my jetson nao board was working fine, then to enable spi communication on board i used sdk manager to flash the device. in between the jetson board flashing process the usb connection become unresponsive. after that I normally start the device it shows blank screen.
and it still continue to show blank screen (no Nvidia logo appears on screen) after I flash the jetson nano image on SD card using host PC. it shows only glows green power LED while no data on HDMI screen.
I am experiencing the same issue. LED light is on but no HDMI signal.
Please try to get the UART log if possible. Are you using any converter on your HDMI port?
If your monitor supports DP too, could you also try to use the DP port?
previously it was working fine. after got stuck while flashing the jetson nano image using sdk_manager at force recovery mode, it only shows black screen at HDMI. I have also write the image on sd card but it doesnt boot.
now please tell me where can i find UART log?
" then to enable spi communication on board i used sdk manager to flash the device." May I know what did you do to enable spi communication?
Are you able to ping 192.168.55.1 on your host when you conenct usb cable to micro usb port on Nano?
I just want to know if the device boots up normally or not.
Hi Manjeet!
You can access the UART log in two possible ways.
- If your board boots, you can connect a micro USB cable to the Nano and the PC and then run the following command:
sudo minicom -D /dev/ttyACM0
After that, you can directly access to the terminal of your Nano similar as with the ssh command. Then login to the Nano board and access its system image.
- You can connect a USB to TTL Serial Cable (as the one on the below link) to your Nano board and your PC on the Nano board J44 Serial Port Pin Header. The RX, TX and GND pins are labeled on the Nano board PCB. Then on your PC, run any terminal emulator (minicom, picocom, termnet, etc) to connect to the /dev/ttyUSBX device that appears when you plugged in the USB to TTL Serial Cable to your PC.
This method allows us to see all the board log since powerup, so any boot problems could be easily debugged. The other methods only give us access to board log until it reaches the login screen, so many useful debug information may be lost.
USB to TTL Serial Cable link:
https://www.sparkfun.com/products/12977
Also, in regards to the black screen problem that you describe. When you use a compiled kernel from source code, you need to always replace the kernel Image, device tree (dtb) and kernel modules. If you only replace the Kernel Image and dtb, but miss the modules changes, the kernel will not load the modules. So to avoid any issue, always copy your built modules to “/lib/modules/”.
If you run the following commands on your Nano standard image, you will see that the kernel version has a sufix (-tegra):
~$ uname -a
Linux dchaverri-desktop 4.9.140-tegra #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019 aarch64 aarch64 aarch64 GNU/Linux
/$ ls /lib/modules/
4.9.140-tegra
The kernel and module version has to perfectly match (including the suffix string). If you are using a custom kernel image, the suffix of the kernel image changes as it does the module’s version, so you have to copy your custom modules version to “/usr/lib” in your Nano board.
I hope this information will be useful!
I am facing the problem of having the green power lid up but no HDMI output. I am not sure whether it is the same issue as manjeet.elect.
My UART log is as below:-
It is complaining of “Invalid GPT Partition”. What should I do?
Regards,
James
15:12:14.999 → [0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
15:12:31.931 → [0000.131] Processing in cold boot mode Bootloader 2
15:12:31.931 → [0000.136] A02 Bootrom Patch rev = 1023
15:12:31.931 → [0000.139] Power-up reason: pmc por
15:12:31.931 → [0000.142] No Battery Present
15:12:31.931 → [0000.145] pmic max77620 reset reason
15:12:31.931 → [0000.148] pmic max77620 NVERC : 0x40
15:12:31.931 → [0000.152] RamCode = 0
15:12:31.931 → [0000.154] Platform has DDR4 type RAM
15:12:31.969 → [0000.157] max77620 disabling SD1 Remote Sense
15:12:31.969 → [0000.161] Setting DDR voltage to 1125mv
15:12:31.969 → [0000.165] Serial Number of Pmic Max77663: 0xb2de9
15:12:31.969 → [0000.173] Entering ramdump check
15:12:31.969 → [0000.176] Get RamDumpCarveOut = 0x0
15:12:31.969 → [0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
15:12:31.969 → [0000.184] Last reboot was clean, booting normally!
