[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x50
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0xa1e61
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.233] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI …
[0000.280] Initialize FailControl
[0000.283] Read PT from (2:0)
[0000.314] PT crc32 and magic check passed.
[0000.318] Using BFS PT to query partitions
[0000.324] Loading Tboot-CPU binary
[0000.352] Verifying TBC in OdmNonSecureSBK mode
[0000.362] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.369] Bootloader downloaded successfully.
[0000.373] Downloaded Tboot-CPU binary to 0xa0000258
[0000.378] MAX77620_GPIO5 configured
[0000.381] CPU power rail is up
[0000.384] CPU clock enabled
[0000.388] Performing RAM repair
[0000.391] Updating A64 Warmreset Address to 0xa00002e9
[0000.396] BoardID = 3448, SKU = 0x0
[0000.399] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.403] Nano-SD: checking PT table on QSPI …
[0000.407] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.413] Loading NvTbootBootloaderDTB
[0000.480] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.551] Bootloader DTB Load Address: 0x83000000
[0000.556] BoardID = 3448, SKU = 0x0
[0000.559] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.563] Nano-SD: checking PT table on QSPI …
[0000.567] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.574] Loading NvTbootKernelDTB
[0000.639] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.711] Kernel DTB Load Address: 0x83100000
[0000.715] BoardID = 3448, SKU = 0x0
[0000.718] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.722] Nano-SD: checking PT table on QSPI …
[0000.726] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.734] Loading cboot binary
[0000.850] Verifying EBT in OdmNonSecureSBK mode
[0000.892] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.899] Bootloader downloaded successfully.
[0000.903] BoardID = 3448, SKU = 0x0
[0000.906] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.910] Nano-SD: checking PT table on QSPI …
[0000.914] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.921] PT: Partition NCT NOT found !
[0000.924] Warning: Find Partition via PT Failed
[0000.928] Next binary entry address: 0x92c00258
[0000.933] BoardId: 3448
[0000.938] Overriding pmu board id with proc board id
[0000.942] Display board id is not available
[0000.947] BoardID = 3448, SKU = 0x0
[0000.950] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.954] Nano-SD: checking PT table on QSPI …
[0000.958] NvTbootFailControlDoFailover: No failover; Continuing …
[0001.065] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.121] /bpmp deleted
[0001.123] SC7EntryFw header found loaded at 0xff700000
[0001.311] OVR2 PMIC
[0001.313] Bpmp FW successfully loaded
[0001.316] BoardID = 3448, SKU = 0x0
[0001.320] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.323] Nano-SD: checking PT table on QSPI …
[0001.328] NvTbootFailControlDoFailover: No failover; Continuing …
[0001.335] WB0 init successfully at 0xff780000
[0001.339] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.344] Set NvDecSticky Bits
[0001.348] GSC2 address ff53fffc value c0edbbcc
[0001.354] GSC MC Settings done
[0001.357] BoardID = 3448, SKU = 0x0
[0001.360] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.364] Nano-SD: checking PT table on QSPI …
[0001.368] NvTbootFailControlDoFailover: No failover; Continuing …
[0001.375] TOS Image length 53680
[0001.378] Monitor size 53680
[0001.381] OS size 0
[0001.396] Secure Os AES-CMAC Verification Success!
[0001.401] TOS image cipher info: plaintext
[0001.405] Loading and Validation of Secure OS Successful
[0001.421] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.425] NvTbootPackSdramParams: start.
[0001.430] NvTbootPackSdramParams: done.
