No HDMI display on Jetson Module with Jetson nano development Kit board
I just got a Jetson nano module so ia get 16gb emmc, i tried to install jetpack with the sdk and i wonderments get any screen, this is the serial log :
[code[0000.203] [L4T TegraBoot] (version 00.00.2018.01-l4t-39a9dc3d)
[0000.208] Processing in cold boot mode Bootloader 2
[0000.213] A02 Bootrom Patch rev = 1023
[0000.217] Power-up reason: software reset
[0000.220] No Battery Present
[0000.223] pmic max77620 reset reason
[0000.226] pmic max77620 NVERC : 0x0
[0000.230] RamCode = 0
[0000.232] Platform has DDR4 type RAM
[0000.235] max77620 disabling SD1 Remote Sense
[0000.239] Setting DDR voltage to 1125mv
[0000.243] Serial Number of Pmic Max77663: 0xe05b1
[0000.251] Entering ramdump check
[0000.254] Get RamDumpCarveOut = 0x0
[0000.257] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.262] Last reboot was clean, booting normally!
[0000.267] Sdram initialization is successful
[0000.271] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.277] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.283] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.289] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.295] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.301] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.306] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.312] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.328] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.334] Platform-DebugCarveout: 0
[0000.338] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.343] Non secure mode, and RB not enabled.
[0000.360] Csd NumOfBlocks=0
[0000.552] *** Booting BFS0.
[0000.558] Using BFS PT to query partitions
[0001.530] *** Booting KFS0.
[0001.534] Using GPT Primary to query partitions
[0001.539] Loading Tboot-CPU binary
[0001.546] Verifying TBC in OdmNonSecureSBK mode
[0001.556] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0001.563] Bootloader downloaded successfully.
[0001.567] Downloaded Tboot-CPU binary to 0xa0000258
[0001.572] MAX77620_GPIO5 configured
[0001.575] CPU power rail is up
[0001.578] CPU clock enabled
[0001.582] Performing RAM repair
[0001.585] Updating A64 Warmreset Address to 0xa00002e9
[0001.590] Loading NvTbootBootloaderDTB
[0001.607] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0001.672] Bootloader DTB Load Address: 0x83000000
[0001.677] Loading NvTbootKernelDTB
[0001.707] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0001.772] Kernel DTB Load Address: 0x83100000
[0001.777] Loading cboot binary
[0001.788] Verifying EBT in OdmNonSecureSBK mode
[0001.830] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.837] Bootloader downloaded successfully.
[0001.841] Next binary entry address: 0x92c00258
[0001.846] BoardId: 3448
[0001.850] Overriding pmu board id with proc board id
[0001.855] Display board id is not available
[0001.867] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.919] /bpmp deleted
[0001.921] SC7EntryFw header found loaded at 0xff700000
[0002.110] OVR2 PMIC
[0002.112] Bpmp FW successfully loaded
[0002.117] WB0 init successfully at 0xff780000
[0002.121] Set NvDecSticky Bits
[0002.124] GSC2 address ff53fffc value c0edbbcc
[0002.131] GSC MC Settings done
[0002.134] TOS Image length 53680
[0002.137] Monitor size 53680
[0002.140] OS size 0
[0002.145] Secure Os AES-CMAC Verification Success!
[0002.150] TOS image cipher info: plaintext
[0002.154] Loading and Validation of Secure OS Successful
[0002.170] SC7 Entry Firmware - 0xff700000, 0x4000
[0002.174] NvTbootPackSdramParams: start.
[0002.179] NvTbootPackSdramParams: done.
