I am adding the dmesg log for reference:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-shikra-3.00-00 (kjeevraj@kjeevraj) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Thu Feb 21 11:24:57 IST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 1921024
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 21896 pages used for memmap
[ 0.000000] Normal zone: 1401344 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1890936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0424718090548 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7451760K/7684096K available (11404K kernel code, 1800K rwdata, 5740K rodata, 1148K init, 692K bss, 166800K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc00113f000 - 0xffffffc00125e000 ( 1148 KB)
.text : 0xffffffc000080000 - 0xffffffc00113f000 ( 17148 KB)
.data : 0xffffffc00127f000 - 0xffffffc001441080 ( 1801 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009298] Console: colour dummy device 80x25
[ 0.013946] console [tty0] enabled
[ 0.017504] bootconsole [uart0] disabled
[ 0.021605] kmemleak: Kernel memory leak detector disabled
[ 0.021618] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.021631] pid_max: default: 32768 minimum: 301
[ 0.021683] Security Framework initialized
[ 0.021723] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.021733] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022119] Initializing cgroup subsys io
[ 0.022134] Initializing cgroup subsys memory
[ 0.022153] Initializing cgroup subsys devices
[ 0.022164] Initializing cgroup subsys freezer
[ 0.022174] Initializing cgroup subsys net_cls
[ 0.022186] Initializing cgroup subsys perf_event
[ 0.022195] Initializing cgroup subsys net_prio
[ 0.022207] Initializing cgroup subsys pids
[ 0.022215] Initializing cgroup subsys debug
[ 0.022374] CPU0 ipc=752
[ 0.022385] CPU1 ipc=1024
[ 0.022394] CPU2 ipc=1024
[ 0.022403] CPU3 ipc=752
[ 0.022412] CPU4 ipc=752
[ 0.022422] CPU5 ipc=752
[ 0.022468] ASID allocator initialised with 65536 entries
[ 0.046760] tegra-id: chipid=21817.
[ 0.046781] tegra-id: opt_subrevision=1.
[ 0.046796] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.048358] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.048385] DTB Build time: May 17 2018 00:17:47
[ 0.062823] CPU1: Booted secondary processor [4e0f0030]
[ 0.074323] CPU2: Booted secondary processor [4e0f0030]
[ 0.085963] CPU3: Booted secondary processor [411fd073]
[ 0.097959] CPU4: Booted secondary processor [411fd073]
[ 0.109957] CPU5: Booted secondary processor [411fd073]
[ 0.110032] Brought up 6 CPUs
[ 0.110095] SMP: Total of 6 processors activated.
[ 0.110110] CPU: All CPU(s) started at EL2
[ 0.110593] devtmpfs: initialized
[ 0.138738] Initilizing CustomIPI irq domain
[ 0.138973] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.139843] pinctrl core: initialized pinctrl subsystem
[ 0.139977] OS set in device tree is not L4T.
[ 0.140186] regulator-dummy: no parameters
[ 0.140306] Initializing plugin-manager
[ 0.140401] Plugin module not found
[ 0.140532] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.141485] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.141743] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.141866] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.142216] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.142510] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142958] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.143269] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.143989] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144146] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.144490] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.144845] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.144952] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.145194] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.145323] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.148625] Adding domain adsp-pd to PM domain ape-pd
[ 0.149820] NET: Registered protocol family 16
[ 0.150693] console [pstore-1] enabled
[ 0.150706] pstore: Registered ramoops as persistent store backend
[ 0.150719] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161465] cpuidle: using governor ladder
[ 0.165960] cpuidle: using governor menu
[ 0.166639] bpmp: waiting for handshake
[ 0.166656] bpmp: handshake completed
[ 0.166698] bpmp: synchronizing channels
[ 0.166723] bpmp: channels synchronized
[ 0.166734] bpmp: mail init ok
[ 0.167087] vdso: 2 pages (1 code @ ffffffc001285000, 1 data @ ffffffc001284000)
[ 0.167124] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168073] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169577] tegra_powergate_init: DONE
[ 0.169602] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169629] DTB Build time: May 17 2018 00:17:47
[ 0.171270] Tegra reboot handler registered.
[ 0.172651] Registering Tegra186 clocks (this may take a while)…done
[ 0.174099] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.174119] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.174134] arm-smmu 12000000.iommu: stage 1 translation
[ 0.174148] arm-smmu 12000000.iommu: stage 2 translation
[ 0.174161] arm-smmu 12000000.iommu: nested translation
[ 0.174177] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.174197] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174215] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174230] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.174243] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.255267] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.260617] mc: mapped MMIO address: 0xffffff8000540000 → 0x2c10000
[ 0.260679] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c20000
[ 0.260723] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c30000
[ 0.260762] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c40000
[ 0.260807] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c50000
[ 0.260847] mc-err: Set intmask: 0xf3140
[ 0.261083] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.261466] iommu: Adding device d000000.bpmp to group 0
[ 0.261823] bpmp: ping status is 0
[ 0.261978] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.262416] bpmp d000000.bpmp: probe ok
[ 0.263632] iommu: Adding device 3550000.xudc to group 1
[ 0.267738] gpiochip_add_data: registered GPIOs 448 to 511 on device: tegra-gpio-aon
[ 0.273339] iommu: Adding device 17000000.gp10b to group 2
[ 0.274925] vdd-ac-bat: 5000 mV
[ 0.276378] vdd-1v8-ap: 1800 mV
[ 0.277868] Wake73 for irq=42
[ 0.280437] iommu: Adding device smmu_test to group 3
[ 0.280902] iommu: Adding device 3210000.spi to group 4
[ 0.281305] iommu: Adding device c260000.spi to group 5
[ 0.281672] iommu: Adding device 3240000.spi to group 6
[ 0.282403] iommu: Adding device b000000.rtcpu to group 7
[ 0.283543] iommu: Adding device 3507000.ahci-sata to group 8
[ 0.284616] iommu: Adding device 3100000.serial to group 9
[ 0.284968] iommu: Adding device 3110000.serial to group 10
[ 0.285376] iommu: Adding device 3130000.serial to group 11
[ 0.285729] iommu: Adding device c280000.serial to group 12
[ 0.288471] tegra-reset 5000000.clock: registered 193 resets.
