Jetson Nano does not boot - power led switch off after Nvidia LOGO
Hi, I am new to the Jetson Nao, got it today.
When trying to boot, i have a problem. I tried with 3 different SD cards, one 128GB one 64GB on one 32GB.
With the first 2, the nano power led goes on, and switchs off after 5 seconds.
With the 32GB card, same problem, but I at least I can see the NVIDEA Logo.
I use the microUSB with a usb poersupply, I montor the current, it goes up to 0.27 A and then led goes off and power usage drops to 0.024 A
please find the uart log here :
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB1, 17:06:30
Press CTRL-A Z for help on special keys
�[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x2419e5
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.272] Invalid GPT Partition
[0000.287] Using BFS PT to query partitions
[0000.291] failed to load NvTbootTbootCpu from (2:0)
[0000.296] re-load NvTbootTbootCpu from (4:0)
[0000.426] Csd NumOfBlocks=62333952
[0000.485] Using GPT Primary to query partitions
[0000.495] Loading Tboot-CPU binary
[0000.872] Verifying TBC in OdmNonSecureSBK mode
[0000.882] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.889] Bootloader downloaded successfully.
[0000.893] Downloaded Tboot-CPU binary to 0xa0000258
[0000.898] MAX77620_GPIO5 configured
[0000.902] CPU power rail is up
[0000.905] CPU clock enabled
[0000.908] Performing RAM repair
[0000.911] Updating A64 Warmreset Address to 0xa00002e9
[0000.916] Loading NvTbootBootloaderDTB
[0002.227] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0002.292] Bootloader DTB Load Address: 0x83000000
[0002.297] Loading NvTbootKernelDTB
[0003.608] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0003.672] Kernel DTB Load Address: 0x83100000
[0003.683] Loading cboot binary
[0005.364] Verifying EBT in OdmNonSecureSBK mode
[0005.406] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0005.413] Bootloader downloaded successfully.
[0005.607] Using BFS PT to query partitions
[0005.611] Next binary entry address: 0x92c00258
[0005.615] BoardId: 3448
[0005.620] Overriding pmu board id with proc board id
[0005.625] Display board id is not available
[0007.123] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0007.175] /bpmp deleted
[0007.177] SC7EntryFw header found loaded at 0xff700000
[0007.365] OVR2 PMIC
[0007.367] Bpmp FW successfully loaded
[0007.385] WB0 init successfully at 0xff780000
[0007.389] Set NvDecSticky Bits
[0007.393] GSC2 address ff53fffc value c0edbbcc
[0007.399] GSC MC Settings done
[0007.407] TOS Image length 53680
[0007.410] Monitor size 53680
[0007.412] OS size 0
[0007.575] Secure Os AES-CMAC Verification Success!
[0007.580] TOS image cipher info: plaintext
[0007.584] Loading and Validation of Secure OS Successful
[0007.600] SC7 Entry Firmware - 0xff700000, 0x4000
[0007.604] NvTbootPackSdramParams: start.
[0007.609] NvTbootPackSdramParams: done.
[0007.613] Tegraboot started after 53279 us
[0007.617] Basic modules init took 5711353 us
[0007.621] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0007.626] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0007.632] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0007.637] Storage Device Read Time = 6748 ms, Read Size = 2306 KB
[0007.643] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0007.649] Next stage binary read took 1529624 us
[0007.653] Carveout took -1541301 us
[0007.657] CPU initialization took 2043422 us
[0007.661] Total time taken by TegraBoot 7743098 us
[0007.666] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 13:38:45, Nov 5 2019
ERROR: Error initializing runtime service trusty_fast
[0007.788] RamCode = 0
[0007.792] LPDDR4 Training: Read DT: Number of tables = 2
[0007.797] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0007.810] EMC Training Successful
[0007.813] 408000 not found in DVFS table
[0007.820] RamCode = 0
[0007.823] DT Write: emc-table@204000 succeeded
[0007.829] DT Write: emc-table@1600000 succeeded
[0007.833] LPDDR4 Training: Write DT: Number of tables = 2
[0008.030]
[0008.031] Debug Init done
[0008.033] Marked DTB cacheable
[0008.036] Bootloader DTB loaded at 0x83000000
[0008.041] Marked DTB cacheable
[0008.044] Kernel DTB loaded at 0x83100000
[0008.048] DeviceTree Init done
[0008.060] Pinmux applied successfully
[0008.064] gicd_base: 0x50041000
[0008.068] gicc_base: 0x50042000
[0008.071] Interrupts Init done
[0008.075] Using base:0x60005090 & irq:208 for tick-timer
[0008.080] Using base:0x60005098 for delay-timer
[0008.084] platform_init_timer: DONE
[0008.088] Timer(tick) Init done
[0008.091] osc freq = 38400 khz
[0008.096]
[0008.097] welcome to cboot
[0008.099]
[0008.100] Cboot Version: 00.00.2018.01-t210-21e03500
[0008.105] calling constructors
[0008.108] initializing heap
[0008.111] initializing threads
[0008.114] initializing timers
[0008.117] creating bootstrap completion thread
[0008.121] top of bootstrap2()
[0008.124] CPU: ARM Cortex A57
[0008.127] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0008.132] initializing platform
[0008.135] Scratch reg 37 & 271 initial value set..
