Jetson Nano boot problem
I am writing this post today because I have been trying for the last 3 days to revive my Jetson Nano and I have not been successful. I have already tried with different SD cards, and different images (from the most recent to the oldest) and it always stays on the same screen.
This development module was working until a month ago when it was shut down for vacation and never worked again.
To describe the process, the system starts and shows the Nvidia logo, moments later it allows me to perform the steps of the first installation (language selection, keyboard, password). Once the installation is finished, the graphical interface stops and I go to the terminal, where it starts to throw several errors (attached images). If I reboot the device goes into a loop of non-stop reboots. I have tried to leave it longer but nothing changes.
The model is 945-13450-0000-100 (P3450).
I have used 32,64 and 128 Gb sd cards.
I use a DC power supply of 5V - 4 A.
I attach the logs after installation:
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1909a9
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI ...
[0000.281] Initialize FailControl
[0000.284] Read PT from (2:0)
[0000.314] PT crc32 and magic check passed.
[0000.318] Using BFS PT to query partitions
[0000.324] Loading Tboot-CPU binary
[0000.352] Verifying TBC in OdmNonSecureSBK mode
[0000.362] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.369] Bootloader downloaded successfully.
[0000.373] Downloaded Tboot-CPU binary to 0xa0000258
[0000.378] MAX77620_GPIO5 configured
[0000.381] CPU power rail is up
[0000.384] CPU clock enabled
[0000.388] Performing RAM repair
[0000.391] Updating A64 Warmreset Address to 0xa00002e9
[0000.396] BoardID = 3448, SKU = 0x0
[0000.399] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.403] Nano-SD: checking PT table on QSPI ...
[0000.407] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.413] Loading NvTbootBootloaderDTB
[0000.480] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.551] Bootloader DTB Load Address: 0x83000000
[0000.556] BoardID = 3448, SKU = 0x0
[0000.559] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.563] Nano-SD: checking PT table on QSPI ...
[0000.567] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.574] Loading NvTbootKernelDTB
[0000.640] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.711] Kernel DTB Load Address: 0x83100000
[0000.715] BoardID = 3448, SKU = 0x0
[0000.718] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.722] Nano-SD: checking PT table on QSPI ...
[0000.727] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.734] Loading cboot binary
[0000.850] Verifying EBT in OdmNonSecureSBK mode
[0000.892] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.899] Bootloader downloaded successfully.
[0000.903] BoardID = 3448, SKU = 0x0
[0000.906] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.910] Nano-SD: checking PT table on QSPI ...
[0000.914] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.921] PT: Partition NCT NOT found !
[0000.924] Warning: Find Partition via PT Failed
[0000.929] Next binary entry address: 0x92c00258
[0000.933] BoardId: 3448
[0000.938] Overriding pmu board id with proc board id
[0000.942] Display board id is not available
[0000.947] BoardID = 3448, SKU = 0x0
[0000.950] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.954] Nano-SD: checking PT table on QSPI ...
[0000.958] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.065] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.121] /bpmp deleted
[0001.123] SC7EntryFw header found loaded at 0xff700000
[0001.311] OVR2 PMIC
[0001.313] Bpmp FW successfully loaded
[0001.316] BoardID = 3448, SKU = 0x0
[0001.320] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.324] Nano-SD: checking PT table on QSPI ...
[0001.328] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.335] WB0 init successfully at 0xff780000
[0001.339] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.344] Set NvDecSticky Bits
[0001.348] GSC2 address ff53fffc value c0edbbcc
[0001.354] GSC MC Settings done
[0001.357] BoardID = 3448, SKU = 0x0
[0001.360] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.364] Nano-SD: checking PT table on QSPI ...
[0001.368] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.375] TOS Image length 53680
[0001.378]  Monitor size 53680
[0001.381]  OS size 0
[0001.396] Secure Os AES-CMAC Verification Success!
[0001.401] TOS image cipher info: plaintext
[0001.405] Loading and Validation of Secure OS Successful
[0001.421] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.425] NvTbootPackSdramParams: start.
[0001.431] NvTbootPackSdramParams: done.
[0001.434] Tegraboot started after 51871 us
[0001.438] Basic modules init took 936078 us
[0001.442] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.448] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.453] Next stage binary read took 102859 us
[0001.458] Carveout took -132463 us
[0001.461] CPU initialization took 510781 us
[0001.465] Total time taken by TegraBoot 1417255 us
[0001.470] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):9892ce1
NOTICE:  BL31: Built : 09:21:33, Nov 22 2022
ERROR:   Error initializing runtime service trusty_fast
[0001.592] RamCode = 0
[0001.596] LPDDR4 Training: Read DT: Number of tables = 2
[0001.601] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.614] EMC Training Successful
[0001.617] 408000 not found in DVFS table
[0001.623] RamCode = 0
[0001.627] DT Write: emc-table@204000 succeeded
[0001.632] DT Write: emc-table@1600000 succeeded
[0001.637] LPDDR4 Training: Write DT: Number of tables = 2
[0001.685]
[0001.686] Debug Init done
[0001.688] Marked DTB cacheable
[0001.691] Bootloader DTB loaded at 0x83000000
[0001.696] Marked DTB cacheable
[0001.699] Kernel DTB loaded at 0x83100000
[0001.703] DeviceTree Init done
[0001.716] Pinmux applied successfully
[0001.720] gicd_base: 0x50041000
[0001.724] gicc_base: 0x50042000
[0001.727] Interrupts Init done
[0001.731] Using base:0x60005090 & irq:208 for tick-timer
[0001.736] Using base:0x60005098 for delay-timer
[0001.741] platform_init_timer: DONE
[0001.744] Timer(tick) Init done
[0001.748] osc freq = 38400 khz
[0001.752]
[0001.753] Welcome to L4T Cboot
[0001.756]
[0001.757] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.762] calling constructors
[0001.765] initializing heap
[0001.768] initializing threads
[0001.771] initializing timers
[0001.773] creating bootstrap completion thread
[0001.778] top of bootstrap2()
[0001.781] CPU: ARM Cortex A57
[0001.784] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.788] initializing platform
[0001.796] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.800] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.805] Macronix QSPI chip present
[0001.808] SPI device register
[0001.811] init boot device
[0001.814] allocating memory for boot device(SPI)
[0001.818] registering boot device
[0001.827] QSPI bdev is already initialized
[0001.830] Enable APE clock
[0001.833] Un-powergate APE partition
[0001.837] of_register: registering tegra_udc to of_hal
[0001.842] of_register: registering inv20628-driver to of_hal
[0001.847] of_register: registering ads1015-driver to of_hal
[0001.853] of_register: registering lp8557-bl-driver to of_hal
[0001.859] of_register: registering bq2419x_charger to of_hal
[0001.864] of_register: registering bq27441_fuel_gauge to of_hal
[0001.876] gpio framework initialized
[0001.879] of_register: registering tca9539_gpio to of_hal
[0001.884] of_register: registering tca9539_gpio to of_hal
[0001.890] of_register: registering i2c_bus_driver to of_hal
[0001.895] of_register: registering i2c_bus_driver to of_hal
[0001.901] of_register: registering i2c_bus_driver to of_hal
[0001.907] pmic framework initialized
[0001.910] of_register: registering max77620_pmic to of_hal
[0001.915] regulator framework initialized
[0001.919] of_register: registering tps65132_bl_driver to of_hal
[0001.925] initializing target
[0001.931] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.939] board ID = D78, board SKU = 0
[0001.943] Skipping Z3!
