Can someone tell me what’s going on with the 2gb nano.
My PS is official pi 4 5.1 3A
It’s just hangs up now. Was working fine pas couple days
Already did a new fresh image install
Much of what is shown is not a problem, e.g., the rate limiting is normal. If you don’t have the imx camera showing i2c failures, then this would not be an error (you’d expect a missing camera to fail). However, if there are i2c fails on a system expected to work, then perhaps the device tree was updated and caused a problem.
The screenshot is not nearly enough to actually know what is happening. If you were to use a serial console, then you could log the entire boot from your host PC and upload the log. See:
https://www.jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
Also, make sure to mention if this is a dev kit or other, and mention what peripherals are attached.
I ran it just pluging in the usb c power and hdmi only. Same errors.
i have a nano 2gb trying to find the documentation for using the microusb to get serial out.
Is there a prebuild image with the latest jetson pack and hello world ai working?
happy to reflash it and avoid the 20min setup to get the detectnet working. Already this this twice. Not gonna keep doing these steps if I can avoid it.
If you are looking for serial for the purpose of serial console, then the micro-B USB would not be correct, there is a different header for serial console. Note that the earliest carrier boards use a header in a different location than those of the newer carrier boards (for serial console). Take a look at the images here:
…the one with the header on the top of the carrier board near the camera end is for earlier boards. The one with the serial console pins being under the module at the edge of the carrier board are what most people have.
What I see visible from your screenshot is “mostly” normal, and there isn’t much of a way to debug further without the serial console log. There is so much more we could know if we had a full serial console boot log.
If you used the 4GB model image instead of the 2GB model image I doubt it would boot that far, but you might double check.
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-c536fca9)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 1
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x31cf
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.205] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.211] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.216] Resize the SecureOs Carveout to 0x00100000
[0000.221] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.227] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.233] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.238] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.244] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.250] Platform-DebugCarveout: 0
[0000.253] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.259] Non secure mode, and RB not enabled.
[0000.264] Read GPT from (4:0)
[0000.422] Csd NumOfBlocks=124735488
[0000.427] Set High speed to 1
[0000.430] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.440] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.447] Number of retries left 4
[0000.462] Using GPT Primary to query partitions
[0000.466] Loading Tboot-CPU binary
[0000.476] Verifying TBC in OdmNonSecureSBK mode
[0000.486] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.493] Bootloader downloaded successfully.
[0000.497] Downloaded Tboot-CPU binary to 0xa0000258
[0000.502] MAX77620_GPIO5 configured
[0000.505] CPU power rail is up
[0000.508] CPU clock enabled
[0000.512] Performing RAM repair
[0000.515] Updating A64 Warmreset Address to 0xa00002e9
[0000.520] Loading NvTbootBootloaderDTB
[0000.544] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.624] Bootloader DTB Load Address: 0x83000000
[0000.629] Loading NvTbootKernelDTB
[0000.653] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.732] Kernel DTB Load Address: 0x83100000
[0000.737] Loading cboot binary
[0000.766] Verifying EBT in OdmNonSecureSBK mode
[0000.808] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.815] Bootloader downloaded successfully.
[0000.819] Read PT from (2:0)
[0000.835] Using BFS PT to query partitions
[0000.839] PT: Partition NCT NOT found !
[0000.842] Warning: Find Partition via PT Failed
[0000.847] Next binary entry address: 0x92c00258
[0000.851] BoardId: 3448
[0000.856] Overriding pmu board id with proc board id
[0000.861] Display board id is not available
[0000.865] No Bpmp FW loaded
[0000.867] Not loading WB0 as no bpmp/sc7entry fw
[0000.872] Set NvDecSticky Bits
[0000.875] GSC2 address ff93fffc value c0edbbcc
[0000.882] GSC MC Settings done
[0000.885] TOS Image length 53680
[0000.888] Monitor size 53680
[0000.891] OS size 0
[0000.898] Secure Os AES-CMAC Verification Success!
[0000.902] TOS image cipher info: plaintext
[0000.906] Loading and Validation of Secure OS Successful
[0000.922] NvTbootPackSdramParams: start.
[0000.927] NvTbootPackSdramParams: done.
[0000.931] Tegraboot started after 52523 us
[0000.935] Basic modules init took 862226 us
[0000.939] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0000.944] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0000.950] Storage Device Read Time = 88 ms, Read Size = 1712 KB
[0000.955] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0000.961] Next stage binary read took 2714 us
[0000.965] Carveout took -42948 us
[0000.968] CPU initialization took 79106 us
[0000.972] Total time taken by TegraBoot 901098 us
[0000.977] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 20:52:47, Oct 27 2020
ERROR: Error initializing runtime service trusty_fast
[0001.098] RamCode = 1
[0001.103] LPDDR4 Training: Read DT: Number of tables = 2
[0001.108] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.121] EMC Training Successful
[0001.124] 408000 not found in DVFS table
[0001.130] RamCode = 1
[0001.134] DT Write: emc-table@204000 succeeded
[0001.139] DT Write: emc-table@1600000 succeeded
[0001.143] LPDDR4 Training: Write DT: Number of tables = 2
[0001.180]
[0001.181] Debug Init done
[0001.183] Marked DTB cacheable
[0001.186] Bootloader DTB loaded at 0x83000000
[0001.191] Marked DTB cacheable
[0001.194] Kernel DTB loaded at 0x83100000
[0001.198] DeviceTree Init done
[0001.211] Pinmux applied successfully
[0001.215] gicd_base: 0x50041000
[0001.219] gicc_base: 0x50042000
[0001.222] Interrupts Init done
[0001.226] Using base:0x60005090 & irq:208 for tick-timer
[0001.231] Using base:0x60005098 for delay-timer
[0001.235] platform_init_timer: DONE
[0001.239] Timer(tick) Init done
[0001.243] osc freq = 38400 khz
[0001.247]
[0001.248] Welcome to L4T Cboot
[0001.251]
[0001.252] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.257] calling constructors
[0001.260] initializing heap
[0001.262] initializing threads
[0001.265] initializing timers
[0001.268] creating bootstrap completion thread
[0001.273] top of bootstrap2()
[0001.275] CPU: ARM Cortex A57
[0001.278] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.283] initializing platform
[0001.291] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.295] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.300] Macronix QSPI chip present
[0001.303] SPI device register
[0001.306] init boot device
[0001.309] allocating memory for boot device(SPI)
[0001.313] registering boot device
[0001.332] sdmmc node status = okay
[0001.336] sdcard instance = 0
[0001.339] sdcard gpio handle 0x5a
[0001.342] sdcard gpio pin 0xc9
[0001.345] sdcard gpio flags 0x0
[0001.348] vmmc-supply 0x9d
[0001.350] Instance: 0
[0001.353] Allocating memory for context
[0001.356] enabling clock
[0001.359] sd card init
[0001.361] Check card present and stable
[0001.365] Send command 0
[0001.389] Send command 3
[0001.394] Set RCA for the card
[0001.396] Query card specific data by command 9
[0001.403] Parse CSD data
[0001.405] Send command 7
[0001.416] Calling sd device register
[0001.419] Init sdcard
[0001.421] Allocating memory for boot device
[0001.425] Registering user device
[0001.439] Enable APE clock
[0001.441] Un-powergate APE partition
[0001.445] of_register: registering tegra_udc to of_hal
[0001.450] of_register: registering inv20628-driver to of_hal
[0001.455] of_register: registering ads1015-driver to of_hal
[0001.461] of_register: registering lp8557-bl-driver to of_hal
[0001.467] of_register: registering bq2419x_charger to of_hal
[0001.472] of_register: registering bq27441_fuel_gauge to of_hal
[0001.484] gpio framework initialized
[0001.487] of_register: registering tca9539_gpio to of_hal
[0001.493] of_register: registering tca9539_gpio to of_hal
[0001.498] of_register: registering i2c_bus_driver to of_hal
[0001.504] of_register: registering i2c_bus_driver to of_hal
[0001.509] of_register: registering i2c_bus_driver to of_hal
[0001.515] pmic framework initialized
[0001.518] of_register: registering max77620_pmic to of_hal
[0001.524] regulator framework initialized
[0001.528] of_register: registering tps65132_bl_driver to of_hal
[0001.534] initializing target
[0001.539] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.547] board ID = D78, board SKU = 3
[0001.551] Skipping Z3!