15:12:31.969 → [0000.189] Sdram initialization is successful
15:12:31.969 → [0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
15:12:32.006 → [0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
15:12:32.006 → [0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
15:12:32.006 → [0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
15:12:32.006 → [0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
15:12:32.006 → [0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
15:12:32.006 → [0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
15:12:32.044 → [0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
15:12:32.044 → [0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
15:12:32.044 → [0000.256] Platform-DebugCarveout: 0
15:12:32.044 → [0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
15:12:32.044 → [0000.265] Non secure mode, and RB not enabled.
15:12:32.079 → [0000.272] Invalid GPT Partition
15:12:32.079 → [0000.287] Using BFS PT to query partitions
15:12:32.079 → [0000.291] failed to load NvTbootTbootCpu from (2:0)
15:12:32.079 → [0000.296] re-load NvTbootTbootCpu from (4:0)
15:12:32.268 → [0000.441] Csd NumOfBlocks=62333952
15:12:32.268 → [0000.451] Invalid GPT Partition
15:12:32.452 → [0000.642] Using BFS PT to query partitions
15:12:32.452 → [0000.651] Invalid GPT Partition
15:12:32.452 → [0000.653] Error is 1
I would suggest to reflash the board. Corrupted gpt partition is not very common.
I have reflashed the SD card many times using my linux machine and mac.
The result is still the same …
Sorry, I misread your reply.
You said “reflash the board”. May I know how to reflash the board?
Hi james.ee.developer!
To reflash your nano board you should follow these steps:
- Attach micro USB cable between the Nano and the PC.
- Put the Nano board on recovery mode. If you execute “lsusb” on your host PC command line, you should see a line with the following message: “NVIDIA Corp” or something similar.
- Go into the following directory inside JetPack:
cp ${JETPACK}/JetPack_4.2_Linux_P3448/Linux_for_Tegra/ - Flash whole Nano file system
sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
Best regards,
-Daniel
Pop the microsd card out, stick it in a reader, and use Etcher to flash the .zip to the sdcard.
I flash images using gnome-disks on Ubuntu as well (hit Windows key and type disks, Disks should be your first result). Select the sd card in the list in the left, click the hamburger/menu icon in the top right corner, and click restore disk image. Then select the extracted .img file and write it to the card. If you see a bunch of partitions, it’s correct. The last partition will resize to the extents of the drive on first boot.
can you please take a lot at my error message while booting?
I am using 5V6A power supply just to guarantee there is always enough power delievery. Also I monitored to voltage during the booting, there is no voltage drop when it hangs.
U-Boot 2016.07-g0eb73f4 (Mar 13 2019 - 00:21:24 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
239 bytes read in 126 ms (1000 Bytes/s)
p3450-porg eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
0 bytes read in 96 ms (0 Bytes/s)
Retrieving file: /boot/Image
34048008 bytes read in 2924 ms (11.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 vit
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 0000000083173e9a
Starting kernel ...
<hit enter to activate fiq debugger>
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3531) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef9009
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc0fefd2000 s53400 r8192 d32616 u94208
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emct
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29492(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3576064K/4159488K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 108288K reserved, 475136K cma-)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001463] Console: colour dummy device 80x25
[ 0.002314] console [tty0] enabled
[ 0.002340] kmemleak: Kernel memory leak detector disabled
[ 0.002368] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002395] pid_max: default: 32768 minimum: 301
[ 0.002849] Security Framework initialized
[ 0.003079] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003099] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004300] ftrace: allocating 46802 entries in 183 pages
[ 0.175845] ASID allocator initialised with 65536 entries
[ 0.211315] tegra-id: chipid=22117.
[ 0.211357] tegra-id: opt_subrevision=0.
