nano system start problem
dear sir
I’m using nano with emmc on my own board,when i disable sd card on SDMMC3 ,the system is normal started,but when i enable the sd card,we got sd card error log and the system is starded so long about 240 seconds,then the system resart, now the system is normal and we can detect the sd card
[   27.919652] mmc1: CMD CRC or end bit error, int mask 0xa0001
dmesg ok
[0000.252] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.258] Processing in cold boot mode Bootloader 2
[0000.262] A02 Bootrom Patch rev = 1023
[0000.266] Power-up reason: pmc por
[0000.269] No Battery Present
[0000.272] pmic max77620 reset reason
[0000.275] pmic max77620 NVERC : 0x40
[0000.278] RamCode = 0
[0000.281] Platform has DDR4 type RAM
[0000.284] max77620 disabling SD1 Remote Sense
[0000.288] Setting DDR voltage to 1125mv
[0000.292] Serial Number of Pmic Max77663: 0x2304ad
[0000.300] Entering ramdump check
[0000.303] Get RamDumpCarveOut = 0x0
[0000.306] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.311] Last reboot was clean, booting normally!
[0000.316] Sdram initialization is successful
[0000.320] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.326] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.332] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.338] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.343] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.349] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.355] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.361] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.377] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.383] Platform-DebugCarveout: 0
[0000.386] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.392] Non secure mode, and RB not enabled.
[0000.409] Csd NumOfBlocks=0
[0000.418] Using GPT Primary to query partitions
[0000.422] Loading Tboot-CPU binary
[0000.428] Verifying TBC in OdmNonSecureSBK mode
[0000.438] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.445] Bootloader downloaded successfully.
[0000.450] Downloaded Tboot-CPU binary to 0xa0000258
[0000.455] MAX77620_GPIO5 configured
[0000.458] CPU power rail is up
[0000.461] CPU clock enabled
[0000.465] Performing RAM repair
[0000.467] Updating A64 Warmreset Address to 0xa00002e9
[0000.473] Loading NvTbootBootloaderDTB
[0000.487] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.554] Bootloader DTB Load Address: 0x83000000
[0000.559] Loading NvTbootKernelDTB
[0000.573] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.638] Kernel DTB Load Address: 0x83100000
[0000.643] Loading cboot binary
[0000.658] Verifying EBT in OdmNonSecureSBK mode
[0000.701] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.708] Bootloader downloaded successfully.
[0000.715] Using BFS PT to query partitions
[0000.719] Next binary entry address: 0x92c00258
[0000.723] BoardId: 3448
[0000.728] Overriding pmu board id with proc board id
[0000.732] Display board id is not available
[0000.748] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.800] /bpmp deleted
[0000.803] SC7EntryFw header found loaded at 0xff700000
[0000.996] OVR2 PMIC
[0000.998] Bpmp FW successfully loaded
[0001.003] WB0 init successfully at 0xff780000
[0001.007] Set NvDecSticky Bits
[0001.011] GSC2 address ff53fffc value c0edbbcc
[0001.017] GSC MC Settings done
[0001.020] TOS Image length 53680
[0001.023]  Monitor size 53680
[0001.026]  OS size 0
[0001.032] Secure Os AES-CMAC Verification Success!
[0001.036] TOS image cipher info: plaintext
[0001.040] Loading and Validation of Secure OS Successful
[0001.056] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.060] NvTbootPackSdramParams: start.
[0001.066] NvTbootPackSdramParams: done.
[0001.069] Tegraboot started after 182864 us
[0001.073] Basic modules init took 572125 us
[0001.077] Sec Bootdevice Read Time = 57 ms, Read Size = 2292 KB
[0001.083] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.089] Next stage binary read took 11916 us
[0001.093] Carveout took -23619 us
[0001.096] CPU initialization took 352133 us
[0001.100] Total time taken by TegraBoot 912555 us
[0001.105] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):a28d87f09
NOTICE:  BL31: Built : 21:10:01, Aug 12 2019
ERROR:   Error initializing runtime service trusty_fast
[0001.227] RamCode = 0
[0001.232] LPDDR4 Training: Read DT: Number of tables = 2
[0001.237] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.249] EMC Training Successful
[0001.252] 408000 not found in DVFS table
[0001.259] RamCode = 0
[0001.262] DT Write: emc-table@204000 succeeded
[0001.268] DT Write: emc-table@1600000 succeeded
[0001.272] LPDDR4 Training: Write DT: Number of tables = 2
[0001.312]
[0001.313] Debug Init done
[0001.315] Marked DTB cacheable
[0001.318] Bootloader DTB loaded at 0x83000000
[0001.323] Marked DTB cacheable
[0001.326] Kernel DTB loaded at 0x83100000
[0001.330] DeviceTree Init done
[0001.341] Pinmux applied successfully
[0001.346] gicd_base: 0x50041000
[0001.349] gicc_base: 0x50042000
[0001.352] Interrupts Init done
[0001.356] Using base:0x60005090 & irq:208 for tick-timer
[0001.361] Using base:0x60005098 for delay-timer
[0001.366] platform_init_timer: DONE
[0001.369] Timer(tick) Init done
[0001.373] osc freq = 38400 khz
[0001.377]
[0001.378] welcome to cboot
[0001.381]
[0001.382] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.387] calling constructors
[0001.390] initializing heap
[0001.393] initializing threads
[0001.396] initializing timers
[0001.398] creating bootstrap completion thread
[0001.403] top of bootstrap2()
[0001.406] CPU: ARM Cortex A57
[0001.409] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.413] initializing platform
[0001.416] Scratch reg 37 & 271 initial value set..
