dmesg.txt (54.3 KB)
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.337-tegra (rvp@rvp-pc) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #77 SMP PREEMPT Tue Dec 5 14:52:58 MSK 2023
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu s53848 r8192 d32168 u94208
[ 0.000000] pcpu-alloc: s53848 r8192 d32168 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: enabling workaround for Spectre-BHB
[ 0.000000] CPU features: enabling workaround for ARM erratum 1742098
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 usbcore.usbfs_memory_mb=1024 usbcore.autosuspend=-1 usb_port_owner_info=2
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29700(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3582180K/4159488K available (11198K kernel code, 1560K rwdata, 4472K rodata, 2688K init, 565K bss, 102172K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0x (ptrval) - 0x (ptrval) ( 11200 KB)
[ 0.000000] .rodata : 0x (ptrval) - 0x (ptrval) ( 4544 KB)
[ 0.000000] .init : 0x (ptrval) - 0x (ptrval) ( 2688 KB)
[ 0.000000] .data : 0x (ptrval) - 0x (ptrval) ( 1561 KB)
[ 0.000000] .bss : 0x (ptrval) - 0x (ptrval) ( 566 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001489] Console: colour dummy device 80x25
[ 0.001498] console [tty0] enabled
[ 0.001505] bootconsole [uart8250] disabled
[ 0.001537] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001548] pid_max: default: 32768 minimum: 301
[ 0.001634] Security Framework initialized
[ 0.001668] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.001673] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002847] sched-energy: CPU device node has no sched-energy-costs
[ 0.012178] ASID allocator initialised with 65536 entries
[ 0.036134] tegra-id: chipid=22117.
[ 0.036142] tegra-id: opt_subrevision=0.
[ 0.036226] Tegra Speedo/IDDQ fuse revision 4
[ 0.036231] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.036235] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.036239] Tegra: CPU Speedo Value 2102, SoC Speedo Value 1972, GPU Speedo Value 2094
[ 0.036243] Tegra: CPU IDDQ Value 2288, SoC IDDQ Value 2492, GPU IDDQ Value 3020
[ 0.036269] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.036286] DTS File Name: /home/rvp/work/nvidia/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/lecor.dts
[ 0.036292] DTB Build time: Dec 5 2023 13:36:58
[ 0.084450] CPU1: Booted secondary processor [411fd071]
[ 0.116361] CPU2: Booted secondary processor [411fd071]
[ 0.148353] CPU3: Booted secondary processor [411fd071]
[ 0.148432] Brought up 4 CPUs
[ 0.148438] SMP: Total of 4 processors activated.
[ 0.148447] CPU features: detected feature: 32-bit EL0 Support
[ 0.148675] CPU: All CPU(s) started at EL2
[ 0.148693] alternatives: patching kernel code
[ 0.155165] devtmpfs: initialized
[ 0.193350] Initilizing CustomIPI irq domain
[ 0.193674] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.193695] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.205525] pinctrl core: initialized pinctrl subsystem
[ 0.206006] OS set in device tree is not L4T.
[ 0.206380] regulator-dummy: no parameters
[ 0.206623] Initializing plugin-manager
[ 0.206767] Plugin module not found
[ 0.206805] Plugin-manager not available
[ 0.209372] NET: Registered protocol family 16
[ 0.224171] cpuidle: using governor menu
[ 0.227274] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.229017] vdso: 2 pages (1 code @ (ptrval), 1 data @ (ptrval))
[ 0.229039] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.230648] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.233000] Serial: AMBA PL011 UART driver
[ 0.233492] tegra_powergate_init: DONE
[ 0.235223] Tegra reboot handler registered.
