Jetson Nano Developer Kit (4gb) doesn't boot after System Update (only shows Nvidia Logo)
I recently got a Nvidia Jetson Nano Developer Kit (4gb), on the Jetson I loaded the associated image. After I set up everything, I was shown a system update which I ran. When the update was finished, I was told to restart the Jetson, which I did. When the Jetson was supposed to reboot, it simply stopped at the Nvidia logo, since then the Jetson no longer boots. I have already reloaded the image several times on the SD card but the Jetson always hangs in the same place and only shows the Nvidia logo.
Since I have not found any other question about this specific problem, I hope you can help me.
hello domi,
could you please setup serial console to gather bootloader messages for reference,
thanks
Hello Jerry, sorry for the late reply, here are the bootloader messages from the serial console.
I hope this is the correct information you need.
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-dd84d362)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x830e6
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.233] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI …
[0000.280] Read PT from (2:0)
[0000.296] Using BFS PT to query partitions
[0000.301] Loading Tboot-CPU binary
[0000.330] Verifying TBC in OdmNonSecureSBK mode
[0000.340] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.347] Bootloader downloaded successfully.
[0000.351] Downloaded Tboot-CPU binary to 0xa0000258
[0000.356] MAX77620_GPIO5 configured
[0000.359] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.374] BoardID = 3448, SKU = 0x0
[0000.377] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.381] Nano-SD: checking PT table on QSPI …
[0000.385] Loading NvTbootBootloaderDTB
[0000.452] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.532] Bootloader DTB Load Address: 0x83000000
[0000.536] BoardID = 3448, SKU = 0x0
[0000.539] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.543] Nano-SD: checking PT table on QSPI …
[0000.548] Loading NvTbootKernelDTB
[0000.614] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.693] Kernel DTB Load Address: 0x83100000
[0000.698] BoardID = 3448, SKU = 0x0
[0000.701] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.705] Nano-SD: checking PT table on QSPI …
[0000.711] Loading cboot binary
[0000.827] Verifying EBT in OdmNonSecureSBK mode
[0000.868] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.875] Bootloader downloaded successfully.
[0000.880] BoardID = 3448, SKU = 0x0
[0000.883] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.887] Nano-SD: checking PT table on QSPI …
[0000.891] PT: Partition NCT NOT found !
[0000.895] Warning: Find Partition via PT Failed
[0000.899] Next binary entry address: 0x92c00258
[0000.904] BoardId: 3448
[0000.908] Overriding pmu board id with proc board id
[0000.913] Display board id is not available
[0000.917] BoardID = 3448, SKU = 0x0
[0000.921] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.924] Nano-SD: checking PT table on QSPI …
[0001.029] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.089] /bpmp deleted
[0001.091] SC7EntryFw header found loaded at 0xff700000
[0001.286] OVR2 PMIC
[0001.288] Bpmp FW successfully loaded
[0001.292] BoardID = 3448, SKU = 0x0
[0001.295] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.299] Nano-SD: checking PT table on QSPI …
[0001.304] WB0 init successfully at 0xff780000
[0001.308] Set NvDecSticky Bits
[0001.312] GSC2 address ff53fffc value c0edbbcc
[0001.318] GSC MC Settings done
[0001.321] BoardID = 3448, SKU = 0x0
[0001.324] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.328] Nano-SD: checking PT table on QSPI …
[0001.333] TOS Image length 53680
[0001.336] Monitor size 53680
[0001.339] OS size 0
[0001.355] Secure Os AES-CMAC Verification Success!
[0001.359] TOS image cipher info: plaintext
[0001.363] Loading and Validation of Secure OS Successful
[0001.379] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.383] NvTbootPackSdramParams: start.
[0001.389] NvTbootPackSdramParams: done.
[0001.392] Tegraboot started after 51833 us
[0001.396] Basic modules init took 899913 us
[0001.400] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.406] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.411] Next stage binary read took 102860 us
[0001.416] Carveout took -126354 us
[0001.419] CPU initialization took 497943 us
[0001.423] Total time taken by TegraBoot 1374362 us
[0001.428] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 11:29:29, Jun 14 2021
ERROR: Error initializing runtime service trusty_fast
[0001.550] RamCode = 0
[0001.552] get_emc_table_offset: Can’t find emc-table node
[0001.557] LPDDR4 Training: Can’t find emc-table node
[0001.603]
[0001.604] Debug Init done
[0001.607] Marked DTB cacheable
[0001.610] Bootloader DTB loaded at 0x83000000
[0001.614] Marked DTB cacheable
[0001.617] Kernel DTB loaded at 0x83100000
[0001.621] DeviceTree Init done
[0001.634] Pinmux applied successfully
[0001.638] gicd_base: 0x50041000
[0001.642] gicc_base: 0x50042000
[0001.645] Interrupts Init done
[0001.649] Using base:0x60005090 & irq:208 for tick-timer
[0001.654] Using base:0x60005098 for delay-timer
[0001.659] platform_init_timer: DONE
[0001.662] Timer(tick) Init done
[0001.666] osc freq = 38400 khz
[0001.670]
[0001.671] Welcome to L4T Cboot
[0001.674]
[0001.675] Cboot Version: 00.00.2018.01-t210-39562017
[0001.680] calling constructors
[0001.683] initializing heap
[0001.686] initializing threads
[0001.689] initializing timers
[0001.691] creating bootstrap completion thread
[0001.696] top of bootstrap2()
[0001.699] CPU: ARM Cortex A57
[0001.702] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.706] initializing platform
[0001.714] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.718] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.723] Macronix QSPI chip present
[0001.726] SPI device register
[0001.729] init boot device
[0001.732] allocating memory for boot device(SPI)
[0001.736] registering boot device
[0001.745] QSPI bdev is already initialized
[0001.749] Enable APE clock
[0001.751] Un-powergate APE partition
[0001.755] of_register: registering tegra_udc to of_hal
[0001.760] of_register: registering inv20628-driver to of_hal
[0001.766] of_register: registering ads1015-driver to of_hal
[0001.771] of_register: registering lp8557-bl-driver to of_hal
[0001.777] of_register: registering bq2419x_charger to of_hal
[0001.783] of_register: registering bq27441_fuel_gauge to of_hal
[0001.794] gpio framework initialized
[0001.798] of_register: registering tca9539_gpio to of_hal
[0001.803] of_register: registering tca9539_gpio to of_hal
[0001.808] of_register: registering i2c_bus_driver to of_hal
[0001.814] of_register: registering i2c_bus_driver to of_hal
[0001.819] of_register: registering i2c_bus_driver to of_hal
[0001.825] pmic framework initialized
[0001.828] of_register: registering max77620_pmic to of_hal
[0001.834] regulator framework initialized
[0001.838] of_register: registering tps65132_bl_driver to of_hal
[0001.844] initializing target
[0001.850] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.858] board ID = D78, board SKU = 0
[0001.861] Skipping Z3!
