usbcore: registered new device driver usb
[ 0.567118] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.573188] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.573336] random: fast init done
[ 0.574208] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.577076] vdd-ddr-1v1: 1150 mV
[ 0.581078] vdd-pre-reg-1v35: 1350 mV
[ 0.585142] vdd-1v8: 1800 mV
[ 0.589076] avdd-sys-1v2: 1200 mV
[ 0.593076] vdd-pex-1v0: 1050 mV
[ 0.593701] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.594222] max77620-ldo3: at 3100 mV
[ 0.597079] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.597677] max77620-ldo5: at 3100 mV
[ 0.598240] max77620-ldo6: at 2800 mV
[ 0.601077] avdd-1v05-pll: 1050 mV
[ 0.605077] avdd-io-hdmi-dp: 1050 mV
[ 0.607699] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.608026] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.608313] max77620 4-003c: max77620 probe successful
[ 0.611135] media: Linux media interface: v0.10
[ 0.611195] Linux video capture interface: v2.00
[ 0.612102] pps_core: LinuxPPS API ver. 1 registered
[ 0.612109] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.612130] PTP clock support registered
[ 0.615983] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.622343] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.623185] Advanced Linux Sound Architecture Driver Initialized.
[ 0.623814] Bluetooth: Core ver 2.22
[ 0.623863] NET: Registered protocol family 31
[ 0.623867] Bluetooth: HCI device and connection manager initialized
[ 0.623882] Bluetooth: HCI socket layer initialized
[ 0.623890] Bluetooth: L2CAP socket layer initialized
[ 0.623916] Bluetooth: SCO socket layer initialized
[ 0.625697] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.625716] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.625761] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.625775] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.628943] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.630141] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.630215] vdd-3v3-sys: 3300 mV
[ 0.630490] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.633138] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.633617] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.633687] vdd-3v3-sd: 3300 mV
[ 0.634805] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.634854] avdd-io-edp-1v05: 1050 mV
[ 0.635335] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.635372] vdd-usb-hub-en: 5000 mV
[ 0.636902] camchar: rtcpu character device driver loaded
[ 0.637649] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.639063] clocksource: Switched to clocksource arch_sys_counter
[ 0.679488] VFS: Disk quotas dquot_6.6.0
[ 0.679617] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.680109] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.680536] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.680555] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.680743] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.680749] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.680766] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.680795] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.680802] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.680816] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.680824] nvmap_page_pool_init: Total RAM pages: 1009340
[ 0.680828] nvmap_page_pool_init: nvmap page pool size: 126167 pages (492 MB)
[ 0.680920] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.681415] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.682417] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.690726] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.691165] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.691431] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.691648] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.691826] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.692101] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.692106] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.692540] NET: Registered protocol family 2
[ 0.693544] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.693756] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.694293] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.694454] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.694533] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.694948] NET: Registered protocol family 1
[ 0.695764] RPC: Registered named UNIX socket transport module.
[ 0.695771] RPC: Registered udp transport module.
[ 0.695774] RPC: Registered tcp transport module.
[ 0.695778] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.695793] PCI: CLS 0 bytes, default 64
[ 0.696054] Trying to unpack rootfs image as initramfs…
[ 0.929666] Freeing initrd memory: 5356K
[ 0.939876] host1x 50000000.host1x: initialized
[ 0.941732] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.945008] audit: initializing netlink subsys (disabled)
[ 0.945075] audit: type=2000 audit(0.791:1): initialized
[ 0.945855] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.956001] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.957510] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.958316] 9p: Installing v9fs 9p2000 file system support
[ 0.961636] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.961781] io scheduler noop registered
[ 0.962089] io scheduler cfq registered (default)
[ 0.964859] gic 702f9000.agic: GIC IRQ controller registered
[ 0.967861] iommu: Adding device 702ef000.adsp to group 33
[ 0.977367] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.977516] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.978133] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8208412
[ 0.978142] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.979836] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.979936] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.980036] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.980251] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.980339] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.980430] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.980518] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.980606] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.980697] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.980787] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.986882] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.988702] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.990619] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.991931] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.992297] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.993453] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.993696] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.993925] Adding domain tsec-pd to PM domain host1x-pd
[ 0.996264] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.997344] tsec 54500000.tsec: initialized
[ 0.998952] tsec 54100000.tsecb: initialized
[ 0.999703] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.003232] nvdec 54480000.nvdec: initialized
[ 1.004310] Adding domain vic03-pd to PM domain host1x-pd
[ 1.004481] Adding domain msenc-pd to PM domain host1x-pd
[ 1.004649] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.008830] falcon 54340000.vic: initialized
[ 1.010038] falcon 544c0000.nvenc: initialized
[ 1.011416] falcon 54380000.nvjpg: initialized
[ 1.015657] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.015700] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.015733] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.015941] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.016030] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.016036] tegra_cec 70015000.tegra_cec: probed
[ 1.016067] display board info: id 0x0, fab 0x0
[ 1.016140] generic_infoframe_type: 0x87
[ 1.016288] tegradc tegradc.0: DT parsed successfully
[ 1.016337] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.016837] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.024076] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.025150] tegradc tegradc.0: probed
[ 1.030800] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.032309] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.032804] kfuse 7000fc00.kfuse: initialized
[ 1.034443] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.035515] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.037050] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.037066] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.037661] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.039388] vdd-gpu: applied init 1000000uV constraint
[ 1.039397] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.039851] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.045460] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.045632] No Device Node present for smmu client: serial8250 !!
