I updated and upgraded the OS on a standard Jetson Nano with SSD. I then rebooted, the NVidia screen came up, it started booting and then stopped, and became unresponsive. Is there some way I can recover this?
Hi paulthanlon,
Are you using the devkit or custom board?
Could it boot up success before? Or boot up w/o external SSD connected?
Could you also provide the full serial console log for further check?
As far as I know it is the Devkit (bought from Mouser) two years ago. I used the JetsonHacks way of setting up the SSD, and I didnāt have any issues with it. I also have a 5v 4A power supply which hasnāt had any issues either. First time I tried to update and upgrade, I had an issue, but because I hadnāt loaded much up, I updated the SD Card instead and rewrote it to the SSD and everything worked fine.
I updated and upgraded this time around because a program I wanted to install needed a newer version of CMake, and anyway, it was time to upgrade. It went smoothly, I followed the recommended actions when prompted, and was told I had to reboot. So I did, and that was the result. It started in the usual way, and then just stopped, with those errors shown on the screenshot.
This time around, just upgrading the Micro SD card is not really an option as I have put a lot of programs onto the SSD, all of which worked fine, but took a lot of time to set up.
When this happened, I turned off the Jetson, and backed up my home folder on another PC, so there isnāt any corruption of the drive as far as I can see. Other than that, I went through the forum, but I could not find another issue that was the same.
Any help you can give me would be great, as I am actually in the middle of doing something with it right now, and I really donāt want to have to go through the hours and hours of setting everything up again.
Sorry, just saw the last part of your post. Where could I find the full serial console log. I should be able to connect the SSD to another computer, and retrieve it from there.
How did you do this? What issue did you get?
and this?
You could refer to the following link for capturing serial console log.
Jetson Nano Style - Serial Console - JetsonHacks
And at first, I would suggest you to backup your SSD content.
Updating and Upgrading.
I updated and upgraded the normal way on most Linux systems. I typed in sudo apt update, typed in my password, and waited for it to get the latest repositories. Then when that finished I typed in sudo apt upgrade. It downloaded a lot of programs and installed them.
There were three prompts asking me if I wanted to overwrite some programs that were already there. The recommended action was to not overwrite. I canāt remember which programs this happened on, but I took the recommended advice and typed in N(No) to continue. Everything loaded up, or seemed to. A dialog popped up on my screen to reboot, so I clicked the restart button on that dialog. It shut down, it started back up, I got the initial NVidia screen then it raced through the first screen, and stopped on the second, with the output in the photograph.
Updated SD Card then transferred to the SSD Card.
This was ten months or so ago. I updated and upgraded in the same way as above, it too crashed, so I downloaded whatever was the latest version of Jetpack (I think 4.5) onto my SD Card, copied the root filesystem over to the SSD, and made the changes in the boot config file to point to the root filesystem on the SSD drive, and got back up and running that way. And it worked fine from there.
Serial console log.
The article you pointed me to says that the Jetson Nano uses a PL2303 chipset, the cable it links to uses a SiLabs CP2012 chipset. There is also the FTDI chipset and another one, I think it is the CH341 chipset. Which one does the Jetson Nano use? If it is not the FTDI chipset, Iām going to have to buy a new cable to get the serial log output, which is going to take some time to get to me.
Backing up.
Well, Iāve already backed up my home folder. There really isnāt any point in backing up anything else, as it would be backing up a system which doesnāt work. From my experience with Raspberry Pis and some other SBCs, once youāre at the point where your relying on serial log output to fix something, it usually means you end up having to start all over again. Let me know which cable I need, Iāll order it up and get back to you.
OK,
I took a chance and tried the serial cables that I did have. Weirdly, I was able to login using minicom, but it just halts when trying to boot it up on the machine itself. This is the output from the serial console
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 14:39:12
Press CTRL-A Z for help on special keys
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x230ee2
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI ā¦
[0000.281] Initialize FailControl
[0000.284] Read PT from (2:0)
[0000.314] PT crc32 and magic check passed.
[0000.318] Using BFS PT to query partitions
[0000.324] Loading Tboot-CPU binary
[0000.352] Verifying TBC in OdmNonSecureSBK mode
[0000.362] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.369] Bootloader downloaded successfully.
[0000.373] Downloaded Tboot-CPU binary to 0xa0000258
[0000.378] MAX77620_GPIO5 configured
[0000.381] CPU power rail is up
[0000.384] CPU clock enabled
[0000.388] Performing RAM repair
[0000.391] Updating A64 Warmreset Address to 0xa00002e9
[0000.396] BoardID = 3448, SKU = 0x0
[0000.399] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.403] Nano-SD: checking PT table on QSPI ā¦
[0000.407] NvTbootFailControlDoFailover: No failover; Continuing ā¦
[0000.413] Loading NvTbootBootloaderDTB
[0000.480] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.549] Bootloader DTB Load Address: 0x83000000
[0000.554] BoardID = 3448, SKU = 0x0
[0000.557] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.561] Nano-SD: checking PT table on QSPI ā¦
[0000.565] NvTbootFailControlDoFailover: No failover; Continuing ā¦
[0000.571] Loading NvTbootKernelDTB
[0000.637] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.706] Kernel DTB Load Address: 0x83100000
[0000.710] BoardID = 3448, SKU = 0x0
[0000.714] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.717] Nano-SD: checking PT table on QSPI ā¦
[0000.722] NvTbootFailControlDoFailover: No failover; Continuing ā¦
[0000.730] Loading cboot binary
[0000.845] Verifying EBT in OdmNonSecureSBK mode
[0000.887] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.894] Bootloader downloaded successfully.
[0000.898] BoardID = 3448, SKU = 0x0
[0000.902] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.905] Nano-SD: checking PT table on QSPI ā¦
[0000.910] NvTbootFailControlDoFailover: No failover; Continuing ā¦
[0000.916] PT: Partition NCT NOT found !
[0000.920] Warning: Find Partition via PT Failed
[0000.924] Next binary entry address: 0x92c00258
[0000.928] BoardId: 3448
[0000.933] Overriding pmu board id with proc board id
[0000.938] Display board id is not available
[0000.942] BoardID = 3448, SKU = 0x0
[0000.945] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.949] Nano-SD: checking PT table on QSPI ā¦
[0000.953] NvTbootFailControlDoFailover: No failover; Continuing ā¦
[0001.060] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.115] /bpmp deleted
[0001.117] SC7EntryFw header found loaded at 0xff700000
[0001.311] OVR2 PMIC
[0001.313] Bpmp FW successfully loaded
[0001.316] BoardID = 3448, SKU = 0x0
[0001.320] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.323] Nano-SD: checking PT table on QSPI ā¦
[0001.328] NvTbootFailControlDoFailover: No failover; Continuing ā¦
[0001.335] WB0 init successfully at 0xff780000
[0001.339] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.344] Set NvDecSticky Bits
[0001.348] GSC2 address ff53fffc value c0edbbcc
[0001.354] GSC MC Settings done
[0001.357] BoardID = 3448, SKU = 0x0
[0001.360] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.364] Nano-SD: checking PT table on QSPI ā¦
[0001.368] NvTbootFailControlDoFailover: No failover; Continuing ā¦
[0001.375] TOS Image length 53680
[0001.378] Monitor size 53680
[0001.381] OS size 0
[0001.396] Secure Os AES-CMAC Verification Success!
[0001.401] TOS image cipher info: plaintext
[0001.405] Loading and Validation of Secure OS Successful
[0001.421] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.425] NvTbootPackSdramParams: start.
[0001.430] NvTbootPackSdramParams: done.
[0001.434] Tegraboot started after 51869 us
[0001.438] Basic modules init took 931249 us
[0001.442] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.448] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.453] Next stage binary read took 102859 us
[0001.457] Carveout took -132462 us
[0001.461] CPU initialization took 515445 us
[0001.465] Total time taken by TegraBoot 1417091 us
[0001.469] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):9892ce1
NOTICE: BL31: Built : 09:21:33, Nov 22 2022
ERROR: Error initializing runtime service trusty_fast
[0001.592] RamCode = 0
[0001.596] LPDDR4 Training: Read DT: Number of tables = 2
[0001.601] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.614] EMC Training Successful
[0001.617] 408000 not found in DVFS table
[0001.624] RamCode = 0
[0001.627] DT Write: emc-table@204000 succeeded
[0001.632] DT Write: emc-table@1600000 succeeded
[0001.637] LPDDR4 Training: Write DT: Number of tables = 2
[0001.685]
[0001.686] Debug Init done
[0001.688] Marked DTB cacheable
[0001.691] Bootloader DTB loaded at 0x83000000
[0001.696] Marked DTB cacheable
[0001.699] Kernel DTB loaded at 0x83100000
[0001.703] DeviceTree Init done
[0001.716] Pinmux applied successfully
[0001.721] gicd_base: 0x50041000
[0001.724] gicc_base: 0x50042000
[0001.727] Interrupts Init done
[0001.731] Using base:0x60005090 & irq:208 for tick-timer
[0001.736] Using base:0x60005098 for delay-timer
[0001.741] platform_init_timer: DONE
[0001.744] Timer(tick) Init done
[0001.748] osc freq = 38400 khz
[0001.752]
[0001.753] Welcome to L4T Cboot
[0001.756]
[0001.757] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.762] calling constructors
[0001.765] initializing heap
[0001.768] initializing threads
[0001.771] initializing timers
[0001.774] creating bootstrap completion thread
[0001.778] top of bootstrap2()
[0001.781] CPU: ARM Cortex A57
[0001.784] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.788] initializing platform
[0001.796] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.801] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.805] Macronix QSPI chip present
[0001.809] SPI device register
[0001.811] init boot device
[0001.814] allocating memory for boot device(SPI)
[0001.819] registering boot device
[0001.837] QSPI bdev is already initialized
[0001.841] Enable APE clock
[0001.844] Un-powergate APE partition
[0001.847] of_register: registering tegra_udc to of_hal
[0001.852] of_register: registering inv20628-driver to of_hal
[0001.858] of_register: registering ads1015-driver to of_hal
[0001.863] of_register: registering lp8557-bl-driver to of_hal
[0001.869] of_register: registering bq2419x_charger to of_hal
[0001.875] of_register: registering bq27441_fuel_gauge to of_hal
[0001.886] gpio framework initialized
[0001.890] of_register: registering tca9539_gpio to of_hal
[0001.895] of_register: registering tca9539_gpio to of_hal
[0001.901] of_register: registering i2c_bus_driver to of_hal
[0001.906] of_register: registering i2c_bus_driver to of_hal
[0001.912] of_register: registering i2c_bus_driver to of_hal
[0001.917] pmic framework initialized
[0001.921] of_register: registering max77620_pmic to of_hal
[0001.926] regulator framework initialized
[0001.930] of_register: registering tps65132_bl_driver to of_hal
[0001.936] initializing target
[0001.942] gpio_driver_register: register ātegra_gpio_driverā driver
[0001.950] board ID = D78, board SKU = 0
[0001.954] Skipping Z3!