[0001.423] cboot:secure-pmc present
[0001.472] config for ddr50 mode completed
[0001.476] sdmmc bdev is already initialized
[0001.480] Enable APE clock
[0001.483] Un-powergate APE partition
[0001.486] of_register: registering tegra_udc to of_hal
[0001.492] of_register: registering tegra_udc to of_hal
[0001.497] of_register: registering inv20628-driver to of_hal
[0001.502] of_register: registering ads1015-driver to of_hal
[0001.508] of_register: registering lp8557-bl-driver to of_hal
[0001.514] of_register: registering bq2419x_charger to of_hal
[0001.519] of_register: registering cpc to of_hal
[0001.524] of_register: registering bq27441_fuel_gauge to of_hal
[0001.535] gpio framework initialized
[0001.539] of_register: registering tca9539_gpio to of_hal
[0001.544] of_register: registering tca9539_gpio to of_hal
[0001.550] of_register: registering i2c_bus_driver to of_hal
[0001.555] of_register: registering i2c_bus_driver to of_hal
[0001.561] of_register: registering i2c_bus_driver to of_hal
[0001.566] of_register: registering i2c_bus_driver to of_hal
[0001.572] pmic framework initialized
[0001.575] of_register: registering max77620_pmic to of_hal
[0001.581] regulator framework initialized
[0001.585] of_register: registering tps65132_bl_driver to of_hal
[0001.591] initializing target
[0001.596] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.605] fixed regulator driver initialized
[0001.636] initializing OF layer
[0001.639] NCK carveout not present
[0001.642] Skipping dts_overrides
[0001.646] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.663] I2C Bus Init done
[0001.666] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.676] I2C Bus Init done
[0001.679] of_children_init: Ops found for compatible string ti,tca9539
[0001.688] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0001.695] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.702] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.712] I2C Bus Init done
[0001.715] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.725] I2C Bus Init done
[0001.728] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.738] I2C Bus Init done
[0001.741] of_children_init: Ops found for compatible string maxim,max77620
[0001.751] max77620_init using irq 118
[0001.756] register 'maxim,max77620' pmic
[0001.760] gpio_driver_register: register 'max77620-gpio' driver
[0001.767] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.777] I2C Bus Init done
[0001.781] NCK carveout not present
[0001.784] shim_invoke: No NCT, Calling dts updates
[0001.796] Find /i2c@7000c000's alias i2c0
[0001.799] get eeprom at 1-a0, size 256, type 0
[0001.808] Find /i2c@7000c500's alias i2c2
[0001.812] get eeprom at 3-a0, size 256, type 0
[0001.817] get eeprom at 3-ae, size 256, type 0
[0001.821] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.826] I2C slave not started
[0001.829] I2C write failed
[0001.832] Writing offset failed
[0001.835] eeprom_init: EEPROM read failed
[0001.839] pm_ids_update: eeprom init failed
[0001.843] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.873] pm_ids_update: The pm board id is 3448-0002-400
[0001.880] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0001.888] pm_ids_update: pm id update successful
[0001.892] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.897] I2C slave not started
[0001.900] I2C write failed
[0001.903] Writing offset failed
[0001.906] eeprom_init: EEPROM read failed
[0001.910] pm_ids_update: eeprom init failed
[0001.940] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.946] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.954] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.960] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.969] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d7:54
[0001.975] Plugin Manager: Parse ODM data 0x00094000
[0001.985] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.007] Find /i2c@7000c000's alias i2c0
[0002.010] get eeprom at 1-a0, size 256, type 0
[0002.019] Find /i2c@7000c500's alias i2c2
[0002.023] get eeprom at 3-a0, size 256, type 0
[0002.028] get eeprom at 3-ae, size 256, type 0
[0002.032] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.037] I2C slave not started
[0002.040] I2C write failed
[0002.043] Writing offset failed
[0002.046] eeprom_init: EEPROM read failed
[0002.050] pm_ids_update: eeprom init failed
[0002.054] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.084] pm_ids_update: The pm board id is 3448-0002-400
[0002.091] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.098] pm_ids_update: pm id update successful
[0002.102] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.108] I2C slave not started
[0002.111] I2C write failed
[0002.113] Writing offset failed
[0002.116] eeprom_init: EEPROM read failed
[0002.120] pm_ids_update: eeprom init failed
[0002.150] Chip UID is 00000001644495880400000015030400
[0002.155] Add serial number:14230191146290000403 as DT property
[0002.164] Applying platform configs
[0002.170] platform-init is not present. Skipping
[0002.175] calling apps_init()
[0002.191] Found 14 GPT partitions in "sdmmc3_user"
[0002.195] Proceeding to Cold Boot
[0002.199] starting app android_boot_app
[0002.202] Device state: unlocked
[0002.206] display console init
[0002.214] could not find regulator
[0002.217] hdmi cable connected
[0002.252] DT entry for leds-pwm not found
[0004.228] I2C transfer timeout
[0004.230] I2C write failed
[0004.233] Writing offset failed
[0004.236] could not read edid
[0004.242] tmds-config node not found
[0004.246] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0004.261] setting 'vdd-1v8' regulator to 1800000 micro volts
[0004.268] could not find regulator
[0004.271] could not find regulator
[0004.275] could not find regulator
[0004.303] using default cmu settings
[0004.307] dc_hdmi_enable, starting HDMI initialisation
[0004.313] dc_hdmi_enable, HDMI initialisation complete
[0004.318] list and configure display window
[0004.323] display console init completed
[0004.330] subnode volume_up is not found !
[0004.334] subnode back is not found !
[0004.338] subnode volume_down is not found !
[0004.342] subnode menu is not found !
[0004.346] Gpio keyboard init success
[0004.393] found decompressor handler: lz4-legacy
[0004.407] decompressing blob (type 1)...
[0004.441] load_bmp_blob: panelresolution=480 type=0
[0004.490] decompressor handler not found
[0004.494] load_firmware_blob: Firmware blob loaded, entries=2
[0004.500] se_aes_verify_sbk_clear: Error
[0004.503] bl_battery_charging: connected to external power supply
[0004.511] xusb is supported
[0004.517] error while finding nvidia,portmap
[0004.522] could not find regulator
[0005.025] xusb blob version 0 size 124416
[0005.029] firmware size 124416
[0005.034] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0005.048] xhci0: 64 bytes context size, 32-bit DMA
[0005.088] usbus0: 5.0Gbps Super Speed USB v3.0
[0005.108] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0005.758] uhub0: 9 ports with 9 removable, self powered
[0006.758] failed to get HID devices
[0006.762] failed to init xhci or no usb device attached
[0006.776] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0006.783] MSC Partition not found
[0006.792] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0006.800] USP partition read failed!