[ 0.211384] Tegra Speedo/IDDQ fuse revision 4
[ 0.211400] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211416] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.211432] Tegra: CPU Speedo Value 2047, SoC Speedo Value 1940, GPU Speedo Value 2044
[ 0.211453] Tegra: CPU IDDQ Value 2064, SoC IDDQ Value 2324, GPU IDDQ Value 2750
[ 0.211487] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.211510] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porgs
[ 0.211545] DTB Build time: Mar 15 2019 09:52:07
[ 0.261053] CPU1: Booted secondary processor [411fd071]
[ 0.292951] CPU2: Booted secondary processor [411fd071]
[ 0.324934] CPU3: Booted secondary processor [411fd071]
[ 0.325026] Brought up 4 CPUs
[ 0.325088] SMP: Total of 4 processors activated.
[ 0.325105] CPU features: detected feature: 32-bit EL0 Support
[ 0.325386] CPU: All CPU(s) started at EL2
[ 0.325416] alternatives: patching kernel code
[ 0.333365] devtmpfs: initialized
[ 0.367635] Initilizing CustomIPI irq domain
[ 0.368031] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.368078] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.378560] pinctrl core: initialized pinctrl subsystem
[ 0.379189] OS set in device tree is not L4T.
[ 0.379592] regulator-dummy: no parameters
[ 0.379868] Initializing plugin-manager
[ 0.380019] Plugin module not found
[ 0.380234] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.380776] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.381562] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.384686] NET: Registered protocol family 16
[ 0.386065] pstore: using zlib compression
[ 0.386694] console [pstore-1] enabled
[ 0.386711] pstore: Registered ramoops as persistent store backend
[ 0.386729] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.401071] cpuidle: using governor menu
[ 0.404865] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.406353] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.406400] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.409471] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.410960] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.411919] tegra_powergate_init: DONE
[ 0.411958] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porgs
[ 0.411995] DTB Build time: Mar 15 2019 09:52:07
[ 0.413615] Tegra reboot handler registered.
[ 0.417945] iommu: Adding device tegra-carveouts to group 0
[ 0.418111] platform tegra-carveouts: domain=ffffffc0f9bc03d8 allocates as[0]=ffffffc0f9bd80a8
[ 0.418487] iommu: Adding device smmu_test to group 1
[ 0.418556] platform smmu_test: domain=ffffffc0f9bc0618 allocates as[0]=ffffffc0f9bd8110
[ 0.419380] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.419456] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.419531] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.419553] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.419587] mc-err: mcerr ops are set to t21x
[ 0.429237] iommu: Adding device 70090000.xusb to group 2
[ 0.429555] iommu: Adding device 70006000.serial to group 3
[ 0.429659] platform 70006000.serial: domain=ffffffc0f946c618 allocates as[0]=ffffffc0f9bd8178
[ 0.430094] iommu: Adding device 70006040.serial to group 4
[ 0.430386] iommu: Adding device 70006200.serial to group 5
[ 0.430619] iommu: Adding device sound to group 6
[ 0.430680] platform sound: domain=ffffffc0f946cb58 allocates as[0]=ffffffc0f9bd81e0
[ 0.431244] iommu: Adding device 7000d400.spi to group 7
[ 0.431520] iommu: Adding device 7000d600.spi to group 8
[ 0.431799] iommu: Adding device 70410000.spi to group 9
[ 0.432115] iommu: Adding device 50000000.host1x to group 10
[ 0.432406] iommu: Adding device 54080000.vi to group 11
[ 0.432808] iommu: Adding device 54600000.isp to group 12
[ 0.433116] iommu: Adding device 54680000.isp to group 13
[ 0.433457] iommu: Adding device tegradc.0 to group 14
[ 0.433530] platform tegradc.0: domain=ffffffc0f9479a98 allocates as[0]=ffffffc0f9bd8248
[ 0.434067] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.434399] iommu: Adding device tegradc.1 to group 15
[ 0.434460] platform tegradc.1: domain=ffffffc0f9479cd8 allocates as[0]=ffffffc0f9bd82b0
[ 0.434990] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.435243] iommu: Adding device 54340000.vic to group 16