[0001.959] fixed regulator driver initialized
[0001.977] initializing OF layer
[0001.980] NCK carveout not present
[0001.983] Skipping dts_overrides
[0001.987] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.003] I2C Bus Init done
[0002.006] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.016] I2C Bus Init done
[0002.019] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.030] I2C Bus Init done
[0002.032] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.043] I2C Bus Init done
[0002.045] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.056] I2C Bus Init done
[0002.058] of_children_init: Ops found for compatible string maxim,max77620
[0002.069] max77620_init using irq 118
[0002.074] register āmaxim,max77620ā pmic
[0002.078] gpio_driver_register: register āmax77620-gpioā driver
[0002.084] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.095] I2C Bus Init done
[0002.098] NCK carveout not present
[0002.108] Find /i2c@7000c000ās alias i2c0
[0002.112] get eeprom at 1-a0, size 256, type 0
[0002.121] Find /i2c@7000c500ās alias i2c2
[0002.125] get eeprom at 3-a0, size 256, type 0
[0002.129] get eeprom at 3-ae, size 256, type 0
[0002.134] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.139] I2C slave not started
[0002.142] I2C write failed
[0002.145] Writing offset failed
[0002.148] eeprom_init: EEPROM read failed
[0002.151] pm_ids_update: eeprom init failed
[0002.156] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.186] pm_ids_update: The pm board id is 3448-0000-200
[0002.192] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.201] pm_ids_update: pm id update successful
[0002.205] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.235] pm_ids_update: The pm board id is 3449-0000-200
[0002.242] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.250] pm_ids_update: pm id update successful
[0002.280] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.286] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.294] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.299] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.308] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:b3:8e
[0002.314] Plugin Manager: Parse ODM data 0x000a4000
[0002.326] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.341] Find /i2c@7000c000ās alias i2c0
[0002.345] get eeprom at 1-a0, size 256, type 0
[0002.354] Find /i2c@7000c500ās alias i2c2
[0002.358] get eeprom at 3-a0, size 256, type 0
[0002.362] get eeprom at 3-ae, size 256, type 0
[0002.366] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.372] I2C slave not started
[0002.375] I2C write failed
[0002.377] Writing offset failed
[0002.380] eeprom_init: EEPROM read failed
[0002.384] pm_ids_update: eeprom init failed
[0002.388] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.419] pm_ids_update: The pm board id is 3448-0000-200
[0002.425] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.432] pm_ids_update: pm id update successful
[0002.436] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.466] pm_ids_update: The pm board id is 3449-0000-200
[0002.473] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.480] pm_ids_update: pm id update successful
[0002.510] Add serial number:1422619023470 as DT property
[0002.518] Applying platform configs
[0002.524] platform-init is not present. Skipping
[0002.528] calling apps_init()
[0002.534] Couldnāt find GPT header
[0002.539] Proceeding to Cold Boot
[0002.542] starting app android_boot_app
[0002.546] Device state: unlocked
[0002.549] display console init
[0002.557] could not find regulator
[0002.581] hdmi cable not connected
[0002.584] is_hdmi_needed: HDMI not connected, returning false
[0002.590] hdmi is not connected
[0002.593] DT entry for leds-pwm not found
s[0002.600] or0 is not supported
[0002.603] display_console_init: no valid display out_type
[0002.611] subnode volume_up is not found !
[0002.614] subnode back is not found !
[0002.618] subnode volume_down is not found !
[0002.622] subnode menu is not found !
[0002.626] Gpio keyboard init success
[0002.706] found decompressor handler: lz4-legacy
[0002.721] decompressing blob (type 1)ā¦
[0002.787] display_resolution: No display init
[0002.791] Failed to retrieve display resolution
[0002.796] Could not load/initialize BMP blobā¦ignoring
[0002.801] -------> se_aes_verify_sbk_clear: 747
[0002.805] se_aes_verify_sbk_clear: Error
[0002.809] SE operation failed
[0002.812] bl_battery_charging: connected to external power supply
[0002.821] display_console_ioctl: No display init
[0002.826] switch_backlight failed
[0002.832] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.839] MSC Partition not found
[0002.846] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.853] USP partition read failed!
[0002.856] blob_init: blob-partition USP header read failed
[0002.862] android_boot Unable to update recovery partition
[0002.867] kfs_getpartname: name = LNX
[0002.871] Loading kernel from LNX
[0002.880] Found 19 BFS partitions in āspiflash0ā
[0003.201] load kernel from storage
[0003.206] decompressor handler not found
[0003.471] Successfully loaded kernel and ramdisk images
[0003.476] board ID = D78, board SKU = 0
[0003.481] sdmmc node status = okay
[0003.484] sdcard instance = 0
[0003.487] sdmmc cd-inverted
[0003.490] sdcard gpio handle 0x5b
[0003.493] sdcard gpio pin 0xc9
[0003.496] sdcard gpio flags 0x0
[0003.499] vmmc-supply 0x9b
[0003.502] cd_gpio_pin = 201
[0003.505] pin_state = 0
[0003.507] Found sdcard
[0003.509] SD-card IS present ā¦
[0003.512] load_and_boot_kernel: SD card detected OK
[0003.518] display_resolution: No display init
[0003.522] Failed to retrieve display resolution
[0003.527] bmp blob is not loaded and initialized
[0003.531] Failed to display boot-logo
[0003.535] NCK carveout not present
[0003.538] Skipping dts_overrides
[0003.541] NCK carveout not present
[0003.551] Find /i2c@7000c000ās alias i2c0
[0003.555] get eeprom at 1-a0, size 256, type 0
[0003.564] Find /i2c@7000c500ās alias i2c2
[0003.568] get eeprom at 3-a0, size 256, type 0
[0003.572] get eeprom at 3-ae, size 256, type 0
[0003.577] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.582] I2C slave not started
[0003.585] I2C write failed
[0003.588] Writing offset failed
[0003.591] eeprom_init: EEPROM read failed
[0003.595] pm_ids_update: eeprom init failed
[0003.599] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.629] pm_ids_update: The pm board id is 3448-0000-200
[0003.636] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0003.644] pm_ids_update: pm id update successful
[0003.648] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.679] pm_ids_update: The pm board id is 3449-0000-200
[0003.685] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0003.693] pm_ids_update: pm id update successful
[0003.723] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.729] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.737] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.743] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.751] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:b3:8e
[0003.757] Plugin Manager: Parse ODM data 0x000a4000
[0003.769] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.777] Add serial number:1422619023470 as DT property
[0003.786] ābpmpā doesnāt exist, creating
[0003.792] Updated bpmp info to DTB
[0003.797] Updated initrd info to DTB
[0003.800] āproc-boardā doesnāt exist, creating
[0003.806] Updated board info to DTB
[0003.809] āpmu-boardā doesnāt exist, creating
[0003.815] Updated board info to DTB
[0003.819] ādisplay-boardā doesnāt exist, creating
[0003.825] Updated board info to DTB
[0003.828] āresetā doesnāt exist, creating
[0003.833] Updated reset info to DTB
[0003.836] display_console_ioctl: No display init
[0003.840] display_console_ioctl: No display init
[0003.845] display_console_ioctl: No display init
[0003.850] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_ow
[0003.884] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.890] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 co
[0003.903] Updated bootarg info to DTB
[0003.907] Adding uuid 00000001644495850c00000014000600 to DT
[0003.913] Adding eks info 0 to DT
[0003.918] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.924] Updated memory info to DTB
[0003.930] Updated system-lp0-disable info to DTB
[0003.938] set vdd_core voltage to 1125 mv
[0003.941] setting āvdd-coreā regulator to 1125000 micro volts
[0003.947] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Nov 22 2022 - 09:21:37 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash⦠SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiBB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1ā¦
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
876 bytes read in 33 ms (25.4 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7160179 bytes read in 349 ms (19.6 MiB/s)
Retrieving file: /boot/Image
34484232 bytes read in 1508 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 l
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317adec
copying carveout for /host1x@50000000/dc@54200000ā¦
copying carveout for /host1x@50000000/dc@54240000ā¦
Starting kernel ā¦
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5494-d8000) (gcc version 7.3.1 20180422
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options āā)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.062033] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.567780] Host read timeout at address 545c00c4
[ 1.786850] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.794511] imx219 6-0010: board setup failed
[ 2.939933] usb 1-2.1.1.1: 1:1: cannot get freq at ep 0x2
[ 6.044789] cgroup: cgroup2: unknown option ānsdelegateā
[ 7.266710] using random self ethernet address
[ 7.283070] using random host ethernet address
[ 8.113949] using random self ethernet address
[ 8.134887] using random host ethernet address
Ubuntu 18.04.6 LTS paul-desktop ttyS0
paul-desktop login: paul
Password:
Welcome to Ubuntu 18.04.6 LTS (GNU/Linux 4.9.253-tegra aarch64)
- Documentation: https://help.ubuntu.com
- Management: https://landscape.canonical.com
- Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the āunminimizeā command.