[0006.803] blob_init: blob-partition USP header read failed
[0006.809] android_boot Unable to update recovery partition
[0006.814] kfs_getpartname: name = LNX
[0006.818] Loading kernel from LNX
[0006.843] Verifying boot image in OdmNonSecureSBK mode
[0006.887] kernel load address: 0x80080000, size: 481248 bytes
[0006.892] ramdisk load address: 0x84100000, size: 0 bytes
[0006.898] load kernel from storage
[0006.907] decompressor handler not found
[0006.927] Successfully loaded kernel and ramdisk images
[0006.933] load_bmp_blob: panelresolution=480 type=0
[0007.006] display bmp image done
[0007.009] NCK carveout not present
[0007.013] Skipping dts_overrides
[0007.016] NCK carveout not present
[0007.019] shim_invoke: No NCT, Calling dts updates
[0007.031] Find /i2c@7000c000's alias i2c0
[0007.034] get eeprom at 1-a0, size 256, type 0
[0007.043] Find /i2c@7000c500's alias i2c2
[0007.047] get eeprom at 3-a0, size 256, type 0
[0007.052] get eeprom at 3-ae, size 256, type 0
[0007.056] pm_ids_update: Updating 1,a0, size 256, type 0
[0007.061] I2C slave not started
[0007.064] I2C write failed
[0007.067] Writing offset failed
[0007.070] eeprom_init: EEPROM read failed
[0007.074] pm_ids_update: eeprom init failed
[0007.078] pm_ids_update: Updating 3,a0, size 256, type 0
[0007.108] pm_ids_update: The pm board id is 3448-0002-400
[0007.115] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0007.122] pm_ids_update: pm id update successful
[0007.127] pm_ids_update: Updating 3,ae, size 256, type 0
[0007.132] I2C slave not started
[0007.135] I2C write failed
[0007.138] Writing offset failed
[0007.141] eeprom_init: EEPROM read failed
[0007.145] pm_ids_update: eeprom init failed
[0007.175] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0007.181] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0007.189] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0007.195] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0007.203] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d7:54
[0007.210] Plugin Manager: Parse ODM data 0x00094000
[0007.219] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0007.234] Add serial number:14230191146290000403 as DT property
[0007.244] "bpmp" doesn't exist, creating
[0007.249] Updated bpmp info to DTB
[0007.254] Updated initrd info to DTB
[0007.257] "proc-board" doesn't exist, creating
[0007.263] Updated board info to DTB
[0007.266] "pmu-board" doesn't exist, creating
[0007.271] Updated board info to DTB
[0007.275] "display-board" doesn't exist, creating
[0007.280] Updated board info to DTB
[0007.284] "reset" doesn't exist, creating
[0007.288] Updated reset info to DTB
[0007.292] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1
[0007.331] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0007.343] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0007.356] Updated bootarg info to DTB
[0007.360] Adding uuid 00000001644495880400000015030400 to DT
[0007.366] Adding eks info 0 to DT
[0007.371] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0007.377] Updated memory info to DTB
[0007.385] set vdd_core voltage to 1075 mv
[0007.389] setting 'vdd-core' regulator to 1075000 micro volts
[0007.408] could not find regulator
[0007.412] Found secure-pmc; disable BPMP
U-Boot 2016.07 (Dec 03 2019 - 18:02:08 +0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM:  4 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MMC: no card present
** Bad device mmc 1 **
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 100 ms (6.8 KiB/s)
L4T boot options
1:      primary kernel
Enter choice: 1:        primary kernel
Retrieving file: /boot/initrd
5562384 bytes read in 194 ms (27.3 MiB/s)
Retrieving file: /boot/Image
34457608 bytes read in 812 ms (40.5 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0    root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
   reserving fdt memory region: addr=80000000 size=20000
   Using Device Tree in place at 0000000083100000, end 0000000083177533
Starting kernel ...
<hit enter to activate fiq debugger>
[   11.123809] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[   11.130994] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   11.137710] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[   11.142859] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   11.149568] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[   11.155148] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   11.161000] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[   11.166235] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[   11.171556] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   11.180874] tegradc tegradc.1: dpd enable lookup fail:-19
[   14.366605] OV2718 ov2718_write_reg:i2c write failed, 3000 = 2
[   21.363805] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[   21.370966] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   21.377675] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[   21.382824] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   21.389532] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[   21.395112] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   21.400952] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[   21.406184] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[   21.411504] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   21.945778] tegradc tegradc.0: hdmi: edid read failed
[   27.507243] OV2718 ov2718_write_reg:i2c write failed, 3000 = 2
[   27.899561] ak89xx 1-000c: akm_self_test ERR: out_of_range 4
[   28.150297] cgroup: cgroup2: unknown option "nsdelegate"
[   29.195625] using random self ethernet address
[   29.200500] using random host ethernet address
[   29.239373] using random self ethernet address
[   29.258711] using random host ethernet address
[   31.427628] tegra_i2c_handle_xfer_error: 9 callbacks suppressed
[   31.427634] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[   32.112237] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
Ubuntu 18.04.2 LTS zalend-desktop ttyS0
zalend-desktop login:
dmesg error
[code][0000.252] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.257] Processing in cold boot mode Bootloader 2
[0000.261] A02 Bootrom Patch rev = 1023
[0000.265] Power-up reason: pmc por
[0000.268] No Battery Present
[0000.271] pmic max77620 reset reason
[0000.274] pmic max77620 NVERC : 0x40
[0000.277] RamCode = 0
[0000.280] Platform has DDR4 type RAM
[0000.283] max77620 disabling SD1 Remote Sense
[0000.287] Setting DDR voltage to 1125mv
[0000.291] Serial Number of Pmic Max77663: 0x2304ad
[0000.299] Entering ramdump check
[0000.302] Get RamDumpCarveOut = 0x0
[0000.305] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.310] Last reboot was clean, booting normally!
