Jetson fails to boot after being powered off over night
Hi all,
again facing more issues with the Jetson Nano,.
This is also the 2nd time this happened within a few days. After initial SD card setup and configuration of the device and a full day of work with it, including multiple reboots, it decides to hang at the NVIDIA Logo screen.
I have to say, I’m new to using Jetson Nano and Docker, but I’m not new to using Linux.
Can anyone please shine some light on what is happening?
I have extracted the boot trace from a serial connection.
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 06:03:10
Press CTRL-A Z for help on special keys
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-80a468da)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x101ee
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] Read GPT from (4:0)
[0000.655] Csd NumOfBlocks=250085376
[0000.660] Set High speed to 1
[0000.670] Using GPT Primary to query partitions
[0000.675] Loading Tboot-CPU binary
[0000.685] Verifying TBC in OdmNonSecureSBK mode
[0000.695] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.702] Bootloader downloaded successfully.
[0000.706] Downloaded Tboot-CPU binary to 0xa0000258
[0000.711] MAX77620_GPIO5 configured
[0000.714] CPU power rail is up
[0000.717] CPU clock enabled
[0000.721] Performing RAM repair
[0000.724] Updating A64 Warmreset Address to 0xa00002e9
[0000.729] Read GPT from (4:0)
[0000.737] Using GPT Primary to query partitions
[0000.742] Loading NvTbootBootloaderDTB
[0000.766] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.838] Bootloader DTB Load Address: 0x83000000
[0000.842] Read GPT from (4:0)
[0000.851] Using GPT Primary to query partitions
[0000.855] Loading NvTbootKernelDTB
[0000.880] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.951] Kernel DTB Load Address: 0x83100000
[0000.955] Read GPT from (4:0)
[0000.964] Using GPT Primary to query partitions
[0000.969] Loading cboot binary
[0000.998] Verifying EBT in OdmNonSecureSBK mode
[0001.040] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.047] Bootloader downloaded successfully.
[0001.051] Read GPT from (4:0)
[0001.060] Using GPT Primary to query partitions
[0001.064] Read PT from (2:0)
[0001.080] Using BFS PT to query partitions
[0001.084] PT: Partition NCT NOT found !
[0001.088] Warning: Find Partition via PT Failed
[0001.092] Next binary entry address: 0x92c00258
[0001.096] BoardId: 3448
[0001.101] Overriding pmu board id with proc board id
[0001.106] Display board id is not available
[0001.110] Read GPT from (4:0)
[0001.119] Using GPT Primary to query partitions
[0001.147] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.203] /bpmp deleted
[0001.205] SC7EntryFw header found loaded at 0xff700000
[0001.393] OVR2 PMIC
[0001.395] Bpmp FW successfully loaded
[0001.399] Read GPT from (4:0)
[0001.407] Using GPT Primary to query partitions
[0001.412] WB0 init successfully at 0xff780000
[0001.417] Set NvDecSticky Bits
[0001.420] GSC2 address ff53fffc value c0edbbcc
[0001.427] GSC MC Settings done
[0001.429] Read GPT from (4:0)
[0001.438] Using GPT Primary to query partitions
[0001.443] TOS Image length 53680
[0001.446] Monitor size 53680
[0001.449] OS size 0
[0001.456] Secure Os AES-CMAC Verification Success!
[0001.461] TOS image cipher info: plaintext
[0001.465] Loading and Validation of Secure OS Successful
[0001.480] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.485] NvTbootPackSdramParams: start.
[0001.490] NvTbootPackSdramParams: done.