0 updates can be applied immediately.
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
paul@paul-desktop:~$
This is the output when I tried to start up the X Window Server. I have also included the output from the Xorg log file
paul@paul-desktop:~$ [ 316.526291] EXT4-fs (sda1): error count since last fsck: 35
[ 316.532208] EXT4-fs (sda1): initial error at time 1664078222: ext4_journal_check_start:56
[ 316.540636] EXT4-fs (sda1): last error at time 1671031753: ext4_remount:5043: inode 21366694
startx
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 5.4.0-135-generic aarch64 Ubuntu
Current Operating System: Linux paul-desktop 4.9.253-tegra #1 SMP PREEMPT Wed Apr 20 14:25:12 PDT 2022 a4
Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_o
Build Date: 07 December 2022 03:27:42PM
xorg-server 2:1.19.6-1ubuntu4.13 (For technical support please see Enterprise open source support | Ubuntu)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (ā) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: ā/var/log/Xorg.0.logā, Time: Wed Jan 4 15:04:49 2023
(==) Using config file: ā/etc/X11/xorg.confā
(==) Using system config directory ā/usr/share/X11/xorg.conf.dā
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at ā/var/log/Xorg.0.logā for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
Couldnāt get a file descriptor referring to the console
This is the output from the Xorg log file
paul@paul-desktop:~$ cat /var/log/Xorg.0.log
[ 791.478]
[ 791.478] X Protocol Version 11, Revision 0
[ 791.478] Build Operating System: Linux 5.4.0-135-generic aarch64 Ubuntu
[ 791.478] Current Operating System: Linux paul-desktop 4.9.253-tegra #1 SMP PREEMPT Wed Apr 20 14:25:4
[ 791.478] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resi
[ 791.478] Build Date: 07 December 2022 03:27:42PM
[ 791.478] xorg-server 2:1.19.6-1ubuntu4.13 (For technical support please see http://www.ubuntu.com/su
[ 791.478] Current version of pixman: 0.34.0
[ 791.478] Before reporting problems, check http://wiki.x.org
[ 791.478] Markers: (ā) probed, () from config file, (==) default setting,
[ 791.479] (==) Log file: ā/var/log/Xorg.0.logā, Time: Wed Jan 4 15:04:49 2023
[ 791.479] (==) Using config file: ā/etc/X11/xorg.confā
[ 791.479] (==) Using system config directory ā/usr/share/X11/xorg.conf.dā
[ 791.479] (==) No Layout section. Using the first Screen section.
[ 791.479] (==) No screen section available. Using defaults.
[ 791.479] () |ā>Screen āDefault Screen Sectionā (0)
[ 791.479] () | |ā>Monitor āā
[ 791.480] (==) No device specified for screen āDefault Screen Sectionā.
Using the first device section listed.
[ 791.480] () | |ā>Device āTegra0ā
[ 791.480] (==) No monitor specified for screen āDefault Screen Sectionā.
Using a default monitor configuration.
[ 791.480] (==) Automatically adding devices
[ 791.480] (==) Automatically enabling devices
[ 791.480] (==) Automatically adding GPU devices
[ 791.480] (==) Automatically binding GPU devices
[ 791.480] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 791.480] (WW) The directory ā/usr/share/fonts/X11/cyrillicā does not exist.
[ 791.480] Entry deleted from font path.
[ 791.480] (WW) The directory ā/usr/share/fonts/X11/100dpi/ā does not exist.
[ 791.480] (WW) The directory ā/usr/share/fonts/X11/75dpi/ā does not exist.
[ 791.480] (WW) The directory ā/usr/share/fonts/X11/100dpiā does not exist.
[ 791.480] (WW) The directory ā/usr/share/fonts/X11/75dpiā does not exist.
[ 791.481] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 791.481] (==) ModulePath set to ā/usr/lib/xorg/modulesā
[ 791.481] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 791.481] (II) Loader magic: 0x558c27b010
[ 791.481] (II) Module ABI versions:
[ 791.481] X.Org ANSI C Emulation: 0.4
[ 791.481] X.Org Video Driver: 23.0
[ 791.481] X.Org XInput driver : 24.1
[ 791.481] X.Org Server Extension : 10.0
[ 791.482] (ā) using VT number 2
[ 791.482] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, din
[ 791.483] (II) no primary bus or device found
[ 791.483] (WW) ādriā will not be loaded unless youāve specified it to be loaded elsewhere.
[ 791.483] (II) āglxā will be loaded by default.
[ 791.484] (II) LoadModule: āextmodā
[ 791.484] (II) Module āextmodā already built-in
[ 791.484] (II) LoadModule: āglxā
[ 791.484] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 791.486] (II) Module glx: vendor=āX.Org Foundationā
[ 791.486] compiled for 1.19.6, module version = 1.0.0
[ 791.486] ABI class: X.Org Server Extension, version 10.0
[ 791.486] (II) LoadModule: ānvidiaā
[ 791.486] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 791.488] (II) Module nvidia: vendor=āNVIDIA Corporationā
[ 791.488] compiled for 4.0.2, module version = 1.0.0
[ 791.488] Module class: X.Org Video Driver
[ 791.488] (II) NVIDIA dlloader X Driver 32.7.3 Release Build (integ_stage_rel) (buildbrain@mobile2
[ 791.488] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 791.488] (WW) Falling back to old probe method for NVIDIA
[ 791.488] (II) Loading sub module āfbā
[ 791.488] (II) LoadModule: āfbā
[ 791.489] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 791.489] (II) Module fb: vendor=āX.Org Foundationā
[ 791.489] compiled for 1.19.6, module version = 1.0.0
[ 791.489] ABI class: X.Org ANSI C Emulation, version 0.4
[ 791.489] (II) Loading sub module āwfbā
[ 791.489] (II) LoadModule: āwfbā
[ 791.490] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 791.490] (II) Module wfb: vendor=āX.Org Foundationā
[ 791.490] compiled for 1.19.6, module version = 1.0.0
[ 791.490] ABI class: X.Org ANSI C Emulation, version 0.4
[ 791.490] (II) Loading sub module āramdacā
[ 791.490] (II) LoadModule: āramdacā
[ 791.490] (II) Module āramdacā already built-in
[ 791.491] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 791.491] (II) NVIDIA(0): Creating default Display subsection in Screen section
āDefault Screen Sectionā for depth/fbbpp 24/32
[ 791.491] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 791.491] (==) NVIDIA(0): RGB weight 888
[ 791.491] (==) NVIDIA(0): Default visual is TrueColor
[ 791.491] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 791.491] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 791.491] () NVIDIA(0): Option āAllowEmptyInitialConfigurationā ātrueā
[ 791.492] () NVIDIA(0): Enabling 2D acceleration
[ 791.492] (II) Loading sub module āglxserver_nvidiaā
[ 791.492] (II) LoadModule: āglxserver_nvidiaā
[ 791.492] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 791.503] (II) Module glxserver_nvidia: vendor=āNVIDIA Corporationā
[ 791.503] compiled for 4.0.2, module version = 1.0.0
[ 791.503] Module class: X.Org Server Extension
[ 791.503] (II) NVIDIA GLX Module 32.7.3 Release Build (integ_stage_rel) (buildbrain@mobile-u64-532
[ 791.503] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 791.503] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 791.503] (II) UnloadModule: ānvidiaā
[ 791.503] (II) UnloadSubModule: āglxserver_nvidiaā
[ 791.503] (II) Unloading glxserver_nvidia
[ 791.503] (II) UnloadSubModule: āwfbā
[ 791.503] (II) UnloadSubModule: āfbā
[ 791.503] (EE) Screen(s) found, but none have a usable configuration.
[ 791.503] (EE)
Fatal server error:
[ 791.503] (EE) no screens found(EE)
[ 791.503] (EE)
for help.
[ 791.503] (EE) Please also check the log file at ā/var/log/Xorg.0.logā for additional information.
[ 791.503] (EE)
[ 791.504] (EE) Server terminated with error (1). Closing log file.
And this is the output from dmesg
paul@paul-desktop:~$ dmesg --human
[Jan 4 14:51] Booting Linux on physical CPU 0x0
[ +0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5494-d8000) (gc
[ +0.000000] Boot CPU: AArch64 Processor [411fd071]
[ +0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ +0.000000] OF: fdt: - 80000000 , 7ee00000
[ +0.000000] OF: fdt: - 100000000 , 7f200000
[ +0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options āā)
[ +0.000000] bootconsole [uart8250] enabled
[ +0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvi
[ +0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nv
[ +0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id
[ +0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ +0.000000] On node 0 totalpages: 1039872
[ +0.000000] DMA zone: 8192 pages used for memmap
[ +0.000000] DMA zone: 0 pages reserved
[ +0.000000] DMA zone: 519168 pages, LIFO batch:31
[ +0.000000] Normal zone: 8136 pages used for memmap
[ +0.000000] Normal zone: 520704 pages, LIFO batch:31
[ +0.000000] psci: probing for conduit method from DT.
[ +0.000000] psci: PSCIv1.0 detected in firmware.
[ +0.000000] psci: Using standard PSCI v0.2 function IDs
[ +0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ +0.000000] psci: SMC Calling Convention v1.1
[ +0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ +0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ +0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ +0.000000] CPU features: enabling workaround for ARM erratum 832075
[ +0.000000] Speculative Store Bypass Disable mitigation not required
[ +0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total page
[ +0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M sectio
[ +0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ +0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ +0.000000] log_buf_len min size: 32768 bytes
[ +0.000000] log_buf_len: 131072 bytes
[ +0.000000] early log buf free: 29836(91%)
[ +0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ +0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ +0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ +0.000000] Memory: 3568528K/4159488K available (15358K kernel code, 2956K rwd
[ +0.000000] Virtual kernel memory layout:
[ +0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB
[ +0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB
[ +0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB
[ +0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB
[ +0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB
[ +0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB
[ +0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB
[ +0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB
[ +0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB
[ +0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB
[ +0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB
[ +0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB
[ +0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ +0.000000] Preemptible hierarchical RCU implementation.