[0001.948] fixed regulator driver initialized
[0001.966] initializing OF layer
[0001.969] NCK carveout not present
[0001.972] Skipping dts_overrides
[0001.976] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.993] I2C Bus Init done
[0001.995] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.005] I2C Bus Init done
[0002.008] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.018] I2C Bus Init done
[0002.021] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.031] I2C Bus Init done
[0002.034] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.044] I2C Bus Init done
[0002.047] of_children_init: Ops found for compatible string maxim,max77620
[0002.057] max77620_init using irq 118
[0002.062] register 'maxim,max77620' pmic
[0002.066] gpio_driver_register: register 'max77620-gpio' driver
[0002.073] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.083] I2C Bus Init done
[0002.087] NCK carveout not present
[0002.096] Find /i2c@7000c000's alias i2c0
[0002.100] get eeprom at 1-a0, size 256, type 0
[0002.109] Find /i2c@7000c500's alias i2c2
[0002.113] get eeprom at 3-a0, size 256, type 0
[0002.117] get eeprom at 3-ae, size 256, type 0
[0002.121] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.127] I2C slave not started
[0002.130] I2C write failed
[0002.132] Writing offset failed
[0002.135] eeprom_init: EEPROM read failed
[0002.139] pm_ids_update: eeprom init failed
[0002.144] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.174] pm_ids_update: The pm board id is 3448-0000-402
[0002.180] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.189] pm_ids_update: pm id update successful
[0002.193] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.223] pm_ids_update: The pm board id is 3449-0000-400
[0002.230] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.238] pm_ids_update: pm id update successful
[0002.268] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.274] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.282] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.287] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.296] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3d:04:2d
[0002.302] Plugin Manager: Parse ODM data 0x000a4000
[0002.314] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70        006000
[0002.329] Find /i2c@7000c000's alias i2c0
[0002.333] get eeprom at 1-a0, size 256, type 0
[0002.342] Find /i2c@7000c500's alias i2c2
[0002.346] get eeprom at 3-a0, size 256, type 0
[0002.350] get eeprom at 3-ae, size 256, type 0
[0002.354] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.360] I2C slave not started
[0002.363] I2C write failed
[0002.365] Writing offset failed
[0002.368] eeprom_init: EEPROM read failed
[0002.372] pm_ids_update: eeprom init failed
[0002.376] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.406] pm_ids_update: The pm board id is 3448-0000-402
[0002.413] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.420] pm_ids_update: pm id update successful
[0002.424] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.454] pm_ids_update: The pm board id is 3449-0000-400
[0002.460] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.467] pm_ids_update: pm id update successful
[0002.498] Add serial number:1421321062719 as DT property
[0002.505] Applying platform configs
[0002.512] platform-init is not present. Skipping
[0002.516] calling apps_init()
[0002.522] Couldn't find GPT header
[0002.527] Proceeding to Cold Boot
[0002.530] starting app android_boot_app
[0002.534] Device state: unlocked
[0002.537] display console init
[0002.545] could not find regulator
[0002.549] hdmi cable connected
[0002.564] edid read success
[0002.579] edid read success
[0002.582] width DT entry for leds-pwm not found
=[0002.590]  640, height = 480, frequency = 25174825
[0002.594] width = 640, height = 480, frequency = 25174825
[0002.600] width = 640, height = 480, frequency = 25174825
[0002.605] width = 640, height = 480, frequency = 25174825
[0002.611] width = 1920, height = 1080, frequency = 148500000
[0002.616] width = 1280, height = 720, frequency = 74250000
[0002.622] width = 1920, height = 1080, frequency = 148351648
[0002.627] width = 1280, height = 720, frequency = 74175824
[0002.633] width = 1920, height = 1080, frequency = 148351648
[0002.638] width = 1280, height = 720, frequency = 74175824
[0002.644] width = 720, height = 576, frequency = 26973026
[0002.649] width = 720, height = 480, frequency = 26973026
[0002.655] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.662] tmds-config node not found
[0002.667] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepr        opsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.681] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.689] could not find regulator
[0002.692] could not find regulator
[0002.695] could not find regulator
[0002.724] using default cmu settings
[0002.727] dc_hdmi_enable, starting HDMI initialisation
[0002.734] dc_hdmi_enable, HDMI initialisation complete
[0002.739] list and configure display window
[0002.747] display console init completed
[0002.758] subnode volume_up is not found !
