Here’s the output:
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-2d758fea)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x3213ee
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.270] Read GPT from (4:0)
[0000.416] Csd NumOfBlocks=124735488
[0000.421] Set High speed to 1
[0000.425] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.435] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.441] Number of retries left 4
[0000.449] Using GPT Primary to query partitions
[0000.454] Loading Tboot-CPU binary
[0000.463] Verifying TBC in OdmNonSecureSBK mode
[0000.473] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.480] Bootloader downloaded successfully.
[0000.484] Downloaded Tboot-CPU binary to 0xa0000258
[0000.489] MAX77620_GPIO5 configured
[0000.493] CPU power rail is up
[0000.496] CPU clock enabled
[0000.499] Performing RAM repair
[0000.502] Updating A64 Warmreset Address to 0xa00002e9
[0000.507] Loading NvTbootBootloaderDTB
[0000.534] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.599] Bootloader DTB Load Address: 0x83000000
[0000.604] Loading NvTbootKernelDTB
[0000.630] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.695] Kernel DTB Load Address: 0x83100000
[0000.702] Loading cboot binary
[0000.731] Verifying EBT in OdmNonSecureSBK mode
[0000.773] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.780] Bootloader downloaded successfully.
[0000.784] Read PT from (2:0)
[0000.799] Using BFS PT to query partitions
[0000.803] PT: Partition NCT NOT found !
[0000.807] Warning: Find Partition via PT Failed
[0000.811] Next binary entry address: 0x92c00258
[0000.816] BoardId: 3448
[0000.820] Overriding pmu board id with proc board id
[0000.825] Display board id is not available
[0000.855] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.907] /bpmp deleted
[0000.909] SC7EntryFw header found loaded at 0xff700000
[0001.099] OVR2 PMIC
[0001.101] Bpmp FW successfully loaded
[0001.107] WB0 init successfully at 0xff780000
[0001.111] Set NvDecSticky Bits
[0001.115] GSC2 address ff53fffc value c0edbbcc
[0001.121] GSC MC Settings done
[0001.127] TOS Image length 53680
[0001.130] Monitor size 53680
[0001.132] OS size 0
[0001.142] Secure Os AES-CMAC Verification Success!
[0001.146] TOS image cipher info: plaintext
[0001.150] Loading and Validation of Secure OS Successful
[0001.166] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.170] NvTbootPackSdramParams: start.
[0001.176] NvTbootPackSdramParams: done.
[0001.179] Tegraboot started after 52318 us
[0001.183] Basic modules init took 797614 us
[0001.187] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.193] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.198] Storage Device Read Time = 123 ms, Read Size = 2226 KB
[0001.204] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.210] Next stage binary read took 26212 us
[0001.214] Carveout took -37896 us
[0001.217] CPU initialization took 369830 us
[0001.221] Total time taken by TegraBoot 1155760 us
[0001.226] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):fe06da916
NOTICE: BL31: Built : 18:04:17, Apr 8 2020
ERROR: Error initializing runtime service trusty_fast
[0001.348] RamCode = 0
[0001.353] LPDDR4 Training: Read DT: Number of tables = 2
[0001.358] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.370] EMC Training Successful
[0001.373] 408000 not found in DVFS table
[0001.380] RamCode = 0
[0001.383] DT Write: emc-table@204000 succeeded
[0001.389] DT Write: emc-table@1600000 succeeded
[0001.393] LPDDR4 Training: Write DT: Number of tables = 2
[0001.436]
[0001.437] Debug Init done
[0001.439] Marked DTB cacheable
[0001.442] Bootloader DTB loaded at 0x83000000
[0001.447] Marked DTB cacheable
[0001.450] Kernel DTB loaded at 0x83100000
[0001.454] DeviceTree Init done
[0001.470] Pinmux applied successfully
[0001.474] gicd_base: 0x50041000
[0001.477] gicc_base: 0x50042000
[0001.480] Interrupts Init done
[0001.485] Using base:0x60005090 & irq:208 for tick-timer
[0001.490] Using base:0x60005098 for delay-timer