[0001.434] Tegraboot started after 51856 us
[0001.438] Basic modules init took 935952 us
[0001.442] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.448] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.453] Next stage binary read took 102860 us
[0001.457] Carveout took -132466 us
[0001.461] CPU initialization took 510786 us
[0001.465] Total time taken by TegraBoot 1417132 us[0001.469] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 14:22:20, Apr 20 2022
ERROR: Error initializing runtime service trusty_fast
[0001.591] RamCode = 0
[0001.596] LPDDR4 Training: Read DT: Number of tables = 2
[0001.601] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.614] EMC Training Successful
[0001.617] 408000 not found in DVFS table
[0001.623] RamCode = 0
[0001.627] DT Write: emc-table@204000 succeeded
[0001.632] DT Write: emc-table@1600000 succeeded
[0001.636] LPDDR4 Training: Write DT: Number of tables = 2
[0001.685]
[0001.686] Debug Init done
[0001.688] Marked DTB cacheable
[0001.691] Bootloader DTB loaded at 0x83000000
[0001.696] Marked DTB cacheable
[0001.699] Kernel DTB loaded at 0x83100000
[0001.703] DeviceTree Init done
[0001.716] Pinmux applied successfully
[0001.720] gicd_base: 0x50041000
[0001.724] gicc_base: 0x50042000
[0001.727] Interrupts Init done
[0001.731] Using base:0x60005090 & irq:208 for tick-timer
[0001.736] Using base:0x60005098 for delay-timer
[0001.740] platform_init_timer: DONE
[0001.744] Timer(tick) Init done
[0001.748] osc freq = 38400 khz
[0001.751]
[0001.753] Welcome to L4T Cboot
[0001.756]
[0001.757] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.762] calling constructors
[0001.765] initializing heap
[0001.767] initializing threads
[0001.770] initializing timers
[0001.773] creating bootstrap completion thread
[0001.777] top of bootstrap2()
[0001.780] CPU: ARM Cortex A57
[0001.783] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.788] initializing platform
[0001.795] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.800] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.804] Macronix QSPI chip present
[0001.808] SPI device register
[0001.811] init boot device
[0001.813] allocating memory for boot device(SPI)
[0001.818] registering boot device
[0001.836] QSPI bdev is already initialized
[0001.840] Enable APE clock
[0001.843] Un-powergate APE partition
[0001.846] of_register: registering tegra_udc to of_hal
[0001.851] of_register: registering inv20628-driver to of_hal
[0001.857] of_register: registering ads1015-driver to of_hal
[0001.863] of_register: registering lp8557-bl-driver to of_hal
[0001.868] of_register: registering bq2419x_charger to of_hal
[0001.874] of_register: registering bq27441_fuel_gauge to of_hal
[0001.885] gpio framework initialized
[0001.889] of_register: registering tca9539_gpio to of_hal
[0001.894] of_register: registering tca9539_gpio to of_hal
[0001.900] of_register: registering i2c_bus_driver to of_hal
[0001.905] of_register: registering i2c_bus_driver to of_hal
[0001.911] of_register: registering i2c_bus_driver to of_hal
[0001.916] pmic framework initialized
[0001.920] of_register: registering max77620_pmic to of_hal
[0001.925] regulator framework initialized
[0001.929] of_register: registering tps65132_bl_driver to of_hal
[0001.935] initializing target
[0001.941] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.949] board ID = D78, board SKU = 0
[0001.953] Skipping Z3!
