Issue with HDMI output
Hello, I’m using a jetson nano module emmc with an official jetson nano carrier board: p3450-0000
The problem is that i can’t get any video output from HDMI (I can’t test displayport)
int eh early boot stage of the device i can see this (from cboot?):
[0002.654] Device state: unlocked
[0002.657] display console init
[0002.667] could not find regulator
[0002.670] hdmi cable connected
[0002.686] edid read success
[0002.698] DT entry for leds-pwm not found
[0002.706] edid read success
whenever i plug the HDMI cable in the HDMI port i receive these messages in the serial console once the control is passed to the linux kernel:
[  190.256977] tegradc tegradc.1: dp: unplug event received
[  190.262725] hpd: state 3 (Disabled), hpd 0, pending_hpd_evt 1
[  190.268871] hpd: switching from state 3 (Disabled) to state 0 (Reset)
[  190.275446] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[  190.280993] tegradc tegradc.1: dp: plug event received
[  190.286161] tegradc tegradc.1: blank - powerdown
[  190.290789] tegradc tegradc.1: dp: unplug event received
[  190.296142] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[  190.303365] Extcon DP: HPD disabled
[  190.306863] hpd: hpd_switch 0
[  190.309835] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[  190.316453] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 1
[  190.322629] hpd: switching from state 1 (Check Plug) to state 0 (Reset)
[  190.329290] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[  190.334874] tegradc tegradc.1: blank - powerdown
[  190.339518] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[  190.346809] Extcon DP: HPD disabled
[  190.350315] hpd: hpd_switch 0
[  190.353273] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[  190.360022] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[  190.366166] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
this is my bootargs
tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mapper/unox-root rw rootwait rootfstype=ext4 console=ttyS0,115200n8 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
am i doing anything wrong?
can this problem be caused by a wrong dtb being loaded? how can i check which exact dtb should i pass to u-boot?
any suggestion that can be helpful in solving this issue is very apreciated.
thank you
Try to share the full dmesg if you cannot interpret the log…
For example, you told us you are testing HDMI, but the kernel log you shared is all related to DP… I really don’t know whether what you said is correct or not.
thank you for your reply.
here is the full boot log
[0000.235] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.240] Processing in cold boot mode Bootloader 2
[0000.245] A02 Bootrom Patch rev = 1023
[0000.248] Power-up reason: pmc por
[0000.252] No Battery Present
[0000.254] pmic max77620 reset reason
[0000.258] pmic max77620 NVERC : 0x40
[0000.261] RamCode = 0
[0000.263] Platform has DDR4 type RAM
[0000.267] max77620 disabling SD1 Remote Sense
[0000.271] Setting DDR voltage to 1125mv
[0000.275] Serial Number of Pmic Max77663: 0x163f6d
[0000.282] Entering ramdump check
[0000.285] Get RamDumpCarveOut = 0x0
[0000.289] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.294] Last reboot was clean, booting normally!
[0000.298] Sdram initialization is successful
[0000.303] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.309] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.314] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.320] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.326] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.332] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.338] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.344] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.360] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.366] Platform-DebugCarveout: 0
[0000.369] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.375] BoardID = 3448, SKU = 0x2
[0000.378] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.384] Read GPT from (0:3)
[0000.399] Csd NumOfBlocks=0
[0000.411] Using GPT Primary to query partitions
[0000.415] Initialize FailControl
[0000.418] Read PT from (0:3)
[0000.453] PT crc32 and magic check passed.
[0000.457] Using BFS PT to query partitions
[0000.461] PT: Partition RP5 NOT found !
[0000.465] Warning: Find Partition via PT Failed
[0000.469] Load RPB failed, skip RPB.
[0000.473] BoardID = 3448, SKU = 0x2
[0000.476] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.482] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.489] Loading Tboot-CPU binary
[0000.495] Verifying TBC in SecurePKC mode
[0000.505] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.512] Bootloader downloaded successfully.
[0000.516] Downloaded Tboot-CPU binary to 0xa0000258
[0000.521] MAX77620_GPIO5 configured
[0000.524] CPU power rail is up
[0000.527] CPU clock enabled
[0000.531] Performing RAM repair
[0000.534] Updating A64 Warmreset Address to 0xa00002e9
[0000.539] BoardID = 3448, SKU = 0x2
[0000.542] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.548] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.554] Loading NvTbootBootloaderDTB
[0000.571] Verifying NvTbootBootloaderDTB in SecurePKC mode
[0000.638] Bootloader DTB Load Address: 0x83000000
[0000.643] BoardID = 3448, SKU = 0x2
[0000.646] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.652] Loading NvTbootKernelDTB
[0000.669] Verifying NvTbootKernelDTB in SecurePKC mode
[0000.736] Kernel DTB Load Address: 0x83100000
[0000.740] BoardID = 3448, SKU = 0x2
[0000.743] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.749] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.756] Loading cboot binary
[0000.768] Verifying EBT in SecurePKC mode
[0000.800] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.807] Bootloader downloaded successfully.
[0000.811] BoardID = 3448, SKU = 0x2
[0000.815] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.821] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.827] PT: Partition NCT NOT found !
[0000.831] Warning: Find Partition via PT Failed
[0000.835] Next binary entry address: 0x92c00258
[0000.839] BoardId: 3448
[0000.844] Overriding pmu board id with proc board id
[0000.849] Display board id is not available
[0000.853] BoardID = 3448, SKU = 0x2
[0000.856] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.862] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.876] Verifying SC7EntryFw in SecurePKC mode
[0000.966] /bpmp deleted
[0000.968] SC7EntryFw header found loaded at 0xff700000
[0001.376] OVR2 PMIC
[0001.378] Bpmp FW successfully loaded
[0001.381] BoardID = 3448, SKU = 0x2
[0001.385] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.391] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.398] WB0 init successfully at 0xff780000
[0001.402] Verifying NvTbootWb0 in SecurePKC mode
[0001.407] Set NvDecSticky Bits
[0001.411] GSC2 address ff53fffc value c0edbbcc
[0001.417] GSC MC Settings done
[0001.420] BoardID = 3448, SKU = 0x2
[0001.423] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.430] TOS Image length 53680
[0001.433]  Monitor size 53680
[0001.436]  OS size 0
[0001.442] Secure Os PKC Verification Success!
[0001.446] TOS image cipher info: plaintext
[0001.450] Loading and Validation of Secure OS Successful
[0001.466] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.471] NvTbootPackSdramParams: start.
[0001.476] NvTbootPackSdramParams: done.
[0001.480] Tegraboot started after 164598 us
[0001.484] Basic modules init took 725257 us
[0001.488] Sec Bootdevice Read Time = 54 ms, Read Size = 3682 KB
[0001.493] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.499] Next stage binary read took 7377 us
[0001.503] Validation of images took -34800 us
[0001.507] Carveout took 1 us
[0001.510] CPU initialization took 652971 us
[0001.514] Total time taken by TegraBoot 1350806 us
[0001.518] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):f9bf1e1
NOTICE:  BL31: Built : 21:16:40, Jun  8 2023
ERROR:   Error initializing runtime service trusty_fast
[0001.638] Tboot-cpu rollback check passed, continue to boot..
[0001.647] RamCode = 0
[0001.656] LPDDR4 Training: found 4 entries (2 nominal, 2 derated)
[0001.662] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.675] EMC Training Successful
[0001.678] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.690] EMC Training Successful
[0001.693] 408000 not found in DVFS table
[0001.734] RamCode = 0
[0001.739] DT Write: emc-table@204000 succeeded
[0001.747] DT Write: emc-table@1600000 succeeded
[0001.755] DT Write: emc-table-derated@204000 succeeded
[0001.764] DT Write: emc-table-derated@1600000 succeeded
[0001.769] LPDDR4 Training: Write DT: Number of tables = 4
[0001.820]
[0001.821] Debug Init done
[0001.823] Marked DTB cacheable
[0001.826] Bootloader DTB loaded at 0x83000000
[0001.831] Marked DTB cacheable
[0001.834] Kernel DTB loaded at 0x83100000
[0001.838] DeviceTree Init done
[0001.853] Pinmux applied successfully
[0001.858] gicd_base: 0x50041000
[0001.861] gicc_base: 0x50042000
[0001.864] Interrupts Init done
[0001.869] Using base:0x60005090 & irq:208 for tick-timer
[0001.874] Using base:0x60005098 for delay-timer
[0001.878] platform_init_timer: DONE
[0001.882] Timer(tick) Init done
[0001.886] osc freq = 38400 khz
[0001.890]
[0001.891] Welcome to L4T Cboot
[0001.894]
[0001.895] Cboot Version: 00.00.2018.01-t210-acb23272
[0001.900] calling constructors
[0001.903] initializing heap
[0001.906] initializing threads
[0001.909] initializing timers
[0001.911] creating bootstrap completion thread
[0001.916] top of bootstrap2()
[0001.919] CPU: ARM Cortex A57
[0001.922] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.926] initializing platform
[0001.981] Config for emmc ddr50 mode completed
[0001.985] sdmmc bdev is already initialized
[0001.989] Enable APE clock
[0001.992] Un-powergate APE partition
[0001.996] of_register: registering tegra_udc to of_hal
[0002.001] of_register: registering inv20628-driver to of_hal
[0002.006] of_register: registering ads1015-driver to of_hal
[0002.012] of_register: registering lp8557-bl-driver to of_hal
[0002.018] of_register: registering bq2419x_charger to of_hal
[0002.023] of_register: registering bq27441_fuel_gauge to of_hal
[0002.036] gpio framework initialized
[0002.039] of_register: registering tca9539_gpio to of_hal
[0002.045] of_register: registering tca9539_gpio to of_hal
[0002.050] of_register: registering i2c_bus_driver to of_hal
[0002.056] of_register: registering i2c_bus_driver to of_hal
[0002.061] of_register: registering i2c_bus_driver to of_hal
[0002.067] pmic framework initialized
[0002.070] of_register: registering max77620_pmic to of_hal
[0002.076] regulator framework initialized
[0002.080] of_register: registering tps65132_bl_driver to of_hal
[0002.086] initializing target
[0002.092] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.101] board ID = D78, board SKU = 2
[0002.108] fixed regulator driver initialized
[0002.129] initializing OF layer
[0002.132] NCK carveout not present
[0002.135] Skipping dts_overrides
[0002.139] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.158] I2C Bus Init done
[0002.161] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.172] I2C Bus Init done
[0002.175] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.186] I2C Bus Init done
[0002.188] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.199] I2C Bus Init done
[0002.202] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.213] I2C Bus Init done
[0002.216] of_children_init: Ops found for compatible string maxim,max77620
[0002.227] max77620_init using irq 118
[0002.232] register 'maxim,max77620' pmic
[0002.236] gpio_driver_register: register 'max77620-gpio' driver
[0002.242] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.253] I2C Bus Init done
[0002.257] NCK carveout not present
[0002.268] Find /i2c@7000c000's alias i2c0
[0002.272] get eeprom at 1-a0, size 256, type 0
[0002.282] Find /i2c@7000c500's alias i2c2
[0002.286] get eeprom at 3-a0, size 256, type 0
[0002.290] get eeprom at 3-ae, size 256, type 0
[0002.295] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.300] I2C slave not started
[0002.303] I2C write failed
[0002.306] Writing offset failed
[0002.309] eeprom_init: EEPROM read failed
[0002.313] pm_ids_update: eeprom init failed
[0002.317] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.347] pm_ids_update: The pm board id is 3448-0002-401
[0002.354] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0002.363] pm_ids_update: pm id update successful
[0002.367] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.373] I2C slave not started
[0002.376] I2C write failed
[0002.378] Writing offset failed
[0002.381] eeprom_init: EEPROM read failed
[0002.385] pm_ids_update: eeprom init failed
[0002.415] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.421] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.429] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.435] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.444] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:8e:e1:11
[0002.450] Plugin Manager: Parse ODM data 0x000a4000
[0002.463] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.479] Find /i2c@7000c000's alias i2c0
[0002.483] get eeprom at 1-a0, size 256, type 0
[0002.493] Find /i2c@7000c500's alias i2c2
[0002.497] get eeprom at 3-a0, size 256, type 0
[0002.501] get eeprom at 3-ae, size 256, type 0
[0002.506] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.511] I2C slave not started
[0002.514] I2C write failed
[0002.517] Writing offset failed
[0002.520] eeprom_init: EEPROM read failed
[0002.524] pm_ids_update: eeprom init failed
[0002.528] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.558] pm_ids_update: The pm board id is 3448-0002-401
[0002.564] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0002.571] pm_ids_update: pm id update successful
[0002.576] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.581] I2C slave not started
[0002.584] I2C write failed
[0002.587] Writing offset failed
[0002.590] eeprom_init: EEPROM read failed
[0002.594] pm_ids_update: eeprom init failed
[0002.624] Add serial number:1422922127158 as DT property
[0002.632] Applying platform configs
[0002.640] platform-init is not present. Skipping
[0002.644] calling apps_init()
[0002.665] Found 18 GPT partitions in "sdmmc3_user"
[0002.670] Proceeding to Cold Boot
[0002.673] starting app android_boot_app
[0002.677] Cboot RB passed, continue to boot..
[0002.681] Device state: unlocked
[0002.684] display console init
[0002.694] could not find regulator
[0002.697] hdmi cable connected
[0002.726] DT entry for leds-pwm not found
[0004.708] I2C transfer timeout
[0004.711] I2C write failed
[0004.714] Writing offset failed
[0004.717] could not read edid
[0004.722] tmds-config node not found
[0004.726] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0004.741] setting 'vdd-1v8' regulator to 1800000 micro volts
[0004.749] could not find regulator
[0004.752] could not find regulator
[0004.755] could not find regulator
[0004.784] using default cmu settings
[0004.787] dc_hdmi_enable, starting HDMI initialisation
[0004.794] dc_hdmi_enable, HDMI initialisation complete
[0004.799] list and configure display window
[0004.803] display console init completed
[0004.811] subnode volume_up is not found !
[0004.815] subnode back is not found !
[0004.819] subnode volume_down is not found !
[0004.823] subnode menu is not found !
[0004.826] Gpio keyboard init success
[0004.875] found decompressor handler: lz4-legacy
[0004.890] decompressing blob (type 1)...
[0004.956] load_bmp_blob: panelresolution=480 type=0
[0004.961] bl_battery_charging: connected to external power supply
[0004.977] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0004.985] MSC Partition not found
[0004.994] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0005.002] USP partition read failed!
