To who may concern,
we are having several failures concerning jetson Nanos. They do not work correctly after a period of time.
We have multiple jetson nano and we can easily flash them all. We succesfully flashed them all before, and now some of them are not working despite there being any changes in the flashing procedure from our side. We still can flash other new jetsons.
From the technical side:
We decided to flash them again because we were unable to update/change any data on them due to an error stating that all files are in read-only mode. If we try to remove something, it does not get removed and restores itself after rebooting the jetson.
Flashing is stuck in the middle of the process. We tried to use new boards. Boards are all working fine, since no problem is encountered with working jetsons.
Connecting a monitor to the board does not display the Nvidia logo on the problematic jetsons, instead as it should normally appear.
The behaviour of the failure is similar in all the Jetsons we are having trouble with. Therefore, we would like to send to you some Jetson Nanos and have the specific hardware problem analysed.
Thank you for your support,
Matteo Postacchini,
Logivations GmbH
Just to confirm, does your “flash stuck” mean your run sdkmanager to flash them and it got stuck?
Is it on custom board or devkit?
Hi, thank you for your reply.
The boards we are using are the “JNX30 ” by Auvidea.
We are flashing from the terminal,
We pulled jetpack via NVIDIA SDK, and then go into “~/nvidia/nvidia_sdk/JetPack_4.6.2_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra”
and flashed as
“sudo ./flash.sh jetson-nano-emmc mmcblk0p1”
We tried with jetpack 4.4 4.5 and 4.6
Is their carrier board able to dump the UART serial console log?
Would like to see what error you saw on host side and also the UART log (device log) during flash.
# L4T BSP Information:
# R32 , REVISION: 5.1
# Target Board Information:
# Name: jetson-nano-emmc, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet "/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/nvtboot_recovery.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0067 ] Generating RCM messages
[ 0.0085 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0099 ] RCM 0 is saved as rcm_0.rcm
[ 0.0114 ] RCM 1 is saved as rcm_1.rcm
[ 0.0115 ] List of rcm files are saved in rcm_list.xml
[ 0.0115 ]
[ 0.0115 ] Signing RCM messages
[ 0.0138 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0149 ] Assuming zero filled SBK key
[ 0.0243 ]
[ 0.0244 ] Copying signature to RCM mesages
[ 0.0258 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0284 ]
[ 0.0285 ] Boot Rom communication
[ 0.0298 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0317 ] RCM version 0X210001
[ 0.0742 ] Boot Rom communication completed
[ 1.0814 ]
[ 1.0816 ] dump EEPROM info
[ 1.0839 ] tegrarcm --oem platformdetails eeprom /home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0859 ] Applet version 00.01.0000
[ 1.1034 ] Saved platform info in /home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1801 ]
[ 1.1826 ] tegrarcm --reboot recovery
[ 1.1844 ] Applet version 00.01.0000
[ 1.2040 ]
Board ID(3448) version(401)
copying bctfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying initrd(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
Existing sosfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
Existing tbcfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)... done.
copying cfgfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_emmc_p3448.xml) to flash.xml... done.
copying flasher(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --bins "EBT cboot.bin; DTB tegra210-p3448-0002-p3449-0000-b00.dtb"
saving flash command in /home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/nvidia/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0012 ] tegrasign --key None --getmode mode.txt
[ 0.0019 ] Assuming zero filled SBK key
[ 0.0021 ]
[ 0.0022 ] Generating RCM messages
[ 0.0029 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0036 ] RCM 0 is saved as rcm_0.rcm