[ 0.289101] iommu: Adding device 13e10000.host1x to group 13
[ 0.289357] iommu: Adding device 13e10000.host1x:ctx0 to group 14
[ 0.290223] iommu: Adding device 13e10000.host1x:ctx1 to group 15
[ 0.290484] iommu: Adding device 13e10000.host1x:ctx2 to group 16
[ 0.290749] iommu: Adding device 13e10000.host1x:ctx3 to group 17
[ 0.291017] iommu: Adding device 13e10000.host1x:ctx4 to group 18
[ 0.291321] iommu: Adding device 13e10000.host1x:ctx5 to group 19
[ 0.291540] iommu: Adding device 13e10000.host1x:ctx6 to group 20
[ 0.291808] iommu: Adding device 13e10000.host1x:ctx7 to group 21
[ 0.292325] iommu: Adding device 150c0000.nvcsi to group 22
[ 0.292725] iommu: Adding device 15380000.nvjpg to group 23
[ 0.293262] iommu: Adding device 15810000.se to group 24
[ 0.293468] iommu: Adding device 15820000.se to group 25
[ 0.293657] iommu: Adding device 15830000.se to group 26
[ 0.293884] iommu: Adding device 15840000.se to group 27
[ 0.294075] iommu: Adding device 154c0000.nvenc to group 28
[ 0.294282] iommu: Adding device 15100000.tsecb to group 29
[ 0.294899] iommu: Adding device 15700000.vi to group 30
[ 0.295106] iommu: Adding device 15480000.nvdec to group 31
[ 0.295476] iommu: Adding device 15600000.isp to group 32
[ 0.295677] iommu: Adding device 15500000.tsec to group 33
[ 0.295904] iommu: Adding device 15340000.vic to group 34
[ 0.298501] iommu: Adding device c1a0000.aon to group 35
[ 0.303318] Wake76 for irq=199
[ 0.303360] Wake77 for irq=199
[ 0.303388] Wake78 for irq=199
[ 0.303416] Wake79 for irq=199
[ 0.303442] Wake80 for irq=199
[ 0.303469] Wake81 for irq=199
[ 0.303496] Wake82 for irq=199
[ 0.303648] iommu: Adding device 3530000.xhci to group 36
[ 0.306759] iommu: Adding device 2993000.adsp to group 37
[ 0.308025] iommu: Adding device 2490000.ether_qos to group 38
[ 0.309554] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.309593] tegra-pmc: ### PMC reset source: Power on reset
[ 0.309644] tegra-pmc: ### PMC reset level: L0
[ 0.309671] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.309985] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.310066] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.310228] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.310257] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.311188] GPIO line 397 (cam0-rst) hogged as output/low
[ 0.311250] GPIO line 392 (cam0-pwdn) hogged as output/low
[ 0.311316] GPIO line 393 (cam1-rst) hogged as output/low
[ 0.311362] GPIO line 362 (cam1-pwdn) hogged as output/low
[ 0.311412] GPIO line 381 (sdmmc-wake-input) hogged as input
[ 0.311462] GPIO line 382 (sdmmc-wake-output) hogged as output/low
[ 0.311580] gpiochip_add_data: registered GPIOs 256 to 447 on device: tegra-gpio
[ 0.313430] iommu: Adding device 3160000.i2c to group 39
[ 0.313760] iommu: Adding device 3180000.i2c to group 40
[ 0.314117] iommu: Adding device 3190000.i2c to group 41
[ 0.317293] iommu: Adding device 2600000.dma to group 42
[ 0.317639] iommu: Adding device c240000.i2c to group 43
[ 0.318356] iommu: Adding device c250000.i2c to group 44
[ 0.319199] iommu: Adding device 31b0000.i2c to group 45
[ 0.319526] iommu: Adding device 31c0000.i2c to group 46
[ 0.319891] iommu: Adding device 3400000.sdhci to group 47
[ 0.320252] iommu: Adding device 31e0000.i2c to group 48
[ 0.320805] iommu: Adding device 3460000.sdhci to group 49
[ 0.336903] SCSI subsystem initialized
[ 0.337112] libata version 3.00 loaded.
