dear sir
We have a custom board with a sd card connected to SDMMC3 (CLK/CMD/DATA is connected to Nano pin #229, 227, 219, 221, 223, 225).but we do not connect sd_detect to gpio8(designed error),so we reference another tx2 custom board,connect gpio8 to gnd(is wordked fine on tx2),I modified the dts files according to the link https://devtalk.nvidia.com/default/topic/1062120/jetson-nano/microsd-card-not-detected-on-jetson-nano-production-module/
sdhci@700b0000 { /* SDMMC1 for SD card the comment is error*/
status = "disabled";
sdhci@700b0400 { /* SDMMC3 for SD card */
status = "okay";
no-sdio;
no-mmc;
sd-uhs-sdr104;
sd-uhs-sdr50;
sd-uhs-sdr25;
sd-uhs-sdr12;
mmc-ddr-1_8v;
mmc-ocr-mask = <3>;
uhs-mask = <0x0>;
max-clk-limit = <100000>;
tap-delay = <185>;
but still can’t see /dev/mmcblk1
$ ls /dev/|grep mmc
mmcblk0
mmcblk0p1
mmcblk0p10
mmcblk0p11
mmcblk0p12
mmcblk0p13
mmcblk0p14
mmcblk0p2
mmcblk0p3
mmcblk0p4
mmcblk0p5
mmcblk0p6
mmcblk0p7
mmcblk0p8
mmcblk0p9
mmcblk0rpmb
the dmesg message find a error,how to correct this? mmc1: error -110 whilst initialising SD card
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (wdg@wdg-HP-EliteBook-8560p) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #7 SMP PREEMPT Tue Nov 19 14:12:57 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb0000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29504(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3570072K/4159488K available (15294K kernel code, 2930K rwdata, 6784K rodata, 8576K init, 609K bss, 114280K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009620000 ( 6848 KB)
[ 0.000000] .init : 0xffffff8009620000 - 0xffffff8009e80000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a15c808 ( 2931 KB)
[ 0.000000] .bss : 0xffffff800a15c808 - 0xffffff800a1f4dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001653] Console: colour dummy device 80x25
[ 0.001673] console [tty0] enabled
[ 0.001691] kmemleak: Kernel memory leak detector disabled
[ 0.001708] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001722] pid_max: default: 32768 minimum: 301
[ 0.002167] Security Framework initialized
[ 0.002389] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002397] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003502] ftrace: allocating 47199 entries in 185 pages
[ 0.177003] sched-energy: CPU device node has no sched-energy-costs
[ 0.177037] ASID allocator initialised with 65536 entries
[ 0.215633] tegra-id: chipid=22117.
[ 0.215647] tegra-id: opt_subrevision=0.
[ 0.215665] Tegra Speedo/IDDQ fuse revision 4
[ 0.215670] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.215675] Tegra: CPU Process ID 1, SoC Process ID 1, GPU Process ID 0
[ 0.215681] Tegra: CPU Speedo Value 2145, SoC Speedo Value 2051, GPU Speedo Value 2145
[ 0.215685] Tegra: CPU IDDQ Value 2800, SoC IDDQ Value 3060, GPU IDDQ Value 3665
[ 0.215704] Tegra Revision: A02 SKU: 0x8f CPU Process: 1 SoC Process: 1
[ 0.215718] DTS File Name: /home/wdg/nvidia/Jetpack/JetPack_4.2.2_Linux_GA_P3448-0020/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-B01-adas-0001.dts
[ 0.215725] DTB Build time: Nov 20 2019 16:14:56
[ 0.265027] CPU1: Booted secondary processor [411fd071]
[ 0.296953] CPU2: Booted secondary processor [411fd071]
[ 0.328925] CPU3: Booted secondary processor [411fd071]
[ 0.329011] Brought up 4 CPUs
[ 0.329018] SMP: Total of 4 processors activated.
[ 0.329027] CPU features: detected feature: 32-bit EL0 Support
[ 0.329292] CPU: All CPU(s) started at EL2
[ 0.329309] alternatives: patching kernel code
[ 0.337360] devtmpfs: initialized
[ 0.374739] Initilizing CustomIPI irq domain
[ 0.375159] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.375184] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.385694] pinctrl core: initialized pinctrl subsystem
[ 0.386316] OS set in device tree is not L4T.
[ 0.386705] regulator-dummy: no parameters
[ 0.386987] Initializing plugin-manager
[ 0.387099] Plugin module not found
[ 0.387328] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.387900] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.388405] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.389154] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.389604] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.390240] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[ 0.390310] Node override does not have targer node
[ 0.395234] NET: Registered protocol family 16
[ 0.396581] pstore: using zlib compression
[ 0.396640] console [pstore-1] enabled
[ 0.396645] pstore: Registered ramoops as persistent store backend
[ 0.396651] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.413044] cpuidle: using governor menu
[ 0.417344] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.418950] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e84000)
[ 0.418972] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421495] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.424109] tegra_powergate_init: DONE
[ 0.424124] DTS File Name: /home/wdg/nvidia/Jetpack/JetPack_4.2.2_Linux_GA_P3448-0020/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-B01-adas-0001.dts
[ 0.424129] DTB Build time: Nov 20 2019 16:14:56
[ 0.425909] Tegra reboot handler registered.
