I can’t find information about Jetson TX2 sd card slot. Does it support UHS - III SD cards?
No, it doesn’t. It’s UHS-I only same as TX1.
Could you, please, recoment which SD card i should get. UHS-I are rarely available.
UHS-I card is common type, there are lots of on Amazon
Here are some UHS-1 cards:
[url]uhs-1 | Newegg.com
It seems that Amazon.com should work. Shouldn’t it?
Cards marked with UHS-1 should be available. Please note that it is SD socket on board, not micro SD socket. It needs adapter if with micro SD card.
Thank you very much!
Hi, I have an issue also with my Jetson TX2 recognizing SD cards. Actually it doesn’t recognize any UHS-I SD card. Tried with JetPack 3.1RC and JetPack 3.2DP too. It is really frustrating. Dunno if it needs RMA.
I have also some logs from dmesg I am attaching.
As you can see:
[ 4.102830] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.102873] mmc1: new ultra high speed SDR104 SDIO card at address 0001
it finds the card, but then I get this all the time:
[ 9.295257] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
Any help, would be highly appreciated, as I don’t really want to send it back for RMA if it is possible.
The full log:
[code][ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-753) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Fri Dec 1 06:08:28 PST 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@969e9000
[ 0.000000] Found lut_mem2: 00002008@969e6000
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2051584
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519920 pages, LIFO batch:31
[ 0.000000] Normal zone: 23933 pages used for memmap
[ 0.000000] Normal zone: 1531664 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5cf2000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=174096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019459
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x969e9000 lut_mem2=0x2008@0x969e6000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0323917022910 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7965748K/8206336K available (11272K kernel code, 1849K rwdata, 5780K rodata, 1168K init, 690K bss, 175052K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 MB)
.init : 0xffffffc001128000 - 0xffffffc00124c000 ( 1168 KB)
.text : 0xffffffc000080000 - 0xffffffc001128000 ( 17056 KB)
.data : 0xffffffc00126d000 - 0xffffffc00143b510 ( 1850 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009857] Console: colour dummy device 80x25
[ 0.014514] console [tty0] enabled
[ 0.018070] bootconsole [uart0] disabled
[ 0.022172] kmemleak: Kernel memory leak detector disabled
[ 0.022182] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022194] pid_max: default: 32768 minimum: 301
[ 0.022241] Security Framework initialized
[ 0.022278] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022286] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022666] Initializing cgroup subsys io
[ 0.022678] Initializing cgroup subsys memory
[ 0.022694] Initializing cgroup subsys devices
[ 0.022703] Initializing cgroup subsys freezer
[ 0.022710] Initializing cgroup subsys net_cls
[ 0.022719] Initializing cgroup subsys perf_event
[ 0.022727] Initializing cgroup subsys net_prio
[ 0.022736] Initializing cgroup subsys pids
[ 0.022743] Initializing cgroup subsys debug
[ 0.022882] CPU0 ipc=752
[ 0.022891] CPU1 ipc=1024
[ 0.022898] CPU2 ipc=1024
[ 0.022906] CPU3 ipc=752
[ 0.022914] CPU4 ipc=752
[ 0.022923] CPU5 ipc=752
[ 0.022962] ASID allocator initialised with 65536 entries
[ 0.046281] tegra-id: chipid=21817.
[ 0.046298] tegra-id: opt_subrevision=1.
[ 0.046310] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046963] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046988] DTB Build time: Dec 1 2017 06:10:28
[ 0.062577] CPU1: Booted secondary processor [4e0f0030]
[ 0.074124] CPU2: Booted secondary processor [4e0f0030]
[ 0.085819] CPU3: Booted secondary processor [411fd073]
[ 0.097818] CPU4: Booted secondary processor [411fd073]
[ 0.109813] CPU5: Booted secondary processor [411fd073]
[ 0.109873] Brought up 6 CPUs
[ 0.109922] SMP: Total of 6 processors activated.
[ 0.109933] CPU: All CPU(s) started at EL2
[ 0.110382] devtmpfs: initialized
[ 0.137485] Initilizing CustomIPI irq domain
[ 0.137695] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138531] pinctrl core: initialized pinctrl subsystem
[ 0.138711] OS set in device tree is L4T.
[ 0.138905] regulator-dummy: no parameters
[ 0.139013] Initializing plugin-manager
[ 0.139066] Plugin module not found
[ 0.139478] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139816] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140428] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141623] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141979] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.142231] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142449] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142872] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143313] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143589] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143970] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.144216] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144435] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144695] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146263] node /plugin-manager/fragment-e3326@0 match with board 3326-
[ 0.147356] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.149157] Adding domain adsp-pd to PM domain ape-pd
[ 0.151519] NET: Registered protocol family 16
[ 0.153681] console [pstore-1] enabled
[ 0.153692] pstore: Registered ramoops as persistent store backend
[ 0.153704] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.165360] cpuidle: using governor ladder
[ 0.169820] cpuidle: using governor menu
[ 0.170989] bpmp: waiting for handshake
[ 0.171001] bpmp: handshake completed
[ 0.171041] bpmp: synchronizing channels
[ 0.171071] bpmp: channels synchronized
[ 0.171081] bpmp: mail init ok
[ 0.171438] vdso: 2 pages (1 code @ ffffffc001275000, 1 data @ ffffffc001274000)
[ 0.171470] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.172400] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.173836] tegra_powergate_init: DONE
[ 0.173857] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.173882] DTB Build time: Dec 1 2017 06:10:28
[ 0.174806] Tegra reboot handler registered.