[0008.141] cboot:secure-pmc present
[0008.144] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0008.149] ID LSB = 0x36, ID-CFI len = 194 bytes
[0008.153] Macronix QSPI chip present
[0008.157] SPI device register
[0008.160] init boot device
[0008.162] allocating memory for boot device(SPI)
[0008.167] registering boot device
[0008.176] sdmmc node status = okay
[0008.180] sdcard instance = 0
[0008.182] sdcard gpio handle 0x56
[0008.186] sdcard gpio pin 0xc9
[0008.189] sdcard gpio flags 0x0
[0008.192] vmmc-supply 0x99
[0008.194] Instance: 0
[0008.196] Allocating memory for context
[0008.200] enabling clock
[0008.203] sd card init
[0008.205] Check card present and stable
[0008.209] Send command 0
[0008.233] Send command 3
[0008.237] Set RCA for the card
[0008.240] Query card specific data by command 9
[0008.247] Parse CSD data
[0008.249] Send command 7
[0008.260] Calling sd device register
[0008.263] Init sdcard
[0008.265] Allocating memory for boot device
[0008.269] Registering user device
[0008.283] Enable APE clock
[0008.285] Un-powergate APE partition
[0008.289] of_register: registering tegra_udc to of_hal
[0008.294] of_register: registering tegra_udc to of_hal
[0008.299] of_register: registering inv20628-driver to of_hal
[0008.304] of_register: registering ads1015-driver to of_hal
[0008.310] of_register: registering lp8557-bl-driver to of_hal
[0008.316] of_register: registering bq2419x_charger to of_hal
[0008.321] of_register: registering cpc to of_hal
[0008.326] of_register: registering bq27441_fuel_gauge to of_hal
[0008.337] gpio framework initialized
[0008.341] of_register: registering tca9539_gpio to of_hal
[0008.346] of_register: registering tca9539_gpio to of_hal
[0008.351] of_register: registering i2c_bus_driver to of_hal
[0008.357] of_register: registering i2c_bus_driver to of_hal
[0008.363] of_register: registering i2c_bus_driver to of_hal
[0008.368] of_register: registering i2c_bus_driver to of_hal
[0008.374] pmic framework initialized
[0008.377] of_register: registering max77620_pmic to of_hal
[0008.383] regulator framework initialized
[0008.387] of_register: registering tps65132_bl_driver to of_hal
[0008.392] initializing target
[0008.398] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0008.407] fixed regulator driver initialized
[0008.424] initializing OF layer
[0008.427] NCK carveout not present
[0008.430] Skipping dts_overrides
[0008.434] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.451] I2C Bus Init done
[0008.453] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.463] I2C Bus Init done
[0008.466] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.476] I2C Bus Init done
[0008.479] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.489] I2C Bus Init done
[0008.492] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.502] I2C Bus Init done
[0008.505] of_children_init: Ops found for compatible string maxim,max77620
[0008.515] max77620_init using irq 118
[0008.520] register ‘maxim,max77620’ pmic
[0008.524] gpio_driver_register: register ‘max77620-gpio’ driver
[0008.530] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.541] I2C Bus Init done
[0008.544] NCK carveout not present
[0008.548] shim_invoke: No NCT, Calling dts updates
[0008.559] Find /i2c@7000c000’s alias i2c0
[0008.563] get eeprom at 1-a0, size 256, type 0
[0008.571] Find /i2c@7000c500’s alias i2c2
[0008.575] get eeprom at 3-a0, size 256, type 0
[0008.580] get eeprom at 3-ae, size 256, type 0
[0008.584] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.589] I2C slave not started
[0008.592] I2C write failed
[0008.595] Writing offset failed
[0008.598] eeprom_init: EEPROM read failed
[0008.602] pm_ids_update: eeprom init failed
[0008.606] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.636] pm_ids_update: The pm board id is 3448-0000-200
[0008.643] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0008.650] pm_ids_update: pm id update successful
[0008.655] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.685] pm_ids_update: The pm board id is 3449-0000-200
[0008.691] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0008.699] pm_ids_update: pm id update successful
[0008.730] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.735] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0008.744] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.749] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0008.758] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:2c:2e