[0001.957] fixed regulator driver initialized
[0001.975] initializing OF layer
[0001.978] NCK carveout not present
[0001.981] Skipping dts_overrides
[0001.986] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.002] I2C Bus Init done
[0002.005] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.015] I2C Bus Init done
[0002.018] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.028] I2C Bus Init done
[0002.031] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.041] I2C Bus Init done
[0002.044] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.054] I2C Bus Init done
[0002.057] of_children_init: Ops found for compatible string maxim,max77620
[0002.067] max77620_init using irq 118
[0002.072] register ‘maxim,max77620’ pmic
[0002.076] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.083] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.093] I2C Bus Init done
[0002.097] NCK carveout not present
[0002.106] Find /i2c@7000c000’s alias i2c0
[0002.110] get eeprom at 1-a0, size 256, type 0
[0002.119] Find /i2c@7000c500’s alias i2c2
[0002.123] get eeprom at 3-a0, size 256, type 0
[0002.127] get eeprom at 3-ae, size 256, type 0
[0002.131] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.137] I2C slave not started
[0002.140] I2C write failed
[0002.142] Writing offset failed
[0002.145] eeprom_init: EEPROM read failed
[0002.149] pm_ids_update: eeprom init failed
[0002.153] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.183] pm_ids_update: The pm board id is 3448-0000-402
[0002.190] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.199] pm_ids_update: pm id update successful
[0002.203] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.233] eeprom_init: EEPROM incompatible version found
[0002.238] pm_ids_update: eeprom init failed
[0002.268] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.274] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.282] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.288] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.296] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:5b:c7:1c
[0002.303] Plugin Manager: Parse ODM data 0x000a4000
[0002.315] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.329] Find /i2c@7000c000’s alias i2c0
[0002.333] get eeprom at 1-a0, size 256, type 0
[0002.342] Find /i2c@7000c500’s alias i2c2
[0002.346] get eeprom at 3-a0, size 256, type 0
[0002.350] get eeprom at 3-ae, size 256, type 0
[0002.355] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.360] I2C slave not started
[0002.363] I2C write failed
[0002.366] Writing offset failed
[0002.369] eeprom_init: EEPROM read failed
[0002.373] pm_ids_update: eeprom init failed
[0002.377] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.407] pm_ids_update: The pm board id is 3448-0000-402
[0002.413] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.420] pm_ids_update: pm id update successful
[0002.425] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.455] eeprom_init: EEPROM incompatible version found
[0002.460] pm_ids_update: eeprom init failed
[0002.490] Add serial number:1423721002436 as DT property
[0002.498] Applying platform configs
[0002.504] platform-init is not present. Skipping
[0002.509] calling apps_init()
[0002.514] Couldn’t find GPT header
[0002.519] Proceeding to Cold Boot
[0002.522] starting app android_boot_app
[0002.526] Device state: unlocked
[0002.529] display console init
[0002.537] could not find regulator
[0002.541] hdmi cable connected
[0002.556] edid read success
[0002.560] tmds-config node not found
[0002.565] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avddDT entry for leds-pwm not found
-[0002.579] io-hdmi-dp’ regulator to 1050000 micro volts
[0002.587] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.594] could not find regulator
[0002.597] could not find regulator
[0002.601] could not find regulator
[0002.629] using default cmu settings
[0002.633] dc_hdmi_enable, starting HDMI initialisation
[0002.639] dc_hdmi_enable, HDMI initialisation complete
[0002.644] list and configure display window
[0002.649] display console init completed
[0002.656] subnode volume_up is not found !
[0002.660] subnode back is not found !
[0002.664] subnode volume_down is not found !
[0002.668] subnode menu is not found !
[0002.671] Gpio keyboard init success
[0002.752] found decompressor handler: lz4-legacy
[0002.766] decompressing blob (type 1)…
[0002.833] load_bmp_blob: panelresolution=480 type=0
[0002.838] -------> se_aes_verify_sbk_clear: 747
[0002.842] se_aes_verify_sbk_clear: Error
[0002.846] SE operation failed
[0002.849] bl_battery_charging: connected to external power supply
[0002.861] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.869] MSC Partition not found
[0002.875] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.882] USP partition read failed!