[ 1.045649] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.045720] iommu: Adding device serial8250 to group 35
[ 1.049557] console [ttyS0] disabled
[ 1.049702] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.049886] console [ttyS0] enabled
[ 1.051144] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.051477] serial-tegra 70006200.serial: RX in PIO mode
[ 1.051575] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.052645] [drm] Initialized
[ 1.057295] Console: switching to colour frame buffer device 240x67
[ 1.057428] tegradc tegradc.0: fb registered
[ 1.063928] brd: module loaded
[ 1.064997] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.065059] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.065594] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.065609] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.069750] loop: module loaded
[ 1.069869] tegra_profiler: version: 1.139, samples/io: 47/27
[ 1.069999] tegra_profiler: auth: init
[ 1.071606] THERMAL EST: found 2 subdevs
[ 1.071615] THERMAL EST num_resources: 0
[ 1.071622] [THERMAL EST subdev 0]
[ 1.071628] [THERMAL EST subdev 1]
[ 1.072086] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.072090] THERMAL EST: thz register success.
[ 1.072253] THERMAL EST: end of probe, return err: 0
[ 1.073571] hisi_sas: driver version v1.6
[ 1.078135] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.079602] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.079615] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.082766] libphy: Fixed MDIO Bus: probed
[ 1.083436] tun: Universal TUN/TAP device driver, 1.6
[ 1.083442] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.084772] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.084777] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.084830] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.084834] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.084881] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.084885] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.084936] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.084940] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.085969] PPP generic driver version 2.4.2
[ 1.086172] PPP BSD Compression module registered
[ 1.086175] PPP Deflate Compression module registered
[ 1.086221] PPP MPPE Compression module registered
[ 1.086228] NET: Registered protocol family 24
[ 1.086300] usbcore: registered new interface driver r8152
[ 1.086358] usbcore: registered new interface driver asix
[ 1.086409] usbcore: registered new interface driver ax88179_178a
[ 1.086448] usbcore: registered new interface driver cdc_ether
[ 1.086490] usbcore: registered new interface driver net1080
[ 1.086527] usbcore: registered new interface driver cdc_subset
[ 1.086575] usbcore: registered new interface driver zaurus
[ 1.086647] usbcore: registered new interface driver cdc_ncm
[ 1.086846] VFIO - User Level meta-driver version: 0.3
[ 1.088355] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.088386] ehci-pci: EHCI PCI platform driver
[ 1.088433] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.088445] ohci-pci: OHCI PCI platform driver
[ 1.088490] ohci-platform: OHCI generic platform driver
[ 1.091319] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.091934] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.092044] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.092051] Extcon AUX1(HDMI) enable
[ 1.092900] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.092982] tegradc tegradc.1: No lt-data, using default setting
[ 1.093014] tegradc tegradc.1: No hpd-gpio in DT
[ 1.093050] tegradc tegradc.1: DT parsed successfully
[ 1.093112] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 1.093259] tegra-xusb 70090000.xusb: extcon 0: ffffffc0fa5d1000 id
[ 1.094949] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.095041] usbcore: registered new interface driver uas
[ 1.095145] usbcore: registered new interface driver usb-storage
[ 1.095278] usbcore: registered new interface driver usbserial
[ 1.099466] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.100960] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.100993] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.101067] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.101093] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.101872] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.101925] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.102136] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.102141] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102145] usb usb1: Product: xHCI Host Controller
[ 1.102149] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.102153] usb usb1: SerialNumber: 70090000.xusb
[ 1.102374] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.102389] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.102415] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.102440] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.102786] hub 1-0:1.0: USB hub found
[ 1.102828] hub 1-0:1.0: 5 ports detected
[ 1.103580] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.103595] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.103697] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.103807] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.103813] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.103819] usb usb2: Product: xHCI Host Controller
[ 1.103824] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.103828] usb usb2: SerialNumber: 70090000.xusb
[ 1.107370] mousedev: PS/2 mouse device common for all mice
[ 1.107409] hub 2-0:1.0: USB hub found
[ 1.107445] hub 2-0:1.0: 4 ports detected
[ 1.107499] usbcore: registered new interface driver xpad
[ 1.112893] tegradc tegradc.1: probed
