I don’t have a serial usb device. Here’s the dmesg:
lz@jetson:~$ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29248(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3560376K/4159488K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 123976K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001780] Console: colour dummy device 80x25
[ 0.001789] console [tty0] enabled
[ 0.001795] bootconsole [uart8250] disabled
[ 0.001812] kmemleak: Kernel memory leak detector disabled
[ 0.001833] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001845] pid_max: default: 32768 minimum: 301
[ 0.002297] Security Framework initialized
[ 0.002517] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002526] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003664] ftrace: allocating 47208 entries in 185 pages
[ 0.174497] sched-energy: CPU device node has no sched-energy-costs
[ 0.174531] ASID allocator initialised with 65536 entries
[ 0.212162] tegra-id: chipid=22117.
[ 0.212175] tegra-id: opt_subrevision=0.
[ 0.212193] Tegra Speedo/IDDQ fuse revision 4
[ 0.212198] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.212203] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.212209] Tegra: CPU Speedo Value 2044, SoC Speedo Value 1965, GPU Speedo Value 2052
[ 0.212213] Tegra: CPU IDDQ Value 1944, SoC IDDQ Value 2328, GPU IDDQ Value 2785
[ 0.212271] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.212287] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.212296] DTB Build time: Feb 19 2021 08:42:41
[ 0.261112] CPU1: Booted secondary processor [411fd071]
[ 0.293012] CPU2: Booted secondary processor [411fd071]
[ 0.324973] CPU3: Booted secondary processor [411fd071]
[ 0.325068] Brought up 4 CPUs
[ 0.325075] SMP: Total of 4 processors activated.
[ 0.325085] CPU features: detected feature: 32-bit EL0 Support
[ 0.325350] CPU: All CPU(s) started at EL2
[ 0.325367] alternatives: patching kernel code
[ 0.333861] devtmpfs: initialized
[ 0.374002] Initilizing CustomIPI irq domain
[ 0.374419] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.374441] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.386010] pinctrl core: initialized pinctrl subsystem
[ 0.386640] OS set in device tree is not L4T.
[ 0.387059] regulator-dummy: no parameters
[ 0.387328] Initializing plugin-manager
[ 0.387477] Plugin module not found
[ 0.387667] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.388200] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.388932] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.389519] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.389721] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.390075] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.394959] NET: Registered protocol family 16
[ 0.396465] pstore: using zlib compression
[ 0.396508] console [pstore-1] enabled
[ 0.396511] pstore: Registered ramoops as persistent store backend
[ 0.396517] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.417132] cpuidle: using governor menu
[ 0.421555] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.423341] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.423364] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.425737] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.428245] Serial: AMBA PL011 UART driver
[ 0.428742] tegra_powergate_init: DONE
[ 0.428758] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.428765] DTB Build time: Feb 19 2021 08:42:41
[ 0.430741] Tegra reboot handler registered.
[ 0.435479] iommu: Adding device tegra-carveouts to group 0
[ 0.435624] platform tegra-carveouts: domain=ffffffc0f9bed498 allocates as[0]=ffffffc0f944c0a8
[ 0.435977] iommu: Adding device smmu_test to group 1
[ 0.436023] platform smmu_test: domain=ffffffc0f9bed6d8 allocates as[0]=ffffffc0f944c110
[ 0.436876] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.436933] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.436988] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.436998] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.437021] mc-err: mcerr ops are set to t21x
[ 0.447552] iommu: Adding device 70090000.xusb to group 2
[ 0.447877] iommu: Adding device 70006000.serial to group 3
