I exported the dmesg shown as following:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3531) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb6000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc0fefd2000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb6000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29384(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3567872K/4159488K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 116480K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] boot misc1 0x90000000: expected 0x10000000
[ 0.000000] (comparison mask = 0xf8000000)
[ 0.000000] boot misc2 0x0: expected 0xf6e0f620
[ 0.000000] (comparison mask = 0xffffffff)
[ 0.000000] boot misc3 0xf5c1: expected 0x10000
[ 0.000000] PLL_D2 already enabled. Postponing set full defaults
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001519] Console: colour dummy device 80x25
[ 0.002462] console [tty0] enabled
[ 0.002487] kmemleak: Kernel memory leak detector disabled
[ 0.002517] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.002545] pid_max: default: 32768 minimum: 301
[ 0.003009] Security Framework initialized
[ 0.003243] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003263] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004523] ftrace: allocating 46802 entries in 183 pages
[ 0.176041] sched-energy: CPU device node has no sched-energy-costs
[ 0.176076] ASID allocator initialised with 65536 entries
[ 0.215645] tegra-id: chipid=22117.
[ 0.215696] tegra-id: opt_subrevision=0.
[ 0.215725] Tegra Speedo/IDDQ fuse revision 4
[ 0.215740] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.215756] Tegra: CPU Process ID 1, SoC Process ID 1, GPU Process ID 0
[ 0.215772] Tegra: CPU Speedo Value 2134, SoC Speedo Value 2038, GPU Speedo Value 2142
[ 0.215792] Tegra: CPU IDDQ Value 2668, SoC IDDQ Value 3036, GPU IDDQ Value 3755
[ 0.215825] Tegra Revision: A02 SKU: 0x8f CPU Process: 1 SoC Process: 1
[ 0.215851] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.215886] DTB Build time: Mar 15 2019 09:52:07
[ 0.265081] CPU1: Booted secondary processor [411fd071]
[ 0.296994] CPU2: Booted secondary processor [411fd071]
[ 0.328970] CPU3: Booted secondary processor [411fd071]
[ 0.329071] Brought up 4 CPUs
[ 0.329137] SMP: Total of 4 processors activated.
[ 0.329155] CPU features: detected feature: 32-bit EL0 Support
[ 0.329435] CPU: All CPU(s) started at EL2
[ 0.329466] alternatives: patching kernel code
[ 0.337854] devtmpfs: initialized
[ 0.372145] Initilizing CustomIPI irq domain
[ 0.372627] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.372673] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.384158] pinctrl core: initialized pinctrl subsystem
[ 0.384845] OS set in device tree is not L4T.
[ 0.385311] regulator-dummy: no parameters
[ 0.385607] Initializing plugin-manager
[ 0.385762] Plugin module not found
[ 0.385981] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.386520] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.387296] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.390568] NET: Registered protocol family 16
[ 0.392028] pstore: using zlib compression
[ 0.392784] console [pstore-1] enabled
[ 0.392801] pstore: Registered ramoops as persistent store backend
[ 0.392819] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.408240] cpuidle: using governor menu
[ 0.412295] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.413896] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.413941] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.416827] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.418431] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.419387] tegra_powergate_init: DONE
[ 0.419428] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.419465] DTB Build time: Mar 15 2019 09:52:07
[ 0.421189] Tegra reboot handler registered.
