I’ve rebuilt everything from scratch and tried it with patch and without(without “quiet” in /boot/extlinux/extlinux.conf ).
SanDisk Ultra 64GB, class 10 . No, I have not, at the moment I do not have the second card.
Yes it is.
No I’m not able to see ubuntu desktop monitor. System reboots after some time, with the same error.
It was because of my mistake (custom kernel image name).
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
727 bytes read in 161 ms (3.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 292 ms (17.9 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 1546 ms (21.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,11520
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831774fa
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (framos@dev-arm07) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #8 SMP PREEMPT 0
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb2000 s61592 r8192 d32616 u102400
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29516(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3570416K/4159488K available (15230K kernel code, 2926K rwdata, 6588K rodata, 8576K init, 609K bss, 113936K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a11b808 ( 2927 KB)
[ 0.000000] .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001710] Console: colour dummy device 80x25
[ 0.002549] console [tty0] enabled
[ 0.002576] kmemleak: Kernel memory leak detector disabled
[ 0.002605] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.002635] pid_max: default: 32768 minimum: 301
[ 0.003088] Security Framework initialized
[ 0.003322] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003343] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004546] ftrace: allocating 47001 entries in 184 pages
[ 0.176575] ASID allocator initialised with 65536 entries
[ 0.215987] tegra-id: chipid=22117.
[ 0.216030] tegra-id: opt_subrevision=0.
[ 0.216058] Tegra Speedo/IDDQ fuse revision 4
[ 0.216074] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.216089] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.216105] Tegra: CPU Speedo Value 2114, SoC Speedo Value 2003, GPU Speedo Value 2120
[ 0.216126] Tegra: CPU IDDQ Value 2128, SoC IDDQ Value 2332, GPU IDDQ Value 2870
[ 0.216160] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.216187] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01.dts
[ 0.216254] DTB Build time: Dec 9 2019 22:51:54
[ 0.265040] CPU1: Booted secondary processor [411fd071]
[ 0.296981] CPU2: Booted secondary processor [411fd071]
[ 0.328944] CPU3: Booted secondary processor [411fd071]
[ 0.329031] Brought up 4 CPUs
[ 0.329095] SMP: Total of 4 processors activated.
[ 0.329113] CPU features: detected feature: 32-bit EL0 Support
[ 0.329384] CPU: All CPU(s) started at EL2
[ 0.329417] alternatives: patching kernel code
[ 0.337478] devtmpfs: initialized
[ 0.375054] Initilizing CustomIPI irq domain
[ 0.375480] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.375526] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.386015] pinctrl core: initialized pinctrl subsystem
[ 0.386695] OS set in device tree is not L4T.
[ 0.387102] regulator-dummy: no parameters
[ 0.387410] Initializing plugin-manager
[ 0.387538] Plugin module not found
[ 0.387782] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.388352] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.389480] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.389973] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.390621] node /plugin-manager/fragement@10 match with board >=3448-0000-300
[ 0.392724] node /plugin-manager/fragement@11 match with board >=3448-0000-300
[ 0.396264] NET: Registered protocol family 16
[ 0.400714] pstore: using zlib compression
[ 0.401416] console [pstore-1] enabled
[ 0.401434] pstore: Registered ramoops as persistent store backend
[ 0.401454] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.417056] cpuidle: using governor menu
[ 0.421360] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.422986] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.423028] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.425509] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.428174] tegra_powergate_init: DONE
[ 0.428214] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a01.dts
[ 0.428250] DTB Build time: Dec 9 2019 22:51:54
[ 0.430072] Tegra reboot handler registered.
[ 0.434595] iommu: Adding device tegra-carveouts to group 0
[ 0.434763] platform tegra-carveouts: domain=ffffffc0f9bcc318 allocates as[0]=ffffffc0f94200a8
[ 0.435132] iommu: Adding device smmu_test to group 1
[ 0.435198] platform smmu_test: domain=ffffffc0f9bcc558 allocates as[0]=ffffffc0f9420110
[ 0.436038] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.436111] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.436177] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.436200] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.436235] mc-err: mcerr ops are set to t21x
[ 0.446024] iommu: Adding device 70090000.xusb to group 2
[ 0.446335] iommu: Adding device 70006000.serial to group 3
[ 0.446431] platform 70006000.serial: domain=ffffffc0f94c4618 allocates as[0]=ffffffc0f9420178
[ 0.446868] iommu: Adding device 70006040.serial to group 4
[ 0.447151] iommu: Adding device 70006200.serial to group 5
[ 0.447390] iommu: Adding device sound to group 6
[ 0.447457] platform sound: domain=ffffffc0f94c4b58 allocates as[0]=ffffffc0f94201e0
[ 0.448033] iommu: Adding device 7000d400.spi to group 7
[ 0.448316] iommu: Adding device 7000d600.spi to group 8
[ 0.448612] iommu: Adding device 70410000.spi to group 9
[ 0.448932] iommu: Adding device 50000000.host1x to group 10
[ 0.449291] iommu: Adding device 54080000.vi to group 11
[ 0.449696] iommu: Adding device 54600000.isp to group 12
[ 0.449967] iommu: Adding device 54680000.isp to group 13
[ 0.450289] iommu: Adding device tegradc.0 to group 14
[ 0.450356] platform tegradc.0: domain=ffffffc0f94d1a98 allocates as[0]=ffffffc0f9420248
[ 0.450889] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.451224] iommu: Adding device tegradc.1 to group 15
[ 0.451288] platform tegradc.1: domain=ffffffc0f94d1cd8 allocates as[0]=ffffffc0f94202b0
[ 0.451814] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.452083] iommu: Adding device 54340000.vic to group 16
[ 0.452314] iommu: Adding device 544c0000.nvenc to group 17
[ 0.452531] iommu: Adding device 54500000.tsec to group 18
[ 0.452747] iommu: Adding device 54100000.tsecb to group 19
[ 0.452963] iommu: Adding device 54480000.nvdec to group 20
[ 0.453241] iommu: Adding device 54380000.nvjpg to group 21
[ 0.454311] iommu: Adding device 546c0000.i2c to group 22
[ 0.454656] iommu: Adding device 57000000.gpu to group 23
[ 0.454721] platform 57000000.gpu: domain=ffffffc0f94ddcd8 allocates as[0]=ffffffc0f9420318
[ 0.454778] platform 57000000.gpu: domain=ffffffc0f94ddcd8 allocates as[1]=ffffffc0f9420380
[ 0.454841] platform 57000000.gpu: domain=ffffffc0f94ddcd8 allocates as[2]=ffffffc0f94203e8
[ 0.454892] platform 57000000.gpu: domain=ffffffc0f94ddcd8 allocates as[3]=ffffffc0f9420450
[ 0.455786] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.455825] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.455853] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.455872] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.455890] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.509162] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509197] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509229] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509313] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509612] iommu: Adding device 70012000.se to group 24
[ 0.510468] iommu: Adding device 7000c000.i2c to group 25
[ 0.510809] iommu: Adding device 7000c400.i2c to group 26
[ 0.511147] iommu: Adding device 7000c500.i2c to group 27
[ 0.511466] iommu: Adding device 7000c700.i2c to group 28
[ 0.511836] iommu: Adding device 7000d000.i2c to group 29
[ 0.512158] iommu: Adding device 7000d100.i2c to group 30
[ 0.512521] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.512594] platform sdhci-tegra.0: domain=ffffffc0f956ce58 allocates as[0]=ffffffc0f94204b8
[ 0.513572] iommu: Adding device 700d0000.xudc to group 32
[ 0.518075] vdd-ac-bat: 5000 mV
[ 0.518550] vdd-5v0-sys: 5000 mV
[ 0.519755] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.519841] vdd-5v0-hdmi: 5000 mV
[ 0.520324] vdd-1v8-sys: 1800 mV
[ 0.520785] vdd-fan: supplied by vdd-5v0-sys
[ 0.520837] vdd-fan: 5000 mV
[ 0.521315] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.521385] vdd-usb-vbus: 5000 mV
[ 0.522041] vdd-usb-vbus2: 5000 mV
[ 0.549866] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.554214] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.554274] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.554327] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.554747] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.562591] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.562983] SCSI subsystem initialized
