PCIe Bus Error, AER: Multiple Corrected error received on tx2 r28.1
Hi all,
We are using TX2 r28.1. We use the usb lane mapping #3. Two INTEL® 82574L GIGABIT ETHERNET CONTROLLERLs are connected to the two PCIE x1.
I can successfully see with lspci -nn
00:02.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:10e6] (rev a1)
00:03.0 PCI bridge [0604]: NVIDIA Corporation Device [10de:10e6] (rev a1)
01:00.0 Ethernet controller [0200]: Intel Corporation 82574L Gigabit Network Connection [8086:10d3]
02:00.0 Ethernet controller [0200]: Intel Corporation 82574L Gigabit Network Connection [8086:10d3]
With errors:
[ 1037.954738] pcieport 0000:00:02.0:    [ 0] Receiver Error         (First)
[ 1038.292688] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[ 1038.300325] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 1038.310621] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[ 1038.319060] pcieport 0000:00:02.0:    [ 0] Receiver Error         (First)
[ 1038.528783] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[ 1038.536412] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[ 1038.546714] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[ 1038.555146] pcieport 0000:00:02.0:    [ 0] Receiver Error         (First)
The USB 3.0s works. Can anyone help me?
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.38 (as@as-XS) (gcc version 4.8.5 (GCC) ) #34 SMP PREEMPT Mon Jan 15 10:27:37 CST 2018
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[    0.000000] On node 0 totalpages: 2051072
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519408 pages, LIFO batch:31
[    0.000000]   Normal zone: 23933 pages used for memmap
[    0.000000]   Normal zone: 1531664 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5cf0000 s31232 r8192 d30208 u69632
[    0.000000] pcpu-alloc: s31232 r8192 d30208 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2018947
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0323917023426 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[    0.000000] log_buf_len individual max cpu contribution: 1048576 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 5242880 bytes
[    0.000000] log_buf_len min size: 1048576 bytes
[    0.000000] log_buf_len: 8388608 bytes
[    0.000000] early log buf free: 1046388(99%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7962820K/8204288K available (11324K kernel code, 1782K rwdata, 5800K rodata, 1160K init, 1578K bss, 175932K reserved, 65536K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000   (   246 GB)
                   vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
                             0xffffffbdc2000000 - 0xffffffbdc9d7c400   (   125 MB actual)
                   fixed   : 0xffffffbffa7fd000 - 0xffffffbffac00000   (  4108 KB)
                   PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000   (    16 MB)
                   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                   memory  : 0xffffffc000000000 - 0xffffffc1f5f10000   (  8031 MB)
                     .init : 0xffffffc00113a000 - 0xffffffc00125c000   (  1160 KB)
                     .text : 0xffffffc000080000 - 0xffffffc00113a000   ( 17128 KB)
                     .data : 0xffffffc00127e000 - 0xffffffc00143b970   (  1783 KB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.009886] Console: colour dummy device 80x25
[    0.014544] console [tty0] enabled
[    0.018100] bootconsole [uart0] disabled
[    0.022201] kmemleak: Kernel memory leak detector disabled
[    0.022211] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.022224] pid_max: default: 32768 minimum: 301
[    0.022265] Security Framework initialized
[    0.022292] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.022301] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.022655] Initializing cgroup subsys freezer
[    0.022666] Initializing cgroup subsys debug
[    0.022805] CPU0 ipc=752
[    0.022814] CPU1 ipc=1024
[    0.022821] CPU2 ipc=1024
[    0.022829] CPU3 ipc=752
[    0.022837] CPU4 ipc=752
[    0.022846] CPU5 ipc=752
[    0.022879] ASID allocator initialised with 65536 entries
[    0.046432] tegra-id: chipid=21817.
[    0.046443] tegra-id: opt_subrevision=1.
[    0.046452] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[    0.047100] DTS File Name: /ext/jet31.old/64_TX2/source_release/kernel_src-tx2/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[    0.047120] DTB Build time: Jan  8 2018 17:02:24
[    0.062619] CPU1: Booted secondary processor [4e0f0030]
[    0.074111] CPU2: Booted secondary processor [4e0f0030]
[    0.085841] CPU3: Booted secondary processor [411fd073]
[    0.097832] CPU4: Booted secondary processor [411fd073]
[    0.109829] CPU5: Booted secondary processor [411fd073]
[    0.109891] Brought up 6 CPUs
[    0.109940] SMP: Total of 6 processors activated.
[    0.109951] CPU: All CPU(s) started at EL2
[    0.110374] devtmpfs: initialized
[    0.137664] Initilizing CustomIPI irq domain
[    0.137863] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.138716] pinctrl core: initialized pinctrl subsystem
[    0.138879] OS set in device tree is L4T.
[    0.139076] regulator-dummy: no parameters
[    0.139185] Initializing plugin-manager
[    0.139237] Plugin module not found
[    0.139647] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[    0.139987] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[    0.140596] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[    0.141594] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[    0.141942] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[    0.142197] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[    0.142418] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[    0.142834] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[    0.143275] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[    0.143291] node /plugin-manager/fragment-500-e3325-pcie match with odm-data enable-pcie-on-uphy-lane0
[    0.143711] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[    0.143953] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[    0.144172] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[    0.144425] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[    0.145993] node /plugin-manager/fragment-e3326@0 match with board 3310-*
[    0.147527] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[    0.149344] Adding domain adsp-pd to PM domain ape-pd
[    0.151722] NET: Registered protocol family 16
[    0.153776] console [pstore-1] enabled
[    0.153786] pstore: Registered ramoops as persistent store backend
[    0.153799] ramoops: attached 0x200000@0x96080000, ecc: 0/0
[    0.165376] cpuidle: using governor ladder
[    0.169840] cpuidle: using governor menu
[    0.171008] bpmp: waiting for handshake
[    0.171021] bpmp: handshake completed
[    0.171061] bpmp: synchronizing channels
[    0.171088] bpmp: channels synchronized
[    0.171098] bpmp: mail init ok
[    0.171438] vdso: 2 pages (1 code @ ffffffc001285000, 1 data @ ffffffc001284000)
[    0.171469] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.172392] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.173829] tegra_powergate_init: DONE
[    0.173859] DTS File Name: /ext/jet31.old/64_TX2/source_release/kernel_src-tx2/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[    0.173884] DTB Build time: Jan  8 2018 17:02:24
[    0.174796] Tegra reboot handler registered.