[ 0.175886] Registering Tegra186 clocks (this may take a while)…done
[ 0.178032] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.178048] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.178061] arm-smmu 12000000.iommu: stage 1 translation
[ 0.178072] arm-smmu 12000000.iommu: stage 2 translation
[ 0.178083] arm-smmu 12000000.iommu: nested translation
[ 0.178097] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.178114] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.178132] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.178145] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.178156] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.227178] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.233070] iommu: Adding device 3460000.sdhci to group 0
[ 0.233899] iommu: Adding device 3400000.sdhci to group 1
[ 0.237424] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.237875] iommu: Adding device 3160000.i2c to group 3
[ 0.238271] iommu: Adding device c240000.i2c to group 4
[ 0.238616] iommu: Adding device 3180000.i2c to group 5
[ 0.239007] iommu: Adding device 3190000.i2c to group 6
[ 0.239445] iommu: Adding device 31b0000.i2c to group 7
[ 0.239760] iommu: Adding device 31c0000.i2c to group 8
[ 0.240085] iommu: Adding device c250000.i2c to group 9
[ 0.240427] iommu: Adding device 31e0000.i2c to group 10
[ 0.242466] iommu: Adding device 3210000.spi to group 11
[ 0.242798] iommu: Adding device c260000.spi to group 12
[ 0.243170] iommu: Adding device 3240000.spi to group 13
[ 0.243970] iommu: Adding device 3100000.serial to group 14
[ 0.244293] iommu: Adding device 3110000.serial to group 15
[ 0.244584] iommu: Adding device c280000.serial to group 16
[ 0.244903] iommu: Adding device 3130000.serial to group 17
[ 0.246146] iommu: Adding device 2490000.ether_qos to group 18
[ 0.246766] iommu: Adding device b000000.rtcpu to group 19
[ 0.247277] iommu: Adding device c1a0000.aon to group 20
[ 0.248107] Wake73 for irq=42
[ 0.248433] iommu: Adding device smmu_test to group 21
[ 0.248941] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.248978] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.249015] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.249048] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.249080] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.249112] mc-err: Set intmask: 0xf3140
[ 0.249398] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.250238] Wake76 for irq=199
[ 0.250259] Wake77 for irq=199
[ 0.250277] Wake78 for irq=199
[ 0.250294] Wake79 for irq=199
[ 0.250311] Wake80 for irq=199
[ 0.250328] Wake81 for irq=199
[ 0.250369] Wake82 for irq=199
[ 0.250479] iommu: Adding device 3530000.xhci to group 22
[ 0.250860] iommu: Adding device 3550000.xudc to group 23
[ 0.251646] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.251678] tegra-pmc: ### PMC reset source: Software reset
[ 0.251698] tegra-pmc: ### PMC reset level: L1
[ 0.251717] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.251991] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.252030] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.252199] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.252226] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.252705] iommu: Adding device 13e10000.host1x to group 24
[ 0.252958] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.253216] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.253439] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.253703] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.253917] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.254204] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.254432] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.254692] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.255132] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.255637] iommu: Adding device 15700000.vi to group 34
[ 0.255961] iommu: Adding device 15600000.isp to group 35
[ 0.256343] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.256512] platform 15210000.nvdisplay: IOVA linear map 0x00000000969e9000(800000)
[ 0.256550] platform 15210000.nvdisplay: IOVA linear map 0x00000000969e6000(3000)
[ 0.256734] iommu: Adding device 15340000.vic to group 37
[ 0.256959] iommu: Adding device 154c0000.nvenc to group 38
[ 0.257153] iommu: Adding device 15480000.nvdec to group 39
[ 0.257501] iommu: Adding device 15380000.nvjpg to group 40
[ 0.257697] iommu: Adding device 15500000.tsec to group 41
[ 0.257916] iommu: Adding device 15100000.tsecb to group 42
[ 0.258671] iommu: Adding device 15810000.se to group 43
[ 0.258877] iommu: Adding device 15820000.se to group 44
[ 0.259093] iommu: Adding device 15830000.se to group 45
[ 0.259269] iommu: Adding device 15840000.se to group 46
[ 0.259804] iommu: Adding device 17000000.gp10b to group 47
[ 0.261167] tegra-reset 5000000.clock: registered 193 resets.
