Jetson Nano 2GB will not boot
I have a new 2GB nano and I can get it past the nvidia logo screen.
I connect to the serial and I get the following
U-Boot 2016.07-g7a7e3f476e (Oct 16 2020 - 12:23:42 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
844 bytes read in 177 ms (3.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487776 bytes read in 373 ms (14 MiB/s)
Retrieving file: /boot/Image
34332680 bytes read in 1542 ms (21.2 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 000000008317de85
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4263) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc0
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f200000
[ 0.000000] OF: fdt: - c0000000 , 3ee00000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
and then it will reboot once and get to this same section again.
I have reflashed the SD card and changed SD cards as well as different power supplies.
Any suggestions would be greatly appreciated!
Please disable the quiet keyword in kernel cmdline and share the log again.
https://elinux.org/Jetson/General_debug
thank you for the reply, here is the full output with the quiet keyword removed
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-80a468da)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x60
[0000.151] RamCode = 1
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x2815f7
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x00000000bf300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.270] Read GPT from (4:0)
[0000.658] Csd NumOfBlocks=250085376
[0000.663] Set High speed to 1
[0000.672] Using GPT Primary to query partitions
[0000.677] Loading Tboot-CPU binary
[0000.687] Verifying TBC in OdmNonSecureSBK mode
[0000.697] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.704] Bootloader downloaded successfully.
[0000.708] Downloaded Tboot-CPU binary to 0xa0000258
[0000.713] MAX77620_GPIO5 configured
[0000.716] CPU power rail is up
[0000.719] CPU clock enabled
[0000.723] Performing RAM repair
[0000.726] Updating A64 Warmreset Address to 0xa00002e9
[0000.731] Read GPT from (4:0)
[0000.739] Using GPT Primary to query partitions
[0000.744] Loading NvTbootBootloaderDTB
[0000.768] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.841] Bootloader DTB Load Address: 0x83000000
[0000.845] Read GPT from (4:0)
[0000.854] Using GPT Primary to query partitions
[0000.858] Loading NvTbootKernelDTB
[0000.882] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.954] Kernel DTB Load Address: 0x83100000
[0000.959] Read GPT from (4:0)
[0000.967] Using GPT Primary to query partitions
[0000.972] Loading cboot binary
[0001.002] Verifying EBT in OdmNonSecureSBK mode
[0001.043] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.050] Bootloader downloaded successfully.
[0001.054] Read GPT from (4:0)
[0001.063] Using GPT Primary to query partitions
[0001.068] Read PT from (2:0)
[0001.083] Using BFS PT to query partitions
[0001.087] PT: Partition NCT NOT found !
[0001.091] Warning: Find Partition via PT Failed
[0001.095] Next binary entry address: 0x92c00258
[0001.099] BoardId: 3448
[0001.104] Overriding pmu board id with proc board id
[0001.109] Display board id is not available
[0001.113] Read GPT from (4:0)
[0001.122] Using GPT Primary to query partitions
[0001.150] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.206] /bpmp deleted
[0001.208] SC7EntryFw header found loaded at 0xff700000
[0001.400] OVR2 PMIC
[0001.402] Bpmp FW successfully loaded
[0001.406] Read GPT from (4:0)
[0001.414] Using GPT Primary to query partitions
[0001.419] WB0 init successfully at 0xff780000
[0001.423] Set NvDecSticky Bits
[0001.427] GSC2 address ff53fffc value c0edbbcc
[0001.433] GSC MC Settings done
[0001.436] Read GPT from (4:0)
[0001.445] Using GPT Primary to query partitions
[0001.450] TOS Image length 53680
[0001.453] Monitor size 53680
[0001.455] OS size 0
[0001.463] Secure Os AES-CMAC Verification Success!
[0001.467] TOS image cipher info: plaintext
[0001.471] Loading and Validation of Secure OS Successful
[0001.487] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.492] NvTbootPackSdramParams: start.
[0001.497] NvTbootPackSdramParams: done.
[0001.501] Tegraboot started after 52318 us
[0001.504] Basic modules init took 1101114 us
[0001.509] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.514] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.520] Storage Device Read Time = 122 ms, Read Size = 2359 KB
[0001.525] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.531] Next stage binary read took 24431 us
[0001.535] Carveout took -49158 us
[0001.538] CPU initialization took 408230 us
[0001.542] Total time taken by TegraBoot 1484617 us
[0001.547] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 12:23:48, Oct 16 2020
ERROR: Error initializing runtime service trusty_fast
[0001.668] RamCode = 1
[0001.671] get_emc_table_offset: Can’t find emc-table node
[0001.676] LPDDR4 Training: Can’t find emc-table node
[0001.724]
[0001.725] Debug Init done
[0001.728] Marked DTB cacheable
[0001.731] Bootloader DTB loaded at 0x83000000
[0001.736] Marked DTB cacheable
[0001.739] Kernel DTB loaded at 0x83100000
[0001.742] DeviceTree Init done
[0001.755] Pinmux applied successfully
[0001.760] gicd_base: 0x50041000
[0001.763] gicc_base: 0x50042000
[0001.766] Interrupts Init done
[0001.770] Using base:0x60005090 & irq:208 for tick-timer
[0001.776] Using base:0x60005098 for delay-timer
[0001.780] platform_init_timer: DONE
[0001.783] Timer(tick) Init done
[0001.787] osc freq = 38400 khz
[0001.791]
[0001.792] Welcome to L4T Cboot
[0001.795]
[0001.796] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.801] calling constructors
[0001.804] initializing heap
[0001.807] initializing threads
[0001.810] initializing timers
[0001.813] creating bootstrap completion thread
[0001.817] top of bootstrap2()
[0001.820] CPU: ARM Cortex A57
[0001.823] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.828] initializing platform
[0001.835] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.840] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.844] Macronix QSPI chip present
[0001.848] SPI device register
[0001.850] init boot device
[0001.853] allocating memory for boot device(SPI)
[0001.858] registering boot device
[0001.867] sdmmc node status = okay
[0001.870] sdcard instance = 0
[0001.873] sdcard gpio handle 0x5b
[0001.876] sdcard gpio pin 0xc9
[0001.879] sdcard gpio flags 0x0
[0001.882] vmmc-supply 0x9e
[0001.885] Instance: 0
[0001.887] Allocating memory for context
[0001.891] enabling clock
[0001.893] sd card init
[0001.896] Check card present and stable
[0001.899] Send command 0
[0001.916] Send command 3
[0001.920] Set RCA for the card
[0001.923] Query card specific data by command 9
[0001.929] Parse CSD data
[0001.932] Send command 7
[0001.942] Calling sd device register
[0001.946] Init sdcard
[0001.948] Allocating memory for boot device
[0001.952] Registering user device
[0001.965] Enable APE clock
[0001.968] Un-powergate APE partition
[0001.971] of_register: registering tegra_udc to of_hal
[0001.976] of_register: registering inv20628-driver to of_hal
[0001.982] of_register: registering ads1015-driver to of_hal
[0001.987] of_register: registering lp8557-bl-driver to of_hal
[0001.993] of_register: registering bq2419x_charger to of_hal
[0001.999] of_register: registering bq27441_fuel_gauge to of_hal
[0002.010] gpio framework initialized
[0002.014] of_register: registering tca9539_gpio to of_hal
[0002.019] of_register: registering tca9539_gpio to of_hal
[0002.025] of_register: registering i2c_bus_driver to of_hal
[0002.030] of_register: registering i2c_bus_driver to of_hal
[0002.036] of_register: registering i2c_bus_driver to of_hal
[0002.041] pmic framework initialized
[0002.045] of_register: registering max77620_pmic to of_hal
[0002.050] regulator framework initialized
[0002.054] of_register: registering tps65132_bl_driver to of_hal
[0002.060] initializing target
[0002.066] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0002.074] board ID = D78, board SKU = 3
[0002.078] Skipping Z3!