[ +0.000000] Build-time adjustment of leaf fanout to 64.
[ +0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ +0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ +0.000000] NR_IRQS:64 nr_irqs:64 0
[ +0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /inter
[ +0.000000] t210 clock and reset probe
[ +0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ +0.000000] clk_cbus_recalc_rate: no gbus parent
[ +0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phy
[ +0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:
[ +0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 439804
[ +0.001507] Console: colour dummy device 80x25
[ +0.000010] console [tty0] enabled
[ +0.000006] bootconsole [uart8250] disabled
[ +0.000020] kmemleak: Kernel memory leak detector disabled
[ +0.000018] Calibrating delay loop (skipped), value calculated using timer fre
[ +0.000013] pid_max: default: 32768 minimum: 301
[ +0.000444] Security Framework initialized
[ +0.000219] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ +0.000010] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ +0.001092] ftrace: allocating 47098 entries in 184 pages
[ +0.167613] sched-energy: CPU device node has no sched-energy-costs
[ +0.000030] ASID allocator initialised with 65536 entries
[ +0.036441] tegra-id: chipid=22117.
[ +0.000014] tegra-id: opt_subrevision=0.
[ +0.000017] Tegra Speedo/IDDQ fuse revision 4
[ +0.000005] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ +0.000004] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ +0.000005] Tegra: CPU Speedo Value 1972, SoC Speedo Value 1857, GPU Speedo Va
[ +0.000004] Tegra: CPU IDDQ Value 1408, SoC IDDQ Value 1504, GPU IDDQ Value 17
[ +0.000019] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ +0.000016] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/a
[ +0.000008] DTB Build time: Nov 22 2022 09:26:48
[ +0.049544] CPU1: Booted secondary processor [411fd071]
[ +0.031910] CPU2: Booted secondary processor [411fd071]
[ +0.031983] CPU3: Booted secondary processor [411fd071]
[ +0.000089] Brought up 4 CPUs
[ +0.000008] SMP: Total of 4 processors activated.
[ +0.000008] CPU features: detected feature: 32-bit EL0 Support
[ +0.000262] CPU: All CPU(s) started at EL2
[ +0.000018] alternatives: patching kernel code
[ +0.008069] devtmpfs: initialized
[ +0.036068] Initilizing CustomIPI irq domain
[ +0.000312] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max
[ +0.000021] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ +0.010500] pinctrl core: initialized pinctrl subsystem
[ +0.000591] OS set in device tree is not L4T.
[ +0.000470] regulator-dummy: no parameters
[ +0.000279] Initializing plugin-manager
[ +0.000153] Plugin module not found
[ +0.000193] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ +0.000499] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ +0.000710] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ +0.000526] node /plugin-manager/fragement@7 match with odm-data enable-pmic-w
[ +0.000202] node /plugin-manager/fragement@8 match with odm-data enable-pmic-w
[ +0.000267] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ +0.003439] NET: Registered protocol family 16
[ +0.001301] pstore: using zlib compression
[ +0.000035] console [pstore-1] enabled
[ +0.000005] pstore: Registered ramoops as persistent store backend
[ +0.000005] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ +0.016094] cpuidle: using governor menu
[ +0.003668] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ +0.001554] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e8400
[ +0.000019] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ +0.003162] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic
[ +0.002067] Serial: AMBA PL011 UART driver
[ +0.000498] tegra_powergate_init: DONE
[ +0.000015] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/a
[ +0.001731] Tegra reboot handler registered.
[ +0.004419] iommu: Adding device tegra-carveouts to group 0
[ +0.000126] platform tegra-carveouts: domain=ffffffc0f9bf83d8 allocates as[0]=
[ +0.000350] iommu: Adding device smmu_test to group 1
[ +0.000045] platform smmu_test: domain=ffffffc0f9bf8618 allocates as[0]=ffffff
[ +0.000816] mc: mapped MMIO address: 0xffffff8008041000 ā 0x70019000
[ +0.000060] mc: mapped MMIO address: 0xffffff8008067000 ā 0x7001c000
[ +0.000053] mc: mapped MMIO address: 0xffffff800807b000 ā 0x7001d000
[ +0.000011] nv-tegra-mc 70019000.mc: No mssnvlink node
[ +0.000023] mc-err: mcerr ops are set to t21x
[ +0.011023] iommu: Adding device 70090000.xusb to group 2
[ +0.000276] iommu: Adding device 70006000.serial to group 3
[ +0.000074] platform 70006000.serial: domain=ffffffc0f9496498 allocates as[0]=
[ +0.000422] iommu: Adding device 70006040.serial to group 4
[ +0.000272] iommu: Adding device 70006200.serial to group 5
[ +0.000229] iommu: Adding device sound to group 6
[ +0.000046] platform sound: domain=ffffffc0f94969d8 allocates as[0]=ffffffc0f9
[ +0.000556] iommu: Adding device 7000d400.spi to group 7
[ +0.000267] iommu: Adding device 7000d600.spi to group 8
[ +0.000312] iommu: Adding device 70410000.spi to group 9
[ +0.000325] iommu: Adding device 50000000.host1x to group 10
[ +0.000273] iommu: Adding device 54080000.vi to group 11
[ +0.000390] iommu: Adding device 54600000.isp to group 12
[ +0.000288] iommu: Adding device 54680000.isp to group 13
[ +0.000273] iommu: Adding device tegradc.0 to group 14
[ +0.000051] platform tegradc.0: domain=ffffffc0f94a1918 allocates as[0]=ffffff
[ +0.000518] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ +0.000312] iommu: Adding device tegradc.1 to group 15
[ +0.000047] platform tegradc.1: domain=ffffffc0f94a1b58 allocates as[0]=ffffff
[ +0.000508] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ +0.000248] iommu: Adding device 54340000.vic to group 16
[ +0.000215] iommu: Adding device 544c0000.nvenc to group 17
[ +0.000219] iommu: Adding device 54500000.tsec to group 18
[ +0.000246] iommu: Adding device 54100000.tsecb to group 19
[ +0.000224] iommu: Adding device 54480000.nvdec to group 20
[ +0.000197] iommu: Adding device 54380000.nvjpg to group 21
[ +0.001041] iommu: Adding device 546c0000.i2c to group 22
[ +0.000338] iommu: Adding device 57000000.gpu to group 23
[ +0.000055] platform 57000000.gpu: domain=ffffffc0f94abb58 allocates as[0]=fff
[ +0.000037] platform 57000000.gpu: domain=ffffffc0f94abb58 allocates as[1]=fff
[ +0.000040] platform 57000000.gpu: domain=ffffffc0f94abb58 allocates as[2]=fff
[ +0.000059] platform 57000000.gpu: domain=ffffffc0f94abb58 allocates as[3]=fff
[ +0.000862] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency th
[ +0.000010] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ +0.000014] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ +0.000005] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ +0.000004] tegra-pmc: ### PMC reset status reg: 0x0
[ +0.053176] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ +0.000009] tegra-pmc: Clear bootloader IO dpd settings
[ +0.000020] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ +0.000064] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset
[ +0.000298] iommu: Adding device 70012000.se to group 24
[ +0.000564] iommu: Adding device 1003000.pcie to group 25
[ +0.000053] platform 1003000.pcie: domain=ffffffc0f9540318 allocates as[0]=fff
[ +0.000551] iommu: Adding device 7000c000.i2c to group 26
[ +0.000320] iommu: Adding device 7000c400.i2c to group 27
[ +0.000307] iommu: Adding device 7000c500.i2c to group 28
[ +0.000301] iommu: Adding device 7000c700.i2c to group 29
[ +0.000311] iommu: Adding device 7000d000.i2c to group 30
[ +0.000308] iommu: Adding device 7000d100.i2c to group 31
[ +0.000301] iommu: Adding device sdhci-tegra.0 to group 32
[ +0.000054] platform sdhci-tegra.0: domain=ffffffc0f9540e58 allocates as[0]=ff
[ +0.001078] iommu: Adding device 700d0000.xudc to group 33
[ +0.004016] vdd-ac-bat: 5000 mV
[ +0.000414] vdd-5v0-sys: 5000 mV
[ +0.000864] vdd-5v0-hdmi: 5000 mV
[ +0.000431] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ +0.000257] vdd-1v8-sys: 1800 mV
[ +0.000488] vdd-fan: 5000 mV
[ +0.000235] vdd-fan: supplied by vdd-5v0-sys
[ +0.000271] vdd-usb-vbus: 5000 mV
[ +0.000217] vdd-usb-vbus: supplied by vdd-5v0-sys
[ +0.000418] vdd-usb-vbus2: 5000 mV
[ +0.028571] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ +0.002263] gpio gpiochip0: gpio-line-names specifies 240 line names but there
[ +0.001203] GPIO line 151 (camera-control-output-low) hogged as output/low
[ +0.000404] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0
[ +0.008643] eventlib_kernel: keventlib is initialized, test id: 0
[ +0.000372] SCSI subsystem initialized
[ +0.000187] libata version 3.00 loaded.
[ +0.000278] usbcore: registered new interface driver usbfs
[ +0.000049] usbcore: registered new interface driver hub
[ +0.000040] usbcore: registered new device driver usb
[ +0.004042] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ +0.005746] vdd-core: 600 <ā> 1162 mV at 1125 mV
[ +0.000922] random: fast init done
[ +0.000109] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ +0.002850] vdd-ddr-1v1: 1150 mV
[ +0.003327] vdd-pre-reg-1v35: 1350 mV
[ +0.003913] vdd-1v8: 1800 mV
[ +0.003999] avdd-sys-1v2: 1200 mV
[ +0.004001] vdd-pex-1v0: 1050 mV
[ +0.000693] vddio-sdmmc-ap: 1800 <ā> 3300 mV at 3300 mV
[ +0.000539] max77620-ldo3: at 3100 mV
[ +0.002773] vdd-rtc: 850 <ā> 1100 mV at 1000 mV
[ +0.000543] max77620-ldo5: at 3100 mV
[ +0.000540] max77620-ldo6: at 2800 mV
[ +0.002920] avdd-1v05-pll: 1050 mV
[ +0.003990] avdd-io-hdmi-dp: 1050 mV
[ +0.002675] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ +0.000283] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochi
[ +0.000293] max77620 4-003c: max77620 probe successful
[ +0.002897] media: Linux media interface: v0.10
[ +0.000054] Linux video capture interface: v2.00
[ +0.000941] pps_core: LinuxPPS API ver. 1 registered
[ +0.000006] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giomet
[ +0.000030] PTP clock support registered
[ +0.003209] tegra210-emc 7001b000.external-memory-controller: validated EMC DF
[ +0.000803] Advanced Linux Sound Architecture Driver Initialized.
