My HDMI cable is plugged in but nothing appears
Log below.
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.140] Power-up reason: pmc por
[0000.143] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.149] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.158] max77620 disabling SD1 Remote Sense
[0000.162] Setting DDR voltage to 1125mv
[0000.166] Serial Number of Pmic Max77663: 0x2e1fea
[0000.174] Entering ramdump check
[0000.177] Get RamDumpCarveOut = 0x0
[0000.180] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.185] Last reboot was clean, booting normally!
[0000.190] Sdram initialization is successful
[0000.194] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.200] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.206] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.212] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.229] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.235] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.251] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.411] Csd NumOfBlocks=124735488
[0000.417] Set High speed to 1
[0000.420] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.430] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.437] Number of retries left 4
[0000.449] Using GPT Primary to query partitions
[0000.454] Loading Tboot-CPU binary
[0000.466] Verifying TBC in OdmNonSecureSBK mode
[0000.476] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.483] Bootloader downloaded successfully.
[0000.488] Downloaded Tboot-CPU binary to 0xa0000258
[0000.493] MAX77620_GPIO5 configured
[0000.496] CPU power rail is up
[0000.499] CPU clock enabled
[0000.503] Performing RAM repair
[0000.505] Updating A64 Warmreset Address to 0xa00002e9
[0000.511] Loading NvTbootBootloaderDTB
[0000.548] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.613] Bootloader DTB Load Address: 0x83000000
[0000.618] Loading NvTbootKernelDTB
[0000.655] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.720] Kernel DTB Load Address: 0x83100000
[0000.727] Loading cboot binary
[0000.771] Verifying EBT in OdmNonSecureSBK mode
[0000.813] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.820] Bootloader downloaded successfully.
[0000.825] Next binary entry address: 0x92c00258
[0000.829] BoardId: 3448
[0000.834] Overriding pmu board id with proc board id
[0000.839] Display board id is not available
[0000.882] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.933] /bpmp deleted
[0000.936] SC7EntryFw header found loaded at 0xff700000
[0001.124] OVR2 PMIC
[0001.126] Bpmp FW successfully loaded
[0001.132] WB0 init successfully at 0xff780000
[0001.136] Set NvDecSticky Bits
[0001.140] GSC2 address ff53fffc value c0edbbcc
[0001.146] GSC MC Settings done
[0001.151] TOS Image length 53680
[0001.155] Monitor size 53680
[0001.157] OS size 0
[0001.168] Secure Os AES-CMAC Verification Success!
[0001.172] TOS image cipher info: plaintext
[0001.176] Loading and Validation of Secure OS Successful
[0001.192] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.197] NvTbootPackSdramParams: start.
[0001.202] NvTbootPackSdramParams: done.
[0001.206] Tegraboot started after 53779 us
[0001.210] Basic modules init took 809919 us
[0001.214] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.219] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.226] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.231] Storage Device Read Time = 181 ms, Read Size = 2241 KB
[0001.237] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.242] Next stage binary read took 39558 us
[0001.247] Carveout took -51220 us
[0001.250] CPU initialization took 382918 us
[0001.254] Total time taken by TegraBoot 1181175 us
[0001.259] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 16:52:46, Jul 16 2019
ERROR: Error initializing runtime service trusty_fast
[0001.381] RamCode = 0
[0001.385] LPDDR4 Training: Read DT: Number of tables = 2
[0001.390] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.403] EMC Training Successful
[0001.406] 408000 not found in DVFS table
[0001.413] RamCode = 0
[0001.416] DT Write: emc-table@204000 succeeded
[0001.422] DT Write: emc-table@1600000 succeeded
[0001.426] LPDDR4 Training: Write DT: Number of tables = 2
[0001.469]
[0001.470] Debug Init done
[0001.473] Marked DTB cacheable
[0001.476] Bootloader DTB loaded at 0x83000000
[0001.480] Marked DTB cacheable
[0001.483] Kernel DTB loaded at 0x83100000
[0001.487] DeviceTree Init done
[0001.499] Pinmux applied successfully
[0001.503] gicd_base: 0x50041000
[0001.507] gicc_base: 0x50042000
[0001.510] Interrupts Init done
[0001.514] Using base:0x60005090 & irq:208 for tick-timer
[0001.519] Using base:0x60005098 for delay-timer
[0001.524] platform_init_timer: DONE
[0001.527] Timer(tick) Init done
[0001.531] osc freq = 38400 khz
[0001.535]
[0001.536] welcome to cboot
[0001.538]
[0001.540] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.545] calling constructors
[0001.548] initializing heap
[0001.550] initializing threads
[0001.553] initializing timers
[0001.556] creating bootstrap completion thread
[0001.560] top of bootstrap2()
[0001.563] CPU: ARM Cortex A57
[0001.566] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.571] initializing platform
[0001.574] Scratch reg 37 & 271 initial value set..