[ 0.337270] usbcore: registered new interface driver usbfs
[ 0.337330] usbcore: registered new interface driver hub
[ 0.337437] usbcore: registered new device driver usb
[ 0.340575] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.340787] pca953x 0-0074: failed reading register
[ 0.340868] pca953x: probe of 0-0074 failed with error -121
[ 0.341321] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.341520] pca953x 0-0077: failed reading register
[ 0.341586] pca953x: probe of 0-0077 failed with error -121
[ 0.352146] media: Linux media interface: v0.10
[ 0.352214] Linux video capture interface: v2.00
[ 0.355891] pps_core: LinuxPPS API ver. 1 registered
[ 0.355922] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.355970] PTP clock support registered
[ 0.356894] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.356966] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.358520] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.360656] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.360850] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.360954] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.366983] vddio-ddr: at 1125 mV
[ 0.370819] avdd_dsi_csi: 1200 mV
[ 0.374824] vdd-1v8: 1800 mV
[ 0.378821] vdd-3v3-sys: 3300 mV
[ 0.379947] spmic-ldo0: at 1800 mV
[ 0.380837] spmic-ldo1: at 800 mV
[ 0.386818] vddio-3v3: 3300 mV
[ 0.387475] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.390822] vdd-rtc: at 800 mV
[ 0.391629] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.393964] spmic-ldo6: at 1500 mV
[ 0.397963] vdd-pex-1v05: 1000 mV
[ 0.398519] dvdd-pex: 1000 mV
[ 0.398802] max77620 4-003c: max77620 probe successful
[ 0.399135] Advanced Linux Sound Architecture Driver Initialized.
[ 0.400210] en-vdd-sd: 3300 mV
[ 0.400658] vdd-usb0-5v: 5000 mV
[ 0.400889] vdd-usb1-5v: 5000 mV
[ 0.401792] vdd-3v3: 3300 mV
[ 0.402019] en-vdd-vcm-2v8: 2800 mV
[ 0.402237] vdd-sys-bl: 3300 mV
[ 0.405402] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.405980] clocksource: Switched to clocksource arch_sys_counter
[ 0.426604] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.426957] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.427638] nvmap_page_pool_init: Total RAM pages: 1879324
[ 0.427658] nvmap_page_pool_init: nvmap page pool size: 234915 pages (917 MB)
[ 0.427883] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.433744] Wake76 for irq=199
[ 0.433762] Wake77 for irq=199
[ 0.433774] Wake78 for irq=199
[ 0.433785] Wake79 for irq=199
[ 0.433796] Wake80 for irq=199
[ 0.433806] Wake81 for irq=199
[ 0.433817] Wake82 for irq=199
[ 0.435163] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type GPU-therm
[ 0.435403] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.435557] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type Tdiode_tegra
[ 0.435639] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.435855] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.436055] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type BCPU-therm
[ 0.436206] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.436504] isomgr_init(): iso emc max clk=1866000KHz
[ 0.436517] isomgr_init(): max_iso_bw=26870400KB
[ 0.436610] NET: Registered protocol family 2
[ 0.436934] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.437168] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.437494] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.437553] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.437616] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.437799] NET: Registered protocol family 1
[ 0.438058] RPC: Registered named UNIX socket transport module.
[ 0.438077] RPC: Registered udp transport module.
[ 0.438089] RPC: Registered tcp transport module.
[ 0.438101] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.438124] PCI: CLS 0 bytes, default 128
[ 0.438229] Trying to unpack rootfs image as initramfs…
[ 0.453952] host1x 13e10000.host1x: initialized
[ 0.456357] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.459927] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.460107] audit: initializing netlink subsys (disabled)
[ 0.460179] audit: type=2000 audit(0.452:1): initialized
[ 0.470790] io scheduler noop registered
[ 0.470994] io scheduler cfq registered (default)
[ 0.474504] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.476006] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.477266] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.477750] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.483937] tsec 15100000.tsecb: initialized
[ 0.485376] tsec 15500000.tsec: initialized
[ 0.488860] nvdec 15480000.nvdec: initialized
[ 0.492803] falcon 15380000.nvjpg: initialized
[ 0.494117] falcon 154c0000.nvenc: initialized
[ 0.496387] falcon 15340000.vic: initialized
[ 0.497480] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.498233] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.498959] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.499776] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.500470] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.501182] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.501903] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.502628] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.505370] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.505520] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.505555] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.513520] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.514977] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.515515] kfuse 3830000.kfuse: initialized
[ 0.516623] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.517223] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.520022] console [ttyS0] disabled
[ 0.520112] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 98, base_baud = 25500000) is a Tegra
[ 2.448686] console [ttyS0] enabled
[ 2.454221] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 99, base_baud = 0) is a TEGRA_UART
[ 2.463217] serial-tegra 3130000.serial: RX in PIO mode
[ 2.469315] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 100, base_baud = 0) is a TEGRA_UART
[ 2.479124] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 101, base_baud = 0) is a TEGRA_UART
[ 2.498173] brd: module loaded
[ 2.505121] loop: module loaded
[ 2.508468] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.514825] nct1008_nct72 7-004c: starting parse dt
[ 2.515608] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.526370] nct1008_nct72 7-004c: success parsing dt
[ 2.531472] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.576395] tmp451: Enabled overheat logging at 104.00C
[ 2.581786] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.590684] THERMAL EST: found 3 subdevs
[ 2.594654] THERMAL EST num_resources: 0
[ 2.598608] [THERMAL EST subdev 0]
[ 2.602058] [THERMAL EST subdev 1]
[ 2.605469] [THERMAL EST subdev 2]
[ 2.609213] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.618200] THERMAL EST: thz register success.