[ 0.430317] iommu: Adding device tegra-carveouts to group 0
[ 0.430441] platform tegra-carveouts: domain=ffffffc0f943d318 allocates as[0]=ffffffc0f9bd40a8
[ 0.430789] iommu: Adding device smmu_test to group 1
[ 0.430833] platform smmu_test: domain=ffffffc0f943d558 allocates as[0]=ffffffc0f9bd4110
[ 0.431630] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.431688] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.431745] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.431753] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.431776] mc-err: mcerr ops are set to t21x
[ 0.441142] iommu: Adding device 70090000.xusb to group 2
[ 0.441420] iommu: Adding device 70006000.serial to group 3
[ 0.441490] platform 70006000.serial: domain=ffffffc0f94b56d8 allocates as[0]=ffffffc0f9bd4178
[ 0.441897] iommu: Adding device 70006040.serial to group 4
[ 0.442168] iommu: Adding device 70006200.serial to group 5
[ 0.442396] iommu: Adding device sound to group 6
[ 0.442444] platform sound: domain=ffffffc0f94b5c18 allocates as[0]=ffffffc0f9bd41e0
[ 0.442999] iommu: Adding device 7000d400.spi to group 7
[ 0.443252] iommu: Adding device 7000d600.spi to group 8
[ 0.443572] iommu: Adding device 50000000.host1x to group 9
[ 0.443841] iommu: Adding device 54080000.vi to group 10
[ 0.444237] iommu: Adding device 54600000.isp to group 11
[ 0.444504] iommu: Adding device 54680000.isp to group 12
[ 0.444778] iommu: Adding device tegradc.0 to group 13
[ 0.444845] platform tegradc.0: domain=ffffffc0f94c29d8 allocates as[0]=ffffffc0f9bd4248
[ 0.445515] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.445858] iommu: Adding device tegradc.1 to group 14
[ 0.445908] platform tegradc.1: domain=ffffffc0f94c2c18 allocates as[0]=ffffffc0f9bd42b0
[ 0.446413] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.446650] iommu: Adding device 54340000.vic to group 15
[ 0.446852] iommu: Adding device 544c0000.nvenc to group 16
[ 0.447045] iommu: Adding device 54500000.tsec to group 17
[ 0.447242] iommu: Adding device 54100000.tsecb to group 18
[ 0.447435] iommu: Adding device 54480000.nvdec to group 19
[ 0.447627] iommu: Adding device 54380000.nvjpg to group 20
[ 0.448699] iommu: Adding device 546c0000.i2c to group 21
[ 0.449071] iommu: Adding device 57000000.gpu to group 22
[ 0.449125] platform 57000000.gpu: domain=ffffffc0f94ccc18 allocates as[0]=ffffffc0f9bd4318
[ 0.449160] platform 57000000.gpu: domain=ffffffc0f94ccc18 allocates as[1]=ffffffc0f9bd4380
[ 0.449200] platform 57000000.gpu: domain=ffffffc0f94ccc18 allocates as[2]=ffffffc0f9bd43e8
[ 0.449238] platform 57000000.gpu: domain=ffffffc0f94ccc18 allocates as[3]=ffffffc0f9bd4450
[ 0.450124] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.450135] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.450148] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.450152] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.450156] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.501121] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.501130] tegra-pmc: Clear bootloader IO dpd settings
[ 0.501149] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.501212] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.501503] iommu: Adding device 70012000.se to group 23
[ 0.502347] iommu: Adding device 7000c000.i2c to group 24
[ 0.502659] iommu: Adding device 7000c400.i2c to group 25
[ 0.502960] iommu: Adding device 7000c500.i2c to group 26
[ 0.503255] iommu: Adding device 7000c700.i2c to group 27
[ 0.503554] iommu: Adding device 7000d000.i2c to group 28
[ 0.503892] iommu: Adding device 7000d100.i2c to group 29
[ 0.504197] iommu: Adding device sdhci-tegra.3 to group 30
[ 0.504253] platform sdhci-tegra.3: domain=ffffffc0f94f3e58 allocates as[0]=ffffffc0f9bd44b8
[ 0.504681] iommu: Adding device sdhci-tegra.2 to group 31
[ 0.504739] platform sdhci-tegra.2: domain=ffffffc0f9568018 allocates as[0]=ffffffc0f9bd4520
[ 0.505806] iommu: Adding device 700d0000.xudc to group 32
[ 0.510035] vdd-ac-bat: 5000 mV
[ 0.510468] vdd-5v0-sys: 5000 mV
[ 0.511650] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.511692] vdd-5v0-hdmi: 5000 mV
[ 0.512122] vdd-1v8-sys: 1800 mV
[ 0.512630] vdd-fan: supplied by vdd-5v0-sys
[ 0.512664] vdd-fan: 5000 mV
[ 0.513165] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.513198] vdd-usb-vbus: 5000 mV
[ 0.513853] vdd-usb-vbus2: 5000 mV
[ 0.546042] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548623] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.549730] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.549748] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.549776] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.549800] GPIO line 66 (mpu9250_interrupt) hogged as input
[ 0.550196] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.558143] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.558495] SCSI subsystem initialized
[ 0.558720] libata version 3.00 loaded.
