Failed to start
Hi, I have a nano over 3 months, recently I found it starts failure, so I capture its log as below, hope some can give me some advices. Thanks.
Basic info:
Jestpack 4.4
Ubuntu 18.04.4 LTS
Linux version 4.9.140-tegra
[2022-03-28 10:33:09.325]# RECV ASCII>
[2022-03-28 10:33:09.484]# RECV ASCII>
[2022-03-28 10:33:09.642]# RECV ASCII>
[0000.230] [L4T TegraBoot] (version 00.00.2018.01-l4t-80a468da)
[0000.235] Processing in cold boot mode Bootloader 2
[0000.240] A02 Bootrom Patch rev = 1023
[0000.244] Power-up reason: pmc por
[0000.247] No Battery Present
[0000.249] pmic max77620 reset reason
[0000.253] pmic max77620 NVERC : 0x10
[0000.256] RamCode = 0
[0000.258] Platform has DDR4 type RAM
[0000.262] max77620 disabling SD1 Remote Sense
[0000.266] Setting DDR voltage to 1125mv
[0000.270] Serial Number of Pmic Max77663: 0x292ff2
[2022-03-28 10:33:09.647]# RECV ASCII>
[0000.278] Entering ramdump check
[0000.281] Get RamDumpCarveOut = 0x0
[0000.284] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.289] Last reboot was clean, booting normally!
[0000.294] Sdram initialization is successful
[0000.298] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.304] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.310] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.316] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.321]
[2022-03-28 10:33:09.749]# RECV ASCII>
 GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.327] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.333] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.339] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.355] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.361] Platform-DebugCarveout: 0
[0000.364] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.370] Non secure mode, and RB not enabled.
[0000.387] Csd NumOfBlocks=0
[2022-03-28 10:33:09.944]# RECV ASCII>
[0000.579] *** Booting BFS0.
[0000.581] Read PT from (0:3)
[0000.588] Using BFS PT to query partitions
[0000.592] PT: Partition LNX NOT found !
[2022-03-28 10:33:10.562]# RECV ASCII>
[0001.178] *** Booting KFS0.
[0001.180] Read GPT from (0:3)
[0001.185] Using GPT Primary to query partitions
[0001.189] Loading Tboot-CPU binary
[0001.196] Verifying TBC in OdmNonSecureSBK mode
[0001.206] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0001.213] Bootloader downloaded successfully.
[0001.217] Downloaded Tboot-CPU binary to 0xa0000258
[0001.222] MAX77620_GPIO5 configured
[0001.226] CPU power rail is up
[0001.228] CPU clock enabled
[0001.232] Performing RAM repai
[2022-03-28 10:33:10.714]# RECV ASCII>
r
[0001.235] Updating A64 Warmreset Address to 0xa00002e9
[0001.240] Loading NvTbootBootloaderDTB
[0001.257] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0001.323] Bootloader DTB Load Address: 0x83000000
[0001.328] Loading NvTbootKernelDTB
[0001.344] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[2022-03-28 10:33:10.803]# RECV ASCII>
[0001.409] Kernel DTB Load Address: 0x83100000
[0001.415] Loading cboot binary
[0001.426] Verifying EBT in OdmNonSecureSBK mode
[2022-03-28 10:33:10.890]# RECV ASCII>
[0001.467] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.474] Bootloader downloaded successfully.
[0001.479] PT: Partition NCT NOT found !
[0001.483] Warning: Find Partition via PT Failed
[0001.487] Next binary entry address: 0x92c00258
[0001.491] BoardId: 3448
[0001.496] Overriding pmu board id with proc board id
[0001.501] Display board id is not available
[0001.512] Verifying SC7EntryFw in OdmNonSecureSBK mode
[2022-03-28 10:33:10.946]# RECV ASCII>
[0001.565] /bpmp deleted
[0001.567] SC7EntryFw header found loaded at 0xff700000
[2022-03-28 10:33:11.184]# RECV ASCII>
[0001.757] OVR2 PMIC
[0001.759] Bpmp FW successfully loaded
[0001.763] WB0 init successfully at 0xff780000
[0001.768] Set NvDecSticky Bits
[0001.771] GSC2 address ff53fffc value c0edbbcc
[0001.778] GSC MC Settings done
[0001.781] TOS Image length 53680
[0001.784]  Monitor size 53680
[0001.787]  OS size 0
[0001.792] Secure Os AES-CMAC Verification Success!
[0001.796] TOS image cipher info: plaintext
[0001.800] Loading and Validation of Secure OS Successful
[0001.816] SC7
[2022-03-28 10:33:11.221]# RECV ASCII>
Entry Firmware - 0xff700000, 0x4000
[0001.821] NvTbootPackSdramParams: start.
[0001.826] NvTbootPackSdramParams: done.