[ 0.563525] usbcore: registered new interface driver usbfs
[ 0.563595] usbcore: registered new interface driver hub
[ 0.563689] usbcore: registered new device driver usb
[ 0.567595] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.573246] random: fast init done
[ 0.573258] vdd-core: 600 ↔ 1162 mV at 1075 mV
[ 0.574255] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.577060] vdd-ddr-1v1: 1150 mV
[ 0.581105] vdd-pre-reg-1v35: 1350 mV
[ 0.585055] vdd-1v8: 1800 mV
[ 0.589052] avdd-sys-1v2: 1200 mV
[ 0.593053] vdd-pex-1v0: 1050 mV
[ 0.593716] vddio-sdmmc-ap: 1800 ↔ 3300 mV at 3300 mV
[ 0.594308] max77620-ldo3: at 3100 mV
[ 0.596249] vdd-rtc: 850 ↔ 1100 mV at 1000 mV
[ 0.596854] max77620-ldo5: at 3100 mV
[ 0.600241] vddio-sdmmc3-ap: 1800 ↔ 3300 mV at 2800 mV
[ 0.604241] avdd-1v05-pll: 1050 mV
[ 0.608237] avdd-io-hdmi-dp: 1050 mV
[ 0.610893] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.611191] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.611494] max77620 4-003c: max77620 probe successful
[ 0.614199] media: Linux media interface: v0.10
[ 0.614273] Linux video capture interface: v2.00
[ 0.615173] pps_core: LinuxPPS API ver. 1 registered
[ 0.615200] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.615247] PTP clock support registered
[ 0.618930] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.625291] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.626154] Advanced Linux Sound Architecture Driver Initialized.
[ 0.626825] Bluetooth: Core ver 2.22
[ 0.626897] NET: Registered protocol family 31
[ 0.626916] Bluetooth: HCI device and connection manager initialized
[ 0.626944] Bluetooth: HCI socket layer initialized
[ 0.626967] Bluetooth: L2CAP socket layer initialized
[ 0.627007] Bluetooth: SCO socket layer initialized
[ 0.628764] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.628804] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.628863] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.628890] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.632058] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.633279] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.633368] vdd-3v3-sys: 3300 mV
[ 0.633652] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.636306] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.636773] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.636827] vdd-3v3-sd: 3300 mV
[ 0.637905] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.637968] avdd-io-edp-1v05: 1050 mV
[ 0.638442] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.638495] vdd-usb-hub-en: 5000 mV
[ 0.639888] camchar: rtcpu character device driver loaded
[ 0.640654] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.641959] clocksource: Switched to clocksource arch_sys_counter
[ 0.681039] VFS: Disk quotas dquot_6.6.0
[ 0.681205] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.681695] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.682169] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.682219] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.682458] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.682483] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.682512] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.682563] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.682588] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.682621] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.682645] nvmap_page_pool_init: Total RAM pages: 1011388
[ 0.682663] nvmap_page_pool_init: nvmap page pool size: 126423 pages (493 MB)
[ 0.682798] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.683242] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.684192] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.692236] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.692688] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.692964] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.693192] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.693392] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.693667] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.693687] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.694174] NET: Registered protocol family 2
[ 0.695252] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.695488] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.695998] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.696167] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.696266] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.696694] NET: Registered protocol family 1
[ 0.697395] RPC: Registered named UNIX socket transport module.
[ 0.697427] RPC: Registered udp transport module.
[ 0.697444] RPC: Registered tcp transport module.
[ 0.697460] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.697708] Trying to unpack rootfs image as initramfs…
[ 0.929197] Freeing initrd memory: 5356K
[ 0.939393] host1x 50000000.host1x: initialized
[ 0.941192] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.944463] audit: initializing netlink subsys (disabled)
[ 0.944555] audit: type=2000 audit(0.795:1): initialized
[ 0.945323] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.955452] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.956957] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.957791] 9p: Installing v9fs 9p2000 file system support
[ 0.961133] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.961292] io scheduler noop registered
[ 0.961595] io scheduler cfq registered (default)
[ 0.964348] gic 702f9000.agic: GIC IRQ controller registered
[ 0.967386] iommu: Adding device 702ef000.adsp to group 33
[ 0.976547] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.976726] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.977378] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9228c12
[ 0.977411] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.979113] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.979260] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.979372] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.979582] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.979695] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.979809] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.979915] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.980026] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.980130] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.980241] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.986352] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.988158] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.990192] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.991475] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.991846] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.993078] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.993330] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.993602] Adding domain tsec-pd to PM domain host1x-pd
[ 0.995995] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.996933] tsec 54500000.tsec: initialized
[ 0.998547] tsec 54100000.tsecb: initialized
[ 0.999263] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.002666] nvdec 54480000.nvdec: initialized
[ 1.003735] Adding domain vic03-pd to PM domain host1x-pd
[ 1.003936] Adding domain msenc-pd to PM domain host1x-pd
[ 1.004115] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.008242] falcon 54340000.vic: initialized
[ 1.009476] falcon 544c0000.nvenc: initialized
[ 1.010866] falcon 54380000.nvjpg: initialized
[ 1.015252] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.015343] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.015390] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.015500] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.015641] display board info: id 0x0, fab 0x0
[ 1.015713] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.015732] generic_infoframe_type: 0x87
[ 1.015749] tegra_cec 70015000.tegra_cec: probed
[ 1.015872] tegradc tegradc.0: DT parsed successfully
[ 1.015940] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.023164] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.028392] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.029068] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.029357] kfuse 7000fc00.kfuse: initialized
[ 1.030389] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.031368] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.032555] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.032592] vdd-cpu: 708 ↔ 1322 mV at 708 mV
[ 1.032994] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.034279] vdd-gpu: applied init 1000000uV constraint
[ 1.034305] vdd-gpu: 708 ↔ 1323 mV at 997 mV
[ 1.034669] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.038309] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.038437] No Device Node present for smmu client: serial8250 !!