[ 0.263224] iommu: Adding device d000000.bpmp to group 48
[ 0.263493] bpmp: ping status is 0
[ 0.263671] bpmp d000000.bpmp: firmware tag is 63057f9a9f82d7b13a2680dbce98d104
[ 0.264034] bpmp d000000.bpmp: probe ok
[ 0.266668] iommu: Adding device 2600000.dma to group 49
[ 0.267746] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.267806] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.267882] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.267932] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.267986] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.268040] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.268110] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.268218] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.270165] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.270293] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.271381] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.271628] iommu: Adding device sound to group 51
[ 0.273262] iommu: Adding device 3510000.hda to group 52
[ 0.274809] iommu: Adding device adsp_audio to group 53
[ 0.276218] iommu: Adding device 2993000.adsp to group 54
[ 0.285326] vdd-ac-bat: 5000 mV
[ 0.287522] vdd-1v8-ap: 1800 mV
[ 0.304764] SCSI subsystem initialized
[ 0.304927] libata version 3.00 loaded.
[ 0.305087] usbcore: registered new interface driver usbfs
[ 0.305138] usbcore: registered new interface driver hub
[ 0.305257] usbcore: registered new device driver usb
[ 0.308986] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.309439] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.309533] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.310857] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.310946] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.321400] media: Linux media interface: v0.10
[ 0.321460] Linux video capture interface: v2.00
[ 0.324434] pps_core: LinuxPPS API ver. 1 registered
[ 0.324457] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.324499] PTP clock support registered
[ 0.325390] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.325433] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.326873] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.328822] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.329005] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.329098] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.334748] vddio-ddr: at 1125 mV
[ 0.338587] avdd_dsi_csi: 1200 mV
[ 0.342586] vdd-1v8: 1800 mV
[ 0.346586] vdd-3v3-sys: 3300 mV
[ 0.347339] spmic-ldo0: at 1800 mV
[ 0.348122] spmic-ldo1: at 800 mV
[ 0.350589] vddio-3v3: 3300 mV
[ 0.351219] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.354589] vdd-rtc: at 800 mV
[ 0.355230] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.358589] spmic-ldo6: at 1500 mV
[ 0.361357] vdd-pex-1v05: 1000 mV
[ 0.361920] dvdd-pex: 1000 mV
[ 0.362194] max77620 4-003c: max77620 probe successful
[ 0.362443] Advanced Linux Sound Architecture Driver Initialized.
[ 0.363428] en-vdd-sd: 3300 mV
[ 0.364034] en-vdd-cam: 1800 mV
[ 0.365822] vdd-hdmi: 5000 mV
[ 0.365998] vdd-usb0-5v: 5000 mV
[ 0.366166] vdd-usb1-5v: 5000 mV
[ 0.369823] en-vdd-ts-1v8: 1800 mV
[ 0.373822] en-vdd-ts-hv-3v3: 3300 mV
[ 0.374359] en-vdd-disp-3v3: 3300 mV
[ 0.374869] en-mdm-pwr-3v7: 3700 mV
[ 0.375377] en-vdd-disp-1v8: 1800 mV
[ 0.375896] en-vdd-cam-hv-2v8: 2800 mV
[ 0.376418] en-vdd-cam-1v2: 1200 mV
[ 0.376938] vdd-fan: 5000 mV
[ 0.377056] vdd-3v3: 3300 mV
[ 0.377785] dis-vdd-1v2: 1200 mV
[ 0.377905] en-vdd-vcm-2v8: 2800 mV
[ 0.378423] vdd-usb2-5v: 5000 mV
[ 0.378528] vdd-sys-bl: 3300 mV
[ 0.379063] en-vdd-sys: 1200 mV
[ 0.382427] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 0.382847] clocksource: Switched to clocksource arch_sys_counter
[ 0.401471] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.401742] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.402216] nvmap_page_pool_init: Total RAM pages: 2007821
[ 0.402231] nvmap_page_pool_init: nvmap page pool size: 250977 pages (980 MB)
[ 0.402370] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.406806] Wake76 for irq=199
[ 0.406817] Wake77 for irq=199
[ 0.406827] Wake78 for irq=199
[ 0.406837] Wake79 for irq=199
[ 0.406845] Wake80 for irq=199
[ 0.406854] Wake81 for irq=199
[ 0.406862] Wake82 for irq=199
[ 0.407601] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.407800] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.407916] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.407990] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.408380] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.408520] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.408662] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.408809] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.409102] isomgr_init(): iso emc max clk=1866000KHz
[ 0.409113] isomgr_init(): max_iso_bw=26870400KB
[ 0.409197] NET: Registered protocol family 2
[ 0.409503] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.409725] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.410017] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.410077] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.410129] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.410288] NET: Registered protocol family 1
[ 0.410488] RPC: Registered named UNIX socket transport module.
[ 0.410524] RPC: Registered udp transport module.
[ 0.410535] RPC: Registered tcp transport module.