[ 0.425619] iommu: Adding device tegra-carveouts to group 0
[ 0.425767] platform tegra-carveouts: domain=ffffffc0f9b89f18 allocates as[0]=ffffffc0f9bac0a8
[ 0.426140] iommu: Adding device smmu_test to group 1
[ 0.426219] platform smmu_test: domain=ffffffc0f9b96198 allocates as[0]=ffffffc0f9bac110
[ 0.427051] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.427123] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.427210] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.427232] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.427265] mc-err: mcerr ops are set to t21x
[ 0.436939] iommu: Adding device 70090000.xusb to group 2
[ 0.437382] iommu: Adding device 70006000.serial to group 3
[ 0.437484] platform 70006000.serial: domain=ffffffc0f948b618 allocates as[0]=ffffffc0f9bac178
[ 0.437933] iommu: Adding device 70006040.serial to group 4
[ 0.438227] iommu: Adding device 70006200.serial to group 5
[ 0.438466] iommu: Adding device sound to group 6
[ 0.438529] platform sound: domain=ffffffc0f948bb58 allocates as[0]=ffffffc0f9bac1e0
[ 0.439121] iommu: Adding device 7000d400.spi to group 7
[ 0.439397] iommu: Adding device 7000d600.spi to group 8
[ 0.439687] iommu: Adding device 70410000.spi to group 9
[ 0.440014] iommu: Adding device 50000000.host1x to group 10
[ 0.440316] iommu: Adding device 54080000.vi to group 11
[ 0.440728] iommu: Adding device 54600000.isp to group 12
[ 0.441010] iommu: Adding device 54680000.isp to group 13
[ 0.441392] iommu: Adding device tegradc.0 to group 14
[ 0.441462] platform tegradc.0: domain=ffffffc0f94b0a98 allocates as[0]=ffffffc0f9bac248
[ 0.445728] platform tegradc.0: IOVA linear map 0x0000000092cb6000(800000)
[ 0.446142] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.446491] iommu: Adding device tegradc.1 to group 15
[ 0.446559] platform tegradc.1: domain=ffffffc0f94b0cd8 allocates as[0]=ffffffc0f9bac2b0
[ 0.450762] platform tegradc.1: IOVA linear map 0x0000000092cb6000(800000)
[ 0.451173] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.451438] iommu: Adding device 54340000.vic to group 16
[ 0.451677] iommu: Adding device 544c0000.nvenc to group 17
[ 0.451901] iommu: Adding device 54500000.tsec to group 18
[ 0.452114] iommu: Adding device 54100000.tsecb to group 19
[ 0.452327] iommu: Adding device 54480000.nvdec to group 20
[ 0.452571] iommu: Adding device 54380000.nvjpg to group 21
[ 0.453677] iommu: Adding device 546c0000.i2c to group 22
[ 0.454028] iommu: Adding device 57000000.gpu to group 23
[ 0.454098] platform 57000000.gpu: domain=ffffffc0f94dacd8 allocates as[0]=ffffffc0f9bac318
[ 0.454160] platform 57000000.gpu: domain=ffffffc0f94dacd8 allocates as[1]=ffffffc0f9bac380
[ 0.454225] platform 57000000.gpu: domain=ffffffc0f94dacd8 allocates as[2]=ffffffc0f9bac3e8
[ 0.454280] platform 57000000.gpu: domain=ffffffc0f94dacd8 allocates as[3]=ffffffc0f9bac450
[ 0.455188] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.455230] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.455259] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.455280] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.455296] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.505251] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.505284] tegra-pmc: Clear bootloader IO dpd settings
[ 0.505320] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.505400] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.505714] iommu: Adding device 70012000.se to group 24
[ 0.506511] iommu: Adding device 7000c000.i2c to group 25
[ 0.506781] iommu: Adding device 7000c400.i2c to group 26
[ 0.507055] iommu: Adding device 7000c500.i2c to group 27
[ 0.507329] iommu: Adding device 7000c700.i2c to group 28
[ 0.507632] iommu: Adding device 7000d000.i2c to group 29
[ 0.507904] iommu: Adding device 7000d100.i2c to group 30
[ 0.508223] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.508296] platform sdhci-tegra.0: domain=ffffffc0f954be58 allocates as[0]=ffffffc0f9bac4b8
[ 0.509194] iommu: Adding device 700d0000.xudc to group 32
[ 0.513834] vdd-ac-bat: 5000 mV
[ 0.514225] vdd-5v0-sys: 5000 mV
[ 0.515216] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.515302] vdd-5v0-hdmi: 5000 mV
[ 0.515723] vdd-1v8: 1800 mV
[ 0.516120] vdd-fan: supplied by vdd-5v0-sys
[ 0.516171] vdd-fan: 5000 mV
[ 0.516597] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.516673] vdd-usb-vbus: 5000 mV
[ 0.517263] vdd-usb-vbus2: 5000 mV
[ 0.545973] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548557] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.549023] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.557069] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.557482] SCSI subsystem initialized
[ 0.557718] libata version 3.00 loaded.
[ 0.558008] usbcore: registered new interface driver usbfs
[ 0.558080] usbcore: registered new interface driver hub
[ 0.558174] usbcore: registered new device driver usb
[ 0.562298] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.563738] random: fast init done
[ 0.568438] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.569753] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.572245] vdd-ddr-1v1: 1150 mV
[ 0.576297] vdd-pre-reg-1v35: 1350 mV
[ 0.580238] vdd-1v8: 1800 mV
[ 0.580521] vdd-1v8: Failed to create debugfs directory
[ 0.584237] avdd-sys-1v2: 1200 mV
[ 0.588242] vdd-pex-1v0: 1050 mV
[ 0.589033] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.589685] max77620-ldo3: at 3100 mV
[ 0.592239] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.592938] max77620-ldo5: at 3100 mV
[ 0.593609] max77620-ldo6: at 2800 mV
[ 0.596246] avdd-1v05-pll: 1050 mV
[ 0.600236] avdd-io-hdmi-dp: 1050 mV
[ 0.601872] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.602177] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.604403] max77620 4-003c: max77620 probe successful
[ 0.606691] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.607246] media: Linux media interface: v0.10
[ 0.607313] Linux video capture interface: v2.00
[ 0.608356] pps_core: LinuxPPS API ver. 1 registered
[ 0.608386] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.608429] PTP clock support registered
[ 0.611769] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.618052] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.618902] Advanced Linux Sound Architecture Driver Initialized.
