I use latest eMMC version,and HDMI not working.
log shows edid read failed:
[0005.841] set vdd_core voltage to 1075 mv
[0005.845] setting ‘vdd-core’ regulator to 1075000 micro volts
[0005.869] could not find regulator
[0005.873] Found secure-pmc; disable BPMP
U-Boot 2016.07-gd917e08cec (Nov 05 2019 - 13:38:56 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
MMC: no card present
** Bad device mmc 1 **
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 83 ms (7.8 KiB/s)
L4T boot options
1: primary kernel
Enter choice:
not found
L4T boot options
1: primary kernel
Enter choice:
[0000.222] [TegraBoot] (version 00.00.2018.01-l4t-7da7a580)
[0000.227] Processing in cold boot mode Bootloader 2
[0000.231] A02 Bootrom Patch rev = 1023
[0000.235] Power-up reason: pmc por
[0000.238] No Battery Present
[0000.241] pmic max77620 reset reason
[0000.244] pmic max77620 NVERC : 0x50
[0000.248] RamCode = 0
[0000.250] Platform has DDR4 type RAM
[0000.253] max77620 disabling SD1 Remote Sense
[0000.257] Setting DDR voltage to 1125mv
[0000.261] Serial Number of Pmic Max77663: 0x81bf1
[0000.269] Entering ramdump check
[0000.272] Get RamDumpCarveOut = 0x0
[0000.275] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.280] Last reboot was clean, booting normally!
[0000.285] Sdram initialization is successful
[0000.289] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.295] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.301] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.307] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.313] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.319] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.324] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.330] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.346] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.352] Platform-DebugCarveout: 0
[0000.356] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.361] Non secure mode, and RB not enabled.
[0000.378] Csd NumOfBlocks=0
[0000.387] Using GPT Primary to query partitions
[0000.391] Loading Tboot-CPU binary
[0000.398] Verifying TBC in OdmNonSecureSBK mode
[0000.408] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.415] Bootloader downloaded successfully.
[0000.419] Downloaded Tboot-CPU binary to 0xa0000258
[0000.424] MAX77620_GPIO5 configured
[0000.427] CPU power rail is up
[0000.430] CPU clock enabled
[0000.434] Performing RAM repair
[0000.437] Updating A64 Warmreset Address to 0xa00002e9
[0000.442] Loading NvTbootBootloaderDTB
[0000.456] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.521] Bootloader DTB Load Address: 0x83000000
[0000.526] Loading NvTbootKernelDTB
[0000.540] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.604] Kernel DTB Load Address: 0x83100000
[0000.610] Loading cboot binary
[0000.625] Verifying EBT in OdmNonSecureSBK mode
[0000.668] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.675] Bootloader downloaded successfully.
[0000.681] Using BFS PT to query partitions
[0000.685] Next binary entry address: 0x92c00258
[0000.690] BoardId: 3448
[0000.694] Overriding pmu board id with proc board id
[0000.699] Display board id is not available
[0000.715] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.767] /bpmp deleted
[0000.769] SC7EntryFw header found loaded at 0xff700000
[0000.957] OVR2 PMIC
[0000.959] Bpmp FW successfully loaded
[0000.964] WB0 init successfully at 0xff780000
[0000.968] Set NvDecSticky Bits
[0000.972] GSC2 address ff53fffc value c0edbbcc
[0000.978] GSC MC Settings done
[0000.981] TOS Image length 53680
[0000.984] Monitor size 53680
[0000.987] OS size 0
[0000.993] Secure Os AES-CMAC Verification Success!
[0000.997] TOS image cipher info: plaintext
[0001.001] Loading and Validation of Secure OS Successful
[0001.017] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.021] NvTbootPackSdramParams: start.
[0001.027] NvTbootPackSdramParams: done.
