Ok, I went through and got the log for the good nano, which is included below:
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1f20e1
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.272] Invalid GPT Partition
[0000.287] Using BFS PT to query partitions
[0000.291] failed to load NvTbootTbootCpu from (2:0)
[0000.296] re-load NvTbootTbootCpu from (4:0)
[0000.558] Csd NumOfBlocks=249737216
[0000.617] Using GPT Primary to query partitions
[0000.625] Loading Tboot-CPU binary
[0001.002] Verifying TBC in OdmNonSecureSBK mode
[0001.012] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0001.019] Bootloader downloaded successfully.
[0001.023] Downloaded Tboot-CPU binary to 0xa0000258
[0001.028] MAX77620_GPIO5 configured
[0001.031] CPU power rail is up
[0001.034] CPU clock enabled
[0001.038] Performing RAM repair
[0001.041] Updating A64 Warmreset Address to 0xa00002e9
[0001.046] Loading NvTbootBootloaderDTB
[0002.355] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0002.420] Bootloader DTB Load Address: 0x83000000
[0002.425] Loading NvTbootKernelDTB
[0003.734] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0003.799] Kernel DTB Load Address: 0x83100000
[0003.807] Loading cboot binary
[0005.488] Verifying EBT in OdmNonSecureSBK mode
[0005.529] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0005.536] Bootloader downloaded successfully.
[0005.728] Using BFS PT to query partitions
[0005.732] Next binary entry address: 0x92c00258
[0005.737] BoardId: 3448
[0005.741] Overriding pmu board id with proc board id
[0005.746] Display board id is not available
[0007.242] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0007.294] /bpmp deleted
[0007.297] SC7EntryFw header found loaded at 0xff700000
[0007.485] OVR2 PMIC
[0007.487] Bpmp FW successfully loaded
[0007.503] WB0 init successfully at 0xff780000
[0007.508] Set NvDecSticky Bits
[0007.511] GSC2 address ff53fffc value c0edbbcc
[0007.518] GSC MC Settings done
[0007.523] TOS Image length 53680
[0007.526] Monitor size 53680
[0007.529] OS size 0
[0007.690] Secure Os AES-CMAC Verification Success!
[0007.694] TOS image cipher info: plaintext
[0007.698] Loading and Validation of Secure OS Successful
[0007.714] SC7 Entry Firmware - 0xff700000, 0x4000
[0007.719] NvTbootPackSdramParams: start.
[0007.724] NvTbootPackSdramParams: done.
[0007.728] Tegraboot started after 53292 us
[0007.731] Basic modules init took 5835795 us
[0007.736] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0007.741] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0007.746] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0007.752] Storage Device Read Time = 6729 ms, Read Size = 2306 KB
[0007.758] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0007.763] Next stage binary read took 1527607 us
[0007.768] Carveout took -1539290 us
[0007.771] CPU initialization took 2035976 us
[0007.775] Total time taken by TegraBoot 7860088 us
[0007.780] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:39:57, Dec 9 2019
ERROR: Error initializing runtime service trusty_fast
[0007.902] RamCode = 0
[0007.907] LPDDR4 Training: Read DT: Number of tables = 2
[0007.912] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0007.924] EMC Training Successful
[0007.927] 408000 not found in DVFS table
[0007.934] RamCode = 0
[0007.937] DT Write: emc-table@204000 succeeded
[0007.943] DT Write: emc-table@1600000 succeeded
[0007.947] LPDDR4 Training: Write DT: Number of tables = 2
[0008.147]
[0008.148] Debug Init done
[0008.151] Marked DTB cacheable
[0008.154] Bootloader DTB loaded at 0x83000000
[0008.158] Marked DTB cacheable
[0008.161] Kernel DTB loaded at 0x83100000
[0008.165] DeviceTree Init done
[0008.181] Pinmux applied successfully
[0008.185] gicd_base: 0x50041000
[0008.189] gicc_base: 0x50042000
[0008.192] Interrupts Init done
[0008.196] Using base:0x60005090 & irq:208 for tick-timer
[0008.201] Using base:0x60005098 for delay-timer
[0008.205] platform_init_timer: DONE
[0008.209] Timer(tick) Init done
[0008.213] osc freq = 38400 khz
[0008.217]
[0008.218] Welcome to L4T Cboot
[0008.221]
[0008.222] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0008.227] calling constructors
[0008.230] initializing heap
[0008.233] initializing threads
[0008.236] initializing timers
[0008.238] creating bootstrap completion thread
[0008.243] top of bootstrap2()
[0008.246] CPU: ARM Cortex A57
[0008.249] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0008.253] initializing platform
