I tried booting it up today, and now it is behaving differently. When I plug it in, it repeatedly reboots itself until I unplug it. Here is what appears in the log every time it tries to boot:
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.140] Power-up reason: pmc por
[0000.143] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.149] pmic max77620 NVERC : 0x4c
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.158] max77620 disabling SD1 Remote Sense
[0000.162] Setting DDR voltage to 1125mv
[0000.166] Serial Number of Pmic Max77663: 0x1b16e5
[0000.174] Entering ramdump check
[0000.177] Get RamDumpCarveOut = 0x0
[0000.180] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.185] Last reboot was clean, booting normally!
[0000.190] Sdram initialization is successful
[0000.194] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.200] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.206] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.212] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.229] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.235] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.251] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.465] Csd NumOfBlocks=31037440
[0000.469] Set High speed to 1
[0000.478] Using GPT Primary to query partitions
[0000.483] Loading Tboot-CPU binary
[0000.497] Verifying TBC in OdmNonSecureSBK mode
[0000.507] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.514] Bootloader downloaded successfully.
[0000.518] Downloaded Tboot-CPU binary to 0xa0000258
[0000.523] MAX77620_GPIO5 configured
[0000.526] CPU power rail is up
[0000.529] CPU clock enabled
[0000.533] Performing RAM repair
[0000.536] Updating A64 Warmreset Address to 0xa00002e9
[0000.541] Loading NvTbootBootloaderDTB
[0000.580] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.645] Bootloader DTB Load Address: 0x83000000
[0000.649] Loading NvTbootKernelDTB
[0000.686] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.751] Kernel DTB Load Address: 0x83100000
[0000.755] Loading cboot binary
[0000.800] Verifying EBT in OdmNonSecureSBK mode
[0000.843] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.850] Bootloader downloaded successfully.
[0000.854] Next binary entry address: 0x92c00258
[0000.859] BoardId: 3448
[0000.863] Overriding pmu board id with proc board id
[0000.868] Display board id is not available
[0000.909] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.961] /bpmp deleted
[0000.964] SC7EntryFw header found loaded at 0xff700000
[0001.152] OVR2 PMIC
[0001.154] Bpmp FW successfully loaded
[0001.158] WB0 init successfully at 0xff780000
[0001.162] Set NvDecSticky Bits
[0001.166] GSC2 address ff53fffc value c0edbbcc
[0001.172] GSC MC Settings done
[0001.175] TOS Image length 53680
[0001.178] Monitor size 53680
[0001.181] OS size 0
[0001.190] Secure Os AES-CMAC Verification Success!
[0001.195] TOS image cipher info: plaintext
[0001.198] Loading and Validation of Secure OS Successful
[0001.214] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.219] NvTbootPackSdramParams: start.
[0001.224] NvTbootPackSdramParams: done.
[0001.228] Tegraboot started after 53780 us
[0001.232] Basic modules init took 840137 us
[0001.236] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.241] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.248] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.253] Storage Device Read Time = 170 ms, Read Size = 2241 KB
[0001.259] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.265] Next stage binary read took 37908 us
[0001.269] Carveout took -49570 us
[0001.272] CPU initialization took 375427 us
[0001.276] Total time taken by TegraBoot 1203902 us
[0001.281] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 16:52:46, Jul 16 2019
ERROR: Error initializing runtime service trusty_fast
[0001.403] RamCode = 0
[0001.408] LPDDR4 Training: Read DT: Number of tables = 2
[0001.413] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.425] EMC Training Successful
[0001.428] 408000 not found in DVFS table
[0001.435] RamCode = 0
[0001.438] DT Write: emc-table@204000 succeeded
[0001.444] DT Write: emc-table@1600000 succeeded
[0001.448] LPDDR4 Training: Write DT: Number of tables = 2
[0001.492]
[0001.493] Debug Init done
[0001.495] Marked DTB cacheable
[0001.498] Bootloader DTB loaded at 0x83000000
[0001.503] Marked DTB cacheable
[0001.506] Kernel DTB loaded at 0x83100000
[0001.510] DeviceTree Init done
[0001.522] Pinmux applied successfully
[0001.526] gicd_base: 0x50041000
[0001.530] gicc_base: 0x50042000
[0001.533] Interrupts Init done
[0001.537] Using base:0x60005090 & irq:208 for tick-timer
[0001.542] Using base:0x60005098 for delay-timer
[0001.546] platform_init_timer: DONE
[0001.550] Timer(tick) Init done
[0001.553] osc freq = 38400 khz
[0001.558]
[0001.559] welcome to cboot
[0001.561]
[0001.562] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.567] calling constructors
[0001.570] initializing heap
[0001.573] initializing threads
[0001.576] initializing timers
[0001.579] creating bootstrap completion thread
[0001.583] top of bootstrap2()
[0001.586] CPU: ARM Cortex A57
[0001.589] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.594] initializing platform
[0001.597] Scratch reg 37 & 271 initial value set..