[0005.005] blob_init: blob-partition USP header read failed
[0005.011] android_boot Unable to update recovery partition
[0005.016] kfs_getpartname: name = LNX
[0005.020] Loading kernel from LNX
[0005.061] Verifying boot image in SecurePKC mode
[0005.115] load kernel from storage
[0005.125] decompressor handler not found
[0005.158] Successfully loaded kernel and ramdisk images
[0005.163] board ID = D78, board SKU = 2
[0005.168] load_bmp_blob: panelresolution=480 type=0
[0005.241] display bmp image done
[0005.244] NCK carveout not present
[0005.248] Skipping dts_overrides
[0005.251] NCK carveout not present
[0005.262] Find /i2c@7000c000's alias i2c0
[0005.266] get eeprom at 1-a0, size 256, type 0
[0005.276] Find /i2c@7000c500's alias i2c2
[0005.280] get eeprom at 3-a0, size 256, type 0
[0005.284] get eeprom at 3-ae, size 256, type 0
[0005.288] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.294] I2C slave not started
[0005.297] I2C write failed
[0005.299] Writing offset failed
[0005.302] eeprom_init: EEPROM read failed
[0005.306] pm_ids_update: eeprom init failed
[0005.310] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.340] pm_ids_update: The pm board id is 3448-0002-401
[0005.348] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0005.356] pm_ids_update: pm id update successful
[0005.361] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.366] I2C slave not started
[0005.369] I2C write failed
[0005.372] Writing offset failed
[0005.375] eeprom_init: EEPROM read failed
[0005.379] pm_ids_update: eeprom init failed
[0005.409] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.415] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.423] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.429] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.437] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:8e:e1:11
[0005.444] Plugin Manager: Parse ODM data 0x000a4000
[0005.457] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0005.465] Add serial number:1422922127158 as DT property
[0005.475] "bpmp" doesn't exist, creating
[0005.481] Updated bpmp info to DTB
[0005.486] Updated initrd info to DTB
[0005.489] "proc-board" doesn't exist, creating
[0005.495] Updated board info to DTB
[0005.498] "pmu-board" doesn't exist, creating
[0005.504] Updated board info to DTB
[0005.508] "display-board" doesn't exist, creating
[0005.514] Updated board info to DTB
[0005.517] "reset" doesn't exist, creating
[0005.522] Updated reset info to DTB
[0005.525] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1
[0005.564] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0005.570] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0005.586] Updated bootarg info to DTB
[0005.590] Adding uuid 00000001643c6304140000000fff0580 to DT
[0005.596] Adding eks info 0 to DT
[0005.602] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.608] Updated memory info to DTB
[0005.617] set vdd_core voltage to 1125 mv
[0005.621] setting 'vdd-core' regulator to 1125000 micro volts
[0005.627] Found secure-pmc; disable BPMP
U-Boot 2020.04-dirty (Oct 05 2023 - 16:24:46 +0200)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM:  4 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... OK
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
starting USB...
Bus usb@7d000000: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
Bus xusb@70090000: Loading XUSB FW blob from RP4 partition ...
Firmware size 126464
Firmware timestamp: 0x644782df, Version: 50.29 release
Register HCSParams1: 9000124 NbrPorts: 9
Starting the controller
USB XHCI 1.00
scanning bus xusb@70090000 for devices... 3 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
47264714 bytes read in 4218 ms (10.7 MiB/s)
## Loading kernel from FIT Image at 96000000 ...
   Using 'conf' configuration
   Verifying Hash Integrity ... sha256,rsa2048:rsa_unox_testkey_priv+ OK
   Trying 'kernel' kernel subimage
     Description:  Linux
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x960000bc
     Data Size:    34904072 Bytes = 33.3 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x80080000
     Entry Point:  0x80080000
     Hash algo:    sha256
     Hash value:   55d4a7a21353ce3a8e6cafdac9cb08b57c2faf3d7b00ca9b2b787bea1f958a77
   Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 96000000 ...
   Trying 'initrd' ramdisk subimage
     Description:  Initrd
     Type:         RAMDisk Image
     Data Start:   0x981499b4
     Data Size:    12129819 Bytes = 11.6 MiB
     OS:           Linux
     Load Address: 0x83420000
     Entry Point:  0x83420000
     Hash algo:    sha256
     Hash value:   63b9ad6b5663b017071ed2924371c700630f0b5c837557f74b1ac61a830bc910
   Loading ramdisk from 0x981499b4 to 0x83420000
## Loading fdt from FIT Image at 96000000 ...
   Trying 'fdt' fdt subimage
     Description:  DTB
     Type:         Flat Device Tree
     Data Start:   0x98cdb0b8
     Data Size:    228719 Bytes = 223.4 KiB
     Hash algo:    sha256
     Hash value:   9f358ae6797068ecbd71ab0bbad5c0c3a463de43c07ebb1aa47fab986deb0d25
   Loading fdt from 0x98cdb0b8 to 0x83000000
   Booting using the fdt blob at 0x83000000
   Loading Kernel Image
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000083000000, end 000000008303ad6e
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
DT property /chosen/nvidia,bluetooth-mac missing in source; can't copy
DT property /chosen/nvidia,wifi-mac missing in source; can't copy
DT property /psci/nvidia,system-lp0-disable missing in source; can't copy
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.337 (rampage@Unox-VM) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #1 SMP PREEMPT Sat Oct 7 17:19:14 CEST 2023
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] Found tegra_fbmem: 00800000@92cb4000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57816 r8192 d32296 u98304
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: enabling workaround for Spectre-BHB
[    0.000000] CPU features: enabling workaround for ARM erratum 1742098
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mapper/unox-root rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29784(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3555072K/4159488K available (15422K kernel code, 2982K rwdata, 6964K rodata, 8640K init, 614K bss, 129280K reserved, 475136K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0x        (ptrval) - 0x        (ptrval)   ( 15424 KB)
[    0.000000]     .rodata : 0x        (ptrval) - 0x        (ptrval)   (  7040 KB)
[    0.000000]       .init : 0x        (ptrval) - 0x        (ptrval)   (  8640 KB)
[    0.000000]       .data : 0x        (ptrval) - 0x        (ptrval)   (  2983 KB)
[    0.000000]        .bss : 0x        (ptrval) - 0x        (ptrval)   (   615 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03fc8000   (    63 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ff200000   (  4082 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] PLL_RE already enabled. Postponing set full defaults
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.009825] Console: colour dummy device 80x25
[    0.014471] console [tty0] enabled
[    0.017982] bootconsole [uart8250] disabled
[    0.022313] kmemleak: Kernel memory leak detector disabled
[    0.022342] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.022365] pid_max: default: 32768 minimum: 301
[    0.022853] Security Framework initialized
[    0.023100] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.023113] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.024257] ftrace: allocating 47296 entries in 185 pages
[    0.212473] ASID allocator initialised with 65536 entries
[    0.239795] tegra-id: chipid=22117.
[    0.239826] tegra-id: opt_subrevision=0.
[    0.239848] Tegra Speedo/IDDQ fuse revision 4
[    0.239858] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.239869] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[    0.239880] Tegra: CPU Speedo Value 2059, SoC Speedo Value 1937, GPU Speedo Value 2047
[    0.239891] Tegra: CPU IDDQ Value 2156, SoC IDDQ Value 2264, GPU IDDQ Value 2875
[    0.239926] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[    0.239946] DTS File Name: /home/rampage/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-a02.dts
[    0.239978] DTB Build time: Oct  9 2023 16:48:58
[    0.289280] CPU1: Booted secondary processor [411fd071]
[    0.321150] CPU2: Booted secondary processor [411fd071]
[    0.353133] CPU3: Booted secondary processor [411fd071]
[    0.353228] Brought up 4 CPUs
[    0.353285] SMP: Total of 4 processors activated.
[    0.353301] CPU features: detected feature: 32-bit EL0 Support
[    0.353547] CPU: All CPU(s) started at EL2
[    0.353577] alternatives: patching kernel code
[    0.361719] devtmpfs: initialized
[    0.397968] Initilizing CustomIPI irq domain
[    0.398310] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.398355] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.408990] pinctrl core: initialized pinctrl subsystem
[    0.409689] OS set in device tree is not L4T.
[    0.410115] regulator-dummy: no parameters
[    0.410390] Initializing plugin-manager
[    0.410560] Plugin module not found
[    0.410755] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[    0.411287] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[    0.411724] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[    0.412448] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[    0.412673] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[    0.413316] node /plugin-manager/fragement@13 match with board >=3448-0002-300
[    0.416801] NET: Registered protocol family 16
[    0.418068] pstore: using zlib compression
[    0.418578] console [pstore-1] enabled
[    0.418593] pstore: Registered ramoops as persistent store backend
[    0.418610] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.433300] cpuidle: using governor menu
[    0.436406] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.438128] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.438171] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.441711] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.444028] Serial: AMBA PL011 UART driver
[    0.444525] tegra_powergate_init: DONE
[    0.444557] DTS File Name: /home/rampage/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-a02.dts
[    0.444600] DTB Build time: Oct  9 2023 16:48:58
[    0.446432] Tegra reboot handler registered.
[    0.450876] iommu: Adding device tegra-carveouts to group 0
[    0.451043] platform tegra-carveouts: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.451438] iommu: Adding device smmu_test to group 1
[    0.451501] platform smmu_test: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.452340] mc: mapped MMIO address: 0x        (ptrval) -> 0x70019000
[    0.452412] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001c000
[    0.452485] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001d000
[    0.452507] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.452540] mc-err: mcerr ops are set to t21x
[    0.463133] iommu: Adding device 70090000.xusb to group 2
[    0.463440] iommu: Adding device 70006000.serial to group 3
[    0.463530] platform 70006000.serial: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.463986] iommu: Adding device 70006040.serial to group 4
[    0.464266] iommu: Adding device 70006200.serial to group 5
[    0.464501] iommu: Adding device sound to group 6
[    0.464567] platform sound: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.465141] iommu: Adding device 7000d400.spi to group 7
[    0.465470] iommu: Adding device 7000d600.spi to group 8
[    0.465824] iommu: Adding device 50000000.host1x to group 9
[    0.466107] iommu: Adding device 54080000.vi to group 10
[    0.466498] iommu: Adding device 54600000.isp to group 11
[    0.466771] iommu: Adding device 54680000.isp to group 12
[    0.467094] iommu: Adding device tegradc.0 to group 13
[    0.467158] platform tegradc.0: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.471324] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[    0.471733] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[    0.472075] iommu: Adding device tegradc.1 to group 14
[    0.472143] platform tegradc.1: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.476310] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[    0.476717] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[    0.476975] iommu: Adding device 54340000.vic to group 15
[    0.477204] iommu: Adding device 544c0000.nvenc to group 16
[    0.477409] iommu: Adding device 54500000.tsec to group 17
[    0.477620] iommu: Adding device 54100000.tsecb to group 18
[    0.477831] iommu: Adding device 54480000.nvdec to group 19
[    0.478050] iommu: Adding device 54380000.nvjpg to group 20
[    0.479058] iommu: Adding device 546c0000.i2c to group 21
[    0.479383] iommu: Adding device 57000000.gpu to group 22
[    0.479445] platform 57000000.gpu: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.479501] platform 57000000.gpu: domain=        (ptrval) allocates as[1]=        (ptrval)
[    0.479556] platform 57000000.gpu: domain=        (ptrval) allocates as[2]=        (ptrval)
[    0.479621] platform 57000000.gpu: domain=        (ptrval) allocates as[3]=        (ptrval)
[    0.480551] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.480586] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.480613] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.480632] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.480649] tegra-pmc: ### PMC reset status reg: 0x0
[    0.533320] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.533352] tegra-pmc: Clear bootloader IO dpd settings
[    0.533383] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.533461] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.533773] iommu: Adding device 70012000.se to group 23
[    0.534362] iommu: Adding device 1003000.pcie to group 24
[    0.534425] platform 1003000.pcie: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.534862] iommu: Adding device 7000c000.i2c to group 25
[    0.535186] iommu: Adding device 7000c400.i2c to group 26
[    0.535442] iommu: Adding device 7000c500.i2c to group 27
[    0.535706] iommu: Adding device 7000c700.i2c to group 28
[    0.535972] iommu: Adding device 7000d000.i2c to group 29
[    0.536239] iommu: Adding device 7000d100.i2c to group 30
[    0.536523] iommu: Adding device sdhci-tegra.3 to group 31
[    0.536589] platform sdhci-tegra.3: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.537491] iommu: Adding device 700d0000.xudc to group 32
[    0.540679] vdd-ac-bat: 5000 mV
[    0.541100] vdd-5v0-sys: 5000 mV
[    0.541802] vdd-5v0-hdmi: 5000 mV
[    0.542235] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.542506] vdd-1v8-sys: 1800 mV
[    0.542886] vdd-fan: 5000 mV
[    0.543141] vdd-fan: supplied by vdd-5v0-sys
[    0.543382] vdd-usb-vbus: 5000 mV
[    0.543611] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.543946] vdd-usb-vbus2: 5000 mV
[    0.578011] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.580257] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.581497] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.581541] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.581922] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.589949] eventlib_kernel: keventlib is initialized, test id: 0
[    0.590317] SCSI subsystem initialized
[    0.590766] usbcore: registered new interface driver usbfs
[    0.590839] usbcore: registered new interface driver hub
[    0.590895] usbcore: registered new device driver usb
[    0.594879] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.601403] vdd-core: 600 <--> 1162 mV at 1125 mV
[    0.602464] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.605301] vdd-ddr-1v1: 1150 mV
[    0.609302] vdd-pre-reg-1v35: 1350 mV
[    0.613296] vdd-1v8: 1800 mV
[    0.617294] avdd-sys-1v2: 1200 mV
[    0.621299] vdd-pex-1v0: 1050 mV
[    0.621929] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.622463] max77620-ldo3: at 3100 mV
[    0.625300] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.625852] max77620-ldo5: at 3100 mV
[    0.629297] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[    0.633298] avdd-1v05-pll: 1050 mV
[    0.637294] avdd-io-hdmi-dp: 1050 mV
[    0.639933] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.640276] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.640580] max77620 4-003c: max77620 probe successful
[    0.643449] media: Linux media interface: v0.10
[    0.643520] Linux video capture interface: v2.00
[    0.644466] pps_core: LinuxPPS API ver. 1 registered
[    0.644489] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.644529] PTP clock support registered
[    0.647795] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.648636] Advanced Linux Sound Architecture Driver Initialized.