[0001.494] Tegraboot started after 52318 us
[0001.498] Basic modules init took 1098281 us
[0001.502] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.507] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.513] Storage Device Read Time = 125 ms, Read Size = 2359 KB
[0001.519] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.524] Next stage binary read took 24400 us
[0001.528] Carveout took -49414 us
[0001.532] CPU initialization took 404623 us
[0001.536] Total time taken by TegraBoot 1477890 us
[0001.540] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 08:56:32, Feb 19 2022
ERROR: Error initializing runtime service trusty_fast
[0001.662] RamCode = 0
[0001.667] LPDDR4 Training: Read DT: Number of tables = 2
[0001.672] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.685] EMC Training Successful
[0001.688] 408000 not found in DVFS table
[0001.694] RamCode = 0
[0001.698] DT Write: emc-table@204000 succeeded
[0001.703] DT Write: emc-table@1600000 succeeded
[0001.707] LPDDR4 Training: Write DT: Number of tables = 2
[0001.757]
[0001.758] Debug Init done
[0001.761] Marked DTB cacheable
[0001.764] Bootloader DTB loaded at 0x83000000
[0001.769] Marked DTB cacheable
[0001.771] Kernel DTB loaded at 0x83100000
[0001.775] DeviceTree Init done
[0001.788] Pinmux applied successfully
[0001.793] gicd_base: 0x50041000
[0001.796] gicc_base: 0x50042000
[0001.799] Interrupts Init done
[0001.803] Using base:0x60005090 & irq:208 for tick-timer
[0001.809] Using base:0x60005098 for delay-timer
[0001.813] platform_init_timer: DONE
[0001.817] Timer(tick) Init done
[0001.820] osc freq = 38400 khz
[0001.824]
[0001.825] Welcome to L4T Cboot
[0001.828]
[0001.829] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.834] calling constructors
[0001.837] initializing heap
[0001.840] initializing threads
[0001.843] initializing timers
[0001.846] creating bootstrap completion thread
[0001.850] top of bootstrap2()
[0001.853] CPU: ARM Cortex A57
[0001.856] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.861] initializing platform
[0001.868] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.872] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.877] Macronix QSPI chip present
[0001.880] SPI device register
[0001.883] init boot device
[0001.886] allocating memory for boot device(SPI)
[0001.890] registering boot device
[0001.900] sdmmc node status = okay
[0001.903] sdcard instance = 0
[0001.906] sdmmc cd-inverted
[0001.909] sdcard gpio handle 0x5b
[0001.912] sdcard gpio pin 0xc9
[0001.915] sdcard gpio flags 0x0
[0001.918] vmmc-supply 0x9d
[0001.920] Instance: 0
[0001.923] Allocating memory for context
[0001.926] enabling clock
[0001.929] sd card init
[0001.931] Check card present and stable
[0001.935] Send command 0
[0001.951] Send command 3
[0001.956] Set RCA for the card
[0001.958] Query card specific data by command 9
[0001.965] Parse CSD data
[0001.967] Send command 7
[0001.978] Calling sd device register
[0001.981] Init sdcard
[0001.983] Allocating memory for boot device
[0001.987] Registering user device
[0002.001] Enable APE clock
[0002.003] Un-powergate APE partition
[0002.007] of_register: registering tegra_udc to of_hal
[0002.012] of_register: registering inv20628-driver to of_hal
[0002.017] of_register: registering ads1015-driver to of_hal
[0002.023] of_register: registering lp8557-bl-driver to of_hal
[0002.029] of_register: registering bq2419x_charger to of_hal
[0002.034] of_register: registering bq27441_fuel_gauge to of_hal
[0002.046] gpio framework initialized
[0002.049] of_register: registering tca9539_gpio to of_hal
[0002.055] of_register: registering tca9539_gpio to of_hal
[0002.060] of_register: registering i2c_bus_driver to of_hal
[0002.066] of_register: registering i2c_bus_driver to of_hal
[0002.071] of_register: registering i2c_bus_driver to of_hal
[0002.077] pmic framework initialized
[0002.080] of_register: registering max77620_pmic to of_hal
[0002.086] regulator framework initialized
[0002.090] of_register: registering tps65132_bl_driver to of_hal
[0002.095] initializing target
[0002.101] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0002.109] board ID = D78, board SKU = 0
[0002.113] Skipping Z3!