[ 0.447940] platform 70006000.serial: domain=ffffffc0f9436d98 allocates as[0]=ffffffc0f944c178
[ 0.448374] iommu: Adding device 70006040.serial to group 4
[ 0.448637] iommu: Adding device 70006200.serial to group 5
[ 0.448823] iommu: Adding device sound to group 6
[ 0.448871] platform sound: domain=ffffffc0f94c9318 allocates as[0]=ffffffc0f944c1e0
[ 0.449465] iommu: Adding device 7000d400.spi to group 7
[ 0.449726] iommu: Adding device 7000d600.spi to group 8
[ 0.450029] iommu: Adding device 70410000.spi to group 9
[ 0.450342] iommu: Adding device 50000000.host1x to group 10
[ 0.450617] iommu: Adding device 54080000.vi to group 11
[ 0.451020] iommu: Adding device 54600000.isp to group 12
[ 0.451292] iommu: Adding device 54680000.isp to group 13
[ 0.451567] iommu: Adding device tegradc.0 to group 14
[ 0.451616] platform tegradc.0: domain=ffffffc0f94d5258 allocates as[0]=ffffffc0f944c248
[ 0.455784] platform tegradc.0: IOVA linear map 0x0000000092ca9000(800000)
[ 0.456178] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.456520] iommu: Adding device tegradc.1 to group 15
[ 0.456572] platform tegradc.1: domain=ffffffc0f94d5498 allocates as[0]=ffffffc0f944c2b0
[ 0.460723] platform tegradc.1: IOVA linear map 0x0000000092ca9000(800000)
[ 0.461135] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.461442] iommu: Adding device 54340000.vic to group 16
[ 0.461650] iommu: Adding device 544c0000.nvenc to group 17
[ 0.461837] iommu: Adding device 54500000.tsec to group 18
[ 0.462028] iommu: Adding device 54100000.tsecb to group 19
[ 0.462216] iommu: Adding device 54480000.nvdec to group 20
[ 0.462405] iommu: Adding device 54380000.nvjpg to group 21
[ 0.463447] iommu: Adding device 546c0000.i2c to group 22
[ 0.463778] iommu: Adding device 57000000.gpu to group 23
[ 0.463836] platform 57000000.gpu: domain=ffffffc0f9588498 allocates as[0]=ffffffc0f944c318
[ 0.463896] platform 57000000.gpu: domain=ffffffc0f9588498 allocates as[1]=ffffffc0f944c380
[ 0.463934] platform 57000000.gpu: domain=ffffffc0f9588498 allocates as[2]=ffffffc0f944c3e8
[ 0.463969] platform 57000000.gpu: domain=ffffffc0f9588498 allocates as[3]=ffffffc0f944c450
[ 0.464877] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.464889] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.464900] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.464905] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.464909] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.517304] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.517313] tegra-pmc: Clear bootloader IO dpd settings
[ 0.517334] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.517394] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.517697] iommu: Adding device 70012000.se to group 24
[ 0.518482] iommu: Adding device 7000c000.i2c to group 25
[ 0.518738] iommu: Adding device 7000c400.i2c to group 26
[ 0.519001] iommu: Adding device 7000c500.i2c to group 27
[ 0.519249] iommu: Adding device 7000c700.i2c to group 28
[ 0.519513] iommu: Adding device 7000d000.i2c to group 29
[ 0.519761] iommu: Adding device 7000d100.i2c to group 30
[ 0.520052] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.520110] platform sdhci-tegra.0: domain=ffffffc0f9597618 allocates as[0]=ffffffc0f944c4b8
[ 0.520952] iommu: Adding device 700d0000.xudc to group 32
[ 0.524198] vdd-ac-bat: 5000 mV
[ 0.524556] vdd-5v0-sys: 5000 mV
[ 0.525541] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.525590] vdd-5v0-hdmi: 5000 mV
[ 0.526005] vdd-1v8-sys: 1800 mV
[ 0.526455] vdd-fan: supplied by vdd-5v0-sys
[ 0.526493] vdd-fan: 5000 mV
[ 0.526878] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.526910] vdd-usb-vbus: 5000 mV
[ 0.527415] vdd-usb-vbus2: 5000 mV
[ 0.562048] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.564633] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.565884] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.565904] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.566278] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.574396] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.574742] SCSI subsystem initialized
[ 0.574977] libata version 3.00 loaded.