[    0.175871] Registering Tegra186 clocks (this may take a while)...done
[    0.177487] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.177502] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.177514] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.177525] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.177535] arm-smmu 12000000.iommu: 	nested translation
[    0.177549] arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.177567] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.177584] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.177596] arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
[    0.177608] arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
[    0.227416] arm-smmu 12000000.iommu: registered 67 master devices
[    0.232599] iommu: Adding device 3460000.sdhci to group 0
[    0.233538] iommu: Adding device 3400000.sdhci to group 1
[    0.237396] iommu: Adding device 3507000.ahci-sata to group 2
[    0.237830] iommu: Adding device 3160000.i2c to group 3
[    0.238234] iommu: Adding device c240000.i2c to group 4
[    0.238647] iommu: Adding device 3180000.i2c to group 5
[    0.239009] iommu: Adding device 3190000.i2c to group 6
[    0.239475] iommu: Adding device 31b0000.i2c to group 7
[    0.239822] iommu: Adding device 31c0000.i2c to group 8
[    0.240117] iommu: Adding device c250000.i2c to group 9
[    0.240460] iommu: Adding device 31e0000.i2c to group 10
[    0.242372] iommu: Adding device 3210000.spi to group 11
[    0.242749] iommu: Adding device c260000.spi to group 12
[    0.243033] iommu: Adding device 3240000.spi to group 13
[    0.243809] iommu: Adding device 3100000.serial to group 14
[    0.244100] iommu: Adding device 3110000.serial to group 15
[    0.244405] iommu: Adding device c280000.serial to group 16
[    0.244755] iommu: Adding device 3130000.serial to group 17
[    0.245934] iommu: Adding device 2490000.ether_qos to group 18
[    0.246499] iommu: Adding device b000000.rtcpu to group 19
[    0.247037] iommu: Adding device c1a0000.aon to group 20
[    0.247896] Wake73 for irq=42
[    0.248195] iommu: Adding device smmu_test to group 21
[    0.248699] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[    0.248738] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[    0.248795] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[    0.248828] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[    0.248880] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[    0.248911] mc-err: Set intmask: 0xf3140
[    0.249121] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[    0.249930] Wake76 for irq=199
[    0.249950] Wake77 for irq=199
[    0.249968] Wake78 for irq=199
[    0.249985] Wake79 for irq=199
[    0.250002] Wake80 for irq=199
[    0.250044] Wake81 for irq=199
[    0.250061] Wake82 for irq=199
[    0.250199] iommu: Adding device 3530000.xhci to group 22
[    0.250535] iommu: Adding device 3550000.xudc to group 23
[    0.251339] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.251367] tegra-pmc: ### PMC reset source: Software reset
[    0.251388] tegra-pmc: ### PMC reset level: L1
[    0.251406] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.251676] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.251711] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.251874] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.251930] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[    0.252397] iommu: Adding device 13e10000.host1x to group 24
[    0.252630] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[    0.252886] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[    0.253116] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[    0.253377] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[    0.253586] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[    0.253825] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[    0.254039] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[    0.254273] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[    0.254739] iommu: Adding device 150c0000.nvcsi to group 33
[    0.255246] iommu: Adding device 15700000.vi to group 34
[    0.255575] iommu: Adding device 15600000.isp to group 35
[    0.255871] iommu: Adding device 15210000.nvdisplay to group 36
[    0.256060] iommu: Adding device 15340000.vic to group 37
[    0.256249] iommu: Adding device 154c0000.nvenc to group 38
[    0.256489] iommu: Adding device 15480000.nvdec to group 39
[    0.256788] iommu: Adding device 15380000.nvjpg to group 40
[    0.257021] iommu: Adding device 15500000.tsec to group 41
[    0.257205] iommu: Adding device 15100000.tsecb to group 42
[    0.257863] iommu: Adding device 15810000.se to group 43
[    0.258053] iommu: Adding device 15820000.se to group 44
[    0.258240] iommu: Adding device 15830000.se to group 45
[    0.258436] iommu: Adding device 15840000.se to group 46
[    0.258961] iommu: Adding device 17000000.gp10b to group 47
[    0.260312] tegra-reset 5000000.clock: registered 193 resets.
[    0.262328] iommu: Adding device d000000.bpmp to group 48
[    0.262567] bpmp: ping status is 0
[    0.262753] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
[    0.263110] bpmp d000000.bpmp: probe ok
[    0.265488] iommu: Adding device 2600000.dma to group 49
[    0.266267] GPIO line 459 (pcie-lane2-mux) hogged as output/low
[    0.266324] GPIO line 461 (cam0-rst) hogged as output/low
[    0.266390] GPIO line 456 (cam0-pwdn) hogged as output/low
[    0.266438] GPIO line 457 (cam1-rst) hogged as output/low
[    0.266482] GPIO line 426 (cam1-pwdn) hogged as output/low
[    0.266529] GPIO line 424 (wifi-enable) hogged as output/high
[    0.266577] GPIO line 445 (sdmmc-wake-input) hogged as input
[    0.266673] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[    0.266772] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[    0.268573] GPIO line 315 (wifi-wake-ap) hogged as input
[    0.268713] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[    0.269587] iommu: Adding device 10003000.pcie-controller to group 50
[    0.269825] iommu: Adding device sound to group 51
[    0.271597] iommu: Adding device 3510000.hda to group 52
[    0.272733] iommu: Adding device adsp_audio to group 53
[    0.274151] iommu: Adding device 2993000.adsp to group 54
[    0.283951] vdd-ac-bat: 5000 mV
[    0.286101] vdd-1v8-ap: 1800 mV
[    0.287265] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[    0.287620] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[    0.304651] SCSI subsystem initialized
[    0.304833] libata version 3.00 loaded.
