Nano 4G emmc after flash can't boot
How can I solve this problem?
This is the flash log
sudo BOARDID=3448 BOARDSKU=0002 FAB=400 ./flash.sh -r jetson-nano-emmc mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 7.3
# Target Board Information:
# Name: jetson-nano-emmc, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
# Disk encryption: disabled ,
Board ID(“3448”) version(“400”)
copying bctfile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
Existing sosfile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
copying wb0boot(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
Existing tbcfile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)... done.
copying cfgfile(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_emmc_p3448.xml) to flash.xml... done.
copying flasher(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct  P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin  --cmd "flash; reboot"  --cfg flash.xml --chip 0x21   --skipuid --bins "EBT cboot.bin; DTB tegra210-p3448-0002-p3449-0000-b00.dtb"
saving flash command in /home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/user/Downloads/ch341ser_linux/Linux_for_Tegra/bootloader/flash_win.bat
assign_value: crc-flash.xml.bin 1 131056 1
printf '\x1' | dd of=crc-flash.xml.bin bs=1 seek=131056 count=1 conv=notrunc
记录了1+0 的读入
记录了1+0 的写出
1字节已复制,0.000109889 s,9.1 kB/s
assign_value: crc-flash.xml.bin 0 131057 1
printf '\x0' | dd of=crc-flash.xml.bin bs=1 seek=131057 count=1 conv=notrunc
记录了1+0 的读入
记录了1+0 的写出
1字节已复制,0.000100073 s,10.0 kB/s
assign_string: crc-flash.xml.bin PTHD 131064 4
echo PTHD | dd of=crc-flash.xml.bin bs=1 seek=131064 count=4 conv=notrunc
记录了4+0 的读入
记录了4+0 的写出
4字节已复制,9.3457e-05 s,42.8 kB/s
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0017 ] tegrasign --getmode mode.txt --key None
[   0.0023 ] Assuming zero filled SBK key
[   0.0024 ]
[   0.0024 ] Generating RCM messages
[   0.0041 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[   0.0045 ] RCM 0 is saved as rcm_0.rcm
[   0.0047 ] RCM 1 is saved as rcm_1.rcm
[   0.0048 ] List of rcm files are saved in rcm_list.xml
[   0.0048 ]
[   0.0048 ] Signing RCM messages
[   0.0063 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0068 ] Assuming zero filled SBK key
[   0.0102 ]
[   0.0102 ] Copying signature to RCM mesages
[   0.0119 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[   0.0126 ]
[   0.0126 ] Parsing partition layout
[   0.0141 ] tegraparser --pt flash.xml.tmp
[   0.0151 ]
[   0.0152 ] Using default ramcode: 0
[   0.0152 ] Disable BPMP dtb trim, using default dtb
[   0.0152 ]
[   0.0153 ] Creating list of images to be signed
[   0.0169 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[   0.0208 ]
[   0.0208 ] Generating signatures
[   0.0228 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[   0.0233 ] Assuming zero filled SBK key
[   0.0937 ]
[   0.0937 ] Generating br-bct
[   0.0954 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[   0.0977 ]
[   0.0977 ] Updating boot device parameters
[   0.0983 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[   0.0988 ] Warning: No sdram params
[   0.0989 ]
[   0.0989 ] Updating bl info
[   0.1005 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   0.1016 ]
[   0.1016 ] Updating secondary storage information into bct
[   0.1033 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[   0.1039 ]
[   0.1039 ] Updating Odmdata
[   0.1044 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[   0.1054 ] Warning: No sdram params
[   0.1055 ]
[   0.1055 ] Get Signed section of bct
[   0.1071 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[   0.1076 ]
[   0.1076 ] Signing BCT