[0002.762] subnode back is not found !
[0002.766] subnode volume_down is not found !
[0002.770] subnode menu is not found !
[0002.774] Gpio keyboard init success
[0002.854] found decompressor handler: lz4-legacy
[0002.869] decompressing blob (type 1)...
[0002.938] load_bmp_blob: panelresolution=1080 type=3
[0002.943] -------> se_aes_verify_sbk_clear: 747
[0002.948] se_aes_verify_sbk_clear: Error
[0002.952] SE operation failed
[0002.954] bl_battery_charging: connected to external power supply
[0002.967] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.974] MSC Partition not found
[0002.980] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.988] USP partition read failed!
[0002.991] blob_init: blob-partition USP header read failed
[0002.997] android_boot Unable to update recovery partition
[0003.002] kfs_getpartname: name = LNX
[0003.006] Loading kernel from LNX
[0003.015] Found 19 BFS partitions in "spiflash0"
[0003.337] load kernel from storage
[0003.342] decompressor handler not found
[0003.608] Successfully loaded kernel and ramdisk images
[0003.613] board ID = D78, board SKU = 0
[0003.618] sdmmc node status = okay
[0003.621] sdcard instance = 0
[0003.624] sdmmc cd-inverted
[0003.627] sdcard gpio handle 0x5b
[0003.630] sdcard gpio pin 0xc9
[0003.633] sdcard gpio flags 0x0
[0003.636] vmmc-supply 0x9d
[0003.638] cd_gpio_pin = 201
[0003.641] pin_state = 0
[0003.643] Found sdcard
[0003.646] SD-card IS present ...
[0003.649] load_and_boot_kernel: SD card detected OK
[0003.655] load_bmp_blob: panelresolution=1080 type=3
[0004.149] display bmp image done
[0004.152] NCK carveout not present
[0004.155] Skipping dts_overrides
[0004.158] NCK carveout not present
[0004.168] Find /i2c@7000c000's alias i2c0
[0004.172] get eeprom at 1-a0, size 256, type 0
[0004.180] Find /i2c@7000c500's alias i2c2
[0004.184] get eeprom at 3-a0, size 256, type 0
[0004.189] get eeprom at 3-ae, size 256, type 0
[0004.193] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.198] I2C slave not started
[0004.201] I2C write failed
[0004.204] Writing offset failed
[0004.207] eeprom_init: EEPROM read failed
[0004.211] pm_ids_update: eeprom init failed
[0004.215] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.245] pm_ids_update: The pm board id is 3448-0000-402
[0004.252] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0004.261] pm_ids_update: pm id update successful
[0004.265] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.295] pm_ids_update: The pm board id is 3449-0000-400
[0004.301] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.309] pm_ids_update: pm id update successful
[0004.340] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.345] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.353] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.359] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.367] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3d:04:2d
[0004.374] Plugin Manager: Parse ODM data 0x000a4000
[0004.386] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70        006000
[0004.394] Add serial number:1421321062719 as DT property
[0004.403] "bpmp" doesn't exist, creating
[0004.409] Updated bpmp info to DTB
[0004.414] Updated initrd info to DTB
[0004.417] "proc-board" doesn't exist, creating
[0004.423] Updated board info to DTB
[0004.427] "pmu-board" doesn't exist, creating
[0004.433] Updated board info to DTB
[0004.436] "display-board" doesn't exist, creating
[0004.442] Updated board info to DTB
[0004.445] "reset" doesn't exist, creating
[0004.450] Updated reset info to DTB
[0004.453] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=        0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@6        3 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lspor        t,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 l        p0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800        000@0x92ca9000 is_hdmi_initialised=1
[0004.493] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.498] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 c        onsole=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.511] Updated bootarg info to DTB
[0004.515] Adding uuid 000000016430b744140000000a020080 to DT
[0004.521] Adding eks info 0 to DT
[0004.526] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.532] Updated memory info to DTB
[0004.540] set vdd_core voltage to 1075 mv
[0004.544] setting 'vdd-core' regulator to 1075000 micro volts
[0004.550] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Nov 22 2022 - 09:21:37 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM:  4 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256        Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 28 ms (29.3 KiB/s)
1:      primary kernel
Retrieving file: /boot/initrd
7160133 bytes read in 332 ms (20.6 MiB/s)
Retrieving file: /boot/Image
34484232 bytes read in 1508 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000083100000, end 000000008317cf27
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5496-d5000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:13:06 PDT 2021
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] Found tegra_fbmem: 00800000@92ca9000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    1.164968] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.304091] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.304162] imx219 7-0010: board setup failed
[    1.328007] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.328063] imx219 8-0010: board setup failed
[    2.003710] cgroup: cgroup2: unknown option "nsdelegate"
[    3.086179] using random self ethernet address
[    3.093115] using random host ethernet address
[    3.512227] random: crng init done
[    3.515658] random: 7 urandom warning(s) missed due to ratelimiting
[    3.526157] using random self ethernet address
[    3.530810] using random host ethernet address
[   13.785785] Please complete system configuration setup on desktop to proceed...