[    0.304993] usbcore: registered new interface driver usbfs
[    0.305055] usbcore: registered new interface driver hub
[    0.305196] usbcore: registered new device driver usb
[    0.309212] GPIO line 241 (touch-rail-1) hogged as output/high
[    0.309657] GPIO line 242 (touch-rail-2) hogged as output/high
[    0.309754] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[    0.310101] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[    0.310570] pca953x 0-0077: failed reading register
[    0.310660] pca953x: probe of 0-0077 failed with error -121
[    0.322826] media: Linux media interface: v0.10
[    0.322889] Linux video capture interface: v2.00
[    0.326844] pps_core: LinuxPPS API ver. 1 registered
[    0.326876] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.326948] PTP clock support registered
[    0.327885] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.327930] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.329366] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[    0.331325] GPIO line 237 (spmic_gpio_input_5) hogged as input
[    0.331521] GPIO line 238 (spmic_gpio_input_6) hogged as input
[    0.331618] gpiochip_add_data: registered GPIOs 232 to 239 on device: max77620-gpio
[    0.338796] vddio-ddr: at 1125 mV
[    0.342633] avdd_dsi_csi: 1200 mV
[    0.346632] vdd-1v8: 1800 mV
[    0.350632] vdd-3v3-sys: 3300 mV
[    0.351409] spmic-ldo0: at 1800 mV
[    0.352183] spmic-ldo1: at 800 mV
[    0.354633] vddio-3v3: 3300 mV
[    0.355264] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[    0.358635] vdd-rtc: at 800 mV
[    0.359274] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[    0.361840] spmic-ldo6: at 1500 mV
[    0.365838] vdd-pex-1v05: 1000 mV
[    0.366378] dvdd-pex: 1000 mV
[    0.366638] max77620 4-003c: max77620 probe successful
[    0.366885] Advanced Linux Sound Architecture Driver Initialized.
[    0.367843] en-vdd-sd: 3300 mV
[    0.369837] vdd-hdmi: 5000 mV
[    0.370019] vdd-usb0-5v: 5000 mV
[    0.370186] vdd-usb1-5v: 5000 mV
[    0.373835] en-vdd-ts-1v8: 1800 mV
[    0.377834] en-vdd-ts-hv-3v3: 3300 mV
[    0.378360] en-vdd-disp-3v3: 3300 mV
[    0.378864] en-mdm-pwr-3v7: 3700 mV
[    0.379374] en-vdd-disp-1v8: 1800 mV
[    0.379886] en-vdd-cam-hv-2v8: 2800 mV
[    0.380434] vdd-fan: 5000 mV
[    0.380542] vdd-3v3: 3300 mV
[    0.381279] dis-vdd-1v2: 1200 mV
[    0.381388] en-vdd-vcm-2v8: 2800 mV
[    0.381916] vdd-usb2-5v: 5000 mV
[    0.382022] vdd-sys-bl: 3300 mV
[    0.383755] gpio tegra-gpio wake53 for gpio=159(X:7)
[    0.385376] extcon-gpio-states external-connection:extcon@1: Cable state 1
[    0.385764] clocksource: Switched to clocksource arch_sys_counter
[    0.404808] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.405085] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[    0.405556] nvmap_page_pool_init: Total RAM pages: 2007089
[    0.405570] nvmap_page_pool_init: nvmap page pool size: 250886 pages (980 MB)
[    0.405820] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.410272] Wake76 for irq=199
[    0.410284] Wake77 for irq=199
[    0.410294] Wake78 for irq=199
[    0.410303] Wake79 for irq=199
[    0.410312] Wake80 for irq=199
[    0.410320] Wake81 for irq=199
[    0.410329] Wake82 for irq=199
[    0.410796] vcc_lp = (null), pca954x
[    0.410815] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[    0.410831] pca954x 2-0070: device detect skipped.
[    0.410920] regulator_get() failed for (2-0070,vcc-pullup), -19
[    0.410932] pca954x 2-0070: vcc-pullup regulator not found
[    0.411131] i2c i2c-2: Added multiplexed i2c bus 30
[    0.411249] i2c i2c-2: Added multiplexed i2c bus 31
[    0.411314] i2c i2c-2: Added multiplexed i2c bus 32
[    0.411380] i2c i2c-2: Added multiplexed i2c bus 33
[    0.411393] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
[    0.411713] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[    0.411909] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[    0.412022] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.412099] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.412489] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[    0.412631] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[    0.412766] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[    0.412916] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[    0.413205] isomgr_init(): iso emc max clk=1866000KHz
[    0.413216] isomgr_init(): max_iso_bw=26870400KB
[    0.413290] NET: Registered protocol family 2
[    0.413596] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.413828] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.414120] TCP: Hash tables configured (established 65536 bind 65536)
[    0.414175] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.414228] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.414387] NET: Registered protocol family 1
[    0.414589] RPC: Registered named UNIX socket transport module.
[    0.414602] RPC: Registered udp transport module.