[   0.1108 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[   0.1113 ] Assuming zero filled SBK key
[   0.1116 ]
[   0.1117 ] Updating BCT with signature
[   0.1134 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[   0.1141 ]
[   0.1141 ] Copying signatures
[   0.1159 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   0.1228 ]
[   0.1228 ] Updating BFS information on BCT
[   0.1254 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[   0.1268 ]    BFS:
[   0.1292 ]      0: [PT ] crc-flash.xml.bin (size=131072/131072)
[   0.1298 ]      1: [TBC] nvtboot_cpu.bin.encrypt (size=65760/196608)
[   0.1304 ]      2: [RP1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[   0.1313 ]      3: [EBT] cboot.bin.encrypt (size=484464/655360)
[   0.1317 ]      4: [WB0] warmboot.bin.encrypt (size=3952/131072)
[   0.1321 ]      5: [BPF] sc7entry-firmware.bin.encrypt (size=3376/262144)
[   0.1326 ] BFS0: 131072 @ 2560 SUM 25796f2d over 2883584 bytes
[   0.1328 ]    BFS:
[   0.1329 ]      0: [PT-1] crc-flash.xml.bin (size=131072/131072)
[   0.1331 ]      1: [TBC-1] nvtboot_cpu.bin.encrypt (size=65760/196608)
[   0.1332 ]      2: [RP1-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[   0.1334 ]      3: [EBT-1] cboot.bin.encrypt (size=484464/655360)
[   0.1335 ]      4: [WB0-1] warmboot.bin.encrypt (size=3952/131072)
[   0.1336 ]      5: [BPF-1] sc7entry-firmware.bin.encrypt (size=3376/262144)
[   0.1337 ]      8: [VER_b] emmc_bootblob_ver.txt (size=114/32768)
[   0.1338 ]      9: [VER] emmc_bootblob_ver.txt (size=114/32768)
[   0.1340 ] BFS1: 131072 @ 8704 SUM 25796f2d over 2981888 bytes
[   0.1341 ]    KFS:
[   0.1503 ]      0: [DTB] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[   0.1505 ]      1: [TOS] tos-mon-only.img.encrypt (size=54208/6291456)
[   0.1507 ]      2: [EKS] eks.img (size=1028/81920)
[   0.1508 ]      3: [LNX] boot.img.encrypt (size=667648/67092480)
[   0.1509 ] KFS0: 1048576 @ 29376546 SUM 35569660 over 8089600 bytes
[   0.1534 ]    KFS:
[   0.1699 ]      0: [DTB-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=238224/1048576)
[   0.1701 ]      1: [TOS-1] tos-mon-only.img.encrypt (size=54208/6291456)
[   0.1702 ]      2: [EKS-1] eks.img (size=1028/81920)
[   0.1703 ]      3: [LNX-1] boot.img.encrypt (size=667648/67092480)
[   0.1705 ] KFS1: 1048576 @ 29522082 SUM 35569660 over 8089600 bytes
[   0.1726 ]
[   0.1727 ] Boot Rom communication
[   0.1743 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[   0.1748 ] RCM version 0X210001
[   0.2198 ] Boot Rom communication completed
[   1.2348 ]
[   1.2349 ] Sending BCTs
[   1.2371 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[   1.2376 ] Applet version 00.01.0000
[   1.2400 ] Sending bct
[   1.2400 ] [................................................] 100%
[   1.4659 ]
[   1.4701 ] tegrahost --chip 0x21 --align cboot.bin
[   1.4724 ]
[   1.4761 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[   1.4820 ]
[   1.4862 ] tegrasign --key None --list cboot.bin_list.xml
[   1.4883 ] Assuming zero filled SBK key
[   1.5006 ]
[   1.5024 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[   1.5033 ]
[   1.5053 ] tegrahost --chip 0x21 --align tegra210-p3448-0002-p3449-0000-b00.dtb
[   1.5059 ]
[   1.5078 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0002-p3449-0000-b00.dtb tegra210-p3448-0002-p3449-0000-b00.dtb_blheader
[   1.5090 ]
[   1.5112 ] tegrasign --key None --list tegra210-p3448-0002-p3449-0000-b00.dtb_list.xml
[   1.5122 ] Assuming zero filled SBK key
[   1.5195 ]
[   1.5214 ] tegrahost --updatesigheader tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.hash zerosbk
[   1.5224 ]
[   1.5226 ] Sending bootloader and pre-requisite binaries