[ 0.239508] iommu: Adding device tegra-carveouts to group 0
[ 0.239601] platform tegra-carveouts: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.239932] iommu: Adding device smmu_test to group 1
[ 0.239980] platform smmu_test: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.240770] mc: mapped MMIO address: 0x (ptrval) -> 0x70019000
[ 0.240825] mc: mapped MMIO address: 0x (ptrval) -> 0x7001c000
[ 0.240881] mc: mapped MMIO address: 0x (ptrval) -> 0x7001d000
[ 0.240890] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.240905] mc-err: mcerr ops are set to t21x
[ 0.250782] iommu: Adding device 70090000.xusb to group 2
[ 0.251041] iommu: Adding device 70006000.serial to group 3
[ 0.251099] platform 70006000.serial: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.251490] iommu: Adding device 70006040.serial to group 4
[ 0.251724] iommu: Adding device 70006200.serial to group 5
[ 0.252109] iommu: Adding device 7000d400.spi to group 6
[ 0.252328] iommu: Adding device 7000d600.spi to group 7
[ 0.252695] iommu: Adding device 50000000.host1x to group 8
[ 0.252951] iommu: Adding device 54080000.vi to group 9
[ 0.253305] iommu: Adding device 54600000.isp to group 10
[ 0.253539] iommu: Adding device 54680000.isp to group 11
[ 0.253776] iommu: Adding device tegradc.0 to group 12
[ 0.253822] platform tegradc.0: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.254330] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.254653] iommu: Adding device tegradc.1 to group 13
[ 0.254702] platform tegradc.1: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.255195] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.255405] iommu: Adding device 54340000.vic to group 14
[ 0.255582] iommu: Adding device 544c0000.nvenc to group 15
[ 0.255756] iommu: Adding device 54500000.tsec to group 16
[ 0.255923] iommu: Adding device 54100000.tsecb to group 17
[ 0.256103] iommu: Adding device 54480000.nvdec to group 18
[ 0.256277] iommu: Adding device 54380000.nvjpg to group 19
[ 0.257254] iommu: Adding device 546c0000.i2c to group 20
[ 0.257595] iommu: Adding device 57000000.gpu to group 21
[ 0.257641] platform 57000000.gpu: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.257673] platform 57000000.gpu: domain= (ptrval) allocates as[1]= (ptrval)
[ 0.257708] platform 57000000.gpu: domain= (ptrval) allocates as[2]= (ptrval)
[ 0.257745] platform 57000000.gpu: domain= (ptrval) allocates as[3]= (ptrval)
[ 0.258569] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.258580] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.258591] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.258595] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.258599] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.308552] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.308558] tegra-pmc: Clear bootloader IO dpd settings
[ 0.308582] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.308637] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.308914] iommu: Adding device 70012000.se to group 22
[ 0.309680] iommu: Adding device 7000c000.i2c to group 23
[ 0.309914] iommu: Adding device 7000c400.i2c to group 24
[ 0.310195] iommu: Adding device 7000c500.i2c to group 25
[ 0.310429] iommu: Adding device 7000c700.i2c to group 26
[ 0.310704] iommu: Adding device 7000d000.i2c to group 27
[ 0.310926] iommu: Adding device 7000d100.i2c to group 28
[ 0.311241] iommu: Adding device sdhci-tegra.3 to group 29
[ 0.311305] platform sdhci-tegra.3: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.311697] iommu: Adding device sdhci-tegra.2 to group 30
[ 0.311742] platform sdhci-tegra.2: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.312614] iommu: Adding device 700d0000.xudc to group 31
[ 0.315893] vdd-ac-bat: 5000 mV
[ 0.316244] vdd-5v0-sys: 5000 mV
[ 0.316965] vdd-5v0-hdmi: 5000 mV
[ 0.317370] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.317594] vdd-1v8-sys: 1800 mV
[ 0.317977] vdd-fan: 5000 mV
[ 0.318170] vdd-fan: supplied by vdd-5v0-sys
[ 0.318394] vdd-usb-vbus: 5000 mV
[ 0.318600] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.318883] vdd-usb-vbus2: 5000 mV
[ 0.347067] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.348267] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.348596] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.355976] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.356246] SCSI subsystem initialized
[ 0.356441] libata version 3.00 loaded.