[ +0.000639] Bluetooth: Core ver 2.22
[ +0.000045] NET: Registered protocol family 31
[ +0.000005] Bluetooth: HCI device and connection manager initialized
[ +0.000014] Bluetooth: HCI socket layer initialized
[ +0.000008] Bluetooth: L2CAP socket layer initialized
[ +0.000027] Bluetooth: SCO socket layer initialized
[ +0.001698] tegra210_dvfs: no clock found for sdmmc2_ddr
[ +0.000015] tegra210_dvfs: no clock found for sdmmc4_ddr
[ +0.000049] tegra210_dvfs: no clock found for sdmmc1_ddr
[ +0.000015] tegra210_dvfs: no clock found for sdmmc3_ddr
[ +0.003142] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering pro
[ +0.001110] vdd-3v3-sys: 3300 mV
[ +0.000365] vdd-3v3-sys: supplied by vdd-5v0-sys
[ +0.000052] vdd-1v8-sys: supplied by vdd-3v3-sys
[ +0.002566] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ +0.000441] vdd-3v3-sd: 3300 mV
[ +0.000389] vdd-3v3-sd: supplied by vdd-3v3-sys
[ +0.000775] avdd-io-edp-1v05: 1050 mV
[ +0.000389] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ +0.000202] vdd-usb-hub-en: 5000 mV
[ +0.000348] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ +0.001062] camchar: rtcpu character device driver loaded
[ +0.000751] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ +0.001283] clocksource: Switched to clocksource arch_sys_counter
[ +0.039754] VFS: Disk quotas dquot_6.6.0
[ +0.000128] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ +0.000551] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ +0.000443] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr,
[ +0.000015] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->n
[ +0.000266] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ +0.000006] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=
[ +0.000014] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr
[ +0.000030] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x
[ +0.000006] tegra-carveouts tegra-carveouts: assigned reserved memory node ira
[ +0.000014] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ +0.000009] nvmap_page_pool_init: Total RAM pages: 1010916
[ +0.000006] nvmap_page_pool_init: nvmap page pool size: 126364 pages (493 MB)
[ +0.000083] nvmap_background_zero_thread: PP zeroing thread starting.
[ +0.000516] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB
[ +0.000865] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600K
[ +0.008266] thermal thermal_zone0: Registering thermal zone thermal_zone0 for
[ +0.000447] thermal thermal_zone1: Registering thermal zone thermal_zone1 for
[ +0.000364] thermal thermal_zone2: Registering thermal zone thermal_zone2 for
[ +0.000311] thermal thermal_zone3: Registering thermal zone thermal_zone3 for
[ +0.000197] thermal thermal_zone4: Registering thermal zone thermal_zone4 for
[ +0.000252] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ +0.000005] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ +0.000433] NET: Registered protocol family 2
[ +0.000122] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ +0.002348] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ +0.000213] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ +0.000586] TCP: Hash tables configured (established 32768 bind 32768)
[ +0.000155] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ +0.000081] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ +0.000448] NET: Registered protocol family 1
[ +0.000651] RPC: Registered named UNIX socket transport module.
[ +0.000006] RPC: Registered udp transport module.
[ +0.000005] RPC: Registered tcp transport module.
[ +0.000004] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ +0.000013] PCI: CLS 0 bytes, default 64
[ +0.000227] Trying to unpack rootfs image as initramfsā¦
[ +0.297737] Freeing initrd memory: 6992K
[ +0.009851] host1x 50000000.host1x: initialized
[ +0.001842] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ava
[ +0.003297] audit: initializing netlink subsys (disabled)
[ +0.000092] audit: type=2000 audit(0.835:1): initialized
[ +0.000705] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ +0.009969] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ +0.001481] ntfs: driver 2.1.32 [Flags: R/W].
[ +0.000770] 9p: Installing v9fs 9p2000 file system support
[ +0.003179] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 24
[ +0.000117] io scheduler noop registered
[ +0.000296] io scheduler cfq registered (default)
[ +0.002719] gic 702f9000.agic: GIC IRQ controller registered
[ +0.002991] iommu: Adding device 702ef000.adsp to group 34
[ +0.009179] iommu: Adding device aconnect@702c0000:adsp_audio to group 35
[ +0.000162] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ +0.000610] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0
[ +0.000008] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0
[ +0.001822] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = u
[ +0.000101] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = u
[ +0.000097] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = u
[ +0.000203] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = p
[ +0.000099] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = p
[ +0.000090] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = p
[ +0.000097] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = p
[ +0.000090] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = p
[ +0.000087] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = p
[ +0.000091] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = p
[ +0.006098] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ +0.001686] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ +0.001859] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ +0.001279] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ +0.000354] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ +0.001190] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:ca
[ +0.000214] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=15
[ +0.000223] Adding domain tsec-pd to PM domain host1x-pd
[ +0.001863] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ +0.001010] tsec 54500000.tsec: initialized
[ +0.001603] tsec 54100000.tsecb: initialized
[ +0.000665] Adding domain nvdec-pd to PM domain host1x-pd
[ +0.003261] nvdec 54480000.nvdec: initialized
[ +0.001014] Adding domain vic03-pd to PM domain host1x-pd
[ +0.000206] Adding domain msenc-pd to PM domain host1x-pd
[ +0.000164] Adding domain nvjpg-pd to PM domain host1x-pd
[ +0.003576] falcon 54340000.vic: initialized
[ +0.001322] falcon 544c0000.nvenc: initialized
[ +0.001387] falcon 54380000.nvjpg: initialized
[ +0.004377] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF
[ +0.000042] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ +0.000034] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ +0.000104] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ +0.000084] display board info: id 0x0, fab 0x0
[ +0.000059] generic_infoframe_type: 0x87
[ +0.000064] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ +0.000007] tegra_cec 70015000.tegra_cec: probed
[ +0.000100] tegradc tegradc.0: DT parsed successfully
[ +0.000055] tegradc tegradc.0: Display dc.ffffff800abc0000 registered with id=
[ +0.003755] tegradc tegradc.0: probed
[ +0.000813] Console: switching to colour frame buffer device 80x30
[ +0.000034] tegradc tegradc.0: fb registered
[ +0.001268] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ +0.000092] tegradc tegradc.1: No lt-data, using default setting
[ +0.000028] tegradc tegradc.1: No hpd-gpio in DT
[ +0.000035] tegradc tegradc.1: DT parsed successfully
[ +0.000048] tegradc tegradc.1: Display dc.ffffff800ad40000 registered with id=
[ +0.001630] tegradc tegradc.1: dpd enable lookup fail:-19
[ +0.000325] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 chan
[ +0.505422] Host read timeout at address 545c00c4
[ +0.001753] tegradc tegradc.1: probed
[ +0.000432] tegradc tegradc.1: fb registered
[ +0.000483] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 chann
[ +0.000820] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check di
[ +0.000007] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initia
[ +0.000305] kfuse 7000fc00.kfuse: initialized
[ +0.000903] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply
[ +0.000813] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ +0.000197] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ +0.000007] hpd: switching from state 7 (Takeover from bootloader) to state 0
[ +0.000012] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ +0.000017] tegradc tegradc.1: blank - powerdown
[ +0.000021] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ +0.000005] Extcon DP: HPD disabled
[ +0.000004] hpd: hpd_switch 0
[ +0.000005] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ +0.000010] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ +0.000008] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ +0.000675] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ +0.000011] vdd-cpu: 708 <ā> 1322 mV at 708 mV
[ +0.000387] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator regist
[ +0.001346] vdd-gpu: applied init 1000000uV constraint
[ +0.000007] vdd-gpu: 708 <ā> 1323 mV at 997 mV
[ +0.000362] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator regist
[ +0.003625] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ +0.000099] No Device Node present for smmu client: serial8250 !!
[ +0.000010] platform serial8250: No iommus property found in DT node, got swgi
[ +0.000036] iommu: Adding device serial8250 to group 36
[ +0.002297] console [ttyS0] disabled
[ +0.000083] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 2
[ +0.010395] console [ttyS0] enabled
[ +0.001059] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud =
[ +0.000323] serial-tegra 70006200.serial: RX in PIO mode
[ +0.000095] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud =
[ +0.001094] [drm] Initialized
[ +0.010234] brd: module loaded
[ +0.005260] loop: module loaded
[ +0.000093] tegra_profiler: version: 1.145, samples/io: 49/28
[ +0.000133] tegra_profiler: auth: init
[ +0.001355] THERMAL EST: found 2 subdevs
[ +0.000008] THERMAL EST num_resources: 0
[ +0.000006] [THERMAL EST subdev 0]
[ +0.000008] [THERMAL EST subdev 1]
[ +0.000500] thermal thermal_zone5: Registering thermal zone thermal_zone5 for
[ +0.000005] THERMAL EST: thz register success.
[ +0.000164] THERMAL EST: end of probe, return err: 0
[ +0.001143] sd: No Scsi addr parsed to reserve index
[ +0.000044] hisi_sas: driver version v1.6
[ +0.005114] tegra-qspi 70410000.spi: Prod settings list not found
[ +0.001197] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ +0.000010] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4Mi
[ +0.003030] libphy: Fixed MDIO Bus: probed
[ +0.000715] tun: Universal TUN/TAP device driver, 1.6
[ +0.000006] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ +0.000967] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ +0.000006] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ +0.000061] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ +0.000005] igb: Copyright (c) 2007-2014 Intel Corporation.