[0001.866] fixed regulator driver initialized
[0001.885] initializing OF layer
[0001.888] NCK carveout not present
[0001.891] Skipping dts_overrides
[0001.896] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.913] I2C Bus Init done
[0001.915] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.926] I2C Bus Init done
[0001.928] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.939] I2C Bus Init done
[0001.941] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.952] I2C Bus Init done
[0001.954] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.965] I2C Bus Init done
[0001.967] of_children_init: Ops found for compatible string maxim,max77620
[0001.978] max77620_init using irq 118
[0001.983] register ‘maxim,max77620’ pmic
[0001.987] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.993] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.004] I2C Bus Init done
[0002.007] NCK carveout not present
[0002.017] Find /i2c@7000c000’s alias i2c0
[0002.021] get eeprom at 1-a0, size 256, type 0
[0002.030] Find /i2c@7000c500’s alias i2c2
[0002.034] get eeprom at 3-a0, size 256, type 0
[0002.038] get eeprom at 3-ae, size 256, type 0
[0002.042] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.048] I2C slave not started
[0002.051] I2C write failed
[0002.053] Writing offset failed
[0002.056] eeprom_init: EEPROM read failed
[0002.060] pm_ids_update: eeprom init failed
[0002.065] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.095] pm_ids_update: The pm board id is 3448-0000-400
[0002.102] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.110] pm_ids_update: pm id update successful
[0002.115] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.145] pm_ids_update: The pm board id is 3449-0000-400
[0002.151] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.159] pm_ids_update: pm id update successful
[0002.189] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.195] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.203] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.209] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.217] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0002.224] Plugin Manager: Parse ODM data 0x000a4000
[0002.237] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.252] Find /i2c@7000c000’s alias i2c0
[0002.256] get eeprom at 1-a0, size 256, type 0
[0002.265] Find /i2c@7000c500’s alias i2c2
[0002.268] get eeprom at 3-a0, size 256, type 0
[0002.273] get eeprom at 3-ae, size 256, type 0
[0002.277] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.283] I2C slave not started
[0002.286] I2C write failed
[0002.288] Writing offset failed
[0002.291] eeprom_init: EEPROM read failed
[0002.295] pm_ids_update: eeprom init failed
[0002.299] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.329] pm_ids_update: The pm board id is 3448-0000-400
[0002.336] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.343] pm_ids_update: pm id update successful
[0002.347] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.377] pm_ids_update: The pm board id is 3449-0000-400
[0002.383] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.390] pm_ids_update: pm id update successful
[0002.421] Add serial number:1422919145299 as DT property
[0002.429] Applying platform configs
[0002.435] platform-init is not present. Skipping
[0002.440] calling apps_init()
[0002.446] Couldn’t find GPT header
[0002.450] Proceeding to Cold Boot
[0002.453] starting app android_boot_app
[0002.457] Device state: unlocked
[0002.460] display console init
[0002.469] could not find regulator
[0002.472] hdmi cable connected
[0002.487] edid read success
[0002.505] DT entry for leds-pwm not found
[0002.509] edid read success
[0002.511] width = 640, height = 480, frequency = 25174825
[0002.517] width = 640, height = 480, frequency = 25174825
[0002.522] width = 640, height = 480, frequency = 25174825
[0002.528] width = 640, height = 480, frequency = 25174825
[0002.533] width = 1920, height = 1080, frequency = 148500000
[0002.539] width = 1280, height = 720, frequency = 74250000
[0002.544] width = 1920, height = 540, frequency = 74250000
[0002.550] width = 1920, height = 1080, frequency = 148351648
[0002.555] width = 1280, height = 720, frequency = 74175824
[0002.561] width = 1920, height = 1080, frequency = 148351648
[0002.566] width = 1280, height = 720, frequency = 74175824
[0002.572] width = 720, height = 576, frequency = 26973026
[0002.577] width = 720, height = 480, frequency = 26973026
[0002.583] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.590] tmds-config node not found
[0002.594] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.609] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.617] could not find regulator
[0002.620] could not find regulator
[0002.623] could not find regulator
[0002.652] using default cmu settings
[0002.655] dc_hdmi_enable, starting HDMI initialisation
[0002.661] dc_hdmi_enable, HDMI initialisation complete
[0002.666] list and configure display window
[0002.675] display console init completed
[0002.686] subnode volume_up is not found !