[ 0.0040 ] RCM 1 is saved as rcm_1.rcm
[ 0.0040 ] List of rcm files are saved in rcm_list.xml
[ 0.0040 ]
[ 0.0041 ] Signing RCM messages
[ 0.0048 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0055 ] Assuming zero filled SBK key
[ 0.0109 ]
[ 0.0110 ] Copying signature to RCM mesages
[ 0.0119 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0130 ]
[ 0.0131 ] Parsing partition layout
[ 0.0145 ] tegraparser --pt flash.xml.tmp
[ 0.0164 ]
[ 0.0164 ] Creating list of images to be signed
[ 0.0177 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0261 ]
[ 0.0261 ] Generating signatures
[ 0.0271 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0279 ] Assuming zero filled SBK key
[ 0.1243 ]
[ 0.1243 ] Generating br-bct
[ 0.1262 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.1269 ] Copying Sdram info from 2 to 3 set
[ 0.1303 ]
[ 0.1303 ] Updating boot device parameters
[ 0.1312 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.1320 ] Warning: No sdram params
[ 0.1323 ]
[ 0.1323 ] Updating bl info
[ 0.1331 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1345 ]
[ 0.1345 ] Updating secondary storage information into bct
[ 0.1359 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.1370 ]
[ 0.1370 ] Updating Odmdata
[ 0.1379 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.1387 ] Warning: No sdram params
[ 0.1389 ]
[ 0.1389 ] Get Signed section of bct
[ 0.1397 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.1416 ]
[ 0.1417 ] Signing BCT
[ 0.1436 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.1445 ] Assuming zero filled SBK key
[ 0.1450 ]
[ 0.1450 ] Updating BCT with signature
[ 0.1459 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.1469 ]
[ 0.1470 ] Copying signatures
[ 0.1477 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.1553 ]
[ 0.1553 ] Updating BFS information on BCT
[ 0.1563 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.1576 ] BFS:
[ 0.1589 ] 0: [PT ] flash.xml.bin (size=4367/131072)
[ 0.1593 ] 1: [TBC] nvtboot_cpu.bin.encrypt (size=65760/196608)
[ 0.1597 ] 2: [RP1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=246688/1048576)
[ 0.1602 ] 3: [EBT] cboot.bin.encrypt (size=485120/655360)
[ 0.1605 ] 4: [WB0] warmboot.bin.encrypt (size=3952/131072)
[ 0.1608 ] 5: [BPF] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.1612 ] BFS0: 131072 @ 2560 SUM 451f5c43 over 2883584 bytes
[ 0.1614 ] BFS:
[ 0.1615 ] 0: [PT-1] flash.xml.bin (size=4367/131072)
[ 0.1618 ] 1: [TBC-1] nvtboot_cpu.bin.encrypt (size=65760/196608)
[ 0.1621 ] 2: [RP1-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=246688/1048576)
[ 0.1626 ] 3: [EBT-1] cboot.bin.encrypt (size=485120/655360)
[ 0.1629 ] 4: [WB0-1] warmboot.bin.encrypt (size=3952/131072)
[ 0.1632 ] 5: [BPF-1] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 0.1636 ] 8: [VER_b] emmc_bootblob_ver.txt (size=102/32768)
[ 0.1639 ] 9: [VER] emmc_bootblob_ver.txt (size=102/32768)
[ 0.1642 ] BFS1: 131072 @ 8704 SUM 451f5c43 over 2981888 bytes
[ 0.1645 ] KFS:
[ 0.1906 ] 0: [DTB] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=246688/1048576)
[ 0.1911 ] 1: [TOS] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.1916 ] 2: [EKS] eks.img (size=1028/81920)
[ 0.1922 ] 3: [LNX] boot.img.encrypt (size=661504/67092480)
[ 0.1928 ] KFS0: 1048576 @ 29376546 SUM 2e51f174 over 8083456 bytes
[ 0.1948 ] KFS:
[ 0.2232 ] 0: [DTB-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=246688/1048576)
[ 0.2236 ] 1: [TOS-1] tos-mon-only.img.encrypt (size=54208/6291456)
[ 0.2239 ] 2: [EKS-1] eks.img (size=1028/81920)
[ 0.2240 ] 3: [LNX-1] boot.img.encrypt (size=661504/67092480)
[ 0.2243 ] KFS1: 1048576 @ 29522082 SUM 2e51f174 over 8083456 bytes
[ 0.2273 ]
[ 0.2273 ] Boot Rom communication
[ 0.2282 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.2289 ] BR_CID: 0x32101001645047000400000012060340
[ 0.2298 ] RCM version 0X210001
[ 0.2440 ] Boot Rom communication completed
[ 1.2512 ]
[ 1.2513 ] Sending BCTs
[ 1.2536 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.2555 ] Applet version 00.01.0000
[ 1.2799 ] Sending bct