[ 0.559004] usbcore: registered new interface driver usbfs
[ 0.559058] usbcore: registered new interface driver hub
[ 0.559129] usbcore: registered new device driver usb
[ 0.563089] gpiochip_setup_dev: registered GPIOs 496 to 511 on device: gpiochip1 (tca9539)
[ 0.565413] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.567239] random: fast init done
[ 0.569125] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.569940] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.573089] vdd-ddr-1v1: 1150 mV
[ 0.577041] vdd-pre-reg-1v35: 1350 mV
[ 0.581039] vdd-1v8: 1800 mV
[ 0.585038] avdd-sys-1v2: 1200 mV
[ 0.589040] vdd-pex-1v0: 1050 mV
[ 0.589579] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.590064] max77620-ldo3: at 3100 mV
[ 0.593039] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.593574] max77620-ldo5: at 3100 mV
[ 0.597044] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.601037] avdd-1v05-pll: 1050 mV
[ 0.605036] avdd-io-hdmi-dp: 1050 mV
[ 0.606200] GPIO line 489 (spmic-default-output-high) hogged as output/high
[ 0.606472] gpiochip_setup_dev: registered GPIOs 488 to 495 on device: gpiochip2 (max77620-gpio)
[ 0.607809] max77620 4-003c: max77620 probe successful
[ 0.610489] media: Linux media interface: v0.10
[ 0.610545] Linux video capture interface: v2.00
[ 0.611454] pps_core: LinuxPPS API ver. 1 registered
[ 0.611460] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.611498] PTP clock support registered
[ 0.615516] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.621950] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.622775] Advanced Linux Sound Architecture Driver Initialized.
[ 0.623426] Bluetooth: Core ver 2.22
[ 0.623472] NET: Registered protocol family 31
[ 0.623477] Bluetooth: HCI device and connection manager initialized
[ 0.623489] Bluetooth: HCI socket layer initialized
[ 0.623500] Bluetooth: L2CAP socket layer initialized
[ 0.623527] Bluetooth: SCO socket layer initialized
[ 0.625314] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.625331] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.625379] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.625393] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.628582] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.629658] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.629721] vdd-3v3-sys: 3300 mV
[ 0.630017] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.633037] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.633524] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.633565] vdd-3v3-sd: 3300 mV
[ 0.634527] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.634567] avdd-io-edp-1v05: 1050 mV
[ 0.634999] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.635060] vdd-usb-hub-en: 5000 mV
[ 0.636351] pw-on-4g: 1800 mV
[ 0.637501] rst-4g: 1800 mV
[ 0.638639] en-4g-vdd-3v8: 3800 mV
[ 0.639788] en-aud-vdd-1v8: 1800 mV
[ 0.640957] en-aud-vdd-3v3: 3300 mV
[ 0.642125] en-aud-spk-5v0: 5000 mV
[ 0.643471] camchar: rtcpu character device driver loaded
[ 0.644194] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.645632] clocksource: Switched to clocksource arch_sys_counter
[ 0.686013] VFS: Disk quotas dquot_6.6.0
[ 0.686144] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.686628] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.687018] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.687034] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.687229] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.687234] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.687244] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.687269] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.687275] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.687286] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.687294] nvmap_page_pool_init: Total RAM pages: 1011302
[ 0.687299] nvmap_page_pool_init: nvmap page pool size: 126412 pages (493 MB)
[ 0.687389] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.687919] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.688824] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.696886] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.697300] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.697551] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.697800] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.697989] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.698257] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.698261] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.698703] NET: Registered protocol family 2
[ 0.699741] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.699951] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.700447] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.700599] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.700680] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.701084] NET: Registered protocol family 1
[ 0.701955] RPC: Registered named UNIX socket transport module.
[ 0.701962] RPC: Registered udp transport module.
[ 0.701966] RPC: Registered tcp transport module.
[ 0.701971] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.701984] PCI: CLS 0 bytes, default 64
[ 0.702212] Trying to unpack rootfs image as initramfs...