[ 1.038461] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.038527] iommu: Adding device serial8250 to group 35
[ 1.040821] console [ttyS0] disabled
[ 1.040912] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.059857] tegradc tegradc.0: probed
[ 1.521305] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.925753] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.037980] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.037986] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.329665] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.331684] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.437816] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.437824] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.437828] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.437833] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.437838] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.438270] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.450104] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.450110] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.450119] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.450140] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.450158] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.450168] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.450174] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.450180] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.450584] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.450589] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.447736] console [ttyS0] enabled
[ 3.448379] Console: switching to colour frame buffer device 240x75
[ 3.451270] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.451615] serial-tegra 70006200.serial: RX in PIO mode
[ 3.451718] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.452766] [drm] Initialized
[ 3.479522] brd: module loaded
[ 3.487759] tegradc tegradc.0: fb registered
[ 3.490227] loop: module loaded
[ 3.490330] tegra_profiler: version: 1.139, samples/io: 47/27
[ 3.492107] tegra_profiler: auth: init
[ 3.496528] THERMAL EST: found 2 subdevs
[ 3.496534] THERMAL EST num_resources: 0
[ 3.496540] [THERMAL EST subdev 0]
[ 3.496545] [THERMAL EST subdev 1]
[ 3.497019] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.497022] THERMAL EST: thz register success.
[ 3.497168] THERMAL EST: end of probe, return err: 0
[ 3.498326] hisi_sas: driver version v1.6
[ 3.503418] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.504564] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.504571] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.517665] libphy: Fixed MDIO Bus: probed
[ 3.518568] tun: Universal TUN/TAP device driver, 1.6
[ 3.518570] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.519632] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.519634] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.519698] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.519699] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.519751] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.519753] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.519802] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.519804] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.520749] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 3.520776] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.535379] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.535557] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e5:b2:f4 from device tree
[ 3.536123] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.536182] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
[ 3.536182] This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
[ 3.536182] This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.536748] PPP generic driver version 2.4.2
[ 3.536945] PPP BSD Compression module registered
[ 3.536950] PPP Deflate Compression module registered
[ 3.536990] PPP MPPE Compression module registered
[ 3.536996] NET: Registered protocol family 24
[ 3.537072] usbcore: registered new interface driver r8152
[ 3.537117] usbcore: registered new interface driver asix
[ 3.537170] usbcore: registered new interface driver ax88179_178a
[ 3.537209] usbcore: registered new interface driver cdc_ether
[ 3.537253] usbcore: registered new interface driver net1080
[ 3.537300] usbcore: registered new interface driver cdc_subset
[ 3.537338] usbcore: registered new interface driver zaurus
[ 3.537393] usbcore: registered new interface driver cdc_ncm
[ 3.537569] VFIO - User Level meta-driver version: 0.3
[ 3.538859] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.538883] ehci-pci: EHCI PCI platform driver
[ 3.538931] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.538942] ohci-pci: OHCI PCI platform driver
[ 3.538981] ohci-platform: OHCI generic platform driver
[ 3.541672] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.542211] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.543391] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9012c00 id
[ 3.545584] usbcore: registered new interface driver uas
[ 3.545729] usbcore: registered new interface driver usb-storage
[ 3.545852] usbcore: registered new interface driver usbserial
[ 3.546057] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 3.546105] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.546129] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 3.546884] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 3.546938] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 3.547558] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.547563] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.547568] usb usb1: Product: xHCI Host Controller
[ 3.547571] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.547575] usb usb1: SerialNumber: 70090000.xusb
[ 3.548206] hub 1-0:1.0: USB hub found
[ 3.548248] hub 1-0:1.0: 5 ports detected
[ 3.548882] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.548893] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 3.549000] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.549098] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.549103] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.549107] usb usb2: Product: xHCI Host Controller
[ 3.549110] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.549114] usb usb2: SerialNumber: 70090000.xusb
[ 3.549554] hub 2-0:1.0: USB hub found
[ 3.549585] hub 2-0:1.0: 4 ports detected
[ 3.553180] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.554504] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.554518] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.554552] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.554800] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.555483] mousedev: PS/2 mouse device common for all mice
[ 3.555588] usbcore: registered new interface driver xpad
[ 3.650051] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 3.683365] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.685906] rtc rtc1: alarm rtc device
[ 3.685922] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.685985] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.686517] i2c /dev entries driver
[ 3.688437] i2c i2c-6: Added multiplexed i2c bus 7
[ 3.688801] i2c i2c-6: Added multiplexed i2c bus 8
[ 3.688808] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 3.689537] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.712873] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.712961] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.712994] imx219 7-0010: board setup failed
[ 3.713093] imx219: probe of 7-0010 failed with error -121
[ 3.713625] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.736895] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.736966] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.736995] imx219 8-0010: board setup failed
[ 3.737061] imx219: probe of 8-0010 failed with error -121
[ 3.738159] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.740733] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.740738] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.741756] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.741800] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.741824] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.742382] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.742413] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.742432] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.743037] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.743063] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.743078] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.743773] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.746095] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.746276] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.746355] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.746419] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.746449] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.749888] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.749940] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.750848] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 3.752586] parse_throttle_dt_data: Num cap clks = 6
[ 3.752602] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.752629] parse_throttle_dt_data: clk=gpu type=4
[ 3.752702] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.752765] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.752837] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.752848] parse_throttle_dt_data: clk=emc type=3
[ 3.754175] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.754665] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.755216] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.757626] FAN dev name: pwm-fan
[ 3.757798] FAN:gpio request success.