[0002.690] subnode back is not found !
[0002.694] subnode volume_down is not found !
[0002.698] subnode menu is not found !
[0002.702] Gpio keyboard init success
[0002.782] found decompressor handler: lz4-legacy
[0002.797] decompressing blob (type 1)…
[0002.867] load_bmp_blob: panelresolution=1080 type=3
[0002.941] decompressor handler not found
[0002.945] load_firmware_blob: Firmware blob loaded, entries=2
[0002.951] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.957] -------> se_aes_verify_sbk_clear: 747
[0002.961] se_aes_verify_sbk_clear: Error
[0002.965] SE operation failed
[0002.968] bl_battery_charging: connected to external power supply
[0002.980] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.988] MSC Partition not found
[0002.994] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.001] USP partition read failed!
[0003.005] blob_init: blob-partition USP header read failed
[0003.010] android_boot Unable to update recovery partition
[0003.016] kfs_getpartname: name = LNX
[0003.019] Loading kernel from LNX
[0003.029] Found 19 BFS partitions in “spiflash0”
[0003.350] load kernel from storage
[0003.355] decompressor handler not found
[0003.621] Successfully loaded kernel and ramdisk images
[0003.626] board ID = D78, board SKU = 0
[0003.631] sdmmc node status = okay
[0003.634] sdcard instance = 0
[0003.637] sdcard gpio handle 0x5a
[0003.641] sdcard gpio pin 0xc9
[0003.643] sdcard gpio flags 0x0
[0003.647] vmmc-supply 0x9d
[0003.649] cd_gpio_pin = 201
[0003.652] pin_state = 0
[0003.654] Found sdcard
[0003.656] SD-card IS present …
[0003.660] load_and_boot_kernel: SD card detected OK
[0003.665] load_bmp_blob: panelresolution=1080 type=3
[0004.161] display bmp image done
[0004.164] NCK carveout not present
[0004.168] Skipping dts_overrides
[0004.171] NCK carveout not present
[0004.181] Find /i2c@7000c000’s alias i2c0
[0004.185] get eeprom at 1-a0, size 256, type 0
[0004.194] Find /i2c@7000c500’s alias i2c2
[0004.197] get eeprom at 3-a0, size 256, type 0
[0004.202] get eeprom at 3-ae, size 256, type 0
[0004.206] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.212] I2C slave not started
[0004.215] I2C write failed
[0004.217] Writing offset failed
[0004.220] eeprom_init: EEPROM read failed
[0004.224] pm_ids_update: eeprom init failed
[0004.228] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.258] pm_ids_update: The pm board id is 3448-0000-400
[0004.265] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0004.274] pm_ids_update: pm id update successful
[0004.278] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.309] pm_ids_update: The pm board id is 3449-0000-400
[0004.315] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.323] pm_ids_update: pm id update successful
[0004.353] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.359] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.367] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.373] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.381] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0004.387] Plugin Manager: Parse ODM data 0x000a4000
[0004.401] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.409] Add serial number:1422919145299 as DT property
[0004.418] “bpmp” doesn’t exist, creating
[0004.424] Updated bpmp info to DTB
[0004.429] Updated initrd info to DTB
[0004.432] “proc-board” doesn’t exist, creating
[0004.438] Updated board info to DTB
[0004.442] “pmu-board” doesn’t exist, creating
[0004.448] Updated board info to DTB
[0004.451] “display-board” doesn’t exist, creating
[0004.457] Updated board info to DTB
[0004.461] “reset” doesn’t exist, creating
[0004.465] Updated reset info to DTB
[0004.469] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1
[0004.508] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.514] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.527] Updated bootarg info to DTB
[0004.530] Adding uuid 0000000164456809200000000ffc8240 to DT
[0004.536] Adding eks info 0 to DT
[0004.542] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.548] Updated memory info to DTB
[0004.556] set vdd_core voltage to 1075 mv
[0004.560] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.565] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Jun 14 2021 - 11:29:25 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano 2GB Developer Kit
Board: NVIDIA P3541-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 26 ms (31.3 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159841 bytes read in 328 ms (20.8 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 1503 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 00000000831843cf
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[0000.159] [L4T TegraBoot] (version 00.00.2018.01-l4t-dd84d362)
[0000.164] Processing in cold boot mode Bootloader 2
[0000.169] A02 Bootrom Patch rev = 1023
[0000.173] Power-up reason: software reset
[0000.176] No Battery Present
[0000.179] pmic max77620 reset reason
[0000.182] pmic max77620 NVERC : 0x0
[0000.186] RamCode = 0
[0000.188] Platform has DDR4 type RAM
[0000.191] max77620 disabling SD1 Remote Sense
[0000.195] Setting DDR voltage to 1125mv
[0000.199] Serial Number of Pmic Max77663: 0x830e6
[0000.207] Entering ramdump check
[0000.210] Get RamDumpCarveOut = 0x0
[0000.213] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.218] Last reboot was clean, booting normally!
[0000.223] Sdram initialization is successful
[0000.227] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.233] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.239] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.245] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.251] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.257] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.262] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.268] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.284] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.290] Platform-DebugCarveout: 0
[0000.294] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.299] Non secure mode, and RB not enabled.