[ 0.435463] iommu: Adding device 544c0000.nvenc to group 17
[ 0.435677] iommu: Adding device 54500000.tsec to group 18
[ 0.435890] iommu: Adding device 54100000.tsecb to group 19
[ 0.436098] iommu: Adding device 54480000.nvdec to group 20
[ 0.436336] iommu: Adding device 54380000.nvjpg to group 21
[ 0.437498] iommu: Adding device 546c0000.i2c to group 22
[ 0.437843] iommu: Adding device 57000000.gpu to group 23
[ 0.437909] platform 57000000.gpu: domain=ffffffc0f9485cd8 allocates as[0]=ffffffc0f9bd8318
[ 0.437964] platform 57000000.gpu: domain=ffffffc0f9485cd8 allocates as[1]=ffffffc0f9bd8380
[ 0.438022] platform 57000000.gpu: domain=ffffffc0f9485cd8 allocates as[2]=ffffffc0f9bd83e8
[ 0.438080] platform 57000000.gpu: domain=ffffffc0f9485cd8 allocates as[3]=ffffffc0f9bd8450
[ 0.438987] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.439028] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.439055] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.439076] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.439094] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.489134] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.489171] tegra-pmc: Clear bootloader IO dpd settings
[ 0.489204] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.489282] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.489603] iommu: Adding device 70012000.se to group 24
[ 0.490466] iommu: Adding device 7000c000.i2c to group 25
[ 0.490798] iommu: Adding device 7000c400.i2c to group 26
[ 0.491117] iommu: Adding device 7000c500.i2c to group 27
[ 0.491429] iommu: Adding device 7000c700.i2c to group 28
[ 0.491790] iommu: Adding device 7000d000.i2c to group 29
[ 0.492109] iommu: Adding device 7000d100.i2c to group 30
[ 0.492476] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.492544] platform sdhci-tegra.0: domain=ffffffc0f9514e58 allocates as[0]=ffffffc0f9bd84b8
[ 0.493538] iommu: Adding device 700d0000.xudc to group 32
[ 0.499339] vdd-ac-bat: 5000 mV
[ 0.499776] vdd-5v0-sys: 5000 mV
[ 0.500917] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.501021] vdd-5v0-hdmi: 5000 mV
[ 0.501445] vdd-1v8: 1800 mV
[ 0.501914] vdd-fan: supplied by vdd-5v0-sys
[ 0.501965] vdd-fan: 5000 mV
[ 0.502415] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.502484] vdd-usb-vbus: 5000 mV
[ 0.503066] vdd-usb-vbus2: 5000 mV
[ 0.537757] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540194] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.540650] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.548704] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.549065] SCSI subsystem initialized
[ 0.549681] usbcore: registered new interface driver usbfs
[ 0.549759] usbcore: registered new interface driver hub
[ 0.549844] usbcore: registered new device driver usb
[ 0.553940] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.555612] random: fast init done
[ 0.560375] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.561632] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.564231] vdd-ddr-1v1: 1150 mV
[ 0.568228] vdd-pre-reg-1v35: 1350 mV
[ 0.572229] vdd-1v8: 1800 mV
[ 0.572514] vdd-1v8: Failed to create debugfs directory
[ 0.576226] avdd-sys-1v2: 1200 mV
[ 0.580226] vdd-pex-1v0: 1050 mV
[ 0.581003] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.581644] max77620-ldo3: at 3100 mV
[ 0.584227] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.584905] max77620-ldo5: at 3100 mV
[ 0.585560] max77620-ldo6: at 2800 mV
[ 0.588233] avdd-1v05-pll: 1050 mV
[ 0.592226] avdd-io-hdmi-dp: 1050 mV
[ 0.593760] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.594049] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.596147] max77620 4-003c: max77620 probe successful
[ 0.598421] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.598976] media: Linux media interface: v0.10
[ 0.599044] Linux video capture interface: v2.00
[ 0.599978] pps_core: LinuxPPS API ver. 1 registered
[ 0.600008] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.600048] PTP clock support registered
[ 0.603431] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.609683] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.610583] Advanced Linux Sound Architecture Driver Initialized.