[    0.649336] Bluetooth: Core ver 2.22
[    0.649411] NET: Registered protocol family 31
[    0.649429] Bluetooth: HCI device and connection manager initialized
[    0.649455] Bluetooth: HCI socket layer initialized
[    0.649480] Bluetooth: L2CAP socket layer initialized
[    0.649516] Bluetooth: SCO socket layer initialized
[    0.651286] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.651323] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.651379] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.651404] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.654686] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.655961] vdd-3v3-sys: 3300 mV
[    0.656369] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.656438] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.660583] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.661047] vdd-3v3-sd: 3300 mV
[    0.661491] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.662286] avdd-io-edp-1v05: 1050 mV
[    0.662667] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.662813] vdd-usb-hub-en: 5000 mV
[    0.663176] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.664292] camchar: rtcpu character device driver loaded
[    0.665048] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[    0.666415] clocksource: Switched to clocksource arch_sys_counter
[    0.707319] VFS: Disk quotas dquot_6.6.0
[    0.707487] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.707997] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.708459] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.708506]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.708773] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.708797] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.708825] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.708877] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.708902] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.708943] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.708965] nvmap_page_pool_init: Total RAM pages: 1007552
[    0.708982] nvmap_page_pool_init: nvmap page pool size: 125944 pages (491 MB)
[    0.709151] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.709556] misc nvmap: created heap iram base 0x        (ptrval) size (252KiB)
[    0.710590] misc nvmap: created heap vpr base 0x        (ptrval) size (409600KiB)
[    0.718744] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.719229] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.719619] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.719940] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.720145] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.720426] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.720446] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.720914] NET: Registered protocol family 2
[    0.721081] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.738701] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.738940] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.739465] TCP: Hash tables configured (established 32768 bind 32768)
[    0.739632] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.739728] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.740175] NET: Registered protocol family 1
[    0.740882] RPC: Registered named UNIX socket transport module.
[    0.740913] RPC: Registered udp transport module.
[    0.740929] RPC: Registered tcp transport module.
[    0.740944] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.741209] Trying to unpack rootfs image as initramfs...
[    1.270686] Freeing initrd memory: 11844K
[    1.280405] host1x 50000000.host1x: initialized
[    1.282165] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.285478] audit: initializing netlink subsys (disabled)
[    1.285574] audit: type=2000 audit(1.119:1): initialized
[    1.286319] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.296349] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.297892] ntfs: driver 2.1.32 [Flags: R/W].
[    1.298770] 9p: Installing v9fs 9p2000 file system support
[    1.302036] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.302162] io scheduler noop registered
[    1.302869] io scheduler cfq registered (default)
[    1.305605] gic 702f9000.agic: GIC IRQ controller registered
[    1.308644] iommu: Adding device 702ef000.adsp to group 33
[    1.317682] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[    1.317849] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    1.318494] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x822840f
[    1.318524] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    1.320142] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    1.320269] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    1.320413] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    1.320624] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    1.320733] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    1.320841] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    1.320957] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    1.321063] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    1.321171] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    1.321281] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    1.327576] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    1.329287] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    1.331198] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    1.332484] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    1.332854] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    1.334143] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.334393] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[    1.334570] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    1.334993] Adding domain tsec-pd to PM domain host1x-pd
[    1.338031] tsec 54500000.tsec: initialized
[    1.339390] tsec 54100000.tsecb: initialized
[    1.340110] Adding domain nvdec-pd to PM domain host1x-pd
[    1.343337] nvdec 54480000.nvdec: initialized
[    1.344446] Adding domain vic03-pd to PM domain host1x-pd
[    1.344629] Adding domain msenc-pd to PM domain host1x-pd
[    1.344802] Adding domain nvjpg-pd to PM domain host1x-pd
[    1.348606] falcon 54340000.vic: initialized
[    1.349807] falcon 544c0000.nvenc: initialized
[    1.351176] falcon 54380000.nvjpg: initialized
[    1.355655] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=96
[    1.355726] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    1.355785] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    1.355844] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    1.355957] display board info: id 0x0, fab 0x0
[    1.356033] generic_infoframe_type: 0x87
[    1.356076] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    1.356095] tegra_cec 70015000.tegra_cec: probed
[    1.356196] tegradc tegradc.0: DT parsed successfully
[    1.356265] tegradc tegradc.0: Display dc.        (ptrval) registered with id=0
[    1.356843] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[    1.363964] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.368756] tegradc tegradc.0: probed
[    1.369599] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.371276] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.371322] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.371924] kfuse 7000fc00.kfuse: initialized
[    1.373490] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.374538] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.376097] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.376140] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.376713] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.378335] vdd-gpu: applied init 1000000uV constraint
[    1.378362] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.378923] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.383536] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.383714] No Device Node present for smmu client: serial8250 !!
[    1.383743] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.383825] iommu: Adding device serial8250 to group 35
[    1.387443] console [ttyS0] disabled
[    1.387586] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.831518] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.235957] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.378440] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    2.378445] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    2.640078] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.642095] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.748316] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.748325] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.748330] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.748335] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.748340] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.748733] iommu: Adding device 0000:00:02.0 to group 36
[    2.748853] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.749502] iommu: Adding device 0000:01:00.0 to group 37
[    2.758531] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[    2.758536] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.758546] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[    2.758568] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[    2.758587] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.758599] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.758605] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.758612] pci 0000:00:02.0:   bridge window [mem 0x20000000-0x200fffff 64bit pref]
[    2.758994] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.758998] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    3.849135] console [ttyS0] enabled
[    3.849519] Console: switching to colour frame buffer device 80x30
[    3.850651] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    3.851036] serial-tegra 70006200.serial: RX in PIO mode
[    3.851133] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    3.852148] [drm] Initialized
[    3.874281] brd: module loaded
[    3.879489] loop: module loaded
[    3.879567] tegra_profiler: version: 1.145, samples/io: 49/28
[    3.879682] tegra_profiler: auth: init
[    3.881080] THERMAL EST: found 2 subdevs
[    3.881086] THERMAL EST num_resources: 0
[    3.881092] [THERMAL EST subdev 0]
[    3.881099] [THERMAL EST subdev 1]
[    3.881552] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    3.881555] THERMAL EST: thz register success.
[    3.881737] THERMAL EST: end of probe, return err: 0
[    3.883095] sd: No Scsi addr parsed to reserve index
[    3.883135] hisi_sas: driver version v1.6
[    3.890983] tun: Universal TUN/TAP device driver, 1.6
[    3.890987] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.891956] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    3.891957] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.892009] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    3.892010] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.892053] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    3.892056] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    3.892104] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    3.892106] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    3.895084] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    3.895115] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    3.916430] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    3.916571] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:8e:e1:11 from device tree
[    3.917246] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    3.917306] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
[    3.917306]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[    3.917306]  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    3.917937] PPP generic driver version 2.4.2
[    3.918169] PPP BSD Compression module registered
[    3.918173] PPP Deflate Compression module registered
[    3.918210] PPP MPPE Compression module registered
[    3.918216] NET: Registered protocol family 24
[    3.918286] usbcore: registered new interface driver r8152
[    3.918336] usbcore: registered new interface driver asix
[    3.918441] usbcore: registered new interface driver ax88179_178a
[    3.918482] usbcore: registered new interface driver cdc_ether
[    3.918576] usbcore: registered new interface driver net1080
[    3.918615] usbcore: registered new interface driver cdc_subset
[    3.918654] usbcore: registered new interface driver zaurus
[    3.918726] usbcore: registered new interface driver cdc_ncm
[    3.918898] VFIO - User Level meta-driver version: 0.3
[    3.923693] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.923719] ehci-pci: EHCI PCI platform driver
[    3.923765] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.923776] ohci-pci: OHCI PCI platform driver
[    3.923822] ohci-platform: OHCI generic platform driver
[    3.926699] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    3.927297] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    3.928473] tegra-xusb 70090000.xusb: extcon 0:         (ptrval) id
[    3.930487] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[    3.930540] tegra-xusb 70090000.xusb: xHCI Host Controller
[    3.930567] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[    3.931326] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[    3.931401] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[    3.931615] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.931621] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.931625] usb usb1: Product: xHCI Host Controller
[    3.931629] usb usb1: Manufacturer: Linux 4.9.337 xhci-hcd
[    3.931632] usb usb1: SerialNumber: 70090000.xusb
[    3.931913] usbcore: registered new interface driver uas
[    3.931985] usbcore: registered new interface driver usb-storage
[    3.932119] usbcore: registered new interface driver usbserial
[    3.932582] hub 1-0:1.0: USB hub found
[    3.932697] hub 1-0:1.0: 5 ports detected
[    3.933333] tegra-xusb 70090000.xusb: xHCI Host Controller
[    3.933348] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[    3.933470] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.933578] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    3.933583] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.933587] usb usb2: Product: xHCI Host Controller
[    3.933590] usb usb2: Manufacturer: Linux 4.9.337 xhci-hcd
[    3.933593] usb usb2: SerialNumber: 70090000.xusb
[    3.934129] hub 2-0:1.0: USB hub found
[    3.934167] hub 2-0:1.0: 4 ports detected
[    3.935078] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[    3.935083] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[    3.936144] tegra-xudc-new 700d0000.xudc: device count: 1
[    3.937803] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    3.937813] tegra-xudc-new 700d0000.xudc: vbus state: 1
[    3.937826] tegra-xudc-new 700d0000.xudc: device mode on: 0
[    3.937839] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[    3.937860] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[    3.938613] mousedev: PS/2 mouse device common for all mice
[    3.938736] usbcore: registered new interface driver xpad
[    3.958515] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[    4.054816] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    4.057354] rtc rtc1: alarm rtc device
[    4.057374] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    4.057407] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    4.058029] i2c /dev entries driver
[    4.059999] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[    4.083325] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    4.083393] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[    4.083523] imx219 6-0010: board setup failed
[    4.083594] imx219: probe of 6-0010 failed with error -121
[    4.084926] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    4.088021] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    4.088026] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    4.088496] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.088513] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    4.088522] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    4.088652] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.088662] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    4.088668] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    4.088819] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.088830] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    4.088835] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    4.089010] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    4.089866] tegra_aotag tegra-aotag: Registering sensor 0
[    4.089926] tegra_aotag tegra-aotag: Invalid temp readout
[    4.089952] tegra_aotag tegra-aotag: Invalid temp readout
[    4.089968] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    4.089976] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    4.091132] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.091153] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    4.091349] tegra_aotag tegra-aotag: Invalid temp readout
[    4.091381] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    4.091878] parse_throttle_dt_data: Num cap clks = 6
[    4.091884] parse_throttle_dt_data: clk=cclk_g type=2
[    4.091897] parse_throttle_dt_data: clk=gpu type=4
[    4.091926] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    4.091947] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    4.091969] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    4.091972] parse_throttle_dt_data: clk=emc type=3
[    4.092419] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.092565] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.092728] tegra_throttle_probe: probe successful. #cdevs=4
[    4.093593] FAN dev name: pwm-fan
[    4.093681] FAN:gpio request success.
[    4.093744] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    4.094111] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    4.094295] pwm_fan_driver pwm-fan: fan tach request irq success
[    4.094305] pwm_fan_driver pwm-fan: tach period: 1000
[    4.094438] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    4.094443] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    4.094447] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    4.094451] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    4.094455] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    4.094458] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    4.094462] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    4.094466] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    4.094469] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    4.094473] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    4.097381] device-mapper: uevent: version 1.0.3
[    4.097854] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    4.103229] tegra210-cpufreq cpufreq: probe()...completed
[    4.103936] sdhci: Secure Digital Host Controller Interface driver
[    4.103938] sdhci: Copyright(c) Pierre Ossman
[    4.103939] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.104290] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[    4.110757] tegra-se 70012000.se: tegra_se_probe: complete
[    4.111274] hidraw: raw HID events driver (C) Jiri Kosina
[    4.112403] usbcore: registered new interface driver usbhid
[    4.112405] usbhid: USB HID core driver
[    4.113834] ashmem: initialized
[    4.114819] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    4.115042] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    4.121589] nvpmodel: initialized successfully
[    4.122811] usbcore: registered new interface driver snd-usb-audio
[    4.122867] No Device Node present for smmu client: snd-soc-dummy !!