[ +0.000054] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version
[ +0.000005] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ +0.000046] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.
[ +0.000003] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ +0.001121] PPP generic driver version 2.4.2
[ +0.000252] PPP BSD Compression module registered
[ +0.000006] PPP Deflate Compression module registered
[ +0.000041] PPP MPPE Compression module registered
[ +0.000007] NET: Registered protocol family 24
[ +0.000081] usbcore: registered new interface driver r8152
[ +0.000046] usbcore: registered new interface driver asix
[ +0.000051] usbcore: registered new interface driver ax88179_178a
[ +0.000037] usbcore: registered new interface driver cdc_ether
[ +0.000041] usbcore: registered new interface driver net1080
[ +0.000040] usbcore: registered new interface driver cdc_subset
[ +0.000036] usbcore: registered new interface driver zaurus
[ +0.000052] usbcore: registered new interface driver cdc_ncm
[ +0.000167] VFIO - User Level meta-driver version: 0.3
[ +0.001334] ehci_hcd: USB 2.0 āEnhancedā Host Controller (EHCI) Driver
[ +0.000026] ehci-pci: EHCI PCI platform driver
[ +0.000045] ohci_hcd: USB 1.1 āOpenā Host Controller (OHCI) Driver
[ +0.000014] ohci-pci: OHCI PCI platform driver
[ +0.000041] ohci-platform: OHCI generic platform driver
[ +0.003054] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ +0.000644] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ +0.001193] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9235c00 id
[ +0.002456] usbcore: registered new interface driver uas
[ +0.000072] usbcore: registered new interface driver usb-storage
[ +0.000112] usbcore: registered new interface driver usbserial
[ +0.003043] tegra-xusb 70090000.xusb: Firmware timestamp: 2020-07-31 09:33:12
[ +0.000068] tegra-xusb 70090000.xusb: xHCI Host Controller
[ +0.000029] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus num
[ +0.000780] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100
[ +0.000047] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ +0.000292] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ +0.000007] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000006] usb usb1: Product: xHCI Host Controller
[ +0.000005] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ +0.000004] usb usb1: SerialNumber: 70090000.xusb
[ +0.000361] tegra-xudc-new 700d0000.xudc: device count: 1
[ +0.000330] hub 1-0:1.0: USB hub found
[ +0.000044] hub 1-0:1.0: 5 ports detected
[ +0.000835] tegra-xusb 70090000.xusb: xHCI Host Controller
[ +0.000016] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus num
[ +0.000119] usb usb2: We donāt know the algorithms for LPM for this host, disa
[ +0.000107] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ +0.000006] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000005] usb usb2: Product: xHCI Host Controller
[ +0.000005] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ +0.000005] usb usb2: SerialNumber: 70090000.xusb
[ +0.000376] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ +0.000015] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ +0.000036] tegra-xudc-new 700d0000.xudc: entering ELPG
[ +0.000309] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ +0.000897] hub 2-0:1.0: USB hub found
[ +0.000079] mousedev: PS/2 mouse device common for all mice
[ +0.000089] hub 2-0:1.0: 4 ports detected
[ +0.000035] usbcore: registered new interface driver xpad
[ +0.000901] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ +0.000009] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ +0.097408] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ +0.004158] usb usb2: usb_suspend_both: status 0
[ +0.010713] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rt
[ +0.002527] rtc rtc1: alarm rtc device
[ +0.000018] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ +0.000032] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ +0.000641] i2c /dev entries driver
[ +0.002433] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ +0.023338] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ +0.000095] imx219 6-0010: imx219_board_setup: error during i2c read probe (-1
[ +0.007661] imx219 6-0010: board setup failed
[ +0.004435] imx219: probe of 6-0010 failed with error -121
[ +0.001259] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ +0.002525] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ +0.000008] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ +0.000516] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147
[ +0.000016] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when c
[ +0.000012] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cp
[ +0.000139] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147
[ +0.000012] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when g
[ +0.000008] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gp
[ +0.000149] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147
[ +0.000013] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when p
[ +0.000006] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temp
[ +0.000180] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ +0.000838] tegra_aotag tegra-aotag: Registering sensor 0
[ +0.000056] tegra_aotag tegra-aotag: Invalid temp readout
[ +0.000027] tegra_aotag tegra-aotag: Invalid temp readout
[ +0.000019] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ +0.000009] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ +0.000920] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147
[ +0.000020] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ācap cooling deviceā r
[ +0.000189] tegra_aotag tegra-aotag: Invalid temp readout
[ +0.000033] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling devic
[ +0.000407] parse_throttle_dt_data: Num cap clks = 6
[ +0.000006] parse_throttle_dt_data: clk=cclk_g type=2
[ +0.000014] parse_throttle_dt_data: clk=gpu type=4
[ +0.000026] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ +0.000022] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ +0.000024] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ +0.000005] parse_throttle_dt_data: clk=emc type=3
[ +0.000436] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147
[ +0.000110] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147
[ +0.000161] tegra_throttle_probe: probe successful. #cdevs=4
[ +0.000769] FAN dev name: pwm-fan
[ +0.000082] FAN:gpio request success.
[ +0.000062] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ +0.000327] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ +0.000176] pwm_fan_driver pwm-fan: fan tach request irq success
[ +0.000010] pwm_fan_driver pwm-fan: tach period: 1000
[ +0.000101] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, sta
[ +0.000005] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, s
[ +0.000006] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1,
[ +0.000005] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1,
[ +0.000005] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1,
[ +0.000005] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1,
[ +0.000005] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1,
[ +0.000005] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1,
[ +0.000005] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1,
[ +0.000005] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1,
[ +0.002933] device-mapper: uevent: version 1.0.3
[ +0.000463] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-de
[ +0.005601] tegra210-cpufreq cpufreq: probe()ā¦completed
[ +0.000731] sdhci: Secure Digital Host Controller Interface driver
[ +0.000002] sdhci: Copyright(c) Pierre Ossman
[ +0.000002] sdhci-pltfm: SDHCI platform and OF driver helper
[ +0.000508] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ +0.000356] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ +0.000125] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ +0.004025] tegra-se 70012000.se: tegra_se_probe: complete
[ +0.000486] hidraw: raw HID events driver (C) Jiri Kosina
[ +0.001279] usbcore: registered new interface driver usbhid
[ +0.000002] usbhid: USB HID core driver
[ +0.002184] tegra21x_actmon 6000c800.actmon: in actmon_register()ā¦
[ +0.000160] tegra21x_actmon 6000c800.actmon: initialization Completed for the
[ +0.001926] nvpmodel: initialized successfully
[ +0.001093] usbcore: registered new interface driver snd-usb-audio
[ +0.000060] No Device Node present for smmu client: snd-soc-dummy !!
[ +0.000005] platform snd-soc-dummy: No iommus property found in DT node, got s
[ +0.000017] iommu: Adding device snd-soc-dummy to group 37
[ +0.005640] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card
[ +0.013658] OPE platform probe
[ +0.000085] OPE platform probe successful
[ +0.000027] OPE platform probe
[ +0.000079] OPE platform probe successful
[ +0.016949] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ +0.007407] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ +0.000141] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ +0.000137] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ +0.000301] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ +0.000151] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ +0.000133] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ +0.000128] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ +0.000163] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ +0.000128] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ +0.000173] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ +0.011911] u32 classifier
[ +0.000003] Actions configured
[ +0.000074] Initializing XFRM netlink socket
[ +0.000735] NET: Registered protocol family 10
[ +0.000690] NET: Registered protocol family 17
[ +0.000011] NET: Registered protocol family 15
[ +0.000075] bridge: filtering via arp/ip/ip6tables is no longer available by d
[ +0.000045] Bluetooth: RFCOMM socket layer initialized
[ +0.000009] Bluetooth: RFCOMM ver 1.11
[ +0.000005] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ +0.000005] Bluetooth: HIDP socket layer initialized
[ +0.000018] 9pnet: Installing 9P2000 support
[ +0.000036] Key type dns_resolver registered
[ +0.000403] Registered cp15_barrier emulation handler
[ +0.000006] Registered setend emulation handler
[ +0.001073] registered taskstats version 1
[ +0.000512] Adding domain ve2-pd to PM domain host1x-pd
[ +0.000251] Adding domain ve-pd to PM domain host1x-pd
[ +0.001944] isp 54600000.isp: initialized
[ +0.000956] isp 54680000.isp: initialized
[ +0.010377] last reset is due to power on reset
[ +0.000004] KERNEL: PMC reset status reg: 0x0
[ +0.000059] BL: PMC reset status reg: 0x0
[ +0.000003] BL: PMIC poweroff Event Recorder: 0x40
[ +0.001433] clk_cbus_recalc_rate: no gbus parent
[ +0.000005] clk_cbus_round_rate: no gbus parent
[ +0.000002] clk_cbus_round_rate: no gbus parent
[ +0.000008] clk_cbus_recalc_rate: no gbus parent
[ +0.000109] clk_cbus_recalc_rate: no gbus parent
[ +0.000003] clk_cbus_round_rate: no gbus parent
[ +0.000004] clk_cbus_recalc_rate: no gbus parent
[ +0.000707] tegra_dvfs: GPU-cap: registered
[ +0.000059] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV
[ +0.000003] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500u
[ +0.000002] tegra dvfs: vdd-gpu: nominal 1098mV, offset 708000uV, step 10000uV
[ +0.001419] tegra_dvfs: vdd-gpu-vts: registered
[ +0.000700] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor coo
[ +0.000628] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling
[ +0.000491] input: gpio-keys as /devices/gpio-keys/input/input1
[ +0.033042] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:1
[ +0.000951] vi 54080000.vi: vi_probe: ++
[ +0.003108] vi 54080000.vi: initialized
[ +0.002024] vi 54080000.vi: subdev nvcsiā1 bound
[ +0.001461] Disable partitions left on by BL
[ +0.000004] disb
[ +0.000043] bwmgr: missing cdev-type property
[ +0.000095] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147
[ +0.000006] DRAM derating cdev registered.