[ 0.410545] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.410564] PCI: CLS 0 bytes, default 128
[ 0.410667] Trying to unpack rootfs image as initramfs…
[ 0.424425] host1x 13e10000.host1x: initialized
[ 0.425294] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.426942] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.427041] audit: initializing netlink subsys (disabled)
[ 0.427082] audit: type=2000 audit(0.416:1): initialized
[ 0.434068] io scheduler noop registered
[ 0.434168] io scheduler cfq registered (default)
[ 0.436676] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.437813] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.438846] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.439857] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.443242] tsec 15500000.tsec: initialized
[ 0.444347] tsec 15100000.tsecb: initialized
[ 0.446658] nvdec 15480000.nvdec: initialized
[ 0.450278] falcon 15340000.vic: initialized
[ 0.451258] falcon 154c0000.nvenc: initialized
[ 0.452273] falcon 15380000.nvjpg: initialized
[ 0.453055] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.453561] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.454066] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.454571] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.455088] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.455592] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.456092] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.456594] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.459209] DC OR NODE connected to /host1x/sor1
[ 0.459332] generic_infoframe_type: 0x87
[ 0.459341] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.459435] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.459454] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.459458] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.459488] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.466688] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.466707] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.466722] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.466768] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.466783] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.466923] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.467716] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.469473] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.469817] kfuse 3830000.kfuse: initialized
[ 0.469904] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.471251] tegradc 15210000.nvdisplay: probed
[ 0.471674] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.472156] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.474097] console [ttyS0] disabled
[ 0.474146] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.609036] console [ttyS0] enabled
[ 2.611018] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.612070] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.612290] serial-tegra 3130000.serial: RX in PIO mode
[ 2.613202] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.623713] Console: switching to colour frame buffer device 240x67
[ 2.623758] brd: module loaded
[ 2.628573] loop: module loaded
[ 2.628841] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.628845] nct1008_nct72 7-004c: starting parse dt
[ 2.628934] nct1008_nct72 7-004c: success parsing dt
[ 2.629048] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.708431] tegradc 15210000.nvdisplay: fb registered
[ 2.708479] tmp451: Enabled overheat logging at 104.00C
[ 2.708590] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.724787] PD DISP0 index2 UP
[ 2.725901] THERMAL EST: found 3 subdevs
[ 2.725903] THERMAL EST num_resources: 0
[ 2.725906] [THERMAL EST subdev 0]
[ 2.725910] [THERMAL EST subdev 1]
[ 2.725912] [THERMAL EST subdev 2]
[ 2.726125] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.726126] THERMAL EST: thz register success.
[ 2.726198] THERMAL EST: end of probe, return err: 0
[ 2.726236] tegra_profiler: Branch: Dev
[ 2.726237] tegra_profiler: Version: 1.112
[ 2.726238] tegra_profiler: Samples version: 39
[ 2.726239] tegra_profiler: IO version: 22
[ 2.726243] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.726245] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.726248] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.726249] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 2.726251] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.726253] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 2.726254] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.726256] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.726258] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.726260] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.726262] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.726263] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.726374] tegra_profiler: auth: init
[ 2.727068] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.729079] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.729086] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.729701] scsi host0: tegra_ahci
[ 2.729925] scsi host1: tegra_ahci
[ 2.730040] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.730042] ata2: DUMMY
[ 2.730775] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.731143] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.731459] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.732060] tun: Universal TUN/TAP device driver, 1.6
[ 2.732062] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.732190] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.732191] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.732217] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.732219] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.732994] PPP generic driver version 2.4.2
[ 2.733083] PPP BSD Compression module registered
[ 2.733087] PPP Deflate Compression module registered
[ 2.733101] PPP MPPE Compression module registered
[ 2.733108] NET: Registered protocol family 24
[ 2.733146] usbcore: registered new interface driver r8152
[ 2.733174] usbcore: registered new interface driver asix
[ 2.733197] usbcore: registered new interface driver ax88179_178a
[ 2.733218] usbcore: registered new interface driver cdc_ether
[ 2.733247] usbcore: registered new interface driver smsc75xx
[ 2.733268] usbcore: registered new interface driver net1080
[ 2.733288] usbcore: registered new interface driver cdc_subset
[ 2.733309] usbcore: registered new interface driver zaurus
[ 2.733346] usbcore: registered new interface driver cdc_ncm
[ 2.733500] Wake76 for irq=199
[ 2.733501] Wake77 for irq=199
[ 2.733503] Wake78 for irq=199
[ 2.733504] Wake79 for irq=199
[ 2.733504] Wake80 for irq=199
[ 2.733505] Wake81 for irq=199
[ 2.733506] Wake82 for irq=199
[ 2.733549] tegra-xotg xotg: usb2 phy is not available yet
[ 2.733932] usbcore: registered new interface driver usb-storage
[ 2.733978] usbcore: registered new interface driver usbserial
[ 2.734001] usbcore: registered new interface driver cp210x
[ 2.734016] usbserial: USB Serial support registered for cp210x
[ 2.734035] usbcore: registered new interface driver ftdi_sio
[ 2.734048] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.734067] usbcore: registered new interface driver option
[ 2.734080] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.734098] usbcore: registered new interface driver pl2303
[ 2.734115] usbserial: USB Serial support registered for pl2303
[ 2.734346] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.736319] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 65 26
[ 2.736768] libphy: dwc_phy: probed
[ 2.737211] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.799995] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.856137] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.858335] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.858347] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.858485] i2c /dev entries driver
[ 2.859217] [OV5693]: probing v4l2 sensor.