[ 2.622869] THERMAL EST: end of probe, return err: 0
[ 2.627984] tegra_profiler: Branch: Dev
[ 2.631846] tegra_profiler: Version: 1.117
[ 2.635960] tegra_profiler: Samples version: 41
[ 2.640507] tegra_profiler: IO version: 22
[ 2.644626] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649004] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.657206] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.661588] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.669879] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.674256] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.682541] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.686917] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.695114] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.699488] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.707685] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.712061] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.720473] tegra_profiler: auth: init
[ 2.727580] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.737045] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.747485] scsi host0: tegra_ahci
[ 2.751287] scsi host1: tegra_ahci
[ 2.754878] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 95
[ 2.762829] ata2: DUMMY
[ 2.766201] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.788102] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.794819] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.801939] tun: Universal TUN/TAP device driver, 1.6
[ 2.807086] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.813503] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.819367] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.825351] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.832357] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.839224] PPP generic driver version 2.4.2
[ 2.842295] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c6 91 6
[ 2.842754] libphy: dwc_phy: probed
[ 2.853615] PPP BSD Compression module registered
[ 2.858356] PPP Deflate Compression module registered
[ 2.863484] PPP MPPE Compression module registered
[ 2.868305] NET: Registered protocol family 24
[ 2.872857] usbcore: registered new interface driver r8152
[ 2.878404] usbcore: registered new interface driver asix
[ 2.883892] usbcore: registered new interface driver ax88179_178a
[ 2.890040] usbcore: registered new interface driver cdc_ether
[ 2.895932] usbcore: registered new interface driver smsc75xx
[ 2.901756] usbcore: registered new interface driver net1080
[ 2.907145] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.913226] usbcore: registered new interface driver cdc_subset
[ 2.919190] usbcore: registered new interface driver zaurus
[ 2.924830] usbcore: registered new interface driver cdc_ncm
[ 2.930846] Wake76 for irq=199
[ 2.933911] Wake77 for irq=199
[ 2.936971] Wake78 for irq=199
[ 2.940029] Wake79 for irq=199
[ 2.943089] Wake80 for irq=199
[ 2.946147] Wake81 for irq=199
[ 2.949205] Wake82 for irq=199
[ 2.952405] tegra-xotg xotg: usb2 phy is not available yet
[ 2.958530] usbcore: registered new interface driver cdc_acm
[ 2.964222] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.972289] usbcore: registered new interface driver usb-storage
[ 2.978448] usbcore: registered new interface driver usbserial
[ 2.984332] usbcore: registered new interface driver cp210x
[ 2.989952] usbserial: USB Serial support registered for cp210x
[ 2.995915] usbcore: registered new interface driver ftdi_sio
[ 3.001704] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.009068] usbcore: registered new interface driver option
[ 3.014688] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.021691] usbcore: registered new interface driver pl2303
[ 3.027311] usbserial: USB Serial support registered for pl2303
[ 3.033648] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.041151] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.082006] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.180056] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.189853] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.196845] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.203206] i2c /dev entries driver
[ 3.207537] gspca_main: v2.14.0 registered
[ 3.211692] usbcore: registered new interface driver gspca_zc3xx
[ 3.217978] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.226684] FAN: coudln’t get the regulator
[ 3.231848] device-mapper: uevent: version 1.0.3
[ 3.236673] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.245621] sdhci: Secure Digital Host Controller Interface driver
[ 3.251812] sdhci: Copyright(c) Pierre Ossman
[ 3.256186] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.262690] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.267596] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.267976] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.268155] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.270062] usbcore: registered new interface driver usbhid
[ 3.270065] usbhid: USB HID core driver
[ 3.274013] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 3.274228] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 3.274411] ina3221x: probe of 0-0042 failed with error -121
[ 3.274931] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 3.275106] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 3.275289] ina3221x: probe of 0-0043 failed with error -121
[ 3.275777] nvadsp 2993000.adsp: in probe()…
[ 3.276581] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.276626] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.276860] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.277668] Denver: backdoor interface is NOT available.