[0002.118] fixed regulator driver initialized
[0002.136] initializing OF layer
[0002.139] NCK carveout not present
[0002.142] Skipping dts_overrides
[0002.146] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.163] I2C Bus Init done
[0002.165] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.176] I2C Bus Init done
[0002.178] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.189] I2C Bus Init done
[0002.191] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.202] I2C Bus Init done
[0002.204] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.215] I2C Bus Init done
[0002.217] of_children_init: Ops found for compatible string maxim,max77620
[0002.227] max77620_init using irq 118
[0002.232] register ‘maxim,max77620’ pmic
[0002.237] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.243] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.253] I2C Bus Init done
[0002.257] NCK carveout not present
[0002.266] Find /i2c@7000c000’s alias i2c0
[0002.270] get eeprom at 1-a0, size 256, type 0
[0002.279] Find /i2c@7000c500’s alias i2c2
[0002.283] get eeprom at 3-a0, size 256, type 0
[0002.287] get eeprom at 3-ae, size 256, type 0
[0002.292] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.297] I2C slave not started
[0002.300] I2C write failed
[0002.302] Writing offset failed
[0002.306] eeprom_init: EEPROM read failed
[0002.309] pm_ids_update: eeprom init failed
[0002.314] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.344] pm_ids_update: The pm board id is 3448-0000-402
[0002.350] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.359] pm_ids_update: pm id update successful
[0002.363] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.394] pm_ids_update: The pm board id is 3449-0000-400
[0002.400] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.408] pm_ids_update: pm id update successful
[0002.438] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.444] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.452] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.458] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.466] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:9e:ae
[0002.472] Plugin Manager: Parse ODM data 0x00094000
[0002.485] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.499] Find /i2c@7000c000’s alias i2c0
[0002.503] get eeprom at 1-a0, size 256, type 0
[0002.512] Find /i2c@7000c500’s alias i2c2
[0002.516] get eeprom at 3-a0, size 256, type 0
[0002.520] get eeprom at 3-ae, size 256, type 0
[0002.525] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.530] I2C slave not started
[0002.533] I2C write failed
[0002.536] Writing offset failed
[0002.539] eeprom_init: EEPROM read failed
[0002.542] pm_ids_update: eeprom init failed
[0002.547] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.577] pm_ids_update: The pm board id is 3448-0000-402
[0002.583] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.590] pm_ids_update: pm id update successful
[0002.594] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.625] pm_ids_update: The pm board id is 3449-0000-400
[0002.631] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.638] pm_ids_update: pm id update successful
[0002.668] Add serial number:1420921008944 as DT property
[0002.676] Applying platform configs
[0002.682] platform-init is not present. Skipping
[0002.687] calling apps_init()
[0002.712] Found 14 GPT partitions in “sd0”
[0002.716] Proceeding to Cold Boot
[0002.719] starting app android_boot_app
[0002.723] Device state: unlocked
[0002.726] display console init
[0002.734] could not find regulator
[0002.738] hdmi cable connected
[0002.753] edid read success
[0002.769] DT entry for leds-pwm not found
[0002.773] edid read success
[0002.776] width = 640, height = 480, frequency = 25174825
[0002.781] width = 640, height = 480, frequency = 25174825
[0002.786] width = 640, height = 480, frequency = 25174825
[0002.792] width = 640, height = 480, frequency = 25174825
[0002.797] width = 1920, height = 1080, frequency = 148500000
[0002.803] width = 1280, height = 720, frequency = 74250000
[0002.808] width = 1280, height = 720, frequency = 74250000
[0002.814] width = 1920, height = 1080, frequency = 148351648
[0002.819] width = 1280, height = 720, frequency = 74175824
[0002.825] width = 1920, height = 1080, frequency = 148351648
[0002.830] width = 1280, height = 720, frequency = 74175824
[0002.836] width = 720, height = 576, frequency = 26973026
[0002.841] width = 720, height = 480, frequency = 26973026
[0002.847] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.854] tmds-config node not found
[0002.859] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regs
[0002.873] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.881] could not find regulator
[0002.884] could not find regulator
[0002.887] could not find regulator
[0002.916] using default cmu settings
[0002.919] dc_hdmi_enable, starting HDMI initialisation
[0002.926] dc_hdmi_enable, HDMI initialisation complete
[0002.931] list and configure display window
[0002.939] display console init completed
[0002.950] subnode volume_up is not found !
[0002.954] subnode back is not found !
[0002.958] subnode volume_down is not found !
[0002.962] subnode menu is not found !
[0002.966] Gpio keyboard init success
[0003.016] found decompressor handler: lz4-legacy
[0003.030] decompressing blob (type 1)…
[0003.100] load_bmp_blob: panelresolution=1080 type=3
[0003.105] -------> se_aes_verify_sbk_clear: 747
[0003.110] se_aes_verify_sbk_clear: Error
[0003.113] SE operation failed
[0003.116] bl_battery_charging: connected to external power supply
[0003.128] device_query_partition_size: failed to open partition sd0:MSC !
[0003.135] MSC Partition not found
[0003.141] device_query_partition_size: failed to open partition sd0:USP !
[0003.148] USP partition read failed!
