Jetson Nano emmc boot stuck
Hi, I deisgned custom carrier board for nano/tx2nx/xavier nx.
It is boot normal in nano-sd/tx2nx/xavier nx, but fail in nano-emmc.
This is log from debug uart.
[0000.221] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.226] Processing in cold boot mode Bootloader 2
[0000.231] A02 Bootrom Patch rev = 1023
[0000.234] Power-up reason: pmc por
[0000.238] No Battery Present
[0000.240] pmic max77620 reset reason
[0000.244] pmic max77620 NVERC : 0x80
[0000.247] RamCode = 0
[0000.249] Platform has DDR4 type RAM
[0000.253] max77620 disabling SD1 Remote Sense
[0000.257] Setting DDR voltage to 1125mv
[0000.261] Serial Number of Pmic Max77663: 0x935ee
[0000.268] Entering ramdump check
[0000.271] Get RamDumpCarveOut = 0x0
[0000.275] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.280] Last reboot was clean, booting normally!
[0000.284] Sdram initialization is successful
[0000.288] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.295] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.300] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.306] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.312] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.318] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.324] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.330] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.346] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.352] Platform-DebugCarveout: 0
[0000.355] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.361] Non secure mode, and RB not enabled.
[0000.365] BoardID = 3448, SKU = 0x2
[0000.368] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.374] Read GPT from (0:3)
[0000.389] Csd NumOfBlocks=0
[0000.401] Using GPT Primary to query partitions
[0000.405] Initialize FailControl
[0000.408] Read PT from (0:3)
[0000.443] PT crc32 and magic check passed.
[0000.447] Using BFS PT to query partitions
[0000.452] Loading Tboot-CPU binary
[0000.458] Verifying TBC in OdmNonSecureSBK mode
[0000.468] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.475] Bootloader downloaded successfully.
[0000.479] Downloaded Tboot-CPU binary to 0xa0000258
[0000.484] MAX77620_GPIO5 configured
[0000.487] CPU power rail is up
[0000.490] CPU clock enabled
[0000.494] Performing RAM repair
[0000.497] Updating A64 Warmreset Address to 0xa00002e9
[0000.502] BoardID = 3448, SKU = 0x2
[0000.505] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.511] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.517] Loading NvTbootBootloaderDTB
[0000.534] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.606] Bootloader DTB Load Address: 0x83000000
[0000.610] BoardID = 3448, SKU = 0x2
[0000.614] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.619] Loading NvTbootKernelDTB
[0000.636] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.707] Kernel DTB Load Address: 0x83100000
[0000.712] BoardID = 3448, SKU = 0x2
[0000.715] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.721] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.728] Loading cboot binary
[0000.739] Verifying EBT in OdmNonSecureSBK mode
[0000.781] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.788] Bootloader downloaded successfully.
[0000.792] BoardID = 3448, SKU = 0x2
[0000.795] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.801] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.808] PT: Partition NCT NOT found !
[0000.811] Warning: Find Partition via PT Failed
[0000.816] Next binary entry address: 0x92c00258
[0000.820] BoardId: 3448
[0000.825] Overriding pmu board id with proc board id
[0000.829] Display board id is not available
[0000.834] BoardID = 3448, SKU = 0x2
[0000.837] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.843] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.856] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.912] /bpmp deleted
[0000.915] SC7EntryFw header found loaded at 0xff700000
[0001.102] OVR2 PMIC
[0001.104] Bpmp FW successfully loaded
[0001.108] BoardID = 3448, SKU = 0x2
[0001.111] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.117] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.124] WB0 init successfully at 0xff780000
[0001.128] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.133] Set NvDecSticky Bits
[0001.137] GSC2 address ff53fffc value c0edbbcc
[0001.143] GSC MC Settings done
[0001.146] BoardID = 3448, SKU = 0x2
[0001.149] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.156] TOS Image length 53680
[0001.159]  Monitor size 53680
[0001.162]  OS size 0
[0001.167] Secure Os AES-CMAC Verification Success!
[0001.172] TOS image cipher info: plaintext
[0001.176] Loading and Validation of Secure OS Successful
[0001.192] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.196] NvTbootPackSdramParams: start.
[0001.201] NvTbootPackSdramParams: done.
[0001.205] Tegraboot started after 150198 us
[0001.209] Basic modules init took 719771 us
[0001.213] Sec Bootdevice Read Time = 54 ms, Read Size = 3682 KB
[0001.219] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.224] Next stage binary read took 7379 us
[0001.228] Carveout took -34773 us
[0001.232] CPU initialization took 391755 us
[0001.236] Total time taken by TegraBoot 1084132 us
[0001.240] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):b5eeb33f7
NOTICE:  BL31: Built : 12:09:37, Jul 26 2021
ERROR:   Error initializing runtime service trusty_fast
[0001.362] RamCode = 0
[0001.367] LPDDR4 Training: Read DT: Number of tables = 2
[0001.372] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.385] EMC Training Successful
[0001.388] 408000 not found in DVFS table
[0001.394] RamCode = 0
[0001.398] DT Write: emc-table@204000 succeeded
[0001.403] DT Write: emc-table@1600000 succeeded
[0001.407] LPDDR4 Training: Write DT: Number of tables = 2
[0001.450]
[0001.451] Debug Init done
[0001.454] Marked DTB cacheable
[0001.457] Bootloader DTB loaded at 0x83000000
[0001.461] Marked DTB cacheable
[0001.464] Kernel DTB loaded at 0x83100000
[0001.468] DeviceTree Init done
[0001.481] Pinmux applied successfully
[0001.486] gicd_base: 0x50041000
[0001.489] gicc_base: 0x50042000
[0001.492] Interrupts Init done
[0001.496] Using base:0x60005090 & irq:208 for tick-timer
[0001.501] Using base:0x60005098 for delay-timer
[0001.506] platform_init_timer: DONE
[0001.509] Timer(tick) Init done
[0001.513] osc freq = 38400 khz
[0001.517]
[0001.518] Welcome to L4T Cboot
[0001.521]
[0001.522] Cboot Version: 00.00.2018.01-t210-c952b4e6