[0000.304] BoardID = 3448, SKU = 0x0
[0000.307] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.311] Nano-SD: checking PT table on QSPI …
[0000.315] Read PT from (2:0)
[0000.331] Using BFS PT to query partitions
[0000.336] Loading Tboot-CPU binary
[0000.365] Verifying TBC in OdmNonSecureSBK mode
[0000.375] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.382] Bootloader downloaded successfully.
[0000.386] Downloaded Tboot-CPU binary to 0xa0000258
[0000.391] MAX77620_GPIO5 configured
[0000.394] CPU power rail is up
[0000.397] CPU clock enabled
[0000.401] Performing RAM repair
[0000.404] Updating A64 Warmreset Address to 0xa00002e9
[0000.409] BoardID = 3448, SKU = 0x0
[0000.412] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.416] Nano-SD: checking PT table on QSPI …
[0000.420] Loading NvTbootBootloaderDTB
[0000.487] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.567] Bootloader DTB Load Address: 0x83000000
[0000.571] BoardID = 3448, SKU = 0x0
[0000.575] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.578] Nano-SD: checking PT table on QSPI …
[0000.583] Loading NvTbootKernelDTB
[0000.649] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.729] Kernel DTB Load Address: 0x83100000
[0000.733] BoardID = 3448, SKU = 0x0
[0000.736] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.740] Nano-SD: checking PT table on QSPI …
[0000.746] Loading cboot binary
[0000.862] Verifying EBT in OdmNonSecureSBK mode
[0000.904] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.911] Bootloader downloaded successfully.
[0000.915] BoardID = 3448, SKU = 0x0
[0000.918] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.922] Nano-SD: checking PT table on QSPI …
[0000.927] PT: Partition NCT NOT found !
[0000.930] Warning: Find Partition via PT Failed
[0000.935] Next binary entry address: 0x92c00258
[0000.939] BoardId: 3448
[0000.944] Overriding pmu board id with proc board id
[0000.948] Display board id is not available
[0000.953] BoardID = 3448, SKU = 0x0
[0000.956] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.960] Nano-SD: checking PT table on QSPI …
[0001.065] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.124] /bpmp deleted
[0001.126] SC7EntryFw header found loaded at 0xff700000
[0001.322] OVR2 PMIC
[0001.323] Bpmp FW successfully loaded
[0001.327] BoardID = 3448, SKU = 0x0
[0001.330] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.334] Nano-SD: checking PT table on QSPI …
[0001.339] WB0 init successfully at 0xff780000
[0001.344] Set NvDecSticky Bits
[0001.347] GSC2 address ff53fffc value c0edbbcc
[0001.353] GSC MC Settings done
[0001.356] BoardID = 3448, SKU = 0x0
[0001.360] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.363] Nano-SD: checking PT table on QSPI …
[0001.369] TOS Image length 53680
[0001.372] Monitor size 53680
[0001.375] OS size 0
[0001.390] Secure Os AES-CMAC Verification Success!
[0001.394] TOS image cipher info: plaintext
[0001.398] Loading and Validation of Secure OS Successful
[0001.414] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.419] NvTbootPackSdramParams: start.
[00
[0000.949] Display board id is not available
[0001.324] Bpmp FW successfully loaded
[0001.354] GSC MC Settings done
[0001.364] Nano-SD: checking PT table on QSPI …
[0001.395] TOS image cipher info: plaintext
[0001.424] NvTbootPackSdramParams: done.
[0001.428] Tegraboot started after 86960 us
[0001.432] Basic modules init took 901092 us
[0001.436] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.441] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.447] Next stage binary read took 102860 us
[0001.451] Carveout took -126356 us
[0001.454] CPU initialization took 498062 us
[0001.458] Total time taken by TegraBoot 1375658 us
[0001.463] Starting CPU & Halting co-processor
[0001.586] RamCode = 0
[0001.588] get_emc_table_offset: Can’t find emc-table node
[0001.593] LPDDR4 Training: Can’t find emc-table node
[0001.639]
[0001.640] Debug Init done
[0001.643] Marked DTB cacheable
[0001.646] Bootloader DTB loaded at 0x83000000
[0001.651] Marked DTB cacheable
[0001.654] Kernel DTB loaded at 0x83100000
[0001.658] DeviceTree Init done
[0001.670] Pinmux applied successfully
[0001.675] gicd_base: 0x50041000
[0001.678] gicc_base: 0x50042000
[0001.681] Interrupts Init done
[0001.685] Using base:0x60005090 & irq:208 for tick-timer
[0001.691] Using base:0x60005098 for delay-timer
[0001.695] platform_init_timer: DONE
[0001.699] Timer(tick) Init done
[0001.702] osc freq = 38400 khz
[0001.706]
[0001.707] Welcome to L4T Cboot
[0001.710]
[0001.711] Cboot Version: 00.00.2018.01-t210-39562017
[0001.716] calling constructors
[0001.719] initializing heap
[0001.722] initializing threads
[0001.725] initializing timers
[0001.728] creating bootstrap completion thread
[0001.732] top of bootstrap2()
[0001.735] CPU: ARM Cortex A57
[0001.738] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.743] initializing platform
[0001.750] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.755] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.759] Macronix QSPI chip present
[0001.763] SPI device register
[0001.766] init boot device
[0001.768] allocating memory for boot device(SPI)
[0001.773] registering boot device
[0001.781] QSPI bdev is already initialized
[0001.785] Enable APE clock
[0001.788] Un-powergate APE partition
[0001.791] of_register: registering tegra_udc to of_hal
[0001.796] of_register: registering inv20628-driver to of_hal
[0001.802] of_register: registering ads1015-driver to of_hal
[0001.807] of_register: registering lp8557-bl-driver to of_hal
[0001.813] of_register: registering bq2419x_charger to of_hal
[0001.819] of_register: registering bq27441_fuel_gauge to of_hal
[0001.830] gpio framework initialized
[0001.834] of_register: registering tca9539_gpio to of_hal
[0001.839] of_register: registering tca9539_gpio to of_hal
[0001.845] of_register: registering i2c_bus_driver to of_hal
[0001.850] of_register: registering i2c_bus_driver to of_hal
[0001.856] of_register: registering i2c_bus_driver to of_hal
[0001.861] pmic framework initialized
[0001.865] of_register: registering max77620_pmic to of_hal
[0001.870] regulator framework initialized
[0001.874] of_register: registering tps65132_bl_driver to of_hal
[0001.880] initializing target
[0001.886] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.894] board ID = D78, board SKU = 0
[0001.898] Skipping Z3!