[ 3.279869] coresight-tmc 8030000.etf: TMC initialized
[ 3.280796] coresight-tmc 8050000.etr: TMC initialized
[ 3.281191] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.281692] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.282178] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.282596] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.283242] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.284207] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.285023] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.294124] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.295051] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.295112] Module initialized successfully
[ 3.297337] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.299100] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.299435] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.299944] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x1000-0x1200 TX[1x384]=0x1200-0x1400
[ 3.300000] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x1400-0x1600 TX[1x384]=0x1600-0x1800
[ 3.300049] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1800-0x3880 TX[64x128]=0x3880-0x5900
[ 3.300108] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5900-0x6d80 TX[16x320]=0x6d80-0x8200
[ 3.300159] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x8200-0x8680 TX[16x64]=0x8680-0x8b00
[ 3.300239] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x8b00-0x8bc0 TX[1x64]=0x8bc0-0x8c80
[ 3.300288] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8c80-0x9100 TX[16x64]=0x9100-0x9580
[ 3.300480] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (93)
[ 3.300486] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.301842] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.301847] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.301852] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.301883] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.301886] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.301890] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.301895] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.302010] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.307051] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.308051] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.308257] camchar: rtcpu character device driver loaded
[ 3.312534] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.312843] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.312941] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.313375] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.313431] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.313466] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.313498] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.313532] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.313640] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.313673] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.313704] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.313737] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.313778] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.313847] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.313883] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.313919] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.313952] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.314025] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.314102] tegra18_a57_serr_init: on CPU 2 a Denver Core
[ 3.314173] parse_throttle_dt_data: Num cap clks = 4
[ 3.314178] parse_throttle_dt_data: clk=mcpu type=1
[ 3.314181] parse_throttle_dt_data: clk=bcpu type=2
[ 3.314189] parse_throttle_dt_data: clk=gpu type=4
[ 3.314192] parse_throttle_dt_data: clk=emc type=3
[ 3.314811] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.315070] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.315689] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.316192] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.319006] tegra-se-nvhost 15810000.se: initialized
[ 3.319699] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.320189] tegra-se-nvhost 15820000.se: initialized
[ 3.320856] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.321256] tegra-se-nvhost 15830000.se: initialized
[ 3.321432] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.321782] tegra-se-nvhost 15840000.se: initialized
[ 3.322445] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.327724] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.331782] cpufreq: platform driver Initialization: pass
[ 3.331870] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.331955] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.332306] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.332313] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.332350] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 3.332354] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.333699] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.335357] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.335882] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.340989] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.341156] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.342402] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.342406] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.348924] OPE platform probe
[ 3.349052] OPE platform probe successful
[ 3.370629] GACT probability NOT on
[ 3.370640] Mirror/redirect action on
[ 3.370655] u32 classifier
[ 3.370656] Actions configured
[ 3.370686] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.371364] IPVS: Registered protocols ()
[ 3.371448] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.371519] IPVS: Creating netns size=1424 id=0
[ 3.371546] IPVS: ipvs loaded.
[ 3.371552] IPVS: [rr] scheduler registered.
[ 3.371630] ipip: IPv4 over IPv4 tunneling driver
[ 3.371959] Initializing XFRM netlink socket
[ 3.372267] NET: Registered protocol family 10
[ 3.372969] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.373045] NET: Registered protocol family 17
[ 3.373058] NET: Registered protocol family 15
[ 3.373081] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.373085] 8021q: 802.1Q VLAN Support v1.8
[ 3.378775] Registered cp15_barrier emulation handler
[ 3.385210] Registered setend emulation handler
[ 3.386824] registered taskstats version 1
[ 3.390208] isp 15600000.isp: initialized
[ 3.394222] nvcsi 150c0000.nvcsi: initialized
[ 3.398318] Wake76 for irq=199
[ 3.398320] Wake77 for irq=199
[ 3.398320] Wake78 for irq=199
[ 3.398321] Wake79 for irq=199
[ 3.398322] Wake80 for irq=199
[ 3.398322] Wake81 for irq=199
[ 3.398323] Wake82 for irq=199
[ 3.398660] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 3.399110] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.399953] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.400824] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.401474] Wake76 for irq=199
[ 3.401475] Wake77 for irq=199
[ 3.401476] Wake78 for irq=199
[ 3.401476] Wake79 for irq=199
[ 3.401477] Wake80 for irq=199
[ 3.401478] Wake81 for irq=199
[ 3.401479] Wake82 for irq=199
[ 3.401533] tegra-xotg xotg: usb2 phy is not available yet
[ 3.401754] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.402126] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.402386] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.402391] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.402434] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 3.402437] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.403162] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.407262] Wake76 for irq=199
[ 3.407263] Wake77 for irq=199
[ 3.407264] Wake78 for irq=199
[ 3.407265] Wake79 for irq=199
[ 3.407266] Wake80 for irq=199
[ 3.407266] Wake81 for irq=199
[ 3.407267] Wake82 for irq=199
[ 3.407525] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 3.408653] input: gpio-keys as /devices/gpio-keys/input/input0
[ 3.409105] Wake76 for irq=199
[ 3.409106] Wake77 for irq=199
[ 3.409107] Wake78 for irq=199
[ 3.409107] Wake79 for irq=199
[ 3.409108] Wake80 for irq=199
[ 3.409109] Wake81 for irq=199
[ 3.409109] Wake82 for irq=199
[ 3.409157] tegra-xotg xotg: usb2 phy is not available yet
[ 3.409314] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.409629] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.409845] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.409850] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.409892] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 3.409895] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.410599] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.414276] Wake76 for irq=199
[ 3.414277] Wake77 for irq=199
[ 3.414278] Wake78 for irq=199
[ 3.414278] Wake79 for irq=199
[ 3.414279] Wake80 for irq=199
[ 3.414280] Wake81 for irq=199
[ 3.414280] Wake82 for irq=199
[ 3.414533] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 3.447704] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:15 UTC (946688415)
[ 3.481648] bpmp: mounted debugfs mirror
[ 3.482233] [dram-timers] DRAM derating cdev registered.