[0001.580] cboot:secure-pmc present
[0001.584] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.588] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.593] Macronix QSPI chip present
[0001.596] SPI device register
[0001.599] init boot device
[0001.602] allocating memory for boot device(SPI)
[0001.606] registering boot device
[0001.616] sdmmc node status = okay
[0001.619] sdcard instance = 0
[0001.622] sdcard gpio handle 0x56
[0001.625] sdcard gpio pin 0xc9
[0001.628] sdcard gpio flags 0x0
[0001.631] vmmc-supply 0x99
[0001.633] Instance: 0
[0001.636] Allocating memory for context
[0001.639] enabling clock
[0001.642] sd card init
[0001.644] Check card present and stable
[0001.648] Send command 0
[0001.672] Send command 3
[0001.677] Set RCA for the card
[0001.680] Query card specific data by command 9
[0001.686] Parse CSD data
[0001.688] Send command 7
[0001.699] Calling sd device register
[0001.702] Init sdcard
[0001.704] Allocating memory for boot device
[0001.708] Registering user device
[0001.722] Enable APE clock
[0001.724] Un-powergate APE partition
[0001.728] of_register: registering tegra_udc to of_hal
[0001.733] of_register: registering tegra_udc to of_hal
[0001.738] of_register: registering inv20628-driver to of_hal
[0001.744] of_register: registering ads1015-driver to of_hal
[0001.749] of_register: registering lp8557-bl-driver to of_hal
[0001.755] of_register: registering bq2419x_charger to of_hal
[0001.761] of_register: registering cpc to of_hal
[0001.765] of_register: registering bq27441_fuel_gauge to of_hal
[0001.776] gpio framework initialized
[0001.780] of_register: registering tca9539_gpio to of_hal
[0001.785] of_register: registering tca9539_gpio to of_hal
[0001.791] of_register: registering i2c_bus_driver to of_hal
[0001.796] of_register: registering i2c_bus_driver to of_hal
[0001.802] of_register: registering i2c_bus_driver to of_hal
[0001.807] of_register: registering i2c_bus_driver to of_hal
[0001.813] pmic framework initialized
[0001.816] of_register: registering max77620_pmic to of_hal
[0001.822] regulator framework initialized
[0001.826] of_register: registering tps65132_bl_driver to of_hal
[0001.832] initializing target
[0001.837] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.846] fixed regulator driver initialized
[0001.863] initializing OF layer
[0001.866] NCK carveout not present
[0001.869] Skipping dts_overrides
[0001.873] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.890] I2C Bus Init done
[0001.892] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.903] I2C Bus Init done
[0001.905] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.916] I2C Bus Init done
[0001.918] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.928] I2C Bus Init done
[0001.931] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.941] I2C Bus Init done
[0001.944] of_children_init: Ops found for compatible string maxim,max77620
[0001.954] max77620_init using irq 118
[0001.959] register ‘maxim,max77620’ pmic
[0001.963] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.970] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.980] I2C Bus Init done
[0001.984] NCK carveout not present
[0001.987] shim_invoke: No NCT, Calling dts updates
[0001.998] Find /i2c@7000c000’s alias i2c0
[0002.002] get eeprom at 1-a0, size 256, type 0
[0002.011] Find /i2c@7000c500’s alias i2c2
[0002.014] get eeprom at 3-a0, size 256, type 0
[0002.019] get eeprom at 3-ae, size 256, type 0
[0002.023] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.029] I2C slave not started
[0002.032] I2C write failed
[0002.034] Writing offset failed
[0002.037] eeprom_init: EEPROM read failed
[0002.041] pm_ids_update: eeprom init failed
[0002.045] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.075] pm_ids_update: The pm board id is 3448-0000-200
[0002.082] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.090] pm_ids_update: pm id update successful