[0001.903] fixed regulator driver initialized
[0001.921] initializing OF layer
[0001.924] NCK carveout not present
[0001.928] Skipping dts_overrides
[0001.932] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.949] I2C Bus Init done
[0001.952] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.962] I2C Bus Init done
[0001.965] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.975] I2C Bus Init done
[0001.978] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.988] I2C Bus Init done
[0001.991] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.001] I2C Bus Init done
[0002.004] of_children_init: Ops found for compatible string maxim,max77620
[0002.014] max77620_init using irq 118
[0002.019] register ‘maxim,max77620’ pmic
[0002.023] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.030] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.040] I2C Bus Init done
[0002.044] NCK carveout not present
[0002.054] Find /i2c@7000c000’s alias i2c0
[0002.057] get eeprom at 1-a0, size 256, type 0
[0002.066] Find /i2c@7000c500’s alias i2c2
[0002.070] get eeprom at 3-a0, size 256, type 0
[0002.075] get eeprom at 3-ae, size 256, type 0
[0002.079] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.084] I2C slave not started
[0002.087] I2C write failed
[0002.090] Writing offset failed
[0002.093] eeprom_init: EEPROM read failed
[0002.097] pm_ids_update: eeprom init failed
[0002.101] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.131] pm_ids_update: The pm board id is 3448-0000-400
[0002.138] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.147] pm_ids_update: pm id update successful
[0002.151] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.181] pm_ids_update: The pm board id is 3449-0000-400
[0002.188] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.196] pm_ids_update: pm id update successful
[0002.226] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.232] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.240] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.246] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.254] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0002.260] Plugin Manager: Parse ODM data 0x000a4000
[0002.273] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.288] Find /i2c@7000c000’s alias i2c0
[0002.292] get eeprom at 1-a0, size 256, type 0
[0002.301] Find /i2c@7000c500’s alias i2c2
[0002.305] get eeprom at 3-a0, size 256, type 0
[0002.309] get eeprom at 3-ae, size 256, type 0
[0002.314] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.319] I2C slave not started
[0002.322] I2C write failed
[0002.325] Writing offset failed
[0002.328] eeprom_init: EEPROM read failed
[0002.332] pm_ids_update: eeprom init failed
[0002.336] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.366] pm_ids_update: The pm board id is 3448-0000-400
[0002.372] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.379] pm_ids_update: pm id update successful
[0002.384] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.414] pm_ids_update: The pm board id is 3449-0000-400
[0002.420] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.427] pm_ids_update: pm id update successful
[0002.457] Add serial number:1422919145299 as DT property
[0002.465] Applying platform configs
[0002.472] platform-init is not present. Skipping
[0002.476] calling apps_init()
[0002.482] Couldn’t find GPT header
[0002.487] Proceeding to Cold Boot
[0002.490] starting app android_boot_app
[0002.494] Device state: unlocked
[0002.497] display console init
[0002.505] could not find regulator
[0002.508] hdmi cable connected
[0002.524] edid read success
[0002.541] DT entry for leds-pwm not found
[0002.545] edid read success
[0002.548] width = 640, height = 480, frequency = 25174825
[0002.553] width = 640, height = 480, frequency = 25174825
[0002.559] width = 640, height = 480, frequency = 25174825
[0002.564] width = 640, height = 480, frequency = 25174825
[0002.569] width = 1920, height = 1080, frequency = 148500000
[0002.575] width = 1280, height = 720, frequency = 74250000
[0002.580] width = 1920, height = 540, frequency = 74250000
[0002.586] width = 1920, height = 1080, frequency = 148351648
[0002.592] width = 1280, height = 720, frequency = 74175824
[0002.597] width = 1920, height = 1080, frequency = 148351648
[0002.603] width = 1280, height = 720, frequency = 74175824
[0002.608] width = 720, height = 576, frequency = 26973026
[0002.613] width = 720, height = 480, frequency = 26973026
[0002.619] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.627] tmds-config node not found
[0002.631] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.645] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.653] could not find regulator
[0002.656] could not find regulator
[0002.660] could not find regulator
[0002.688] using default cmu settings
[0002.691] dc_hdmi_enable, starting HDMI initialisation
[0002.698] dc_hdmi_enable, HDMI initialisation complete
[0002.703] list and configure display window
[0002.711] display console init completed
[0002.723] subnode volume_up is not found !
