I apologize for the incomplete logs. Here are the full ones:
Host Log after issuing sudo ./flash.sh jetson-nano-2gb-devkit mmcblk0p1:
# L4T BSP Information:
# R32 , REVISION: 5.2
# Target Board Information:
# Name: jetson-nano-2gb-devkit, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet "/home/myuser/src/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0012 ] Generating RCM messages
[ 0.0023 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/myuser/src/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0032 ] RCM 0 is saved as rcm_0.rcm
[ 0.0039 ] RCM 1 is saved as rcm_1.rcm
[ 0.0039 ] List of rcm files are saved in rcm_list.xml
[ 0.0039 ]
[ 0.0039 ] Signing RCM messages
[ 0.0048 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0057 ] Assuming zero filled SBK key
[ 0.0141 ]
[ 0.0141 ] Copying signature to RCM mesages
[ 0.0155 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0173 ]
[ 0.0174 ] Boot Rom communication
[ 0.0185 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
Device Log:
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-dd84d362)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x46
[0000.151] RamCode = 1
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x228d3
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.204] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.210] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.216] Resize the SecureOs Carveout to 0x00100000
[0000.221] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.226] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.232] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.238] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.244] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.250] Platform-DebugCarveout: 0
[0000.253] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.259] Non secure mode, and RB not enabled.
[0000.263] BoardID = 3448, SKU = 0x3
[0000.266] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.270] Nano-SD: checking PT table on QSPI ...
[0000.274] Read PT from (2:0)
[0000.290] Using BFS PT to query partitions
[0000.295] Loading Tboot-CPU binary
[0000.324] Verifying TBC in OdmNonSecureSBK mode
[0000.334] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.341] Bootloader downloaded successfully.
[0000.345] Downloaded Tboot-CPU binary to 0xa0000258
[0000.350] MAX77620_GPIO5 configured
[0000.353] CPU power rail is up
[0000.356] CPU clock enabled
[0000.360] Performing RAM repair
[0000.363] Updating A64 Warmreset Address to 0xa00002e9
[0000.368] BoardID = 3448, SKU = 0x3
[0000.371] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.375] Nano-SD: checking PT table on QSPI ...
[0000.379] Loading NvTbootBootloaderDTB
[0000.446] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.519] Bootloader DTB Load Address: 0x83000000
[0000.523] BoardID = 3448, SKU = 0x3
[0000.527] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.530] Nano-SD: checking PT table on QSPI ...
[0000.535] Loading NvTbootKernelDTB
[0000.601] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.674] Kernel DTB Load Address: 0x83100000
[0000.678] BoardID = 3448, SKU = 0x3
[0000.681] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.685] Nano-SD: checking PT table on QSPI ...
[0000.691] Loading cboot binary
[0000.807] Verifying EBT in OdmNonSecureSBK mode
[0000.849] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.856] Bootloader downloaded successfully.
[0000.860] BoardID = 3448, SKU = 0x3
[0000.863] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.867] Nano-SD: checking PT table on QSPI ...
[0000.872] PT: Partition NCT NOT found !
[0000.875] Warning: Find Partition via PT Failed
[0000.880] Next binary entry address: 0x92c00258
[0000.884] BoardId: 3448
[0000.889] Overriding pmu board id with proc board id
[0000.894] Display board id is not available
[0000.898] No Bpmp FW loaded
[0000.900] Not loading WB0 as no bpmp/sc7entry fw
[0000.905] Set NvDecSticky Bits
[0000.908] GSC2 address ff93fffc value c0edbbcc
[0000.915] GSC MC Settings done
[0000.917] BoardID = 3448, SKU = 0x3
[0000.921] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.925] Nano-SD: checking PT table on QSPI ...
[0000.930] TOS Image length 53680
[0000.933] Monitor size 53680
[0000.936] OS size 0
[0000.951] Secure Os AES-CMAC Verification Success!
[0000.956] TOS image cipher info: plaintext
[0000.959] Loading and Validation of Secure OS Successful
[0000.975] NvTbootPackSdramParams: start.
[0000.980] NvTbootPackSdramParams: done.