[ 0.936869] Freeing initrd memory: 5432K
[ 0.946450] host1x 50000000.host1x: initialized
[ 0.948317] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.951597] audit: initializing netlink subsys (disabled)
[ 0.951664] audit: type=2000 audit(0.799:1): initialized
[ 0.952401] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.962386] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.963849] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.964634] 9p: Installing v9fs 9p2000 file system support
[ 0.967898] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.968036] io scheduler noop registered
[ 0.968325] io scheduler cfq registered (default)
[ 0.971014] gic 702f9000.agic: GIC IRQ controller registered
[ 0.973998] iommu: Adding device 702ef000.adsp to group 33
[ 0.980636] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.980790] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.981367] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8a28c13
[ 0.981375] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.983593] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.983699] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.983803] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.984000] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.984087] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.984176] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.984260] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.984345] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.984433] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.984518] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.989937] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.991644] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.993523] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.994862] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.995206] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.996465] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.996689] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.996940] Adding domain tsec-pd to PM domain host1x-pd
[ 0.999151] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.000030] tsec 54500000.tsec: initialized
[ 1.001534] tsec 54100000.tsecb: initialized
[ 1.002271] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.005564] nvdec 54480000.nvdec: initialized
[ 1.006690] Adding domain vic03-pd to PM domain host1x-pd
[ 1.006865] Adding domain msenc-pd to PM domain host1x-pd
[ 1.007024] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.011053] falcon 54340000.vic: initialized
[ 1.012221] falcon 544c0000.nvenc: initialized
[ 1.013466] falcon 54380000.nvjpg: initialized
[ 1.018067] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.018189] display board info: id 0x0, fab 0x0
[ 1.018254] generic_infoframe_type: 0x87
[ 1.018387] tegradc tegradc.0: DT parsed successfully
[ 1.018434] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.021342] tegradc tegradc.0: probed
[ 1.026407] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.030689] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.031493] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.031855] kfuse 7000fc00.kfuse: initialized
[ 1.033247] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.034324] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.035846] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.035865] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.036400] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.037720] vdd-gpu: applied init 1000000uV constraint
[ 1.037727] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.038208] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.042384] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.042484] No Device Node present for smmu client: serial8250 !!
[ 1.042494] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.042535] iommu: Adding device serial8250 to group 35
[ 1.044844] console [ttyS0] disabled
[ 1.044918] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.049943] console [ttyS0] enabled
[ 1.050298] Console: switching to colour frame buffer device 80x30
[ 1.050334] tegradc tegradc.0: fb registered
[ 1.051544] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.051711] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.051784] tegradc tegradc.1: No lt-data, using default setting
[ 1.051818] tegradc tegradc.1: No hpd-gpio in DT
[ 1.051859] tegradc tegradc.1: DT parsed successfully
[ 1.051902] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.052035] serial-tegra 70006200.serial: RX in PIO mode
[ 1.052161] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.053346] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.053815] [drm] Initialized
[ 1.564780] Host read timeout at address 545c00c4
[ 1.566915] tegradc tegradc.1: probed
[ 1.575687] brd: module loaded
[ 1.589595] tegradc tegradc.1: fb registered
[ 1.592887] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.592895] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.592905] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.592926] tegradc tegradc.1: blank - powerdown
[ 1.592948] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.592953] Extcon DP: HPD disabled
[ 1.592957] hpd: hpd_switch 0
[ 1.592962] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.592970] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.592976] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.602232] loop: module loaded
[ 1.602812] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.602965] tegra_profiler: auth: init
[ 1.603899] THERMAL EST: found 2 subdevs
[ 1.603908] THERMAL EST num_resources: 0
[ 1.603914] [THERMAL EST subdev 0]
[ 1.603922] [THERMAL EST subdev 1]
[ 1.604371] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.604376] THERMAL EST: thz register success.
[ 1.608566] THERMAL EST: end of probe, return err: 0
[ 1.609772] hisi_sas: driver version v1.6
[ 1.615131] libphy: Fixed MDIO Bus: probed
[ 1.615799] tun: Universal TUN/TAP device driver, 1.6
[ 1.615805] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.616860] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.616867] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.616921] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.616924] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.616971] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.616975] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.617022] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.617026] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.622077] PPP generic driver version 2.4.2
[ 1.622274] PPP BSD Compression module registered
[ 1.622279] PPP Deflate Compression module registered
[ 1.622321] PPP MPPE Compression module registered
[ 1.622329] NET: Registered protocol family 24
[ 1.622397] usbcore: registered new interface driver r8152
[ 1.622445] usbcore: registered new interface driver asix
[ 1.622492] usbcore: registered new interface driver ax88179_178a
[ 1.622534] usbcore: registered new interface driver cdc_ether
[ 1.622576] usbcore: registered new interface driver net1080
[ 1.622614] usbcore: registered new interface driver cdc_subset
[ 1.622655] usbcore: registered new interface driver zaurus
[ 1.622696] usbcore: registered new interface driver simcom_wwan
[ 1.622747] usbcore: registered new interface driver cdc_ncm
[ 1.622914] VFIO - User Level meta-driver version: 0.3