[ 3.758055] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.759055] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.759492] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.759518] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.759828] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.759845] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.759861] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.759877] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.759892] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.759907] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.759922] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.759937] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.759952] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.759968] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.761844] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.762986] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.766042] device-mapper: uevent: version 1.0.3
[ 3.767878] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.777921] tegra210-cpufreq cpufreq: probe()…completed
[ 3.780676] sdhci: Secure Digital Host Controller Interface driver
[ 3.780680] sdhci: Copyright(c) Pierre Ossman
[ 3.780685] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.782361] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.783633] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.783867] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.795836] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.797711] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.802156] usbcore: registered new interface driver usbhid
[ 3.802161] usbhid: USB HID core driver
[ 3.808068] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.808513] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.814990] nvpmodel: initialized successfully
[ 3.818743] usbcore: registered new interface driver snd-usb-audio
[ 3.818932] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.818947] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.819004] iommu: Adding device snd-soc-dummy to group 36
[ 3.832690] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 3.834356] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.881832] OPE platform probe
[ 3.882020] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 3.882274] OPE platform probe successful
[ 3.882776] OPE platform probe
[ 3.883064] OPE platform probe successful
[ 3.916985] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 3.917000] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.917011] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 3.917021] usb 1-2: Manufacturer: Generic
[ 3.920610] hub 1-2:1.0: USB hub found
[ 3.921401] hub 1-2:1.0: 4 ports detected
[ 3.963187] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 3.963583] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 3.963962] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 3.964359] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 3.964736] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 3.965115] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 3.965491] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 3.965876] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 3.966362] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 3.966742] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 4.008905] u32 classifier
[ 4.008909] Actions configured
[ 4.009151] Initializing XFRM netlink socket
[ 4.011890] NET: Registered protocol family 10
[ 4.014468] NET: Registered protocol family 17
[ 4.014503] NET: Registered protocol family 15
[ 4.014779] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.014939] Bluetooth: RFCOMM socket layer initialized
[ 4.014963] Bluetooth: RFCOMM ver 1.11
[ 4.014977] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.014992] Bluetooth: HIDP socket layer initialized
[ 4.015055] 9pnet: Installing 9P2000 support
[ 4.015172] Key type dns_resolver registered
[ 4.021093] Registered cp15_barrier emulation handler
[ 4.021545] Registered setend emulation handler
[ 4.025809] registered taskstats version 1
[ 4.027285] Adding domain ve2-pd to PM domain host1x-pd
[ 4.027692] Adding domain ve-pd to PM domain host1x-pd
[ 4.042219] mmc0: hw tuning done …
[ 4.042363] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 4.043303] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 4.050431] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 4.222152] usb 1-2.3: new high-speed USB device number 3 using tegra-xusb
[ 4.244160] usb 1-2.3: New USB device found, idVendor=0451, idProduct=8142
[ 4.244173] usb 1-2.3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 4.244183] usb 1-2.3: SerialNumber: 22010869509D
[ 4.245880] hub 1-2.3:1.0: USB hub found
[ 4.246029] hub 1-2.3:1.0: 4 ports detected
[ 4.534146] usb 1-2.3.2: new low-speed USB device number 4 using tegra-xusb
[ 4.561899] usb 1-2.3.2: New USB device found, idVendor=046d, idProduct=c050
[ 4.561912] usb 1-2.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.561922] usb 1-2.3.2: Product: USB-PS/2 Optical Mouse
[ 4.561931] usb 1-2.3.2: Manufacturer: Logitech
[ 4.569162] input: Logitech USB-PS/2 Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.2/1-2.3.2:1.0/0003:046D:C050.0001/input/input1
[ 4.570662] hid-generic 0003:046D:C050.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-70090000.xusb-2.3.2/input0
[ 4.658144] usb 1-2.3.3: new low-speed USB device number 5 using tegra-xusb
[ 4.685321] usb 1-2.3.3: New USB device found, idVendor=046d, idProduct=c31c
[ 4.685334] usb 1-2.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.685343] usb 1-2.3.3: Product: USB Keyboard
[ 4.685352] usb 1-2.3.3: Manufacturer: Logitech
[ 4.694862] input: Logitech USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.0/0003:046D:C31C.0002/input/input2
[ 4.755974] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-70090000.xusb-2.3.3/input0
[ 4.766001] input: Logitech USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3:1.1/0003:046D:C31C.0003/input/input3
[ 4.822786] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-70090000.xusb-2.3.3/input1
[ 4.910146] usb 1-2.3.4: new high-speed USB device number 6 using tegra-xusb
[ 4.932516] usb 1-2.3.4: New USB device found, idVendor=0451, idProduct=8142
[ 4.932529] usb 1-2.3.4: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 4.932539] usb 1-2.3.4: SerialNumber: 02010879509D
[ 4.934445] hub 1-2.3.4:1.0: USB hub found
[ 4.934720] hub 1-2.3.4:1.0: 4 ports detected
[ 5.096889] tegradc tegradc.0: nominal-pclk:154128000 parent:154126875 div:1.0 pclk:154126875 152586720~167999520
[ 5.107362] tegradc tegradc.0: hdmi: tmds rate:154128K prod-setting:prod_c_hdmi_150m_300m
[ 5.116932] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 5.122783] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5.164160] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5.170323] Extcon AUX1(HDMI) enable
[ 5.175305] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 5.181923] tegradc tegradc.1: No lt-data, using default setting
[ 5.188037] tegradc tegradc.1: No hpd-gpio in DT
[ 5.192854] tegradc tegradc.1: DT parsed successfully
[ 5.198056] tegradc tegradc.1: Display dc.ffffff800acc0000 registered with id=1
[ 5.207828] tegradc tegradc.1: dpd enable lookup fail:-19
[ 5.220982] tegradc tegradc.1: probed
[ 5.222038] usb 1-2.3.4.3: new full-speed USB device number 7 using tegra-xusb
[ 5.232630] tegradc tegradc.1: fb registered
[ 5.240180] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 5.244653] isp 54600000.isp: initialized
[ 5.246842] isp 54680000.isp: initialized
[ 5.255522] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 5.263451] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.269017] tegradc tegradc.1: blank - powerdown
[ 5.273724] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 5.278929] usb 1-2.3.4.3: New USB device found, idVendor=0451, idProduct=ca01
[ 5.278944] usb 1-2.3.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.278956] usb 1-2.3.4.3: Product: Texas Instruments USBtoI2C Solution
[ 5.278966] usb 1-2.3.4.3: Manufacturer: Texas Instruments
[ 5.278975] usb 1-2.3.4.3: SerialNumb
[ 5.283311] last reset is due to power on reset
[ 5.283318] KERNEL: PMC reset status reg: 0x0
[ 5.283486] BL: PMC reset status reg: 0x0
[ 5.283492] BL: PMIC poweroff Event Recorder: 0x40
[ 5.287316] clk_cbus_recalc_rate: no gbus parent
[ 5.287327] clk_cbus_round_rate: no gbus parent
[ 5.287333] clk_cbus_round_rate: no gbus parent
[ 5.287350] clk_cbus_recalc_rate: no gbus parent
[ 5.287629] clk_cbus_recalc_rate: no gbus parent
[ 5.287639] clk_cbus_round_rate: no gbus parent
[ 5.287645] clk_cbus_round_rate: no gbus parent
[ 5.287657] clk_cbus_recalc_rate: no gbus parent
[ 5.287706] tegra_dvfs: GPU-cap: registered
[ 5.287875] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 5.287883] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 5.287891] tegra dvfs: vdd-gpu: nominal 1038mV, offset 708000uV, step 10000uV, scaling enabled
[ 5.291696] tegra_dvfs: vdd-gpu-vts: registered
[ 5.293200] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 5.296262] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 5.297730] input: gpio-keys as /devices/gpio-keys/input/input4
[ 5.303420] hid-generic 0003:0451:CA01.0004: hidraw3: USB HID v1.00 Device [Texas Instruments Texas Instruments USBtoI2C Solution] on usb-70090000.xusb-2.3.4.3/input0
[ 5.335376] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 5.337530] vi 54080000.vi: vi_probe: ++
[ 5.344835] vi 54080000.vi: initialized
[ 5.348574] vi 54080000.vi: subdev nvcsi–2 bound
[ 5.348949] vi 54080000.vi: subdev nvcsi–1 bound
[ 5.349568] mmcblk mmc0:aaaa: Card claimed for testing.