[   1.5244 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
[   1.5249 ] Applet version 00.01.0000
[   1.5276 ] Sending ebt
[   1.5278 ] [................................................] 100%
[   1.6455 ] Sending rp1
[   1.6502 ] [................................................] 100%
[   1.7110 ]
[   1.7131 ] tegrarcm --boot recovery
[   1.7136 ] Applet version 00.01.0000
[   1.7168 ]
[   1.7169 ] Retrieving storage infomation
[   1.7186 ] tegrarcm --oem platformdetails storage storage_info.bin
[   1.7190 ] Applet is not running on device. Continue with Bootloader
[   2.3363 ]
[   2.3381 ] tegradevflash --oem platformdetails storage storage_info.bin
[   2.3387 ] Cboot version 00.01.0000
[   2.3408 ] Saved platform info in storage_info.bin
[   2.3424 ]
[   2.3424 ] Flashing the device
[   2.3429 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[   2.3434 ] Cboot version 00.01.0000
[   2.3455 ] Writing partition GPT with gpt.bin
[   2.3456 ] [................................................] 100%
[   2.3524 ] Writing partition PT with crc-flash.xml.bin
[   2.7823 ] [................................................] 100%
[   2.7956 ] Writing partition PT-1 with crc-flash.xml.bin
[   2.8077 ] [................................................] 100%
[   2.8320 ] Writing partition NVC with nvtboot.bin.encrypt
[   2.8729 ] [................................................] 100%
[   2.8956 ] Writing partition TBC with nvtboot_cpu.bin.encrypt
[   2.9267 ] [................................................] 100%
[   2.9479 ] Writing partition RP1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[   2.9961 ] [................................................] 100%
[   3.0261 ] Writing partition EBT with cboot.bin.encrypt
[   3.0777 ] [................................................] 100%
[   3.1256 ] Writing partition WB0 with warmboot.bin.encrypt
[   3.1800 ] [................................................] 100%
[   3.1971 ] Writing partition BPF with sc7entry-firmware.bin.encrypt
[   3.2457 ] [................................................] 100%
[   3.2626 ] Writing partition NVC-1 with nvtboot.bin.encrypt
[   3.3130 ] [................................................] 100%
[   3.3428 ] Writing partition TBC-1 with nvtboot_cpu.bin.encrypt
[   3.4063 ] [................................................] 100%
[   3.4301 ] Writing partition RP1-1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[   3.4923 ] [................................................] 100%
[   3.5282 ] Writing partition EBT-1 with cboot.bin.encrypt
[   3.5930 ] [................................................] 100%
[   3.6398 ] Writing partition WB0-1 with warmboot.bin.encrypt
[   3.7059 ] [................................................] 100%
[   3.7235 ] Writing partition BPF-1 with sc7entry-firmware.bin.encrypt
[   3.7842 ] [................................................] 100%
[   3.8012 ] Writing partition VER_b with emmc_bootblob_ver.txt
[   3.8641 ] [................................................] 100%
[   3.8830 ] Writing partition VER with emmc_bootblob_ver.txt
[   3.9348 ] [................................................] 100%
[   3.9532 ] Writing partition APP with system.img
[   4.0041 ] [................................................] 100%
[ 134.1357 ] Writing partition DTB with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 134.7668 ] [................................................] 100%
[ 134.7934 ] Writing partition TOS with tos-mon-only.img.encrypt
[ 134.8346 ] [................................................] 100%
[ 134.8500 ] Warning: EKS partition magic header mismatch!