[    0.414612] RPC: Registered tcp transport module.
[    0.414622] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.414642] PCI: CLS 0 bytes, default 128
[    0.414732] Trying to unpack rootfs image as initramfs...
[    0.428638] host1x 13e10000.host1x: initialized
[    0.429464] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.431482] futex hash table entries: 2048 (order: 6, 262144 bytes)
[    0.431576] audit: initializing netlink subsys (disabled)
[    0.431604] audit: type=2000 audit(0.420:1): initialized
[    0.438080] io scheduler noop registered (default)
[    0.440611] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.441822] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[    0.442890] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.443955] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.446486] tegra-pcie 10003000.pcie-controller: 1x1, 1x1, 1x1 configuration
[    0.448474] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[    0.448984] tegra-pcie 10003000.pcie-controller: probing port 0, using 1 lanes
[    0.449880] tsec 15500000.tsec: initialized
[    0.450989] tsec 15100000.tsecb: initialized
[    0.452963] nvdec 15480000.nvdec: initialized
[    0.456329] falcon 15340000.vic: initialized
[    0.457311] falcon 154c0000.nvenc: initialized
[    0.458284] falcon 15380000.nvjpg: initialized
[    0.458986] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    0.459485] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    0.459985] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    0.460480] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    0.460980] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    0.461477] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    0.461990] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    0.462505] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    0.463825] DC OR NODE connected to /host1x/sor1
[    0.464022] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.464041] tegradc 15210000.nvdisplay: DT parsed successfully
[    0.464080] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[    0.464260] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    0.464279] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=3000000, max_bw=4687500
[    0.471227] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[    0.471246] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[    0.471262] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[    0.471304] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[    0.471318] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[    0.471446] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[    0.473785] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    0.473838] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[    0.473858] PD DISP0 index2 UP
[    0.474753] PD DISP1 index3 UP
[    0.474885] kfuse 3830000.kfuse: initialized
[    0.474938] PD DISP2 index4 UP
[    0.476215] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.476630] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.478523] console [ttyS0] disabled
[    0.478573] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[    0.503404] Unsupported HDMI VIC 5, ignoring
[    0.503407] Unsupported HDMI VIC 58, ignoring
[    0.503409] Unsupported HDMI VIC 128, ignoring
[    0.503410] Unsupported HDMI VIC 24, ignoring
[    0.503420] PD DISP2 index4 DOWN
[    0.503584] PD DISP1 index3 DOWN
[    0.503729] PD DISP0 index2 DOWN
[    0.505575] tegradc 15210000.nvdisplay: probed
[    0.551229] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[    0.653380] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[    1.178997] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.583299] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.986958] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.988973] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[    1.989183] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[    1.989188] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[    1.989191] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[    1.989194] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.989197] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[    1.989223] pci 0000:00:02.0: [10de:10e6] type 01 class 0x060400
[    1.989325] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.989489] iommu: Adding device 0000:00:02.0 to group 55
[    1.989562] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[    1.989657] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.989825] iommu: Adding device 0000:00:03.0 to group 56
[    1.989873] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.989885] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.990033] pci 0000:01:00.0: [8086:10d3] type 00 class 0x020000
[    1.990101] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[    1.990117] pci 0000:01:00.0: reg 0x14: [mem 0x00000000-0x000fffff]
[    1.990132] pci 0000:01:00.0: reg 0x18: [io  0x0000-0x001f]
[    1.990148] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[    1.990270] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    1.990437] iommu: Adding device 0000:01:00.0 to group 57
[    1.997818] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.997959] pci 0000:02:00.0: [8086:10d3] type 00 class 0x020000
[    1.998026] pci 0000:02:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[    1.998041] pci 0000:02:00.0: reg 0x14: [mem 0x00000000-0x000fffff]
[    1.998057] pci 0000:02:00.0: reg 0x18: [io  0x0000-0x001f]
[    1.998073] pci 0000:02:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[    1.998194] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    1.998362] iommu: Adding device 0000:02:00.0 to group 58
[    2.005814] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[    2.005956] pci 0000:00:02.0: BAR 8: assigned [mem 0x50100000-0x502fffff]
[    2.005959] pci 0000:00:03.0: BAR 8: assigned [mem 0x50300000-0x504fffff]
[    2.005963] pci 0000:00:02.0: BAR 7: assigned [io  0x1000-0x1fff]
[    2.005966] pci 0000:00:03.0: BAR 7: assigned [io  0x2000-0x2fff]
[    2.005971] pci 0000:01:00.0: BAR 1: assigned [mem 0x50100000-0x501fffff]
[    2.005984] pci 0000:01:00.0: BAR 0: assigned [mem 0x50200000-0x5021ffff]
[    2.005997] pci 0000:01:00.0: BAR 3: assigned [mem 0x50220000-0x50223fff]
[    2.006010] pci 0000:01:00.0: BAR 2: assigned [io  0x1000-0x101f]
[    2.006024] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.006028] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.006035] pci 0000:00:02.0:   bridge window [mem 0x50100000-0x502fffff]
[    2.006046] pci 0000:02:00.0: BAR 1: assigned [mem 0x50300000-0x503fffff]
[    2.006059] pci 0000:02:00.0: BAR 0: assigned [mem 0x50400000-0x5041ffff]
[    2.006071] pci 0000:02:00.0: BAR 3: assigned [mem 0x50420000-0x50423fff]
[    2.006084] pci 0000:02:00.0: BAR 2: assigned [io  0x2000-0x201f]
[    2.006097] pci 0000:00:03.0: PCI bridge to [bus 02]
[    2.006101] pci 0000:00:03.0:   bridge window [io  0x2000-0x2fff]
[    2.006107] pci 0000:00:03.0:   bridge window [mem 0x50300000-0x504fffff]
[    2.006231] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.006234] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.006240] pcie_pme 0000:00:02.0:pcie01: service driver pcie_pme loaded
[    2.006313] aer 0000:00:02.0:pcie02: service driver aer loaded
[    2.006454] pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
[    2.006457] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[    2.006463] pcie_pme 0000:00:03.0:pcie01: service driver pcie_pme loaded
[    2.006529] aer 0000:00:03.0:pcie02: service driver aer loaded
[    2.937871] console [ttyS0] enabled
[    2.940276] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[    2.941516] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[    2.941748] serial-tegra 3130000.serial: RX in PIO mode
[    2.942873] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[    2.952329] Console: switching to colour frame buffer device 240x67
[    2.953170] brd: module loaded
[    2.957514] loop: module loaded
[    2.957857] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[    2.957877] nct1008_nct72 7-004c: find device tree node, parsing dt
[    2.957881] nct1008_nct72 7-004c: starting parse dt
[    2.957970] nct1008_nct72 7-004c: success parsing dt
[    2.958111] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[    3.025986] tmp451: Enabled overheat logging at 104.00C
[    3.026063] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[    3.026096] nct1008_nct72 7-004c: nct1008_probe: initialized
[    3.028556] THERMAL EST: found 3 subdevs
[    3.028560] THERMAL EST num_resources: 0
[    3.028563] [THERMAL EST subdev 0]
[    3.028568] [THERMAL EST subdev 1]
[    3.028571] [THERMAL EST subdev 2]
[    3.028804] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[    3.028806] THERMAL EST: thz register success.