[ 3.046855] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.291339] PD DISP1 index3 UP
[ 3.296003] PD DISP2 index4 UP
[ 3.311765] Parent Clock set for DC plld2
[ 3.318233] edid invalid
[ 3.360456] edid invalid
[ 3.364360] edid invalid
[ 3.368248] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting:prod_c_150M
[ 3.523074] tegradc 15210000.nvdisplay: blank - normal
[ 3.527272] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.585876] PD DISP2 index4 DOWN
[ 3.587012] PD DISP1 index3 DOWN
[ 3.587621] PD DISP0 index2 DOWN
[ 3.602443] tegradc 15210000.nvdisplay: unblank
[ 3.602550] PD DISP0 index2 UP
[ 3.608916] PD DISP1 index3 UP
[ 3.609448] PD DISP2 index4 UP
[ 3.624993] Parent Clock set for DC plld2
[ 3.628500] tegradc 15210000.nvdisplay: hdmi: pclk:27027K, set prod-setting:prod_c_54M
[ 3.730585] gspca_main: v2.14.0 registered
[ 3.730627] usbcore: registered new interface driver gspca_zc3xx
[ 3.730953] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.732925] FAN dev name: pwm-fan
[ 3.732971] FAN:gpio request success.
[ 3.732977] FAN: can’t find tach_gpio
[ 3.732999] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.733159] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.733163] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.733457] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.733460] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.733464] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.733467] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.733469] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.733472] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.733475] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.733478] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.733480] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.733483] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.734218] device-mapper: uevent: version 1.0.3
[ 3.734388] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.734782] sdhci: Secure Digital Host Controller Interface driver
[ 3.734783] sdhci: Copyright(c) Pierre Ossman
[ 3.734786] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.735091] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.735381] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.735620] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.736805] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.736924] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.738366] usbcore: registered new interface driver usbhid
[ 3.738367] usbhid: USB HID core driver
[ 3.743249] nvadsp 2993000.adsp: in probe()…
[ 3.745179] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.745205] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.745388] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.746139] Denver: backdoor interface is NOT available.
[ 3.747817] coresight-tmc 8030000.etf: TMC initialized
[ 3.748839] coresight-tmc 8050000.etr: TMC initialized
[ 3.749188] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.749636] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.750039] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.750442] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.750871] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.751460] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.751990] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.752528] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.753059] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.753083] Module initialized successfully
[ 3.756404] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.757748] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.758052] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.758431] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.758474] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.758517] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.758557] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.758595] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.758631] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.758670] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.758829] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.758832] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.759851] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.759853] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.759856] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.759858] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.759860] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.759862] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.759864] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.759888] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.763788] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.764512] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.764605] camchar: rtcpu character device driver loaded
[ 3.764632] random: nonblocking pool is initialized
[ 3.767952] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.768186] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.768272] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.768598] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.768623] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.768646] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.768671] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.768693] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.768715] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.768737] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.768762] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.768784] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.768806] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.768829] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.768854] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.768879] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.768901] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.768923] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.768972] **** A57 ECC: Enabled
[ 3.768974] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.769119] parse_throttle_dt_data: Num cap clks = 4
[ 3.769121] parse_throttle_dt_data: clk=mcpu type=1
[ 3.769123] parse_throttle_dt_data: clk=bcpu type=2
[ 3.769129] parse_throttle_dt_data: clk=gpu type=4
[ 3.769131] parse_throttle_dt_data: clk=emc type=3
[ 3.769560] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.769647] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.770844] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.772049] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.772123] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.772283] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.772479] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.774542] tegra-se-nvhost 15810000.se: initialized
[ 3.774983] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.775320] tegra-se-nvhost 15820000.se: initialized
[ 3.775876] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.776175] tegra-se-nvhost 15830000.se: initialized
[ 3.776281] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.776563] tegra-se-nvhost 15840000.se: initialized
[ 3.776957] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.780836] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.784233] cpufreq: platform driver Initialization: pass
[ 3.784369] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.784418] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.784585] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.784589] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.784623] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ea896
[ 3.784627] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.785782] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.786292] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 3.786800] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.788814] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.788919] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.789784] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.789788] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.792480] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.793012] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.793229] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.793527] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.793772] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.794068] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.794072] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.794073] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.804664] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.804664] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.804781] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.805184] OPE platform probe
[ 3.805258] OPE platform probe successful
[ 3.806860] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.807095] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.807136] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.807195] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.807216] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.807657] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.840852] mmc0: MAN_BKOPS_EN bit is not set
[ 3.846890] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.848545] mmc0: Skipping tuning since strobe enabled
[ 3.855950] mmc0: periodic cache flush enabled
[ 3.855956] mmc0: new HS400 MMC card at address 0001
[ 3.856223] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.856341] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.856448] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.856563] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.857786] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27
[ 3.879845] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.879955] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.880076] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.880180] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.880309] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.880411] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.880538] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.880643] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.880747] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.880850] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.880977] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 3.881080] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 3.881184] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 3.881291] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 3.881421] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 3.881526] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 3.881649] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.881754] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.881855] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.881966] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.887204] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 3.887312] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 3.887346] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 3.887376] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 3.899248] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.923432] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.924243] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.924246] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.925040] GACT probability NOT on
[ 3.925050] Mirror/redirect action on
[ 3.925063] u32 classifier
[ 3.925064] Actions configured
[ 3.925094] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.925737] IPVS: Registered protocols ()
[ 3.925766] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.925838] IPVS: Creating netns size=1424 id=0
[ 3.925866] IPVS: ipvs loaded.