[ 3.486738] spmic-ldo0: disabling
[ 3.486916] spmic-ldo1: disabling
[ 3.487058] vddio-sdmmc1: disabling
[ 3.487194] avdd-ts-hv: disabling
[ 3.487363] en-vdd-sd: disabling
[ 3.487365] vdd-usb0-5v: disabling
[ 3.487367] vdd-usb1-5v: disabling
[ 3.487369] vdd-3v3: disabling
[ 3.487371] en-vdd-vcm-2v8: disabling
[ 3.487373] vdd-sys-bl: disabling
[ 3.493528] ALSA device list:
[ 3.493530] No soundcards found.
[ 3.494357] tegra-vi4 15700000.vi: initialized
[ 3.496061] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 3.496064] tegra-vi4 15700000.vi: all channel register failed
[ 3.496373] Wake76 for irq=199
[ 3.496374] Wake77 for irq=199
[ 3.496375] Wake78 for irq=199
[ 3.496375] Wake79 for irq=199
[ 3.496376] Wake80 for irq=199
[ 3.496376] Wake81 for irq=199
[ 3.496377] Wake82 for irq=199
[ 3.496476] tegra-xotg xotg: usb2 phy is not available yet
[ 3.496742] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.497119] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.497401] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.497406] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.497448] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 3.497451] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.498152] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.502458] Wake76 for irq=199
[ 3.502460] Wake77 for irq=199
[ 3.502460] Wake78 for irq=199
[ 3.502462] Wake79 for irq=199
[ 3.502462] Wake80 for irq=199
[ 3.502463] Wake81 for irq=199
[ 3.502464] Wake82 for irq=199
[ 3.502742] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.488776] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 4.495766] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 305
[ 4.502766] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.550109] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.559738] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 4.559762] Wake76 for irq=199
[ 4.559763] Wake77 for irq=199
[ 4.559763] Wake78 for irq=199
[ 4.559764] Wake79 for irq=199
[ 4.559765] Wake80 for irq=199
[ 4.559765] Wake81 for irq=199
[ 4.559766] Wake82 for irq=199
[ 4.559837] tegra-xotg xotg: usb2 phy is not available yet
[ 4.560071] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.560446] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.560692] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.560697] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.560740] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 4.560744] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.576055] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.602838] Wake76 for irq=199
[ 4.602839] Wake77 for irq=199
[ 4.602840] Wake78 for irq=199
[ 4.602841] Wake79 for irq=199
[ 4.602842] Wake80 for irq=199
[ 4.602843] Wake81 for irq=199
[ 4.602843] Wake82 for irq=199
[ 4.603099] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.672267] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 4.714015] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.723669] Wake76 for irq=199
[ 4.723686] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 4.723987] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 4.724237] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.748100] Wake77 for irq=199
[ 4.751149] Wake78 for irq=199
[ 4.754199] Wake79 for irq=199
[ 4.757249] Wake80 for irq=199
[ 4.760298] Wake81 for irq=199
[ 4.763346] Wake82 for irq=199
[ 4.766441] mmc2: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.775834] tegra-xotg xotg: usb2 phy is not available yet
[ 4.779251] Waiting for root device /dev/mmcblk0p1…
[ 4.786663] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.792855] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.799698] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.809187] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.818356] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 4.825233] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.832742] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.843698] Wake76 for irq=199
[ 4.846762] Wake77 for irq=199
[ 4.849817] Wake78 for irq=199
[ 4.852871] Wake79 for irq=199
[ 4.855923] Wake80 for irq=199
[ 4.858976] Wake81 for irq=199
[ 4.862029] Wake82 for irq=199
[ 4.865633] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.872137] Wake76 for irq=199
[ 4.875195] Wake77 for irq=199
[ 4.878250] Wake78 for irq=199
[ 4.881304] Wake79 for irq=199
[ 4.884358] Wake80 for irq=199
[ 4.887412] Wake81 for irq=199
[ 4.890466] Wake82 for irq=199
[ 4.893596] tegra-xotg xotg: usb2 phy is not available yet
[ 4.932006] mmc2: MAN_BKOPS_EN bit is not set
[ 4.944206] mmc2: Skipping tuning since strobe enabled
[ 4.956893] mmc2: periodic cache flush enabled
[ 4.961346] mmc2: new HS400 MMC card at address 0001
[ 4.966645] mmcblk0: mmc2:0001 032G34 29.1 GiB
[ 4.971413] mmcblk0boot0: mmc2:0001 032G34 partition 1 4.00 MiB
[ 4.977543] mmcblk0boot1: mmc2:0001 032G34 partition 2 4.00 MiB
[ 4.983651] mmcblk0rpmb: mmc2:0001 032G34 partition 3 4.00 MiB
[ 4.991729] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 5.005717] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.012006] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.018857] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.028366] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.037588] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 5.044478] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.051772] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.062808] Wake76 for irq=199
[ 5.065877] Wake77 for irq=199
[ 5.068933] Wake78 for irq=199
[ 5.071988] Wake79 for irq=199
[ 5.075043] Wake80 for irq=199
[ 5.078096] Wake81 for irq=199
[ 5.081149] Wake82 for irq=199
[ 5.084597] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 5.091123] Wake76 for irq=199
[ 5.094185] Wake77 for irq=199
[ 5.097239] Wake78 for irq=199
[ 5.100292] Wake79 for irq=199
[ 5.103346] Wake80 for irq=199
[ 5.106398] Wake81 for irq=199
[ 5.109453] Wake82 for irq=199
[ 5.112753] tegra-xotg xotg: usb2 phy is not available yet
[ 5.315885] EXT4-fs (mmcblk0p1): 15 orphan inodes deleted
[ 5.321342] EXT4-fs (mmcblk0p1): recovery complete
[ 5.334106] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.342253] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.350654] devtmpfs: mounted
[ 5.353989] Freeing unused kernel memory: 1148K (ffffffc00113f000 - ffffffc00125e000)
[ 5.361847] Freeing alternatives memory: 96K (ffffffc00125e000 - ffffffc001276000)
[ 5.376907] btb inv war enabled
[ 5.418120] systemd[1]: System time before build time, advancing clock.