[0003.152] blob_init: blob-partition USP header read failed
[0003.157] android_boot Unable to update recovery partition
[0003.162] kfs_getpartname: name = LNX
[0003.166] Loading kernel from LNX
[0003.309] load kernel from storage
[0003.321] decompressor handler not found
[0003.404] Successfully loaded kernel and ramdisk images
[0003.409] board ID = D78, board SKU = 0
[0003.414] sdmmc node status = okay
[0003.417] sdcard instance = 0
[0003.420] sdmmc cd-inverted
[0003.422] sdcard gpio handle 0x5b
[0003.426] sdcard gpio pin 0xc9
[0003.429] sdcard gpio flags 0x0
[0003.432] vmmc-supply 0x9d
[0003.434] cd_gpio_pin = 201
[0003.437] pin_state = 0
[0003.439] Found sdcard
[0003.442] SD-card IS present …
[0003.445] load_and_boot_kernel: SD card detected OK
[0003.450] load_bmp_blob: panelresolution=1080 type=3
[0003.947] display bmp image done
[0003.950] NCK carveout not present
[0003.953] Skipping dts_overrides
[0003.956] NCK carveout not present
[0003.966] Find /i2c@7000c000’s alias i2c0
[0003.970] get eeprom at 1-a0, size 256, type 0
[0003.979] Find /i2c@7000c500’s alias i2c2
[0003.982] get eeprom at 3-a0, size 256, type 0
[0003.987] get eeprom at 3-ae, size 256, type 0
[0003.991] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.997] I2C slave not started
[0004.000] I2C write failed
[0004.002] Writing offset failed
[0004.005] eeprom_init: EEPROM read failed
[0004.009] pm_ids_update: eeprom init failed
[0004.013] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.043] pm_ids_update: The pm board id is 3448-0000-402
[0004.050] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0004.059] pm_ids_update: pm id update successful
[0004.063] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.093] pm_ids_update: The pm board id is 3449-0000-400
[0004.099] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.107] pm_ids_update: pm id update successful
[0004.138] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.144] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.151] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.157] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.166] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:3c:9e:ae
[0004.172] Plugin Manager: Parse ODM data 0x00094000
[0004.184] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.193] Add serial number:1420921008944 as DT property
[0004.202] “bpmp” doesn’t exist, creating
[0004.207] Updated bpmp info to DTB
[0004.212] Updated initrd info to DTB
[0004.215] “proc-board” doesn’t exist, creating
[0004.221] Updated board info to DTB
[0004.225] “pmu-board” doesn’t exist, creating
[0004.231] Updated board info to DTB
[0004.234] “display-board” doesn’t exist, creating
[0004.240] Updated board info to DTB
[0004.243] “reset” doesn’t exist, creating
[0004.248] Updated reset info to DTB
[0004.251] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_inf
[0004.291] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.296] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=t
[0004.309] Updated bootarg info to DTB
[0004.313] Adding uuid 00000001642e12c310000000190702c0 to DT
[0004.319] Adding eks info 0 to DT
[0004.324] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.330] Updated memory info to DTB
[0004.338] set vdd_core voltage to 1075 mv
[0004.342] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.348] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Feb 19 2022 - 08:56:35 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, totalB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 42 ms (19.5 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7160134 bytes read in 340 ms (20.1 MiB/s)
Retrieving file: /boot/Image
Skipping primary for failure retrieving kernel
SCRIPT FAILED: continuing…
Card did not respond to voltage select!
starting USB…
Bus usb@7d000000: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
Bus xusb@70090000: Loading XUSB FW blob from RP4 partition …
SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
Firmware size 0
Firmware timestamp: 0x00000000, Version: d9.18 release
Falcon not stopped. Falcon state: 0x10
Failed to load XUSB firmware!: -5
XHCI: failed to initialize controller
probe failed, error -22
No working controllers found
USB is stopped. Please issue ‘usb start’ first.
Device 0: unknown device
starting USB…
Firmware size 0
Firmware already loaded, Falcon state 0x10
XUSB firmware already running: -17
probe failed, error -110
Warning: eth_rtl8169 using MAC address from ROM
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
missing environment variable: pxeuuid
Retrieving file: /boot/extlinux/pxelinux.cfg/01-48-b0-2d-3c-9e-ae
*** ERROR: serverip' not set Retrieving file: /boot/extlinux/pxelinux.cfg/00000000 *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: /boot/extlinux/pxelinux.cfg/000000 *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: /boot/extlinux/pxelinux.cfg/0000 *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: /boot/extlinux/pxelinux.cfg/00 *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: /boot/extlinux/pxelinux.cfg/default-arm-tegra210-p3450-0000 *** ERROR: serverip’ not set
*** ERROR: serverip' not set Retrieving file: /boot/extlinux/pxelinux.cfg/default-arm *** ERROR: serverip’ not set
*** ERROR: `serverip’ not set
Config file not found
starting USB…
Firmware size 0
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Tegra210 (P3450-0000) #
please use sdkmanager to reflash this board and see if it can still boot after that.