[ 1.628209] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.628234] ehci-pci: EHCI PCI platform driver
[ 1.628279] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.628291] ohci-pci: OHCI PCI platform driver
[ 1.628331] ohci-platform: OHCI generic platform driver
[ 1.631029] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.631638] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.632820] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f910d400 id
[ 1.634038] usbcore: registered new interface driver uas
[ 1.634097] usbcore: registered new interface driver usb-storage
[ 1.634227] usbcore: registered new interface driver usbserial
[ 1.637351] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.639282] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.639299] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.639315] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.639327] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.639351] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.640103] mousedev: PS/2 mouse device common for all mice
[ 1.640200] usbcore: registered new interface driver xpad
[ 1.640494] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 1.640550] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.640574] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.641481] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.641541] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.641916] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.641923] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.641929] usb usb1: Product: xHCI Host Controller
[ 1.641934] usb usb1: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.641939] usb usb1: SerialNumber: 70090000.xusb
[ 1.643247] hub 1-0:1.0: USB hub found
[ 1.643366] hub 1-0:1.0: 5 ports detected
[ 1.644147] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.644160] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.644336] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.644449] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.644454] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.644459] usb usb2: Product: xHCI Host Controller
[ 1.644464] usb usb2: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.644468] usb usb2: SerialNumber: 70090000.xusb
[ 1.644923] hub 2-0:1.0: USB hub found
[ 1.644956] hub 2-0:1.0: 4 ports detected
[ 1.736527] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.739049] rtc rtc1: alarm rtc device
[ 1.739070] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.739103] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.739793] i2c /dev entries driver
[ 1.741821] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.742237] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.742244] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.743109] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.745744] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.766449] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.766546] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.774135] imx219 7-0010: board setup failed
[ 1.778604] imx219: probe of 7-0010 failed with error -121
[ 1.779149] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.802431] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.802525] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.810061] imx219 8-0010: board setup failed
[ 1.814497] imx219: probe of 8-0010 failed with error -121
[ 1.815595] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.818316] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.818322] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.818775] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.818794] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.818804] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.818935] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.818946] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.818953] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.819099] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.819110] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.819116] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.819295] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.820073] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.820132] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.820160] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.820179] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.820188] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.821093] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.821112] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.821313] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.821344] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.821796] parse_throttle_dt_data: Num cap clks = 6
[ 1.821802] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.821817] parse_throttle_dt_data: clk=gpu type=4
[ 1.821844] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.821866] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.821890] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.821895] parse_throttle_dt_data: clk=emc type=3
[ 1.822287] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.822394] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.822524] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.823304] FAN dev name: pwm-fan
[ 1.823360] FAN:gpio request success.
[ 1.823436] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.823764] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.823970] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.823980] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.824080] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.824086] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.824092] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.824097] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.824102] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.824108] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.824112] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.824117] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.824122] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.824127] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.824782] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.825108] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.826054] device-mapper: uevent: version 1.0.3
[ 1.826513] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.832245] tegra210-cpufreq cpufreq: probe()...completed
[ 1.832957] sdhci: Secure Digital Host Controller Interface driver
[ 1.832959] sdhci: Copyright(c) Pierre Ossman
[ 1.832961] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.833314] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.838058] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[ 1.840740] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.841293] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.842637] usbcore: registered new interface driver usbhid
[ 1.842640] usbhid: USB HID core driver
[ 1.844815] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.844980] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.846456] mpu6xxx 1-0069: nvi_probe mpu9250
[ 1.847084] nvpmodel: initialized successfully
[ 1.848058] usbcore: registered new interface driver snd-usb-audio