[0000.315] Sdram initialization is successful
[0000.319] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.325] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.331] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.337] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.354] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.360] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.376] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.382] Platform-DebugCarveout: 0
[0000.391] Non secure mode, and RB not enabled.
[0000.408] Csd NumOfBlocks=0
[0000.417] Using GPT Primary to query partitions
[0000.449] Downloaded Tboot-CPU binary to 0xa0000258
[0000.454] MAX77620_GPIO5 configured
[0000.457] CPU power rail is up
[0000.460] CPU clock enabled
[0000.464] Performing RAM repair
[0000.472] Loading NvTbootBootloaderDTB
[0000.486] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.553] Bootloader DTB Load Address: 0x83000000
[0000.558] Loading NvTbootKernelDTB
[0000.572] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.637] Kernel DTB Load Address: 0x83100000
[0000.642] Loading cboot binary
[0000.700] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.707] Bootloader downloaded successfully.
[0000.714] Using BFS PT to query partitions
[0000.718] Next binary entry address: 0x92c00258
[0000.727] Overriding pmu board id with proc board id
[0000.802] SC7EntryFw header found loaded at 0xff700000
[0001.010] GSC2 address ff53fffc value c0edbbcc
[0001.031] Secure Os AES-CMAC Verification Success!
[0001.065] NvTbootPackSdramParams: done.
[0001.069] Tegraboot started after 182113 us
[0001.073] Basic modules init took 572308 us
[0001.088] Next stage binary read took 12147 us
[0001.093] Carveout took -23847 us
[0001.096] CPU initialization took 352600 us
[0001.100] Total time taken by TegraBoot 913208 us
[0001.312]
[0001.377]
[0001.381]
[0001.392] initializing threads
[0001.395] initializing timers
[0001.408] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.416] Scratch reg 37 & 271 initial value set…
[0001.491] of_register: registering tegra_udc to of_hal
[0001.549] of_register: registering i2c_bus_driver to of_hal
[0001.590] initializing target
[0001.596] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.695] gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.756] register ‘maxim,max77620’ pmic
[0001.760] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.795] Find /i2c@7000c000’s alias i2c0
[0001.808] Find /i2c@7000c500’s alias i2c2
[0001.816] get eeprom at 3-ae, size 256, type 0
[0001.887] pm_ids_update: pm id update successful
[0001.968] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d7:54
[0002.006] Find /i2c@7000c000’s alias i2c0
[0002.019] Find /i2c@7000c500’s alias i2c2
[0002.027] get eeprom at 3-ae, size 256, type 0
[0002.107] I2C slave not started
[0002.110] I2C write failed
[0002.191] Found 14 GPT partitions in “sdmmc3_user”
[0002.198] starting app android_boot_app
[0002.205] display console init
[0004.227] I2C transfer timeout
[0004.246] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0004.260] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0004.407] decompressing blob (type 1)…
[0006.775] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0006.926] Successfully loaded kernel and ramdisk images
[0007.031] Find /i2c@7000c000’s alias i2c0
[0007.035] get eeprom at 1-a0, size 256, type 0
[0007.044] Find /i2c@7000c500’s alias i2c2
[0007.062] I2C slave not started
[0007.065] I2C write failed
[0007.123] pm_ids_update: pm id update successful
[0007.133] I2C slave not started
[0007.220] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0007.244] “bpmp” doesn’t exist, creating
[0007.257] “proc-board” doesn’t exist, creating
[0007.266] “pmu-board” doesn’t exist, creating
[0007.272] Updated board info to DTB
[0007.275] “display-board” doesn’t exist, creating
[0007.281] Updated board info to DTB
[0007.284] “reset” doesn’t exist, creating
[0007.289] Updated reset info to DTB
[0007.389] setting ‘vdd-core’ regulator to 1075000 micro volts
TEGRA210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1…
733 bytes read in 101 ms (6.8 KiB/s)
L4T boot options
1: primary kernel
5562384 bytes read in 193 ms (27.5 MiB/s)
34457608 bytes read in 811 ms (40.5 MiB/s)
Starting kernel …
[ 11.116669] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128 [ 11.123894] tegra-i2c 7000c700.i2c: --- register dump for debugging ---- [ 11.130613] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00 [ 11.135791] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001 [ 11.142506] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0 [ 11.148087] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040 [ 11.153959] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d [ 11.159198] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0 [ 11.164520] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50 [ 11.173806] tegradc tegradc.1: dpd enable lookup fail:-19 [ 14.340385] OV2718 ov2718_write_reg:i2c write failed, 3000 = 2 [ 21.356663] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128 [ 21.363824] tegra-i2c 7000c700.i2c: --- register dump for debugging ---- [ 21.370532] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00 [ 21.375679] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001 [ 21.382387] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0 [ 21.387965] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040 [ 21.393805] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d [ 21.399034] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0 [ 21.404354] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50 [ 27.477968] OV2718 ov2718_write_reg:i2c write failed, 3000 = 2 [ 27.867147] ak89xx 1-000c: akm_self_test ERR: out_of_range 4 [ 27.919652] mmc1: CMD CRC or end bit error, int mask 0xa0001 [ 31.596755] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128 [ 31.603912] tegra-i2c 7000c700.i2c: --- register dump for debugging ---- [ 31.610624] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00 [ 31.615775] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001 [ 31.622486] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0 [ 31.628070] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040 [ 31.633914] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d [ 31.639147] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0 [ 31.644478] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50 [ 38.508752] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 38.515726] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 38.522437] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 38.527587] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 38.534473] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 38.540059] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 38.545901] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 38.551138] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 38.556545] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 40.044839] mmc1: Timeout waiting for hardware interrupt. [ 40.050229] sdhci: =========== REGISTER DUMP (mmc1)=========== [ 40.056056] sdhci: Sys addr: 0x00000008 | Version: 0x00000303 [ 40.061883] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000008 [ 40.067709] sdhci: Argument: 0x00000000 | Trn mode: 0x0000003b [ 40.073535] sdhci: Present: 0x01fb0008 | Host ctl: 0x00000017 [ 40.079360] sdhci: Power: 0x00000001 | Blk gap: 0x00000000 [ 40.085185] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 40.091011] sdhci: Timeout: 0x0000000e | Int stat: 0x00001000 [ 40.096836] sdhci: Int enab: 0x02ff100b | Sig enab: 0x02fc100b [ 40.102662] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000 [ 40.108487] sdhci: Caps: 0x376cd08c | Caps_1: 0x10006f77 [ 40.114313] sdhci: Cmd: 0x0000123a | Max curr: 0x00000000 [ 40.120137] sdhci: Host ctl2: 0x0000308b [ 40.124057] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe410 [ 40.130627] sdhci: =========================================== [ 48.748740] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 