[0002.082] fixed regulator driver initialized
[0002.100] initializing OF layer
[0002.103] NCK carveout not present
[0002.107] Skipping dts_overrides
[0002.111] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.128] I2C Bus Init done
[0002.130] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.141] I2C Bus Init done
[0002.143] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.154] I2C Bus Init done
[0002.156] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.167] I2C Bus Init done
[0002.169] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.180] I2C Bus Init done
[0002.182] of_children_init: Ops found for compatible string maxim,max77620
[0002.193] max77620_init using irq 118
[0002.198] register ‘maxim,max77620’ pmic
[0002.202] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.208] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.219] I2C Bus Init done
[0002.222] NCK carveout not present
[0002.232] Find /i2c@7000c000’s alias i2c0
[0002.236] get eeprom at 1-a0, size 256, type 0
[0002.245] Find /i2c@7000c500’s alias i2c2
[0002.249] get eeprom at 3-a0, size 256, type 0
[0002.253] get eeprom at 3-ae, size 256, type 0
[0002.257] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.263] I2C slave not started
[0002.266] I2C write failed
[0002.268] Writing offset failed
[0002.271] eeprom_init: EEPROM read failed
[0002.275] pm_ids_update: eeprom init failed
[0002.279] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.310] pm_ids_update: The pm board id is 3448-0003-400
[0002.316] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.325] pm_ids_update: pm id update successful
[0002.329] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.359] pm_ids_update: The pm board id is 3542-0000-201
[0002.366] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.374] pm_ids_update: pm id update successful
[0002.404] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.410] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.418] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.424] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.432] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:9d:4e
[0002.438] Plugin Manager: Parse ODM data 0x00094000
[0002.451] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.466] Find /i2c@7000c000’s alias i2c0
[0002.469] get eeprom at 1-a0, size 256, type 0
[0002.478] Find /i2c@7000c500’s alias i2c2
[0002.482] get eeprom at 3-a0, size 256, type 0
[0002.487] get eeprom at 3-ae, size 256, type 0
[0002.491] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.496] I2C slave not started
[0002.499] I2C write failed
[0002.502] Writing offset failed
[0002.505] eeprom_init: EEPROM read failed
[0002.509] pm_ids_update: eeprom init failed
[0002.513] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.543] pm_ids_update: The pm board id is 3448-0003-400
[0002.549] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.556] pm_ids_update: pm id update successful
[0002.561] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.591] pm_ids_update: The pm board id is 3542-0000-201
[0002.597] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.604] pm_ids_update: pm id update successful
[0002.634] Add serial number:1424120059084 as DT property
[0002.642] Applying platform configs
[0002.649] platform-init is not present. Skipping
[0002.653] calling apps_init()
[0002.678] Found 14 GPT partitions in “sd0”
[0002.682] Proceeding to Cold Boot
[0002.686] starting app android_boot_app
[0002.689] Device state: unlocked
[0002.693] display console init
[0002.701] could not find regulator
[0002.724] hdmi cable not connected
[0002.727] is_hdmi_needed: HDMI not connected, returning faDT entry for leds-pwm not found
l[0002.739] se
[0002.740] hdmi is not connected
[0002.743] sor0 is not supported
[0002.746] display_console_init: no valid display out_type
[0002.755] subnode volume_up is not found !
[0002.759] subnode back is not found !
[0002.762] subnode volume_down is not found !
[0002.766] subnode menu is not found !
[0002.770] Gpio keyboard init success
[0002.814] found decompressor handler: lz4-legacy
[0002.828] decompressing blob (type 1)…
[0002.861] display_resolution: No display init
[0002.866] Failed to retrieve display resolution
[0002.870] Could not load/initialize BMP blob…ignoring
[0002.921] decompressor handler not found
[0002.925] load_firmware_blob: Firmware blob loaded, entries=2
[0002.931] -------> se_aes_verify_sbk_clear: 747
[0002.935] se_aes_verify_sbk_clear: Error
[0002.939] bl_battery_charging: connected to external power supply
[0002.946] xusb is supported
[0002.952] error while finding nvidia,portmap
[0003.456] xusb blob version 0 size 124416
[0003.460] firmware size 124416
[0003.465] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.473] xhci0: 64 bytes context size, 32-bit DMA
[0003.513] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.533] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.183] uhub0: 9 ports with 9 removable, self powered
[0005.303] uhub1: <vendor 0x1a40 USB 2.0 Hub, class 9/0, rev 2.00/1.00, addr 1> on usbus0
[0006.083] uhub1: 4 ports with 4 removable, self powered
[0007.473] failed to get HID devices
[0007.476] failed to init xhci or no usb device attached
[0007.483] display_console_ioctl: No display init
[0007.488] switch_backlight failed
[0007.494] device_query_partition_size: failed to open partition sd0:MSC !
[0007.501] MSC Partition not found
[0007.507] device_query_partition_size: failed to open partition sd0:USP !
[0007.514] USP partition read failed!