[    3.028893] THERMAL EST: end of probe, return err: 0
[    3.029110] tegra_profiler: Branch: Dev
[    3.029112] tegra_profiler: Version: 1.109
[    3.029113] tegra_profiler: Samples version: 37
[    3.029114] tegra_profiler: IO version: 21
[    3.029118] armv8_pmu: imp: 0x41, idcode: 0x1
[    3.029121] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    3.029123] armv8_pmu: imp: 0x4e, idcode: 0x1
[    3.029125] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[    3.029127] armv8_pmu: imp: 0x4e, idcode: 0x1
[    3.029129] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[    3.029131] armv8_pmu: imp: 0x41, idcode: 0x1
[    3.029132] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    3.029134] armv8_pmu: imp: 0x41, idcode: 0x1
[    3.029136] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    3.029138] armv8_pmu: imp: 0x41, idcode: 0x1
[    3.029139] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[    3.029281] tegra_profiler: auth: init
[    3.031801] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[    3.033808] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[    3.033815] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[    3.034534] scsi host0: tegra_ahci
[    3.034780] scsi host1: tegra_ahci
[    3.034900] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[    3.034902] ata2: DUMMY
[    3.035802] spi-tegra114 3210000.spi: Static pin configuration used
[    3.036201] spi-tegra114 c260000.spi: Static pin configuration used
[    3.036555] spi-tegra114 3240000.spi: Static pin configuration used
[    3.037240] tun: Universal TUN/TAP device driver, 1.6
[    3.037242] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.037401] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[    3.037402] e100: Copyright(c) 1999-2006 Intel Corporation
[    3.037433] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    3.037434] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    3.037465] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[    3.037467] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.037500] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.0.2-k
[    3.037501] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    3.037533] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.4.6
[    3.037534] Copyright(c) 1999 - 2016 Intel Corporation.
[    3.037644] ixgbevf: Intel(R) 10 Gigabit PCI Express Virtual Function Network Driver - version 2.12.1-k
[    3.037646] ixgbevf: Copyright (c) 2009 - 2012 Intel Corporation.
[    3.037676] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.3.46-k
[    3.037678] i40e: Copyright (c) 2013 - 2014 Intel Corporation.
[    3.037715] ixgb: Intel(R) PRO/10GbE Network Driver - version 1.0.135-k2-NAPI
[    3.037716] ixgb: Copyright (c) 1999-2008 Intel Corporation.
[    3.037751] i40evf: Intel(R) XL710/X710 Virtual Function Network Driver - version 1.3.33
[    3.037769] Copyright (c) 2013 - 2015 Intel Corporation.
[    3.037803] Intel(R) Ethernet Switch Host Interface Driver - version 0.15.2-k
[    3.037804] Copyright (c) 2013 Intel Corporation.
[    3.038852] PPP generic driver version 2.4.2
[    3.038967] PPP BSD Compression module registered
[    3.038970] PPP Deflate Compression module registered
[    3.038986] PPP MPPE Compression module registered
[    3.038993] NET: Registered protocol family 24
[    3.039034] usbcore: registered new interface driver r8152
[    3.039064] usbcore: registered new interface driver asix
[    3.039085] usbcore: registered new interface driver ax88179_178a
[    3.039106] usbcore: registered new interface driver cdc_ether
[    3.039139] usbcore: registered new interface driver smsc95xx
[    3.039159] usbcore: registered new interface driver net1080
[    3.039190] usbcore: registered new interface driver cdc_subset
[    3.039210] usbcore: registered new interface driver zaurus
[    3.039246] usbcore: registered new interface driver cdc_ncm
[    3.039471] Wake76 for irq=199
[    3.039472] Wake77 for irq=199
[    3.039473] Wake78 for irq=199
[    3.039474] Wake79 for irq=199
[    3.039475] Wake80 for irq=199
[    3.039476] Wake81 for irq=199
[    3.039477] Wake82 for irq=199
[    3.039530] tegra-xotg xotg: usb2 phy is not available yet
[    3.040011] usbcore: registered new interface driver usb-storage
[    3.040060] usbcore: registered new interface driver usbserial
[    3.040079] usbcore: registered new interface driver ftdi_sio
[    3.040096] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.040117] usbcore: registered new interface driver option
[    3.040134] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.040151] usbcore: registered new interface driver pl2303
[    3.040164] usbserial: USB Serial support registered for pl2303
[    3.040332] tegra-usb-cd usb_cd: otg phy is not available yet
[    3.042534] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 6a 9c
[    3.043044] libphy: dwc_phy: probed
[    3.043445] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[    3.106812] gpio tegra-gpio wake18 for gpio=101(M:5)
[    3.106961] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[    3.175613] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    3.177871] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    3.177888] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.178039] i2c /dev entries driver
[    3.179181] [OV5693]: probing v4l2 sensor.