[0001.030] Tegraboot started after 151490 us
[0001.034] Basic modules init took 569446 us
[0001.038] Sec Bootdevice Read Time = 57 ms, Read Size = 2292 KB
[0001.044] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.050] Next stage binary read took 11898 us
[0001.054] Carveout took -23600 us
[0001.057] CPU initialization took 346257 us
[0001.061] Total time taken by TegraBoot 904001 us
[0001.066] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 13:38:45, Nov 5 2019
ERROR: Error initializing runtime service trusty_fast
[0001.188] RamCode = 0
[0001.193] LPDDR4 Training: Read DT: Number of tables = 2
[0001.198] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.210] EMC Training Successful
[0001.213] 408000 not found in DVFS table
[0001.220] RamCode = 0
[0001.223] DT Write: emc-table@204000 succeeded
[0001.229] DT Write: emc-table@1600000 succeeded
[0001.233] LPDDR4 Training: Write DT: Number of tables = 2
[0001.271]
[0001.273] Debug Init done
[0001.275] Marked DTB cacheable
[0001.278] Bootloader DTB loaded at 0x83000000
[0001.283] Marked DTB cacheable
[0001.286] Kernel DTB loaded at 0x83100000
[0001.290] DeviceTree Init done
[0001.301] Pinmux applied successfully
[0001.305] gicd_base: 0x50041000
[0001.309] gicc_base: 0x50042000
[0001.312] Interrupts Init done
[0001.316] Using base:0x60005090 & irq:208 for tick-timer
[0001.321] Using base:0x60005098 for delay-timer
[0001.326] platform_init_timer: DONE
[0001.329] Timer(tick) Init done
[0001.333] osc freq = 38400 khz
[0001.337]
[0001.338] welcome to cboot
[0001.341]
[0001.342] Cboot Version: 00.00.2018.01-t210-21e03500
[0001.347] calling constructors
[0001.350] initializing heap
[0001.352] initializing threads
[0001.355] initializing timers
[0001.358] creating bootstrap completion thread
[0001.363] top of bootstrap2()
[0001.365] CPU: ARM Cortex A57
[0001.368] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.373] initializing platform
[0001.376] Scratch reg 37 & 271 initial value set…
[0001.383] cboot:secure-pmc present
[0001.432] config for ddr50 mode completed
[0001.436] sdmmc bdev is already initialized
[0001.440] Enable APE clock
[0001.443] Un-powergate APE partition
[0001.446] of_register: registering tegra_udc to of_hal
[0001.451] of_register: registering tegra_udc to of_hal
[0001.456] of_register: registering inv20628-driver to of_hal
[0001.462] of_register: registering ads1015-driver to of_hal
[0001.468] of_register: registering lp8557-bl-driver to of_hal
[0001.473] of_register: registering bq2419x_charger to of_hal
[0001.479] of_register: registering cpc to of_hal
[0001.484] of_register: registering bq27441_fuel_gauge to of_hal
[0001.495] gpio framework initialized
[0001.498] of_register: registering tca9539_gpio to of_hal
[0001.504] of_register: registering tca9539_gpio to of_hal
[0001.509] of_register: registering i2c_bus_driver to of_hal
[0001.515] of_register: registering i2c_bus_driver to of_hal
[0001.520] of_register: registering i2c_bus_driver to of_hal
[0001.526] of_register: registering i2c_bus_driver to of_hal
[0001.531] pmic framework initialized
[0001.535] of_register: registering max77620_pmic to of_hal
[0001.540] regulator framework initialized
[0001.544] of_register: registering tps65132_bl_driver to of_hal
[0001.550] initializing target
[0001.556] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.564] fixed regulator driver initialized
[0001.581] initializing OF layer
[0001.584] NCK carveout not present
[0001.588] Skipping dts_overrides
[0001.592] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.608] I2C Bus Init done
[0001.611] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.621] I2C Bus Init done
[0001.624] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.634] I2C Bus Init done
[0001.636] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.647] I2C Bus Init done
[0001.649] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.660] I2C Bus Init done
[0001.662] of_children_init: Ops found for compatible string maxim,max77620
[0001.672] max77620_init using irq 118
[0001.677] register ‘maxim,max77620’ pmic
[0001.682] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.688] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.698] I2C Bus Init done
[0001.702] NCK carveout not present
[0001.705] shim_invoke: No NCT, Calling dts updates
[0001.716] Find /i2c@7000c000’s alias i2c0
[0001.720] get eeprom at 1-a0, size 256, type 0