[ 0.575268] usbcore: registered new interface driver usbfs
[ 0.575323] usbcore: registered new interface driver hub
[ 0.575396] usbcore: registered new device driver usb
[ 0.579455] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.580978] random: fast init done
[ 0.584361] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.585331] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.588246] vdd-ddr-1v1: 1150 mV
[ 0.592303] vdd-pre-reg-1v35: 1350 mV
[ 0.596240] vdd-1v8: 1800 mV
[ 0.600241] avdd-sys-1v2: 1200 mV
[ 0.604242] vdd-pex-1v0: 1050 mV
[ 0.604940] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.605485] max77620-ldo3: at 3100 mV
[ 0.608249] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.608781] max77620-ldo5: at 3100 mV
[ 0.609315] max77620-ldo6: at 2800 mV
[ 0.612246] avdd-1v05-pll: 1050 mV
[ 0.616245] avdd-io-hdmi-dp: 1050 mV
[ 0.618711] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.619022] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.619327] max77620 4-003c: max77620 probe successful
[ 0.622165] media: Linux media interface: v0.10
[ 0.622226] Linux video capture interface: v2.00
[ 0.623181] pps_core: LinuxPPS API ver. 1 registered
[ 0.623189] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.623217] PTP clock support registered
[ 0.626379] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.627316] Advanced Linux Sound Architecture Driver Initialized.
[ 0.627973] Bluetooth: Core ver 2.22
[ 0.628027] NET: Registered protocol family 31
[ 0.628031] Bluetooth: HCI device and connection manager initialized
[ 0.628046] Bluetooth: HCI socket layer initialized
[ 0.628054] Bluetooth: L2CAP socket layer initialized
[ 0.628081] Bluetooth: SCO socket layer initialized
[ 0.629879] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.629897] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.629946] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.629961] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.633692] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.634998] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.635083] vdd-3v3-sys: 3300 mV
[ 0.635377] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.636329] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.636798] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.636835] vdd-3v3-sd: 3300 mV
[ 0.637776] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.637820] avdd-io-edp-1v05: 1050 mV
[ 0.638332] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.638369] vdd-usb-hub-en: 5000 mV
[ 0.639742] camchar: rtcpu character device driver loaded
[ 0.640563] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.642036] clocksource: Switched to clocksource arch_sys_counter
[ 0.683548] VFS: Disk quotas dquot_6.6.0
[ 0.683685] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.684177] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.684631] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.684660] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.684874] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.684880] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.684891] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.684921] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.684927] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.684943] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.684951] nvmap_page_pool_init: Total RAM pages: 1008878
[ 0.684956] nvmap_page_pool_init: nvmap page pool size: 126109 pages (492 MB)
[ 0.685051] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.685549] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.686627] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.695088] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.695558] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.695930] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.696229] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.696407] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.696707] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.696711] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.697151] NET: Registered protocol family 2
[ 0.698181] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.698395] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.698930] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.699086] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.699165] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.699583] NET: Registered protocol family 1
[ 0.700406] RPC: Registered named UNIX socket transport module.
[ 0.700412] RPC: Registered udp transport module.
[ 0.700416] RPC: Registered tcp transport module.
[ 0.700420] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.700433] PCI: CLS 0 bytes, default 64
[ 0.700669] Trying to unpack rootfs image as initramfs...
[ 1.005723] Freeing initrd memory: 6992K
[ 1.015937] host1x 50000000.host1x: initialized
[ 1.017902] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.021207] audit: initializing netlink subsys (disabled)
[ 1.021305] audit: type=2000 audit(0.867:1): initialized
[ 1.022187] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.032122] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.033623] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.034467] 9p: Installing v9fs 9p2000 file system support
[ 1.037744] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.037882] io scheduler noop registered
[ 1.038218] io scheduler cfq registered (default)
[ 1.040944] gic 702f9000.agic: GIC IRQ controller registered
[ 1.044123] iommu: Adding device 702ef000.adsp to group 33
[ 1.052950] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.053135] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.053765] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7a09411
[ 1.053773] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.055899] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.056000] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.056097] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.056292] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.056378] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.056473] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.056555] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.056650] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.056731] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.056819] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.062812] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.064545] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.066530] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.067797] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.068159] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.069353] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.069572] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 1.069816] Adding domain tsec-pd to PM domain host1x-pd
[ 1.072134] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.073159] tsec 54500000.tsec: initialized
[ 1.074813] tsec 54100000.tsecb: initialized
[ 1.075523] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.079233] nvdec 54480000.nvdec: initialized
[ 1.080293] Adding domain vic03-pd to PM domain host1x-pd
[ 1.080475] Adding domain msenc-pd to PM domain host1x-pd
[ 1.080642] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.084984] falcon 54340000.vic: initialized
[ 1.086302] falcon 544c0000.nvenc: initialized
[ 1.087695] falcon 54380000.nvjpg: initialized
[ 1.091996] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.092060] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.092093] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.092259] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.092370] display board info: id 0x0, fab 0x0
[ 1.092390] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.092396] tegra_cec 70015000.tegra_cec: probed
[ 1.092435] generic_infoframe_type: 0x87
[ 1.092592] tegradc tegradc.0: DT parsed successfully
[ 1.092633] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.093186] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.100608] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.102914] tegradc tegradc.0: probed
[ 1.107156] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.108713] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.108722] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.109232] kfuse 7000fc00.kfuse: initialized
[ 1.110949] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.111985] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.113674] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.113692] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.114250] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.115815] vdd-gpu: applied init 1000000uV constraint
[ 1.115823] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.116280] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.121554] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.121719] No Device Node present for smmu client: serial8250 !!