[0007.517] blob_init: blob-partition USP header read failed
[0007.523] android_boot Unable to update recovery partition
[0007.528] kfs_getpartname: name = LNX
[0007.532] Loading kernel from LNX
[0007.630] load kernel from storage
[0007.642] decompressor handler not found
[0007.699] Successfully loaded kernel and ramdisk images
[0007.705] display_resolution: No display init
[0007.709] Failed to retrieve display resolution
[0007.714] bmp blob is not loaded and initialized
[0007.718] Failed to display boot-logo
[0007.722] NCK carveout not present
[0007.725] Skipping dts_overrides
[0007.728] NCK carveout not present
[0007.738] Find /i2c@7000c000’s alias i2c0
[0007.742] get eeprom at 1-a0, size 256, type 0
[0007.751] Find /i2c@7000c500’s alias i2c2
[0007.755] get eeprom at 3-a0, size 256, type 0
[0007.759] get eeprom at 3-ae, size 256, type 0
[0007.764] pm_ids_update: Updating 1,a0, size 256, type 0
[0007.769] I2C slave not started
[0007.772] I2C write failed
[0007.775] Writing offset failed
[0007.778] eeprom_init: EEPROM read failed
[0007.782] pm_ids_update: eeprom init failed
[0007.786] pm_ids_update: Updating 3,a0, size 256, type 0
[0007.816] pm_ids_update: The pm board id is 3448-0003-400
[0007.823] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0007.831] pm_ids_update: pm id update successful
[0007.836] pm_ids_update: Updating 3,ae, size 256, type 0
[0007.866] pm_ids_update: The pm board id is 3542-0000-201
[0007.872] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0007.880] pm_ids_update: pm id update successful
[0007.910] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0007.916] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0007.924] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0007.930] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0007.938] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:9d:4e
[0007.945] Plugin Manager: Parse ODM data 0x00094000
[0007.957] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0007.965] Add serial number:1424120059084 as DT property
[0007.975] “bpmp” doesn’t exist, creating
[0007.980] Updated bpmp info to DTB
[0007.985] Updated initrd info to DTB
[0007.988] “proc-board” doesn’t exist, creating
[0007.994] Updated board info to DTB
[0007.998] “pmu-board” doesn’t exist, creating
[0008.004] Updated board info to DTB
[0008.007] “display-board” doesn’t exist, creating
[0008.013] Updated board info to DTB
[0008.016] “reset” doesn’t exist, creating
[0008.021] Updated reset info to DTB
[0008.024] display_console_ioctl: No display init
[0008.029] display_console_ioctl: No display init
[0008.034] display_console_ioctl: No display init
[0008.038] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvf
[0008.072] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0008.078] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.091] Updated bootarg info to DTB
[0008.094] Adding uuid 0000000164460805100000000b0304c0 to DT
[0008.100] Adding eks info 0 to DT
[0008.106] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0008.112] Updated memory info to DTB
[0008.120] set vdd_core voltage to 1075 mv
[0008.124] setting ‘vdd-core’ regulator to 1075000 micro volts
[0008.143] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 1:1…
838 bytes read in 176 ms (3.9 KiB/s)
1: primary kernel
5487776 bytes read in 372 ms (14.1 MiB/s)
34332680 bytes read in 1543 ms (21.2 MiB/s)
Starting kernel …
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc07ab9c000 s61656 r8192 d32552 u102400
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 507464
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_in
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29468(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1508904K/2062336K available (15294K kernel code, 2936K rwdata, 6644K rodata, 8576K init, 611K bss, 78296K reserved, 47513)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13e008 ( 2937 KB)
[ 0.000000] .bss : 0xffffff800a13e008 - 0xffffff800a1d6f7c ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf01fb8000 ( 31 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc07ee00000 ( 2030 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.009969] Console: colour dummy device 80x25
[ 0.014621] console [tty0] enabled
[ 0.018137] bootconsole [uart8250] disabled
[0000.159] [L4T TegraBoot] (version 00.00.2018.01-l4t-80a468da)
[0000.165] Processing in cold boot mode Bootloader 2
[0000.170] A02 Bootrom Patch rev = 1023
[0000.173] Power-up reason: software reset
[0000.177] No Battery Present
[0000.179] pmic max77620 reset reason
[0000.183] pmic max77620 NVERC : 0x0
[0000.186] RamCode = 1
[0000.188] Platform has DDR4 type RAM
[0000.192] max77620 disabling SD1 Remote Sense
[0000.196] Setting DDR voltage to 1125mv
[0000.200] Serial Number of Pmic Max77663: 0x2815f7
[0000.208] Entering ramdump check
[0000.211] Get RamDumpCarveOut = 0x0
[0000.214] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.219] Last reboot was clean, booting normally!
[0000.224] Sdram initialization is successful
[0000.228] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.234] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.240] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.246] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.251] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.257] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.263] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.269] GSC3 Carveout Base=0x00000000bf300000 Size=0x00d00000
[0000.285] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.291] Platform-DebugCarveout: 0
[0000.294] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.300] Non secure mode, and RB not enabled.
[0000.304] Read GPT from (4:0)
[0000.655] Csd NumOfBlocks=250085376
[0000.659] Set High speed to 1
[0000.669] Using GPT Primary to query partitions
[0000.674] Loading Tboot-CPU binary
[0000.683] Verifying TBC in OdmNonSecureSBK mode
[0000.693] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.700] Bootloader downloaded successfully.
[0000.704] Downloaded Tboot-CPU binary to 0xa0000258
[0000.710] MAX77620_GPIO5 configured
[0000.713] CPU power rail is up
[0000.716] CPU clock enabled
[0000.719] Performing RAM repair
[0000.722] Updating A64 Warmreset Address to 0xa00002e9
[0000.727] Read GPT from (4:0)
[0000.736] Using GPT Primary to query partitions
[0000.740] Loading NvTbootBootloaderDTB
[0000.765] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.837] Bootloader DTB Load Address: 0x83000000
[0000.842] Read GPT from (4:0)
[0000.850] Using GPT Primary to query partitions
[0000.855] Loading NvTbootKernelDTB
[0000.879] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.951] Kernel DTB Load Address: 0x83100000
[0000.955] Read GPT from (4:0)
[0000.964] Using GPT Primary to query partitions
[0000.969] Loading cboot binary
[0000.998] Verifying EBT in OdmNonSecureSBK mode
[0001.040] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.047] Bootloader downloaded successfully.
[0001.051] Read GPT from (4:0)
[0001.060] Using GPT Primary to query partitions
[0001.064] Read PT from (2:0)
[0001.080] Using BFS PT to query partitions
[0001.084] PT: Partition NCT NOT found !
[0001.087] Warning: Find Partition via PT Failed
[0001.092] Next binary entry address: 0x92c00258
[0001.096] BoardId: 3448
[0001.101] Overriding pmu board id with proc board id
[0001.105] Display board id is not available
[0001.110] Read GPT from (4:0)
[0001.118] Using GPT Primary to query partitions
[0001.146] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.202] /bpmp deleted
[0001.204] SC7EntryFw header found loaded at 0xff700000
[0001.397] OVR2 PMIC
[0001.399] Bpmp FW successfully loaded
[0001.402] Read GPT from (4:0)
[0001.411] Using GPT Primary to query partitions
[0001.416] WB0 init successfully at 0xff780000
[0001.420] Set NvDecSticky Bits
[0001.424] GSC2 address ff53fffc value c0edbbcc
[0001.430] GSC MC Settings done
[0001.433] Read GPT from (4:0)
[0001.441] Using GPT Primary to query partitions
[0001.446] TOS Image length 53680
[0001.449] Monitor size 53680
[0001.452] OS size 0
[0001.459] Secure Os AES-CMAC Verification Success!
[0001.464] TOS image cipher info: plaintext
[0001.468] Loading and Validation of Secure OS Successful
[0001.484] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.488] NvTbootPackSdramParams: start.
[0001.493] NvTbootPackSdramParams: done.