[0001.603] cboot:secure-pmc present
[0001.606] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.611] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.615] Macronix QSPI chip present
[0001.619] SPI device register
[0001.622] init boot device
[0001.624] allocating memory for boot device(SPI)
[0001.629] registering boot device
[0001.638] sdmmc node status = okay
[0001.642] sdcard instance = 0
[0001.644] sdcard gpio handle 0x56
[0001.648] sdcard gpio pin 0xc9
[0001.651] sdcard gpio flags 0x0
[0001.654] vmmc-supply 0x99
[0001.656] Instance: 0
[0001.658] Allocating memory for context
[0001.662] enabling clock
[0001.665] sd card init
[0001.667] Check card present and stable
[0001.671] Send command 0
[0001.691] Send command 3
[0001.695] Set RCA for the card
[0001.698] Query card specific data by command 9
[0001.705] Parse CSD data
[0001.707] Send command 7
[0001.718] Calling sd device register
[0001.721] Init sdcard
[0001.723] Allocating memory for boot device
[0001.727] Registering user device
[0001.740] Enable APE clock
[0001.743] Un-powergate APE partition
[0001.746] of_register: registering tegra_udc to of_hal
[0001.752] of_register: registering tegra_udc to of_hal
[0001.757] of_register: registering inv20628-driver to of_hal
[0001.762] of_register: registering ads1015-driver to of_hal
[0001.768] of_register: registering lp8557-bl-driver to of_hal
[0001.774] of_register: registering bq2419x_charger to of_hal
[0001.779] of_register: registering cpc to of_hal
[0001.784] of_register: registering bq27441_fuel_gauge to of_hal
[0001.795] gpio framework initialized
[0001.799] of_register: registering tca9539_gpio to of_hal
[0001.804] of_register: registering tca9539_gpio to of_hal
[0001.809] of_register: registering i2c_bus_driver to of_hal
[0001.815] of_register: registering i2c_bus_driver to of_hal
[0001.820] of_register: registering i2c_bus_driver to of_hal
[0001.826] of_register: registering i2c_bus_driver to of_hal
[0001.832] pmic framework initialized
[0001.835] of_register: registering max77620_pmic to of_hal
[0001.841] regulator framework initialized
[0001.844] of_register: registering tps65132_bl_driver to of_hal
[0001.850] initializing target
[0001.856] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.865] fixed regulator driver initialized
[0001.882] initializing OF layer
[0001.885] NCK carveout not present
[0001.888] Skipping dts_overrides
[0001.892] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.909] I2C Bus Init done
[0001.911] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.921] I2C Bus Init done
[0001.924] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.934] I2C Bus Init done
[0001.937] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.947] I2C Bus Init done
[0001.950] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.960] I2C Bus Init done
[0001.963] of_children_init: Ops found for compatible string maxim,max77620
[0001.973] max77620_init using irq 118
[0001.978] register ‘maxim,max77620’ pmic
[0001.982] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.988] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.999] I2C Bus Init done
[0002.002] NCK carveout not present
[0002.006] shim_invoke: No NCT, Calling dts updates
[0002.017] Find /i2c@7000c000’s alias i2c0
[0002.021] get eeprom at 1-a0, size 256, type 0
[0002.029] Find /i2c@7000c500’s alias i2c2
[0002.033] get eeprom at 3-a0, size 256, type 0
[0002.038] get eeprom at 3-ae, size 256, type 0
[0002.042] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.047] I2C slave not started
[0002.050] I2C write failed
[0002.053] Writing offset failed
[0002.056] eeprom_init: EEPROM read failed
[0002.060] pm_ids_update: eeprom init failed
[0002.064] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.094] pm_ids_update: The pm board id is 3448-0000-200
[0002.101] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.108] pm_ids_update: pm id update successful
[0002.113] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.143] pm_ids_update: The pm board id is 3449-0000-200
[0002.150] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.157] pm_ids_update: pm id update successful
[0002.188] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.193] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.202] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.207] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.216] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:54:30