[0001.556] fixed regulator driver initialized
[0001.575] initializing OF layer
[0001.578] NCK carveout not present
[0001.581] Skipping dts_overrides
[0001.585] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.603] I2C Bus Init done
[0001.605] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.615] I2C Bus Init done
[0001.618] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.629] I2C Bus Init done
[0001.631] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.642] I2C Bus Init done
[0001.644] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.655] I2C Bus Init done
[0001.657] of_children_init: Ops found for compatible string maxim,max77620
[0001.668] max77620_init using irq 118
[0001.672] register ‘maxim,max77620’ pmic
[0001.677] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.683] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.694] I2C Bus Init done
[0001.697] NCK carveout not present
[0001.707] Find /i2c@7000c000’s alias i2c0
[0001.711] get eeprom at 1-a0, size 256, type 0
[0001.720] Find /i2c@7000c500’s alias i2c2
[0001.724] get eeprom at 3-a0, size 256, type 0
[0001.728] get eeprom at 3-ae, size 256, type 0
[0001.732] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.738] I2C slave not started
[0001.741] I2C write failed
[0001.743] Writing offset failed
[0001.746] eeprom_init: EEPROM read failed
[0001.750] pm_ids_update: eeprom init failed
[0001.754] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.784] pm_ids_update: The pm board id is 3448-0003-400
[0001.791] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.800] pm_ids_update: pm id update successful
[0001.805] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.835] pm_ids_update: The pm board id is 3542-0000-201
[0001.841] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0001.849] pm_ids_update: pm id update successful
[0001.880] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.885] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.893] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.899] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.908] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:02:df
[0001.914] Plugin Manager: Parse ODM data 0x00094000
[0001.927] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0001.942] Find /i2c@7000c000’s alias i2c0
[0001.946] get eeprom at 1-a0, size 256, type 0
[0001.955] Find /i2c@7000c500’s alias i2c2
[0001.959] get eeprom at 3-a0, size 256, type 0
[0001.963] get eeprom at 3-ae, size 256, type 0
[0001.967] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.973] I2C slave not started
[0001.976] I2C write failed
[0001.978] Writing offset failed
[0001.981] eeprom_init: EEPROM read failed
[0001.985] pm_ids_update: eeprom init failed
[0001.989] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.020] pm_ids_update: The pm board id is 3448-0003-400
[0002.026] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.033] pm_ids_update: pm id update successful
[0002.037] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.067] pm_ids_update: The pm board id is 3542-0000-201
[0002.074] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.081] pm_ids_update: pm id update successful
[0002.111] Add serial number:1424120112662 as DT property
[0002.119] Applying platform configs
[0002.126] platform-init is not present. Skipping
[0002.130] calling apps_init()
[0002.155] Found 14 GPT partitions in “sd0”
[0002.159] Proceeding to Cold Boot
[0002.162] starting app android_boot_app
[0002.166] Device state: unlocked
[0002.169] display console init
[0002.178] could not find regulator
[0002.181] hdmi cable connected
[0002.196] edid read success
[0002.212] DT entry for leds-pwm not found
[0002.216] edid read success
[0002.218] width = 640, height = 480, frequency = 25174825
[0002.224] width = 640, height = 480, frequency = 25174825
[0002.229] width = 640, height = 480, frequency = 25174825
[0002.235] width = 1920, height = 1080, frequency = 148500000
[0002.240] width = 1920, height = 1080, frequency = 148500000
[0002.246] width = 1920, height = 1080, frequency = 148351648
[0002.252] width = 640, height = 480, frequency = 25174825
[0002.257] width = 720, height = 480, frequency = 26973026
[0002.262] width = 720, height = 480, frequency = 26973026
[0002.268] width = 1280, height = 720, frequency = 74175824
[0002.273] width = 720, height = 576, frequency = 26973026
[0002.278] width = 1280, height = 720, frequency = 74175824
[0002.284] width = 1920, height = 1080, frequency = 148351648
[0002.290] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.297] tmds-config node not found
[0002.301] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.316] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.324] could not find regulator
[0002.327] could not find regulator
[0002.330] could not find regulator
[0002.359] using default cmu settings
[0002.362] dc_hdmi_enable, starting HDMI initialisation
[0002.368] dc_hdmi_enable, HDMI initialisation complete
[0002.373] list and configure display window
[0002.382] display console init completed
[0002.393] subnode volume_up is not found !
[0002.397] subnode back is not found !
[0002.401] subnode volume_down is not found !
[0002.405] subnode menu is not found !
[0002.409] Gpio keyboard init success
[0002.453] found decompressor handler: lz4-legacy
[0002.467] decompressing blob (type 1)…
[0002.502] load_bmp_blob: panelresolution=1080 type=3
[0002.553] decompressor handler not found
[0002.557] load_firmware_blob: Firmware blob loaded, entries=2
[0002.562] -------> se_aes_verify_sbk_clear: 747
[0002.567] se_aes_verify_sbk_clear: Error
[0002.571] bl_battery_charging: connected to external power supply
[0002.578] xusb is supported
[0002.584] error while finding nvidia,portmap
[0003.088] xusb blob version 0 size 124416
[0003.092] firmware size 124416
[0003.096] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.108] xhci0: 64 bytes context size, 32-bit DMA
[0003.148] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.168] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.818] uhub0: 9 ports with 9 removable, self powered
[0004.938] uhub1: <vendor 0x1a40 USB 2.0 Hub, class 9/0, rev 2.00/1.00, addr 1> on usbus0
[0005.718] uhub1: 4 ports with 4 removable, self powered
[0007.108] failed to get HID devices
[0007.111] failed to init xhci or no usb device attached
[0007.122] device_query_partition_size: failed to open partition sd0:MSC !
[0007.129] MSC Partition not found
[0007.135] device_query_partition_size: failed to open partition sd0:USP !
[0007.142] USP partition read failed!