[    3.180404] [OV5693]: probing v4l2 sensor.
[    3.181092] pca9570 30-0024: pca9570_icr_move, forward val=5
[    3.291500] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.292155] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    3.292496] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.293129] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[    3.353803] ata1: SATA link down (SStatus 0 SControl 300)
[    3.403514] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.404157] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    3.404500] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.405123] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[    3.510149] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.510767] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    3.511097] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.511707] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[    3.622075] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.622694] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    3.623023] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.623624] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[    3.733975] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.734592] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    3.734921] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.735534] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[    3.845910] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.846537] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    3.846871] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.847486] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[    3.957848] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.958468] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    3.958803] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    3.959420] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[    3.997781] tegradc 15210000.nvdisplay: fb registered
[    4.004833] gpio tegra-gpio wake21 for gpio=121(P:1)
[    4.011656] PD DISP0 index2 UP
[    4.017585] PD DISP1 index3 UP
[    4.022626] PD DISP2 index4 UP
[    4.034466] Parent Clock set for DC plld2
[    4.044314] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[    4.069768] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    4.079682] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    4.090150] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    4.100309] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[    4.143259] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[    4.154005] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[    4.167418] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[    4.179042] pcieport 0000:00:02.0:    [ 0] Receiver Error         (First)
[    4.214819] Unsupported HDMI VIC 5, ignoring
[    4.220780] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    4.221362] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    4.221691] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    4.222256] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 2
[    4.255205] Unsupported HDMI VIC 58, ignoring
[    4.261541] Unsupported HDMI VIC 128, ignoring
[    4.267940] Unsupported HDMI VIC 24, ignoring
[    4.332610] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    4.333190] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 48
[    4.333520] tegra-i2c 3180000.i2c: no acknowledge from address 0x24
[    4.334075] pca9570 30-0024: pca9570_write_reg:i2c write failed, 0x24 = 0
[    4.334077] pca9570 30-0024: pca9570_icr_move:i2c write failed
[    4.334121] pca9570: probe of 30-0024 failed with error -121
[    4.334157] gspca_main: v2.14.0 registered
[    4.334210] usbcore: registered new interface driver gspca_zc3xx
[    4.334519] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    4.336368] FAN dev name: pwm-fan
[    4.336415] FAN:gpio request success.
[    4.336421] FAN: can't find tach_gpio
[    4.336443] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    4.336588] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[    4.336592] pwm_fan_driver pwm-fan: got pwm for fan
[    4.336596] pwm_fan_driver pwm-fan: tach period: 1000
[    4.336900] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    4.336903] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    4.336906] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    4.336909] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    4.336912] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    4.336915] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    4.336918] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    4.336921] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    4.336924] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    4.336927] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    4.337651] device-mapper: uevent: version 1.0.3
[    4.337863] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    4.338191] sdhci: Secure Digital Host Controller Interface driver
[    4.338192] sdhci: Copyright(c) Pierre Ossman
[    4.338197] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.338498] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[    4.338795] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[    4.339032] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    4.340167] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    4.340292] hidraw: raw HID events driver (C) Jiri Kosina
[    4.341862] usbcore: registered new interface driver usbhid
[    4.341863] usbhid: USB HID core driver
[    4.343674] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[    4.344055] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[    4.344163] ina3221x: probe of 0-0042 failed with error -121
[    4.344506] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[    4.344872] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[    4.344961] ina3221x: probe of 0-0043 failed with error -121
[    4.345276] nvadsp 2993000.adsp: in probe()...
[    4.347140] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[    4.347166] nvadsp 2993000.adsp: AMC/ARAM initialized.
[    4.347352] nvadsp 2993000.adsp: nvadsp_app_module_probe
[    4.348064] Denver: backdoor interface is NOT available.