[0002.886] blob_init: blob-partition USP header read failed
[0002.891] android_boot Unable to update recovery partition
[0002.897] kfs_getpartname: name = LNX
[0002.900] Loading kernel from LNX
[0002.910] Found 19 BFS partitions in “spiflash0”
[0003.231] load kernel from storage
[0003.236] decompressor handler not found
[0003.502] Successfully loaded kernel and ramdisk images
[0003.507] board ID = D78, board SKU = 0
[0003.511] sdmmc node status = okay
[0003.515] sdcard instance = 0
[0003.518] sdmmc cd-inverted
[0003.520] sdcard gpio handle 0x5b
[0003.523] sdcard gpio pin 0xc9
[0003.526] sdcard gpio flags 0x0
[0003.529] vmmc-supply 0x9d
[0003.532] cd_gpio_pin = 201
[0003.535] pin_state = 0
[0003.537] Found sdcard
[0003.539] SD-card IS present …
[0003.542] load_and_boot_kernel: SD card detected OK
[0003.548] load_bmp_blob: panelresolution=480 type=0
[0003.622] display bmp image done
[0003.625] NCK carveout not present
[0003.628] Skipping dts_overrides
[0003.631] NCK carveout not present
[0003.641] Find /i2c@7000c000’s alias i2c0
[0003.645] get eeprom at 1-a0, size 256, type 0
[0003.653] Find /i2c@7000c500’s alias i2c2
[0003.657] get eeprom at 3-a0, size 256, type 0
[0003.662] get eeprom at 3-ae, size 256, type 0
[0003.666] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.671] I2C slave not started
[0003.674] I2C write failed
[0003.677] Writing offset failed
[0003.680] eeprom_init: EEPROM read failed
[0003.684] pm_ids_update: eeprom init failed
[0003.688] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.718] pm_ids_update: The pm board id is 3448-0000-402
[0003.725] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0003.733] pm_ids_update: pm id update successful
[0003.738] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.768] eeprom_init: EEPROM incompatible version found
[0003.773] pm_ids_update: eeprom init failed
[0003.803] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.809] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.817] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.823] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.831] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:5b:c7:1c
[0003.837] Plugin Manager: Parse ODM data 0x000a4000
[0003.850] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.858] Add serial number:1423721002436 as DT property
[0003.867] “bpmp” doesn’t exist, creating
[0003.873] Updated bpmp info to DTB
[0003.877] Updated initrd info to DTB
[0003.881] “proc-board” doesn’t exist, creating
[0003.887] Updated board info to DTB
[0003.890] “pmu-board” doesn’t exist, creating
[0003.896] Updated board info to DTB
[0003.900] “display-board” doesn’t exist, creating
[0003.905] Updated board info to DTB
[0003.909] “reset” doesn’t exist, creating
[0003.914] Updated reset info to DTB
[0003.917] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1
[0003.956] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.962] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0003.975] Updated bootarg info to DTB
[0003.978] Adding uuid 000000016431b6c91800000011038340 to DT
[0003.984] Adding eks info 0 to DT
[0003.990] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.996] Updated memory info to DTB
[0004.003] set vdd_core voltage to 1075 mv
[0004.007] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.013] Found secure-pmc; disable BPMPU-Boot 2020.04-g4335beb (Apr 20 2022 - 14:22:25 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environmentIn: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 37 ms (21.5 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7160133 bytes read in 387 ms (17.6 MiB/s)
Retrieving file: /boot/Image
34484232 bytes read in 1536 ms (21.4 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317ced3
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5496-d5000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:13:06 PDT 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00140000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.180136] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.300716] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.308293] imx219 7-0010: board setup failed
[ 1.336551] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.344108] imx219 8-0010: board setup failed
[ 3.121512] cgroup: cgroup2: unknown option “nsdelegate”
[ 4.623168] using random self ethernet address
[ 4.629663] using random host ethernet address
[ 5.026069] random: crng init done
[ 5.029498] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.290424] using random self ethernet address
[ 6.294991] using random host ethernet address
[ 10.198263] Bridge firewalling registeredUbuntu 18.04.6 LTS alton ttyS0
alton login: Preformatted text
Blockquote
In case you don’t know. You didn’t provide any helpful info because kernel log is in silent mode.
Also, try to use block for your log so that others can read it more easier… really try to check your own format after sending out a comment please…
this is block
so could you please tell me how to get the kernel log ? May I ask where the official instructions are? thank you.