[0001.829] Tegraboot started after 159650 us
[0001.833] Basic modules init took 1382220 us
[0001.838] Sec Bootdevice Read Time = 544 ms, Read Size = 14459 KB
[0001.843] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.849] Next stage binary read took 7377 us
[0001.853] Carveout took -19279 us
[0001.856] CPU initialization took 343730 us
[0001.860] Total time taken by Te
[2022-03-28 10:33:11.266]# RECV ASCII>
graBoot 1714048 us
[0001.865] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):41d46a9cf
NOTICE:  BL31: Built : 21:18:12, Jun 25 2020
ERROR:   Error initializing runtime service trusty_fast
[2022-03-28 10:33:11.363]# RECV ASCII>
[0001.987] RamCode = 0
[0001.992] LP
[2022-03-28 10:33:11.487]# RECV ASCII>
DDR4 Training: Read DT: Number of tables = 2
[0001.997] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.010] EMC Training Successful
[0002.013] 408000 not found in DVFS table
[0002.019] RamCode = 0
[0002.022] DT Write: emc-table@204000 succeeded
[0002.028] DT Write: emc-table@1600000 succeeded
[0002.032] LPDDR4 Training: Write DT: Number of tables = 2
[0002.090]
[0002.091] Debug Init done
[0002.093] Marked DTB cacheable
[0002.096] Bootloader DTB loaded at 0x83000000
[0002.101] Marked D
[2022-03-28 10:33:11.499]# RECV ASCII>
TB cacheable
[0002.104] Kernel DTB loaded at 0x83100000
[0002.108] DeviceTree Init done
[0002.121] Pinmux applied successfully
[0002.125] gicd_base: 0x50041000
[0002.129] gicc_base: 0x50042000
[0002.132] Interrupts Init done
[0002.136] Using base:0x60005090 & irq:208 for tick-timer
[0002.141] Using base:0x60005098 for delay-timer
[0002.146] platform_init_timer: DONE
[0002.149] Timer(tick) Init done
[0002.153] osc freq = 38400 khz
[0002.157]
[0002.158] Welcome to L4T Cboot
[0002.161]
[0002.1
[2022-03-28 10:33:11.546]# RECV ASCII>
62] Cboot Version: 00.00.2018.01-t210-3a7ad565
[0002.167] calling constructors
[0002.170] initializing heap
[0002.173] initializing threads
[0002.176] initializing timers
[0002.179] creating bootstrap completion thread
[0002.183] top of bootstrap2()
[0002.186] CPU: ARM Cortex A57
[0002.189] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.193] initializing platform
[2022-03-28 10:33:11.665]# RECV ASCII>
[0002.247] Config for emmc ddr50 mode completed
[0002.252] sdmmc bdev is already initialized
[0002.256] Enable APE clock
[0002.258] Un-powergate APE partition
[0002.262] of_register: registering tegra_udc to of_hal
[0002.267] of_register: registering inv20628-driver to of_hal
[0002.273] of_register: registering ads1015-driver to of_hal
[0002.278] of_register: registering lp8557-bl-driver to of_hal
[0002.284] of_register: registering bq2419x_charger to of_hal
[0002.289] of_register: registering bq27
[2022-03-28 10:33:11.672]# RECV ASCII>
441_fuel_gauge to of_hal
[0002.301] gpio framework initialized
[0002.304] of_register: registering tca9539_gpio to of_hal
[0002.310] of_register: registering tca9539_gpio to of_hal
[0002.315] of_register: registering i2c_bus_driver to of_hal
[0002.321] of_register: registering i2c_bus_driver to of_hal
[0002.326] of_register: registering i2c_bus_driver to of_hal
[0002.332] pmic framework initialized
[0002.335] of_register: registering max77620_pmic to of_hal
[0002.341] regulator framework initialize
[2022-03-28 10:33:11.709]# RECV ASCII>
d
[0002.345] of_register: registering tps65132_bl_driver to of_hal
[0002.351] initializing target
[0002.356] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.367] fixed regulator driver initialized
[0002.385] initializ
[2022-03-28 10:33:11.862]# RECV ASCII>
ing OF layer
[0002.388] NCK carveout not present
[0002.391] Skipping dts_overrides
[0002.395] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.412] I2C Bus Init done
[0002.415] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.425] I2C Bus Init done
[0002.428] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.438] I2C Bus Init done
[0002.441] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.45
[2022-03-28 10:33:11.873]# RECV ASCII>
1] I2C Bus Init done
[0002.454] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.464] I2C Bus Init done
[0002.467] of_children_init: Ops found for compatible string maxim,max77620
[0002.477] max77620_init using irq 118
[0002.482] register 'maxim,max77620' pmic
[0002.486] gpio_driver_register: register 'max77620-gpio' driver
[0002.492] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.503] I2C Bus Init done
[0002.506] NCK carveout not present
[00
[2022-03-28 10:33:11.881]# RECV ASCII>
02.516] Find /i2c@7000c000's alias i2c0
[0002.520] get eeprom at 1-a0, size 256, type 0
[0002.529] Find /i2c@7000c500's alias i2c2
[0002.533] get eeprom at 3-a0, size 256, type 0
[0002.537] get eeprom at 3-ae, size 256, type 0