[ 0.619582] Bluetooth: Core ver 2.22
[ 0.619649] NET: Registered protocol family 31
[ 0.619667] Bluetooth: HCI device and connection manager initialized
[ 0.619695] Bluetooth: HCI socket layer initialized
[ 0.619719] Bluetooth: L2CAP socket layer initialized
[ 0.619756] Bluetooth: SCO socket layer initialized
[ 0.621398] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.621436] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.621493] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.621519] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.624194] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.625647] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.625737] vdd-3v3-sys: 3300 mV
[ 0.626027] vdd-1v8: supplied by vdd-3v3-sys
[ 0.628303] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.628820] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.628874] vdd-3v3-sd: 3300 mV
[ 0.630122] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.630184] avdd-io-edp-1v05: 1050 mV
[ 0.630677] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.630762] vdd-usb-hub-en: 5000 mV
[ 0.632141] camchar: rtcpu character device driver loaded
[ 0.632927] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.634415] clocksource: Switched to clocksource arch_sys_counter
[ 0.675619] VFS: Disk quotas dquot_6.6.0
[ 0.675784] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.676321] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.676789] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.676840] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.677068] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.677093] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.677120] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.677170] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.677195] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.677226] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.677248] nvmap_page_pool_init: Total RAM pages: 1010752
[ 0.677265] nvmap_page_pool_init: nvmap page pool size: 126344 pages (493 MB)
[ 0.677374] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.677896] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.678980] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.687177] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.687564] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.687837] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.688081] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.688281] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.688583] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.688603] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.689047] NET: Registered protocol family 2
[ 0.690013] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.690250] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.690831] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.691014] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691113] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691537] NET: Registered protocol family 1
[ 0.692351] RPC: Registered named UNIX socket transport module.
[ 0.692382] RPC: Registered udp transport module.
[ 0.692399] RPC: Registered tcp transport module.
[ 0.692416] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.692441] PCI: CLS 0 bytes, default 64
[ 0.692698] Trying to unpack rootfs image as initramfs…
[ 0.701954] host1x 50000000.host1x: initialized
[ 0.703894] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.707273] audit: initializing netlink subsys (disabled)
[ 0.707401] audit: type=2000 audit(0.559:1): initialized
[ 0.708173] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.718300] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.719873] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.720700] 9p: Installing v9fs 9p2000 file system support
[ 0.724208] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.724383] io scheduler noop registered
[ 0.724696] io scheduler cfq registered (default)
[ 0.727681] gic 702f9000.agic: GIC IRQ controller registered
[ 0.730683] iommu: Adding device 702ef000.adsp to group 33
[ 0.737413] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.737635] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.738271] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x81e6c0b
[ 0.738304] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.739988] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.740119] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.740238] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.740444] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.740554] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.740660] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.740780] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.740893] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.741000] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.741110] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.747512] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.748838] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.750756] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.752086] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.752452] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.753699] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.753950] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.754224] Adding domain tsec-pd to PM domain host1x-pd
[ 0.756322] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.757561] tsec 54500000.tsec: initialized
[ 0.759255] tsec 54100000.tsecb: initialized
[ 0.760020] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.763356] nvdec 54480000.nvdec: initialized
[ 0.764476] Adding domain vic03-pd to PM domain host1x-pd
[ 0.764678] Adding domain msenc-pd to PM domain host1x-pd
[ 0.764860] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.768768] falcon 54340000.vic: initialized
[ 0.770021] falcon 544c0000.nvenc: initialized
[ 0.771362] falcon 54380000.nvjpg: initialized
[ 0.775996] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.776131] display board info: id 0x0, fab 0x0
[ 0.776209] generic_infoframe_type: 0x87
[ 0.776354] tegradc tegradc.0: DT parsed successfully
[ 0.776418] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 0.776996] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 0.779836] tegradc tegradc.0: probed
[ 0.785025] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.789943] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.791074] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 0.791132] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.791158] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 0.791183] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 0.791213] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.791295] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 0.791489] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.791925] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.791974] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 0.792100] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.792345] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.792386] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.792492] kfuse 7000fc00.kfuse: initialized
[ 0.792625] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[ 0.792693] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 0.793017] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.794390] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.795806] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.797452] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.797511] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.798052] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.799838] vdd-gpu: applied init 1000000uV constraint
[ 0.799881] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 0.800337] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.802625] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.802943] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.802992] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 0.803047] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 0.803085] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 0.803377] pci 0000:02:00.0: supports D1 D2
[ 0.803382] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.806209] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.806453] No Device Node present for smmu client: serial8250 !!