You can just run dmesg command in your console. There is no official instructions. It is just linux command.
I will also suggest that you remove the word “quiet” from the “/boot/extlinux/extlinux.conf” file anywhere you find it (but it will be in the “APPEND” key/value pair).
Hi, thanks. but my jetson nano was hang when it just entered the desktop. i cannot get kernel log by dmesg command. As you can see in the video, i could not do anything when entered the desktop.
Thinks, I acted on your advice. But, I still don’t have any more information from the serial port.
Is there an underlying hardware problem causing this crash, Is there any official document about checking hardware.Thinks
Sorry. Just ignore my previous comment.
Please just answer the first question here.
Are you able to interact with your board by using the serial console or not?
Sorry, I am not good at English. Thank you for any advice you give me. I relly removed “quiet” on officia baseboard B01, because Nano works normally on B01. On a baseboard of my own design, I got the above information through the serial port, but I haven’t tried to send instructions to the nano through the serial port.
我這邊解釋一下好了… 其實有點不太理解到底困難點在哪.
首先,你能用serial console抓到log了. dmesg基本上就是在console上打幾個字然後把結果貼給我們. 移掉quiet也就是讓serial console開機的時候能順便印出kernel log. 跟dmesg上是做差不多的事情.
我知道你的困難點現在在於你的usb是不能用的狀態. 所以你應該要試著使用serial console port進行操作…
還有 custom board不能用usb port很正常, 因為原先的device tree設定是給我們devkit使用的, 如果你換了一個usb配置, 那device tree就要重改.
我不確定你對於linux kernel的device tree熟不熟悉. 如果不熟悉的話, 建議是直接找一個熟悉的人來. 不然我從頭開始講起你可能也會不太理解.
Thanks, I’m really just a beginner… I’ll try it as you say
Some basic information: Serial console has very few requirements for it to work. Other than the very simple serial UART, all of the drivers for video and keyboard exist on the host PC instead of the Jetson. That means video and USB can crash and burn and serial UARTs will continue working. In fact a very large part of the kernel can be destroyed and the serial console will continue to work. Much bootloader software is able to interact with the serial console due to this very minimal driver requirement. This means boot software would not need a video or USB driver to function with a serial console. This is one of the best (and least expensive) debug tools you can have.
I did notice an i2c error. Since this is a custom board, then you might mention if your device tree adjusted for any i2c changes. Any change in layout relative to the dev kit carrier board implies parts of the carrier board will not be found correctly if the device tree does not inform the software about those changes (and i2c is a candidate for that).
I’m extremely grateful to you and @WayneWWW. I’m just a beginner and student interested in jetson. I learned a lot with your help. Following your suggestions, I obtained the following information. As you said, I added a chip to split the HDMI signal in two, probably that’s why HDMI doesn’t work…just dp worked.I think I’ll also learn about the device tree to get to the next step. Thank you again for your help.
dmesg.txt (64.8 KB)
厄…這邊跟你建議一下. 如果你要貼log. 麻煩就做成附件.txt然後貼上來.
你這種整個複製貼上的做法對其他人而言其實不太好… 尤其是你前面已經貼了另外一份log. 我們很多時候需要用搜尋功能找一些log裡面的關鍵字的.
Thanks, Changed log to .txt file.
再提醒一下. 你的dmesg.txt每一行都被截掉了…
Note that serial console logs will show up even in boot stages. dmesg only shows up once the Linux kernel is loaded. Serial console programs run from a host PC can also log an entire session. If you have serial console running, and the logging started prior to booting, then all you have to do is boot, and then save the serial console as a log. No lines cut off, no need to copy and paste, no need to transfer the log from the Jetson to another computer (it’s already on the host PC).
minicom_nano_log022002.txt (129.3 KB)
Hello, thank you for your help. I just boot and save the serial console as a log.
I found this issue, thanks!
