Jetson Nano was working until yesterday, now not booting
Hi, I’m a laboratory technician of UPV university (Spain). We’ve 6x Jetson nano for developing. Now we’ve a problem with one of them (bought Dec’19). Until yesterday was working. Now it isn’t booting. The boot led is green. But there isn’t any output in the HDMI port or keyboard activity. The ethernet port has no activity.
P/N: 945-13450-0000-000
S/N: 1422719008445
The release is:
R32 (release), REVISION: 4.4
I’ve tried to change the video/keyboard cables, the micro usb charge cable, the power charger 5V/3A that are working in the others jetson nano without any positive result.
Also I’ve fsck the filesystem of the microSD and is OK.
Please, any help?
Best regards.
A serial console boot log would help, and provides information even from early boot prior to Linux ever loading. See:
https://www.jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
Hello Linuxdev,
The board is A02 sorry. I’ve connected a serial cable with this output:
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-c536fca9)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x92deb
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] Read GPT from (4:0)
[0000.416] Csd NumOfBlocks=60973056
[0000.420] Set High speed to 1
[0000.429] Using GPT Primary to query partitions
[0000.434] Loading Tboot-CPU binary
[0000.444] Verifying TBC in OdmNonSecureSBK mode
[0000.454] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.461] Bootloader downloaded successfully.
[0000.465] Downloaded Tboot-CPU binary to 0xa0000258
[0000.470] MAX77620_GPIO5 configured
[0000.473] CPU power rail is up
[0000.476] CPU clock enabled
[0000.480] Performing RAM repair
[0000.483] Updating A64 Warmreset Address to 0xa00002e9
[0000.488] Loading NvTbootBootloaderDTB
[0000.512] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.585] Bootloader DTB Load Address: 0x83000000
[0000.590] Loading NvTbootKernelDTB
[0000.614] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.686] Kernel DTB Load Address: 0x83100000
[0000.691] Loading cboot binary
[0000.721] Verifying EBT in OdmNonSecureSBK mode
[0000.763] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.770] Bootloader downloaded successfully.
[0000.774] Read PT from (2:0)
[0000.790] Using BFS PT to query partitions
[0000.794] PT: Partition NCT NOT found !
[0000.797] Warning: Find Partition via PT Failed
[0000.802] Next binary entry address: 0x92c00258
[0000.806] BoardId: 3448
[0000.811] Overriding pmu board id with proc board id
[0000.816] Display board id is not available
[0000.844] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.900] /bpmp deleted
[0000.903] SC7EntryFw header found loaded at 0xff700000
[0001.097] OVR2 PMIC
[0001.099] Bpmp FW successfully loaded
[0001.104] WB0 init successfully at 0xff780000
[0001.108] Set NvDecSticky Bits
[0001.111] GSC2 address ff53fffc value c0edbbcc
[0001.118] GSC MC Settings done
[0001.121] TOS Image length 53680
[0001.124] Monitor size 53680
[0001.127] OS size 0
[0001.134] Secure Os AES-CMAC Verification Success!
[0001.139] TOS image cipher info: plaintext
[0001.142] Loading and Validation of Secure OS Successful
[0001.158] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.163] NvTbootPackSdramParams: start.
[0001.168] NvTbootPackSdramParams: done.