[ 1.113298] tegradc tegradc.1: fb registered
[ 1.116929] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.116937] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.116946] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.116960] tegradc tegradc.1: blank - powerdown
[ 1.116981] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.116987] Extcon DP: HPD disabled
[ 1.116991] hpd: hpd_switch 0
[ 1.116996] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.117004] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.117011] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.130219] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.207129] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.226529] tegradc tegradc.0: blank - powerdown
[ 1.227877] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.230104] rtc rtc1: alarm rtc device
[ 1.230116] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.230134] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.230531] i2c /dev entries driver
[ 1.232122] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.255407] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.255479] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.255505] imx219 6-0010: board setup failed
[ 1.255566] imx219: probe of 6-0010 failed with error -121
[ 1.256353] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.258260] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.258264] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.258564] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.258577] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.258584] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.258716] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.258724] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.258730] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.258870] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.258877] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.258882] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.259071] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.259619] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.259663] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.259684] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.259699] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.259707] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.260467] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.260481] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.260630] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.260652] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.260994] parse_throttle_dt_data: Num cap clks = 6
[ 1.260998] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.261004] parse_throttle_dt_data: clk=gpu type=4
[ 1.261021] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.261037] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.261055] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.261058] parse_throttle_dt_data: clk=emc type=3
[ 1.261353] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.261438] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.261542] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.262082] FAN dev name: pwm-fan
[ 1.262126] FAN:gpio request success.
[ 1.262178] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.262400] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.262508] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.262514] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.262588] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.262593] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.262597] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.262601] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.262605] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.262608] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.262612] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.262616] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.262620] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.262623] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.263089] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.263333] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.264052] device-mapper: uevent: version 1.0.3
[ 1.264454] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.267065] tegra210-cpufreq cpufreq: probe()…completed
[ 1.267741] sdhci: Secure Digital Host Controller Interface driver
[ 1.267743] sdhci: Copyright(c) Pierre Ossman
[ 1.267744] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.268209] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.268547] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.268674] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.269972] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.269974] Extcon AUX1(HDMI) disable
[ 1.275364] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.276019] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.277526] usbcore: registered new interface driver usbhid
[ 1.277527] usbhid: USB HID core driver
[ 1.279697] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.280011] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.281786] nvpmodel: initialized successfully
[ 1.282807] usbcore: registered new interface driver snd-usb-audio
[ 1.282862] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.282866] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.282886] iommu: Adding device snd-soc-dummy to group 36
[ 1.293377] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.295153] tegradc tegradc.0: unblank
[ 1.297778] OPE platform probe
[ 1.297868] OPE platform probe successful
[ 1.297894] OPE platform probe
[ 1.297975] OPE platform probe successful