[0001.729] Find /i2c@7000c500’s alias i2c2
[0001.733] get eeprom at 3-a0, size 256, type 0
[0001.737] get eeprom at 3-ae, size 256, type 0
[0001.742] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.747] I2C slave not started
[0001.750] I2C write failed
[0001.752] Writing offset failed
[0001.756] eeprom_init: EEPROM read failed
[0001.759] pm_ids_update: eeprom init failed
[0001.764] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.794] pm_ids_update: The pm board id is 3448-0002-400
[0001.800] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0001.808] pm_ids_update: pm id update successful
[0001.812] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.818] I2C slave not started
[0001.821] I2C write failed
[0001.823] Writing offset failed
[0001.827] eeprom_init: EEPROM read failed
[0001.830] pm_ids_update: eeprom init failed
[0001.861] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.866] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.875] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.880] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.889] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:db:70
[0001.895] Plugin Manager: Parse ODM data 0x00094000
[0001.905] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0001.927] Find /i2c@7000c000’s alias i2c0
[0001.930] get eeprom at 1-a0, size 256, type 0
[0001.940] Find /i2c@7000c500’s alias i2c2
[0001.943] get eeprom at 3-a0, size 256, type 0
[0001.948] get eeprom at 3-ae, size 256, type 0
[0001.952] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.957] I2C slave not started
[0001.960] I2C write failed
[0001.963] Writing offset failed
[0001.966] eeprom_init: EEPROM read failed
[0001.970] pm_ids_update: eeprom init failed
[0001.974] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.004] pm_ids_update: The pm board id is 3448-0002-400
[0002.011] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.018] pm_ids_update: pm id update successful
[0002.022] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.028] I2C slave not started
[0002.031] I2C write failed
[0002.033] Writing offset failed
[0002.036] eeprom_init: EEPROM read failed
[0002.040] pm_ids_update: eeprom init failed
[0002.070] Chip UID is 0000000164456806080000000eff0200
[0002.075] Add serial number:142281901823100002ff as DT property
[0002.084] Applying platform configs
[0002.090] platform-init is not present. Skipping
[0002.095] calling apps_init()
[0002.111] Found 14 GPT partitions in “sdmmc3_user”
[0002.115] Proceeding to Cold Boot
[0002.118] starting app android_boot_app
[0002.122] Device state: unlocked
[0002.125] display console init
[0002.134] could not find regulator
[0002.157] hdmi cable not connected
[0002.160] is_hdmi_needed: HDMI not connected, returning false
[0002.166] hdmi is notDT entry for leds-pwm not found
[0002.174] connected
[0002.176] sor0 is not supported
[0002.179] display_console_init: no valid display out_type
[0002.187] subnode volume_up is not found !
[0002.191] subnode back is not found !
[0002.195] subnode volume_down is not found !
[0002.199] subnode menu is not found !
[0002.203] Gpio keyboard init success
[0002.249] found decompressor handler: lz4-legacy
[0002.264] decompressing blob (type 1)…
[0002.297] display_resolution: No display init
[0002.301] Failed to retrieve display resolution
[0002.306] Could not load/initialize BMP blob…ignoring
[0002.355] decompressor handler not found
[0002.359] load_firmware_blob: Firmware blob loaded, entries=2
[0002.365] se_aes_verify_sbk_clear: Error
[0002.369] bl_battery_charging: connected to external power supply
[0002.376] xusb is supported
[0002.382] error while finding nvidia,portmap
[0002.387] could not find regulator
[0002.891] xusb blob version 0 size 124416
[0002.895] firmware size 124416
[0002.899] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0002.908] xhci0: 64 bytes context size, 32-bit DMA
[0002.948] usbus0: 5.0Gbps Super Speed USB v3.0
[0002.968] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.618] uhub0: 9 ports with 9 removable, self powered
[0004.618] failed to get HID devices
[0004.622] failed to init xhci or no usb device attached
[0004.629] display_console_ioctl: No display init
[0004.633] switch_backlight failed
[0004.643] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0004.650] MSC Partition not found
[0004.660] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0004.667] USP partition read failed!