[    4.349797] coresight-tmc 8030000.etf: TMC initialized
[    4.350851] coresight-tmc 8050000.etr: TMC initialized
[    4.351193] coresight-tpiu 8060000.tpiu: TPIU initialized
[    4.351660] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[    4.352061] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[    4.352293] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[    4.352680] coresight-replicator 8040000.replicator: REPLICATOR initialized
[    4.353107] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[    4.353461] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[    4.353844] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[    4.354205] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[    4.354228] Module initialized successfully
[    4.357566] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[    4.358832] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[    4.359113] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[    4.359514] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.359559] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[    4.359597] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[    4.359639] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[    4.359676] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[    4.359713] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[    4.359753] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[    4.359896] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[    4.359898] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[    4.360941] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[    4.360943] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[    4.360946] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[    4.360948] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[    4.360950] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[    4.360952] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[    4.360954] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[    4.360968] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[    4.362326] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[    4.362415] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[    4.362489] camchar: rtcpu character device driver loaded
[    4.364667] tegra186-aondbg aondbg: aondbg driver probe() OK
[    4.364901] register_ari_mca_banks: Registered MCA ROC:IOB
[    4.364990] register_ari_mca_banks: Registered MCA ROC:CCE
[    4.365316] tegra18-bridge 2390000.axi2apb: bridge probed OK
[    4.365344] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[    4.365368] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[    4.365391] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[    4.365415] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[    4.365442] tegra18-bridge 2100000.axip2p: bridge probed OK
[    4.365465] tegra18-bridge 2110000.axip2p: bridge probed OK
[    4.365488] tegra18-bridge 2120000.axip2p: bridge probed OK
[    4.365511] tegra18-bridge 2130000.axip2p: bridge probed OK
[    4.365536] tegra18-bridge 2140000.axip2p: bridge probed OK
[    4.365559] tegra18-bridge 2150000.axip2p: bridge probed OK
[    4.365584] tegra18-bridge 2160000.axip2p: bridge probed OK
[    4.365607] tegra18-bridge 2170000.axip2p: bridge probed OK
[    4.365634] tegra18-bridge 2180000.axip2p: bridge probed OK
[    4.365656] tegra18-bridge 2190000.axip2p: bridge probed OK
[    4.365706] **** A57 ECC: Enabled
[    4.365708] tegra18_a57_serr_init: on CPU 3 a A57 Core
[    4.365858] parse_throttle_dt_data: Num cap clks = 4
[    4.365860] parse_throttle_dt_data: clk=mcpu type=1
[    4.365862] parse_throttle_dt_data: clk=bcpu type=2
[    4.365867] parse_throttle_dt_data: clk=gpu type=4
[    4.365869] parse_throttle_dt_data: clk=emc type=3
[    4.366300] tegra_throttle_probe: probe successful. #cdevs=4
[    4.366383] tegra18x_actmon d230000.actmon: in actmon_register()...
[    4.368834] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[    4.369146] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[    4.371259] tegra-se-nvhost 15810000.se: initialized
[    4.371696] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    4.372016] tegra-se-nvhost 15820000.se: initialized
[    4.372476] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    4.372754] tegra-se-nvhost 15830000.se: initialized
[    4.372867] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    4.373150] tegra-se-nvhost 15840000.se: initialized
[    4.373540] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    4.373784] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    4.374014] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[    4.374324] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    4.377550] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[    4.381082] cpufreq: platform driver Initialization: pass
[    4.381225] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[    4.381274] tegra_cluster_clk e090000.cluster_clk_priv: passed
[    4.381487] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[    4.381491] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[    4.381529] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2aa894
[    4.381532] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[    4.382600] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[    4.383149] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[    4.383682] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[    4.385526] cpuidle: Initializing cpuidle driver init for Denver cluster
[    4.385635] cpuidle: Initializing cpuidle driver init for A57 cluster
[    4.386533] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[    4.386537] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[    4.389200] tegra210_adsp_audio_platform_probe: platform probe started
[    4.389791] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[    4.390028] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[    4.390326] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[    4.390588] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[    4.393837] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[    4.393842] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[    4.393844] tegra210-adsp adsp_audio: using adma channel page 0
[    4.401381] tegra210_adsp_audio_platform_probe probe successfull.
[    4.401381] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    4.401505] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    4.404237] OPE platform probe
[    4.404304] OPE platform probe successful
[    4.409778] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    4.410005] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    4.410045] sdhci-tegra 3400000.sdhci: Got WP GPIO
[    4.410158] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[    4.410177] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[    4.410365] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    4.412035] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[    4.443791] mmc0: MAN_BKOPS_EN bit is not set
[    4.449855] gpio tegra-gpio wake71 for gpio=125(P:5)
[    4.449888] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    4.451016] mmc0: Skipping tuning since strobe enabled
[    4.458420] mmc0: periodic cache flush enabled
[    4.458427] mmc0: new HS400 MMC card at address 0001
[    4.458665] mmcblk0: mmc0:0001 032G34 29.1 GiB
[    4.458761] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[    4.458845] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[    4.458930] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[    4.460017]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[    4.469537] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    4.469683] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    4.469838] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    4.469944] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    4.470041] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    4.470137] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    4.470258] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    4.470353] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    4.470449] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    4.470565] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    4.470663] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    4.470759] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    4.470853] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    4.470964] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    4.471065] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    4.471165] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    4.471270] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    4.471371] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    4.471519] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    4.471647] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    4.476053] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[    4.476166] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[    4.476196] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[    4.476239] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[    4.498196] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[    4.509976] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[    4.510687] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[    4.510690] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[    4.511389] GACT probability NOT on
[    4.511398] Mirror/redirect action on
[    4.511410] u32 classifier
[    4.511411]     Actions configured
[    4.511431] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[    4.512203] ipip: IPv4 over IPv4 tunneling driver
[    4.512559] Initializing XFRM netlink socket
[    4.512901] NET: Registered protocol family 10
[    4.513597] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    4.513678] NET: Registered protocol family 17
[    4.513691] NET: Registered protocol family 15
[    4.513713] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    4.513719] 8021q: 802.1Q VLAN Support v1.8
[    4.514391] Registered cp15_barrier emulation handler
[    4.514425] Registered setend emulation handler
[    4.515852] registered taskstats version 1
[    4.519734] isp 15600000.isp: initialized
[    4.524206] nvcsi 150c0000.nvcsi: initialized
[    4.525608] Wake76 for irq=199
[    4.525609] Wake77 for irq=199
[    4.525610] Wake78 for irq=199
[    4.525611] Wake79 for irq=199
[    4.525611] Wake80 for irq=199
[    4.525612] Wake81 for irq=199
[    4.525613] Wake82 for irq=199
[    4.526021] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[    4.526023] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[    4.526396] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[    4.526409] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[    4.526412] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[    4.526415] pcieport 0000:00:02.0:    [ 0] Receiver Error         (First)
[    4.527568] spi-tegra114 3210000.spi: Static pin configuration used
[    4.527709] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[    4.527711] xhci-tegra 3530000.xhci: Falling back to user helper
[    4.528177] spi-tegra114 c260000.spi: Static pin configuration used
[    4.528850] spi-tegra114 3240000.spi: Static pin configuration used
[    4.529470] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[    4.529503] tegra-xotg xotg: update_id_state: ID floating
[    4.529508] tegra-xotg xotg: update_vbus_state: VBUS detected
[    4.529521] tegra-xotg xotg: Nvidia XUSB OTG Controller
[    4.531209] tegra-xotg xotg: otg: gadget gadget registered
[    4.531211] tegra-xotg xotg: set gadget otg_caps from OTG controller
[    4.531213] tegra-xotg xotg: otg: host not registered yet
[    4.531214] tegra-xotg xotg: otg: start OTG finite state machine
[    4.531255] tegra-xudc-new 3550000.xudc: entering ELPG
[    4.531764] tegra-xudc-new 3550000.xudc: entering ELPG done
[    4.532721] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[    4.532788] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[    4.532882] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[    4.533006] input: gpio-keys as /devices/gpio-keys/input/input3
[    4.567233] tegra_rtc c2a0000.rtc: setting system clock to 2018-01-19 01:27:18 UTC (1516325238)
[    4.597476] bpmp: mounted debugfs mirror
[    4.597999] [dram-timers] DRAM derating cdev registered.