[0000.984] Tegraboot started after 51830 us
[0000.988] Basic modules init took 909012 us
[0000.992] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0000.998] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.003] Next stage binary read took 11286 us
[0001.007] Carveout took -63810 us
[0001.011] CPU initialization took 99962 us
[0001.014] Total time taken by TegraBoot 956450 us
[0001.019] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 11:29:29, Jun 14 2021
ERROR: Error initializing runtime service trusty_fast
[0001.141] RamCode = 1
[0001.143] get_emc_table_offset: Can't find emc-table node
[0001.148] LPDDR4 Training: Can't find emc-table node
[0001.184]
[0001.185] Debug Init done
[0001.187] Marked DTB cacheable
[0001.190] Bootloader DTB loaded at 0x83000000
[0001.195] Marked DTB cacheable
[0001.198] Kernel DTB loaded at 0x83100000
[0001.202] DeviceTree Init done
[0001.215] Pinmux applied successfully
[0001.219] gicd_base: 0x50041000
[0001.223] gicc_base: 0x50042000
[0001.226] Interrupts Init done
[0001.230] Using base:0x60005090 & irq:208 for tick-timer
[0001.235] Using base:0x60005098 for delay-timer
[0001.240] platform_init_timer: DONE
[0001.243] Timer(tick) Init done
[0001.247] osc freq = 38400 khz
[0001.251]
[0001.252] Welcome to L4T Cboot
[0001.255]
[0001.256] Cboot Version: 00.00.2018.01-t210-39562017
[0001.261] calling constructors
[0001.264] initializing heap
[0001.266] initializing threads
[0001.269] initializing timers
[0001.272] creating bootstrap completion thread
[0001.277] top of bootstrap2()
[0001.280] CPU: ARM Cortex A57
[0001.282] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.287] initializing platform
[0001.295] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.299] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.304] Macronix QSPI chip present
[0001.307] SPI device register
[0001.310] init boot device
[0001.313] allocating memory for boot device(SPI)
[0001.317] registering boot device
[0001.326] QSPI bdev is already initialized
[0001.330] Enable APE clock
[0001.332] Un-powergate APE partition
[0001.336] of_register: registering tegra_udc to of_hal
[0001.341] of_register: registering inv20628-driver to of_hal
[0001.346] of_register: registering ads1015-driver to of_hal
[0001.352] of_register: registering lp8557-bl-driver to of_hal
[0001.358] of_register: registering bq2419x_charger to of_hal
[0001.363] of_register: registering bq27441_fuel_gauge to of_hal
[0001.375] gpio framework initialized
[0001.378] of_register: registering tca9539_gpio to of_hal
[0001.384] of_register: registering tca9539_gpio to of_hal
[0001.389] of_register: registering i2c_bus_driver to of_hal
[0001.395] of_register: registering i2c_bus_driver to of_hal
[0001.400] of_register: registering i2c_bus_driver to of_hal
[0001.406] pmic framework initialized
[0001.409] of_register: registering max77620_pmic to of_hal
[0001.415] regulator framework initialized
[0001.419] of_register: registering tps65132_bl_driver to of_hal
[0001.425] initializing target
[0001.430] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.438] board ID = D78, board SKU = 3
[0001.442] Skipping Z3!