[0004.671] blob_init: blob-partition USP header read failed
[0004.676] android_boot Unable to update recovery partition
[0004.682] kfs_getpartname: name = LNX
[0004.685] Loading kernel from LNX
[0004.711] Verifying boot image in OdmNonSecureSBK mode
[0004.754] kernel load address: 0x80080000, size: 482032 bytes
[0004.760] ramdisk load address: 0x84100000, size: 0 bytes
[0004.765] load kernel from storage
[0004.775] decompressor handler not found
[0004.794] Successfully loaded kernel and ramdisk images
[0004.800] display_resolution: No display init
[0004.805] Failed to retrieve display resolution
[0004.809] bmp blob is not loaded and initialized
[0004.814] Failed to display boot-logo
[0004.817] NCK carveout not present
[0004.821] Skipping dts_overrides
[0004.824] NCK carveout not present
[0004.827] shim_invoke: No NCT, Calling dts updates
[0004.838] Find /i2c@7000c000’s alias i2c0
[0004.842] get eeprom at 1-a0, size 256, type 0
[0004.851] Find /i2c@7000c500’s alias i2c2
[0004.855] get eeprom at 3-a0, size 256, type 0
[0004.859] get eeprom at 3-ae, size 256, type 0
[0004.864] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.869] I2C slave not started
[0004.872] I2C write failed
[0004.874] Writing offset failed
[0004.877] eeprom_init: EEPROM read failed
[0004.881] pm_ids_update: eeprom init failed
[0004.886] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.916] pm_ids_update: The pm board id is 3448-0002-400
[0004.922] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0004.930] pm_ids_update: pm id update successful
[0004.934] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.940] I2C slave not started
[0004.943] I2C write failed
[0004.945] Writing offset failed
[0004.948] eeprom_init: EEPROM read failed
[0004.952] pm_ids_update: eeprom init failed
[0004.983] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.988] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.997] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.002] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.011] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:db:70
[0005.017] Plugin Manager: Parse ODM data 0x00094000
[0005.027] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.042] Add serial number:142281901823100002ff as DT property
[0005.052] “bpmp” doesn’t exist, creating
[0005.057] Updated bpmp info to DTB
[0005.062] Updated initrd info to DTB
[0005.065] “proc-board” doesn’t exist, creating
[0005.071] Updated board info to DTB
[0005.074] “pmu-board” doesn’t exist, creating
[0005.080] Updated board info to DTB
[0005.083] “display-board” doesn’t exist, creating
[0005.089] Updated board info to DTB
[0005.092] “reset” doesn’t exist, creating
[0005.097] Updated reset info to DTB
[0005.100] display_console_ioctl: No display init
[0005.105] display_console_ioctl: No display init
[0005.109] display_console_ioctl: No display init
[0005.114] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000
[0005.148] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.160] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.173] Updated bootarg info to DTB
[0005.177] Adding uuid 0000000164456806080000000eff0200 to DT
[0005.183] Adding eks info 0 to DT
[0005.188] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.194] Updated memory info to DTB
[0005.202] set vdd_core voltage to 1075 mv
[0005.206] setting ‘vdd-core’ regulator to 1075000 micro volts
[0005.228] could not find regulator
[0005.232] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1…
733 bytes read in 82 ms (7.8 KiB/s)
L4T boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
5562303 bytes read in 175 ms (30.3 MiB/s)
Retrieving file: /boot/Image
34179080 bytes read in 806 ms (40.4 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 0000000083177238
Starting kernel …
[ 1.053556] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.565001] Host read timeout at address 545c00c4 [ 1.600561] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.600575] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100 [ 1.613137] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.613143] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.618127] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.618131] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.623049] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.623053] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.627671] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.627675] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.627681] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.742641] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.748948] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.762240] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.768519] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.781806] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.788083] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.801364] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.807639] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.815907] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.823669] hpd: edid read prepare failed[ 1.848801] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.856338] imx219 7-0010: board setup failed [ 1.884757] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.892293] imx219 8-0010: board setup failed [ 2.280305] cgroup: cgroup2: unknown option "nsdelegate" [ 3.214220] using random self ethernet address [ 3.218822] using random host ethernet address [ 3.245424] using random self ethernet address [ 3.250106] using random host ethernet address [ 3.591642] random: crng init done [ 3.595049] random: 7 urandom warning(s) missed due to ratelimiting [ 6.049133] Please complete system configuration setup on /dev/ttyGS0 to proceed... [ 605.071753] edid invalid 0000.251] [TegraBoot] (version 00.00.2018.01-l4t-7da7a580) [0000.257] Processing in cold boot mode Bootloader 2 [0000.261] A02 Bootrom Patch rev = 1023 [0000.265] Power-up reason: pmc por [0000.268] No Battery Present [0000.271] pmic max77620 reset reason [0000.274] pmic max77620 NVERC : 0x50 [0000.277] RamCode = 0 [0000.280] Platform has DDR4 type RAM [0000.283] max77620 disabling SD1 Remote Sense [0000.287] Setting DDR voltage to 1125mv [0000.291] Serial Number of Pmic Max77663: 0x81bf1 [0000.299] Entering ramdump check [0000.302] Get RamDumpCarveOut = 0x0 [0000.305] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8 [0000.310] Last reboot was clean, booting normally! [0000.315] Sdram initialization is successful [0000.319] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000 [0000.325] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000 [0000.331] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000 [0000.337] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000 [0000.342] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000 [0000.348] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000 [0000.354] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000 [0000.360] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000 [0000.376] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000 [0000.382] Platform-DebugCarveout: 0 [0000.385] Nck Carveout Base=0x00000000ff080000 Size=0x00200000 [0000.391] Non secure mode, and RB not enabled. [0000.408] Csd NumOfBlocks=0 [0000.417] Using GPT Primary to query partitions [0000.421] Loading Tboot-CPU binary [0000.428] Verifying TBC in OdmNonSecureSBK mode [0000.438] Bootloader load address is 0xa0000000, entry address is 0xa0000258 [0000.445] Bootloader downloaded successfully. [0000.449] Downloaded Tboot-CPU binary to 0xa0000258 [0000.454] MAX77620_GPIO5 configured [0000.457] CPU power rail is up [0000.460] CPU clock enabled [0000.464] Performing RAM repair [0000.467] Updating A64 Warmreset Address to 0xa00002e9 [0000.472] Loading NvTbootBootloaderDTB [0000.486] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode [0000.551] Bootloader DTB Load Address: 0x83000000 [0000.556] Loading NvTbootKernelDTB [0000.570] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode [0000.634] Kernel DTB Load Address: 0x83100000 [0000.640] Loading cboot binary [0000.655] Verifying EBT in OdmNonSecureSBK mode [0000.698] Bootloader load address is 0x92c00000, entry address is 0x92c00258 [0000.705] Bootloader downloaded successfully. [0000.711] Using BFS PT to query partitions [0000.715] Next binary entry address: 0x92c00258 [0000.720] BoardId: 3448 [0000.724] Overriding pmu board id with proc board id [0000.729] Display board id is not available [0000.745] Verifying SC7EntryFw in OdmNonSecureSBK mode [0000.797] /bpmp deleted [0000.799] SC7EntryFw header found loaded at 0xff700000 [0000.987] OVR2 PMIC [0000.989] Bpmp FW successfully loaded [0000.994] WB0 init successfully at 0xff780000 [0000.998] Set NvDecSticky Bits [0001.002] GSC2 address ff53fffc value c0edbbcc [0001.008] GSC MC Settings done [0001.011] TOS Image length 53680 [0001.014] Monitor size 53680 [0001.017] OS size 0 [0001.023] Secure Os AES-CMAC Verification Success! [0001.027] TOS image cipher info: plaintext [0001.031] Loading and Validation of Secure OS Successful [0001.047] SC7 Entry Firmware - 0xff700000, 0x4000 [0001.052] NvTbootPackSdramParams: start. [0001.057] NvTbootPackSdramParams: done. [0001.061] Tegraboot started after 181841 us [0001.065] Basic modules init took 569803 us [0001.069] Sec Bootdevice Read Time = 57 ms, Read Size = 2292 KB [0001.074] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB [0001.080] Next stage binary read took 11903 us [0001.084] Carveout took -23602 us [0001.087] CPU initialization took 346511 us [0001.091] Total time taken by TegraBoot 904615 us[0001.096] Starting CPU & Halting co-processor