[0001.494] platform_init_timer: DONE
[0001.498] Timer(tick) Init done
[0001.501] osc freq = 38400 khz
[0001.506]
[0001.507] Welcome to L4T Cboot
[0001.510]
[0001.511] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0001.516] calling constructors
[0001.519] initializing heap
[0001.521] initializing threads
[0001.524] initializing timers
[0001.527] creating bootstrap completion thread
[0001.532] top of bootstrap2()
[0001.534] CPU: ARM Cortex A57
[0001.537] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.542] initializing platform
[0001.550] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.554] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.559] Macronix QSPI chip present
[0001.562] SPI device register
[0001.565] init boot device
[0001.568] allocating memory for boot device(SPI)
[0001.572] registering boot device
[0001.582] sdmmc node status = okay
[0001.585] sdcard instance = 0
[0001.588] sdcard gpio handle 0x56
[0001.591] sdcard gpio pin 0xc9
[0001.594] sdcard gpio flags 0x0
[0001.597] vmmc-supply 0x99
[0001.599] Instance: 0
[0001.602] Allocating memory for context
[0001.605] enabling clock
[0001.608] sd card init
[0001.610] Check card present and stable
[0001.614] Send command 0
[0001.638] Send command 3
[0001.643] Set RCA for the card
[0001.646] Query card specific data by command 9
[0001.652] Parse CSD data
[0001.654] Send command 7
[0001.665] Calling sd device register
[0001.668] Init sdcard
[0001.670] Allocating memory for boot device
[0001.674] Registering user device
[0001.688] Enable APE clock
[0001.690] Un-powergate APE partition
[0001.694] of_register: registering tegra_udc to of_hal
[0001.699] of_register: registering inv20628-driver to of_hal
[0001.704] of_register: registering ads1015-driver to of_hal
[0001.710] of_register: registering lp8557-bl-driver to of_hal
[0001.716] of_register: registering bq2419x_charger to of_hal
[0001.721] of_register: registering bq27441_fuel_gauge to of_hal
[0001.733] gpio framework initialized
[0001.736] of_register: registering tca9539_gpio to of_hal
[0001.742] of_register: registering tca9539_gpio to of_hal
[0001.747] of_register: registering i2c_bus_driver to of_hal
[0001.753] of_register: registering i2c_bus_driver to of_hal
[0001.758] of_register: registering i2c_bus_driver to of_hal
[0001.764] pmic framework initialized
[0001.767] of_register: registering max77620_pmic to of_hal
[0001.773] regulator framework initialized
[0001.777] of_register: registering tps65132_bl_driver to of_hal
[0001.783] initializing target
[0001.788] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.797] board ID = D78, board SKU = 0
[0001.800] Skipping Z3!
[0001.805] fixed regulator driver initialized
[0001.823] initializing OF layer
[0001.826] NCK carveout not present
[0001.829] Skipping dts_overrides
[0001.833] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.850] I2C Bus Init done
[0001.852] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.863] I2C Bus Init done
[0001.865] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.876] I2C Bus Init done
[0001.878] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.889] I2C Bus Init done
[0001.891] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.902] I2C Bus Init done
[0001.905] of_children_init: Ops found for compatible string maxim,max77620
[0001.915] max77620_init using irq 118
[0001.920] register 'maxim,max77620' pmic
[0001.924] gpio_driver_register: register 'max77620-gpio' driver
[0001.930] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.941] I2C Bus Init done
[0001.944] NCK carveout not present
[0001.954] Find /i2c@7000c000's alias i2c0
[0001.958] get eeprom at 1-a0, size 256, type 0
[0001.967] Find /i2c@7000c500's alias i2c2
[0001.971] get eeprom at 3-a0, size 256, type 0
[0001.975] get eeprom at 3-ae, size 256, type 0
[0001.980] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.985] I2C slave not started
[0001.988] I2C write failed
[0001.991] Writing offset failed
[0001.994] eeprom_init: EEPROM read failed