[ 0.806488] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.806573] iommu: Adding device serial8250 to group 35
[ 0.810321] console [ttyS0] disabled
[ 0.810619] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 0.818624] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 0.818756] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 0.818763] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 0.818768] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.818780] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[ 0.818815] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.818827] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 0.818843] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 0.818869] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 0.818895] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 0.818905] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.818909] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 0.818917] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 0.820514] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 0.820522] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.820533] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 0.820712] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 0.821053] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 0.821058] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.821064] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 0.821215] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.245481] console [ttyS0] enabled
[ 3.246164] Console: switching to colour frame buffer device 240x67
[ 3.246972] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.247357] serial-tegra 70006200.serial: RX in PIO mode
[ 3.247498] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.248491] [drm] Initialized
[ 3.268886] brd: module loaded
[ 3.280684] loop: module loaded
[ 3.280814] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.280940] tegra_profiler: auth: init
[ 3.282378] THERMAL EST: found 2 subdevs
[ 3.282385] THERMAL EST num_resources: 0
[ 3.282391] [THERMAL EST subdev 0]
[ 3.282445] [THERMAL EST subdev 1]
[ 3.282924] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.282926] THERMAL EST: thz register success.
[ 3.283096] THERMAL EST: end of probe, return err: 0
[ 3.284448] hisi_sas: driver version v1.6
[ 3.288753] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.295709] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.295717] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.302323] libphy: Fixed MDIO Bus: probed
[ 3.303101] tun: Universal TUN/TAP device driver, 1.6
[ 3.303107] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.304438] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 3.304441] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 3.304513] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.304515] igb: Copyright © 2007-2014 Intel Corporation.
[ 3.304568] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.304571] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 3.304628] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.304631] Copyright© 1999 - 2017 Intel Corporation.
[ 3.309842] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 3.309882] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.324077] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.324234] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e4:f2:c8 from device tree
[ 3.324861] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.324899] r8168 Copyright © 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.325513] PPP generic driver version 2.4.2
[ 3.325746] PPP BSD Compression module registered
[ 3.325753] PPP Deflate Compression module registered
[ 3.325793] PPP MPPE Compression module registered
[ 3.325800] NET: Registered protocol family 24
[ 3.325876] usbcore: registered new interface driver r8152
[ 3.325924] usbcore: registered new interface driver asix
[ 3.325988] usbcore: registered new interface driver ax88179_178a
[ 3.326035] usbcore: registered new interface driver cdc_ether
[ 3.326082] usbcore: registered new interface driver net1080
[ 3.326188] usbcore: registered new interface driver cdc_subset
[ 3.326229] usbcore: registered new interface driver zaurus
[ 3.326293] usbcore: registered new interface driver cdc_ncm
[ 3.326723] VFIO - User Level meta-driver version: 0.3
[ 3.328080] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.328105] ehci-pci: EHCI PCI platform driver
[ 3.328154] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.328194] ohci-pci: OHCI PCI platform driver
[ 3.328243] ohci-platform: OHCI generic platform driver
[ 3.331124] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.331725] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.332893] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f90a4400 id
[ 3.333012] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.333015] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.334352] usbcore: registered new interface driver uas
[ 3.334442] usbcore: registered new interface driver usb-storage
[ 3.334569] usbcore: registered new interface driver usbserial
[ 3.337821] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.339247] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.339261] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 3.339279] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 3.339304] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 3.339325] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 3.339993] mousedev: PS/2 mouse device common for all mice
[ 3.340076] usbcore: registered new interface driver xpad
[ 3.585161] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.597902] rtc rtc1: alarm rtc device
[ 3.597918] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.597943] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.598611] i2c /dev entries driver
[ 3.600566] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.624406] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.624484] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.624515] imx219 6-0010: board setup failed
[ 3.624614] imx219: probe of 6-0010 failed with error -121
[ 3.634090] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.675548] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.675552] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.676004] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.676018] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.676027] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.676199] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.676210] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.676216] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.676360] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.676370] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.676375] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.676555] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.677397] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.677453] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.677480] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.677496] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.677504] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.678452] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.678472] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.678666] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.678696] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 3.679147] parse_throttle_dt_data: Num cap clks = 6
[ 3.679153] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.679167] parse_throttle_dt_data: clk=gpu type=4
[ 3.679196] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.679216] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.679238] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.679241] parse_throttle_dt_data: clk=emc type=3
[ 3.680456] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.680563] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.680712] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.681504] FAN dev name: pwm-fan
[ 3.681557] FAN:gpio request success.