[0001.218] RamCode = 0
[0001.223] LPDDR4 Training: Read DT: Number of tables = 2
[0001.228] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.240] EMC Training Successful
[0001.244] 408000 not found in DVFS table
[0001.250] RamCode = 0
[0001.253] DT Write: emc-table@204000 succeeded
[0001.259] DT Write: emc-table@1600000 succeeded
[0001.263] LPDDR4 Training: Write DT: Number of tables = 2
[0001.302]
[0001.304] Debug Init done
[0001.306] Marked DTB cacheable
[0001.309] Bootloader DTB loaded at 0x83000000
[0001.314] Marked DTB cacheable
[0001.317] Kernel DTB loaded at 0x83100000
[0001.321] DeviceTree Init done
[0001.332] Pinmux applied successfully
[0001.336] gicd_base: 0x50041000
[0001.340] gicc_base: 0x50042000
[0001.343] Interrupts Init done
[0001.347] Using base:0x60005090 & irq:208 for tick-timer
[0001.352] Using base:0x60005098 for delay-timer
[0001.357] platform_init_timer: DONE
[0001.360] Timer(tick) Init done
[0001.364] osc freq = 38400 khz
[0001.368]
[0001.369] welcome to cboot
[0001.372]
[0001.373] Cboot Version: 00.00.2018.01-t210-21e03500
[0001.378] calling constructors
[0001.381] initializing heap
[0001.383] initializing threads
[0001.386] initializing timers
[0001.389] creating bootstrap completion thread
[0001.394] top of bootstrap2()
[0001.396] CPU: ARM Cortex A57
[0001.399] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.404] initializing platform
[0001.407] Scratch reg 37 & 271 initial value set…
[0001.413] cboot:secure-pmc present
[0001.463] config for ddr50 mode completed
[0001.467] sdmmc bdev is already initialized
[0001.471] Enable APE clock
[0001.474] Un-powergate APE partition
[0001.477] of_register: registering tegra_udc to of_hal
[0001.482] of_register: registering tegra_udc to of_hal
[0001.487] of_register: registering inv20628-driver to of_hal
[0001.493] of_register: registering ads1015-driver to of_hal
[0001.499] of_register: registering lp8557-bl-driver to of_hal
[0001.504] of_register: registering bq2419x_charger to of_hal
[0001.510] of_register: registering cpc to of_hal
[0001.514] of_register: registering bq27441_fuel_gauge to of_hal
[0001.526] gpio framework initialized
[0001.529] of_register: registering tca9539_gpio to of_hal
[0001.535] of_register: registering tca9539_gpio to of_hal
[0001.540] of_register: registering i2c_bus_driver to of_hal
[0001.546] of_register: registering i2c_bus_driver to of_hal
[0001.551] of_register: registering i2c_bus_driver to of_hal
[0001.557] of_register: registering i2c_bus_driver to of_hal
[0001.562] pmic framework initialized
[0001.566] of_register: registering max77620_pmic to of_hal
[0001.571] regulator framework initialized
[0001.575] of_register: registering tps65132_bl_driver to of_hal
[0001.581] initializing target
[0001.587] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.595] fixed regulator driver initialized
[0001.612] initializing OF layer
[0001.615] NCK carveout not present
[0001.619] Skipping dts_overrides
[0001.623] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.639] I2C Bus Init done
[0001.642] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.652] I2C Bus Init done
[0001.655] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.665] I2C Bus Init done
[0001.668] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.678] I2C Bus Init done
[0001.680] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.691] I2C Bus Init done
[0001.693] of_children_init: Ops found for compatible string maxim,max77620
[0001.704] max77620_init using irq 118
[0001.708] register ‘maxim,max77620’ pmic
[0001.713] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.719] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.729] I2C Bus Init done
[0001.733] NCK carveout not present
[0001.736] shim_invoke: No NCT, Calling dts updates
[0001.747] Find /i2c@7000c000’s alias i2c0
[0001.751] get eeprom at 1-a0, size 256, type 0
[0001.760] Find /i2c@7000c500’s alias i2c2
[0001.764] get eeprom at 3-a0, size 256, type 0
[0001.768] get eeprom at 3-ae, size 256, type 0
[0001.773] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.778] I2C slave not started
[0001.781] I2C write failed
[0001.784] Writing offset failed
[0001.787] eeprom_init: EEPROM read failed
[0001.791] pm_ids_update: eeprom init failed
[0001.795] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.825] pm_ids_update: The pm board id is 3448-0002-400
[0001.832] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0001.839] pm_ids_update: pm id update successful
[0001.844] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.849] I2C slave not started
[0001.852] I2C write failed
[0001.855] Writing offset failed