[    4.602149] spmic-ldo0: disabling
[    4.602335] spmic-ldo1: disabling
[    4.602481] vdd-usb0-5v: disabling
[    4.602483] vdd-usb1-5v: disabling
[    4.602486] en-vdd-disp-3v3: disabling
[    4.602488] en-mdm-pwr-3v7: disabling
[    4.602489] en-vdd-disp-1v8: disabling
[    4.602491] en-vdd-cam-hv-2v8: disabling
[    4.602493] vdd-fan: disabling
[    4.602495] vdd-3v3: disabling
[    4.602497] en-vdd-vcm-2v8: disabling
[    4.602498] vdd-usb2-5v: disabling
[    4.602500] vdd-sys-bl: disabling
[    4.609306] ALSA device list:
[    4.609308]   #0: tegra-hda at 0x3518000 irq 400
[    4.609309]   #1: tegra-snd-t186ref-mobile-rt565x
[    4.610713] tegra-vi4 15700000.vi: initialized
[    4.700076] mmc1 tuning done saved tap delay=67
[    4.700079] mmc1: hw tuning done ...
[    4.700086] mmc1: tuning_window[0]: 0xffffffff
[    4.700091] mmc1: tuning_window[1]: 0xffffe7ff
[    4.700095] mmc1: tuning_window[2]: 0xf3ffffff
[    4.700119] mmc1: tuning_window[3]: 0x7fffffff
[    4.700124] mmc1: tuning_window[4]: 0x0
[    4.700129] mmc1: tuning_window[5]: 0x0
[    4.700133] mmc1: tuning_window[6]: 0x0
[    4.700138] mmc1: tuning_window[7]: 0x0
[    4.700140] sdhci: Tap value: 67 | Trim value: 5
[    4.700143] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[    4.705944] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    4.705988] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    5.069803] tegra186-padctl 3520000.pinctrl: tegra18x_phy_xusb_utmi_pad_dcd: DCD timeout 418 ms
[    5.113804] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[    5.113807] tegra-usb-cd usb_cd: set current 0ma
[    5.113814] tegra-xudc-new 3550000.xudc: exiting ELPG
[    5.114796] tegra-xudc-new 3550000.xudc: exiting ELPG done
[    5.114799] tegra-xudc-new 3550000.xudc: device mode on
[    5.654467] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[    5.654483] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[    5.654487] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[    5.654491] pcieport 0000:00:02.0:    [ 0] Receiver Error
[    6.029422] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[    6.029435] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[    6.029438] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[    6.029442] pcieport 0000:00:02.0:    [ 0] Receiver Error
[    6.422767] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[    6.422780] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[    6.422784] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[    6.422786] pcieport 0000:00:02.0:    [ 0] Receiver Error
[    7.883900] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[    7.883913] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[    7.883916] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[    7.883919] pcieport 0000:00:02.0:    [ 0] Receiver Error
[    9.436854] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[    9.436867] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[    9.436871] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[    9.436873] pcieport 0000:00:02.0:    [ 0] Receiver Error
[   10.058795] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[   10.058808] pcieport 0000:00:02.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
[   10.058811] pcieport 0000:00:02.0:   device [10de:10e6] error status/mask=00000001/00002000
[   10.058814] pcieport 0000:00:02.0:    [ 0] Receiver Error
[   10.460656] pcieport 0000:00:02.0: AER: Multiple Corrected error received: id=0040
[   10.460670]
Can anyone help on this?
Is this the wrong place for my question?
I can’t answer on the issue, but this is the right place to ask. One thing you might want to list is the “sudo lspci -vvv” verbose output.
Hi zhaozoz,
So the device is detected but cannot be accessed?
For config 3, PCIe#0_0, PCIe#1_0 and PCIe#2_0 are enabled. Which one is connected to the ethernet controller?
Hi zhaozoz,
Any update or issue has been clarified and fixed?
Could you try to disable following in tegra18_defconfig and rebuild kernel image?
CONFIG_PCIEASPM_POWERSAVE=y
This is most likely because of ASPM states being enabled.
Can you please try suggestion in #6 ?
Alternatively, you can edit kernel command line to add ‘pcie_aspm=off’ to disable ASPM
Hi vidyas,
The PCIE error won’t show. The e1000e driver module can be insmod successfully.