[0001.527] calling constructors
[0001.530] initializing heap
[0001.533] initializing threads
[0001.536] initializing timers
[0001.539] creating bootstrap completion thread
[0001.543] top of bootstrap2()
[0001.546] CPU: ARM Cortex A57
[0001.549] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.553] initializing platform
[0001.607] Config for emmc ddr50 mode completed
[0001.611] sdmmc bdev is already initialized
[0001.615] Enable APE clock
[0001.618] Un-powergate APE partition
[0001.621] of_register: registering tegra_udc to of_hal
[0001.627] of_register: registering inv20628-driver to of_hal
[0001.632] of_register: registering ads1015-driver to of_hal
[0001.638] of_register: registering lp8557-bl-driver to of_hal
[0001.644] of_register: registering bq2419x_charger to of_hal
[0001.649] of_register: registering bq27441_fuel_gauge to of_hal
[0001.660] gpio framework initialized
[0001.664] of_register: registering tca9539_gpio to of_hal
[0001.669] of_register: registering tca9539_gpio to of_hal
[0001.675] of_register: registering i2c_bus_driver to of_hal
[0001.680] of_register: registering i2c_bus_driver to of_hal
[0001.686] of_register: registering i2c_bus_driver to of_hal
[0001.691] pmic framework initialized
[0001.695] of_register: registering max77620_pmic to of_hal
[0001.700] regulator framework initialized
[0001.704] of_register: registering tps65132_bl_driver to of_hal
[0001.710] initializing target
[0001.716] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.727] fixed regulator driver initialized
[0001.744] initializing OF layer
[0001.747] NCK carveout not present
[0001.750] Skipping dts_overrides
[0001.754] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.771] I2C Bus Init done
[0001.773] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.783] I2C Bus Init done
[0001.786] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.796] I2C Bus Init done
[0001.799] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.809] I2C Bus Init done
[0001.812] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.822] I2C Bus Init done
[0001.825] of_children_init: Ops found for compatible string maxim,max77620
[0001.835] max77620_init using irq 118
[0001.840] register 'maxim,max77620' pmic
[0001.844] gpio_driver_register: register 'max77620-gpio' driver
[0001.850] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.861] I2C Bus Init done
[0001.864] NCK carveout not present
[0001.873] Find /i2c@7000c000's alias i2c0
[0001.877] get eeprom at 1-a0, size 256, type 0
[0001.886] Find /i2c@7000c500's alias i2c2
[0001.890] get eeprom at 3-a0, size 256, type 0
[0001.894] get eeprom at 3-ae, size 256, type 0
[0001.899] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.904] I2C slave not started
[0001.907] I2C write failed
[0001.910] Writing offset failed
[0001.913] eeprom_init: EEPROM read failed
[0001.917] pm_ids_update: eeprom init failed
[0001.921] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.951] pm_ids_update: The pm board id is 3448-0002-400
[0001.957] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0001.966] pm_ids_update: pm id update successful
[0001.970] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.976] I2C slave not started
[0001.979] I2C write failed
[0001.981] Writing offset failed
[0001.984] eeprom_init: EEPROM read failed
[0001.988] pm_ids_update: eeprom init failed
[0002.018] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.024] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.032] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.038] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.046] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:cf:2b
[0002.052] Plugin Manager: Parse ODM data 0x000a4000
[0002.065] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.079] Find /i2c@7000c000's alias i2c0
[0002.083] get eeprom at 1-a0, size 256, type 0
[0002.092] Find /i2c@7000c500's alias i2c2
[0002.096] get eeprom at 3-a0, size 256, type 0
[0002.100] get eeprom at 3-ae, size 256, type 0
[0002.104] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.110] I2C slave not started
[0002.113] I2C write failed
[0002.115] Writing offset failed
[0002.118] eeprom_init: EEPROM read failed
[0002.122] pm_ids_update: eeprom init failed
[0002.126] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.157] pm_ids_update: The pm board id is 3448-0002-400
[0002.163] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.170] pm_ids_update: pm id update successful
[0002.174] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.180] I2C slave not started
[0002.183] I2C write failed
[0002.185] Writing offset failed
[0002.188] eeprom_init: EEPROM read failed
[0002.192] pm_ids_update: eeprom init failed
[0002.222] Add serial number:1423019109468 as DT property
[0002.230] Applying platform configs
[0002.236] platform-init is not present. Skipping
[0002.241] calling apps_init()
[0002.262] Found 17 GPT partitions in "sdmmc3_user"
[0002.267] Proceeding to Cold Boot
[0002.270] starting app android_boot_app
[0002.274] Device state: unlocked
[0002.277] display console init
[0002.285] could not find regulator
[0002.308] hdmi cable not connected
[0002.312] is_hdmi_needed: HDMI not connected, returning false
[0002.317] hdmDT entry for leds-pwm not found
i[0002.325]  is not connected
[0002.327] sor0 is not supported
[0002.330] display_console_init: no valid display out_type
[0002.338] subnode volume_up is not found !
[0002.342] subnode back is not found !
[0002.346] subnode volume_down is not found !
[0002.350] subnode menu is not found !
[0002.354] Gpio keyboard init success
[0002.401] found decompressor handler: lz4-legacy
[0002.415] decompressing blob (type 1)...
[0002.482] display_resolution: No display init
[0002.486] Failed to retrieve display resolution
[0002.490] Could not load/initialize BMP blob...ignoring
[0002.540] decompressor handler not found
[0002.544] load_firmware_blob: Firmware blob loaded, entries=2
[0002.549] XUSB blob version 0 size 126464 @ 0x92cb328c
[0002.555] -------> se_aes_verify_sbk_clear: 747
[0002.560] se_aes_verify_sbk_clear: Error
[0002.564] SE operation failed
[0002.567] bl_battery_charging: connected to external power supply
[0002.576] display_console_ioctl: No display init
[0002.580] switch_backlight failed
[0002.590] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0002.597] MSC Partition not found
[0002.607] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0002.614] USP partition read failed!