[ 1.121735] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.121801] iommu: Adding device serial8250 to group 35
[ 1.125601] console [ttyS0] disabled
[ 1.125781] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.125959] console [ttyS0] enabled
[ 1.127394] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.127779] serial-tegra 70006200.serial: RX in PIO mode
[ 1.127890] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.129138] [drm] Initialized
[ 1.135252] Console: switching to colour frame buffer device 240x67
[ 1.135388] tegradc tegradc.0: fb registered
[ 1.141077] brd: module loaded
[ 1.142753] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.142815] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.143360] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.143372] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.146937] loop: module loaded
[ 1.147048] tegra_profiler: version: 1.143, samples/io: 48/28
[ 1.147171] tegra_profiler: auth: init
[ 1.148604] THERMAL EST: found 2 subdevs
[ 1.148611] THERMAL EST num_resources: 0
[ 1.148619] [THERMAL EST subdev 0]
[ 1.148629] [THERMAL EST subdev 1]
[ 1.149093] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.149098] THERMAL EST: thz register success.
[ 1.149270] THERMAL EST: end of probe, return err: 0
[ 1.150554] sd: No Scsi addr parsed to reserve index
[ 1.150594] hisi_sas: driver version v1.6
[ 1.155697] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.156961] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.156971] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.160324] libphy: Fixed MDIO Bus: probed
[ 1.161068] tun: Universal TUN/TAP device driver, 1.6
[ 1.161072] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.162501] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.162507] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.162556] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.162560] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.162614] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.162619] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.162668] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.162672] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.163878] PPP generic driver version 2.4.2
[ 1.164112] PPP BSD Compression module registered
[ 1.164120] PPP Deflate Compression module registered
[ 1.164165] PPP MPPE Compression module registered
[ 1.164173] NET: Registered protocol family 24
[ 1.164260] usbcore: registered new interface driver r8152
[ 1.164307] usbcore: registered new interface driver asix
[ 1.164357] usbcore: registered new interface driver ax88179_178a
[ 1.164390] usbcore: registered new interface driver cdc_ether
[ 1.164421] usbcore: registered new interface driver net1080
[ 1.164460] usbcore: registered new interface driver cdc_subset
[ 1.164496] usbcore: registered new interface driver zaurus
[ 1.164546] usbcore: registered new interface driver cdc_ncm
[ 1.164751] VFIO - User Level meta-driver version: 0.3
[ 1.166471] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.166499] ehci-pci: EHCI PCI platform driver
[ 1.166552] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.166565] ohci-pci: OHCI PCI platform driver
[ 1.166607] ohci-platform: OHCI generic platform driver
[ 1.169478] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.169907] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.169916] Extcon AUX1(HDMI) enable
[ 1.170372] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.171572] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9046400 id
[ 1.173649] usbcore: registered new interface driver uas
[ 1.173714] usbcore: registered new interface driver usb-storage
[ 1.173859] usbcore: registered new interface driver usbserial
[ 1.174109] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.174188] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.174229] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.175043] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.175112] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.175378] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.175479] tegradc tegradc.1: No lt-data, using default setting
[ 1.175510] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.175512] tegradc tegradc.1: No hpd-gpio in DT
[ 1.175518] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.175524] usb usb1: Product: xHCI Host Controller
[ 1.175529] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.175533] usb usb1: SerialNumber: 70090000.xusb
[ 1.175554] tegradc tegradc.1: DT parsed successfully
[ 1.175622] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.176185] hub 1-0:1.0: USB hub found
[ 1.176237] hub 1-0:1.0: 5 ports detected
[ 1.177036] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.177052] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.177164] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.177288] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.177294] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.177300] usb usb2: Product: xHCI Host Controller
[ 1.177305] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 1.177309] usb usb2: SerialNumber: 70090000.xusb
[ 1.177827] hub 2-0:1.0: USB hub found
[ 1.177872] hub 2-0:1.0: 4 ports detected
[ 1.178369] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.179127] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.179132] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.179179] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.180996] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.181008] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.181026] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.181037] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.181064] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.181910] mousedev: PS/2 mouse device common for all mice