[ 3.925872] IPVS: [rr] scheduler registered.
[ 3.925943] ipip: IPv4 over IPv4 tunneling driver
[ 3.926311] Initializing XFRM netlink socket
[ 3.926737] NET: Registered protocol family 10
[ 3.927430] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.927494] NET: Registered protocol family 17
[ 3.927507] NET: Registered protocol family 15
[ 3.927530] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.927535] 8021q: 802.1Q VLAN Support v1.8
[ 3.928073] Registered cp15_barrier emulation handler
[ 3.928087] Registered setend emulation handler
[ 3.930197] registered taskstats version 1
[ 3.933901] isp 15600000.isp: initialized
[ 3.938040] nvcsi 150c0000.nvcsi: initialized
[ 3.939094] Wake76 for irq=199
[ 3.939096] Wake77 for irq=199
[ 3.939097] Wake78 for irq=199
[ 3.939098] Wake79 for irq=199
[ 3.939098] Wake80 for irq=199
[ 3.939099] Wake81 for irq=199
[ 3.939100] Wake82 for irq=199
[ 3.939435] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 3.939437] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 3.963126] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.963281] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.963283] xhci-tegra 3530000.xhci: Falling back to user helper
[ 3.963754] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.964510] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.965265] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 3.965298] tegra-xotg xotg: update_id_state: ID grounded
[ 3.965302] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 3.965314] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 3.967347] tegra-xotg xotg: otg: gadget gadget registered
[ 3.967349] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 3.967350] tegra-xotg xotg: otg: host not registered yet
[ 3.967351] tegra-xotg xotg: otg: start OTG finite state machine
[ 3.967391] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.967419] tegra-xotg xotg: FSM: can’t move to a_idle, host isn’t ready
[ 3.967888] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.968350] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.002548] tegra_rtc c2a0000.rtc: setting system clock to 2018-02-07 19:55:41 UTC (1518033341)
[ 4.032800] bpmp: mounted debugfs mirror
[ 4.033308] [dram-timers] DRAM derating cdev registered.
[ 4.037846] spmic-ldo0: disabling
[ 4.038023] spmic-ldo1: disabling
[ 4.038169] en-vdd-cam: disabling
[ 4.038171] vdd-usb0-5v: disabling
[ 4.038173] vdd-usb1-5v: disabling
[ 4.038175] en-vdd-disp-3v3: disabling
[ 4.038177] en-mdm-pwr-3v7: disabling
[ 4.038178] en-vdd-disp-1v8: disabling
[ 4.038180] en-vdd-cam-hv-2v8: disabling
[ 4.038181] en-vdd-cam-1v2: disabling
[ 4.038183] vdd-fan: disabling
[ 4.038184] vdd-3v3: disabling
[ 4.038187] en-vdd-vcm-2v8: disabling
[ 4.038188] vdd-usb2-5v: disabling
[ 4.038190] vdd-sys-bl: disabling
[ 4.038192] en-vdd-sys: disabling
[ 4.045138] ALSA device list:
[ 4.045141] #0: tegra-hda at 0x3518000 irq 400
[ 4.045142] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.046325] tegra-vi4 15700000.vi: initialized
[ 4.047556] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 4.047559] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 4.097300] mmc1 tuning done saved tap delay=20
[ 4.097303] mmc1: hw tuning done …
[ 4.097309] mmc1: tuning_window[0]: 0xffffffff
[ 4.097316] mmc1: tuning_window[1]: 0xffffe3ff
[ 4.097321] mmc1: tuning_window[2]: 0xfc7fffff
[ 4.097345] mmc1: tuning_window[3]: 0x7fffffff
[ 4.097349] mmc1: tuning_window[4]: 0x0
[ 4.097353] mmc1: tuning_window[5]: 0x0
[ 4.097357] mmc1: tuning_window[6]: 0x0
[ 4.097361] mmc1: tuning_window[7]: 0x0
[ 4.097364] sdhci: Tap value: 20 | Trim value: 5
[ 4.097367] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 6.459295] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.463932] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.463945] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.464987] devtmpfs: mounted
[ 6.465279] Freeing unused kernel memory: 1168K (ffffffc001128000 - ffffffc00124c000)
[ 6.465302] Freeing alternatives memory: 96K (ffffffc00124c000 - ffffffc001264000)
[ 6.529134] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.549692] systemd[1]: Detected architecture arm64.
[ 6.561390] systemd[1]: Set hostname to .
[ 6.688167] systemd[1]: Listening on Journal Audit Socket.