[ 3.681631] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.681934] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.682123] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.682132] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.682224] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.682229] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.682233] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.682237] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.682241] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.682245] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.682249] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.682253] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.682257] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.682261] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.682936] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.683297] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.684196] device-mapper: uevent: version 1.0.3
[ 3.684682] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.690057] tegra210-cpufreq cpufreq: probe()…completed
[ 3.690801] sdhci: Secure Digital Host Controller Interface driver
[ 3.690802] sdhci: Copyright© Pierre Ossman
[ 3.690803] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.691296] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.691644] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.691767] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.695213] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.695734] hidraw: raw HID events driver © Jiri Kosina
[ 3.696943] usbcore: registered new interface driver usbhid
[ 3.696944] usbhid: USB HID core driver
[ 3.715626] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.715943] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.717738] nvpmodel: initialized successfully
[ 3.718840] usbcore: registered new interface driver snd-usb-audio
[ 3.718901] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.718906] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.718924] iommu: Adding device snd-soc-dummy to group 36
[ 3.738529] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.756873] OPE platform probe
[ 3.756969] OPE platform probe successful
[ 3.757354] OPE platform probe
[ 3.757438] OPE platform probe successful
[ 3.782697] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.782830] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.782952] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.783080] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.783201] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.783323] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.783446] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.783572] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.783697] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.783822] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.796554] u32 classifier
[ 3.796555] Actions configured
[ 3.796628] Initializing XFRM netlink socket
[ 3.797372] NET: Registered protocol family 10
[ 3.798127] NET: Registered protocol family 17
[ 3.798139] NET: Registered protocol family 15
[ 3.798215] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.798260] Bluetooth: RFCOMM socket layer initialized
[ 3.798269] Bluetooth: RFCOMM ver 1.11
[ 3.798273] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.798277] Bluetooth: HIDP socket layer initialized
[ 3.798294] 9pnet: Installing 9P2000 support
[ 3.798327] Key type dns_resolver registered
[ 3.800725] Registered cp15_barrier emulation handler
[ 3.800769] Registered setend emulation handler
[ 3.801863] registered taskstats version 1
[ 3.802534] Adding domain ve2-pd to PM domain host1x-pd
[ 3.802777] Adding domain ve-pd to PM domain host1x-pd
[ 3.907086] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.413371] tegradc tegradc.0: fb registered
[ 4.423977] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 4.431229] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 4.439652] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 4.446804] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 4.454121] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.460234] Extcon AUX1(HDMI) enable
[ 4.464242] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.470664] tegradc tegradc.1: No lt-data, using default setting
[ 4.470696] edid invalid
[ 4.479214] tegradc tegradc.1: No hpd-gpio in DT
[ 4.483850] tegradc tegradc.1: DT parsed successfully
[ 4.488922] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 4.496998] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.497058] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 4.516713] tegradc tegradc.1: probed
[ 4.534889] tegradc tegradc.1: fb registered
[ 4.542299] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.547582] isp 54600000.isp: initialized
[ 4.548372] isp 54680000.isp: initialized
[ 4.557571] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.560092] clk_cbus_recalc_rate: no gbus parent
[ 4.560096] clk_cbus_round_rate: no gbus parent
[ 4.560098] clk_cbus_round_rate: no gbus parent
[ 4.560105] clk_cbus_recalc_rate: no gbus parent
[ 4.560206] clk_cbus_recalc_rate: no gbus parent
[ 4.560209] clk_cbus_round_rate: no gbus parent
[ 4.560210] clk_cbus_round_rate: no gbus parent
[ 4.560213] clk_cbus_recalc_rate: no gbus parent
[ 4.560904] tegra_dvfs: GPU-cap: registered
[ 4.560959] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.560960] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.560962] tegra dvfs: vdd-gpu: nominal 1038mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.563195] tegra_dvfs: vdd-gpu-vts: registered
[ 4.564215] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 4.564663] mmc0: hw tuning done …
[ 4.564693] mmc0: new ultra high speed SDR104 SDHC card at address 0001
[ 4.564841] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 4.564993] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 4.565370] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.571382] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 4.597374] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:28 UTC (946688428)
[ 4.598339] vi 54080000.vi: vi_probe: ++
[ 4.602195] vi 54080000.vi: initialized
[ 4.604772] vi 54080000.vi: subdev nvcsi–1 bound
[ 4.604990] mmcblk mmc0:0001: Card claimed for testing.
[ 4.606198] Disable partitions left on by BL
[ 4.606200] disb
[ 4.606248] bwmgr: missing cdev-type property
[ 4.606348] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.606354] DRAM derating cdev registered.