[ 1.182052] usbcore: registered new interface driver xpad
[ 1.188228] tegradc tegradc.1: probed
[ 1.191836] tegradc tegradc.1: fb registered
[ 1.195047] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.195054] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.195063] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.195076] tegradc tegradc.1: blank - powerdown
[ 1.195096] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.195102] Extcon DP: HPD disabled
[ 1.195107] hpd: hpd_switch 0
[ 1.195111] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.195121] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.195127] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.199903] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.278106] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.282258] usb usb2: usb_suspend_both: status 0
[ 1.298345] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.300484] rtc rtc1: alarm rtc device
[ 1.300497] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.300515] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.300880] i2c /dev entries driver
[ 1.302353] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.305582] tegradc tegradc.0: blank - powerdown
[ 1.325639] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.325710] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.325780] imx219 6-0010: board setup failed
[ 1.325833] imx219: probe of 6-0010 failed with error -121
[ 1.326814] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.328980] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.328985] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.329295] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.329307] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.329314] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.329441] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.329450] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.329457] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.329604] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.329612] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.329616] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.329791] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.330373] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.330419] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.330439] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.330455] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.330463] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.331368] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.331383] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.331570] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.331593] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.332017] parse_throttle_dt_data: Num cap clks = 6
[ 1.332021] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.332027] parse_throttle_dt_data: clk=gpu type=4
[ 1.332047] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.332088] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.332110] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.332114] parse_throttle_dt_data: clk=emc type=3
[ 1.332483] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.332610] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.332756] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.333309] FAN dev name: pwm-fan
[ 1.333353] FAN:gpio request success.
[ 1.333403] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.333635] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.333750] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.333756] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.333831] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.333836] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.333840] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.333844] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.333848] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.333852] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.333856] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.333859] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.333863] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.333867] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.336031] device-mapper: uevent: version 1.0.3
[ 1.336460] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.339192] tegra210-cpufreq cpufreq: probe()...completed
[ 1.339920] sdhci: Secure Digital Host Controller Interface driver
[ 1.339922] sdhci: Copyright(c) Pierre Ossman
[ 1.339923] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.340404] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.340759] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.340884] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.345011] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.345496] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.346591] usbcore: registered new interface driver usbhid
[ 1.346592] usbhid: USB HID core driver
[ 1.348786] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.348960] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.350833] nvpmodel: initialized successfully
[ 1.351900] usbcore: registered new interface driver snd-usb-audio
[ 1.351957] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.351962] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.351980] iommu: Adding device snd-soc-dummy to group 36
[ 1.353917] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.353920] Extcon AUX1(HDMI) disable
[ 1.366803] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.378801] OPE platform probe
[ 1.378892] OPE platform probe successful
[ 1.379150] OPE platform probe
[ 1.379225] OPE platform probe successful
[ 1.381874] tegradc tegradc.0: unblank