[ 134.8875 ] Writing partition EKS with eks.img
[ 134.8876 ] [................................................] 100%
[ 134.8981 ] Writing partition LNX with boot.img.encrypt
[ 134.9360 ] [................................................] 100%
[ 134.9936 ] Writing partition DTB-1 with kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 135.0458 ] [................................................] 100%
[ 135.0731 ] Writing partition TOS-1 with tos-mon-only.img.encrypt
[ 135.1133 ] [................................................] 100%
[ 135.1278 ] Writing partition EKS-1 with eks.img
[ 135.1662 ] [................................................] 100%
[ 135.1791 ] Writing partition LNX-1 with boot.img.encrypt
[ 135.2168 ] [................................................] 100%
[ 135.2757 ] Writing partition BMP with bmp.blob
[ 135.3265 ] [................................................] 100%
[ 135.3866 ] Writing partition RP4 with rp4.blob
[ 135.4255 ] [................................................] 100%
[ 135.4848 ]
[ 135.4866 ] tegradevflash --write BCT P3448_A00_lpddr4_204Mhz_P987.bct
[ 135.4871 ] Cboot version 00.01.0000
[ 135.4889 ] Writing partition BCT with P3448_A00_lpddr4_204Mhz_P987.bct
[ 135.4891 ] [................................................] 100%
[ 135.8901 ]
[ 135.8901 ] Flashing completed
[ 135.8902 ] Coldbooting the device
[ 135.8920 ] tegradevflash --reboot coldboot
[ 135.8925 ] Cboot version 00.01.0000
[ 135.8949 ]
*** The target t210ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
This is the output of the serial port
[0000.252] [L4T TegraBoot] (version 00.00.2018.01-l4t-8)
[0000.257] Processing in cold boot mode Bootloader 2
[0000.262] A02 Bootrom Patch rev = 1023
[0000.266] Power-up reason: pmc por
[0000.269] No Battery Present
[0000.271] pmic max77620 reset reason
[0000.275] pmic max77620 NVERC : 0x40
[0000.278] RamCode = 0
[0000.280] Platform has DDR4 type RAM
[0000.284] max77620 disabling SD1 Remote Sense
[0000.288] Setting DDR voltage to 1125mv
[0000.292] Serial Number of Pmic Max77663: 0x2135f0
[0000.300] Entering ramdump check
[0000.303] Get RamDumpCarveOut = 0x0
[0000.306] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.311] Last reboot was clean, booting normally!
[0000.316] Sdram initialization is successful
[0000.320] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.326] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.332] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.337] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.343] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.349] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.355] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.361] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.377] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.383] Platform-DebugCarveout: 0
[0000.386] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.392] Non secure mode, and RB not enabled.
[0000.396] *** Booting BFS0.
[0000.399] Initialize FailControl
[0000.402] Read PT from (0:3)
[0000.417] Csd NumOfBlocks=0
[0000.456] PT crc32 and magic check passed.
[0000.460] Using BFS PT to query partitions
[0000.464] PT: Partition LNX NOT found !
[0000.468] *** Booting KFS0.
[0000.470] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.476] BoardID = 3448, SKU = 0x2
[0000.480] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.485] Read GPT from (0:3)
[0000.494] Using GPT Primary to query partitions
[0000.498] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.505] Loading Tboot-CPU binary
[0000.510] Verifying TBC in OdmNonSecureSBK mode
[0000.520] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.527] Bootloader downloaded successfully.
[0000.532] Downloaded Tboot-CPU binary to 0xa0000258
[0000.537] MAX77620_GPIO5 configured
[0000.540] CPU power rail is up
[0000.543] CPU clock enabled
[0000.546] Performing RAM repair
[0000.549] Updating A64 Warmreset Address to 0xa00002e9
[0000.554] BoardID = 3448, SKU = 0x2
[0000.558] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.564] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.570] Loading NvTbootBootloaderDTB
[0000.587] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.658] Bootloader DTB Load Address: 0x83000000
[0000.663] BoardID = 3448, SKU = 0x2
[0000.666] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.672] Loading NvTbootKernelDTB
[0000.697] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.769] Kernel DTB Load Address: 0x83100000
[0000.773] BoardID = 3448, SKU = 0x2
[0000.776] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.782] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.789] Loading cboot binary
[0000.800] Verifying EBT in OdmNonSecureSBK mode
[0000.842] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.849] Bootloader downloaded successfully.
[0000.853] BoardID = 3448, SKU = 0x2
[0000.856] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.862] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.869] PT: Partition NCT NOT found !
[0000.872] Warning: Find Partition via PT Failed
[0000.877] Next binary entry address: 0x92c00258
[0000.881] BoardId: 3448
[0000.886] Overriding pmu board id with proc board id
[0000.891] Display board id is not available
[0000.895] BoardID = 3448, SKU = 0x2
[0000.898] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.904] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.917] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.973] /bpmp deleted
[0000.976] SC7EntryFw header found loaded at 0xff700000
[0001.164] OVR2 PMIC
[0001.166] Bpmp FW successfully loaded
[0001.169] BoardID = 3448, SKU = 0x2
[0001.172] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.178] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.185] WB0 init successfully at 0xff780000
[0001.190] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.195] Set NvDecSticky Bits
[0001.198] GSC2 address ff53fffc value c0edbbcc
[0001.205] GSC MC Settings done
[0001.208] BoardID = 3448, SKU = 0x2
[0001.211] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.218] TOS Image length 53680
[0001.221]  Monitor size 53680
[0001.223]  OS size 0
[0001.229] Secure Os AES-CMAC Verification Success!