[0002.222] Plugin Manager: Parse ODM data 0x00094000
[0002.232] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.253] Find /i2c@7000c000’s alias i2c0
[0002.257] get eeprom at 1-a0, size 256, type 0
[0002.266] Find /i2c@7000c500’s alias i2c2
[0002.270] get eeprom at 3-a0, size 256, type 0
[0002.274] get eeprom at 3-ae, size 256, type 0
[0002.279] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.284] I2C slave not started
[0002.287] I2C write failed
[0002.290] Writing offset failed
[0002.293] eeprom_init: EEPROM read failed
[0002.297] pm_ids_update: eeprom init failed
[0002.301] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.331] pm_ids_update: The pm board id is 3448-0000-200
[0002.337] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.344] pm_ids_update: pm id update successful
[0002.349] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.379] pm_ids_update: The pm board id is 3449-0000-200
[0002.385] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.392] pm_ids_update: pm id update successful
[0002.423] Chip UID is 0000000164449582100000000a028080
[0002.428] Add serial number:14224190883450808002 as DT property
[0002.436] Applying platform configs
[0002.443] platform-init is not present. Skipping
[0002.447] calling apps_init()
[0002.473] Found 12 GPT partitions in “sd0”
[0002.477] Proceeding to Cold Boot
[0002.480] starting app android_boot_app
[0002.484] Device state: unlocked
[0002.487] display console init
[0002.495] could not find regulator
[0002.498] hdmi cable connected
[0002.514] edid read success
[0002.532] DT entry for leds-pwm not found
[0002.536] edid read success
[0002.539] width = 640, height = 480, frequency = 25174825
[0002.544] width = 640, height = 480, frequency = 25174825
[0002.549] width = 1920, height = 1080, frequency = 148500000
[0002.555] width = 1920, height = 1080, frequency = 148500000
[0002.561] width = 640, height = 480, frequency = 25174825
[0002.566] width = 720, height = 480, frequency = 26973026
[0002.571] width = 720, height = 480, frequency = 26973026
[0002.577] width = 720, height = 576, frequency = 26973026
[0002.582] width = 720, height = 576, frequency = 26973026
[0002.588] width = 1280, height = 720, frequency = 74175824
[0002.593] width = 1280, height = 720, frequency = 74175824
[0002.598] width = 1920, height = 1080, frequency = 148351648
[0002.604] width = 1920, height = 1080, frequency = 148351648
[0002.610] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.618] tmds-config node not found
[0002.622] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.636] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.644] could not find regulator
[0002.647] could not find regulator
[0002.650] could not find regulator
[0002.679] using default cmu settings
[0002.682] dc_hdmi_enable, starting HDMI initialisation
[0002.689] dc_hdmi_enable, HDMI initialisation complete
[0002.694] list and configure display window
[0002.702] display console init completed
[0002.713] subnode volume_up is not found !
[0002.717] subnode back is not found !
[0002.721] subnode volume_down is not found !
[0002.725] subnode menu is not found !
[0002.729] Gpio keyboard init success
[0002.761] found decompressor handler: lz4-legacy
[0002.776] decompressing blob (type 1)…
[0002.811] load_bmp_blob: panelresolution=1080 type=3
[0002.851] decompressor handler not found
[0002.855] load_firmware_blob: Firmware blob loaded, entries=2
[0002.860] se_aes_verify_sbk_clear: Error
[0002.864] bl_battery_charging: connected to external power supply
[0002.872] xusb is supported
[0002.878] error while finding nvidia,portmap
[0002.883] could not find regulator
[0003.386] xusb blob version 0 size 124416
[0003.390] firmware size 124416
[0003.395] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.409] xhci0: 64 bytes context size, 32-bit DMA
[0003.449] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.469] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.119] uhub0: 9 ports with 9 removable, self powered
[0005.119] failed to get HID devices
[0005.122] failed to init xhci or no usb device attached
[0005.130] device_query_partition_size: failed to open partition sd0:MSC !
[0005.136] MSC Partition not found
[0005.140] device_query_partition_size: failed to open partition sd0:USP !
[0005.146] USP partition read failed!