[    4.122871] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    4.122889] iommu: Adding device snd-soc-dummy to group 38
[    4.128454] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    4.147738] OPE platform probe
[    4.147825] OPE platform probe successful
[    4.148098] OPE platform probe
[    4.148178] OPE platform probe successful
[    4.150438] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[    4.172659] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    4.172791] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    4.172917] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    4.173037] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    4.173160] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    4.173281] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    4.173404] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    4.173526] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    4.173646] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    4.173768] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    4.185344] u32 classifier
[    4.185346]     Actions configured
[    4.185416] Initializing XFRM netlink socket
[    4.186148] NET: Registered protocol family 10
[    4.186938] NET: Registered protocol family 17
[    4.186948] NET: Registered protocol family 15
[    4.187030] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.187074] Bluetooth: RFCOMM socket layer initialized
[    4.187082] Bluetooth: RFCOMM ver 1.11
[    4.187086] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.187090] Bluetooth: HIDP socket layer initialized
[    4.187108] 9pnet: Installing 9P2000 support
[    4.187159] Key type dns_resolver registered
[    4.192988] Registered cp15_barrier emulation handler
[    4.192996] Registered setend emulation handler
[    4.194158] registered taskstats version 1
[    4.194827] Adding domain ve2-pd to PM domain host1x-pd
[    4.195062] Adding domain ve-pd to PM domain host1x-pd
[    4.206422] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    4.206867] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    4.207241] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    4.211375] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    4.215497] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    4.219662] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    4.222314]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[    4.246722] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[    4.246725] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.246728] usb 1-2: Product: 4-Port USB 2.1 Hub
[    4.246730] usb 1-2: Manufacturer: Generic
[    4.247890] hub 1-2:1.0: USB hub found
[    4.249019] hub 1-2:1.0: 4 ports detected
[    4.347218] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[    4.382582] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[    4.382585] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.382588] usb 2-1: Product: 4-Port USB 3.1 Hub
[    4.382590] usb 2-1: Manufacturer: Generic
[    4.386554] hub 2-1:1.0: USB hub found
[    4.387979] hub 2-1:1.0: 4 ports detected
[    4.542422] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[    4.550420] usb 2-1: usb_suspend_both: status 0
[    4.550540] usb usb2: usb_suspend_both: status 0
[    4.564962] usb 1-2.1: New USB device found, idVendor=13fe, idProduct=1d00
[    4.564966] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.564968] usb 1-2.1: Product: DataTraveler 2.0
[    4.564971] usb 1-2.1: Manufacturer: Kingston
[    4.564973] usb 1-2.1: SerialNumber: 5B6A16880D0B
[    4.565752] usb-storage 1-2.1:1.0: USB Mass Storage device detected
[    4.565892] scsi host0: usb-storage 1-2.1:1.0
[    5.268000] tegradc tegradc.0: fb registered
[    5.277114] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[    5.284355] tegradc tegradc.0: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[    5.292503] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[    5.299645] tegradc tegradc.0: hdmi: BL set VIC 0
[    5.304347] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[    5.571512] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 0 CCS
[    5.580694] sd 0:0:0:0: [sda] 1953792 512-byte logical blocks: (1.00 GB/954 MiB)
[    5.588358] sd 0:0:0:0: [sda] Write Protect is off
[    5.593310] sd 0:0:0:0: [sda] No Caching mode page found
[    5.598626] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    5.612346]  sda: sda1
[    5.615946] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   15.490465] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[   15.496912] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   15.503611] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x2c00
[   15.508661] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   15.515362] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[   15.520932] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   15.526762] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[   15.531987] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[   15.537322] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   15.543867] extcon-disp-state extcon:disp-state: cable 47 state 1
[   15.549962] Extcon AUX1(HDMI) enable
[   15.553982] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[   15.560381] tegradc tegradc.1: No lt-data, using default setting
[   15.566412] tegradc tegradc.1: No hpd-gpio in DT
[   15.566486] edid invalid
[   15.573569] tegradc tegradc.1: DT parsed successfully
[   15.578634] tegradc tegradc.1: Display dc.        (ptrval) registered with id=1
[   15.586680] tegradc tegradc.1: dpd enable lookup fail:-19
[   15.592734] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[   15.596318] tegradc tegradc.1: probed
[   15.606225] tegradc tegradc.1: fb registered
[   15.614256] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   15.622053] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   15.629847] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   15.637643] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   15.643909] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[   15.657020] tegradc tegradc.1: nominal-pclk:25200000 parent:25200000 div:1.0 pclk:25200000 24948000~27468000
[   15.670618] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   15.678419] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   15.686210] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   15.693999] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   15.700267] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[   15.709162] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   15.716952] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   15.724743] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   15.732536] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   15.738801] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[   15.747693] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   15.755484] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   15.763277] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   15.771068] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   15.777333] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[   15.786226] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   15.794016] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   15.801805] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   15.809594] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   15.815859] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[   15.824115] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[   15.831928] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[   15.839066] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[   15.840393] isp 54600000.isp: initialized
[   15.841267] isp 54680000.isp: initialized
[   15.851560] last reset is due to power on reset
[   15.851563] KERNEL: PMC reset status reg: 0x0
[   15.851624] BL: PMC reset status reg: 0x0
[   15.851626] BL: PMIC poweroff Event Recorder: 0x40
[   15.853078] clk_cbus_recalc_rate: no gbus parent
[   15.853082] clk_cbus_round_rate: no gbus parent
[   15.853084] clk_cbus_round_rate: no gbus parent
[   15.853090] clk_cbus_recalc_rate: no gbus parent
[   15.853199] clk_cbus_recalc_rate: no gbus parent
[   15.853201] clk_cbus_round_rate: no gbus parent
[   15.853203] clk_cbus_round_rate: no gbus parent
[   15.853206] clk_cbus_recalc_rate: no gbus parent
[   15.853218] tegra_dvfs: GPU-cap: registered
[   15.853277] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[   15.853279] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[   15.853281] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[   15.900755] tegra_dvfs: vdd-gpu-vts: registered
[   15.931451] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[   15.932070] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[   15.932593] input: gpio-keys as /devices/gpio-keys/input/input1
[   15.975164] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:32 UTC (946688432)
[   15.985066] vi 54080000.vi: vi_probe: ++
[   15.992426] vi 54080000.vi: initialized
[   15.998193] vi 54080000.vi: subdev nvcsi--1 bound
[   16.003120] mmcblk mmc0:0001: Card claimed for testing.
[   16.008910] Disable partitions left on by BL
[   16.013191]   disb
[   16.015248] bwmgr: missing cdev-type property
[   16.019694] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[   16.028998] DRAM derating cdev registered.
[   16.034033] ALSA device list:
[   16.037010]   #0: tegra-hda at 0x70038000 irq 82
[   16.041630]   #1: tegra-snd-t210ref-mobile-rt565x
[   16.049689] Freeing unused kernel memory: 8640K
[   16.074478] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[   16.080414] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[   16.094468] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[   16.101048] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   16.108860] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   16.116667] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   16.124472] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   16.130739] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[   16.139642] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   16.147447] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   16.155253] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   16.163058] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   16.169324] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[   16.178225] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   16.186030] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   16.193827] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   16.201637] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   16.207904] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[   16.216806] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[   16.224609] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[   16.232412] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[   16.240214] tegradc tegradc.1: dp: aux write got error (0x10000100)
[   16.246482] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[   16.254752] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[   16.262488] hpd: edid read prepare failed[   16.266314] hpd: DC from connected to disconnected
[   17.282781] tegradc tegradc.1: blank - powerdown
[   17.287414] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[   17.294635] Extcon DP: HPD disabled
[   17.298114] hpd: hpd_switch 0
[   17.301083] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[   25.730473] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[   25.736917] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   25.743614] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x2c00
[   25.748664] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   25.755361] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[   25.760930] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   25.766759] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[   25.771981] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[   25.777315] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   31.196845] device-mapper: crypt: xts(aes) using implementation "xts-aes-ce"
[   31.213143] random: vgscan: uninitialized urandom read (4 bytes read)
[   31.330876] random: vgchange: uninitialized urandom read (4 bytes read)
[   31.431867] EXT4-fs (dm-1): couldn't mount as ext3 due to feature incompatibilities
[   31.439888] EXT4-fs (dm-1): couldn't mount as ext2 due to feature incompatibilities
[   31.451943] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   31.594314] systemd[1]: System time before build time, advancing clock.
[   31.616598] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
[   31.625482] cgroup: cgroup2: unknown option "nsdelegate"
[   31.637863] systemd[1]: systemd 252.5-2~bpo11+1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   31.670460] systemd[1]: Detected architecture arm64.
[   31.676047] systemd[1]: Warning! Reported kernel version 4.9.337 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
[   31.691488] systemd[1]: Hostname set to <digitalid>.
[   31.702511] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[   31.864061] systemd[1]: /etc/systemd/system/nvs-service.service:38: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   31.942626] systemd[1]: /lib/systemd/system/systemd-random-seed.service:16: Failed to add dependency on systemd-tmpfiles-setup, ignoring: Invalid argument
[   31.956491] systemd[1]: /lib/systemd/system/systemd-random-seed.service:17: Failed to add dependency on systemd-tmpfiles-setup, ignoring: Invalid argument
[   32.018887] systemd[1]: Queued start job for default target graphical.target.
[   32.029575] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[   32.037839] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   32.046597] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[   32.055976] systemd[1]: Created slice user.slice - User and Session Slice.
[   32.063153] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[   32.074498] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   32.087065] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   32.099781] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[   32.107604] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   32.116639] systemd[1]: Reached target paths.target - Path Units.
[   32.122872] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[   32.130224] systemd[1]: Reached target slices.target - Slice Units.
[   32.136632] systemd[1]: Reached target swap.target - Swaps.
[   32.142343] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   32.152462] systemd[1]: Listening on syslog.socket - Syslog Socket.
[   32.159042] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   32.168273] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[   32.176909] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   32.186184] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   32.195677] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   32.204186] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   32.214021] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   32.223453] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   32.233488] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   32.243358] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   32.253765] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   32.262437] systemd[1]: kmod-static-nodes.service - Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/4.9.337/modules.devname).
[   32.282146] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   32.293450] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   32.303653] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   32.314755] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   32.323172] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   32.336057] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   32.346318] systemd[1]: Starting systemd-journald.service - Journal Service...
[   32.357032] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   32.367243] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   32.376755] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   32.390573] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   32.403005] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   32.410796] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   32.419067] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   32.427156] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   32.435947] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   32.443403] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   32.452909] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   32.459781] EXT4-fs (dm-1): re-mounted. Opts: (null)
[   32.511573] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   32.518643] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   32.527871] systemd-journald[2004]: Data hash table of /run/log/journal/f2c947244d9b48428e296d4e6952a0fc/system.journal has a fill level at 75.1 (1537 of 2047 items, 1048576 file size, 682 bytes per hash table item), suggesting rotation.
[   32.528411] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   32.528758] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   32.565200] systemd-journald[2004]: /run/log/journal/f2c947244d9b48428e296d4e6952a0fc/system.journal: Journal header limits reached or header out-of-date, rotating.
[   32.611316] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   32.618438] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   32.646711] systemd[1]: Started systemd-journald.service - Journal Service.
[   32.741331] systemd-journald[2004]: Received client request to flush runtime journal.
[   32.958987] random: mktemp: uninitialized urandom read (6 bytes read)
[   32.990452] random: ckbcomp: uninitialized urandom read (4 bytes read)
[   33.157409] proc: unrecognized mount option "hidepid=invisible" or missing value
[   33.378428] random: crng init done
[   34.836837] proc: unrecognized mount option "hidepid=invisible" or missing value
[   35.077542] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   35.104085] eth0: 0xffffff800a44c000, 48:b0:2d:8e:e1:11, IRQ 405
[   35.217303] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   35.970883] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[   35.978384] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   35.988107] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x2c00
[   35.993250] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   36.000070] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[   36.005716] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   36.011575] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[   36.016812] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[   36.022156] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   46.210903] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[   46.212830] vdd-fan: disabling
[   46.212855] vdd-usb-vbus: disabling
[   46.212874] vdd-usb-vbus2: disabling
[   46.212939] vddio-sdmmc-ap: disabling
[   46.217951] vddio-sdmmc3-ap: disabling
[   46.221119] vdd-3v3-sd: disabling
[   46.221136] avdd-io-edp-1v05: disabling
[   46.221146] vdd-usb-hub-en: disabling
[   46.246386] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   46.253092] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x2c00
[   46.258152] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   46.264929] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[   46.270522] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   46.276421] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[   46.281654] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[   46.287000] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   56.450738] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[   56.457529] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   56.467295] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x2c00
[   56.472561] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   56.479364] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[   56.484967] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   56.490809] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[   56.496045] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[   56.501389] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   66.690879] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[   66.697682] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   66.704636] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x2c00
[   66.709807] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   66.716625] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[   66.722265] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   66.728201] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[   66.733463] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[   66.738817] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[   76.930876] tegra-i2c 7000c700.i2c: rx dma timeout txlen:28 rxlen:128
[   76.937677] tegra-i2c 7000c700.i2c: --- register dump for debugging ----
[   76.944616] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x2c00
[   76.949729] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[   76.956578] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0x1c
[   76.962206] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[   76.968135] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x6c
[   76.973394] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x2
[   76.978739] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
Could you try to flash your whole device back to default jetpack image first to confirm the hardware is fine?
It looks like currently both kernel and dtb are customized one by you. The DP error log seems abnormal.
I would suggest a full flash first.
If you don’t want to flash default image, at least check if “lsmod” command on your jetson is empty or not.
This is the default jetpack build flashed on the board.
I still get no video output from HDMI.
I’ve also tried swapping hdmi cable and display, i still get no output.
the problem is not that X doesn’t display anything, it’s that i don’t get ANY output on screen, not even framebuffer startup logs/messages/anything.
EDIT: also tried displayport, no signal over there too.
[0000.205] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.211] Processing in cold boot mode Bootloader 2
[0000.215] A02 Bootrom Patch rev = 1023
[0000.219] Power-up reason: software reset
[0000.222] No Battery Present
[0000.225] pmic max77620 reset reason
[0000.228] pmic max77620 NVERC : 0x0
[0000.232] RamCode = 0
[0000.234] Platform has DDR4 type RAM
[0000.237] max77620 disabling SD1 Remote Sense
[0000.242] Setting DDR voltage to 1125mv
[0000.246] Serial Number of Pmic Max77663: 0x163f6d
[0000.253] Entering ramdump check
[0000.256] Get RamDumpCarveOut = 0x0
[0000.259] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.265] Last reboot was clean, booting normally!
[0000.269] Sdram initialization is successful
[0000.273] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.279] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.285] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.291] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.297] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.303] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.309] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.314] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.331] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.337] Platform-DebugCarveout: 0
[0000.340] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.346] BoardID = 3448, SKU = 0x2
[0000.349] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.355] Read GPT from (0:3)
[0000.370] Csd NumOfBlocks=0
[0000.381] Using GPT Primary to query partitions
[0000.386] Initialize FailControl
[0000.389] Read PT from (0:3)
[0000.424] PT crc32 and magic check passed.
[0000.428] Using BFS PT to query partitions
[0000.432] PT: Partition RP5 NOT found !
[0000.436] Warning: Find Partition via PT Failed
[0000.440] Load RPB failed, skip RPB.
[0000.444] *** Booting BFS0.
[0000.446] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.453] PT: Partition LNX NOT found !
[0000.456] *** Booting KFS0.
[0000.459] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.465] BoardID = 3448, SKU = 0x2
[0000.468] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.474] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.481] Loading Tboot-CPU binary
[0000.487] Verifying TBC in SecurePKC mode
[0000.497] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.504] Bootloader downloaded successfully.