[0002.183] Tegraboot started after 132033 us
[0002.187] Basic modules init took 1772844 us
[0002.191] Sec Bootdevice Read Time = 953 ms, Read Size = 14457 KB
[0002.197] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0002.203] Next stage binary read took 7384 us
[0002.207] Carveout took -19260 us
[0002.210] CPU initialization took 343079 us
[0002.214] Total time taken by TegraBoot 2104047 us
[0002.219] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:39:57, Dec 9 2019
ERROR: Error initializing runtime service trusty_fast
[0002.341] RamCode = 0
[0002.346] LPDDR4 Training: Read DT: Number of tables = 2
[0002.351] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.363] EMC Training Successful
[0002.367] 408000 not found in DVFS table
[0002.373] RamCode = 0
[0002.376] DT Write: emc-table@204000 succeeded
[0002.382] DT Write: emc-table@1600000 succeeded
[0002.386] LPDDR4 Training: Write DT: Number of tables = 2
[0002.453]
[0002.454] Debug Init done
[0002.456] Marked DTB cacheable
[0002.459] Bootloader DTB loaded at 0x83000000
[0002.464] Marked DTB cacheable
[0002.467] Kernel DTB loaded at 0x83100000
[0002.471] DeviceTree Init done
[0002.487] Pinmux applied successfully
[0002.491] gicd_base: 0x50041000
[0002.494] gicc_base: 0x50042000
[0002.497] Interrupts Init done
[0002.501] Using base:0x60005090 & irq:208 for tick-timer
[0002.507] Using base:0x60005098 for delay-timer
[0002.511] platform_init_timer: DONE
[0002.515] Timer(tick) Init done
[0002.518] osc freq = 38400 khz
[0002.523]
[0002.524] Welcome to L4T Cboot
[0002.527]
[0002.528] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0002.533] calling constructors
[0002.536] initializing heap
[0002.538] initializing threads
[0002.541] initializing timers
[0002.544] creating bootstrap completion thread
[0002.549] top of bootstrap2()
[0002.551] CPU: ARM Cortex A57
[0002.554] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.559] initializing platform
[0002.613] Config for emmc ddr50 mode completed
[0002.617] sdmmc bdev is already initialized
[0002.621] Enable APE clock
[0002.624] Un-powergate APE partition
[0002.627] of_register: registering tegra_udc to of_hal
[0002.633] of_register: registering inv20628-driver to of_hal
[0002.638] of_register: registering ads1015-driver to of_hal
[0002.644] of_register: registering lp8557-bl-driver to of_hal
[0002.649] of_register: registering bq2419x_charger to of_hal
[0002.655] of_register: registering bq27441_fuel_gauge to of_hal
[0002.667] gpio framework initialized
[0002.670] of_register: registering tca9539_gpio to of_hal
[0002.675] of_register: registering tca9539_gpio to of_hal
[0002.681] of_register: registering i2c_bus_driver to of_hal
[0002.686] of_register: registering i2c_bus_driver to of_hal
[0002.692] of_register: registering i2c_bus_driver to of_hal
[0002.698] pmic framework initialized
[0002.701] of_register: registering max77620_pmic to of_hal
[0002.706] regulator framework initialized
[0002.710] of_register: registering tps65132_bl_driver to of_hal
[0002.716] initializing target
[0002.722] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0002.733] fixed regulator driver initialized
[0002.750] initializing OF layer
[0002.753] NCK carveout not present
[0002.757] Skipping dts_overrides
[0002.761] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.778] I2C Bus Init done
[0002.780] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.790] I2C Bus Init done
[0002.793] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.803] I2C Bus Init done
[0002.806] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.816] I2C Bus Init done
[0002.819] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.829] I2C Bus Init done
[0002.832] of_children_init: Ops found for compatible string maxim,max77620
[0002.842] max77620_init using irq 118
[0002.847] register ‘maxim,max77620’ pmic
[0002.852] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.858] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.868] I2C Bus Init done
[0002.872] NCK carveout not present
[0002.882] Find /i2c@7000c000’s alias i2c0
[0002.886] get eeprom at 1-a0, size 256, type 0
[0002.895] Find /i2c@7000c500’s alias i2c2
[0002.898] get eeprom at 3-a0, size 256, type 0
[0002.903] get eeprom at 3-ae, size 256, type 0
[0002.907] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.912] I2C slave not started
[0002.915] I2C write failed