[ 0.611225] Bluetooth: Core ver 2.22
[ 0.611294] NET: Registered protocol family 31
[ 0.611312] Bluetooth: HCI device and connection manager initialized
[ 0.611338] Bluetooth: HCI socket layer initialized
[ 0.611359] Bluetooth: L2CAP socket layer initialized
[ 0.611395] Bluetooth: SCO socket layer initialized
[ 0.613131] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.613169] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.613231] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.613258] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.615932] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.617361] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.617449] vdd-3v3-sys: 3300 mV
[ 0.617721] vdd-1v8: supplied by vdd-3v3-sys
[ 0.620297] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.620792] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.620838] vdd-3v3-sd: 3300 mV
[ 0.622084] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.622143] avdd-io-edp-1v05: 1050 mV
[ 0.622642] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.622716] vdd-usb-hub-en: 5000 mV
[ 0.623996] camchar: rtcpu character device driver loaded
[ 0.624818] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.626160] clocksource: Switched to clocksource arch_sys_counter
[ 0.665494] VFS: Disk quotas dquot_6.6.0
[ 0.665658] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.666206] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.666641] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.666692] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.666912] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.666940] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.666965] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.667016] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.667042] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.667073] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.667096] nvmap_page_pool_init: Total RAM pages: 1012800
[ 0.667114] nvmap_page_pool_init: nvmap page pool size: 126600 pages (494 MB)
[ 0.667360] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.667675] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.668647] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.676734] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.677141] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.677418] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.677650] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.677852] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.678130] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.678183] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.678635] NET: Registered protocol family 2
[ 0.679592] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.679830] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.680334] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.680498] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.680595] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.681016] NET: Registered protocol family 1
[ 0.681814] RPC: Registered named UNIX socket transport module.
[ 0.681844] RPC: Registered udp transport module.
[ 0.681861] RPC: Registered tcp transport module.
[ 0.681877] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.682138] Trying to unpack rootfs image as initramfs...
[ 0.691148] host1x 50000000.host1x: initialized
[ 0.692952] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.696482] audit: initializing netlink subsys (disabled)
[ 0.696604] audit: type=2000 audit(0.547:1): initialized
[ 0.697367] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.707503] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.709012] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.709820] 9p: Installing v9fs 9p2000 file system support
[ 0.713100] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.713260] io scheduler noop registered
[ 0.713572] io scheduler cfq registered (default)
[ 0.716269] gic 702f9000.agic: GIC IRQ controller registered
[ 0.719162] iommu: Adding device 702ef000.adsp to group 33
[ 0.725221] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.725384] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.725979] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x61a740c
[ 0.726011] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.727735] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.727870] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.727990] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.728209] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.728318] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.728432] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.728541] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.728651] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.728760] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.728867] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.735628] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.736976] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.738859] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.740172] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.740548] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.741732] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.741996] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.742405] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.742463] Adding domain tsec-pd to PM domain host1x-pd
[ 0.745322] tsec 54500000.tsec: initialized
[ 0.746789] tsec 54100000.tsecb: initialized
[ 0.747526] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.750648] nvdec 54480000.nvdec: initialized
[ 0.751735] Adding domain vic03-pd to PM domain host1x-pd
[ 0.751936] Adding domain msenc-pd to PM domain host1x-pd
[ 0.752114] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.755735] falcon 54340000.vic: initialized
[ 0.756983] falcon 544c0000.nvenc: initialized
[ 0.758403] falcon 54380000.nvjpg: initialized
[ 0.763001] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.763130] display board info: id 0x0, fab 0x0
[ 0.763209] generic_infoframe_type: 0x87
[ 0.763352] tegradc tegradc.0: DT parsed successfully
[ 0.763410] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 0.766994] tegradc tegradc.0: probed
[ 0.770786] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.775568] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.776491] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.776848] kfuse 7000fc00.kfuse: initialized
[ 0.778392] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.779319] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.780756] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.780804] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 0.781307] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.783078] vdd-gpu: applied init 1000000uV constraint
[ 0.783112] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 0.783564] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.788119] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.788354] No Device Node present for smmu client: serial8250 !!