[0001.497] Tegraboot started after 87459 us
[0001.501] Basic modules init took 1062570 us
[0001.505] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.511] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.516] Storage Device Read Time = 122 ms, Read Size = 2359 KB
[0001.522] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.527] Next stage binary read took 24430 us
[0001.532] Carveout took -49153 us
[0001.535] CPU initialization took 408226 us
[0001.539] Total time taken by TegraBoot 1446073 us
[0001.544] Starting CPU & Halting co-processor
[0001.665] RamCode = 1
[0001.667] get_emc_table_offset: Can’t find emc-table node
[0001.672] LPDDR4 Training: Can’t find emc-table node
[0001.721]
[0001.722] Debug Init done
[0001.725] Marked DTB cacheable
[0001.727] Bootloader DTB loaded at 0x83000000
[0001.732] Marked DTB cacheable
[0001.735] Kernel DTB loaded at 0x83100000
[0001.739] DeviceTree Init done
[0001.752] Pinmux applied successfully
[0001.756] gicd_base: 0x50041000
[0001.760] gicc_base: 0x50042000
[0001.763] Interrupts Init done
[0001.767] Using base:0x60005090 & irq:208 for tick-timer
[0001.772] Using base:0x60005098 for delay-timer
[0001.777] platform_init_timer: DONE
[0001.780] Timer(tick) Init done
[0001.784] osc freq = 38400 khz
[0001.788]
[0001.789] Welcome to L4T Cboot
[0001.792]
[0001.793] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.798] calling constructors
[0001.801] initializing heap
[0001.803] initializing threads
[0001.806] initializing timers
[0001.809] creating bootstrap completion thread
[0001.814] top of bootstrap2()
[0001.817] CPU: ARM Cortex A57
[0001.819] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.824] initializing platform
[0001.832] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.836] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.841] Macronix QSPI chip present
[0001.844] SPI device register
[0001.847] init boot device
[0001.850] allocating memory for boot device(SPI)
[0001.854] registering boot device
[0001.864] sdmmc node status = okay
[0001.867] sdcard instance = 0
[0001.870] sdcard gpio handle 0x5b
[0001.873] sdcard gpio pin 0xc9
[0001.876] sdcard gpio flags 0x0
[0001.879] vmmc-supply 0x9e
[0001.882] Instance: 0
[0001.884] Allocating memory for context
[0001.887] enabling clock
[0001.890] sd card init
[0001.892] Check card present and stable
[0001.896] Send command 0
[0001.912] Send command 3
[0001.917] Set RCA for the card
[0001.920] Query card specific data by command 9
[0001.926] Parse CSD data
[0001.928] Send command 7
[0001.939] Calling sd device register
[0001.942] Init sdcard
[0001.944] Allocating memory for boot device
[0001.949] Registering user device
[0001.962] Enable APE clock
[0001.964] Un-powergate APE partition
[0001.968] of_register: registering tegra_udc to of_hal
[0001.973] of_register: registering inv20628-driver to of_hal
[0001.979] of_register: registering ads1015-driver to of_hal
[0001.984] of_register: registering lp8557-bl-driver to of_hal
[0001.990] of_register: registering bq2419x_charger to of_hal
[0001.995] of_register: registering bq27441_fuel_gauge to of_hal
[0002.007] gpio framework initialized
[0002.010] of_register: registering tca9539_gpio to of_hal
[0002.016] of_register: registering tca9539_gpio to of_hal
[0002.021] of_register: registering i2c_bus_driver to of_hal
[0002.027] of_register: registering i2c_bus_driver to of_hal
[0002.032] of_register: registering i2c_bus_driver to of_hal
[0002.038] pmic framework initialized
[0002.041] of_register: registering max77620_pmic to of_hal
[0002.047] regulator framework initialized
[0002.051] of_register: registering tps65132_bl_driver to of_hal
[0002.057] initializing target
[0002.062] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0002.071] board ID = D78, board SKU = 3
[0002.074] Skipping Z3!
[0002.079] fixed regulator driver initialized
[0002.097] initializing OF layer
[0002.100] NCK carveout not present
[0002.103] Skipping dts_overrides
[0002.107] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.124] I2C Bus Init done
[0002.127] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.137] I2C Bus Init done
[0002.140] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.150] I2C Bus Init done
[0002.153] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.163] I2C Bus Init done
[0002.166] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.176] I2C Bus Init done
[0002.179] of_children_init: Ops found for compatible string maxim,max77620
[0002.189] max77620_init using irq 118
[0002.194] register ‘maxim,max77620’ pmic
[0002.198] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.205] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.215] I2C Bus Init done
[0002.219] NCK carveout not present
[0002.229] Find /i2c@7000c000’s alias i2c0
[0002.232] get eeprom at 1-a0, size 256, type 0
[0002.241] Find /i2c@7000c500’s alias i2c2
[0002.245] get eeprom at 3-a0, size 256, type 0
[0002.250] get eeprom at 3-ae, size 256, type 0
[0002.254] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.259] I2C slave not started
[0002.262] I2C write failed
[0002.265] Writing offset failed
[0002.268] eeprom_init: EEPROM read failed
[0002.272] pm_ids_update: eeprom init failed
[0002.276] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.306] pm_ids_update: The pm board id is 3448-0003-400
[0002.313] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.321] pm_ids_update: pm id update successful
[0002.326] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.356] pm_ids_update: The pm board id is 3542-0000-201
[0002.362] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.370] pm_ids_update: pm id update successful
[0002.401] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.406] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.414] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.420] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.429] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:9d:4e
[0002.435] Plugin Manager: Parse ODM data 0x00094000
[0002.447] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.462] Find /i2c@7000c000’s alias i2c0
[0002.466] get eeprom at 1-a0, size 256, type 0
[0002.475] Find /i2c@7000c500’s alias i2c2
[0002.479] get eeprom at 3-a0, size 256, type 0
[0002.483] get eeprom at 3-ae, size 256, type 0
[0002.488] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.493] I2C slave not started
[0002.496] I2C write failed
[0002.498] Writing offset failed
[0002.502] eeprom_init: EEPROM read failed
[0002.505] pm_ids_update: eeprom init failed
[0002.510] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.540] pm_ids_update: The pm board id is 3448-0003-400
[0002.546] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.553] pm_ids_update: pm id update successful
[0002.557] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.587] pm_ids_update: The pm board id is 3542-0000-201
[0002.594] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.601] pm_ids_update: pm id update successful
[0002.631] Add serial number:1424120059084 as DT property
[0002.639] Applying platform configs
[0002.645] platform-init is not present. Skipping
[0002.650] calling apps_init()
[0002.675] Found 14 GPT partitions in “sd0”
[0002.679] Proceeding to Cold Boot
[0002.682] starting app android_boot_app
[0002.686] Device state: unlocked
[0002.689] display console init
[0002.697] could not find regulator
[0002.721] hdmi cable not connected
[0002.724] is_hdmi_needed: HDMI not connected, returning faDT entry for leds-pwm not found
l[0002.736] se
[0002.737] hdmi is not connected
[0002.740] sor0 is not supported
[0002.743] display_console_init: no valid display out_type
[0002.751] subnode volume_up is not found !
[0002.755] subnode back is not found !
[0002.759] subnode volume_down is not found !
[0002.763] subnode menu is not found !