[   47.306394] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[   47.315067] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[   74.917007] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[   74.917042] INFO: rcu_preempt self-detected stall on CPU
[   74.917047]  1-...: (1 ticks this GP) idle=7ef/1/0 softirq=7653/7653 fqs=0
[   74.917051]   (t=5263 jiffies g=2132 c=2131 q=125)
[   74.917055] rcu_preempt kthread starved for 5263 jiffies! g2132 c2131 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[   74.918996] INFO: rcu_sched detected stalls on CPUs/tasks:
[   74.919004]  0-...: (0 ticks this GP) idle=78f/140000000000001/0 softirq=9390/9390 fqs=2
[   74.919009]  (detected by 3, t=5265 jiffies, g=1320, c=1319, q=2)
[   74.972734] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  342.388416] Bridge firewalling registered
[  370.208039] INFO: rcu_preempt self-detected stall on CPU
[  370.208041] INFO: rcu_preempt self-detected stall on CPU
[  370.208046] INFO: rcu_preempt self-detected stall on CPU
[  370.208053]  2-...: (1 GPs behind) idle=c13/140000000000001/0 softirq=37079/37080 fqs=0
[  370.208058]  1-...: (1 GPs behind) idle=fa7/140000000000001/0 softirq=34293/34303 fqs=0
[  370.208059]
[  370.208061]
[  370.208069] INFO: rcu_preempt self-detected stall on CPU
[  370.208069] rcu_preempt kthread starved for 5264 jiffies! g11162 c11161 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  370.208073] rcu_preempt kthread starved for 5264 jiffies! g11162 c11161 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  370.208081]  0-...: (1 ticks this GP) idle=9b9/140000000000002/0 softirq=34571/34571 fqs=0
[  370.208086]
[  370.208106] rcu_preempt kthread starved for 5264 jiffies! g11162 c11161 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  370.209705] CPU2: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000002, esr=bf000002
[  370.210256] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  370.341224]  3-...: (1 GPs behind) idle=029/140000000000001/0 softirq=33458/33460 fqs=1
[  370.357561]   (t=5301 jiffies g=11162 c=11161 q=1113)
[  391.867939] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  391.867941] INFO: rcu_preempt self-detected stall on CPU
[  391.867946] INFO: rcu_sched detected stalls on CPUs/tasks:
[  391.867953]  1-...: (1 ticks this GP) idle=343/140000000000001/0 softirq=35094/35095 fqs=0
[  391.867958]  1-...: (1 ticks this GP) idle=343/140000000000001/0 softirq=35094/35095 fqs=0
[  391.867959]
[  391.867961]
[  391.867968] rcu_preempt kthread starved for 5265 jiffies! g11208 c11207 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  391.868008] rcu_sched kthread starved for 5265 jiffies! g5850 c5849 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  391.868085] CPU2: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000002, esr=bf000002
[  391.868834] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  391.963517]  3-...: (1 GPs behind) idle=1ad/140000000000001/0 softirq=34155/34157 fqs=11
[  391.976832]  (detected by 3, t=27 jiffies, g=11209, c=11208, q=1230)
Ubuntu 18.04.5 LTS nanoStation ttyS0
nanoStation login: [  416.779780] INFO: rcu_preempt self-detected stall on CPU[  416.779820] INFO: rcu_preempt self-detected stall on CPU
[  416.779827]  3-...: (1 ticks this GP) idle=b0d/1/0 softirq=35109/35109 fqs=0
[  416.779828]
[  416.779833] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  416.779836] rcu_preempt kthread starved for 5265 jiffies! g11605 c11604 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  416.779843]  2-...: (1 GPs behind) idle=fed/140000000000001/0 softirq=40236/40239 fqs=0
[  416.779848]  3-...: (1 ticks this GP) idle=b0d/1/0 softirq=35109/35109 fqs=0
[  416.779849]
[  416.779866] INFO: rcu_sched detected stalls on CPUs/tasks:
[  416.779878]  2-...: (1 ticks this GP) idle=fed/140000000000001/0 softirq=40239/40239 fqs=0
[  416.779886]  3-...: (1 ticks this GP) idle=b0d/1/0 softirq=35109/35109 fqs=0
[  416.779891]
[  416.779973] rcu_sched kthread starved for 5265 jiffies! g5949 c5948 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  416.780075] rcu_preempt kthread starved for 5265 jiffies! g11605 c11604 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[  416.872568]  2-...: (1 GPs behind) idle=fed/140000000000001/0 softirq=40236/40239 fqs=1
[  416.872569]
[  416.874239] CPU2: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000002, esr=bf000002
[  416.875981] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  440.581466] INFO: rcu_preempt self-detected stall on CPU
[  440.581471] INFO: rcu_preempt self-detected stall on CPU
[  440.581478]  3-...: (1 GPs behind) idle=cfd/140000000000001/0 softirq=41550/41551 fqs=0
[  440.581482]   (t=5264 jiffies g=11912 c=11911 q=283)
[  440.581486] rcu_preempt kthread starved for 5264 jiffies! g11912 c11911 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  440.581523] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  440.581531]  0-...: (0 ticks this GP) idle=485/1/0 softirq=37599/37599 fqs=0
[  440.581535]  1-...: (1 GPs behind) idle=bcd/140000000000001/0 softirq=36420/36433 fqs=0
[  440.581538]  3-...: (1 GPs behind) idle=cfd/140000000000001/0 softirq=41550/41551 fqs=0
[  440.581541]
[  440.583259] rcu_preempt kthread starved for 5264 jiffies! g11912 c11911 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[  440.583290] INFO: rcu_sched self-detected stall on CPU
[  440.583294]  2-...: (1 ticks this GP) idle=7e1/1/0 softirq=40659/40659 fqs=0
[  440.583297]   (t=5264 jiffies g=5985 c=5984 q=5)