[ 5.353640] Disable partitions left on by BL
[ 5.353647] disb
[ 5.353776] bwmgr: missing cdev-type property
[ 5.354135] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.354149] DRAM derating cdev registered.
[ 5.357160] vdd-fan: disabling
[ 5.357167] vdd-usb-vbus: disabling
[ 5.357173] vdd-usb-vbus2: disabling
[ 5.357200] vddio-sdmmc3-ap: disabling
[ 5.357388] avdd-io-edp-1v05: disabling
[ 5.357395] vdd-usb-hub-en: disabling
[ 5.357537] ALSA device list:
[ 5.357545] #0: tegra-hda at 0x70038000 irq 83
[ 5.357550] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.531115] Extcon DP: HPD disabled
[ 5.531121] hpd: hpd_switch 0
[ 5.531130] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.531152] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.531164] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.531230] tegradc tegradc.0: blank - powerdown
[ 5.579355] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 5.579362] Extcon AUX1(HDMI) disable
[ 5.664313] tegradc tegradc.0: unblank
[ 5.729871] tegradc tegradc.0: nominal-pclk:154000000 parent:153999375 div:1.0 pclk:153999375 152460000~167860000
[ 5.730071] tegradc tegradc.0: hdmi: tmds rate:154000K prod-setting:prod_c_hdmi_150m_300m
[ 5.731445] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 5.731462] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5.767025] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5.767031] Extcon AUX1(HDMI) enable
[ 5.767929] tegradc tegradc.0: sync windows ret = 250
[ 6.062015] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 6.062023] Extcon HDMI: HPD enabled
[ 6.062067] tegradc tegradc.0: hdmi: plugged
[ 6.114233] Freeing unused kernel memory: 8576K
[ 6.202255] Root device found: mmcblk0p1
[ 6.220192] Found dev node: /dev/mmcblk0p1
[ 6.490856] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 6.505937] EXT4-fs (mmcblk0p1): recovery complete
[ 6.540267] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.560389] Rootfs mounted over mmcblk0p1
[ 6.637402] Switching from initrd to actual rootfs
[ 6.924069] systemd[1]: System time before build time, advancing clock.
[ 6.995853] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.058884] cgroup: cgroup2: unknown option “nsdelegate”
[ 7.103829] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -ID)
[ 7.148591] systemd[1]: Detected architecture arm64.
[ 7.295543] systemd[1]: Set hostname to .
[ 7.551149] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 7.578990] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 7.711079] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 7.727731] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 8.006483] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.031903] systemd[1]: Created slice System Slice.
[ 8.047820] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 8.076543] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 8.076557] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.076567] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 8.076576] usb 2-1: Manufacturer: Generic
[ 8.144922] hub 2-1:1.0: USB hub found
[ 8.145067] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.145897] systemd[1]: Listening on Journal Socket.
[ 8.193657] hub 2-1:1.0: 4 ports detected
[ 8.219569] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.244456] systemd[1]: Mounting POSIX Message Queue File System…
[ 8.273509] systemd[1]: Reached target User and Group Name Lookups.
[ 8.303152] systemd[1]: Listening on udev Kernel Socket.
[ 8.482586] usb 2-1.3: new SuperSpeed USB device number 3 using tegra-xusb
[ 8.503779] usb 2-1.3: New USB device found, idVendor=0451, idProduct=8140
[ 8.521220] usb 2-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.523310] hub 2-1.3:1.0: USB hub found
[ 8.523571] hub 2-1.3:1.0: 4 ports detected
[ 8.631617] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.810385] usb 2-1.3.4: new SuperSpeed USB device number 4 using tegra-xusb
[ 8.830761] usb 2-1.3.4: New USB device found, idVendor=0451, idProduct=8140
[ 8.830778] usb 2-1.3.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.833009] hub 2-1.3.4:1.0: USB hub found
[ 8.833182] hub 2-1.3.4:1.0: 4 ports detected
[ 8.958068] usb 2-1.3.4: usb_suspend_both: status 0
[ 8.998050] usb 2-1.3: usb_suspend_both: status 0
[ 9.070074] usb 2-1: usb_suspend_both: status 0
[ 9.070394] usb usb2: usb_suspend_both: status 0
[ 9.179334] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 10.687769] random: crng init done
[ 10.698519] random: 7 urandom warning(s) missed due to ratelimiting
[ 12.325743] using random self ethernet address
[ 12.340490] using random host ethernet address
[ 14.252903] using random self ethernet address
[ 14.264451] using random host ethernet address
[ 17.752136] nvgpu: 57000000.gpu __nvgpu_timeout_expired_msg_cpu:94 [ERR] Timeout detected @ gr_gk20a_ctx_wait_ucode+0xa4/0x3a8 [nvgpu]
[ 17.774307] nvgpu: 57000000.gpu gr_gk20a_ctx_wait_ucode:528 [ERR] timeout waiting on mailbox=0 value=0x00000010
[ 17.794474] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 17.811438] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x40
[ 17.840930] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x1
[ 17.862057] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 17.879896] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 17.900256] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 17.916831] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 17.933515] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 17.950923] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 17.967436] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 17.984494] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 18.001332] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x300
[ 18.020350] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x10
[ 18.037746] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 18.037777] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x41009