[0008.764] Plugin Manager: Parse ODM data 0x00084000
[0008.775] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootw
[0008.796] Find /i2c@7000c000’s alias i2c0
[0008.800] get eeprom at 1-a0, size 256, type 0
[0008.808] Find /i2c@7000c500’s alias i2c2
[0008.812] get eeprom at 3-a0, size 256, type 0
[0008.817] get eeprom at 3-ae, size 256, type 0
[0008.821] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.826] I2C slave not started
[0008.829] I2C write failed
[0008.832] Writing offset failed
[0008.835] eeprom_init: EEPROM read failed
[0008.839] pm_ids_update: eeprom init failed
[0008.843] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.873] pm_ids_update: The pm board id is 3448-0000-200
[0008.880] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0008.887] pm_ids_update: pm id update successful
[0008.891] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.921] pm_ids_update: The pm board id is 3449-0000-200
[0008.928] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0008.935] pm_ids_update: pm id update successful
[0008.965] Chip UID is 000000016441f8400c00000005030000
[0008.970] Add serial number:14219190850030000003 as DT property
[0008.979] Applying platform configs
[0008.985] platform-init is not present. Skipping
[0008.990] calling apps_init()
[0009.015] Found 12 GPT partitions in “sd0”
[0009.019] Proceeding to Cold Boot
[0009.022] starting app android_boot_app
[0009.026] Device state: unlocked
[0009.029] display console init
[0009.037] could not find regulator
[0009.041] hdmi cable connected
[0009.056] edid read success
[0009.070] DT entry for leds-pwm not found
[0009.075] edid read success
[0009.078] width = 640, height = 480, frequency = 25174825
[0009.083] width = 640, height = 480, frequency = 25174825
[0009.089] width = 640, height = 480, frequency = 25174825
[0009.094] width = 640, height = 480, frequency = 25174825
[0009.100] width = 1920, height = 1080, frequency = 148500000
[0009.105] width = 1920, height = 1080, frequency = 148500000
[0009.111] width = 1920, height = 1080, frequency = 148351648
[0009.117] width = 1280, height = 720, frequency = 74175824
[0009.122] width = 720, height = 480, frequency = 26973026
[0009.127] width = 720, height = 480, frequency = 26973026
[0009.133] width = 1920, height = 1080, frequency = 148351648
[0009.138] width = 1280, height = 720, frequency = 74175824
[0009.144] width = 720, height = 576, frequency = 26973026
[0009.149] width = 720, height = 576, frequency = 26973026
[0009.155] width = 640, height = 480, frequency = 25174825
[0009.160] Best mode Width = 1920, Height = 1080, freq = 148351648
[0009.168] tmds-config node not found
[0009.172] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltageps
[0009.187] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0009.194] could not find regulator
[0009.197] could not find regulator
[0009.201] could not find regulator
[0009.229] using default cmu settings
[0009.233] dc_hdmi_enable, starting HDMI initialisation
[0009.239] dc_hdmi_enable, HDMI initialisation complete
[0009.244] list and configure display window
[0009.253] display console init completed
[0009.264] subnode volume_up is not found !
[0009.268] subnode back is not found !
[0009.271] subnode volume_down is not found !
[0009.275] subnode menu is not found !
[0009.279] Gpio keyboard init success
[0009.325] found decompressor handler: lz4-legacy
[0009.339] decompressing blob (type 1)…
[0009.374] load_bmp_blob: panelresolution=1080 type=3
[0009.427] decompressor handler not found
[0009.431] load_firmware_blob: Firmware blob loaded, entries=2
[0009.437] se_aes_verify_sbk_clear: Error
[0009.441] bl_battery_charging: connected to external power supply
[0009.448] xusb is supported
[0009.454] error while finding nvidia,portmap
[0009.459] could not find regulator
[0009.963] xusb blob version 0 size 124416
[0009.966] firmware size 124416
[0009.971] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0009.987] xhci0: 64 bytes context size, 32-bit DMA
[0010.027] usbus0: 5.0Gbps Super Speed USB v3.0
[0010.047] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on u0
[0010.697] uhub0: 9 ports with 9 removable, self powered
[0011.697] failed to get HID devices
[0011.700] failed to init xhci or no usb device attached
[0011.711] device_query_partition_size: failed to open partition sd0:MSC !