[ 1.848115] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.848121] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.848140] iommu: Adding device snd-soc-dummy to group 36
[ 1.850510] chien:wm8960_i2c_probe,ret=0
[ 1.860598] OPE platform probe
[ 1.860682] OPE platform probe successful
[ 1.860707] OPE platform probe
[ 1.860789] OPE platform probe successful
[ 1.869402] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.873650] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 1.885685] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 1.887837] chien:wm8960_probe
[ 1.888961] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.889107] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.889237] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.889364] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.889506] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.889658] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.889794] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.889923] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.890051] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.890180] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.925247] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.925798] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 1.925992] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 1.927204] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.939638] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.969690] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.990228] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
[ 1.990233] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.990236] usb 1-2: Product: USB 2.0 Hub
[ 1.991250] hub 1-2:1.0: USB hub found
[ 1.991318] hub 1-2:1.0: 4 ports detected
[ 2.012661] chien:tegra_machine_driver_probe,ret=0
[ 2.013167] u32 classifier
[ 2.013169] Actions configured
[ 2.013245] Initializing XFRM netlink socket
[ 2.014003] NET: Registered protocol family 10
[ 2.014673] NET: Registered protocol family 17
[ 2.014687] NET: Registered protocol family 15
[ 2.014761] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.014806] Bluetooth: RFCOMM socket layer initialized
[ 2.014815] Bluetooth: RFCOMM ver 1.11
[ 2.014821] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.014826] Bluetooth: HIDP socket layer initialized
[ 2.014845] 9pnet: Installing 9P2000 support
[ 2.014882] Key type dns_resolver registered
[ 2.015261] Registered cp15_barrier emulation handler
[ 2.015267] Registered setend emulation handler
[ 2.016324] registered taskstats version 1
[ 2.016857] Adding domain ve2-pd to PM domain host1x-pd
[ 2.017112] Adding domain ve-pd to PM domain host1x-pd
[ 2.019218] isp 54600000.isp: initialized
[ 2.020255] isp 54680000.isp: initialized
[ 2.030566] last reset is due to software reset
[ 2.030571] KERNEL: PMC reset status reg: 0x3
[ 2.030648] BL: PMC reset status reg: 0x3
[ 2.030650] BL: PMIC poweroff Event Recorder: 0x0
[ 2.032139] clk_cbus_recalc_rate: no gbus parent
[ 2.032145] clk_cbus_round_rate: no gbus parent
[ 2.032147] clk_cbus_round_rate: no gbus parent
[ 2.032155] clk_cbus_recalc_rate: no gbus parent
[ 2.032260] clk_cbus_recalc_rate: no gbus parent
[ 2.032264] clk_cbus_round_rate: no gbus parent
[ 2.032266] clk_cbus_round_rate: no gbus parent
[ 2.032270] clk_cbus_recalc_rate: no gbus parent
[ 2.032950] tegra_dvfs: GPU-cap: registered
[ 2.033003] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 2.033006] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 2.033008] tegra dvfs: vdd-gpu: nominal 1038mV, offset 708000uV, step 10000uV, scaling enabled
[ 2.034425] tegra_dvfs: vdd-gpu-vts: registered
[ 2.035111] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 2.035649] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 2.036193] input: gpio-keys as /devices/gpio-keys/input/input1
[ 2.066634] tegra_rtc 7000e000.rtc: setting system clock to 2019-11-20 08:15:51 UTC (1574237751)
[ 2.067658] vi 54080000.vi: vi_probe: ++
[ 2.070278] vi 54080000.vi: initialized
[ 2.072313] vi 54080000.vi: subdev nvcsi--2 bound
[ 2.072453] vi 54080000.vi: subdev nvcsi--1 bound
[ 2.072707] mmcblk mmc0:0001: Card claimed for testing.
[ 2.074071] Disable partitions left on by BL
[ 2.074075] disb
[ 2.074118] bwmgr: missing cdev-type property
[ 2.074244] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.074251] DRAM derating cdev registered.
[ 2.074689] mpu6xxx 1-0069: nvi_id_dev: USING DEVICE TREE: mpu9250
[ 2.074840] mpu6xxx 1-0069: nvs_probe (iio)
[ 2.075231] mpu6xxx 1-0069: nvs_probe (iio) accelerometer done
[ 2.075235] mpu6xxx 1-0069: nvs_probe (iio)
[ 2.075313] ak89xx 1-000c: ak89xx akm_probe
[ 2.075569] mpu6xxx 1-0069: nvs_probe (iio) gyroscope done
[ 2.075572] mpu6xxx 1-0069: nvs_probe (iio)
[ 2.075811] mpu6xxx 1-0069: nvs_probe (iio) gyro_temp done
[ 2.075815] mpu6xxx 1-0069: nvs_probe (iio)
[ 2.075818] mpu6xxx 1-0069: nvs_probe significant_motion disabled
[ 2.075820] mpu6xxx 1-0069: nvs_probe (iio)
[ 2.075823] mpu6xxx 1-0069: nvs_probe step_detector disabled
[ 2.075826] mpu6xxx 1-0069: nvs_probe (iio)
[ 2.075829] mpu6xxx 1-0069: nvs_probe quaternion disabled
[ 2.075832] mpu6xxx 1-0069: nvs_probe (iio)
[ 2.075834] mpu6xxx 1-0069: nvs_probe geomagnetic_rotation_vector disabled
[ 2.075837] mpu6xxx 1-0069: nvs_probe (iio)
[ 2.075840] mpu6xxx 1-0069: nvs_probe gyroscope_uncalibrated disabled
[ 2.076600] mpu6xxx 1-0069: nvi_dmp_fw_load_worker done
[ 2.147365] mmc1: error -110 whilst initialising SD card
[ 2.148344] mpu6xxx 1-0069: nvi_aux_dev_valid MPU read 0x48 from device 0xc
[ 2.148348] ak89xx 1-000c: akm_id_dev AUTO ID=48 ret=0
[ 2.182223] ak89xx 1-000c: akm_self_test ERR: out_of_range 4
[ 2.205483] ak89xx 1-000c: nvs_probe (iio)
[ 2.205793] ak89xx 1-000c: nvs_probe (iio) magnetic_field done
[ 2.205796] ak89xx 1-000c: akm_probe done
[ 2.206338] vdd-fan: disabling
[ 2.206341] vdd-usb-vbus: disabling
[ 2.206344] vdd-usb-vbus2: disabling
[ 2.206351] vddio-sdmmc-ap: disabling
[ 2.206433] vdd-3v3-sd: disabling
[ 2.206438] avdd-io-edp-1v05: disabling
[ 2.206441] vdd-usb-hub-en: disabling
[ 2.206444] pw-on-4g: disabling
[ 2.206446] rst-4g: disabling
[ 2.206449] en-4g-vdd-3v8: disabling
[ 2.206451] en-aud-vdd-1v8: disabling
[ 2.206454] en-aud-vdd-3v3: disabling
[ 2.206456] en-aud-spk-5v0: disabling
[ 2.206593] ALSA device list:
[ 2.206596] #0: tegra-hda at 0x70038000 irq 82
[ 2.206598] #1: tegra-snd-t210ref-mobile-rt565x
[ 2.209722] Freeing unused kernel memory: 8576K
[ 2.228137] L4T-INITRD Build DATE: Wed Nov 20 08:15:51 UTC 2019
[ 2.232539] Root device found: mmcblk0p1
[ 2.233646] Found dev node: /dev/mmcblk0p1
[ 2.277640] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 2.299128] usb 1-2.1: New USB device found, idVendor=05e3, idProduct=0608
[ 2.299133] usb 1-2.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.299136] usb 1-2.1: Product: USB2.0 Hub
[ 2.300530] hub 1-2.1:1.0: USB hub found
[ 2.300898] hub 1-2.1:1.0: 4 ports detected
[ 2.313339] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 2.313343] EXT4-fs (mmcblk0p1): recovery complete
[ 2.320572] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.321297] Rootfs mounted over mmcblk0p1
[ 2.337428] Switching from initrd to actual rootfs
[ 2.343654] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.439035] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.450488] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.464808] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.465549] systemd[1]: Detected architecture arm64.
