Sorry for relay so late, here is the full message
[code][ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (root@tegra-ubuntu) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.10) ) #3 SMP PREEMPT Thu Aug 9 13:06:41 UTC 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31256 r8192 d30184 u69632
[ 0.000000] pcpu-alloc: s31256 r8192 d30184 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0323917023616 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7976108K/8208384K available (11376K kernel code, 1794K rwdata, 5656K rodata, 1148K init, 687K bss, 166740K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc001123000 - 0xffffffc001242000 ( 1148 KB)
.text : 0xffffffc000080000 - 0xffffffc001123000 ( 17036 KB)
.data : 0xffffffc001263000 - 0xffffffc001423b90 ( 1795 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009832] Console: colour dummy device 80x25
[ 0.014490] console [tty0] enabled
[ 0.018044] bootconsole [uart0] disabled
[ 0.022145] kmemleak: Kernel memory leak detector disabled
[ 0.022156] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022166] pid_max: default: 32768 minimum: 301
[ 0.022215] Security Framework initialized
[ 0.022248] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022257] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022636] Initializing cgroup subsys io
[ 0.022648] Initializing cgroup subsys memory
[ 0.022665] Initializing cgroup subsys devices
[ 0.022673] Initializing cgroup subsys freezer
[ 0.022680] Initializing cgroup subsys net_cls
[ 0.022690] Initializing cgroup subsys perf_event
[ 0.022697] Initializing cgroup subsys net_prio
[ 0.022706] Initializing cgroup subsys pids
[ 0.022712] Initializing cgroup subsys debug
[ 0.022850] CPU0 ipc=752
[ 0.022858] CPU1 ipc=1024
[ 0.022865] CPU2 ipc=1024
[ 0.022872] CPU3 ipc=752
[ 0.022880] CPU4 ipc=752
[ 0.022888] CPU5 ipc=752
[ 0.022927] ASID allocator initialised with 65536 entries
[ 0.046205] tegra-id: chipid=21817.
[ 0.046222] tegra-id: opt_subrevision=1.
[ 0.046234] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046878] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046897] DTB Build time: May 21 2018 10:37:41
[ 0.062547] CPU1: Booted secondary processor [4e0f0030]
[ 0.074118] CPU2: Booted secondary processor [4e0f0030]
[ 0.085832] CPU3: Booted secondary processor [411fd073]
[ 0.097840] CPU4: Booted secondary processor [411fd073]
[ 0.109800] CPU5: Booted secondary processor [411fd073]
[ 0.109867] Brought up 6 CPUs
[ 0.109920] SMP: Total of 6 processors activated.
[ 0.109932] CPU: All CPU(s) started at EL2
[ 0.110397] devtmpfs: initialized
[ 0.137736] Initilizing CustomIPI irq domain
[ 0.137937] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138709] pinctrl core: initialized pinctrl subsystem
[ 0.138876] OS set in device tree is not L4T.
[ 0.139065] regulator-dummy: no parameters
[ 0.139170] Initializing plugin-manager
[ 0.139223] Plugin module not found
[ 0.139633] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139972] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140578] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141757] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.142105] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.142357] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142577] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142995] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143434] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143708] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.144085] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.144330] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144548] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144801] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146768] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148609] Adding domain adsp-pd to PM domain ape-pd
[ 0.151021] NET: Registered protocol family 16
[ 0.151701] console [pstore-1] enabled
[ 0.151711] pstore: Registered ramoops as persistent store backend
[ 0.151724] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161332] cpuidle: using governor ladder
[ 0.165831] cpuidle: using governor menu
[ 0.166968] bpmp: waiting for handshake
[ 0.166982] bpmp: handshake completed
[ 0.167021] bpmp: synchronizing channels
[ 0.167051] bpmp: channels synchronized
[ 0.167061] bpmp: mail init ok
[ 0.167430] vdso: 2 pages (1 code @ ffffffc001269000, 1 data @ ffffffc001268000)
[ 0.167463] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168410] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169847] tegra_powergate_init: DONE
[ 0.169869] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169889] DTB Build time: May 21 2018 10:37:41
[ 0.170820] Tegra reboot handler registered.