[ 1.324308] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.324445] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.324571] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.324694] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.324822] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.324947] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.325069] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.325198] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.325322] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.325451] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.331226] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.334437] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.334489] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.337173] u32 classifier
[ 1.337175] Actions configured
[ 1.337243] Initializing XFRM netlink socket
[ 1.337950] NET: Registered protocol family 10
[ 1.338620] NET: Registered protocol family 17
[ 1.338630] NET: Registered protocol family 15
[ 1.338701] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.338744] Bluetooth: RFCOMM socket layer initialized
[ 1.338753] Bluetooth: RFCOMM ver 1.11
[ 1.338757] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.338765] Bluetooth: HIDP socket layer initialized
[ 1.338782] 9pnet: Installing 9P2000 support
[ 1.338818] Key type dns_resolver registered
[ 1.339237] Registered cp15_barrier emulation handler
[ 1.339243] Registered setend emulation handler
[ 1.340292] registered taskstats version 1
[ 1.340806] Adding domain ve2-pd to PM domain host1x-pd
[ 1.341055] Adding domain ve-pd to PM domain host1x-pd
[ 1.343184] isp 54600000.isp: initialized
[ 1.344142] isp 54680000.isp: initialized
[ 1.354280] last reset is due to power on reset
[ 1.354282] KERNEL: PMC reset status reg: 0x0
[ 1.354360] BL: PMC reset status reg: 0x0
[ 1.354362] BL: PMIC poweroff Event Recorder: 0xdd
[ 1.355793] clk_cbus_recalc_rate: no gbus parent
[ 1.355797] clk_cbus_round_rate: no gbus parent
[ 1.355799] clk_cbus_round_rate: no gbus parent
[ 1.355805] clk_cbus_recalc_rate: no gbus parent
[ 1.355904] clk_cbus_recalc_rate: no gbus parent
[ 1.355906] clk_cbus_round_rate: no gbus parent
[ 1.355908] clk_cbus_round_rate: no gbus parent
[ 1.355911] clk_cbus_recalc_rate: no gbus parent
[ 1.356574] tegra_dvfs: GPU-cap: registered
[ 1.356625] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.356627] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.356629] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.357992] tegra_dvfs: vdd-gpu-vts: registered
[ 1.358656] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.359256] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.359728] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.373558] tegradc tegradc.0: sync windows ret = 250
[ 1.382583] mmc0: new high speed SDHC card at address 1234
[ 1.382871] mmcblk0: mmc0:1234 SA16G 14.4 GiB
[ 1.395225] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:13 UTC (946688413)
[ 1.395263] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.395369] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.395372] Extcon HDMI: HPD enabled
[ 1.395385] tegradc tegradc.0: hdmi: plugged
[ 1.396279] vi 54080000.vi: vi_probe: ++
[ 1.398884] vi 54080000.vi: initialized
[ 1.400892] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.401119] mmcblk mmc0:1234: Card claimed for testing.
[ 1.402386] Disable partitions left on by BL
[ 1.402389] disb
[ 1.402438] bwmgr: missing cdev-type property
[ 1.402545] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.402552] DRAM derating cdev registered.
[ 1.403596] vdd-fan: disabling
[ 1.403599] vdd-usb-vbus: disabling
[ 1.403601] vdd-usb-vbus2: disabling
[ 1.403610] avdd-io-edp-1v05: disabling
[ 1.403715] ALSA device list:
[ 1.403720] #0: tegra-hda at 0x70038000 irq 83
[ 1.403723] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.406786] Freeing unused kernel memory: 8576K
[ 1.427594] Root device found: mmcblk0p1
[ 1.428616] Found dev node: /dev/mmcblk0p1
[ 1.431161] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.431203] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.466944] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.466949] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.466953] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.466957] usb 1-2: Manufacturer: Generic
[ 1.468272] hub 1-2:1.0: USB hub found
[ 1.469417] hub 1-2:1.0: 4 ports detected
[ 1.759074] usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
[ 1.787874] usb 1-2.1: New USB device found, idVendor=04d9, idProduct=1133
[ 1.787880] usb 1-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.795921] input: HID 04d9:1133 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:04D9:1133.0001/input/input2
[ 1.796203] hid-generic 0003:04D9:1133.0001: input,hidraw0: USB HID v1.10 Mouse [HID 04d9:1133] on usb-70090000.xusb-2.1/input0
[ 1.837289] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.879072] usb 1-2.2: new low-speed USB device number 4 using tegra-xusb
[ 1.907193] usb 1-2.2: New USB device found, idVendor=413c, idProduct=2113
[ 1.907198] usb 1-2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.907202] usb 1-2.2: Product: Dell KB216 Wired Keyboard
[ 1.912222] input: Dell KB216 Wired Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.0/0003:413C:2113.0002/input/input3
[ 1.971475] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-70090000.xusb-2.2/input0
[ 1.975707] input: Dell KB216 Wired Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.1/0003:413C:2113.0003/input/input4
[ 2.035333] hid-generic 0003:413C:2113.0003: input,hidraw2: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-70090000.xusb-2.2/input1
[ 2.039078] tegra_cec 70015000.tegra_cec: physical address: 02:3a.