[0002.918] Writing offset failed
[0002.921] eeprom_init: EEPROM read failed
[0002.925] pm_ids_update: eeprom init failed
[0002.929] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.959] pm_ids_update: The pm board id is 3448-0002-400
[0002.966] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.974] pm_ids_update: pm id update successful
[0002.978] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.984] I2C slave not started
[0002.987] I2C write failed
[0002.989] Writing offset failed
[0002.992] eeprom_init: EEPROM read failed
[0002.996] pm_ids_update: eeprom init failed
[0003.027] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.032] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.041] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.046] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.055] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:c2:54
[0003.061] Plugin Manager: Parse ODM data 0x00094000
[0003.072] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0003.096] Find /i2c@7000c000’s alias i2c0
[0003.100] get eeprom at 1-a0, size 256, type 0
[0003.109] Find /i2c@7000c500’s alias i2c2
[0003.113] get eeprom at 3-a0, size 256, type 0
[0003.117] get eeprom at 3-ae, size 256, type 0
[0003.121] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.127] I2C slave not started
[0003.130] I2C write failed
[0003.132] Writing offset failed
[0003.135] eeprom_init: EEPROM read failed
[0003.139] pm_ids_update: eeprom init failed
[0003.143] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.173] pm_ids_update: The pm board id is 3448-0002-400
[0003.180] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0003.187] pm_ids_update: pm id update successful
[0003.192] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.197] I2C slave not started
[0003.200] I2C write failed
[0003.202] Writing offset failed
[0003.206] eeprom_init: EEPROM read failed
[0003.209] pm_ids_update: eeprom init failed
[0003.240] Add serial number:1423019037777 as DT property
[0003.247] Applying platform configs
[0003.254] platform-init is not present. Skipping
[0003.259] calling apps_init()
[0003.275] Found 17 GPT partitions in “sdmmc3_user”
[0003.279] Proceeding to Cold Boot
[0003.282] starting app android_boot_app
[0003.286] Device state: unlocked
[0003.289] display console init
[0003.298] could not find regulator
[0003.301] hdmi cable connected
[0003.304] I2C slave not started
[0003.307] I2C write failed
[0003.310] Writing offset failed
[0003.313] could not read edid
[0003.317] tmds-config node not found
[0003.322] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0003.337] DT entry for leds-pwm not found
[0003.343] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0003.351] could not find regulator
[0003.354] could not find regulator
[0003.358] could not find regulator
[0003.386] using default cmu settings
[0003.390] dc_hdmi_enable, starting HDMI initialisation
[0003.396] dc_hdmi_enable, HDMI initialisation complete
[0003.401] list and configure display window
[0003.406] display console init completed
[0003.413] subnode volume_up is not found !
[0003.417] subnode back is not found !
[0003.421] subnode volume_down is not found !
[0003.425] subnode menu is not found !
[0003.428] Gpio keyboard init success
[0003.476] found decompressor handler: lz4-legacy
[0003.490] decompressing blob (type 1)…
[0003.524] load_bmp_blob: panelresolution=480 type=0
[0003.574] decompressor handler not found
[0003.578] load_firmware_blob: Firmware blob loaded, entries=2
[0003.584] -------> se_aes_verify_sbk_clear: 747
[0003.588] se_aes_verify_sbk_clear: Error
[0003.592] bl_battery_charging: connected to external power supply
[0003.600] xusb is supported
[0003.606] error while finding nvidia,portmap
[0004.110] xusb blob version 0 size 124416
[0004.114] firmware size 124416
[0004.119] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0004.134] xhci0: 64 bytes context size, 32-bit DMA
[0004.174] usbus0: 5.0Gbps Super Speed USB v3.0
[0004.194] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.844] uhub0: 9 ports with 9 removable, self powered
[0005.844] failed to get HID devices
[0005.847] failed to init xhci or no usb device attached
[0005.861] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0005.869] MSC Partition not found
[0005.878] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0005.886] USP partition read failed!