[0005.150] blob_init: blob-partition USP header read failed
[0005.155] android_boot Unable to update recovery partition
[0005.161] kfs_getpartname: name = LNX
[0005.164] Loading kernel from LNX
[0005.226] Verifying boot image in OdmNonSecureSBK mode
[0005.270] kernel load address: 0x80080000, size: 482032 bytes
[0005.275] ramdisk load address: 0x84100000, size: 0 bytes
[0005.281] load kernel from storage
[0005.293] decompressor handler not found
[0005.350] Successfully loaded kernel and ramdisk images
[0005.356] load_bmp_blob: panelresolution=1080 type=3
[0005.851] display bmp image done
[0005.854] NCK carveout not present
[0005.858] Skipping dts_overrides
[0005.861] NCK carveout not present
[0005.864] shim_invoke: No NCT, Calling dts updates
[0005.875] Find /i2c@7000c000’s alias i2c0
[0005.879] get eeprom at 1-a0, size 256, type 0
[0005.888] Find /i2c@7000c500’s alias i2c2
[0005.892] get eeprom at 3-a0, size 256, type 0
[0005.896] get eeprom at 3-ae, size 256, type 0
[0005.901] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.906] I2C slave not started
[0005.909] I2C write failed
[0005.912] Writing offset failed
[0005.915] eeprom_init: EEPROM read failed
[0005.919] pm_ids_update: eeprom init failed
[0005.923] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.953] pm_ids_update: The pm board id is 3448-0000-200
[0005.960] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.967] pm_ids_update: pm id update successful
[0005.972] pm_ids_update: Updating 3,ae, size 256, type 0
[0006.002] pm_ids_update: The pm board id is 3449-0000-200
[0006.008] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0006.016] pm_ids_update: pm id update successful
[0006.046] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.052] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0006.060] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.066] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0006.075] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:54:30
[0006.081] Plugin Manager: Parse ODM data 0x00094000
[0006.091] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.106] Add serial number:14224190883450808002 as DT property
[0006.115] “bpmp” doesn’t exist, creating
[0006.121] Updated bpmp info to DTB
[0006.126] Updated initrd info to DTB
[0006.129] “proc-board” doesn’t exist, creating
[0006.134] Updated board info to DTB
[0006.138] “pmu-board” doesn’t exist, creating
[0006.143] Updated board info to DTB
[0006.147] “display-board” doesn’t exist, creating
[0006.152] Updated board info to DTB
[0006.155] “reset” doesn’t exist, creating
[0006.160] Updated reset info to DTB
[0006.163] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb7000 is_hdmi_initialised=1
[0006.202] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.215] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.228] Updated bootarg info to DTB
[0006.231] Adding uuid 0000000164449582100000000a028080 to DT
[0006.237] Adding eks info 0 to DT
[0006.243] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.249] Updated memory info to DTB
[0006.254] Updated system-lp0-disable info to DTB
[0006.262] set vdd_core voltage to 1125 mv
[0006.266] setting ‘vdd-core’ regulator to 1125000 micro volts
[0006.289] could not find regulator
[0006.293] Found secure-pmc; disable BPMP
U-Boot 2016.07-gd917e08cec (Jul 16 2019 - 16:52:59 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 72 ms (9.8 KiB/s)
L4T boot options
1:primary kernel
Enter choice: 1:primary kernel
Retrieving file: /boot/initrd
5562393 bytes read in 407 ms (13 MiB/s)
Retrieving file: /boot/Image
34179080 bytes read in 2451 ms (13.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb7000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 0000000083177282
Starting kernel …
[ 1.096094] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.246473] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.246503] imx219 6-0010: board setup failed
[ 1.765720] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 1.765720]
[ 1.774900] CPU: 1 PID: 1 Comm: init Not tainted 4.9.140-tegra #1
[ 1.781019] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 1.787048] Call trace:
[ 1.789511] [] dump_backtrace+0x0/0x198
[ 1.794932] [] show_stack+0x24/0x30
[ 1.800006] [] dump_stack+0x98/0xc0
[ 1.805081] [] panic+0x11c/0x298
[ 1.809891] [] do_exit+0xa04/0xa08
[ 1.814877] [] do_group_exit+0x40/0xa8
[ 1.820210] [] __wake_up_parent+0x0/0x40
[ 1.825717] [] el0_svc_naked+0x34/0x38
[ 1.831053] SMP: stopping secondary CPUs
[ 1.835044] Kernel Offset: disabled
[ 1.838550] Memory Limit: none
[ 1.846892] Rebooting in 5 seconds..