[0002.617] blob_init: blob-partition USP header read failed
[0002.623] android_boot Unable to update recovery partition
[0002.628] kfs_getpartname: name = LNX
[0002.632] Loading kernel from LNX
[0002.721] load kernel from storage
[0002.731] decompressor handler not found
[0002.765] Successfully loaded kernel and ramdisk images
[0002.770] board ID = D78, board SKU = 2
[0002.774] display_resolution: No display init
[0002.779] Failed to retrieve display resolution
[0002.783] bmp blob is not loaded and initialized
[0002.788] Failed to display boot-logo
[0002.791] NCK carveout not present
[0002.795] Skipping dts_overrides
[0002.798] NCK carveout not present
[0002.807] Find /i2c@7000c000's alias i2c0
[0002.811] get eeprom at 1-a0, size 256, type 0
[0002.820] Find /i2c@7000c500's alias i2c2
[0002.824] get eeprom at 3-a0, size 256, type 0
[0002.828] get eeprom at 3-ae, size 256, type 0
[0002.832] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.838] I2C slave not started
[0002.841] I2C write failed
[0002.843] Writing offset failed
[0002.846] eeprom_init: EEPROM read failed
[0002.850] pm_ids_update: eeprom init failed
[0002.854] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.884] pm_ids_update: The pm board id is 3448-0002-400
[0002.891] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.900] pm_ids_update: pm id update successful
[0002.904] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.910] I2C slave not started
[0002.913] I2C write failed
[0002.915] Writing offset failed
[0002.918] eeprom_init: EEPROM read failed
[0002.922] pm_ids_update: eeprom init failed
[0002.952] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.958] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.966] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.972] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.980] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:cf:2b
[0002.986] Plugin Manager: Parse ODM data 0x000a4000
[0002.998] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.007] Add serial number:1423019109468 as DT property
[0003.016] "bpmp" doesn't exist, creating
[0003.021] Updated bpmp info to DTB
[0003.026] Updated initrd info to DTB
[0003.029] "proc-board" doesn't exist, creating
[0003.036] Updated board info to DTB
[0003.039] "pmu-board" doesn't exist, creating
[0003.045] Updated board info to DTB
[0003.048] "display-board" doesn't exist, creating
[0003.054] Updated board info to DTB
[0003.057] "reset" doesn't exist, creating
[0003.062] Updated reset info to DTB
[0003.066] display_console_ioctl: No display init
[0003.070] display_console_ioctl: No display init
[0003.075] display_console_ioctl: No display init
[0003.079] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt
[0003.114] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.119] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0003.136] Updated bootarg info to DTB
[0003.139] Adding uuid 000000016445c8461800000017060100 to DT
[0003.145] Adding eks info 0 to DT
[0003.151] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.157] Updated memory info to DTB
[0003.164] set vdd_core voltage to 1125 mv
[0003.168] setting 'vdd-core' regulator to 1125000 micro volts
[0003.174] Found secure-pmc; disable BPMP
U-Boot 2020.04-g46e4604c78 (Jul 26 2021 - 12:09:42 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM:  4 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  2  0
Tegra210 (P3450-0000) # MC:   sdhci@700b480p: LKH/k+鷼?样
It seem the key hited? And the design for debug uart pin is floating.How can I shield the key to stop autoboot and make the autoboot continue.
Thank you very much!
This is TX2NX, It seems normal.
[0000.215] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-c368a720)
[0000.223] I> Boot-device: eMMC
[0000.230] I> sdmmc bdev is already initialized
[0000.235] I> pmic: reset reason (nverc)	: 0x80
[0000.268] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.288] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.294] W> No valid slot number is found in scratch register
[0000.300] W> Return default slot: _a
[0000.303] I> A/B: bin_type (16) slot 0
[0000.307] I> Loading partition bpmp-fw at 0xd7800000
[0000.312] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.317] I> Addr: 0xd7800000, start-block: 29417480, num_blocks: 1
[0000.342] I> Binary(16) of size 534416 is loaded @ 0xd7800000
[0000.347] W> No valid slot number is found in scratch register
[0000.353] W> Return default slot: _a
[0000.356] I> A/B: bin_type (17) slot 0
[0000.360] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.365] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.371] I> Addr: 0xd79f0000, start-block: 29419896, num_blocks: 1
[0000.390] I> Binary(17) of size 113248 is loaded @ 0xd79e4400
[0000.418] I> Loading SCE-FW ...
[0000.421] W> No valid slot number is found in scratch register
[0000.427] W> Return default slot: _a
[0000.430] I> A/B: bin_type (12) slot 0
[0000.434] I> Loading partition sce-fw at 0xd7300000
[0000.438] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.444] I> Addr: 0xd7300000, start-block: 29423992, num_blocks: 1
[0000.463] I> Binary(12) of size 125632 is loaded @ 0xd7300000
[0000.468] I> Init SCE
[0000.471] I> Loading APE-FW ...
[0000.474] W> No valid slot number is found in scratch register
[0000.480] W> Return default slot: _a
[0000.483] I> A/B: bin_type (11) slot 0
[0000.487] I> Loading partition adsp-fw at 0xd7400000
[0000.491] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.497] I> Addr: 0xd7400000, start-block: 29401096, num_blocks: 1
[0000.516] I> Binary(11) of size 77216 is loaded @ 0xd7400000
[0000.522] I> Copy BTCM section
[0000.525] W> No valid slot number is found in scratch register
[0000.530] W> Return default slot: _a
[0000.534] I> A/B: bin_type (13) slot 0
[0000.537] I> Loading partition cpu-bootloader at 0x96000000
[0000.543] I> Reading two headers - addr:0x96000000 blocks:1
[0000.548] I> Addr: 0x96000000, start-block: 29380616, num_blocks: 1
[0000.569] I> Binary(13) of size 308800 is loaded @ 0x96000000
[0000.575] W> No valid slot number is found in scratch register
[0000.581] W> Return default slot: _a
[0000.584] I> A/B: bin_type (20) slot 0
[0000.588] I> Loading partition bootloader-dtb at 0x85205400
[0000.593] I> Reading two headers - addr:0x85205400 blocks:1
[0000.599] I> Addr: 0x85205400, start-block: 29382664, num_blocks: 1
[0000.618] I> Binary(20) of size 192320 is loaded @ 0x85205400
[0000.624] W> No valid slot number is found in scratch register
[0000.630] W> Return default slot: _a
[0000.633] I> A/B: bin_type (14) slot 0
[0000.637] I> Loading partition secure-os at 0x85305600
[0000.642] I> Reading two headers - addr:0x85305600 blocks:1
[0000.647] I> Addr: 0x85305600, start-block: 29384712, num_blocks: 1
[0000.669] I> Binary(14) of size 402864 is loaded @ 0x85305600
[0000.677] I> TOS boot-params @ 0x85000000
[0000.681] I> TOS params prepared
[0000.684] I> Loading EKS ...