[ 0.171854] Registering Tegra186 clocks (this may take a while)…done
[ 0.173403] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.173418] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173431] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173442] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173453] arm-smmu 12000000.iommu: nested translation
[ 0.173466] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.173484] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.173501] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.173514] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.173525] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.219178] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.224908] iommu: Adding device 3460000.sdhci to group 0
[ 0.225843] iommu: Adding device 3400000.sdhci to group 1
[ 0.229618] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.230113] iommu: Adding device 3160000.i2c to group 3
[ 0.230502] iommu: Adding device c240000.i2c to group 4
[ 0.230895] iommu: Adding device 3180000.i2c to group 5
[ 0.231252] iommu: Adding device 3190000.i2c to group 6
[ 0.231680] iommu: Adding device 31b0000.i2c to group 7
[ 0.232028] iommu: Adding device 31c0000.i2c to group 8
[ 0.232316] iommu: Adding device c250000.i2c to group 9
[ 0.232627] iommu: Adding device 31e0000.i2c to group 10
[ 0.234638] iommu: Adding device 3210000.spi to group 11
[ 0.234967] iommu: Adding device c260000.spi to group 12
[ 0.235301] iommu: Adding device 3240000.spi to group 13
[ 0.236128] iommu: Adding device 3100000.serial to group 14
[ 0.236425] iommu: Adding device 3110000.serial to group 15
[ 0.236705] iommu: Adding device c280000.serial to group 16
[ 0.237033] iommu: Adding device 3130000.serial to group 17
[ 0.237349] iommu: Adding device 3140000.serial to group 18
[ 0.237628] iommu: Adding device 3150000.serial to group 19
[ 0.237958] iommu: Adding device c290000.serial to group 20
[ 0.239150] iommu: Adding device 2490000.ether_qos to group 21
[ 0.239749] iommu: Adding device b000000.rtcpu to group 22
[ 0.240172] iommu: Adding device c1a0000.aon to group 23
[ 0.241037] Wake73 for irq=42
[ 0.241391] iommu: Adding device smmu_test to group 24
[ 0.241865] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.241904] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.241940] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.242002] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.242035] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.242067] mc-err: Set intmask: 0xf3140
[ 0.242238] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.243041] Wake76 for irq=199
[ 0.243063] Wake77 for irq=199
[ 0.243083] Wake78 for irq=199
[ 0.243101] Wake79 for irq=199
[ 0.243120] Wake80 for irq=199
[ 0.243139] Wake81 for irq=199
[ 0.243177] Wake82 for irq=199
[ 0.243318] iommu: Adding device 3530000.xhci to group 25
[ 0.243677] iommu: Adding device 3550000.xudc to group 26
[ 0.244511] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.244540] tegra-pmc: ### PMC reset source: Power on reset
[ 0.244562] tegra-pmc: ### PMC reset level: L0
[ 0.244581] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.244853] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.244889] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.245050] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.245077] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.245577] iommu: Adding device 13e10000.host1x to group 27
[ 0.245827] iommu: Adding device 13e10000.host1x:ctx0 to group 28
[ 0.246073] iommu: Adding device 13e10000.host1x:ctx1 to group 29
[ 0.246303] iommu: Adding device 13e10000.host1x:ctx2 to group 30
[ 0.246581] iommu: Adding device 13e10000.host1x:ctx3 to group 31
[ 0.246800] iommu: Adding device 13e10000.host1x:ctx4 to group 32
[ 0.247035] iommu: Adding device 13e10000.host1x:ctx5 to group 33
[ 0.247245] iommu: Adding device 13e10000.host1x:ctx6 to group 34
[ 0.247534] iommu: Adding device 13e10000.host1x:ctx7 to group 35
[ 0.247945] iommu: Adding device 150c0000.nvcsi to group 36
[ 0.248466] iommu: Adding device 15700000.vi to group 37
[ 0.248803] iommu: Adding device 15600000.isp to group 38
[ 0.249119] iommu: Adding device 15210000.nvdisplay to group 39
[ 0.249329] iommu: Adding device 15340000.vic to group 40
[ 0.249531] iommu: Adding device 154c0000.nvenc to group 41
[ 0.249740] iommu: Adding device 15480000.nvdec to group 42
[ 0.250082] iommu: Adding device 15380000.nvjpg to group 43
[ 0.250306] iommu: Adding device 15500000.tsec to group 44
[ 0.250508] iommu: Adding device 15100000.tsecb to group 45
[ 0.251221] iommu: Adding device 15810000.se to group 46
[ 0.251446] iommu: Adding device 15820000.se to group 47
[ 0.251626] iommu: Adding device 15830000.se to group 48
[ 0.251806] iommu: Adding device 15840000.se to group 49
[ 0.252292] iommu: Adding device 17000000.gp10b to group 50
[ 0.253652] tegra-reset 5000000.clock: registered 193 resets.