[ 4.607351] vdd-1v8: disabling
[ 4.607353] vdd-fan: disabling
[ 4.607355] vdd-usb-vbus: disabling
[ 4.607356] vdd-usb-vbus2: disabling
[ 4.607366] avdd-io-edp-1v05: disabling
[ 4.607367] vdd-usb-hub-en: disabling
[ 4.607530] ALSA device list:
[ 4.607532] #0: tegra-hda at 0x70038000 irq 83
[ 4.607534] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.764395] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.764416] tegradc tegradc.0: blank - powerdown
[ 4.799166] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 4.799167] Extcon AUX1(HDMI) disable
[ 4.827311] tegradc tegradc.0: unblank
[ 4.864832] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 4.864881] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 4.865867] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 4.865871] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 4.869095] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.869096] Extcon AUX1(HDMI) enable
[ 4.869358] tegradc tegradc.0: sync windows ret = 250
[ 4.972989] tegradc tegradc.1: blank - powerdown
[ 4.979850] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 4.979851] Extcon DP: HPD disabled
[ 4.979853] hpd: hpd_switch 0
[ 4.979860] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.979872] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 4.979876] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.026225] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 5.026226] Extcon HDMI: HPD enabled
[ 5.026236] tegradc tegradc.0: hdmi: plugged
[ 7.126460] EXT4-fs (mmcblk0p1): recovery complete
[ 7.141489] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.151687] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.163405] devtmpfs: mounted
[ 7.171534] Freeing unused kernel memory: 8512K
[ 7.365486] systemd[1]: System time before build time, advancing clock.
[ 7.402986] ip_tables: © 2000-2006 Netfilter Core Team
[ 7.421523] cgroup: cgroup2: unknown option “nsdelegate”
[ 7.443164] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 7.469952] systemd[1]: Detected architecture arm64.
[ 7.509819] systemd[1]: Set hostname to .
[ 7.587847] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 7.607294] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 7.727291] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.738128] systemd[1]: Created slice User and Session Slice.
[ 7.749272] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.760298] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.774997] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.784226] systemd[1]: Reached target Swap.
[ 7.793731] systemd[1]: Reached target User and Group Name Lookups.
[ 7.805420] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.929732] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.971135] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 8.205549] systemd-journald[1962]: Received request to flush runtime journal from PID 1
[ 8.588962] using random self ethernet address
[ 8.595421] using random host ethernet address
[ 8.622589] Mass Storage Function, version: 2009/09/11
[ 8.622596] LUN: removable file: (no medium)
[ 8.634836] using random self ethernet address
[ 8.650658] using random host ethernet address
[ 8.674253] rndis0: HOST MAC f6:69:03:59:90:58
[ 8.674310] rndis0: MAC f6:69:03:59:90:59
[ 8.674844] usb0: HOST MAC f6:69:03:59:90:5a
[ 8.674867] usb0: MAC f6:69:03:59:90:5b
[ 8.674896] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.896534] l4tbr0: port 1(rndis0) entered blocking state
[ 8.896569] l4tbr0: port 1(rndis0) entered disabled state
[ 8.897064] device rndis0 entered promiscuous mode
[ 8.911611] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 8.916195] l4tbr0: port 2(usb0) entered blocking state
[ 8.916200] l4tbr0: port 2(usb0) entered disabled state
[ 8.916338] device usb0 entered promiscuous mode
[ 8.923698] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.923705] l4tbr0: port 2(usb0) entered blocking state
[ 8.923708] l4tbr0: port 2(usb0) entered forwarding state
[ 9.151052] random: crng init done
[ 9.156011] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.628385] tegra-xusb 70090000.xusb: cannot find firmware…retry after 1 second
[ 9.682482] l4tbr0: port 2(usb0) entered disabled state
[ 9.798089] nvs_dsm nvs_dsm: dsm_probe
[ 9.798115] nvs_dsm nvs_dsm: dsm_remove
[ 9.798118] nvs_dsm nvs_dsm: dsm_probe done
[ 10.274496] Intel® Wireless WiFi driver for Linux
[ 10.274500] Copyright© 2003- 2015 Intel Corporation
[ 10.274729] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 10.286387] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 10.298438] iwlwifi 0000:01:00.0: Falling back to user helper
[ 10.649452] tegra-xusb 70090000.xusb: Firmware timestamp: 2017-11-03 13:36:19 UTC, Version: 50.20 release
[ 10.649494] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 10.649517] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 10.650389] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 10.650483] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 10.650647] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 10.650653] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.650656] usb usb1: Product: xHCI Host Controller
[ 10.650659] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 10.650662] usb usb1: SerialNumber: 70090000.xusb
[ 10.651116] hub 1-0:1.0: USB hub found
[ 10.651151] hub 1-0:1.0: 5 ports detected
[ 10.651595] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 10.651605] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 10.651679] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 10.651751] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 10.651755] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.651758] usb usb2: Product: xHCI Host Controller
[ 10.651760] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 10.651763] usb usb2: SerialNumber: 70090000.xusb
