Hi @WayneWWW,
Thank’s for your reply. I don’t have a B01 devkit here, but, I will try to buy one, in the meantime, I’m trying to use my custom carrier board.
This is the log through UART when the “Parsing board information failed” happens.
[0348.297] Enabled early print
[0348.300] [L4T TegraBoot] (version �^���\�ǿ��Q�����v����ŕ������� )
[0348.306] Processing in recovery mode
[0348.309] A02 Bootrom Patch rev = 1023
[0348.313] Power-up reason: pmc por
[0348.316] Established communication link with host
[0349.320] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0349.328] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0349.336] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
So, I tried these steps.
I put this commands “SKIP_EEPROM_CHECK=”-n";" in the “jetson-nano-emmc.conf” file.
I set this variables “dtbfab=b00;” and “board_sku=“0002”;” in the “p3448-0000.conf.common”. So, the dtb “tegra210-p3448-0002-p3449-0000-b00.dtb” is used.
Now, the “Parsing board information failed” not happens, but, I have another failure, look at the log below. Do you have any suggestions? Are the above steps correct?
Using this comand: sudo ./flash.sh jetson-nano-emmc mmcblk0p1
L4T BSP Information:
R32 , REVISION: 5.0
Target Board Information:
Name: jetson-nano-emmc, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet “/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0014 ] Generating RCM messages
[ 0.0021 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0026 ] RCM 0 is saved as rcm_0.rcm
[ 0.0029 ] RCM 1 is saved as rcm_1.rcm
[ 0.0029 ] List of rcm files are saved in rcm_list.xml
[ 0.0029 ]
[ 0.0029 ] Signing RCM messages
[ 0.0034 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0040 ] Assuming zero filled SBK key
[ 0.0077 ]
[ 0.0077 ] Copying signature to RCM mesages
[ 0.0082 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0090 ]
[ 0.0091 ] Boot Rom communication
[ 0.0096 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0101 ] RCM version 0X210001
[ 0.0521 ] Boot Rom communication completed
[ 1.0601 ]
[ 1.0603 ] dump EEPROM info
[ 1.0641 ] tegrarcm --oem platformdetails eeprom /home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0671 ] Applet version 00.01.0000
[ 1.0871 ] Saved platform info in /home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1645 ]
[ 1.1682 ] tegrarcm --reboot recovery
[ 1.1711 ] Applet version 00.01.0000
[ 1.1745 ]
Board ID() version()
copying bctfile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)… done.
copying bootloader(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying initrd(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating /home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb to rootfs… done.
Making Boot image… done.
Existing sosfile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
copying cpu_bootloader(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying bpffile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
Existing badpagefile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)… done.
Copying nv_boot_control.conf to rootfs
Making system.img…
populating rootfs from /home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/rootfs … done.
populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)… done.
copying cfgfile(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_emmc_p3448.xml) to flash.xml… done.
copying flasher(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x21 --bins “EBT cboot.bin; DTB tegra210-p3448-0002-p3449-0000-b00.dtb”
saving flash command in /home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/rene/image-box/nvidia/nvidia_sdk/JetPack_4.5_Linux_JETSON_NANO/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0954 ] tegrasign --key None --getmode mode.txt
[ 0.0986 ] Assuming zero filled SBK key
[ 0.5519 ]
[ 0.5523 ] Generating RCM messages
[ 0.5672 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.5706 ] RCM 0 is saved as rcm_0.rcm
[ 0.7965 ] RCM 1 is saved as rcm_1.rcm
[ 0.7966 ] List of rcm files are saved in rcm_list.xml
[ 0.7966 ]
[ 0.7967 ] Signing RCM messages
[ 0.8003 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.8034 ] Assuming zero filled SBK key
[ 0.8226 ]
[ 0.8226 ] Copying signature to RCM mesages
[ 0.8252 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.8441 ]
[ 0.8443 ] Parsing partition layout
[ 0.9615 ] tegraparser --pt flash.xml.tmp
[ 1.0252 ]
[ 1.0254 ] Creating list of images to be signed
[ 1.2205 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 1.3048 ]
[ 1.3050 ] Generating signatures
[ 1.3085 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 1.3120 ] Assuming zero filled SBK key
[ 1.4730 ]
[ 1.4730 ] Generating br-bct
[ 1.5101 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 1.5132 ] Copying Sdram info from 2 to 3 set
[ 1.5500 ]
[ 1.5501 ] Updating boot device parameters
[ 1.5531 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 1.5565 ] Warning: No sdram params
[ 1.5571 ]
[ 1.5572 ] Updating bl info
[ 1.5600 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 1.5650 ]
[ 1.5652 ] Updating secondary storage information into bct