[ 0.788384] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.788469] iommu: Adding device serial8250 to group 35
[ 0.791799] console [ttyS0] disabled
[ 0.791955] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.262328] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 1.666676] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.071000] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.073017] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 2.073425] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.073435] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.073440] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.073445] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.073450] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.073871] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.082345] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.082350] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.082359] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.082385] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.082408] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.082419] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.082426] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.082433] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.083205] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.083210] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.139579] console [ttyS0] enabled
[ 3.139954] Console: switching to colour frame buffer device 80x30
[ 3.141062] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.141394] serial-tegra 70006200.serial: RX in PIO mode
[ 3.141481] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.142501] [drm] Initialized
[ 3.163759] brd: module loaded
[ 3.179906] tegradc tegradc.0: fb registered
[ 3.180096] loop: module loaded
[ 3.180199] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.184278] tegra_profiler: auth: init
[ 3.187519] THERMAL EST: found 2 subdevs
[ 3.187524] THERMAL EST num_resources: 0
[ 3.187530] [THERMAL EST subdev 0]
[ 3.187538] [THERMAL EST subdev 1]
[ 3.188026] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.188028] THERMAL EST: thz register success.
[ 3.188185] THERMAL EST: end of probe, return err: 0
[ 3.189392] hisi_sas: driver version v1.6
[ 3.193437] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.201000] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.201007] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.207769] libphy: Fixed MDIO Bus: probed
[ 3.208799] tun: Universal TUN/TAP device driver, 1.6
[ 3.208801] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.209800] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.209802] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.209847] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.209848] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.209894] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.209897] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.209937] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.209939] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.210992] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 3.211021] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.225761] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.225796] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
[ 3.225796] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[ 3.225796] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.226385] PPP generic driver version 2.4.2
[ 3.226586] PPP BSD Compression module registered
[ 3.226591] PPP Deflate Compression module registered
[ 3.226633] PPP MPPE Compression module registered
[ 3.226640] NET: Registered protocol family 24
[ 3.226709] usbcore: registered new interface driver r8152
[ 3.226754] usbcore: registered new interface driver asix
[ 3.226812] usbcore: registered new interface driver ax88179_178a
[ 3.226854] usbcore: registered new interface driver cdc_ether
[ 3.226901] usbcore: registered new interface driver net1080
[ 3.226988] usbcore: registered new interface driver cdc_subset
[ 3.227027] usbcore: registered new interface driver zaurus
[ 3.227079] usbcore: registered new interface driver cdc_ncm
[ 3.227246] VFIO - User Level meta-driver version: 0.3
[ 3.231725] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.231748] ehci-pci: EHCI PCI platform driver
[ 3.231818] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.231831] ohci-pci: OHCI PCI platform driver
[ 3.231872] ohci-platform: OHCI generic platform driver
[ 3.234642] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.235246] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.236416] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f90ac400 id
[ 3.236528] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.236531] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.237814] usbcore: registered new interface driver uas
[ 3.237873] usbcore: registered new interface driver usb-storage
[ 3.237983] usbcore: registered new interface driver usbserial
[ 3.241108] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.242385] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.242396] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.242434] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.242693] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.243344] mousedev: PS/2 mouse device common for all mice
[ 3.243426] usbcore: registered new interface driver xpad
[ 3.468598] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.480298] rtc rtc1: alarm rtc device
[ 3.480314] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.480342] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.480884] i2c /dev entries driver
[ 3.482545] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.506931] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.507003] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.507033] imx219 6-0010: board setup failed
[ 3.507131] imx219: probe of 6-0010 failed with error -121
[ 3.513073] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.553581] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.553586] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.553994] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.554010] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.554019] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.554177] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.554187] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.554193] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.554347] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.554356] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.554361] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.554564] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.555345] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.555398] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.555422] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.555438] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.555447] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.556326] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.556344] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 3.556541] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.556570] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 3.557009] parse_throttle_dt_data: Num cap clks = 6
[ 3.557014] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.557029] parse_throttle_dt_data: clk=gpu type=4
[ 3.557054] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.557073] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.557094] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.557097] parse_throttle_dt_data: clk=emc type=3
[ 3.558673] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.558770] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.558901] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.559653] FAN dev name: pwm-fan
[ 3.559699] FAN:gpio request success.