[ 0.356746] usbcore: registered new interface driver usbfs
[ 0.356791] usbcore: registered new interface driver hub
[ 0.356828] usbcore: registered new device driver usb
[ 0.360713] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.364690] vdd-core: 1000 <--> 1162 mV at 1075 mV
[ 0.365603] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.368513] vdd-ddr-1v1: 1150 mV
[ 0.372467] vdd-pre-reg-1v35: 1350 mV
[ 0.376467] vdd-1v8: 1800 mV
[ 0.380467] avdd-sys-1v2: 1200 mV
[ 0.384465] vdd-pex-1v0: 1050 mV
[ 0.385094] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.385602] max77620-ldo3: at 3100 mV
[ 0.388469] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.388983] max77620-ldo5: at 3100 mV
[ 0.392469] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.396465] avdd-1v05-pll: 1050 mV
[ 0.400166] avdd-io-hdmi-dp: 1050 mV
[ 0.402573] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.402820] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.403061] max77620 4-003c: max77620 probe successful
[ 0.405917] media: Linux media interface: v0.10
[ 0.405971] Linux video capture interface: v2.00
[ 0.406802] pps_core: LinuxPPS API ver. 1 registered
[ 0.406808] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.410428] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.413354] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.413372] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.413425] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.413440] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.416603] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.417708] vdd-3v3-sys: 3300 mV
[ 0.418045] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.418094] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.420539] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.420980] vdd-3v3-sd: 3300 mV
[ 0.421334] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.421790] avdd-io-edp-1v05: 1050 mV
[ 0.422117] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.422240] vdd-usb-hub-en: 5000 mV
[ 0.422585] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.423616] camchar: rtcpu character device driver loaded
[ 0.424264] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.425556] clocksource: Switched to clocksource arch_sys_counter
[ 0.425730] VFS: Disk quotas dquot_6.6.0
[ 0.425795] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.425944] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.426152] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.426166] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.426354] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.426359] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.426373] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.426395] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.426401] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.426417] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.426423] nvmap_page_pool_init: Total RAM pages: 1014329
[ 0.426428] nvmap_page_pool_init: nvmap page pool size: 126791 pages (495 MB)
[ 0.426494] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.426763] misc nvmap: created heap iram base 0x (ptrval) size (252KiB)
[ 0.427542] misc nvmap: created heap vpr base 0x (ptrval) size (409600KiB)
[ 0.434650] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.435013] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.435246] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.435444] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.435609] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.435865] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.435869] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.435987] NET: Registered protocol family 2
[ 0.436128] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.461693] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.461905] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.462410] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.462556] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.462636] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.462876] NET: Registered protocol family 1
[ 0.462906] PCI: CLS 0 bytes, default 64
[ 0.463119] Trying to unpack rootfs image as initramfs...
[ 0.768618] Freeing initrd memory: 6988K
[ 0.778351] host1x 50000000.host1x: initialized
[ 0.780004] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.782885] audit: initializing netlink subsys (disabled)
[ 0.782995] audit: type=2000 audit(0.779:1): initialized
[ 0.783574] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.789091] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.791894] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[ 0.792002] io scheduler noop registered
[ 0.792127] io scheduler cfq registered (default)
[ 0.794153] gic 702f9000.agic: GIC IRQ controller registered
[ 0.797017] iommu: Adding device 702ef000.adsp to group 32
[ 0.797121] platform 702ef000.adsp: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.806109] iommu: Adding device aconnect@702c0000:adsp_audio to group 33
[ 0.806246] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.806825] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x91e9411
[ 0.806832] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.808423] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.808509] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.808586] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.808756] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.808834] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.808914] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.808987] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.809065] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.809142] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.809215] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.815270] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.816783] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.818633] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.819880] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.820213] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.821462] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.821690] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.821830] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=5250, vi_iso_bw=1029000, max_bw=1029000
[ 0.822063] Adding domain tsec-pd to PM domain host1x-pd
[ 0.825229] tsec 54500000.tsec: initialized
[ 0.826621] tsec 54100000.tsecb: initialized
[ 0.827290] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.830506] nvdec 54480000.nvdec: initialized
[ 0.831490] Adding domain vic03-pd to PM domain host1x-pd
[ 0.831669] Adding domain msenc-pd to PM domain host1x-pd
[ 0.831827] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.835914] falcon 54340000.vic: initialized
[ 0.837034] falcon 544c0000.nvenc: initialized