[ 1.390222] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.404842] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.404975] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.405102] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.405230] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.405359] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.405485] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.405613] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.405743] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.405871] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.405996] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.417693] u32 classifier
[ 1.417695] Actions configured
[ 1.417767] Initializing XFRM netlink socket
[ 1.418525] NET: Registered protocol family 10
[ 1.419190] NET: Registered protocol family 17
[ 1.419200] NET: Registered protocol family 15
[ 1.419271] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.419322] Bluetooth: RFCOMM socket layer initialized
[ 1.419331] Bluetooth: RFCOMM ver 1.11
[ 1.419335] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.419339] Bluetooth: HIDP socket layer initialized
[ 1.419356] 9pnet: Installing 9P2000 support
[ 1.419389] Key type dns_resolver registered
[ 1.419789] Registered cp15_barrier emulation handler
[ 1.419795] Registered setend emulation handler
[ 1.419989] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.420035] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.421034] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.422267] registered taskstats version 1
[ 1.422798] Adding domain ve2-pd to PM domain host1x-pd
[ 1.423047] Adding domain ve-pd to PM domain host1x-pd
[ 1.425121] isp 54600000.isp: initialized
[ 1.426133] isp 54680000.isp: initialized
[ 1.436412] last reset is due to software reset
[ 1.436415] KERNEL: PMC reset status reg: 0x3
[ 1.436472] BL: PMC reset status reg: 0x3
[ 1.436474] BL: PMIC poweroff Event Recorder: 0x0
[ 1.437934] clk_cbus_recalc_rate: no gbus parent
[ 1.437938] clk_cbus_round_rate: no gbus parent
[ 1.437940] clk_cbus_round_rate: no gbus parent
[ 1.437947] clk_cbus_recalc_rate: no gbus parent
[ 1.438074] clk_cbus_recalc_rate: no gbus parent
[ 1.438077] clk_cbus_round_rate: no gbus parent
[ 1.438079] clk_cbus_round_rate: no gbus parent
[ 1.438082] clk_cbus_recalc_rate: no gbus parent
[ 1.438764] tegra_dvfs: GPU-cap: registered
[ 1.438821] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.438823] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.438825] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.440331] tegra_dvfs: vdd-gpu-vts: registered
[ 1.441040] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.441609] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.443178] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.455972] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.455975] Extcon AUX1(HDMI) enable
[ 1.471545] tegradc tegradc.0: sync windows ret = 246
[ 1.476699] tegra_rtc 7000e000.rtc: setting system clock to 2021-07-13 04:10:29 UTC (1626149429)
[ 1.477801] vi 54080000.vi: vi_probe: ++
[ 1.494215] vi 54080000.vi: initialized
[ 1.500532] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.502051] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.502143] Disable partitions left on by BL
[ 1.502145] disb
[ 1.502195] bwmgr: missing cdev-type property
[ 1.502284] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.502290] DRAM derating cdev registered.
[ 1.503216] ALSA device list:
[ 1.503219] #0: tegra-hda at 0x70038000 irq 83
[ 1.503220] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.503673] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.519973] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.519975] Extcon HDMI: HPD enabled
[ 1.519991] tegradc tegradc.0: hdmi: plugged
[ 1.523142] Freeing unused kernel memory: 8576K
[ 1.543779] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.543785] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.543788] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.543791] usb 1-2: Manufacturer: Generic
[ 1.545998] hub 1-2:1.0: USB hub found
[ 1.547849] Root device found: mmcblk0p1
[ 1.548028] hub 1-2:1.0: 4 ports detected
[ 1.601987] mmc0: hw tuning done ...
[ 1.602032] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 1.602501] mmcblk0: mmc0:aaaa SB64G 59.5 GiB
[ 1.608966] mmcblk0: p1
[ 1.651605] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 1.686205] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 1.686210] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.686213] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 1.686215] usb 2-1: Manufacturer: Generic
[ 1.690464] hub 2-1:1.0: USB hub found
[ 1.693198] hub 2-1:1.0: 4 ports detected
[ 1.752890] Found dev node: /dev/mmcblk0p1
[ 1.789970] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.791986] Rootfs mounted over mmcblk0p1
[ 1.817366] Switching from initrd to actual rootfs
[ 1.850052] usb 2-1: usb_suspend_both: status 0
[ 1.850110] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 1.850237] usb usb2: usb_suspend_both: status 0
[ 1.911293] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.992246] usb 1-2.1: New USB device found, idVendor=148f, idProduct=7601
[ 1.992251] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.992255] usb 1-2.1: Product: 802.11 n WLAN
[ 1.992257] usb 1-2.1: SerialNumber: 1.0
[ 2.054460] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.066679] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.074101] usb 1-2.2: new full-speed USB device number 4 using tegra-xusb
[ 2.098907] usb 1-2.2: New USB device found, idVendor=045e, idProduct=07fd
[ 2.098912] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.098915] usb 1-2.2: Product: Microsoft Nano Transceiver 1.1
[ 2.098918] usb 1-2.2: Manufacturer: Microsoft
[ 2.099353] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.100181] systemd[1]: Detected architecture arm64.