[0001.233] TOS image cipher info: plaintext
[0001.237] Loading and Validation of Secure OS Successful
[0001.253] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.258] NvTbootPackSdramParams: start.
[0001.263] NvTbootPackSdramParams: done.
[0001.267] Tegraboot started after 182128 us
[0001.271] Basic modules init took 750464 us
[0001.275] Sec Bootdevice Read Time = 63 ms, Read Size = 3682 KB
[0001.280] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.286] Next stage binary read took 7381 us
[0001.290] Carveout took -34773 us
[0001.293] CPU initialization took 392174 us
[0001.297] Total time taken by TegraBoot 1115246 us
[0001.302] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):9892ce1
NOTICE:  BL31: Built : 09:21:33, Nov 22 2022
ERROR:   Error initializing runtime service trusty_fast
[0001.424] RamCode = 0
[0001.429] LPDDR4 Training: Read DT: Number of tables = 2
[0001.434] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.446] EMC Training Successful
[0001.449] 408000 not found in DVFS table
[0001.456] RamCode = 0
[0001.459] DT Write: emc-table@204000 succeeded
[0001.465] DT Write: emc-table@1600000 succeeded
[0001.469] LPDDR4 Training: Write DT: Number of tables = 2
[0001.513]
[0001.514] Debug Init done
[0001.517] Marked DTB cacheable
[0001.519] Bootloader DTB loaded at 0x83000000
[0001.524] Marked DTB cacheable
[0001.527] Kernel DTB loaded at 0x83100000
[0001.531] DeviceTree Init done
[0001.544] Pinmux applied successfully
[0001.548] gicd_base: 0x50041000
[0001.552] gicc_base: 0x50042000
[0001.555] Interrupts Init done
[0001.559] Using base:0x60005090 & irq:208 for tick-timer
[0001.564] Using base:0x60005098 for delay-timer
[0001.569] platform_init_timer: DONE
[0001.572] Timer(tick) Init done
[0001.576] osc freq = 38400 khz
[0001.580]
[0001.581] Welcome to L4T Cboot
[0001.584]
[0001.585] Cboot Version: 00.00.2018.01-t210-a2f2e4b8
[0001.590] calling constructors
[0001.593] initializing heap
[0001.596] initializing threads
[0001.599] initializing timers
[0001.601] creating bootstrap completion thread
[0001.606] top of bootstrap2()
[0001.609] CPU: ARM Cortex A57
[0001.612] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.616] initializing platform
[0001.670] Config for emmc ddr50 mode completed
[0001.674] sdmmc bdev is already initialized
[0001.678] Enable APE clock
[0001.681] Un-powergate APE partition
[0001.685] of_register: registering tegra_udc to of_hal
[0001.690] of_register: registering inv20628-driver to of_hal
[0001.695] of_register: registering ads1015-driver to of_hal
[0001.701] of_register: registering lp8557-bl-driver to of_hal
[0001.707] of_register: registering bq2419x_charger to of_hal
[0001.712] of_register: registering bq27441_fuel_gauge to of_hal
[0001.724] gpio framework initialized
[0001.727] of_register: registering tca9539_gpio to of_hal
[0001.732] of_register: registering tca9539_gpio to of_hal
[0001.738] of_register: registering i2c_bus_driver to of_hal
[0001.743] of_register: registering i2c_bus_driver to of_hal
[0001.749] of_register: registering i2c_bus_driver to of_hal
[0001.754] pmic framework initialized
[0001.758] of_register: registering max77620_pmic to of_hal
[0001.763] regulator framework initialized
[0001.767] of_register: registering tps65132_bl_driver to of_hal
[0001.773] initializing target
[0001.779] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.787] board ID = D78, board SKU = 2
[0001.793] fixed regulator driver initialized
[0001.811] initializing OF layer
[0001.814] NCK carveout not present
[0001.817] Skipping dts_overrides
[0001.822] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.838] I2C Bus Init done
[0001.841] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.851] I2C Bus Init done
[0001.854] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.864] I2C Bus Init done
[0001.867] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.877] I2C Bus Init done
[0001.880] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.890] I2C Bus Init done
[0001.893] of_children_init: Ops found for compatible string maxim,max77620