[ 0.838363] falcon 54380000.nvjpg: initialized
[ 0.842628] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 0.842668] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 0.842703] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 0.842761] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.842855] display board info: id 0x101, fab 0x53
[ 0.842910] generic_infoframe_type: 0x87
[ 0.842948] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 0.842953] tegra_cec 70015000.tegra_cec: probed
[ 0.843053] tegradc tegradc.0: DT parsed successfully
[ 0.843092] tegradc tegradc.0: Display dc. (ptrval) registered with id=0
[ 0.846438] tegradc tegradc.0: probed
[ 0.847104] Console: switching to colour frame buffer device 80x30
[ 0.847138] tegradc tegradc.0: fb registered
[ 0.848294] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 0.848372] tegradc tegradc.1: No lt-data, using default setting
[ 0.848398] tegradc tegradc.1: No hpd-gpio in DT
[ 0.848430] tegradc tegradc.1: DT parsed successfully
[ 0.848472] tegradc tegradc.1: Display dc. (ptrval) registered with id=1
[ 0.850076] tegradc tegradc.1: dpd enable lookup fail:-19
[ 0.850565] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.355822] Host read timeout at address 545c00c4
[ 1.357264] tegradc tegradc.1: probed
[ 1.357638] tegradc tegradc.1: fb registered
[ 1.358283] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.359050] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.359056] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.359343] kfuse 7000fc00.kfuse: initialized
[ 1.360215] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.360872] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.360878] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.360886] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.360900] tegradc tegradc.1: blank - powerdown
[ 1.360924] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.360928] Extcon DP: HPD disabled
[ 1.360932] hpd: hpd_switch 0
[ 1.360936] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.360944] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.360950] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.360977] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.363022] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.363029] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.363035] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.363040] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.363046] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.363067] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.363129] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.363292] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.363348] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.363494] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.363503] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.363607] pci 0000:01:00.0: [1d6a:14c0] type 00 class 0x020000
[ 1.363638] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0007ffff 64bit]
[ 1.363658] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 1.363677] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x003fffff 64bit]
[ 1.363690] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[ 1.363828] pci 0000:01:00.0: supports D1 D2
[ 1.363833] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 1.364303] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.364310] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.364615] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.365560] vdd-gpu: applied init 1000000uV constraint
[ 1.365565] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.365870] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.368217] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.368268] No Device Node present for smmu client: serial8250 !!
[ 1.368274] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.368298] iommu: Adding device serial8250 to group 34
[ 1.369655] console [ttyS0] disabled
[ 1.369691] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.377628] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.377748] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 1.377771] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.377799] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 1.377818] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 1.377938] pci 0000:02:00.0: supports D1 D2
[ 1.377941] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.379849] console [ttyS0] enabled
[ 1.380505] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.380699] serial-tegra 70006200.serial: RX in PIO mode
[ 1.380771] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.381511] [drm] Initialized
[ 1.382017] nvgpu: 57000000.gpu nvgpu_probe:265 [INFO] platform probe failed
[ 1.385626] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 1.385672] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x135fffff]
[ 1.385681] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 1.385687] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.385697] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x133fffff 64bit]
[ 1.385715] pci 0000:01:00.0: BAR 0: assigned [mem 0x13400000-0x1347ffff 64bit]
[ 1.385732] pci 0000:01:00.0: BAR 6: assigned [mem 0x13480000-0x1349ffff pref]
[ 1.385738] pci 0000:01:00.0: BAR 2: assigned [mem 0x134a0000-0x134a0fff 64bit]
[ 1.385756] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.385762] pci 0000:00:01.0: bridge window [mem 0x13000000-0x135fffff]
[ 1.385773] pci 0000:02:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[ 1.385791] pci 0000:02:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[ 1.385807] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.385816] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 1.385820] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.385828] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[ 1.386095] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.386100] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.386106] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.386217] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 1.386399] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.386403] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.386409] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.386515] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 1.388923] brd: module loaded
[ 1.392448] loop: module loaded
[ 1.392874] at24 0-0051: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 1.392960] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.393041] tegra_profiler: auth: init
[ 1.393659] THERMAL EST: found 2 subdevs
[ 1.393664] THERMAL EST num_resources: 0
[ 1.393668] [THERMAL EST subdev 0]
[ 1.393674] [THERMAL EST subdev 1]
[ 1.393956] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.393959] THERMAL EST: thz register success.