[0001.998] pm_ids_update: eeprom init failed
[0002.002] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.032] pm_ids_update: The pm board id is 3448-0000-400
[0002.039] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.046] pm_ids_update: pm id update successful
[0002.051] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.081] pm_ids_update: The pm board id is 3449-0000-400
[0002.088] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.095] pm_ids_update: pm id update successful
[0002.126] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.132] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.140] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.146] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.155] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:b5:04
[0002.161] Plugin Manager: Parse ODM data 0x00094000
[0002.171] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.193] Find /i2c@7000c000's alias i2c0
[0002.197] get eeprom at 1-a0, size 256, type 0
[0002.205] Find /i2c@7000c500's alias i2c2
[0002.209] get eeprom at 3-a0, size 256, type 0
[0002.214] get eeprom at 3-ae, size 256, type 0
[0002.218] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.223] I2C slave not started
[0002.226] I2C write failed
[0002.229] Writing offset failed
[0002.232] eeprom_init: EEPROM read failed
[0002.236] pm_ids_update: eeprom init failed
[0002.240] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.270] pm_ids_update: The pm board id is 3448-0000-400
[0002.277] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.284] pm_ids_update: pm id update successful
[0002.288] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.318] pm_ids_update: The pm board id is 3449-0000-400
[0002.325] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.332] pm_ids_update: pm id update successful
[0002.363] Add serial number:1422919015699 as DT property
[0002.370] Applying platform configs
[0002.377] platform-init is not present. Skipping
[0002.381] calling apps_init()
[0002.401] Found 14 GPT partitions in "sd0"
[0002.405] Proceeding to Cold Boot
[0002.408] starting app android_boot_app
[0002.412] Device state: unlocked
[0002.415] display console init
[0002.424] could not find regulator
[0002.447] hdmi cable not connected
[0002.451] is_hdmi_needed: HDMI not connected, returning false
[0002.456[0002.460] DT entry for leds-pwm not found
] hdmi is not connected
[0002.467] sor0 is not supported
[0002.470] display_console_init: no valid display out_type
[0002.478] subnode volume_up is not found !
[0002.482] subnode back is not found !
[0002.485] subnode volume_down is not found !
[0002.489] subnode menu is not found !
[0002.493] Gpio keyboard init success
[0002.539] found decompressor handler: lz4-legacy
[0002.553] decompressing blob (type 1)...
[0002.587] display_resolution: No display init
[0002.591] Failed to retrieve display resolution
[0002.595] Could not load/initialize BMP blob...ignoring
[0002.649] decompressor handler not found
[0002.652] load_firmware_blob: Firmware blob loaded, entries=2
[0002.658] -------> se_aes_verify_sbk_clear: 747
[0002.663] se_aes_verify_sbk_clear: Error
[0002.666] bl_battery_charging: connected to external power supply
[0002.674] xusb is supported
[0002.680] error while finding nvidia,portmap
[0003.184] xusb blob version 0 size 124416
[0003.188] firmware size 124416
[0003.193] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.207] xhci0: 64 bytes context size, 32-bit DMA
[0003.247] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.267] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.917] uhub0: 9 ports with 9 removable, self powered
[0004.917] failed to get HID devices
[0004.920] failed to init xhci or no usb device attached
[0004.928] display_console_ioctl: No display init
[0004.933] switch_backlight failed
[0004.939] device_query_partition_size: failed to open partition sd0:MSC !
[0004.945] MSC Partition not found
[0004.952] device_query_partition_size: failed to open partition sd0:USP !
[0004.958] USP partition read failed!