[0000.508] Downloaded Tboot-CPU binary to 0xa0000258
[0000.513] MAX77620_GPIO5 configured
[0000.516] CPU power rail is up
[0000.519] CPU clock enabled
[0000.523] Performing RAM repair
[0000.526] Updating A64 Warmreset Address to 0xa00002e9
[0000.531] BoardID = 3448, SKU = 0x2
[0000.534] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.540] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.546] Loading NvTbootBootloaderDTB
[0000.563] Verifying NvTbootBootloaderDTB in SecurePKC mode
[0000.631] Bootloader DTB Load Address: 0x83000000
[0000.635] BoardID = 3448, SKU = 0x2
[0000.638] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.644] Loading NvTbootKernelDTB
[0000.662] Verifying NvTbootKernelDTB in SecurePKC mode
[0000.728] Kernel DTB Load Address: 0x83100000
[0000.733] BoardID = 3448, SKU = 0x2
[0000.736] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.742] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.749] Loading cboot binary
[0000.760] Verifying EBT in SecurePKC mode
[0000.793] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.800] Bootloader downloaded successfully.
[0000.804] BoardID = 3448, SKU = 0x2
[0000.807] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.813] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.819] PT: Partition NCT NOT found !
[0000.823] Warning: Find Partition via PT Failed
[0000.827] Next binary entry address: 0x92c00258
[0000.832] BoardId: 3448
[0000.836] Overriding pmu board id with proc board id
[0000.841] Display board id is not available
[0000.845] BoardID = 3448, SKU = 0x2
[0000.849] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.855] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.868] Verifying SC7EntryFw in SecurePKC mode
[0000.958] /bpmp deleted
[0000.960] SC7EntryFw header found loaded at 0xff700000
[0001.368] OVR2 PMIC
[0001.370] Bpmp FW successfully loaded
[0001.374] BoardID = 3448, SKU = 0x2
[0001.377] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.383] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.390] WB0 init successfully at 0xff780000
[0001.394] Verifying NvTbootWb0 in SecurePKC mode
[0001.400] Set NvDecSticky Bits
[0001.403] GSC2 address ff53fffc value c0edbbcc
[0001.410] GSC MC Settings done
[0001.412] BoardID = 3448, SKU = 0x2
[0001.416] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.423] TOS Image length 53680
[0001.426]  Monitor size 53680
[0001.428]  OS size 0
[0001.435] Secure Os PKC Verification Success!
[0001.439] TOS image cipher info: plaintext
[0001.443] Loading and Validation of Secure OS Successful
[0001.458] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.463] NvTbootPackSdramParams: start.
[0001.468] NvTbootPackSdramParams: done.
[0001.472] Tegraboot started after 134151 us
[0001.476] Basic modules init took 747870 us
[0001.480] Sec Bootdevice Read Time = 55 ms, Read Size = 3682 KB
[0001.486] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.491] Next stage binary read took 7381 us
[0001.495] Validation of images took -34804 us
[0001.500] Carveout took 1 us
[0001.502] CPU initialization took 653103 us
[0001.506] Total time taken by TegraBoot 1373551 us
[0001.511] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):f9bf1e1
NOTICE:  BL31: Built : 21:16:40, Jun  8 2023
ERROR:   Error initializing runtime service trusty_fast
[0001.630] Tboot-cpu rollback check passed, continue to boot..
[0001.639] RamCode = 0
[0001.649] LPDDR4 Training: found 4 entries (2 nominal, 2 derated)
[0001.654] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.667] EMC Training Successful
[0001.670] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.683] EMC Training Successful
[0001.686] 408000 not found in DVFS table
[0001.726] RamCode = 0
[0001.732] DT Write: emc-table@204000 succeeded
[0001.740] DT Write: emc-table@1600000 succeeded
[0001.748] DT Write: emc-table-derated@204000 succeeded
[0001.756] DT Write: emc-table-derated@1600000 succeeded
[0001.761] LPDDR4 Training: Write DT: Number of tables = 4
[0001.812]
[0001.813] Debug Init done
[0001.816] Marked DTB cacheable
[0001.819] Bootloader DTB loaded at 0x83000000
[0001.823] Marked DTB cacheable
[0001.826] Kernel DTB loaded at 0x83100000
[0001.830] DeviceTree Init done
[0001.845] Pinmux applied successfully
[0001.850] gicd_base: 0x50041000
[0001.853] gicc_base: 0x50042000
[0001.856] Interrupts Init done
[0001.861] Using base:0x60005090 & irq:208 for tick-timer
[0001.866] Using base:0x60005098 for delay-timer
[0001.871] platform_init_timer: DONE
[0001.874] Timer(tick) Init done
[0001.878] osc freq = 38400 khz
[0001.882]
[0001.883] Welcome to L4T Cboot
[0001.886]
[0001.887] Cboot Version: 00.00.2018.01-t210-acb23272
[0001.892] calling constructors
[0001.895] initializing heap
[0001.898] initializing threads
[0001.901] initializing timers
[0001.904] creating bootstrap completion thread
[0001.908] top of bootstrap2()
[0001.911] CPU: ARM Cortex A57
[0001.914] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.919] initializing platform
[0001.973] Config for emmc ddr50 mode completed
[0001.978] sdmmc bdev is already initialized
[0001.982] Enable APE clock
[0001.984] Un-powergate APE partition
[0001.988] of_register: registering tegra_udc to of_hal
[0001.993] of_register: registering inv20628-driver to of_hal
[0001.999] of_register: registering ads1015-driver to of_hal
[0002.004] of_register: registering lp8557-bl-driver to of_hal
[0002.010] of_register: registering bq2419x_charger to of_hal
[0002.015] of_register: registering bq27441_fuel_gauge to of_hal
[0002.028] gpio framework initialized
[0002.032] of_register: registering tca9539_gpio to of_hal
[0002.037] of_register: registering tca9539_gpio to of_hal
[0002.042] of_register: registering i2c_bus_driver to of_hal
[0002.048] of_register: registering i2c_bus_driver to of_hal
[0002.054] of_register: registering i2c_bus_driver to of_hal
[0002.059] pmic framework initialized
[0002.063] of_register: registering max77620_pmic to of_hal
[0002.068] regulator framework initialized
[0002.072] of_register: registering tps65132_bl_driver to of_hal
[0002.078] initializing target
[0002.084] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.093] board ID = D78, board SKU = 2
[0002.100] fixed regulator driver initialized
[0002.121] initializing OF layer
[0002.124] NCK carveout not present
[0002.127] Skipping dts_overrides
[0002.132] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.151] I2C Bus Init done
[0002.153] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.164] I2C Bus Init done
[0002.167] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.178] I2C Bus Init done
[0002.180] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.192] I2C Bus Init done
[0002.194] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.205] I2C Bus Init done
[0002.208] of_children_init: Ops found for compatible string maxim,max77620
[0002.219] max77620_init using irq 118
[0002.224] register 'maxim,max77620' pmic
[0002.228] gpio_driver_register: register 'max77620-gpio' driver
[0002.235] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.246] I2C Bus Init done
[0002.250] NCK carveout not present
[0002.261] Find /i2c@7000c000's alias i2c0
[0002.265] get eeprom at 1-a0, size 256, type 0
[0002.274] Find /i2c@7000c500's alias i2c2
[0002.278] get eeprom at 3-a0, size 256, type 0
[0002.283] get eeprom at 3-ae, size 256, type 0
[0002.287] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.292] I2C slave not started
[0002.295] I2C write failed
[0002.298] Writing offset failed
[0002.301] eeprom_init: EEPROM read failed
[0002.305] pm_ids_update: eeprom init failed
[0002.309] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.339] pm_ids_update: The pm board id is 3448-0002-401
[0002.346] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0002.355] pm_ids_update: pm id update successful
[0002.359] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.365] I2C slave not started
[0002.368] I2C write failed
[0002.370] Writing offset failed
[0002.373] eeprom_init: EEPROM read failed
[0002.377] pm_ids_update: eeprom init failed
[0002.407] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.413] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.422] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.427] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.436] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:8e:e1:11
[0002.442] Plugin Manager: Parse ODM data 0x000a4000
[0002.455] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.471] Find /i2c@7000c000's alias i2c0
[0002.475] get eeprom at 1-a0, size 256, type 0
[0002.485] Find /i2c@7000c500's alias i2c2
[0002.489] get eeprom at 3-a0, size 256, type 0
[0002.494] get eeprom at 3-ae, size 256, type 0
[0002.498] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.503] I2C slave not started
[0002.506] I2C write failed
[0002.509] Writing offset failed
[0002.512] eeprom_init: EEPROM read failed
[0002.516] pm_ids_update: eeprom init failed
[0002.520] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.550] pm_ids_update: The pm board id is 3448-0002-401
[0002.557] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0002.563] pm_ids_update: pm id update successful
[0002.568] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.573] I2C slave not started
[0002.576] I2C write failed
[0002.579] Writing offset failed
[0002.582] eeprom_init: EEPROM read failed
[0002.586] pm_ids_update: eeprom init failed
[0002.616] Add serial number:1422922127158 as DT property
[0002.624] Applying platform configs
[0002.632] platform-init is not present. Skipping
[0002.636] calling apps_init()
[0002.657] Found 17 GPT partitions in "sdmmc3_user"
[0002.662] Proceeding to Cold Boot
[0002.665] starting app android_boot_app
[0002.669] Cboot RB passed, continue to boot..
[0002.673] Device state: unlocked
[0002.677] display console init
[0002.686] could not find regulator
[0002.690] hdmi cable connected
[0002.693] I2C slave not started
[0002.696] I2C write failed
[0002.698] Writing offset failed
[0002.701] could not read edid
[0002.706] tmds-config node not found
[0002.711] pmc_set_io_pad_voltage: EDT entry for leds-pwm not found
r[0002.721] ror -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.733] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.741] could not find regulator
[0002.744] could not find regulator
[0002.747] could not find regulator
[0002.776] using default cmu settings
[0002.780] dc_hdmi_enable, starting HDMI initialisation
[0002.786] dc_hdmi_enable, HDMI initialisation complete
[0002.791] list and configure display window
[0002.796] display console init completed
[0002.803] subnode volume_up is not found !
[0002.807] subnode back is not found !
[0002.811] subnode volume_down is not found !
[0002.815] subnode menu is not found !
[0002.819] Gpio keyboard init success
[0002.868] found decompressor handler: lz4-legacy
[0002.882] decompressing blob (type 1)...
[0002.949] load_bmp_blob: panelresolution=480 type=0
[0002.953] bl_battery_charging: connected to external power supply
[0002.970] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0002.977] MSC Partition not found
[0002.987] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0002.994] USP partition read failed!
[0002.998] blob_init: blob-partition USP header read failed
[0003.003] android_boot Unable to update recovery partition
[0003.009] kfs_getpartname: name = LNX
[0003.012] Loading kernel from LNX
[0003.054] Verifying boot image in SecurePKC mode
[0003.105] load kernel from storage
[0003.114] decompressor handler not found
[0003.150] Successfully loaded kernel and ramdisk images
[0003.155] board ID = D78, board SKU = 2
[0003.160] load_bmp_blob: panelresolution=480 type=0
[0003.233] display bmp image done
[0003.237] NCK carveout not present
[0003.240] Skipping dts_overrides
[0003.243] NCK carveout not present
[0003.254] Find /i2c@7000c000's alias i2c0
[0003.258] get eeprom at 1-a0, size 256, type 0
[0003.268] Find /i2c@7000c500's alias i2c2
[0003.272] get eeprom at 3-a0, size 256, type 0
[0003.276] get eeprom at 3-ae, size 256, type 0
[0003.281] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.286] I2C slave not started
[0003.289] I2C write failed
[0003.292] Writing offset failed
[0003.295] eeprom_init: EEPROM read failed
[0003.299] pm_ids_update: eeprom init failed
[0003.303] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.333] pm_ids_update: The pm board id is 3448-0002-401
[0003.340] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[0003.348] pm_ids_update: pm id update successful
[0003.353] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.358] I2C slave not started
[0003.361] I2C write failed
[0003.364] Writing offset failed
[0003.367] eeprom_init: EEPROM read failed
[0003.371] pm_ids_update: eeprom init failed
[0003.401] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.407] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.415] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.421] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.430] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:8e:e1:11
[0003.436] Plugin Manager: Parse ODM data 0x000a4000
[0003.449] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.457] Add serial number:1422922127158 as DT property
[0003.467] "bpmp" doesn't exist, creating
[0003.473] Updated bpmp info to DTB
[0003.478] Updated initrd info to DTB
[0003.481] "proc-board" doesn't exist, creating
[0003.487] Updated board info to DTB
[0003.491] "pmu-board" doesn't exist, creating
[0003.497] Updated board info to DTB
[0003.500] "display-board" doesn't exist, creating
[0003.506] Updated board info to DTB
[0003.509] "reset" doesn't exist, creating
[0003.514] Updated reset info to DTB
[0003.517] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1
[0003.557] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.562] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0003.579] Updated bootarg info to DTB
[0003.582] Adding uuid 00000001643c6304140000000fff0580 to DT
[0003.588] Adding eks info 0 to DT
[0003.594] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.600] Updated memory info to DTB
[0003.609] set vdd_core voltage to 1125 mv
[0003.613] setting 'vdd-core' regulator to 1125000 micro volts
[0003.619] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Jun 08 2023 - 21:16:44 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM:  4 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
879 bytes read in 28 ms (30.3 KiB/s)
1:      primary kernel
Retrieving file: /boot/initrd
7159654 bytes read in 176 ms (38.8 MiB/s)
Retrieving file: /boot/Image
34707464 bytes read in 786 ms (42.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=83410000 size=10000)
ERROR: reserving fdt memory region failed (addr=83400000 size=10000)
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000083100000, end 000000008317dfff
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5434-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 8 21:19:14 PDT 2023
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] Found tegra_fbmem: 00140000@92cb4000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    1.158030] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.189706] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.196057] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[    1.216778] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.223067] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.236215] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.242510] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.255803] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.262162] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.275581] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.281921] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.290260] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[    1.313390] tegradc tegradc.0: hdmi: edid read failed
[    1.363460] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.363527] imx219 7-0010: board setup failed
[    1.387398] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.387496] imx219 8-0010: board setup failed
[    1.415348] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.415352] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.421317] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.421321] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.426305] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.426308] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.431320] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.431323] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.431326] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[    1.431331] hpd: edid read prepare failed
[    1.736143] cgroup: cgroup2: unknown option "nsdelegate"
[    2.779405] using random self ethernet address
[    2.791426] using random host ethernet address
[    2.816533] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 0 CCS
[    3.000764] random: systemd: uninitialized urandom read (16 bytes read)
[    3.007664] random: systemd: uninitialized urandom read (16 bytes read)
[    3.048402] random: systemd: uninitialized urandom read (16 bytes read)
[    3.052056] sd 0:0:0:0: [sda] 1953792 512-byte logical blocks: (1.00 GB/954 MiB)
[    3.052356] sd 0:0:0:0: [sda] Write Protect is off
[    3.052523] sd 0:0:0:0: [sda] No Caching mode page found
[    3.052526] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    3.098144] random: crng init done
[    3.102875] random: 109 urandom warning(s) missed due to ratelimiting
[    3.265900] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    3.310693] using random self ethernet address
[    3.321286] using random host ethernet address
[    4.222133] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[    4.231180] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -62.