[0001.447] fixed regulator driver initialized
[0001.465] initializing OF layer
[0001.468] NCK carveout not present
[0001.471] Skipping dts_overrides
[0001.475] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.492] I2C Bus Init done
[0001.495] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.505] I2C Bus Init done
[0001.508] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.518] I2C Bus Init done
[0001.521] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.531] I2C Bus Init done
[0001.534] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.544] I2C Bus Init done
[0001.547] of_children_init: Ops found for compatible string maxim,max77620
[0001.557] max77620_init using irq 118
[0001.562] register 'maxim,max77620' pmic
[0001.567] gpio_driver_register: register 'max77620-gpio' driver
[0001.573] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.583] I2C Bus Init done
[0001.587] NCK carveout not present
[0001.597] Find /i2c@7000c000's alias i2c0
[0001.601] get eeprom at 1-a0, size 256, type 0
[0001.610] Find /i2c@7000c500's alias i2c2
[0001.613] get eeprom at 3-a0, size 256, type 0
[0001.618] get eeprom at 3-ae, size 256, type 0
[0001.622] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.627] I2C slave not started
[0001.630] I2C write failed
[0001.633] Writing offset failed
[0001.636] eeprom_init: EEPROM read failed
[0001.640] pm_ids_update: eeprom init failed
[0001.644] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.674] pm_ids_update: The pm board id is 3448-0003-400
[0001.681] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.690] pm_ids_update: pm id update successful
[0001.694] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.724] pm_ids_update: The pm board id is 3542-0000-200
[0001.730] Adding plugin-manager/ids/3542-0000-200=/i2c@7000c500:module@0x57
[0001.738] pm_ids_update: pm id update successful
[0001.769] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.774] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.782] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.788] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.797] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2d:fd:ef
[0001.803] Plugin Manager: Parse ODM data 0x000a4000
[0001.815] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0001.830] Find /i2c@7000c000's alias i2c0
[0001.834] get eeprom at 1-a0, size 256, type 0
[0001.843] Find /i2c@7000c500's alias i2c2
[0001.847] get eeprom at 3-a0, size 256, type 0
[0001.851] get eeprom at 3-ae, size 256, type 0
[0001.856] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.861] I2C slave not started
[0001.864] I2C write failed
[0001.867] Writing offset failed
[0001.870] eeprom_init: EEPROM read failed
[0001.873] pm_ids_update: eeprom init failed
[0001.878] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.908] pm_ids_update: The pm board id is 3448-0003-400
[0001.914] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.921] pm_ids_update: pm id update successful
[0001.925] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.956] pm_ids_update: The pm board id is 3542-0000-200
[0001.962] Adding plugin-manager/ids/3542-0000-200=/i2c@7000c500:module@0x57
[0001.969] pm_ids_update: pm id update successful
[0001.999] Add serial number:1423820002778 as DT property
[0002.007] Applying platform configs
[0002.014] platform-init is not present. Skipping
[0002.018] calling apps_init()
[0002.024] Couldn't find GPT header
[0002.028] Proceeding to Cold Boot
[0002.032] starting app android_boot_app
[0002.035] Device state: unlocked
[0002.039] display console init
[0002.047] could not find regulator
[0002.050] hdmi cable connected
[0002.066] edid read success
[0002.081] edid rDT entry for leds-pwm not found
e[0002.089] ad success
[0002.091] width = 640, height = 480, frequency = 25174825
[0002.096] width = 640, height = 480, frequency = 25174825
[0002.101] width = 640, height = 480, frequency = 25174825
[0002.107] width = 640, height = 480, frequency = 25174825
[0002.112] width = 2560, height = 1440, frequency = 241500000
[0002.118] width = 1920, height = 1080, frequency = 148351648
[0002.123] width = 1280, height = 720, frequency = 74175824
[0002.129] width = 720, height = 480, frequency = 26973026
[0002.134] width = 720, height = 480, frequency = 26973026
[0002.140] width = 1920, height = 1080, frequency = 148351648
[0002.145] width = 1280, height = 720, frequency = 74175824
[0002.151] width = 720, height = 576, frequency = 26973026
[0002.156] width = 720, height = 576, frequency = 26973026
[0002.162] width = 640, height = 480, frequency = 25174825
[0002.167] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.175] tmds-config node not found
[0002.179] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.194] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.201] could not find regulator
[0002.204] could not find regulator
[0002.208] could not find regulator
[0002.236] using default cmu settings
[0002.240] dc_hdmi_enable, starting HDMI initialisation
[0002.246] dc_hdmi_enable, HDMI initialisation complete
[0002.251] list and configure display window
[0002.260] display console init completed
[0002.271] subnode volume_up is not found !
[0002.275] subnode back is not found !
[0002.278] subnode volume_down is not found !
[0002.283] subnode menu is not found !
[0002.286] Gpio keyboard init success
[0002.367] found decompressor handler: lz4-legacy
[0002.381] decompressing blob (type 1)...