[0001.903] max77620_init using irq 118
[0001.908] register 'maxim,max77620' pmic
[0001.912] gpio_driver_register: register 'max77620-gpio' driver
[0001.918] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.929] I2C Bus Init done
[0001.932] NCK carveout not present
[0001.942] Find /i2c@7000c000's alias i2c0
[0001.946] get eeprom at 1-a0, size 256, type 0
[0001.954] Find /i2c@7000c500's alias i2c2
[0001.958] get eeprom at 3-a0, size 256, type 0
[0001.963] get eeprom at 3-ae, size 256, type 0
[0001.967] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.972] I2C slave not started
[0001.975] I2C write failed
[0001.978] Writing offset failed
[0001.981] eeprom_init: EEPROM read failed
[0001.985] pm_ids_update: eeprom init failed
[0001.989] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.019] pm_ids_update: The pm board id is 3448-0002-400
[0002.026] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.035] pm_ids_update: pm id update successful
[0002.039] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.069] eeprom_init: EEPROM incompatible version found
[0002.074] pm_ids_update: eeprom init failed
[0002.104] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.110] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.118] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.124] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.132] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:c4:16
[0002.139] Plugin Manager: Parse ODM data 0x000a4000
[0002.151] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0002.165] Find /i2c@7000c000's alias i2c0
[0002.169] get eeprom at 1-a0, size 256, type 0
[0002.178] Find /i2c@7000c500's alias i2c2
[0002.182] get eeprom at 3-a0, size 256, type 0
[0002.186] get eeprom at 3-ae, size 256, type 0
[0002.191] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.196] I2C slave not started
[0002.199] I2C write failed
[0002.202] Writing offset failed
[0002.205] eeprom_init: EEPROM read failed
[0002.209] pm_ids_update: eeprom init failed
[0002.213] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.243] pm_ids_update: The pm board id is 3448-0002-400
[0002.249] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.256] pm_ids_update: pm id update successful
[0002.261] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.291] eeprom_init: EEPROM incompatible version found
[0002.296] pm_ids_update: eeprom init failed
[0002.326] Add serial number:1423019109255 as DT property
[0002.333] Applying platform configs
[0002.340] platform-init is not present. Skipping
[0002.345] calling apps_init()
[0002.366] Found 17 GPT partitions in "sdmmc3_user"
[0002.370] Proceeding to Cold Boot
[0002.374] starting app android_boot_app
[0002.377] Device state: unlocked
[0002.381] display console init
[0002.389] could not find regulator
[0002.412] hdmi cable not connected
[0002.415] is_hdmi_needed: HDMI not connected, returning false
[00[0002.425] DT entry for leds-pwm not found
02.421] hdmi is not connected
[0002.431] sor0 is not supported
[0002.434] display_console_init: no valid display out_type
[0002.442] subnode volume_up is not found !
[0002.446] subnode back is not found !
[0002.450] subnode volume_down is not found !
[0002.454] subnode menu is not found !
[0002.458] Gpio keyboard init success
[0002.506] found decompressor handler: lz4-legacy
[0002.520] decompressing blob (type 1)...
[0002.586] display_resolution: No display init
[0002.591] Failed to retrieve display resolution
[0002.595] Could not load/initialize BMP blob...ignoring
[0002.600] -------> se_aes_verify_sbk_clear: 747
[0002.605] se_aes_verify_sbk_clear: Error
[0002.609] SE operation failed
[0002.611] bl_battery_charging: connected to external power supply
[0002.621] display_console_ioctl: No display init
[0002.625] switch_backlight failed
[0002.635] device_query_partition_size: failed to open partition sdmmc3_user:MS!
[0002.642] MSC Partition not found
[0002.652] device_query_partition_size: failed to open partition sdmmc3_user:US!
[0002.659] USP partition read failed!