[    4.239199] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[   10.737644] Please complete system configuration setup on desktop to proceed...
this is what i see when i try to plug a displayport cable connected to a displayport capable screen
[  427.936272] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  427.942560] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  427.963220] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  427.969512] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  427.982712] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  427.989019] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  428.003340] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  428.009643] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  428.018006] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[  428.025776] hpd: edid read prepare failed[  649.971177] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  649.977453] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  649.990662] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  649.990665] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  649.995562] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  649.995565] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  650.000176] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  650.000179] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  650.000181] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[  650.021989] hpd: edid read prepare failed
[  657.203213] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  657.209607] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  657.222789] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  657.229160] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  657.243190] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  657.249480] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  657.263723] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  657.270007] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  657.278364] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[  657.286122] hpd: edid read prepare failed[  669.692245] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  669.698697] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  669.712152] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  669.718478] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  669.731732] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  669.738009] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  669.751495] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  669.757779] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  669.766072] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
note that for this last test i’ve used the same cable that normally connects my desktop rtx3070ti to my desktop display, therefore the cable is guaranteed to be working
You can try to use l4t_create_default_user.sh on your host PC first and then reflash to bypass the system configuration.
After you bypass the configuration, your uart log can proceed and you can help dump the full dmesg. Currently, your serial console does not have full kernel log.
Thanks for your kind reply
here is the full dmesg.
nvidia@tegra-ubuntu:~$ dmesg
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] On node 0 totalpages: 1039872
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519168 pages, LIFO batch:31
[    0.000000]   Normal zone: 8136 pages used for memmap
[    0.000000]   Normal zone: 520704 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57816 r8192 d32296 u98304
[    0.000000] pcpu-alloc: s57816 r8192 d32296 u98304 alloc=24*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: enabling workaround for Spectre-BHB
[    0.000000] CPU features: enabling workaround for ARM erratum 1742098
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt tegra_fbmem=0x140000@0x92cb4000 is_hdmi_initialised=1  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29548(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3566976K/4159488K available (15486K kernel code, 2982K rwdata, 6716K rodata, 8640K init, 614K bss, 117376K reserved, 475136K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0x        (ptrval) - 0x        (ptrval)   ( 15488 KB)
[    0.000000]     .rodata : 0x        (ptrval) - 0x        (ptrval)   (  6784 KB)
[    0.000000]       .init : 0x        (ptrval) - 0x        (ptrval)   (  8640 KB)
[    0.000000]       .data : 0x        (ptrval) - 0x        (ptrval)   (  2983 KB)
[    0.000000]        .bss : 0x        (ptrval) - 0x        (ptrval)   (   615 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03fc8000   (    63 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ff200000   (  4082 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001709] Console: colour dummy device 80x25
[    0.001719] console [tty0] enabled
[    0.001724] bootconsole [uart8250] disabled
[    0.001744] kmemleak: Kernel memory leak detector disabled
[    0.001764] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001776] pid_max: default: 32768 minimum: 301
[    0.002252] Security Framework initialized
[    0.002495] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002501] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003634] ftrace: allocating 47296 entries in 185 pages
[    0.180734] sched-energy: CPU device node has no sched-energy-costs
[    0.192264] ASID allocator initialised with 65536 entries
[    0.219509] tegra-id: chipid=22117.
[    0.219522] tegra-id: opt_subrevision=0.
[    0.219540] Tegra Speedo/IDDQ fuse revision 4
[    0.219545] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.219549] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[    0.219555] Tegra: CPU Speedo Value 2059, SoC Speedo Value 1937, GPU Speedo Value 2047
[    0.219559] Tegra: CPU IDDQ Value 2156, SoC IDDQ Value 2264, GPU IDDQ Value 2875
[    0.219585] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[    0.219599] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[    0.219607] DTB Build time: Jun  8 2023 21:21:40
[    0.269102] CPU1: Booted secondary processor [411fd071]
[    0.300980] CPU2: Booted secondary processor [411fd071]
[    0.332962] CPU3: Booted secondary processor [411fd071]
[    0.333054] Brought up 4 CPUs
[    0.333060] SMP: Total of 4 processors activated.
[    0.333068] CPU features: detected feature: 32-bit EL0 Support
[    0.333310] CPU: All CPU(s) started at EL2
[    0.333326] alternatives: patching kernel code
[    0.341558] devtmpfs: initialized
[    0.379738] Initilizing CustomIPI irq domain
[    0.380039] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.380059] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.392203] pinctrl core: initialized pinctrl subsystem
[    0.392788] OS set in device tree is not L4T.
[    0.393250] regulator-dummy: no parameters
[    0.393521] Initializing plugin-manager
[    0.393686] Plugin module not found
[    0.393882] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[    0.394393] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[    0.394826] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[    0.395545] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[    0.395748] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[    0.396359] node /plugin-manager/fragement@13 match with board >=3448-0002-300
[    0.400025] NET: Registered protocol family 16
[    0.401427] pstore: using zlib compression
[    0.401469] console [pstore-1] enabled
[    0.401474] pstore: Registered ramoops as persistent store backend
[    0.401479] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.421125] cpuidle: using governor menu
[    0.425170] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.426855] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.426877] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.429617] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.431913] Serial: AMBA PL011 UART driver
[    0.432415] tegra_powergate_init: DONE
[    0.432430] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[    0.432436] DTB Build time: Jun  8 2023 21:21:40
[    0.434318] Tegra reboot handler registered.
[    0.438804] iommu: Adding device tegra-carveouts to group 0
[    0.438944] platform tegra-carveouts: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.439298] iommu: Adding device smmu_test to group 1
[    0.439346] platform smmu_test: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.440167] mc: mapped MMIO address: 0x        (ptrval) -> 0x70019000
[    0.440219] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001c000
[    0.440272] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001d000
[    0.440281] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.440306] mc-err: mcerr ops are set to t21x
[    0.450797] iommu: Adding device 70090000.xusb to group 2
[    0.451070] iommu: Adding device 70006000.serial to group 3
[    0.451126] platform 70006000.serial: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.451545] iommu: Adding device 70006040.serial to group 4
[    0.451798] iommu: Adding device 70006200.serial to group 5
[    0.451980] iommu: Adding device sound to group 6
[    0.452036] platform sound: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.452596] iommu: Adding device 7000d400.spi to group 7
[    0.452887] iommu: Adding device 7000d600.spi to group 8
[    0.453255] iommu: Adding device 50000000.host1x to group 9
[    0.453527] iommu: Adding device 54080000.vi to group 10
[    0.453949] iommu: Adding device 54600000.isp to group 11
[    0.454217] iommu: Adding device 54680000.isp to group 12
[    0.454483] iommu: Adding device tegradc.0 to group 13
[    0.454536] platform tegradc.0: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.455922] platform tegradc.0: IOVA linear map 0x0000000092cb4000(140000)
[    0.456312] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[    0.456639] iommu: Adding device tegradc.1 to group 14
[    0.456692] platform tegradc.1: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.458096] platform tegradc.1: IOVA linear map 0x0000000092cb4000(140000)
[    0.458484] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[    0.458761] iommu: Adding device 54340000.vic to group 15
[    0.458952] iommu: Adding device 544c0000.nvenc to group 16
[    0.459148] iommu: Adding device 54500000.tsec to group 17
[    0.459341] iommu: Adding device 54100000.tsecb to group 18
[    0.459528] iommu: Adding device 54480000.nvdec to group 19
[    0.459724] iommu: Adding device 54380000.nvjpg to group 20
[    0.460780] iommu: Adding device 546c0000.i2c to group 21
[    0.461152] iommu: Adding device 57000000.gpu to group 22
[    0.461226] platform 57000000.gpu: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.461265] platform 57000000.gpu: domain=        (ptrval) allocates as[1]=        (ptrval)
[    0.461300] platform 57000000.gpu: domain=        (ptrval) allocates as[2]=        (ptrval)
[    0.461336] platform 57000000.gpu: domain=        (ptrval) allocates as[3]=        (ptrval)
[    0.462191] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.462202] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.462213] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.462217] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.462222] tegra-pmc: ### PMC reset status reg: 0x3
[    0.513285] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.513295] tegra-pmc: Clear bootloader IO dpd settings
[    0.513316] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.513377] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.513668] iommu: Adding device 70012000.se to group 23
[    0.514266] iommu: Adding device 1003000.pcie to group 24
[    0.514318] platform 1003000.pcie: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.514815] iommu: Adding device 7000c000.i2c to group 25
[    0.515139] iommu: Adding device 7000c400.i2c to group 26
[    0.515445] iommu: Adding device 7000c500.i2c to group 27
[    0.515778] iommu: Adding device 7000c700.i2c to group 28
[    0.516110] iommu: Adding device 7000d000.i2c to group 29
[    0.516447] iommu: Adding device 7000d100.i2c to group 30
[    0.516718] iommu: Adding device sdhci-tegra.3 to group 31
[    0.516773] platform sdhci-tegra.3: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.517875] iommu: Adding device 700d0000.xudc to group 32
[    0.521850] vdd-ac-bat: 5000 mV
[    0.522191] vdd-5v0-sys: 5000 mV
[    0.523090] vdd-5v0-hdmi: 5000 mV
[    0.523608] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.523951] vdd-1v8-sys: 1800 mV
[    0.524447] vdd-fan: 5000 mV
[    0.524720] vdd-fan: supplied by vdd-5v0-sys
[    0.524997] vdd-usb-vbus: 5000 mV
[    0.525279] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.525727] vdd-usb-vbus2: 5000 mV
[    0.558126] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.560434] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.562227] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.562255] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.562275] GPIO line 152 (camera-control-output-low) hogged as output/low
[    0.562644] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.570632] eventlib_kernel: keventlib is initialized, test id: 0
[    0.571028] SCSI subsystem initialized
[    0.571229] libata version 3.00 loaded.
[    0.571603] usbcore: registered new interface driver usbfs
[    0.571653] usbcore: registered new interface driver hub
[    0.571692] usbcore: registered new device driver usb
[    0.575788] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.581097] vdd-core: 600 <--> 1162 mV at 1125 mV
[    0.582137] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.585035] vdd-ddr-1v1: 1150 mV
[    0.588979] vdd-pre-reg-1v35: 1350 mV
[    0.592254] vdd-1v8: 1800 mV
[    0.596246] avdd-sys-1v2: 1200 mV
[    0.600239] vdd-pex-1v0: 1050 mV
[    0.600895] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.601452] max77620-ldo3: at 3100 mV
[    0.604243] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.604793] max77620-ldo5: at 3100 mV
[    0.608238] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[    0.612238] avdd-1v05-pll: 1050 mV
[    0.616236] avdd-io-hdmi-dp: 1050 mV
[    0.618985] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.619299] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.619578] max77620 4-003c: max77620 probe successful
[    0.622281] media: Linux media interface: v0.10
[    0.622342] Linux video capture interface: v2.00
[    0.623270] pps_core: LinuxPPS API ver. 1 registered
[    0.623277] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.623297] PTP clock support registered
[    0.626533] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.627404] Advanced Linux Sound Architecture Driver Initialized.
[    0.627995] Bluetooth: Core ver 2.22
[    0.628037] NET: Registered protocol family 31
[    0.628041] Bluetooth: HCI device and connection manager initialized
[    0.628060] Bluetooth: HCI socket layer initialized
[    0.628069] Bluetooth: L2CAP socket layer initialized
[    0.628092] Bluetooth: SCO socket layer initialized
[    0.630012] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.630032] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.630087] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.630104] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.633561] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.634664] vdd-3v3-sys: 3300 mV
[    0.635039] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.635092] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.636349] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.636782] vdd-3v3-sd: 3300 mV
[    0.637208] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.637973] avdd-io-edp-1v05: 1050 mV
[    0.638327] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.638457] vdd-usb-hub-en: 5000 mV
[    0.638786] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.639922] camchar: rtcpu character device driver loaded
[    0.640677] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[    0.642352] clocksource: Switched to clocksource arch_sys_counter
[    0.682969] VFS: Disk quotas dquot_6.6.0
[    0.683101] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.683615] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.684072] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.684091]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.684289] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.684296] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.684309] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.684335] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.684340] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.684361] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.684368] nvmap_page_pool_init: Total RAM pages: 1010528
[    0.684373] nvmap_page_pool_init: nvmap page pool size: 126316 pages (493 MB)
[    0.684458] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.684887] misc nvmap: created heap iram base 0x        (ptrval) size (252KiB)
[    0.685620] misc nvmap: created heap vpr base 0x        (ptrval) size (409600KiB)
[    0.695227] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.695684] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.696037] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.696309] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.696488] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.696754] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.696759] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.697212] NET: Registered protocol family 2
[    0.697365] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.718631] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.718845] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.719352] TCP: Hash tables configured (established 32768 bind 32768)
[    0.719511] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.719593] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.720033] NET: Registered protocol family 1
[    0.720693] RPC: Registered named UNIX socket transport module.
[    0.720697] RPC: Registered udp transport module.
[    0.720701] RPC: Registered tcp transport module.
[    0.720705] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.720720] PCI: CLS 0 bytes, default 64
[    0.720970] Trying to unpack rootfs image as initramfs...
[    1.029324] Freeing initrd memory: 6988K
[    1.039281] host1x 50000000.host1x: initialized
[    1.041143] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.044443] audit: initializing netlink subsys (disabled)
[    1.044536] audit: type=2000 audit(0.887:1): initialized
[    1.045237] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.054991] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.056476] ntfs: driver 2.1.32 [Flags: R/W].