[ 0.255600] iommu: Adding device d000000.bpmp to group 51
[ 0.256024] bpmp: ping status is 0
[ 0.256211] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.256576] bpmp d000000.bpmp: probe ok
[ 0.259264] iommu: Adding device 2600000.dma to group 52
[ 0.260090] GPIO line 460 (wifi-over-pcie) hogged as output/low
[ 0.260151] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.260202] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.260268] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.260310] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.260357] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.260401] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.260446] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.260570] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.262449] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.262569] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.263426] iommu: Adding device 10003000.pcie-controller to group 53
[ 0.263672] iommu: Adding device sound to group 54
[ 0.265321] iommu: Adding device 3510000.hda to group 55
[ 0.266386] iommu: Adding device adsp_audio to group 56
[ 0.267731] iommu: Adding device 2993000.adsp to group 57
[ 0.276816] vdd-ac-bat: 5000 mV
[ 0.278956] vdd-1v8-ap: 1800 mV
[ 0.296853] SCSI subsystem initialized
[ 0.297078] libata version 3.00 loaded.
[ 0.297249] usbcore: registered new interface driver usbfs
[ 0.297304] usbcore: registered new interface driver hub
[ 0.297407] usbcore: registered new device driver usb
[ 0.300271] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.300504] pca953x 0-0074: failed reading register
[ 0.300575] pca953x: probe of 0-0074 failed with error -121
[ 0.300966] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.301180] pca953x 0-0077: failed reading register
[ 0.301238] pca953x: probe of 0-0077 failed with error -121
[ 0.312564] media: Linux media interface: v0.10
[ 0.312632] Linux video capture interface: v2.00
[ 0.316562] pps_core: LinuxPPS API ver. 1 registered
[ 0.316588] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.316634] PTP clock support registered
[ 0.317521] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.317588] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.319040] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.320962] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.321146] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.321243] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.326279] vddio-ddr: at 1125 mV
[ 0.330124] avdd_dsi_csi: 1200 mV
[ 0.334128] vdd-1v8: 1800 mV
[ 0.338126] vdd-3v3-sys: 3300 mV
[ 0.339168] spmic-ldo0: at 1800 mV
[ 0.339938] spmic-ldo1: at 800 mV
[ 0.342128] vddio-3v3: 3300 mV
[ 0.342765] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.346128] vdd-rtc: at 800 mV
[ 0.346959] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.350126] spmic-ldo6: at 1500 mV
[ 0.353844] vdd-pex-1v05: 1000 mV
[ 0.354438] dvdd-pex: 1000 mV
[ 0.354698] max77620 4-003c: max77620 probe successful
[ 0.354955] Advanced Linux Sound Architecture Driver Initialized.