[ 10.652173] hub 2-0:1.0: USB hub found
[ 10.652239] hub 2-0:1.0: 4 ports detected
[ 10.682084] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.686604] eth0: 0xffffff800a2fe000, 00:04:4b:e4:f2:c8, IRQ 404
[ 10.754602] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 10.754661] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 10.754868] usb usb2: usb_suspend_both: status 0
[ 10.756439] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.978517] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 11.017595] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 11.017602] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.017605] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 11.017608] usb 1-2: Manufacturer: Generic
[ 11.018946] hub 1-2:1.0: USB hub found
[ 11.020043] hub 1-2:1.0: 4 ports detected
[ 11.123484] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 11.146469] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 11.158644] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 11.158650] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 11.158654] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 11.158656] usb 2-1: Manufacturer: Generic
[ 11.162942] hub 2-1:1.0: USB hub found
[ 11.165509] hub 2-1:1.0: 4 ports detected
[ 11.166500] usb 1-2: usb_suspend_both: status 0
[ 11.266714] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 11.277595] iwlwifi 0000:01:00.0: Falling back to user helper
[ 11.278441] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 11.296766] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 11.296774] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 11.334464] usb 2-1: usb_suspend_both: status 0
[ 11.462502] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 11.462535] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 11.475212] iwlwifi 0000:01:00.0: Falling back to user helper
[ 11.488198] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 11.499181] iwlwifi 0000:01:00.0: Falling back to user helper
[ 11.553804] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 11.583568] usb 2-1-port1: over-current condition
[ 11.613613] iwlwifi 0000:01:00.0: Detected Intel® Dual Band Wireless AC 8265, REV=0x230
[ 11.616458] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 11.617645] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 11.706582] usb 1-2-port1: over-current condition
[ 11.741169] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 11.742063] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 11.748810] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 11.797025] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.799826] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 11.800335] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 11.807619] usb 2-1-port2: over-current condition
[ 11.920718] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 11.920978] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 11.926540] usb 1-2-port2: over-current condition
[ 11.984866] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.031683] usb 2-1-port1: over-current condition
[ 12.150733] usb 1-2-port1: over-current condition
[ 12.203727] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 12.251614] usb 2-1-port2: over-current condition
[ 12.314607] tegradc tegradc.0: blank - powerdown
[ 12.367005] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 12.367007] Extcon AUX1(HDMI) disable
[ 12.386551] tegradc tegradc.0: unblank
[ 12.398506] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 12.398574] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 12.399593] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 12.399600] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 12.402848] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 12.402849] Extcon AUX1(HDMI) enable
[ 12.408769] tegradc tegradc.0: unblank
[ 12.408778] tegradc tegradc.1: blank - powerdown
[ 12.471600] usb 2-1-port1: over-current condition
[ 12.590598] usb 1-2-port1: over-current condition
[ 12.691583] usb 2-1-port2: over-current condition
[ 12.814581] usb 1-2-port2: over-current condition
[ 12.915588] usb 2-1-port1: over-current condition
[ 13.152022] fuse init (API version 7.26)
[ 13.910744] usb 1-2-port1: over-current condition
[ 14.367423] tegradc tegradc.0: blank - powerdown
[ 14.439904] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 14.439912] Extcon AUX1(HDMI) disable
[ 14.453936] tegradc tegradc.0: unblank
[ 14.460092] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 14.460167] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 14.461170] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 14.461177] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 14.464430] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 14.464432] Extcon AUX1(HDMI) enable
[ 14.464977] tegradc tegradc.0: unblank
[ 14.464985] tegradc tegradc.1: blank - powerdown
[ 15.485085] wlan0: authenticate with c0:25:e9:3a:0a:de
[ 15.495013] wlan0: send auth to c0:25:e9:3a:0a:de (try 1/3)
[ 15.500068] wlan0: authenticated
[ 15.502470] wlan0: associate with c0:25:e9:3a:0a:de (try 1/3)
[ 15.503401] wlan0: RX AssocResp from c0:25:e9:3a:0a:de (capab=0x1011 status=0 aid=12)
[ 15.505155] wlan0: associated
[ 15.526948] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.730544] usb 1-2-port2: over-current condition
[ 23.467024] usb 1-2-port1: over-current condition
[ 23.686962] usb 1-2-port2: over-current condition
[ 31.495021] usb 1-2-port2: over-current condition
[ 35.611070] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 35.635988] usb 1-2.3: New USB device found, idVendor=05ac, idProduct=0220
[ 35.636061] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 35.636104] usb 1-2.3: Product: 66EC-S
[ 35.636142] usb 1-2.3: Manufacturer: CATEX TECH.