[0007.145] blob_init: blob-partition USP header read failed
[0007.151] android_boot Unable to update recovery partition
[0007.156] kfs_getpartname: name = LNX
[0007.160] Loading kernel from LNX
[0007.258] load kernel from storage
[0007.270] decompressor handler not found
[0007.327] Successfully loaded kernel and ramdisk images
[0007.333] load_bmp_blob: panelresolution=1080 type=3
[0007.817] display bmp image done
[0007.820] NCK carveout not present
[0007.823] Skipping dts_overrides
[0007.826] NCK carveout not present
[0007.836] Find /i2c@7000c000’s alias i2c0
[0007.840] get eeprom at 1-a0, size 256, type 0
[0007.849] Find /i2c@7000c500’s alias i2c2
[0007.853] get eeprom at 3-a0, size 256, type 0
[0007.857] get eeprom at 3-ae, size 256, type 0
[0007.862] pm_ids_update: Updating 1,a0, size 256, type 0
[0007.867] I2C slave not started
[0007.870] I2C write failed
[0007.873] Writing offset failed
[0007.876] eeprom_init: EEPROM read failed
[0007.880] pm_ids_update: eeprom init failed
[0007.884] pm_ids_update: Updating 3,a0, size 256, type 0
[0007.914] pm_ids_update: The pm board id is 3448-0003-400
[0007.921] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0007.930] pm_ids_update: pm id update successful
[0007.934] pm_ids_update: Updating 3,ae, size 256, type 0
[0007.964] pm_ids_update: The pm board id is 3542-0000-201
[0007.970] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0007.979] pm_ids_update: pm id update successful
[0008.009] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.015] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0008.023] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.029] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0008.037] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:02:df
[0008.043] Plugin Manager: Parse ODM data 0x00094000
[0008.056] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0008.065] Add serial number:1424120112662 as DT property
[0008.073] Updated bpmp info to DTB
[0008.078] Updated initrd info to DTB
[0008.081] “proc-board” doesn’t exist, creating
[0008.087] Updated board info to DTB
[0008.091] “pmu-board” doesn’t exist, creating
[0008.097] Updated board info to DTB
[0008.100] “display-board” doesn’t exist, creating
[0008.106] Updated board info to DTB
[0008.110] “reset” doesn’t exist, creating
[0008.114] Updated reset info to DTB
[0008.118] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1
[0008.154] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0008.160] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.173] Updated bootarg info to DTB
[0008.177] Adding uuid 000000016450b700100000000e008440 to DT
[0008.183] Adding eks info 0 to DT
[0008.189] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0008.195] Updated memory info to DTB
[0008.203] set vdd_core voltage to 1125 mv
[0008.206] setting ‘vdd-core’ regulator to 1125000 micro volts
[0008.228] Found secure-pmc; disable BPMP
U-Boot 2016.07-g7a7e3f476e (Oct 27 2020 - 20:52:33 -0700)
TEGRA210
Model: NVIDIA P3541-0000
Board: NVIDIA P3541-0000
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
844 bytes read in 137 ms (5.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487776 bytes read in 401 ms (13.1 MiB/s)
Retrieving file: /boot/Image
34332680 bytes read in 1529 ms (21.4 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 000000008318432f
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-4428) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Oct 27 21:02:37 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f800000
[ 0.000000] OF: fdt: - bfa00000 , 3fe00000
[ 0.000000] OF: fdt: - ffa00000 , 600000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.218521] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.218549] imx219 6-0010: board setup failed
[ 2.082664] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.928638] random: crng init done
[ 3.932072] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.009167] using random self ethernet address
[ 4.014908] using random host ethernet address
[ 4.213983] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[ 4.221777] tegra_cec 70015000.tegra_cec: Sent res: -62.
[ 4.229114] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 5.206785] using random self ethernet address
[ 5.224911] using random host ethernet address
Ubuntu 18.04.5 LTS test-desktop ttyS0
test-desktop login: test
Password:
Last login: Sat Dec 5 15:47:57 EST 2020 on ttyS0
Welcome to Ubuntu 18.04.5 LTS (GNU/Linux 4.9.140-tegra aarch64)
To restore this content, you can run the ‘unminimize’ command.
4 packages can be updated.
1 update is a security update.
test@test-desktop:~$
@linuxdev sorry had to find a ttl usb cable.
Ok this is strage it booted headless on its own? I am able to interact with the nano using serial console.
Any idea why it went into this mode?
Also is there a better way to post log so its formmated nicely?
did a ‘sudo reboot’ from serial console and this was the second log
it took a while at
‘setting vdd-core regulator to 11525000 micro volts’
and stopping at
‘usb usb1-port3: unable to enumerate USB device’
But when I press enter, it goes to the Ubuntu command login. Nothing on the hdmi monitor other than initial nvidia logo
Able to access hello AI folder and even run detectnet to a rtp server working but all headless using serial console only. the detectnet stream not showing up at the jetson hdmi output.
swapping usbcam shows it fails to create videoSource device but booting with it connected seems to work
[ 1715.958019] uvcvideo 1-3.2:1.2: Enti!
[ 1715.966033] uvcvideo 1-3.2:1.2: Entity type for entity Processing 2 was not initialized!
[ 1715.974214] uvcvideo 1-3.2:1.2: Entity type for entity Camera 1 was not initialized!
[ 1715.981974] uvcvideo 1-3.2:1.2: Entity type for entity Extension 5 was not initialized!
[ 1715.990058] uvcvideo 1-3.2:1.2: Entity type for entity Extension 6 was not initialized!
[ 1715.998091] uvcvideo 1-3.2:1.2: Entity type for entity Extension 7 was not initialized!
[ 1716.006173] uvcvideo 1-3.2:1.2: Entity type for entity Extension 8 was not initialized!
serial console log of reboot
test@test-desktop:~ Luname -a
Linux test-desktop 4.9.140-tegra #1 SMP PREEMPT Tue Oct 27 21:02:37 PDT 2020 aarch64 aarch64 aarch64 GNU/Linux
test@test-desktop:~ reboot
Failed to set wall message, ignoring: Interactive authentication required.
Failed to reboot system via logind: Interactive authentication required.
Failed to open /dev/initctl: Permission denied
Failed to talk to init daemon.
test@test-desktop:~$ sudo reboot
[sudo] password for test:
[ 655.477879] watchdog: watchdog0: watchdog did not stop!
[ 655.489038] systemd-shutdow: 39 output lines suppressed due to ratelimiting
[ 655.725041] tegra-xusb 70090000.xusb: Host not halted after 16000 microseconds.
[ 655.750009] reboot: Restarting system
[0000.159] [L4T TegraBoot] (version 00.00.2018.01-l4t-c536fca9)
[0000.165] Processing in cold boot mode Bootloader 2
[0000.170] A02 Bootrom Patch rev = 1023
[0000.173] Power-up reason: software reset
[0000.177] No Battery Present
[0000.179] pmic max77620 reset reason
[0000.183] pmic max77620 NVERC : 0x0
[0000.186] RamCode = 1
[0000.188] Platform has DDR4 type RAM
[0000.192] max77620 disabling SD1 Remote Sense
[0000.196] Setting DDR voltage to 1125mv
[0000.200] Serial Number of Pmic Max77663: 0x31cf
[0000.207] Entering ramdump check
[0000.210] Get RamDumpCarveOut = 0x0
[0000.214] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.219] Last reboot was clean, booting normally!
[0000.223] Sdram initialization is successful
[0000.227] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.234] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.239] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.245] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.251] Resize the SecureOs Carveout to 0x00100000
[0000.256] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.262] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.267] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.273] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.279] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.285] Platform-DebugCarveout: 0
[0000.288] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.294] Non secure mode, and RB not enabled.
[0000.298] Read GPT from (4:0)
[0000.479] Csd NumOfBlocks=124735488
[0000.484] Set High speed to 1
[0000.487] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.498] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.504] Number of retries left 4
[0000.513] Using GPT Primary to query partitions
[0000.518] Loading Tboot-CPU binary
[0000.527] Verifying TBC in OdmNonSecureSBK mode
[0000.537] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.544] Bootloader downloaded successfully.
[0000.548] Downloaded Tboot-CPU binary to 0xa0000258
[0000.553] MAX77620_GPIO5 configured
[0000.557] CPU power rail is up
[0000.559] CPU clock enabled
[0000.563] Performing RAM repair
[0000.566] Updating A64 Warmreset Address to 0xa00002e9
[0000.571] Loading NvTbootBootloaderDTB
[0000.596] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.675] Bootloader DTB Load Address: 0x83000000
[0000.680] Loading NvTbootKernelDTB
[0000.704] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.783] Kernel DTB Load Address: 0x83100000
[0000.788] Loading cboot binary
[0000.818] Verifying EBT in OdmNonSecureSBK mode
[0000.859] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.866] Bootloader downloaded successfully.
[0000.871] Read PT from (2:0)
[0000.886] Using BFS PT to query partitions
[0000.890] PT: Partition NCT NOT found !