[ 3.559770] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.560064] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.560260] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.560269] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.560358] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.560363] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.560368] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.560371] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.560375] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.560379] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.560382] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.560385] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.560389] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.560393] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.561005] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.561389] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.562342] device-mapper: uevent: version 1.0.3
[ 3.562815] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.568132] tegra210-cpufreq cpufreq: probe()...completed
[ 3.568859] sdhci: Secure Digital Host Controller Interface driver
[ 3.568860] sdhci: Copyright(c) Pierre Ossman
[ 3.568861] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.569348] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.569699] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.569824] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.573267] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.573790] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.575054] usbcore: registered new interface driver usbhid
[ 3.575055] usbhid: USB HID core driver
[ 3.595140] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 3.595358] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.597066] nvpmodel: initialized successfully
[ 3.598171] usbcore: registered new interface driver snd-usb-audio
[ 3.598232] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.598237] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.598254] iommu: Adding device snd-soc-dummy to group 36
[ 3.610255] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.611855] OPE platform probe
[ 3.611936] OPE platform probe successful
[ 3.611960] OPE platform probe
[ 3.612037] OPE platform probe successful
[ 3.636738] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.636865] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.636986] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.637116] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.637238] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.637363] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.637483] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.637606] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.637729] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.637856] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.650035] u32 classifier
[ 3.650036] Actions configured
[ 3.650108] Initializing XFRM netlink socket
[ 3.650863] NET: Registered protocol family 10
[ 3.651586] NET: Registered protocol family 17
[ 3.651597] NET: Registered protocol family 15
[ 3.651671] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.651718] Bluetooth: RFCOMM socket layer initialized
[ 3.651726] Bluetooth: RFCOMM ver 1.11
[ 3.651731] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.651735] Bluetooth: HIDP socket layer initialized
[ 3.651753] 9pnet: Installing 9P2000 support
[ 3.651788] Key type dns_resolver registered
[ 3.657823] Registered cp15_barrier emulation handler
[ 3.657837] Registered setend emulation handler
[ 3.658995] registered taskstats version 1
[ 3.659573] Adding domain ve2-pd to PM domain host1x-pd
[ 3.659819] Adding domain ve-pd to PM domain host1x-pd
[ 3.773018] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.280103] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.286519] tegradc tegradc.1: No lt-data, using default setting
[ 4.292545] tegradc tegradc.1: No hpd-gpio in DT
[ 4.297197] tegradc tegradc.1: DT parsed successfully
[ 4.302277] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 4.310313] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.821352] Host read timeout at address 545c00c4
[ 4.821906] tegradc tegradc.1: probed
[ 4.836515] tegradc tegradc.1: fb registered
[ 4.843936] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.845845] isp 54600000.isp: initialized
[ 4.846651] isp 54680000.isp: initialized
[ 4.858386] clk_cbus_recalc_rate: no gbus parent
[ 4.858390] clk_cbus_round_rate: no gbus parent
[ 4.858391] clk_cbus_round_rate: no gbus parent
[ 4.858396] clk_cbus_recalc_rate: no gbus parent
[ 4.858495] clk_cbus_recalc_rate: no gbus parent
[ 4.858498] clk_cbus_round_rate: no gbus parent
[ 4.858499] clk_cbus_round_rate: no gbus parent
[ 4.858502] clk_cbus_recalc_rate: no gbus parent
[ 4.858516] tegra_dvfs: GPU-cap: registered
[ 4.858576] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.858578] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.858580] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.909055] tegra_dvfs: vdd-gpu-vts: registered
[ 4.930903] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.938787] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.944292] tegradc tegradc.1: blank - powerdown
[ 4.944348] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 4.945003] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 4.945539] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.972962] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 4.980233] Extcon DP: HPD disabled
[ 4.983731] hpd: hpd_switch 0
[ 4.986711] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.993351] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 4.999268] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:28 UTC (946688428)
[ 5.000185] vi 54080000.vi: vi_probe: ++
[ 5.011930] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.023297] vi 54080000.vi: initialized
[ 5.025739] mmc0: hw tuning done ...