[ 18.037795] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x20
[ 18.037811] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 18.037824] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 18.037836] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 18.037847] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 18.037857] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 18.037869] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 18.037879] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 18.037889] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 18.037899] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 18.037919] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 18.037929] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 18.037940] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 18.038000] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 18.038010] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 18.038020] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 18.038032] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 18.038042] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 18.038052] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 18.038063] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 18.038073] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 18.038085] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 18.038097] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 18.038108] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 18.038118] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 18.038128] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 18.038138] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 18.038147] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 18.038157] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 18.038636] nvgpu: 57000000.gpu gr_gk20a_submit_fecs_method_op:579 [ERR] fecs method: data=0x807ff65e push adr=0x00000009
[ 18.038647] nvgpu: 57000000.gpu gr_gk20a_fecs_ctx_image_save:1367 [ERR] save context image failed
Ubuntu 18.04.3 LTS nvidia-desktop ttyS0
nvidia-desktop login: [ 25.954264] nvgpu: 57000000.gpu nvgpu_set_error_notifier_locked:137 [ERR] error notifier set to 8 for ch 507
Dump for CPU1:
pid: 4391 comm: snapd
x0 ffffffc0fa000001 x1 000000000000000a
x2 0000000000000000 x3 0000000000000000
x4 000000000000000a x5 ffffffc0fa000000
x6 000000000000000f x7 ffffffc0fa000028
x8 ffffffc0fa000000 x9 ffffff8009e64440
x10 0000000000000040 x11 0000000000000001
x12 0000000000000000 x13 0000000000000000
x14 00000044203db930 x15 0000000000000000
x16 0000000000000000 x17 0000000000018da2
x18 0000007f9892ea70 x19 000000000000000a
x20 000000000000000a x21 0000000000000000
x22 0000000000000000 x23 ffffffc0ece7bad0
x24 ffffffc0fa5d0000 x25 ffffffc0fefcb060
x26 ffffffc0fefcf050 x27 0000005571667000
x28 ffffffc0ece70000 x29 ffffffc0fefcef90
x30 ffffff80084646cc sp ffffffc0fefcef90
pc ffffff8008464618 cpsr a00001c5 (EL1h)
__radix_tree_lookup+0x68/0xe0:
pc ffffff8008464618 sp ffffffc0fefcef90 fp ffffffc0fefcef90
generic_handle_irq+0x28/0x50:
pc ffffff8008122240 sp ffffffc0fefcefa0 fp ffffffc0fefcefa0
__handle_domain_irq+0x68/0xc0:
pc ffffff8008122930 sp ffffffc0fefcefb0 fp ffffffc0fefcefc0
gic_handle_irq+0x5c/0xb0:
pc ffffff8008080d44 sp ffffffc0fefcefd0 fp ffffffc0fefcf000
el1_irq+0xe8/0x18c:
pc ffffff8008082be8 sp ffffffc0fefcf010 fp ffffffc0fefcf040
ptep_clear_flush+0x68/0x90:
pc ffffff8008215e48 sp ffffffc0ece7bad0 fp ffffffc0ece7bc00
wp_page_copy+0x2f8/0x870:
pc ffffff80081fefe0 sp ffffffc0ece7bc10 fp ffffffc0ece7bc30
do_wp_page+0x1cc/0x5d0:
pc ffffff8008201704 sp ffffffc0ece7bc40 fp ffffffc0ece7bcb0
handle_mm_fault+0x69c/0xa68:
pc ffffff8008204c74 sp ffffffc0ece7bcc0 fp ffffffc0ece7bd20
do_page_fault+0x308/0x518:
pc ffffff80080a36b0 sp ffffffc0ece7bd30 fp ffffffc0ece7bdb0
do_mem_abort+0x54/0xb0:
pc ffffff8008080954 sp ffffffc0ece7bdc0 fp ffffffc0ece7be10
el0_da+0x20/0x24:
pc ffffff80080833c8 sp ffffffc0ece7be20 fp 0000000000000000
debug> x0 ffffffc0fa000001 x1 000000000000000a
sp_el0 ffffffc0ece70000
elr_el1 ffffff8008215e48
spsr_el1 60000145
debug> [ 25.964573] nvgpu: 57000000.gpu gk20a_fifo_handle_sched_error:2522 [ERR] fifo sched ctxsw timeout error: engine=0, tsg=4, ms=3100
[ 25.964698] tegradc tegradc.0: blank - powerdown
[ 25.964908] ---- mlocks ----
[ 25.964924]
[ 25.964929] ---- syncpts ----
[ 25.964943] id 1 (disp0_a) min 1 max 1 refs 1 (previous client : )
[ 25.964953] id 2 (disp0_b) min 1 max 1 refs 1 (previous client : )
[ 25.964962] id 3 (disp0_c) min 1 max 1 refs 1 (previous client : )
[ 25.964975] id 8 (gm20b_507) min 2 max 4 refs 1 (previous client : )
[ 25.965003] id 26 (vblank0) min 1212 max -2 refs 1 (previous client : )
[ 25.965210]
[ 25.965215] ---- channels ----
[ 25.965232]
[ 25.965232] ---- host general irq ----
[ 25.965232]
[ 25.965239] sync_hintmask_ext = 0xc0000000
[ 25.965245] sync_hintmask = 0x80000000
[ 25.965251] sync_intc0mask = 0x00000001
[ 25.965257] sync_intmask = 0x00000011
[ 25.965262]
[ 25.965262] ---- host syncpt irq mask ----
[ 25.965262]
[ 25.965269] syncpt_thresh_int_mask(0) = 0x00010001
[ 25.965275] syncpt_thresh_int_mask(1) = 0x00000000
[ 25.965282] syncpt_thresh_int_mask(2) = 0x00000000
[ 25.965288] syncpt_thresh_int_mask(3) = 0x00000000
[ 25.965294] syncpt_thresh_int_mask(4) = 0x00000000
[ 25.965299] syncpt_thresh_int_mask(5) = 0x00000000
[ 25.965305] syncpt_thresh_int_mask(6) = 0x00000000
[ 25.965311] syncpt_thresh_int_mask(7) = 0x00000000
[ 25.965317] syncpt_thresh_int_mask(8) = 0x00000000
[ 25.965323] syncpt_thresh_int_mask(9) = 0x00000000
[ 25.965329] syncpt_thresh_int_mask(10) = 0x00000000
[ 25.965336] syncpt_thresh_int_mask(11) = 0x00000000
[ 25.965340]
[ 25.965340] ---- host syncpt irq status ----
[ 25.965340]