[0002.542] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.547] I2C slave not started
[0002.550] I2C write failed
[0002.553] Writing offset failed
[0002.556] eeprom_init: EEPROM read failed
[0002.560] pm_ids_update: eeprom init failed
[0002.564] pm_ids_update: Updating
[2022-03-28 10:33:11.920]# RECV ASCII>
 3,a0, size 256, type 0
[0002.594] pm_ids_update: The pm board id is 3448-0002-400
[2022-03-28 10:33:11.986]# RECV ASCII>
[0002.601] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.608] pm_ids_update: pm id update successful
[0002.613] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.618] I2C slave not started
[0002.621] I2C write failed
[0002.624] Writing offset failed
[0002.627] eeprom_init: EEPROM read failed
[0002.631] pm_ids_update: eeprom init failed
[0002.661] eeprom_get_mac: EEPROM invalid MAC address (al
[2022-03-28 10:33:12.062]# RECV ASCII>
l 0xff)
[0002.667] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.675] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.681] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.690] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:ed:61
[0002.696] Plugin Manager: Parse ODM data 0x00094000
[0002.706] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.721] Find /i2c@7000c000's alias i2c0
[0002.725] get eeprom
[2022-03-28 10:33:12.122]# RECV ASCII>
[0002.734] Find /i2c@7000c500's alias i2c2
[0002.738] get eeprom at 3-a0, size 256, type 0
[0002.742] get eeprom at 3-ae, size 256, type 0
[0002.746] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.752] I2C slave not started
[0002.755] I2C write failed
[0002.757] Writing offset failed
[0002.760] eeprom_init: EEPROM read failed
[0002.764] pm_ids_update: eeprom init failed
[0002.769] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.799] pm_ids
[2022-03-28 10:33:12.177]# RECV ASCII>
[0002.805] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.812] pm_ids_update: pm id update successful
[0002.817] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.822] I2C slave not started
[0002.825] I2C write failed
[0002.828] Writing offset failed
[0002.831] eeprom_init: EEPROM read failed
[0002.835] pm_ids_update: eeprom init failed
[0002.865] Add serial number:1423119048004 as DT property
[0002.873] Applying platform config
[2022-03-28 10:33:12.278]# RECV ASCII>
s
[0002.879] platform-init is not present. Skipping
[0002.884] calling apps_init()
[0002.900] Found 17 GPT partitions in "sdmmc3_user"
[0002.904] Proceeding to Cold Boot
[0002.908] starting app android_boot_app
[0002.911] Device state: unlocked
[0002.914] display console init
[0002.923] could not find regulator
[0002.946] hdmi c
[2022-03-28 10:33:12.348]# RECV ASCII>
able not connected
[0002.950] is_hdmi_needed: HDMI not connected, returning false
[0002.955] hdmi is not connected
[[0002.962] DT entry for leds-pwm not found
0002.958] sor0 is not supported
[0002.969] display_console_init: no valid display out_type
[0002.977] subnode volume_up is not found !
[0002.981] subnode back is not found !
[0002.984] subnode volume_down is not found !
[0002.989] subnode menu is not found !
[0002.992] Gpio keyboard init success
[0003.039] found decompressor handler: lz4-le
[2022-03-28 10:33:12.423]# RECV ASCII>
gacy
[0003.053] decompressing blob (type 1)...
[0003.083] display_resolution: No display init
[0003.087] Failed to retrieve display resolution
[0003.091] Could not load/initialize BMP blob...ignoring
[2022-03-28 10:33:12.512]# RECV ASCII>
[0003.141] decompressor handler not found
[0003.145] load_firmware_blob: Firmware blob loaded, entries=2
[0003.151] -------> se_aes_verify_sbk_clear: 747
[0003.155] se_aes_verify_sbk_clear: Error
[0003.159] bl_battery_charging: connected to external power supply
[0003.167] xusb is supported
[0003.173] error while finding nvidia,portmap
[2022-03-28 10:33:13.101]# RECV ASCII>
[0003.677] xusb blob version 0 size 124416
[0003.681] firmware size 124416
[0003.685] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.699] xhci0: 64 bytes context size, 32-bit DMA
[0003.739] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.759] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[2022-03-28 10:33:13.742]# RECV ASCII>
[0004.409] uhub0: 9 ports with 9 removable, self powered
[2022-03-28 10:33:14.732]# RECV ASCII>
[0005.409] failed to
[2022-03-28 10:33:14.767]# RECV ASCII>
get HID devices
[0005.412] failed to init xhci or no usb device attached
[0005.419] display_console_ioctl: No display init
[0005.424] switch_backlight failed
[0005.434] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0005.441] MSC Partition not found
[0005.451] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0005.458] USP partition read failed!