[ 2.103697] tegra_cec 70015000.tegra_cec: Sent res: -113.
[ 2.103700] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.243835] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.245908] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.351578] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.351584] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.351587] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.351590] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.351594] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.351614] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.351673] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.351812] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.351914] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.351937] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.351966] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.351986] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.352116] pci 0000:01:00.0: supports D1 D2
[ 2.352119] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.367193] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.367218] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.367222] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.367227] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.367242] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.367257] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.367264] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.367267] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.367272] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.367513] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.367517] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.367521] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.367600] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.367764] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.367780] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.381805] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.381889] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:a1:03 from device tree
[ 2.382294] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.382308] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 5.267708] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.267714] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.596088] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.632672] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.632676] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.632678] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.632681] usb 2-1: Manufacturer: Generic
[ 5.637057] hub 2-1:1.0: USB hub found
[ 5.638454] hub 2-1:1.0: 4 ports detected
[ 5.935525] usb 2-1.3: new SuperSpeed USB device number 3 using tegra-xusb
[ 5.956864] usb 2-1.3: New USB device found, idVendor=046d, idProduct=085e
[ 5.956868] usb 2-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=3
[ 5.956870] usb 2-1.3: Product: Logitech BRIO
[ 5.956873] usb 2-1.3: SerialNumber: 33326299
[ 5.964599] usb 2-1.3: current rate 16000 is different from the runtime rate 24000
[ 5.967840] usb 2-1.3: current rate 16000 is different from the runtime rate 32000
[ 5.970941] usb 2-1.3: current rate 16000 is different from the runtime rate 48000
[ 5.977403] input: Logitech BRIO as /devices/70090000.xusb/usb2/2-1/2-1.3/2-1.3:1.5/0003:046D:085E.0004/input/input5
[ 6.035365] hid-generic 0003:046D:085E.0004: input,hidraw3: USB HID v1.11 Device [Logitech BRIO] on usb-70090000.xusb-1.3/input5
[ 26.521397] EXT4-fs (mmcblk0p1): 16 orphan inodes deleted
[ 26.521400] EXT4-fs (mmcblk0p1): recovery complete
[ 28.106074] random: crng init done
[ 29.153138] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 29.153922] Rootfs mounted over mmcblk0p1
[ 29.185152] Switching from initrd to actual rootfs
[ 29.797911] systemd[1]: System time before build time, advancing clock.
[ 29.886592] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 29.901084] cgroup: cgroup2: unknown option “nsdelegate”
[ 29.931460] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 29.932185] systemd[1]: Detected architecture arm64.
[ 29.955847] systemd[1]: Set hostname to .
[ 30.120144] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 30.120154] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 30.374413] systemd[1]: Created slice User and Session Slice.
[ 30.374535] systemd[1]: Reached target Swap.
[ 30.375393] systemd[1]: Created slice System Slice.
[ 30.375654] systemd[1]: Listening on Journal Socket.
[ 30.377703] systemd[1]: Mounting RPC Pipe File System…
[ 30.631139] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 30.784161] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 30.882067] systemd-journald[2002]: Received request to flush runtime journal from PID 1
[ 33.253826] uvcvideo: Unknown video format 00000032-0002-0010-8000-00aa00389b71
[ 33.253844] uvcvideo: Found UVC 1.00 device Logitech BRIO (046d:085e)
[ 33.266658] uvcvideo: Unable to create debugfs 2-3 directory.
[ 33.266845] uvcvideo 2-1.3:1.0: Entity type for entity Processing 3 was not initialized!
[ 33.275084] uvcvideo 2-1.3:1.0: Entity type for entity Extension 14 was not initialized!
[ 33.283446] uvcvideo 2-1.3:1.0: Entity type for entity Extension 6 was not initialized!
[ 33.291636] uvcvideo 2-1.3:1.0: Entity type for entity Extension 8 was not initialized!
[ 33.299851] uvcvideo 2-1.3:1.0: Entity type for entity Extension 9 was not initialized!
[ 33.308181] uvcvideo 2-1.3:1.0: Entity type for entity Extension 10 was not initialized!
[ 33.316475] uvcvideo 2-1.3:1.0: Entity type for entity Extension 11 was not initialized!