[0001.172] Tegraboot started after 52351 us
[0001.176] Basic modules init took 787724 us
[0001.180] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.185] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.191] Storage Device Read Time = 108 ms, Read Size = 2241 KB
[0001.197] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.202] Next stage binary read took 24631 us
[0001.206] Carveout took -36314 us
[0001.209] CPU initialization took 371944 us
[0001.213] Total time taken by TegraBoot 1147985 us
[0001.218] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):de895fd9e
NOTICE: BL31: Built : 12:23:48, Oct 16 2020
ERROR: Error initializing runtime service trusty_fast
[0001.340] RamCode = 0
[0001.345] LPDDR4 Training: Read DT: Number of tables = 2
[0001.350] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.363] EMC Training Successful
[0001.366] 408000 not found in DVFS table
[0001.372] RamCode = 0
[0001.376] DT Write: emc-table@204000 succeeded
[0001.381] DT Write: emc-table@1600000 succeeded
[0001.386] LPDDR4 Training: Write DT: Number of tables = 2
[0001.428]
[0001.429] Debug Init done
[0001.431] Marked DTB cacheable
[0001.434] Bootloader DTB loaded at 0x83000000
[0001.439] Marked DTB cacheable
[0001.442] Kernel DTB loaded at 0x83100000
[0001.446] DeviceTree Init done
[0001.459] Pinmux applied successfully
[0001.463] gicd_base: 0x50041000
[0001.467] gicc_base: 0x50042000
[0001.470] Interrupts Init done
[0001.474] Using base:0x60005090 & irq:208 for tick-timer
[0001.479] Using base:0x60005098 for delay-timer
[0001.483] platform_init_timer: DONE
[0001.487] Timer(tick) Init done
[0001.491] osc freq = 38400 khz
[0001.494]
[0001.496] Welcome to L4T Cboot
[0001.499]
[0001.500] Cboot Version: 00.00.2018.01-t210-4686ce50
[0001.505] calling constructors
[0001.508] initializing heap
[0001.510] initializing threads
[0001.513] initializing timers
[0001.516] creating bootstrap completion thread
[0001.520] top of bootstrap2()
[0001.523] CPU: ARM Cortex A57
[0001.526] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.531] initializing platform
[0001.539] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.543] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.547] Macronix QSPI chip present
[0001.551] SPI device register
[0001.554] init boot device
[0001.556] allocating memory for boot device(SPI)
[0001.561] registering boot device
[0001.570] sdmmc node status = okay
[0001.574] sdcard instance = 0
[0001.576] sdcard gpio handle 0x5b
[0001.580] sdcard gpio pin 0xc9
[0001.583] sdcard gpio flags 0x0
[0001.586] vmmc-supply 0x9e
[0001.588] Instance: 0
[0001.590] Allocating memory for context
[0001.594] enabling clock
[0001.597] sd card init
[0001.599] Check card present and stable
[0001.603] Send command 0
[0001.619] Send command 3
[0001.623] Set RCA for the card
[0001.626] Query card specific data by command 9
[0001.633] Parse CSD data
[0001.635] Send command 7
[0001.646] Calling sd device register
[0001.649] Init sdcard
[0001.651] Allocating memory for boot device
[0001.655] Registering user device
[0001.668] Enable APE clock
[0001.671] Un-powergate APE partition
[0001.675] of_register: registering tegra_udc to of_hal
[0001.680] of_register: registering inv20628-driver to of_hal
[0001.685] of_register: registering ads1015-driver to of_hal
[0001.691] of_register: registering lp8557-bl-driver to of_hal
[0001.697] of_register: registering bq2419x_charger to of_hal
[0001.702] of_register: registering bq27441_fuel_gauge to of_hal
[0001.714] gpio framework initialized
[0001.717] of_register: registering tca9539_gpio to of_hal
[0001.723] of_register: registering tca9539_gpio to of_hal
[0001.728] of_register: registering i2c_bus_driver to of_hal
[0001.733] of_register: registering i2c_bus_driver to of_hal
[0001.739] of_register: registering i2c_bus_driver to of_hal
[0001.745] pmic framework initialized
[0001.748] of_register: registering max77620_pmic to of_hal
[0001.754] regulator framework initialized
[0001.758] of_register: registering tps65132_bl_driver to of_hal
[0001.763] initializing target
[0001.769] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.777] board ID = D78, board SKU = 0
[0001.781] Skipping Z3!