48.755717] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 48.762428] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 48.767581] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 48.774461] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 48.780045] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 48.785890] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 48.791124] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 48.796540] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 48.803059] Failed to set dvfs regulator vdd-core [ 58.988757] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 58.995730] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 59.002438] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 59.007590] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 59.014475] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 59.020058] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 59.025904] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 59.031137] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 59.036551] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 69.228747] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 69.235721] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 69.242434] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 69.247585] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 69.254471] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 69.260056] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 69.265900] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 69.271133] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 69.276552] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 69.283073] Failed to set dvfs regulator vdd-core [ 79.468753] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 79.475726] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 79.482436] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 79.487587] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 79.494469] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 79.500053] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 79.505892] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 79.511130] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 79.516539] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 89.708743] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 89.715718] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 89.722425] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 89.727573] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 89.734455] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 89.740035] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 89.745878] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 89.751112] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 89.756528] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 89.763041] Failed to set dvfs regulator vdd-core [ 89.767757] Failed to set regulator vdd-core for clock cbus to 800 mV [ 99.948743] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 99.955722] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 99.962435] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 99.967588] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 99.974471] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 99.980056] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 99.985900] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 99.991134] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 99.996549] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 110.188741] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 110.195716] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 110.202426] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 110.207577] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 110.214459] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 110.220043] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 110.225882] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 110.231120] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 110.236533] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 110.243051] Failed to set dvfs regulator vdd-core [ 120.428750] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 120.435723] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 120.442437] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 120.447589] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 120.454474] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 120.460059] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 120.465903] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 120.471137] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 120.476546] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 130.668746] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 130.675719] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 130.682429] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 130.687581] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 130.694466] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 130.700051] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 130.705895] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 130.711128] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 130.716544] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 130.723063] Failed to set dvfs regulator vdd-core [ 140.908744] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 140.915722] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 140.922433] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 140.927582] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 140.934466] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 140.940046] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 140.945889] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 140.951123] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 140.956540] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 151.148751] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 151.155727] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 151.162437] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 151.167588] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 151.174474] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 151.180059] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 151.185899] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 151.191137] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 151.196550] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 151.203065] Failed to set dvfs regulator vdd-core [ 151.207781] Failed to set regulator vdd-core for clock vi to 800 mV [ 161.388749] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 161.395724] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 161.402435] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 161.407586] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 161.414472] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 161.420055] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 161.425897] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 161.431134] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 161.436549] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 171.628749] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 171.635722] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 171.642432] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 171.647581] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 171.654465] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 171.660045] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 171.665889] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 171.671122] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 171.676540] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 171.683056] Failed to set dvfs regulator vdd-core [ 181.868740] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 