[0002.727] subnode back is not found !
[0002.730] subnode volume_down is not found !
[0002.735] subnode menu is not found !
[0002.738] Gpio keyboard init success
[0002.819] found decompressor handler: lz4-legacy
[0002.833] decompressing blob (type 1)…
[0002.903] load_bmp_blob: panelresolution=1080 type=3
[0002.978] decompressor handler not found
[0002.981] load_firmware_blob: Firmware blob loaded, entries=2
[0002.987] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.993] -------> se_aes_verify_sbk_clear: 747
[0002.998] se_aes_verify_sbk_clear: Error
[0003.002] SE operation failed
[0003.004] bl_battery_charging: connected to external power supply
[0003.017] device_query_partition_size: failed to open partition spiflash0:MSC !
[0003.024] MSC Partition not found
[0003.030] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.037] USP partition read failed!
[0003.041] blob_init: blob-partition USP header read failed
[0003.046] android_boot Unable to update recovery partition
[0003.052] kfs_getpartname: name = LNX
[0003.055] Loading kernel from LNX
[0003.065] Found 19 BFS partitions in “spiflash0”
[0003.386] load kernel from storage
[0003.391] decompressor handler not found
[0003.658] Successfully loaded kernel and ramdisk images
[0003.663] board ID = D78, board SKU = 0
[0003.667] sdmmc node status = okay
[0003.671] sdcard instance = 0
[0003.673] sdcard gpio handle 0x5a
[0003.677] sdcard gpio pin 0xc9
[0003.680] sdcard gpio flags 0x0
[0003.683] vmmc-supply 0x9d
[0003.685] cd_gpio_pin = 201
[0003.688] pin_state = 0
[0003.690] Found sdcard
[0003.693] SD-card IS present …
[0003.696] load_and_boot_kernel: SD card detected OK
[0003.702] load_bmp_blob: panelresolution=1080 type=3
[0004.198] display bmp image done
[0004.201] NCK carveout not present
[0004.204] Skipping dts_overrides
[0004.207] NCK carveout not present
[0004.217] Find /i2c@7000c000’s alias i2c0
[0004.221] get eeprom at 1-a0, size 256, type 0
[0004.230] Find /i2c@7000c500’s alias i2c2
[0004.234] get eeprom at 3-a0, size 256, type 0
[0004.238] get eeprom at 3-ae, size 256, type 0
[0004.242] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.248] I2C slave not started
[0004.251] I2C write failed
[0004.253] Writing offset failed
[0004.256] eeprom_init: EEPROM read failed
[0004.260] pm_ids_update: eeprom init failed
[0004.264] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.295] pm_ids_update: The pm board id is 3448-0000-400
[0004.301] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0004.310] pm_ids_update: pm id update successful
[0004.315] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.345] pm_ids_update: The pm board id is 3449-0000-400
[0004.351] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.359] pm_ids_update: pm id update successful
[0004.389] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.395] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.403] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.409] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.417] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0004.424] Plugin Manager: Parse ODM data 0x000a4000
[0004.437] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.445] Add serial number:1422919145299 as DT property
[0004.454] “bpmp” doesn’t exist, creating
[0004.460] Updated bpmp info to DTB
[0004.465] Updated initrd info to DTB
[0004.468] “proc-board” doesn’t exist, creating
[0004.475] Updated board info to DTB
[0004.478] “pmu-board” doesn’t exist, creating
[0004.484] Updated board info to DTB
[0004.487] “display-board” doesn’t exist, creating
[0004.493] Updated board info to DTB
[0004.497] “reset” doesn’t exist, creating
[0004.502] Updated reset info to DTB
[0004.505] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1
[0004.544] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.550] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.563] Updated bootarg info to DTB
[0004.566] Adding uuid 0000000164456809200000000ffc8240 to DT
[0004.572] Adding eks info 0 to DT
[0004.578] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.584] Updated memory info to DTB
[0004.592] set vdd_core voltage to 1075 mv
[0004.596] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.602] Found secure-pmc; disable BPMP
SoC: tegra210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 1:1…
845 bytes read in 25 ms (32.2 KiB/s)
1: primary kernel
7159841 bytes read in 327 ms (20.9 MiB/s)
34338824 bytes read in 1502 ms (21.8 MiB/s)
Starting kernel …
[0000.566] Bootloader DTB Load Address: 0x83000000
[0000.574] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.728] Kernel DTB Load Address: 0x83100000
[0000.732] BoardID = 3448, SKU = 0x0
[0000.861] Verifying EBT in OdmNonSecureSBK mode
[0000.903] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.910] Bootloader downloaded successfully.
[0000.914] BoardID = 3448, SKU = 0x0
[0000.921] Nano-SD: checking PT table on QSPI …
[0000.926] PT: Partition NCT NOT found !
[0000.934] Next binary entry address: 0x92c00258
[0000.943] Overriding pmu board id with proc board id
[0000.952] BoardID = 3448, SKU = 0x0
[0000.955] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.959] Nano-SD: checking PT table on QSPI …
[0001.064] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.123] /bpmp deleted
[0001.321] OVR2 PMIC
[0001.326] BoardID = 3448, SKU = 0x0
[0001.333] Nano-SD: checking PT table on QSPI …
[0001.343] Set NvDecSticky Bits
[0001.359] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.368] TOS Image length 53680
[0001.371] Monitor size 53680
[0001.374] OS size 0
[0001.389] Secure Os AES-CMAC Verification Success!
[0001.418] NvTbootPackSdramParams: start.