[ 2.101970] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.0/0003:045E:07FD.0001/input/input2
[ 2.102069] tegra_cec 70015000.tegra_cec: physical address: 40:00.
[ 2.125228] systemd[1]: Set hostname to <jetson>.
[ 2.158912] hid-generic 0003:045E:07FD.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft Nano Transceiver 1.1] on usb-70090000.xusb-2.2/input0
[ 2.163784] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.1/0003:045E:07FD.0002/input/input3
[ 2.166591] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: 0.
[ 2.224619] hid-generic 0003:045E:07FD.0002: input,hidraw1: USB HID v1.11 Device [Microsoft Microsoft Nano Transceiver 1.1] on usb-70090000.xusb-2.2/input1
[ 2.226427] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.2/0003:045E:07FD.0003/input/input4
[ 2.226670] hid-generic 0003:045E:07FD.0003: input,hidraw2: USB HID v1.11 Mouse [Microsoft Microsoft Nano Transceiver 1.1] on usb-70090000.xusb-2.2/input2
[ 2.232446] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.232455] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.283955] tegra_cec 70015000.tegra_cec: Broadcast <Active Source> res: -104.
[ 2.283960] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.310051] usb 1-2.4: new full-speed USB device number 5 using tegra-xusb
[ 2.330072] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.332149] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.332265] usb 1-2.4: New USB device found, idVendor=0a12, idProduct=0001
[ 2.332269] usb 1-2.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.332272] usb 1-2.4: Product: CSR8510 A10
[ 2.379150] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.380984] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.381099] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.381215] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.381277] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.383005] systemd[1]: Created slice System Slice.
[ 2.383263] systemd[1]: Listening on udev Control Socket.
[ 2.383563] systemd[1]: Listening on Journal Audit Socket.
[ 2.435682] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.435688] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.435693] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.435696] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.435701] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.435723] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.435786] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.435962] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.436081] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.436105] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.436135] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.436155] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.436290] pci 0000:01:00.0: supports D1 D2
[ 2.436293] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.439345] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.446148] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.446181] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.446186] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.446194] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.446212] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.446228] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.446236] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.446241] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.446246] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.446551] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.446556] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.446561] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.446658] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.446842] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.446859] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.460903] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.460974] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:18:b0 from device tree
[ 2.461454] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.461468] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 2.563252] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.573378] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.573401] cpu-throttle-alert cooling device registered.
[ 2.573526] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.573540] gpu-throttle-alert cooling device registered.
[ 2.573692] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.573705] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.573719] hot-surface-alert cooling device registered.
[ 2.742829] systemd-journald[2022]: Received request to flush runtime journal from PID 1
[ 3.624250] using random self ethernet address
[ 3.628807] using random host ethernet address
[ 3.750724] random: crng init done