[0000.686] I> A/B: bin_type (15) slot 0
[0000.690] I> Loading partition eks at 0x85905800
[0000.695] I> Reading two headers - addr:0x85905800 blocks:1
[0000.700] I> Addr: 0x85905800, start-block: 29397000, num_blocks: 1
[0000.719] I> Binary(15) of size 1040 is loaded @ 0x85905800
[0000.724] I> EKB detected (length: 0x400) @ 0x85905800
[0000.729] I> Copied encrypted keys
[0000.733] I> boot profiler @ 0x175844000
[0000.737] I> boot profiler for TOS @ 0x175844000
[0000.742] I> Unhalting SCE
[0000.744] I> Primary Memory Start:80000000 Size:70000000
[0000.750] I> Extended Memory Start:f0110000 Size:856f0000
[0000.756] I> MB2(TBoot-BPMP) done
NOTICE:  BL31: Built : 12:15:17, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0000.978] I> Welcome to Cboot
[0000.980] I> Cboot Version: t186-00029e71
[0000.984] I> CPU-BL Params @ 0x175800000
[0000.988] I>  0) Base:0x00000000 Size:0x00000000
[0000.992] I>  1) Base:0x177f00000 Size:0x00100000
[0000.997] I>  2) Base:0x177e00000 Size:0x00100000
[0001.001] I>  3) Base:0x177d00000 Size:0x00100000
[0001.006] I>  4) Base:0x177c00000 Size:0x00100000
[0001.010] I>  5) Base:0x177b00000 Size:0x00100000
[0001.015] I>  6) Base:0x177800000 Size:0x00200000
[0001.020] I>  7) Base:0x177400000 Size:0x00400000
[0001.024] I>  8) Base:0x177a00000 Size:0x00100000
[0001.029] I>  9) Base:0x177300000 Size:0x00100000
[0001.033] I> 10) Base:0x176800000 Size:0x00800000
[0001.038] I> 11) Base:0x30000000 Size:0x00040000
[0001.042] I> 12) Base:0xf0000000 Size:0x00100000
[0001.046] I> 13) Base:0x30040000 Size:0x00001000
[0001.051] I> 14) Base:0x30048000 Size:0x00001000
[0001.055] I> 15) Base:0x30049000 Size:0x00001000
[0001.060] I> 16) Base:0x3004a000 Size:0x00001000
[0001.064] I> 17) Base:0x3004b000 Size:0x00001000
[0001.069] I> 18) Base:0x3004c000 Size:0x00001000
[0001.073] I> 19) Base:0x3004d000 Size:0x00001000
[0001.077] I> 20) Base:0x3004e000 Size:0x00001000
[0001.082] I> 21) Base:0x3004f000 Size:0x00001000
[0001.086] I> 22) Base:0x00000000 Size:0x00000000
[0001.091] I> 23) Base:0xf0100000 Size:0x00010000
[0001.095] I> 24) Base:0x00000000 Size:0x00000000
[0001.100] I> 25) Base:0x00000000 Size:0x00000000
[0001.104] I> 26) Base:0x00000000 Size:0x00000000
[0001.108] I> 27) Base:0x00000000 Size:0x00000000
[0001.113] I> 28) Base:0x84400000 Size:0x00400000
[0001.117] I> 29) Base:0x30000000 Size:0x00010000
[0001.122] I> 30) Base:0x178000000 Size:0x08000000
[0001.126] I> 31) Base:0x00000000 Size:0x00000000
[0001.131] I> 32) Base:0x176000000 Size:0x00600000
[0001.135] I> 33) Base:0x80000000 Size:0x70000000
[0001.140] I> 34) Base:0xf0110000 Size:0x856f0000
[0001.144] I> 35) Base:0x00000000 Size:0x00000000
[0001.149] I> 36) Base:0x00000000 Size:0x00000000
[0001.153] I> 37) Base:0x1772e0000 Size:0x00020000
[0001.157] I> 38) Base:0x84000000 Size:0x00400000
[0001.162] I> 39) Base:0x96000000 Size:0x02000000
[0001.166] I> 40) Base:0x85000000 Size:0x01200000
[0001.171] I> 41) Base:0x175800000 Size:0x00500000
[0001.175] I> 42) Base:0x00000000 Size:0x00000000
[0001.180] I> 43) Base:0x00000000 Size:0x00000000
[0001.184] GIC-SPI Target CPU: 4
[0001.187] Interrupts Init done
[0001.191] calling constructors
[0001.194] initializing heap
[0001.197] initializing threads
[0001.200] initializing timers
[0001.203] creating bootstrap completion thread
[0001.208] top of bootstrap2()
[0001.211] CPU: ARM Cortex A57
[0001.214] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.219] initializing platform
[0001.223] I> Bl_dtb @0x85205400
[0001.225] I> gpio framework initialized
[0001.231] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.239] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.247] I> GPIO framework and drivers are initialized.
[0001.252] I> Boot-device: eMMC
[0001.259] I> sdmmc bdev is already initialized
[0001.290] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0001.308] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.313] W> opt-in fuse is not set, skip fuse_burning
[0001.318] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.324] W> No valid slot number is found in scratch register
[0001.329] W> Return default slot: _a
[0001.339] I> A/B: bin_type (21) slot 0
[0001.342] I> Loading kernel-dtb from partition
[0001.347] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.364] I> Kernel_dtb @0x80000000
[0001.368] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.375] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.385] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.393] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.399] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.407] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.417] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.425] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.433] I> fixed regulator driver initialized
[0001.455] I> register 'maxim' power off handle
[0001.460] I> virtual i2c enabled
[0001.463] I> registered 'maxim,max77620' pmic
[0001.467] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.478] E> failed to read label property for node 149928: 13
[0001.484] E> failed to read reg property for node 150024: 13
[0001.491] E> failed to read reg property for node 150076: 13
[0001.498] E> failed to read label property for node 150160: 13
[0001.505] E> failed to read reg property for node 150228: 13
[0001.512] E> failed to read reg property for node 150300: 13
[0001.519] I> Find /i2c@c250000's alias i2c7
[0001.523] I> Reading eeprom i2c=7 address=0x50
[0001.552] I> Device at /i2c@c250000:0x50
[0001.556] I> Reading eeprom i2c=7 address=0x57
[0001.560] E> I2C: slave not found in slaves.