181.875713] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 181.882425] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 181.887576] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 181.894462] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 181.900041] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 181.905885] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 181.911118] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 181.916532] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 192.108741] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 192.115716] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 192.122426] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 192.127576] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 192.134460] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 192.140040] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 192.145884] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 192.151122] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 192.156534] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 192.163046] Failed to set dvfs regulator vdd-core [ 202.348749] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 202.355722] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 202.362434] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 202.367585] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 202.374471] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 202.380056] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 202.385900] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 202.391133] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 202.396546] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 212.588737] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 212.595714] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 212.602424] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 212.607576] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 212.614458] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 212.620042] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 212.625881] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 212.631116] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 212.636531] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 212.643049] Failed to set dvfs regulator vdd-core [ 212.647766] Failed to set regulator vdd-core for clock cbus to 800 mV [ 222.828751] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 222.835725] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 222.842436] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 222.847584] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 222.854468] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 222.860048] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 222.865891] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 222.871125] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 222.876541] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 233.068740] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4 [ 233.075717] tegra-i2c 7000d000.i2c: --- register dump for debugging ---- [ 233.082427] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00 [ 233.087579] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001 [ 233.094464] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0 [ 233.100043] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081 [ 233.105887] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d [ 233.111121] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3 [ 233.116535] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c [ 233.123055] Failed to set dvfs regulator vdd-core [ 242.796752] INFO: task kworker/3:1:651 blocked for more than 120 seconds. [ 242.803556] Tainted: G W 4.9.140 #15 [ 242.808792] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 242.816794] Kernel panic - not syncing: hung_task: blocked tasks [ 242.822801] CPU: 1 PID: 603 Comm: khungtaskd Tainted: G W 4.9.140 #15 [ 242.830363] Hardware name: NVIDIA Jetson Nano Developer Kit (DT) [ 242.836367] Call trace: [ 242.838820] [] dump_backtrace+0x0/0x198 [ 242.844218] [] show_stack+0x24/0x30 [ 242.849268] [] dump_stack+0x98/0xc0 [ 242.854319] [] panic+0x11c/0x298 [ 242.859113] [] watchdog+0x300/0x3b8 [ 242.864166] [] kthread+0xec/0xf0 [ 242.868959] [] ret_from_fork+0x10/0x40 [ 242.874272] SMP: stopping secondary CPUs [ 242.878275] Kernel Offset: disabled [ 242.881756] Memory Limit: none [ 242.893541] Rebooting in 5 seconds.. [0000.205] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49) [0000.210] Processing in cold boot mode Bootloader 2 [0000.215] A02 Bootrom Patch rev = 1023 [0000.218] Power-up reason: software reset [0000.222] No Battery Present [0000.225] pmic max77620 reset reason [0000.228] pmic max77620 NVERC : 0x0 [0000.231] RamCode = 0 [0000.234] Platform has DDR4 type RAM [0000.237] max77620 disabling SD1 Remote Sense [0000.241] Setting DDR voltage to 1125mv [0000.245] Serial Number of Pmic Max77663: 0x2304ad [0000.253] Entering ramdump check [0000.256] Get RamDumpCarveOut = 0x0 [0000.259] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8 [0000.264] Last reboot was clean, booting normally! [0000.269] Sdram initialization is successful [0000.273] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000 [0000.279] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000 [0000.285] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000 [0000.291] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000 [0000.297] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000 [0000.302] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000 [0000.308] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000 [0000.314] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000 [0000.330] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000 [0000.336] Platform-DebugCarveout: 0 [0000.340] Nck Carveout Base=0x00000000ff080000 Size=0x00200000 [0000.345] Non secure mode, and RB not enabled. [0000.362] Csd NumOfBlocks=0 [0000.371] Using GPT Primary to query partitions [0000.375] Loading Tboot-CPU binary [0000.381] Verifying TBC in OdmNonSecureSBK mode [0000.391] Bootloader load address is 0xa0000000, entry address is 0xa0000258 [0000.398] Bootloader downloaded successfully. [0000.402] Downloaded Tboot-CPU binary to 0xa0000258 [0000.408] MAX77620_GPIO5 configured [0000.411] CPU power rail is up [0000.414] CPU clock enabled [0000.417] Performing RAM repair [0000.420] Updating A64 Warmreset Address to 0xa00002e9 [0000.425] Loading NvTbootBootloaderDTB [0000.440] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode [0000.507] Bootloader DTB Load Address: 0x83000000 [0000.512] Loading NvTbootKernelDTB [0000.526] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode [0000.590] Kernel DTB Load Address: 0x83100000 [0000.596] Loading cboot binary [0000.611] Verifying EBT in OdmNonSecureSBK mode [0000.654] Bootloader load address is 0x92c00000, entry address is 0x92c00258 [0000.661] Bootloader downloaded successfully. [0000.668] Using BFS PT to query partitions [0000.672] Next binary entry address: 0x92c00258 [0000.676] BoardId: 3448 [0000.681] Overriding pmu board id with proc board id [0000.686] Display board id is not available [0000.701] Verifying SC7EntryFw in OdmNonSecureSBK mode [0000.753] /bpmp deleted [0000.755] SC7EntryFw header found loaded at 0xff700000 [0000.949] OVR2 PMIC [0000.951] Bpmp FW successfully loaded [0000.956] WB0 init successfully at 0xff780000 [0000.960] Set NvDecSticky Bits [0000.963] GSC2 address ff53fffc value c0edbbcc [0000.970] GSC MC Settings done [0000.973] TOS Image length 53680 [0000.976] Monitor size 53680 [0000.979] OS size 0 [0000.984] Secure Os AES-CMAC Verification Success! [0000.989] TOS image cipher info: plaintext [0000.993] Loading and Validation of Secure OS Successful [0001.009] SC7 Entry Firmware - 0xff700000, 0x4000 [0001.013] NvTbootPackSdramParams: start. [0001.018] NvTbootPackSdramParams: done. [0001.022] Tegraboot started after 134300 us [0001.026] Basic modules init took 572661 us [0001.030] Sec Bootdevice Read Time = 56 ms, Read Size = 2292 KB [0001.036] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB [0001.041] Next stage binary read took 11574 us [0001.046] Carveout took -23273 us [0001.049] CPU initialization took 351733 us [0001.053] Total time taken by TegraBoot 912695 us