[ 1.2802 ] [................................................] 100%
[ 1.5023 ]
[ 1.5046 ] tegrahost --chip 0x21 --align cboot.bin
[ 1.5067 ]
[ 1.5090 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 1.5142 ]
[ 1.5172 ] tegrasign --key None --list cboot.bin_list.xml
[ 1.5193 ] Assuming zero filled SBK key
[ 1.5514 ]
[ 1.5531 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 1.5553 ]
[ 1.5571 ] tegrahost --chip 0x21 --align tegra210-p3448-0002-p3449-0000-b00.dtb
[ 1.5583 ]
[ 1.5595 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0002-p3449-0000-b00.dtb tegra210-p3448-0002-p3449-0000-b00.dtb_blheader
[ 1.5618 ]
[ 1.5634 ] tegrasign --key None --list tegra210-p3448-0002-p3449-0000-b00.dtb_list.xml
[ 1.5647 ] Assuming zero filled SBK key
[ 1.5728 ]
[ 1.5739 ] tegrahost --updatesigheader tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 1.5752 ]
[ 1.5756 ] Sending bootloader and pre-requisite binaries
[ 1.5764 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
[ 1.5772 ] Applet version 00.01.0000
[ 1.5941 ] Sending ebt
[ 1.5952 ] [................................................] 100%
[ 1.7001 ] Sending rp1
[ 1.7047 ] [................................................] 100%
[ 1.7622 ]
[ 1.7645 ] tegrarcm --boot recovery
[ 1.7665 ] Applet version 00.01.0000
[ 1.7875 ]
[ 1.7875 ] Retrieving storage infomation
[ 1.7897 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 1.7920 ] Applet is not running on device. Continue with Bootloader
[ 4.7120 ]
[ 4.7168 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 4.7198 ] Cboot version 00.01.0000
[ 4.7224 ] Saved platform info in storage_info.bin
v1.2
[0012.160] Enabled early print
[0012.163] [L4T TegraBoot] (version ▒▒K$)
[0012.167] Processing in recovery mode
[0012.170] A02 Bootrom Patch rev = 1023
[0012.174] Power-up reason: pmc por
[0012.177] Established communication link with host
[0013.179] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0013.187] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0013.195] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
[0002.548] Enabled early print
[0002.551] [L4T TegraBoot] (version ▒▒K$)
[0002.554] Processing in recovery mode
[0002.558] A02 Bootrom Patch rev = 1023
[0002.561] Power-up reason: software reset
[0002.565] Established communication link with host
[0003.555] Odmdata from BCT: 0x000a4000
[0003.558] DebugPort= 0x3
[0003.561] SkipQspiOnly= 0x0
[0003.613] BoardId read from EEPROM/NCT: 3448
[0003.617] BoardID = 3448, SKU = 0x2
[0003.644] NvTbootInit_Porg: Setting GPIO_A6 for HDMI ...
[0003.649] max77620 setting MBLPD bit
[0003.653] No Battery Present
[0003.656] RamCode = 2
[0003.658] Platform has DDR4 type RAM
[0003.661] max77620 disabling SD1 Remote Sense
[0003.665] Setting DDR voltage to 1125mv
[0003.669] Serial Number of Pmic Max77663: 0x52fd8
[0003.677] Entering ramdump check
[0003.680] Get RamDumpCarveOut = 0x0
[0003.683] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0003.688] Last reboot was clean, booting normally!
[0003.693] Sdram initialization is successful
[0003.697] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0003.703] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0003.709] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0003.715] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0003.721] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0003.727] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0003.733] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0003.738] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0003.755] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0003.761] Platform-DebugCarveout: 0
[0003.764] Downloaded BCT successfully
[0003.961] Downloaded Bootloader successfully
[0004.019] Downloaded rp1 successfully
[0004.048] MAX77620_GPIO5 configured
[0004.051] CPU power rail is up
[0004.054] CPU clock enabled
[0004.058] Performing RAM repair
[0004.061] Updating A64 Warmreset Address to 0x92c002e9
[0004.067] Enable APE clock/reset
[0004.070] Error in NvTbootGetTOSBinaryLength: 0x11 !
[0004.074] Loading Secure OS image failed.