[0008.261] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0008.265] ID LSB = 0x36, ID-CFI len = 194 bytes
[0008.270] Macronix QSPI chip present
[0008.273] SPI device register
[0008.276] init boot device
[0008.279] allocating memory for boot device(SPI)
[0008.283] registering boot device
[0008.303] sdmmc node status = okay
[0008.306] sdcard instance = 0
[0008.309] sdcard gpio handle 0x56
[0008.312] sdcard gpio pin 0xc9
[0008.315] sdcard gpio flags 0x0
[0008.318] vmmc-supply 0x99
[0008.321] Instance: 0
[0008.323] Allocating memory for context
[0008.327] enabling clock
[0008.329] sd card init
[0008.331] Check card present and stable
[0008.335] Send command 0
[0008.360] Send command 3
[0008.364] Set RCA for the card
[0008.367] Query card specific data by command 9
[0008.373] Parse CSD data
[0008.376] Send command 7
[0008.386] Calling sd device register
[0008.389] Init sdcard
[0008.392] Allocating memory for boot device
[0008.396] Registering user device
[0008.409] Enable APE clock
[0008.412] Un-powergate APE partition
[0008.415] of_register: registering tegra_udc to of_hal
[0008.420] of_register: registering inv20628-driver to of_hal
[0008.426] of_register: registering ads1015-driver to of_hal
[0008.431] of_register: registering lp8557-bl-driver to of_hal
[0008.437] of_register: registering bq2419x_charger to of_hal
[0008.443] of_register: registering bq27441_fuel_gauge to of_hal
[0008.454] gpio framework initialized
[0008.458] of_register: registering tca9539_gpio to of_hal
[0008.463] of_register: registering tca9539_gpio to of_hal
[0008.468] of_register: registering i2c_bus_driver to of_hal
[0008.474] of_register: registering i2c_bus_driver to of_hal
[0008.479] of_register: registering i2c_bus_driver to of_hal
[0008.485] pmic framework initialized
[0008.489] of_register: registering max77620_pmic to of_hal
[0008.494] regulator framework initialized
[0008.498] of_register: registering tps65132_bl_driver to of_hal
[0008.504] initializing target
[0008.510] gpio_driver_register: register 'tegra_gpio_driver' driver
[0008.518] board ID = D78, board SKU = 0
[0008.522] Skipping Z3!
[0008.526] fixed regulator driver initialized
[0008.544] initializing OF layer
[0008.547] NCK carveout not present
[0008.550] Skipping dts_overrides
[0008.554] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.571] I2C Bus Init done
[0008.574] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.584] I2C Bus Init done
[0008.587] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.597] I2C Bus Init done
[0008.599] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.610] I2C Bus Init done
[0008.613] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.623] I2C Bus Init done
[0008.626] of_children_init: Ops found for compatible string maxim,max77620
[0008.636] max77620_init using irq 118
[0008.641] register 'maxim,max77620' pmic
[0008.645] gpio_driver_register: register 'max77620-gpio' driver
[0008.651] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.662] I2C Bus Init done
[0008.665] NCK carveout not present
[0008.675] Find /i2c@7000c000's alias i2c0
[0008.679] get eeprom at 1-a0, size 256, type 0
[0008.688] Find /i2c@7000c500's alias i2c2
[0008.692] get eeprom at 3-a0, size 256, type 0
[0008.696] get eeprom at 3-ae, size 256, type 0
[0008.701] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.706] I2C slave not started
[0008.709] I2C write failed
[0008.712] Writing offset failed
[0008.715] eeprom_init: EEPROM read failed
[0008.719] pm_ids_update: eeprom init failed
[0008.723] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.753] pm_ids_update: The pm board id is 3448-0000-200
[0008.759] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0008.767] pm_ids_update: pm id update successful
[0008.772] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.802] pm_ids_update: The pm board id is 3449-0000-200
[0008.808] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0008.816] pm_ids_update: pm id update successful
[0008.847] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.853] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0008.861] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.867] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0008.875] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:5b:76
[0008.882] Plugin Manager: Parse ODM data 0x00084000