[ 33.324728] uvcvideo 2-1.3:1.0: Entity type for entity Extension 12 was not initialized!
[ 33.332987] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[ 33.341167] input: Logitech BRIO as /devices/70090000.xusb/usb2/2-1/2-1.3/2-1.3:1.0/input/input6
[ 33.341409] usbcore: registered new interface driver uvcvideo
[ 33.341412] USB Video Class driver (1.1.1)
[ 36.768705] using random self ethernet address
[ 36.773404] using random host ethernet address
[ 38.441759] Mass Storage Function, version: 2009/09/11
[ 38.441765] LUN: removable file: (no medium)
[ 38.446222] using random self ethernet address
[ 38.451602] using random host ethernet address
[ 38.589860] rndis0: HOST MAC 1e:71:3e:a0:25:ac
[ 38.589989] rndis0: MAC 1e:71:3e:a0:25:ad
[ 38.591828] usb0: HOST MAC 1e:71:3e:a0:25:ae
[ 38.591862] usb0: MAC 1e:71:3e:a0:25:af
[ 38.591893] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 38.596535] l4tbr0: port 1(rndis0) entered blocking state
[ 38.596542] l4tbr0: port 1(rndis0) entered disabled state
[ 38.596734] device rndis0 entered promiscuous mode
[ 38.605514] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 38.612617] l4tbr0: port 2(usb0) entered blocking state
[ 38.612623] l4tbr0: port 2(usb0) entered disabled state
[ 38.613619] device usb0 entered promiscuous mode
[ 38.618832] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 38.844606] android_work: did not send uevent (0 0 (null))
[ 38.877312] android_work: sent uevent USB_STATE=CONNECTED
[ 38.933578] configfs-gadget gadget: high-speed config #1: c
[ 38.933615] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 38.933631] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 38.933646] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 38.933739] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 38.933755] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 38.933770] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 38.933803] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 38.933821] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 38.933842] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 38.933890] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 38.934064] android_work: sent uevent USB_STATE=CONFIGURED
[ 39.784363] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 39.785652] eth0: 0xffffff800abaf000, 00:04:4b:e6:a1:03, IRQ 407
[ 39.835787] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 43.927123] r8168: eth0: link up
[ 43.927172] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 47.771259] zram: Added device: zram0
[ 47.780620] zram: Added device: zram1
[ 47.781302] zram: Added device: zram2
[ 47.781856] zram: Added device: zram3
[ 47.800800] zram0: detected capacity change from 0 to 518565888
[ 47.859744] Adding 506408k swap on /dev/zram0. Priority:5 extents:1 across:506408k SS
[ 47.866395] zram1: detected capacity change from 0 to 518565888
[ 47.878497] Adding 506408k swap on /dev/zram1. Priority:5 extents:1 across:506408k SS
[ 47.883979] zram2: detected capacity change from 0 to 518565888
[ 47.899709] Adding 506408k swap on /dev/zram2. Priority:5 extents:1 across:506408k SS
[ 47.907164] zram3: detected capacity change from 0 to 518565888
[ 47.929473] Adding 506408k swap on /dev/zram3. Priority:5 extents:1 across:506408k SS
[ 48.324715] l4tbr0: port 1(rndis0) entered blocking state
[ 48.324721] l4tbr0: port 1(rndis0) entered forwarding state
[ 48.326569] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 48.326590] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 53.282063] tegradc tegradc.0: blank - powerdown
[ 53.339214] extcon-disp-state extcon:disp-state: cable 47 state 0 already set.
[ 53.339224] Extcon AUX1(HDMI) disable
[ 53.362650] tegradc tegradc.0: unblank
[ 53.375669] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 53.375747] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 53.423707] tegradc tegradc.0: unblank
[ 53.423990] tegradc tegradc.1: blank - powerdown
[ 58.778156] fuse init (API version 7.26)
[ 59.376389] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 59.376400] Bluetooth: BNEP socket layer initialized
[ 67.144916] usb 2-1.3: current rate 16000 is different from the runtime rate 48000
[ 67.265306] usb 2-1.3: current rate 16000 is different from the runtime rate 48000
[ 67.359564] usb 2-1.3: current rate 16000 is different from the runtime rate 48000
[ 80.511308] tegradc tegradc.0: unblank
[ 80.511519] tegradc tegradc.1: blank - powerdown
Thanks,
Jérôme