[ 25.965347] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 25.965353] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 25.965359] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 25.965365] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 25.965371] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 25.965377] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 25.965382]
[ 25.965382] ---- host syncpt thresh ----
[ 25.965382]
[ 25.965389] syncpt_int_thresh_thresh_0(0) = 1
[ 25.965402] syncpt_int_thresh_thresh_0(8) = 4
[ 25.965556] gm20b pbdma 0:
[ 25.965557] id: 4 (tsg), next_id: 4 (tsg) chan status: valid
[ 25.965590] PBDMA_PUT: 0000001e000081d0 PBDMA_GET: 0000001e00000044 GP_PUT: 00000006 GP_GET: 00000004 FETCH: 00000006 HEADER: 800302ec
[ 25.965590] HDR: 800160bb SHADOW0: 00000004 SHADOW1: 0081cc1e
[ 25.965591]
[ 25.965606] gm20b eng 0:
[ 25.965611] id: 4 (tsg), next_id: 4 (tsg), ctx status: load
[ 25.965616] busy
[ 25.965616]
[ 25.965643] gm20b eng 1:
[ 25.965648] id: 4 (tsg), next_id: 4 (tsg), ctx status: invalid
[ 25.965649]
[ 25.965652]
[ 25.966115] 507-gm20b, pid 5716, refs 4:
[ 25.966117] channel status: in use on_pbdma_and_eng busy
[ 25.966139] RAMFC : TOP: 8000001e00000044 PUT: 0000001e000081d0 GET: 0000001e00000044 FETCH: 00eaa01e00000c80
[ 25.966139] HEADER: 800302ec COUNT: 01110001
[ 25.966139] SYNCPOINT 00000000 00000801 SEMAPHORE 0000000d fc002000 00000000 01100002
[ 25.966153]
[ 25.966174] 508-gm20b, pid 4650, refs 2:
[ 25.966175] channel status: in use idle not busy
[ 25.966198] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[ 25.966198] HEADER: 60400000 COUNT: 00000000
[ 25.966198] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
[ 25.966204]
[ 25.966221] 509-gm20b, pid 4650, refs 2:
[ 25.966222] channel status: in use idle not busy
[ 25.966238] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[ 25.966238] HEADER: 60400000 COUNT: 00000000
[ 25.966238] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
[ 25.966255]
[ 25.966276] 510-gm20b, pid 4650, refs 2:
[ 25.966276] channel status: in use idle not busy
[ 25.966292] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[ 25.966292] HEADER: 60400000 COUNT: 00000000
[ 25.966292] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
[ 25.966298]
[ 25.966322] 511-gm20b, pid 4650, refs 2:
[ 25.966322] channel status: in use idle not busy
[ 25.966338] RAMFC : TOP: 0000000000000000 PUT: 0000000000000000 GET: 0000000000000000 FETCH: 0000000000000000
[ 25.966338] HEADER: 60400000 COUNT: 00000000
[ 25.966338] SYNCPOINT 00000000 00000000 SEMAPHORE 00000000 00000000 00000000 00000000
[ 25.966344]
[ 25.966694] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1721 [ERR] fake mmu fault on engine 0, engine subid 0 (gpc), client 3 (l1 1), addr 0x1fe5899000, type 12 (bad kind), access_type 0x00
[ 25.966706] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 25.966717] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x40
[ 25.966727] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x1
[ 25.966736] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 25.966746] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 25.966755] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 25.966765] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 25.966774] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 25.966783] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 25.966793] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 25.966803] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 25.966812] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x200
[ 25.966823] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x1
[ 25.966833] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 25.966843] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x90009
[ 25.966853] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x0
[ 25.966863] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 25.966873] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x1
[ 25.966882] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x1
[ 25.966891] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 25.966901] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 25.966910] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 25.966919] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 25.966929] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x1
[ 25.966938] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 25.966948] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 25.966958] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 25.966967] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 25.966977] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 25.966990] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 25.966999] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 25.967009] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 25.967019] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 25.967029] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 25.967039] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 25.967049] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 25.967059] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 25.967070] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 25.967079] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 25.967089] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 25.967099] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 25.967108] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 25.967118] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 25.967127] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 25.967137] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1726 [ERR] gr_status_r : 0x81
[ 47.068475] CPU1: SError detected, daif=140, spsr=0x40000045, mpidr=80000001, esr=bf000002
[ 68.122261] INFO: rcu_preempt self-detected stall on CPU
[ 68.122280] 0-…: (1 GPs behind) idle=cdf/140000000000002/0 softirq=8845/8846 fqs=0
[ 68.122294] (t=10527 jiffies g=1444 c=1443 q=205)
[ 68.122308] rcu_preempt kthread starved for 10527 jiffies! g1444 c1443 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[ 68.122323] rcu_preempt S 0 7 2 0x00000000
