Started having my jetson nano B01 fail after a few days running with a problem reading mmcblk0p1 error. Tried different sd cards and same result. Found documents telling me I needed to flash the QSPI with the SDK manager. when I attempted to do that, it fails telling me the device is in a bad state. Tried to flash directly with sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 and i get the following results:
L4T BSP Information:
R32 , REVISION: 6.1
Target Board Information:
Name: jetson-nano-qspi, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet “/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0025 ] Generating RCM messages
[ 0.0048 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0058 ] RCM 0 is saved as rcm_0.rcm
[ 0.0069 ] RCM 1 is saved as rcm_1.rcm
[ 0.0078 ] List of rcm files are saved in rcm_list.xml
[ 0.0146 ]
[ 0.0147 ] Signing RCM messages
[ 0.0175 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0185 ] Assuming zero filled SBK key
[ 0.0327 ]
[ 0.0329 ] Copying signature to RCM mesages
[ 0.0352 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0456 ]
[ 0.0460 ] Boot Rom communication
[ 0.0487 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0523 ] RCM version 0X210001
[ 0.1057 ] Boot Rom communication completed
[ 1.1871 ]
[ 1.1872 ] dump EEPROM info
[ 1.1896 ] tegrarcm --oem platformdetails eeprom /home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1905 ] Applet version 00.01.0000
[ 1.3775 ] Saved platform info in /home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 1.6351 ]
[ 1.6376 ] tegrarcm --reboot recovery
[ 1.6385 ] Applet version 00.01.0000
[ 1.9028 ]
Board ID(3448) version(400)
copying bctfile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)… done.
copying bootloader(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying initrd(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
Existing sosfile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
copying cpu_bootloader(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying bpffile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
copying wb0boot(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Existing tbcfile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
copying cfgfile(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_p3448.xml) to flash.xml… done.
copying flasher(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0000-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x21 --bins “EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-b00.dtb”
saving flash command in /home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/oracle/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
assign_value: crc-flash.xml.bin 1 65520 1
printf ‘\x1’ | dd of=crc-flash.xml.bin bs=1 seek=65520 count=1 conv=notrunc
1+0 records in
1+0 records out
1 byte copied, 0.000285154 s, 3.5 kB/s
assign_value: crc-flash.xml.bin 0 65521 1
printf ‘\x0’ | dd of=crc-flash.xml.bin bs=1 seek=65521 count=1 conv=notrunc
1+0 records in
1+0 records out
1 byte copied, 0.000289813 s, 3.5 kB/s
assign_string: crc-flash.xml.bin PTHD 65528 4
echo PTHD | dd of=crc-flash.xml.bin bs=1 seek=65528 count=4 conv=notrunc
4+0 records in
4+0 records out
4 bytes copied, 0.00027711 s, 14.4 kB/s
*** Flashing target device started. ***
version 1.0.0
[ 0.0022 ] tegrasign --getmode mode.txt --key None
[ 0.0034 ] Assuming zero filled SBK key
[ 0.0091 ]
[ 0.0093 ] Generating RCM messages
[ 0.0115 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0126 ] RCM 0 is saved as rcm_0.rcm
[ 0.0137 ] RCM 1 is saved as rcm_1.rcm
[ 0.0145 ] List of rcm files are saved in rcm_list.xml
[ 0.0209 ]
[ 0.0210 ] Signing RCM messages
[ 0.0251 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0260 ] Assuming zero filled SBK key
[ 0.0419 ]
[ 0.0421 ] Copying signature to RCM mesages
[ 0.0448 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0532 ]
[ 0.0534 ] Parsing partition layout
[ 0.0556 ] tegraparser --pt flash.xml.tmp
[ 0.0650 ]
[ 0.0652 ] Using default ramcode: 0
[ 0.0653 ] Disable BPMP dtb trim, using default dtb
[ 0.0653 ]
[ 0.0654 ] Creating list of images to be signed
[ 0.0677 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0806 ]
[ 0.0808 ] Generating signatures
[ 0.0832 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0847 ] Assuming zero filled SBK key
[ 0.1492 ]
[ 0.1493 ] Generating br-bct
[ 0.1515 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.1610 ]
[ 0.1611 ] Updating boot device parameters
[ 0.1633 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.1643 ] Warning: No sdram params
[ 0.1688 ]
[ 0.1689 ] Updating bl info
[ 0.1744 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1855 ]
[ 0.1857 ] Updating secondary storage information into bct
[ 0.1879 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.1972 ]
[ 0.1974 ] Updating Odmdata
[ 0.1996 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.2009 ] Warning: No sdram params
[ 0.2083 ]
[ 0.2083 ] Get Signed section of bct
[ 0.2129 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.2207 ]
[ 0.2208 ] Signing BCT
[ 0.2289 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.2304 ] Assuming zero filled SBK key
[ 0.2374 ]
[ 0.2376 ] Updating BCT with signature
[ 0.2436 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.2492 ]
[ 0.2494 ] Copying signatures
[ 0.2551 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.2689 ]
[ 0.2691 ] Updating BFS information on BCT
[ 0.2747 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.2815 ]
[ 0.2817 ] Boot Rom communication
[ 0.2871 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.2882 ] BootRom is not running
[ 0.3015 ]
[ 0.3016 ] Sending BCTs
[ 0.3070 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.3080 ] Applet is not running on device. Continue with Bootloader
[ 0.3207 ]
[ 0.3230 ] tegrahost --chip 0x21 --align cboot.bin
[ 0.3294 ]
[ 0.3315 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 0.3412 ]
[ 0.3438 ] tegrasign --key None --list cboot.bin_list.xml
[ 0.3447 ] Assuming zero filled SBK key
[ 0.3641 ]
[ 0.3690 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 0.3797 ]
[ 0.3838 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-b00.dtb
[ 0.3892 ]
[ 0.3913 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-b00.dtb tegra210-p3448-0000-p3449-0000-b00.dtb_blheader
[ 0.4010 ]
[ 0.4035 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-b00.dtb_list.xml
[ 0.4044 ] Assuming zero filled SBK key
[ 0.4166 ]
[ 0.4196 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 0.4254 ]
[ 0.4263 ] Sending bootloader and pre-requisite binaries
[ 0.4309 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt 0
[ 0.4319 ] Applet is not running on device. Continue with Bootloader
[ 0.4533 ]
[ 0.4559 ] tegrarcm --boot recovery
[ 0.4599 ] Applet is not running on device. Continue with Bootloader
[ 0.4722 ]
[ 0.4725 ] Retrieving storage infomation
[ 0.4755 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 0.4768 ] Applet is not running on device. Continue with Bootloader
[ 0.4879 ]
[ 0.4928 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 0.4938 ] Cboot is not running on device.
[ 0.5091 ]
Error: Return value 4
Command tegradevflash --oem platformdetails storage storage_info.bin
Failed flashing t210ref.
any ideas?