[ 0.355934] en-vdd-sd: 3300 mV
[ 0.356208] vdd-usb0-5v: 5000 mV
[ 0.356376] vdd-usb1-5v: 5000 mV
[ 0.356728] vdd-3v3: 3300 mV
[ 0.356870] en-vdd-vcm-2v8: 2800 mV
[ 0.357010] vdd-sys-bl: 3300 mV
[ 0.360358] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 0.360762] clocksource: Switched to clocksource arch_sys_counter
[ 0.379661] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.379930] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.380412] nvmap_page_pool_init: Total RAM pages: 2010411
[ 0.380428] nvmap_page_pool_init: nvmap page pool size: 251301 pages (981 MB)
[ 0.380645] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.385133] Wake76 for irq=199
[ 0.385145] Wake77 for irq=199
[ 0.385155] Wake78 for irq=199
[ 0.385164] Wake79 for irq=199
[ 0.385172] Wake80 for irq=199
[ 0.385181] Wake81 for irq=199
[ 0.385189] Wake82 for irq=199
[ 0.385899] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.386090] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.386207] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.386284] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.386651] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.386790] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.386926] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.387069] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.387363] isomgr_init(): iso emc max clk=1866000KHz
[ 0.387374] isomgr_init(): max_iso_bw=26870400KB
[ 0.387459] NET: Registered protocol family 2
[ 0.387842] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.388041] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.388330] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.388380] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.388437] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.388598] NET: Registered protocol family 1
[ 0.388800] RPC: Registered named UNIX socket transport module.
[ 0.388814] RPC: Registered udp transport module.
[ 0.388823] RPC: Registered tcp transport module.
[ 0.388833] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.388853] PCI: CLS 0 bytes, default 128
[ 0.388950] Trying to unpack rootfs image as initramfs…
[ 0.402576] host1x 13e10000.host1x: initialized
[ 0.403380] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.405525] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.405623] audit: initializing netlink subsys (disabled)
[ 0.405653] audit: type=2000 audit(0.392:1): initialized
[ 0.412454] io scheduler noop registered
[ 0.412565] io scheduler cfq registered (default)
[ 0.415556] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.416760] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.417816] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.418840] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.422223] tsec 15500000.tsec: initialized
[ 0.423309] tsec 15100000.tsecb: initialized
[ 0.425340] nvdec 15480000.nvdec: initialized
[ 0.428766] falcon 15340000.vic: initialized
[ 0.429780] falcon 154c0000.nvenc: initialized
[ 0.430780] falcon 15380000.nvjpg: initialized
[ 0.431489] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.431990] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.432497] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.433015] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.433519] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.434018] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.434521] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.435019] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.436367] DC OR NODE connected to /host1x/sor1
[ 0.436493] generic_infoframe_type: 0x87
[ 0.436506] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.436594] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.436604] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.436608] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.436665] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.443812] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.443831] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.443846] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.443888] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.443903] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.444021] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.444283] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 0.446273] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.446493] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.446605] kfuse 3830000.kfuse: initialized
[ 0.447774] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.448189] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.450141] console [ttyS0] disabled
[ 0.450185] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.482015] tegradc 15210000.nvdisplay: probed
[ 2.516880] console [ttyS0] enabled
[ 2.518871] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.519905] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.520159] serial-tegra 3130000.serial: RX in PIO mode
[ 2.521005] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.521984] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 41, base_baud = 0) is a TEGRA_UART
[ 2.522942] 3150000.serial: ttyTHS5 at MMIO 0x3150000 (irq = 42, base_baud = 0) is a TEGRA_UART
[ 2.523927] c290000.serial: ttyTHS6 at MMIO 0xc290000 (irq = 43, base_baud = 0) is a TEGRA_UART
[ 2.525066] Console: switching to colour frame buffer device 240x67
[ 2.534417] brd: module loaded
[ 2.538909] loop: module loaded
[ 2.539127] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.539131] nct1008_nct72 7-004c: starting parse dt
[ 2.539212] nct1008_nct72 7-004c: success parsing dt
[ 2.539323] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.552174] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.575860] tmp451: Enabled overheat logging at 104.00C
[ 2.576014] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.578455] THERMAL EST: found 3 subdevs
[ 2.578459] THERMAL EST num_resources: 0
[ 2.578463] [THERMAL EST subdev 0]
[ 2.578473] [THERMAL EST subdev 1]
[ 2.578477] [THERMAL EST subdev 2]
[ 2.578767] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.578769] THERMAL EST: thz register success.