[0002.767] Gpio keyboard init success
[0002.810] found decompressor handler: lz4-legacy
[0002.825] decompressing blob (type 1)…
[0002.858] display_resolution: No display init
[0002.862] Failed to retrieve display resolution
[0002.867] Could not load/initialize BMP blob…ignoring
[0002.918] decompressor handler not found
[0002.921] load_firmware_blob: Firmware blob loaded, entries=2
[0002.927] -------> se_aes_verify_sbk_clear: 747
[0002.932] se_aes_verify_sbk_clear: Error
[0002.935] bl_battery_charging: connected to external power supply
[0002.942] xusb is supported
[0002.948] error while finding nvidia,portmap
[0003.453] xusb blob version 0 size 124416
[0003.457] firmware size 124416
[0003.461] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.469] xhci0: 64 bytes context size, 32-bit DMA
[0003.509] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.529] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.179] uhub0: 9 ports with 9 removable, self powered
[0005.299] uhub1: <vendor 0x1a40 USB 2.0 Hub, class 9/0, rev 2.00/1.00, addr 1> on usbus0
[0006.079] uhub1: 4 ports with 4 removable, self powered
[0007.469] failed to get HID devices
[0007.473] failed to init xhci or no usb device attached
[0007.480] display_console_ioctl: No display init
[0007.484] switch_backlight failed
[0007.491] device_query_partition_size: failed to open partition sd0:MSC !
[0007.497] MSC Partition not found
[0007.504] device_query_partition_size: failed to open partition sd0:USP !
[0007.510] USP partition read failed!
[0007.514] blob_init: blob-partition USP header read failed
[0007.519] android_boot Unable to update recovery partition
[0007.525] kfs_getpartname: name = LNX
[0007.528] Loading kernel from LNX
[0007.627] load kernel from storage
[0007.638] decompressor handler not found
[0007.696] Successfully loaded kernel and ramdisk images
[0007.702] display_resolution: No display init
[0007.706] Failed to retrieve display resolution
[0007.710] bmp blob is not loaded and initialized
[0007.715] Failed to display boot-logo
[0007.719] NCK carveout not present
[0007.722] Skipping dts_overrides
[0007.725] NCK carveout not present
[0007.735] Find /i2c@7000c000’s alias i2c0
[0007.739] get eeprom at 1-a0, size 256, type 0
[0007.748] Find /i2c@7000c500’s alias i2c2
[0007.751] get eeprom at 3-a0, size 256, type 0
[0007.756] get eeprom at 3-ae, size 256, type 0
[0007.760] pm_ids_update: Updating 1,a0, size 256, type 0
[0007.766] I2C slave not started
[0007.769] I2C write failed
[0007.771] Writing offset failed
[0007.774] eeprom_init: EEPROM read failed
[0007.778] pm_ids_update: eeprom init failed
[0007.782] pm_ids_update: Updating 3,a0, size 256, type 0
[0007.812] pm_ids_update: The pm board id is 3448-0003-400
[0007.819] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0007.828] pm_ids_update: pm id update successful
[0007.832] pm_ids_update: Updating 3,ae, size 256, type 0
[0007.862] pm_ids_update: The pm board id is 3542-0000-201
[0007.868] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0007.877] pm_ids_update: pm id update successful
[0007.907] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0007.913] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0007.921] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0007.926] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0007.935] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:9d:4e
[0007.941] Plugin Manager: Parse ODM data 0x00094000
[0007.954] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0007.962] Add serial number:1424120059084 as DT property
[0007.971] “bpmp” doesn’t exist, creating
[0007.977] Updated bpmp info to DTB
[0007.981] Updated initrd info to DTB
[0007.985] “proc-board” doesn’t exist, creating
[0007.991] Updated board info to DTB
[0007.994] “pmu-board” doesn’t exist, creating
[0008.000] Updated board info to DTB
[0008.004] “display-board” doesn’t exist, creating
[0008.009] Updated board info to DTB
[0008.013] “reset” doesn’t exist, creating
[0008.017] Updated reset info to DTB
[0008.021] display_console_ioctl: No display init
[0008.025] display_console_ioctl: No display init
[0008.030] display_console_ioctl: No display init
[0008.035] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvf
[0008.069] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0008.074] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.087] Updated bootarg info to DTB
[0008.091] Adding uuid 0000000164460805100000000b0304c0 to DT
[0008.097] Adding eks info 0 to DT
[0008.102] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0008.108] Updated memory info to DTB
[0008.116] set vdd_core voltage to 1075 mv
[0008.120] setting ‘vdd-core’ regulator to 1075000 micro volts
[0008.139] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 1:1…
1: primary kernel
5487776 bytes read in 371 ms (14.1 MiB/s)
Starting kernel …
[ 0.009982] Console: colour dummy device 80x25
[ 0.014642] console [tty0] enabled
[ 0.018156] bootconsole [uart8250] disabled
Did you ever configure your user account on monitor? In your logs, I don’t see any display is connected even you told me you can see the logo.
It never gets past the logo, so I have never been able to setup an account. For this last logs I did not have the monitor hooked up. here it is with it hooked up
[0000.148] pmic max77620 NVERC : 0x40
[0000.620] Csd NumOfBlocks=250085376
[0000.625] Set High speed to 1
[0000.634] Using GPT Primary to query partitions
[0000.639] Loading Tboot-CPU binary
[0000.648] Verifying TBC in OdmNonSecureSBK mode
[0000.659] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.665] Bootloader downloaded successfully.
[0000.670] Downloaded Tboot-CPU binary to 0xa0000258
[0000.675] MAX77620_GPIO5 configured
[0000.678] CPU power rail is up
[0000.681] CPU clock enabled
[0000.685] Performing RAM repair
[0000.688] Updating A64 Warmreset Address to 0xa00002e9
[0000.693] Read GPT from (4:0)
[0000.701] Using GPT Primary to query partitions
[0000.705] Loading NvTbootBootloaderDTB
[0000.730] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.802] Bootloader DTB Load Address: 0x83000000
[0000.807] Read GPT from (4:0)
[0000.815] Using GPT Primary to query partitions
[0000.820] Loading NvTbootKernelDTB
[0000.844] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.916] Kernel DTB Load Address: 0x83100000
[0000.920] Read GPT from (4:0)
[0000.929] Using GPT Primary to query partitions
[0000.934] Loading cboot binary
[0000.963] Verifying EBT in OdmNonSecureSBK mode
[0001.005] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.012] Bootloader downloaded successfully.
[0001.016] Read GPT from (4:0)
[0001.025] Using GPT Primary to query partitions
[0001.029] Read PT from (2:0)
[0001.045] Using BFS PT to query partitions
[0001.049] PT: Partition NCT NOT found !