[0001.786] fixed regulator driver initialized
[0001.804] initializing OF layer
[0001.807] NCK carveout not present
[0001.810] Skipping dts_overrides
[0001.814] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.831] I2C Bus Init done
[0001.834] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.844] I2C Bus Init done
[0001.847] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.857] I2C Bus Init done
[0001.860] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.870] I2C Bus Init done
[0001.873] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.883] I2C Bus Init done
[0001.886] of_children_init: Ops found for compatible string maxim,max77620
[0001.896] max77620_init using irq 118
[0001.901] register ‘maxim,max77620’ pmic
[0001.905] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.912] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.922] I2C Bus Init done
[0001.926] NCK carveout not present
[0001.935] Find /i2c@7000c000’s alias i2c0
[0001.939] get eeprom at 1-a0, size 256, type 0
[0001.948] Find /i2c@7000c500’s alias i2c2
[0001.952] get eeprom at 3-a0, size 256, type 0
[0001.956] get eeprom at 3-ae, size 256, type 0
[0001.961] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.966] I2C slave not started
[0001.969] I2C write failed
[0001.972] Writing offset failed
[0001.975] eeprom_init: EEPROM read failed
[0001.979] pm_ids_update: eeprom init failed
[0001.983] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.013] pm_ids_update: The pm board id is 3448-0000-200
[0002.020] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.028] pm_ids_update: pm id update successful
[0002.033] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.063] pm_ids_update: The pm board id is 3449-0000-200
[0002.069] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.077] pm_ids_update: pm id update successful
[0002.107] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.113] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.121] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.127] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.135] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:df:20
[0002.142] Plugin Manager: Parse ODM data 0x00094000
[0002.154] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.169] Find /i2c@7000c000’s alias i2c0
[0002.173] get eeprom at 1-a0, size 256, type 0
[0002.182] Find /i2c@7000c500’s alias i2c2
[0002.186] get eeprom at 3-a0, size 256, type 0
[0002.190] get eeprom at 3-ae, size 256, type 0
[0002.194] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.200] I2C slave not started
[0002.203] I2C write failed
[0002.205] Writing offset failed
[0002.208] eeprom_init: EEPROM read failed
[0002.212] pm_ids_update: eeprom init failed
[0002.216] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.246] pm_ids_update: The pm board id is 3448-0000-200
[0002.253] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.260] pm_ids_update: pm id update successful
[0002.264] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.294] pm_ids_update: The pm board id is 3449-0000-200
[0002.301] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.307] pm_ids_update: pm id update successful
[0002.338] Add serial number:1422619037814 as DT property
[0002.346] Applying platform configs
[0002.352] platform-init is not present. Skipping
[0002.357] calling apps_init()
[0002.382] Found 14 GPT partitions in “sd0”
[0002.386] Proceeding to Cold Boot
[0002.389] starting app android_boot_app
[0002.393] Device state: unlocked
[0002.396] display console init
[0002.404] could not find regulator
[0002.428] hdmi cable not connected
[0002.431] is_hdmi_needed: HDMI not connected, returning fDT entry for leds-pwm not found
a[0002.442] lse
[0002.444] hdmi is not connected
[0002.447] sor0 is not supported
[0002.450] display_console_init: no valid display out_type
[0002.458] subnode volume_up is not found !
[0002.462] subnode back is not found !
[0002.466] subnode volume_down is not found !
[0002.470] subnode menu is not found !
[0002.473] Gpio keyboard init success
[0002.517] found decompressor handler: lz4-legacy
[0002.532] decompressing blob (type 1)…
[0002.565] display_resolution: No display init
[0002.570] Failed to retrieve display resolution
[0002.574] Could not load/initialize BMP blob…ignoring
[0002.625] decompressor handler not found
[0002.629] load_firmware_blob: Firmware blob loaded, entries=2
[0002.635] -------> se_aes_verify_sbk_clear: 747
[0002.639] se_aes_verify_sbk_clear: Error
[0002.643] bl_battery_charging: connected to external power supply
[0002.650] xusb is supported
[0002.656] error while finding nvidia,portmap
[0003.160] xusb blob version 0 size 124416
[0003.164] firmware size 124416
[0003.169] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.176] xhci0: 64 bytes context size, 32-bit DMA
[0003.216] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.236] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.886] uhub0: 9 ports with 9 removable, self powered
[0004.886] failed to get HID devices
[0004.889] failed to init xhci or no usb device attached
[0004.897] display_console_ioctl: No display init
[0004.901] switch_backlight failed
[0004.907] device_query_partition_size: failed to open partition sd0:MSC !
[0004.914] MSC Partition not found
[0004.920] device_query_partition_size: failed to open partition sd0:USP !
[0004.927] USP partition read failed!