[0004.962] blob_init: blob-partition USP header read failed
[0004.967] android_boot Unable to update recovery partition
[0004.973] kfs_getpartname: name = LNX
[0004.976] Loading kernel from LNX
[0005.075] load kernel from storage
[0005.086] decompressor handler not found
[0005.143] Successfully loaded kernel and ramdisk images
[0005.150] display_resolution: No display init
[0005.154] Failed to retrieve display resolution
[0005.158] bmp blob is not loaded and initialized
[0005.163] Failed to display boot-logo
[0005.167] NCK carveout not present
[0005.170] Skipping dts_overrides
[0005.173] NCK carveout not present
[0005.183] Find /i2c@7000c000's alias i2c0
[0005.187] get eeprom at 1-a0, size 256, type 0
[0005.196] Find /i2c@7000c500's alias i2c2
[0005.200] get eeprom at 3-a0, size 256, type 0
[0005.204] get eeprom at 3-ae, size 256, type 0
[0005.209] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.214] I2C slave not started
[0005.217] I2C write failed
[0005.219] Writing offset failed
[0005.223] eeprom_init: EEPROM read failed
[0005.226] pm_ids_update: eeprom init failed
[0005.231] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.261] pm_ids_update: The pm board id is 3448-0000-400
[0005.267] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0005.275] pm_ids_update: pm id update successful
[0005.280] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.310] pm_ids_update: The pm board id is 3449-0000-400
[0005.316] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0005.324] pm_ids_update: pm id update successful
[0005.355] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.361] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.369] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.375] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.383] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:b5:04
[0005.390] Plugin Manager: Parse ODM data 0x00094000
[0005.400] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.415] Add serial number:1422919015699 as DT property
[0005.424] "bpmp" doesn't exist, creating
[0005.429] Updated bpmp info to DTB
[0005.434] Updated initrd info to DTB
[0005.438] "proc-board" doesn't exist, creating
[0005.443] Updated board info to DTB
[0005.447] "pmu-board" doesn't exist, creating
[0005.452] Updated board info to DTB
[0005.455] "display-board" doesn't exist, creating
[0005.461] Updated board info to DTB
[0005.464] "reset" doesn't exist, creating
[0005.469] Updated reset info to DTB
[0005.472] display_console_ioctl: No display init
[0005.477] display_console_ioctl: No display init
[0005.481] display_console_ioctl: No display init
[0005.486] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000
[0005.520] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.533] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.545] Updated bootarg info to DTB
[0005.549] Adding uuid 000000016450f709000000000efd02c0 to DT
[0005.555] Adding eks info 0 to DT
[0005.561] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.566] Updated memory info to DTB
[0005.575] set vdd_core voltage to 1075 mv
[0005.579] setting 'vdd-core' regulator to 1075000 micro volts
[0005.597] Found secure-pmc; disable BPMP
U-Boot 2016.07-g45dfa3dff4 (Apr 08 2020 - 18:04:08 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 104 ms (6.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487746 bytes read in 315 ms (16.6 MiB/s)
Retrieving file: /boot/Image
34265096 bytes read in 1534 ms (21.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831777ed
Starting kernel ...
[ 1.013327] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.519408] Host read timeout at address 545c00c4
[ 1.826301] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.826333] imx219 7-0010: board setup failed
[ 1.851169] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.851203] imx219 8-0010: board setup failed
[ 2.600272] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.720805] using random self ethernet address
[ 3.725366] using random host ethernet address
[ 4.085596] random: crng init done
[ 4.089003] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.135764] using random self ethernet address
[ 4.140245] using random host ethernet address
[ 6.587200] Please complete system configuration setup on desktop to proceed...
[ 33.867638] nvgpu: 57000000.gpu nvgpu_set_error_notifier_locked:137 [ERR] error notifier set to 8 for ch 507
[ 33.877828] nvgpu: 57000000.gpu gk20a_fifo_handle_sched_error:2531 [ERR] fifo sched ctxsw timeout error: engine=0, tsg=4, ms=3100
[ 33.890887] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1721 [ERR] fake mmu fault on engine 0, engine subid 1 (hub), client 26 (mmu nb), addr 0xb20bb2c000, type 0 (pde), access_type 0x00000000,inst_ptr 0x54ca2f000
[ 33.910868] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 33.919479] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x40
[ 33.928691] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x1
[ 33.938079] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 33.947376] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 33.956678] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 33.965890] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 33.975109] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 33.984580] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 33.993794] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 34.003005] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 34.012391] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x304
[ 34.022384] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x1
[ 34.032377] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 34.042368] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x90009
[ 34.052708] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x14000
[ 34.063045] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 34.073472] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 34.083463] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 34.093455] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 34.103459] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 34.113456] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 34.123445] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 34.133526] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 34.143605] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 34.153687] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 34.163765] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 34.173845] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 34.183923] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 34.193049] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 34.202174] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 34.211300] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 34.221290] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 34.231282] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 34.241273] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 34.251267] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 34.261344] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 34.271250] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 34.281156] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 34.291065] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 34.300970] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 34.310876] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 34.320780] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 34.330688] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 34.340593] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1726 [ERR] gr_status_r : 0x81