[0005.461] blob_init: blob-partition USP header read failed
[0005.467] android_boot Unable to update recov
[2022-03-28 10:33:14.828]# RECV ASCII>
ery partition
[0005.472] kfs_getpartname: name = LNX
[0005.476] Loading kernel from LNX
[2022-03-28 10:33:14.891]# RECV ASCII>
[0005.540] load kernel from storage
[0005.549] decompressor handler not found
[2022-03-28 10:33:14.954]# RECV ASCII>
[0005.571] Successfully loaded kernel and ramdisk images
[0005.577] display_resolution: No display init
[0005.582] Failed to retrieve display resolution
[0005.586] bmp blob is not loaded and initialized
[0005.591] Failed to display boot-logo
[0005.594] NCK carveout not present
[0005.597] Skipping dts_overrides
[0005.601] NCK carveout not present
[0005.611] Find /i2c@7000c000's alias i2c0
[0005.615] get eeprom at 1-a0, size 256, type 0
[0005.623] Find /i2c@7000c500's alias i2c2
[0005.627] get eepr
[2022-03-28 10:33:15.013]# RECV ASCII>
[0005.632] get eeprom at 3-ae, size 256, type 0
[0005.636] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.641] I2C slave not started
[0005.644] I2C write failed
[0005.647] Writing offset failed
[0005.650] eeprom_init: EEPROM read failed
[0005.654] pm_ids_update: eeprom init failed
[0005.658] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.688] pm_ids_update: The pm board id
[2022-03-28 10:33:15.081]# RECV ASCII>
is 3448-0002-400
[0005.695] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0005.703] pm_ids_update: pm id update successful
[0005.707] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.712] I2C slave not started
[0005.715] I2C write failed
[0005.718] Writing offset failed
[0005.721] eeprom_init: EEPROM read failed
[0005.725] pm_ids_update: eeprom init failed
[0005.755] eeprom_get_mac: EEPROM invalid
[2022-03-28 10:33:15.266]# RECV ASCII>
[0005.761] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.769] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.775] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.784] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:ed:61
[0005.790] Plugin Manager: Parse ODM data 0x00094000
[0005.800] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0005.808] Add serial number:1423119048004 as DT p
[2022-03-28 10:33:15.271]# RECV ASCII>
roperty
[0005.817] "bpmp" doesn't exist, creating
[0005.823] Updated bpmp info to DTB
[0005.828] Updated initrd info to DTB
[0005.831] "proc-board" doesn't exist, creating
[0005.837] Updated board info to DTB
[0005.840] "pmu-board" doesn't exist, creating
[0005.846] Updated board info to DTB
[0005.849] "display-board" doesn't exist, creating
[0005.855] Updated board info to DTB
[0005.858] "reset" doesn't exist, creating
[0005.863] Updated reset info to DTB
[0005.866] display_console_ioctl:
[2022-03-28 10:33:15.274]# RECV ASCII>
No display init
[0005.870] display_console_ioctl: No display init
[0005.875] display_console_ioctl: No display init
[0005.880] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000
[0005.914] D
[2022-03-28 10:33:15.278]# RECV ASCII>
TB cmdline: earlycon=uart8250,mmio32,0x70006000
[0005.919] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0005.935] Updated bootarg info to DTB
[0005.939] Adding uuid 000000016445c8450c0000000c0083c0 to DT
[0005.945] Adding eks info 0 to DT
[0005.950] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.956] Updated memory info to DTB
[0005.965] set vdd_core voltage to 1125
[2022-03-28 10:33:15.389]# RECV ASCII>
mv
[0005.969] setting 'vdd-core' regulator to 1125000 micro volts
[0005.989] Found secure-pmc; disable BPMP
U-Boot 2016.07-ge6da093be3 (Jun 25 2020 - 21:18:08 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM:
[2022-03-28 10:33:15.547]# RECV ASCII>
4 GiB
[2022-03-28 10:33:15.679]# RECV ASCII>
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Failed to get idcodes
*** Warning - spi_flash_probe() failed, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Card did not respond to voltage select!
** Bad device mmc 1 **
Hit any key to stop autoboot:  1
[2022-03-28 10:33:16.686]# RECV ASCII>
 0
[2022-03-28 10:33:16.781]# RECV ASCII>
switch to partitions #0, OK
mmc0(part 0) is current device
[2022-03-28 10:33:17.483]# RECV ASCII>
Scanning mmc 0:1...
Do you interrupt the uboot ? Why not just let it boot automatically?