[0001.564] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.572] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.578] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.588] E> eeprom: Failed to read I2C slave device
[0001.592] I> Eeprom read failed 0x3526070d
[0001.597] I> Find /i2c@3160000's alias i2c0
[0001.601] I> Reading eeprom i2c=0 address=0x50
[0001.606] E> I2C: slave not found in slaves.
[0001.610] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.618] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.623] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.633] E> eeprom: Failed to read I2C slave device
[0001.638] I> Eeprom read failed 0x3526070d
[0001.642] I> Find /i2c@3180000's alias i2c2
[0001.646] I> Reading eeprom i2c=2 address=0x54
[0001.651] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.655] C> GPIO driver for chip_id 0x2 could not be found
[0001.661] E> cam_eeprom_read: Can't get gpio driver
[0001.665] I> Eeprom read failed 0x4d4d000d
[0001.669] I> Reading eeprom i2c=2 address=0x57
[0001.674] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.678] C> GPIO driver for chip_id 0x2 could not be found
[0001.684] E> cam_eeprom_read: Can't get gpio driver
[0001.688] I> Eeprom read failed 0x4d4d000d
[0001.692] I> create_pm_ids: id: 3636-0001-300-H, len: 15
[0001.697] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.721] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.732] I> regulator 'vdd-hdmi-5v0' already enabled
[0001.737] I> hdmi cable connected
[0001.741] I> setting 'vdd-pex-1v00' regulator to 1000000 micro volts
[0001.749] I> setting 'vdd-1v8' regulator to 1800000 micro volts
[0001.755] I> retrieved tmds range from prod_list_hdmi_soc
[0001.762] E> cannot find any other nvdisp nodes
[0001.781] I> edid read success
[0001.784] I> width = 1024, height = 600, frequency = 49000000
[0001.789] I> Best mode Width = 640, Height = 480, freq = 25174825
[0001.798] I> hdmi_enable, starting HDMI initialisation
[0001.806] I> hdmi_enable, HDMI initialisation complete
[0001.812] initializing target
[0001.815] calling apps_init()
[0001.819] starting app kernel_boot_app
[0001.841] I> found decompressor handler: lz4-legacy
[0001.845] I> decompressing BMP blob ...
[0001.857] I> Kernel type = Normal
[0001.860] I> ########## Fixed storage boot ##########
[0001.865] I> Loading kernel-bootctrl from partition
[0001.870] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0001.884] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0001.891] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0001.898] W> No valid slot number is found in scratch register
[0001.904] W> Return default slot: _a
[0001.907] I> A/B: bin_type (24) slot 0
[0001.923] I> Boot image size read from image header: 99085
[0001.928] I> Boot image load address: 0x80400000
[0001.933] I> Loading kernel from partition
[0001.937] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.880] I> Validate kernel ...
[0002.883] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0002.891] I> Decrypt the buffer ... [0002.894] W> tegrabl_decrypt_block: fuse (0x0) is not burnt to do encryption (0x4); skip decryption.
[0002.903] I> done
[0002.905] I> Checking boot.img header magic ... [0002.909] I> [OK]
[0002.911] I> kernel-dtb is already loaded
[0002.915] I> Validate kernel-dtb ...
[0002.918] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0002.925] I> Decrypt the buffer ... [0002.928] W> tegrabl_decrypt_block: fuse (0x0) is not burnt to do encryption (0x4); skip decryption.
[0002.937] I> done
[0002.939] I> Kernel hdr @0x80400000
[0002.942] I> Kernel dtb @0x80000000
[0002.946] I> decompressor handler not found
[0002.950] I> Copying kernel image (626821 bytes) from 0x80400800 to 0x80600000 ... [0002.957] I> Done
[0002.959] I> Move ramdisk (len: 0) from 0x8049a000 to 0x947d0000
[0002.966] I> Updated bpmp info to DTB
[0002.971] I> Ramdisk: Base: 0x947d0000; Size: 0x0
[0002.975] I> Updated initrd info to DTB
[0002.979] W> WARN: Fail to override "console=none" in commandline
[0002.985] I> Active rootfs suffix:
[0002.988] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0002.995] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.003] I> disabled_core_mask: 0xffffff0c
[0003.007] W> No valid slot number is found in scratch register
[0003.012] W> Return default slot: _a
[0003.016] I> Active slot suffix:
[0003.019] I> add_boot_slot_suffix: slot_suffix =
[0003.023] I> Linux Cmdline: console=ttyS0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2  video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt rootfs.slot_suffix= tegra_fbmem=0x140000@0x96085000 lut_mem=0x2008@0x96081000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1
[0003.070] I> Updated bootarg info to DTB
[0003.074] W> MAC addr invalid!
[0003.077] E> Failed to get WIFI MAC address
[0003.081] W> MAC addr invalid!