[0000.894] Warning: Find Partition via PT Failed
[0000.898] Next binary entry address: 0x92c00258
[0000.903] BoardId: 3448
[0000.907] Overriding pmu board id with proc board id
[0000.912] Display board id is not available
[0000.916] No Bpmp FW loaded
[0000.919] Not loading WB0 as no bpmp/sc7entry fw
[0000.923] Set NvDecSticky Bits
[0000.927] GSC2 address ff93fffc value c0edbbcc
[0000.933] GSC MC Settings done
[0000.936] TOS Image length 53680
[0000.939] Monitor size 53680
[0000.942] OS size 0
[0000.949] Secure Os AES-CMAC Verification Success!
[0000.954] TOS image cipher info: plaintext
[0000.957] Loading and Validation of Secure OS Successful
[0000.973] NvTbootPackSdramParams: start.
[0000.978] NvTbootPackSdramParams: done.
[0000.982] Tegraboot started after 87474 us
[0000.986] Basic modules init took 879898 us
[0000.990] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0000.996] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.001] Storage Device Read Time = 82 ms, Read Size = 1712 KB
[0001.007] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.012] Next stage binary read took 2716 us
[0001.016] Carveout took -42950 us
[0001.020] CPU initialization took 79094 us
[0001.024] Total time taken by TegraBoot 918758 us
[0001.028] Starting CPU & Halting co-processor
[0001.150] RamCode = 1
[0001.154] LPDDR4 Training: Read DT: Number of tables = 2
[0001.159] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.172] EMC Training Successful
[0001.175] 408000 not found in DVFS table
[0001.182] RamCode = 1
[0001.185] DT Write: emc-table@204000 succeeded
[0001.191] DT Write: emc-table@1600000 succeeded
[0001.195] LPDDR4 Training: Write DT: Number of tables = 2
[0001.232]
[0001.234] Debug Init done
[0001.236] Marked DTB cacheable
[0001.239] Bootloader DTB loaded at 0x83000000
[0001.244] Marked DTB cacheable
[0001.247] Kernel DTB loaded at 0x83100000
[0001.251] DeviceTree Init done
[0001.263] Pinmux applied successfully
[0001.268] gicd_base: 0x50041000
[0001.271] gicc_base: 0x50042000
[0001.274] Interrupts Init done
[0001.278] Using base:0x60005090 & irq:208 for tick-timer
[0001.284] Using base:0x60005098 for delay-timer
[0001.288] platform_init_timer: DONE
[0001.292] Timer(tick) Init done
[0001.295] osc freq = 38400 khz
[0001.299]
[0001.300] Welcome to L4T Cboot
[0001.303]
[0001.304] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.309] calling constructors
[0001.312] initializing heap
[0001.315] initializing threads
[0001.318] initializing timers
[0001.321] creating bootstrap completion thread
[0001.325] top of bootstrap2()
[0001.328] CPU: ARM Cortex A57
[0001.331] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.336] initializing platform
[0001.343] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.348] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.352] Macronix QSPI chip present
[0001.356] SPI device register
[0001.359] init boot device
[0001.361] allocating memory for boot device(SPI)
[0001.366] registering boot device
[0001.380] sdmmc node status = okay
[0001.383] sdcard instance = 0
[0001.386] sdcard gpio handle 0x5a
[0001.389] sdcard gpio pin 0xc9
[0001.392] sdcard gpio flags 0x0
[0001.395] vmmc-supply 0x9d
[0001.398] Instance: 0
[0001.400] Allocating memory for context
[0001.404] enabling clock
[0001.406] sd card init
[0001.409] Check card present and stable
[0001.412] Send command 0
[0001.437] Send command 3
[0001.441] Set RCA for the card
[0001.444] Query card specific data by command 9
[0001.451] Parse CSD data
[0001.453] Send command 7
[0001.463] Calling sd device register
[0001.467] Init sdcard
[0001.469] Allocating memory for boot device
[0001.473] Registering user device
[0001.486] Enable APE clock
[0001.489] Un-powergate APE partition
[0001.492] of_register: registering tegra_udc to of_hal
[0001.497] of_register: registering inv20628-driver to of_hal
[0001.503] of_register: registering ads1015-driver to of_hal
[0001.509] of_register: registering lp8557-bl-driver to of_hal
[0001.514] of_register: registering bq2419x_charger to of_hal
[0001.520] of_register: registering bq27441_fuel_gauge to of_hal
[0001.532] gpio framework initialized
[0001.535] of_register: registering tca9539_gpio to of_hal
[0001.540] of_register: registering tca9539_gpio to of_hal
[0001.546] of_register: registering i2c_bus_driver to of_hal
[0001.551] of_register: registering i2c_bus_driver to of_hal
[0001.557] of_register: registering i2c_bus_driver to of_hal
[0001.562] pmic framework initialized
[0001.566] of_register: registering max77620_pmic to of_hal
[0001.571] regulator framework initialized
[0001.575] of_register: registering tps65132_bl_driver to of_hal
[0001.581] initializing target
[0001.587] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.595] board ID = D78, board SKU = 3
[0001.599] Skipping Z3!
[0001.604] fixed regulator driver initialized
[0001.623] initializing OF layer
[0001.625] NCK carveout not present
[0001.629] Skipping dts_overrides
[0001.633] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.650] I2C Bus Init done
[0001.653] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.663] I2C Bus Init done
[0001.666] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.676] I2C Bus Init done
[0001.679] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.689] I2C Bus Init done
[0001.692] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.702] I2C Bus Init done
[0001.705] of_children_init: Ops found for compatible string maxim,max77620
[0001.715] max77620_init using irq 118
[0001.720] register ‘maxim,max77620’ pmic
[0001.724] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.731] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.741] I2C Bus Init done
[0001.745] NCK carveout not present
[0001.754] Find /i2c@7000c000’s alias i2c0
[0001.758] get eeprom at 1-a0, size 256, type 0
[0001.767] Find /i2c@7000c500’s alias i2c2
[0001.771] get eeprom at 3-a0, size 256, type 0
[0001.775] get eeprom at 3-ae, size 256, type 0
[0001.780] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.785] I2C slave not started
[0001.788] I2C write failed
[0001.791] Writing offset failed
[0001.794] eeprom_init: EEPROM read failed
[0001.798] pm_ids_update: eeprom init failed
[0001.802] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.832] pm_ids_update: The pm board id is 3448-0003-400
[0001.839] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.848] pm_ids_update: pm id update successful
[0001.852] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.882] pm_ids_update: The pm board id is 3542-0000-201
[0001.889] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0001.897] pm_ids_update: pm id update successful
[0001.927] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.933] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.941] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.947] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.955] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:02:df
[0001.961] Plugin Manager: Parse ODM data 0x00094000
[0001.975] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0001.989] Find /i2c@7000c000’s alias i2c0
[0001.993] get eeprom at 1-a0, size 256, type 0
[0002.002] Find /i2c@7000c500’s alias i2c2
[0002.006] get eeprom at 3-a0, size 256, type 0
[0002.011] get eeprom at 3-ae, size 256, type 0
[0002.015] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.020] I2C slave not started
[0002.023] I2C write failed
[0002.026] Writing offset failed
[0002.029] eeprom_init: EEPROM read failed
[0002.033] pm_ids_update: eeprom init failed
[0002.037] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.067] pm_ids_update: The pm board id is 3448-0003-400
[0002.073] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.080] pm_ids_update: pm id update successful
[0002.085] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.115] pm_ids_update: The pm board id is 3542-0000-201
[0002.121] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.128] pm_ids_update: pm id update successful
[0002.158] Add serial number:1424120112662 as DT property
[0002.166] Applying platform configs
[0002.173] platform-init is not present. Skipping
[0002.178] calling apps_init()
[0002.203] Found 14 GPT partitions in “sd0”
[0002.207] Proceeding to Cold Boot
[0002.210] starting app android_boot_app
[0002.214] Device state: unlocked
[0002.217] display console init
[0002.225] could not find regulator
[0002.228] hdmi cable connected
[0002.244] edid read success
[0002.259] edid reaDT entry for leds-pwm not found
d[0002.267] success
[0002.269] width = 640, height = 480, frequency = 25174825
[0002.274] width = 640, height = 480, frequency = 25174825
[0002.280] width = 640, height = 480, frequency = 25174825
[0002.285] width = 1920, height = 1080, frequency = 148500000
[0002.291] width = 1920, height = 1080, frequency = 148500000
[0002.296] width = 1920, height = 1080, frequency = 148351648
[0002.302] width = 640, height = 480, frequency = 25174825
[0002.308] width = 720, height = 480, frequency = 26973026
[0002.313] width = 720, height = 480, frequency = 26973026
[0002.318] width = 1280, height = 720, frequency = 74175824
[0002.324] width = 720, height = 576, frequency = 26973026
[0002.329] width = 1280, height = 720, frequency = 74175824
[0002.335] width = 1920, height = 1080, frequency = 148351648
[0002.340] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.348] tmds-config node not found
[0002.352] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.367] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.374] could not find regulator
[0002.378] could not find regulator
[0002.381] could not find regulator
[0002.409] using default cmu settings
[0002.413] dc_hdmi_enable, starting HDMI initialisation
[0002.419] dc_hdmi_enable, HDMI initialisation complete
[0002.424] list and configure display window
[0002.433] display console init completed
[0002.444] subnode volume_up is not found !