[ 1.394056] THERMAL EST: end of probe, return err: 0
[ 1.394576] sd: No Scsi addr parsed to reserve index
[ 1.394603] hisi_sas: driver version v1.6
[ 1.399167] atlantic 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.399221] atlantic 0000:01:00.0 (unnamed net_device) (uninitialized): Hardware revision 0x0
[ 1.437670] atlantic: Detect ATL2FW 1030013
[ 1.440082] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 1.440099] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.461116] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.461177] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e9:fb:54 from device tree
[ 1.461502] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.461535] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.461644] usbcore: registered new interface driver asix
[ 1.461680] usbcore: registered new interface driver ax88179_178a
[ 1.461714] usbcore: registered new interface driver cdc_ether
[ 1.461754] usbcore: registered new interface driver net1080
[ 1.461789] usbcore: registered new interface driver cdc_subset
[ 1.461822] usbcore: registered new interface driver zaurus
[ 1.461874] usbcore: registered new interface driver cdc_ncm
[ 1.462004] VFIO - User Level meta-driver version: 0.3
[ 1.462681] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.462685] ehci-pci: EHCI PCI platform driver
[ 1.462721] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.462731] ohci-pci: OHCI PCI platform driver
[ 1.462765] ohci-platform: OHCI generic platform driver
[ 1.464521] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.465054] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.466142] tegra-xusb 70090000.xusb: extcon 0: (ptrval) id
[ 1.467220] usbcore: registered new interface driver uas
[ 1.467270] usbcore: registered new interface driver usb-storage
[ 1.467351] usbcore: registered new interface driver usbserial
[ 1.467380] usbcore: registered new interface driver usbserial_generic
[ 1.467404] usbserial: USB Serial support registered for generic
[ 1.467438] usbcore: registered new interface driver ftdi_sio
[ 1.467456] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.469545] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[ 1.469607] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.469625] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.470326] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.470357] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.470501] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.470507] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.470512] usb usb1: Product: xHCI Host Controller
[ 1.470516] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[ 1.470520] usb usb1: SerialNumber: 70090000.xusb
[ 1.470665] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.470903] hub 1-0:1.0: USB hub found
[ 1.470934] hub 1-0:1.0: 5 ports detected
[ 1.471341] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.471351] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.471414] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.471495] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.471501] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.471505] usb usb2: Product: xHCI Host Controller
[ 1.471510] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[ 1.471514] usb usb2: SerialNumber: 70090000.xusb
[ 1.471603] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.471613] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.471634] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.471855] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.471874] hub 2-0:1.0: USB hub found
[ 1.471902] hub 2-0:1.0: 4 ports detected
[ 1.472302] mousedev: PS/2 mouse device common for all mice
[ 1.472640] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.472646] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.493622] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.493675] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.602727] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.604792] rtc rtc1: alarm rtc device
[ 1.604805] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.604830] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.605163] i2c /dev entries driver
[ 1.606764] letim 6-003a: tegracam sensor driver:letim_v2.0.6
[ 1.607197] letim 6-003b: tegracam sensor driver:letim_v2.0.6
[ 1.607623] letim 6-003c: tegracam sensor driver:letim_v2.0.6
[ 1.608040] letim 6-003d: tegracam sensor driver:letim_v2.0.6
[ 1.608462] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.610286] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.610292] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.610569] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.610582] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.610589] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.610714] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.610724] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.610730] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.610893] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.610901] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.610906] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.611084] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.611632] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.611682] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.611701] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.611717] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.611726] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.612455] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.612469] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.612603] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.612625] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.612957] parse_throttle_dt_data: Num cap clks = 6
[ 1.612963] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.612970] parse_throttle_dt_data: clk=gpu type=4
[ 1.612988] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.613005] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.613023] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.613027] parse_throttle_dt_data: clk=emc type=3
[ 1.613281] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.613361] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.613460] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.614030] FAN dev name: pwm-fan
[ 1.614070] FAN:gpio request success.