[0003.084] E> Failed to get Bluetooth MAC address
[0003.088] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3b:70:f5
[0003.095] E> Found no plugin manager ids in source DT
[0003.099] W> Add plugin manager ids from board info
[0003.104] W> "plugin-manager" doesn't exist, creating
[0003.109] W> "ids" doesn't exist, creating
[0003.113] W> "connection" doesn't exist, creating
[0003.118] W> "configs" doesn't exist, creating
[0003.122] I> create_pm_ids: id: 3636-0001-300-H, len: 15
[0003.127] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.138] I> Adding plugin-manager/ids/3636-0001-300=/i2c@c250000:module@0x50
[0003.145] W> "i2c@c250000" doesn't exist, creating
[0003.150] W> "module@0x50" doesn't exist, creating
[0003.156] I> Adding plugin-manager/ids/3636-0001-300-H
[0003.162] I> Adding plugin-manager/configs/3636-mem-type 00
[0003.167] I> Adding plugin-manager/configs/3636-power-config 00
[0003.173] I> Adding plugin-manager/configs/3636-misc-config 00
[0003.179] I> Adding plugin-manager/configs/3636-modem-config 00
[0003.185] I> Adding plugin-manager/configs/3636-touch-config 00
[0003.191] I> Adding plugin-manager/configs/3636-display-config 00
[0003.197] I> Adding plugin-manager/cvm
[0003.201] W> "chip-id" doesn't exist, creating
[0003.205] I> Adding plugin-manager/chip-id/A02P
[0003.209] W> "odm-data" doesn't exist, creating
[0003.214] I> Adding /chosen/plugin-manager/odm-data
[0003.222] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.228] I> added [base:0xf0200000, size:0x85600000] to /memory
[0003.234] I> added [base:0x175e00000, size:0x200000] to /memory
[0003.239] I> added [base:0x176600000, size:0x200000] to /memory
[0003.245] I> added [base:0x177000000, size:0x200000] to /memory
[0003.251] I> Updated memory info to DTB
[0003.255] E> add_disp_param: failed to get display params for du=1
[0003.262] W> "reset" doesn't exist, creating
[0003.266] W> "pmc-reset-reason" doesn't exist, creating
[0003.272] W> "pmic-reset-reason" doesn't exist, creating
[0003.278] I> Adding ecid(00000001640911c11000000009040180) to DT
[0003.283] I> disabled_core_mask: 0xffffff0c
[0003.292] I> Add serial number:1421621063214 as DT property
[0003.299] I> Plugin-manager override starting
[0003.304] I> node /plugin-manager/fragement@0 matches
[0003.312] I> node /plugin-manager/fragement@3 matches
[0003.325] I> Disable plugin-manager status in FDT
[0003.330] I> Plugin-manager override finished successfully
[0003.335] I> tegrabl_load_kernel_and_dtb: Done
[0003.345] I> Kernel EP: 0x80600000, DTB: 0x80000000
U-Boot 2020.04-g46e4604c78 (Jul 26 2021 - 12:10:58 -0700)
SoC: tegra186
Model: NVIDIA P3636-0001
Board: NVIDIA P3636-0001
DRAM:  3.8 GiB
MMC:   sdhci@3400000: 1, sdhci@3460000: 0
In:    serial
Out:   serial
Err:   serial
Net:
Warning: ethernet@2490000 using MAC address from ROM
eth0: ethernet@2490000
Hit any key to stop autoboot:  2  1  0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
This nano-sd, also normal.
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-80a468da)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x80
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x261feb
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.270] Read GPT from (4:0)
[0000.401] Csd NumOfBlocks=60661760
[0000.406] Set High speed to 1
[0000.417] Using GPT Primary to query partitions
[0000.422] Loading Tboot-CPU binary
[0000.431] Verifying TBC in OdmNonSecureSBK mode
[0000.441] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.448] Bootloader downloaded successfully.
[0000.452] Downloaded Tboot-CPU binary to 0xa0000258
[0000.457] MAX77620_GPIO5 configured
[0000.460] CPU power rail is up
[0000.463] CPU clock enabled
[0000.467] Performing RAM repair
[0000.470] Updating A64 Warmreset Address to 0xa00002e9
[0000.475] Loading NvTbootBootloaderDTB
[0000.500] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.565] Bootloader DTB Load Address: 0x83000000
[0000.570] Loading NvTbootKernelDTB
[0000.594] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.660] Kernel DTB Load Address: 0x83100000
[0000.665] Loading cboot binary
[0000.694] Verifying EBT in OdmNonSecureSBK mode
[0000.736] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.743] Bootloader downloaded successfully.
[0000.747] Read PT from (2:0)
[0000.763] Using BFS PT to query partitions
[0000.767] PT: Partition NCT NOT found !
[0000.770] Warning: Find Partition via PT Failed
[0000.775] Next binary entry address: 0x92c00258
[0000.779] BoardId: 3448
[0000.784] Overriding pmu board id with proc board id
[0000.788] Display board id is not available
[0000.817] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.869] /bpmp deleted
[0000.871] SC7EntryFw header found loaded at 0xff700000
[0001.061] OVR2 PMIC
[0001.063] Bpmp FW successfully loaded
[0001.067] WB0 init successfully at 0xff780000
[0001.072] Set NvDecSticky Bits
[0001.075] GSC2 address ff53fffc value c0edbbcc
[0001.082] GSC MC Settings done
[0001.085] TOS Image length 53680
[0001.088]  Monitor size 53680
[0001.091]  OS size 0
[0001.099] Secure Os AES-CMAC Verification Success!
[0001.103] TOS image cipher info: plaintext
[0001.107] Loading and Validation of Secure OS Successful
[0001.123] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.128] NvTbootPackSdramParams: start.
[0001.133] NvTbootPackSdramParams: done.