[0008.892] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0008.914] Find /i2c@7000c000's alias i2c0
[0008.918] get eeprom at 1-a0, size 256, type 0
[0008.926] Find /i2c@7000c500's alias i2c2
[0008.930] get eeprom at 3-a0, size 256, type 0
[0008.935] get eeprom at 3-ae, size 256, type 0
[0008.939] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.944] I2C slave not started
[0008.947] I2C write failed
[0008.950] Writing offset failed
[0008.953] eeprom_init: EEPROM read failed
[0008.957] pm_ids_update: eeprom init failed
[0008.961] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.991] pm_ids_update: The pm board id is 3448-0000-200
[0008.998] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0009.005] pm_ids_update: pm id update successful
[0009.009] pm_ids_update: Updating 3,ae, size 256, type 0
[0009.039] pm_ids_update: The pm board id is 3449-0000-200
[0009.046] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0009.053] pm_ids_update: pm id update successful
[0009.083] Add serial number:1422019085141 as DT property
[0009.091] Applying platform configs
[0009.098] platform-init is not present. Skipping
[0009.102] calling apps_init()
[0009.128] Found 14 GPT partitions in "sd0"
[0009.132] Proceeding to Cold Boot
[0009.135] starting app android_boot_app
[0009.139] Device state: unlocked
[0009.142] display console init
[0009.150] could not find regulator
[0009.154] hdmi cable connected
[0009.169] edid read success
[0009.184] edid read success
[0009.187] widtDT entry for leds-pwm not found
h[0009.195] = 640, height = 480, frequency = 25174825
[0009.200] width = 640, height = 480, frequency = 25174825
[0009.205] width = 1920, height = 1200, frequency = 154000000
[0009.211] width = 1280, height = 720, frequency = 74250000
[0009.216] width = 1920, height = 540, frequency = 74250000
[0009.222] width = 720, height = 480, frequency = 27000000
[0009.227] width = 1440, height = 240, frequency = 27000000
[0009.232] width = 1920, height = 1080, frequency = 148500000
[0009.238] width = 640, height = 480, frequency = 25174825
[0009.243] width = 720, height = 480, frequency = 26973026
[0009.249] width = 720, height = 480, frequency = 26973026
[0009.254] width = 1280, height = 720, frequency = 74175824
[0009.260] width = 1920, height = 1080, frequency = 148351648
[0009.265] width = 720, height = 576, frequency = 26973026
[0009.271] width = 720, height = 576, frequency = 26973026
[0009.276] width = 1280, height = 720, frequency = 74175824
[0009.282] width = 1920, height = 1080, frequency = 148351648
[0009.287] Best mode Width = 1920, Height = 1080, freq = 148351648
[0009.295] tmds-config node not found
[0009.299] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0009.314] setting 'vdd-1v8' regulator to 1800000 micro volts
[0009.321] could not find regulator
[0009.325] could not find regulator
[0009.328] could not find regulator
[0009.356] using default cmu settings
[0009.360] dc_hdmi_enable, starting HDMI initialisation
[0009.366] dc_hdmi_enable, HDMI initialisation complete
[0009.371] list and configure display window
[0009.380] display console init completed
[0009.391] subnode volume_up is not found !
[0009.395] subnode back is not found !
[0009.398] subnode volume_down is not found !
[0009.403] subnode menu is not found !
[0009.406] Gpio keyboard init success
[0009.450] found decompressor handler: lz4-legacy
[0009.464] decompressing blob (type 1)...
[0009.500] load_bmp_blob: panelresolution=1080 type=3
[0009.550] decompressor handler not found
[0009.554] load_firmware_blob: Firmware blob loaded, entries=2
[0009.560] -------> se_aes_verify_sbk_clear: 747
[0009.564] se_aes_verify_sbk_clear: Error
[0009.568] bl_battery_charging: connected to external power supply
[0009.576] xusb is supported
[0009.582] error while finding nvidia,portmap
[0010.086] xusb blob version 0 size 124416
[0010.090] firmware size 124416
[0010.095] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0010.108] xhci0: 64 bytes context size, 32-bit DMA
[0010.148] usbus0: 5.0Gbps Super Speed USB v3.0
[0010.168] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0010.818] uhub0: 9 ports with 9 removable, self powered
[0011.818] failed to get HID devices
[0011.822] failed to init xhci or no usb device attached
[0011.832] device_query_partition_size: failed to open partition sd0:MSC !
[0011.839] MSC Partition not found
[0011.845] device_query_partition_size: failed to open partition sd0:USP !
[0011.852] USP partition read failed!