[0002.450] load_bmp_blob: panelresolution=1080 type=3
[0002.525] decompressor handler not found
[0002.529] load_firmware_blob: Firmware blob loaded, entries=2
[0002.535] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.541] -------> se_aes_verify_sbk_clear: 747
[0002.545] se_aes_verify_sbk_clear: Error
[0002.549] SE operation failed
[0002.552] bl_battery_charging: connected to external power supply
[0002.564] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.571] MSC Partition not found
[0002.578] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.585] USP partition read failed!
[0002.588] blob_init: blob-partition USP header read failed
[0002.594] android_boot Unable to update recovery partition
[0002.599] kfs_getpartname: name = LNX
[0002.603] Loading kernel from LNX
[0002.612] Found 19 BFS partitions in "spiflash0"
[0002.935] load kernel from storage
[0002.940] decompressor handler not found
[0003.208] Successfully loaded kernel and ramdisk images
[0003.213] board ID = D78, board SKU = 3
[0003.218] sdmmc node status = okay
[0003.221] sdcard instance = 0
[0003.224] sdcard gpio handle 0x5b
[0003.227] sdcard gpio pin 0xc9
[0003.230] sdcard gpio flags 0x0
[0003.233] vmmc-supply 0x9e
[0003.236] cd_gpio_pin = 201
[0003.238] pin_state = 0
[0003.241] Found sdcard
[0003.243] SD-card IS present ...
[0003.246] load_and_boot_kernel: SD card detected OK
[0003.252] load_bmp_blob: panelresolution=1080 type=3
[0003.736] display bmp image done
[0003.739] NCK carveout not present
[0003.742] Skipping dts_overrides
[0003.746] NCK carveout not present
[0003.755] Find /i2c@7000c000's alias i2c0
[0003.759] get eeprom at 1-a0, size 256, type 0
[0003.768] Find /i2c@7000c500's alias i2c2
[0003.772] get eeprom at 3-a0, size 256, type 0
[0003.777] get eeprom at 3-ae, size 256, type 0
[0003.781] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.786] I2C slave not started
[0003.789] I2C write failed
[0003.792] Writing offset failed
[0003.795] eeprom_init: EEPROM read failed
[0003.799] pm_ids_update: eeprom init failed
[0003.803] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.833] pm_ids_update: The pm board id is 3448-0003-400
[0003.840] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0003.848] pm_ids_update: pm id update successful
[0003.853] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.883] pm_ids_update: The pm board id is 3542-0000-200
[0003.889] Adding plugin-manager/ids/3542-0000-200=/i2c@7000c500:module@0x57
[0003.897] pm_ids_update: pm id update successful
[0003.927] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.933] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.941] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.947] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.955] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2d:fd:ef
[0003.962] Plugin Manager: Parse ODM data 0x000a4000
[0003.974] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.982] Add serial number:1423820002778 as DT property
[0003.990] Updated bpmp info to DTB
[0003.995] Updated initrd info to DTB
[0003.999] "proc-board" doesn't exist, creating
[0004.005] Updated board info to DTB
[0004.008] "pmu-board" doesn't exist, creating
[0004.014] Updated board info to DTB
[0004.017] "display-board" doesn't exist, creating
[0004.023] Updated board info to DTB
[0004.027] "reset" doesn't exist, creating
[0004.031] Updated reset info to DTB
[0004.035] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=te
[0004.072] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.077] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.090] Updated bootarg info to DTB
[0004.094] Adding uuid 000000016450888208000000180604c0 to DT
[0004.100] Adding eks info 0 to DT
[0004.105] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.111] Updated memory info to DTB
[0004.119] set vdd_core voltage to 1125 mv
[0004.123] setting 'vdd-core' regulator to 1125000 micro volts
[0004.129] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Jun 14 2021 - 11:29:26 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 2 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 25 ms (32.2 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159841 bytes read in 328 ms (20.8 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 1501 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_con
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317e68d
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f9191
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f800000
[ 0.000000] OF: fdt: - bfa00000 , 3fe00000
[ 0.000000] OF: fdt: - ffa00000 , 600000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