[0001.053] Warning: Find Partition via PT Failed
[0001.057] Next binary entry address: 0x92c00258
[0001.061] BoardId: 3448
[0001.066] Overriding pmu board id with proc board id
[0001.071] Display board id is not available
[0001.075] Read GPT from (4:0)
[0001.083] Using GPT Primary to query partitions
[0001.112] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.167] /bpmp deleted
[0001.170] SC7EntryFw header found loaded at 0xff700000
[0001.362] OVR2 PMIC
[0001.364] Bpmp FW successfully loaded
[0001.368] Read GPT from (4:0)
[0001.376] Using GPT Primary to query partitions
[0001.381] WB0 init successfully at 0xff780000
[0001.385] Set NvDecSticky Bits
[0001.389] GSC2 address ff53fffc value c0edbbcc
[0001.395] GSC MC Settings done
[0001.398] Read GPT from (4:0)
[0001.406] Using GPT Primary to query partitions
[0001.411] TOS Image length 53680
[0001.414] Monitor size 53680
[0001.417] OS size 0
[0001.424] Secure Os AES-CMAC Verification Success!
[0001.429] TOS image cipher info: plaintext
[0001.433] Loading and Validation of Secure OS Successful
[0001.449] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.453] NvTbootPackSdramParams: start.
[0001.459] NvTbootPackSdramParams: done.
[0001.462] Tegraboot started after 52318 us
[0001.466] Basic modules init took 1061993 us
[0001.470] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.476] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.481] Storage Device Read Time = 122 ms, Read Size = 2359 KB
[0001.487] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.493] Next stage binary read took 24431 us
[0001.497] Carveout took -49150 us
[0001.500] CPU initialization took 408222 us
[0001.504] Total time taken by TegraBoot 1445496 us
[0001.509] Starting CPU & Halting co-processor
[0001.630] RamCode = 1
[0001.632] get_emc_table_offset: Can’t find emc-table node
[0001.637] LPDDR4 Training: Can’t find emc-table node
[0001.685]
[0001.686] Debug Init done
[0001.689] Marked DTB cacheable
[0001.692] Bootloader DTB loaded at 0x83000000
[0001.697] Marked DTB cacheable
[0001.699] Kernel DTB loaded at 0x83100000
[0001.703] DeviceTree Init done
[0001.716] Pinmux applied successfully
[0001.721] gicd_base: 0x50041000
[0001.724] gicc_base: 0x50042000
[0001.727] Interrupts Init done
[0001.731] Using base:0x60005090 & irq:208 for tick-timer
[0001.736] Using base:0x60005098 for delay-timer
[0001.741] platform_init_timer: DONE
[0001.744] Timer(tick) Init done
[0001.748] osc freq = 38400 khz
[0001.752]
[0001.753] Welcome to L4T Cboot
[0001.756]
[0001.757] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.762] calling constructors
[0001.765] initializing heap
[0001.768] initializing threads
[0001.771] initializing timers
[0001.774] creating bootstrap completion thread
[0001.778] top of bootstrap2()
[0001.781] CPU: ARM Cortex A57
[0001.784] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.788] initializing platform
[0001.796] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.800] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.805] Macronix QSPI chip present
[0001.808] SPI device register
[0001.811] init boot device
[0001.814] allocating memory for boot device(SPI)
[0001.818] registering boot device
[0001.828] sdmmc node status = okay
[0001.831] sdcard instance = 0
[0001.834] sdcard gpio handle 0x5b
[0001.837] sdcard gpio pin 0xc9
[0001.840] sdcard gpio flags 0x0
[0001.843] vmmc-supply 0x9e
[0001.846] Instance: 0
[0001.848] Allocating memory for context
[0001.852] enabling clock
[0001.854] sd card init
[0001.856] Check card present and stable
[0001.860] Send command 0
[0001.877] Send command 3
[0001.881] Set RCA for the card
[0001.884] Query card specific data by command 9
[0001.890] Parse CSD data
[0001.893] Send command 7
[0001.903] Calling sd device register
[0001.906] Init sdcard
[0001.909] Allocating memory for boot device
[0001.913] Registering user device
[0001.926] Enable APE clock
[0001.929] Un-powergate APE partition
[0001.932] of_register: registering tegra_udc to of_hal
[0001.937] of_register: registering inv20628-driver to of_hal
[0001.943] of_register: registering ads1015-driver to of_hal
[0001.948] of_register: registering lp8557-bl-driver to of_hal
[0001.954] of_register: registering bq2419x_charger to of_hal
[0001.960] of_register: registering bq27441_fuel_gauge to of_hal
[0001.971] gpio framework initialized
[0001.975] of_register: registering tca9539_gpio to of_hal
[0001.980] of_register: registering tca9539_gpio to of_hal
[0001.985] of_register: registering i2c_bus_driver to of_hal
[0001.991] of_register: registering i2c_bus_driver to of_hal
[0001.997] of_register: registering i2c_bus_driver to of_hal
[0002.002] pmic framework initialized
[0002.006] of_register: registering max77620_pmic to of_hal
[0002.011] regulator framework initialized
[0002.015] of_register: registering tps65132_bl_driver to of_hal
[0002.021] initializing target
[0002.027] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0002.035] board ID = D78, board SKU = 3
[0002.038] Skipping Z3!
[0002.043] fixed regulator driver initialized
[0002.061] initializing OF layer
[0002.064] NCK carveout not present
[0002.067] Skipping dts_overrides
[0002.072] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.089] I2C Bus Init done
[0002.091] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.101] I2C Bus Init done
[0002.104] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.114] I2C Bus Init done
[0002.117] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.143] of_children_init: Ops found for compatible string maxim,max77620
[0002.154] max77620_init using irq 118
[0002.158] register ‘maxim,max77620’ pmic
[0002.163] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.179] I2C Bus Init done
[0002.183] NCK carveout not present
[0002.193] Find /i2c@7000c000’s alias i2c0
[0002.197] get eeprom at 1-a0, size 256, type 0
[0002.205] Find /i2c@7000c500’s alias i2c2
[0002.209] get eeprom at 3-a0, size 256, type 0
[0002.214] get eeprom at 3-ae, size 256, type 0
[0002.218] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.223] I2C slave not started
[0002.226] I2C write failed
[0002.229] Writing offset failed
[0002.232] eeprom_init: EEPROM read failed
[0002.236] pm_ids_update: eeprom init failed
[0002.240] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.270] pm_ids_update: The pm board id is 3448-0003-400
[0002.277] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.286] pm_ids_update: pm id update successful
[0002.290] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.320] pm_ids_update: The pm board id is 3542-0000-201
[0002.326] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.335] pm_ids_update: pm id update successful
[0002.365] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.371] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.379] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.384] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.393] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:9d:4e
[0002.399] Plugin Manager: Parse ODM data 0x00094000
[0002.411] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.426] Find /i2c@7000c000’s alias i2c0
[0002.430] get eeprom at 1-a0, size 256, type 0
[0002.439] Find /i2c@7000c500’s alias i2c2
[0002.443] get eeprom at 3-a0, size 256, type 0
[0002.447] get eeprom at 3-ae, size 256, type 0
[0002.452] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.457] I2C slave not started
[0002.460] I2C write failed
[0002.463] Writing offset failed
[0002.466] eeprom_init: EEPROM read failed
[0002.470] pm_ids_update: eeprom init failed
[0002.474] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.504] pm_ids_update: The pm board id is 3448-0003-400
[0002.510] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.517] pm_ids_update: pm id update successful
[0002.522] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.552] pm_ids_update: The pm board id is 3542-0000-201
[0002.558] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.565] pm_ids_update: pm id update successful
[0002.595] Add serial number:1424120059084 as DT property
[0002.603] Applying platform configs
[0002.610] platform-init is not present. Skipping
[0002.614] calling apps_init()
[0002.639] Found 14 GPT partitions in “sd0”
[0002.643] Proceeding to Cold Boot
[0002.646] starting app android_boot_app
[0002.650] Device state: unlocked
[0002.653] display console init
[0002.662] could not find regulator
[0002.665] hdmi cable connected
[0002.680] edid read success
[0002.697] DT entry for leds-pwm not found