[0001.858] eeprom_init: EEPROM read failed
[0001.862] pm_ids_update: eeprom init failed
[0001.892] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.898] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.906] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.912] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.920] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:db:70
[0001.926] Plugin Manager: Parse ODM data 0x00094000
[0001.936] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0001.958] Find /i2c@7000c000’s alias i2c0
[0001.962] get eeprom at 1-a0, size 256, type 0
[0001.970] Find /i2c@7000c500’s alias i2c2
[0001.974] get eeprom at 3-a0, size 256, type 0
[0001.979] get eeprom at 3-ae, size 256, type 0
[0001.983] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.988] I2C slave not started
[0001.991] I2C write failed
[0001.994] Writing offset failed
[0001.997] eeprom_init: EEPROM read failed
[0002.001] pm_ids_update: eeprom init failed
[0002.005] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.035] pm_ids_update: The pm board id is 3448-0002-400
[0002.042] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.049] pm_ids_update: pm id update successful
[0002.053] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.059] I2C slave not started
[0002.061] I2C write failed
[0002.064] Writing offset failed
[0002.067] eeprom_init: EEPROM read failed
[0002.071] pm_ids_update: eeprom init failed
[0002.101] Chip UID is 0000000164456806080000000eff0200
[0002.106] Add serial number:142281901823100002ff as DT property
[0002.115] Applying platform configs
[0002.121] platform-init is not present. Skipping
[0002.126] calling apps_init()
[0002.141] Found 14 GPT partitions in “sdmmc3_user”
[0002.146] Proceeding to Cold Boot
[0002.149] starting app android_boot_app
[0002.153] Device state: unlocked
[0002.156] display console init
[0002.165] could not find regulator
[0002.168] hdmi cable connected
[0002.183] edid read success
[0002.1[0002.202] DT entry for leds-pwm not found
99] edid read success
[0002.208] width = 640, height = 480, frequency = 25174825
[0002.214] width = 640, height = 480, frequency = 25174825
[0002.219] width = 640, height = 480, frequency = 25174825
[0002.224] width = 640, height = 480, frequency = 25174825
[0002.230] width = 2560, height = 1440, frequency = 241500000
[0002.235] width = 1920, height = 1080, frequency = 148500000
[0002.241] width = 1920, height = 1080, frequency = 148351648
[0002.247] width = 1920, height = 1080, frequency = 148351648
[0002.252] width = 1280, height = 720, frequency = 74175824
[0002.258] width = 1280, height = 720, frequency = 74175824
[0002.263] width = 720, height = 480, frequency = 26973026
[0002.269] width = 720, height = 576, frequency = 26973026
[0002.274] width = 720, height = 480, frequency = 26973026
[0002.279] width = 720, height = 576, frequency = 26973026
[0002.285] width = 640, height = 480, frequency = 25174825
[0002.290] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.298] tmds-config node not found
[0002.302] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.317] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.324] could not find regulator
[0002.328] could not find regulator
[0002.331] could not find regulator
[0002.359] using default cmu settings
[0002.363] dc_hdmi_enable, starting HDMI initialisation
[0002.369] dc_hdmi_enable, HDMI initialisation complete
[0002.374] list and configure display window
[0002.383] display console init completed
[0002.394] subnode volume_up is not found !
[0002.398] subnode back is not found !
[0002.401] subnode volume_down is not found !
[0002.406] subnode menu is not found !
[0002.409] Gpio keyboard init success
[0002.456] found decompressor handler: lz4-legacy
[0002.470] decompressing blob (type 1)…
[0002.506] load_bmp_blob: panelresolution=1080 type=3
[0002.555] decompressor handler not found
[0002.559] load_firmware_blob: Firmware blob loaded, entries=2
[0002.564] se_aes_verify_sbk_clear: Error
[0002.568] bl_battery_charging: connected to external power supply
[0002.576] xusb is supported
[0002.582] error while finding nvidia,portmap
[0002.587] could not find regulator
[0003.090] xusb blob version 0 size 124416
[0003.094] firmware size 124416
[0003.099] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.109] xhci0: 64 bytes context size, 32-bit DMA
[0003.149] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.169] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.819] uhub0: 9 ports with 9 removable, self powered
[0004.819] failed to get HID devices
[0004.822] failed to init xhci or no usb device attached
[0004.836] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0004.844] MSC Partition not found
[0004.853] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0004.861] USP partition read failed!