[ 5.025771] mmc0: new ultra high speed SDR104 SDHC card at address 0001
[ 5.030290] mmcblk0: mmc0:0001 SD32G 29.1 GiB
[ 5.039124] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 5.039126] GPT:25165823 != 61095935
[ 5.039127] GPT:Alternate GPT header not at the end of the disk.
[ 5.039128] GPT:25165823 != 61095935
[ 5.039129] GPT: Use GNU Parted to correct GPT errors.
[ 5.039149] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 5.075574] vi 54080000.vi: subdev nvcsi--1 bound
[ 5.080530] mmcblk mmc0:0001: Card claimed for testing.
[ 5.086997] Disable partitions left on by BL
[ 5.091283] disb
[ 5.093338] bwmgr: missing cdev-type property
[ 5.097793] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.107107] DRAM derating cdev registered.
[ 5.112260] vdd-1v8: disabling
[ 5.115328] vdd-fan: disabling
[ 5.118386] vdd-usb-vbus: disabling
[ 5.121867] vdd-usb-vbus2: disabling
[ 5.125451] avdd-io-edp-1v05: disabling
[ 5.129288] vdd-usb-hub-en: disabling
[ 5.133162] ALSA device list:
[ 5.136142] #0: tegra-hda at 0x70038000 irq 83
[ 5.140757] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.747949] EXT4-fs (mmcblk0p1): recovery complete
[ 5.758560] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.766669] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.776414] devtmpfs: mounted
[ 5.782465] Freeing unused kernel memory: 8512K
[ 6.019250] systemd[1]: System time before build time, advancing clock.
[ 6.071415] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.087682] cgroup: cgroup2: unknown option "nsdelegate"
[ 6.107785] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTL)
[ 6.129897] systemd[1]: Detected architecture arm64.
[ 6.160496] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 6.283278] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does.
[ 6.300369] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.514946] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.521603] systemd[1]: Reached target Swap.
[ 6.526325] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.534877] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.544433] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.552941] systemd[1]: Created slice System Slice.
[ 6.558168] systemd[1]: Listening on udev Control Socket.
[ 6.563882] systemd[1]: Listening on Journal Socket.
[ 6.639539] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.829940] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 6.898430] systemd-journald[1912]: Received request to flush runtime journal from PID 1
[ 7.807833] random: crng init done
[ 7.811240] random: 7 urandom warning(s) missed due to ratelimiting
Hi blp_engineer,
Sorry for late reply. What is the problem here? Is your boot in #13 the first time boot up?
Do you connect any monitor on Nano? I don’t see hdmi driver have any activity.
Hi, thank you for the reply. Someone suggested hotplug and it resolved the issue.
No HDMI driver message, hah, I guess it indicate that it the HDMI was not connected at all? Maybe it was some sort of wiring issue which was fixed by the hotplug?
Also, I’d like to just comment that people are so responsive here, which is quite different from my previous experiences on forums. Thank you, and everyone else for help me resolving the issue.
Hi blp_engineer,
Are you able to reproduce this issue regularly (every boot)?
- If you plug the hdmi during boot up, could you always see blanked monitor?
- If (1) is true, does it always works after hotplug?
I don’t think I have rebooted yet…if my memory is correct. Currently I am out of the lab, and would let you know the answer when I get back on Monday. Thanks for taking interest in the issue.
james.ee.developer,
Have you resolved your issue?
Hi blp_enigneer,
Any update?
Hi Wayne, I just tried booting it twice, both time were issue free. Now I think there is a high probability that the error message was due to not being able to make that HDMI connection.
Also, I just saw your comment on another thread, you were asking me if I was booting for the first time when I saw that error message. So yes. When I first got the board, there was no HDMI signal, i booted a few times, but still no signal therefore I used a serial interface to see what is going on. It always stops at that urandom message. That is when I decided to post thing on the forum.