[ 1.5681 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.5717 ]
[ 1.5719 ] Updating Odmdata
[ 1.5749 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 1.5783 ] Warning: No sdram params
[ 1.5788 ]
[ 1.5789 ] Get Signed section of bct
[ 1.5816 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 1.5847 ]
[ 1.5849 ] Signing BCT
[ 1.5916 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 1.5943 ] Assuming zero filled SBK key
[ 1.5963 ]
[ 1.5963 ] Updating BCT with signature
[ 1.5990 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 1.6027 ]
[ 1.6029 ] Copying signatures
[ 1.6059 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.6371 ]
[ 1.6373 ] Updating BFS information on BCT
[ 1.6410 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 1.6437 ] BFS:
[ 1.6476 ] 0: [PT ] flash.xml.bin (size=4367/131072)
[ 1.6487 ] 1: [TBC] nvtboot_cpu.bin.encrypt (size=65760/196608)
[ 1.6499 ] 2: [RP1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=244352/1048576)
[ 1.6513 ] 3: [EBT] cboot.bin.encrypt (size=485120/655360)
[ 1.6520 ] 4: [WB0] warmboot.bin.encrypt (size=3952/131072)
[ 1.6529 ] 5: [BPF] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 1.6540 ] BFS0: 131072 @ 2560 SUM abfb6379 over 2883584 bytes
[ 1.6550 ] BFS:
[ 1.6552 ] 0: [PT-1] flash.xml.bin (size=4367/131072)
[ 1.6560 ] 1: [TBC-1] nvtboot_cpu.bin.encrypt (size=65760/196608)
[ 1.6569 ] 2: [RP1-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=244352/1048576)
[ 1.6578 ] 3: [EBT-1] cboot.bin.encrypt (size=485120/655360)
[ 1.6583 ] 4: [WB0-1] warmboot.bin.encrypt (size=3952/131072)
[ 1.6587 ] 5: [BPF-1] sc7entry-firmware.bin.encrypt (size=3376/262144)
[ 1.6593 ] 8: [VER_b] emmc_bootblob_ver.txt (size=91/32768)
[ 1.7381 ] 9: [VER] emmc_bootblob_ver.txt (size=91/32768)
[ 1.7393 ] BFS1: 131072 @ 8704 SUM abfb6379 over 2981888 bytes
[ 1.7405 ] KFS:
[ 1.7983 ] 0: [DTB] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=244352/1048576)
[ 1.7988 ] 1: [TOS] tos-mon-only.img.encrypt (size=54208/6291456)
[ 1.7992 ] 2: [EKS] eks.img (size=1028/81920)
[ 1.8266 ] 3: [LNX] boot.img.encrypt (size=661504/67092480)
[ 1.8271 ] KFS0: 1048576 @ 29376546 SUM 2512d27b over 8083456 bytes
[ 1.8316 ] KFS:
[ 1.8586 ] 0: [DTB-1] kernel_tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt (size=244352/1048576)
[ 1.8592 ] 1: [TOS-1] tos-mon-only.img.encrypt (size=54208/6291456)
[ 1.8596 ] 2: [EKS-1] eks.img (size=1028/81920)
[ 1.8599 ] 3: [LNX-1] boot.img.encrypt (size=661504/67092480)
[ 1.8603 ] KFS1: 1048576 @ 29522082 SUM 2512d27b over 8083456 bytes
[ 1.8631 ]
[ 1.8631 ] Boot Rom communication
[ 1.8639 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 1.8646 ] BR_CID: 0x32101001644612850c0000000afe85c0
[ 1.8653 ] RCM version 0X210001
[ 1.8798 ] Boot Rom communication completed
[ 2.8878 ]
[ 2.8879 ] Sending BCTs
[ 2.8912 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 2.8942 ] Applet version 00.01.0000
[ 2.8977 ] Sending bct
[ 2.8980 ] […] 100%
[ 2.9831 ]
[ 2.9867 ] tegrahost --chip 0x21 --align cboot.bin
[ 2.9903 ]
[ 2.9938 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 3.0019 ]
[ 3.0063 ] tegrasign --key None --list cboot.bin_list.xml
[ 3.0100 ] Assuming zero filled SBK key
[ 3.0392 ]
[ 3.0405 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 3.0426 ]
[ 3.0450 ] tegrahost --chip 0x21 --align tegra210-p3448-0002-p3449-0000-b00.dtb
[ 3.0466 ]
[ 3.0476 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0002-p3449-0000-b00.dtb tegra210-p3448-0002-p3449-0000-b00.dtb_blheader
[ 3.0493 ]
[ 3.0504 ] tegrasign --key None --list tegra210-p3448-0002-p3449-0000-b00.dtb_list.xml
[ 3.0512 ] Assuming zero filled SBK key
[ 3.0578 ]
[ 3.0596 ] tegrahost --updatesigheader tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 3.0615 ]
[ 3.0619 ] Sending bootloader and pre-requisite binaries
[ 3.0632 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
[ 3.0641 ] Applet version 00.01.0000
[ 3.0811 ] Sending ebt
[ 3.1468 ]
Error: Return value 1
Command tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
Failed flashing t210ref.
Log from device side through UART:
[2059.322] Enabled early print
[2059.325] [L4T TegraBoot] (version �^���\�ǿ��Q�v���������ŕ������� )
[2059.331] Processing in recovery mode
[2059.334] A02 Bootrom Patch rev = 1023
[2059.338] Power-up reason: software reset
[2059.342] Established communication link with host
[2060.346] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[2060.354] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[2060.362] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
[0559.775] Enabled early print
[0559.777] [L4T TegraBoot] (version �^���\�ǿ��Q�v���������ŕ������� )
[0559.783] Processing in recovery mode
[0559.787] A02 Bootrom Patch rev = 1023
[0559.790] Power-up reason: software reset
[0559.794] Established communication link with host
[0560.765] Odmdata from BCT: 0x000a4000
[0560.768] DebugPort= 0x3
[0560.771] SkipQspiOnly= 0x0
[0560.823] EEPROM CRC failed. Calculated crc=0xac CRC stored = 0x88
[0560.828] Reading Board-Type unsuccessful
[0560.832] BoardId read from EEPROM/NCT: 0
[0560.836] Unsupported Platform 0
[0560.839] Downloaded BCT successfully