[ 68.122329] Call trace:
[ 68.122351] [] __switch_to+0x9c/0xc0
[ 68.122370] [] __schedule+0x270/0x780
[ 68.122383] [] schedule+0x40/0xa8
[ 68.122394] [] schedule_timeout+0x88/0x420
[ 68.122408] [] rcu_gp_kthread+0x4a4/0x7d8
[ 68.122418] [] kthread+0xec/0xf0
[ 68.122429] [] ret_from_fork+0x10/0x40
[ 68.122450] Task dump for CPU 0:
[ 68.122467] irq/80-gk20a_st R running task 0 2707 2 0x00000000
[ 68.122471] Call trace:
[ 68.122484] [] dump_backtrace+0x0/0x198
[ 68.122496] [] show_stack+0x24/0x30
[ 68.122510] [] sched_show_task+0xf8/0x148
[ 68.122519] [] dump_cpu_task+0x48/0x58
[ 68.122533] [] rcu_dump_cpu_stacks+0xb8/0xec
[ 68.122545] [] rcu_check_callbacks+0x728/0xa48
[ 68.122556] [] update_process_times+0x34/0x60
[ 68.122569] [] tick_sched_handle.isra.5+0x38/0x70
[ 68.122580] [] tick_sched_timer+0x4c/0x90
[ 68.122589] [] __hrtimer_run_queues+0xd8/0x360
[ 68.122599] [] hrtimer_interrupt+0xa8/0x1e0
[ 68.122614] [] tegra210_timer_isr+0x38/0x48
[ 68.122625] [] __handle_irq_event_percpu+0x68/0x288
[ 68.122635] [] handle_irq_event_percpu+0x28/0x60
[ 68.122644] [] handle_irq_event+0x50/0x80
[ 68.122655] [] handle_fasteoi_irq+0xc8/0x1b8
[ 68.122663] [] generic_handle_irq+0x34/0x50
[ 68.122671] [] __handle_domain_irq+0x68/0xc0
[ 68.122679] [] gic_handle_irq+0x5c/0xb0
[ 68.122688] [] el1_irq+0xe8/0x18c
[ 68.122700] [] irq_exit+0xd0/0x118
[ 68.122709] [] __handle_domain_irq+0x6c/0xc0
[ 68.122717] [] gic_handle_irq+0x5c/0xb0
[ 68.122724] [] el1_irq+0xe8/0x18c
[ 68.122732] [] el1_serr+0xa8/0x148
[ 68.123761] [] nvgpu_readl+0x28/0x60 [nvgpu]
[ 68.124801] [] gr_gk20a_ctx_wait_ucode+0xc8/0x3a8 [nvgpu]
[ 68.125825] [] gr_gk20a_submit_fecs_method_op+0xac/0x170 [nvgpu]
[ 68.126852] [] gr_gk20a_halt_pipe+0x6c/0x78 [nvgpu]
[ 68.127876] [] gk20a_fifo_reset_engine+0x104/0x200 [nvgpu]
[ 68.128902] [] gk20a_fifo_handle_mmu_fault_locked+0x2ac/0x890 [nvgpu]
[ 68.129928] [] gk20a_fifo_teardown_ch_tsg+0x1c8/0x3e0 [nvgpu]
[ 68.130952] [] gk20a_fifo_recover+0x78/0xa0 [nvgpu]
[ 68.131975] [] gk20a_fifo_handle_sched_error+0x1ec/0x2a0 [nvgpu]
[ 68.133000] [] gk20a_fifo_isr+0x1ec/0x668 [nvgpu]
[ 68.133970] [] gm20b_mc_isr_stall+0x168/0x190 [nvgpu]
[ 68.134952] [] nvgpu_intr_thread_stall+0x50/0x1d8 [nvgpu]
[ 68.135942] [] gk20a_intr_thread_stall+0x20/0x30 [nvgpu]
[ 68.135955] [] irq_thread_fn+0x30/0x80
[ 68.135965] [] irq_thread+0x11c/0x1a8
[ 68.135975] [] kthread+0xec/0xf0
[ 68.135985] [] ret_from_fork+0x10/0x40
[ 68.135991] Task dump for CPU 1:
[ 68.136007] snapd R running task 0 4391 1 0x00000002
[ 68.136011] Call trace:
[ 68.136022] [] __switch_to+0x9c/0xc0
[ 68.136028] [< (null)>] (null)
[ 68.136033] Task dump for CPU 2:
[ 68.136048] swapper/2 R running task 0 0 1 0x00000002
[ 68.136052] Call trace:
[ 68.136063] [] __switch_to+0x9c/0xc0
[ 68.136079] [] cpuidle_enter_state+0x84/0x380
[ 68.136090] [] cpuidle_enter+0x34/0x48
[ 68.136099] [] call_cpuidle+0x44/0x70
[ 68.136108] [] cpu_startup_entry+0x1b0/0x200
[ 68.136120] [] secondary_start_kernel+0x190/0x1f8
[ 68.136127] [<0000000080f5a1a4>] 0x80f5a1a4
[ 68.136132] Task dump for CPU 3:
[ 68.136147] swapper/3 R running task 0 0 1 0x00000002
[ 68.136151] Call trace:
[ 68.136162] [] __switch_to+0x9c/0xc0
[ 68.136174] [] cpuidle_enter_state+0x84/0x380
[ 68.136185] [] cpuidle_enter+0x34/0x48
[ 68.136193] [] call_cpuidle+0x44/0x70
[ 68.136201] [] cpu_startup_entry+0x1b0/0x200
[ 68.136211] [] secondary_start_kernel+0x190/0x1f8
[ 68.136217] [<0000000080f5a1a4>] 0x80f5a1a4
[ 68.136242] sched: RT throttling activated for rt_rq ffffffc0fefbfea8 (cpu 0)
[ 68.136242] potential CPU hogs:
[ 68.136242] irq/80-gk20a_st (2707)
[ 68.137638] BUG: workqueue lockup - pool cpus=0-3 flags=0x4 nice=0 stuck for 42s!
[ 68.137655] Showing busy workqueues and worker pools:
[ 68.137665] workqueue events_unbound: flags=0x2
[ 68.137685] pwq 8: cpus=0-3 flags=0x4 nice=0 active=1/512
[ 68.137708] pending: flush_to_ldisc
[ 68.137717] workqueue events_power_efficient: flags=0x80
[ 68.137741] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
[ 68.137762] pending: do_cache_clean
[ 68.137772] workqueue pm: flags=0x4
[ 68.137794] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
[ 68.137814] pending: pm_runtime_work
[ 68.137836] workqueue vmstat: flags=0xc
[ 68.137859] pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
[ 68.137877] pending: vmstat_update
[ 84.225956] Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 1
[ 84.225972] CPU: 0 PID: 4558 Comm: snapd Not tainted 4.9.140-tegra #8
[ 84.225979] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 84.225984] Call trace:
[ 84.226004] [] dump_backtrace+0x0/0x198
[ 84.226018] [] show_stack+0x24/0x30
[ 84.226030] [] dump_stack+0x98/0xc0
[ 84.226042] [] panic+0x11c/0x298
[ 84.226059] [] watchdog_check_hardlockup_other_cpu+0x11c/0x120
[ 84.226071] [] watchdog_timer_fn+0x98/0x2c0
[ 84.226083] [] __hrtimer_run_queues+0xd8/0x360
[ 84.226093] [] hrtimer_interrupt+0xa8/0x1e0
[ 84.226108] [] tegra210_timer_isr+0x38/0x48
[ 84.226119] [] __handle_irq_event_percpu+0x68/0x288
[ 84.226128] [] handle_irq_event_percpu+0x28/0x60
[ 84.226137] [] handle_irq_event+0x50/0x80
[ 84.226149] [] handle_fasteoi_irq+0xc8/0x1b8
[ 84.226157] [] generic_handle_irq+0x34/0x50
[ 84.226166] [] __handle_domain_irq+0x68/0xc0
[ 84.226174] [] gic_handle_irq+0x5c/0xb0
[ 84.226182] [] el1_irq+0xe8/0x18c
[ 84.226193] [] _raw_spin_lock+0x4c/0x68
[ 84.226206] [] do_anonymous_page+0xb8/0x4d8
[ 84.226218] [] handle_mm_fault+0x5d4/0xa68
[ 84.226230] [] do_page_fault+0x308/0x518
[ 84.226240] [] do_translation_fault+0x6c/0x80
[ 84.226247] [] do_mem_abort+0x54/0xb0
[ 84.226256] [] el0_da+0x20/0x24
[ 84.226268] SMP: stopping secondary CPUs
[ 85.511598] SMP: failed to stop secondary CPUs 0-3
[ 85.511617] Kernel Offset: disabled
[ 85.511622] Memory Limit: none
[ 87.142662] Rebooting in 5 seconds…
[ 92.147847] SMP: stopping secondary CPUs
[ 93.437382] SMP: failed to stop secondary CPUs 0-3