[ 2.490390] systemd[1]: Set hostname to <zalend-desktop>.
[ 2.550510] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.550520] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.593641] usb 1-2.1.1: new high-speed USB device number 4 using tegra-xusb
[ 2.626800] usb 1-2.1.1: New USB device found, idVendor=0b95, idProduct=772b
[ 2.626805] usb 1-2.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.626808] usb 1-2.1.1: Product: AX88772C
[ 2.626811] usb 1-2.1.1: Manufacturer: ASIX Elec. Corp.
[ 2.626813] usb 1-2.1.1: SerialNumber: 0007AC
[ 2.645994] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.647649] systemd[1]: Created slice System Slice.
[ 2.648010] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.648113] systemd[1]: Listening on Journal Audit Socket.
[ 2.648140] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.649025] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.649073] systemd[1]: Reached target User and Group Name Lookups.
[ 2.649904] systemd[1]: Created slice User and Session Slice.
[ 2.729152] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.747665] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.749654] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.855084] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.855092] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.855096] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.855100] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.855104] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.855125] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.855190] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.855386] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.855514] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.855539] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.855570] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 2.855590] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 2.855719] pci 0000:01:00.0: supports D1 D2
[ 2.855723] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.865701] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.865736] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 2.865740] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.865748] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[ 2.865766] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[ 2.865783] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.865791] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.865795] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.865802] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[ 2.866102] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.866107] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.866113] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.866222] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.866409] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 2.866427] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.888005] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.888101] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e9:d7:54 from device tree
[ 2.888630] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.888646] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.035563] systemd-journald[1956]: Received request to flush runtime journal from PID 1
[ 3.045900] asix 1-2.1.1:1.0 eth1: register 'asix' at usb-70090000.xusb-2.1.1, ASIX AX88772B USB 2.0 Ethernet, 00:0e:c6:be:31:16
[ 3.253020] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 3.512882] using random self ethernet address
[ 3.519563] using random host ethernet address
[ 3.554146] Mass Storage Function, version: 2009/09/11
[ 3.554152] LUN: removable file: (no medium)
[ 3.559717] using random self ethernet address
[ 3.601796] using random host ethernet address
[ 3.678329] rndis0: HOST MAC d6:a6:51:6f:d6:dc
[ 3.678380] rndis0: MAC d6:a6:51:6f:d6:dd
[ 3.682560] usb0: HOST MAC d6:a6:51:6f:d6:de
[ 3.682592] usb0: MAC d6:a6:51:6f:d6:df
[ 3.682619] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 3.690424] l4tbr0: port 1(rndis0) entered blocking state
[ 3.690429] l4tbr0: port 1(rndis0) entered disabled state
[ 3.690986] device rndis0 entered promiscuous mode
[ 3.707100] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 3.714892] l4tbr0: port 2(usb0) entered blocking state
[ 3.714897] l4tbr0: port 2(usb0) entered disabled state
[ 3.715071] device usb0 entered promiscuous mode
[ 3.732021] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 3.986718] android_work: did not send uevent (0 0 (null))
[ 4.055408] android_work: sent uevent USB_STATE=CONNECTED
[ 4.066785] android_work: sent uevent USB_STATE=DISCONNECTED
[ 4.068747] random: crng init done
[ 4.072157] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.163486] android_work: sent uevent USB_STATE=CONNECTED
[ 4.165895] configfs-gadget gadget: high-speed config #1: c
[ 4.165924] tegra-xudc-new 700d0000.xudc: ep 5 (type: 3, dir: in) enabled
[ 4.165940] tegra-xudc-new 700d0000.xudc: ep 3 (type: 2, dir: in) enabled
[ 4.165956] tegra-xudc-new 700d0000.xudc: ep 2 (type: 2, dir: out) enabled