[    1.057280] 9p: Installing v9fs 9p2000 file system support
[    1.060511] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.060625] io scheduler noop registered
[    1.060932] io scheduler cfq registered (default)
[    1.063795] gic 702f9000.agic: GIC IRQ controller registered
[    1.066803] iommu: Adding device 702ef000.adsp to group 33
[    1.075764] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[    1.075929] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    1.076544] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x822840f
[    1.076551] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    1.078141] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    1.078239] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    1.078378] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    1.078597] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    1.078689] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    1.078789] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    1.078877] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    1.078972] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    1.079055] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    1.079145] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    1.085174] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    1.086949] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    1.088859] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    1.090147] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    1.090530] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    1.091756] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.091984] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    1.092225] Adding domain tsec-pd to PM domain host1x-pd
[    1.094302] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    1.095301] tsec 54500000.tsec: initialized
[    1.096841] tsec 54100000.tsecb: initialized
[    1.097541] Adding domain nvdec-pd to PM domain host1x-pd
[    1.100946] nvdec 54480000.nvdec: initialized
[    1.101989] Adding domain vic03-pd to PM domain host1x-pd
[    1.102159] Adding domain msenc-pd to PM domain host1x-pd
[    1.102316] Adding domain nvjpg-pd to PM domain host1x-pd
[    1.106268] falcon 54340000.vic: initialized
[    1.107477] falcon 544c0000.nvenc: initialized
[    1.108761] falcon 54380000.nvjpg: initialized
[    1.112954] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=96
[    1.112997] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    1.113033] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    1.113209] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    1.113302] display board info: id 0x0, fab 0x0
[    1.113305] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    1.113309] tegra_cec 70015000.tegra_cec: probed
[    1.113365] generic_infoframe_type: 0x87
[    1.113507] tegradc tegradc.0: DT parsed successfully
[    1.113550] tegradc tegradc.0: Display dc.        (ptrval) registered with id=0
[    1.114080] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[    1.121376] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.121721] tegradc tegradc.0: probed
[    1.128139] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.129426] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.129432] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.129826] kfuse 7000fc00.kfuse: initialized
[    1.131317] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.132303] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.133736] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.133751] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.134330] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.135978] vdd-gpu: applied init 1000000uV constraint
[    1.135989] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.136435] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.140901] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.141038] No Device Node present for smmu client: serial8250 !!
[    1.141047] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.141110] iommu: Adding device serial8250 to group 35
[    1.144359] console [ttyS0] disabled
[    1.144437] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.144535] console [ttyS0] enabled
[    1.145440] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    1.145724] serial-tegra 70006200.serial: RX in PIO mode
[    1.145814] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    1.146813] [drm] Initialized
[    1.148537] Console: switching to colour frame buffer device 80x30
[    1.148574] tegradc tegradc.0: fb registered
[    1.155685] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[    1.155736] tegradc tegradc.0: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[    1.156254] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[    1.156266] tegradc tegradc.0: hdmi: BL set VIC 0
[    1.156272] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[    1.157063] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[    1.157344] extcon-disp-state extcon:disp-state: cable 47 state 1
[    1.157350] Extcon AUX1(HDMI) enable
[    1.158484] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[    1.158565] tegradc tegradc.1: No lt-data, using default setting
[    1.158599] tegradc tegradc.1: No hpd-gpio in DT
[    1.158633] tegradc tegradc.1: DT parsed successfully
[    1.158682] tegradc tegradc.1: Display dc.        (ptrval) registered with id=1
[    1.160315] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.162156] brd: module loaded
[    1.165860] edid invalid
[    1.179648] tegradc tegradc.1: probed
[    1.180059] tegradc tegradc.1: fb registered
[    1.183582] loop: module loaded
[    1.183675] tegra_profiler: version: 1.145, samples/io: 49/28
[    1.183965] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.185420] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.186876] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.188112] tegra_profiler: auth: init
[    1.188215] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.191560] THERMAL EST: found 2 subdevs
[    1.191567] THERMAL EST num_resources: 0
[    1.191572] [THERMAL EST subdev 0]
[    1.191579] [THERMAL EST subdev 1]
[    1.192010] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.192012] THERMAL EST: thz register success.
[    1.192401] THERMAL EST: end of probe, return err: 0
[    1.193634] sd: No Scsi addr parsed to reserve index
[    1.193667] hisi_sas: driver version v1.6
[    1.194575] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[    1.196282] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[    1.200979] tun: Universal TUN/TAP device driver, 1.6
[    1.200982] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.201635] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.201637] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.201681] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    1.201683] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.201723] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.201725] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.201771] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    1.201773] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    1.210123] tegradc tegradc.1: nominal-pclk:25200000 parent:25200000 div:1.0 pclk:25200000 24948000~27468000
[    1.210796] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.211296] PPP generic driver version 2.4.2
[    1.211435] PPP BSD Compression module registered
[    1.211439] PPP Deflate Compression module registered
[    1.211453] PPP MPPE Compression module registered
[    1.211457] NET: Registered protocol family 24
[    1.211506] usbcore: registered new interface driver r8152
[    1.211545] usbcore: registered new interface driver asix
[    1.211581] usbcore: registered new interface driver ax88179_178a
[    1.211618] usbcore: registered new interface driver cdc_ether
[    1.211652] usbcore: registered new interface driver net1080
[    1.211687] usbcore: registered new interface driver cdc_subset
[    1.211721] usbcore: registered new interface driver zaurus
[    1.211772] usbcore: registered new interface driver cdc_ncm
[    1.211902] VFIO - User Level meta-driver version: 0.3
[    1.212271] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.212847] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.212858] ehci-pci: EHCI PCI platform driver
[    1.212898] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.212905] ohci-pci: OHCI PCI platform driver
[    1.212940] ohci-platform: OHCI generic platform driver
[    1.213735] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.214870] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    1.215014] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.215532] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    1.216595] tegra-xusb 70090000.xusb: extcon 0:         (ptrval) id
[    1.218089] usbcore: registered new interface driver uas
[    1.218136] usbcore: registered new interface driver usb-storage
[    1.218217] usbcore: registered new interface driver usbserial
[    1.218377] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[    1.218407] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.218424] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[    1.219147] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[    1.219182] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[    1.219439] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.219444] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.219448] usb usb1: Product: xHCI Host Controller
[    1.219452] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.219455] usb usb1: SerialNumber: 70090000.xusb
[    1.219979] hub 1-0:1.0: USB hub found
[    1.220012] hub 1-0:1.0: 5 ports detected
[    1.220609] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.220619] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[    1.220689] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.220742] tegra-xudc-new 700d0000.xudc: device count: 1
[    1.220787] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.220792] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.220795] usb usb2: Product: xHCI Host Controller
[    1.220799] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.220802] usb usb2: SerialNumber: 70090000.xusb
[    1.221224] hub 2-0:1.0: USB hub found
[    1.221254] hub 2-0:1.0: 4 ports detected
[    1.221322] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.221801] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    1.221810] tegra-xudc-new 700d0000.xudc: vbus state: 1
[    1.221819] tegra-xudc-new 700d0000.xudc: device mode on: 0
[    1.221837] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[    1.221859] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[    1.221924] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[    1.221929] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[    1.222319] mousedev: PS/2 mouse device common for all mice
[    1.222407] usbcore: registered new interface driver xpad
[    1.230290] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.231751] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.233208] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.234669] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.240963] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.246407] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[    1.249888] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.251002] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.252460] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.253915] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.260215] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.269143] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.270609] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.272073] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.273539] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.279824] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.288104] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[    1.295427] tegradc tegradc.0: hdmi: edid read failed
[    1.295480] tegradc tegradc.0: hdmi: using fallback edid
[    1.300944] tegradc tegradc.0: blank - powerdown
[    1.301036] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[    1.301040] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[    1.322695] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.324834] rtc rtc1: alarm rtc device
[    1.324846] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    1.324873] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    1.325197] i2c /dev entries driver
[    1.326916] i2c i2c-6: Added multiplexed i2c bus 7
[    1.327409] i2c i2c-6: Added multiplexed i2c bus 8
[    1.327413] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[    1.328087] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[    1.349360] extcon-disp-state extcon:disp-state: cable 47 state 0
[    1.349363] Extcon AUX1(HDMI) disable
[    1.351381] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.351462] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.351530] imx219 7-0010: board setup failed
[    1.351582] imx219: probe of 7-0010 failed with error -121
[    1.352028] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[    1.375341] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.375426] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.375521] imx219 8-0010: board setup failed
[    1.375601] imx219: probe of 8-0010 failed with error -121
[    1.377457] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.380294] tegradc tegradc.0: unblank
[    1.380482] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    1.380486] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    1.380959] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.380975] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    1.380984] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    1.381149] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.381159] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    1.381166] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    1.381322] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.381332] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    1.381337] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    1.381523] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    1.382586] tegra_aotag tegra-aotag: Registering sensor 0
[    1.382650] tegra_aotag tegra-aotag: Invalid temp readout
[    1.382677] tegra_aotag tegra-aotag: Invalid temp readout
[    1.382694] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    1.382703] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    1.383988] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.384008] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    1.384223] tegra_aotag tegra-aotag: Invalid temp readout
[    1.384251] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    1.384757] parse_throttle_dt_data: Num cap clks = 6
[    1.384762] parse_throttle_dt_data: clk=cclk_g type=2
[    1.384776] parse_throttle_dt_data: clk=gpu type=4
[    1.384811] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    1.384836] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    1.384864] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    1.384867] parse_throttle_dt_data: clk=emc type=3
[    1.385313] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.385472] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.385674] tegra_throttle_probe: probe successful. #cdevs=4
[    1.386712] FAN dev name: pwm-fan
[    1.386793] FAN:gpio request success.
[    1.386856] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    1.387184] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.387353] pwm_fan_driver pwm-fan: fan tach request irq success
[    1.387363] pwm_fan_driver pwm-fan: tach period: 1000
[    1.387458] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.387463] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    1.387467] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    1.387471] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    1.387475] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.387479] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.387483] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.387487] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.387491] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.387495] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.390705] device-mapper: uevent: version 1.0.3
[    1.391238] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.396214] tegra210-cpufreq cpufreq: probe()...completed
[    1.397009] sdhci: Secure Digital Host Controller Interface driver
[    1.397011] sdhci: Copyright(c) Pierre Ossman
[    1.397012] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.397417] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[    1.402374] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[    1.402380] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[    1.404149] tegra-se 70012000.se: tegra_se_probe: complete
[    1.404639] hidraw: raw HID events driver (C) Jiri Kosina
[    1.405984] usbcore: registered new interface driver usbhid
[    1.405986] usbhid: USB HID core driver
[    1.407460] ashmem: initialized
[    1.408423] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    1.408594] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    1.410372] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[    1.411014] nvpmodel: initialized successfully
[    1.411509] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.412008] usbcore: registered new interface driver snd-usb-audio
[    1.412068] No Device Node present for smmu client: snd-soc-dummy !!
[    1.412073] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.412089] iommu: Adding device snd-soc-dummy to group 36
[    1.414917] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.416370] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.419271] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.419276] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.419858] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.421330] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.422784] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.424088] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.424092] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.424286] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    1.424799] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.425723] tegradc tegradc.0: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[    1.425777] tegradc tegradc.0: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[    1.426248] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.426828] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[    1.427700] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.429149] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.429153] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.429801] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[    1.430123] OPE platform probe
[    1.430209] OPE platform probe successful
[    1.430550] OPE platform probe
[    1.430633] OPE platform probe successful
[    1.430997] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[    1.432452] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[    1.433504] extcon-disp-state extcon:disp-state: cable 47 state 1
[    1.433506] Extcon AUX1(HDMI) enable
[    1.433902] tegradc tegradc.1: dp: aux write got error (0x10000100)
[    1.433905] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[    1.433908] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[    1.433911] hpd: edid read prepare failed
[    1.433912] hpd: DC from connected to disconnected
[    1.438390] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[    1.443792] tegradc tegradc.0: sync windows ret = 247
[    1.456327] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.456461] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.456590] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.456717] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.456843] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.456969] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.457097] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.457225] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.457350] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.457478] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.470366] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    1.478321] u32 classifier
[    1.478322]     Actions configured
[    1.478417] Initializing XFRM netlink socket
[    1.479151] NET: Registered protocol family 10
[    1.479841] NET: Registered protocol family 17
[    1.479851] NET: Registered protocol family 15
[    1.479932] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.479976] Bluetooth: RFCOMM socket layer initialized
[    1.479984] Bluetooth: RFCOMM ver 1.11
[    1.479988] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.479992] Bluetooth: HIDP socket layer initialized
[    1.480009] 9pnet: Installing 9P2000 support
[    1.480048] Key type dns_resolver registered
[    1.483400] Registered cp15_barrier emulation handler
[    1.483409] Registered setend emulation handler
[    1.484627] registered taskstats version 1
[    1.485176] Adding domain ve2-pd to PM domain host1x-pd
[    1.485423] Adding domain ve-pd to PM domain host1x-pd
[    1.488253] isp 54600000.isp: initialized
[    1.489625] isp 54680000.isp: initialized
[    1.494566] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    1.498935] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.500198] last reset is due to software reset
[    1.500200] KERNEL: PMC reset status reg: 0x3
[    1.500259] BL: PMC reset status reg: 0x3
[    1.500261] BL: PMIC poweroff Event Recorder: 0x0
[    1.501693] clk_cbus_recalc_rate: no gbus parent
[    1.501698] clk_cbus_round_rate: no gbus parent
[    1.501700] clk_cbus_round_rate: no gbus parent
[    1.501706] clk_cbus_recalc_rate: no gbus parent
[    1.501806] clk_cbus_recalc_rate: no gbus parent
[    1.501809] clk_cbus_round_rate: no gbus parent
[    1.501811] clk_cbus_round_rate: no gbus parent
[    1.501814] clk_cbus_recalc_rate: no gbus parent
[    1.502537] tegra_dvfs: GPU-cap: registered
[    1.502590] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    1.502592] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[    1.502594] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[    1.503111] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.503312] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.503444] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    1.504086] tegra_dvfs: vdd-gpu-vts: registered
[    1.504834] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    1.505481] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    1.506009] input: gpio-keys as /devices/gpio-keys/input/input1
[    1.506025]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[    1.511008] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[    1.511012] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.511015] usb 1-2: Product: 4-Port USB 2.1 Hub
[    1.511018] usb 1-2: Manufacturer: Generic
[    1.512127] hub 1-2:1.0: USB hub found
[    1.513315] hub 1-2:1.0: 4 ports detected
[    1.546271] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:22:56 UTC (946689776)
[    1.547321] vi 54080000.vi: vi_probe: ++
[    1.550591] vi 54080000.vi: initialized
[    1.552796] vi 54080000.vi: subdev nvcsi--2 bound
[    1.552901] vi 54080000.vi: subdev nvcsi--1 bound
[    1.553128] mmcblk mmc0:0001: Card claimed for testing.