[0005.889] blob_init: blob-partition USP header read failed
[0005.895] android_boot Unable to update recovery partition
[0005.900] kfs_getpartname: name = LNX
[0005.904] Loading kernel from LNX
[0005.968] load kernel from storage
[0005.978] decompressor handler not found
[0005.997] Successfully loaded kernel and ramdisk images
[0006.004] load_bmp_blob: panelresolution=480 type=0
[0006.077] display bmp image done
[0006.080] NCK carveout not present
[0006.083] Skipping dts_overrides
[0006.086] NCK carveout not present
[0006.096] Find /i2c@7000c000’s alias i2c0
[0006.100] get eeprom at 1-a0, size 256, type 0
[0006.109] Find /i2c@7000c500’s alias i2c2
[0006.113] get eeprom at 3-a0, size 256, type 0
[0006.118] get eeprom at 3-ae, size 256, type 0
[0006.122] pm_ids_update: Updating 1,a0, size 256, type 0
[0006.127] I2C slave not started
[0006.130] I2C write failed
[0006.133] Writing offset failed
[0006.136] eeprom_init: EEPROM read failed
[0006.140] pm_ids_update: eeprom init failed
[0006.144] pm_ids_update: Updating 3,a0, size 256, type 0
[0006.174] pm_ids_update: The pm board id is 3448-0002-400
[0006.181] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0006.188] pm_ids_update: pm id update successful
[0006.193] pm_ids_update: Updating 3,ae, size 256, type 0
[0006.198] I2C slave not started
[0006.201] I2C write failed
[0006.204] Writing offset failed
[0006.207] eeprom_init: EEPROM read failed
[0006.211] pm_ids_update: eeprom init failed
[0006.241] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.247] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0006.255] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0006.261] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0006.270] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:c2:54
[0006.276] Plugin Manager: Parse ODM data 0x00094000
[0006.286] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.304] Add serial number:1423019037777 as DT property
[0006.313] “bpmp” doesn’t exist, creating
[0006.318] Updated bpmp info to DTB
[0006.323] Updated initrd info to DTB
[0006.327] “proc-board” doesn’t exist, creating
[0006.332] Updated board info to DTB
[0006.336] “pmu-board” doesn’t exist, creating
[0006.341] Updated board info to DTB
[0006.345] “display-board” doesn’t exist, creating
[0006.350] Updated board info to DTB
[0006.354] “reset” doesn’t exist, creating
[0006.358] Updated reset info to DTB
[0006.362] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1
[0006.400] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.416] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0006.432] Updated bootarg info to DTB
[0006.436] Adding uuid 000000016445c8800800000012048140 to DT
[0006.441] Adding eks info 0 to DT
[0006.447] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.453] Updated memory info to DTB
[0006.461] set vdd_core voltage to 1075 mv
[0006.465] setting ‘vdd-core’ regulator to 1075000 micro volts
[0006.484] Found secure-pmc; disable BPMP
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Failed to get idcodes
*** Warning - spi_flash_probe() failed, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Card did not respond to voltage select!
** Bad device mmc 1 **
Hit any key to stop autoboot: 1 … 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 74 ms (8.8 KiB/s)
1:.primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 201 ms (26 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 807 ms (40.4 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831776fe
Starting kernel …
[ 1.056096] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.191047] tegradc tegradc.0: hdmi: edid read failed [ 1.232614] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.232643] imx219 7-0010: board setup failed [ 1.256497] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.256531] imx219 8-0010: board setup failed [ 1.583791] cgroup: cgroup2: unknown option "nsdelegate" [ 2.608784] using random self ethernet address [ 2.613291] using random host ethernet address [ 2.887775] random: crng init done [ 2.891207] random: 7 urandom warning(s) missed due to ratelimiting [ 2.982581] using random self ethernet address [ 2.987088] using random host ethernet address [ 4.209991] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l:172. [ 4.218404] tegra_cec 70015000.tegra_cec: Sent res: -62. [ 4.225533] tegra_cec 70015000.tegra_cec: tegra_cec_init Done. [ 5.363372] Please complete system configuration setup on desktop to proceed... [ 14.078346] tegra_i2c_handle_xfer_error: 11 callbacks suppressed [ 14.078349] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50[/code]
Was there an HDMI monitor attached during the flash? If not, then give that a try in another flash. Basically it looks like the monitor is either missing or not a true HDMI monitor (the i2c query is looking for the monitor’s response to tell the video driver what its specs are, but the i2c bus is failing…VGA and some other adapters cut that wire).