[ 6.695518] systemd[1]: Listening on udev Kernel Socket.
[ 6.702625] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.711555] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.719517] systemd[1]: Listening on Syslog Socket.
[ 6.726553] systemd[1]: Listening on udev Control Socket.
[ 6.734126] systemd[1]: Reached target User and Group Name Lookups.
[ 6.742762] systemd[1]: Created slice User and Session Slice.
[ 6.751590] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.764201] systemd[1]: Created slice System Slice.
[ 6.771100] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.778963] systemd[1]: Reached target Slices.
[ 6.784815] systemd[1]: Reached target Swap.
[ 6.790612] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.798295] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.806326] systemd[1]: Reached target Encrypted Volumes.
[ 6.813406] systemd[1]: Listening on Journal Socket.
[ 6.821190] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 6.835448] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 6.849280] systemd[1]: Mounting Debug File System…
[ 6.863752] systemd[1]: Starting Load Kernel Modules…
[ 6.872304] systemd[1]: Starting Set console keymap…
[ 6.881220] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.890700] systemd[1]: Starting Journal Service…
[ 6.898481] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.908784] systemd[1]: Started Braille Device Support.
[ 6.916235] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.924715] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.932258] systemd[1]: Reached target Remote File Systems.
[ 6.943381] systemd[1]: Mounted Debug File System.
[ 6.950087] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.957974] systemd[1]: Started Journal Service.
[ 7.104191] systemd-journald[286]: Received request to flush runtime journal from PID 1
[ 7.243928] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 7.263532] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 7.273546] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 7.284384] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 7.292725] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 7.448630] dhd_module_init in
[ 7.456458] tegra_net_perf_init: cannot get wifi sclk
[ 7.466756] found wifi platform device bcmdhd_wlan
[ 7.524910] wifi_platform_get_country_code_map: could not get country_code_map
[ 7.524912] wifi_plat_dev_drv_probe:platform country code map is not available
[ 7.524924] Power-up adapter ‘DHD generic adapter’
[ 7.524929] wifi_platform_set_power = 1
[ 7.718854] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.726839] wifi_platform_bus_enumerate device present 1
[ 7.744807] wifi_platform_bus_enumerate device present 0
[ 7.745366] F1 signature read @0x18000000=0x17214354
[ 7.751140] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 7.751900] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 7.751982] wifi_platform_prealloc: failed to alloc static mem section 7
[ 7.751996] wifi_platform_get_mac_addr
[ 7.752726] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 7.753413] wl_create_event_handler(): thread:wl_event_handler:24b started
[ 7.753491] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e0a01a70
[ 7.758725] dhd_attach(): thread:dhd_watchdog_thread:24c started
[ 7.765064] dhd_attach(): thread:dhd_dpc:255 started
[ 7.765426] dhd_attach(): thread:dhd_rxf:259 started
[ 7.765433] dhd_deferred_work_init: work queue initialized
[ 7.765905] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Dec 1 2017 at 06:06:28
[ 7.766207] tegra_sysfs_register
[ 7.766234] Register interface [wlan0] MAC: 00:04:4b:8d:65:24
[ 7.766237] dhd_prot_ioctl : bus is down. we have nothing to do
[ 7.766356] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
[ 7.767398] wifi_platform_set_power = 0
[ 8.118873] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.166565] using random self ethernet address
[ 8.171655] using random host ethernet address
[ 8.188362] Mass Storage Function, version: 2009/09/11
[ 8.194070] LUN: removable file: (no medium)
[ 8.203223] using random self ethernet address
[ 8.208664] using random host ethernet address
[ 8.219189] usb0: HOST MAC be:7a:8f:f9:62:7d
[ 8.224311] usb0: MAC c6:8e:3e:60:d9:80
[ 8.224782] usb1: HOST MAC 8e:e7:71:b4:e3:36
[ 8.224795] usb1: MAC b6:fc:88:96:67:77
[ 8.224809] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.225784] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.225797] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.226330] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.227319] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.251076] device usb0 entered promiscuous mode
[ 8.257205] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.261458] device usb1 entered promiscuous mode
[ 8.265177] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 8.265181] l4tbr0: port 2(usb1) entered forwarding state
[ 8.265188] l4tbr0: port 2(usb1) entered forwarding state
[ 8.300738] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 8.302782] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.302798] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 8.303635] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 8.303659] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 8.303787] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.303789] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.303791] usb usb1: Product: xHCI Host Controller
[ 8.303793] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.303794] usb usb1: SerialNumber: 3530000.xhci
[ 8.304070] hub 1-0:1.0: USB hub found
[ 8.304091] hub 1-0:1.0: 4 ports detected
[ 8.335007] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.335013] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 8.335119] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.335121] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.335123] usb usb2: Product: xHCI Host Controller
[ 8.335125] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.335126] usb usb2: SerialNumber: 3530000.xhci
[ 8.335371] hub 2-0:1.0: USB hub found
[ 8.335388] hub 2-0:1.0: 3 ports detected
[ 8.335754] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 8.347024] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 8.530841] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.540486] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 8.618849] usb 1-1: new high-speed USB device number 2 using xhci-tegra
[ 8.756530] usb 1-1: feature bit otg_vbus_off set
[ 8.762157] usb 1-1: New USB device found, idVendor=03e7, idProduct=2150
[ 8.769782] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.777903] usb 1-1: Product: Movidius MA2X5X
[ 8.783166] usb 1-1: Manufacturer: Movidius Ltd.