[  440.583300] rcu_sched kthread starved for 5264 jiffies! g5985 c5984 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  440.583303] CPU3: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000003, esr=bf000002
[  440.583495] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  440.699108]  1-...: (1 GPs behind) idle=bcd/140000000000001/0 softirq=36420/36433 fqs=14
[  440.699117]   (t=5293 jiffies g=11912 c=11911 q=274)
[  441.233188] using random self ethernet address
[  441.237929] using random host ethernet address
[  462.296360] INFO: rcu_preempt self-detected stall on CPU[  462.296365] INFO: rcu_preempt self-detected stall on CPU
[  462.296372]  3-...: (1 ticks this GP) idle=01f/140000000000001/0 softirq=42090/42090 fqs=0
[  462.296373]
[  462.296380] rcu_preempt kthread starved for 5264 jiffies! g11972 c11971 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  462.296418] INFO: rcu_preempt self-detected stall on CPU
[  462.296427]  1-...: (1 GPs behind) idle=e59/1/0 softirq=36737/36742 fqs=0
[  462.296428]
[  462.296433] rcu_preempt kthread starved for 5264 jiffies! g11972 c11971 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[  462.298083] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  462.298190]  1-...: (1 GPs behind) idle=e59/1/0 softirq=36737/36742 fqs=0
[  462.298194]  2-...: (1 ticks this GP) idle=b5b/140000000000001/0 softirq=41038/41038 fqs=0
[  462.298197]  3-...: (1 ticks this GP) idle=01f/140000000000001/0 softirq=42090/42090 fqs=0
[  462.298198]
[  462.298208] CPU3: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000003, esr=bf000002
[  462.298262] rcu_preempt kthread starved for 5264 jiffies! g11972 c11971 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[  462.298373] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  462.407192]  2-...: (1 ticks this GP) idle=b5b/140000000000001/0 softirq=41038/41038 fqs=1
[  462.407203]   (t=5291 jiffies g=11972 c=11971 q=180)
[  462.738302] using random self ethernet address
[  462.744616] using random host ethernet address
[  484.049766] CPU2: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000002, esr=bf000002
[  484.049783] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  484.049790]  2-...: (1 ticks this GP) idle=edf/140000000000001/0 softirq=41459/41462 fqs=1
[  484.049794]  (detected by 1, t=5265 jiffies, g=12037, c=12036, q=228)
[  484.049823] rcu_preempt kthread starved for 5263 jiffies! g12037 c12036 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  484.088623] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
Logs after reboot:
[  450.784367] INFO: rcu_preempt self-detected stall on CPU
[  450.784378] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  450.784378] 	2-...: (1 ticks this GP) idle=b91/140000000000001/0 softirq=34125/34133 fqs=0
[  450.784382] 	 (t=5264 jiffies g=10533 c=10532 q=1243)
[  450.784387] 	2-...: (1 ticks this GP) idle=b91/140000000000001/0 softirq=34125/34133 fqs=0
[  450.784391] rcu_preempt kthread starved for 5264 jiffies! g10533 c10532 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  450.784394] 	3-...: (1 GPs behind) idle=211/140000000000001/0 softirq=35495/35498 fqs=0
[  450.784397] INFO: rcu_sched self-detected stall on CPU
[  450.784399]
[  450.784408] 	0-...: (1 ticks this GP) idle=f55/140000000000002/0 softirq=35625/35625 fqs=0
[  450.784419]
[  450.784432] rcu_sched kthread starved for 5263 jiffies! g5192 c5191 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  450.786174] rcu_preempt kthread starved for 5264 jiffies! g10533 c10532 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[  450.786212] CPU2: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000002, esr=bf000002
[  450.786784] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  450.793049] using random self ethernet address
[  450.793052] using random host ethernet address
[  450.901519] 	3-...: (1 GPs behind) idle=211/140000000000001/0 softirq=35495/35498 fqs=15
[  450.901526] 	 (t=5294 jiffies g=10533 c=10532 q=1859)
[  451.183682] using random self ethernet address
[  451.190135] using random host ethernet address
[  472.525659] INFO: rcu_preempt self-detected stall on CPU
[  472.525661] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  472.525669] 	0-...: (0 ticks this GP) idle=601/140000000000001/0 softirq=36140/36140 fqs=0
[  472.525673] 	2-...: (1 ticks this GP) idle=eed/140000000000001/0 softirq=34583/34587 fqs=0
[  472.525677] 	3-...: (1 ticks this GP) idle=541/140000000000001/0 softirq=35947/35947 fqs=0
[  472.525681] 	(detected by 1, t=5265 jiffies, g=10592, c=10591, q=377)
[  472.525710] CPU2: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000002, esr=bf000002
[  472.525737] rcu_preempt kthread starved for 5265 jiffies! g10592 c10591 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  472.529013] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  472.594593] 	3-...: (1 ticks this GP) idle=541/140000000000001/0 softirq=35947/35947 fqs=9
[  472.594598] 	 (t=5282 jiffies g=10592 c=10591 q=566)
[  474.820852] ------------[ cut here ]------------
[  474.825472] WARNING: CPU: 1 PID: 20008 at /dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/platform/tegra/mc/mc.c:223 tegra_mc_flush+0x288/0x2a8
[  474.840734] ---[ end trace 5063c5d3780d74fd ]---
[  495.914939] CPU1: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000001, esr=bf000002
[  495.923606] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  497.667165] ------------[ cut here ]------------
[  497.671782] WARNING: CPU: 0 PID: 20008 at /dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/platform/tegra/mc/mc.c:223 tegra_mc_flush+0x288/0x2a8
[  497.685275] ---[ end trace 5063c5d3780d74fe ]---