[0002.701] edid read success
[0002.703] width = 640, height = 480, frequency = 25174825
[0002.709] width = 640, height = 480, frequency = 25174825
[0002.714] width = 640, height = 480, frequency = 25174825
[0002.720] width = 1024, height = 768, frequency = 65000000
[0002.725] width = 1808, height = 1080, frequency = 148500000
[0002.731] width = 640, height = 480, frequency = 25174825
[0002.736] width = 720, height = 480, frequency = 26973026
[0002.741] width = 720, height = 480, frequency = 26973026
[0002.747] width = 1280, height = 720, frequency = 74175824
[0002.752] width = 1920, height = 1080, frequency = 148351648
[0002.758] width = 720, height = 576, frequency = 26973026
[0002.763] width = 1280, height = 720, frequency = 74175824
[0002.769] width = 1920, height = 1080, frequency = 148351648
[0002.774] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.782] tmds-config node not found
[0002.786] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.801] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.809] could not find regulator
[0002.812] could not find regulator
[0002.815] could not find regulator
[0002.844] using default cmu settings
[0002.847] dc_hdmi_enable, starting HDMI initialisation
[0002.853] dc_hdmi_enable, HDMI initialisation complete
[0002.858] list and configure display window
[0002.867] display console init completed
[0002.878] subnode volume_up is not found !
[0002.882] subnode back is not found !
[0002.886] subnode volume_down is not found !
[0002.890] subnode menu is not found !
[0002.894] Gpio keyboard init success
[0002.938] found decompressor handler: lz4-legacy
[0002.952] decompressing blob (type 1)…
[0002.987] load_bmp_blob: panelresolution=1080 type=3
[0003.037] decompressor handler not found
[0003.041] load_firmware_blob: Firmware blob loaded, entries=2
[0003.047] -------> se_aes_verify_sbk_clear: 747
[0003.051] se_aes_verify_sbk_clear: Error
[0003.055] bl_battery_charging: connected to external power supply
[0003.062] xusb is supported
[0003.068] error while finding nvidia,portmap
[0003.573] xusb blob version 0 size 124416
[0003.576] firmware size 124416
[0003.581] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.594] xhci0: 64 bytes context size, 32-bit DMA
[0003.634] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.654] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.304] uhub0: 9 ports with 9 removable, self powered
[0005.424] uhub1: <vendor 0x1a40 USB 2.0 Hub, class 9/0, rev 2.00/1.00, addr 1> on usbus0
[0006.204] uhub1: 4 ports with 4 removable, self powered
[0007.594] failed to get HID devices
[0007.597] failed to init xhci or no usb device attached
[0007.607] device_query_partition_size: failed to open partition sd0:MSC !
[0007.614] MSC Partition not found
[0007.620] device_query_partition_size: failed to open partition sd0:USP !
[0007.627] USP partition read failed!
[0007.630] blob_init: blob-partition USP header read failed
[0007.636] android_boot Unable to update recovery partition
[0007.641] kfs_getpartname: name = LNX
[0007.645] Loading kernel from LNX
[0007.744] load kernel from storage
[0007.755] decompressor handler not found
[0007.813] Successfully loaded kernel and ramdisk images
[0007.819] load_bmp_blob: panelresolution=1080 type=3
[0008.308] display bmp image done
[0008.311] NCK carveout not present
[0008.314] Skipping dts_overrides
[0008.318] NCK carveout not present
[0008.327] Find /i2c@7000c000’s alias i2c0
[0008.331] get eeprom at 1-a0, size 256, type 0
[0008.340] Find /i2c@7000c500’s alias i2c2
[0008.344] get eeprom at 3-a0, size 256, type 0
[0008.348] get eeprom at 3-ae, size 256, type 0
[0008.353] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.358] I2C slave not started
[0008.361] I2C write failed
[0008.364] Writing offset failed
[0008.367] eeprom_init: EEPROM read failed
[0008.371] pm_ids_update: eeprom init failed
[0008.375] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.405] pm_ids_update: The pm board id is 3448-0003-400
[0008.412] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0008.420] pm_ids_update: pm id update successful
[0008.425] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.455] pm_ids_update: The pm board id is 3542-0000-201
[0008.461] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0008.469] pm_ids_update: pm id update successful
[0008.499] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.505] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0008.513] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.519] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0008.527] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:9d:4e
[0008.534] Plugin Manager: Parse ODM data 0x00094000
[0008.546] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0008.554] Add serial number:1424120059084 as DT property
[0008.564] “bpmp” doesn’t exist, creating
[0008.569] Updated bpmp info to DTB
[0008.574] Updated initrd info to DTB
[0008.577] “proc-board” doesn’t exist, creating
[0008.583] Updated board info to DTB
[0008.587] “pmu-board” doesn’t exist, creating
[0008.593] Updated board info to DTB
[0008.596] “display-board” doesn’t exist, creating
[0008.602] Updated board info to DTB
[0008.605] “reset” doesn’t exist, creating
[0008.610] Updated reset info to DTB
[0008.613] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0
[0008.652] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0008.658] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.671] Updated bootarg info to DTB
[0008.675] Adding uuid 0000000164460805100000000b0304c0 to DT
[0008.681] Adding eks info 0 to DT
[0008.686] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0008.692] Updated memory info to DTB
[0008.700] set vdd_core voltage to 1075 mv
[0008.704] setting ‘vdd-core’ regulator to 1075000 micro volts
[0008.724] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 1:1…
838 bytes read in 175 ms (3.9 KiB/s)
1: primary kernel
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 de
Starting kernel …
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4263) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEM0
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend
[ 0.000000] early log buf free: 29364(89%)
[ 0.000000] Memory: 1500712K/2062336K available (15294K kernel code, 2936K rwdata, 6644K rodata, 8576K init, 611K bss, 86488K reserved, 475136K cma-reserved)
[ 0.010052] Console: colour dummy device 80x25
[ 0.014708] console [tty0] enabled
[ 0.018219] bootconsole [uart8250] disabled
[0000.709] MAX77620_GPIO5 configured
[0001.497] Tegraboot started after 87457 us
[0001.501] Basic modules init took 1062566 us
[0001.532] Carveout took -49152 us
[0001.535] CPU initialization took 408224 us
[0001.539] Total time taken by TegraBoot 1446068 us
[0001.721]
[0001.788]
[0001.792]
[0001.881] Instance: 0
[0001.948] Registering user device
[0001.978] of_register: registering ads1015-driver to of_hal
[0002.487] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.501] eeprom_init: EEPROM read failed
[0002.701] hdmi cable connected
[0002.716] edid read success
[0002.733] DT entry for leds-pwm not found
[0002.737] edid read success
[0002.739] width = 640, height = 480, frequency = 25174825
[0002.745] width = 640, height = 480, frequency = 25174825
[0002.750] width = 640, height = 480, frequency = 25174825
[0002.755] width = 1024, height = 768, frequency = 65000000
[0002.761] width = 1808, height = 1080, frequency = 148500000
[0002.766] width = 640, height = 480, frequency = 25174825
[0002.772] width = 720, height = 480, frequency = 26973026
[0002.777] width = 720, height = 480, frequency = 26973026
[0002.783] width = 1280, height = 720, frequency = 74175824
[0002.788] width = 1920, height = 1080, frequency = 148351648
[0002.794] width = 720, height = 576, frequency = 26973026
[0002.799] width = 1280, height = 720, frequency = 74175824
[0002.805] width = 1920, height = 1080, frequency = 148351648
[0002.810] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.818] tmds-config node not found
[0002.822] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.837] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.844] could not find regulator
[0002.848] could not find regulator
[0002.851] could not find regulator
[0002.879] using default cmu settings
[0002.883] dc_hdmi_enable, starting HDMI initialisation
[0002.889] dc_hdmi_enable, HDMI initialisation complete
[0002.894] list and configure display window
[0002.903] display console init completed
[0002.914] subnode volume_up is not found !