I managed to make the system configuration with an script posted in another topic, right now i can ssh the nano but i still dont have any display.
This is my EEPROM:
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 01 00 fc 00 78 0d 02 00 04 46 00 00 00 00 00 00 ?.?.x??.?F…
10: 00 00 00 00 36 39 39 2d 31 33 34 34 38 2d 30 30 …699-13448-00
20: 30 32 2d 34 30 30 20 46 2e 30 00 00 00 00 00 00 02-400 F.0…
30: 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff …
40: ff ff ff ff 54 c2 e9 4b 04 00 31 34 32 33 30 31 …T??K?.142301
50: 39 30 33 37 37 37 37 00 00 00 00 00 00 00 00 00 9037777…
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
90: 00 00 00 00 00 00 4e 56 43 42 1c 00 4d 31 00 00 …NVCB?.M1…
a0: ff ff ff ff ff ff ff ff ff ff ff ff 54 c2 e9 4b …T??K
b0: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ?..
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5a …Z
and i get this on serial :
[ 7255.015585] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
Is this an actual HDMI monitor? What do you get from:
sudo -s
cat `find /sys -name edid`
exit
The EDID from the HDMI monitor query should show up there as hex data, but I doubt it will…the 0x50 address error seems to be from that query (but I am uncertain if that is the base address for the video controller…this could be a different controller, e.g., for a camera). Knowing what “/sys” thinks is the acid test…if EDID is present there, then you know the HDMI query is working (and you would then be able to move on to other testing, or confirm it is an HDMI configuration issue).
cat find /sys -name edidroot@localhost:~# cat find /sys -name edid
No EDID
00 ff ff ff ff ff ff 00 3a c4 01 00 00 00 00 00
05 1b 01 03 80 59 32 8c 0a e2 bd a1 5b 4a 98 24
15 47 4a 20 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 01 1d 00 72 51 d0 1e 20 6e 28
55 00 75 f2 31 00 00 1e 01 1d 00 bc 52 d0 1e 20
b8 28 55 40 75 f2 31 00 00 1e 00 00 00 fd 00 32
3d 0f 2e 08 00 0a 20 20 20 20 20 20 00 00 00 fc
00 4e 56 49 44 49 41 00 0a 20 20 20 20 20 01 f9
02 03 19 71 46 84 13 05 14 03 12 23 09 07 07 83
01 00 00 65 03 0c 00 10 00 01 1d 80 18 71 1c 16
20 58 2c 25 00 75 f2 31 00 00 9e 01 1d 80 d0 72
1c 16 20 10 2c 25 80 75 f2 31 00 00 9e 8c 0a d0
8a 20 e0 2d 10 10 3e 96 00 75 f2 31 00 00 18 8c
0a d0 90 20 40 31 20 0c 40 55 00 75 f2 31 00 00
18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca
This says there are two display controller configurations possible, that one controller has no EDID, and that the other controller has the EDID you pasted. Pasting that into http://www.edidreader.com verifies the checksum is valid. This latter monitor can work if nothing else gets in the way. i2c for query of that monitor is working.
This earlier log excerpt makes me believe the error is related to the unused display controller:
[ 4.218404] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -62.
One place to disable a controller is via the device tree. Is your device tree customized? Or the kernel?
Well I just found that the jetson nano module b02 is not compatible with dev kit carrier board A01 but I still don’t know if is hardware or software , is it posible to make it work ?
Someone else will need to answer that (I do not know for certain), but I suspect that anything listed as “incompatible” is due to hardware. If this were a simple case of rerouting certain wires which are configurable, then a new device tree would simply be put in place for that revision.