[ +0.000889] ALSA device list:
[ +0.000003] #0: tegra-hda at 0x70038000 irq 83
[ +0.000003] #1: tegra-snd-t210ref-mobile-rt565x
[ +0.003368] Freeing unused kernel memory: 8640K
[ +0.009118] tegra-pcie 1003000.pcie: link 0 down, retrying
[ +0.001992] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ +0.014474] Root device found: PARTUUID=2341b3e3-9676-4ae5-a8cd-3c1cc5ff97bc
[ +0.021647] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ +0.000007] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000004] usb 1-2: Product: 4-Port USB 2.1 Hub
[ +0.000003] usb 1-2: Manufacturer: Generic
[ +0.001218] hub 1-2:1.0: USB hub found
[ +0.001075] hub 1-2:1.0: 4 ports detected
[ +0.061559] tegra_cec 70015000.tegra_cec: Canāt find physical addresse.
[ +0.000004] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ +0.002979] mmc0: hw tuning done ā¦
[ +0.000035] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ +0.000321] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
[ +0.005826] mmcblk0: p1
[ +0.035738] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ +0.034347] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ +0.000006] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000004] usb 2-1: Product: 4-Port USB 3.1 Hub
[ +0.000004] usb 2-1: Manufacturer: Generic
[ +0.005192] hub 2-1:1.0: USB hub found
[ +0.001433] hub 2-1:1.0: 4 ports detected
[ +0.142104] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ +0.020398] usb 1-2.1: New USB device found, idVendor=1a40, idProduct=0101
[ +0.000004] usb 1-2.1: New USB device strings: Mfr=0, Product=1, SerialNumber=
[ +0.000004] usb 1-2.1: Product: USB 2.0 Hub
[ +0.000787] hub 1-2.1:1.0: USB hub found
[ +0.000074] hub 1-2.1:1.0: 4 ports detected
[ +0.052769] tegra-pcie 1003000.pcie: link 0 down, retrying
[ +0.074311] usb 2-1.3: new SuperSpeed USB device number 3 using tegra-xusb
[ +0.020804] usb 2-1.3: New USB device found, idVendor=154b, idProduct=f00a
[ +0.000005] usb 2-1.3: New USB device strings: Mfr=2, Product=3, SerialNumber=
[ +0.000004] usb 2-1.3: Product: PNY ELITE PSSD
[ +0.000003] usb 2-1.3: Manufacturer: PNY
[ +0.000003] usb 2-1.3: SerialNumber: 511200224150FF2E004D
[ +0.004097] scsi host0: uas
[ +0.001005] scsi 0:0:0:0: Direct-Access PNY PNY ELITE PSSD 0 PQ:
[ +0.034539] sd 0:0:0:0: [sda] Spinning up diskā¦
[ +0.099198] usb 1-2.1.1: new high-speed USB device number 4 using tegra-xusb
[ +0.020597] usb 1-2.1.1: New USB device found, idVendor=1a40, idProduct=0101
[ +0.000005] usb 1-2.1.1: New USB device strings: Mfr=0, Product=1, SerialNumbe
[ +0.000003] usb 1-2.1.1: Product: USB 2.0 Hub
[ +0.000755] hub 1-2.1.1:1.0: USB hub found
[ +0.000072] hub 1-2.1.1:1.0: 4 ports detected
[ +0.086574] usb 1-2.1.2: new high-speed USB device number 5 using tegra-xusb
[ +0.020439] usb 1-2.1.2: New USB device found, idVendor=1a40, idProduct=0101
[ +0.000005] usb 1-2.1.2: New USB device strings: Mfr=0, Product=1, SerialNumbe
[ +0.000003] usb 1-2.1.2: Product: USB 2.0 Hub
[ +0.000837] hub 1-2.1.2:1.0: USB hub found
[ +0.000071] hub 1-2.1.2:1.0: 4 ports detected
[ +0.042694] tegra-pcie 1003000.pcie: link 0 down, retrying
[ +0.002030] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ +0.037926] usb 1-2.1.3: new low-speed USB device number 6 using tegra-xusb
[ +0.024471] usb 1-2.1.3: New USB device found, idVendor=046d, idProduct=c077
[ +0.000006] usb 1-2.1.3: New USB device strings: Mfr=1, Product=2, SerialNumbe
[ +0.000003] usb 1-2.1.3: Product: USB Optical Mouse
[ +0.000004] usb 1-2.1.3: Manufacturer: Logitech
[ +0.002971] input: Logitech USB Optical Mouse as /devices/70090000.xusb/usb1/1
[ +0.000317] hid-generic 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mous
[ +0.012232] usb 1-2.1.2: usb_suspend_both: status 0
[ +0.026239] random: crng init done
[ +0.002101] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ +0.000006] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ +0.000005] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ +0.000006] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref
[ +0.000005] pci_bus 0000:00: root bus resource [bus 00-ff]
[ +0.000021] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ +0.000070] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ +0.000131] iommu: Adding device 0000:00:02.0 to group 38
[ +0.000069] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reco
[ +0.000106] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ +0.000024] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ +0.000030] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ +0.000020] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ +0.000138] pci 0000:01:00.0: supports D1 D2
[ +0.000003] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ +0.000144] iommu: Adding device 0000:01:00.0 to group 39
[ +0.014967] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ +0.000034] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ +0.000005] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ +0.000016] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit
[ +0.000026] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit
[ +0.000025] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ +0.000016] pci 0000:00:02.0: PCI bridge to [bus 01]
[ +0.000004] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ +0.000005] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ +0.000344] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ +0.000004] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ +0.000005] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ +0.000120] aer 0000:00:02.0:pcie002: service driver aer loaded
[ +0.000244] r8168 0000:01:00.0: enabling device (0000 ā 0003)
[ +0.000016] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ +0.014247] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid e
[ +0.000068] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found val
[ +0.000582] r8168: This product is covered by one or more of the following pat
[ +0.000015] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realt
This program comes with ABSOLUTELY NO WARRANTY; for details, plea
This is free software, and you are welcome to redistribute it und
[ +0.000127] usb 1-2.1.1.1: new full-speed USB device number 7 using tegra-xusb
[ +0.022718] usb 1-2.1.1.1: New USB device found, idVendor=1908, idProduct=2070
[ +0.000006] usb 1-2.1.1.1: New USB device strings: Mfr=1, Product=2, SerialNum
[ +0.000016] usb 1-2.1.1.1: Product: USB2.0 Device
[ +0.000004] usb 1-2.1.1.1: Manufacturer: Generic
[ +0.000002] usb 1-2.1.1.1: SerialNumber: 20130100ph0
[ +0.002370] usb 1-2.1.1.1: 1:1: cannot get freq at ep 0x2
[ +0.078897] usb 1-2.1.4: new low-speed USB device number 8 using tegra-xusb
[ +0.027494] usb 1-2.1.4: New USB device found, idVendor=046d, idProduct=c31c
[ +0.000005] usb 1-2.1.4: New USB device strings: Mfr=1, Product=2, SerialNumbe
[ +0.000003] usb 1-2.1.4: Product: USB Keyboard
[ +0.000002] usb 1-2.1.4: Manufacturer: Logitech
[ +0.007408] input: Logitech USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-
[ +0.057571] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyb
[ +0.003940] input: Logitech USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-
[ +0.059759] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Devi
[ +0.363855] .
[ +1.023999] .
[ +1.027938] .
[ +0.000162] ready
[ +0.000298] sd 0:0:0:0: [sda] 937703088 512-byte logical blocks: (480 GB/447 G
[ +0.000923] sd 0:0:0:0: [sda] Write Protect is off
[ +0.000006] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ +0.000374] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn
[ +0.000513] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ +0.005414] sda: sda1
[ +0.002082] sd 0:0:0:0: [sda] Attached SCSI disk
[ +0.217002] EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck i
[ +0.012421] EXT4-fs (sda1): recovery complete
[ +0.000854] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (
[ +0.005218] Rootfs mounted over PARTUUID=2341b3e3-9676-4ae5-a8cd-3c1cc5ff97bc
[ +0.020915] Switching from initrd to actual rootfs
[ +0.129737] systemd[1]: System time before build time, advancing clock.
[ +0.058066] cgroup: cgroup2: unknown option ānsdelegateā
[ +0.027674] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELI
[ +0.000764] systemd[1]: Detected architecture arm64.
[ +0.021981] systemd[1]: Set hostname to .
[ +0.094976] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 c
[ +0.000010] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warnin
[ +0.179519] systemd[1]: Reached target User and Group Name Lookups.
[ +0.000302] systemd[1]: Started Forward Password Requests to Wall Directory Wa
[ +0.000031] systemd[1]: Reached target Swap.
[ +0.001562] systemd[1]: Set up automount Arbitrary Executable File Formats Fil
[ +0.001927] systemd[1]: Created slice User and Session Slice.