[0002.918] subnode back is not found !
[0002.922] subnode volume_down is not found !
[0002.926] subnode menu is not found !
[0002.929] Gpio keyboard init success
[0002.973] found decompressor handler: lz4-legacy
[0002.988] decompressing blob (type 1)…
[0003.022] load_bmp_blob: panelresolution=1080 type=3
[0003.073] decompressor handler not found
[0003.077] load_firmware_blob: Firmware blob loaded, entries=2
[0003.083] -------> se_aes_verify_sbk_clear: 747
[0003.087] se_aes_verify_sbk_clear: Error
[0003.091] bl_battery_charging: connected to external power supply
[0003.098] xusb is supported
[0003.104] error while finding nvidia,portmap
[0003.608] xusb blob version 0 size 124416
[0003.612] firmware size 124416
[0003.617] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.629] xhci0: 64 bytes context size, 32-bit DMA
[0003.669] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.689] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.339] uhub0: 9 ports with 9 removable, self powered
[0005.459] uhub1: <vendor 0x1a40 USB 2.0 Hub, class 9/0, rev 2.00/1.00, addr 1> on usbus0
[0006.239] uhub1: 4 ports with 4 removable, self powered
[0007.629] failed to get HID devices
[0007.633] failed to init xhci or no usb device attached
[0007.643] device_query_partition_size: failed to open partition sd0:MSC !
[0007.650] MSC Partition not found
[0007.656] device_query_partition_size: failed to open partition sd0:USP !
[0007.663] USP partition read failed!
[0007.666] blob_init: blob-partition USP header read failed
[0007.672] android_boot Unable to update recovery partition
[0007.677] kfs_getpartname: name = LNX
[0007.681] Loading kernel from LNX
[0007.779] load kernel from storage
[0007.791] decompressor handler not found
[0007.848] Successfully loaded kernel and ramdisk images
[0007.855] load_bmp_blob: panelresolution=1080 type=3
[0008.344] display bmp image done
[0008.347] NCK carveout not present
[0008.350] Skipping dts_overrides
[0008.353] NCK carveout not present
[0008.363] Find /i2c@7000c000’s alias i2c0
[0008.367] get eeprom at 1-a0, size 256, type 0
[0008.376] Find /i2c@7000c500’s alias i2c2
[0008.380] get eeprom at 3-a0, size 256, type 0
[0008.384] get eeprom at 3-ae, size 256, type 0
[0008.388] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.394] I2C slave not started
[0008.397] I2C write failed
[0008.399] Writing offset failed
[0008.402] eeprom_init: EEPROM read failed
[0008.406] pm_ids_update: eeprom init failed
[0008.411] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.441] pm_ids_update: The pm board id is 3448-0003-400
[0008.447] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0008.456] pm_ids_update: pm id update successful
[0008.460] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.490] pm_ids_update: The pm board id is 3542-0000-201
[0008.497] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0008.505] pm_ids_update: pm id update successful
[0008.535] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.541] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0008.549] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.555] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0008.563] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:9d:4e
[0008.570] Plugin Manager: Parse ODM data 0x00094000
[0008.582] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0008.590] Add serial number:1424120059084 as DT property
[0008.599] “bpmp” doesn’t exist, creating
[0008.605] Updated bpmp info to DTB
[0008.610] Updated initrd info to DTB
[0008.613] “proc-board” doesn’t exist, creating
[0008.619] Updated board info to DTB
[0008.623] “pmu-board” doesn’t exist, creating
[0008.629] Updated board info to DTB
[0008.632] “display-board” doesn’t exist, creating
[0008.638] Updated board info to DTB
[0008.641] “reset” doesn’t exist, creating
[0008.646] Updated reset info to DTB
[0008.649] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0
[0008.688] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0008.694] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.707] Updated bootarg info to DTB
[0008.711] Adding uuid 0000000164460805100000000b0304c0 to DT
[0008.717] Adding eks info 0 to DT
[0008.722] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0008.728] Updated memory info to DTB
[0008.736] set vdd_core voltage to 1075 mv
[0008.740] setting ‘vdd-core’ regulator to 1075000 micro volts
[0008.759] Found secure-pmc; disable BPMP
U-Boot 2016.07-g7a7e3f476e (Oct 16 2020 - 12:23:42 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1: primary kernel
Retrieving file: /boot/initrd
Retrieving file: /boot/Image
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 000000008317de85
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f200000
[ 0.000000] OF: fdt: - c0000000 , 3ee00000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.010068] Console: colour dummy device 80x25
[ 0.014722] console [tty0] enabled
[ 0.018234] bootconsole [uart8250] disabled
the board looks to reboot a couple times
Is there any log from uart serial console when device tries to reboot?
I notice something weird from your kernel log.
This is my kernel command line from my board.
nvidia@nvidia-desktop:~$ dmesg |grep “Kernel command line”
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
But this is yours:
How did you set up your nano-2gb? Which image link do you use?
Great point, I have a 4gb nano and I wonder if I got the images messed up. I’m downloading the 2gb file and deleted any others, I’ll image that and then let you know if that it is. Hopefully it is.
4GB Image is not compatible with 2gb device. I think that is the cause.
yes, that was the cause. It boots up correctly now.
I’ll have to remember to keep the 2gb and 4gb files separate, and better worded, so that I don’t have that mix up again.
Thank you for your help!