[0011.855] blob_init: blob-partition USP header read failed
[0011.861] android_boot Unable to update recovery partition
[0011.866] kfs_getpartname: name = LNX
[0011.870] Loading kernel from LNX
[0011.968] load kernel from storage
[0011.980] decompressor handler not found
[0012.037] Successfully loaded kernel and ramdisk images
[0012.043] load_bmp_blob: panelresolution=1080 type=3
[0012.540] display bmp image done
[0012.543] NCK carveout not present
[0012.546] Skipping dts_overrides
[0012.549] NCK carveout not present
[0012.559] Find /i2c@7000c000's alias i2c0
[0012.563] get eeprom at 1-a0, size 256, type 0
[0012.572] Find /i2c@7000c500's alias i2c2
[0012.576] get eeprom at 3-a0, size 256, type 0
[0012.580] get eeprom at 3-ae, size 256, type 0
[0012.585] pm_ids_update: Updating 1,a0, size 256, type 0
[0012.590] I2C slave not started
[0012.593] I2C write failed
[0012.596] Writing offset failed
[0012.599] eeprom_init: EEPROM read failed
[0012.603] pm_ids_update: eeprom init failed
[0012.607] pm_ids_update: Updating 3,a0, size 256, type 0
[0012.637] pm_ids_update: The pm board id is 3448-0000-200
[0012.644] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0012.651] pm_ids_update: pm id update successful
[0012.656] pm_ids_update: Updating 3,ae, size 256, type 0
[0012.686] pm_ids_update: The pm board id is 3449-0000-200
[0012.693] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0012.700] pm_ids_update: pm id update successful
[0012.731] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0012.737] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0012.745] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0012.751] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0012.760] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:5b:76
[0012.766] Plugin Manager: Parse ODM data 0x00084000
[0012.777] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0012.791] Add serial number:1422019085141 as DT property
[0012.800] "bpmp" doesn't exist, creating
[0012.806] Updated bpmp info to DTB
[0012.811] Updated initrd info to DTB
[0012.814] "proc-board" doesn't exist, creating
[0012.820] Updated board info to DTB
[0012.823] "pmu-board" doesn't exist, creating
[0012.829] Updated board info to DTB
[0012.832] "display-board" doesn't exist, creating
[0012.838] Updated board info to DTB
[0012.841] "reset" doesn't exist, creating
[0012.846] Updated reset info to DTB
[0012.849] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1
[0012.888] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0012.900] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0012.913] Updated bootarg info to DTB
[0012.917] Adding uuid 00000001644475c1080000000e030340 to DT
[0012.923] Adding eks info 0 to DT
[0012.928] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0012.934] Updated memory info to DTB
[0012.940] Updated system-lp0-disable info to DTB
[0012.948] set vdd_core voltage to 1075 mv
[0012.952] setting 'vdd-core' regulator to 1075000 micro volts
[0012.968] Found secure-pmc; disable BPMP
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 162 ms (3.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 288 ms (18.2 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 1533 ms (21.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831776f0
Starting kernel ...
<hit enter to activate fiq debugger>
[ 1.102985] tegradc tegradc.1: dpd enable lookup fail:-19
[ 2.284820] cgroup: cgroup2: unknown option "nsdelegate"
[ 4.013323] random: crng init done
[ 4.016758] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.042851] using random self ethernet address
[ 4.047449] using random host ethernet address
[ 5.602156] using random self ethernet address
[ 5.606840] using random host ethernet address
Ubuntu 18.04.4 LTS jay-nano ttyS0
jay-nano login:
I then went through, delimited it all in excel, and did a comparison of which lines are different. Below are the lines that were marked as different:
Good Nano:
bad nano:
Serial Number of Pmic Max77663: 0x1015c9
Tegraboot started after 53275 us
Basic modules init took 5759415 us
Next stage binary read took 1527588 us
Carveout took -1539268 us
CPU initialization took 2035945 us
Total time taken by TegraBoot 7783680 us
updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:e8:62
Add serial number:1422019048669 as DT property
wiDT entry for leds-pwm not found
Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1
Adding uuid 00000001644495081800000012060480 to DT
set vdd_core voltage to 1125 mv
setting 'vdd-core' regulator to 1125000 micro volts
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
imx219 6-0010: board setup failed
Based on this, the main differences I see are the I2c read probe fail on the bad board, and the difference in vdd-core voltage. I’m not sure what to do with this information.