[ 1.614112] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.614325] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.614433] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.614440] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.614507] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.614512] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.614517] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.614522] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.614527] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.614532] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.614536] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.614541] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.614546] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.614551] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.615425] device-mapper: uevent: version 1.0.3
[ 1.615618] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.618301] tegra210-cpufreq cpufreq: probe()...completed
[ 1.618956] sdhci: Secure Digital Host Controller Interface driver
[ 1.618958] sdhci: Copyright(c) Pierre Ossman
[ 1.618960] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.619294] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.621804] sdhci-tegra sdhci-tegra.2: Got CD GPIO
[ 1.622134] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[ 1.622258] sdhci-tegra sdhci-tegra.2: wakeup init done, cdirq 293
[ 1.625937] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.626421] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.626570] usbcore: registered new interface driver usbhid
[ 1.626572] usbhid: USB HID core driver
[ 1.628645] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.628782] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.630887] Initializing XFRM netlink socket
[ 1.631106] NET: Registered protocol family 10
[ 1.631589] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.631860] NET: Registered protocol family 17
[ 1.631871] NET: Registered protocol family 15
[ 1.632167] Registered cp15_barrier emulation handler
[ 1.632173] Registered setend emulation handler
[ 1.633016] registered taskstats version 1
[ 1.633515] Adding domain ve2-pd to PM domain host1x-pd
[ 1.633767] Adding domain ve-pd to PM domain host1x-pd
[ 1.635631] isp 54600000.isp: initialized
[ 1.636482] isp 54680000.isp: initialized
[ 1.646168] last reset is due to software reset
[ 1.646172] KERNEL: PMC reset status reg: 0x3
[ 1.646231] BL: PMC reset status reg: 0x3
[ 1.646233] BL: PMIC poweroff Event Recorder: 0x0
[ 1.647717] clk_cbus_recalc_rate: no gbus parent
[ 1.647722] clk_cbus_round_rate: no gbus parent
[ 1.647725] clk_cbus_round_rate: no gbus parent
[ 1.647732] clk_cbus_recalc_rate: no gbus parent
[ 1.647822] clk_cbus_recalc_rate: no gbus parent
[ 1.647826] clk_cbus_round_rate: no gbus parent
[ 1.647828] clk_cbus_round_rate: no gbus parent
[ 1.647832] clk_cbus_recalc_rate: no gbus parent
[ 1.648497] tegra_dvfs: GPU-cap: registered
[ 1.648557] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.648559] tegra dvfs: vdd-core: nominal 1075mV, offset 1000000uV, step 12500uV, scaling enabled
[ 1.648562] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.649620] tegra_dvfs: vdd-gpu-vts: registered
[ 1.650304] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.651006] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.651497] input: gpio-keys as /devices/gpio-keys/input/input0
[ 1.653702] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 1.665570] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 1.665703] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 1.682262] tegra_rtc 7000e000.rtc: setting system clock to 2023-12-06 08:36:47 UTC (1701851807)
[ 1.683163] vi 54080000.vi: vi_probe: ++
[ 1.685404] vi 54080000.vi: initialized
[ 1.687271] vi 54080000.vi: subdev nvcsi--4 bound
[ 1.687284] vi 54080000.vi: subdev letim 6-003a bound
[ 1.688449] vi 54080000.vi: subdev nvcsi--3 bound
[ 1.688455] vi 54080000.vi: subdev letim 6-003b bound
[ 1.689583] vi 54080000.vi: subdev nvcsi--2 bound
[ 1.689588] vi 54080000.vi: subdev letim 6-003c bound
[ 1.690708] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.690714] vi 54080000.vi: subdev letim 6-003d bound
[ 1.692427] Disable partitions left on by BL
[ 1.692430] disb
[ 1.692585] bwmgr: missing cdev-type property
[ 1.692706] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.692712] DRAM derating cdev registered.
[ 1.694694] Freeing unused kernel memory: 2688K
[ 1.699658] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.699946] mmc1: new SD card at address e624
[ 1.700288] mmcblk1: mmc1:e624 SR064 59.5 MiB
[ 1.703077] mmcblk1:
[ 1.722082] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.723732] Root device found: mmcblk0p1
[ 1.726415] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 1.726619] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 1.726765] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 1.726866] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 1.729197] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 1.857623] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 1.857627] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 1.928634] Found dev node: /dev/mmcblk0p1
[ 1.946753] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.948622] Rootfs mounted over mmcblk0p1
[ 1.962046] Switching from initrd to actual rootfs
[ 2.058725] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
[ 2.067676] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.076522] systemd[1]: systemd 253-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 2.076552] systemd[1]: Detected architecture arm64.