[  540.808502] 	1-...: (1 GPs behind) idle=72b/1/0 softirq=42740/42741 fqs=0
[  540.808504] INFO: rcu_preempt self-detected stall on CPU
[  540.808505]
[  540.808524] 	0-...: (1 ticks this GP) idle=b85/2/0 softirq=36752/36752 fqs=0
[  540.808527] rcu_preempt kthread starved for 5262 jiffies! g10758 c10757 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  540.808530]
[  540.808544] rcu_preempt kthread starved for 5262 jiffies! g10758 c10757 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  540.884137] 	2-...: (1 GPs behind) idle=c11/140000000000001/0 softirq=35532/35533 fqs=6
[  540.892206] 	 (t=5281 jiffies g=10758 c=10757 q=173)
[  540.898855] CPU2: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000002, esr=bf000002
[  540.907291] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  562.435223] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[  562.435266] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  562.435273] 	0-...: (0 ticks this GP) idle=f97/140000000000001/0 softirq=37080/37080 fqs=1
[  562.435277] 	(detected by 3, t=5264 jiffies, g=10810, c=10809, q=114)
[  562.435305] rcu_preempt kthread starved for 5262 jiffies! g10810 c10809 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[  562.491386] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  584.027856] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[  584.027885] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  584.027892] 	0-...: (1 GPs behind) idle=379/140000000000001/0 softirq=37230/37238 fqs=0
[  584.027896] 	2-...: (0 ticks this GP) idle=37d/1/0 softirq=35828/35828 fqs=0
[  584.027900] 	(detected by 3, t=5265 jiffies, g=10864, c=10863, q=188)
[  584.027942] rcu_preempt kthread starved for 5265 jiffies! g10864 c10863 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[  584.073783] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[  605.617812] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[  605.617839] INFO: rcu_preempt self-detected stall on CPU
[  605.617846] INFO: rcu_preempt self-detected stall on CPU
[  605.617846] 	1-...: (1 GPs behind) idle=215/1/0 softirq=43407/43408 fqs=0
[  605.617849] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  605.617854]
[  605.617854] 	2-...: (1 GPs behind) idle=753/1/0 softirq=35993/35993 fqs=0
[  605.617861]
[  605.617862] 	0-...: (1 GPs behind) idle=791/140000000000001/0 softirq=37424/37427 fqs=0
[  605.617864] rcu_preempt kthread starved for 5263 jiffies! g10915 c10914 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  605.617869] 	1-...: (1 GPs behind) idle=215/1/0 softirq=43407/43408 fqs=0
[  605.617873] rcu_preempt kthread starved for 5263 jiffies! g10915 c10914 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[  605.617876] 	2-...: (1 GPs behind) idle=753/1/0 softirq=35993/35993 fqs=0
[  605.617880]
[  605.618227] rcu_preempt kthread starved for 5263 jiffies! g10915 c10914 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[  605.712516] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
Logs 2nd reboot:
[0001.323] Nano-SD: checking PT table on QSPI ...
[0001.430] NvTbootPackSdramParams: done.
[0001.434] Tegraboot started after 51868 us
[0001.438] Basic modules init took 936063 us
[0001.461] CPU initialization took 510782 us
[0001.465] Total time taken by TegraBoot 1417241 us
[0001.636] LPDDR4 Training: Write DT: Number of tables = 2
[0001.685]
[0001.752]
[0001.756]
[0001.770] initializing timers
[0001.783] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.826] QSPI bdev is already initialized
[0001.906] pmic framework initialized
[0001.968] NCK carveout not present
[0002.122] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.224] pm_ids_update: The pm board id is 3449-0000-400
[0002.288] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.315] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70        006000
[0002.407] pm_ids_update: The pm board id is 3448-0000-402
[0002.461] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.506] Applying platform configs
[0002.517] calling apps_init()
[0002.582] widtDT entry for leds-pwm not found
h[0002.590]  = 640, height = 480, frequency = 25174825
[0002.595] width = 640, height = 480, frequency = 25174825
[0002.639] width = 1280, height = 720, frequency = 74175824
[0002.663] tmds-config node not found
[0002.696] could not find regulator
[0002.939] load_bmp_blob: panelresolution=1080 type=3
[0002.955] bl_battery_charging: connected to external power supply
[0003.644] Found sdcard
[0004.395] Add serial number:1421321062719 as DT property
SoC: tegra210
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
1:      primary kernel
7160133 bytes read in 333 ms (20.5 MiB/s)
Starting kernel ...
[    1.162425] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.328174] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.328244] imx219 7-0010: board setup failed
[    1.352099] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.352156] imx219 8-0010: board setup failed
[    2.176656] cgroup: cgroup2: unknown option "nsdelegate"
[    3.306559] using random self ethernet address
[    3.320122] using random host ethernet address
[    3.873894] random: crng init done
[    3.877326] random: 7 urandom warning(s) missed due to ratelimiting
[    4.375375] using random self ethernet address
[    4.385731] using random host ethernet address
[   25.851766] INFO: rcu_preempt detected stalls on CPUs/tasks:
[   25.851767] INFO: rcu_sched detected stalls on CPUs/tasks:
[   25.851775]  0-...: (0 ticks this GP) idle=c3f/140000000000001/0 softirq=4526/4526 fqs=1
[   25.851781]  0-...: (1 GPs behind) idle=c3f/140000000000001/0 softirq=4451/4526 fqs=1