[0001.423] NvTbootPackSdramParams: done.
[0001.427] Tegraboot started after 86963 us
[0001.431] Basic modules init took 900434 us
[0001.435] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.446] Next stage binary read took 102859 us
[0001.450] Carveout took -126353 us
[0001.454] CPU initialization took 497941 us
[0001.458] Total time taken by TegraBoot 1374881 us
[0001.462] Starting CPU & Halting co-processor
[0001.585] RamCode = 0
[0001.587] get_emc_table_offset: Can’t find emc-table node
[0001.592] LPDDR4 Training: Can’t find emc-table node
[0001.639]
[0001.642] Marked DTB cacheable
[0001.645] Bootloader DTB loaded at 0x83000000
[0001.650] Marked DTB cacheable
[0001.653] Kernel DTB loaded at 0x83100000
[0001.657] DeviceTree Init done
[0001.674] gicd_base: 0x50041000
[0001.690] Using base:0x60005098 for delay-timer
[0001.694] platform_init_timer: DONE
[0001.698] Timer(tick) Init done
[0001.705]
[0001.709]
[0001.721] initializing threads
[0001.724] initializing timers
[0001.727] creating bootstrap completion thread
[0001.731] top of bootstrap2()
[0001.734] CPU: ARM Cortex A57
[0001.737] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.742] initializing platform
[0001.749] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.754] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.758] Macronix QSPI chip present
[0001.762] SPI device register
[0001.765] init boot device
[0001.767] allocating memory for boot device(SPI)
[0001.772] registering boot device
[0001.780] QSPI bdev is already initialized
[0001.784] Enable APE clock
[0001.787] Un-powergate APE partition
[0001.790] of_register: registering tegra_udc to of_hal
[0001.801] of_register: registering ads1015-driver to of_hal
[0001.812] of_register: registering bq2419x_charger to of_hal
[0001.818] of_register: registering bq27441_fuel_gauge to of_hal
[0001.833] of_register: registering tca9539_gpio to of_hal
[0001.838] of_register: registering tca9539_gpio to of_hal
[0001.844] of_register: registering i2c_bus_driver to of_hal
[0001.849] of_register: registering i2c_bus_driver to of_hal
[0001.855] of_register: registering i2c_bus_driver to of_hal
[0001.864] of_register: registering max77620_pmic to of_hal
[0001.869] regulator framework initialized
[0001.873] of_register: registering tps65132_bl_driver to of_hal
[0001.879] initializing target
[0001.885] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.893] board ID = D78, board SKU = 0
[0001.897] Skipping Z3!
[0001.902] fixed regulator driver initialized
[0001.927] Skipping dts_overrides
[0001.931] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.948] I2C Bus Init done
[0001.951] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.961] I2C Bus Init done
[0001.964] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.974] I2C Bus Init done
[0001.977] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.987] I2C Bus Init done
[0001.990] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.000] I2C Bus Init done
[0002.003] of_children_init: Ops found for compatible string maxim,max77620
[0002.013] max77620_init using irq 118
[0002.018] register ‘maxim,max77620’ pmic
[0002.022] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.029] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.039] I2C Bus Init done
[0002.043] NCK carveout not present
[0002.053] Find /i2c@7000c000’s alias i2c0
[0002.065] Find /i2c@7000c500’s alias i2c2
[0002.069] get eeprom at 3-a0, size 256, type 0
[0002.074] get eeprom at 3-ae, size 256, type 0
[0002.078] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.083] I2C slave not started
[0002.086] I2C write failed
[0002.089] Writing offset failed
[0002.092] eeprom_init: EEPROM read failed
[0002.096] pm_ids_update: eeprom init failed
[0002.100] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.130] pm_ids_update: The pm board id is 3448-0000-400
[0002.137] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.146] pm_ids_update: pm id update successful
[0002.150] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.180] pm_ids_update: The pm board id is 3449-0000-400
[0002.187] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.195] pm_ids_update: pm id update successful
[0002.225] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.231] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.239] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.245] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.253] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0002.259] Plugin Manager: Parse ODM data 0x000a4000
[0002.272] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.287] Find /i2c@7000c000’s alias i2c0
[0002.291] get eeprom at 1-a0, size 256, type 0
[0002.300] Find /i2c@7000c500’s alias i2c2
[0002.304] get eeprom at 3-a0, size 256, type 0
[0002.313] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.318] I2C slave not started
[0002.321] I2C write failed
[0002.324] Writing offset failed
[0002.327] eeprom_init: EEPROM read failed
[0002.331] pm_ids_update: eeprom init failed
[0002.335] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.365] pm_ids_update: The pm board id is 3448-0000-400
[0002.371] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0002.378] pm_ids_update: pm id update successful
[0002.383] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.413] pm_ids_update: The pm board id is 3449-0000-400
[0002.419] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.426] pm_ids_update: pm id update successful
[0002.456] Add serial number:1422919145299 as DT property
[0002.464] Applying platform configs
[0002.471] platform-init is not present. Skipping
[0002.481] Couldn’t find GPT header
[0002.486] Proceeding to Cold Boot
[0002.489] starting app android_boot_app
[0002.493] Device state: unlocked
[0002.496] display console init
[0002.504] could not find regulator
[0002.523] edid read success
[0002.540] DT entry for leds-pwm not found
[0002.544] edid read success
[0002.547] width = 640, height = 480, frequency = 25174825
[0002.552] width = 640, height = 480, frequency = 25174825
[0002.558] width = 640, height = 480, frequency = 25174825
[0002.563] width = 640, height = 480, frequency = 25174825
[0002.574] width = 1280, height = 720, frequency = 74250000
[0002.585] width = 1920, height = 1080, frequency = 148351648
[0002.591] width = 1280, height = 720, frequency = 74175824
[0002.596] width = 1920, height = 1080, frequency = 148351648
[0002.602] width = 1280, height = 720, frequency = 74175824
[0002.607] width = 720, height = 576, frequency = 26973026
[0002.618] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.626] tmds-config node not found
[0002.630] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.652] could not find regulator
[0002.659] could not find regulator
[0002.687] using default cmu settings
[0002.697] dc_hdmi_enable, HDMI initialisation complete
[0002.702] list and configure display window
[0002.722] subnode volume_up is not found !