[0002.094] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.124] pm_ids_update: The pm board id is 3449-0000-200
[0002.131] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.138] pm_ids_update: pm id update successful
[0002.169] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.175] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.183] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.189] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.197] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:84:5e
[0002.204] Plugin Manager: Parse ODM data 0x00094000
[0002.214] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.235] Find /i2c@7000c000’s alias i2c0
[0002.239] get eeprom at 1-a0, size 256, type 0
[0002.247] Find /i2c@7000c500’s alias i2c2
[0002.251] get eeprom at 3-a0, size 256, type 0
[0002.256] get eeprom at 3-ae, size 256, type 0
[0002.260] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.265] I2C slave not started
[0002.268] I2C write failed
[0002.271] Writing offset failed
[0002.274] eeprom_init: EEPROM read failed
[0002.278] pm_ids_update: eeprom init failed
[0002.282] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.312] pm_ids_update: The pm board id is 3448-0000-200
[0002.319] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.326] pm_ids_update: pm id update successful
[0002.330] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.360] pm_ids_update: The pm board id is 3449-0000-200
[0002.367] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.374] pm_ids_update: pm id update successful
[0002.404] Chip UID is 00000001644475c4100000000e078240
[0002.409] Add serial number:14225190786670408207 as DT property
[0002.418] Applying platform configs
[0002.424] platform-init is not present. Skipping
[0002.429] calling apps_init()
[0002.454] Found 12 GPT partitions in “sd0”
[0002.458] Proceeding to Cold Boot
[0002.461] starting app android_boot_app
[0002.465] Device state: unlocked
[0002.468] display console init
[0002.476] could not find regulator
[0002.500] hdmi cable not connected
[0002.503] is_hdmi_needed: HDMI nDT entry for leds-pwm not found
o[0002.512] t connected, returning false
[0002.516] hdmi is not connected
[0002.519] sor0 is not supported
[0002.522] display_console_init: no valid display out_type
[0002.530] subnode volume_up is not found !
[0002.534] subnode back is not found !
[0002.538] subnode volume_down is not found !
[0002.542] subnode menu is not found !
[0002.545] Gpio keyboard init success
[0002.577] found decompressor handler: lz4-legacy
[0002.592] decompressing blob (type 1)…
[0002.625] display_resolution: No display init
[0002.629] Failed to retrieve display resolution
[0002.634] Could not load/initialize BMP blob…ignoring
[0002.674] decompressor handler not found
[0002.677] load_firmware_blob: Firmware blob loaded, entries=2
[0002.683] se_aes_verify_sbk_clear: Error
[0002.687] bl_battery_charging: connected to external power supply
[0002.694] xusb is supported
[0002.700] error while finding nvidia,portmap
[0002.706] could not find regulator
[0003.209] xusb blob version 0 size 124416
[0003.213] firmware size 124416
[0003.218] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.226] xhci0: 64 bytes context size, 32-bit DMA
[0003.266] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.286] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.936] uhub0: 9 ports with 9 removable, self powered
[0004.936] failed to get HID devices
[0004.939] failed to init xhci or no usb device attached
[0004.947] display_console_ioctl: No display init
[0004.951] switch_backlight failed
[0004.955] device_query_partition_size: failed to open partition sd0:MSC !
[0004.961] MSC Partition not found
[0004.965] device_query_partition_size: failed to open partition sd0:USP !
[0004.971] USP partition read failed!