[ 3.754155] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.268639] Mass Storage Function, version: 2009/09/11
[ 4.268646] LUN: removable file: (no medium)
[ 4.273749] using random self ethernet address
[ 4.285673] using random host ethernet address
[ 4.485635] usbcore: registered new interface driver btusb
[ 4.569325] rndis0: HOST MAC 6e:59:70:bd:be:10
[ 4.569906] rndis0: MAC 6e:59:70:bd:be:11
[ 4.572087] usb0: HOST MAC 6e:59:70:bd:be:12
[ 4.572122] usb0: MAC 6e:59:70:bd:be:13
[ 4.572155] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.577941] l4tbr0: port 1(rndis0) entered blocking state
[ 4.577946] l4tbr0: port 1(rndis0) entered disabled state
[ 4.582270] device rndis0 entered promiscuous mode
[ 4.591543] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.599066] l4tbr0: port 2(usb0) entered blocking state
[ 4.599071] l4tbr0: port 2(usb0) entered disabled state
[ 4.599968] device usb0 entered promiscuous mode
[ 4.606565] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.158410] usb 1-2.1: reset high-speed USB device number 3 using tegra-xusb
[ 5.182540] mt7601u 1-2.1:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 5.219146] mt7601u 1-2.1:1.0: EEPROM ver:0c fae:00
[ 5.463695] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.463706] Bluetooth: BNEP socket layer initialized
[ 5.468894] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.481314] eth0: 0xffffff800d5fb000, 00:04:4b:e6:18:b0, IRQ 407
[ 5.537208] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.540415] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 5.541585] usbcore: registered new interface driver mt7601u
[ 5.706632] zram: Added device: zram0
[ 5.710468] zram: Added device: zram1
[ 5.713777] zram: Added device: zram2
[ 5.716891] zram: Added device: zram3
[ 5.743900] zram0: detected capacity change from 0 to 518541312
[ 5.818292] Adding 506384k swap on /dev/zram0. Priority:5 extents:1 across:506384k SS
[ 5.827980] zram1: detected capacity change from 0 to 518541312
[ 5.842253] Adding 506384k swap on /dev/zram1. Priority:5 extents:1 across:506384k SS
[ 5.845753] zram2: detected capacity change from 0 to 518541312
[ 5.876941] Adding 506384k swap on /dev/zram2. Priority:5 extents:1 across:506384k SS
[ 5.886655] zram3: detected capacity change from 0 to 518541312
[ 5.892754] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5.907953] Adding 506384k swap on /dev/zram3. Priority:5 extents:1 across:506384k SS
[ 7.380046] tegradc tegradc.0: unblank
[ 7.380068] tegradc tegradc.1: blank - powerdown
[ 8.747731] fuse init (API version 7.26)
[ 12.605653] tegradc tegradc.0: unblank
[ 12.605662] tegradc tegradc.1: blank - powerdown
[ 22.525598] hid-generic 0005:046D:B342.0004: unknown main item tag 0x0
[ 22.532431] input: Keyboard K380 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/bluetooth/hci0/hci0:48/0005:046D:B342.0004/input/input5
[ 22.533185] hid-generic 0005:046D:B342.0004: input,hidraw3: BLUETOOTH HID v42.01 Keyboard [Keyboard K380] on 00:1a:7d:da:71:10
[ 31.862800] vdd-fan: disabling
[ 31.862815] vdd-usb-vbus: disabling
[ 31.862825] vdd-usb-vbus2: disabling
[ 31.862861] avdd-io-edp-1v05: disabling
[ 66.966512] r8168: eth0: link up
[ 66.967325] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 67.990165] r8168: eth0: link down
[ 80.321578] r8168: eth0: link up
[ 81.334151] r8168: eth0: link down
[ 93.665717] r8168: eth0: link up
[ 94.678105] r8168: eth0: link down
[ 114.178283] r8168: eth0: link up
[ 115.190103] r8168: eth0: link down
[ 131.618010] r8168: eth0: link up
[ 132.630257] r8168: eth0: link down
[ 158.884357] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 158.950588] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 160.253062] wlan0: authenticate with 5c:e3:0e:14:e3:cc
[ 160.268945] wlan0: send auth to 5c:e3:0e:14:e3:cc (try 1/3)
[ 160.270526] wlan0: authenticated
[ 160.274098] wlan0: associate with 5c:e3:0e:14:e3:cc (try 1/3)
[ 160.478062] wlan0: associate with 5c:e3:0e:14:e3:cc (try 2/3)
[ 160.499906] wlan0: RX AssocResp from 5c:e3:0e:14:e3:cc (capab=0xc31 status=0 aid=3)
[ 160.529869] wlan0: associated
[ 160.609897] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 164.417575] r8168: eth0: link up
[ 165.430092] r8168: eth0: link down
[ 165.713705] wlan0: deauthenticating from 5c:e3:0e:14:e3:cc by local choice (Reason: 3=DEAUTH_LEAVING)
[ 169.119375] wlan0: authenticate with 5c:e3:0e:14:e3:cc
[ 169.153567] wlan0: send auth to 5c:e3:0e:14:e3:cc (try 1/3)
[ 169.156943] wlan0: authenticated
[ 169.158113] wlan0: associate with 5c:e3:0e:14:e3:cc (try 1/3)
[ 169.162798] wlan0: RX AssocResp from 5c:e3:0e:14:e3:cc (capab=0xc31 status=0 aid=3)
[ 169.194394] wlan0: associated
[ 177.761625] r8168: eth0: link up
[ 178.774090] r8168: eth0: link down
[ 211.585623] r8168: eth0: link up
[ 212.598046] r8168: eth0: link down
[ 232.099267] r8168: eth0: link up
[ 233.111862] r8168: eth0: link down
[ 252.612114] r8168: eth0: link up