[0002.663] blob_init: blob-partition USP header read failed
[0002.668] android_boot Unable to update recovery partition
[0002.673] kfs_getpartname: name = LNX
[0002.677] Loading kernel from LNX
[0002.774] load kernel from storage
[0002.784] decompressor handler not found
[0002.818] Successfully loaded kernel and ramdisk images
[0002.823] board ID = D78, board SKU = 2
[0002.827] display_resolution: No display init
[0002.832] Failed to retrieve display resolution
[0002.836] bmp blob is not loaded and initialized
[0002.841] Failed to display boot-logo
[0002.844] NCK carveout not present
[0002.848] Skipping dts_overrides
[0002.851] NCK carveout not present
[0002.860] Find /i2c@7000c000's alias i2c0
[0002.864] get eeprom at 1-a0, size 256, type 0
[0002.873] Find /i2c@7000c500's alias i2c2
[0002.877] get eeprom at 3-a0, size 256, type 0
[0002.881] get eeprom at 3-ae, size 256, type 0
[0002.885] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.891] I2C slave not started
[0002.894] I2C write failed
[0002.896] Writing offset failed
[0002.899] eeprom_init: EEPROM read failed
[0002.903] pm_ids_update: eeprom init failed
[0002.908] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.938] pm_ids_update: The pm board id is 3448-0002-400
[0002.944] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.953] pm_ids_update: pm id update successful
[0002.957] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.987] eeprom_init: EEPROM incompatible version found
[0002.993] pm_ids_update: eeprom init failed
[0003.023] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.028] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.036] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.042] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.050] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:c4:16
[0003.057] Plugin Manager: Parse ODM data 0x000a4000
[0003.069] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0003.078] Add serial number:1423019109255 as DT property
[0003.086] "bpmp" doesn't exist, creating
[0003.092] Updated bpmp info to DTB
[0003.097] Updated initrd info to DTB
[0003.100] "proc-board" doesn't exist, creating
[0003.106] Updated board info to DTB
[0003.110] "pmu-board" doesn't exist, creating
[0003.116] Updated board info to DTB
[0003.119] "display-board" doesn't exist, creating
[0003.125] Updated board info to DTB
[0003.128] "reset" doesn't exist, creating
[0003.133] Updated reset info to DTB
[0003.136] display_console_ioctl: No display init
[0003.141] display_console_ioctl: No display init
[0003.145] display_console_ioctl: No display init
[0003.150] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype
[0003.184] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.190] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0003.206] Updated bootarg info to DTB
[0003.210] Adding uuid 000000016445c8450400000017040180 to DT
[0003.216] Adding eks info 0 to DT
[0003.221] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.227] Updated memory info to DTB
[0003.235] set vdd_core voltage to 1075 mv
[0003.239] setting 'vdd-core' regulator to 1075000 micro volts
[0003.245] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Nov 22 2022 - 09:21:37 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM:  4 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
starting USB...
Bus usb@7d000000: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
Bus xusb@70090000: Loading XUSB FW blob from RP4 partition ...
Firmware size 126464
Firmware timestamp: 0x5f23e558, Version: 50.26 release
Register HCSParams1: 9000124 NbrPorts: 9
Starting the controller
USB XHCI 1.00
scanning bus xusb@70090000 for devices... 4 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
PCI device eth_rtl8169: unknown chip version, assuming RTL-8169
PCI device: TxConfig = 0x4B100D00
Warning: eth_rtl8169 using MAC address from ROM
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-00-04-4b-e9-c4-16
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-tegra210-p3450-0000
Config file not found
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Tegra210 (P3450-0000) # i2c dev 3
Setting bus to 3
Tegra210 (P3450-0000) # i2c md 0x50 0x00 0x100
0000: 01 00 fc 00 78 0d 02 00 04 46 00 00 00 00 00 00    ....x....F......
0010: 00 00 00 00 36 39 39 2d 31 33 34 34 38 2d 30 30    ....699-13448-00
0020: 30 32 2d 34 30 30 20 46 2e 30 00 00 00 00 00 00    02-400 F.0......
0030: 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff    ................
0040: ff ff ff ff 16 c4 e9 4b 04 00 31 34 32 33 30 31    .......K..142301
0050: 39 31 30 39 32 35 35 00 00 00 00 00 00 00 00 00    9109255.........
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
0090: 00 00 00 00 00 00 4e 56 43 42 1c 00 4d 31 00 00    ......NVCB..M1..
00a0: ff ff ff ff ff ff ff ff ff ff ff ff 16 c4 e9 4b    ...............K
00b0: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f6    ................
Can you please take out both BOARDID=3448 BOARDSKU=0002 and -r to let the script generate a new image and flash again?