[0002.448] subnode back is not found !
[0002.452] subnode volume_down is not found !
[0002.456] subnode menu is not found !
[0002.459] Gpio keyboard init success
[0002.503] found decompressor handler: lz4-legacy
[0002.518] decompressing blob (type 1)…
[0002.552] load_bmp_blob: panelresolution=1080 type=3
[0002.603] decompressor handler not found
[0002.607] load_firmware_blob: Firmware blob loaded, entries=2
[0002.612] -------> se_aes_verify_sbk_clear: 747
[0002.617] se_aes_verify_sbk_clear: Error
[0002.621] bl_battery_charging: connected to external power supply
[0002.628] xusb is supported
[0002.634] error while finding nvidia,portmap
[0003.138] xusb blob version 0 size 124416
[0003.142] firmware size 124416
[0003.147] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.161] xhci0: 64 bytes context size, 32-bit DMA
[0003.201] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.221] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.871] uhub0: 9 ports with 9 removable, self powered
[0004.991] uhub1: <vendor 0x1a40 USB 2.0 Hub, class 9/0, rev 2.00/1.00, addr 1> on usbus0
[0005.771] uhub1: 4 ports with 4 removable, self powered
[0007.161] failed to get HID devices
[0007.164] failed to init xhci or no usb device attached
[0007.174] device_query_partition_size: failed to open partition sd0:MSC !
[0007.181] MSC Partition not found
[0007.187] device_query_partition_size: failed to open partition sd0:USP !
[0007.194] USP partition read failed!
[0007.198] blob_init: blob-partition USP header read failed
[0007.203] android_boot Unable to update recovery partition
[0007.209] kfs_getpartname: name = LNX
[0007.212] Loading kernel from LNX
[0007.311] load kernel from storage
[0007.322] decompressor handler not found
[0007.379] Successfully loaded kernel and ramdisk images
[0007.385] load_bmp_blob: panelresolution=1080 type=3
[0007.869] display bmp image done
[0007.872] NCK carveout not present
[0007.876] Skipping dts_overrides
[0007.879] NCK carveout not present
[0007.889] Find /i2c@7000c000’s alias i2c0
[0007.893] get eeprom at 1-a0, size 256, type 0
[0007.901] Find /i2c@7000c500’s alias i2c2
[0007.905] get eeprom at 3-a0, size 256, type 0
[0007.910] get eeprom at 3-ae, size 256, type 0
[0007.914] pm_ids_update: Updating 1,a0, size 256, type 0
[0007.919] I2C slave not started
[0007.922] I2C write failed
[0007.925] Writing offset failed
[0007.928] eeprom_init: EEPROM read failed
[0007.932] pm_ids_update: eeprom init failed
[0007.936] pm_ids_update: Updating 3,a0, size 256, type 0
[0007.966] pm_ids_update: The pm board id is 3448-0003-400
[0007.973] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0007.982] pm_ids_update: pm id update successful
[0007.987] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.017] pm_ids_update: The pm board id is 3542-0000-201
[0008.023] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0008.031] pm_ids_update: pm id update successful
[0008.061] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.067] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0008.075] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.081] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0008.089] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:02:df
[0008.096] Plugin Manager: Parse ODM data 0x00094000
[0008.109] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0008.117] Add serial number:1424120112662 as DT property
[0008.125] Updated bpmp info to DTB
[0008.130] Updated initrd info to DTB
[0008.134] “proc-board” doesn’t exist, creating
[0008.140] Updated board info to DTB
[0008.143] “pmu-board” doesn’t exist, creating
[0008.149] Updated board info to DTB
[0008.153] “display-board” doesn’t exist, creating
[0008.159] Updated board info to DTB
[0008.162] “reset” doesn’t exist, creating
[0008.167] Updated reset info to DTB
[0008.170] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1
[0008.207] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0008.212] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.226] Updated bootarg info to DTB
[0008.230] Adding uuid 000000016450b700100000000e008440 to DT
[0008.236] Adding eks info 0 to DT
[0008.241] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0008.247] Updated memory info to DTB
[0008.255] set vdd_core voltage to 1125 mv
[0008.259] setting ‘vdd-core’ regulator to 1125000 micro volts
[0008.281] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 1:1…
844 bytes read in 138 ms (5.9 KiB/s)
1: primary kernel
5487776 bytes read in 403 ms (13 MiB/s)
34332680 bytes read in 1528 ms (21.4 MiB/s)
Starting kernel …
[ 1.227529] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.227556] imx219 6-0010: board setup failed
[ 1.960583] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.725377] random: crng init done
[ 3.728810] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.214754] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[ 4.214759] tegra_cec 70015000.tegra_cec: Sent res: -62.
[ 4.214762] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 4.360666] using random self ethernet address
[ 4.368018] using random host ethernet address
[ 5.275730] using random self ethernet address
[ 5.286760] using random host ethernet address
test-desktop login: test11
Password:
test-desktop login: e test
Password:
Last login: Sat Dec 5 15:47:49 EST 2020 on ttyS0
test@test-desktop:~$ [0000.143] [L4T TegraBoot] (version 00.00.2018.01-l4t-c536fca9)
[0000.148] Processing in cold boot mode Bootloader 2
[0000.153] A02 Bootrom Patch rev = 1023
[0000.156] Power-up reason: pmc por
[0000.159] No Battery Present
[0000.162] pmic max77620 reset reason
[0000.165] pmic max77620 NVERC : 0x40
[0000.169] RamCode = 1
[0000.171] Platform has DDR4 type RAM
[0000.174] max77620 disabling SD1 Remote Sense
[0000.179] Setting DDR voltage to 1125mv
[0000.183] Serial Number of Pmic Max77663: 0x31cf
[0000.190] Entering ramdump check
[0000.193] Get RamDumpCarveOut = 0x0
[0000.196] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.201] Last reboot was clean, booting normally!
[0000.206] Sdram initialization is successful
[0000.210] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.216] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.222] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.228] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.234] Resize the SecureOs Carveout to 0x00100000
[0000.238] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.244] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.250] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.256] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.262] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.268] Platform-DebugCarveout: 0
[0000.271] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.276] Non secure mode, and RB not enabled.
[0000.281] Read GPT from (4:0)
[0000.455] Csd NumOfBlocks=124735488
[0000.460] Set High speed to 1
[0000.463] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.474] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.480] Number of retries left 4
[0000.489] Using GPT Primary to query partitions
[0000.494] Loading Tboot-CPU binary
[0000.503] Verifying TBC in OdmNonSecureSBK mode
[0000.513] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.520] Bootloader downloaded successfully.