[ 2.076974] systemd[1]: Warning! Reported kernel version 4.9.337-tegra is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
[ 2.078399] systemd[1]: Hostname set to <alarm>.
[ 2.092817] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
[ 2.314443] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.317942] systemd[1]: Created slice Slice /system/getty.
[ 2.318646] systemd[1]: Created slice Slice /system/modprobe.
[ 2.319321] systemd[1]: Created slice Slice /system/serial-getty.
[ 2.319759] systemd[1]: Created slice User and Session Slice.
[ 2.319937] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.320090] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.320195] systemd[1]: Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[ 2.320269] systemd[1]: Reached target Local Encrypted Volumes.
[ 2.320339] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 2.320416] systemd[1]: Reached target Path Units.
[ 2.320468] systemd[1]: Reached target Remote File Systems.
[ 2.320504] systemd[1]: Reached target Slice Units.
[ 2.320565] systemd[1]: Reached target Swaps.
[ 2.320623] systemd[1]: Reached target Local Verity Protected Volumes.
[ 2.320838] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.323905] systemd[1]: Listening on Process Core Dump Socket.
[ 2.324240] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.324529] systemd[1]: Listening on Journal Socket.
[ 2.324874] systemd[1]: Listening on Network Service Netlink Socket.
[ 2.325536] systemd[1]: Listening on udev Control Socket.
[ 2.325773] systemd[1]: Listening on udev Kernel Socket.
[ 2.325981] systemd[1]: Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 2.327672] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.329798] systemd[1]: Mounting Kernel Debug File System...
[ 2.330049] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 2.332380] systemd[1]: Mounting Temporary Directory /tmp...
[ 2.332532] systemd[1]: Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/4.9.337-tegra/modules.devname).
[ 2.334799] systemd[1]: Starting Load Kernel Module configfs...
[ 2.337241] systemd[1]: Starting Load Kernel Module dm_mod...
[ 2.339635] systemd[1]: Starting Load Kernel Module drm...
[ 2.342088] systemd[1]: Starting Load Kernel Module fuse...
[ 2.344191] systemd[1]: Starting Load Kernel Module loop...
[ 2.344759] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 2.344769] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 2.346595] systemd[1]: Starting Journal Service...
[ 2.347866] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
[ 2.349797] systemd[1]: Starting Generate network units from Kernel command line...
[ 2.349914] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[ 2.352008] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.354199] systemd[1]: Starting Apply Kernel Variables...
[ 2.356402] systemd[1]: Starting Coldplug All udev Devices...
[ 2.360653] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.361071] systemd[1]: Mounted Kernel Debug File System.
[ 2.361455] systemd[1]: Mounted Temporary Directory /tmp.
[ 2.362633] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.363008] systemd[1]: Finished Load Kernel Module configfs.
[ 2.364570] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 2.365042] systemd[1]: Finished Load Kernel Module dm_mod.
[ 2.366204] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.366554] systemd[1]: Finished Load Kernel Module drm.
[ 2.367577] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.367938] systemd[1]: Finished Load Kernel Module fuse.
[ 2.369136] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 2.369536] systemd[1]: Finished Load Kernel Module loop.
[ 2.372393] systemd[1]: Finished Generate network units from Kernel command line.
[ 2.373054] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.374547] systemd[1]: Reached target Preparation for Network.
[ 2.374819] systemd[1]: FUSE Control File System was skipped because of an unmet condition check (ConditionPathExists=/sys/fs/fuse/connections).
[ 2.377100] systemd[1]: Mounting Kernel Configuration File System...
[ 2.377205] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 2.378191] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 2.380285] systemd[1]: Starting Load/Save OS Random Seed...
[ 2.380545] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 2.380891] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[ 2.391456] systemd-journald[1683]: Collecting audit messages is disabled.