[ 5.445238] random: systemd: uninitialized urandom read (16 bytes read, 89 bits of entropy available)
[ 5.456441] random: systemd: uninitialized urandom read (16 bytes read, 89 bits of entropy available)
[ 5.465721] random: systemd: uninitialized urandom read (16 bytes read, 89 bits of entropy available)
[ 5.476028] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.494414] systemd[1]: Detected architecture arm64.
[ 5.505413] systemd[1]: Set hostname to .
[ 5.522835] random: systemd: uninitialized urandom read (16 bytes read, 91 bits of entropy available)
[ 5.528061] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 91 bits of entropy available)
[ 5.530055] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 92 bits of entropy available)
[ 5.532963] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 92 bits of entropy available)
[ 5.563323] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[ 5.577189] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 95 bits of entropy available)
[ 5.587223] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 96 bits of entropy available)
[ 5.682632] systemd[1]: Listening on udev Control Socket.
[ 5.688401] systemd[1]: Listening on Journal Socket.
[ 5.693542] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 5.699872] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.708210] systemd[1]: Created slice User and Session Slice.
[ 5.714110] systemd[1]: Listening on Syslog Socket.
[ 5.719088] systemd[1]: Reached target User and Group Name Lookups.
[ 5.725486] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.732556] systemd[1]: Listening on LVM2 poll daemon socket.
[ 5.738375] systemd[1]: Reached target Remote File Systems (Pre).
[ 5.744569] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.751119] systemd[1]: Listening on Journal Audit Socket.
[ 5.756844] systemd[1]: Reached target Encrypted Volumes.
[ 5.762522] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 5.769229] systemd[1]: Reached target Swap.
[ 5.774747] systemd[1]: Created slice System Slice.
[ 5.781952] systemd[1]: Mounting Debug File System…
[ 5.789343] systemd[1]: Started Braille Device Support.
[ 5.797415] systemd[1]: Mounting POSIX Message Queue File System…
[ 5.804000] systemd[1]: Reached target Slices.
[ 5.811133] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 5.823956] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 5.834678] systemd[1]: Created slice system-getty.slice.
[ 5.841571] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.850047] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 5.856420] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 5.864908] systemd[1]: Starting Journal Service…
[ 5.896280] systemd[1]: Starting Load Kernel Modules…
[ 5.901796] systemd[1]: Reached target Remote File Systems.
[ 5.907715] systemd[1]: Listening on udev Kernel Socket.
[ 5.909957] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.910550] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.910865] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.910870] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.910908] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 5.910911] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.911633] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.916276] Wake76 for irq=199
[ 5.916277] Wake77 for irq=199
[ 5.916278] Wake78 for irq=199
[ 5.916279] Wake79 for irq=199
[ 5.916279] Wake80 for irq=199
[ 5.916280] Wake81 for irq=199
[ 5.916280] Wake82 for irq=199
[ 5.916568] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 5.916961] Wake76 for irq=199
[ 5.916962] Wake77 for irq=199
[ 5.916962] Wake78 for irq=199
[ 5.916963] Wake79 for irq=199
[ 5.916964] Wake80 for irq=199
[ 5.916964] Wake81 for irq=199
[ 5.916965] Wake82 for irq=199
[ 5.917023] tegra-xotg xotg: usb2 phy is not available yet
[ 6.023134] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.029431] systemd[1]: Mounted Debug File System.
[ 6.034733] systemd[1]: Started Journal Service.