[    1.554387] Disable partitions left on by BL
[    1.554390]   disb
[    1.554438] bwmgr: missing cdev-type property
[    1.554532] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.554539] DRAM derating cdev registered.
[    1.555404] ALSA device list:
[    1.555407]   #0: tegra-hda at 0x70038000 irq 82
[    1.555408]   #1: tegra-snd-t210ref-mobile-rt565x
[    1.558264] extcon-disp-state extcon:disp-state: cable 51 state 1
[    1.558267] Extcon HDMI: HPD enabled
[    1.558284] tegradc tegradc.0: hdmi: plugged
[    1.561765] Freeing unused kernel memory: 8640K
[    1.578367] tegra-pcie 1003000.pcie: link 0 down, retrying
[    1.587117] Root device found: mmcblk0p1
[    1.588536] Found dev node: /dev/mmcblk0p1
[    1.608335] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    1.610217] Rootfs mounted over mmcblk0p1
[    1.619298] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[    1.627528] Switching from initrd to actual rootfs
[    1.638390] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[    1.653604] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[    1.653608] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.653611] usb 2-1: Product: 4-Port USB 3.1 Hub
[    1.653614] usb 2-1: Manufacturer: Generic
[    1.658371] usb 1-2: usb_suspend_both: status 0
[    1.659064] hub 2-1:1.0: USB hub found
[    1.660692] hub 2-1:1.0: 4 ports detected
[    1.703191] systemd[1]: System time before build time, advancing clock.
[    1.719669] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.722522] usb usb1: usb_suspend_both: status 0
[    1.731081] cgroup: cgroup2: unknown option "nsdelegate"
[    1.744823] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    1.745615] systemd[1]: Detected architecture arm64.
[    1.767893] systemd[1]: Set hostname to <tegra-ubuntu>.
[    1.818379] usb 2-1: usb_suspend_both: status 0
[    1.818591] usb usb2: usb_suspend_both: status 0
[    1.849356] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    1.849365] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    1.953830] random: systemd: uninitialized urandom read (16 bytes read)
[    1.954085] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    1.954177] random: systemd: uninitialized urandom read (16 bytes read)
[    1.954201] systemd[1]: Reached target Swap.
[    1.954242] random: systemd: uninitialized urandom read (16 bytes read)
[    1.956022] systemd[1]: Created slice User and Session Slice.
[    1.956080] systemd[1]: Reached target User and Group Name Lookups.
[    1.956907] systemd[1]: Created slice System Slice.
[    1.986379] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.007648] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    2.066074] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[    2.138384] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[    2.300857] systemd-journald[1950]: Received request to flush runtime journal from PID 1
[    2.400637] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.404181] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.458731] tegradc tegradc.1: blank - powerdown
[    2.458742] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[    2.458745] Extcon DP: HPD disabled
[    2.458747] hpd: hpd_switch 0
[    2.458751] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[    2.509754] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.509762] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.509767] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.509771] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.509775] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.509798] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    2.509870] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.510000] iommu: Adding device 0000:00:02.0 to group 37
[    2.510081] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.510196] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.510223] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.510256] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[    2.510278] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[    2.510477] pci 0000:01:00.0: supports D1 D2
[    2.510481] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.510650] iommu: Adding device 0000:01:00.0 to group 38
[    2.522419] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.522453] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[    2.522458] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.522465] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[    2.522484] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[    2.522502] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.522511] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.522515] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.522521] pci 0000:00:02.0:   bridge window [mem 0x20000000-0x200fffff 64bit pref]
[    2.522786] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.522790] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.522795] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    2.522882] aer 0000:00:02.0:pcie002: service driver aer loaded
[    2.523069] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    2.523088] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    2.546604] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    2.546676] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:8e:e1:11 from device tree
[    2.547507] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    2.547523] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    2.956693] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    2.957422] random: systemd: uninitialized urandom read (16 bytes read)
[    2.964144] random: systemd: uninitialized urandom read (16 bytes read)
[    3.180573] using random self ethernet address
[    3.218378] using random host ethernet address
[    3.310381] random: crng init done
[    3.315055] random: 173 urandom warning(s) missed due to ratelimiting
[    3.677174] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    3.677197] cpu-throttle-alert cooling device registered.
[    3.678750] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    3.678867] gpu-throttle-alert cooling device registered.
[    3.682933] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    3.682950] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    3.682968] hot-surface-alert cooling device registered.
[    3.721669] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    3.744859] eth0: 0xffffff800d535000, 48:b0:2d:8e:e1:11, IRQ 406
[    3.855395] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    3.880231] Mass Storage Function, version: 2009/09/11
[    3.880237] LUN: removable file: (no medium)
[    3.898503] using random self ethernet address
[    3.907132] using random host ethernet address
[    3.944708] rndis0: HOST MAC 0e:c3:bc:f1:2e:58
[    3.944840] rndis0: MAC 0e:c3:bc:f1:2e:59
[    3.951146] usb0: HOST MAC 0e:c3:bc:f1:2e:5a
[    3.951182] usb0: MAC 0e:c3:bc:f1:2e:5b
[    3.951214] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[    3.958450] l4tbr0: port 1(rndis0) entered blocking state
[    3.958455] l4tbr0: port 1(rndis0) entered disabled state
[    3.959079] device rndis0 entered promiscuous mode
[    3.969988] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    3.975143] l4tbr0: port 2(usb0) entered blocking state
[    3.975147] l4tbr0: port 2(usb0) entered disabled state
[    3.975724] device usb0 entered promiscuous mode
[    3.995772] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    4.199203] android_work: did not send uevent (0 0           (null))
[    4.218526] tegra-xusb 70090000.xusb: entering ELPG
[    4.219560] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[    4.219947] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[    4.220863] tegra-xusb 70090000.xusb: entering ELPG done
[    4.232335] android_work: sent uevent USB_STATE=CONNECTED
[    4.474380] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[    4.483464] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -62.
[    4.494373] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    4.508240] android_work: sent uevent USB_STATE=DISCONNECTED
[    4.541406] android_work: sent uevent USB_STATE=CONNECTED
[    4.564330] configfs-gadget gadget: high-speed config #1: c
[    4.564361] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[    4.564377] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[    4.564392] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[    4.564502] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[    4.564519] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[    4.564533] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[    4.564570] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[    4.564589] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[    4.564612] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[    4.564752] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[    4.565316] android_work: sent uevent USB_STATE=CONFIGURED
[    8.150699] Bridge firewalling registered
[    8.168913] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    8.433398] Netfilter messages via NETLINK v0.30.
[    8.436024] ctnetlink v0.93: registering with nfnetlink.
[    8.537340] l4tbr0: port 1(rndis0) entered blocking state
[    8.537345] l4tbr0: port 1(rndis0) entered forwarding state
[    8.538456] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[    8.553010] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[    9.466423] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[   21.029857] zram: Added device: zram0
[   21.030285] zram: Added device: zram1
[   21.036277] zram: Added device: zram2
[   21.039088] zram: Added device: zram3
[   21.064668] zram0: detected capacity change from 0 to 519393280
[   21.102037] Adding 507216k swap on /dev/zram0.  Priority:5 extents:1 across:507216k SS
[   21.114103] zram1: detected capacity change from 0 to 519393280
[   21.130118] Adding 507216k swap on /dev/zram1.  Priority:5 extents:1 across:507216k SS
[   21.140828] zram2: detected capacity change from 0 to 519393280
[   21.161859] Adding 507216k swap on /dev/zram2.  Priority:5 extents:1 across:507216k SS
[   21.174408] zram3: detected capacity change from 0 to 519393280
[   21.185601] Adding 507216k swap on /dev/zram3.  Priority:5 extents:1 across:507216k SS
[   21.770507] tegradc tegradc.0: unblank
[   21.770746] tegradc tegradc.1: blank - powerdown
[   22.253810] fuse init (API version 7.26)
[   31.866519] vdd-fan: disabling
[   31.866523] vdd-usb-vbus: disabling
[   31.866526] vdd-usb-vbus2: disabling
[   31.866535] vddio-sdmmc-ap: disabling
[   31.866609] vddio-sdmmc3-ap: disabling
[   31.866667] vdd-3v3-sd: disabling
[   31.866671] avdd-io-edp-1v05: disabling
[   31.866674] vdd-usb-hub-en: disabling
[  272.590057] tegradc tegradc.1: dp: unplug event received
[  272.590270] hpd: state 3 (Disabled), hpd 0, pending_hpd_evt 1
[  272.590310] hpd: switching from state 3 (Disabled) to state 0 (Reset)
[  272.590828] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[  272.590932] tegradc tegradc.1: blank - powerdown
[  272.591097] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[  272.591126] Extcon DP: HPD disabled
[  272.591154] hpd: hpd_switch 0
[  272.591224] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[  272.591297] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[  272.591343] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[  272.609395] tegradc tegradc.0: unblank
[  272.609419] tegradc tegradc.1: blank - powerdown
[  272.612817] tegradc tegradc.1: dp: plug event received
[  272.612842] hpd: state 3 (Disabled), hpd 1, pending_hpd_evt 1
[  272.612846] hpd: switching from state 3 (Disabled) to state 0 (Reset)
[  272.714547] hpd: state 0 (Reset), hpd 1, pending_hpd_evt 0
[  272.714567] tegradc tegradc.1: blank - powerdown
[  272.714586] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[  272.714590] Extcon DP: HPD disabled
[  272.714595] hpd: hpd_switch 0
[  272.714600] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[  272.714612] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[  272.714620] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[  272.716918] tegradc tegradc.0: unblank
[  272.717228] tegradc tegradc.1: blank - powerdown
[  272.722437] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[  272.723111] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[  272.724574] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[  272.726026] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[  272.727575] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  272.733942] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  272.742876] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[  272.744341] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[  272.745788] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[  272.747059] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  272.753370] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  272.762387] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[  272.763869] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[  272.765385] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[  272.766700] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  272.773019] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  272.782063] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[  272.783527] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[  272.784977] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[  272.786435] tegradc tegradc.1: dp: aux write got error (0x10000100)
[  272.792756] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[  272.801067] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[  272.808858] hpd: edid read prepare failed
[  272.812733] tegradc tegradc.1: blank - powerdown
[  272.812752] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[  272.812755] Extcon DP: HPD disabled
[  272.812758] hpd: hpd_switch 0
[  272.812761] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[  272.818135] tegradc tegradc.0: unblank
[  272.818145] tegradc tegradc.1: blank - powerdown
[  273.225892] tegradc tegradc.1: dp: unplug event received
[  273.226105] hpd: state 3 (Disabled), hpd 0, pending_hpd_evt 1
[  273.226146] hpd: switching from state 3 (Disabled) to state 0 (Reset)
[  273.226209] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[  273.226283] tegradc tegradc.1: blank - powerdown
[  273.226896] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[  273.226954] Extcon DP: HPD disabled
[  273.227007] hpd: hpd_switch 0
[  273.227069] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[  273.227170] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[  273.227218] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[  273.233530] tegradc tegradc.0: unblank
[  273.233562] tegradc tegradc.1: blank - powerdown
May I ask are you always using same module to test here?
Your log seems telling that you are testing with multiple modules. If you are not using multiple modules to test, then something is wrong here.
Also, just a suggestion. If you want to share multiple logs, please just attach them as separate file but not copy and paste. It would be hard to check posts if you copy more and more logs…
Hello, what do you mean by multiple modules?
I’ve been using a single module, with always the same carrier board:
I was asked to flash the Jetpack version of Linux 4 Tegra on the module, and so i did
Here is the procedure i followed:
  • downloaded jetpack
  • unpacked sample rootfs
  • ran add_binaries
  • ran the add default user script
  • used flash.sh command to flash everything on the module
then i booted the module connected via serial console for logging in and printing the dmesg: this is the result of the last post.
from now on i’ll make sure to attach everything as file instead of posting it as quoted text.
yet, the latest dmesg log i posted is the one resulting from the above procedure.
still no video output from either hdmi or display port.
I don’t know if this is of any relevance for the video output to work: the board is in production mode and has a PKC fuse burned for secure boot.
for flashing i’m therefore passing the -u option to flash.sh as it needs my private key for flashing.
I don’t have another module nor carrier board for swapping and test.
Then there is something wrong.
Take your first log as example, it was
[ 0.239946] DTS File Name: /home/rampage/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_NANO_TARGETS/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-a02.dts
I know it could be something built by you.
The latest log said you are using below dtb. This is from NV default one.
[ 0.432430] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
The problem here is “b00” and “a02” are two different kinds of carrier boards and modules.
A02 is a module that was released in very early stage in Jetson nano lifecycle. I mean it was a module released for like 4 years ago and there was no longer such module anymore.
B00 module is a commercial one and most of user should use this kind of module.
The dtb of these two are different and are not interchangeable.
Then, I would like to confirm which kind of module is in use here? I believe it should be b00 one because a02 one seems to be the wrong customization done by you.
As for the HDMI problem, I would like to know does this module and carrier board ever be able to give correct HDMI output before?
I mean, does this issue happened recently and suddenly?
I saw HDMI driver is not able to read edid from the monitor anymore. And DP side has same problem with dpaux too, which you could think it as the i2c part in DP part is also dead.
yes, indeed I think i made an error during my custom flashing procedure and i used the a02 dtb
flash.sh flashed automatically the b00 dtb on the RP1 and RP1-1 partition, so i think the b00 dtb is the correct one to use.
I think what made me think it was an a02 revision was the following on the bottom of the carrier board PCB:
and the following message in the kernel boot process
[    0.219585] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
anyway, I’ve never been able to get video output from the device, it never worked.
I only noticed this recently because during the earlier stages of development i never needed to connect the device to a display for video output as i always worked through serial console.
We just tried to flash a02 jetson nano devkit and it has no error as you mentioned.
Thus, this looks like a hardware defect on you side.
dmesg_Jetson-Nano-A02+r32.7.4.log (60.0 KB)
Thank you very much for your reply.
I’ll check with the hardware supplier for a module replacement.
I think they also made a wrong “mix and match” providing me with a b00 module paired with an a02 carrier board, which of course would not work together.