[0001.057] Starting CPU & Halting co-processor
[0001.180] RamCode = 0
[0001.184] LPDDR4 Training: Read DT: Number of tables = 2
[0001.189] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.202] EMC Training Successful
[0001.205] 408000 not found in DVFS table
[0001.212] RamCode = 0
[0001.215] DT Write: emc-table@204000 succeeded
[0001.221] DT Write: emc-table@1600000 succeeded
[0001.225] LPDDR4 Training: Write DT: Number of tables = 2
[0001.263]
[0001.264] Debug Init done
[0001.267] Marked DTB cacheable
[0001.270] Bootloader DTB loaded at 0x83000000
[0001.275] Marked DTB cacheable
[0001.277] Kernel DTB loaded at 0x83100000
[0001.281] DeviceTree Init done
[0001.293] Pinmux applied successfully
[0001.297] gicd_base: 0x50041000
[0001.301] gicc_base: 0x50042000
[0001.304] Interrupts Init done
[0001.308] Using base:0x60005090 & irq:208 for tick-timer
[0001.313] Using base:0x60005098 for delay-timer
[0001.317] platform_init_timer: DONE
[0001.321] Timer(tick) Init done
[0001.325] osc freq = 38400 khz
[0001.329]
[0001.330] welcome to cboot
[0001.332]
[0001.334] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.339] calling constructors
[0001.342] initializing heap
[0001.344] initializing threads
[0001.347] initializing timers
[0001.350] creating bootstrap completion thread
[0001.354] top of bootstrap2()
[0001.357] CPU: ARM Cortex A57
[0001.360] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.365] initializing platform
[0001.368] Scratch reg 37 & 271 initial value set…
[0001.374] cboot:secure-pmc present
[0001.424] config for ddr50 mode completed
[0001.428] sdmmc bdev is already initialized
[0001.432] Enable APE clock
[0001.435] Un-powergate APE partition
[0001.438] of_register: registering tegra_udc to of_hal
[0001.443] of_register: registering tegra_udc to of_hal
[0001.448] of_register: registering inv20628-driver to of_hal
[0001.454] of_register: registering ads1015-driver to of_hal
[0001.459] of_register: registering lp8557-bl-driver to of_hal
[0001.465] of_register: registering bq2419x_charger to of_hal
[0001.471] of_register: registering cpc to of_hal
[0001.475] of_register: registering bq27441_fuel_gauge to of_hal
[0001.487] gpio framework initialized
[0001.490] of_register: registering tca9539_gpio to of_hal
[0001.496] of_register: registering tca9539_gpio to of_hal
[0001.501] of_register: registering i2c_bus_driver to of_hal
[0001.507] of_register: registering i2c_bus_driver to of_hal
[0001.512] of_register: registering i2c_bus_driver to of_hal
[0001.518] of
[0001.518] of_register: registering i2c_bus_driver to of_hal
[0001.523] pmic framework initialized
[0001.527] of_register: registering max77620_pmic to of_hal
[0001.532] regulator framework initialized
[0001.536] of_register: registering tps65132_bl_driver to of_hal
[0001.542] initializing target
[0001.548] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.557] fixed regulator driver initialized
[0001.587] initializing OF layer
[0001.590] NCK carveout not present
[0001.594] Skipping dts_overrides
[0001.598] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.615] I2C Bus Init done
[0001.617] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.628] I2C Bus Init done
[0001.630] of_children_init: Ops found for compatible string ti,tca9539
[0001.640] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0001.647] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.653] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.664] I2C Bus Init done
[0001.677] I2C Bus Init done
[0001.679] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.690] I2C Bus Init done
[0001.693] of_children_init: Ops found for compatible string maxim,max77620
[0001.703] max77620_init using irq 118
[0001.708] register 'maxim,max77620' pmic
[0001.712] gpio_driver_register: register 'max77620-gpio' driver
[0001.718] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.729] I2C Bus Init done
[0001.732] NCK carveout not present
[0001.736] shim_invoke: No NCT, Calling dts updates
[0001.747] Find /i2c@7000c000's alias i2c0
[0001.751] get eeprom at 1-a0, size 256, type 0
[0001.760] Find /i2c@7000c500's alias i2c2
[0001.764] get eeprom at 3-a0, size 256, type 0
[0001.768] get eeprom at 3-ae, size 256, type 0
[0001.773] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.778] I2C slave not started
[0001.781] I2C write failed
[0001.783] Writing offset failed
[0001.786] eeprom_init: EEPROM read failed
[0001.790] pm_ids_update: eeprom init failed
[0001.795] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.825] pm_ids_update: The pm board id is 3448-0002-400
[0001.832] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0001.839] pm_ids_update: pm id update successful
[0001.844] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.849] I2C slave not started
[0001.852] I2C write failed
[0001.855] Writing offset failed
[0001.858] eeprom_init: EEPROM read failed
[0001.862] pm_ids_update: eeprom init failed
[0001.892] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.898] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.906] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.912] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.920] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d7:54
[0001.927] Plugin Manager: Parse ODM data 0x00094000
[0001.937] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0001.958] Find /i2c@7000c000's alias i2c0
[0001.962] get eeprom at 1-a0, size 256, type 0
[0001.971] Find /i2c@7000c500's alias i2c2
[0001.975] get eeprom at 3-a0, size 256, type 0
[0001.980] get eeprom at 3-ae, size 256, type 0
[0001.984] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.989] I2C slave not started
[0001.992] I2C write failed
[0001.995] Writing offset failed
[0001.998] eeprom_init: EEPROM read failed
[0002.002] pm_ids_update: eeprom init failed
[0002.006] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.036] pm_ids_update: The pm board id is 3448-0002-400
[0002.043] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.050] pm_ids_update: pm id update successful
[0002.054] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.060] I2C slave not started
[0002.062] I2C write failed
[0002.065] Writing offset failed
[0002.068] eeprom_init: EEPROM read failed
[0002.072] pm_ids_update: eeprom init failed
[0002.102] Chip UID is 00000001644495880400000015030400
[0002.107] Add serial number:14230191146290000403 as DT property
[0002.116] Applying platform configs
[0002.122] platform-init is not present. Skipping
[0002.127] calling apps_init()
[0002.143] Found 14 GPT partitions in "sdmmc3_user"
[0002.147] Proceeding to Cold Boot
[0002.150] starting app android_boot_app
[0002.154] Device state: unlocked
[0002.157] display console init
[0002.166] could not find regulator
[0002.169] hdmi cable connected
[0002.203] DT entry for leds-pwm not found
[0004.179] I2C transfer timeout
[0004.182] I2C write failed
[0004.185] Writing offset failed
[0004.188] could not read edid
[0004.194] tmds-config node not found
[0004.198] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0004.213] setting 'vdd-1v8' regulator to 1800000 micro volts
[0004.220] could not find regulator
[0004.223] could not find regulator
[0004.227] could not find regulator
[0004.255] using default cmu settings
[0004.259] dc_hdmi_enable, starting HDMI initialisation
[0004.265] dc_hdmi_enable, HDMI initialisation complete
[0004.270] list and configure display window
[0004.275] display console init completed
[0004.282] subnode volume_up is not found !
[0004.286] subnode back is not found !
[0004.290] subnode volume_down is not found !
[0004.294] subnode menu is not found !
[0004.298] Gpio keyboard init success
[0004.345] found decompressor handler: lz4-legacy
[0004.359] decompressing blob (type 1)...