[0000.525] Downloaded Tboot-CPU binary to 0xa0000258
[0000.530] MAX77620_GPIO5 configured
[0000.533] CPU power rail is up
[0000.536] CPU clock enabled
[0000.539] Performing RAM repair
[0000.542] Updating A64 Warmreset Address to 0xa00002e9
[0000.547] Loading NvTbootBootloaderDTB
[0000.572] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.651] Bootloader DTB Load Address: 0x83000000
[0000.656] Loading NvTbootKernelDTB
[0000.680] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.760] Kernel DTB Load Address: 0x83100000
[0000.764] Loading cboot binary
[0000.794] Verifying EBT in OdmNonSecureSBK mode
[0000.835] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.842] Bootloader downloaded successfully.
[0000.847] Read PT from (2:0)
[0000.862] Using BFS PT to query partitions
[0000.866] PT: Partition NCT NOT found !
[0000.870] Warning: Find Partition via PT Failed
[0000.874] Next binary entry address: 0x92c00258
[0000.879] BoardId: 3448
[0000.883] Overriding pmu board id with proc board id
[0000.888] Display board id is not available
[0000.892] No Bpmp FW loaded
[0000.895] Not loading WB0 as no bpmp/sc7entry fw
[0000.899] Set NvDecSticky Bits
[0000.903] GSC2 address ff93fffc value c0edbbcc
[0000.909] GSC MC Settings done
[0000.913] TOS Image length 53680
[0000.916] Monitor size 53680
[0000.918] OS size 0
[0000.925] Secure Os AES-CMAC Verification Success!
[0000.930] TOS image cipher info: plaintext
[0000.934] Loading and Validation of Secure OS Successful
[0000.950] NvTbootPackSdramParams: start.
[0000.955] NvTbootPackSdramParams: done.
[0000.958] Tegraboot started after 70228 us
[0000.962] Basic modules init took 872783 us
[0000.966] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0000.972] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0000.977] Storage Device Read Time = 82 ms, Read Size = 1712 KB
[0000.983] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0000.989] Next stage binary read took 2715 us
[0000.993] Carveout took -42950 us
[0000.996] CPU initialization took 79103 us
[0001.000] Total time taken by TegraBoot 911651 us
[0001.004] Starting CPU & Halting co-processor
[0001.126] RamCode = 1
[0001.131] LPDDR4 Training: Read DT: Number of tables = 2
[0001.136] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.148] EMC Training Successful
[0001.151] 408000 not found in DVFS table
[0001.158] RamCode = 1
[0001.161] DT Write: emc-table@204000 succeeded
[0001.167] DT Write: emc-table@1600000 succeeded
[0001.171] LPDDR4 Training: Write DT: Number of tables = 2
[0001.208]
[0001.209] Debug Init done
[0001.212] Marked DTB cacheable
[0001.215] Bootloader DTB loaded at 0x83000000
[0001.219] Marked DTB cacheable
[0001.222] Kernel DTB loaded at 0x83100000
[0001.226] DeviceTree Init done
[0001.239] Pinmux applied successfully
[0001.243] gicd_base: 0x50041000
[0001.247] gicc_base: 0x50042000
[0001.250] Interrupts Init done
[0001.254] Using base:0x60005090 & irq:208 for tick-timer
[0001.259] Using base:0x60005098 for delay-timer
[0001.264] platform_init_timer: DONE
[0001.267] Timer(tick) Init done
[0001.271] osc freq = 38400 khz
[0001.275]
[0001.276] Welcome to L4T Cboot
[0001.279]
[0001.280] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.285] calling constructors
[0001.288] initializing heap
[0001.291] initializing threads
[0001.293] initializing timers
[0001.296] creating bootstrap completion thread
[0001.301] top of bootstrap2()
[0001.304] CPU: ARM Cortex A57
[0001.306] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.311] initializing platform
[0001.319] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.323] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.328] Macronix QSPI chip present
[0001.331] SPI device register
[0001.334] init boot device
[0001.337] allocating memory for boot device(SPI)
[0001.341] registering boot device
[0001.361] sdmmc node status = okay
[0001.364] sdcard instance = 0
[0001.367] sdcard gpio handle 0x5a
[0001.370] sdcard gpio pin 0xc9
[0001.373] sdcard gpio flags 0x0
[0001.376] vmmc-supply 0x9d
[0001.379] Instance: 0
[0001.381] Allocating memory for context
[0001.385] enabling clock
[0001.387] sd card init
[0001.389] Check card present and stable
[0001.393] Send command 0
[0001.418] Send command 3
[0001.422] Set RCA for the card
[0001.425] Query card specific data by command 9
[0001.431] Parse CSD data
[0001.434] Send command 7
[0001.444] Calling sd device register
[0001.448] Init sdcard
[0001.450] Allocating memory for boot device
[0001.454] Registering user device
[0001.467] Enable APE clock
[0001.470] Un-powergate APE partition
[0001.473] of_register: registering tegra_udc to of_hal
[0001.478] of_register: registering inv20628-driver to of_hal
[0001.484] of_register: registering ads1015-driver to of_hal
[0001.489] of_register: registering lp8557-bl-driver to of_hal
[0001.495] of_register: registering bq2419x_charger to of_hal
[0001.501] of_register: registering bq27441_fuel_gauge to of_hal
[0001.512] gpio framework initialized
[0001.516] of_register: registering tca9539_gpio to of_hal
[0001.521] of_register: registering tca9539_gpio to of_hal
[0001.526] of_register: registering i2c_bus_driver to of_hal
[0001.532] of_register: registering i2c_bus_driver to of_hal
[0001.538] of_register: registering i2c_bus_driver to of_hal
[0001.543] pmic framework initialized
[0001.547] of_register: registering max77620_pmic to of_hal
[0001.552] regulator framework initialized
[0001.556] of_register: registering tps65132_bl_driver to of_hal
[0001.562] initializing target
[0001.568] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.576] board ID = D78, board SKU = 3
[0001.580] Skipping Z3!