[ 2.578946] THERMAL EST: end of probe, return err: 0
[ 2.579023] tegra_profiler: Branch: Dev
[ 2.579025] tegra_profiler: Version: 1.112
[ 2.579027] tegra_profiler: Samples version: 39
[ 2.579029] tegra_profiler: IO version: 22
[ 2.579037] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.579040] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.579044] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.579047] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.579050] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.579053] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.579056] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.579059] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.579062] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.579064] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.579067] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.579070] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.579247] tegra_profiler: auth: init
[ 2.582503] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.582515] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.583447] scsi host0: tegra_ahci
[ 2.583808] scsi host1: tegra_ahci
[ 2.583944] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.583947] ata2: DUMMY
[ 2.584887] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.585300] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.585677] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.586495] tun: Universal TUN/TAP device driver, 1.6
[ 2.586497] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.586658] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.586660] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.586694] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.586696] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.587756] PPP generic driver version 2.4.2
[ 2.587871] PPP BSD Compression module registered
[ 2.587878] PPP Deflate Compression module registered
[ 2.587900] PPP MPPE Compression module registered
[ 2.587910] NET: Registered protocol family 24
[ 2.587957] usbcore: registered new interface driver r8152
[ 2.587987] usbcore: registered new interface driver asix
[ 2.588017] usbcore: registered new interface driver ax88179_178a
[ 2.588042] usbcore: registered new interface driver cdc_ether
[ 2.588075] usbcore: registered new interface driver smsc75xx
[ 2.588129] usbcore: registered new interface driver net1080
[ 2.588155] usbcore: registered new interface driver cdc_subset
[ 2.588182] usbcore: registered new interface driver zaurus
[ 2.588222] usbcore: registered new interface driver cdc_ncm
[ 2.588433] Wake76 for irq=199
[ 2.588436] Wake77 for irq=199
[ 2.588438] Wake78 for irq=199
[ 2.588439] Wake79 for irq=199
[ 2.588441] Wake80 for irq=199
[ 2.588443] Wake81 for irq=199
[ 2.588444] Wake82 for irq=199
[ 2.588494] tegra-xotg xotg: usb2 phy is not available yet
[ 2.589212] usbcore: registered new interface driver cdc_acm
[ 2.589215] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.589268] usbcore: registered new interface driver usb-storage
[ 2.589320] usbcore: registered new interface driver usbserial
[ 2.589345] usbcore: registered new interface driver cp210x
[ 2.589363] usbserial: USB Serial support registered for cp210x
[ 2.589386] usbcore: registered new interface driver ftdi_sio
[ 2.589405] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.589427] usbcore: registered new interface driver pl2303
[ 2.589444] usbserial: USB Serial support registered for pl2303
[ 2.589648] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.590787] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 6c 7
[ 2.591324] libphy: dwc_phy: probed
[ 2.592105] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.653912] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.710114] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.712362] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.712376] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.712525] i2c /dev entries driver
[ 2.713338] gspca_main: v2.14.0 registered
[ 2.713379] usbcore: registered new interface driver gspca_zc3xx
[ 2.713623] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.715522] FAN: coudln’t get the regulator
[ 2.716251] device-mapper: uevent: version 1.0.3
[ 2.716431] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.716812] sdhci: Secure Digital Host Controller Interface driver
[ 2.716813] sdhci: Copyright(c) Pierre Ossman
[ 2.716818] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.717077] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.717348] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.717565] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.720703] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.720877] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.722443] usbcore: registered new interface driver usbhid
[ 2.722444] usbhid: USB HID core driver
[ 2.727664] nvadsp 2993000.adsp: in probe()…
[ 2.729010] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.729047] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.729302] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.740848] Denver: backdoor interface is NOT available.