[0002.726] subnode back is not found !
[0002.729] subnode volume_down is not found !
[0002.734] subnode menu is not found !
[0002.737] Gpio keyboard init success
[0002.818] found decompressor handler: lz4-legacy
[0002.832] decompressing blob (type 1)…
[0002.902] load_bmp_blob: panelresolution=1080 type=3
[0002.977] decompressor handler not found
[0002.986] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.997] se_aes_verify_sbk_clear: Error
[0003.001] SE operation failed
[0003.016] device_query_partition_size: failed to open partition spiflash0:MSC !
[0003.023] MSC Partition not found
[0003.029] device_query_partition_size: failed to open partition spiflash0:USP !
[0003.040] blob_init: blob-partition USP header read failed
[0003.051] kfs_getpartname: name = LNX
[0003.064] Found 19 BFS partitions in “spiflash0”
[0003.382] load kernel from storage
[0003.387] decompressor handler not found
[0003.650] Successfully loaded kernel and ramdisk images
[0003.655] board ID = D78, board SKU = 0
[0003.660] sdmmc node status = okay
[0003.663] sdcard instance = 0
[0003.666] sdcard gpio handle 0x5a
[0003.669] sdcard gpio pin 0xc9
[0003.672] sdcard gpio flags 0x0
[0003.675] vmmc-supply 0x9d
[0003.678] cd_gpio_pin = 201
[0003.681] pin_state = 0
[0003.683] Found sdcard
[0003.685] SD-card IS present …
[0003.688] load_and_boot_kernel: SD card detected OK
[0003.694] load_bmp_blob: panelresolution=1080 type=3
[0004.190] display bmp image done
[0004.193] NCK carveout not present
[0004.196] Skipping dts_overrides
[0004.200] NCK carveout not present
[0004.209] Find /i2c@7000c000’s alias i2c0
[0004.213] get eeprom at 1-a0, size 256, type 0
[0004.222] Find /i2c@7000c500’s alias i2c2
[0004.226] get eeprom at 3-a0, size 256, type 0
[0004.231] get eeprom at 3-ae, size 256, type 0
[0004.235] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.240] I2C slave not started
[0004.243] I2C write failed
[0004.246] Writing offset failed
[0004.249] eeprom_init: EEPROM read failed
[0004.253] pm_ids_update: eeprom init failed
[0004.257] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.287] pm_ids_update: The pm board id is 3448-0000-400
[0004.294] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0004.303] pm_ids_update: pm id update successful
[0004.307] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.337] pm_ids_update: The pm board id is 3449-0000-400
[0004.344] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0004.352] pm_ids_update: pm id update successful
[0004.382] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.388] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.396] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.402] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.410] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e7:2b:9a
[0004.416] Plugin Manager: Parse ODM data 0x000a4000
[0004.429] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.438] Add serial number:1422919145299 as DT property
[0004.447] “bpmp” doesn’t exist, creating
[0004.453] Updated bpmp info to DTB
[0004.457] Updated initrd info to DTB
[0004.461] “proc-board” doesn’t exist, creating
[0004.467] Updated board info to DTB
[0004.471] “pmu-board” doesn’t exist, creating
[0004.477] Updated board info to DTB
[0004.480] “display-board” doesn’t exist, creating
[0004.486] Updated board info to DTB
[0004.489] “reset” doesn’t exist, creating
[0004.494] Updated reset info to DTB
[0004.497] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1
[0004.537] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.542] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.555] Updated bootarg info to DTB
[0004.559] Adding uuid 0000000164456809200000000ffc8240 to DT
[0004.565] Adding eks info 0 to DT
[0004.570] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.576] Updated memory info to DTB
[0004.584] set vdd_core voltage to 1075 mv
[0004.588] setting ‘vdd-core’ regulator to 1075000 micro volts
[0004.594] Found secure-pmc; disable BPMP
SoC: tegra210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Tegra210 (P3541-0000) #
hello domi,
your board reboot randomly, please check below two paragraph for more details.
(1) kernel is loaded, but system rebooted very quickly.
(2) here’s another booting process, this time, system reboot during bootloader stage.
couple of things you may try..
  1. do you have peripheral device connected to Nano platform? it may be noise sending to device cause it reboot randomly.
  2. what’s the power supply you’re using. could you please replace a good one for confirmation.
Hallo Jerry,
  1. I have several devices connected to the Jetson, but even when I unplug everything it does not boot.
  2. Unfortunately I only have one power supply available here, so I can’t check that.
hello domi,
please share the details, what kind of power-supply you’re using.
note, Jetson Nano Developer Kit requires a 5V power supply capable of supplying 2A current.
you may also check Jetson Nano Developer Kit User Guide for reference,
thanks