[   25.851785]
[   25.851785] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[   25.851788]
[   25.851789] (detected by 2, t=5266 jiffies, g=-9, c=-10, q=10)
[   25.851791] (detected by 3, t=5266 jiffies, g=127, c=126, q=2609)
[   25.851794] NMI watchdog: BUG: soft lockup - CPU#1 stuck for 21s! [systemd-udevd:2788]
[   25.851796] Task dump for CPU 0:
[   25.851797] Task dump for CPU 0:
[   25.851800] Modules linked in:
[   25.851800] tegra-xusb 70090000.xusb: controller firmware hang
[   25.851803] nvpmodel        R
[   25.851804] nvpmodel        R
[   25.851805]  overlay
[   25.851807]   running task
[   25.851807] tegra-xusb 70090000.xusb: hcd_reinit is disabled or in progress
[   25.851809]   running task
[   25.851811]  userspace_alert
[   25.851811]     0  4777      1 0x00000008
[   25.851813]     0  4777      1 0x00000008
[   25.851815]  nvgpu
[   25.851815] Call trace:
[   25.851816] Call trace:
[   25.851824]  ip_tables
[   25.851824] [<ffffff800808604c>] __switch_to+0x9c/0xc0
[   25.851829] [<ffffff800808604c>] __switch_to+0x9c/0xc0
[   25.851834]  x_tables
[   25.851835] [<ffffff8009836018>] cpu_number+0x0/0x8
[   25.851838] [<ffffff8009836018>] cpu_number+0x0/0x8
[   25.851842] rcu_sched kthread starved for 5264 jiffies! g18446744073709551607 c18446744073709551606 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[   25.851842]
[   25.851846] rcu_preempt kthread starved for 5264 jiffies! g127 c126 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[   25.851850] rcu_sched       S
[   25.851850] CPU: 1 PID: 2788 Comm: systemd-udevd Not tainted 4.9.253-tegra #1
[   25.851853] rcu_preempt     S
[   25.851853]     0     8      2 0x00000000
[   25.851855] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[   25.851856]     0     7      2 0x00000000
[   25.851857] Call trace:
[   25.851859] task: ffffffc0f1213800 task.stack: ffffffc0f1c34000
[   25.851859] Call trace:
[   25.851862] [<ffffff800808604c>] __switch_to+0x9c/0xc0
[   25.851865] [<ffffff800808604c>] __switch_to+0x9c/0xc0
[   25.851870] [<ffffff8008f68078>] __schedule+0x238/0x7d0
[   25.851871] PC is at copy_process.isra.7.part.8+0x1440/0x1578
[   25.851874] [<ffffff8008f68078>] __schedule+0x238/0x7d0
[   25.851876] [<ffffff8008f68650>] schedule+0x40/0xa8
[   25.851877] LR is at copy_process.isra.7.part.8+0x1428/0x1578
[   25.851879] [<ffffff8008f68650>] schedule+0x40/0xa8
[   25.851882] [<ffffff8008f6b690>] schedule_timeout+0x88/0x420
[   25.851885] pc : [<ffffff80080b0b40>] lr : [<ffffff80080b0b28>] pstate: 60400045
[   25.851888] [<ffffff8008f6b690>] schedule_timeout+0x88/0x420
[   25.851892] [<ffffff800813082c>] rcu_gp_kthread+0x4a4/0x7d8
[   25.851892] sp : ffffffc0f1c37d10
[   25.851895] [<ffffff800813082c>] rcu_gp_kthread+0x4a4/0x7d8
[   25.851898] [<ffffff80080db09c>] kthread+0xec/0xf0
[   25.851902] x29: ffffffc0f1c37d10
[   25.851902] [<ffffff80080db09c>] kthread+0xec/0xf0
[   25.851905] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
[   25.851908] x28: 0000000000000000
[   25.851909] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
[   25.851913] x27: ffffffc0e99413a8 x26: ffffffc0e9941600
[   25.851916] x25: ffffffc0e9941400 x24: ffffffc0e9940e00
[   25.851920] x23: 0000000000000000 x22: 0000000000000000
[   25.851923] x21: 0000000000000000 x20: 0000000000000000
[   25.851926] x19: 0000000001200011 x18: 0000007fd5227e51
[   25.851929] x17: 0000000000000000 x16: 0000000000000000
[   25.851932] x15: 000000000000000a x14: ffffffc0f1c0ac10
[   25.851934] x13: 0000000000000000 x12: 0000000000000000
[   25.851937] x11: 0000008015209000 x10: 0000000000000000
[   25.851940] x9 : ffffffc0f9b8b548 x8 : 00000000f1c0f548
[   25.851943] x7 : 0000007fd5409000 x6 : 00e0000173224fd3
[   25.851946] x5 : 00000000e99a8048 x4 : ffffffc0f1213800
[   25.851949] x3 : 0000000000000000 x2 : 0000000000000004
[   25.851952] x1 : ffffffc0ee5db868 x0 : 0088000000000000
[   25.851953]
[   25.851956] Kernel panic - not syncing: softlockup: hung tasks
[   25.851959] CPU: 1 PID: 2788 Comm: systemd-udevd Tainted: G             L  4.9.253-tegra #1
[   25.851961] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[   25.851962] Call trace:
[   25.851967] [<ffffff800808ba40>] dump_backtrace+0x0/0x198
[   25.851970] [<ffffff800808c004>] show_stack+0x24/0x30
[   25.851974] [<ffffff8008f6121c>] dump_stack+0xa0/0xc4
[   25.851978] [<ffffff8008f5e2c0>] panic+0x12c/0x2a8
[   25.851983] [<ffffff8008180d30>] watchdog_unpark_threads+0x0/0x98
[   25.851987] [<ffffff8008138f10>] __hrtimer_run_queues+0xd8/0x360
[   25.851989] [<ffffff8008139860>] hrtimer_interrupt+0xa8/0x1e0
[   25.851993] [<ffffff8008bfa838>] tegra210_timer_isr+0x38/0x48
[   25.851996] [<ffffff8008121940>] __handle_irq_event_percpu+0x68/0x288
[   25.851998] [<ffffff8008121b88>] handle_irq_event_percpu+0x28/0x60
[   25.852001] [<ffffff8008121c10>] handle_irq_event+0x50/0x80
[   25.852004] [<ffffff8008125aa4>] handle_fasteoi_irq+0xd4/0x1c0
[   25.852006] [<ffffff80081208f4>] generic_handle_irq+0x34/0x50
[   25.852008] [<ffffff8008120fe0>] __handle_domain_irq+0x68/0xc0
[   25.852011] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[   25.852013] [<ffffff8008082c28>] el1_irq+0xe8/0x194
[   25.852015] [<ffffff80080b0b40>] copy_process.isra.7.part.8+0x1440/0x1578
[   25.852018] [<ffffff80080b0e18>] _do_fork+0xd8/0x470
[   25.852020] [<ffffff80080b1324>] SyS_clone+0x4c/0x60
[   25.852023] [<ffffff800808395c>] __sys_trace_return+0x0/0x4
[   25.852027] SMP: stopping secondary CPUs
[   25.852069] Kernel Offset: disabled
[   25.852070] Memory Limit: none
[   26.466641] Rebooting in 5 seconds..