[0001.584] fixed regulator driver initialized
[0001.603] initializing OF layer
[0001.606] NCK carveout not present
[0001.610] Skipping dts_overrides
[0001.614] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.631] I2C Bus Init done
[0001.644] I2C Bus Init done
[0001.646] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.657] I2C Bus Init done
[0001.659] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.670] I2C Bus Init done
[0001.673] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.683] I2C Bus Init done
[0001.686] of_children_init: Ops found for compatible string maxim,max77620
[0001.696] max77620_init using irq 118
[0001.701] register ‘maxim,max77620’ pmic
[0001.705] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.711] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.722] I2C Bus Init done
[0001.725] NCK carveout not present
[0001.735] Find /i2c@7000c000’s alias i2c0
[0001.739] get eeprom at 1-a0, size 256, type 0
[0001.748] Find /i2c@7000c500’s alias i2c2
[0001.752] get eeprom at 3-a0, size 256, type 0
[0001.756] get eeprom at 3-ae, size 256, type 0
[0001.761] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.766] I2C slave not started
[0001.769] I2C write failed
[0001.772] Writing offset failed
[0001.775] eeprom_init: EEPROM read failed
[0001.779] pm_ids_update: eeprom init failed
[0001.783] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.813] pm_ids_update: The pm board id is 3448-0003-400
[0001.820] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.828] pm_ids_update: pm id update successful
[0001.833] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.863] pm_ids_update: The pm board id is 3542-0000-201
[0001.869] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0001.878] pm_ids_update: pm id update successful
[0001.908] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.914] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.922] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.927] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.936] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:02:df
[0001.942] Plugin Manager: Parse ODM data 0x00094000
[0001.955] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0001.970] Find /i2c@7000c000’s alias i2c0
[0001.974] get eeprom at 1-a0, size 256, type 0
[0001.983] Find /i2c@7000c500’s alias i2c2
[0001.987] get eeprom at 3-a0, size 256, type 0
[0001.991] get eeprom at 3-ae, size 256, type 0
[0001.996] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.001] I2C slave not started
[0002.004] I2C write failed
[0002.007] Writing offset failed
[0002.010] eeprom_init: EEPROM read failed
[0002.014] pm_ids_update: eeprom init failed
[0002.018] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.048] pm_ids_update: The pm board id is 3448-0003-400
[0002.054] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.061] pm_ids_update: pm id update successful
[0002.066] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.096] pm_ids_update: The pm board id is 3542-0000-201
[0002.102] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.109] pm_ids_update: pm id update successful
[0002.139] Add serial number:1424120112662 as DT property
[0002.147] Applying platform configs
[0002.154] platform-init is not present. Skipping
[0002.158] calling apps_init()
[0002.184] Found 14 GPT partitions in “sd0”
[0002.188] Proceeding to Cold Boot
[0002.191] starting app android_boot_app
[0002.195] Device state: unlocked
[0002.198] display console init
[0002.206] could not find regulator
[0002.209] hdmi cable connected
[0002.225] edid read success
[0002.240] DT entry for leds-pwm not found
[0002.247] width = 640, height = 480, frequency = 25174825
[0002.257] width = 640, height = 480, frequency = 25174825
[0002.263] width = 1920, height = 1080, frequency = 148500000
[0002.268] width = 1920, height = 1080, frequency = 148500000
[0002.274] width = 1920, height = 1080, frequency = 148351648
[0002.285] width = 720, height = 480, frequency = 26973026
[0002.290] width = 720, height = 480, frequency = 26973026
[0002.296] width = 1280, height = 720, frequency = 74175824
[0002.301] width = 720, height = 576, frequency = 26973026
[0002.307] width = 1280, height = 720, frequency = 74175824
[0002.312] width = 1920, height = 1080, frequency = 148351648
[0002.318] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.326] tmds-config node not found
[0002.330] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.344] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.352] could not find regulator
[0002.355] could not find regulator
[0002.359] could not find regulator
[0002.387] using default cmu settings
[0002.390] dc_hdmi_enable, starting HDMI initialisation
[0002.397] dc_hdmi_enable, HDMI initialisation complete
[0002.402] list and configure display window
[0002.410] display console init completed
[0002.422] subnode volume_up is not found !
[0002.426] subnode back is not found !
[0002.429] subnode volume_down is not found !
[0002.433] subnode menu is not found !
[0002.437] Gpio keyboard init success
[0002.481] found decompressor handler: lz4-legacy
[0002.495] decompressing blob (type 1)…
[0002.530] load_bmp_blob: panelresolution=1080 type=3
[0002.581] decompressor handler not found
[0002.584] load_firmware_blob: Firmware blob loaded, entries=2
[0002.590] -------> se_aes_verify_sbk_clear: 747
[0002.595] se_aes_verify_sbk_clear: Error
[0002.598] bl_battery_charging: connected to external power supply
[0002.605] xusb is supported
[0002.612] error while finding nvidia,portmap
[0003.116] xusb blob version 0 size 124416
[0003.120] firmware size 124416
[0003.124] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.136] xhci0: 64 bytes context size, 32-bit DMA
[0003.176] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.196] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.846] uhub0: 9 ports with 9 removable, self powered
[0013.176] get polling status timeout
[0013.180] failed to init xhci or no usb device attached
[0013.190] device_query_partition_size: failed to open partition sd0:MSC !
[0013.197] MSC Partition not found
[0013.203] device_query_partition_size: failed to open partition sd0:USP !
[0013.210] USP partition read failed!
[0013.213] blob_init: blob-partition USP header read failed
[0013.219] android_boot Unable to update recovery partition
[0013.224] kfs_getpartname: name = LNX
[0013.228] Loading kernel from LNX
[0013.326] load kernel from storage
[0013.338] decompressor handler not found
[0013.395] Successfully loaded kernel and ramdisk images
[0013.401] load_bmp_blob: panelresolution=1080 type=3
[0013.888] display bmp image done
[0013.891] NCK carveout not present
[0013.895] Skipping dts_overrides
[0013.898] NCK carveout not present
[0013.908] Find /i2c@7000c000’s alias i2c0
[0013.912] get eeprom at 1-a0, size 256, type 0
[0013.921] Find /i2c@7000c500’s alias i2c2
[0013.924] get eeprom at 3-a0, size 256, type 0
[0013.929] get eeprom at 3-ae, size 256, type 0
[0013.933] pm_ids_update: Updating 1,a0, size 256, type 0
[0013.939] I2C slave not started
[0013.942] I2C write failed
[0013.944] Writing offset failed
[0013.947] eeprom_init: EEPROM read failed
[0013.951] pm_ids_update: eeprom init failed
[0013.955] pm_ids_update: Updating 3,a0, size 256, type 0
[0013.985] pm_ids_update: The pm board id is 3448-0003-400
[0013.992] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0014.001] pm_ids_update: pm id update successful
[0014.006] pm_ids_update: Updating 3,ae, size 256, type 0
[0014.036] pm_ids_update: The pm board id is 3542-0000-201
[0014.042] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0014.050] pm_ids_update: pm id update successful
[0014.081] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0014.086] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0014.094] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0014.100] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0014.109] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:02:df
[0014.115] Plugin Manager: Parse ODM data 0x00094000
[0014.128] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0014.136] Add serial number:1424120112662 as DT property
[0014.145] Updated bpmp info to DTB
[0014.149] Updated initrd info to DTB
[0014.153] “proc-board” doesn’t exist, creating
[0014.159] Updated board info to DTB
[0014.162] “pmu-board” doesn’t exist, creating
[0014.168] Updated board info to DTB
[0014.172] “display-board” doesn’t exist, creating
[0014.178] Updated board info to DTB
[0014.181] “reset” doesn’t exist, creating
[0014.186] Updated reset info to DTB
[0014.189] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1
[0014.226] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0014.231] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0014.245] Updated bootarg info to DTB
[0014.249] Adding uuid 000000016450b700100000000e008440 to DT
[0014.255] Adding eks info 0 to DT
[0014.260] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0014.266] Updated memory info to DTB
[0014.274] set vdd_core voltage to 1125 mv
[0014.278] setting ‘vdd-core’ regulator to 1125000 micro volts
[0121.677] failed to get HID devices
[0121.697] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 1:1…
844 bytes read in 139 ms (5.9 KiB/s)
1: primary kernel
5487776 bytes read in 404 ms (13 MiB/s)
34332680 bytes read in 1531 ms (21.4 MiB/s)
Starting kernel …
[ 1.233562] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.233589] imx219 6-0010: board setup failed
[ 2.071961] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.090142] usb 1-3: device not accepting address 2, error -71
[ 2.634099] usb 1-3: device not accepting address 3, error -71
[ 3.424403] using random self ethernet address
[ 3.429015] using random host ethernet address
[ 3.614293] usb 1-3: device descriptor read/64, error -71
[ 3.849100] random: crng init done
[ 3.852535] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.859018] usb 1-3: device descriptor read/64, error -71
[ 4.129637] using random self ethernet address
[ 4.134163] using random host ethernet address
[ 4.214108] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[ 4.214238] usb 1-3: device descriptor read/64, error -71
[ 4.227451] tegra_cec 70015000.tegra_cec: Sent res: -62.
[ 4.234198] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 4.442309] usb 1-3: device descriptor read/64, error -71
[ 4.554179] usb usb1-port3: unable to enumerate USB device
[ 4.826546] usb 1-3: Device not responding to setup address.
[ 5.038401] usb 1-3: Device not responding to setup address.
[ 5.246134] usb 1-3: device not accepting address 6, error -71
[ 5.378411] usb 1-3: Device not responding to setup address.
[ 5.590360] usb 1-3: Device not responding to setup address.