[0004.975] blob_init: blob-partition USP header read failed
[0004.980] android_boot Unable to update recovery partition
[0004.986] kfs_getpartname: name = LNX
[0004.989] Loading kernel from LNX
[0005.046] Verifying boot image in OdmNonSecureSBK mode
[0005.090] kernel load address: 0x80080000, size: 482032 bytes
[0005.095] ramdisk load address: 0x84100000, size: 0 bytes
[0005.101] load kernel from storage
[0005.112] decompressor handler not found
[0005.169] Successfully loaded kernel and ramdisk images
[0005.176] display_resolution: No display init
[0005.180] Failed to retrieve display resolution
[0005.184] bmp blob is not loaded and initialized
[0005.189] Failed to display boot-logo
[0005.193] NCK carveout not present
[0005.196] Skipping dts_overrides
[0005.199] NCK carveout not present
[0005.202] shim_invoke: No NCT, Calling dts updates
[0005.214] Find /i2c@7000c000’s alias i2c0
[0005.217] get eeprom at 1-a0, size 256, type 0
[0005.226] Find /i2c@7000c500’s alias i2c2
[0005.230] get eeprom at 3-a0, size 256, type 0
[0005.234] get eeprom at 3-ae, size 256, type 0
[0005.239] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.244] I2C slave not started
[0005.247] I2C write failed
[0005.250] Writing offset failed
[0005.253] eeprom_init: EEPROM read failed
[0005.257] pm_ids_update: eeprom init failed
[0005.261] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.291] pm_ids_update: The pm board id is 3448-0000-200
[0005.298] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.305] pm_ids_update: pm id update successful
[0005.310] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.340] pm_ids_update: The pm board id is 3449-0000-200
[0005.346] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0005.354] pm_ids_update: pm id update successful
[0005.384] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.390] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.398] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.404] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.413] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:84:5e
[0005.419] Plugin Manager: Parse ODM data 0x00094000
[0005.429] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.444] Add serial number:14225190786670408207 as DT property
[0005.453] “bpmp” doesn’t exist, creating
[0005.459] Updated bpmp info to DTB
[0005.464] Updated initrd info to DTB
[0005.467] “proc-board” doesn’t exist, creating
[0005.473] Updated board info to DTB
[0005.476] “pmu-board” doesn’t exist, creating
[0005.481] Updated board info to DTB
[0005.485] “display-board” doesn’t exist, creating
[0005.490] Updated board info to DTB
[0005.494] “reset” doesn’t exist, creating
[0005.498] Updated reset info to DTB
[0005.501] display_console_ioctl: No display init
[0005.506] display_console_ioctl: No display init
[0005.511] display_console_ioctl: No display init
[0005.515] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000
[0005.549] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.562] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.574] Updated bootarg info to DTB
[0005.578] Adding uuid 00000001644475c4100000000e078240 to DT
[0005.584] Adding eks info 0 to DT
[0005.590] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.595] Updated memory info to DTB
[0005.601] Updated system-lp0-disable info to DTB
[0005.609] set vdd_core voltage to 1125 mv
[0005.613] setting ‘vdd-core’ regulator to 1125000 micro volts
[0005.636] could not find regulator
[0005.640] Found secure-pmc; disable BPMP
U-Boot 2016.07-gd917e08cec (Jul 16 2019 - 16:52:59 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 1  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 72 ms (9.8 KiB/s)
L4T boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
5562393 bytes read in 352 ms (15.1 MiB/s)
Retrieving file: /boot/Image
34179080 bytes read in 1540 ms (21.2 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 0000000083177282
Starting kernel …
[ 1.026896] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.538381] Host read timeout at address 545c00c4 [ 1.716227] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.723797] imx219 6-0010: board setup failed [ 2.741517] cgroup: cgroup2: unknown option "nsdelegate" [ 3.809851] using random self ethernet address [ 3.815864] using random host ethernet address [ 3.857517] using random self ethernet address [ 3.866466] using random host ethernet address [ 4.196655] random: crng init done [ 4.200063] random: 7 urandom warning(s) missed due to ratelimiting [ 7.231587] Please complete system configuration setup on /dev/ttyGS0 to proceed...
You bootloader indicates there is no HDMI cable detected. Are you using any converter?
Please use a monitor with native HDMI port to test first.
No I plug the HDMI directly in. I tried plugging the hdmi in and out for about 1 hour. It is solved now.