Screenshots:
Thank you very much for your help.
Nixon
Update:
Some extra logs:
SoC: tegra210
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
1:      primary kernel
Starting kernel ...
[    1.163253] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.309824] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.309888] imx219 7-0010: board setup failed
[    1.333726] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.333783] imx219 8-0010: board setup failed
[    2.188949] cgroup: cgroup2: unknown option "nsdelegate"
[    3.830101] random: crng init done
[    3.833529] random: 7 urandom warning(s) missed due to ratelimiting
[    4.143522] using random self ethernet address
[    4.149047] using random host ethernet address
[    5.088982] using random self ethernet address
[    5.094836] using random host ethernet address
[   26.573068] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[   26.581422] INFO: rcu_preempt self-detected stall on CPU[   26.582735] INFO: rcu_preempt detected stalls on CPUs/tasks:
[   26.582737] INFO: rcu_sched detected stalls on CPUs/tasks:
[   26.582740]  Tasks blocked on level-0 rcu_node (CPUs 0-3):
[   26.582746]  0-...: (1 GPs behind) idle=db1/140000000000002/0 softirq=5128/5140 fqs=0
[   26.582747]
[   26.582755]  0-...: (1 GPs behind) idle=db1/140000000000002/0 softirq=5119/5140 fqs=0
[   26.582757]
[   26.582794] rcu_sched kthread starved for 5265 jiffies! g49 c48 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[   26.582920] rcu_preempt kthread starved for 5265 jiffies! g226 c225 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[   26.640835]  0-...: (1 GPs behind) idle=db1/140000000000002/0 softirq=5119/5140 fqs=1
[   26.640836]
[   26.644001] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[   49.250654] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[   49.259051] tegra-xusb 70090000.xusb: controller firmware hang
[   49.259086] INFO: rcu_preempt self-detected stall on CPU
[   49.259093]  0-...: (1 ticks this GP) idle=c9b/140000000000002/0 softirq=5881/5881 fqs=0
[   49.259097]   (t=5267 jiffies g=371 c=370 q=51)
[   49.259100] rcu_preempt kthread starved for 5267 jiffies! g371 c370 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
Ubuntu 18.04.5 LTS nanoStation ttyS0[   49.261703] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
nanoStation login: [   49.790719] Bridge firewalling registered
[   71.487722] INFO: rcu_preempt self-detected stall on CPU
[   71.487728] INFO: rcu_preempt detected stalls on CPUs/tasks:
[   71.487735]  1-...: (0 ticks this GP) idle=2da/0/0 softirq=9259/9260 fqs=0
[   71.487739]  3-...: (1 ticks this GP) idle=b29/140000000000001/0 softirq=9026/9026 fqs=0
[   71.487742]  (detected by 2, t=5265 jiffies, g=499, c=498, q=56)
[   71.487764] CPU0: SError detected, daif=1c0, spsr=0x40000045, mpidr=80000000, esr=bf000002
[   71.487778] INFO: rcu_sched self-detected stall on CPU
[   71.487785]  0-...: (1 ticks this GP) idle=ccf/140000000000002/0 softirq=6569/6569 fqs=0
[   71.487790]
[   71.487796] rcu_sched kthread starved for 5265 jiffies! g311 c310 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
[   71.487821] rcu_preempt kthread starved for 5265 jiffies! g499 c498 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[   71.489479] INFO: rcu_sched detected stalls on CPUs/tasks:
[   71.489483]  0-...: (1 ticks this GP) idle=ccf/140000000000002/0 softirq=6569/6569 fqs=0
[   71.489487]  3-...: (1 ticks this GP) idle=b29/140000000000001/0 softirq=9026/9026 fqs=0
[   71.489490]  (detected by 2, t=5265 jiffies, g=311, c=310, q=6)
[   71.493686] nvgpu: 57000000.gpu                    nvgpu_init_hal:91   [ERR]  no support for 0
[   71.597718]  3-...: (1 ticks this GP) idle=b29/140000000000001/0 softirq=9026/9026 fqs=14
[   71.597726]   (t=5292 jiffies g=499 c=498 q=221)
please try to use sdkmanager to flash the board instead of using sdcard image first.
I will add that there are some reasons why @WayneWWW says to flash the actual Jetson. Most people don’t know this, but Jetsons do not have a BIOS, and the equivalent of BIOS plus bootloader exist outside of the SD card. On Nano models which are SD card models, there is QSPI memory on the module itself. That memory contains the equivalent of BIOS and boot content, and flashing the Nano itself flashes this. That content must be valid and of a compatible release before the SD card can succeed. Fully flashing a Jetson implies you are also updating the equivalent of the BIOS and the boot content; simply adjusting the SD card won’t help if that other content is not current (although likely after that you could use several new SD card releases without another flash, but this is not guaranteed).
Thank you very much for your quick support.
I have installed the required ubuntu version (I was using 22.04), installed the SDK Manager and flashed the Jetson Nano (I have placed it correctly in recovery mode). Unfortunately I still have the same problem. I have tried the latest version of jetpack, as well as a slightly older one. The result is still the same.
Something that has caught my attention is that in the log of the Sdk Manager, starting the installation an error “00:37:11 ERROR: Flash Jetson Nano - flash: Board ID(3448) version(402)” is shown. The installation ends with “Success” but I still can’t use the Nano.
I don’t know if I can try something different or if I did a mistake.
Log are attached.
SDKM_logs_JetPack_4.6.2_Linux_for_Jetson_Nano_modules_2023-08-06_00-29-34.zip (209.9 KB)
Thanks again.
If the serial console log still returns similar error after you did the full flash (your log said the flash is done), then this board may have hardware problem and cannot be fixed.