[ 4.166053] tegra-xudc-new 700d0000.xudc: ep 9 (type: 3, dir: in) enabled
[ 4.166069] tegra-xudc-new 700d0000.xudc: ep 7 (type: 2, dir: in) enabled
[ 4.166084] tegra-xudc-new 700d0000.xudc: ep 4 (type: 2, dir: out) enabled
[ 4.166115] tegra-xudc-new 700d0000.xudc: ep 15 (type: 3, dir: in) enabled
[ 4.166147] tegra-xudc-new 700d0000.xudc: ep 11 (type: 2, dir: in) enabled
[ 4.166154] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 4.166164] tegra-xudc-new 700d0000.xudc: ep 6 (type: 2, dir: out) enabled
[ 4.166294] android_work: sent uevent USB_STATE=CONFIGURED
[ 4.172669] tegra-xudc-new 700d0000.xudc: ep 13 (type: 2, dir: in) enabled
[ 4.172688] tegra-xudc-new 700d0000.xudc: ep 8 (type: 2, dir: out) enabled
[ 4.172800] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 4.619477] zram: Added device: zram0
[ 4.619984] zram: Added device: zram1
[ 4.620571] zram: Added device: zram2
[ 4.627544] zram: Added device: zram3
[ 4.671381] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.674208] eth0: 0xffffff800ac4b000, 00:04:4b:e9:d7:54, IRQ 413
[ 4.689663] zram0: detected capacity change from 0 to 519581696
[ 4.737153] Adding 507400k swap on /dev/zram0. Priority:5 extents:1 across:507400k SS
[ 4.758675] zram1: detected capacity change from 0 to 519581696
[ 4.835583] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.839825] Adding 507400k swap on /dev/zram1. Priority:5 extents:1 across:507400k SS
[ 4.844713] zram2: detected capacity change from 0 to 519581696
[ 4.859648] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 4.880632] Adding 507400k swap on /dev/zram2. Priority:5 extents:1 across:507400k SS
[ 4.885148] zram3: detected capacity change from 0 to 519581696
[ 4.885835] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 4.904095] Adding 507400k swap on /dev/zram3. Priority:5 extents:1 across:507400k SS
[ 5.052997] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 5.056096] asix 1-2.1.1:1.0 eth1: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 5.515565] tegradc tegradc.0: blank - powerdown
[ 5.829738] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.829745] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.929923] usb usb2: usb_suspend_both: status 0
[ 6.069664] FAN rising trip_level:1 cur_temp:51250 trip_temps[2]:61000
[ 6.168440] tegradc tegradc.0: blank - powerdown
[ 6.168455] tegradc tegradc.1: blank - powerdown
[ 6.488424] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 6.742968] fuse init (API version 7.26)
[ 6.749651] usb 1-3: new high-speed USB device number 5 using tegra-xusb
[ 6.784701] usb 1-3: New USB device found, idVendor=1e0e, idProduct=9001
[ 6.784709] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.784713] usb 1-3: Product: SimTech, Incorporated
[ 6.784717] usb 1-3: Manufacturer: SimTech, Incorporated
[ 6.784720] usb 1-3: SerialNumber: 0123456789ABCDEF
[ 6.788950] simcom_wwan: probe of 1-3:1.0 failed with error -22
[ 6.795393] simcom_wwan: probe of 1-3:1.1 failed with error -22
[ 6.805884] simcom_wwan: probe of 1-3:1.2 failed with error -22
[ 6.812264] simcom_wwan: probe of 1-3:1.3 failed with error -22
[ 6.821324] simcom_wwan: probe of 1-3:1.4 failed with error -22
[ 6.829852] simcom usbnet bind here
[ 6.831126] simcom_wwan 1-3:1.5 wwan0: register 'simcom_wwan' at usb-70090000.xusb-3, SIMCOM wwan/QMI device, 0e:4a:45:20:ea:72
[ 7.017117] usbcore: registered new interface driver option
[ 7.019201] usbserial: USB Serial support registered for GSM modem (1-port)
[ 7.019452] option 1-3:1.0: GSM modem (1-port) converter detected
[ 7.020054] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB0
[ 7.020192] option 1-3:1.1: GSM modem (1-port) converter detected
[ 7.020749] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB1
[ 7.020886] option 1-3:1.2: GSM modem (1-port) converter detected
[ 7.021394] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB2
[ 7.021539] option 1-3:1.3: GSM modem (1-port) converter detected
[ 7.026243] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB3
[ 7.026381] option 1-3:1.4: GSM modem (1-port) converter detected
[ 7.026921] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB4
[ 9.660783] l4tbr0: port 2(usb0) entered blocking state
[ 9.660789] l4tbr0: port 2(usb0) entered forwarding state
[ 9.660850] l4tbr0: port 1(rndis0) entered blocking state
[ 9.660855] l4tbr0: port 1(rndis0) entered forwarding state
[ 9.666854] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 9.666887] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 12.294449] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.433685] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.549545] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.670572] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.671716] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.673456] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.785852] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.786993] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.799941] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 12.953328] pll_a_out0 = 45158400 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