[ 2.466069] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 2.491050] usb 2-1: New USB device found, idVendor=1c04, idProduct=0015
[ 2.491055] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.491059] usb 2-1: Product: QNAP QNA-UC5G1T USB to 5GbE Adapter
[ 2.491061] usb 2-1: Manufacturer: QNAP
[ 2.491064] usb 2-1: SerialNumber: 98I04653
[ 2.495070] cdc_ether 2-1:2.0 eth2: register 'cdc_ether' at usb-70090000.xusb-1, CDC Ethernet Device, 24:5e:be:42:65:3f
[ 2.507150] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.509186] systemd[1]: Finished Apply Kernel Variables.
[ 2.509761] systemd[1]: Mounted Kernel Configuration File System.
[ 2.605572] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 2.607639] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.608001] systemd[1]: Reached target Preparation for Local File Systems.
[ 2.608077] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[ 2.608119] systemd[1]: Reached target Local File Systems.
[ 2.608360] systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
[ 2.609151] systemd[1]: Set Up Additional Binary Formats was skipped because of an unmet condition check (ConditionPathIsMountPoint=/proc/sys/fs/binfmt_misc).
[ 2.610982] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 2.625848] usb 1-3: New USB device found, idVendor=0424, idProduct=2512
[ 2.625854] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.626681] hub 1-3:1.0: USB hub found
[ 2.626767] hub 1-3:1.0: 2 ports detected
[ 2.627955] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 2.648649] systemd[1]: Started Journal Service.
[ 2.664322] systemd-journald[1683]: Received client request to flush runtime journal.
[ 2.673842] (md-udevd)[1701]: systemd-udevd.service: ProtectHostname=yes is configured, but the kernel does not support UTS namespaces, ignoring namespace setup.
[ 2.682626] systemd-journald[1683]: /var/log/journal/a517533acb4d4bb0ae1d494126e1a51e/system.journal: Montonic clock jumped backwards relative to last journal entry, rotating.
[ 2.682640] systemd-journald[1683]: Rotating system journal.
[ 2.913671] usb 1-3.2: new full-speed USB device number 4 using tegra-xusb
[ 2.924403] proc: unrecognized mount option "hidepid=invisible" or missing value
[ 2.942660] usb 1-3.2: New USB device found, idVendor=0403, idProduct=6015
[ 2.942666] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.942670] usb 1-3.2: Product: FT230X Basic UART
[ 2.942674] usb 1-3.2: Manufacturer: FTDI
[ 2.942676] usb 1-3.2: SerialNumber: DK0EHV5E
[ 2.948125] ftdi_sio 1-3.2:1.0: FTDI USB Serial Device converter detected
[ 2.948199] usb 1-3.2: Detected FT-X
[ 2.948486] usb 1-3.2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 3.286289] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.288665] eth1: 0xffffff800983e000, 00:04:4b:e9:fb:54, IRQ 413
[ 3.392338] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 3.403090] cdc_ether 2-1:2.0 eth2: kevent 12 may have been dropped
[ 3.419557] cdc_ether 2-1:2.0 eth2: kevent 12 may have been dropped
[ 3.523745] proc: unrecognized mount option "hidepid=invisible" or missing value
[ 3.881558] random: crng init done
[ 5.442111] r8168: eth1: link up
[ 5.442137] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 17.791624] systemd-journald[1683]: /var/log/journal/a517533acb4d4bb0ae1d494126e1a51e/user-1000.journal: Montonic clock jumped backwards relative to last journal entry, rotating.
[ 17.791646] systemd-journald[1683]: Failed to write entry to /var/log/journal/a517533acb4d4bb0ae1d494126e1a51e/user-1000.journal (30 items, 800 bytes), rotating before retrying: Not a XENIX named type file
[ 31.713753] vdd-fan: disabling
[ 31.713756] vdd-usb-vbus: disabling
[ 31.713758] vdd-usb-vbus2: disabling
[ 31.713766] vddio-sdmmc-ap: disabling
[ 31.713912] vddio-sdmmc3-ap: disabling
[ 31.714052] vdd-3v3-sd: disabling
[ 31.714056] avdd-io-edp-1v05: disabling
[ 31.714059] vdd-usb-hub-en: disabling