[0004.864] blob_init: blob-partition USP header read failed
[0004.870] android_boot Unable to update recovery partition
[0004.875] kfs_getpartname: name = LNX
[0004.879] Loading kernel from LNX
[0004.904] Verifying boot image in OdmNonSecureSBK mode
[0004.948] kernel load address: 0x80080000, size: 482032 bytes
[0004.953] ramdisk load address: 0x84100000, size: 0 bytes
[0004.959] load kernel from storage
[0004.968] decompressor handler not found
[0004.988] Successfully loaded kernel and ramdisk images
[0004.994] load_bmp_blob: panelresolution=1080 type=3
[0005.492] display bmp image done
[0005.495] NCK carveout not present
[0005.498] Skipping dts_overrides
[0005.501] NCK carveout not present
[0005.504] shim_invoke: No NCT, Calling dts updates
[0005.516] Find /i2c@7000c000’s alias i2c0
[0005.520] get eeprom at 1-a0, size 256, type 0
[0005.528] Find /i2c@7000c500’s alias i2c2
[0005.532] get eeprom at 3-a0, size 256, type 0
[0005.537] get eeprom at 3-ae, size 256, type 0
[0005.541] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.546] I2C slave not started
[0005.549] I2C write failed
[0005.552] Writing offset failed
[0005.555] eeprom_init: EEPROM read failed
[0005.559] pm_ids_update: eeprom init failed
[0005.563] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.593] pm_ids_update: The pm board id is 3448-0002-400
[0005.600] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0005.607] pm_ids_update: pm id update successful
[0005.612] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.617] I2C slave not started
[0005.620] I2C write failed
[0005.623] Writing offset failed
[0005.626] eeprom_init: EEPROM read failed
[0005.630] pm_ids_update: eeprom init failed
[0005.660] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.666] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.674] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.680] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.688] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:db:70
[0005.695] Plugin Manager: Parse ODM data 0x00094000
[0005.705] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.720] Add serial number:142281901823100002ff as DT property
[0005.729] “bpmp” doesn’t exist, creating
[0005.734] Updated bpmp info to DTB
[0005.739] Updated initrd info to DTB
[0005.743] “proc-board” doesn’t exist, creating
[0005.748] Updated board info to DTB
[0005.752] “pmu-board” doesn’t exist, creating
[0005.757] Updated board info to DTB
[0005.761] “display-board” doesn’t exist, creating
[0005.766] Updated board info to DTB
[0005.770] “reset” doesn’t exist, creating
[0005.774] Updated reset info to DTB
[0005.778] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb3000 is_hdmi_initialised=1
[0005.816] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.829] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.842] Updated bootarg info to DTB
[0005.846] Adding uuid 0000000164456806080000000eff0200 to DT
[0005.851] Adding eks info 0 to DT
[0005.857] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.863] Updated memory info to DTB
[0005.871] set vdd_core voltage to 1075 mv
[0005.875] setting ‘vdd-core’ regulator to 1075000 micro volts
[0005.899] could not find regulator
[0005.903] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1…
L4T boot options
1: primary kernel
5562303 bytes read in 176 ms (30.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb3000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
Starting kernel …
[ 1.269564] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.277148] imx219 7-0010: board setup failed [ 1.305573] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.313145] imx219 8-0010: board setup failed [ 1.315797] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.360648] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.366946] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100 [ 1.387693] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.394004] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.407309] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.413629] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.426986] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.433285] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.446534] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.452835] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.461192] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.582932] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.582936] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.587914] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.587916] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.592900] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.592903] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.597885] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.597887] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.597890] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.597894] hpd: edid read prepare failed [ 1.907723] cgroup: cgroup2: unknown option "nsdelegate" [ 2.858842] using random self ethernet address [ 2.863500] using random host ethernet address [ 2.895417] using random self ethernet address [ 2.900124] using random host ethernet address [ 3.140722] Please complete system configuration setup on desktop to proceed... [ 3.255887] random: crng init done [ 3.259322] random: 7 urandom warning(s) missed due to ratelimitinghowever, on uboot, it shows edid read successful