[ 2.742867] coresight-tmc 8030000.etf: TMC initialized
[ 2.754283] coresight-tmc 8050000.etr: TMC initialized
[ 2.754799] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.755380] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.755887] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.756377] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.756764] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.756890] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.757043] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.757359] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.758147] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.761397] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.762016] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.762691] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.762723] Module initialized successfully
[ 2.766542] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.767891] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.768103] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.768443] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.768496] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.768539] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.768580] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.768618] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.768655] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.768695] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.768848] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (55)
[ 2.768850] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.769382] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.769385] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.769388] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.769391] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.769393] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.769396] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.769398] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.769425] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.773316] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.774089] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.774182] camchar: rtcpu character device driver loaded
[ 2.778068] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.778363] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.778507] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.778955] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.778984] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.779011] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.779039] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.779063] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.779092] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.779116] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.779142] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.779166] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.779190] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.779215] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.779240] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.779264] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.779291] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.779314] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.779362] **** A57 ECC: Enabled
[ 2.779365] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 2.779512] parse_throttle_dt_data: Num cap clks = 4
[ 2.779515] parse_throttle_dt_data: clk=mcpu type=1
[ 2.779516] parse_throttle_dt_data: clk=bcpu type=2
[ 2.779523] parse_throttle_dt_data: clk=gpu type=4
[ 2.779525] parse_throttle_dt_data: clk=emc type=3
[ 2.780046] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.780136] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.783273] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.783900] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.796758] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.797013] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.797066] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.797148] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.797174] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 259
[ 2.797421] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.830741] mmc0: MAN_BKOPS_EN bit is not set
[ 2.837974] mmc0: Skipping tuning since strobe enabled
[ 2.844819] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.845370] mmc0: periodic cache flush enabled
[ 2.845377] mmc0: new HS400 MMC card at address 0001
[ 2.845689] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.845846] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.845989] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.846133] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.847503] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 2.889152] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 2.904772] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.086835] mmc1 tuning done saved tap delay=66
[ 3.086839] mmc1: hw tuning done …
[ 3.086846] mmc1: tuning_window[0]: 0xffffffff
[ 3.086852] mmc1: tuning_window[1]: 0xffffe3ff
[ 3.086858] mmc1: tuning_window[2]: 0xf8ffffff
[ 3.086863] mmc1: tuning_window[3]: 0x7fffffff
[ 3.086869] mmc1: tuning_window[4]: 0x0
[ 3.086873] mmc1: tuning_window[5]: 0x0
[ 3.086906] mmc1: tuning_window[6]: 0x0
[ 3.086912] mmc1: tuning_window[7]: 0x0
[ 3.086916] sdhci: Tap value: 66 | Trim value: 5
[ 3.086919] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.093168] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.093215] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.096075] tegradc 15210000.nvdisplay: fb registered
[ 4.100786]
mmc2 sdhci_cmd_irq 2639 SDHCI_INT_END_BIT
[ 4.100787] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.100792] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.100797] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.100803] sdhci: Argument: 0x000001aa | Trn mode: 0x00000000
[ 4.100808] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.100813] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.100817] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.100822] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.100827] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.100832] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.100836] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.100842] sdhci: Cmd: 0x0000081a | Max curr: 0x00000000
[ 4.100845] sdhci: Host ctl2: 0x00003000
[ 4.100851] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.100852] sdhci: ===========================================
[ 4.101213]
[ 4.101213] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.101218] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.101223] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.101227] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.101232] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.101237] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.101241] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.101246] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.101251] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.101255] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.101260] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.101265] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 4.101267] sdhci: Host ctl2: 0x00003000
[ 4.101274] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.101275] sdhci: ===========================================
[ 4.101629]
[ 4.101629] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.101634] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.101638] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.101643] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.101648] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.101652] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.101657] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.101662] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.101666] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.101671] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.101676] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.101681] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 4.101684] sdhci: Host ctl2: 0x00003000
[ 4.101690] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.101691] sdhci: ===========================================
[ 4.102050]
[ 4.102050] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.102055] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.102059] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.102064] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.102068] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.102073] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.102078] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.102082] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.102087] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.102092] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.102096] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.102101] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 4.102104] sdhci: Host ctl2: 0x00003000
[ 4.102110] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.102112] sdhci: ===========================================