[0004.078] Set NvDecSticky Bits
[0004.082] GSC2 address ff53fffc value c0edbbcc
[0004.088] GSC MC Settings done
[0004.092] Next binary entry address: 0x92c00258
[0004.097] BoardId: 3448
[0004.099] Overriding pmu board id with proc board id
[0004.104] Display board id is not available
[0004.108] Starting CPU & Halting co-processor
[0004.218]
[0004.219] Debug Init done
[0004.222] Marked DTB cacheable
[0004.225] Bootloader DTB loaded at 0x83000400
[0004.229] DeviceTree Init done
[0004.242] Pinmux applied successfully
[0004.247] gicd_base: 0x50041000
[0004.250] gicc_base: 0x50042000
[0004.253] Interrupts Init done
[0004.257] Using base:0x60005090 & irq:208 for tick-timer
[0004.262] Using base:0x60005098 for delay-timer
[0004.267] platform_init_timer: DONE
[0004.270] Timer(tick) Init done
[0004.274] osc freq = 38400 khz
[0004.278]
[0004.279] Welcome to L4T Cboot
[0004.282]
[0004.283] Cboot Version: 00.00.2018.01-t210-39562017
[0004.288] calling constructors
[0004.291] initializing heap
[0004.294] initializing threads
[0004.297] initializing timers
[0004.300] creating bootstrap completion thread
[0004.304] top of bootstrap2()
[0004.307] CPU: ARM Cortex A57
[0004.310] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0004.315] initializing platform
[0005.518] Error in command_complete 18001 int_status
[0005.525] Error in command_complete 18001 int_status
[0005.531] Error in command_complete 18001 int_status
[0005.536] sending the command failed 0xffffffec in sdmmc_send_command at 109
[0005.543] sending cid failed 0xffffffec in sdmmc_identify_card at 840
[0005.550] identify card failed 0xffffffec in sdmmc_init at 1131
[0005.556] sdmmc init failed 0xffffffec in sdmmc_bdev_open at 438
[0006.757] Error in command_complete 18001 int_status
[0006.764] Error in command_complete 18001 int_status
[0006.770] Error in command_complete 18001 int_status
[0006.775] sending the command failed 0xffffffec in sdmmc_send_command at 109
[0006.782] sending cid failed 0xffffffec in sdmmc_identify_card at 840
[0006.789] identify card failed 0xffffffec in sdmmc_init at 1131
[0006.795] sdmmc init failed 0xffffffec in sdmmc_bdev_open at 438
[0006.801] of_register: registering tegra_udc to of_hal
[0006.806] of_register: registering inv20628-driver to of_hal
[0006.812] of_register: registering ads1015-driver to of_hal
[0006.817] of_register: registering lp8557-bl-driver to of_hal
[0006.823] of_register: registering bq2419x_charger to of_hal
[0006.828] of_register: registering bq27441_fuel_gauge to of_hal
[0006.841] gpio framework initialized
[0006.844] of_register: registering tca9539_gpio to of_hal
[0006.850] of_register: registering tca9539_gpio to of_hal
[0006.855] of_register: registering i2c_bus_driver to of_hal
[0006.861] of_register: registering i2c_bus_driver to of_hal
[0006.866] of_register: registering i2c_bus_driver to of_hal
[0006.872] pmic framework initialized
[0006.875] of_register: registering max77620_pmic to of_hal
[0006.881] regulator framework initialized
[0006.885] of_register: registering tps65132_bl_driver to of_hal
[0006.891] initializing target
[0006.896] gpio_driver_register: register 'tegra_gpio_driver' driver
[0006.908] fixed regulator driver initialized
[0006.927] initializing OF layer
[0006.931] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0006.948] I2C Bus Init done
[0006.951] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0006.961] I2C Bus Init done
[0006.964] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0006.974] I2C Bus Init done
[0006.977] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0006.988] I2C Bus Init done
[0006.990] of_children_init: Ops found for compatible string maxim,max77620
[0007.001] max77620_init using irq 118
[0007.006] register 'maxim,max77620' pmic
[0007.010] gpio_driver_register: register 'max77620-gpio' driver
[0007.017] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0007.027] I2C Bus Init done
[0007.031] Applying platform configs
[0007.038] platform-init is not present. Skipping
[0007.043] calling apps_init()
[0007.045] Failed to open "sdmmc3_user" for publishing partitions
[0007.051] Proceeding to flashing Server
[0007.055] usbdcd_reinit Initialize driver to use already enumerated device
[0007.062] nv3p_priv_usbf_open USB configuration success
[0007.079] populate_storage_info: failed to open sdmmc3_boot !
[0007.085] populate_platform_info: failed to populate storage info
[0007.091] pre_process_oem_commands: failed to populate platform info
[0007.098] pre_process_oem_commands: failed to process oem commands
[0007.104] oem_commands: processing oem command failed
Looks like a hardware issue that the emmc has problem.
Hey @WayneWWW , will it be possible to use the board with other modes, for example booting from Network or micro-SD card? Or is the board unusable if the EMMC has a problem?
If this is emmc module, then not possible to boot from network or sdcard.
system
Closed
November 23, 2022, 8:36am
11