[0011.717] MSC Partition not found
[0011.724] device_query_partition_size: failed to open partition sd0:USP !
[0011.730] USP partition read failed!
[0011.734] blob_init: blob-partition USP header read failed
[0011.739] android_boot Unable to update recovery partition
[0011.745] kfs_getpartname: name = LNX
[0011.748] Loading kernel from LNX
[0011.808] Verifying boot image in OdmNonSecureSBK mode
[0011.852] kernel load address: 0x80080000, size: 482032 bytes
[0011.857] ramdisk load address: 0x84100000, size: 0 bytes
[0011.863] load kernel from storage
[0011.874] decompressor handler not found
[0011.932] Successfully loaded kernel and ramdisk images
[0011.938] load_bmp_blob: panelresolution=1080 type=3
[0012.433] display bmp image done
[0012.436] NCK carveout not present
[0012.439] Skipping dts_overrides
[0012.442] NCK carveout not present
[0012.446] shim_invoke: No NCT, Calling dts updates
[0012.457] Find /i2c@7000c000’s alias i2c0
[0012.461] get eeprom at 1-a0, size 256, type 0
[0012.469] Find /i2c@7000c500’s alias i2c2
[0012.473] get eeprom at 3-a0, size 256, type 0
[0012.478] get eeprom at 3-ae, size 256, type 0
[0012.482] pm_ids_update: Updating 1,a0, size 256, type 0
[0012.487] I2C slave not started
[0012.490] I2C write failed
[0012.493] Writing offset failed
[0012.496] eeprom_init: EEPROM read failed
[0012.500] pm_ids_update: eeprom init failed
[0012.504] pm_ids_update: Updating 3,a0, size 256, type 0
[0012.534] pm_ids_update: The pm board id is 3448-0000-200
[0012.541] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0012.549] pm_ids_update: pm id update successful
[0012.553] pm_ids_update: Updating 3,ae, size 256, type 0
[0012.583] pm_ids_update: The pm board id is 3449-0000-200
[0012.590] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0012.597] pm_ids_update: pm id update successful
[0012.628] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0012.634] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0012.642] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0012.648] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0012.656] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:2c:2e
[0012.663] Plugin Manager: Parse ODM data 0x00084000
[0012.673] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootw
[0012.688] Add serial number:14219190850030000003 as DT property
[0012.697] “bpmp” doesn’t exist, creating
[0012.703] Updated bpmp info to DTB
[0012.708] Updated initrd info to DTB
[0012.711] “proc-board” doesn’t exist, creating
[0012.717] Updated board info to DTB
[0012.720] “pmu-board” doesn’t exist, creating
[0012.726] Updated board info to DTB
[0012.729] “display-board” doesn’t exist, creating
[0012.735] Updated board info to DTB
[0012.738] “reset” doesn’t exist, creating
[0012.743] Updated reset info to DTB
[0012.746] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype
[0012.785] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console
[0012.797] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0012.810] Updated bootarg info to DTB
[0012.814] Adding uuid 000000016441f8400c00000005030000 to DT
[0012.820] Adding eks info 0 to DT
[0012.825] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0012.831] Updated memory info to DTB
[0012.837] Updated system-lp0-disable info to DTB
[0012.845] set vdd_core voltage to 1125 mv
[0012.849] setting ‘vdd-core’ regulator to 1125000 micro volts
[0012.867] could not find regulator
[0012.871] Found secure-pmc; disable BPMP
U-Boot 2016.07-gd917e08cec (Nov 05 2019 - 13:38:56 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 117 ms (5.9 KiB/s)
L4T boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
5562303 bytes read in 294 ms (18 MiB/s)
Retrieving file: /boot/Image
34179080 bytes read in 1538 ms (21.2 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resizt
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 0000000083177282
Starting kernel …
�ਮ�5z�� [/code]
hello nvidea21208,
you’ll need to power the developer kit with a good quality power supply,
please also refer to Getting Started With Jetson Nano Developer Kit, and check the Troubleshooting session.
thanks