[ 6.204744] systemd-journald[290]: Received request to flush runtime journal from PID 1
[ 6.302007] random: nonblocking pool is initialized
[ 6.387032] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 6.397780] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.404769] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 6.404877] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 6.405274] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 6.405279] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 6.405316] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 6.405320] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 6.406070] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 6.411357] Wake76 for irq=199
[ 6.411359] Wake77 for irq=199
[ 6.411360] Wake78 for irq=199
[ 6.411360] Wake79 for irq=199
[ 6.411361] Wake80 for irq=199
[ 6.411362] Wake81 for irq=199
[ 6.411362] Wake82 for irq=199
[ 6.411726] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 6.414028] Wake76 for irq=199
[ 6.414029] Wake77 for irq=199
[ 6.414030] Wake78 for irq=199
[ 6.414031] Wake79 for irq=199
[ 6.414031] Wake80 for irq=199
[ 6.414032] Wake81 for irq=199
[ 6.414033] Wake82 for irq=199
[ 6.414261] tegra-xotg xotg: usb2 phy is not available yet
[ 6.511764] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 6.521188] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 6.953980] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 7.369347] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 7.725552] cfg80211: World regulatory domain updated:
[ 7.730746] cfg80211: DFS Master region: unset
[ 7.735548] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.750179] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.758226] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.766339] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.774500] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.784142] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.793684] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.801822] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.809887] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.832018] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 7.840635] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 7.847597] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 7.854934] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[ 7.861831] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[ 7.869178] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 7.874689] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 7.880929] pci 0000:00:01.0: [10de:10e5] type 01 class 0x060400
[ 7.887052] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 7.894035] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 7.902238] pci 0000:01:00.0: [111d:808f] type 01 class 0x060400
[ 7.908454] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 7.914744] pci 0000:01:00.1: [111d:808f] type 00 class 0x068000
[ 7.920849] pci 0000:01:00.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 7.927695] pci 0000:01:00.1: reg 0x18: [mem 0x00000000-0x01ffffff 64bit pref]
[ 7.934964] pci 0000:01:00.1: reg 0x20: [mem 0x00000000-0x01ffffff 64bit]
[ 7.935389] pci 0000:01:00.2: [111d:808f] type 00 class 0x088000
[ 7.935453] pci 0000:01:00.2: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 7.935775] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 7.935936] pci 0000:02:08.0: [111d:808f] type 01 class 0x060400
[ 7.936134] pci 0000:02:08.0: PME# supported from D0 D3hot D3cold
[ 7.936284] pci 0000:02:08.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 7.950747] pci 0000:03:00.0: [1b21:0612] type 00 class 0x010601
[ 7.989482] pci 0000:03:00.0: Max Payload Size set to 128 (was 16384, max 512)
[ 7.994630] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[ 7.994641] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 03
[ 7.994651] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 03
[ 7.994741] pci 0000:00:01.0: BAR 9: assigned [mem 0x58000000-0x59ffffff 64bit pref]
[ 7.994743] pci 0000:00:01.0: BAR 8: assigned [mem 0x51000000-0x53ffffff]
[ 7.994748] pci 0000:01:00.1: BAR 2: assigned [mem 0x58000000-0x59ffffff 64bit pref]
[ 7.994770] pci 0000:01:00.1: BAR 4: assigned [mem 0x52000000-0x53ffffff 64bit]
[ 7.994792] pci 0000:01:00.1: BAR 0: assigned [mem 0x51000000-0x51000fff 64bit]
[ 7.994814] pci 0000:01:00.2: BAR 0: assigned [mem 0x51001000-0x51001fff 64bit]
[ 7.994833] pci 0000:02:08.0: PCI bridge to [bus 03]
[ 7.994862] pci 0000:01:00.0: PCI bridge to [bus 02-03]
[ 7.994890] pci 0000:00:01.0: PCI bridge to [bus 01-03]
[ 7.994896] pci 0000:00:01.0: bridge window [mem 0x51000000-0x53ffffff]
[ 7.994900] pci 0000:00:01.0: bridge window [mem 0x58000000-0x59ffffff 64bit pref]
[ 7.994966] pcieport 0000:00:01.0: enabling device (0000 → 0002)
[ 7.995050] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 7.995052] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 7.995053] pci 0000:02:08.0: Signaling PME through PCIe PME interrupt
[ 7.995054] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 7.995056] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[ 7.995057] pci 0000:01:00.2: Signaling PME through PCIe PME interrupt
[ 7.995062] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[ 7.995147] aer 0000:00:01.0:pcie02: service driver aer loaded
[ 7.995334] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.995796] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 → Gen-2
[ 7.995977] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 7.996299] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 7.996305] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 7.996344] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b496
[ 7.996348] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 7.996955] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 → Gen-2
[ 8.020992] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 8.039329] Wake76 for irq=199
[ 8.039331] Wake77 for irq=199
[ 8.039332] Wake78 for irq=199
[ 8.039332] Wake79 for irq=199
[ 8.039333] Wake80 for irq=199
[ 8.039334] Wake81 for irq=199
[ 8.039334] Wake82 for irq=199
[ 8.039621] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 8.040080] Wake76 for irq=199
[ 8.040081] Wake77 for irq=199
[ 8.040082] Wake78 for irq=199
[ 8.040082] Wake79 for irq=199
[ 8.040083] Wake80 for irq=199
[ 8.040084] Wake81 for irq=199
[ 8.040084] Wake82 for irq=199
[ 8.040147] tegra-xotg xotg: usb2 phy is not available yet
[ 8.040337] tegra-usb-cd usb_cd: otg phy is not available yet
[ 8.040726] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 8.100246] ahci 0000:03:00.0: version 3.0
[ 8.100317] ahci: probe of 0000:03:00.0 failed with error -22
[ 8.342412] IPVS: Creating netns size=1424 id=1
[ 8.420690] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.429163] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.935654] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
[ 8.943698] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 8.955462] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 8.955465] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 8.955473] pcieport 0000:00:01.0: broadcast error_detected message
[ 8.955483] pcieport 0000:00:01.0: AER: Device recovery failed
[ 8.962647] gk20a 17000000.gp10b: railgate is disabled.
[ 9.943594] Bridge firewalling registered
[ 10.051638] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.555054] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 11.325364] fuse init (API version 7.23)
[ 11.662023] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.670958] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.045397] IPVS: Creating netns size=1424 id=2
[ 15.416174] IPVS: Creating netns size=1424 id=3