[0001.136] Tegraboot started after 52318 us
[0001.140] Basic modules init took 760000 us
[0001.144] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.150] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.155] Storage Device Read Time = 112 ms, Read Size = 2241 KB
[0001.161] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.167] Next stage binary read took 24713 us
[0001.171] Carveout took -36393 us
[0001.174] CPU initialization took 363424 us
[0001.178] Total time taken by TegraBoot 1111744 us
[0001.183] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):41d46a9cf
NOTICE:  BL31: Built : 21:18:12, Jun 25 2020
[0001.305] RamCode = 0
[0001.310] LPDDR4 Training: Read DT: Number of tables = 2
[0001.315] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.327] EMC Training Successful
[0001.330] 408000 not found in DVFS table
[0001.337] RamCode = 0
[0001.340] DT Write: emc-table@204000 succeeded
[0001.346] DT Write: emc-table@1600000 succeeded
[0001.350] LPDDR4 Training: Write DT: Number of tables = 2
[0001.391]
[0001.392] Debug Init done
[0001.395] Marked DTB cacheable
[0001.398] Bootloader DTB loaded at 0x83000000
[0001.403] Marked DTB cacheable
[0001.405] Kernel DTB loaded at 0x83100000
[0001.409] DeviceTree Init done
[0001.422] Pinmux applied successfully
[0001.427] gicd_base: 0x50041000
[0001.430] gicc_base: 0x50042000
[0001.433] Interrupts Init done
[0001.437] Using base:0x60005090 & irq:208 for tick-timer
[0001.442] Using base:0x60005098 for delay-timer
[0001.447] platform_init_timer: DONE
[0001.450] Timer(tick) Init done
[0001.454] osc freq = 38400 khz
[0001.458]
[0001.459] Welcome to L4T Cboot
[0001.462]
[0001.463] Cboot Version: 00.00.2018.01-t210-3a7ad565
[0001.468] calling constructors
[0001.471] initializing heap
[0001.474] initializing threads
[0001.477] initializing timers
[0001.480] creating bootstrap completion thread
[0001.484] top of bootstrap2()
[0001.487] CPU: ARM Cortex A57
[0001.490] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.495] initializing platform
[0001.502] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.507] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.511] Macronix QSPI chip present
[0001.515] SPI device register
[0001.518] init boot device
[0001.520] allocating memory for boot device(SPI)
[0001.525] registering boot device
[0001.544] sdmmc node status = okay
[0001.547] sdcard instance = 0
[0001.550] sdcard gpio handle 0x56
[0001.553] sdcard gpio pin 0xc9
[0001.556] sdcard gpio flags 0x0
[0001.559] vmmc-supply 0x99
[0001.562] Instance: 0
[0001.564] Allocating memory for context
[0001.568] enabling clock
[0001.570] sd card init
[0001.573] Check card present and stable
[0001.576] Send command 0
[0001.593] Send command 3
[0001.597] Set RCA for the card
[0001.600] Query card specific data by command 9
[0001.607] Parse CSD data
[0001.609] Send command 7
[0001.619] Calling sd device register
[0001.623] Init sdcard
[0001.625] Allocating memory for boot device
[0001.629] Registering user device
[0001.642] Enable APE clock
[0001.645] Un-powergate APE partition
[0001.648] of_register: registering tegra_udc to of_hal
[0001.653] of_register: registering inv20628-driver to of_hal
[0001.659] of_register: registering ads1015-driver to of_hal
[0001.665] of_register: registering lp8557-bl-driver to of_hal
[0001.670] of_register: registering bq2419x_charger to of_hal
[0001.676] of_register: registering bq27441_fuel_gauge to of_hal
[0001.688] gpio framework initialized
[0001.691] of_register: registering tca9539_gpio to of_hal
[0001.696] of_register: registering tca9539_gpio to of_hal
[0001.702] of_register: registering i2c_bus_driver to of_hal
[0001.707] of_register: registering i2c_bus_driver to of_hal
[0001.713] of_register: registering i2c_bus_driver to of_hal
[0001.718] pmic framework initialized
[0001.722] of_register: registering max77620_pmic to of_hal
[0001.727] regulator framework initialized
[0001.731] of_register: registering tps65132_bl_driver to of_hal
[0001.737] initializing target
[0001.743] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.751] board ID = D78, board SKU = 0
[0001.755] Skipping Z3!
[0001.760] fixed regulator driver initialized
[0001.777] initializing OF layer
[0001.780] NCK carveout not present
[0001.783] Skipping dts_overrides
[0001.787] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.804] I2C Bus Init done
[0001.807] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.817] I2C Bus Init done
[0001.820] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.830] I2C Bus Init done
[0001.833] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.843] I2C Bus Init done
[0001.846] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.856] I2C Bus Init done
[0001.859] of_children_init: Ops found for compatible string maxim,max77620
[0001.869] max77620_init using irq 118
[0001.874] register 'maxim,max77620' pmic
[0001.879] gpio_driver_register: register 'max77620-gpio' driver
[0001.885] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.895] I2C Bus Init done
[0001.899] NCK carveout not present
[0001.909] Find /i2c@7000c000's alias i2c0
[0001.913] get eeprom at 1-a0, size 256, type 0
[0001.922] Find /i2c@7000c500's alias i2c2
[0001.925] get eeprom at 3-a0, size 256, type 0
[0001.930] get eeprom at 3-ae, size 256, type 0
[0001.934] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.940] I2C slave not started
[0001.943] I2C write failed
[0001.945] Writing offset failed
[0001.948] eeprom_init: EEPROM read failed
[0001.952] pm_ids_update: eeprom init failed
[0001.956] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.986] pm_ids_update: The pm board id is 3448-0000-400
[0001.993] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.001] pm_ids_update: pm id update successful
[0002.005] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.011] I2C slave not started
[0002.014] I2C write failed
[0002.016] Writing offset failed
[0002.019] eeprom_init: EEPROM read failed
[0002.023] pm_ids_update: eeprom init failed
[0002.053] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.059] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.067] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.073] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.082] updating /chosen/nvidia,ethernet-mac node 00:04:4b:ec:32:1c
[0002.088] Plugin Manager: Parse ODM data 0x00094000
[0002.099] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.113] Find /i2c@7000c000's alias i2c0
[0002.117] get eeprom at 1-a0, size 256, type 0
[0002.126] Find /i2c@7000c500's alias i2c2
[0002.130] get eeprom at 3-a0, size 256, type 0
[0002.134] get eeprom at 3-ae, size 256, type 0
[0002.139] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.144] I2C slave not started
[0002.147] I2C write failed
[0002.150] Writing offset failed
[0002.153] eeprom_init: EEPROM read failed
[0002.157] pm_ids_update: eeprom init failed
[0002.161] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.191] pm_ids_update: The pm board id is 3448-0000-400
[0002.197] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.204] pm_ids_update: pm id update successful
[0002.209] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.214] I2C slave not started
[0002.217] I2C write failed
[0002.220] Writing offset failed
[0002.223] eeprom_init: EEPROM read failed
[0002.227] pm_ids_update: eeprom init failed
[0002.257] Add serial number:1423219107800 as DT property
[0002.265] Applying platform configs
[0002.271] platform-init is not present. Skipping
[0002.276] calling apps_init()
[0002.301] Found 14 GPT partitions in "sd0"
[0002.305] Proceeding to Cold Boot
[0002.309] starting app android_boot_app
[0002.312] Device state: unlocked
[0002.315] display console init
[0002.324] could not find regulator
[0002.327] hdmi cable connected
[0002.343] edid read success
[0002.345] width = 1024, height = 600, frequency = 49000000
[0002.351] Best mode Width = 640, Height = 480, freq = 25174825
[0002.358] tmds-cDT entry for leds-pwm not found
o[0002.366] nfig node not found
[0002.370] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.384] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.392] could not find regulator
[0002.395] could not find regulator
[0002.399] could not find regulator
[0002.427] using default cmu settings
[0002.431] dc_hdmi_enable, starting HDMI initialisation
[0002.437] dc_hdmi_enable, HDMI initialisation complete
[0002.442] list and configure display window
[0002.447] display console init completed
[0002.454] subnode volume_up is not found !