[0004.393] load_bmp_blob: panelresolution=480 type=0
[0004.442] decompressor handler not found
[0004.446] load_firmware_blob: Firmware blob loaded, entries=2
[0004.452] se_aes_verify_sbk_clear: Error
[0004.455] bl_battery_charging: connected to external power supply
[0004.463] xusb is supported
[0004.469] error while finding nvidia,portmap
[0004.474] could not find regulator
[0004.977] xusb blob version 0 size 124416
[0004.981] firmware size 124416
[0004.986] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0005.000] xhci0: 64 bytes context size, 32-bit DMA
[0005.040] usbus0: 5.0Gbps Super Speed USB v3.0
[0005.060] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0005.710] uhub0: 9 ports with 9 removable, self powered
[0007.870] failed to get HID devices
[0007.873] failed to init xhci or no usb device attached
[0007.887] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0007.895] MSC Partition not found
[0007.904] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0007.912] USP partition read failed!
[0007.915] blob_init: blob-partition USP header read failed
[0007.921] android_boot Unable to update recovery partition
[0007.926] kfs_getpartname: name = LNX
[0007.930] Loading kernel from LNX
[0007.955] Verifying boot image in OdmNonSecureSBK mode
[0007.998] kernel load address: 0x80080000, size: 481248 bytes
[0008.004] ramdisk load address: 0x84100000, size: 0 bytes
[0008.009] load kernel from storage
[0008.019] decompressor handler not found
[0008.038] Successfully loaded kernel and ramdisk images
[0008.045] load_bmp_blob: panelresolution=480 type=0
[0008.118] display bmp image done
[0008.121] NCK carveout not present
[0008.125] Skipping dts_overrides
[0008.128] NCK carveout not present
[0008.131] shim_invoke: No NCT, Calling dts updates
[0008.142] Find /i2c@7000c000's alias i2c0
[0008.146] get eeprom at 1-a0, size 256, type 0
[0008.155] Find /i2c@7000c500's alias i2c2
[0008.159] get eeprom at 3-a0, size 256, type 0
[0008.163] get eeprom at 3-ae, size 256, type 0
[0008.168] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.173] I2C slave not started
[0008.176] I2C write failed
[0008.179] Writing offset failed
[0008.182] eeprom_init: EEPROM read failed
[0008.186] pm_ids_update: eeprom init failed
[0008.190] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.220] pm_ids_update: The pm board id is 3448-0002-400
[0008.227] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0008.234] pm_ids_update: pm id update successful
[0008.239] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.244] I2C slave not started
[0008.247] I2C write failed
[0008.250] Writing offset failed
[0008.253] eeprom_init: EEPROM read failed
[0008.257] pm_ids_update: eeprom init failed
[0008.287] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.293] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0008.301] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.307] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0008.315] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d7:54
[0008.321] Plugin Manager: Parse ODM data 0x00094000
[0008.331] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.346] Add serial number:14230191146290000403 as DT property
[0008.355] "bpmp" doesn't exist, creating
[0008.361] Updated bpmp info to DTB
[0008.366] Updated initrd info to DTB
[0008.369] "proc-board" doesn't exist, creating
[0008.375] Updated board info to DTB
[0008.378] "pmu-board" doesn't exist, creating
[0008.383] Updated board info to DTB
[0008.387] "display-board" doesn't exist, creating
[0008.392] Updated board info to DTB
[0008.396] "reset" doesn't exist, creating
[0008.400] Updated reset info to DTB
[0008.404] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1
[0008.442] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.455] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.468] Updated bootarg info to DTB
[0008.472] Adding uuid 00000001644495880400000015030400 to DT
[0008.477] Adding eks info 0 to DT
[0008.483] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0008.489] Updated memory info to DTB
[0008.497] set vdd_core voltage to 1075 mv
[0008.501] setting 'vdd-core' regulator to 1075000 micro volts
[0008.520] could not find regulator
[0008.524] Found secure-pmc; disable BPMP
TEGRA210
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 0:1...
L4T boot options
1:      primary kernel
Starting kernel ...
[   11.127925] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[   11.135114] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   11.141844] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[   11.146995] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   11.153703] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[   11.159284] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   11.165127] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[   11.170360] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[   11.175682] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   11.184985] tegradc tegradc.1: dpd enable lookup fail:-19
[   14.370812] OV2718 ov2718_write_reg:i2c write failed, 3000 = 2
[   21.367913] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[   21.375073] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   21.381786] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[   21.386933] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   21.393640] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[   21.399220] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   21.405061] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[   21.410293] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[   21.415615] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   27.506651] OV2718 ov2718_write_reg:i2c write failed, 3000 = 2
[   27.904357] ak89xx 1-000c: akm_self_test ERR: out_of_range 4
[   28.137475] cgroup: cgroup2: unknown option "nsdelegate"
[   29.202166] using random self ethernet address
[   29.206777] using random host ethernet address
[   29.262937] using random self ethernet address
[   29.282121] using random host ethernet address
[   31.607983] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[   31.615159] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   31.627502] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[   31.627506] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   31.627509] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[   31.627512] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   31.627515] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[   31.627518] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[   31.627523] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   41.848690] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[   41.848728] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   41.848764] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[   41.848795] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   41.848827] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[   41.848858] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   41.848890] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[   41.848920] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[   41.848957] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   52.088594] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[   52.088631] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   52.088664] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[   52.088694] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   52.088726] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[   52.088757] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   52.088790] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[   52.088819] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[   52.088856] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
~$ dmesg |grep mmc1
[    0.620089] tegra210_dvfs: no clock found for sdmmc1_ddr
[   27.588066] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[   27.626923] mmc1: host does not support reading read-only switch, assuming write-enable
[   27.633343] mmc1: new high speed SDXC card at address aaaa
[   27.637166] mmcblk1: mmc1:aaaa SC64G 59.5 GiB
[   27.795938] mmcblk mmc1:aaaa: Card claimed for testing.
Hi dgw_1985,
Please continue posting issue at previous topic:
https://devtalk.nvidia.com/default/topic/1066922/jetson-nano/can-not-detect-sd-card/post/5407410/#5407410