[ 8.788758] usb 1-1: SerialNumber: 03e72150
[ 8.794355] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 8.921947] IPVS: Creating netns size=1424 id=1
[ 8.986967] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.992858] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.999541]
[ 9.013230] wl_android_wifi_on in
[ 9.016577] wifi_platform_set_power = 1
[ 9.061279] tegradc 15210000.nvdisplay: blank - powerdown
[ 9.116938] PD DISP2 index4 DOWN
[ 9.117041] PD DISP1 index3 DOWN
[ 9.117127] PD DISP0 index2 DOWN
[ 9.133204] tegradc 15210000.nvdisplay: unblank
[ 9.133218] PD DISP0 index2 UP
[ 9.134252] PD DISP1 index3 UP
[ 9.134342] PD DISP2 index4 UP
[ 9.135977] Parent Clock set for DC plld2
[ 9.139155] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 9.360704] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
[ 9.361102] F1 signature read @0x18000000=0x17214354
[ 9.364405] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.364868] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.394476] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.412397] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.454133] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.454358] Enabling wake69
[ 9.455268] wifi_platform_get_mac_addr
[ 9.456717] Firmware up: op_mode=0x0005, MAC=00:04:4b:8d:65:24
[ 9.461929] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.466075] Firmware version = wl0: May 4 2017 13:48:00 version 7.35.221.21 (r697384) FWID 01-58d9d0b3
[ 9.468218] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.468402] tegra_sysfs_on
[ 9.518016] l4tbr0: port 2(usb1) entered disabled state
[ 9.540083] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.542573] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.642165] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 9.650519] WLC_E_IF: NO_IF set, event Ignored
[ 9.798890] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.800915] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 9.800921] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 9.801084] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 9.827053] cfg80211: World regulatory domain updated:
[ 9.827058] cfg80211: DFS Master region: unset
[ 9.827058] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.827061] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.827063] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.827065] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.827067] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.827069] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.827071] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.827072] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.827074] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 9.982748] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 9.982751] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 10.429132] tegradc 15210000.nvdisplay: unblank
[ 10.732247] tegradc 15210000.nvdisplay: blank - powerdown
[ 10.793898] PD DISP2 index4 DOWN
[ 10.793987] PD DISP1 index3 DOWN
[ 10.794059] PD DISP0 index2 DOWN
[ 10.816461] tegradc 15210000.nvdisplay: unblank
[ 10.816474] PD DISP0 index2 UP
[ 10.817353] PD DISP1 index3 UP
[ 10.817430] PD DISP2 index4 UP
[ 10.818783] Parent Clock set for DC plld2
[ 10.821593] tegradc 15210000.nvdisplay: hdmi: pclk:27027K, set prod-setting:prod_c_54M
[ 11.927130] gk20a 17000000.gp10b: railgate is disabled.
[ 11.974168] tegradc 15210000.nvdisplay: blank - powerdown
[ 12.043009] PD DISP2 index4 DOWN
[ 12.043094] PD DISP1 index3 DOWN
[ 12.043167] PD DISP0 index2 DOWN
[ 12.060658] tegradc 15210000.nvdisplay: unblank
[ 12.060677] PD DISP0 index2 UP
[ 12.061739] PD DISP1 index3 UP
[ 12.061828] PD DISP2 index4 UP
[ 12.063529] Parent Clock set for DC plld2
[ 12.066910] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 12.460885] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control off
[ 12.462110] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.126766] tegradc 15210000.nvdisplay: unblank
[ 13.170961] CPU1: shutdown
[ 13.173817] psci: CPU1 killed.
[ 13.202851] CPU2: shutdown
[ 13.20557
I could be wrong, but I don’t think UHS-1 is supported. Do you have an older SDHC card you could test with just to verify basic function? What is the capacity of the card you have?
UHS-I only
[url]TX2 SD card slot - Jetson TX2 - NVIDIA Developer Forums
Actually I have tried a 16GB UHS-I and a 32GB UHS-I kingston card. None worked. Did not try an older SDHC though. I don’t have one. Will try to find one, but I am afraid the UHS-I should have worked too as per the specification.
Tried a regular SDHC but it is the same error message. The board might have issues. Do you know where I can report a hardware failure?
Did you try to re-flash your board?
If re-flash doesn’t help, you may try to contact the merchant who did sell the board to you.
It does sound like an actual hardware failure…but the re-flash would be a fairly useful step to know for sure. If you do need to RMA look near the top of this for “RMA”:
[url]https://devtalk.nvidia.com/default/topic/793798/embedded-systems/some-jetson-web-links/[/url]
Did the re-flash part couple of times. I will probably proceed with the RMA. Thank you.