[ +0.041256] EXT4-fs (sda1): re-mounted. Opts: (null)
[ +0.306273] systemd-journald[2071]: Received request to flush runtime journal
[ +0.545646] using random self ethernet address
[ +0.016360] using random host ethernet address
[ +0.801213] Mass Storage Function, version: 2009/09/11
[ +0.000007] LUN: removable file: (no medium)
[ +0.029659] using random self ethernet address
[ +0.020938] using random host ethernet address
[ +0.057046] rndis0: HOST MAC ae:39:24:5a:a0:c8
[ +0.000274] rndis0: MAC ae:39:24:5a:a0:c9
[ +0.008851] usb0: HOST MAC ae:39:24:5a:a0:ca
[ +0.000249] usb0: MAC ae:39:24:5a:a0:cb
[ +0.000024] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ +0.000599] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ +0.000020] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ +0.000029] tegra-xudc-new 700d0000.xudc: entering ELPG
[ +0.000237] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ +0.000021] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ +0.000545] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ +0.000128] tegra-xudc-new 700d0000.xudc: entering ELPG
[ +0.000224] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ +0.035122] l4tbr0: port 1(rndis0) entered blocking state
[ +0.000006] l4tbr0: port 1(rndis0) entered disabled state
[ +0.000162] device rndis0 entered promiscuous mode
[ +0.034270] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ +0.004926] l4tbr0: port 2(usb0) entered blocking state
[ +0.000005] l4tbr0: port 2(usb0) entered disabled state
[ +0.001813] device usb0 entered promiscuous mode
[ +0.026168] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ +0.217885] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ +0.048408] eth0: 0xffffff800af20000, 00:04:4b:e6:b3:8e, IRQ 407
[ +0.079766] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ +0.424383] tegradc tegradc.0: blank - powerdown
[ +1.544404] tegradc tegradc.0: blank - powerdown
[ +1.110388] r8168: eth0: link up
[ +0.000216] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ +0.076457] tegradc tegradc.0: blank - powerdown
[ +1.113786] tegradc tegradc.0: blank - powerdown
[ +0.988113] tegradc tegradc.0: blank - powerdown
[ +8.737681] usb 1-2.1: USB disconnect, device number 3
[ +0.000060] usb 1-2.1.1: USB disconnect, device number 4
[ +0.000050] usb 1-2.1.1.1: USB disconnect, device number 7
[ +0.006935] usb 1-2.1.2: USB disconnect, device number 5
[ +0.003001] usb 1-2.1.3: USB disconnect, device number 6
[ +0.033195] usb 1-2.1.4: USB disconnect, device number 8
[ +0.300854] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[Jan 4 14:52] usb 1-2: usb_suspend_both: status 0
[ +0.000287] usb usb1: usb_suspend_both: status 0
[ +10.897857] vdd-fan: disabling
[ +0.000048] vdd-usb-vbus: disabling
[ +0.000032] vdd-usb-vbus2: disabling
[ +0.000109] avdd-io-edp-1v05: disabling
[Jan 4 14:56] EXT4-fs (sda1): error count since last fsck: 35
[ +0.005917] EXT4-fs (sda1): initial error at time 1664078222: ext4_journal_che
[ +0.008428] EXT4-fs (sda1): last error at time 1671031753: ext4_remount:5043:
[Jan 4 15:04] tegradc tegradc.0: blank - powerdown
Just some reminder.
- You can attach your log in either a text file or use a block to put it in. It would be easier for others to read.
block
- Your dmesg is truncated. Each line got cut in half.
Thatās strange. It looks good to me. I have to go in to work for a while. When I come back, Iāll stick the outputs in text files
please also share me the result of ālsmodā.
Hi there,
This is the output of lsmod
paul@paul-desktop:/proc$ lsmod
Module Size Used by
Iām also attaching 3 files
The raw output from dmesg
The /proc folder
modprobe -c output
You might be able to parse what modules are loaded from the last two files
proc_output.txt (18.5 KB)
modprobe_-c.txt (4.9 KB)
dmesg-r.txt (57.2 KB)
Looks like nvgpu driver is gone even after modprobe.
Without nvgpu driver, gpu wonāt be able to workā¦
Could you check if there is nvgpu.ko in your /lib/modules?
Hi there,
This is the output from looking. It looks to be there but buried deep in the folders
paul@paul-desktop:/proc$ cd /lib/modules
paul@paul-desktop:/lib/modules$ ls -al
total 12
drwxr-xr-x 3 root root 4096 Jan 3 22:15 .
drwxr-xr-x 19 root root 4096 Sep 19 09:39 ā¦
drwxr-xr-x 3 root root 4096 Jan 3 23:36 4.9.299-tegra
paul@paul-desktop:/lib/modules$ cd 4.9.299-tegra && ls -al
total 1228
drwxr-xr-x 3 root root 4096 Jan 3 23:36 .
drwxr-xr-x 3 root root 4096 Jan 3 22:15 ā¦
lrwxrwxrwx 1 root root 67 Nov 22 17:30 build ā /usr/src/linux-headers-4.9.299-tegra-ubuntu18.04_aarch64/kernel-4.9
drwxr-xr-x 8 root root 4096 Jan 3 22:15 kernel
-rw-rār-- 1 root root 383676 Jan 3 23:36 modules.alias
-rw-rār-- 1 root root 380252 Jan 3 23:36 modules.alias.bin
-rw-rār-- 1 root root 22141 Nov 22 17:30 modules.builtin
-rw-rār-- 1 root root 24743 Jan 3 23:36 modules.builtin.bin
-rw-rār-- 1 root root 52091 Jan 3 23:36 modules.dep
-rw-rār-- 1 root root 82891 Jan 3 23:36 modules.dep.bin
-rw-rār-- 1 root root 138 Jan 3 23:36 modules.devname
-rw-rār-- 1 root root 27700 Nov 22 17:30 modules.order
-rw-rār-- 1 root root 85 Jan 3 23:36 modules.softdep
-rw-rār-- 1 root root 108208 Jan 3 23:36 modules.symbols
-rw-rār-- 1 root root 132768 Jan 3 23:36 modules.symbols.bin
paul@paul-desktop:/lib/modules/4.9.299-tegra$ find /lib/modules -name nvgpu*
/lib/modules/4.9.299-tegra/kernel/drivers/gpu/nvgpu
/lib/modules/4.9.299-tegra/kernel/drivers/gpu/nvgpu/nvgpu.ko
Iām really sorry. I had almost no sleep last night, so Iāll have to come back to this tomorrow morning
It looks like the cause of this issue is clear now.
- uboot loads the kernel file from your mmc device (either emmc or sdcard). And the kernel version is still version <=32.7.2.
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1ā¦
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
- Your /lib/modules has been upgraded to rel-32.7.3 and system still tries to search the path /lib/modules/{uname -r} for the module. But there is no compatible version inside of it.
To be more clear⦠your āuname -rā shows kernel version 4.9.253 but your /lib/modules only has 4.9.299. Thus, nvgpu driver would not be loaded. Without nvgpu driver, your display/graphic wonāt work.
Hi there,
Yes, I can confirm this. uname -r returns 4.9.253-tegra. Well spotted
What would happen if I were to change
to
/lib/modules/4.9.253-tegra/kernel/drivers/gpu/nvgpu/nvgpu.ko
That directory is writeable by root, so I could just change it.
But would that affect other things the kernel is doing.
Also what would be likely to happen on the next update?
Where is the kernel being told to look for 4.9.253-tegra?
Could that be changed?
Please refer to this document. Change the boot order in the uboot so that uboot will try to load kernel from SSD instead of emmc.
NVMe as example
⢠To set NVMe to boot first with a plain boot command, change the UāBoot variable boot_targets to ānvme0 mmc1 mmc0 usb0 pxe dhcpā, then enter the UāBoot command run boot.
ā¢To make the change permanent, run saveenv in U-Boot after changing boot_targets but before booting
If your SSD is based on usb, then need to put usb0 in highest order.
Sorry, youāre going to have to be more specific than that. 99% of that long document doesnāt apply to this problem, nowhere in that document does it say whether the files that have to be changed are stored on the SD card or on the USB drive, and nowhere in that document does it state what folder I have to be in to run some of these scripts.
For instance, one of the files mentioned was ./flash.sh, never stating what directory it is actually in. Doing a find on the whole file system, including the SDCard turns up nothing.
paul@paul-desktop:/boot$ sudo find / -name flash*
[sudo] password for paul:
/mnt/sdcard/usr/sbin/flash_otp_lock
/mnt/sdcard/usr/sbin/flash_otp_write
/mnt/sdcard/usr/sbin/flash_unlock
/mnt/sdcard/usr/sbin/flash_otp_dump
/mnt/sdcard/usr/sbin/flash_eraseall
/mnt/sdcard/usr/sbin/flashcp
/mnt/sdcard/usr/sbin/flash_lock
/mnt/sdcard/usr/sbin/flash_otp_info
/mnt/sdcard/usr/src/linux-headers-4.9.253-tegra-ubuntu18.04_aarch64/kernel-4.9/include/config/mtd/qspi/flash.h
/mnt/sdcard/usr/src/linux-headers-4.9.253-tegra-ubuntu18.04_aarch64/kernel-4.9/include/linux/spi/flash.h
/mnt/sdcard/usr/src/linux-headers-4.9.253-tegra-ubuntu18.04_aarch64/kernel-4.9/include/linux/mtd/flashchip.h
/mnt/sdcard/usr/src/linux-headers-4.9.253-tegra-ubuntu18.04_aarch64/kernel-4.9/arch/arm/include/asm/mach/flash.h
/usr/sbin/flashcp
/usr/src/linux-headers-4.9.299-tegra-ubuntu18.04_aarch64/kernel-4.9/arch/arm/include/asm/mach/flash.h
/usr/src/linux-headers-4.9.299-tegra-ubuntu18.04_aarch64/kernel-4.9/include/linux/mtd/flashchip.h
/usr/src/linux-headers-4.9.299-tegra-ubuntu18.04_aarch64/kernel-4.9/include/linux/spi/flash.h
/usr/src/linux-headers-4.9.299-tegra-ubuntu18.04_aarch64/kernel-4.9/include/config/mtd/qspi/flash.h
You yourself use NVME as example. There is no NVME on this machine. How about giving me an example for USB SSD and telling me where the file is stored that I have to change.
Thereās a further problem. initrd.img is a link that points to the actual initrd.img, which is
lrwxrwxrwx 1 root root 24 Sep 19 09:27 initrd.img ā initrd.img-4.9.253-tegra
Surely that should be initrd.img-4.9.299-tegra, otherwise it is just going to create problems further down the road. This is on both the SD Card and the USB Drive.
Iāve managed to get all the python modules loaded up on a proper machine so that I could hit the deadline for the project I was doing on the Jetson Nano, so I now have a bit more time to look at this properly, but please donāt waste it.