[0002.458] subnode back is not found !
[0002.462] subnode volume_down is not found !
[0002.466] subnode menu is not found !
[0002.469] Gpio keyboard init success
[0002.514] found decompressor handler: lz4-legacy
[0002.528] decompressing blob (type 1)...
[0002.562] load_bmp_blob: panelresolution=480 type=0
[0002.613] decompressor handler not found
[0002.617] load_firmware_blob: Firmware blob loaded, entries=2
[0002.623] -------> se_aes_verify_sbk_clear: 747
[0002.627] se_aes_verify_sbk_clear: Error
[0002.631] bl_battery_charging: connected to external power supply
[0002.639] xusb is supported
[0002.645] error while finding nvidia,portmap
[0003.149] xusb blob version 0 size 124416
[0003.153] firmware size 124416
[0003.157] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.170] xhci0: 64 bytes context size, 32-bit DMA
[0003.210] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.230] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.880] uhub0: 9 ports with 9 removable, self powered
[0004.880] failed to get HID devices
[0004.883] failed to init xhci or no usb device attached
[0004.894] device_query_partition_size: failed to open partition sd0:MSC !
[0004.900] MSC Partition not found
[0004.907] device_query_partition_size: failed to open partition sd0:USP !
[0004.913] USP partition read failed!
[0004.917] blob_init: blob-partition USP header read failed
[0004.922] android_boot Unable to update recovery partition
[0004.928] kfs_getpartname: name = LNX
[0004.931] Loading kernel from LNX
[0005.030] load kernel from storage
[0005.042] decompressor handler not found
[0005.099] Successfully loaded kernel and ramdisk images
[0005.106] load_bmp_blob: panelresolution=480 type=0
[0005.179] display bmp image done
[0005.182] NCK carveout not present
[0005.186] Skipping dts_overrides
[0005.189] NCK carveout not present
[0005.199] Find /i2c@7000c000's alias i2c0
[0005.203] get eeprom at 1-a0, size 256, type 0
[0005.212] Find /i2c@7000c500's alias i2c2
[0005.216] get eeprom at 3-a0, size 256, type 0
[0005.220] get eeprom at 3-ae, size 256, type 0
[0005.224] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.230] I2C slave not started
[0005.233] I2C write failed
[0005.235] Writing offset failed
[0005.238] eeprom_init: EEPROM read failed
[0005.242] pm_ids_update: eeprom init failed
[0005.246] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.276] pm_ids_update: The pm board id is 3448-0000-400
[0005.283] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0005.291] pm_ids_update: pm id update successful
[0005.296] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.301] I2C slave not started
[0005.304] I2C write failed
[0005.306] Writing offset failed
[0005.310] eeprom_init: EEPROM read failed
[0005.313] pm_ids_update: eeprom init failed
[0005.344] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.350] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.358] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.364] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.372] updating /chosen/nvidia,ethernet-mac node 00:04:4b:ec:32:1c
[0005.379] Plugin Manager: Parse ODM data 0x00094000
[0005.389] shim_cmdline_install: /chosen/bootargs: kmemleak=on earlycon=uart8250,mmio32,0x70006000
[0005.398] Add serial number:1423219107800 as DT property
[0005.407] "bpmp" doesn't exist, creating
[0005.412] Updated bpmp info to DTB
[0005.417] Updated initrd info to DTB
[0005.421] "proc-board" doesn't exist, creating
[0005.426] Updated board info to DTB
[0005.430] "pmu-board" doesn't exist, creating
[0005.435] Updated board info to DTB
[0005.439] "display-board" doesn't exist, creating
[0005.444] Updated board info to DTB
[0005.448] "reset" doesn't exist, creating
[0005.452] Updated reset info to DTB
[0005.456] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1
[0005.494] DTB cmdline: kmemleak=on earlycon=uart8250,mmio32,0x70006000
[0005.501] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.514] Updated bootarg info to DTB
[0005.518] Adding uuid 000000016445c8451400000004ff8580 to DT
[0005.524] Adding eks info 0 to DT
[0005.529] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.535] Updated memory info to DTB
[0005.544] set vdd_core voltage to 1075 mv
[0005.547] setting 'vdd-core' regulator to 1075000 micro volts
[0005.570] Found secure-pmc; disable BPMP
U-Boot 2016.07-ge6da093be3 (Jun 25 2020 - 21:18:08 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM:  4 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  1  0
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
844 bytes read in 141 ms (4.9 KiB/s)
1:	primary kernel
Retrieving file: /boot/initrd
5488163 bytes read in 352 ms (14.9 MiB/s)
Retrieving file: /boot/Image
34330632 bytes read in 1534 ms (21.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1  kmemleak=on earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
   reserving fdt memory region: addr=80000000 size=20000
   Using Device Tree in place at 0000000083100000, end 0000000083177846
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3456) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:25:44 PDT 2020
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] Found tegra_fbmem: 00140000@92cb4000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    1.464888] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.730840] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.738484] imx219 7-0010: board setup failed
[    1.766892] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.774524] imx219 8-0010: board setup failed
[    2.724167] cgroup: cgroup2: unknown option "nsdelegate"
[    4.545644] using random self ethernet address
[    4.550251] using random host ethernet address
[    4.580298] random: crng init done
[    4.583729] random: 7 urandom warning(s) missed due to ratelimiting
[    5.334338] using random self ethernet address
[    5.338874] using random host ethernet address
Ubuntu 18.04.4 LTS nano-desktop ttyS0
nano-desktop login:
The flash command is “sudo ./flash.sh jetson-nano-emmc mmcblk0p1”
please review each product design guide. Jetson NANO/NX/TX2 NX has 3 different document.
This looks like a hardware design problem.
Thanks for your reply. The is normal in nano (SD version), The hardware is same between SD version and EMMC version. Or how can i stop the key control.