[ 35.636178] usb 1-2.3: SerialNumber: CA2017120001
[ 35.645240] input: CATEX TECH. 66EC-S as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:05AC:0220.0001/input/input2
[ 35.708507] apple 0003:05AC:0220.0001: input,hidraw0: USB HID v1.10 Keyboard [CATEX TECH. 66EC-S] on usb-70090000.xusb-2.3/input0
[ 35.709917] apple 0003:05AC:0220.0002: hidraw1: USB HID v1.00 Device [CATEX TECH. 66EC-S] on usb-70090000.xusb-2.3/input1
[ 35.714509] input: CATEX TECH. 66EC-S as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.2/0003:05AC:0220.0003/input/input3
[ 35.777654] apple 0003:05AC:0220.0003: input,hidraw2: USB HID v1.10 Keyboard [CATEX TECH. 66EC-S] on usb-70090000.xusb-2.3/input2
[ 37.307585] usb 1-2-port1: over-current condition
[ 44.679154] usb 1-2-port1: over-current condition
[ 47.061642] usb 1-2.3: USB disconnect, device number 4
[ 48.915397] usb 1-2-port1: over-current condition
[ 50.564424] usb 2-1-port1: over-current condition
[ 57.380800] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 57.380840] Extcon AUX1(HDMI) disable
[ 57.398516] tegradc tegradc.0: blank - powerdown
[ 57.398592] extcon-disp-state extcon:disp-state: cable 40 state 0
[ 57.398595] Extcon HDMI: HPD disabled
[ 57.398617] tegradc tegradc.0: hdmi: unplugged
[ 57.439143] tegradc tegradc.0: blank - powerdown
[ 57.439155] tegradc tegradc.0: unblank
[ 57.439182] tegradc tegradc.0: unblank
[ 57.439190] tegradc tegradc.1: blank - powerdown
[ 91.510991] usb 1-2-port2: over-current condition
[ 107.408544] usb 2-1-port2: over-current condition
[ 133.859458] usb 1-2-port2: over-current condition
[ 174.699400] usb 1-2-port1: over-current condition
[ 193.386874] usbcore: registered new interface driver btusb
[ 193.387933] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 193.388937] Bluetooth: hci0: Device revision is 16
[ 193.388941] Bluetooth: hci0: Secure boot is enabled
[ 193.388943] Bluetooth: hci0: OTP lock is disabled
[ 193.388945] Bluetooth: hci0: API lock is enabled
[ 193.388946] Bluetooth: hci0: Debug lock is disabled
[ 193.388949] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 193.401211] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 193.458060] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 193.458071] Bluetooth: BNEP socket layer initialized
[ 195.143386] Bluetooth: hci0: Waiting for firmware download to complete
[ 195.143972] Bluetooth: hci0: Firmware loaded in 1716113 usecs
[ 195.144142] Bluetooth: hci0: Waiting for device to boot
[ 195.156519] Bluetooth: hci0: Device booted in 12113 usecs
[ 195.161692] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 195.165303] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 223.971675] usb 1-2-port1: over-current condition
[ 230.671429] usb 1-2-port2: over-current condition
[ 242.636724] Host read timeout at address 5458045c
[ 242.642555] tegradc tegradc.0: blank - powerdown
[ 242.642629] tegradc tegradc.0: unblank
[ 242.669749] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 242.669846] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 242.670868] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 242.670875] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 242.674355] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 242.674356] Extcon AUX1(HDMI) enable
[ 242.675907] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 242.675911] Extcon HDMI: HPD enabled
[ 242.675945] tegradc tegradc.0: hdmi: plugged
[ 242.730907] tegradc tegradc.0: blank - powerdown
[ 242.789749] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 242.789754] Extcon AUX1(HDMI) disable
[ 242.808567] tegradc tegradc.0: unblank
[ 242.820408] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 242.820486] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 242.821496] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 242.821503] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 242.826562] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 242.826563] Extcon AUX1(HDMI) enable
[ 242.826715] tegradc tegradc.0: unblank
[ 242.826722] tegradc tegradc.1: blank - powerdown
[ 244.504976] input: M585/M590 as /devices/virtual/misc/uhid/0005:046D:B01B.0004/input/input4
[ 244.505402] hid-generic 0005:046D:B01B.0004: input,hidraw0: BLUETOOTH HID v0.11 Keyboard [M585/M590] on 34:13:E8:62:80:AD
[ 250.099451] usb 1-2-port2: over-current condition
[ 265.193862] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 265.193901] Extcon AUX1(HDM