[0004.931] blob_init: blob-partition USP header read failed
[0004.936] android_boot Unable to update recovery partition
[0004.942] kfs_getpartname: name = LNX
[0004.945] Loading kernel from LNX
[0005.044] load kernel from storage
[0005.055] decompressor handler not found
[0005.113] Successfully loaded kernel and ramdisk images
[0005.119] display_resolution: No display init
[0005.124] Failed to retrieve display resolution
[0005.128] bmp blob is not loaded and initialized
[0005.133] Failed to display boot-logo
[0005.136] NCK carveout not present
[0005.139] Skipping dts_overrides
[0005.143] NCK carveout not present
[0005.152] Find /i2c@7000c000’s alias i2c0
[0005.156] get eeprom at 1-a0, size 256, type 0
[0005.165] Find /i2c@7000c500’s alias i2c2
[0005.169] get eeprom at 3-a0, size 256, type 0
[0005.173] get eeprom at 3-ae, size 256, type 0
[0005.178] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.183] I2C slave not started
[0005.186] I2C write failed
[0005.189] Writing offset failed
[0005.192] eeprom_init: EEPROM read failed
[0005.196] pm_ids_update: eeprom init failed
[0005.200] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.230] pm_ids_update: The pm board id is 3448-0000-200
[0005.237] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.245] pm_ids_update: pm id update successful
[0005.250] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.280] pm_ids_update: The pm board id is 3449-0000-200
[0005.286] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0005.294] pm_ids_update: pm id update successful
[0005.325] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.330] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.338] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.344] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.353] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:df:20
[0005.359] Plugin Manager: Parse ODM data 0x00094000
[0005.371] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0005.380] Add serial number:1422619037814 as DT property
[0005.389] “bpmp” doesn’t exist, creating
[0005.394] Updated bpmp info to DTB
[0005.399] Updated initrd info to DTB
[0005.402] “proc-board” doesn’t exist, creating
[0005.409] Updated board info to DTB
[0005.412] “pmu-board” doesn’t exist, creating
[0005.418] Updated board info to DTB
[0005.421] “display-board” doesn’t exist, creating
[0005.427] Updated board info to DTB
[0005.430] “reset” doesn’t exist, creating
[0005.435] Updated reset info to DTB
[0005.439] display_console_ioctl: No display init
[0005.443] display_console_ioctl: No display init
[0005.448] display_console_ioctl: No display init
[0005.452] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owne
[0005.486] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0005.492] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 cons
[0005.505] Updated bootarg info to DTB
[0005.509] Adding uuid 00000001644475c22400000007060380 to DT
[0005.514] Adding eks info 0 to DT
[0005.520] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.526] Updated memory info to DTB
[0005.532] Updated system-lp0-disable info to DTB
[0005.540] set vdd_core voltage to 1125 mv
[0005.543] setting ‘vdd-core’ regulator to 1125000 micro volts
[0005.566] Found secure-pmc; disable BPMP
U-Boot 2016.07-g7a7e3f476e (Oct 16 2020 - 12:23:42 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
844 bytes read in 510 ms (1000 Bytes/s)
1: primary kernel
Retrieving file: /boot/initrd
5487776 bytes read in 704 ms (7.4 MiB/s)
Retrieving file: /boot/Image
34332680 bytes read in 7865 ms (4.2 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lan
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 000000008317de85
Starting kernel …
“The boot is locked Starting kernel…”
Any suggestions?.
I don’t personally know enough to answer, but I noticed this, which might be related to “The boot is locked…”:
(I can’t really say though since this might actually not mean anything)
Is this an SD card model on a dev kit, or something else? Have there been any device tree changes?
Thanks for the reply @linuxdev. The card is a microSD in a development kit. I haven’t made any changes to the kernel or the device tree.
Would you be able to flash the Nano’s QSPI? You could avoid using that SD card to let it flash specifically for the JetPack with R32.4.4 (which is what is currently running). To start SDK Manager such that you can see old versions, and such that you can stay at R32.4.4:
sdkmanager --archivedversions
(then flash maintaining R32.4.4)
Thanks again @linuxdev. Flashing with the sdkmanager solve the problem (R32.4.4).
Please, if you can transfer the following suggestions to the team that has prepared the manuals: make it clear that you have to put the FRC jumper (at least in the nano) and that to finish the setup process the nano must have a monitor, keyboard and mouse connected like this as internet connection. It is not clear in the sdkmanager manual it seems that this can be done by usb.
Best regards.
Best regards.
Not quite sure what is your last comment here… the setup process can be done by usb interface with the host side help.
Hello @WayneWWW, after you flash the OS of the Nano with the sdkmanager you must configure the OS (Language, Keyboard Layout, Timezone, User/pass). For that you need keyboard, mouse, video, network connected to the Nano. Then you can continue flashing the SDK with the usb connection.
Best regards.
That part could be done by the oem config on the host.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/flashing.html#wwpID0E02C0HA
->To reconfigure the target device with oem-config
Connect the flash port to the ubuntu host and use console tool to open /dev/ttyACM0 on the host side.
Thanks for the answer @WayneWWW . It’s clear to me.