[ 4.102466]
[ 4.102466] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.102471] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.102475] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.102480] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.102485] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.102489] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.102494] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.102499] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.102504] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.102508] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.102513] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.102518] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 4.102521] sdhci: Host ctl2: 0x00003000
[ 4.102527] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.102528] sdhci: ===========================================
[ 4.102885]
[ 4.102885] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.102889] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.102894] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.102899] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.102903] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.102908] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.102913] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.102917] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.102922] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.102927] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.102932] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.102936] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 4.102939] sdhci: Host ctl2: 0x00003000
[ 4.102946] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.102947] sdhci: ===========================================
[ 4.103301]
[ 4.103301] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.103305] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.103310] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.103315] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.103319] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.103324] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.103329] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.103334] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.103339] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.103344] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.103348] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.103353] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 4.103356] sdhci: Host ctl2: 0x00003000
[ 4.103362] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.103363] sdhci: ===========================================
[ 4.103719]
[ 4.103719] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.103724] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.103729] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.103733] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.103738] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.103743] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.103747] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.103752] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.103757] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.103762] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.103766] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.103771] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 4.103774] sdhci: Host ctl2: 0x00003000
[ 4.103781] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.103782] sdhci: ===========================================
[ 4.104135]
[ 4.104135] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.104140] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.104144] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.104149] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.104154] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.104158] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.104163] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.104168] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.104173] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.104177] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.104182] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.104187] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 4.104190] sdhci: Host ctl2: 0x00003000
[ 4.104196] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.104197] sdhci: ===========================================
[ 4.104596]
[ 4.104596] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 4.104601] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 4.104606] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 4.104610] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 4.104615] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 4.104620] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 4.104624] sdhci: Wake-up: 0x00000000 | Clock: 0x00000807
[ 4.104629] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 4.104634] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 4.104638] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 4.104643] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 4.104647] sdhci: Cmd: 0x00000102 | Max curr: 0x00000000
[ 4.104650] sdhci: Host ctl2: 0x00003000
[ 4.104657] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 4.104657] sdhci: ===========================================
[ 5.148817]
[ 5.148818] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.148823] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.148827] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.148832] sdhci: Argument: 0x000001aa | Trn mode: 0x00000000
[ 5.148837] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 5.148841] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.148846] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.148851] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.148856] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.148860] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.148865] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.148869] sdhci: Cmd: 0x0000081a | Max curr: 0x00000000
[ 5.148872] sdhci: Host ctl2: 0x00003000
[ 5.148879] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.148880] sdhci: ===========================================
[ 5.149313]
[ 5.149313] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.149318] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.149323] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.149328] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.149333] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 5.149337] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.149342] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.149347] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.149351] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.149356] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.149361] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.149366] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 5.149369] sdhci: Host ctl2: 0x00003000
[ 5.149375] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.149376] sdhci: ===========================================
[ 5.149807]
[ 5.149807] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.149812] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.149816] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.149821] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.149825] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 5.149830] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.149835] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.149839] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.149844] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.149849] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.149853] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.149858] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 5.149861] sdhci: Host ctl2: 0x00003000
[ 5.149867] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.149868] sdhci: ===========================================
[ 5.150333]
[ 5.150333] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.150338] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.150343] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.150347] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.150352] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 5.150357] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.150361] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.150366] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.150371] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.150376] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.150380] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.150385] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 5.150388] sdhci: Host ctl2: 0x00003000
[ 5.150394] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.150395] sdhci: ===========================================
[ 5.150830]