[ 5.802151] usb 1-3: device not accepting address 7, error -71
[ 6.778228] usb 1-3: device descriptor read/64, error -71
[ 7.010358] usb 1-3: device descriptor read/64, error -71
test-desktop login: [ 7.362489] usb 1-3: device descriptor read/64, error -71
[ 7.595732] usb 1-3: device descriptor read/64, error -71
[ 7.706235] usb usb1-port3: unable to enumerate USB device
[ 8.011077] usb 1-3: Device not responding to setup address.
[ 8.222656] usb 1-3: Device not responding to setup address.
[ 8.434163] usb 1-3: device not accepting address 10, error -71
[ 8.558629] usb 1-3: Device not responding to setup address.
[ 8.770394] usb 1-3: Device not responding to setup address.
[ 8.982151] usb 1-3: device not accepting address 11, error -71
[ 9.958359] usb 1-3: device descriptor read/64, error -71
[ 10.190358] usb 1-3: device descriptor read/64, error -71
[ 10.542373] usb 1-3: device descriptor read/64, error -71
[ 10.774374] usb 1-3: device descriptor read/64, error -71
[ 10.886239] usb usb1-port3: unable to enumerate USB device
[ 11.190519] usb 1-3: Device not responding to setup address.
[ 11.402503] usb 1-3: Device not responding to setup address.
[ 11.614183] usb 1-3: device not accepting address 14, error -71
[ 11.738527] usb 1-3: Device not responding to setup address.
[ 11.950500] usb 1-3: Device not responding to setup address.
[ 12.162151] usb 1-3: device not accepting address 15, error -71
[ 13.970365] usb 1-3: device descriptor read/64, error -71
[ 14.202302] usb 1-3: device descriptor read/64, error -71
[ 14.554366] usb 1-3: device descriptor read/64, error -71
[ 14.786362] usb 1-3: device descriptor read/64, error -71
[ 14.898178] usb usb1-port3: unable to enumerate USB device
[ 15.202480] usb 1-3: Device not responding to setup address.
[ 15.414501] usb 1-3: Device not responding to setup address.
[ 15.626166] usb 1-3: device not accepting address 18, error -71
[ 15.750526] usb 1-3: Device not responding to setup address.
[ 15.962454] usb 1-3: Device not responding to setup address.
[ 16.174145] usb 1-3: device not accepting address 19, error -71
[ 17.150360] usb 1-3: device descriptor read/64, error -71
[ 17.382358] usb 1-3: device descriptor read/64, error -71
[ 17.734361] usb 1-3: device descriptor read/64, error -71
[ 17.966359] usb 1-3: device descriptor read/64, error -71
[ 18.078127] usb usb1-port3: unable to enumerate USB device
test-desktop login:
test-desktop login:
test-desktop login:
test-desktop login:
test-desktop login: uname -a
Password:
Login incorrect
Password:
Last login: Sat Dec 5 15:48:04 EST 2020 on ttyS0
test@test-desktop:~ unmae name- -a
-bash: unname: command not found
test@test-desktop:~ unname -a
Just a suggestion: If you edit your post with the log, and place an empty line above and below the actual log, and then place three single backquote’s (the unshifted tilde ~ key) as the sole content of the line above and below your post, then it’ll format it as code and add scroll bars. These three characters before and after, as their on lines, will format better:
Much of what was there looked normal, and there were some odd log lines, but I am not sure if those mean anything. Is it correct that you are able to log in ok via serial console?
Also, did you have a USB keyboard or mouse attached? I ask because of USB saying nothing found or error. If you had something connected and the device tree were wrong, then it would probably have similar errors.
One reason device tree might be wrong is if you flashed with the 4GB module software instead of the 2GB software.
Yes able to login via serial console. Once logged in can access even remotely through a reverse tunnel. Trying to see if auto-login on boot is possible so i can get rid of the ttl serial on boot.
@linuxdev I think the issue stems from this apt-get updare breaking the gui, that will be fixed in a future jetpack update. In the mean time I think i will just do a fresh image install and not update.
If you were to find an issue with a particular package, then that package could be marked “hold” until it is resolved. A serial console boot log might show the issue, but you are probably correct that just reflashing and not updating is quicker in the long run.
@linuxdev great. is there a way to auto-login on boot. my reverse tunnel only connects once the nano is logged in.
There is auto login as a setting, but I’ve not used this. It is possible not all public documents for Ubuntu 18.04 apply since some of the GUI environment differs, but you might check these URLs:
If you manage to get this working over an ssh
tunnel, then what you could do for security (if the network is not protected from random incoming traffic) is set up to allow ssh
logins only by key and tunnel through ssh
Has anyone else set up for automatic login?
No working
also curious to see if anyone else has it working through cli.
love to see what other rever tunneling services people are using.
Worst case i will refomat image and use gui
I was able to get the gui back by pressing ctrl-alt-f2 on boot
It seems to be an issue with lightdm. I just used ctrl-alt-f2 to switch to a different term after the screen goes blank on boot and switched to gdm.
@linuxdev autologin only works with gui enabled not via cli when running headless.
1. Edit /etc/lightdm/lightdm.conf.d/50-nvidia.conf and add below two lines:
autologin-user=nvidia
autologin-user-timeout=0
2. Save and reboot
Yes, I had not thought of auto login for a text terminal. Are you wanting auto login for the local monitor in text mode? Or for serial console? Either way you might find what follows useful, and I am sorry it is so long, but the details might keep you from breaking something if you are interested in digging in to this topic.
Before I show the URL which might be of interest, beware that Jetson getty
services are named a bit different and may not follow the same option availability. The following will show certain getty
services:
sudo systemctl list-units | grep -i 'getty.*service'
(depending on where you are looking there may be a different service to edit)
Also of interest:
`find /etc/systemd -name ‘getty’
Then:
ls -l `find /etc/systemd -name '*getty*'`
When modifying one of the standard services handled by systemd (including getty) it is customary to add the modified version of the service within “/etc/systemd/
”. Often the files there are just symbolic links into the default version of the file (which is somewhere in "/lib/systemd"). Basically you would leave alone the original service file under "
/lib/systemd" and copy the original somewhere under "
/etc/systemd/system/". During boot the "
/etc" version takes precedence. If you delete or
bzip2 the "
/etc" version, then the customizing becomes inert (I mention
bzip2because it is a good way to temporarily inactivate a file there, and then
bunzip2` the file to reactivate it during testing).
If a file in “/etc/systemd
” is a symbolic link, and you want to edit, then simply copy the original hard link within “/lib/systemd
” to the “/etc/systemd
” location, followed by editing the “/etc
” version. If you don’t like your edits, then you could put the symbolic link back in place, or else bzip2
your version (and perhaps also put the symbolic link back in place).
Note that I have not tried this on a Jetson, so it may not work. However, this URL mentions how to set up auto login for text consoles (and in theory serial consoles) via command line edits based on the above “/etc/systemd
” information:
https://askubuntu.com/questions/819117/how-can-i-get-autologin-at-startup-working-on-ubuntu-server-16-04-1
I was looking at the reply to the original poster’s question which was based on “/etc/systemd
” edits. This probably has a good chance of working if you name the “nv...
” version of the URL’s getty
edits. The “getty@tty1
” implies the text console found at ALT-F1
key binding (if in a console), or CTRL-ALT-F1
key binding (if in a GUI). Similarly, “getty@tty2
” is for the relevant key binding when using ALT-F2
or CTRL-ALT-F2
, and so on. One binding is for the X11 GUI if you have the GUI installed (perhaps even if it is not active), and you’d have to skip that one (getty
is replaced by the X login manager on the binding which is for the GUI). Find out which key binding associates with the text console you want to auto login. I’ll assume it is ALT-F2
, in which case you are interested in the getty variant (or following the them) of “getty@tty2
”. You could substitute for serial consoles as well.
Try to add the correct “/etc/systemd/system
” file. You might get the expected text terminal login.