[ 34.350712] nvgpu: 57000000.gpu fifo_error_isr:2605 [ERR] channel reset initiated from fifo_error_isr; intr=0x00000100
[ 45.751848] nvgpu: 57000000.gpu nvgpu_set_error_notifier_locked:137 [ERR] error notifier set to 8 for ch 507
[ 45.762024] nvgpu: 57000000.gpu gk20a_fifo_handle_sched_error:2531 [ERR] fifo sched ctxsw timeout error: engine=0, tsg=4, ms=3100
[ 45.775043] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1721 [ERR] fake mmu fault on engine 0, engine subid 1 (hub), client 10 (mmu), addr 0x18d7555000, type 2 (pte), access_type 0x00000001,inst_ptr 0x1c0606000
[ 45.794763] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 45.803375] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x40
[ 45.812589] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x1
[ 45.821980] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 45.831279] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 45.840580] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 45.849791] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 45.859005] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 45.868487] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 45.877702] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 45.886912] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 45.896299] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x304
[ 45.906291] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x1
[ 45.916284] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 45.926275] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x90009
[ 45.936615] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x14000
[ 45.946953] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 45.957379] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 45.967370] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 45.977365] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 45.987356] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 45.997349] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 46.007339] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 46.017418] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 46.027495] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 46.037573] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 46.047651] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 46.057730] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 46.067808] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 46.076934] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 46.086058] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 46.095183] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 46.105174] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 46.115168] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 46.125167] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 46.135170] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 46.145249] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 46.155163] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 46.165070] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 46.174978] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 46.184885] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 46.194790] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 46.204694] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 46.214602] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 46.224506] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1726 [ERR] gr_status_r : 0x81
[ 46.234626] nvgpu: 57000000.gpu fifo_error_isr:2605 [ERR] channel reset initiated from fifo_error_isr; intr=0x00000100
[ 48.757980] host1x 50000000.host1x: gnome-shell: syncpoint id 9 (gm20b_505) stuck waiting 440, timeout=-1
[ 51.438113] nvgpu: 57000000.gpu gk20a_channel_timeout_handler:1570 [ERR] Job on channel 505 timed out
[ 51.448327] nvgpu: 57000000.gpu nvgpu_set_error_notifier_locked:137 [ERR] error notifier set to 8 for ch 505
[ 56.934410] nvgpu: 57000000.gpu nvgpu_set_error_notifier_locked:137 [ERR] error notifier set to 8 for ch 507
[ 56.944584] nvgpu: 57000000.gpu gk20a_fifo_handle_sched_error:2531 [ERR] fifo sched ctxsw timeout error: engine=0, tsg=4, ms=3100
[ 56.957619] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1721 [ERR] fake mmu fault on engine 0, engine subid 1 (hub), client 10 (mmu), addr 0x18d7d51000, type 2 (pte), access_type 0x00000001,inst_ptr 0x1c0606000
[ 56.977340] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 56.985955] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x40
[ 56.995169] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x1
[ 57.004557] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 57.013857] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 57.023159] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 57.032370] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 57.041583] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 57.051055] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 57.060269] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 57.069480] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 57.078868] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x304
[ 57.088859] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x1
[ 57.098854] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 57.108846] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x90009
[ 57.119187] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x14000
[ 57.129526] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 57.139953] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 57.149945] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 57.159941] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 57.169935] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 57.179929] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 57.189921] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 57.200002] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 57.210081] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 57.220160] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 57.230249] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 57.240331] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 57.250410] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 57.259538] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 57.268662] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 57.277787] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 57.287778] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 57.297772] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 57.307764] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 57.317760] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 57.327840] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 57.337753] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 57.347659] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 57.357573] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 57.367496] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 57.377410] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 57.387315] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 57.397225] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 57.407128] nvgpu: 57000000.gpu gk20a_fifo_handle_mmu_fault_locked:1726 [ERR] gr_status_r : 0x400081
[ 57.417576] nvgpu: 57000000.gpu fifo_error_isr:2605 [ERR] channel reset initiated from fifo_error_isr; intr=0x00000100
As you can see it crashes in the end after I start the setup.