[ 5.150830] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.150835] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.150839] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.150844] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.150849] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 5.150853] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.150858] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.150863] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.150867] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.150872] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.150877] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.150881] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 5.150884] sdhci: Host ctl2: 0x00003000
[ 5.150891] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.150891] sdhci: ===========================================
[ 5.151323]
[ 5.151323] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.151328] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.151333] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.151337] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.151342] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 5.151347] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.151352] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.151356] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.151361] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.151366] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.151371] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.151375] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 5.151378] sdhci: Host ctl2: 0x00003000
[ 5.151385] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.151385] sdhci: ===========================================
[ 5.151846]
[ 5.151846] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.151851] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.151856] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.151860] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.151865] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 5.151870] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.151874] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.151879] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.151884] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.151888] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.151893] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.151898] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 5.151900] sdhci: Host ctl2: 0x00003000
[ 5.151907] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.151908] sdhci: ===========================================
[ 5.152343]
[ 5.152343] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.152348] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.152353] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.152357] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.152362] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 5.152367] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.152372] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.152377] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.152381] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.152386] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.152391] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.152396] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 5.152399] sdhci: Host ctl2: 0x00003000
[ 5.152406] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.152406] sdhci: ===========================================
[ 5.152841]
[ 5.152842] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.152846] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.152851] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.152856] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.152861] sdhci: Present: 0x000b0000 | Host ctl: 0x00000000
[ 5.152865] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.152870] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.152875] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.152880] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.152885] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.152889] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.152894] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 5.152897] sdhci: Host ctl2: 0x00003000
[ 5.152904] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.152905] sdhci: ===========================================
[ 5.153406]
[ 5.153407] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 5.153411] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 5.153416] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 5.153421] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 5.153426] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 5.153430] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 5.153435] sdhci: Wake-up: 0x00000000 | Clock: 0x00000a07
[ 5.153440] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 5.153444] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 5.153449] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.153454] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 5.153459] sdhci: Cmd: 0x00000102 | Max curr: 0x00000000
[ 5.153462] sdhci: Host ctl2: 0x00003000
[ 5.153468] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 5.153469] sdhci: ===========================================
[ 6.197310]
[ 6.197310] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 6.197315] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 6.197320] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 6.197325] sdhci: Argument: 0x000001aa | Trn mode: 0x00000000
[ 6.197330] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 6.197335] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 6.197339] sdhci: Wake-up: 0x00000000 | Clock: 0x00000f07
[ 6.197344] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 6.197349] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 6.197353] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 6.197358] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 6.197363] sdhci: Cmd: 0x0000081a | Max curr: 0x00000000
[ 6.197366] sdhci: Host ctl2: 0x00003000
[ 6.197373] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 6.197374] sdhci: ===========================================
[ 6.198003]
[ 6.198004] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 6.198009] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 6.198014] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 6.198019] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 6.198024] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 6.198029] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 6.198034] sdhci: Wake-up: 0x00000000 | Clock: 0x00000f07
[ 6.198039] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 6.198044] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 6.198049] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 6.198053] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 6.198058] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 6.198061] sdhci: Host ctl2: 0x00003000
[ 6.198068] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 6.198069] sdhci: ===========================================
[ 6.198698]
[ 6.198699] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 6.198703] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 6.198709] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 6.198713] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 6.198718] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 6.198723] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 6.198727] sdhci: Wake-up: 0x00000000 | Clock: 0x00000f07
[ 6.198732] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.198737] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 6.198741] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 6.198746] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 6.198751] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 6.198754] sdhci: Host ctl2: 0x00003000
[ 6.198760] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 6.198761] sdhci: ===========================================
[ 6.199393]
[ 6.199393] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 6.199398] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 6.199403] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 6.199408] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 6.199413] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 6.199417] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 6.199422] sdhci: Wake-up: 0x00000000 | Clock: 0x00000f07
[ 6.199427] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 6.199431] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 6.199436] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 6.199441] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 6.199446] sdhci: Cmd: 0x00000502 | Max curr: 0x00000000
[ 6.199448] sdhci: Host ctl2: 0x00003000
[ 6.199455] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 6.199456] sdhci: ===========================================
[ 6.200083]
[ 6.200083] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 6.200089] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 6.200094] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 6.200099] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 6.200103] sdhci: Present: 0x000b0001 | Host ctl: 0x00000000
[ 6.200108] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 6.200113] sdhci: Wake-up: 0x00000000 | Clock: 0x00000f07
[ 6.200117]
